  2. Credit
gxdn
By Gurux Documentation , 10 November, 2026
Credit
A credit object represents one source of spendable credit, such as purchased credit, emergency credit or an allowance. Its settings control when that credit can be selected and used.
When to use it
Use it to inspect the remaining emergency credit and the conditions under which it becomes available.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Current credit amount
Shows the present credit balance.
3. Type
Identifies the kind of credit, such as token credit or emergency credit.
4. Priority
Sets the order in which this credit is considered relative to other credits.
5. Warning threshold
Sets the balance at which a low-credit warning is raised.
6. Limit
Defines the lower limit to which this credit may be consumed.
7. Credit configuration
Controls credit behavior, including whether confirmation or other selection conditions apply.
8. Status
Shows the current credit state, such as available, selected or exhausted.
9. Preset credit amount
Defines the amount used when this credit is preset or restored under its configured rules.
10. Credit available threshold
Sets the level used to determine whether this credit can become available.
11. Period
Defines when time-based or consumption-based credit is automatically reset to the preset amount. Wildcard date and time fields allow a repeating reset; an entirely unspecified time disables this reset.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
  • Bank Mandiri Pangkalan Banteng call/wa 0813-627-9539.
  • PT. Sri Kencana Valutindo ☎️/Wa 083150344509
  • Bank Mandiri Kuala Pembuang call/wa 0813-627-9539.
  • Bank Mandiri Kasongan call/wa 0813-627-9539.
  • Bank Mandiri Sebabi call/wa 0813-627-9539.
