  3. Conformance Test HDLC_FRAME_P2 In PC-mode
Conformance test HDLC_FRAME_P2 in PC-mode
By girija , 5 August, 2024
Hello Sir,
While running the conformance test HDLC_FRAME_P2 in PC-mode, the "Values" displays,
"Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: indexSystem.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index"
The same Test-case PASS in MR.
I have referred the forum question- https://www.gurux.fi/node/24481
The association view contains following objects (which exactly I have coded).
1. Data: Logical Device Name
2. Association Logical Name: Association None
3. Clock: clock1
Here, what might the term "Invalid Association View" signify regarding to my case?
Or, what could be other reasons for this error ?
I am using GuruX DLMS ANSI C library.
Thank you.
Kind Regards,
Girija
2 years 1 month ago
Hi, There is something wrong…
There is something wrong with your association view. You need to check that.
Make sure that you have added the exact amount of COSEM objects to the association view and that you have initialized all objects.
