  2. G3-PLC MAC Setup
gxdn
By Gurux Documentation , 10 November, 2026
G3-PLC MAC setup
Configures addressing, security and access to the shared power line channel for a G3 modem. Neighbour information helps the modem choose suitable transmission settings.
When to use it
For example, check the network identifier and neighbour table while commissioning a meter on a G3 network.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. MacShortAddress
Contains the short address used by this device on the local network.
3. MacRcCoord
Shows the route cost to the coordinator for use in beacon announcements.
4. MacPANId
Identifies the personal area network to which the device belongs.
5. MacKeyTable
Stores indexed encryption keys used to protect link layer frames.
6. MacFrameCounter
Tracks the security frame number used to distinguish new protected frames from replayed frames.
7. MacToneMask
Selects which carrier frequencies the modem may use for communication.
8. MacTmrTtl
Sets how long learned tone map settings remain usable before they need refreshing, in minutes.
9. MacMaxFrameRetries
Limits how often a frame is sent again after an unsuccessful transmission.
10. MacNeighbourTableEntryTtl (versions 0-2)
Sets how long a neighbour table entry remains valid, in minutes.
10. MacPosTableEntryTtl (version 3)
Sets how long direct-neighbour reachability entries in the POS table remain valid, in minutes.
11. MacNeighbourTable
Lists nearby devices and learned settings such as usable tones, modulation, gain and link quality.
12. MacHighPriorityWindowSize
Sets the number of channel access slots reserved for high priority traffic.
13. MacCscmFairnessLimit
Sets the number of failed backoffs used by the fairness mechanism before resetting its waiting range.
14. MacBeaconRandomizationWindowLength
Sets the time range over which beacon transmission is randomly delayed to reduce collisions.
15. MacA
Controls how quickly the adaptive contention window is reduced after channel access conditions improve.
16. MacK
Adjusts the rate at which the channel access fairness limit adapts.
17. MacMinCwAttempts
Sets the number of consecutive transmission attempts made with the minimum contention window.
18. MacCenelecLegacyMode
Reports whether the modem uses older or newer interleaving behaviour in the CENELEC frequency band.
19. MacFCCLegacyMode
Reports whether the modem uses older or newer modulation and interleaving behaviour in the FCC frequency band.
20. MacMaxBe
Sets the upper limit of the exponent that determines the random channel access waiting range.
21. MacMaxCsmaBackoffs
Limits the number of times channel access may be deferred before an attempt fails.
22. MacMinBe
Sets the lower limit of the exponent that determines the random channel access waiting range.
23. MacBroadcastMaxCwEnabled
Controls whether broadcast transmissions use the maximum contention window to reduce collisions.
24. MacTransmitAtten
Reduces the modem output level by the configured attenuation in decibels.
25. MacPosTable
Lists devices within direct communication range, with information used to track their reachability.
26. MacDuplicateDetectionTtl
Sets how long received frame identifiers are retained to recognise and reject duplicate frames.
Versions
The installed component exposes attributes 1-22 for versions 0 and 1, attributes 1-25 for version 2, and attributes 1-26 for version 3. Version 3 changes attribute 10 to the POS table entry lifetime.
The component uses the version 1 field meanings for version 0 as well. It does not implement the original version 0 layout with 11 attributes and its different addressing, security and timer definitions.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
  • Bank Mandiri Pangkalan Banteng call/wa 0813-627-9539.
  • PT. Sri Kencana Valutindo ☎️/Wa 083150344509
  • Bank Mandiri Kuala Pembuang call/wa 0813-627-9539.
  • Bank Mandiri Kasongan call/wa 0813-627-9539.
  • Bank Mandiri Sebabi call/wa 0813-627-9539.
