  3. IEC Local Port Setup
IEC Local Port setup
By andre538 , 21 January, 2025
Hello Mikko,
Seems to me that GXDLMSIECLocalPortSetupView in InitializeComponent() should be changed from
this.DefaultModeTB.Type = Gurux.DLMS.Enums.ValueFieldType.TextBox;
to
this.DefaultModeTB.Type = Gurux.DLMS.Enums.ValueFieldType.CompoBox;
In other case it is impossible to change default mode via UI
1 year 7 months ago
Hi, Thank you for pointing…
Thank you for pointing this out. It's done and will be in the next release.
