  3. Query Regarding Class 63 Status Mapping Support In Gurux DLMS Python
Query Regarding Class 63 Status Mapping Support in Gurux DLMS Python
By Prince-2028 , 20 October, 2026
Dear Gurux Support Team,
I am working on a DLMS/COSEM Smart Meter Management System using the Gurux DLMS Python library.
I would like to clarify whether **Class ID 63 (Status Mapping)** is supported in the Gurux DLMS Python library.
Currently, I am using the Gurux DLMS Python package, and I have made some custom changes to the status mapping functionality in my local environment. However, I would prefer to use an officially supported implementation if one is available.
Could you please clarify the following?
1. Does Gurux DLMS Python support Class ID 63 (Status Mapping)?
2. If yes, which library version introduced or supports this functionality?
3. If it is not supported in the current Python package, are there any plans to add support for it?
4. Is there an official implementation or recommended approach for adding this class while maintaining compatibility with future releases?
I am also using GitHub Actions for CI/CD to build a Windows executable with PyInstaller. Therefore, I would appreciate guidance on the recommended package version or source code that should be used to ensure consistent behavior in the final executable.
Thank you for your time and support. I look forward to your response.
Best regards,
Prince Kumar
