  2. Hwo To Connect To Genus Meter Via HighSHA256?
hwo to connect to Genus meter via HighSHA256?
By P3NCYUYkUtQkKX64H , 23 April, 2025
The "Authentication" drop-down for Genus meters only shows "None", "Low", and "HighGMAC". how do i add "HighSHA256" to that list? yes, the meter definitely supports mechanism 6.
I see that the goe.obx file that's downloaded from the website only has those 3, but I can't see a way to edit that file, and I can't see a way to do this in the Manufacturer Settings dialog, either.
1 year 3 months ago
Hi, Genus hasn't sent any…
Genus hasn't sent any meter that supports HighSHA256 to us, but I believe you that it's supported. Restart GXDLMSDirector and select "New Manufacturer Settings Available" from the top menu. After that HighSHA256 support for Genus is available.
P3NCYUYkUtQkKX64H
1 year 3 months ago
thanks!
thanks!
