Arbitrator
An arbitrator resolves competing requests for a set of actions. Permissions and priorities determine which requested action is selected.
When to use it
Use it when several internal controls can request changes to the same supply switch.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Actions
Lists the script actions that can be selected.
3. Permissions table
Defines which actions each requesting actor is permitted to request.
4. Weightings table
Assigns weights to actors and actions so competing requests can be compared.
5. Most recent requests table
Shows the latest action requests received from the actors.
6. Last outcome
Identifies the action selected by the latest arbitration result.
