Hi, Mikko,
I read IP6 Setup from an Indian Standard meter.
10:20:59 Read object type Ip6Setup index: 7
7E A0 2C 03 61 FE CC B0 E6 E6 00 C8 1E 30 00 00 1D 39 40 46 05 42 32 91 84 69 0E 0E AD 73 4B 81 56 54 75 C7 E9 97 31 16 38 08 D0 BF 22 7E
10:20:59
7E A0 4C 61 03 1E 36 28 E6 E7 00 CC 3E 30 00 00 18 03 25 3F 74 0B EE 2E B2 0C 6B 44 68 09 BB 82 C7 EE F3 EE E1 9E 4A 65 EF EE BD 49 F3 D5 CE ED 3D 20 C2 4D 4D 03 32 0D 64 FE 44 AF 30 1B 8D A6 05 E9 B1 AF 2C D0 EF CB 5D EA 62 20 F1 7E
System.ArgumentException: An Invalid IP address was specified.
Parameter Name: address
在 System.Net.IPAddress..ctor(Byte[] address)
在 Gurux.DLMS.Objects.GXDLMSIp6Setup.Gurux.DLMS.Objects.IGXDLMSBase.SetValue(GXDLMSSettings settings, ValueEventArgs e)
在 Gurux.DLMS.GXDLMSClient.UpdateValue(GXDLMSObject target, Int32 attributeIndex, Object value, List`1 columns)
在 Gurux.DLMS.GXDLMSClient.UpdateValue(GXDLMSObject target, Int32 attributeIndex, Object value)
在 GXDLMSDirector.GXDLMSCommunicator.Read(Object sender, GXDLMSObject obj, Boolean forceRead)
在 GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
The Parsed content is as image shows.
But GXDLMSDirector could not give a normal content display which says "An Invalid IP address was specified."
Best Regards,
Jimmy Lau
Hi, Please, don't add…
Please, don't add pictures. They are hard to read and plain text is better.
Your IP address is not a valid IPv6 address: 2100:0000:0000:0000:0000:0000:0000:00001
You need to fix it and use the correct IPv6 address.
Thanks, now I know what it…
Thanks, now I know what it does mean as an prompt message from this unspecified IPv6 address.
Jimmy Lau
