CoAP setup
This object configures the CoAP layer used to carry meter communication over UDP. It controls acknowledgements, retries, message concurrency and wrapper details.
When to use it
Use it when configuring a CoAP endpoint or adjusting retry timing for a network with long delays.
Attributes
1. Logical name
The OBIS code that identifies this object instance in the meter. Use it to distinguish this instance from other objects of the same class.
2. UDP reference
Identifies the TCP-UDP setup object providing the underlying UDP endpoint and port.
3. Acknowledgement timeout
Sets the minimum initial wait for acknowledgement of a confirmable message, in milliseconds.
4. Acknowledgement random factor
Sets the random variation applied to the initial acknowledgement timeout. The stored factor is expressed in hundredths.
5. Maximum retransmissions
Limits how many times a confirmable message can be sent again without acknowledgement.
6. NStart
Limits the number of requests that may remain outstanding at the same time.
7. Delayed acknowledgement timeout
Sets how long, in milliseconds, to wait for an application response before sending a separate acknowledgement.
8. Exponential backoff
Sets the factor that increases the delay between successive retransmissions. The stored factor is expressed in hundredths.
9. Probing rate
Limits the average number of bytes per second sent to an endpoint that does not respond.
10. CoAP URI path
Sets the resource path used by the meter communication wrapper.
11. Transport mode
Selects support for reliable operation, unreliable operation or both.
12. Wrapper version
Identifies the version of the CoAP wrapper used for meter messages.
13. Token length
Sets the number of bytes used for CoAP client tokens that match responses to requests.
