Account
An account brings together the credit balances, charges and payment settings used to manage a supply contract. It provides an overall view of the money available and the debts linked to that account.
When to use it
Use it to inspect a prepaid electricity account and see how its credits, top-ups and standing charges are coordinated.
Attributes
1. Logical name
Identifies this object instance using its six-part OBIS code. Use it to distinguish this object from other instances of the same class.
2. Payment mode
Contains both the payment mode and the account status, such as active or closed.
3. Current credit in use
Gives the index in Credit references of the credit currently being used.
4. Current credit status
Reports flags describing the current credit situation, including conditions that affect whether supply can continue.
5. Available credit
Shows the combined credit currently available to the account.
6. Amount to clear
Shows the credit needed to clear negative balances and restore repayable credit, including the clearance threshold. This amount is represented as a negative value.
7. Clearance threshold
Sets the available credit level needed after clearing negative balances before repayable credits become enabled again.
8. Aggregated debt
Shows the sum still to collect from this account's fixed-total charges. Continuous charges are excluded.
9. Credit references
Lists the logical names of the Credit objects belonging to this account.
10. Charge references
Lists the logical names of the Charge objects belonging to this account.
11. Credit charge configurations
Links credits to charges and specifies the conditions under which charges may be collected from each credit.
12. Token gateway configurations
Defines how incoming token credit is allocated among the referenced credits.
13. Account activation time
Records or schedules when the account becomes active.
14. Account closure time
Records or schedules when the account closes.
15. Currency
Defines the currency name, monetary scale and currency unit used for account amounts.
16. Low credit threshold
Shows the warning level associated with the credit currently in use.
17. Next credit available threshold
Shows the availability threshold for the next credit that may become usable.
18. Max provision
Limits the total amount that payment-event charges can collect from top-ups during the provision period.
19. Max provision period
Defines the period, in seconds, over which the maximum provision limit applies.
