  3. Connection With Actaris SL7000
Connection with Actaris SL7000
By subshock , 25 December, 2017
Hello!
Can you help me please, I just cant connect to meter Actaris SL7000 (SL761) with GXDLMSDirector. I know nothing about my meter parameters, connection RS-485 -> USB converter.
subshock
8 years 7 months ago
kurumi
How can I find out the meter addresses?
8 years 6 months ago
Actaris SL7000
Can you make the connection with GXDLMSDirector? You can find right settings from here:
subshock
8 years 5 months ago
SL-7000
I need the standart settings of this meters (physical adress, password, baud rate). Can you help me?
Thank you!
subshock
In reply to Actaris SL7000 by Kurumi
SL-7000
I can't connect to SL7000 (type SL761) with this settings.
I used RS485 -> PC connection with USB serial converter.
Can you help me? There is message "Failed to receive reply from the device in given time".
Where i can find physical adress of this meter? Is it last 3 symbols in serial number?
SL-7000
Did you check the link what I posted before?
Baud rate can be changed, but you can try with 4800 and 9600.
subshock
In reply to SL-7000 by Kurumi
SL-7000
Yes, I used these parameters, given in the link (without authentication, with low authentication, with rate 4800 and 9600). There is no answer from my meter:
GXDLMSDirector 8.1.1801.2301
Log created 08:49:54
08:49:55 Initializing serial connection.
08:49:55 Send SNRM request.
7E A0 07 23 21 93 34 02 7E
08:50:10 Failed to receive reply from the device in given time.
SL-7000
You have not selected Actaric as the manufacturer.
TTT
8 years 1 month ago
connect sl 7000 (sl761) to raspberry pi 3 (linux) to read index
my tutorial project of this years is " read to the raspberry pi 3 the index of the smart meters actaris SL 7000 type SL761.
i don't know to install GXDLMSDirector to raspberry pi 3. please can you help me ?
TTT
8 years 1 month ago
sl7000 type sl761
Can you help me please, I just cant connect to meter Actaris SL7000 (SL761) with GXDLMSDirector. I know nothing about my meter parameters, connection Rj 45 -> raspberry pi 3
8 years 1 month ago
Connect sl 7000 (sl761) to raspberry pi 3 (linux) to read index
You can read your meter with GXDLMSDirector. Install that to your PC. After you can read it, you can make own app for Raspberry PI.
TTT
8 years 1 month ago
thanks M.Mikko
You have to comment on this application for raspberry after
TTT
8 years 1 month ago
i don't know to do the application for raspberry after.
and, i want to aks ,if GXDLMSDirector take to windows 10 ?
TTT
8 years 1 month ago
Hello Mikko,
please can you help me the datasheet or notice or technical documents of SL 7000 type SL761 ? i want to learn the structure of the trame, speed execution, and metrologie .
8 years 1 month ago
SL 7000
You need to ask SL 7000 documentation from the meter vendor. You can use GXDLMSDirector in Windows 10. We haven't use GXDLMSDirector in Linux for a while.
TTT
8 years 1 month ago
Thanks, M.Mikko
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
