  3. Association Refresh Related Issue
Association refresh related issue
Profile picture for user Amit
By Amit , 3 November, 2026
When I create a new association, the OBIS codes from the previously added association are already available in it. After refreshing, an error is displayed because the previously added object is not available in the newly created association.
Amit
22 hours 13 min ago
The same issue occurs every…
The same issue occurs every time, even after I completely uninstalled the application and removed all application data from the installation folder. When a new association is created, it still shows the OBIS codes from the previously added association. After refreshing, an error is displayed because the previous object is not available in the newly created association
1 min 28 sec ago
Hi Amit, You don't create a…
Hi Amit,
You don't create a new association. The association depends on the current connection settings. It fails because the meter doesn't accept your settings.
