  3. OBIS Code For Average RMS Voltage (percentage Value)
OBIS code for Average RMS voltage (percentage value)
By Balveer Singh , 8 July, 2021
Greetings of the day,
I have to add a new parameter, Average RMS percentage voltage, in the instantaneous profile of the energy meter(3 Phase).
Can you suggest to me the OBIS code, although I have concluded from Blue Book, that it can be 12.7.0, but I think it should be applied if the unit is Volts, but I'm calculating this value in percentage,
So, kindly suggest, what OBIS code should be used?
5 years ago
You can use GXDLMSTranslator to find correct OBIS code.
https://www.gurux.fi/GuruxDLMSTranslator
Remove OBIS code and apply the description to filter.
OBIS code might also be defined in country-specific versions.
Balveer Singh
5 years ago
Thank You, Sir ! Although it
Thank You, Sir ! Although it is very helpful, But I didn't find the OBIS code for the respective parameter, even I didn't found any parameters in percentage units.
Can you suggest to me the appropriate OBIS code?
5 years ago
It might be that there is no standard OBIS code for that. Then you need to use the manufacturer specific OBIS codes.
Balveer Singh
5 years ago
Yes, Sir, Maybe, but while
Yes, Sir, Maybe, but while selecting the Manf. specific OBIS is there any restriction regarding percentage value?
5 years ago
No. It's recommended that Manufacturer-specific values are not used, but if that is not in the standard you need to use it.
Balveer Singh
5 years ago
OK Sir, Thanks for your
OK Sir, Thanks for your valuable time, the information was very helpful,
Thank you again.
  • Malcolmactig
  • mhliang
  • Kevinmug
  • mohanadalhweiti
  • dawnso11
