STS payment token settings
This object exposes the identity and key management settings of a meter that accepts STS payment tokens. It helps a payment system select tokens compatible with that meter.
When to use it
Use it when commissioning a token payment meter or checking its supply group and key revision before issuing tokens.
Attributes
1. Logical name
The OBIS code that identifies this object instance in the meter. Use it to distinguish this instance from other objects of the same class.
2. Meter PAN
Identifies the meter's primary account number using the issuer identifier, decoder reference and check digit. It is set during manufacture.
3. Commodity
Identifies what the meter supplies, such as electricity, water, gas or time. Together with the account currency it determines token units.
4. Token carrier types
Lists the supported ways in which tokens can be carried or presented to the meter.
5. Encryption algorithm
Identifies the algorithm used to protect payment token information.
6. Supply group code
Identifies the meter's supply group for token key management. Key change tokens can update it.
7. Tariff index
Identifies the tariff selection used in token key management. It is updated through key change tokens.
8. Key revision number
Identifies the revision of the token decoding key. It is updated through key change tokens.
9. Key type
Identifies the type of token decoding key currently used by the meter.
10. Key expiry number
Identifies the expiry setting associated with the token decoding key. It is updated through key change tokens.
11. Supported key change tokens
Shows how many tokens the meter supports in a key change sequence.
12. STS certificate
Holds the meter's STS conformance certificate number. It can change when firmware is upgraded.
