We need RJ45 pin configuration of Secure make Saral 300 and 305 meters with client address to read meter serial no and meter kwh. Earlier we implemented Premier300 with RJ11 which has client address 32 and is working. All these meters are being connected to Teltonika Gateways for Solar Plant Monitoring.
Hi, RJ45 pins are usually…
RJ45 pins are usually the same. If you have doubts, you need to verify this from the Secure documentation. Can you connect without authentication? I believe that the password is different, and the connection fails for that reason.
Saral meter manual - gives…
Saral meter manual - gives the exact RJ45 pin configuration(have tried the same config) for RS232 communication - but unlike premier300 manual - password is not available in the manual. Your guess maybe right about the password being wrong. We tried without authentication 16 and none - and then 32 low and the same password ABCD0001 - result is same - error.
