LLC SSCS setup
Shows the addresses assigned when a service node registers with a base node on a power line network.
When to use it
For example, read both addresses to confirm that a newly installed meter has registered with the intended base node.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. ServiceNodeAddress
Contains the service node address assigned during registration. After deregistration it returns to the unassigned NEW address.
3. BaseNodeAddress
Contains the address of the base node with which this node is registered. A zero value indicates that it is not registered.
