  3. Can't Run GXDLMSDirector.application Because of Microsoft Defender SmartScreen
Can't run GXDLMSDirector.application because of Microsoft Defender SmartScreen
By weho24 , 22 July, 2024
Hi all,
I want to run the application on my company computer but unfortunately I can't run it because there is a protection by Microsoft Defender SmartScreen. Unfortunately, I can't turn it off myself. Is there any possibility that gurux gets approved by Windows so that they don't get blocked on start up?
Thanks in advance.
weho24
2 years 3 months ago
Update 22-7-2024. I found…
Update 22-7-2024. I found out by virustotal.com that it is being blocked by virustotal.com because it is flagged as malicious software by VirIT (https://www.tgsoft.it/contatti.asp). I have sent an email to them, hopefully they can trust the software, but perhaps it is better if this is being done from gurux itself.
HI, You can select "More…
HI,
You can select "More Info" and then "Run anyway". It will install the application.
weho24
Unfortunately, I cannot…
Unfortunately, I cannot select that option because it's a protection from my company which will not allow to install unverified software. Is it not possible for you to get whitelisted by VirIT?
2 years 2 months ago
Hi, Is it possible for you…
Is it possible for you to download the source codes from Github and build the app?
https://github.com/Gurux/GXDLMSDirector
