M-Bus port setup
Configures an M-Bus port through which a device provides its DLMS server. It includes addressing, packet size and listening periods.
When to use it
For example, configure a battery powered wireless meter to listen during scheduled communication windows.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. Profile selection
Selects the wired or wireless M-Bus communication profile used by the port.
3. Port communication status
Reports whether the port is available for communication and its current communication state.
4. Data header type
Selects the format of the M-Bus header carried before the application data.
5. Primary address
Sets the short M-Bus address used to address the device.
6. Identification number
Contains the device identification number used in its M-Bus identity.
7. Manufacturer Id
Contains the manufacturer code in the M-Bus identity.
8. MBus version
Contains the device revision used in the M-Bus identity.
9. Device type
Identifies the device category or measured medium in the M-Bus identity.
10. Max PDU size
Sets the largest protocol data unit that the port can handle.
11. Listening window
Lists the time periods during which the port listens for incoming communication.
