  2. How Can I Decode The Data ?
How can I decode the data ?
By Harish07 , 14 July, 2023
In which format(ASCII or hexa) is the data in the command prompt which is getting transmitted and received?
3 years ago
Hi, Data is in hex format…
Data is in hex format. DLMS uses binary data. I believe it doesn't help you a lot because DLMS is not an easy protocol. You can use DLMS translator to convert it to XML.
https://www.gurux.fi/GuruxDLMSTranslator
