  3. IEC HDLC Setup
gxdn
By Administrator , 23 January, 2018
IEC HDLC setup
This object configures the meter's HDLC communication port. It defines the line speed, addressing, frame limits and timeouts used for a serial connection.
When to use it
Use it when matching a reading application's serial settings to a meter or adjusting frame sizes for a constrained link.
Attributes
1. Logical name
The OBIS code that identifies this object instance in the meter. Use it to distinguish this instance from other objects of the same class.
2. Communication speed
Sets the port's communication rate. Another protocol's entry procedure may override this rate.
3. Window size transmit
Sets how many frames the meter may send before receiving an acknowledgement. Connection setup can negotiate another value.
4. Window size receive
Sets how many frames the meter may receive before sending an acknowledgement. Connection setup can negotiate another value.
5. Maximum information length transmit (version 0)
Limits the information field in transmitted frames to 32-128 bytes. A smaller size can be agreed during connection setup.
5. Maximum information length transmit (version 1)
Limits the information field in transmitted frames to 32-2030 bytes. A smaller size can be agreed during connection setup.
6. Maximum information length receive (version 0)
Limits the information field in received frames to 32-128 bytes. A smaller size can be agreed during connection setup.
6. Maximum information length receive (version 1)
Limits the information field in received frames to 32-2030 bytes. A smaller size can be agreed during connection setup.
7. Intercharacter timeout (version 0)
Sets the gap in milliseconds after which received bytes are treated as a complete frame. The configured range is 20-1000 milliseconds.
7. Intercharacter timeout (version 1)
Sets the gap in milliseconds after which received bytes are treated as a complete frame. The configured range is 20-6000 milliseconds.
8. Inactivity timeout
Sets how many seconds without a received frame cause disconnection. Zero disables this timeout.
9. Device address
Holds the physical HDLC address used to reach the device.
Versions
Attribute availability depends on the object version reported by the meter (version 0: attributes 1-9; version 1: attributes 1-9). Use the version-specific descriptions above when an attribute's meaning or representation differs.
Actions
There are no actions available for this object type.
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
  • Account
  • Arbitrator
  • Array manager
  • Charge
  • CoAP diagnostics
  • CoAP setup
  • Communication port protection
  • Credit
  • Data protection
  • Function control
  • G3-PLC 6LoWPAN setup
  • G3-PLC MAC layer counters
  • G3-PLC MAC setup
  • LLC SSCS setup
  • LTE monitoring
  • M-Bus diagnostics
  • M-Bus port setup
  • Network time setup
  • Parameter monitor
  • PRIME application identification
  • PRIME MAC counters
  • PRIME MAC functional parameters
  • PRIME MAC setup
  • PRIME network administration data
  • PRIME physical layer counters
  • S-FSK active initiator
  • S-FSK MAC counters
  • S-FSK physical and MAC setup
  • S-FSK reporting system list
  • S-FSK synchronisation timeouts
  • Schedule
  • Short name association
  • STS payment token settings
  • Tariff plan
  • Token gateway
  • Twisted pair setup
  • Wireless mode Q channel
  • IPv4 setup
  • Register activation
