G3-PLC MAC layer counters
Records traffic and communication problems at the G3 power line link layer. Comparing readings over time helps reveal congestion or poor links.
When to use it
For example, compare missing acknowledgements and checksum errors before and after repairing a noisy connection.
Attributes
1. Logical name
Identifies this object instance by its six-part OBIS code. Use it to distinguish this object from other objects of the same class.
2. TxDataPacketCount
Counts data packets successfully sent.
3. RxDataPacketCount
Counts data packets successfully received.
4. TxCmdPacketCount
Counts link management command packets successfully sent.
5. RxCmdPacketCount
Counts link management command packets successfully received.
6. CSMAFailCount
Counts attempts abandoned after reaching the channel access backoff limit.
7. CSMANoAckCount
Counts unicast data transmissions for which the expected acknowledgement did not arrive.
8. BadCrcCount
Counts received frames that failed the CRC integrity check.
9. TxDataBroadcastCount
Counts broadcast data frames sent.
10. RxDataBroadcastCount
Counts broadcast data frames successfully received.
Versions
Attribute availability in the supplied component help depends on the object version (version 0: attributes 1-10; version 1: attributes 1-10). Use the version-specific descriptions above where provided.
