  3. Smart Meter+raspberry PI
Smart meter+raspberry PI
Profile picture for user maher
By maher , 9 March, 2016
Known problems
Hello every body
I am an electronic engineer student and I am trying to retrieve data from my smart meter (Iskraemeco) and then analyse these data with my raspberry PI and i must use the DLMS protocol.
So here i am, i am searching all the day in forums and in internet how i can start doing this project but i am confusing because i did not found something easy to understand for someone who try to start from the bottom.
So please can anybody enlighten me with steps to follow to understand what i am going to do ?
10 years 7 months ago
I believe you want to use Java? You should get example client from GitHub.
https://github.com/Gurux/gurux.dlms.java
Then you can start your client app with settings like this:
/m=isk /sp=COM1 /t
We are updating doc here:
www.gurux.fi/Gurux.DLMS
maher
i want to work with Python but i'm trying to understand the work's steps with Java especially how to make the client app
MK
One advice. Use Java. It's hard work to transfor Java library to Python, if that is your idea.
DLMS is very complicated protocol. You do not just send few bytes and get some data back.
maher
Thanks Mikko for the reply, i'm going to work with Java so
MK
  • hezhangnihao@163.com
  • ZilvinasN
  • Yosr
  • albino.ramon
  • JosepM
