  2. PUSH Related
PUSH related
By shagufta , 3 July, 2024
Hello sir
PUSH authentication is not working
Logs and refrence image is attached
Please provide a solution
20:11:53 Send SNRM request.
20:11:53
20:11:53 Send AARQ request.
20:11:54
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 1C EA 7E
20:11:54
RX: 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 00 7D 18 7E
20:11:54 Disconnect request
20:11:54
20:11:54 Send SNRM request.
20:11:54
20:11:54 Send AARQ request.
TX: 7E A0 6B 03 21 10 4C B9 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 36 44 59 5C 6A 41 41 66 40 37 5D 3C 5C 6E 77 24 BE 23 04 21 21 1F 30 00 00 00 01 34 69 6E 7E 1F 93 97 5A 7D 5E C2 57 45 D1 C6 67 DD DF 81 65 C1 14 04 E2 7A E6 83 7E 7E
20:11:54
RX: 7E A0 25 21 03 30 BB 86 E6 E7 00 61 17 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D AE 4F 7E
20:11:54
2 years 1 month ago
Hi, Your client's address is…
Your client's address is wrong. You try to use the Public client address (0x10).
shagufta
2 years 1 month ago
Thanks for the response sir …
Thanks for the response sir ,
As you have mentioned we are using same client address 0x10 please check the attached refrence image and provide a solution
2 years ago
Hi, In Indian standard, the…
In Indian standard, the Push client address is 0x40, not 0x10.
Select different authentication level and then select Push again.
It's automatically updated to 0x40.
shagufta
2 years ago
Thanks for your response sir…
Thanks for your response sir,
I have changed the client address to 0x40, but still no luck ...
Please cheack the application mechanism which has written for push is correct or not ?
PS:
const U8 Authentication_Mechanism_Name_PUSH[]={0x60 ,0x85 ,0x74 ,0x05 ,0x08 ,0x02 ,0x00}; //Mechanism name for the PUSH Association
2 years ago
Hi, 0x60 ,0x85 ,0x74 ,0x05 …
0x60 ,0x85 ,0x74 ,0x05 ,0x08 ,0x02 ,0x00 means that authentication is not used, but that breaks the Indian standard. You need to ask the meter manufacturer how they have implemented this.
