When I create a new association, the OBIS codes from the previously added association are already available in it. After refreshing, an error is displayed because the previously added object is not available in the newly created association.
The same issue occurs every time, even after I completely uninstalled the application and removed all application data from the installation folder. When a new association is created, it still shows the OBIS codes from the previously added association. After refreshing, an error is displayed because the previous object is not available in the newly created association
You don't create a new association. The association depends on the current connection settings. It fails because the meter doesn't accept your settings.
The same issue occurs every…
Hi Amit, You don't create a…
Hi Amit,
