  3. New Installation
New installation
By jesperbonde , 21 October, 2025
I am trying to make a new installation of the python DLSM/COSEM application. Testing the standard listener application gives the following feed back. What is the reason?
(venv) pi@raspberrypi:~/gurux.dlms.python/Gurux.DLMS.Push.Listener.Example.python $ python main.py -S '/dev/ttyS0:2400:8None1'
gurux_dlms version: 1.0.191
gurux_net version: 1.0.23
gurux_serial version: 1.0.21
/dev/ttyS0:2400 8NONE1
Press any key to close the application.
Media state changed. MediaState.OPENING
trace:11:10:26 TraceTypes.INFO Settings: Port: /dev/ttyS0 Baud Rate: 2400 Data Bits: 8 Parity: 0 Stop Bits: 0 Eop:126
Invalid Command.
Invalid Command.
Invalid count.
Invalid Command.
<HDLC len="1E8" >
<TargetAddress Value="20" />
<SourceAddress Value="1" />
<FrameType Value="13" />
<PDU>
<GeneralGloCiphering>
<SystemTitle Value="4B414D4501C4EC57" />
<CipheredService Value="3000873EBF390DCDAF836E9F35C76B013EE76E8FDF7D7A22AF3BE4EF46C24F02C673B54B4EA97F1A73A131A17BBBD9DD2FB1FF64D3362048A62E2208CB0E00330D0E35B7578039577FAE62DF1E1DF113423786C49F9C1DCE8B54EF53C9BD2481D55CCEB0EE253E80DEE666F4084F446EFF7D572A7D156A2F454F6FC8BE40FD078587C48EC6609B0CB1F7C8A90E129BE28C79BA550FC62B48B7717CCF53975B79EF8B90BE754D640B8D7DEE252098BE336011FE250AD975F453116BBF2D52B7130ECE3CB0F30E32BE217DC94435ADC361F7A22948BE691082F5136D8F8F353DFCB1E86CE3D5367EA94F9AD3AFFA232A19D78BDD6F78D4797AE2B11209EB8D89A460F3A8C1330178EA91DF5502954B2CD6A2B112862B07211CE265F701F0454A61D9D66CA5E2745147DBF01FAC2C9A51F3A4D43587D736F9CAD347D189A4FBF4E29E9C3BA59BBE0B65289B86EDAF9C395C608EF4D3A389C5903464EB16FB2809E94711CEBC638BD41118D890293BC49F68001E777935E5453F95BEDDE159254BE3DC2F746D4E8F10E9319FEBFCA5C9BB202E7E0FD4215E8B22A77427D4B8411488A4F58C0D68209095ED336B1FCABB90AFCCC5C4FB543E1D53D90A86AD1970F0B5B9B4D4EA7E95E1586DD6EAF957945321" />
</GeneralGloCiphering>
</PDU>
</HDLC>
Invalid count.
^C
Media state changed. MediaState.CLOSING
Media state changed. MediaState.CLOSED
11 months 3 weeks ago
Hi, Your push messages are…
Your push messages are encrypted. You need to give the correct block cipher and authentication keys.
-B YOUR_BLOCK_CIPHER_KEY -A YOUR_AUTHENTICATION_KEY
jesperbonde
Also tried that. Then I get…
File "/home/pi/gurux.dlms.python/Gurux.DLMS.Push.Listener.Example.python/main.py", line 229, in <module>
sampleclient(sys.argv)
File "/home/pi/gurux.dlms.python/Gurux.DLMS.Push.Listener.Example.python/main.py", line 83, in __init__
ret = settings.getParameters(args)
File "/home/pi/gurux.dlms.python/Gurux.DLMS.Push.Listener.Example.python/GXSettings.py", line 115, in getParameters
parameters = GXSettings.__getParameters(args, "p:S:r:i:t:T:A:b:")
File "/home/pi/gurux.dlms.python/Gurux.DLMS.Push.Listener.Example.python/GXSettings.py", line 99, in __getParameters
pos = optstring.index(args[index][1])
ValueError: substring not found
Hi, My bad, the argument is …
My bad, the argument is -b, not -B
-b YOUR_BLOCK_CIPHER_KEY -A YOUR_AUTHENTICATION_KEY
jesperbonde
That was it, so now…
That was it, so now everything is working again. Thanks for your support!
