  3. Connection With Actaris SL7000
Connection with Actaris SL7000
By subshock , 25 December, 2017
Hello!
Can you help me please, I just cant connect to meter Actaris SL7000 (SL761) with GXDLMSDirector. I know nothing about my meter parameters, connection RS-485 -> USB converter.
subshock
8 years 8 months ago
kurumi
How can I find out the meter addresses?
Actaris SL7000
Can you make the connection with GXDLMSDirector? You can find right settings from here:
subshock
8 years 7 months ago
SL-7000
I need the standart settings of this meters (physical adress, password, baud rate). Can you help me?
Thank you!
subshock
In reply to Actaris SL7000 by Kurumi
SL-7000
I can't connect to SL7000 (type SL761) with this settings.
I used RS485 -> PC connection with USB serial converter.
Can you help me? There is message "Failed to receive reply from the device in given time".
Where i can find physical adress of this meter? Is it last 3 symbols in serial number?
SL-7000
Did you check the link what I posted before?
Baud rate can be changed, but you can try with 4800 and 9600.
subshock
In reply to SL-7000 by Kurumi
SL-7000
Yes, I used these parameters, given in the link (without authentication, with low authentication, with rate 4800 and 9600). There is no answer from my meter:
GXDLMSDirector 8.1.1801.2301
Log created 08:49:54
08:49:55 Initializing serial connection.
08:49:55 Send SNRM request.
7E A0 07 23 21 93 34 02 7E
08:50:10 Failed to receive reply from the device in given time.
SL-7000
You have not selected Actaric as the manufacturer.
TTT
8 years 3 months ago
connect sl 7000 (sl761) to raspberry pi 3 (linux) to read index
my tutorial project of this years is " read to the raspberry pi 3 the index of the smart meters actaris SL 7000 type SL761.
i don't know to install GXDLMSDirector to raspberry pi 3. please can you help me ?
TTT
sl7000 type sl761
Can you help me please, I just cant connect to meter Actaris SL7000 (SL761) with GXDLMSDirector. I know nothing about my meter parameters, connection Rj 45 -> raspberry pi 3
Connect sl 7000 (sl761) to raspberry pi 3 (linux) to read index
You can read your meter with GXDLMSDirector. Install that to your PC. After you can read it, you can make own app for Raspberry PI.
TTT
thanks M.Mikko
You have to comment on this application for raspberry after
TTT
i don't know to do the application for raspberry after.
and, i want to aks ,if GXDLMSDirector take to windows 10 ?
TTT
Hello Mikko,
please can you help me the datasheet or notice or technical documents of SL 7000 type SL761 ? i want to learn the structure of the trame, speed execution, and metrologie .
SL 7000
You need to ask SL 7000 documentation from the meter vendor. You can use GXDLMSDirector in Windows 10. We haven't use GXDLMSDirector in Linux for a while.
TTT
Thanks, M.Mikko
