Hi Mikko, in this topic: https://www.gurux.fi/forum/16758 you mentioned that Wasion aMeter100 is compatible, I have a unit here but I tried several addresses/configs and didn't have any luck on trying to connect to it. Can you share what settings this meter uses for default? Thanks
Hi, If you are using an…
If you are using an optical probe, change the interface type to WhlcWithModeE.
If you are using a serial port connection, check your baud rate.
