  2. Manufacturer Custom Objects
gxdn
By Administrator , 30 July, 2024
Getting started
Read basic information from Gurux.DLMS component before you start to create DLMS client.
Device manufacturer custom objects
DLMS standard defines COSEM objects that manufacturers should use. Sometimes manufacturers use their own custom objects to extend the meter functionality. This is not recommended, but support for custom objects has been added to some of Gurux DLMS libraries.
Impementing custom object
At first, implement a custom object and derive it from GXDLMSObject and IGXDLMSBase.
  • Java
  • C#
  • Delphi
  • ANSI C++
  • Python
public class ManufacturerSpecificObject
        extends GXDLMSObject
        implements IGXDLMSBase {
    *  Manufacturer specific attribute.
    public int Manufacturer;
     * Returns amount of attributes.
    @Override
    public final int getAttributeCount() {
        return 2;
     * Returns amount of methods.
    @Override
    public final int getMethodCount() {
        return 1;
     * Returns read attributes.
    @Override
    public int[] getAttributeIndexToRead(boolean all) {
        return new int[] { 1, 2 };
     * Returns attribute names.
    @Override
    public String[] getNames() {
        return new String[] { "Logical Name", "Manufacturer attribute" };
     * Returns method names.
    @Override
    public String[] getMethodNames() {
        return new String[] { "Reset", };
	 * Returns value of given attribute.
	@Override
	public final Object getValue(final GXDLMSSettings settings, final ValueEventArgs e) {
		if (e.getIndex() == 1) {
			return GXCommon.logicalNameToBytes(getLogicalName());
		if (e.getIndex() == 2) {
			return Manufacturer;
		e.setError(ErrorCode.READ_WRITE_DENIED);
		return null;
	 * Set value of given attribute.
	@Override
	public final void setValue(final GXDLMSSettings settings, final ValueEventArgs e) {
			setLogicalName(GXCommon.toLogicalName(e.getValue()));
		} else if (e.getIndex() == 2) {
			Manufacturer = ((Number) e.getValue()).intValue();
		} else {
    @Override
    public void load(GXXmlReader reader) throws XMLStreamException {
        // Load attribute values.
    @Override
    public void save(GXXmlWriter writer) throws XMLStreamException {
        // Save attribute values.
    @Override
    public void postLoad(GXXmlReader reader) {
        // Update attributes after load.
 /// This class implments manucaturer spesific COSEM object.
 public class ManufacturerSpecificObject :
        GXDLMSObject,
        IGXDLMSBase
     /// Manufacturer specific attribute.
         get;
         set;
     /// Returns amount of attributes.
     public int GetAttributeCount()
         return 2;
     /// Returns read attributes.
     public int[] GetAttributeIndexToRead(bool all)
     public int GetMaxSupportedVersion()
         return 0;
     /// Returns amount of methods.
     public int GetMethodCount()
         return 1;
     /// Returns method names.
     public string[] GetMethodNames()
         return new string[] { "Reset" };
     /// Returns attribute names.
     public string[] GetNames()
         return new string[] { "Logical Name", "Manufacturer" };
     /// Value is write for the meter.
     public object GetValue(GXDLMSSettings settings, ValueEventArgs e)
         object ret;
         if (e.Index == 1)
             ret = GXCommon.LogicalNameToBytes(LogicalName);
         else if (e.Index == 2)
             ret = (byte)Manufacturer;
         else
             e.Error = ErrorCode.ReadWriteDenied;
             ret = null;
         return ret;
     /// Value is read from the meter.
     public void SetValue(GXDLMSSettings settings, ValueEventArgs e)
         switch (e.Index)
             case 1:
                 LogicalName = GXCommon.ToLogicalName(e.Value);
                 break;
             case 2:
                 Manufacturer = Convert.ToByte(e.Value);
                 break;
             default:
                 break;
     public byte[] Invoke(GXDLMSSettings settings, ValueEventArgs e)
         //This is not needed on the client side.
         throw new NotImplementedException();
     public void Load(GXXmlReader reader)
     public void PostLoad(GXXmlReader reader)
     public void Save(GXXmlWriter writer)
Custom objects is not implemented at the moment.
The framework invokes onObjectCreate when unknown COSEM type is returned in association view. At first the client must register to listen onObjectCreate events.
  • Java
  • C#
  • Delphi
  • ANSI C++
  • Python
public class GXDLMSSecureClient2 extends GXDLMSSecureClient implements IGXCustomObjectNotifier {
     * Create manufacturer specific custom COSEM object.
    @Override
    public GXDLMSObject onObjectCreateEventHandler(int type, int version) {
        if (type == 10006 && version == 1) {
           return new ManufacturerSpecificObject();
        return null;
GXDLMSClient client = new GXDLMSClient();
client.OnCustomObject += (type, version) =>
    if (type == 6001 && version == 0)
	return null;
If you have any questions or ideas on how to improve Gurux DLMS component let us know or ask questions in a Forum
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
