  3. Topic: Insufficient Memory Error When Reading Class 7 Profile Generic Objects
By Prince-2028 , 11 September, 2026
I am working with a DLMS meter that has 16 Class 7 (Profile Generic) OBIS objects.
I am able to read 12 out of the 16 Profile Generic objects successfully. However, when I try to read the remaining Profile Generic objects, I get the following error:
"Insufficient memory to continue the execution of the program."
The same meter and the same Profile Generic objects work correctly in the TALTECH/Renesas GUI, where I can read the data without any error.
I also checked Attribute 7 (Entries In Use) and Attribute 8 (Profile Entries) for the affected Profile Generic objects. Both values are:
Attribute 7 (Entries In Use): 1
Attribute 8 (Profile Entries): 1
Since there is only one entry in the profile, I am not sure why GXDLMSDirector/client is reporting an insufficient memory error.
Could you please help me understand:
Why does the "Insufficient memory" error occur when reading these Class 7 objects?
Is there any limitation when reading multiple Profile Generic objects?
Why does the same data work correctly in the KALKITECH/Renesas GUI?
Is there any specific setting or read method I should use for these Profile Generic objects?
I can provide the OBIS codes, class IDs, attribute values, communication logs, and error details if needed.
Thank you.
1 month 4 weeks ago
Hi, This means that the…
This means that the meter indicates a PDU size of X bytes, but the actual PDU contains fewer bytes than specified.
This is a meter issue, and you need to ask if there is a firmware update available.
The "insufficient memory" error has been changed to a new exception type to make it easier to identify and troubleshoot the issue when developing a new meter.
We will release the next version at the end of this month.
