  2. Register Activation
gxdn
By Gurux Documentation , 10 November, 2026
Register activation
Register activation selects which registers in an assigned group are active. Named masks allow different subsets to be selected without rebuilding the group.
When to use it
Use it to select the set of tariff registers that should accumulate consumption.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Register assignment
Lists the register objects managed by this activation object.
3. Mask list
Defines named masks, each containing the indexes of registers that belong to that selection.
4. Active mask
Identifies the mask currently used to select active registers.
Actions
1. Add register
Adds new register to assignment list.
2. Add mask
Adds new register to the mask list.
3. Delete mask
Deletes register from the mask list.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
  • Kaliurang Telp/Wa 082371291690
  • Money Changer Indorate Prima Javalas Itc Kuningan Telp/Wa 081930338564
  • Money Changer Valuta Artha Mas Telp/Wa 081930338564
  • Layanan KCU THAMRIN No Cs.0817 819 444
  • Arthamas Citra Mandiri Money Changer Telp/Wa 081930338564
