  3. Error: "Not Enough Data"
Error: "Not enough data"
By mansour , 16 November, 2022
We are using the GX DLMSDirector to connect to new meter with LLS level with Serial (HDLC optical probe) and we got this error: "Not enough data"
Above the related logs:
17:53:03 Send SNRM request.
TX: 7E A0 07 03 41 93 5A 64 7E
17:53:03
RX: 7E A0 1F 41 03 73 35 63 81 80 13 05 02 02 00 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 EC CE 7E
17:53:03 Send AARQ request.
TX: 7E A0 44 03 41 10 B3 E1 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 92 4A 7E
17:53:03
RX: 7E A0 25 41 03 30 F6 83 E6 E7 00 61 2A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D C7 17 7E
17:53:03
Thanks in advance.
Best Regards
Mansour
3 years 11 months ago
Hi Mansour,
Hi Mansour,
There is an issue with the meter. You need to ask the meter manufacturer if there is a firmware update available that fixes this. The problem is that the length is wrong on the meter reply.
2A //Invalid length. This should be 17
The meter returns an invalid password error even the data is not complete. I believe it might be the reason for this. Check your password.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
