  3. Need RJ45 Pin Configuration For Saral 300 and Saral 305 Secure Meters
Need RJ45 pin configuration for Saral 300 and Saral 305 Secure meters
Profile picture for user rooftopurja
By rooftopurja , 29 October, 2026
We need RJ45 pin configuration of Secure make Saral 300 and 305 meters with client address to read meter serial no and meter kwh. Earlier we implemented Premier300 with RJ11 which has client address 32 and is working. All these meters are being connected to Teltonika Gateways for Solar Plant Monitoring.
3 weeks 2 days ago
Hi, RJ45 pins are usually…
RJ45 pins are usually the same. If you have doubts, you need to verify this from the Secure documentation. Can you connect without authentication? I believe that the password is different, and the connection fails for that reason.
rooftopurja
3 weeks 1 day ago
Saral meter manual - gives…
Saral meter manual - gives the exact RJ45 pin configuration(have tried the same config) for RS232 communication - but unlike premier300 manual - password is not available in the manual. Your guess maybe right about the password being wrong. We tried without authentication 16 and none - and then 32 low and the same password ABCD0001 - result is same - error.
1 week 5 days ago
Hi, You need to ask the…
You need to ask the meter manufacturer for the meter password.
It can be anything. Also, manufacturers use different client ID values and authentication levels.
If you can connect with authentication 16 and none, your serial port settings are correct. In general, you need to ask the correct settings from the meter manufacturer.
  • Star Multi Exchange - Money Changer Telp/Wa 083831618807
  • BTN KC Tebet call/wa 0813-627-9539.
  • Hoho Money Changer ☎️/Wa 083150344509
  • BTN KC Teluk Gong call/wa 0813-627-9539.
  • Dolarasia Money Changer Telp/Wa 083831618807
