Schedule
A schedule contains individual entries that run scripts at specified times under weekday, date-range and special-day conditions. Each entry can be enabled independently.
When to use it
Use it to run a control script on selected weekdays during a defined part of the year.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Entries
Contains the schedule entries, including their identifiers, enable flags, script references, switching times, validity windows and day or date conditions.
