  3. LLC Bytes Are Missing From The Message
LLC bytes are missing from the message
By Agg , 5 March, 2024
I tried using Simulator(Java) as the meter,then i use the Director to read the meter。When I connet to the meter without Authentication,it works successfully。But I use the HighGMac,there are some issues here。Show that LLC bytes are missing from the message。
the sever log is below:
Client address: 1 HighGMac authentication, Client address: 1, password:
Conformance:
[GET]
MaxReceivePduSize: 832 MaxSendPduSize: 65535
Security suite: SUITE_0
Security policy: []
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
TCP/IP connection established.
TX: 7E A0 1E 03 03 73 40 CC 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
RX: 7E A0 6B 03 03 10 CF A9 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 4D 4D 4D 00 00 00 00 00 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 51 1A 77 02 04 0F 42 18 75 66 75 5A 70 29 6B 71 BE 23 04 21 21 1F 30 00 00 00 00 C8 78 0A 70 91 93 CB 02 83 8A A3 D2 6E DF 6B D1 76 D2 CD 8C E7 26 1A 04 DD 04 D7 9D 7E
TX: 7E A0 77 03 03 30 58 DC E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4D 4D 4D 00 00 00 00 01 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 17 6E 12 21 65 0D 56 34 0A 72 69 0F 5F 39 33 63 BE 23 04 21 28 1F 30 00 00 00 00 C9 50 5D D6 FC 61 08 89 B3 0D 90 03 C8 79 7D 67 BC A6 80 F7 E9 5A 9C EE CA 1A AC 32 7E
RX: 7E A0 3F 03 03 32 25 0C E6 E6 00 CB 31 30 00 00 00 01 BD BB 1B A6 AC 9E 2D 5B 2B C7 20 A7 1F 14 20 56 AD 3B 9C 2E F2 23 03 72 03 09 5D 8B 5F FA 98 ED 3A C7 DF C9 C9 5C 32 61 AF AB 6A 4B 9D 4B 7E
TX: 7E A0 0C 03 03 52 1C 06 D8 02 02 18 96 7E
RX: 7E A0 07 03 03 53 80 D7 7E
TCP/IP connection closed.
The following image is my configuration,Where is the problem?
Agg
2 years 8 months ago
the secured Connections
Agg
Hi, LLC bytes are there, but…
LLC bytes are there, but the server is offering only Get service. Action service is not added. Did you read this meter without authentication and now try to use the same association for the GMAC? You need to read the meter using GMAC association and then use that to simulate the GMAC connection.
Agg
Thanks a lot.Now I can…
Thanks a lot.Now I can connect the device successfully.
There is a new question here.
How can I use the HighECDSA and SecuritySuite1 to connect to the simulator meter? Does meter need both of keyagreement and DigitalSignature certificates?
Can I use Director to generate a certificate and import it through the Security Setup object? I tried myself, but it shows "Access Error :Device reports a inconsistent Class or object"
Afterwards, I want to use AMI to make the same connection as well.
I am a beginner, please help me.Thanks
Hi, Test first that your…
Test first that your meter is supporting ECDSA. Establish a connection to the meter and read the Security Setup object. Can you see any certificates or is that empty?
You need to import the client certificate for the meter and export the meter's certificate to the client.
Read also this:
https://www.gurux.fi/PublicKeyCryptography
Please, if you have other questions from ECDSA, create a new topic.
