  2. Gurux.DLMS.AMI4
  3. Configuration
  4. Block
By Administrator , 23 May, 2023
The administrator can configure the user interface with Blocks.
The content of the block can be HTML or component
  • Active
    Is the block active. Only active blocks are shown on the user interface.
  • Closable
    If the block is closable, the user can close the block. This can be used with notifications for the user and user can close the message after read.
  • Name
    Block name.
  • Location
    The location will tell where the block is located.
  • Block type
    Is the content of the block HTML or Component.
  • Language
    The content of the HTML block can be localized for the installed languages.
  • Title
    Block title.
  • Publish
    Publish time. If publish time is not set, it's shown at once.
  • Publish
    End time. If the end time is not set, it's shown until the user closes it.
HTML settings
  • Body
    Html body. This can be text or any HTML content.
  • CSS class
    Used CSS class
  • CSS role
    Used CSS role.
  • HTML style
    HTML style settings.
Component settings
  • Component
    Component to shown.
  • Parameters
    Parameters depend on the used component.
Book navigation
  • Agent
  • Configuration
    • Authentications
    • Block
    • Component
    • Cron
    • Installable agents
    • Key Management
    • Language
    • Maintenance
    • Manufacturer
    • Module
    • Performance
    • Roles
    • Script
    • Security
    • Statistic
    • Status
    • System
    • Trigger
    • Workflow
  • Device
  • Device template
  • Extensions
  • Favorites
  • Gateway
  • REST statistic
  • Report
  • Schedule
  • Subtotal
  • System log
  • Tasks
  • User
