  2. Hexing Smart Meter Without Association View
Hexing Smart Meter without Association view
By flagr97 , 11 April, 2023
Hey!
I have a Hexing Smart Meter, that I'm connecting via DLMSDirector, currently is using High level security with Authentication and Encryption, all of the data I've checked with the manufacturer's official application (which can connect and read data)
I've read here that Hexing devices don't have Association View and that the objects need to be manually added, which i tried to do
I've tried to add the standard readout parameterization (0.0.21.0.5.255), which I read with the official program, but when I tried to add to DLMSDirector and click Read, it returns the error "Service not allowed"
This is the Logs when connecting to the meter and click on Read the object:
GXDLMSDirector 9.0.2303.2302
Log created 16:37:17
16:37:19 Initializing serial connection.
16:37:19 04:37:19.639 Info Opening
16:37:19 04:37:19.639 Info Configurações da porta serial: Nome da porta: COM3 Taxa de transmissão: 300 Bits de dados: 7 Paridade: Even Stop Bits: One Controle de fluxo: None Eop: None
16:37:19 04:37:19.646 Info Open
16:37:20 IEC Sending:/?!<CR><LF>
16:37:20 04:37:20.654 Sent 2F 3F 21 0D 0A
16:37:20 04:37:20.940 Received 2F
16:37:20 04:37:20.971 Received 2F
16:37:21 04:37:21.004 Received 48
16:37:21 04:37:21.035 Received 58
16:37:21 04:37:21.067 Received 45
16:37:21 04:37:21.099 Received 35
16:37:21 04:37:21.131 Received 5C
16:37:21 04:37:21.179 Received 32
16:37:21 04:37:21.211 Received 48
16:37:21 04:37:21.243 Received 58
16:37:21 04:37:21.275 Received 46
16:37:21 04:37:21.307 Received 33
16:37:21 04:37:21.339 Received 30
16:37:21 04:37:21.371 Received 30
16:37:21 04:37:21.403 Received 0D
16:37:21 HDLC received: /HXE5\2HXF300<CR><LF>
16:37:21 BaudRate is : 9600
16:37:21 Moving to mode E.
06 32 35 32 0D 0A
16:37:21 04:37:21.407 Sent 06 32 35 32 0D 0A
16:37:23 04:37:23.417 Info Closing
16:37:23 04:37:23.528 Info Closed
16:37:23 04:37:23.528 Info Opening
16:37:23 04:37:23.528 Info Configurações da porta serial: Nome da porta: COM3 Taxa de transmissão: 9600 Bits de dados: 8 Paridade: None Stop Bits: One Controle de fluxo: None Eop: None
16:37:23 04:37:23.551 Info Open
16:37:24 Send SNRM request.
7E A0 07 03 03 93 8C 11 7E
16:37:24 04:37:24.555 Sent 7E A0 07 03 03 93 8C 11 7E
16:37:24 04:37:24.601 Received 7E A0 20 03 03 73 F0 2E 81 80 14 05 02
16:37:24 04:37:24.617 Received 02 01 00
16:37:24 04:37:24.632 Received 00 00 00 01 69 6D
16:37:24
7E A0 20 03 03 73 F0 2E 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E
16:37:24 Parsing UA reply succeeded.
16:37:27 Read object type Data index: 2
7E A0 35 03 03 10 9B D2 E6 E6 00 DB 08 48 45 43 00 05 00 00 01 1E 30 00 00 00 00 E2 04 31 A1 2A 44 E7 2A 07 37 23 B8 5D DB 30 4E 06 1B E9 CF 44 47 8B 8D 5B 5E 4D 7E
16:37:27 04:37:27.603 Sent 7E A0 35 03 03 10 9B D2 E6 E6 00 DB 08 48 45 43 00 05 00 00 01 1E 30 00 00 00 00 E2 04 31 A1 2A 44 E7 2A 07 37 23 B8 5D DB 30 4E 06 1B E9 CF 44 47 8B 8D 5B 5E 4D 7E
16:37:27 04:37:27.703 Received 7E A0 0F
16:37:27 04:37:27.718 Received 0F 03 03 30 C5 63 E6 E7 00 D8 01 01
16:37:27
7E A0 0F 03 03 30 C5 63 E6 E7 00 D8 01 01 3C 43 7E
Gurux.DLMS.GXDLMSExceptionResponse: Exception response. "Service not allowed"-exception. Operation not possible
em Gurux.DLMS.GXDLMS.HandleExceptionResponse(GXReplyData data)
em Gurux.DLMS.GXDLMS.GetPdu(GXDLMSSettings settings, GXReplyData data)
em Gurux.DLMS.GXDLMS.GetData(GXDLMSSettings settings, GXByteBuffer reply, GXReplyData data, GXReplyData notify)
em Gurux.DLMS.GXDLMSClient.GetData(GXByteBuffer reply, GXReplyData data, GXReplyData notify)
em GXDLMSDirector.GXDLMSCommunicator.ReadDLMSPacket(Byte[] data, Int32 tryCount, GXReplyData reply)
em GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
em GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, GXReplyData reply)
em GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, GXReplyData reply)
em GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[][] data, String text, GXReplyData reply)
em GXDLMSDirector.GXDLMSCommunicator.Read(Object sender, GXDLMSObject obj, Boolean forceRead)
em GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
This is the log of the official program, if it helps (Enviado = Sent, Recebido = Received) :
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:16.069
Dado: [55 AF 3F 21 8D 0A]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:16.847
Dado: [2F 48 58 45 35 5C 32 48 58 46 33 30 30 0D 0A]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:17.199
Dado: [06 B2 35 B2 8D 0A]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:18.707
Dado: [7E A0 07 03 03 93 8C 11 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:18.798
Dado: [7E A0 20 03 03 73 F0 2E 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:18.805
Dado: [7E A0 66 03 03 10 40 22 E6 E6 00 60 58 80 02 07 80 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 0A 80 08 1D 3A 18 4E 04 61 06 40 BE 22 04 20 21 1E 30 00 00 00 01 44 91 61 0D A0 0B 89 A6 B6 A1 BE 1D 95 1B 01 6B 60 AD F4 E5 26 B4 6E 25 FD 53 BC 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:19.134
Dado: [7E A0 6F 03 03 30 21 FA E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 48 58 45 03 32 01 07 34 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 BE 22 04 20 21 1E 30 00 BE 23 04 21 28 1F 30 00 00 07 5A C7 35 9D 74 21 22 E4 C8 C9 AB 91 40 1F F8 19 FB 3E 66 99 C5 F0 C7 4B E2 06 B3 46 8D 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:19.136
Dado: [7E A0 3F 03 03 32 25 0C E6 E6 00 CB 31 30 00 00 00 02 7F 2A DB 82 E8 28 E1 2D 5E FC E9 8B 8A E0 16 2B 5A 47 0F 38 F0 5D 67 3B 12 B9 D2 7E D2 1F 22 9B D8 EB 54 BA 34 56 2F CE B4 CB D1 8C 61 02 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:19.374
Dado: [7E A0 38 03 03 52 02 38 E6 E7 00 CF 2A 30 00 00 07 5B 41 71 7D E2 C6 F3 9E 40 80 B4 EE 20 B1 1E 69 7D 94 C3 4C 07 F3 E5 19 B9 5C CA E8 64 BA 71 0F 91 87 F8 25 21 62 B6 AB 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:19.376
Dado: [7E A0 2C 03 03 54 79 EC E6 E6 00 C8 1E 30 00 00 00 03 F0 7C 11 F7 9E 03 67 62 18 7B BA 6C DB 13 11 A9 2B CC 16 CB E7 08 FA F2 47 F6 CA 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:19.567
Dado: [7E A0 31 03 03 74 55 85 E6 E7 00 CC 23 30 00 00 07 5C 99 BA 29 E5 C0 60 2D 84 25 46 12 0B D5 A0 A5 7E 27 5C 56 8D 10 65 AF 7C 44 26 F6 2B 6E 2C 57 0F 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:19.568
Dado: [7E A0 2C 03 03 76 69 EE E6 E6 00 C8 1E 30 00 00 00 04 6D D2 9B F9 DB 8C B3 D8 2F 2F A0 9C 8C 09 CD 8F A2 75 DA 94 45 DE 40 F4 70 40 8E 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:19.726
Dado: [7E A0 31 03 03 96 49 41 E6 E7 00 CC 23 30 00 00 07 5D 6B 90 AF 77 BA 7B 46 4A 5A D9 D0 1D 11 3B FF 07 4D 44 C7 83 1D 48 DC AF 22 6B 3E 5E 73 29 3B 19 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:19.728
Dado: [7E A0 2C 03 03 98 19 E0 E6 E6 00 C8 1E 30 00 00 00 05 B8 A4 CA 04 CC C9 4F 84 FD A8 6E E4 CF C3 39 E5 06 15 D3 FE 90 75 3D 6B 24 41 B2 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:19.887
Dado: [7E A0 31 03 03 B8 35 89 E6 E7 00 CC 23 30 00 00 07 5E E1 62 2C B5 16 EE 57 32 5F BD FD 8B 19 77 C8 6E F2 9A 26 56 4F 3F 83 7E 65 34 45 C0 E8 D2 64 FD 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:19.888
Dado: [7E A0 2C 03 03 BA 09 E2 E6 E6 00 C8 1E 30 00 00 00 06 AA F6 F0 94 BF BB 5A 40 8F FD EE A4 81 B6 0E 31 98 29 41 54 1A 51 88 AF 11 14 38 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:20.046
Dado: [7E A0 2A 03 03 DA 95 CA E6 E7 00 CC 1C 30 00 00 07 5F 4A 15 0E 38 99 35 FF 8B 2B B4 E8 4F 5F 6D E1 3D DE BB 45 93 B4 C4 16 CF A7 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:20.048
Dado: [7E A0 2C 03 03 DC 39 E4 E6 E6 00 C8 1E 30 00 00 00 07 B4 8A C7 43 64 86 57 53 06 7F 48 1F 1D 5B 42 48 EC 05 93 60 A5 C9 71 6B A6 D9 B7 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:20.206
Dado: [7E A0 2D 03 03 FC 80 D9 E6 E7 00 CC 1F 30 00 00 07 60 4D 19 E0 F1 6A 70 FB F4 67 79 BB DF 01 D4 F4 EC 84 19 C0 01 78 53 D1 43 21 D3 65 0B 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:20.206
Dado: [7E A0 2C 03 03 FE 29 E6 E6 E6 00 C8 1E 30 00 00 00 08 14 BD 0F A7 10 9F 1E 7E 63 D0 C6 D0 F4 23 73 E4 D6 74 61 0E 37 AD 84 97 1C D2 18 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:20.382
Dado: [7E A0 39 03 03 1E D1 AC E6 E7 00 CC 2B 30 00 00 07 61 DD F0 07 BD AD BC 67 9D 47 05 79 19 B5 CB DF 68 D8 B7 52 17 05 AE DC 94 97 D0 6B 46 F1 E6 99 8E DE 2B EF 68 21 85 58 33 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:20.384
Dado: [7E A0 2C 03 03 10 59 E8 E6 E6 00 C8 1E 30 00 00 00 09 03 74 D6 90 6F 80 43 93 A4 A1 3B A2 03 49 5D A5 10 D0 3D BB 46 25 76 6F D7 5A 8B 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:20.542
Dado: [7E A0 27 03 03 30 4E 09 E6 E7 00 CC 19 30 00 00 07 62 F1 10 1C 92 59 35 DD C0 61 6B 5E BD 57 A5 44 19 A5 1E 43 23 DD C7 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:20.544
Dado: [7E A0 2C 03 03 32 49 EA E6 E6 00 C8 1E 30 00 00 00 0A 0A F1 EF FE 34 D3 D8 DF 99 F3 A4 06 91 0C 24 B9 98 E1 E3 2C 5A D3 CE 13 18 95 B4 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:20.782
Dado: [7E A0 61 03 03 52 77 14 E6 E7 00 CC 53 30 00 00 07 63 E3 CE 93 D4 BA 36 FF EB D1 2B FA 99 DA 6E 05 C8 0F 98 3C 16 7C E0 65 AC FB 7C 6B F8 A7 6A 8C 4F CA 7B 5D C9 D7 36 2C 87 E1 8D 96 CF 52 19 E2 4E A4 05 71 F8 10 ED 40 E2 C1 4C AD 2E 5C 2D 2B 45 4B 5D 35 1B 29 F2 CF FA C4 17 B3 D2 0B 28 C0 BA 7E]
[Enviado][DLMS/COSEM] - 11/04/2023 16:40:20.783
Dado: [7E A0 07 03 03 53 80 D7 7E]
[Recebido][DLMS/COSEM] - 11/04/2023 16:40:20.845
Dado: [7E A0 07 03 03 73 82 F6 7E]
3 years 2 months ago
Hi, The assoviation view is…
The assoviation view is mandatory. It's not possible to pass DLMS test without that. Because your data is encrypted, I can't help you without authentication key.
flagr97
Hi sorry, here's the command…
sorry, here's the command line parameters that i'm using, you can acces the data with those keys:
-S COM3:300:7EvenOne -i HdlcWithModeE -c 1 -a High -P 3030303030303030 -C AuthenticationEncryption -T 4845430005000001 -M 2C62387445737940 -A 30303030303030303030303030303030 -B 30303030303030303030303030303030 -w 1 -f 128 -t Verbose
Hi, Can you get the hex…
Can you get the hex trace from the official application so I can check what is different?
I believe that your meter is not supporting pre-established connections. For that reason remove the meter system title from the command line parameters:
-M 2C62387445737940
flagr97
3 years 1 month ago
The logs with all options…
The logs with all options enabled is this:
[Input][DLMS/COSEM] - 12/04/2023 17:05:45.206
Data: [55 AF 3F 21 8D 0A]
[Output][DLMS/COSEM] - 12/04/2023 17:05:45.982
Data: [2F 48 58 45 35 5C 32 48 58 46 33 30 30 0D 0A]
[Input][DLMS/COSEM] - 12/04/2023 17:05:46.333
Data: [06 B2 35 B2 8D 0A]
[Input][DLMS/COSEM] - 12/04/2023 17:05:47.857
Data: [7E A0 07 03 03 93 8C 11 7E]
[Output][DLMS/COSEM] - 12/04/2023 17:05:47.932
Data: [7E A0 20 03 03 73 F0 2E 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E]
[Input][DLMS/COSEM] - 12/04/2023 17:05:47.943
Data: [7E A0 66 03 03 10 40 22 E6 E6 00 60 58 80 02 07 80 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 48 45 43 00 05 00 00 01 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 0A 80 08 58 3B 1F 6B 39 4A 14 1A BE 22 04 20 21 1E 30 00 00 00 01 44 91 61 0D A0 0B 89 A6 B6 A1 BE 1D 95 1B 01 6B 60 AD F4 E5 26 B4 6E 25 FD 35 4B 7E]
[Output][DLMS/COSEM] - 12/04/2023 17:05:48.284
Data: [7E A0 6F 03 03 30 21 FA E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 48 58 45 03 32 01 07 34 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 BE 22 04 20 21 1E 30 00 BE 23 04 21 28 1F 30 00 00 07 66 04 C4 E4 C8 1C 65 20 C2 EE F3 D8 29 FC 5C F7 29 97 6A EE CA 7D 61 FD DF BD 13 E4 7E 7E]
[Input][DLMS/COSEM] - 12/04/2023 17:05:48.289
Data: [7E A0 3F 03 03 32 25 0C E6 E6 00 CB 31 30 00 00 00 02 7F 2A DB 82 E8 28 E1 2D 5E FC E9 8B 8A E0 16 2B 5A 47 0F 38 F0 5D 67 3B 12 B9 D2 7E D2 1F 22 9B D8 EB 54 BA 34 56 2F CE B4 CB D1 8C 61 02 7E]
[Output][DLMS/COSEM] - 12/04/2023 17:05:48.523
Data: [7E A0 38 03 03 52 02 38 E6 E7 00 CF 2A 30 00 00 07 67 42 AD 9D 3A 9E C2 97 E7 3A BB C5 D0 6B 23 C8 84 B7 F7 DE A7 E5 C3 1D 1C 59 C3 87 5C 1B 50 D2 2F B1 B4 B0 01 04 87 BF 7E]
[Input][DLMS/COSEM] - 12/04/2023 17:05:48.526
Data: [7E A0 2C 03 03 54 79 EC E6 E6 00 C8 1E 30 00 00 00 03 F0 7C 11 F7 9E 03 67 62 18 7B BA 6C DB 13 11 A9 2B CC 16 CB E7 08 FA F2 47 F6 CA 7E]
Title: [CurrentTime]
Attribute Description: [Class ID:8 | Index:2 | Logical Name:0.0.1.0.0.255]
[Output][DLMS/COSEM] - 12/04/2023 17:05:48.683
Data: [7E A0 31 03 03 74 55 85 E6 E7 00 CC 23 30 00 00 07 68 0C 58 D6 C9 0C FD 72 6F 68 A4 F0 A3 F8 B8 1F B2 17 18 92 C1 94 8E 9E 7B CD 51 E3 DC 47 B8 B7 40 7E]
Original Data: [09 0C 07 E7 04 0C 03 0E 05 02 FF 80 00 00]
Data Analyzed:
-> TYPE: OCTET_STRING, SIZE: 12
-> DATA: 07 E7 04 0C 03 0E 05 02 FF 80 00 00
[Input][DLMS/COSEM] - 12/04/2023 17:05:48.685
Data: [7E A0 2C 03 03 76 69 EE E6 E6 00 C8 1E 30 00 00 00 04 6D D2 9B F9 DB 8C B3 D8 2F 2F A0 9C 8C 09 CD 8F A2 75 DA 94 45 DE 40 F4 70 40 8E 7E]
Title: [CurrentDay]
[Output][DLMS/COSEM] - 12/04/2023 17:05:48.843
Data: [7E A0 31 03 03 96 49 41 E6 E7 00 CC 23 30 00 00 07 69 C2 10 A7 8E 28 3C 43 B5 C8 F1 90 9F 95 EF 2D 6C 3A DE 0D C7 2C E9 BC 30 7E 26 19 B9 5F F8 72 5C 7E]
Title: [CurrentDay]
Data Analyzed:
[Input][DLMS/COSEM] - 12/04/2023 17:05:48.844
Data: [7E A0 2C 03 03 98 19 E0 E6 E6 00 C8 1E 30 00 00 00 05 B8 A4 CA 04 CC C9 4F 84 FD A8 6E E4 CF C3 39 E5 06 15 D3 FE 90 75 3D 6B 24 41 B2 7E]
Title: [DayOfTheWeek]
[Output][DLMS/COSEM] - 12/04/2023 17:05:49.003
Data: [7E A0 31 03 03 B8 35 89 E6 E7 00 CC 23 30 00 00 07 6A 52 CB 93 21 55 FA 1E 8A 1A 88 39 3B D6 5F 2B 94 C9 E8 31 5D 20 05 68 57 A5 D9 C4 5A 1A 9D 71 38 7E]
Data Analyzed:
[Input][DLMS/COSEM] - 12/04/2023 17:05:49.010
Data: [7E A0 2C 03 03 BA 09 E2 E6 E6 00 C8 1E 30 00 00 00 06 AA F6 F0 94 BF BB 5A 40 8F FD EE A4 81 B6 0E 31 98 29 41 54 1A 51 88 AF 11 14 38 7E]
Title: [MeterModel]
Attribute Description: [Class ID:1 | Index:2 | Logical Name:0.0.96.1.137.255]
[Output][DLMS/COSEM] - 12/04/2023 17:05:49.163
Data: [7E A0 2A 03 03 DA 95 CA E6 E7 00 CC 1C 30 00 00 07 6B E2 BD 81 A0 09 05 F5 DF 47 9B F7 04 02 A4 9D B8 2D 40 39 A7 2E D5 0C B8 59 7E]
Title: [MeterModel]
Original Data: [0A 05 31 50 32 4C 33]
Data Analyzed:
-> TYPE: STRING, SIZE: 5
-> DATA: 31 50 32 4C 33
[Input][DLMS/COSEM] - 12/04/2023 17:05:49.164
Data: [7E A0 2C 03 03 DC 39 E4 E6 E6 00 C8 1E 30 00 00 00 07 B4 8A C7 43 64 86 57 53 06 7F 48 1F 1D 5B 42 48 EC 05 93 60 A5 C9 71 6B A6 D9 B7 7E]
Title: [serialNumber]
Attribute Description: [Class ID:1 | Index:2 | Logical Name:0.0.96.1.0.255]
[Output][DLMS/COSEM] - 12/04/2023 17:05:49.339
Data: [7E A0 2D 03 03 FC 80 D9 E6 E7 00 CC 1F 30 00 00 07 6C C8 6F F7 1C 6C 1B DD E0 CE BD 42 30 E2 1B 3D 31 38 E6 02 35 A4 D1 FD 2F 20 9F 7E 73 7E]
Original Data: [0A 08 35 30 30 31 30 37 35 32]
Data Analyzed:
-> TYPE: STRING, SIZE: 8
-> DATA: 35 30 30 31 30 37 35 32
[Input][DLMS/COSEM] - 12/04/2023 17:05:49.341
Data: [7E A0 2C 03 03 FE 29 E6 E6 E6 00 C8 1E 30 00 00 00 08 14 BD 0F A7 10 9F 1E 7E 63 D0 C6 D0 F4 23 73 E4 D6 74 61 0E 37 AD 84 97 1C D2 18 7E]
Title: [VersionOfMeterSoftware]
Attribute Description: [Class ID:1 | Index:2 | Logical Name:1.0.0.2.8.255]
[Output][DLMS/COSEM] - 12/04/2023 17:05:49.514
Data: [7E A0 39 03 03 1E D1 AC E6 E7 00 CC 2B 30 00 00 07 6D AD EB 5A 68 91 AF 52 BF 82 E8 81 BD AF 10 15 DA AC D2 53 54 6E 4E 2A 35 2B BE EE 21 27 2A 29 65 3C CE 74 1E 9E 3E 0A 64 7E]
Original Data: [0A 14 32 33 5A 2E 41 31 2E 46 30 2E 42 52 30 32 2E 56 37 30 31 33]
Data Analyzed:
-> TYPE: STRING, SIZE: 20
-> DATA: 32 33 5A 2E 41 31 2E 46 30 2E 42 52 30 32 2E 56 37 30 31 33
[Input][DLMS/COSEM] - 12/04/2023 17:05:49.515
Data: [7E A0 2C 03 03 10 59 E8 E6 E6 00 C8 1E 30 00 00 00 09 03 74 D6 90 6F 80 43 93 A4 A1 3B A2 03 49 5D A5 10 D0 3D BB 46 25 76 6F D7 5A 8B 7E]
Title: [Adress]
Attribute Description: [Class ID:1 | Index:2 | Logical Name:0.129.128.0.0.255]
[Output][DLMS/COSEM] - 12/04/2023 17:05:49.673
Data: [7E A0 27 03 03 30 4E 09 E6 E7 00 CC 19 30 00 00 07 6E 9A E5 4C 23 59 A1 18 25 D4 DE D5 1B 29 03 3D 9C E3 CB 3F 9B 12 61 7E]
Title: [Adress]
Original Data: [09 02 00 01]
Data Analyzed:
-> TYPE: OCTET_STRING, SIZE: 2
-> DATA: 00 01
[Input][DLMS/COSEM] - 12/04/2023 17:05:49.679
Data: [7E A0 2C 03 03 32 49 EA E6 E6 00 C8 1E 30 00 00 00 0A 0A F1 EF FE 34 D3 D8 DF 99 F3 A4 06 91 0C 24 B9 98 E1 E3 2C 5A D3 CE 13 18 95 B4 7E]
Title: [ResumedInstantValues]
Attribute Description: [Class ID:7 | Index:2 | Logical Name:0.0.21.0.5.255]
[Output][DLMS/COSEM] - 12/04/2023 17:05:49.914
Data: [7E A0 61 03 03 52 77 14 E6 E7 00 CC 53 30 00 00 07 6F 60 A8 67 0D 90 C4 E5 EF 6A 01 0B 68 F6 68 D1 CF 85 AB 76 AB B7 58 40 EC 26 5B 59 19 9A D9 AA BB 08 14 F2 1E 80 38 CD 07 CD D3 B8 8C C5 B0 DD 75 1C 52 19 49 4E 91 3C FC 1A 8A CB 8E 43 98 EB 1A C5 A5 0C 12 7E 0C C9 FD F3 13 31 10 AE DC D1 B9 7E]
Original Data: [01 01 02 0D 09 0C 07 E7 04 0C FF 0E 05 03 00 80 00 00 12 00 DC 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 12 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 06 00 00 00 00 12 03 E8]
Data Analyzed:
-> TYPE: ARRAY, SIZE: 1
-> TYPE: STRUCT, SIZE: 13
-> DATA: 07 E7 04 0C FF 0E 05 03 00 80 00 00
-> TYPE: UINT16
-> DATA: 00 DC
-> TYPE: UINT16
-> DATA: 00 00
-> TYPE: UINT16
-> DATA: 00 00
-> TYPE: UINT16
-> DATA: 00 00
-> TYPE: UINT16
-> DATA: 00 00
-> TYPE: UINT16
-> DATA: 00 00
-> TYPE: UINT16
-> DATA: 00 00
-> TYPE: UINT32
-> DATA: 00 00 00 00
-> TYPE: UINT32
-> TYPE: UINT32
-> TYPE: UINT32
-> TYPE: UINT16
-> DATA: 03 E8
[Input][DLMS/COSEM] - 12/04/2023 17:05:49.916
Data: [7E A0 07 03 03 53 80 D7 7E]
[Output][DLMS/COSEM] - 12/04/2023 17:05:49.977
Data: [7E A0 07 03 03 73 82 F6 7E]
flagr97
3 years 1 month ago
Oh, and removing the -M…
Oh, and removing the -M option returns the error: "Referência de objeto não definida para uma instância de um objeto" (which translates to "Object reference not set to an instance of an object")
3 years 1 month ago
Hi, There is nothing special…
There is nothing special in the official application trace. I believe that you are receiving this exception if the association view is not implemented, but if you add the hex trace I can verify it.
flagr97
3 years 1 month ago
Hi Mikko, How can I get the…
How can I get the hex trace? From the official application, the log that i sent is the most i think I can get. Is is in the DLMSDirector?
3 years 1 month ago
Hi, You should see the hex…
You should see the hex trace when command line argument -t Verbose is added.
Something like this, but remove -M argument:
-S COM3:300:7EvenOne -i HdlcWithModeE -c 1 -a High -P 3030303030303030 -C AuthenticationEncryption -T 4845430005000001 -A 30303030303030303030303030303030 -B 30303030303030303030303030303030 -w 1 -f 128 -t Verbose
ducatilm
2 years 1 month ago
Hi Sir, I would Like to ask…
Hi Sir, I would Like to ask you if you can share the official Hexing program??? I want to connect it to the latest HXE310 M23 meter. I have many communication problems because am newbie , I need also the official software to try.
Thank you.
2 years 1 month ago
Hi, You have not established…
You have not established the connection for the meter. AARQ message is not sent.
Change client address to 1 and authentication to HighGMAC.
Your meter is using a ciphered connection so you need to select "Secured connections" tab and change Security to AuthenticationEncryption and set block cipher and authentication keys.
ducatilm
2 years 1 month ago
Hi, thank you very much for…
Hi, thank you very much for your support!!!. I know that the default pass for that meter is 0000000000000000, but I don't know what is the name on 'System Title' also I don't know the 'block cipher key'. How can I find it??
The meter is brand new and it has the default settings from the factory, when I buy the meters (I have buy 3 of them) from the official Hexing dealer he didn't give any manual or other support document. Also the Hexing official factory support center never respond to my emails.
If you can help me to make correct connection with that meter I will appreciate it.
Regards Lambros
2 years 1 month ago
Hi Lambros, Please, create a…
Hi Lambros,
Please, create a new topic if you have a new question. Now I have answered the wrong question.
You should receive the block cipher key and authentication keys with the meter.
The block cipher and authentication keys can be anything. You need to ask for this information from the meter vendor. I can't help you with that.
