  2. Tariff Plan
gxdn
By Gurux Documentation , 10 November, 2026
Tariff plan
A tariff plan holds a tariff-switching program with its activation settings. The plan describes the periods and day rules used by the supported device tariff scheme.
When to use it
Use it to inspect or prepare a tariff program on a device that provides this tariff-plan object.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Calendar name
Names the tariff calendar or program.
3. Enabled
Shows whether the tariff plan is enabled.
4. Plan
Contains the default tariff band, winter and summer season settings, weekly activation rules and special days. Each season provides separate intervals for working days, Saturdays and holidays.
5. Activation time
Sets the date and time at which the tariff plan is activated.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
  • Bank Mandiri Pangkalan Banteng call/wa 0813-627-9539.
  • PT. Sri Kencana Valutindo ☎️/Wa 083150344509
  • Bank Mandiri Kuala Pembuang call/wa 0813-627-9539.
  • Bank Mandiri Kasongan call/wa 0813-627-9539.
  • Bank Mandiri Sebabi call/wa 0813-627-9539.
