  3. Pass a TCP Client To GXNet
Pass a TCP Client to GXNet
By bkoprulu , 4 May, 2026
Gurux.Net
I have a condition;
I have to open transparent connection with an special command. so I am connecting modem with TCP Client, executing command with success. after that I am trying to read dlms meter over Gurux.Net.
I tried a few hacks but not worked. like set gxnet socket with reflection, use gxnet to send special command v.s.
Can you help me about seting using tcp client as gxnet media
thanks
4 months 1 week ago
Hi, You didn't say are you…
You didn't say are you using Moxa, etc.
Try to connect with GXDLMSDirector. The correct settings should be on the meter documentation.
If you are using TCP/IP connection on the meter side and not serial port, change the interface from HDLC to WRAPPER and the server address to 1.
