Function control
Function control groups device features into named functional blocks that can be enabled or disabled together. A block can refer to several objects.
When to use it
Use it to manage whether a named metering or communication function is active.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Activation status
Lists each functional block and whether it is enabled.
3. Function list
Defines the named blocks and the objects participating in each block.
