  3. Bluetooth DLMS Smart Meter - Cannot Read Data
By Aswin Kumar , 11 March, 2025
Hi ,
We are working with Indian Standard Bluetooth Smart Meter , when we try to read the data from meter via bluetooth using gurux.dlms library (python) , we get error , but , while using the Optical Cable the data was able to be read for the same library .
Kindly help us to resolve this issue.
1 year 5 months ago
Hi, I believe that one of…
I believe that one of your settings is different from what the meter expects. The correct settings should be described in the meter documentation.
The baud rate is usually wrong if your Bluetooth connection uses an optical probe.
Aswin Kumar
1 year 5 months ago
If the meter does not…
If the meter does not support RFCOMM, how can we run the following command? python main.py -S /dev/rfcomm0 -t Verbose
1 year 5 months ago
Hi, You should read this and…
You should read this and check that your meter supports Bluetooth.
https://gurux.fi/bluetooth
Aswin Kumar
1 year 5 months ago
Hi , Yes, our meter supports…
Hi ,
Yes, our meter supports Bluetooth (BLE 5.0); however, it does not support RFCOMM. We referred to this https://gurux.fi/bluetooth - link to communicate with and read data from the meter. Is there any other way to read the data via Bluetooth instead of using RFCOMM?
Aswin Kumar
1 year 5 months ago
This is the errors we got,…
OSError: [Errno 5] Input/output error
File "/usr/local/lib/python3.9/dist-packages/gurux_serial/GXSerial.py", line 211, in __readThread
data = self.__h.read()
File "/usr/local/lib/python3.9/dist-packages/gurux_serial/_handlers/GXLinuxHandler.py", line 395, in read
cnt = self.getBytesToRead()
File "/usr/local/lib/python3.9/dist-packages/gurux_serial/_handlers/GXLinuxHandler.py", line 379, in getBytesToRead
fcntl.ioctl(self.h, termios.TIOCINQ, buf, True)
File "/home/iot/ilm/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/main.py", line 112, in main
File "/home/iot/ilm/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 532, in readAll
self.initializeConnection()
File "/home/iot/ilm/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 306, in initializeConnection
File "/home/iot/ilm/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 118, in readDLMSPacket
File "/home/iot/ilm/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 169, in readDLMSPacket2
raise e
File "/home/iot/ilm/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 164, in readDLMSPacket2
self.media.send(data, None)
File "/usr/local/lib/python3.9/dist-packages/gurux_serial/GXSerial.py", line 172, in send
self.__h.write(data)
File "/usr/local/lib/python3.9/dist-packages/gurux_serial/_handlers/GXLinuxHandler.py", line 407, in write
ret = os.write(self.h, data)
gurux_dlms version: 1.0.174
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
ClientAddress: 0x10
Standard: Standard.DLMS
TX: 17:46:06 7E A0 07 03 21 93 0F 01 7E
RX: 17:46:16
1 year 5 months ago
Hi, If you don't want to use…
If you don't want to use RFCOMM, you need to use Bluetooth library that can communicate with your meter and add the IGXMedia interface to Bluetooth library.
  • addCaptureObject as Class ID=01 (Data) (not 03 (Register))
