  3. Can't Run GXDLMSDirector.application Because of Microsoft Defender SmartScreen
Can't run GXDLMSDirector.application because of Microsoft Defender SmartScreen
By weho24 , 22 July, 2024
Hi all,
I want to run the application on my company computer but unfortunately I can't run it because there is a protection by Microsoft Defender SmartScreen. Unfortunately, I can't turn it off myself. Is there any possibility that gurux gets approved by Windows so that they don't get blocked on start up?
Thanks in advance.
weho24
2 years 1 month ago
Update 22-7-2024. I found…
Update 22-7-2024. I found out by virustotal.com that it is being blocked by virustotal.com because it is flagged as malicious software by VirIT (https://www.tgsoft.it/contatti.asp). I have sent an email to them, hopefully they can trust the software, but perhaps it is better if this is being done from gurux itself.
2 years 1 month ago
HI, You can select "More…
HI,
You can select "More Info" and then "Run anyway". It will install the application.
weho24
2 years 1 month ago
Unfortunately, I cannot…
Unfortunately, I cannot select that option because it's a protection from my company which will not allow to install unverified software. Is it not possible for you to get whitelisted by VirIT?
2 years 1 month ago
Hi, Is it possible for you…
Is it possible for you to download the source codes from Github and build the app?
https://github.com/Gurux/GXDLMSDirector
