  3. DLMS Meter Firmware Update Issue Using Gurux DLMS Director UI
DLMS meter Firmware Update issue using Gurux DLMS director UI
By prasanth , 11 October, 2022
Dear Mikko,
We are facing an issue with the Iskra Meter MT880 firmware update.
It is failing with an error “Access Error: other reason”, while trying meter firmware update using Gurux UI.
Scenario,
We have an Iskra DLMS meter MT880. The vendor gave us the module firmware binary file, which is the clone of the current module firmware in the meter.
First of all, we have a doubt; in the gurux UI firmware upload window, it is asking for input firmware identification number.
Is this identifier referring to the meter module firmware version number (Active firmware identifier)? Or it refers to firmware signature (Active firmware signature)? Which identifier do we have to add here?
As it is the clone of the original firmware, we tried to use the same old firmware identifier in the gurux firmware window as below,
Meter original Module firmware Identifier: ISKAMMT880100506.
Uploaded the module firmware file from the local system with the identifier as the existing module firmware version identifier: ISKAMMT880100506
The image transfer was initiated, and after around 10-15 minutes, the image transfer was completed with an error. The error we are getting is “Access Error: other reason,” pls refer to the screenshot attached.
Could you please check and confirm what the issue is? anything wrong we are doing?
The HEX log is attached below for your refernce
GXDLMSDirector 9.0.2210.0401
Log created 8:38:41 AM
08:39:20 Initializing Network connection.
8:39:21 AM Send AARQ request.
00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 32 33 33 32 32 33 33 32 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 20 1E 5D FF FF
8:39:24 AM
00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 20 1E 1D 05 00 00 07
08:39:24 Parsing AARE reply succeeded.
8:39:34 AM Read object type ImageTransfer index: 2
00 01 00 01 00 01 00 0D C0 01 C1 00 12 00 00 2C 00 00 FF 02 00
8:39:35 AM
00 01 00 01 00 01 00 09 C4 01 C1 00 06 00 00 00 80
8:39:35 AM Read object type ImageTransfer index: 3
00 01 00 01 00 01 00 0D C0 01 C1 00 12 00 00 2C 00 00 FF 03 00
8:39:36 AM
00 01 00 01 00 01 01 88 C4 01 C1 00 04 82 0C 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
8:39:36 AM Read object type ImageTransfer index: 4
00 01 00 01 00 01 00 0D C0 01 C1 00 12 00 00 2C 00 00 FF 04 00
8:39:36 AM
00 01 00 01 00 01 00 09 C4 01 C1 00 06 00 00 09 6B
8:39:36 AM Read object type ImageTransfer index: 5
00 01 00 01 00 01 00 0D C0 01 C1 00 12 00 00 2C 00 00 FF 05 00
8:39:37 AM
00 01 00 01 00 01 00 06 C4 01 C1 00 03 01
8:39:37 AM Read object type ImageTransfer index: 6
00 01 00 01 00 01 00 0D C0 01 C1 00 12 00 00 2C 00 00 FF 06 00
8:39:37 AM
00 01 00 01 00 01 00 06 C4 01 C1 00 16 01
8:39:37 AM Read object type ImageTransfer index: 7
00 01 00 01 00 01 00 0D C0 01 C1 00 12 00 00 2C 00 00 FF 07 00
8:39:38 AM
00 01 00 01 00 01 00 06 C4 01 C1 00 01 00
8:40:16 AM Release request
00 01 00 01 00 01 00 05 62 03 80 01 00
8:40:17 AM
00 01 00 01 00 01 00 05 63 03 80 01 00
08:45:42 Initializing Network connection.
8:45:42 AM Send AARQ request.
8:45:44 AM
00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 05 00 00 07
08:45:44 Parsing AARE reply succeeded.
8:45:52 AM Read object type ImageTransfer index: 2
8:45:53 AM
8:45:53 AM Read object type ImageTransfer index: 3
8:45:54 AM
00 01 00 01 00 01 00 06 C4 01 C1 00 04 00
8:45:54 AM Read object type ImageTransfer index: 4
8:45:55 AM
00 01 00 01 00 01 00 09 C4 01 C1 00 06 00 00 00 00
8:45:55 AM Read object type ImageTransfer index: 5
8:45:55 AM
00 01 00 01 00 01 00 06 C4 01 C1 00 03 00
8:45:55 AM Read object type ImageTransfer index: 6
8:45:56 AM
00 01 00 01 00 01 00 06 C4 01 C1 00 16 00
8:45:56 AM Read object type ImageTransfer index: 7
8:45:57 AM
8:46:23 AM Writing object 0.0.44.0.0.255, interface ImageTransfer
00 01 00 01 00 01 00 0F C1 01 C1 00 12 00 00 2C 00 00 FF 05 00 03 01
8:46:24 AM
00 01 00 01 00 01 00 04 C5 01 C1 00
8:46:24 AM Reading object 0.0.44.0.0.255, interface ImageTransfer
8:46:25 AM
8:46:31 AM Read object type ImageTransfer index: 2
8:46:32 AM
8:46:32 AM Read object type ImageTransfer index: 3
8:46:32 AM
8:46:32 AM Read object type ImageTransfer index: 4
8:46:33 AM
8:46:33 AM Read object type ImageTransfer index: 5
8:46:34 AM
8:46:34 AM Read object type ImageTransfer index: 6
8:46:34 AM
8:46:34 AM Read object type ImageTransfer index: 7
8:46:35 AM
8:46:40 AM Release request
8:46:41 AM
08:46:44 Initializing Network connection.
8:46:44 AM Send AARQ request.
8:46:45 AM
08:46:45 Parsing AARE reply succeeded.
8:46:49 AM Read object type ImageTransfer index: 2
8:46:50 AM
8:46:50 AM Read object type ImageTransfer index: 3
8:46:50 AM
8:46:50 AM Read object type ImageTransfer index: 4
8:46:51 AM
8:46:51 AM Read object type ImageTransfer index: 5
8:46:52 AM
8:46:52 AM Read object type ImageTransfer index: 6
8:46:52 AM
8:46:52 AM Read object type ImageTransfer index: 7
8:46:53 AM
8:47:41 AM Read object type Data index: 2
00 01 00 01 00 01 00 0D C0 01 C1 00 01 01 00 00 02 00 FF 02 00
8:47:43 AM
00 01 00 01 00 01 00 16 C4 01 C1 00 09 10 49 53 4B 41 43 4D 54 38 38 30 31 30 30 35 30 30
8:47:48 AM Read object type Data index: 2
00 01 00 01 00 01 00 0D C0 01 C1 00 01 01 00 00 02 08 FF 02 00
8:47:49 AM
00 01 00 01 00 01 00 16 C4 01 C1 00 09 10 D8 24 2D 56 59 2F F6 5F DD EF 28 D8 49 59 19 D6
8:47:58 AM Read object type Data index: 2
00 01 00 01 00 01 00 0D C0 01 C1 00 01 01 01 00 02 00 FF 02 00
8:48:00 AM
00 01 00 01 00 01 00 16 C4 01 C1 00 09 10 49 53 4B 41 4D 4D 54 38 38 30 31 30 30 35 30 36
8:48:02 AM Read object type Data index: 2
00 01 00 01 00 01 00 0D C0 01 C1 00 01 01 01 00 02 08 FF 02 00
8:48:05 AM
00 01 00 01 00 01 00 16 C4 01 C1 00 09 10 15 4E EE C3 CB C0 50 31 4C DD 66 36 20 FB 2D 60
8:49:55 AM Send Keep Alive
00 01 00 01 00 01 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 01 00
8:49:56 AM
00 01 00 01 00 01 00 0C C4 01 C1 00 09 06 00 00 28 00 00 FF
8:51:45 AM Send Keep Alive
8:51:46 AM
8:53:35 AM Send Keep Alive
8:53:36 AM
8:55:25 AM Send Keep Alive
8:55:26 AM
8:55:49 AM Read object type ImageTransfer index: 2
8:55:50 AM
8:55:50 AM Read object type ImageTransfer index: 3
8:55:51 AM
8:55:51 AM Read object type ImageTransfer index: 4
8:55:52 AM
8:55:52 AM Read object type ImageTransfer index: 5
8:55:53 AM
8:55:53 AM Read object type ImageTransfer index: 6
8:55:53 AM
8:55:53 AM Read object type ImageTransfer index: 7
8:55:54 AM
8:57:01 AM Reading object 0.0.44.0.0.255, interface ImageTransfer
8:57:03 AM
8:57:03 AM Reading object 0.0.44.0.0.255, interface ImageTransfer
8:57:03 AM
8:57:04 AM
8:57:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 26 C3 01 C1 00 12 00 00 2C 00 00 FF 01 01 02 02 09 10 49 53 4B 41 4D 4D 54 38 38 30 31 30 30 35 30 36 06 00 05 6F 90
8:57:05 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
8:57:05 AM Reading object 0.0.44.0.0.255, interface ImageTransfer
8:57:05 AM
8:57:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 00 09 81 80 49 53 4B 2D 49 4D 47 2D 43 4F 4D 2D 49 53 4B 00 51 40 06 00 70 6F 07 00 00 00 02 00 90 6F 07 00 00 3B 00 10 0C A9 00 10 00 00 00 00 01 20 70 47 70 47 F0 B5 AD B0 04 46 0E 46 15 46 40 2A 0D D9 10 A8 E3 F7 B5 FA 2A 46 31 46 10 A8 E4 F7 ED FA 27 A9 10 A8 E4 F7 21 FB 27 AE 14 25 40 21 68 46 E1 F7 3B F9 04 F1 5C 00 40 21 07 46 E1 F7 35 F9 2A 46 31 46 68 46 E1 F7 93 F8 2A 46 31 46 38 46
8:57:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 01 09 81 80 E1 F7 8E F8 00 21 68 46 42 5C 82 F0 36 02 42 54 62 18 49 1C 12 F8 5C 3F 40 29 83 F0 5C 03 13 70 F2 D3 20 46 E3 F7 84 FA 40 22 69 46 20 46 E4 F7 BC FA 2D B0 F0 BD E4 F7 B8 BA 70 B5 04 46 0D 46 E4 F7 EB FA 20 46 E3 F7 73 FA 40 22 04 F1 5C 01 20 46 E4 F7 AA FA 14 22 29 46 20 46 E4 F7 A5 FA 29 46 20 46 BD E8 70 40 E4 F7 D7 BA 70 B5 14 46 A8 B0 0A 46 01 46 1D 46 68 46 2C 9E FF F7 99 FF
8:57:07 AM
8:57:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 02 09 81 80 2A 46 21 46 68 46 FF F7 D6 FF 31 46 68 46 FF F7 D4 FF 28 B0 70 BD 00 00 2D E9 FF 4F B3 B0 11 46 98 46 DD E9 41 20 DD F8 00 91 33 9B EB B1 34 9B DB B1 D1 B1 B8 F1 00 0F 17 D0 B8 F1 80 0F 14 D8 9A B1 90 B1 14 25 43 1E B3 FB F5 F7 7F 1C C7 F1 01 03 03 FB 05 00 93 46 30 90 42 46 01 A8 E1 F7 1F F8 01 24 0D F1 90 0A 3E E0 01 20 37 B0 BD E8 F0 8F 14 21 29 A8 E1 F7 B0 F8 01 26 17 E0 01 2E
8:57:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 03 09 81 80 1B D0 2B 46 24 AA CD F8 00 A0 00 BF DD E9 33 01 FF F7 AC FF 00 20 52 46 29 A9 12 F8 00 C0 0B 5C 83 EA 0C 03 0B 54 40 1C A8 42 F6 D3 76 1C 4E 45 E5 D9 BC 42 11 D1 30 9A 10 E0 01 A8 22 0E 00 F8 08 20 40 44 21 0C 41 70 21 0A 81 70 C4 70 08 F1 04 03 01 AA CD F8 00 A0 D8 E7 2A 46 29 A9 58 46 E0 F7 DE FF AB 44 64 1C BC 42 C2 D9 00 20 BD E7 10 B5 4F F4 0D 71 E1 F7 70 F8 00 20 10 BD 70 B5
8:57:08 AM
8:57:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 04 09 81 80 05 46 0E 46 14 46 10 2A 03 D0 18 2C 01 D0 20 2C 13 D1 28 1D E0 F7 C4 FF E2 00 00 23 31 46 05 F1 50 00 2C 60 E2 F7 DE FC 38 B1 E8 6C 20 F0 0A 00 40 F0 01 00 E8 64 00 20 70 BD 01 20 70 BD 2D E9 F0 41 04 46 C0 6C C3 07 05 D0 43 07 04 F1 14 00 0C D5 10 2A 02 D0 01 20 BD E8 F0 81 10 22 E0 F7 9F FF E0 6C 40 F0 02 00 E0 64 13 E0 00 22 15 46 63 6C 8F 5C 1E 5C 7E 40 1E 54 63 6C 5B 1C 63 64
8:57:09 AM
8:57:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 05 09 81 80 10 2B 04 D1 65 64 E3 6C 43 F0 02 03 E3 64 52 1C 10 2A ED D3 00 20 DF E7 C1 6C CA 07 04 D0 41 F0 04 01 C1 64 00 20 70 47 01 20 70 47 10 B5 C2 6C 52 07 01 D4 01 20 10 BD 10 22 24 30 E0 F7 70 FF 00 20 10 BD 38 B5 05 46 00 F1 24 04 68 46 E8 F7 86 FC 9D F8 00 00 20 70 9D F8 01 00 60 70 9D F8 02 00 A0 70 9D F8 03 00 E0 70 E8 F7 87 FC 00 90 9D F8 00 00 20 71 9D F8 01 00 60 71 9D F8 02 00
8:57:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 06 09 81 80 A0 71 9D F8 03 00 E0 71 A8 6C 00 90 9D F8 00 00 20 72 9D F8 01 00 60 72 9D F8 02 00 A0 72 9D F8 03 00 E0 72 00 20 20 73 60 73 A0 73 E0 73 A8 6C 40 1C A8 64 00 20 38 BD 2D E9 F0 47 04 46 C0 6C 88 46 8C B0 17 46 C1 07 01 D0 80 07 03 D4 01 20 0C B0 BD E8 F0 87 04 F1 24 0A 08 AD 04 AE 04 F1 50 09 E0 6C 40 07 02 D4 20 46 FF F7 AB FF 08 AA 51 46 48 46 E2 F7 43 FC 00 20 22 18 29 5C 12 7D
8:57:10 AM
8:57:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 07 09 81 80 51 40 31 54 40 1C 10 28 F7 DB 6A 46 04 A9 48 46 E2 F7 35 FC 00 20 69 46 2B 5C 0A 5C 5A 40 32 54 40 1C 10 28 F8 DB 04 F1 14 02 04 A9 48 46 E2 F7 26 FC 9D E8 0F 00 04 F1 34 0C AC E8 0F 00 E0 6C 01 07 04 D4 40 F0 08 00 E0 64 40 07 C9 D5 10 2F 06 D8 3A 46 69 46 40 46 E0 F7 E2 FE 00 20 B7 E7 10 22 69 46 40 46 E0 F7 DB FE 08 F1 10 08 10 3F B7 E7 10 B5 11 48 FF F7 FB FE 08 B1 01 20 10 BD
8:57:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 08 09 81 80 10 22 0F 49 0D 48 FF F7 FA FE 0D 49 10 22 10 31 0A 48 FF F7 14 FF 00 20 10 BD 0A 46 01 46 07 48 ED E6 0A 46 01 46 05 48 09 E7 01 46 03 48 3D E7 0A 46 01 46 01 48 7F E7 00 20 70 47 00 3B 00 10 F8 40 06 00 70 B5 15 46 04 46 04 9A 00 F5 F2 70 80 2B 0F D0 4F F4 80 76 B3 42 12 D1 13 46 32 46 E2 F7 C0 FB 00 23 32 46 29 46 20 46 E2 F7 BA FB 00 20 70 BD 13 46 80 22 E2 F7 B4 FB 00 23 80 22
8:57:11 AM
8:57:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 09 09 81 80 F2 E7 01 20 70 BD 10 B5 00 22 11 46 44 5C 02 EB 44 02 42 54 E3 09 49 1C 1A 46 10 29 F6 D3 00 2A 03 D0 01 78 81 F0 87 01 01 70 10 BD 70 B5 15 46 1E 46 00 24 0A 5D 33 5D 5A 40 2A 55 64 1C 10 2C F8 D3 2A 46 11 46 00 F5 F2 70 E2 F7 98 FB 00 24 28 5D 31 5D 48 40 28 55 64 1C 10 2C F8 D3 30 46 FF F7 D1 FF 00 20 70 BD 70 B5 15 46 1E 46 00 24 0A 5D 33 5D 5A 40 2A 55 64 1C 10 2C F8 D3 2A 46
8:57:12 AM
8:57:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 0A 09 81 80 11 46 00 F5 F2 70 E2 F7 83 FB 00 24 28 5D 31 5D 48 40 28 55 64 1C 10 2C F8 D3 30 46 FF F7 B3 FF 00 20 70 BD 2D E9 F0 43 8D B0 0E 46 14 A9 81 46 B1 E8 09 01 14 09 02 F0 0F 05 11 D0 05 B1 64 1E 00 21 6A 46 50 54 00 0A 40 EA 03 60 1B 0A 49 1C 10 29 F7 D3 11 46 48 46 E2 F7 51 FB 00 27 0F E0 01 20 0D B0 BD E8 F0 83 6B 46 42 46 31 46 48 46 FF F7 9C FF 01 28 F4 D0 10 36 08 F1 10 08 7F 1C
8:57:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 0B 09 81 80 A7 42 F1 D3 15 B3 6B 46 08 AA 31 46 48 46 FF F7 8D FF 01 28 E5 D0 00 20 04 A9 08 AA 07 E0 33 18 1B 7C 0B 54 14 5C 08 EB 00 03 40 1C 1C 74 A8 42 F5 D3 02 E0 13 5C 0B 54 40 1C 10 28 FA D3 6B 46 42 46 48 46 FF F7 72 FF 01 28 CA D0 00 20 C8 E7 2D E9 F0 43 8D B0 0E 46 14 A9 81 46 B1 E8 09 01 14 09 02 F0 0F 05 11 D0 05 B1 64 1E 00 21 6A 46 50 54 00 0A 40 EA 03 60 1B 0A 49 1C 10 29 F7 D3
8:57:13 AM
8:57:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 0C 09 81 80 11 46 48 46 E2 F7 FB FA 00 27 0D E0 01 20 A8 E7 6B 46 42 46 31 46 48 46 FF F7 66 FF 01 28 A0 D0 10 36 08 F1 10 08 7F 1C A7 42 F1 D3 55 B3 9D E8 0F 00 04 AC 0F C4 04 A8 FF F7 25 FF 04 AB 08 AA 31 46 48 46 FF F7 50 FF 01 28 8A D0 00 20 08 A9 04 AA 07 E0 33 18 1B 7C 13 54 0C 5C 08 EB 00 03 40 1C 1C 74 A8 42 F5 D3 02 E0 0B 5C 13 54 40 1C 10 28 FA D3 6B 46 42 46 04 A9 48 46 FF F7 34 FF
8:57:14 AM
8:57:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 0D 09 81 80 01 28 C4 D0 00 20 6C E7 10 B5 00 21 F7 4B 08 46 01 E0 39 29 09 DA 01 EB C1 02 02 EB 01 12 03 EB C2 04 C8 34 43 F8 32 40 05 E0 01 EB C1 02 02 EB 01 12 43 F8 32 00 01 EB C1 02 02 EB 01 12 03 EB C2 02 02 F1 10 04 C2 E9 01 04 90 81 49 1C 90 73 09 B2 D0 73 3A 29 DC DB E4 49 E4 4A 0C 39 08 3A 0B 60 3A 21 11 80 01 21 22 F8 11 00 49 1C 09 B2 03 29 F9 DB D0 80 01 20 10 BD DC 4A 0C 3A 11 1D
8:57:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 0E 09 81 80 10 68 90 B1 03 68 13 60 00 22 00 F1 10 03 02 60 C0 E9 01 23 82 81 01 23 83 73 C2 73 0A 88 52 1E 0A 80 4A 88 52 1C 4A 80 70 47 C8 88 40 1C C8 80 00 20 70 47 CD 4A 0C 3A 11 1D 10 68 A0 B1 03 68 13 60 00 22 00 F1 18 03 02 60 C0 E9 01 23 82 81 82 82 02 22 82 73 01 22 C2 73 0A 88 52 1E 0A 80 8A 88 52 1C 8A 80 70 47 C8 88 40 1C C8 80 00 20 70 47 10 B5 F0 B1 BD 49 88 42 1B D3 BC 49 88 42
8:57:15 AM
8:57:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 0F 09 81 80 18 D8 81 7B B1 B1 B9 4A 08 3A 32 F8 11 30 5B 1E 22 F8 11 30 00 21 03 68 81 73 14 88 64 1C 14 80 12 1F 14 68 04 60 10 60 41 60 81 60 81 81 C1 73 18 46 10 BD 00 20 10 BD 00 B5 00 28 04 D0 00 BF FF F7 D7 FF 00 28 FB D1 00 BD 2D E9 F0 41 15 46 B8 B1 A6 4A 90 42 14 D3 A5 4A 90 42 11 D8 00 26 98 46 04 46 00 29 0C DB 5D B1 07 E0 4C B1 B4 F9 0C 00 88 42 1D DC 08 1A 24 68 01 B2 00 29 F5 DC
8:57:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 10 09 81 80 17 E0 00 20 BD E8 F0 81 AC B1 B4 F9 0C 00 40 1A A8 42 00 DB 28 46 07 B2 A0 68 3A 46 01 44 40 46 E0 F7 BE FC E8 1B 05 B2 F0 19 24 68 B8 44 06 B2 00 21 00 2D E8 DC 00 2E 30 46 E3 E7 2D E9 F0 5F 5F EA 00 08 4F F0 00 06 0F 46 15 46 9A 46 B3 46 44 46 47 D0 85 49 88 45 44 D3 85 49 88 45 41 D8 30 E0 39 1A 0F B2 31 18 0E B2 21 68 49 BB A1 68 08 44 21 1A C6 31 89 B2 A9 42 00 DB 29 46 09 B2
8:57:16 AM
8:57:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 11 09 81 80 5F EA 01 09 12 D0 0A 46 51 46 E0 F7 89 FC 0B EB 09 00 0F FA 80 FB A5 EB 09 00 05 B2 06 EB 09 00 A1 89 06 B2 01 EB 09 00 CA 44 A0 81 00 2D 6D D0 FF F7 23 FF 58 B1 E9 19 B6 29 00 D9 B6 21 81 81 20 60 24 68 B4 F9 0C 00 B8 42 CA DB 5C E0 98 F8 0F 10 40 46 C9 07 05 D0 B0 F9 14 10 B1 42 01 DA A8 F8 14 60 00 20 BD E8 F0 9F 00 BF B4 F9 0C 00 C0 1B A8 42 00 DB 28 46 0F FA 80 F9 B9 F1 00 0F
8:57:17 AM
8:57:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 12 09 81 80 0D D0 A0 68 4A 46 38 44 51 46 E0 F7 49 FC 0B EB 09 00 0F FA 80 FB A5 EB 09 00 CA 44 05 B2 09 EB 07 00 30 44 00 27 06 B2 85 B3 20 68 58 BB B4 F9 0C 10 A0 68 08 44 21 1A C6 31 89 B2 A9 42 00 DB 29 46 09 B2 5F EA 01 09 13 D0 0A 46 51 46 E0 F7 27 FC 0B EB 09 00 0F FA 80 FB A5 EB 09 00 05 B2 06 EB 09 00 A1 89 06 B2 01 EB 09 00 CA 44 A0 81 65 B1 FF F7 C2 FE 48 B1 B6 2D 01 D9 B6 21 00 E0
8:57:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 13 09 81 80 29 46 81 81 20 60 04 46 00 2D AF DC 98 F8 0F 10 40 46 C9 07 05 D0 B0 F9 14 10 B1 42 01 DA A8 F8 14 60 58 46 9F E7 2D E9 F0 47 05 46 89 46 04 00 05 D0 2E 48 85 42 02 D3 2D 48 85 42 03 D9 00 20 BD E8 F0 87 04 46 20 68 00 28 FB D1 90 46 4F 46 1B E0 00 BF B4 F9 0C 10 A0 68 08 44 21 1A C6 31 0E B2 BE 42 00 DB 3E 46 4E B1 32 46 41 46 E0 F7 D7 FB B8 1B 07 B2 A0 89 B0 44 30 44 A0 81 37 B1
8:57:18 AM
8:57:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 14 09 81 80 FF F7 7B FE 18 B1 20 60 04 46 00 2F E2 DC E9 7B A9 EB 07 00 00 B2 C9 07 D2 D0 A9 8A 01 44 A9 82 CE E7 30 B5 04 00 0D 46 05 D0 10 48 84 42 02 D3 0F 48 84 42 01 D9 00 20 30 BD E1 7B C8 07 A0 68 A0 EB 04 00 01 D0 18 38 00 E0 10 38 A8 42 06 DB A0 68 40 1B A0 60 A0 89 28 44 A0 81 2D E0 C8 07 08 D0 AE 2D 31 D8 FF F7 65 FE 07 E0 0C 10 00 20 94 3C 00 20 B6 2D 28 D8 FF F7 3F FE 28 B3 E1 7B
8:57:19 AM
8:57:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 15 09 81 80 C9 07 17 D0 D4 E9 04 12 C0 E9 04 12 E1 7B 01 F0 33 01 C1 73 00 F1 18 01 81 60 E1 7B 21 F0 01 01 E1 73 01 21 A1 73 D6 49 8A 88 52 1E 8A 80 4A 88 52 1C 4A 80 04 60 04 46 85 81 E0 7B C0 07 02 D0 A0 8A 28 44 A0 82 20 46 30 BD 20 46 FF F7 74 FE B1 E7 70 B5 30 B1 CA 4A 08 32 90 42 02 D3 C9 4A 90 42 01 D9 00 20 70 BD 4F F0 00 04 0B 1E 02 46 25 46 15 DA 1E E0 00 BF B2 F9 0C 60 9E 42 06 DC
8:57:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 16 09 81 80 9B 1B 34 44 95 81 1B B2 24 B2 12 68 07 E0 F6 1A 96 81 1C 44 96 68 24 B2 33 44 93 60 00 23 0A B1 00 2B E9 DC C2 7B D2 07 3C D0 82 8A C9 1A 51 1A 81 82 37 E0 49 42 0B B2 00 21 96 89 31 44 16 68 09 B2 0E B1 32 46 F8 E7 B2 F9 0C 60 9E 42 0B DB F1 1A 91 81 E1 18 C2 7B 09 B2 D2 07 02 D0 82 8A D2 1A 82 82 08 46 70 BD C9 1A E2 18 09 B2 14 B2 00 29 02 DA 21 44 0C B2 00 21 C2 7B D2 07 0A D0
8:57:20 AM
8:57:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 17 09 81 80 81 82 08 E0 B0 F9 0C 20 8A 42 01 DB 81 81 06 E0 89 1A 00 68 09 B2 00 28 F4 D1 00 E0 85 81 00 68 00 28 FB D1 20 46 70 BD 2D E9 F0 41 04 00 0E 46 06 D0 93 48 08 30 84 42 02 D3 92 48 84 42 01 D9 00 20 1F E6 A0 68 81 19 04 F1 C6 00 81 42 0D D2 20 68 58 B1 B4 F9 0C 10 B1 42 01 DB 20 46 11 E6 25 46 04 46 A8 89 30 1A 06 B2 28 E0 AE 2E 31 D8 E0 7B C0 07 02 D0 FF F7 9D FD 01 E0 FF F7 7D FD
8:57:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 18 09 81 80 05 00 27 D0 00 20 A8 81 E0 7B C0 07 17 D0 D4 E9 04 01 C5 E9 04 01 E0 7B 00 F0 33 00 E8 73 05 F1 18 00 A8 60 E0 7B 20 F0 01 00 E0 73 01 20 A0 73 73 48 81 88 49 1E 81 80 41 88 49 1C 41 80 A9 89 A8 68 08 44 28 1A C6 30 0F FA 80 F8 28 2E 05 DD 31 46 04 E0 20 46 FF F7 AF FD B1 E7 28 21 40 46 41 45 04 DA 28 2E 01 DD 30 46 00 E0 28 20 B4 F9 0C 70 B8 42 0E DA 28 2E 01 DD 31 46 00 E0 28 21
8:57:21 AM
8:57:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 19 09 81 80 40 46 41 45 05 DA 28 2E 01 DD 37 46 02 E0 28 27 00 E0 07 46 B5 F9 0C 10 A8 68 3A 46 08 44 A1 68 E0 F7 7E FA F0 1B 06 B2 A8 89 A8 EB 07 01 38 44 A8 81 A0 89 0F FA 81 F8 C0 1B 00 B2 A0 81 18 B1 A0 68 38 44 A0 60 03 E0 20 46 FF F7 52 FD 04 46 00 2E 05 DD 00 2C B9 D1 28 46 FF F7 4A FD B9 E7 28 46 2C 60 8E E5 10 B5 04 00 06 D0 44 48 08 30 84 42 02 D3 43 48 84 42 01 D9 00 20 10 BD 20 68
8:57:22 AM
8:57:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 1A 09 81 80 FF F7 5A FD 00 20 20 60 A0 81 E1 7B C9 07 00 D0 A0 82 01 20 10 BD 40 B1 39 49 08 31 88 42 04 D3 38 49 88 42 01 D8 01 20 70 47 00 20 70 47 00 B5 03 46 FF F7 F0 FF 00 28 15 D0 D8 7B C1 07 B3 F9 0C 10 03 F1 C6 00 07 D0 AE 29 0B D8 99 68 18 33 06 E0 81 42 06 D2 07 E0 B6 29 03 D8 99 68 10 33 99 42 F6 D2 00 20 00 BD 01 20 00 BD 30 B5 24 48 00 24 00 1F 03 68 0A E0 18 46 FF F7 CC FF D8 B1
8:57:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 1B 09 81 80 98 89 C8 B9 98 7B B8 B9 64 1C 1B 68 A4 B2 00 2B F2 D1 1B 48 00 88 A0 42 0E D1 19 4D 00 24 08 35 04 EB C4 00 00 EB 04 10 05 EB C0 00 81 7B 49 B1 01 29 03 D0 02 29 01 D0 00 20 30 BD FF F7 B7 FF 00 28 FA D0 64 1C A4 B2 3A 2C E9 D3 01 20 30 BD 01 20 70 47 30 B1 0A 49 08 31 88 42 02 D3 09 49 88 42 02 D9 00 20 70 47 08 46 41 68 00 29 FB D1 70 47 03 48 00 88 70 47 01 48 C0 88 70 47 00 00
8:57:23 AM
8:57:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 1C 09 81 80 04 10 00 20 94 3C 00 20 30 B5 85 B0 0D 46 14 46 69 46 E4 F7 62 FB 20 B1 00 21 61 80 21 80 05 B0 30 BD 03 98 A8 42 01 D3 20 80 09 E0 01 28 06 D0 A0 F1 01 00 25 EA 00 05 03 98 28 44 F4 E7 25 80 04 98 80 07 03 D5 01 20 60 80 20 88 03 E0 02 20 60 80 20 88 40 00 A0 80 00 20 E0 E7 03 28 01 D2 39 29 01 D3 0C 20 70 47 6B 23 58 43 FE 4B 03 EB C0 00 40 5C 10 70 00 20 70 47 30 B5 85 B0 14 46
8:57:24 AM
8:57:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 1D 09 81 80 05 46 04 AA FF F7 EA FF 00 28 C8 D1 6A 46 9D F8 10 10 28 46 E4 F7 2E FB 00 28 C0 D1 01 98 20 60 00 20 BC E7 0A 46 08 21 AE E7 01 68 49 1C 06 D0 C0 88 C0 F3 06 00 39 28 01 D2 01 20 70 47 00 20 70 47 70 B5 86 B0 0E 46 14 46 05 46 69 46 FF F7 E9 FF 00 B2 00 28 24 D1 02 AA 31 46 28 46 E4 F7 09 FB 00 B2 00 28 1C D1 BD F8 02 00 01 28 0E D0 BD F8 00 10 03 98 08 23 01 44 22 46 28 46 E4 F7
8:57:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 1E 09 81 80 4F FB 00 B2 00 28 0C D1 20 68 40 1C 08 D1 08 23 22 46 28 46 03 99 E4 F7 43 FB 00 B2 00 28 00 D1 00 20 06 B0 70 BD 38 B5 15 46 04 46 6A 46 FF F7 95 FF 00 28 06 D1 2A 46 9D F8 00 10 20 46 FF F7 C0 FF 00 28 38 BD 0A 46 04 21 5D E7 F0 B5 89 B0 0F 46 15 46 1C 46 06 46 03 A9 E4 F7 BE FA 00 28 02 D1 FF 2D 02 D9 0C 20 09 B0 F0 BD 69 46 30 46 FF F7 98 FF 00 28 F7 D1 04 F1 08 01 30 46 FF F7
8:57:25 AM
8:57:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 1F 09 81 80 E2 FF 00 28 F0 D1 02 AA 39 46 30 46 FF F7 75 FF 00 28 E9 D1 BD F8 04 00 A1 89 05 FB 01 01 02 98 01 44 C4 E9 00 01 00 20 DE E7 F0 B5 87 B0 1C 46 07 46 6B 46 0C 9D FF F7 C9 FF 00 28 2B D1 04 23 05 AA 38 46 01 99 E4 F7 EB FA 00 28 23 D1 BD F8 14 00 4F F6 FF 71 88 42 03 D1 00 20 20 60 29 80 18 E0 28 80 BD F8 0A 00 01 25 02 26 01 28 0A D0 BD F8 08 10 01 98 04 23 01 44 05 AA 38 46 E4 F7
8:57:26 AM
8:57:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 20 09 81 80 CF FA 00 28 07 D1 BD F8 16 00 80 07 01 D4 26 60 00 E0 25 60 00 20 07 B0 F0 BD 03 28 01 D2 39 29 01 D3 00 20 70 47 6B 22 50 43 8F 4A C1 EB C1 01 02 EB C0 00 00 EB 41 00 3A 30 70 47 F0 B5 8B B0 0F 46 15 46 06 46 06 A9 E4 F7 47 FA 00 28 29 D1 39 46 30 46 FF F7 E1 FF 04 00 25 D0 6B 20 82 49 70 43 01 EB C0 00 6A 46 C1 5D 30 46 E4 F7 42 FA 00 28 17 D1 04 A9 30 46 FF F7 14 FF 00 28 11 D1
8:57:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 21 09 81 80 01 20 60 81 02 98 40 1E 20 80 4F F6 FF 70 E0 80 20 81 A8 88 60 80 BD F8 14 00 A0 80 E8 88 40 0B 20 73 00 20 0B B0 F0 BD 0C 20 FB E7 F8 B5 04 46 81 78 00 88 FF F7 B1 FF 07 00 2B D0 A0 88 4F F6 FF 75 00 26 A8 42 27 D1 A1 78 20 88 E2 1C FF F7 C5 FE 00 B2 00 28 1E D1 E1 78 20 88 04 F1 24 02 E4 F7 08 FA 00 B2 00 28 15 D1 A6 80 32 46 A1 78 20 88 04 F1 34 03 FF F7 29 FF 00 B2 00 28 0A D1
8:57:27 AM
8:57:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 22 09 81 80 65 81 25 82 E5 82 65 82 25 83 A5 82 65 83 A6 81 E6 81 08 E0 0C 20 F8 BD B4 F8 40 20 A1 6B 40 1C 11 44 A1 63 A0 80 D4 E9 0D 10 40 1A B9 88 80 B2 81 42 24 D9 E1 6A 81 42 21 D9 B4 F8 40 10 08 44 61 89 88 42 1B D8 A0 1D 00 90 A2 88 A1 78 20 88 04 F1 1C 03 FF F7 29 FF 00 B2 00 28 DB D1 E1 69 19 B1 E0 88 E2 6A 90 42 09 D2 E0 88 7A 88 90 42 07 D8 26 62 B9 B1 E2 8A 07 E0 90 42 07 D9 1D 20
8:57:28 AM
8:57:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 23 09 81 80 F8 BD 01 22 22 62 71 B1 22 8B AA 42 F5 D1 62 89 AA 42 01 D0 82 42 00 D9 60 81 22 6A 2A B1 62 8A AA 42 0B D0 0E E0 26 81 26 E0 22 8A AA 42 07 D1 7A 88 AA 42 02 D0 12 1A 52 1C 05 E0 E2 6A 02 E0 E2 8A 00 E0 22 8B 12 1A 22 81 01 29 0A D0 A1 89 92 B2 11 44 A1 81 79 88 88 42 A1 88 0A D8 21 82 E0 82 09 E0 E1 89 92 B2 11 44 E1 81 A1 88 A1 82 60 83 F0 E7 61 82 20 83 00 20 F8 BD 30 B5 04 88
8:57:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 24 09 81 80 4F F6 FF 75 AC 42 03 D1 00 20 10 60 1D 80 0D E0 1C 80 4C 89 01 21 02 23 01 2C 04 D0 C0 88 80 07 03 D4 13 60 02 E0 40 88 F9 E7 11 60 00 20 30 BD 2D E9 F0 47 04 46 81 78 C0 B0 00 88 FF F7 ED FE 05 00 35 D0 A1 78 20 88 E2 1C FF F7 07 FE 00 B2 00 28 2E D1 E1 78 20 88 04 F1 24 02 E4 F7 4A F9 00 B2 00 28 25 D1 01 E0 34 3D 00 10 00 26 A6 80 04 F1 34 03 32 46 A1 78 20 88 9A 46 FF F7 66 FE
8:57:29 AM
8:57:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 25 09 81 80 00 B2 00 28 15 D1 4F F6 FF 79 A4 F8 0A 90 A4 F8 10 90 A4 F8 16 90 A4 F8 12 90 A4 F8 18 90 A4 F8 14 90 A4 F8 1A 90 A6 81 E6 81 B0 46 AF 88 8D E0 0C 20 40 B0 BD E8 F0 87 FF 2F 01 D8 3E 46 01 E0 4F F4 80 76 B0 42 2E D8 20 88 33 46 6A 46 A1 6B E4 F7 66 F9 00 B2 00 28 EB D1 84 46 72 E0 00 BF D4 E9 0D 10 40 1A A9 88 80 B2 81 42 1B D9 E1 6A 81 42 18 D9 0D EB 0C 00 A3 1D 04 F1 1C 02 51 46
8:57:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 26 09 81 80 FF F7 7C FF E3 69 1B B1 E0 88 E1 6A 88 42 0A D2 E0 88 69 88 88 42 08 D8 C4 F8 20 80 C3 B1 E1 8A 07 E0 88 42 07 D9 1D 20 C3 E7 01 21 21 62 7B B1 21 8B 49 45 F5 D1 62 89 49 46 8A 42 01 D0 82 42 00 D9 60 81 22 6A 32 B1 62 8A 4A 45 0C D0 0F E0 A4 F8 08 80 26 E0 22 8A 8A 42 07 D1 6A 88 4A 45 02 D0 11 1A 49 1C 05 E0 E1 6A 02 E0 E1 8A 00 E0 21 8B 09 1A 21 81 01 2B 0A D0 A1 89 22 89 11 44
8:57:30 AM
8:57:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 27 09 81 80 A1 81 69 88 88 42 A1 88 0A D8 21 82 E0 82 09 E0 E1 89 22 89 11 44 E1 81 A1 88 A1 82 60 83 F0 E7 61 82 20 83 B4 F8 40 00 A1 6B 01 44 A1 63 A1 88 49 1C A1 80 00 EB 0C 01 1F FA 81 FC 31 1A 38 1A 8E B2 87 B2 B4 F8 40 00 B0 42 89 D9 B4 F8 40 00 B8 42 7F F6 71 AF 00 20 6B E7 2D E9 F0 47 8C B0 82 46 FF 22 08 21 68 46 E0 F7 CB FC 06 A9 50 46 E4 F7 73 F8 00 28 03 D1 0A 98 C0 07 02 D0 1A 20
8:57:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 28 09 81 80 0C B0 57 E7 50 46 E4 F7 9A F8 00 28 F8 D1 08 98 39 28 01 D9 39 24 04 E0 04 46 17 28 01 D2 06 20 EE E7 00 25 FF 27 6B 21 0A FB 01 F0 FF 49 A8 46 4F F6 FF 79 01 EB C0 06 31 E0 00 BF A4 F1 16 00 85 42 AD F8 04 90 BD F8 06 00 CD F8 00 80 06 D2 65 F3 06 00 20 F4 60 40 00 F5 00 50 05 E0 20 F4 60 40 40 F0 7F 00 00 F5 40 40 AD F8 06 00 02 AA 29 46 50 46 E4 F7 3E F8 00 28 C1 D1 08 23 6A 46
8:57:31 AM
8:57:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 29 09 81 80 50 46 03 99 E4 F7 79 F8 00 B1 77 55 E9 B2 71 55 6A 46 50 46 FF F7 D2 FD 00 28 B1 D1 6D 1C A5 42 CC D3 01 E0 37 55 64 1C 39 2C FB D3 00 20 A7 E7 E4 F7 51 B8 2D E9 F0 4F B7 B0 82 46 FF 22 08 21 14 A8 E0 F7 5E FC 30 A9 50 46 E4 F7 06 F8 00 28 03 D1 34 98 C0 07 03 D0 1A 20 37 B0 BD E8 F0 8F 32 98 39 28 01 D9 39 24 04 E0 04 46 17 28 01 D2 06 20 F2 E7 A4 F1 16 00 C0 B2 35 90 00 20 FF 21
8:57:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 2A 09 81 80 CA 4B 6B 25 0A FB 05 F2 03 EB C2 05 88 46 29 54 40 1C 39 28 FA D3 00 20 4F F6 FF 77 C0 EB C0 01 05 EB 41 01 40 1C CF 87 39 28 F7 D3 2E A9 50 46 FF F7 B8 FC 00 28 D0 D1 FF 22 39 21 68 46 E0 F7 20 FC 4F F0 00 0B 5E 46 66 E0 F1 B2 14 AA 50 46 16 91 FF F7 B6 FC 00 28 BF D1 BD F8 56 00 01 21 B1 EB 50 3F 18 D1 C0 F3 06 00 39 28 20 D2 2A 5C FF 2A 01 D0 02 20 1C E0 16 9A 2A 54 C0 EB C0 00
8:57:32 AM
8:57:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 2B 09 81 80 05 EB 40 00 80 F8 46 10 BD F8 54 10 81 87 35 98 40 1E C0 B2 35 90 0D E0 06 21 B1 EB 50 3F 07 D1 16 98 0D F8 0B 00 0B F1 01 00 00 F0 FF 0B 01 E0 01 20 81 46 E9 F7 C3 F8 40 05 2C D4 B9 F1 00 0F 29 D0 17 AA 31 46 50 46 E3 F7 94 FF 00 28 84 D1 32 46 11 46 50 46 FF F7 6B FF 00 28 89 D1 B9 F1 01 0F 1F D0 14 98 40 1C 81 46 FF 22 08 21 14 A8 E0 F7 C7 FB CD F8 50 90 08 23 14 AA 50 46 18 99
8:57:33 AM
8:57:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 2C 09 81 80 E3 F7 BB FF 00 28 96 D1 16 98 0D F8 0B 00 0B F1 01 00 00 F0 FF 0B 76 1C A6 42 4F F0 00 09 94 D3 00 26 62 E0 00 20 DF E7 A8 5D FF 28 5C D1 EB 46 1D F8 09 10 14 AA 50 46 FF F7 43 FC 00 28 8B D1 BD F8 56 00 06 21 B1 EB 50 3F 3C D0 E9 F7 77 F8 40 05 49 D4 35 98 AD F8 54 70 00 28 BD F8 56 00 0C D0 66 F3 06 00 20 F4 60 40 00 F5 00 50 AD F8 56 00 35 98 40 1E C0 B2 35 90 07 E0 20 F4 60 40
8:57:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 2D 09 81 80 40 F0 7F 00 00 F5 40 40 AD F8 56 00 1B F8 09 10 17 AA 50 46 E3 F7 2E FF 00 28 98 D1 18 99 04 23 09 1D 15 AA 50 46 E3 F7 68 FF 08 B1 05 F8 06 80 1B F8 09 00 A8 55 14 AA F1 B2 50 46 FF F7 BE FC 00 28 84 D1 0C E0 1B F8 09 00 A8 55 C6 EB C6 00 05 EB 40 00 80 F8 46 10 87 87 BD F8 BC 10 C1 87 09 F1 01 00 00 F0 FF 09 76 1C A6 42 9C D3 20 46 41 46 01 E0 29 54 40 1C 39 28 FB D3 00 26 3C E0
8:57:34 AM
8:57:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 2E 09 81 80 06 F0 FF 08 44 21 1B A8 DF F7 E7 FD AD F8 6C A0 8D F8 6E 80 AD F8 70 70 15 F8 08 10 17 AA 50 46 E3 F7 E8 FE 00 28 8A D1 19 98 4F F0 00 09 40 1E 80 B2 16 90 01 20 2C 90 BD F8 BC B0 06 E0 22 98 01 28 1E D0 02 28 1C D0 4F F0 01 09 1B A8 FF F7 AD FC 00 28 F3 D0 C8 EB C8 00 05 EB 40 00 3A 30 2C 99 41 81 16 99 01 80 BD F8 7C 10 C1 80 BD F8 7E 10 01 81 A0 F8 04 B0 76 1C A6 42 C0 D3 00 20
8:57:35 AM
8:57:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 2F 09 81 80 AB E6 BD F8 72 00 28 B1 16 99 88 42 02 D2 40 1E 80 B2 16 90 DD E9 28 10 40 1A BD F8 AC 10 B9 F1 00 0F 08 44 1F FA 80 FB D0 D0 00 20 2C 90 CD E7 30 B5 85 B0 0C 46 05 46 69 46 E3 F7 8E FE 00 28 03 D1 04 98 C0 07 02 D0 1A 20 05 B0 30 BD 28 46 14 B1 FF F7 02 FE F8 E7 FF F7 6C FE F5 E7 37 B5 0C 46 02 99 00 20 FF 29 05 D9 04 21 02 A8 E7 F7 C3 FA 08 38 C0 B2 61 68 CA 43 21 68 C1 40 62 F3
8:57:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 30 09 81 80 1F 21 00 20 E1 60 3E BD 2D E9 F0 4F AB B0 82 46 FF 20 10 70 8B 46 50 70 14 46 22 A9 50 46 E3 F7 5C FE 00 28 06 D1 26 98 C0 07 01 E0 34 3D 00 10 02 D0 1A 20 2B B0 51 E6 1A A9 50 46 FF F7 32 FB 00 28 F7 D1 28 A9 50 46 FF F7 7D FB 00 28 F1 D1 47 1E 05 46 4F F6 FF 78 CD F8 60 00 E8 F7 6F FF 00 06 01 D5 20 20 E5 E7 29 46 50 46 FF F7 D5 FB 06 00 11 D0 6B 21 0A FB 01 F0 FE 49 01 EB C0 00
8:57:36 AM
8:57:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 31 09 81 80 40 5D 81 46 FF 28 77 D0 01 46 1C AA 50 46 E3 F7 31 FE 00 28 70 D1 01 E0 07 20 CB E7 6A 46 29 46 50 46 FF F7 40 FB 00 28 C4 D1 18 99 00 98 88 42 00 D9 18 90 31 7B BD F8 06 00 B1 EB 50 3F 01 D0 40 0B 30 73 30 7B 01 28 02 D0 06 28 6D D0 77 E0 44 21 04 A8 DF F7 01 FD AD F8 10 A0 8D F8 12 50 AD F8 14 80 04 A8 FF F7 A3 FC BD F8 50 00 01 46 40 1E 10 EA 0B 0F 0D D0 2B EA 00 02 02 EB 01 02
8:57:37 AM
8:57:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 32 09 81 80 BD F8 14 00 40 45 03 D0 BD F8 24 00 40 45 03 D1 0F 98 0F E0 5A 46 F3 E7 BD F8 6C 30 BD F8 1E 60 80 1C 33 44 00 FB 01 30 1E 99 81 42 01 D8 00 20 00 E0 08 1A 90 42 43 D3 20 78 FF 28 1D D0 00 98 17 90 BD F8 1C 00 16 90 16 A9 50 46 1E 9A FF F7 46 FF 00 28 87 D1 19 98 21 6B 88 42 30 D9 25 70 84 F8 02 90 DD E9 00 01 16 AE C4 E9 0D 01 0F CE 04 F1 24 06 0F C6 23 E0 27 E0 BD F8 1C 00 F8 B1
8:57:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 33 09 81 80 25 70 84 F8 02 90 DD E9 00 01 C4 E9 0D 01 00 98 A0 62 BD F8 1C 00 60 62 04 F1 24 01 50 46 1E 9A FF F7 1D FF 00 28 D5 D1 0A E0 00 98 B8 42 07 D2 65 70 07 46 84 F8 03 90 DD E9 00 01 C4 E9 0F 01 6D 1C ED B2 39 2D FF F4 49 AF 20 78 FF 28 06 D0 A1 78 22 1D 50 46 E3 F7 8D FD 00 28 BA D1 60 78 FF 28 07 D0 E1 78 04 F1 14 02 50 46 E3 F7 82 FD 00 28 AF D1 00 20 1D E7 2D E9 F0 43 C5 B0 0F 46
8:57:38 AM
8:57:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 34 09 81 80 15 46 1C 46 81 46 40 A9 E3 F7 67 FD 00 28 04 D1 41 99 28 19 88 42 03 D9 0C 20 45 B0 BD E8 F0 83 4F F4 80 78 17 E0 FF 2C 01 D8 26 46 00 E0 46 46 33 46 6A 46 39 46 48 46 E3 F7 B2 FD 00 28 EC D1 33 46 6A 46 29 46 48 46 E3 F7 97 FD 00 28 E4 D1 37 44 35 44 A4 1B 00 2C E5 D1 00 20 DD E7 10 B5 40 F6 08 21 83 48 DF F7 5F FC 00 20 10 BD 00 20 70 47 9D E6 30 B5 87 B0 0D 46 04 46 02 A9 E3 F7
8:57:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 35 09 81 80 2C FD 00 28 03 D1 06 98 C0 07 02 D0 1A 20 07 B0 30 BD 69 46 20 46 FF F7 56 FA 00 28 F7 D1 00 23 19 46 20 46 FF F7 B9 FA 58 B1 6B 21 71 4A 61 43 02 EB C1 01 C9 5C FF 29 1C D0 01 7B 01 29 02 D0 14 E0 07 20 E3 E7 81 88 42 89 12 B1 BD F8 04 20 11 44 00 88 A8 42 09 D9 05 9A 40 1B 01 2A 01 D9 52 1E 90 43 88 42 01 D3 00 20 D0 E7 5B 1C DB B2 39 2B D5 D3 1B 20 CA E7 2D E9 F7 4F 94 B0 8B 46
8:57:39 AM
8:57:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 36 09 81 80 92 46 0A A9 14 98 E3 F7 E8 FC 00 28 03 D1 0E 98 C0 07 02 D0 1A 20 17 B0 E0 E4 0F A9 14 98 FF F7 12 FA 00 28 F7 D1 00 26 4F F6 FF 78 31 46 14 98 FF F7 73 FA 04 00 11 D0 E0 88 FF 28 01 D3 40 45 2E D1 14 99 6B 22 51 43 4A 4A 02 EB C1 01 89 5D FF 29 7A D0 21 7B 01 29 02 D0 21 E0 07 20 DA E7 A2 88 61 89 11 B1 BD F8 40 10 0A 44 21 88 51 45 16 D9 0D 9B A1 EB 0A 01 01 2B 01 D9 5B 1E 99 43
8:57:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 37 09 81 80 91 42 0D D3 61 89 00 27 00 29 E1 88 0D F1 44 09 20 D0 41 45 09 D1 20 89 40 45 0C D1 00 25 0C E0 76 1C F6 B2 39 2E C1 D3 4F E0 21 89 41 45 02 D0 88 42 00 D8 08 46 40 1C 85 B2 CD F8 00 90 12 AB 2A 46 31 46 14 98 FF F7 F0 F9 00 28 A3 D1 12 98 E8 B1 3A E0 41 45 01 D1 00 25 01 E0 40 1C 85 B2 CD F8 00 90 12 AB 2A 46 31 46 14 98 FF F7 DD F9 00 28 90 D1 12 98 50 B1 6D 1C AD B2 FF 2D 05 D8
8:57:40 AM
8:57:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 38 09 81 80 20 88 BD F8 44 10 88 42 EA D3 1E E0 EF B1 06 AB 2A 46 31 46 14 98 FF F7 99 F9 00 28 9F D1 21 88 A1 EB 0A 00 40 1C 0D 99 80 B2 AD F8 14 00 01 29 03 D9 49 1E 88 43 AD F8 14 00 AD F8 16 80 E8 F7 7E FD 00 06 03 D5 00 20 65 E7 1B 20 63 E7 04 23 05 AA 07 99 14 98 E3 F7 90 FC 00 28 F4 D1 BD F8 14 00 4F F0 01 0A 40 1E 20 80 E0 88 40 45 04 D0 A8 42 01 E0 34 3D 00 10 10 D2 E5 80 20 89 40 45
8:57:41 AM
8:57:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 39 09 81 80 01 D0 A8 42 04 D2 A1 88 BD F8 24 20 11 44 A1 80 40 45 01 D0 A8 42 01 D1 A4 F8 0A A0 68 1C 87 B2 20 89 40 45 1A D0 20 89 B8 42 02 D2 A4 F8 0A A0 14 E0 CD F8 00 90 12 AB 3A 46 31 46 14 98 FF F7 74 F9 00 28 C0 D1 12 98 40 B1 7F 1C BF B2 FF 2F 04 D8 20 88 BD F8 44 10 88 42 E4 D3 06 F0 7F 00 60 F3 1F 25 45 F4 00 41 AB F8 00 10 AB E7 70 B5 90 B0 0C 46 05 46 05 A9 E3 F7 EF FB 00 28 03 D1
8:57:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 3A 09 81 80 09 98 C0 07 02 D0 1A 20 10 B0 70 BD 0E A9 28 46 FF F7 19 F9 00 28 F7 D1 C4 F3 06 26 E4 B2 31 46 28 46 FF F7 7A F9 50 B1 6B 21 F8 4A 69 43 02 EB C1 01 89 5D FF 29 02 D0 00 7B 01 28 01 D0 07 20 E2 E7 0B A8 00 90 0A AB 22 46 31 46 28 46 FF F7 2C F9 00 28 D8 D1 0A 98 01 28 01 D0 1C 20 D3 E7 01 AB 22 46 31 46 28 46 FF F7 F0 F8 00 28 CB D1 BD F8 0E 10 4F F6 FC 70 01 29 10 D0 BD F8 2C 10
8:57:42 AM
8:57:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 3B 09 81 80 AD F8 30 10 AD F8 32 00 BD F8 0C 10 02 98 04 23 01 44 0C AA 28 46 E3 F7 F0 FB 00 28 B4 E7 02 99 AD F8 34 00 89 1C 02 23 0D AA F3 E7 2D E9 F0 43 8F B0 0C 46 06 46 90 46 1F 46 06 A9 DD F8 58 90 E3 F7 8B FB 00 28 03 D1 0A 98 C0 07 02 D0 1A 20 0F B0 23 E6 0C A9 30 46 FF F7 B5 F8 00 28 F7 D1 C4 F3 06 25 E4 B2 29 46 30 46 FF F7 16 F9 50 B1 6B 21 C6 4A 71 43 02 EB C1 01 49 5D FF 29 02 D0
8:57:43 AM
8:57:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 3C 09 81 80 00 7B 01 28 01 D0 07 20 E2 E7 05 A8 00 90 0B AB 22 46 29 46 30 46 FF F7 C8 F8 00 28 D8 D1 0B 98 01 28 01 D0 1C 20 D3 E7 01 AB 22 46 29 46 30 46 FF F7 8C F8 00 28 CB D1 BD F8 14 10 01 98 4B 46 08 44 C1 19 42 46 30 46 E3 F7 AA FB 00 28 BF E7 2D E9 F0 43 8F B0 0C 46 06 46 90 46 1F 46 06 A9 DD F8 58 90 E3 F7 39 FB 00 28 B1 D1 0A 98 C0 07 01 D0 1A 20 AC E7 0C A9 30 46 FF F7 64 F8 00 28
8:57:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 3D 09 81 80 A6 D1 C4 F3 06 25 E4 B2 29 46 30 46 FF F7 C5 F8 50 B1 6B 21 9D 4A 71 43 02 EB C1 01 49 5D FF 29 02 D0 00 7B 01 28 01 D0 07 20 91 E7 05 A8 00 90 0B AB 22 46 29 46 30 46 FF F7 77 F8 00 28 87 D1 0B 98 01 28 01 D0 1C 20 82 E7 01 AB 22 46 29 46 30 46 FF F7 3B F8 00 28 CC D1 BD F8 14 10 01 98 4B 46 08 44 C1 19 42 46 30 46 E3 F7 46 FB 00 28 6E E7 2D E9 F0 47 B8 B0 0C 46 81 46 31 A9 E3 F7
8:57:44 AM
8:57:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 3E 09 81 80 EC FA 00 28 03 D1 35 98 C0 07 03 D0 1A 20 38 B0 BD E8 F0 87 6A 46 21 46 48 46 FF F7 75 FC 00 28 F5 D1 9D F8 00 00 FF 28 34 D0 9D F8 01 00 FF 28 30 D0 13 A9 48 46 FE F7 B5 FF 00 28 E7 D1 44 21 18 A8 DF F7 CA F9 9D F8 00 00 AD F8 60 90 8D F8 62 00 4F F6 FF 78 03 98 AD F8 64 80 40 1E 45 46 84 B2 01 27 BD F8 50 60 4F F0 00 0A E8 F7 E7 FB 00 06 34 D4 BD F8 4E 00 01 28 12 D0 BD F8 4C 10
8:57:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 3F 09 81 80 06 98 04 23 01 44 0F AA 48 46 E3 F7 F6 FA 00 28 BD D1 06 E0 07 20 BA E7 1F 98 01 28 21 D0 4F F0 01 0A 18 A8 FF F7 82 F8 00 28 F5 D0 FF 22 08 21 29 A8 DF F7 E6 FE 0F 98 29 90 9D F8 00 10 BD F8 AA 00 AD F8 A8 40 61 F3 06 00 20 F4 60 40 00 F5 00 50 AD F8 AA 00 E8 F7 B2 FB 00 06 39 D5 00 20 95 E7 DD E9 25 10 40 1A 86 B2 BD F8 68 00 AD F8 5E 80 20 1A 40 1C AD F8 5C 00 BD F8 64 20 9D F8
8:57:45 AM
8:57:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 40 09 81 80 01 10 2D AB 48 46 FE F7 A1 FF 00 28 C3 D1 04 23 17 AA 48 46 2E 99 E3 F7 B0 FA 00 28 BB D1 BD F8 66 10 22 98 BD F8 5C 20 01 44 06 98 BD F8 68 30 02 44 48 46 FF F7 E0 FC 00 28 AC D1 BD F8 68 00 BD F8 64 50 20 1A 84 B2 BA F1 00 0F A9 D0 00 27 A7 E7 BD F8 4E 00 29 AA 01 28 54 D0 BD F8 4C 10 06 98 01 44 09 1D 04 23 12 1D 48 46 E3 F7 85 FA 00 28 90 D1 9D F8 02 10 48 46 0A 46 FF F7 18 FA
8:57:46 AM
8:57:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 41 09 81 80 00 28 88 D1 FF 22 08 21 29 A8 DF F7 7A FE 0D 98 08 23 40 1C 29 90 BD F8 AA 00 AD F8 A8 80 20 F4 60 40 40 F0 7F 00 00 F5 40 40 AD F8 AA 00 29 AA 48 46 02 99 E3 F7 61 FA 00 28 91 D1 6B 23 09 FB 03 F1 12 4B 9D F8 00 00 03 EB C1 01 9D F8 03 20 42 54 9D F8 01 30 C0 EB C0 00 9D F8 02 20 01 EB 40 00 5A 54 20 F8 3A 4F 45 45 44 80 47 81 86 80 03 D0 BD F8 A0 20 32 44 82 80 A0 F8 06 80 05 81
8:57:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 42 09 81 80 01 21 01 73 6B E7 06 99 AC E7 00 00 34 3D 00 10 2D E9 F0 43 85 88 00 26 47 88 89 B0 89 46 20 2D 1C D9 20 24 DF F8 28 84 23 46 6A 46 98 F8 00 00 39 46 E6 F7 68 F8 18 B1 00 20 09 B0 BD E8 F0 83 21 46 68 46 E6 F7 80 FE 30 44 C6 B2 38 19 87 B2 28 1B 85 B2 20 2D 01 D9 20 24 E5 E7 2C 00 E1 D1 89 F8 00 60 01 20 E8 E7 10 B5 40 88 0A 46 40 1E 81 B2 F7 48 01 23 00 78 E6 F7 45 F8 08 B1 00 20
8:57:47 AM
8:57:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 43 09 81 80 10 BD 01 20 10 BD 13 B5 40 88 01 23 40 1E 81 B2 EF 48 01 AA 00 78 E6 F7 5C F8 08 B1 00 20 1C BD 01 20 1C BD 38 B5 04 46 69 46 FF F7 B1 FF 00 28 07 D0 9D F8 00 10 20 46 FF F7 E5 FF 00 28 00 D0 01 20 38 BD 2D E9 FC 5F E2 4D E1 4E 83 46 4F F0 01 09 00 24 04 EB 44 07 05 EB 47 08 06 23 B8 F8 02 00 6A 46 80 1F 1F FA 80 FA 30 78 51 46 E6 F7 0A F8 70 BB BB F1 00 0F 0F D1 BD F8 00 00 35 F8
8:57:48 AM
8:57:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 44 09 81 80 17 10 88 42 09 D1 9D F8 04 00 C0 07 05 D1 BD F8 02 10 B8 F8 04 00 81 42 1D D0 35 F8 17 00 AD F8 00 00 01 20 8D F8 04 00 B8 F8 04 00 AD F8 02 00 00 20 8D F8 05 00 30 78 06 23 6A 46 51 46 E6 F7 08 F8 30 B9 30 78 06 23 6A 46 51 46 E5 F7 DB FF 08 B1 4F F0 00 09 64 1C A4 B2 21 2C BA D3 48 46 BD E8 FC 9F 2D E9 F0 4F 8B B0 5F EA 00 0B 01 D0 64 20 00 E0 65 20 E8 F7 35 F9 4F F0 00 0A B5 4E
8:57:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 45 09 81 80 B3 4D 01 24 D0 46 00 BF 08 EB 48 07 06 EB 47 09 06 23 B9 F8 02 00 04 AA 80 1F 80 B2 00 90 28 78 00 99 E5 F7 B0 FF 08 B1 66 20 D1 E0 BB F1 00 0F 03 D1 9D F8 14 00 C0 07 6F D0 36 F8 17 00 2B 28 7A D2 DF E8 00 F0 79 16 1C 1F 22 25 2B 2E 34 31 3A 3D 79 40 43 46 49 79 4F 61 19 28 79 79 52 79 4C 55 58 79 79 79 5B 5E 79 79 64 67 37 6C 6F 72 75 00 38 F0 30 F9 5D E0 38 F0 3E F9 5A E0 32 F0
8:57:49 AM
8:57:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 46 09 81 80 22 FD 57 E0 01 F0 70 F9 54 E0 01 F0 87 FA 51 E0 30 F0 70 F8 4E E0 30 F0 8A F8 4B E0 2C F0 59 FA 48 E0 0E F0 9A FB 45 E0 1C F0 CD FA 42 E0 0E F0 FD FC 3F E0 2C F0 AA FE 3C E0 0F F0 CD FA 39 E0 0F F0 97 FC 36 E0 10 F0 D0 F8 33 E0 10 F0 6A F9 30 E0 2D F0 68 FD 2D E0 34 F0 CB FE 2A E0 33 F0 21 FF 27 E0 22 F0 E9 FB 24 E0 38 F0 16 F9 21 E0 38 F0 26 F9 1E E0 3A F0 59 FC 1B E0 2D F0 48 FE
8:57:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 47 09 81 80 18 E0 3A F0 45 FB 15 E0 05 F0 FE F8 12 E0 15 F0 52 FF 0F E0 40 F0 30 FF 0C E0 35 E0 0C E0 36 F0 AB FA 07 E0 41 F0 28 FC 04 E0 2A F0 4D FD 01 E0 36 F0 55 FB 00 B9 00 24 9D F8 14 00 06 23 20 F0 01 00 8D F8 14 00 36 F8 17 00 AD F8 10 00 B9 F8 04 00 AD F8 12 00 28 78 04 AA 00 99 E5 F7 39 FF 08 B1 67 20 34 E0 01 A9 48 46 FF F7 91 FE 38 B1 9D F8 04 10 48 46 FF F7 C6 FE 18 B1 6A 20 30 E0
8:57:50 AM
8:57:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 48 09 81 80 68 20 25 E0 69 20 23 E0 01 A9 48 46 FF F7 80 FE 10 B3 03 A9 48 46 FF F7 A7 FE F8 B1 9D F8 14 10 9D F8 04 20 9D F8 0C 30 21 F0 02 00 9A 42 03 D0 40 F0 02 00 4A F0 02 0A 81 42 11 D0 8D F8 14 00 28 78 06 23 04 AA 00 99 E5 F7 03 FF 40 B1 6D 20 E8 F7 48 F8 00 24 06 E0 6B 20 F9 E7 6C 20 F7 E7 6E 20 E8 F7 3F F8 08 F1 01 00 1F FA 80 F8 B8 F1 21 0F FF F4 09 AF 0C B1 6F 20 00 E0 70 20 E8 F7
8:57:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 49 09 81 80 31 F8 5F EA 8A 70 28 79 02 D5 40 F0 02 00 01 E0 20 F0 02 00 28 71 0B B0 20 46 BD E8 F0 8F 2D E9 FC 47 2B 4C 81 46 00 26 20 78 FF 28 4D D0 08 23 6A 46 00 21 E5 F7 A7 FE E8 BB DF F8 9C 80 00 99 26 4D 41 45 08 D1 00 95 01 26 20 78 04 23 6A 46 00 21 E5 F7 BE FE 70 BB 00 98 4F F4 C0 47 A8 42 04 D1 01 98 B8 42 01 D1 01 20 00 E0 00 20 B9 F1 00 0F 01 D0 08 B1 07 E0 90 BB 20 78 08 23 6A 46
8:57:51 AM
8:57:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 4A 09 81 80 00 21 E5 F7 80 FE B0 B9 00 99 41 45 08 D1 00 95 01 26 20 78 04 23 6A 46 00 21 E5 F7 9A FE 50 B9 00 98 A8 42 02 D1 01 98 B8 42 1A D0 E8 F7 07 F9 40 05 16 D4 00 E0 08 E0 CD E9 00 57 20 78 08 23 6A 46 00 21 E5 F7 85 FE 50 B1 00 20 BD E8 FC 87 3C 47 00 10 18 41 06 00 BA AB BB AA DD CC BB AA FF E7 01 25 E8 F7 EB F8 40 05 04 D4 48 46 FF F7 29 FE 00 B9 00 25 65 80 E8 F7 E1 F8 40 05 04 D4
8:57:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 4B 09 81 80 48 46 FF F7 6F FE 00 B9 00 25 0E B1 36 F0 C2 F9 28 46 DB E7 70 B5 76 4D 06 46 88 B0 FF 20 28 70 68 46 E5 F7 56 FD 00 24 05 E0 01 A9 20 46 E5 F7 5E FD 64 1C E4 B2 9D F8 00 00 A0 42 F5 D8 00 20 4F F4 C0 41 6A 4A E5 F7 88 FD 68 46 E5 F7 41 FD 28 78 FF 28 0A D0 05 A9 E5 F7 6D FD 30 46 FF F7 5E FF 00 28 00 D0 01 20 08 B0 70 BD 00 20 FB E7 60 4A 00 21 01 EB 41 03 32 F8 13 30 83 42 04 D1
8:57:52 AM
8:57:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 4C 09 81 80 01 EB 41 00 02 EB 40 00 70 47 49 1C 89 B2 21 29 F0 D3 00 20 70 47 56 48 00 21 01 60 81 80 08 46 B8 E7 00 28 07 D0 52 49 0A 78 02 70 0A 79 02 71 49 88 41 80 01 20 70 47 10 B5 0C 00 09 D0 FF F7 D7 FF 00 28 04 D0 01 68 21 60 80 88 A0 80 01 20 10 BD 00 20 10 BD 01 20 21 E7 00 20 02 E6 2D E9 FC 47 8A 46 DD E9 0A 57 DF F8 04 C1 00 21 39 80 BC F8 02 10 91 46 1E 46 61 B3 FF F7 B9 FF 04 00
8:57:53 AM
8:57:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 4D 09 81 80 28 D0 A0 88 B0 42 25 D9 60 88 E0 46 80 1F 81 B2 9C F8 00 00 06 23 6A 46 E5 F7 B5 FD D0 B9 21 88 BD F8 00 00 81 42 15 D1 A0 88 BD F8 02 10 88 42 10 D1 61 88 80 1B 31 44 89 B2 A8 42 00 DC 05 46 AC B2 A1 45 06 D3 98 F8 00 00 23 46 52 46 E5 F7 9A FD 08 B1 00 20 39 E7 3C 80 01 20 36 E7 2D E9 FC 47 8A 46 DD E9 0A 57 DF F8 84 C0 00 21 39 80 BC F8 02 10 91 46 1E 46 61 B3 FF F7 79 FF 04 00
8:57:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 4E 09 81 80 28 D0 A0 88 B0 42 25 D9 60 88 E0 46 80 1F 81 B2 9C F8 00 00 06 23 6A 46 E5 F7 75 FD D0 B9 20 88 BD F8 00 10 88 42 15 D1 A0 88 BD F8 02 10 88 42 10 D1 61 88 80 1B 31 44 89 B2 A8 42 00 DC 05 46 AD B2 A9 45 06 D3 98 F8 00 00 2B 46 52 46 E5 F7 80 FD 08 B1 00 20 F9 E6 9D F8 04 00 C0 07 04 D1 20 46 FF F7 1F FD 00 28 F5 D0 3D 80 01 20 ED E6 3C 47 00 10 18 41 06 00 FE 48 00 78 70 47 70 B5
8:57:54 AM
8:57:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 4F 09 81 80 05 46 86 B0 FF 20 28 70 4F F4 50 56 68 46 E5 F7 60 FC 00 24 16 E0 01 A9 20 46 E5 F7 68 FC A8 B9 02 98 B0 42 0C D3 9D F8 05 00 C0 F3 02 10 07 28 06 D1 2C B9 2A 46 31 46 20 46 E5 F7 8E FC 40 B1 64 1C E4 B2 9D F8 00 00 A0 42 E4 D8 00 20 06 B0 70 BD E8 4A 28 78 12 1D 00 21 E5 F7 FB FC 01 20 F5 E7 E5 4A 00 21 00 BF 01 EB 41 03 32 F8 13 30 83 42 04 D1 01 EB 41 00 02 EB 40 00 70 47 49 1C
8:57:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 50 09 81 80 C9 B2 06 29 F0 D3 00 20 70 47 70 B5 05 46 0E 46 14 46 B2 F5 93 5F 0D D8 81 20 FF F7 E2 FF 00 28 09 D0 40 88 23 46 41 19 D2 48 32 46 00 78 E5 F7 10 FD 08 B1 00 20 70 BD 01 20 70 BD F8 B5 CD 4F 38 78 FF 28 1E D0 CC 4C 42 F2 58 16 24 34 00 25 E3 88 31 46 38 78 22 68 E5 F7 FB FC E0 88 6D 1C 08 34 ED B2 06 44 02 2D F2 D3 68 46 E6 F7 B7 F9 C2 48 00 88 20 B1 04 22 69 46 08 20 FF F7 C5 FF
8:57:55 AM
8:57:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 51 09 81 80 01 20 F8 BD 00 20 F8 BD 10 B5 38 F0 A0 F9 04 46 01 21 0E 20 39 F0 E7 FF E4 43 A0 06 0E D5 E0 07 02 D0 0F 20 39 F0 67 FE A0 07 02 D5 10 20 39 F0 62 FE 60 07 02 D5 11 20 39 F0 5D FE 07 20 39 F0 5A FE 01 20 10 BD 08 B5 FF F7 B8 FF 68 46 E6 F7 86 F9 A8 49 01 20 48 80 08 BD 2D E9 F0 41 A5 4F 38 78 FF 28 1C D0 A4 4C 42 F2 58 16 24 34 00 25 E3 88 31 46 38 78 22 68 E5 F7 85 FC E0 88 6D 1C
8:57:56 AM
8:57:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 52 09 81 80 08 34 ED B2 06 44 02 2D F2 D3 E7 F7 18 FF 80 07 03 D4 00 21 0E 20 39 F0 A6 FF 01 20 BD E8 F0 81 00 20 FB E7 2D E9 F0 41 90 B0 05 46 FF F7 59 FF 04 00 41 D0 60 88 8F 4E 80 1F 87 B2 06 23 05 AA 39 46 30 78 E5 F7 5F FC B0 BB BD F8 14 00 A8 42 32 D1 A4 88 BD F8 18 00 84 42 2D D1 80 2D 2E D0 81 2D 2C D0 00 25 BF 1D BF B2 B0 46 16 E0 20 2C 01 D2 26 46 00 E0 20 26 33 46 07 AA 39 46 98 F8
8:57:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 53 09 81 80 00 00 E5 F7 40 FC B8 B9 2A 46 31 46 07 A8 E6 F7 59 FA 05 46 B8 19 87 B2 A0 1B 84 B2 00 2C E6 D1 02 23 04 AA 39 46 98 F8 00 00 E5 F7 2C FC 18 B9 BD F8 10 00 A8 42 02 D0 00 20 10 B0 AE E7 01 20 FB E7 2D E9 FC 41 6C 4D 6A 4F 00 24 04 EB 44 01 35 F8 11 00 05 EB 41 01 AD F8 00 00 8A 88 AD F8 04 20 49 88 AD F8 02 10 89 1F 8E B2 FF F7 9A FF 48 B9 06 23 6A 46 31 46 38 78 E5 F7 2A FC 10 B1
8:57:57 AM
8:57:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 54 09 81 80 00 20 BD E8 FC 81 64 1C E4 B2 06 2C DE D3 01 20 F7 E7 2D E9 FC 41 88 46 14 46 07 46 FF F7 E1 FE 00 28 EE D0 40 88 53 4E 80 1F 85 B2 06 23 6A 46 29 46 30 78 E5 F7 E7 FB C0 B9 BD F8 00 00 B8 42 03 D1 BD F8 04 00 A0 42 03 D0 FF F7 BA FF 00 28 D7 D0 AD 1D BD F8 04 20 A9 B2 A2 42 00 D9 22 46 13 46 42 46 30 78 E5 F7 CE FB 08 B1 00 20 C8 E7 01 20 C6 E7 F8 B5 0E 46 14 46 FF F7 B2 FE 00 28
8:57:58 AM
8:57:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 55 09 81 80 1F D0 41 88 80 88 89 1F 89 B2 A0 42 18 D1 89 1D 8D B2 00 22 21 46 30 46 E6 F7 D4 F9 32 46 35 4E AD F8 00 00 23 46 29 46 30 78 E5 F7 D2 FB 38 B9 28 19 81 B2 02 23 6A 46 30 78 E5 F7 CA FB 08 B1 00 20 F8 BD 01 20 F8 BD 2D E9 F0 43 DF F8 A8 80 DF F8 A0 90 87 B0 07 46 00 25 00 BF 05 EB 45 02 08 EB 42 00 38 F8 12 10 AD F8 04 10 82 88 AD F8 08 20 40 88 AD F8 06 00 80 1F 86 B2 1F B9 08 46
8:57:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 56 09 81 80 FF F7 10 FF A8 BB 06 23 01 AA 31 46 4C 46 99 F8 00 00 E5 F7 9E FB 98 BB 00 20 AD F8 00 00 B6 1D B6 B2 03 90 04 90 05 90 A1 46 06 90 19 E0 10 2C 00 D3 10 24 23 46 03 AA 31 46 99 F8 00 00 E5 F7 88 FB E8 B9 BD F8 00 20 21 46 03 A8 E6 F7 7A F9 AD F8 00 00 30 19 86 B2 BD F8 08 00 00 1B AD F8 08 00 BD F8 08 40 00 2C E1 D1 02 23 6A 46 31 46 07 E0 0F E0 44 47 00 10 E0 41 06 00 B0 94 00 10
8:57:59 AM
8:57:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 57 09 81 80 04 E0 99 F8 00 00 E5 F7 64 FB 18 B1 00 20 07 B0 BD E8 F0 83 6D 1C ED B2 06 2D 9F D3 01 20 F6 E7 70 B5 05 46 0E 46 14 46 B2 F5 93 5F 0D D8 81 20 FF F7 17 FE 00 28 09 D0 40 88 23 46 41 19 23 48 32 46 00 78 E5 F7 1F FB 08 B1 00 20 70 BD 01 20 70 BD 79 E7 2D E9 FC 41 1C 4C 00 20 60 80 20 46 FF F7 CD FD 00 28 23 D0 00 25 08 23 6A 46 29 46 20 78 E5 F7 08 FB D0 B9 E7 F7 A1 FD 40 05 18 D4
8:57:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 58 09 81 80 13 4E 00 98 4F F4 50 57 B0 42 02 D1 01 98 B8 42 0F D0 00 20 FF F7 58 FF 00 28 09 D0 CD E9 00 67 08 23 6A 46 29 46 20 78 E5 F7 13 FB 08 B1 00 20 E7 E6 01 20 E5 E6 05 48 10 B5 41 88 19 B1 00 21 41 80 FF F7 21 FE 01 20 10 BD 00 00 44 47 00 10 BA DC CD AB 1C B5 0C 46 69 46 E5 F7 7F FE 01 A9 20 46 E5 F7 7B FE DD E9 00 01 88 42 02 D2 4F F0 FF 30 1C BD 02 D9 4F F0 01 00 1C BD 4F F0 00 00
8:58:00 AM
8:58:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 59 09 81 80 1C BD 0E B5 0B 46 11 46 00 EB 80 02 FC 48 00 EB 82 00 82 88 00 8A 03 FB 00 20 83 B2 02 AA 16 20 CD E9 00 02 02 46 04 20 FF F7 D9 FC 00 28 00 D0 01 20 0E BD 0E B5 0B 46 11 46 00 EB 80 02 F0 48 00 EB 82 00 82 88 00 8A 03 FB 00 20 83 B2 02 AA 16 20 CD E9 00 02 02 46 04 20 FF F7 00 FD 00 28 00 D0 01 20 0E BD 3E B5 0B 46 11 46 00 EB 80 02 E3 48 00 EB 82 00 82 88 04 8A C0 88 03 FB 04 22
8:58:01 AM
8:58:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 5A 09 81 80 10 44 83 B2 02 AA 01 20 CD E9 00 02 02 46 04 20 FF F7 A5 FC 00 28 00 D0 01 20 3E BD 07 B5 00 EB 80 02 D7 48 84 B0 00 EB 82 00 82 88 03 8A C0 88 01 FB 03 21 08 44 83 B2 01 20 02 A9 CD E9 00 01 02 46 06 A9 04 20 FF F7 CA FC 00 28 00 D0 01 20 07 B0 00 BD 2D E9 FF 41 14 46 1E 46 07 46 0D 46 02 AA FF F7 C0 FF 00 28 04 D0 9D F8 08 00 84 42 03 D3 00 20 04 B0 BD E8 F0 81 C1 48 07 EB 87 01
8:58:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 5B 09 81 80 00 EB 81 00 81 88 02 8A C0 88 05 FB 02 11 C4 EB C4 02 00 EB 42 00 08 44 40 1C 83 B2 0E 20 03 A9 CD E9 00 01 02 46 31 46 04 20 FF F7 58 FC 00 28 E0 D0 01 20 DE E7 00 22 02 60 42 60 82 60 0A 78 02 70 4B 78 C3 70 8B 78 83 70 CB 78 03 71 0B 79 43 71 4B 79 83 71 8B 79 C3 71 CA 79 02 72 49 7B 81 72 01 20 70 47 3E B5 1C 46 A5 4B 00 EB 80 00 13 F8 20 50 95 42 01 D8 00 20 3E BD 03 EB 80 00
8:58:02 AM
8:58:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 5C 09 81 80 C2 EB C2 02 83 88 05 8A C0 88 01 FB 05 31 00 EB 42 00 08 44 40 1C 83 B2 0E 20 02 A9 CD E9 00 01 02 46 21 46 04 20 FF F7 5A FC 00 28 E5 D0 01 20 3E BD 2D E9 FF 41 05 46 00 24 00 EB 85 06 90 4F 0E E0 FF 22 0E 21 68 46 DE F7 9B FF 6B 46 22 46 01 21 28 46 FF F7 C7 FF 00 28 8B D0 64 1C E4 B2 17 F8 26 00 A0 42 EC D8 00 22 01 21 28 46 FF F7 55 FF 01 20 7E E7 2D E9 F0 43 97 B0 88 46 17 46
8:58:03 AM
8:58:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 5D 09 81 80 00 25 81 46 FF 26 06 AA 29 46 FF F7 2C FF 00 28 60 D0 00 24 58 E0 0F AB 22 46 00 21 48 46 FF F7 59 FF E8 B3 0F A9 07 A8 FF F7 85 FF 00 28 51 D0 9D F8 26 00 FF 28 45 D0 BD F8 1E 00 AD F8 28 00 9D F8 20 00 8D F8 2A 00 9D F8 21 00 8D F8 2B 00 9D F8 22 00 8D F8 2C 00 9D F8 23 00 8D F8 2D 00 9D F8 24 00 8D F8 2E 00 00 20 8D F8 2F 00 AD F8 30 00 13 AA 0A A9 40 46 EC F7 10 FD 05 A9 40 46
8:58:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 5E 09 81 80 E5 F7 2C FD 04 A9 13 A8 E5 F7 28 FD DD E9 04 01 81 42 0E D2 00 23 0E AA 0A A8 37 F0 6D FD 00 E0 10 E0 01 28 05 D1 0E 99 04 98 88 42 01 D9 40 1A 04 90 DD E9 04 01 81 42 04 D3 A8 42 02 D9 9D F8 26 60 05 46 64 1C E4 B2 9D F8 18 00 84 42 A2 D3 3E 70 01 20 17 B0 BD E8 F0 83 3E B5 0B 46 11 46 00 EB 80 02 46 48 00 EB 82 00 82 88 04 8A 00 89 03 FB 04 22 10 44 83 B2 02 AA 01 20 CD E9 00 02
8:58:04 AM
8:58:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 5F 09 81 80 02 46 04 20 FF F7 6B FB 00 28 00 D0 01 20 3E BD 07 B5 00 EB 80 02 3A 48 84 B0 00 EB 82 00 82 88 03 8A 00 89 01 FB 03 21 08 44 83 B2 01 20 02 A9 CD E9 00 01 02 46 06 A9 04 20 FF F7 90 FB 00 28 00 D0 01 20 C4 E6 2D E9 FF 41 14 46 1E 46 07 46 0D 46 02 AA FF F7 C1 FF 00 28 04 D0 9D F8 08 00 84 42 01 D3 00 20 C5 E6 25 48 07 EB 87 01 00 EB 81 00 81 88 02 8A 00 89 05 FB 02 11 00 EB C4 00
8:58:05 AM
8:58:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 60 09 81 80 08 44 40 1C 83 B2 08 20 03 A9 CD E9 00 01 02 46 31 46 04 20 FF F7 23 FB 00 28 E4 D0 01 20 A9 E6 3E B5 0C 46 19 46 00 EB 80 03 15 48 00 EB 83 00 43 78 93 42 01 D2 00 20 3E BD 83 88 05 8A 00 89 04 FB 05 33 00 EB C2 00 18 44 40 1C 83 B2 02 AA 08 20 CD E9 00 02 02 46 04 20 FF F7 40 FB 00 28 EA D0 01 20 3E BD 2D E9 FF 41 0E 46 15 46 07 46 01 AA 00 21 FF F7 71 FF 00 28 10 D0 00 24 11 E0
8:58:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 61 09 81 80 30 42 06 00 02 AB 22 46 00 21 38 46 FF F7 9B FF 30 B1 9D F8 08 00 B0 42 02 D1 2C 70 01 20 69 E6 64 1C E4 B2 9D F8 04 00 84 42 EB D3 00 20 61 E6 7C B5 05 46 F9 49 00 EB 85 00 00 24 01 EB 80 06 0E E0 FF 22 08 21 68 46 DE F7 5B FE 6B 46 22 46 01 21 28 46 FF F7 A4 FF 00 28 0A D0 64 1C E4 B2 70 78 A0 42 ED D8 00 22 01 21 28 46 FF F7 50 FF 01 20 7C BD FE B5 15 46 0E 46 1C 46 07 46 02 AA
8:58:06 AM
8:58:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 62 09 81 80 29 46 FF F7 B0 FF 00 28 16 D0 6B 46 9D F8 08 20 00 21 38 46 FF F7 57 FF 00 28 0D D0 FF 2D 01 D1 FF 20 20 70 30 79 08 B1 40 1E 00 E0 06 20 C0 B2 68 44 40 78 20 70 01 20 FE BD 3E B5 0C 46 19 46 00 EB 80 03 D5 48 00 EB 83 00 83 78 93 42 01 D8 00 20 3E BD 83 88 05 8A 04 FB 05 33 44 89 40 8A 02 FB 00 40 18 44 80 1C 83 B2 02 AA 01 20 CD E9 00 02 02 46 04 20 FF F7 72 FA 3E BD 3E B5 0C 46
8:58:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 63 09 81 80 19 46 00 EB 80 03 C5 48 00 EB 83 00 83 78 93 42 01 D8 00 20 3E BD 83 88 05 8A 04 FB 05 33 44 89 40 8A 02 FB 00 40 18 44 80 1C 83 B2 02 AA 01 20 CD E9 00 02 02 46 04 20 FF F7 91 FA 3E BD 3E B5 0C 46 19 46 00 EB 80 03 B4 48 00 EB 83 00 83 78 93 42 01 D8 00 20 3E BD 83 88 05 8A 04 FB 05 33 44 89 40 8A 02 FB 00 40 18 44 C0 1C 83 B2 02 AA 01 20 CD E9 00 02 02 46 04 20 FF F7 30 FA 3E BD
8:58:07 AM
8:58:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 64 09 81 80 2D E9 FF 41 1C 46 07 46 0D 46 16 46 02 AB DD F8 28 80 FF F7 92 FF 00 28 04 D0 9D F8 08 00 84 42 01 D3 00 20 A6 E5 9D 48 07 EB 87 01 00 EB 81 00 81 88 02 8A 05 FB 02 11 42 89 40 8A 06 FB 00 20 08 44 04 EB 44 01 00 EB 41 00 00 1D 83 B2 06 20 03 A9 CD E9 00 01 02 46 41 46 04 20 FF F7 FF F9 88 E5 FE B5 00 EB 80 05 8C 48 08 9C 00 EB 85 00 C5 78 9D 42 02 D9 85 78 95 42 01 D8 00 20 FE BD
8:58:08 AM
8:58:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 65 09 81 80 85 88 06 8A 01 FB 06 51 45 89 40 8A 02 FB 00 50 08 44 03 EB 43 01 00 EB 41 00 00 1D 83 B2 06 20 02 A9 CD E9 00 01 02 46 21 46 04 20 FF F7 17 FA FE BD 3E B5 0B 46 11 46 00 EB 80 02 77 48 00 EB 82 00 82 88 04 8A 40 89 03 FB 04 22 10 44 83 B2 02 AA 01 20 CD E9 00 02 02 46 04 20 FF F7 BF F9 3E BD 3E B5 0B 46 11 46 00 EB 80 02 6B 48 00 EB 82 00 82 88 04 8A 40 89 03 FB 04 22 10 44 83 B2
8:58:09 AM
8:58:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 66 09 81 80 02 AA 01 20 CD E9 00 02 02 46 04 20 FF F7 E7 F9 3E BD 2D E9 FF 47 81 46 FF 22 06 21 02 A8 DE F7 30 FD 5E 49 00 25 09 EB 89 00 2F 46 01 EB 80 06 0D F1 08 08 1A E0 00 24 0B E0 23 46 2A 46 01 21 48 46 CD F8 00 80 FF F7 8C FF 00 28 19 D0 64 1C E4 B2 F0 78 A0 42 F0 D8 8D F8 04 70 01 AB 2A 46 01 21 48 46 FF F7 0A FF 6D 1C ED B2 B0 78 A8 42 E1 D8 8D F8 04 70 01 AA 01 21 48 46 FF F7 B1 FF
8:58:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 67 09 81 80 01 20 04 B0 BD E8 F0 87 2D E9 FC 41 0E 46 15 46 07 46 6A 46 00 21 FF F7 8C FF 00 28 0E D0 00 24 10 E0 01 AB 22 46 00 21 38 46 FF F7 08 FF 38 B1 9D F8 04 00 86 42 03 D1 2C 70 01 20 BD E8 FC 81 64 1C E4 B2 9D F8 00 00 84 42 EA D3 00 20 F5 E7 2D E9 F0 41 8E B0 80 46 0F 46 14 46 1E 00 1E D0 FF 22 06 21 07 A8 DE F7 CC FC FF 22 04 21 30 46 DE F7 C7 FC 00 25 FF 2C 11 D0 03 AA 21 46 40 46
8:58:10 AM
8:58:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 68 09 81 80 FF F7 C2 FF 00 28 0B D0 04 AB 9D F8 0C 20 00 21 40 46 FF F7 92 FE 00 28 02 D0 00 24 37 E0 00 20 0E B0 A8 E4 07 A8 00 90 23 46 9D F8 0C 20 00 21 40 46 FF F7 E5 FE 00 28 F2 D0 9D F8 1C 00 FF 28 23 D0 9D F8 1D 10 FF 29 1F D0 3A 68 09 92 7A 68 0A 92 3A 89 8D F8 29 00 8D F8 2A 10 AD F8 2C 20 06 A9 38 46 E5 F7 7A FA 05 A9 09 A8 E5 F7 76 FA DD E9 05 01 81 42 08 D3 A8 42 06 D9 BD F8 1E 10
8:58:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 69 09 81 80 31 80 BD F8 20 10 71 80 05 46 64 1C E4 B2 9D F8 10 00 84 42 C6 D3 01 20 C2 E7 00 00 30 42 06 00 0E B5 00 EB 80 02 FE 48 00 EB 82 00 82 88 C0 89 10 44 83 B2 02 AA 0C 20 CD E9 00 02 02 46 04 20 FF F7 CD F8 0E BD 0E B5 00 EB 80 02 F4 48 00 EB 82 00 82 88 C0 89 10 44 83 B2 02 AA 0C 20 CD E9 00 02 02 46 04 20 FF F7 FA F8 0E BD 0E B5 EC 4A 1C 3A 02 EB 80 00 02 AA 43 88 01 20 CD E9 00 02
8:58:11 AM
8:58:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 6A 09 81 80 02 46 03 20 FF F7 AB F8 0E BD 0E B5 E4 4A 1C 3A 02 EB 80 00 02 AA 43 88 01 20 CD E9 00 02 02 46 03 20 FF F7 DC F8 0E BD 7F B5 0C 46 16 46 05 46 02 A9 FF F7 DB FF 00 28 04 D0 9D F8 08 00 84 42 02 D3 00 20 04 B0 70 BD D5 48 02 21 1C 38 00 EB 85 00 01 EB C4 01 40 88 08 44 83 B2 08 20 03 A9 CD E9 00 01 02 46 31 46 03 20 FF F7 78 F8 E9 E7 17 B5 11 46 CA 4A 85 B0 04 46 1C 3A 9D F8 18 00
8:58:12 AM
8:58:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 6B 09 81 80 12 F8 24 30 83 42 02 D8 00 20 08 B0 10 BD 02 EB 84 02 02 23 52 88 03 EB C0 00 10 44 83 B2 03 AA 08 20 CD E9 00 02 02 46 03 20 FF F7 98 F8 00 28 EB D0 02 A9 20 46 FF F7 99 FF 00 28 E5 D0 9D F8 18 00 9D F8 08 10 88 42 05 D9 06 A9 20 46 FF F7 9C FF 00 28 D9 D0 01 20 D7 E7 10 B5 FF 22 08 21 DE F7 CF FB 01 20 10 BD FE B5 FF 22 08 21 68 46 DE F7 C7 FB 00 24 AA 4E 27 46 1C 3E 00 25 08 E0
8:58:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 6C 09 81 80 6A 46 29 46 20 46 FF F7 B3 FF 00 28 10 D0 6D 1C ED B2 16 F8 24 00 A8 42 F2 D8 8D F8 08 70 02 A9 20 46 FF F7 72 FF 64 1C 14 F0 FF 04 E6 D0 01 20 FE BD 2D E9 F0 43 8B B0 88 46 16 00 81 46 09 D0 01 A9 FF F7 53 FF 00 28 05 D0 00 24 FF 25 4F F6 FF 77 31 E0 00 20 0B B0 7D E4 02 AA 21 46 48 46 FF F7 62 FF 00 28 F6 D0 9D F8 0D 00 FF 28 21 D0 BD F8 08 00 AD F8 10 00 9D F8 0A 00 8D F8 12 00
8:58:13 AM
8:58:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 6D 09 81 80 9D F8 0B 00 8D F8 13 00 9D F8 0C 00 8D F8 14 00 8D F8 15 50 8D F8 16 50 8D F8 17 50 AD F8 18 70 07 AA 04 A9 40 46 EC F7 39 F9 07 A9 40 46 FF F7 D1 FA 38 B1 64 1C E4 B2 9D F8 04 00 84 42 CC D3 35 70 02 E0 9D F8 0D 00 30 70 01 20 C3 E7 30 B5 8B B0 04 46 69 46 FF F7 E3 FE 00 28 52 D0 70 49 0C 22 0C 39 68 46 DD F7 2F FD E0 B3 6C 49 0C 22 18 39 68 46 DD F7 28 FD A8 B3 9D F8 00 00 FF 28
8:58:14 AM
8:58:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 6E 09 81 80 03 D1 9D F8 01 00 FF 28 3E D0 9D F8 02 00 FF 28 3A D0 9D F8 03 00 FF 28 36 D0 9D F8 05 00 FF 28 32 D0 9D F8 06 00 FF 28 2E D0 9D F8 07 00 FF 28 2A D0 9D F8 08 00 FF 28 26 D0 04 A9 68 46 04 F0 A0 FE 00 28 1E D0 07 A8 E5 F7 88 F9 03 A9 04 A8 E5 F7 04 F9 53 4D 03 99 55 F8 24 00 88 42 13 D2 04 A9 07 A8 00 E0 0F E0 FF F7 74 FA 00 28 0B DB 03 98 45 F8 24 00 04 22 29 46 41 F2 E4 10 FF F7
8:58:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 6F 09 81 80 44 F8 01 20 0B B0 30 BD 00 20 FB E7 2D E9 F0 43 07 46 00 EB 87 01 42 48 8B B0 00 EB 81 01 0A AD 88 88 0C 8A 80 46 01 19 1F FA 81 F9 26 E0 20 2C 01 D9 20 26 00 E0 26 46 CD E9 00 65 4B 46 20 22 02 A9 04 20 FE F7 4B FF 00 28 26 D0 CD E9 00 65 43 46 20 22 02 A9 04 20 FE F7 81 FF 00 28 1C D0 BD F8 28 00 00 28 18 D0 09 EB 00 01 1F FA 81 F9 08 EB 00 01 20 1A 1F FA 81 F8 84 B2 00 2C D6 D1
8:58:15 AM
8:58:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 70 09 81 80 17 B1 01 2F 05 D1 01 E0 2B 20 00 E0 8A 20 38 F0 B2 FE 24 49 01 20 09 1F 08 80 1C E7 30 B5 89 B0 FF 22 0C 21 06 A8 DE F7 AC FA 15 21 0D F1 01 00 DD F7 7A FD 00 20 8D F8 00 00 04 46 06 A9 20 46 FF F7 41 FE 05 46 6A 46 01 21 20 46 FF F7 32 FA 05 40 20 46 FF F7 ED FA 05 40 20 46 FF F7 28 FC 05 40 20 46 FF F7 55 FD 05 40 20 46 FF F7 8E FF 64 1C 14 F0 FF 04 E1 D0 09 B0 28 46 30 BD 10 B5
8:58:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 71 09 81 80 86 B0 E6 F7 5C FF 40 05 2A D4 04 A9 68 46 E5 F7 32 F9 03 A9 68 46 E5 F7 61 F8 04 22 01 49 03 E0 30 42 06 00 50 47 00 10 41 F2 E4 14 20 46 FF F7 77 F9 38 4A 03 98 00 21 52 F8 21 30 83 42 00 D9 00 23 42 F8 21 30 49 1C 11 F0 FF 01 F4 D0 04 22 30 49 20 46 FE F7 99 FF 2E 49 00 20 09 1F 08 80 06 B0 10 BD 2B 48 00 1F 01 88 19 B1 00 21 01 80 01 20 70 47 00 20 70 47 2D E9 F0 41 25 4E 05 46
8:58:16 AM
8:58:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 72 09 81 80 00 24 41 F2 E4 17 00 BF 56 F8 24 00 A8 42 06 D9 46 F8 24 50 04 22 1F 49 38 46 FE F7 76 FF 64 1C 14 F0 FF 04 F0 D0 BD E8 F0 81 30 B5 87 B0 05 46 0C 46 06 A9 01 A8 E5 F7 DE F8 28 46 FF F7 C7 FE 10 B1 28 46 FF F7 22 FF 04 AA 01 A9 28 46 FF F7 92 FA 00 28 1C D0 6B 46 9D F8 10 20 01 A9 28 46 FF F7 C8 FB 00 28 13 D0 05 AA 01 A9 28 46 FF F7 60 FE 00 28 0C D0 9D F8 14 20 FF 2A 01 D1 9D F8
8:58:17 AM
8:58:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 73 09 81 80 00 20 8D F8 00 20 23 46 01 A9 28 46 FF F7 20 FD 07 B0 30 BD 50 47 00 10 22 B1 D2 F8 7C 11 01 28 02 D0 04 E0 00 20 70 47 00 20 81 F8 48 00 01 20 70 47 70 B5 0C 46 05 46 DD F7 72 FD 00 28 3B D0 22 46 F6 A1 28 46 DD F7 F5 FC 00 28 36 D0 22 46 F3 A1 28 46 DD F7 EE FC 00 28 31 D0 06 22 F2 A1 28 46 DD F7 E7 FC 00 28 2C D0 07 22 F0 A1 28 46 DD F7 E0 FC 00 28 27 D0 22 46 EF A1 28 46 DD F7
8:58:17 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 74 09 81 80 D9 FC 18 B3 22 46 EF A1 28 46 DD F7 D3 FC F8 B1 22 46 EF A1 28 46 DD F7 CD FC D8 B1 22 46 EE A1 28 46 DD F7 C7 FC B8 B1 0C 22 EE A1 28 46 DD F7 C1 FC 98 B1 00 20 70 BD FF 20 70 BD 01 20 70 BD 02 20 70 BD 03 20 70 BD 04 20 70 BD 05 20 70 BD 06 20 70 BD 07 20 70 BD 08 20 70 BD 09 20 70 BD 2D E9 F7 4F 8A 46 00 EB 8A 14 81 46 A1 7A 9D F8 08 00 01 26 51 B1 02 27 00 25 01 29 09 D0 4F F4
8:58:18 AM
8:58:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 75 09 81 80 FA 78 02 29 16 D0 04 29 02 D1 56 E0 0D 28 2F D0 CD E0 0A 28 03 D0 0D 28 FA D0 A5 72 C7 E0 E0 69 10 B1 FD F7 20 F9 C1 E0 FC F7 44 FE E0 61 00 28 52 D0 BB E0 E0 69 20 B9 FC F7 3C FE E0 61 00 28 4A D0 9D F8 08 00 0A 28 14 D0 0D 28 E0 69 0A D0 B0 F9 14 10 41 45 0E DC 02 AA 01 21 FC F7 63 FF 01 28 38 D1 08 E0 80 8A 10 B1 04 20 A0 72 9E E0 A6 72 9C E0 E0 69 A1 E0 E0 7A 81 06 7E D5 9D F8
8:58:19 AM
8:58:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 76 09 81 80 08 10 3E 29 7A D1 C0 07 0E D0 8D F8 08 50 02 AA 01 21 E0 69 FC F7 47 FF 01 28 1C D1 63 6A 1B B1 00 20 62 6B E1 69 98 47 E0 7A 20 F0 21 00 E0 72 E0 69 FC F7 41 FE E5 61 AF E7 0A 28 0E D0 0D 28 E0 69 77 D0 FD F7 CF F8 02 AA 01 21 E0 69 FC F7 2A FF 01 28 6A D0 00 20 BD E8 FE 8F 8D F8 08 50 02 AA 01 21 E0 69 FC F7 1E FF 01 28 F3 D1 E0 69 81 89 01 29 0D D0 80 68 DD F7 92 FC 81 B2 E0 69
8:58:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 77 09 81 80 80 68 FF F7 16 FF 80 46 E0 7A C0 07 05 D0 63 6A 04 E0 FD F7 A8 F8 A7 72 DD E7 A3 6A 1B B1 40 46 62 6B E1 69 98 47 09 EB 8A 10 38 30 B8 F1 0A 0F 38 D2 DF E8 08 F0 37 05 14 37 2B 13 13 13 13 14 E0 7A C1 07 02 D0 20 F0 01 00 E0 72 C0 B2 41 07 28 D5 26 72 65 72 40 F0 10 00 13 E0 25 72 E1 7A 21 F0 10 01 E1 72 CA 07 07 D0 21 F0 01 01 E1 72 61 7A 02 29 01 D0 E5 F7 11 F8 00 E0 17 E0 E0 7A
8:58:20 AM
8:58:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 78 09 81 80 41 07 0F D5 20 F0 04 00 E0 72 0B E0 26 72 65 72 E1 7A CA 07 06 D0 21 F0 05 01 41 F0 08 01 E1 72 E4 F7 FC FF E0 69 FC F7 C7 FD E5 61 A7 72 01 20 92 E7 FF E7 B0 F9 14 10 41 45 02 DD FD F7 53 F8 F5 E7 02 AA 01 21 FC F7 AE FE 01 28 83 D1 EE E7 F8 B5 00 EB 81 14 05 46 20 7A 01 28 01 D0 60 7A F0 BB 20 6A 00 26 60 B9 E0 68 20 62 B8 B1 42 68 E2 60 02 B9 26 61 46 60 A0 8A 40 1E A0 82 20 6A
8:58:21 AM
8:58:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 79 09 81 80 68 B1 28 78 98 B1 22 6A 6B 46 D5 F8 08 01 97 8A 24 F0 64 FA BD F8 00 00 B8 42 00 D1 26 62 01 20 F8 BD 00 BF FC F7 65 FD 20 62 00 28 F8 D0 20 6A 86 89 00 2E F6 D0 20 6A 6B 46 32 46 81 68 68 78 EA F7 07 FA BD F8 00 10 51 B1 09 B2 20 6A FC F7 00 FF BD F8 00 00 30 1A 06 04 36 0C EB D1 00 E0 07 E0 20 6A 81 89 00 29 D9 D1 FC F7 42 FD 20 62 D5 E7 00 20 F8 BD 02 46 FF 20 13 78 2B B1 01 2B
8:58:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 7A 09 81 80 02 D1 04 29 00 D2 08 46 70 47 52 78 8A 42 FB D1 00 20 70 47 7C B5 04 46 00 25 01 20 CD E9 00 05 60 78 2B 46 08 22 61 68 EA F7 AB F9 25 70 7C BD 2D E9 F0 41 04 46 16 46 1F 46 DD F8 18 80 FF F7 DA FF FF 28 24 D0 04 EB 80 14 E0 69 FC F7 34 FD 20 6A FC F7 31 FD 00 25 E0 68 50 B1 41 68 E1 60 01 B9 25 61 45 60 A1 8A 49 1E A1 82 FC F7 24 FD F2 E7 04 F1 08 00 40 21 DD F7 AF FA A6 62 C4 E9
8:58:22 AM
8:58:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 7B 09 81 80 0C 78 04 20 E0 82 25 83 E5 72 25 72 02 20 A0 72 BD E8 F0 81 01 70 70 47 00 78 70 47 4F 4B 00 00 45 52 52 4F 52 00 00 00 2B 43 52 49 4E 47 00 00 43 4F 4E 4E 45 43 54 00 4E 4F 20 44 49 41 4C 54 4F 4E 45 00 4E 4F 20 43 41 52 52 49 45 52 00 00 42 55 53 59 00 00 00 00 4E 4F 20 41 4E 53 57 45 52 00 00 00 2B 43 4D 45 20 45 52 52 4F 52 3A 20 00 00 00 00 00 EB 81 10 C1 7A 41 F0 20 01 C1 72
8:58:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 7C 09 81 80 70 47 2D E9 FC 47 05 46 14 46 98 46 DD F8 28 90 FF F7 71 FF 06 46 FF 28 27 D0 1C B3 1A 20 8D F8 04 00 01 AA 01 21 20 46 FC F7 BD FD 00 20 AD F8 00 00 28 78 D8 B1 6B 46 22 46 31 46 D5 F8 08 01 24 F0 8C F9 BD F8 00 00 00 B3 05 EB 86 10 C0 F8 40 90 C0 F8 24 80 C1 7A 41 F0 01 01 C1 72 38 30 E4 F7 E0 FE 00 20 BD E8 FC 87 05 20 FB E7 6E B9 A7 89 68 78 6B 46 3A 46 A1 68 EA F7 2A F9 20 46
8:58:23 AM
8:58:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 7D 09 81 80 FC F7 9A FC BD F8 00 00 B8 42 DB D0 04 20 EA E7 2D E9 F8 4F 06 46 90 46 99 46 DD F8 28 A0 FF F7 2A FF 07 46 FF 28 07 D0 40 46 DD F7 F9 FA 50 28 04 D9 01 20 BD E8 F8 8F 05 20 FB E7 06 EB 87 14 E0 7A 80 07 01 D0 02 20 F4 E7 20 7A 01 28 04 D1 60 7A 03 28 01 D0 03 20 EC E7 FC F7 2B FC 05 00 21 D0 F9 A2 02 21 FC F7 5E FD 98 F8 00 00 38 B1 40 46 DD F7 D5 FA 01 B2 42 46 28 46 FC F7 53 FD
8:58:24 AM
8:58:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 7E 09 81 80 F2 A2 02 21 28 46 FC F7 4E FD 00 20 AD F8 00 00 30 78 50 B1 6B 46 2A 46 39 46 D6 F8 08 01 24 F0 1D F9 18 B1 05 E0 00 20 C4 E7 97 B1 28 46 FC F7 43 FC BD F8 00 00 D0 B1 C4 F8 40 A0 C4 F8 24 90 E0 7A 40 F0 01 00 E0 72 04 F1 38 00 E4 F7 6A FE E9 E7 AF 89 70 78 6B 46 3A 46 A9 68 EA F7 B9 F8 28 46 FC F7 29 FC BD F8 00 00 B8 42 E1 D0 04 20 A0 E7 2D E9 F0 47 8A B0 05 46 DD E9 12 67 89 46
8:58:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 7F 09 81 80 90 46 9A 46 FF F7 B7 FE 04 46 FF 28 08 D0 40 46 DD F7 86 FA 20 28 05 D9 01 20 0A B0 BD E8 F0 87 05 20 FA E7 05 EB 84 14 C9 A0 E6 62 00 88 AD F8 04 00 40 46 DD F7 74 FA 02 46 01 AE 41 46 70 1C DD F7 EE F8 40 46 DD F7 6B FA 30 44 00 21 41 70 53 46 01 AA 49 46 28 46 00 97 FF F7 59 FF 00 28 DB D1 E1 7A 41 F0 04 01 E1 72 D6 E7 F8 B5 04 46 8C 46 17 46 1D 46 06 9E FF F7 7D FE FF 28 0A D0
8:58:25 AM
8:58:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 80 09 81 80 04 EB 80 10 3B 46 C5 62 B2 A2 61 46 20 46 00 96 FF F7 3E FF F8 BD 05 20 F8 BD 70 B5 04 46 FF F7 6A FE FF 28 1B D0 04 EB 80 14 20 6A 08 B1 FC F7 C3 FB E0 68 00 28 12 D0 41 68 00 25 E1 60 0A E0 45 60 A1 8A 49 1E A1 82 FC F7 B6 FB E0 68 00 28 05 D0 41 68 E1 60 00 29 F2 D1 25 61 F0 E7 70 BD 2D E9 F0 41 07 46 15 46 1E 46 FF F7 44 FE 01 46 FF 28 06 D0 07 EB 81 14 E0 7A C0 07 03 D0 02 20
8:58:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 81 09 81 80 86 E6 05 20 84 E6 20 7A 58 B1 38 46 FF F7 C5 FF E0 7A C1 06 07 D5 03 21 61 72 20 F0 10 00 E0 72 0C E0 03 20 74 E6 26 64 40 F0 01 00 65 62 E0 72 01 20 60 72 04 F1 38 00 E4 F7 B4 FD 00 20 67 E6 70 B5 06 46 15 46 FF F7 16 FE 01 46 FF 28 06 D0 06 EB 81 14 00 20 22 7A 01 2A 02 D0 03 E0 05 20 70 BD 62 7A 22 B1 E1 7A C9 07 08 D0 02 20 70 BD 2B 46 00 22 30 46 FF F7 B3 FF 08 B1 70 BD 25 64
8:58:26 AM
8:58:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 82 09 81 80 E1 7A 41 F0 02 01 E1 72 70 BD 00 EB 81 10 00 7A 01 28 00 D0 00 20 70 47 00 EB 81 10 00 22 02 72 70 47 70 B5 05 46 14 46 FF F7 E5 FD 01 46 FF 28 05 D0 05 EB 81 13 18 7A 01 28 1B D1 01 E0 05 20 70 BD B3 F9 14 00 B3 F9 16 20 90 42 03 DB 18 8B 40 1C 18 83 0E E0 6C B1 00 20 60 60 18 69 58 B1 44 60 1C 61 98 8A 40 1C 98 82 28 46 FF F7 70 FD 01 20 70 BD 00 20 70 BD DC 60 F2 E7 10 B5 04 46
8:58:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 83 09 81 80 FF F7 B9 FD FF 28 13 D0 04 EB 80 10 01 7A 11 B1 01 29 0D D1 04 E0 C0 7A 80 07 00 D0 01 20 10 BD 41 7A 39 B1 01 29 0A D0 02 29 08 D0 03 29 03 D0 05 20 10 BD 02 20 10 BD C0 7A 80 07 01 D0 04 20 10 BD 03 20 10 BD 2D E9 F0 41 00 25 07 46 88 46 4F EA 05 06 07 EB 85 14 E0 69 FC F7 ED FA 20 6A FC F7 EA FA E6 61 E0 68 50 B1 41 68 E1 60 01 B9 26 61 46 60 A1 8A 49 1E A1 82 FC F7 DD FA F2 E7
8:58:27 AM
8:58:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 84 09 81 80 6D 1C ED B2 04 2D E5 D3 B8 F1 00 0F 05 D0 D7 F8 08 01 BD E8 F0 41 24 F0 0B B8 B9 E5 2D E9 FC 41 00 25 06 46 A8 46 29 46 30 46 00 F0 BD F8 06 EB 85 14 E0 7A C0 07 21 D0 04 F1 38 00 07 46 E4 F7 F9 FC 21 6C 88 42 19 D9 E0 7A 20 F0 01 00 E0 72 38 46 E4 F7 E3 FC B4 F8 44 00 40 1C A4 F8 44 00 23 6B 1B B1 00 21 0A 20 62 6B 98 47 E0 7A 41 07 04 D5 20 F0 04 00 40 F0 02 00 E0 72 20 7A 10 B1
8:58:28 AM
8:58:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 85 09 81 80 01 28 31 D1 17 E0 29 46 30 46 FF F7 C6 FE E0 7A 81 07 29 D5 20 F0 02 00 E0 72 20 6C 00 90 0E 4B 0E A2 29 46 30 46 FF F7 F3 FD 00 28 75 D0 E0 7A 40 F0 02 00 58 E0 60 7A 90 B1 01 28 15 D0 02 28 3C D0 03 28 69 D1 54 E0 41 54 00 00 0D 0A 00 00 44 00 00 00 41 00 00 00 99 39 02 00 48 00 00 00 29 46 30 46 FF F7 B4 FC 57 E0 04 F1 38 00 E4 F7 A1 FC B0 F5 96 6F 50 D9 AD F8 04 80 30 78 80 B1
8:58:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 86 09 81 80 FC F7 18 FA 07 00 48 D0 4B A2 03 21 FC F7 4B FB 01 AB 3A 46 29 46 D6 F8 08 01 23 F0 1F FF 40 B1 0A E0 4D B9 70 78 01 AB 03 22 43 A1 E9 F7 D1 FE 02 E0 38 46 FC F7 40 FA 02 20 18 E0 04 F1 38 00 07 46 E4 F7 77 FC B0 F5 16 6F 26 D9 E0 7A C1 07 0C D0 20 F0 01 00 E0 72 38 46 E4 F7 5F FC 84 F8 09 80 E0 7A 20 F0 02 00 E0 72 16 E0 03 20 60 72 13 E0 E0 7A 81 07 10 D5 20 F0 02 00 E0 72 04 F1
8:58:29 AM
8:58:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 87 09 81 80 38 00 E4 F7 57 FC 21 6C 2C 4B 08 1A AF F2 B4 02 00 90 29 46 30 46 FF F7 7B FD 6D 1C ED B2 04 2D FF F4 41 AF BD E8 FC 81 F0 B5 8B B0 05 46 00 20 AD F8 04 00 A9 70 28 78 0E 46 80 B1 01 A8 00 90 20 23 02 AA 31 46 D5 F8 08 01 23 F0 4E FE 00 28 2F D0 BD F8 04 00 28 B3 00 24 02 AF 0E E0 0E BB 68 78 01 AB 20 22 02 A9 E9 F7 7E FE EF E7 3A 5D 31 46 28 46 FF F7 34 FB 64 1C E4 B2 BD F8 04 00
8:58:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 88 09 81 80 84 42 F4 D3 05 EB 86 10 01 7A 01 29 10 D1 41 7A 03 29 0D D0 C3 6A 2B B1 C1 7A 0A 07 03 D5 21 F0 08 01 C1 72 04 E0 42 6B BD F8 04 10 02 A8 98 47 01 20 0B B0 F0 BD 00 00 2B 2B 2B 00 99 39 02 00 0E B5 02 AA 1C 21 CD E9 00 12 0A 46 01 46 00 23 13 20 FE F7 04 F9 00 28 00 D0 01 20 0E BD 2D E9 F8 4F 06 46 DD E9 0A 8B 91 46 9A 46 02 28 3F D2 F7 49 10 22 41 F2 18 20 00 91 FE F7 91 FB 01 24
8:58:30 AM
8:58:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 89 09 81 80 00 25 28 46 0A E0 0A 23 A4 FB 03 17 00 22 05 FB 03 73 04 FB 02 35 40 1C 0C 46 C0 B2 40 45 F2 D3 22 46 2B 46 48 46 51 46 F4 F7 44 FB 40 1C 41 F1 00 02 A0 FB 04 13 02 FB 04 32 00 FB 05 20 E4 4A 98 3A 02 EB C6 02 D2 E9 26 43 64 1A 83 41 02 D3 BB F1 00 0F 0C D0 02 F1 98 02 C2 E9 00 10 00 99 BD E8 F8 4F 4F F0 10 02 41 F2 18 20 FE F7 8D B9 BD E8 F8 8F 7C B5 05 46 34 F0 3D FD D4 49 98 39
8:58:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 8A 09 81 80 0A 68 82 42 00 D1 E5 B1 08 60 D1 48 18 30 FF F7 97 FF 00 28 12 D0 CE 48 18 30 00 78 06 09 00 24 6D B1 00 20 CD E9 00 60 00 22 13 46 20 46 FF F7 96 FF 64 1C E4 B2 02 2C F2 D3 01 20 7C BD 01 20 F0 E7 00 20 7C BD 0E B5 02 AA 1C 21 CD E9 00 12 0A 46 01 46 00 23 13 20 FE F7 C1 F8 00 28 00 D0 01 20 0E BD 00 28 0D D0 07 E0 02 78 42 2A 01 D0 44 2A 00 D1 20 32 00 F8 01 2B 0A 00 A1 F1 01 01
8:58:31 AM
8:58:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 8B 09 81 80 89 B2 F2 D1 70 47 2D E9 F8 4F 00 26 DD F8 28 90 82 46 88 46 9B 46 14 46 35 46 C9 F8 00 60 24 E0 1A F8 05 20 AB A1 68 46 F4 F7 A4 FB 81 19 07 46 59 45 01 D9 00 20 9B E7 9D F8 00 00 42 28 01 D0 44 28 00 D1 20 30 8D F8 00 00 9D F8 01 00 42 28 01 D0 44 28 00 D1 20 30 8D F8 01 00 69 46 20 46 DC F7 C4 FE 3C 44 3E 44 6D 1C 45 45 D8 D3 01 20 C9 F8 00 60 7C E7 70 B5 AD F5 10 7D 0D 46 20 F0
8:58:32 AM
8:58:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 8C 09 81 80 78 04 8B A9 B4 F5 7B 4F 4D D0 0A DC A4 F5 20 52 84 3A 32 D0 7C 2A 30 D0 A2 F5 4C 42 7C 3A 06 D1 0E E0 6F F4 7B 42 A2 18 3D D0 01 2A 3B D0 00 91 00 23 32 22 29 46 26 F0 41 FC 00 28 74 D0 B6 E0 C0 F3 C3 00 02 28 03 D0 00 20 0D F5 10 7D 70 BD 57 AA 00 21 E0 B2 FE F7 14 FB 9D F8 5C 01 28 80 9D F8 5C 21 0D F2 5D 11 A8 1C DC F7 99 FD 9D F8 5C 01 80 1C AD F8 2C 02 99 E0 00 91 00 23 32 22
8:58:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 8D 09 81 80 57 A9 26 F0 1B FC 00 28 DF D0 8E A8 00 90 32 23 AA 1C BD F8 2C 12 57 A8 FF F7 75 FF 00 28 D4 D0 8E 98 28 80 83 E0 80 22 6B A9 8C A8 E4 F7 F4 FB 20 46 0E F0 75 FC 00 28 C7 D0 01 7A AD F8 90 11 02 21 8D F8 98 11 D0 F8 02 10 CD F8 92 11 C0 88 AD F8 96 01 64 A9 01 A8 0E F0 13 FD 00 28 B4 D0 5B 48 4C 38 01 88 40 7D C9 B2 28 F0 F7 FB 8D F8 3F 00 20 B1 01 21 40 1E 8D F8 8E 10 26 90 8C AA
8:58:33 AM
8:58:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 8E 09 81 80 54 A9 01 A8 0F F0 67 FB 00 26 70 B1 9D F8 50 01 10 28 33 D0 1A DC 03 28 21 D0 05 28 32 D0 06 28 25 D0 0F 28 18 D1 25 E0 3D E0 4C 4A 4C A1 67 A8 F4 F7 E0 FA C4 B2 2E 80 2C 70 22 46 67 A9 A8 1C DC F7 2E FD A0 1C AD F8 2C 02 21 E0 11 28 06 D0 12 28 08 D0 16 28 02 D0 40 4A 41 A1 14 E0 9D F8 54 21 40 A1 10 E0 BD F8 54 21 3F A1 0C E0 3F A1 55 9A 09 E0 9D F8 54 21 3D A1 05 E0 BD F9 54 21
8:58:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 8F 09 81 80 3C A1 01 E0 55 9A 3C A1 67 A8 F4 F7 B3 FA C4 B2 2E 80 2C 70 22 46 67 A9 A8 1C DC F7 01 FD A4 1C AD F8 2C 42 03 E0 BD F8 2C 02 00 28 84 D0 BD F8 2C 02 4A E7 00 B5 87 B0 69 46 E4 F7 6B F9 00 22 03 A9 68 46 E4 F7 AB F9 06 A9 03 A8 E4 F7 C6 F8 06 98 07 B0 00 BD 00 B5 89 B0 03 A9 E4 F7 5A F9 07 AA 69 46 03 A8 E4 F7 D5 F9 06 A9 68 46 E4 F7 B5 F8 06 98 09 B0 00 BD 0D 28 06 D2 17 49 C1 31
8:58:34 AM
8:58:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 90 09 81 80 01 EB C0 01 D1 E9 00 01 70 47 01 20 00 21 70 47 3C 21 DC F7 62 BD F0 B5 05 46 00 20 DF F8 30 C0 16 4E 04 24 01 46 0C F1 18 0C 4F F0 01 0E 00 BF 05 EB D1 02 01 F0 07 03 12 78 F3 5C 1A 42 2F D0 A1 42 1D D2 0E FA 01 F2 02 43 90 B2 28 E0 00 00 F0 47 00 10 25 30 32 58 00 00 00 00 DF 42 06 00 25 73 00 00 25 75 00 00 25 68 75 00 25 6C 75 00 25 64 00 00 25 68 64 00 25 6C 64 00 68 C1 01 00
8:58:35 AM
8:58:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 91 09 81 80 5F F0 00 02 0C EB 02 03 9B 79 8B 42 04 D1 A7 18 0E FA 07 F3 03 43 98 B2 52 1C D2 B2 0C 2A F1 D3 49 1C C9 B2 28 29 C3 D3 F0 BD FA 4B 19 44 89 79 28 29 09 D2 F8 4B 00 EB D1 00 32 B1 01 F0 07 01 02 7D 59 5C 0A 43 02 75 70 47 01 F0 07 01 02 78 59 5C 0A 43 02 70 70 47 30 B5 90 B1 1B 23 22 24 EC 4D 18 46 00 21 6A 18 92 79 9A 42 04 D9 A2 42 02 D8 82 42 00 D9 10 46 49 1C C9 B2 0C 29 F2 D3
8:58:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 92 09 81 80 30 BD 04 23 0B 24 EB E7 3E B5 04 46 68 46 3A F0 2C FC 10 B9 64 20 AD F8 00 00 2D F0 CB FD A0 B1 01 A8 2D F0 D3 FD 58 B1 BD F8 04 00 BD F8 00 10 48 43 BD F8 06 10 B0 FB F1 F0 20 60 01 20 3E BD BD F8 00 00 20 60 00 20 3E BD BD F8 00 00 F4 E7 30 B5 A1 F1 10 04 00 23 03 2C 12 D8 10 29 08 D0 11 29 08 D0 12 29 08 D0 13 29 03 D1 4F F6 FF 71 05 E0 43 87 30 BD FF 21 01 E0 4F F4 7F 41 41 87
8:58:36 AM
8:58:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 93 09 81 80 30 BD 00 2A F5 D0 10 2A F3 D8 01 24 13 00 A2 F1 01 02 D2 B2 F4 D0 8B 1A 10 2B F7 DA 45 8F 04 FA 03 F3 1D 43 45 87 F1 E7 2D E9 FC 5F 04 46 4F F0 00 09 00 BF B9 F1 05 0F 29 D2 DF E8 09 F0 03 0E 16 1C 22 00 10 27 00 26 20 46 FF F7 24 FF 82 46 04 F1 14 00 FF F7 1F FF 04 E0 10 27 B4 F8 06 A0 60 8B 3E 46 80 46 00 25 34 E0 1A 27 20 26 D4 F8 08 A0 E0 69 F6 E7 09 27 3A 26 B4 F8 0C A0 20 8C
8:58:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 94 09 81 80 F0 E7 13 27 43 26 D4 F8 10 A0 60 6A EA E7 00 27 3E 46 BA 46 38 46 E5 E7 01 20 00 FA 05 FB 1B EA 0A 00 00 90 9D 48 06 EB 05 01 40 5C 01 D0 01 21 00 E0 00 21 E9 F7 FA FB 1B EA 08 0F 01 D0 00 98 F0 B1 96 48 71 19 40 5C 5F F0 00 01 E9 F7 21 FC 6D 1C ED B2 BD 42 DF D3 09 F1 01 00 00 F0 FF 09 B9 F1 05 0F A6 D3 00 21 08 46 E9 F7 79 FC 63 8F 01 AA 10 21 04 F1 28 00 E9 F7 7D FC BD E8 FC 9F
8:58:37 AM
8:58:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 95 09 81 80 86 48 71 19 40 5C 01 21 E0 E7 30 B5 87 B0 05 46 00 24 68 46 E9 F7 BD FB 00 28 17 D0 09 E0 00 21 20 46 E9 F7 F6 FB 00 21 20 46 E9 F7 BF FB 64 1C 24 B2 BD F8 04 00 A0 42 F1 DC 01 2D 0D D0 02 2D 06 D0 03 2D 06 D0 04 2D 18 D0 00 20 07 B0 30 BD 01 24 00 E0 00 24 02 25 0C E0 00 24 01 25 09 E0 00 21 20 46 E9 F7 D5 FB 01 21 20 46 E9 F7 9E FB 60 19 04 B2 BD F8 04 00 A0 42 F1 DC 01 20 E5 E7
8:58:38 AM
8:58:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 96 09 81 80 10 B5 07 20 29 F0 82 FE 00 69 80 B2 10 BD 10 B5 07 20 29 F0 7B FE 40 69 80 B2 10 BD 70 B5 90 B0 00 25 41 F2 15 76 34 21 01 A8 DC F7 D6 FB 0E A8 00 90 00 23 32 22 01 A9 30 46 26 F0 BF F9 60 B1 BD F8 38 00 00 28 09 D0 9D F8 04 00 60 F3 07 04 9D F8 05 00 60 F3 0F 24 A5 B2 28 46 10 B0 70 BD 30 B5 87 B0 00 24 05 A9 05 46 00 91 40 F6 95 70 01 94 02 94 03 94 23 46 10 22 04 94 01 A9 26 F0
8:58:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 97 09 81 80 9D F9 50 B1 BD F8 14 00 00 28 9F D0 04 2D 0C D0 05 2D 04 D0 06 2D 05 D0 03 24 20 46 96 E7 9D F8 04 40 FA E7 9D F8 05 40 F7 E7 9D F8 06 40 F4 E7 70 B5 04 46 3A 48 90 F8 68 00 00 F0 03 05 FF F7 AD FF 01 2D 0F D0 02 2D 01 D0 20 46 70 BD 20 1A 42 F6 DF 61 08 44 0C 21 90 FB F1 F2 01 FB 12 00 C0 F1 0C 00 06 E0 00 1B 65 30 64 21 90 FB F1 F2 01 FB 12 00 80 B2 70 BD 70 B5 C2 B0 0C 46 06 46
8:58:39 AM
8:58:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 98 09 81 80 28 F0 9F FA 05 46 69 46 30 46 29 F0 56 FD 4F F6 FF 71 D8 B1 AC 42 19 D2 00 22 68 46 07 E0 00 BF 00 EB 42 03 DB 88 8B 42 03 D0 52 1C D2 B2 AA 42 F6 D3 94 42 0A D8 00 EB 44 00 C0 88 88 42 03 D0 20 F0 78 00 40 F0 10 00 42 B0 70 BD 08 46 FB E7 F8 B5 0E 46 07 46 00 25 FF F7 82 FF 04 46 FF F7 56 FF C0 B2 A0 42 00 D2 04 46 31 88 38 46 FF F7 C3 FF 06 46 A0 F5 7F 40 41 F2 17 77 FF 38 07 D0
8:58:40 AM
8:58:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 99 09 81 80 69 46 30 46 2F F0 FB FB BE 42 00 D0 00 B1 25 46 28 46 F8 BD 08 48 00 10 68 C1 01 00 65 42 06 00 88 7A 00 10 2D E9 F0 41 14 46 1F 46 06 46 0D 46 FF F7 CE FF 01 46 00 22 AF B1 21 88 01 29 04 D9 A1 F1 01 01 21 80 BD E8 F0 81 01 D1 22 80 FA E7 00 29 F8 D1 28 88 29 46 A0 F1 01 00 28 80 30 46 FF F7 B6 FF 03 E0 20 88 88 42 02 D2 40 1C 20 80 E9 E7 22 80 28 88 40 1C 28 80 E4 E7 01 46 00 20
8:58:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 9A 09 81 80 0A 7A 04 2A 00 D1 02 20 09 88 A1 F5 B8 52 07 3A 00 D1 01 20 70 47 2D E9 F8 43 16 46 00 27 09 88 FF F7 6A FF A0 F5 7F 41 04 46 B8 46 FF 39 04 D1 A6 F8 00 80 01 20 BD E8 F8 83 24 F0 78 05 28 46 0E F0 2E F9 03 00 C4 F3 C3 01 03 D0 FF F7 D6 FF 04 46 00 E0 00 24 F7 48 90 F8 68 00 05 28 09 D0 43 B1 18 7A 04 28 06 D1 45 F0 28 00 69 46 2F F0 86 FB 00 B9 00 24 30 88 A0 42 02 D2 40 1C 30 80
8:58:41 AM
8:58:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 9B 09 81 80 02 E0 A6 F8 00 80 01 27 38 46 D4 E7 20 F0 78 01 4E F2 04 02 88 1A 91 42 59 D0 3A DC 45 F2 83 23 A1 EB 03 00 4F F4 80 72 99 42 50 D0 18 DC 45 F2 02 23 A1 EB 03 00 99 42 49 D0 0A DC A1 F5 A0 41 02 39 44 D0 91 42 42 D0 A1 F5 80 71 7F 39 40 D1 3D E0 7E 28 3B D0 7F 28 39 D0 80 28 39 D1 36 E0 40 F2 7F 33 A0 F2 7F 31 98 42 30 D0 08 DC 7F 28 2D D0 A0 F5 80 70 7F 38 29 D0 90 42 29 D1 26 E0
8:58:42 AM
8:58:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 9C 09 81 80 A1 F5 09 41 FF 39 22 D0 01 29 20 D0 02 29 20 D1 1D E0 B0 F5 C1 7F 1A D0 15 DC B0 F5 BF 7F 16 D0 08 DC 01 28 13 D0 02 28 11 D0 A0 F5 80 70 7D 38 0F D1 0C E0 A0 F5 80 70 7F 38 08 D0 01 28 06 D0 02 28 06 D1 03 E0 A0 F2 FD 20 05 28 01 D8 01 20 70 47 00 20 70 47 10 B5 00 28 0F D0 B6 4C 01 F0 07 03 00 EB D1 00 22 B1 01 7D E2 5C 11 43 01 75 03 E0 01 78 E2 5C 11 43 01 70 01 20 10 BD 00 29
8:58:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 9D 09 81 80 08 D0 AE 4B C2 88 19 44 11 F8 01 3C 01 21 99 40 0A 43 C2 80 70 47 58 B1 51 B1 01 60 C2 80 00 21 01 81 20 22 02 71 03 22 82 81 C1 81 01 20 70 47 00 20 70 47 00 28 02 D0 01 71 82 81 01 20 70 47 70 B5 0C 46 90 B1 8C B1 04 60 D1 1A C2 80 20 22 89 B2 43 81 02 71 03 29 00 D3 03 21 81 81 5D 18 05 81 E0 18 DC F7 4D FF 01 20 70 BD 00 20 70 BD 70 B5 04 00 0A D0 49 B1 A5 89 A8 18 83 B2 E0 88
8:58:43 AM
8:58:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 9E 09 81 80 98 42 05 D2 20 81 40 1B 60 81 03 E0 00 20 70 BD 23 81 62 81 62 89 20 68 DC F7 42 F9 61 89 20 68 22 79 08 44 A1 89 DC F7 2C FF 01 20 70 BD 00 28 05 D0 42 89 8A 42 00 D8 00 21 C1 81 01 20 70 47 2D E9 F0 47 04 00 0E 46 99 46 0D D0 66 B1 60 89 4F F0 00 08 90 42 03 D9 E1 89 23 89 99 42 07 D9 41 46 A4 F8 0E 80 04 E0 4F F6 FF 70 BD E8 F0 87 49 B9 90 42 07 D8 32 44 13 1A 02 46 18 46 21 68
8:58:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 9F 09 81 80 DC F7 0E F9 1D E0 88 B2 21 89 83 18 8B 42 02 D8 15 46 00 27 03 E0 09 1A 8D B2 51 1B 8F B2 21 68 2A 46 01 44 30 46 DC F7 FB F8 27 B1 70 19 3A 46 21 68 DC F7 F5 F8 B9 F1 00 0F 02 D0 E0 89 40 1C E0 81 E0 89 21 89 88 42 02 D3 40 46 A4 F8 0E 80 80 B2 CB E7 10 B5 0A 46 59 A1 30 30 F3 F7 8A FE 01 20 10 BD 1B 29 0C D0 1E 29 17 D1 56 4A 00 21 32 F8 11 30 83 42 0B D0 49 1C C9 B2 20 29 F7 D3
8:58:44 AM
8:58:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A0 09 81 80 0C E0 51 4A 00 21 40 32 32 F8 11 30 83 42 01 D1 01 20 70 47 49 1C C9 B2 19 29 F5 D3 00 20 70 47 2D E9 FE 4F 5F EA 00 0A 17 46 4F F0 FF 39 76 D0 00 29 74 D0 00 20 00 90 01 90 04 46 02 90 0B 29 00 D3 0B 21 0D 46 00 2F 01 DA A8 1E 00 E0 68 1E C2 B2 58 B2 00 28 17 DB 69 1E 88 42 5F DA D8 B2 FF F7 CA FB 00 FB 07 F3 00 2B 04 DA BB 42 56 DC 2A 46 36 A1 03 E0 BB 42 51 DB 2A 46 35 A1 68 46
8:58:45 AM
8:58:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A1 09 81 80 F3 F7 38 FE C6 B2 47 E0 C0 43 40 1C 44 B2 94 42 05 DD A0 1A C0 B2 FF F7 AF FB 97 FB F0 F7 94 42 00 DD 14 46 3A 46 AF F6 38 01 68 46 F3 F7 22 FE C0 B2 40 1E 84 42 01 DA 3B 46 D9 E7 3A 46 AF F6 50 01 68 46 F3 F7 16 FE C6 B2 E8 46 00 2F 0F DB 3B 46 2A 46 1D A1 40 46 F3 F7 0C FE 2A 1B 02 EB 08 00 A1 1B 49 1C 40 1E 30 22 DC F7 4A FE 13 E0 76 1E F6 B2 3B 46 2A 46 14 A1 40 46 F3 F7 FA FD
8:58:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A2 09 81 80 2A 1B 02 EB 08 07 A1 1B 89 1C B8 1E 30 22 DC F7 38 FE 2D 20 07 F8 02 0C 0E B1 AE 42 02 D9 48 46 BD E8 FE 8F 2A 46 69 46 50 46 DC F7 39 F8 20 46 F6 E7 00 00 58 47 00 10 68 C1 01 00 52 42 06 00 25 2E 30 38 73 00 00 00 08 44 06 00 25 20 2A 64 00 00 00 00 25 20 2A 6C 75 00 00 00 2D E9 F0 5F 04 46 0D 46 90 46 99 46 FE 48 01 88 40 7D C9 B2 27 F0 B4 FE 82 46 00 20 84 F8 38 00 25 F0 78 00
8:58:46 AM
8:58:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A3 09 81 80 0D F0 0E FF 07 00 7D D0 19 F0 30 0F 4F F0 50 0B 0D D0 84 F8 28 B0 30 20 84 F8 29 00 08 F1 31 00 84 F8 2A 00 E0 88 40 F0 01 00 E0 80 C7 E0 5F EA C9 50 18 D4 5F EA 89 50 03 D5 38 88 B0 F5 90 5F 11 D0 38 88 A0 F5 20 50 82 38 0A D0 02 28 08 D0 04 28 06 D0 7E 28 04 D0 E2 48 64 30 C0 78 80 06 1D D5 00 26 1F E0 08 F1 01 00 64 22 B0 FB F2 F1 02 FB 11 01 04 F8 28 BF 39 20 60 70 A0 70 0A 22
8:58:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A4 09 81 80 B1 FB F2 F0 00 F1 30 03 02 FB 10 10 E3 70 30 30 20 71 34 F8 22 0D 40 F0 05 00 20 80 8F E0 F8 78 02 26 00 B1 01 26 04 F1 28 05 B8 19 82 78 62 2A 2F D0 04 DC 60 2A 28 D0 61 2A 04 D1 27 E0 63 2A 2F D0 80 2A 35 D0 14 F8 38 0F 28 44 AF F6 EC 11 F3 F7 50 FD 20 78 28 44 DC F7 22 F9 21 78 08 44 04 F8 38 09 04 2E 07 D2 94 F8 38 20 E1 88 52 1E 01 20 90 40 01 43 E1 80 B8 F1 00 0F 40 D0 19 F4
8:58:47 AM
8:58:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A5 09 81 80 7F 6F 00 E0 5C E0 1C D0 3A E0 43 22 02 E0 46 22 10 E0 4C 22 94 F8 38 00 41 1C 84 F8 38 10 42 55 E0 E7 94 F8 38 00 42 1C 84 F8 38 20 00 F8 05 B0 D8 E7 55 22 94 F8 38 10 48 1C 84 F8 38 00 4A 55 D0 E7 04 2E 1C D1 40 46 FF F7 72 FC 02 46 94 F8 38 00 4F F0 01 0C 41 1E E3 88 0C FA 01 FC 43 EA 0C 03 E3 80 28 44 A0 A1 F3 F7 04 FD 94 F8 38 00 28 44 DC F7 D5 F8 94 F8 38 10 08 44 84 F8 38 00
8:58:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A6 09 81 80 BA F1 00 0F 17 D0 04 2E 0C D1 94 F8 38 00 E2 88 43 1E 01 21 99 40 0A 43 E2 80 28 44 52 46 92 A1 F3 F7 E8 FC 14 F8 38 0F 28 44 DC F7 B9 F8 21 78 08 44 04 F8 38 09 76 1C 05 2E FF F4 76 AF 01 20 BD E8 F0 9F 30 B5 FF B0 04 46 0D 46 80 22 5D A9 7D A8 E3 F7 A1 FD 25 F0 78 00 0D F0 21 FE 00 28 5F D0 01 7A AD F8 58 11 C5 F3 C3 01 8D F8 60 11 D0 F8 02 10 CD F8 5A 11 C0 88 AD F8 5E 01 56 A9
8:58:48 AM
8:58:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A7 09 81 80 68 46 0D F0 BE FE 00 28 4B D0 76 48 01 88 40 7D C9 B2 27 F0 A3 FD BD F8 58 11 8D F8 3B 00 15 29 05 D1 20 B1 01 21 40 1E 8D F8 8A 10 25 90 7D AA 53 A9 68 46 0E F0 0F FD 00 28 32 D0 9D F8 4C 01 10 28 39 D0 08 DC 03 28 10 D0 05 28 39 D0 06 28 29 D0 0F 28 06 D1 2A E0 11 28 07 D0 12 28 0A D0 16 28 03 D0 62 4A AF F6 88 31 08 E0 9D F8 50 21 AF F6 90 31 03 E0 BD F8 50 21 AF F6 94 31 59 A8
8:58:49 AM
8:58:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A8 09 81 80 F3 F7 78 FC C2 B2 08 2A 00 D9 08 22 C2 F1 10 00 C0 B2 84 F8 38 00 28 34 20 44 59 A9 DB F7 C0 FE 01 20 7F B0 30 BD AF F6 BC 31 54 9A E7 E7 9D F8 50 21 AF F6 C4 31 E2 E7 BD F9 50 21 AF F6 CC 31 DD E7 AF F6 CC 31 54 9A D9 E7 E0 B5 0E 46 09 68 86 B0 07 46 E9 B3 31 78 61 F3 07 00 71 78 61 F3 0F 20 B1 78 61 F3 17 40 F1 78 61 F3 1F 60 03 A9 E3 F7 10 FB 69 46 03 A8 02 F0 C8 FF 39 49 4C 39
8:58:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 A9 09 81 80 B1 F8 66 00 A8 B9 41 F2 11 20 38 80 9D F8 03 20 20 46 62 F3 1F 60 9D F8 02 20 62 F3 17 40 9D F8 00 20 62 F3 07 00 9D F8 01 20 62 F3 0F 20 30 60 34 71 B1 F8 66 00 01 28 11 D1 41 F2 10 20 38 80 9D F8 05 00 60 F3 07 05 9D F8 06 00 60 F3 0F 25 00 E0 07 E0 9D F8 07 00 60 F3 17 45 35 60 01 20 06 B0 E0 BD 00 20 FB E7 F0 B5 1E 4E 07 46 4C 3E 87 B0 B6 F8 66 00 0D 46 00 28 62 D0 02 28 63 D8
8:58:50 AM
8:58:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 AA 09 81 80 38 88 B6 F8 64 10 20 F0 78 00 40 F0 28 00 31 B1 2B 46 32 22 2E F0 D7 FF 01 28 55 D1 03 E0 29 46 FF F7 69 F8 E8 B1 28 68 D8 B1 29 78 20 46 61 F3 07 00 69 78 61 F3 0F 20 A9 78 61 F3 17 40 E9 78 61 F3 1F 60 03 A9 E3 F7 A5 FA 69 46 03 A8 02 F0 5D FF B6 F8 66 00 01 28 1F D1 41 F2 11 20 38 80 08 E0 31 E0 A4 47 00 10 25 30 32 75 00 00 00 00 DF 42 06 00 9D F8 03 10 20 46 61 F3 1F 60 9D F8
8:58:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 AB 09 81 80 02 10 61 F3 17 40 9D F8 00 10 61 F3 07 00 9D F8 01 10 61 F3 0F 20 28 60 2C 71 B6 F8 66 00 02 28 0F D1 41 F2 10 20 38 80 9D F8 05 00 60 F3 07 04 9D F8 06 00 60 F3 0F 24 9D F8 07 00 60 F3 17 44 2C 60 01 20 07 B0 F0 BD 00 20 FB E7 70 B5 C2 B0 06 46 27 F0 B6 FD 04 46 40 1E 85 B2 69 46 30 46 29 F0 6B F8 80 B1 00 21 68 46 4F F6 FF 72 09 E0 00 EB 41 03 DB 88 93 42 02 D1 49 1E 8D B2 03 E0
8:58:51 AM
8:58:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 AC 09 81 80 49 1C 89 B2 A1 42 F3 D3 42 B0 28 46 70 BD 10 B5 88 B0 04 00 04 D0 36 F0 51 FA 01 28 03 D0 23 E0 00 20 08 B0 10 BD 20 68 00 90 60 68 01 90 A0 68 02 90 04 AB 03 AA 05 A9 68 46 02 F0 BE FE 05 A9 01 22 08 46 36 F0 81 FB 00 28 EA D0 9D F8 10 30 BD F9 0C 20 05 A9 68 46 02 F0 8D FE 00 98 20 60 01 98 60 60 02 98 A0 60 01 20 DA E7 2D E9 F7 4F 84 B0 04 46 45 68 93 46 05 98 29 F0 C7 F8 07 46
8:58:52 AM
8:58:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 AD 09 81 80 00 68 FF F7 A8 F8 FD 4E B0 FB F6 F0 00 FB 06 FA 78 68 FF F7 A0 F8 B0 FB F6 F0 31 46 00 FB 01 F8 4F F0 01 09 64 26 FF 22 0C 21 68 46 DC F7 69 FB BB F1 00 0F 03 D0 BB F1 01 0F 5A D0 7E E0 DF F8 BC B3 20 68 CB F1 00 0B F0 BB F8 69 00 28 75 D0 78 68 FF F7 80 F8 20 60 40 45 03 D1 08 EB 0B 00 60 60 01 E0 C4 F8 04 80 01 20 07 B0 BD E8 F0 8F 30 00 A6 F1 01 06 F6 B2 0F D0 B9 F1 00 0F 10 D0
8:58:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 AE 09 81 80 DF 48 28 44 FF F7 56 F8 80 46 68 1C FF F7 52 F8 07 46 DB 48 40 1E 05 44 0E E0 64 26 4F F0 01 09 EE E7 5D 44 68 1C FF F7 45 F8 80 46 D3 48 40 1C 28 44 FF F7 3F F8 07 46 FF 22 0C 21 68 46 DC F7 20 FB 6B 46 3A 46 00 E0 0E E0 41 46 05 98 28 F0 0F FB 48 B1 B9 F1 00 0F 09 D0 64 26 4F F0 00 09 38 46 FF F7 38 F8 45 1E 55 45 C1 D2 26 E0 65 60 19 E0 20 68 10 B9 4F F6 FF 70 20 81 20 89 AD F8
8:58:53 AM
8:58:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 AF 09 81 80 0A 00 60 89 AD F8 00 00 68 1C FF F7 13 F8 06 46 BA 48 28 44 FF F7 0E F8 02 46 6B 46 31 46 05 98 28 F0 E6 FA 50 B1 01 98 FF F7 15 F8 20 60 BD F8 0A 00 20 81 BD F8 00 00 60 81 95 E7 00 20 94 E7 2D E9 F7 4F 86 B0 04 46 45 68 07 98 29 F0 1E F8 07 46 00 68 FE F7 FF FF A8 4E B0 FB F6 F0 00 FB 06 F8 78 68 FE F7 F7 FF B0 FB F6 F0 31 46 00 FB 01 FB 4F F6 FF 7A 00 20 CD E9 03 A0 4F F0 01 09
8:58:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B0 09 81 80 64 26 FF 22 0C 21 68 46 DC F7 BB FA 08 98 10 B1 01 28 63 D0 54 E0 20 68 F0 BB F8 69 E8 B3 38 68 FE F7 D9 FF 20 60 40 45 05 D1 94 49 49 42 08 EB 01 00 60 60 01 E0 C4 F8 04 80 01 20 09 B0 55 E7 30 00 A6 F1 01 06 F6 B2 0F D0 B9 F1 00 0F 10 D0 68 1C FE F7 AF FF 80 46 8A 48 28 44 FE F7 AA FF 07 46 88 48 40 1E 05 44 0F E0 64 26 4F F0 01 09 EE E7 82 48 05 44 68 1C FE F7 9C FF 80 46 7F 48
8:58:54 AM
8:58:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B1 09 81 80 40 1C 28 44 FE F7 96 FF 07 46 FF 22 0C 21 68 46 DC F7 77 FA 6B 46 01 E0 10 E0 11 E0 3A 46 41 46 07 98 28 F0 65 FA 48 B1 B9 F1 00 0F 0A D0 64 26 4F F0 00 09 40 46 FE F7 8E FF 45 1E 5D 45 BF D9 00 20 BB E7 65 60 01 98 FE F7 85 FF 20 60 BD F8 0A 00 20 81 BD F8 00 00 60 81 AE E7 20 68 18 B1 B4 F8 08 A0 60 89 03 90 60 68 40 1C FE F7 62 FF 06 46 62 48 61 68 08 44 FE F7 5C FF 05 46 4F F6
8:58:55 AM
8:58:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B2 09 81 80 FF 70 AD F8 0A 00 14 E0 BD F8 0A 10 51 45 04 D1 BD F8 00 10 03 98 81 42 13 D0 01 98 FE F7 5B FF 20 60 BD F8 0A 00 20 81 BD F8 00 00 60 81 01 20 04 90 6B 46 2A 46 31 46 07 98 28 F0 19 FA 00 28 E2 D1 04 98 7A E7 2D E9 FF 4F AD F2 64 4D 06 46 0D F5 93 60 00 27 B0 E8 20 01 4F F6 FF 7B CD F8 4C 74 CD F8 50 74 99 46 5C 46 BA 46 CD F8 54 74 CD F8 34 74 CD F8 38 74 FF 22 0C 21 0D F5 88 60
8:58:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B3 09 81 80 CD F8 3C 74 DC F7 FD F9 30 68 FE F7 13 FF CD F8 44 04 70 89 AD F8 40 04 30 89 AD F8 4A 04 DD F8 68 04 29 F0 25 F8 30 B1 C6 F8 00 A0 C6 F8 04 A0 C6 F8 08 A0 75 E0 DD F8 6C 04 20 B1 01 28 21 D0 02 28 1E D1 40 E0 30 68 00 28 1A D0 70 68 FE F7 F1 FE 0D F2 4C 41 E3 F7 5D F8 0D F2 34 41 0D F2 4C 40 02 F0 13 FD 0D F2 34 40 FF F7 10 FE DD F8 34 14 C8 F8 00 10 9D F8 38 14 88 F8 04 10 41 F2
8:58:56 AM
8:58:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B4 09 81 80 11 24 8C E0 30 68 00 28 1D D0 FE F7 D3 FE 0D F2 4C 41 E3 F7 3F F8 0D F2 34 41 0D F2 4C 40 02 F0 F5 FC 0D F2 34 40 FF F7 F2 FD DD F8 34 14 C8 F8 00 10 DD F8 38 14 C8 F8 04 10 DD F8 3C 14 C8 F8 08 10 48 F2 10 04 6A E0 0D F2 5C 41 08 1F CD E9 00 01 0D F5 88 63 40 F2 24 42 02 A9 DD F8 68 04 28 F0 F3 FE A8 B3 29 88 DD F8 68 04 FF F7 C4 F8 04 46 20 F0 78 00 4F F4 00 46 1F E0 80 51 01 00
8:58:57 AM
8:58:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B5 09 81 80 01 2A 7C FF 01 D6 83 00 28 88 B9 F1 04 0F 0C D0 40 1C 28 80 DD F8 68 04 FF F7 98 FD 29 88 88 42 05 D2 58 46 0D F2 74 4D 20 E6 40 1E F1 E7 DD F8 68 04 FF F7 A1 F8 04 46 20 F0 78 00 B0 42 E3 D0 DD F8 68 04 FF F7 82 FD 29 88 88 42 27 D3 00 24 12 E0 24 E0 21 46 DD F8 68 04 FF F7 8D F8 20 F0 78 01 B1 42 06 D0 25 F0 C1 F9 40 88 C0 F3 0A 00 38 44 87 B2 64 1C A4 B2 28 88 A0 42 EA D8 81 B2
8:58:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B6 09 81 80 DD F8 68 04 FF F7 78 F8 04 46 25 F0 AF F9 40 88 C0 F3 0A 02 02 A8 C1 19 40 46 DB F7 41 FB 20 46 C0 E7 2D E9 FE 43 04 46 15 46 1E 46 89 46 08 46 28 F0 6C FE 80 46 FF 22 0C 21 68 46 DC F7 21 F9 20 68 00 27 20 B1 04 2E 09 D0 03 2E 0A D0 0C E0 04 2E 02 D0 D8 F8 10 00 05 E0 2F 60 05 E0 28 68 40 1C 01 E0 28 68 40 1E 28 60 29 68 D8 F8 10 00 4F F6 FF 75 81 42 0F D2 6A 46 48 46 28 F0 E9 F8
8:58:58 AM
8:58:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B7 09 81 80 50 B1 01 98 20 60 BD F8 0A 00 20 81 BD F8 00 00 60 81 01 20 BD E8 FE 83 27 60 25 81 00 20 F9 E7 2D E9 FF 4F AD F2 5C 4D 06 46 4F F6 FF 78 40 F2 24 4A 17 46 9B 46 44 46 4F F0 00 09 51 46 02 A8 DD F8 90 54 DB F7 89 FB 30 68 FE F7 F3 FD CD F8 3C 04 70 89 AD F8 38 04 30 89 AD F8 42 04 17 B1 01 2F 17 D1 17 E0 30 68 00 28 13 D0 0D F2 44 41 E2 F7 50 FF 0D F2 2C 41 0D F2 44 40 02 F0 06 FC
8:58:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B8 09 81 80 DD F8 94 04 DD F8 2C 14 41 F2 11 24 01 60 9D F8 30 14 01 71 AC E0 0D F2 54 41 08 1F CD E9 00 01 0D F5 87 63 52 46 02 A9 DD F8 60 04 28 F0 0D FE 00 28 41 D0 29 88 DD F8 60 04 FE F7 DD FF 04 46 DD F8 60 04 FF F7 C2 FC 24 F0 78 01 40 F2 85 4A 07 46 51 45 14 D0 17 E0 28 88 BB F1 04 0F 08 D0 40 1C 81 B2 28 80 B9 42 05 D9 40 46 0D F2 6C 4D 3C E5 40 1E F5 E7 DD F8 60 04 FE F7 BD FF 04 46
8:58:59 AM
8:58:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 B9 09 81 80 24 F0 78 01 51 45 E7 D0 24 F0 78 00 4F F4 00 4B 58 45 12 D1 0D F2 44 41 30 68 E2 F7 FB FE 0D F2 2C 41 0D F2 44 40 02 F0 B1 FB DD F8 94 04 DD F8 31 14 41 F2 10 24 01 60 5A E0 28 88 02 AE B8 42 29 D8 00 24 13 E0 21 46 DD F8 60 04 FE F7 94 FF 20 F0 78 01 59 45 08 D0 25 F0 C8 F8 40 88 C0 F3 0A 01 01 EB 09 00 1F FA 80 F9 64 1C A4 B2 28 88 A0 42 E8 D8 81 B2 DD F8 60 04 FE F7 7D FF 04 46
8:59:00 AM
8:59:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 BA 09 81 80 25 F0 B4 F8 40 88 06 EB 09 01 C0 F3 0A 02 DD F8 94 04 DB F7 45 FA 24 F0 78 00 A0 F5 80 61 86 39 01 D0 49 1E 24 D1 00 25 2C 46 1D E0 21 46 DD F8 60 04 FE F7 61 FF 20 F0 78 02 52 45 09 D1 70 19 FF 21 0D F0 B9 F8 08 B1 00 88 00 E0 40 46 80 46 0C E0 5A 45 06 D0 25 F0 89 F8 40 88 C0 F3 0A 00 28 44 85 B2 64 1C A4 B2 BC 42 DF D3 48 F0 10 04 20 46 7B E7 38 B5 0C 46 FE 49 15 46 31 F8 10 00
8:59:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 BB 09 81 80 20 F0 78 00 B0 F5 90 5F 05 D0 6F F4 90 51 40 18 01 D0 00 20 38 BD 68 46 E2 F7 21 FF 00 98 FE F7 1A FD 20 60 05 20 28 70 01 20 38 BD 10 B5 04 46 8A B0 08 46 69 46 E2 F7 6D FE 24 F0 78 00 B0 F5 90 5F 12 D0 6F F4 90 51 40 18 02 D0 00 20 0A B0 10 BD 09 A9 03 A8 E2 F7 8E FE BD F8 11 00 AD F8 05 00 9D F8 13 00 8D F8 07 00 00 22 06 A9 68 46 E2 F7 95 FE 06 A8 34 F0 76 FD 00 28 E7 D0 01 20
8:59:01 AM
8:59:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 BC 09 81 80 E5 E7 F0 B5 87 B0 06 46 0F 46 15 46 03 2B 02 D0 04 2B 11 D1 01 E0 01 24 01 E0 4F F0 FF 34 69 46 38 68 E2 F7 37 FE 26 F0 78 00 B0 F5 90 5F 46 D0 6F F4 90 51 40 18 02 D0 00 20 07 B0 F0 BD 06 2D 6A D2 DF E8 05 F0 36 2F 22 19 0C 03 BD F8 00 00 04 EB 84 01 00 EB 41 00 AD F8 00 00 5C E0 BD F8 00 00 00 22 20 44 AD F8 00 00 03 A9 68 46 E2 F7 56 FE 18 BB 1C 20 1F E0 9D F8 02 00 04 EB 84 01
8:59:02 AM
8:59:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 BD 09 81 80 00 EB 41 00 8D F8 02 00 46 E0 9D F8 02 00 00 22 20 44 8D F8 02 00 03 A9 68 46 E2 F7 40 FE 68 B9 01 20 09 E0 9D F8 03 00 04 EB 84 01 00 EB 41 00 02 E0 9D F8 03 00 20 44 8D F8 03 00 2C E0 06 2D 2A D2 DF E8 05 F0 24 1D 17 10 0A 03 9D F8 05 00 04 EB 84 01 00 EB 41 00 02 E0 9D F8 05 00 20 44 8D F8 05 00 18 E0 9D F8 06 00 04 EB 84 01 00 EB 41 00 02 E0 9D F8 06 00 20 44 8D F8 06 00 0B E0
8:59:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 BE 09 81 80 9D F8 07 00 04 EB 84 01 00 EB 41 00 02 E0 9D F8 07 00 20 44 8D F8 07 00 00 22 03 A9 68 46 E2 F7 FE FD 00 28 89 D0 39 46 68 46 E2 F7 17 FD 84 E7 2D E9 FF 41 16 46 07 46 88 46 1C 46 01 22 31 46 18 46 FE F7 05 FD 00 25 11 2E 01 D0 13 2E 00 D1 01 25 00 23 1A 46 39 46 20 46 FF F7 FF F8 00 28 12 D0 01 A9 40 46 E2 F7 95 FD 08 20 84 F8 38 00 27 F0 78 01 04 F1 30 00 B1 F5 90 5F 20 D0 6F F4
8:59:03 AM
8:59:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 BF 09 81 80 90 52 89 18 03 D0 00 20 04 B0 BD E8 F0 81 9D F8 07 10 00 91 9D F8 06 30 BD F8 04 20 76 A1 F2 F7 A9 FE 35 B1 60 8B 40 F4 80 60 60 83 40 F4 80 50 1B E0 E0 88 40 F4 80 60 E0 80 40 F4 80 50 20 E0 9D F8 0B 10 00 91 9D F8 0A 30 9D F8 09 20 6E A1 F2 F7 90 FE 5D B1 60 8B 40 F4 80 60 40 F4 80 40 40 F4 80 50 60 83 40 F4 00 40 60 83 0A E0 E0 88 40 F4 80 60 40 F4 80 40 40 F4 80 50 E0 80 40 F4
8:59:04 AM
8:59:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C0 09 81 80 00 40 E0 80 01 20 BF E7 20 F0 78 00 B0 F5 75 4F 1D D0 0A DC A0 F5 20 51 84 39 18 D0 7C 29 16 D0 A1 F5 A0 61 7C 39 09 D1 11 E0 B0 F5 7B 4F 0E D0 6F F4 7B 41 41 18 0A D0 01 29 08 D0 A0 F5 84 51 07 29 04 D9 6F F4 88 51 08 44 81 28 01 D8 01 20 70 47 00 20 70 47 30 B5 8F B0 0D 46 69 46 FE F7 CA FA 00 28 18 D0 BD F8 00 40 80 22 4A 49 0D A8 E2 F7 12 FF 22 46 0D F1 02 01 0D A8 E2 F7 65 FF
8:59:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C1 09 81 80 BD F8 38 30 BD F8 3A 20 28 46 0D 99 FE F7 18 FF 00 28 01 D0 BD F8 38 00 0F B0 30 BD 10 B5 0C 46 08 21 80 F8 38 10 00 F1 30 01 13 46 08 22 20 46 FE F7 46 FF 01 20 10 BD 70 B5 0C 46 36 49 06 46 54 39 0D 46 FF F7 C7 FF 00 23 1A 46 31 46 20 46 FF F7 44 F8 00 21 28 46 FE F7 29 FF 01 22 29 46 20 46 FF F7 DB FF 20 46 FE F7 5E FC BD E8 70 40 29 48 40 38 E2 F7 96 BD 7C B5 27 49 06 9D CC 39
8:59:05 AM
8:59:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C2 09 81 80 01 EB C0 04 04 F1 98 04 D4 E9 00 14 51 1A 73 EB 04 01 06 D3 00 21 CD E9 00 51 FE F7 A0 F9 01 20 7C BD 00 20 7C BD 2D E9 FF 4F A3 B0 00 26 30 9F 04 46 80 F8 38 60 15 46 B1 46 34 21 05 A8 DB F7 CC F8 BD F8 90 00 20 F0 78 00 0C F0 29 FF 80 46 BD F8 90 00 24 F0 8A FE 82 46 BD F8 90 00 FF F7 53 FF 70 B3 0C 48 40 38 05 46 E2 F7 63 FD B0 F5 7A 7F 13 E0 4C 42 06 00 25 30 34 75 25 30 32 75
8:59:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C3 09 81 80 25 30 32 75 00 00 00 00 20 20 25 30 32 75 25 30 32 75 25 30 32 75 00 00 24 48 00 10 04 D9 28 46 E2 F7 40 FD 4F F0 01 09 00 23 1A 46 BD F8 90 10 20 46 FE F7 D3 FF 4A 46 F6 49 20 46 FF F7 6E FF F1 E3 FF E7 B8 F1 00 0F 02 D0 BA F1 00 0F 00 D1 9D B1 DF F8 C0 B3 00 21 AB F1 78 0B 58 46 8B F8 68 10 4F F0 05 09 15 B3 B8 06 17 D5 28 68 05 90 68 68 06 90 A8 68 07 90 7A E0 00 23 1A 46 BD F8
8:59:06 AM
8:59:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C4 09 81 80 90 10 20 46 FE F7 AA FF 00 28 7C D0 BD F8 90 10 20 46 FF F7 97 F8 00 28 F7 D0 C4 E3 BA F8 02 00 29 46 C0 F3 0A 02 05 A8 DA F7 BA FF 60 E0 B0 F8 64 10 05 46 AD F8 4C 10 E1 B3 05 AB 32 22 BD F8 90 00 2E F0 40 F9 00 B2 20 B1 02 28 04 D0 03 28 1E D0 0E E0 D0 49 17 E0 BD F8 90 00 A0 F5 B8 51 17 39 0A D1 05 AB 32 22 BD F8 4C 10 2E F0 A4 F9 70 B1 BD F8 4C 00 26 90 3A E0 85 F8 68 90 00 23
8:59:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C5 09 81 80 BD F8 4C 20 01 46 0A E0 20 46 FE F7 A3 FE 8A E3 85 F8 68 90 BD F8 4C 20 BD F8 90 10 00 23 20 46 FE F7 5C FF BC 48 95 F8 68 10 39 30 00 EB C1 00 41 68 E9 E7 FF E7 BD F8 90 00 13 AA 20 F0 78 00 03 A9 22 F0 8D FE 10 B1 BD F8 4C 00 26 90 95 F8 A8 00 05 A9 40 F0 01 00 85 F8 A8 00 BD F8 90 00 FE F7 89 F9 50 B3 15 F8 A8 0F 20 F0 01 00 28 70 3B 46 BD F8 90 10 20 46 26 9A FE F7 2F FF 40 B3
8:59:07 AM
8:59:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C6 09 81 80 BD F8 90 10 00 E0 FC E3 A1 F5 B8 50 17 38 10 D1 9B F8 A8 00 5D 46 40 F0 01 00 8B F8 A8 00 05 A9 24 A8 FF F7 92 F8 B8 B1 15 F8 A8 0F 20 F0 01 00 28 70 98 F8 08 00 04 28 1D D0 2E E0 96 49 20 46 09 31 FE F7 47 FE 15 F8 A8 0F 20 F0 01 00 28 70 F5 E3 91 49 09 31 EF E3 05 F1 89 05 8E 49 05 F8 21 9C 01 F1 2D 01 20 46 FE F7 34 FE E8 7F 20 F0 01 00 E8 77 17 E3 9B F8 A8 00 5D 46 40 F0 01 00
8:59:08 AM
8:59:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C7 09 81 80 8B F8 A8 00 05 A9 24 A8 FF F7 AE F8 00 28 E3 D0 15 F8 A8 0F 20 F0 01 00 28 70 08 20 84 F8 38 00 BD F8 90 C0 41 F6 03 13 2C F0 78 01 DF F8 E4 91 CA 1A 4F F0 64 0B 09 F1 38 09 04 F1 28 05 04 F1 30 00 99 42 12 D0 37 DC 41 F2 01 03 A1 EB 03 02 99 42 16 D0 16 DC 87 29 76 D0 08 DC 01 29 05 D0 02 29 03 D0 03 29 01 D0 04 29 5B D1 ED E0 A1 F5 80 71 83 39 69 D0 03 29 EE D0 A1 F5 60 61 7D 39
8:59:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C8 09 81 80 50 D1 E0 E0 40 F2 FF 43 A2 F2 FF 41 9A 42 5C D0 08 DC FF 2A 77 D0 A2 F5 80 72 FF 3A 56 D0 01 2A 40 D1 5B E0 B1 F5 80 6F 05 D0 A1 F5 80 61 01 39 01 D0 01 29 36 D1 C8 E0 4A F6 FF 53 D1 1A 9A 42 13 D0 1F DC 43 F6 01 03 A2 EB 03 01 9A 42 F7 D0 0C DC A2 F5 70 62 7F 3A 7E D0 04 2A FC D0 A2 F5 1C 52 7E 3A EC D0 04 2A 1C D1 28 E1 A1 F5 38 51 FC 39 72 D0 B1 F5 8E 4F F7 D0 6F F4 8E 40 08 18
8:59:09 AM
8:59:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 C9 09 81 80 10 D1 1C E1 04 29 F0 D0 06 DC 01 29 ED D0 02 29 EB D0 03 29 06 D1 12 E1 05 29 E6 D0 7E 29 E4 D0 7F 29 E2 D0 21 AA 12 A9 60 46 2D F0 40 FE 9D F8 49 00 1F 28 6D D0 79 DC 1C 28 78 D0 78 DC 08 28 77 D0 1B 28 76 D1 38 E1 E3 E0 82 E0 9D F8 16 10 00 91 9D F8 15 30 9D F8 14 20 B7 E0 9D F8 14 00 8D F8 65 00 9D F8 15 00 8D F8 64 00 99 F8 03 00 4E 46 10 F0 C0 00 07 D0 40 28 11 D0 80 28 2F D0
8:59:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 CA 09 81 80 C0 28 1F D1 39 E0 5E E0 BD F8 64 10 9D F8 17 00 B1 FB FB F2 0B FB 12 12 00 90 9D F8 16 30 0A E0 BD F8 64 10 B1 FB FB F2 0B FB 12 10 00 90 9D F8 16 30 9D F8 17 20 94 F8 38 00 28 44 AF F2 B8 31 F2 F7 D8 FB F0 78 10 F0 C0 00 34 D0 40 28 32 D0 80 28 30 D0 C0 28 01 E0 93 E0 45 E0 43 D1 2E E0 9D F8 17 00 00 90 94 F8 38 00 9D F8 16 30 BD F8 64 20 28 44 AF F2 00 41 E2 E7 BD F8 64 00 00 90
8:59:10 AM
8:59:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 CB 09 81 80 94 F8 38 00 9D F8 16 30 9D F8 17 20 28 44 03 A1 D6 E7 BD E0 D0 47 00 10 DF 42 06 00 25 30 32 75 25 30 32 75 25 30 34 75 00 00 00 00 A4 E0 CB E0 9D E0 D9 E0 B0 E0 E0 88 40 F4 A0 50 28 E0 E0 88 40 F4 A0 60 24 E0 05 AA 75 E0 BD F8 14 20 F7 A1 72 E0 F7 A1 05 9A F2 F7 8D FB 81 B2 94 F8 38 00 28 44 FD F7 BF FF D0 E2 B9 06 13 D5 9D F8 1A 20 9D F8 19 10 CD E9 00 12 9D F8 17 30 9D F8 16 20
8:59:11 AM
8:59:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 CC 09 81 80 ED A1 F2 F7 77 FB E0 88 40 F4 A0 60 40 F4 10 40 E0 80 BA E2 F8 07 09 D0 1E A9 05 A8 E2 F7 3A FA 22 AA 19 A9 1E A8 E2 F7 B5 FA 03 E0 19 A9 05 A8 E2 F7 30 FA B8 07 11 D5 9D F8 16 00 00 90 94 F8 38 00 9D F8 15 30 9D F8 14 20 28 44 AF F2 C8 41 F2 F7 50 FB E0 88 40 F4 88 40 D7 E7 BD F8 64 10 9D F8 17 00 B1 FB FB F2 00 90 94 F8 38 00 0B FB 12 12 9D F8 16 30 28 44 AF F2 F4 41 F2 F7 3A FB
8:59:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 CD 09 81 80 99 E7 0A 20 84 F8 38 00 05 F1 0A 00 0D F1 1E 02 11 E0 BD F8 14 00 05 AA 00 21 13 18 08 28 99 70 76 D8 94 F8 38 10 C0 F1 08 00 08 44 C0 B2 84 F8 38 00 28 44 92 1C C5 49 F2 F7 1C FB 65 E2 05 98 3C 21 B0 FB F1 F0 02 46 05 90 C1 49 15 A8 F2 F7 11 FB C2 B2 08 2A 00 D9 08 22 C2 F1 10 00 C0 B2 84 F8 38 00 28 44 15 A9 DA F7 5A FD 4D E2 1D 28 27 D0 1E 28 10 D1 08 E0 20 28 1B D0 21 28 27 D0
8:59:12 AM
8:59:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 CE 09 81 80 23 28 29 D0 2C 28 07 D1 2A E0 B2 49 A0 68 1D E0 B1 49 A0 68 1A E0 A0 60 9D F8 49 00 0D F1 54 0B 1B 38 09 28 79 D2 DF E8 00 F0 F6 F6 F6 23 23 23 F4 78 F3 00 A9 49 A0 68 08 E0 A0 68 40 F4 7E 50 E9 E7 A7 49 A0 68 01 E0 A6 49 A0 68 08 43 E2 E7 A0 68 40 F4 D7 20 DE E7 A0 68 40 F4 60 70 DA E7 A0 68 40 F0 E0 70 D6 E7 A0 68 40 F0 02 00 D2 E7 99 F8 00 00 4F 46 4F EA 10 18 00 F0 0F 06 01 20
8:59:13 AM
8:59:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 CF 09 81 80 32 F0 0E F8 28 B1 F8 7C 4F F0 08 08 06 09 06 E0 7F E0 B8 F1 00 0F 7C D0 B8 F1 08 0F 79 D8 46 45 77 DA B8 7C 00 09 06 D0 01 28 07 D0 02 28 08 D0 03 28 6E D1 08 E0 00 27 38 46 07 E0 03 27 50 20 04 E0 06 27 30 20 01 E0 09 27 0C 20 A1 68 01 43 A1 60 F1 B2 20 46 FE F7 52 FB 9D F8 48 00 9D F8 49 10 38 1A 80 1B 46 B2 BD F8 90 00 00 2E 20 F0 78 00 20 DA FE F7 F6 FB 00 28 C6 F1 00 00 0D D0
8:59:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D0 09 81 80 C0 B2 FD F7 F9 FF DD E9 05 23 06 46 A6 FB 02 07 01 FB 02 71 06 FB 03 16 25 E0 C0 E1 C0 B2 FD F7 EB FF DD E9 05 32 06 46 A6 FB 03 07 01 FB 03 71 06 FB 02 16 17 E0 FE F7 D5 FB 00 28 F0 B2 09 D0 FD F7 DA FF 02 46 DD E9 05 06 0B 46 31 46 F2 F7 E8 F9 07 E0 FD F7 D0 FF 02 46 0B 46 DD E9 05 01 F2 F7 68 F9 0E 46 81 46 BD F8 90 00 9D F8 49 10 20 F0 78 00 FE F7 B6 FB E8 B1 00 2E 1B DA CD E9
8:59:14 AM
8:59:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D1 09 81 80 00 96 0F 22 58 A1 15 A8 F2 F7 34 FA C8 F1 0F 07 00 E0 89 E0 C8 F1 10 00 20 44 07 EB 0B 01 28 30 42 46 DA F7 7D FC 2D 20 08 2F 00 DC 08 27 39 19 81 F8 28 00 10 E0 CD E9 00 96 0F 22 4C A1 15 A8 F2 F7 18 FA C8 F1 10 00 C8 F1 0F 01 20 44 59 44 28 30 42 46 DA F7 64 FC DF F8 1C A1 00 27 00 BF BD F8 90 10 3A F8 17 00 21 F0 78 01 88 42 0A D1 4A 46 33 46 38 46 CD F8 00 80 FF F7 FD FB 10 B1
8:59:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D2 09 81 80 E1 20 35 F0 38 FE 7F 1C FF B2 02 2F E8 D3 3C E1 1A E1 FC E0 FF E7 99 F8 01 00 06 09 00 F0 0F 07 01 20 31 F0 3D FF 20 B1 99 F8 13 00 07 26 00 F0 0F 07 BD F8 90 00 FE F7 29 FA 60 B1 04 2E 15 D3 F0 1B 04 28 04 DC C0 F1 04 00 47 B2 04 26 10 E0 00 27 04 26 0F E0 98 F8 05 00 02 28 06 D1 B0 1C 08 28 01 D2 B6 1C 00 E0 08 26 F6 B2 E6 B1 08 2E 1A D8 B7 42 18 DA 99 F8 12 00 10 F0 0F 00 06 D0
8:59:15 AM
8:59:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D3 09 81 80 01 28 08 D0 02 28 0A D0 03 28 0D D1 36 E0 4F F0 00 0C 60 46 35 E0 4F F0 03 0C 50 20 31 E0 4F F0 06 0C 30 20 2D E0 F8 E0 C5 E0 00 00 25 38 58 00 25 30 38 6C 58 00 00 00 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 00 00 00 00 40 51 02 00 6C 48 02 00 80 3F 38 00 80 BB 46 00 80 BB 56 00 80 BB 16 00 80 BB 06 00 25 30 2A 6C 6C 64 00 00 25 30 2A 6C 6C 75 00 00 48 42 06 00 4F F0 09 0C
8:59:16 AM
8:59:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D4 09 81 80 0C 20 A1 68 01 43 A1 60 F9 B2 20 46 FE F7 37 FA 9D F8 48 00 9D F8 49 10 AC EB 00 00 C0 1B 47 B2 BD F8 90 00 00 2F 20 F0 78 00 13 DA FE F7 DA FA 00 28 C7 F1 00 00 06 D0 C0 B2 FD F7 DD FE 05 99 00 FB 01 F7 16 E0 C0 B2 FD F7 D6 FE 05 99 00 FB 01 F7 0F E0 FE F7 C6 FA 00 28 F8 B2 05 D0 FD F7 CB FE 05 99 91 FB F0 F7 04 E0 FD F7 C5 FE 05 99 B1 FB F0 F7 BD F8 90 00 9D F8 49 10 20 F0 78 00
8:59:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D5 09 81 80 FE F7 B0 FA D0 B1 00 2F 18 DA 3B 46 0F 22 F7 A1 15 A8 F2 F7 2F F9 C6 F1 10 00 C6 F1 0F 07 20 44 07 EB 0B 01 28 30 32 46 DA F7 7A FB 2D 20 08 2F 00 DC 08 27 39 19 81 F8 28 00 0F E0 3B 46 0F 22 EC A1 15 A8 F2 F7 16 F9 C6 F1 10 00 C6 F1 0F 01 20 44 59 44 28 30 32 46 DA F7 62 FB BD F8 90 00 FE F7 54 F9 78 B3 00 21 BD F8 90 00 2D F0 80 FD 02 46 E2 A1 15 A8 F2 F7 FD F8 BD F8 54 00 20 86
8:59:17 AM
8:59:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D6 09 81 80 00 E0 1D E0 9D F8 56 00 84 F8 32 00 3D E0 99 F8 14 00 00 F0 0F 06 1A E0 40 42 C0 B2 FD F7 6C FE 05 99 00 FB 01 F3 72 1C D2 A1 15 A8 F2 F7 E2 F8 C2 B2 08 2A 19 D9 D3 49 20 46 FE F7 4B FA 00 20 27 B0 BD E8 F0 8F 20 E0 99 F8 14 00 06 09 9D F8 48 00 40 42 80 1B 40 B2 00 28 DD DB C0 B2 FD F7 4B FE 05 99 B1 FB F0 F3 DD E7 94 F8 38 00 C2 F1 08 01 08 44 C0 B2 84 F8 38 00 28 44 15 A9 DA F7
8:59:18 AM
8:59:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D7 09 81 80 0F FB F1 B2 20 46 FE F7 7A F9 14 F8 38 0F 28 44 DA F7 86 FC 21 78 08 44 20 70 01 20 D0 E7 98 F8 08 00 03 28 18 D0 04 28 16 D0 BA F8 02 00 44 F2 02 02 81 1A 90 42 4C D0 20 DC 01 28 39 D0 A0 F5 80 51 02 39 39 D0 A1 F5 80 51 02 39 39 D0 A1 F5 70 61 FD 39 21 D1 38 E0 08 21 58 46 12 9B 05 9A FE F7 1E FA 00 28 04 DB C1 B2 20 46 FE F7 47 F9 5B E0 A4 4A A4 A1 09 3A 15 A8 38 E0 A1 F5 80 51
8:59:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D8 09 81 80 02 39 2E D0 A1 F5 70 61 FD 39 12 D0 B1 F5 80 5F 0F D0 A1 F5 E0 41 03 39 13 D0 00 F4 78 41 C0 F3 0A 09 B1 F5 20 4F 26 D0 96 4A 97 A1 12 3A 58 46 1D E0 9D F8 14 20 95 A1 F9 E7 BD F8 14 20 94 49 F5 E7 93 49 05 9A 09 1D F1 E7 9D F8 14 20 91 A1 ED E7 94 F8 38 00 8E 49 BD F9 14 20 28 44 0C 31 05 E0 94 F8 38 00 8A 49 28 44 10 31 05 9A F2 F7 41 F8 C6 B2 17 E0 DA 46 0D F1 14 08 B9 F1 08 0F
8:59:19 AM
8:59:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 D9 09 81 80 16 D8 00 27 0D E0 00 BF 81 49 18 F8 01 2B 14 39 50 46 F2 F7 2F F8 30 44 7F 1C C6 B2 0A F1 02 0A FF B2 4F 45 F0 D3 08 2E 00 D9 08 26 32 46 14 E5 74 4A 75 A1 09 3A 50 46 D9 E7 2D E9 F0 4F 85 B0 05 46 00 26 AD F8 08 60 73 4C 02 A8 E7 F7 EE FB 20 46 00 F1 2C 01 BD F8 08 20 18 30 01 27 41 F2 88 3A 4F F0 02 08 4F F0 03 09 00 91 04 90 00 2A 71 D0 03 A8 E7 F7 DF FB BD F8 08 00 00 28 6A D0
8:59:20 AM
8:59:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 DA 09 81 80 9D F8 0C 00 00 F0 7F 02 20 46 00 F1 38 0B 44 30 01 90 01 2A 02 D0 02 2A 78 D1 1B E0 9D F8 0D 00 01 28 09 D0 02 28 02 D0 05 28 6C D1 09 E0 20 8D B0 BB 27 85 00 98 0A E0 A0 8E 88 BB A7 86 58 46 05 E0 B4 F8 40 00 58 BB A4 F8 40 70 01 98 E1 F7 69 FF 58 E0 9D F8 0D 00 01 28 47 D0 02 28 02 D0 05 28 50 D1 5E E0 20 8D 08 B3 00 98 83 46 E1 F7 61 FF 43 F6 98 21 88 42 01 D3 0B 20 29 E0 58 46
8:59:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 DB 09 81 80 E1 F7 58 FF 42 F2 10 71 88 42 01 D3 09 20 20 E0 58 46 E1 F7 4F FF B0 F5 FA 5F 02 D3 0A 20 18 E0 31 E0 58 46 E1 F7 46 FF 50 45 01 D3 AF 71 1A E0 58 46 E1 F7 3F FF 40 F2 DC 51 88 42 02 D3 85 F8 06 80 10 E0 58 46 E1 F7 35 FF B0 F5 2F 7F 03 D3 05 20 A8 71 07 E0 19 E0 58 46 E1 F7 2B FF 14 28 01 D3 85 F8 06 90 26 85 00 98 0A E0 A0 8E 30 B1 58 46 E1 F7 1F FF 14 28 01 D3 04 20 A8 71 A6 86
8:59:21 AM
8:59:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 DC 09 81 80 58 46 E1 F7 0B FF 04 98 E1 F7 0C FF 20 8D 58 B3 00 98 83 46 E1 F7 0E FF 43 F6 98 21 88 42 1A D3 0B 20 42 E0 B4 F8 40 00 88 B1 20 8D 00 28 01 98 07 D0 E1 F7 FF FE 50 45 09 D9 07 20 A8 71 26 85 05 E0 E1 F7 F7 FE 14 28 01 D3 06 20 A8 71 A4 F8 40 60 01 98 D5 E7 58 46 E1 F7 EC FE 42 F2 10 71 88 42 1B D3 09 20 20 E0 3A E0 00 00 25 30 2A 6C 64 00 00 00 25 30 2A 6C 75 00 00 00 25 30 33 6C
8:59:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 DD 09 81 80 75 00 00 00 F1 42 06 00 25 73 00 00 25 75 00 00 68 48 02 00 25 64 00 00 58 47 00 10 58 46 E1 F7 C9 FE B0 F5 FA 5F 02 D3 0A 20 E8 71 19 E0 58 46 E1 F7 C0 FE 50 45 01 D3 EF 71 12 E0 58 46 E1 F7 B9 FE 40 F2 DC 51 88 42 02 D3 85 F8 07 80 08 E0 58 46 E1 F7 AF FE 14 28 03 D3 85 F8 07 90 00 E0 EE 71 94 F8 68 00 01 28 05 D1 0F 20 A4 F8 6A 00 40 F6 B8 30 20 67 B4 F8 6A 00 B4 F8 6C 20 DF F8
8:59:22 AM
8:59:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 DE 09 81 80 FC A4 90 42 AA F1 A0 0B 51 D0 0F 28 4F D0 BA F8 1A 00 4F F4 7A 71 48 43 20 67 B4 F8 6A 00 01 28 05 D1 58 46 E1 F7 7E FE 05 20 84 F8 61 00 B4 F8 6A 00 05 28 04 D0 04 28 06 D0 0A 28 12 D0 25 E0 06 20 84 F8 61 00 21 E0 B4 F8 6C 00 40 1F 05 28 1E D2 DF E8 00 F0 1B 12 15 18 03 00 04 20 A4 F8 4C 00 15 E0 B4 F8 6C 00 0B 28 0F D0 0C 28 04 D0 0D 28 05 D0 0E 28 0B D1 05 E0 A4 F8 4C 70 07 E0
8:59:23 AM
8:59:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 DF 09 81 80 A4 F8 4C 80 04 E0 A4 F8 4C 90 01 E0 A4 F8 4C 60 04 F1 64 04 AF 80 E0 88 20 81 26 80 66 80 26 71 E1 8B A4 F1 64 04 04 F1 78 00 FD F7 C0 FF 20 8D 68 B9 B4 F8 40 00 50 B9 04 98 06 46 E1 F7 3A FE 21 6F 88 42 03 D9 6F 80 30 46 E1 F7 27 FE 58 46 5C 46 E1 F7 2F FE BA F8 18 10 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 03 D9 20 46 E1 F7 1B FE 2F 80 01 20 05 B0 A5 E5 38 B5 00 24 69 46 20 46 00 94
8:59:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E0 09 81 80 33 F0 02 FB FE 4D 00 99 A8 68 88 43 08 D1 69 46 01 20 00 94 33 F0 F8 FA A8 69 00 99 88 43 00 D0 01 20 38 BD F0 B5 A5 B0 04 46 1C A8 E7 F7 F1 F8 00 28 7D D0 03 A8 E2 F7 2D FA 16 A8 E2 F7 31 FD 9D F8 58 00 EF 4D 40 07 1E D0 9D F8 0C 00 01 06 0B D5 20 78 29 78 08 43 20 70 9D F8 0C 00 10 F0 15 0F 11 D0 20 7D A9 78 0C E0 40 06 0C D5 20 78 A9 78 08 43 20 70 9D F8 0C 00 10 F0 2A 0F 03 D0
8:59:24 AM
8:59:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E1 09 81 80 20 7D 29 78 08 43 20 75 04 A8 E2 F7 49 FA 9D F8 58 00 40 07 1E D0 9D F8 10 00 01 06 0B D5 20 78 69 78 08 43 20 70 9D F8 10 00 10 F0 15 0F 11 D0 20 7D E9 78 0C E0 40 06 0C D5 20 78 E9 78 08 43 20 70 9D F8 10 00 10 F0 2A 0F 03 D0 20 7D 69 78 08 43 20 75 9D F8 0C 00 9D F8 10 10 08 43 09 D1 20 7D 29 78 08 43 A9 78 08 43 69 78 08 43 E9 78 08 43 20 75 05 A8 E2 F7 AB FB 02 A8 FD F7 04 FC
8:59:25 AM
8:59:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E2 09 81 80 9D F8 0C 00 9D F8 10 10 01 43 8A 07 03 D1 02 9B 05 9A 9A 42 03 D9 A2 89 42 F0 08 02 A2 81 11 F0 0C 0F 03 D1 02 9B 06 9A 9A 42 05 D9 A2 89 00 E0 01 E2 42 F0 10 02 A2 81 11 F0 30 0F 03 D1 02 9A 07 99 91 42 03 D9 A1 89 41 F0 20 01 A1 81 C1 07 03 D0 A1 89 41 F0 40 01 A1 81 41 07 03 D5 A1 89 41 F0 80 01 A1 81 C0 06 03 D5 A0 89 40 F4 80 70 A0 81 15 A8 E2 F7 99 FC BD F9 54 10 08 43 3E D0
8:59:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E3 09 81 80 17 A8 E2 F7 99 FC 9D F8 5C 00 C1 07 03 D0 A1 89 41 F0 01 01 A1 81 81 07 03 D5 A1 89 41 F0 02 01 A1 81 40 07 03 D5 A0 89 40 F0 04 00 A0 81 18 A8 33 F0 1E FB 28 B1 BD F8 60 00 C1 05 01 D5 80 05 09 D4 00 26 01 22 31 46 20 46 FD F7 6E FB 76 1C F6 B2 06 2E F6 D3 00 20 2B F0 C7 FB 84 46 00 20 FD F7 7A FB C0 1E C7 B2 00 26 A8 5D 10 EA 0C 0F 17 D0 BE 42 08 D3 00 BF A6 EB 07 00 05 E0 20 8C
8:59:26 AM
8:59:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E4 09 81 80 40 F0 07 00 20 84 D2 E7 30 46 C1 B2 02 D3 4F F0 01 02 01 E0 4F F0 00 02 01 F1 04 01 20 46 FD F7 1A FE 76 1C F6 B2 08 2E DF D3 01 20 2B F0 9D FB 84 46 01 20 FD F7 50 FB 1A 38 C7 B2 00 26 A8 5D 10 EA 0C 0F 12 D0 BE 42 03 D3 00 BF A6 EB 07 00 00 E0 30 46 C1 B2 02 D3 4F F0 01 02 01 E0 4F F0 00 02 01 F1 1B 01 20 46 FD F7 F5 FD 76 1C F6 B2 08 2E E4 D3 2D F0 CE FC 07 46 00 21 1A A8 34 F0
8:59:27 AM
8:59:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E5 09 81 80 0F FB 02 28 04 D0 01 28 0D D0 03 28 04 D0 7C E0 A0 78 E9 78 08 43 A0 70 9D F8 68 00 01 28 07 D0 02 28 05 D0 71 E0 A0 7D E9 78 08 43 A0 75 6C E0 55 4E F0 78 01 28 01 D0 05 28 14 D1 53 48 00 88 80 07 08 D5 20 69 40 F4 00 70 20 61 60 78 E9 79 08 43 60 70 07 E0 60 6A 40 F4 00 70 60 62 60 7D E9 79 08 43 60 75 30 79 01 28 01 D0 05 28 06 D1 70 79 01 28 0C D0 A0 7D 29 79 08 43 A0 75 70 78
8:59:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E6 09 81 80 63 28 2D D0 1B 28 08 D3 20 69 40 F4 70 50 15 E0 A0 78 29 79 08 43 A0 70 F1 E7 15 28 03 D3 20 69 40 F4 E0 50 0A E0 0F 28 03 D3 20 69 40 F4 40 60 04 E0 09 28 03 D3 20 69 40 F4 80 60 20 61 2F 49 70 78 4A 79 90 42 04 D3 60 78 A9 79 08 43 60 70 06 E0 09 79 88 42 03 D3 60 7D A9 79 08 43 60 75 2E F0 C2 FA 02 28 07 D0 71 79 01 29 04 D0 01 28 07 D0 03 28 05 D0 08 E0 20 69 40 F0 01 00 20 61
8:59:28 AM
8:59:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E7 09 81 80 03 E0 60 6A 40 F0 01 00 60 62 41 F2 11 10 07 42 03 D0 A0 78 29 78 08 43 A0 70 FF F7 2C FE 18 B1 A0 78 69 78 08 43 A0 70 05 20 35 F0 D6 FA 18 B1 A0 78 A9 79 08 43 A0 70 06 20 35 F0 CE FA 18 B1 A0 78 E9 79 08 43 A0 70 37 F0 89 FE 10 F0 FC 7F 03 D0 E0 78 29 78 08 43 E0 70 01 20 35 F0 BD FA 18 B1 20 79 E9 78 08 43 20 71 02 20 35 F0 B5 FA 18 B1 20 79 29 79 08 43 20 71 09 E0 08 48 00 10
8:59:29 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
8:59:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E8 09 81 80 50 80 00 10 68 C1 01 00 30 58 00 10 02 3E 00 20 15 A9 06 20 1E F0 25 FD 30 B1 BD F8 54 00 18 B1 20 79 69 79 08 43 20 71 29 F0 05 FE 18 B1 E0 78 69 78 08 43 E0 70 0F A8 29 F0 D4 FE 9D F8 3C 00 01 28 03 D1 E0 78 A9 78 08 43 E0 70 01 20 31 F0 A7 F9 18 B1 A0 78 69 79 08 43 A0 70 FA 48 B0 F8 6A 00 0B 28 03 D1 A0 78 A9 78 08 43 A0 70 3D 20 35 F0 73 FA 18 B1 20 79 E9 79 08 43 20 71 F3 48
8:59:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 E9 09 81 80 01 68 09 B9 C0 68 18 B1 20 69 40 F4 80 70 20 61 00 25 28 46 1D F0 D7 FE 20 B1 20 69 40 F4 80 40 20 61 03 E0 6D 1C ED B2 03 2D F2 D3 00 25 28 46 33 F0 27 FC 18 B9 28 46 33 F0 75 FC 18 B1 20 69 40 F4 C0 20 20 61 6D 1C ED B2 05 2D EF D3 19 A8 33 F0 5B FB E8 B1 9D F8 64 00 46 28 03 D9 20 69 40 F0 F0 00 0F E0 28 28 03 D9 20 69 40 F0 70 00 09 E0 0A 28 03 D9 20 69 40 F0 30 00 03 E0 20 B1
8:59:30 AM
8:59:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 EA 09 81 80 20 69 40 F0 10 00 20 61 03 E0 60 6A 40 F0 10 00 60 62 0A A8 1D F0 C6 FB 9D F8 29 00 01 28 0A D0 1B A8 1D F0 A1 FB 9D F8 6F 00 02 28 05 D0 20 69 40 F0 08 00 20 61 25 B0 F0 BD 60 6A 40 F0 08 00 60 62 F8 E7 10 B5 86 B0 0C 46 68 46 1D F0 AA FB 9D F8 01 00 24 0E 01 28 0E D0 05 A8 1D F0 84 FB 9D F8 17 00 02 28 05 D1 0A 2C 03 D1 00 22 11 46 1D F0 CF FC 06 B0 10 BD 09 2C FB D1 00 22 11 46
8:59:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 EB 09 81 80 02 20 1D F0 CA FB F5 E7 AF 49 10 B5 B0 31 81 20 08 70 63 20 48 70 64 20 88 70 8F 20 C8 70 08 20 08 71 09 20 AA 4A 48 71 A1 F1 30 00 D2 F8 11 30 C0 F8 36 30 D2 F8 15 30 C0 F8 3A 30 D2 F8 19 20 C0 F8 3E 20 11 20 88 74 43 20 C8 74 02 20 08 75 1E 20 C8 82 0A 20 08 83 3C 20 48 83 01 24 08 46 FC F7 B1 FF 00 B9 00 24 20 46 10 BD 10 B5 B0 21 95 48 D9 F7 72 FE 94 48 1C 21 B0 30 D9 F7 94 FE
8:59:31 AM
8:59:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 EC 09 81 80 E3 F7 9D F8 40 07 01 D5 FF F7 BE FF 01 20 FC F7 71 FF 8D 49 80 22 CC 31 A1 F1 54 00 03 46 FD F7 3A FC 00 21 18 46 FD F7 82 FC 87 48 8C 30 E1 F7 F5 FA 85 49 41 F2 88 30 08 67 01 F1 20 00 E1 F7 F1 FA 81 48 10 30 E1 F7 ED FA 7F 48 18 30 E1 F7 E9 FA BD E8 10 40 E6 F7 A0 BD 7B 49 00 20 B1 F8 6A 10 0B 29 00 D1 01 20 70 47 77 48 90 F8 A8 00 70 47 2D E9 F0 4F 74 4C A9 B0 04 F1 B0 08 00 20
8:59:32 AM
8:59:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 ED 09 81 80 FC F7 38 FF 04 F1 20 00 05 46 E1 F7 D3 FA C8 28 72 D9 28 46 E1 F7 C6 FA 02 A8 FD F7 B9 F8 4F F6 FF 77 34 21 15 A8 D9 F7 18 FE 00 26 13 96 13 A8 14 96 FF F7 02 FB 00 28 73 D0 A1 88 04 F1 08 00 81 46 89 B1 4D 46 E1 F7 B5 FA B8 F8 16 10 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 05 D9 A6 80 E6 F7 5C FD 28 46 E1 F7 9A FA 9D F8 53 00 01 25 10 B9 9D F8 52 00 28 B1 A5 80 E6 F7 BD FE 48 46 E1 F7
8:59:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 EE 09 81 80 91 FA DD E9 13 01 FF F7 1D FF 4F 48 B4 F8 6A 30 00 F1 66 02 12 92 92 1E 01 92 14 32 26 92 14 32 27 92 40 3A 54 30 0E 21 4F F0 0A 0A 4F F0 04 09 4F F0 03 0B 00 92 22 90 11 2B 32 D2 DF E8 03 F0 09 1D 8E 31 FA F9 F8 F8 F7 F6 F5 F4 F3 F2 AB FB F0 00 9D F8 52 00 03 28 0A D0 02 28 08 D0 01 28 03 D0 BD F8 4E 00 00 28 01 D0 A4 F8 6A 50 8D E0 02 20 A4 F8 6A 00 89 E0 13 E0 9D F8 52 00 03 28
8:59:33 AM
8:59:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 EF 09 81 80 09 D0 06 28 5F D0 01 20 31 F0 0A F8 60 B1 0C 20 A4 F8 6A 00 5E E0 01 20 FD F7 77 F9 02 20 A4 F8 6A 00 29 B0 BD E8 F0 8F 9D F8 53 00 08 28 09 D0 BD F8 4C 00 F8 B1 B4 F8 76 00 B8 42 05 D1 A4 F8 4C 60 0F E0 22 49 8E 31 F4 E3 00 99 05 20 88 46 12 9A FD F7 A0 FA 28 B1 00 23 41 46 05 20 01 9A FD F7 60 FA B4 F8 4C 10 05 20 FD F7 05 FA B8 42 01 D1 A4 F8 4C 60 BD F8 50 00 10 B9 BD F8 4C 00
8:59:34 AM
8:59:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F0 09 81 80 B0 B1 B4 F8 4C 10 05 20 FD F7 F6 F9 A4 F8 76 00 FE F7 FA FB 60 B1 26 99 B4 F8 76 00 0E 46 FE F7 1A FC 00 21 30 46 FD F7 82 FB 27 98 E1 F7 FA F9 B4 F8 76 10 B9 42 72 D0 00 23 1A 46 02 A8 00 95 FE F7 71 FC B7 E3 30 E1 58 47 00 10 28 81 00 10 48 42 06 00 02 A8 FD F7 A7 F8 A2 E7 9D F8 52 00 01 28 02 D0 BD F8 4E 10 11 B1 A4 F8 6A 50 98 E7 03 28 04 D0 02 28 02 D0 06 28 03 D0 06 E0 A4 F8
8:59:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F1 09 81 80 6A 90 8E E7 E2 F7 5B FF 40 05 01 D5 01 20 FA E3 A4 F8 6A A0 85 E7 BD F8 50 00 30 B1 02 20 84 F8 68 00 42 F2 10 70 20 67 27 E0 9D F8 52 00 03 28 04 D0 02 28 02 D0 BD F8 4E 10 11 B1 A4 F8 6A A0 1B E0 06 28 19 D1 25 A8 32 F0 92 FF 28 B1 BD F8 94 00 C1 05 01 D5 80 05 06 D4 32 F0 58 FD 32 F0 62 FD 84 F8 68 B0 08 E0 84 F8 68 90 40 F6 B8 30 20 67 04 F1 18 00 E1 F7 95 F9 14 F8 68 1F F7 48
8:59:35 AM
8:59:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F2 09 81 80 00 EB C1 00 41 68 02 A8 FD F7 64 FB 20 78 02 28 98 D1 00 22 11 21 02 A8 FD F7 1A F8 4B E3 18 E3 BA E3 08 E0 6D E3 F0 E3 C1 E3 2B E0 13 E3 67 E2 8C E1 2D E1 8C E0 BD F8 4E 00 68 B1 04 F1 68 04 4F F4 7A 71 A0 88 60 80 B8 F8 1A 00 00 FB 01 F0 A0 60 04 F8 68 69 0B E0 94 F8 68 00 01 28 07 D1 29 F0 86 FB 10 B1 84 F8 68 B0 01 E0 84 F8 68 90 94 F8 68 10 D9 48 00 EB C1 00 41 68 02 A8 FD F7
8:59:36 AM
8:59:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F3 09 81 80 29 FB 18 E3 9D F8 53 00 02 28 06 D0 01 28 10 D0 BD F8 4E 00 00 28 6F D1 0E E0 B4 F8 4C 00 04 28 07 D0 03 28 02 D1 CD 49 15 39 71 E3 CB 49 54 39 6E E3 CA 49 4B 39 6B E3 9D F8 52 00 01 28 5B D0 06 28 72 D0 02 28 04 D0 03 28 21 D0 04 28 2A D0 33 E0 B4 F8 4C 00 05 28 BF F4 DC AE DF E8 00 F0 03 09 10 15 4C 00 04 F1 4E 04 0B 20 A0 83 26 70 30 E7 0C 20 A4 F8 6A 00 01 20 32 F0 45 F8 29 E7
8:59:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F4 09 81 80 0D 20 24 F8 6A 0F A5 72 24 E7 A4 F8 6A 10 21 E7 B4 F8 4C 00 40 1C 80 B2 A4 F8 4C 00 05 28 0C D3 A4 F8 4C 60 09 E0 B4 F8 4C 00 40 1E 80 B2 A4 F8 4C 00 B8 42 01 D1 A4 F8 4C 90 02 A8 FF F7 F2 FA A6 49 B4 F8 4C 00 60 31 01 EB C0 00 41 68 1F E3 9D F8 53 00 02 28 0A D0 01 28 AA D0 9D F8 52 00 01 28 AC D0 BD F8 4E 20 00 2A 94 D1 05 E0 B4 F8 4C 00 05 28 9D D0 99 E7 06 E1 06 28 A1 D0 05 22
8:59:37 AM
8:59:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F5 09 81 80 02 28 04 D0 03 28 2E D0 04 28 4A D0 63 E0 B4 F8 4C 00 58 B1 01 28 0C D0 02 28 10 D0 03 28 14 D0 04 28 18 D0 05 28 8A D0 D4 E6 01 E1 A4 F8 6A 20 D0 E6 04 F1 60 04 06 20 60 81 66 70 CA E6 04 F1 60 04 07 20 60 81 65 70 C4 E6 04 F1 60 04 08 20 60 81 61 70 BE E6 04 F1 60 04 09 20 60 81 4F F0 0F 00 60 70 B6 E6 B4 F8 4C 00 40 1C 80 B2 A4 F8 4C 00 0D E0 98 F8 03 10 42 1E 05 FA 02 F2 11 42
8:59:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F6 09 81 80 08 D1 B4 F8 4C 10 49 1C 40 1C A4 F8 4C 10 80 B2 05 28 EF D3 B4 F8 4C 00 06 28 1C D3 A4 F8 4C 60 19 E0 B4 F8 4C 00 40 1E 80 B2 A4 F8 4C 00 B8 42 0F D1 A4 F8 4C 20 0E E0 98 F8 03 10 40 1E 05 FA 00 F2 11 42 07 D1 B4 F8 4C 10 80 B2 49 1E A4 F8 4C 10 00 28 F0 D1 02 A8 FF F7 64 FA 5F 4D 34 F8 4C 0F 30 35 05 EB C0 00 41 68 02 A8 FD F7 32 FA 20 88 55 F8 30 00 01 28 03 D0 02 28 01 D0 03 28
8:59:38 AM
8:59:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F7 09 81 80 92 D1 BD F8 0E 00 40 F0 80 00 AD F8 0E 00 61 E6 9D F8 53 00 02 28 0D D0 01 28 3F F4 0A AF 9D F8 52 00 02 28 6F D0 01 28 6E D0 BD F8 4E 10 00 29 6A D1 02 E0 49 49 1E 39 6A E2 06 28 78 D0 05 28 04 D0 03 28 12 D0 04 28 23 D0 34 E0 B4 F8 76 00 B8 42 01 D1 00 20 02 E0 B4 F8 4C 00 40 1C 24 F8 4C 0F 26 83 66 83 A4 F1 4C 04 24 E0 B4 F8 76 00 B8 42 02 D1 A4 F8 4C 60 1D E0 00 99 06 20 0E 46
8:59:39 AM
8:59:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F8 09 81 80 12 9A FD F7 88 F8 B0 B1 00 23 31 46 06 20 01 9A 0F E0 B4 F8 76 00 B8 42 05 D1 06 20 FD F7 D6 FC 40 1C A4 F8 4C 00 A4 F8 66 60 DD E9 00 12 01 23 06 20 FD F7 37 F8 BD F8 50 00 18 B9 9D F8 52 00 00 28 69 D0 B4 F8 4C 10 06 20 C3 E1 9D F8 53 00 02 28 0F D0 01 28 A0 D0 9D F8 52 00 01 28 02 D0 BD F8 4E 10 89 B1 44 F8 54 6F 66 60 A6 60 26 73 E5 82 EF E5 94 F8 62 00 01 28 9B D0 94 F8 60 00
8:59:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 F9 09 81 80 02 28 97 D0 92 E6 78 E1 B4 E1 06 28 96 D0 02 28 0F D0 03 28 04 D0 02 28 02 D0 BD F8 50 10 E1 B1 94 F8 60 20 BA B3 01 2A 37 D0 02 2A 72 D1 3A E0 41 E1 94 F8 62 10 01 29 12 D0 94 F8 60 00 02 28 0E D0 00 29 EC D1 02 28 EA D2 40 1C C0 B2 84 F8 60 00 01 28 E4 D1 66 65 E2 E7 37 E0 18 43 06 00 94 F8 60 00 20 B1 01 28 06 D0 02 28 C1 D1 05 E0 66 65 A6 65 E6 65 40 E1 A0 6D 60 65 04 F1 60 04
8:59:40 AM
8:59:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 FA 09 81 80 A6 80 20 78 A0 F1 01 00 20 70 4F F0 02 00 A0 70 A4 F1 60 04 C4 E7 00 E0 8B E1 94 F8 61 10 22 98 FD F7 A4 FC 21 E0 9D F8 52 00 03 28 32 D1 B4 F8 64 10 94 F8 61 00 FC F7 5F FF B8 42 02 D1 A4 F8 64 60 27 E0 B4 F8 64 00 40 1C 21 E0 04 28 21 D1 94 F8 60 20 22 B1 01 2A 02 D0 02 2A 1A D1 07 E0 94 F8 61 10 22 98 FD F7 2B FD 98 B9 66 65 11 E0 B4 F8 64 10 94 F8 61 00 FC F7 3E FF B8 42 04 D1
8:59:41 AM
8:59:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 FB 09 81 80 94 F8 61 00 FD F7 22 FC 02 E0 B4 F8 64 00 40 1E A4 F8 64 00 15 A9 01 98 CD E9 00 01 14 F8 60 2F 9D F8 52 30 61 78 22 98 FD F7 CD FD E0 82 A4 F1 60 04 FE F7 29 F9 78 B1 9D F8 52 00 60 B1 26 99 B4 F8 76 00 88 46 FE F7 46 F9 00 21 40 46 FD F7 AE F8 27 98 E0 F7 26 FF B4 F8 76 00 B8 42 02 D1 84 F8 62 50 AA E1 04 F1 60 04 4F F0 10 00 A6 70 21 78 00 FA 01 F0 80 B2 00 90 63 78 E1 8A A3 E0
8:59:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 FC 09 81 80 9D F8 53 00 02 28 0D D0 01 28 3F F4 D2 AD 9D F8 52 00 01 28 02 D0 BD F8 4E 10 69 B1 04 F8 60 6F 65 81 17 E5 94 F8 62 00 01 28 3F F4 C3 AE 94 F8 60 00 01 28 F9 D0 B9 E5 06 28 7C D0 BD F8 50 10 19 B1 84 F8 62 B0 66 65 53 E0 02 28 04 D0 03 28 1B D0 04 28 31 D0 48 E0 94 F8 60 00 10 B1 01 28 43 D1 07 E0 94 F8 62 00 01 28 3F F4 08 AD 84 F8 60 50 3A E0 04 F1 4C 04 26 75 84 F8 16 B0 20 88
8:59:42 AM
8:59:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 FD 09 81 80 A0 F1 01 00 24 F8 4C 09 33 E0 94 F8 60 00 10 B1 01 28 2A D1 02 E0 84 F8 62 B0 2A E0 B4 F8 64 10 94 F8 61 00 FC F7 A8 FE B8 42 02 D1 A4 F8 64 60 1B E0 B4 F8 64 00 40 1C 15 E0 94 F8 60 00 00 28 E9 D0 01 28 11 D1 B4 F8 64 10 94 F8 61 00 FC F7 93 FE B8 42 04 D1 94 F8 61 00 FD F7 77 FB 02 E0 B4 F8 64 00 40 1E A4 F8 64 00 94 F8 62 00 03 28 0A D1 9D F8 52 30 94 F8 61 10 00 9A 22 98 FD F7
8:59:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 FE 09 81 80 10 FE 08 B1 A4 F8 64 60 15 A9 01 98 CD E9 00 01 14 F8 60 2F 9D F8 52 30 61 78 22 98 FD F7 40 FE E0 82 A4 F1 60 04 B8 42 3F F4 5A AF 04 F1 4C 04 A6 75 21 7D 00 E0 A0 E0 4F F4 80 70 00 FA 01 F0 80 B2 00 90 23 88 61 8D 15 AA 02 A8 FE F7 EB F8 88 BB C0 49 12 E5 9D F8 53 00 02 28 3F F4 2A AE 01 28 3F F4 26 AD 9D F8 52 00 02 28 05 D0 01 28 40 D0 BD F8 4E 10 E9 BB 02 E0 A4 F8 6A 90 69 E4
8:59:43 AM
8:59:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 00 FF 09 81 80 06 28 7A D0 03 28 02 D0 04 28 0B D0 19 E0 B4 F8 76 00 B8 42 02 D1 A4 F8 4C 60 12 E0 B4 F8 4C 00 40 1C 0C E0 B4 F8 76 00 B8 42 05 D1 0F 20 FD F7 0D FB 04 E0 6C E0 79 E0 B4 F8 4C 00 40 1E A4 F8 4C 00 BD F8 50 00 10 B9 9D F8 52 00 88 B3 B4 F8 4C 10 0F 20 FC F7 10 FE A4 F8 76 00 FE F7 14 F8 38 B3 26 99 B4 F8 76 00 0E 46 FE F7 34 F8 00 21 30 46 00 E0 A5 E0 FC F7 9A FF 27 98 E0 F7 12 FE
8:59:44 AM
8:59:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 00 09 81 80 25 E1 9D F8 53 00 02 28 A8 D0 01 28 A9 D0 9D F8 52 00 02 28 08 D0 01 28 02 D0 BD F8 4E 10 49 B1 24 F8 6A 5F A6 72 18 E4 A4 F8 6A A0 84 F8 74 60 13 E4 0C E1 06 28 04 D0 03 28 05 D0 04 28 0E D0 1D E0 84 F8 68 50 08 E4 94 F8 74 00 40 1C C0 B2 84 F8 74 00 04 28 12 D9 84 F8 74 60 16 E0 94 F8 74 00 40 1E 10 F0 FF 00 84 F8 74 00 0E D0 04 28 08 D9 48 46 84 F8 74 90 04 E0 B9 E0 03 E0 94 F8
8:59:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 01 09 81 80 74 00 18 B1 C0 B2 FC F7 00 FD 03 E4 71 49 24 39 02 A8 FC F7 9F FF AB E4 B4 F8 4C 00 40 1C 80 B2 A4 F8 4C 00 05 28 7B D9 A4 F8 6A 50 78 E0 9D F8 53 00 02 28 A8 D0 01 28 A8 D0 9D F8 52 30 01 2B 3F D0 BD F8 4E 00 E0 BB 02 2B 0A D0 DF F8 84 81 94 F8 4E 00 60 49 A8 F1 93 08 28 B1 01 28 5F D1 32 E0 A4 F8 6A A0 83 E4 06 2B 04 D0 03 2B 0D D0 04 2B 14 D0 19 E0 B4 F8 4C 00 04 F1 4F 02 FD F7
8:59:45 AM
8:59:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 02 09 81 80 39 FE 90 B1 84 F8 4E 50 0F E0 4D E0 B4 F8 4C 00 02 28 01 D0 40 1C 06 E0 A4 F8 4C 60 05 E0 B4 F8 4C 00 78 B1 40 1E A4 F8 4C 00 B4 F8 4C 10 38 F8 11 00 40 F0 10 01 B9 42 7F F4 7E AB 45 49 24 39 1C E4 4A E0 02 20 EE E7 B4 F8 4C 20 06 2B 38 F8 12 00 40 F0 10 05 04 D0 03 2B 15 D0 04 2B 13 D0 17 E0 94 F8 4F 00 11 28 05 D0 58 B1 B0 F1 01 00 84 F8 4F 00 0D E0 28 46 21 6D FD F7 17 FE 84 F8
8:59:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 03 09 81 80 4E 60 06 E0 11 20 F3 E7 94 F8 4F 20 28 46 FD F7 38 FE 94 F8 4F 20 02 AB 28 46 21 6D FD F7 C8 FE 02 A8 FE F7 3F FF 23 E4 9D F8 53 00 02 28 3F F4 01 AD 01 28 3F F4 FD AB 01 20 30 F0 F1 FA 60 B1 9D F8 52 00 01 28 0B D0 02 28 0D D0 06 28 0F D0 03 28 10 D0 04 28 21 D0 2F E0 A4 F8 6A 50 07 E4 01 20 30 F0 B7 FA F8 E7 01 20 30 F0 B3 FA 78 E7 84 F8 68 50 08 E4 B4 F8 76 00 B8 42 02 D1 A4 F8
8:59:46 AM
8:59:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 04 09 81 80 4C 60 1A E0 05 20 12 9A 00 99 FC F7 84 FD A0 B1 B4 F8 4C 00 40 1C A4 F8 4C 00 0E E0 B4 F8 76 00 B8 42 03 D1 05 20 FD F7 D1 F9 02 E0 B4 F8 4C 00 40 1E A4 F8 4C 00 A4 F8 66 60 BD F8 50 00 10 B9 9D F8 52 00 18 B1 B4 F8 4C 10 05 20 C2 E6 B4 F8 76 10 70 E7 DF 42 06 00 A8 47 00 10 70 B5 0C 46 05 46 5C 28 12 D8 03 F0 4B F8 00 28 0F D0 6C B1 40 68 00 78 A0 42 09 DB F7 48 50 F8 25 00 00 28
8:59:47 AM
8:59:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 05 09 81 80 05 D0 20 44 10 F8 01 0C 3E 28 01 D3 00 20 70 BD F2 49 01 EB C0 00 70 BD 02 46 5C 28 01 D9 00 20 70 47 EE 48 C0 38 12 2A 17 D0 0B DC 09 2A 2B D0 0A 2A F5 D1 03 29 21 D0 1C DC 01 29 F0 D0 02 29 EE D1 1E E0 30 2A 24 D0 40 2A E9 D1 01 29 0E D0 02 29 E5 D1 E0 48 78 38 70 47 01 29 04 D0 02 29 FA D1 DE 48 B0 38 70 47 DC 48 B8 38 70 47 DB 48 48 30 70 47 82 29 04 D0 83 29 FA D1 D7 48 A8 38
8:59:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 06 09 81 80 70 47 D5 48 60 38 70 47 01 29 FC D1 D3 48 A0 38 70 47 01 29 01 D0 02 29 FA D1 CF 48 20 38 70 47 00 20 70 47 10 B5 48 B1 41 B1 02 88 0B 88 9A 42 04 D1 49 68 40 68 D8 F7 07 FF 08 B1 00 20 10 BD 01 20 10 BD 00 28 13 D0 42 68 00 88 C0 00 13 78 08 38 C0 1A 00 B2 81 42 09 DA 01 F0 07 03 80 20 D8 40 01 23 03 EB D1 01 51 5C 88 43 01 D0 00 20 70 47 01 20 70 47 0F B5 4A 78 02 70 0A 78 42 70
8:59:48 AM
8:59:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 07 09 81 80 8A 78 82 70 CA 78 C2 70 0A 79 02 B9 07 22 02 71 4A 79 42 71 8A 79 82 71 CA 79 C2 71 09 89 0A 22 B1 FB F2 F1 01 72 9D F8 09 10 41 72 9D F8 08 10 81 72 C3 72 04 B0 01 20 00 BD 70 B5 04 78 4C 70 44 78 0C 70 84 78 8C 70 C4 78 CC 70 04 79 FF 2C 04 D0 07 25 B4 FB F5 F6 05 FB 16 44 0C 71 44 79 4C 71 84 79 8C 71 C4 79 CC 71 04 7A FF 2C 0B D0 04 EB 84 04 64 00 0C 81 41 7A 51 70 81 7A 11 70
8:59:49 AM
8:59:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 08 09 81 80 C0 7A 18 70 01 20 70 BD 00 24 F4 E7 70 B5 8C B0 0E 46 6A 46 08 A9 E0 F7 BD FB 00 28 2F D0 01 A8 E0 F7 07 FB BD F8 00 00 C0 07 00 28 04 D0 07 99 01 98 00 EB 01 02 00 E0 01 9A 4F F0 3C 00 92 FB F0 F0 C0 F1 00 00 04 B2 02 D0 4F F0 80 05 01 E0 4F F0 00 05 FF F7 09 F9 40 B1 33 F0 2F FB 01 28 04 D1 08 A9 01 22 08 46 33 F0 6F FC 2B 46 22 46 08 A9 30 46 FF F7 7F FF 00 28 00 D0 01 20 0C B0
8:59:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 09 09 81 80 70 BD 30 B5 87 B0 0D 46 04 46 04 AB 06 AA 01 A9 FF F7 93 FF 00 28 2C D0 9D F8 10 00 FF 28 04 D0 C2 09 20 78 FF 28 08 D0 0A E0 05 A8 E0 F7 BC FA BD F8 16 00 C0 F3 00 02 F3 E7 60 78 FF 28 1A D0 BD F9 18 00 10 F5 00 4F 1D D0 69 46 01 A8 E0 F7 45 FA 00 28 0D D0 BD F9 18 00 00 99 C0 EB 00 10 01 EB 80 00 29 46 00 90 E0 F7 D4 FA 00 28 00 D0 01 20 07 B0 30 BD 01 98 28 60 02 98 68 60 BD F8
8:59:50 AM
8:59:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 0A 09 81 80 0C 00 28 81 F4 E7 29 46 01 A8 E0 F7 08 FB ED E7 00 22 CA 70 42 78 8A 70 82 78 4A 70 C0 78 08 70 70 47 00 22 02 70 8A 78 42 70 4A 78 82 70 09 78 C1 70 70 47 16 22 02 70 09 78 01 71 01 20 70 47 03 22 02 70 09 78 01 71 01 20 70 47 11 22 02 70 09 78 01 71 01 20 70 47 10 B5 04 46 10 46 30 21 E0 F7 9F FC 00 28 05 D0 02 21 21 70 04 21 A1 80 A0 60 01 20 10 BD 0B 78 49 78 63 F3 07 02 61 F3
8:59:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 0B 09 81 80 0F 22 12 21 01 70 82 80 01 20 70 47 0B 78 63 F3 07 02 4B 78 63 F3 0F 22 8B 78 C9 78 63 F3 17 42 61 F3 1F 62 06 21 01 70 42 60 01 20 70 47 2D E9 F0 41 0D 46 96 08 06 EB 46 01 07 46 89 04 18 46 09 0C E0 F7 6E FC 02 00 1C D0 00 21 4F F0 06 0C 12 E0 2B 78 63 F3 07 04 6B 78 63 F3 0F 24 AB 78 63 F3 17 44 EB 78 80 F8 00 C0 63 F3 1F 64 44 60 2D 1D 0C 30 49 1C 89 B2 B1 42 EA D3 01 20 38 70
8:59:51 AM
8:59:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 0C 09 81 80 BE 80 BA 60 BD E8 F0 81 70 B5 0C 46 05 46 09 88 10 46 41 B1 E0 F7 45 FC 06 00 0B D0 22 88 61 68 D8 F7 BE FD 00 E0 00 26 09 20 28 70 20 88 A8 80 01 20 AE 60 70 BD 1C B5 AD F8 00 20 01 91 1A 46 69 46 FF F7 E1 FF 1C BD 7C B5 4A B1 0C 88 95 1E AC 42 07 D9 92 1E 06 E0 10 49 06 00 20 47 06 00 00 20 7C BD 22 46 89 1C AD F8 00 20 01 91 1A 46 69 46 FF F7 C9 FF 7C BD 70 B5 0C 46 05 46 09 88
8:59:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 0D 09 81 80 10 46 71 B1 E0 F7 0D FC 06 00 09 D0 22 88 61 68 D8 F7 86 FD 04 20 28 70 20 88 A8 80 01 20 AE 60 70 BD 00 20 70 BD 1C B5 AD F8 00 20 01 91 1A 46 69 46 FF F7 E1 FF 1C BD 7C B5 2A B1 0C 88 95 1E AC 42 03 D9 92 1E 02 E0 00 20 7C BD 22 46 89 1C AD F8 00 20 01 91 1A 46 69 46 FF F7 CD FF 7C BD 70 B5 05 46 0C 46 10 46 3C 21 E0 F7 DA FB 00 28 19 D0 02 21 29 70 05 21 A9 80 11 21 A8 60 01 70
8:59:52 AM
8:59:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 0E 09 81 80 22 78 02 71 01 73 62 78 02 74 01 76 A2 78 02 77 80 F8 24 10 E2 78 80 F8 28 20 80 F8 30 10 21 79 80 F8 34 10 01 20 70 BD 2D E9 F0 41 04 46 0E 46 1F 46 18 21 18 46 E0 F7 B4 FB 05 00 13 D0 02 20 20 70 A0 80 3A 46 31 46 28 46 A5 60 FF F7 C8 FF 00 28 08 D0 3A 46 31 46 05 F1 0C 00 FF F7 C0 FF 00 28 00 D0 01 20 4D E7 70 B5 96 B0 0E 46 14 46 05 46 02 AB 6A 46 04 A9 FF F7 1F FE E0 B3 03 AB
8:59:53 AM
8:59:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 0F 09 81 80 01 AA 07 A9 05 F1 0C 00 FF F7 17 FE A0 B3 0A AA 04 A9 30 46 E7 F7 C2 F8 70 B3 0D AA 07 A9 30 46 E7 F7 BC F8 40 B3 9D F8 08 30 BD F9 00 20 0A A9 10 A8 FF F7 E0 FD F8 B1 9D F8 0C 30 BD F9 04 20 0D A9 13 A8 FF F7 D7 FD B0 B1 04 A9 10 A8 FF F7 58 FE 88 B1 07 A9 13 A8 FF F7 53 FE 60 B1 21 46 04 A8 E0 F7 BB F8 38 B1 21 1D 07 A8 E0 F7 B6 F8 10 B1 01 20 16 B0 70 BD FF E7 00 20 FA E7 2D E9
8:59:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 10 09 81 80 FF 41 0E 46 07 46 15 46 1C 46 03 A9 30 46 E0 F7 A5 F8 6A 46 31 46 38 46 FF F7 A6 FF 00 28 04 D0 DD E9 00 01 88 42 02 D3 00 20 04 B0 EA E6 03 46 03 98 01 21 00 22 83 42 04 D8 01 9B 83 42 01 D3 29 80 00 E0 2A 80 2C B1 01 9B 83 42 01 D3 21 80 00 E0 22 80 01 20 E8 E7 2D E9 FC 41 04 46 0E 46 17 46 18 21 10 46 E0 F7 1C FB 05 00 1B D0 02 20 20 70 A0 80 A5 60 0C 20 AD F8 00 00 3A 46 69 46
8:59:54 AM
8:59:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 11 09 81 80 28 46 01 96 FF F7 C0 FE 00 28 0A D0 0C 36 3A 46 69 46 05 F1 0C 00 01 96 FF F7 B6 FE 00 28 00 D0 01 20 BD E8 FC 81 00 20 FB E7 1C B5 0B 88 0F 2B 00 D3 0F 23 89 1C 01 91 AD F8 00 30 69 46 FF F7 A3 FE 00 28 00 D0 01 20 1C BD 2D E9 FC 41 06 46 0C 46 17 46 24 21 10 46 E0 F7 E3 FA 05 00 2B D0 02 20 30 70 03 20 B0 80 B5 60 20 88 20 28 00 D3 20 20 AD F8 00 00 A0 1C 01 90 3A 46 69 46 28 46
8:59:55 AM
8:59:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 12 09 81 80 FF F7 82 FE 00 28 CC D0 60 8C 20 28 00 D3 20 20 AD F8 00 00 04 F1 24 00 01 90 3A 46 69 46 05 F1 0C 00 FF F7 71 FE 00 28 BB D0 12 20 28 76 B4 F8 44 00 A8 83 01 20 B4 E7 00 20 B2 E7 1C B5 0B 88 10 2B 00 D3 10 23 89 1C 01 91 AD F8 00 30 69 46 FF F7 5A FE 00 28 00 D0 01 20 1C BD 7C B5 05 46 0C 46 16 46 24 21 10 46 E0 F7 9B FA 00 28 1B D0 02 21 29 70 03 21 A9 80 11 21 A8 60 01 70 22 78
8:59:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 13 09 81 80 02 71 01 73 61 78 01 74 61 88 10 29 00 D3 10 21 AD F8 00 10 24 1D 32 46 69 46 18 30 01 94 FF F7 33 FE 00 28 00 D0 01 20 7C BD 02 78 16 2A 01 D0 00 20 70 47 00 79 08 70 01 20 70 47 02 78 11 2A 01 D0 00 20 70 47 00 79 08 70 01 20 70 47 02 78 12 2A 01 D0 00 20 70 47 80 88 08 80 01 20 70 47 70 B5 04 00 0D 46 06 D0 20 78 09 28 03 D1 A2 88 28 88 82 42 01 D9 00 20 FD E6 A1 68 68 68 D8 F7
8:59:56 AM
8:59:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 14 09 81 80 CF FB A0 88 28 80 01 20 F5 E6 1C B5 01 91 AD F8 00 20 69 46 FF F7 E4 FF 1C BD 70 B5 04 00 0D 46 06 D0 20 78 04 28 03 D1 A2 88 28 88 82 42 01 D9 00 20 E0 E6 A1 68 68 68 D8 F7 B2 FB A0 88 28 80 01 20 D8 E6 70 B5 05 46 0C 00 10 46 0A D0 21 88 51 B1 E0 F7 26 FA 06 00 05 D0 22 88 61 68 D8 F7 9F FB 02 E0 00 20 C6 E6 00 26 0A 20 28 70 20 88 A8 80 01 20 AE 60 BE E6 70 B5 04 00 0D 46 06 D0
8:59:57 AM
8:59:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 15 09 81 80 20 78 0A 28 03 D1 A2 88 28 88 82 42 01 D9 00 20 B1 E6 A1 68 68 68 D8 F7 83 FB A0 88 28 80 01 20 A9 E6 70 B5 04 46 0D 46 10 46 18 21 E0 F7 F9 F9 00 28 0C D0 02 21 21 70 A1 80 0F 21 A0 60 01 70 29 78 01 71 16 21 01 73 69 78 01 74 01 20 92 E6 10 B5 82 88 C4 88 53 1C A3 42 01 D9 00 20 10 BD 03 68 99 54 81 88 49 1C 81 80 01 20 10 BD 03 B5 81 88 C3 88 8A 1C 9A 42 01 D9 00 20 0C BD 02 68
8:59:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 16 09 81 80 11 44 9D F8 05 20 0A 70 9D F8 04 20 4A 70 81 88 89 1C 81 80 01 20 0C BD 03 B5 81 88 C3 88 0A 1D 9A 42 01 D9 00 20 0C BD 02 68 11 44 9D F8 07 20 0A 70 9D F8 06 20 4A 70 9D F8 05 20 8A 70 9D F8 04 20 CA 70 81 88 09 1D 81 80 01 20 0C BD 10 B5 82 88 C4 88 02 F1 08 03 A3 42 01 D9 00 20 10 BD 03 68 1A 44 CB 79 13 70 8B 79 53 70 4B 79 93 70 0B 79 D3 70 CB 78 13 71 8B 78 53 71 4B 78 93 71
8:59:58 AM
8:59:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 17 09 81 80 09 78 D1 71 81 88 08 31 81 80 01 20 10 BD 10 B5 82 88 C4 88 02 F1 08 03 A3 42 01 D9 00 20 10 BD 03 68 1A 44 CB 79 13 70 8B 79 53 70 4B 79 93 70 0B 79 D3 70 CB 78 13 71 8B 78 53 71 4B 78 93 71 09 78 D1 71 81 88 08 31 81 80 01 20 10 BD 08 B5 7F 29 03 D8 8D F8 00 10 01 22 11 E0 FF 29 06 D8 81 22 8D F8 00 20 8D F8 01 10 02 22 08 E0 82 22 8D F8 00 20 0A 0A 8D F8 01 20 8D F8 02 10 03 22
8:59:59 AM
8:59:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 18 09 81 80 69 46 E0 F7 A2 F9 08 BD 70 B5 0C 46 05 46 09 88 FF F7 DD FF 00 28 06 D0 22 88 28 46 61 68 BD E8 70 40 E0 F7 92 B9 E6 E5 70 B5 0C 00 05 46 13 D0 01 21 FF F7 4D FF 00 28 0D D0 21 88 28 46 FF F7 C6 FF 00 28 07 D0 22 88 28 46 61 68 E0 F7 7D F9 00 28 00 D0 01 20 CE E5 00 21 FF F7 39 FF F7 E7 E0 F7 73 B9 2D E9 F0 41 07 46 08 88 0D 46 00 28 04 D0 6C 68 21 78 08 29 01 D9 00 20 C2 E4 64 1C
8:59:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 19 09 81 80 01 28 15 D0 C0 00 08 38 40 1A 86 B2 31 46 38 46 FF F7 9D FF 00 28 F1 D0 46 B1 28 88 21 46 40 1E 82 B2 38 46 E0 F7 51 F9 00 28 E7 D0 01 20 A9 E4 00 26 EB E7 38 B5 CB 43 6A 46 DB 06 0B D0 01 F0 1F 03 C9 B2 1F 24 9B B2 8D F8 00 10 8C 43 02 F1 01 02 02 D0 14 E0 0B 0A F3 E7 7F 2B 02 D8 8D F8 01 30 0C E0 D9 09 00 D0 01 21 41 F0 80 01 8D F8 01 10 52 1C 59 08 00 D0 01 21 8D F8 02 10 52 1C
9:00:00 AM
9:00:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 1A 09 81 80 69 46 51 1A 8A B2 69 46 E0 F7 1F F9 38 BD 7F B5 06 46 0D 46 1C 46 FF F7 CD FF 00 28 14 D0 A8 06 0E D5 20 88 80 1C 81 B2 30 46 FF F7 50 FF 00 28 0A D0 01 22 02 A9 30 46 E0 F7 07 F9 00 28 03 D0 21 46 30 46 FF F7 60 FF 04 B0 54 E5 70 B5 05 46 0C 00 23 D0 20 68 08 B3 00 88 A0 B1 13 21 28 46 FF F7 B6 FE 00 28 18 D0 20 68 02 88 41 68 28 46 E0 F7 EB F8 00 28 10 D0 20 68 41 8A 28 46 FF F7
9:00:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 1B 09 81 80 26 FF 00 28 09 D0 20 68 02 89 2A B1 C1 68 28 46 E0 F7 DB F8 00 28 00 D0 01 20 2C E5 00 20 2A E5 7C B5 05 46 00 20 0C 46 AD F8 00 00 01 22 01 A9 28 46 E0 F7 E1 F8 00 28 0B D0 9D F8 04 20 10 06 02 D4 8D F8 00 20 14 E0 81 2A 0B D0 82 2A 01 D0 00 20 7C BD 01 22 0D F1 01 01 28 46 E0 F7 CC F8 00 28 F6 D0 01 22 69 46 28 46 E0 F7 C5 F8 00 28 EF D0 BD F8 00 00 20 80 01 20 7C BD 2D E9 F0 41
9:00:01 AM
9:00:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 1C 09 81 80 05 46 86 B0 00 20 08 80 AE 88 0F 46 04 46 01 90 02 90 0D F1 04 08 03 90 01 22 69 46 28 46 E0 F7 AB F8 00 28 3A D0 9D F8 00 00 19 28 38 D2 DF E8 00 F0 20 0D 17 20 20 20 20 20 37 20 20 37 37 20 37 20 20 20 20 37 20 20 20 20 20 00 04 A9 28 46 FF F7 A6 FF 00 28 21 D0 01 21 28 F8 14 10 06 E0 08 EB 44 01 28 46 FF F7 9B FF 00 28 16 D0 64 1C 0C E0 74 B1 08 EB 44 01 31 F8 02 0C 28 B1 40 1E
9:00:02 AM
9:00:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 1D 09 81 80 00 04 00 0C 21 F8 02 0C C6 D1 64 1E 24 04 24 0C C2 D1 A8 88 80 1B 38 80 AE 80 01 20 06 B0 62 E4 00 20 FB E7 38 B5 04 46 0D 46 40 68 69 46 FF F7 A5 FF 00 28 0A D0 60 68 E0 F7 1D F8 68 60 60 68 BD F8 00 10 80 88 08 44 28 80 01 20 38 BD 40 68 66 E7 70 B5 D0 E9 01 56 0C 46 FF F7 F8 FF 00 28 10 D0 21 88 59 B1 30 46 DF F7 DB FF 60 60 01 00 08 D0 22 88 28 46 BD E8 70 40 E0 F7 3D B8 00 20
9:00:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 1E 09 81 80 60 60 01 20 77 E4 70 B5 0C 00 05 46 14 D0 21 68 91 B1 FF F7 C7 FF 00 28 0D D0 21 68 28 46 08 31 FF F7 D7 FF 00 28 06 D0 20 68 01 89 41 82 20 68 01 89 01 82 01 20 5E E4 00 20 5C E4 10 B5 40 68 82 88 C4 88 53 1C A3 42 01 D9 00 20 10 BD 03 68 9A 5C 0A 70 81 88 49 1C 81 80 01 20 10 BD 10 B5 40 68 82 88 C4 88 93 1C A3 42 01 D9 00 20 10 BD 03 68 1A 44 13 78 4B 70 52 78 0A 70 81 88 89 1C
9:00:03 AM
9:00:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 1F 09 81 80 81 80 01 20 10 BD 10 B5 40 68 82 88 C4 88 13 1D A3 42 01 D9 00 20 10 BD 03 68 1A 44 13 78 CB 70 53 78 8B 70 93 78 4B 70 D2 78 0A 70 81 88 09 1D 81 80 01 20 10 BD 10 B5 42 68 90 88 D4 88 00 F1 08 03 A3 42 01 D9 00 20 10 BD 13 68 18 44 03 78 CB 71 43 78 8B 71 83 78 4B 71 C3 78 0B 71 03 79 CB 70 43 79 8B 70 83 79 4B 70 C0 79 08 70 90 88 08 30 90 80 01 20 10 BD 40 68 DF F7 BD BF F8 B5
9:00:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 20 09 81 80 0D 46 04 46 69 46 86 68 FF F7 98 FF 00 28 12 D0 9D F8 00 00 60 B1 08 21 30 46 DF F7 42 FF 28 60 01 00 08 D0 20 46 FF F7 54 FF 00 28 03 D0 01 E0 00 20 28 60 01 20 F8 BD F8 B5 D0 E9 01 67 0C 46 69 46 FF F7 44 FF 00 28 22 D0 BD F8 00 00 41 07 4F EA D0 01 01 D0 89 1C 00 E0 49 1C 21 80 BD F8 00 00 42 07 04 D0 00 F0 07 00 C0 F1 08 05 00 E0 00 25 38 46 DF F7 15 FF 60 60 00 28 08 D0 05 70
9:00:04 AM
9:00:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 21 09 81 80 20 88 61 68 40 1E 82 B2 49 1C 30 46 DF F7 74 FF F8 BD 70 B5 43 68 4F F0 1F 04 9A 88 18 68 10 44 4F F0 00 02 0A 60 10 F8 01 2B 94 43 11 D1 10 F8 01 5B 25 F0 80 04 2D 06 09 D5 05 78 2E 06 01 D5 00 20 99 E4 25 F0 80 05 05 EB C4 14 A4 B2 02 EB 04 22 0A 60 19 68 40 1A 98 80 01 20 8C E4 2D E9 F8 43 44 68 84 46 0F 46 A5 88 20 68 90 46 46 19 69 46 60 46 FF F7 CD FF 00 28 13 D0 39 68 00 98
9:00:05 AM
9:00:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 22 09 81 80 81 42 01 D0 A5 80 0C E0 80 06 10 D5 B1 78 30 78 89 1C 88 42 F6 D1 71 78 3A 79 91 42 04 D0 40 1C A0 80 00 20 BD E8 F8 83 A0 88 80 1C A0 80 41 46 60 46 FF F7 CE FE 00 28 E4 D0 01 20 F2 E7 2D E9 F8 43 44 68 0F 46 90 46 06 46 A5 88 69 46 FF F7 A0 FF 00 28 E6 D0 38 68 00 9A 90 42 01 D0 A5 80 22 E0 A0 88 21 68 92 06 01 44 0E D5 8B 78 0A 78 9B 1C 9A 42 F3 D1 49 78 3B 79 99 42 03 D0 10 44
9:00:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 23 09 81 80 40 1C A0 80 10 E0 80 1C A0 80 08 21 B0 68 DF F7 88 FE C8 F8 00 00 01 00 06 D0 30 46 FF F7 99 FE 00 28 BF D0 01 20 BD E7 00 20 BB E7 70 B5 0C 46 15 00 06 46 1B D0 21 68 FF F7 7C FD 00 28 17 D0 20 68 80 06 0D D5 28 88 80 1C 81 B2 30 46 FF F7 FE FC 00 28 0C D0 21 79 30 46 FF F7 79 FC 00 28 06 D0 29 46 30 46 FF F7 0F FD 00 28 00 D0 01 20 0A E4 2D E9 F0 41 06 46 88 46 D6 E9 01 50 AA 88
9:00:06 AM
9:00:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 24 09 81 80 29 68 8F 18 0C 21 DF F7 4C FE 04 00 0D D0 38 78 00 F0 1F 00 20 70 A8 88 40 1C A8 80 20 78 28 B1 01 28 03 D0 02 28 01 D0 00 20 27 E5 21 1D 30 46 FF F7 4F FE 00 28 F8 D0 01 20 C8 F8 00 40 1D E5 38 B5 0C 46 11 46 05 46 FF F7 34 FD 00 28 1A D0 A0 88 80 1C 81 B2 28 46 FF F7 B9 FC 00 28 12 D0 20 78 01 22 40 F0 80 00 8D F8 00 00 69 46 28 46 DF F7 6B FE 00 28 06 D0 20 78 28 B1 01 28 03 D0
9:00:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 25 09 81 80 02 28 01 D0 00 20 38 BD 21 1D 28 46 FF F7 BC FC 38 BD 10 B5 19 B1 FF F7 D3 FF 00 28 00 D0 01 20 10 BD 7C B5 0C 46 05 46 A3 21 FF F7 03 FD 00 28 0D D0 05 21 28 46 FF F7 8A FC 00 28 07 D0 14 F8 01 1B 01 20 01 29 03 D0 02 29 06 D0 00 20 7C BD AD F8 00 00 A1 21 01 94 03 E0 AD F8 00 00 A2 21 01 94 6B 46 02 22 28 46 FF F7 11 FD 7C BD 2D E9 F0 41 D0 E9 01 57 0E 46 A9 88 28 68 44 18 28 46
9:00:07 AM
9:00:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 26 09 81 80 DF F7 0C FE 00 28 16 D0 14 F8 01 0B A0 B1 01 21 38 46 DF F7 C6 FD 30 60 00 28 0C D0 28 46 DF F7 FD FD 00 28 07 D0 31 68 14 F8 01 0B 08 70 28 68 20 1A A8 80 01 20 A1 E4 00 20 30 60 A8 88 40 1C F7 E7 30 B5 0C 00 05 46 0C D0 01 21 FF F7 C0 FB 00 28 06 D0 21 78 28 46 FF F7 BA FB 00 28 00 D0 01 20 30 BD 00 21 F7 E7 38 B5 44 68 0D 46 03 22 69 46 20 46 DF F7 00 FE 00 28 0C D0 9D F8 00 00
9:00:08 AM
9:00:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 27 09 81 80 5F 28 07 D1 9D F8 01 00 1F 28 03 D1 9D F8 02 00 04 28 01 D0 00 20 38 BD 04 22 29 46 20 46 DF F7 EB FD 38 BD 38 B5 45 68 0C 46 02 22 69 46 28 46 DF F7 E2 FD 00 28 08 D0 9D F8 00 00 5E 28 03 D1 9D F8 01 00 02 28 01 D0 00 20 38 BD 00 20 20 70 60 70 02 22 A1 1C 28 46 DF F7 CE FD 38 BD 7C B5 0C 46 05 46 5F 21 FF F7 73 FB 68 B1 1F 21 28 46 FF F7 6E FB 40 B1 04 20 AD F8 00 00 69 46 28 46
9:00:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 28 09 81 80 01 94 FF F7 01 FC 7C BD 00 20 7C BD 02 78 52 1C D2 B2 02 70 06 2A 04 D2 0B 78 01 2B 03 D0 02 2B 01 D0 00 20 70 47 00 EB 82 02 8B 68 13 61 03 78 8A 88 00 EB 43 00 42 80 88 68 70 47 02 78 0A B1 06 2A 01 D3 00 20 70 47 00 EB 82 02 0C 31 11 61 02 78 00 EB 42 03 5A 88 32 B1 52 1E 12 04 12 0C 5A 80 01 D0 08 46 70 47 02 78 00 21 00 EB 82 02 11 61 02 78 00 EB 42 02 51 80 01 78 49 1E C9 B2
9:00:09 AM
9:00:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 29 09 81 80 01 70 00 EB 81 01 09 69 D8 E7 0A 78 01 2A 02 D0 02 2A 00 D0 D2 E7 8A 68 02 B1 B7 E7 00 20 70 47 30 B5 8B B0 05 46 0C 46 28 21 68 46 D7 F7 15 FF 9C B3 21 78 13 29 04 D0 28 46 FF F7 09 FB 00 28 51 D0 20 78 0F 28 1E D0 09 DC 0B 28 4D D2 DF E8 00 F0 43 15 15 1A 1F 25 25 4C 4C 2A 2A 00 15 28 35 D0 08 DC A0 F1 10 00 05 28 3E D2 DF E8 00 F0 20 0B 20 25 2A 00 16 28 37 D1 04 E0 A1 88 28 46
9:00:10 AM
9:00:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 2A 09 81 80 FF F7 65 FB 27 E0 21 79 28 46 FF F7 E1 FA 22 E0 21 1D 28 46 FF F7 A6 FB 1D E0 26 E0 28 46 61 68 FF F7 FA FA 17 E0 21 1D 28 46 FF F7 6D FB 12 E0 A1 88 28 46 FF F7 DB FA 0D E0 21 1D 28 46 FF F7 05 FC 08 E0 21 1D 28 46 FF F7 01 FB 03 E0 21 1D 28 46 FF F7 1C FB 40 B1 21 46 68 46 FF F7 95 FF 04 00 A6 D1 01 20 0B B0 30 BD 00 20 FB E7 10 B1 01 78 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00
9:00:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 2B 09 81 80 80 8A 70 47 18 B1 01 78 09 B1 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00 40 8A 70 47 18 B1 01 78 09 B1 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00 C0 88 70 47 20 B1 01 78 02 29 01 D3 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00 80 88 70 47 F0 B5 C2 68 01 27 00 23 12 F8 3A 4F FF 2C 06 D0 55 1C 65 5D 01 2D 08 D0 02 2D 06 D0 2D E0 13 70 0C 78 54 70 17 81 93 82 2A E0 02 EB 44 05 2D 89 75 B1
9:00:11 AM
9:00:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 2C 09 81 80 64 1C E4 B2 14 70 06 2C 05 D9 01 88 41 F4 00 41 01 80 00 20 F0 BD 02 EB 44 04 A3 82 17 E0 24 B9 04 88 44 F4 00 44 04 80 0E E0 E4 B2 02 EB 44 04 A5 8A 6D 1C AD B2 A5 82 14 78 02 EB 44 06 F6 88 B5 42 04 D3 64 1E 14 70 14 78 00 2C ED D1 15 78 56 1C 0C 78 AC 55 0C 78 01 2C 07 D0 02 2C 05 D0 11 78 02 EB 41 01 0F 81 11 78 08 E0 8B 60 13 78 89 88 02 EB 43 03 19 81 11 78 29 B9 11 89 19 B9
9:00:12 AM
9:00:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 2D 09 81 80 01 88 41 F4 00 41 01 80 11 78 00 23 10 E0 2B B9 54 18 64 78 01 2C 10 D0 02 2C 17 D0 02 EB 41 04 A5 8A E4 88 6D 1C A5 42 04 D3 01 23 49 1E C9 B2 00 29 EC D1 53 B1 29 B1 08 E0 02 EB 41 04 24 89 24 B9 EB E7 01 88 41 F4 00 41 01 80 01 20 F0 BD 70 B5 0C 46 05 46 DF F7 21 FC 22 88 90 42 01 D2 00 20 0F E4 22 B1 61 68 11 B1 28 46 DF F7 2D FC 01 20 07 E4 70 B5 05 46 00 F1 14 04 00 7D 00 21
9:00:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 2E 09 81 80 FF 28 06 D0 62 1C 82 5C 01 2A 14 D0 02 2A 12 D0 32 E0 21 70 A8 78 60 70 A8 88 20 81 A1 82 A8 78 4F F4 00 41 01 28 01 D0 02 28 02 D1 A8 88 00 B1 00 21 29 80 2B E0 04 EB 40 02 12 89 E2 B1 40 1C C0 B2 20 70 06 28 05 D9 28 88 40 F4 00 40 28 80 00 20 B6 E4 04 EB 40 00 81 82 18 E0 04 EB 40 00 81 8A 49 1C 89 B2 81 82 20 78 04 EB 40 02 D2 88 91 42 05 D3 40 1E 20 70 10 F0 FF 00 EE D1 02 E0
9:00:13 AM
9:00:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 2F 09 81 80 10 F0 FF 0F 03 D1 28 88 40 F4 00 40 28 80 22 78 60 1C A9 78 11 54 A8 78 01 28 08 D0 02 28 06 D0 21 78 01 20 04 EB 41 01 08 81 20 78 07 E0 21 78 A8 88 04 EB 41 01 08 81 20 78 28 B9 20 89 18 B9 28 88 40 F4 00 40 28 80 20 78 00 21 10 E0 29 B9 22 18 52 78 01 2A 10 D0 02 2A 17 D0 04 EB 40 02 93 8A D2 88 5B 1C 93 42 04 D3 01 21 40 1E C0 B2 00 28 EC D1 51 B1 28 B1 08 E0 04 EB 40 02 12 89
9:00:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 30 09 81 80 22 B9 EB E7 28 88 40 F4 00 40 28 80 28 69 DF F7 85 FB 18 B9 28 88 40 F4 00 40 28 80 01 20 50 E4 F8 B5 04 46 00 20 08 80 0E 46 A5 88 69 46 20 46 FF F7 E4 FA 90 B1 A0 88 BD F8 00 10 08 44 A0 80 69 46 20 46 FF F7 AC FA 40 B1 A0 88 BD F8 00 10 08 44 40 1B 30 80 A5 80 01 20 F8 BD A5 80 00 20 F8 BD 2D E9 FC 41 05 69 04 46 28 46 DF F7 43 FB 80 46 01 22 A1 1C 28 46 DF F7 7E FB B0 B3 01 20
9:00:14 AM
9:00:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 31 09 81 80 C4 F8 08 80 AD F8 04 00 A3 78 04 21 00 26 08 22 4F F0 02 0C 19 2B 5B D2 DF E8 03 F0 0D 10 10 16 19 29 29 29 5A 2C 2C 5A 5A 16 5A 16 31 16 31 34 57 57 16 29 57 00 AD F8 00 60 36 E0 01 A9 28 46 FF F7 6E FA 90 B1 F6 E7 AD F8 00 00 22 E0 69 46 28 46 FF F7 65 FA 48 B1 BD F8 00 00 41 07 4F EA D0 00 00 D0 40 1C AD F8 00 00 10 E0 30 E0 AD F8 00 10 0F E0 69 46 28 46 FF F7 52 FA 06 E0 AD F8
9:00:15 AM
9:00:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 32 09 81 80 00 C0 07 E0 69 46 28 46 FF F7 8A FF 00 B3 BD F8 00 00 50 B1 28 46 DF F7 01 FB 01 46 BD F8 00 00 81 42 15 D3 A9 88 08 44 A8 80 28 46 DF F7 E3 FA A0 EB 08 00 A0 81 BD F8 04 00 A0 80 20 46 FF F7 D9 FE 28 B1 01 20 BD E8 FC 81 AD F8 00 20 E1 E7 00 20 F8 E7 70 B5 04 46 90 B0 0D 46 40 68 DF F7 DD FA 06 46 60 68 DF F7 C6 FA 01 46 32 46 0D A8 DF F7 92 FA 34 21 68 46 D7 F7 AF FC FF 20 8D F8
9:00:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 33 09 81 80 14 00 0D A8 04 90 DF F7 B6 FA 06 46 1E E0 00 BF BD F8 00 00 00 04 19 D5 BD F8 0C 10 02 98 08 44 CE B1 C0 B1 80 1B 01 04 09 0C 14 D0 29 80 A0 68 DF F7 77 FA 68 60 01 00 06 D0 2A 88 60 68 DF F7 DB FA 00 28 00 D0 01 20 10 B0 11 E4 68 46 FF F7 48 FF 00 28 DC D1 00 20 F6 E7 F8 B5 06 46 00 20 08 60 0D 46 04 46 69 46 30 46 FF F7 A7 FA 00 28 10 D0 9D F8 00 00 58 B1 08 21 B0 68 DF F7 51 FA
9:00:16 AM
9:00:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 34 09 81 80 04 00 08 D0 01 46 30 46 FF F7 A4 FF 00 28 01 D0 01 20 2C 60 F8 BD 00 20 F8 BD 2D E9 F0 41 06 46 40 68 0C 46 00 25 87 88 30 46 FF F7 87 FA 00 28 4C D0 20 78 0F 28 41 D0 09 DC 0B 28 1A D2 DF E8 00 F0 1A 14 14 3D 1F 24 24 19 19 29 29 00 15 28 2F D0 07 DC A0 F1 10 00 04 28 0B D2 DF E8 00 F0 1F 2E 1F 24 16 28 2E D1 28 E0 21 1D 30 46 FF F7 2E FA 05 46 3D B3 21 46 30 46 BD E8 F0 41 A6 E5
9:00:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 35 09 81 80 21 1D 30 46 FF F7 D8 FA F3 E7 21 1D 30 46 FF F7 7A FA EE E7 21 1D 30 46 FF F7 1B FA E9 E7 21 1D 30 46 FF F7 5C FA E4 E7 21 1D 30 46 FF F7 2B FA DF E7 21 1D 30 46 FF F7 7E FA DA E7 21 1D 30 46 FF F7 3C FA D5 E7 70 68 87 80 00 20 33 E4 2D E9 F0 41 05 46 80 88 88 46 28 B9 01 22 28 46 DF F7 64 FA 00 28 F2 D0 28 68 00 27 3C 46 06 78 01 20 19 2E 67 D2 FE 49 11 F8 26 20 93 07 4E D5 A8 88
9:00:17 AM
9:00:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 36 09 81 80 02 28 06 D2 01 22 41 46 28 46 DF F7 4E FA 00 28 DC D0 28 68 40 78 01 06 05 D4 67 F3 0F 24 60 F3 07 04 02 20 32 E0 81 28 02 D0 82 28 12 D0 49 E0 A8 88 03 28 06 D2 01 22 41 46 28 46 DF F7 35 FA 00 28 C3 D0 28 68 67 F3 0F 24 80 78 60 F3 07 04 03 20 1B E0 A8 88 03 28 06 D2 01 22 41 46 28 46 DF F7 23 FA 00 28 B1 D0 A8 88 04 28 06 D2 01 22 41 46 28 46 DF F7 19 FA 00 28 A7 D0 28 68 81 78
9:00:18 AM
9:00:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 37 09 81 80 C0 78 61 F3 0F 24 60 F3 07 04 04 20 01 2E 03 D0 02 2E 01 D0 13 2E 06 D1 3C 46 04 E0 D2 07 11 D0 01 EB 86 01 4C 88 A9 88 20 44 80 B2 81 42 07 D2 40 1A 82 B2 41 46 28 46 DF F7 F7 F9 00 28 85 D0 01 20 83 E7 00 20 81 E7 2D E9 FF 47 80 46 0C 46 17 46 01 26 02 F4 78 49 C2 F3 0A 05 DF F7 8B F9 82 46 40 46 DF F7 9A F9 A8 42 70 D3 44 F2 02 01 78 1A 8F 42 6D D0 16 DC 42 F2 04 01 A7 EB 01 00
9:00:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 38 09 81 80 8F 42 3F D0 06 DC 01 2F 33 D0 A7 F5 80 50 02 38 1F D1 32 E0 A0 F5 00 60 04 38 4B D0 A0 F5 E0 60 F9 38 16 D1 4F E0 41 F6 FF 72 81 1A 90 42 5C D0 08 DC A0 F5 80 50 02 38 4F D0 A0 F5 00 60 04 38 07 D1 4E E0 B1 F5 80 5F 53 D0 A1 F5 E0 41 03 39 55 D0 48 46 B9 F5 20 4F 7E D0 61 DC C7 F3 0A 07 A7 F1 02 07 B0 F5 00 4F 65 D0 B9 F5 10 4F 5D D1 84 E0 20 78 11 28 2A D1 3E E0 20 78 12 28 26 D1
9:00:19 AM
9:00:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 39 09 81 80 02 22 1B E0 20 78 06 28 02 D0 09 28 1F D1 01 E0 04 22 13 E0 A0 88 0C 28 19 D1 69 46 A0 68 FE F7 F0 FB A0 B1 03 A9 68 46 DE F7 58 FE 78 B1 04 22 03 A9 04 E0 20 78 15 28 7A D1 08 22 21 1D 40 46 DF F7 BD F9 6F E0 20 78 0F 28 71 D1 14 E0 6F E0 FF E7 20 78 10 28 6B D1 D2 E7 20 78 05 28 67 D1 D6 E7 20 78 14 28 63 D1 E7 E7 20 78 03 28 5F D1 02 E0 20 78 16 28 5B D1 01 22 21 1D 50 E0 20 78
9:00:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 3A 09 81 80 09 28 13 D1 A0 88 0C 28 10 D1 69 46 A0 68 FE F7 B8 FB 58 B1 51 46 68 46 DE F7 20 FE 30 B1 06 E0 B0 F5 30 4F 37 D0 B9 F5 40 4F 3E D0 00 26 30 46 04 B0 BD E8 F0 87 20 78 09 28 39 D1 02 2D 37 D3 02 22 21 1D 40 46 DF F7 7A F9 00 28 F0 D0 A0 88 B8 42 17 D2 01 46 00 E0 16 E0 8F B2 30 B1 3A 46 40 46 A1 68 DF F7 F1 F8 00 28 E1 D0 E8 1B B8 F8 04 10 80 1E 08 44 A8 F8 04 00 D8 E7 20 78 0A 28
9:00:20 AM
9:00:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 3B 09 81 80 16 D1 DB E7 A9 1E E6 E7 20 78 09 28 10 D1 A2 88 AA 42 0D D1 03 E0 20 78 0A 28 09 D1 F7 E7 A1 68 40 46 DF F7 D2 F8 06 46 C1 E7 20 78 04 28 01 D0 00 20 BD E7 02 22 21 1D 40 46 DF F7 40 F9 00 28 B6 D0 A2 88 EB E7 10 B5 00 78 19 28 1F D2 48 4B 89 68 13 F8 20 20 09 88 D4 07 03 F1 64 02 03 EB 80 03 C1 F3 0A 04 5B 88 07 D0 A3 42 0F D1 32 F8 10 00 70 B1 88 42 0A D1 0B E0 A3 42 07 D3 32 F8
9:00:21 AM
9:00:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 3C 09 81 80 10 00 30 B1 00 F4 78 40 01 F4 78 41 F2 E7 00 20 10 BD 01 20 10 BD 2D E9 FC 5F 00 27 0C 9D 06 46 1F 70 08 78 89 46 14 46 9A 46 01 28 79 D0 02 28 77 D0 28 78 4F F0 02 0C 10 B1 01 28 1F D0 80 E0 20 78 FF 28 19 D0 40 1C 69 78 C0 B2 81 42 00 D8 00 20 31 78 06 29 36 D2 6B 68 00 EB 40 02 13 F8 22 70 8F 42 2F D1 06 EB 41 01 0C EB 82 02 9A 5A 89 8A 8A 42 27 D1 20 70 25 E0 00 20 E4 E7 20 78
9:00:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 3D 09 81 80 FF 28 1D D0 22 E0 00 BF 68 68 07 EB 47 01 33 78 10 F8 21 20 9A 42 11 D1 06 EB 43 03 0C EB 81 02 82 5A 9B 8A 9A 42 01 D0 FF 2A 07 D1 00 EB 81 01 48 46 FF F7 88 FF 08 B1 27 70 04 E0 7F 1C FF B2 68 78 B8 42 E0 D8 20 78 FF 28 74 D0 C0 B2 69 78 83 46 88 42 35 D2 6A 68 0B EB 4B 00 02 EB 80 01 30 78 86 46 06 28 21 D2 0B 78 9E 45 1E D2 01 E0 88 46 06 00 00 20 17 E0 00 EB 40 03 12 F8 23 80
9:00:22 AM
9:00:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 3E 09 81 80 F0 45 0F D1 0C EB 83 03 D7 5A 06 EB 4E 03 9B 8A 9F 42 07 D1 20 70 69 68 00 EB 40 00 01 EB 80 01 04 E0 48 E0 40 1C C0 B2 83 45 E5 D8 C8 88 01 28 1A D9 32 78 06 2A 04 D2 06 EB 42 02 93 8A 83 42 02 D3 00 20 BD E8 FC 9F 8A 68 40 1E 83 42 32 F8 13 20 02 D1 88 88 8A F8 00 00 9A F8 00 00 40 B1 28 78 01 28 03 D0 04 E0 88 68 02 88 F2 E7 FF 20 20 70 99 F8 00 00 09 28 17 D1 B9 F8 04 00 86 28
9:00:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 3F 09 81 80 13 D9 A2 F5 00 40 88 38 0F D1 19 21 8A F8 00 10 B9 F8 04 00 AD F8 00 00 D9 F8 08 00 01 90 08 22 69 46 20 1D DE F7 D1 FF 03 E0 49 46 20 1D FF F7 0B FE 00 28 C6 D0 01 20 C4 E7 70 B5 88 B3 81 B3 04 78 00 22 02 25 01 23 10 2C 40 D0 0D DC 4F F0 04 05 10 2C 3C D2 DF E8 04 F0 23 3D 3D 25 27 3A 3A 23 3B 3D 23 3B 3B 25 3B 25 17 2C 18 D0 0A DC A4 F1 11 04 4F F0 08 00 06 2C 29 D2 DF E8 04 F0
9:00:23 AM
9:00:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 40 09 81 80 12 27 10 23 23 12 0C 20 1A 2C 09 D0 04 DC 18 2C 06 D0 19 2C 1C D1 16 E0 1B 2C 14 D0 FF 2C 17 D1 0A 80 08 E0 0B 80 13 E0 30 F8 04 2F 1A B1 40 68 00 78 08 28 01 D9 00 20 70 BD 01 2A 05 D0 D2 00 08 3A 10 1A 80 B2 08 80 02 E0 00 20 FB E7 0D 80 01 20 70 BD 80 88 F6 E7 70 B5 C2 68 0C 46 05 46 92 F8 8C 10 F1 B3 92 F8 80 00 30 B1 01 28 0B D0 02 28 0F D0 03 28 19 D1 12 E0 21 29 16 D1 02 F1
9:00:24 AM
9:00:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 41 09 81 80 90 02 07 CA 07 C4 32 E0 07 29 0F D1 D2 F8 90 00 E0 60 2C E0 07 29 09 D1 D2 F8 90 00 20 61 26 E0 92 F8 3A 00 03 28 01 D1 21 29 01 D0 00 20 70 BD 32 F8 44 0F D6 89 0E B1 A0 69 08 E0 A0 82 00 EB 40 00 80 04 01 0C A8 68 DE F7 EB FE A0 61 06 EB 46 01 EA 68 00 EB 81 00 02 F1 80 01 D2 F8 90 20 02 60 00 E0 03 E0 4A 69 42 60 89 69 81 60 01 20 70 BD 2D E9 FF 41 04 46 0F 46 16 46 1D 46 20 21
9:00:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 42 09 81 80 18 46 D7 F7 EA F8 07 2F 04 D1 00 27 01 2E 06 D0 02 2E 07 D0 20 88 40 F4 00 40 20 80 5B E0 2F 70 FC 4E 03 E0 01 20 FB 4E 28 70 08 36 E0 68 00 28 52 D0 3A 30 20 21 D7 F7 F7 F8 E0 68 00 F1 80 01 C0 F8 80 70 4F 60 8F 60 E0 68 90 21 8C 30 D7 F7 C4 F8 E0 68 8C 22 00 F1 90 01 84 30 DE F7 9C FE E1 68 FF 20 81 F8 3A 00 E1 68 81 F8 80 00 2C E0 00 96 E0 68 01 A9 00 F1 8C 03 00 F1 80 02 3A 30
9:00:25 AM
9:00:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 43 09 81 80 FF F7 49 FE 00 28 27 D0 E0 68 90 F8 8C 10 E1 B1 29 78 11 B1 01 29 0F D1 06 E0 29 1D 20 46 FF F7 5B FF 00 28 18 D0 07 E0 00 F1 90 00 D0 E9 00 12 80 68 69 60 C5 E9 02 20 E0 68 4F F0 8C 02 00 F1 90 01 00 F1 84 00 DE F7 67 FE 01 A9 20 46 FF F7 24 FC 00 28 CC D1 01 20 04 B0 77 E4 70 B5 0E 46 05 46 14 46 11 46 FE F7 A9 FE 00 28 08 D0 22 78 23 1D 31 46 28 46 FF F7 7C FF 00 28 00 D0 01 20
9:00:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 44 09 81 80 70 BD F8 B5 04 46 00 20 0D 46 10 60 16 46 69 46 20 46 FE F7 93 FE 00 28 10 D0 9D F8 00 00 60 B1 24 21 A0 68 DE F7 3D FE 30 60 02 00 06 D0 29 46 20 46 FF F7 D3 FF 00 28 00 D0 01 20 F8 BD 70 B5 05 46 0C 46 FE F7 8B FE 00 28 0D D0 06 22 A1 1C 28 46 FE F7 D1 FE 00 28 06 D0 04 F1 08 01 28 46 BD E8 70 40 FE F7 6A BE 70 BD 70 B5 0C 46 05 46 09 88 FE F7 3C FC 00 28 0C D0 06 22 A1 1C 28 46
9:00:26 AM
9:00:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 45 09 81 80 FE F7 EE FC 00 28 05 D0 21 7A 28 46 BD E8 70 40 FE F7 1E BC 70 BD 70 B5 05 46 0C 46 FE F7 4E FE 00 28 0C D0 A1 1C 28 46 FF F7 C9 FF 00 28 06 D0 61 88 04 F1 0C 02 28 46 BD E8 70 40 A1 E7 70 BD 70 B5 46 68 0D 46 B1 88 30 68 44 18 30 46 DE F7 25 FE 05 28 01 D2 00 20 70 BD 14 F8 01 0B 28 70 20 78 E8 71 60 78 A8 71 A0 78 68 71 E0 78 28 71 30 68 24 1D 20 1A B0 80 01 20 70 BD 2D E9 F0 41
9:00:27 AM
9:00:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 46 09 81 80 07 46 0D 46 FE F7 1A FE 00 28 26 D0 29 1D 38 46 FE F7 DD FD 00 28 20 D0 A8 88 00 05 01 0C B8 68 DE F7 BF FD 00 28 18 D0 04 46 00 26 A8 60 10 E0 21 46 38 46 FF F7 83 FF 00 28 0E D0 21 88 04 F1 0C 02 38 46 FF F7 5D FF 00 28 06 D0 10 34 76 1C B6 B2 A8 88 B0 42 EB D8 01 20 32 E4 70 B5 0C 46 05 46 09 78 FE F7 B4 FB 00 28 0A D0 21 79 28 46 FE F7 AE FB 00 28 04 D0 20 79 18 B1 01 28 07 D0
9:00:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 47 09 81 80 00 20 70 BD 04 F1 08 01 28 46 FF F7 A1 F9 03 E0 21 7A 28 46 FE F7 9C FB 00 28 F2 D0 01 20 70 BD 70 B5 0C 46 05 46 09 78 FE F7 92 FB 00 28 16 D0 21 79 28 46 FE F7 8C FB 00 28 10 D0 28 46 A1 68 FE F7 AA FB 00 28 0A D0 21 7B 28 46 FE F7 80 FB 00 28 04 D0 20 7B 18 B1 01 28 07 D0 00 20 70 BD 04 F1 10 01 28 46 FE F7 0F FC 03 E0 21 7C 28 46 FE F7 6E FB 00 28 F2 D0 01 20 70 BD 2D E9 F0 41
9:00:28 AM
9:00:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 48 09 81 80 0E 46 07 46 09 78 FE F7 63 FB 00 28 A5 D0 B1 88 38 46 FE F7 DC FB 00 28 9F D0 00 24 1E E0 00 BF B0 68 04 EB 44 01 00 EB 81 05 38 46 29 78 FE F7 4F FB 00 28 91 D0 28 78 18 B1 01 28 06 D0 00 20 8B E7 29 1D 38 46 FF F7 43 F9 03 E0 29 79 38 46 FE F7 3E FB 00 28 80 D0 64 1C A4 B2 B0 88 A0 42 DE D8 01 20 79 E7 30 B5 0C 46 05 46 09 78 FE F7 2F FB 00 28 05 D0 61 78 28 46 BD E8 30 40 FE F7
9:00:29 AM
9:00:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 49 09 81 80 27 BB 30 BD 30 B5 0C 46 05 46 09 78 FE F7 20 FB 00 28 05 D0 28 46 61 68 BD E8 30 40 FE F7 3C BB 30 BD 30 B5 0C 46 05 46 09 78 FE F7 11 FB 00 28 0B D0 61 78 28 46 FE F7 0B FB 00 28 05 D0 28 46 61 68 BD E8 30 40 FE F7 27 BB 30 BD 70 B5 0C 46 06 46 09 78 FE F7 FC FA 00 28 19 D0 A1 88 30 46 FE F7 75 FB 00 28 13 D0 00 25 08 E0 A0 68 41 5D 30 46 FE F7 ED FA 00 28 0A D0 6D 1C AD B2 A0 88
9:00:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 4A 09 81 80 A8 42 F3 D8 30 46 E1 68 BD E8 70 40 FE F7 04 BB 70 BD 00 00 50 46 06 00 70 B5 0D 46 06 46 09 78 FE F7 D6 FA 00 28 F3 D0 A9 88 30 46 FE F7 4F FB 00 28 ED D0 00 24 08 E0 A8 68 01 5D 30 46 FE F7 C7 FA 00 28 E4 D0 64 1C A4 B2 A8 88 A0 42 F3 D8 01 20 DD E7 2D E9 F0 41 07 46 0D 46 44 68 FE F7 4E FD 00 28 34 D0 A1 88 20 68 46 18 16 F8 01 0B 78 B3 29 1D 38 46 FE F7 E1 FC 00 28 28 D0 76 1C
9:00:30 AM
9:00:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 4B 09 81 80 20 68 05 F1 08 01 30 1A A0 80 38 46 FE F7 AF FE 00 28 1D D0 20 46 DE F7 C1 FC 00 28 18 D0 A1 88 20 68 40 5C 28 73 A0 88 40 1C A0 80 20 46 DE F7 B5 FC 07 28 0B D3 05 F1 0D 01 38 46 FE F7 D4 FE 00 28 05 D0 20 46 DE F7 A9 FC 02 28 05 D2 00 20 C3 E6 FF E7 01 20 28 71 D2 E7 A1 88 20 68 08 44 01 78 E9 74 40 78 A8 74 A0 88 80 1C A0 80 01 20 B3 E6 70 B5 0C 46 05 46 09 68 FE F7 A2 FE 00 28
9:00:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 4C 09 81 80 86 D0 21 79 28 46 FE F7 63 FA 00 28 11 D0 61 1D 28 46 FE F7 E4 FE 00 28 0B D0 61 89 28 46 FE F7 66 FA 00 28 05 D0 A1 89 28 46 BD E8 70 40 FE F7 5E BA 6D E7 2D E9 F0 41 0E 46 07 46 09 88 FE F7 C6 FA 00 28 13 D0 00 25 31 E0 70 68 00 EB 05 14 38 46 21 78 FE F7 3C FA 00 28 08 D0 20 78 38 B1 01 28 0A D0 02 28 0D D0 03 28 25 D0 00 20 74 E6 21 1D 38 46 FF F7 2C F8 15 E0 21 79 38 46 FE F7
9:00:31 AM
9:00:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 4D 09 81 80 27 FA 10 E0 21 79 38 46 FE F7 22 FA 00 28 EE D0 E1 88 38 46 FE F7 2B FA 00 28 E8 D0 04 F1 08 01 38 46 FE F7 B1 FA 00 28 E1 D0 6D 1C AD B2 30 88 A8 42 CA D8 01 20 50 E6 A1 88 38 46 FE F7 17 FA F1 E7 2D E9 F0 41 0E 46 07 46 09 88 FE F7 7F FA 00 28 11 D0 00 24 1D E0 70 68 00 EB 84 05 38 46 29 78 FE F7 F5 F9 00 28 06 D0 28 78 80 B1 01 28 03 D0 02 28 06 D0 00 20 2F E6 A9 78 38 46 FE F7
9:00:32 AM
9:00:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 4E 09 81 80 E7 F9 03 E0 69 88 38 46 FE F7 F1 F9 00 28 F3 D0 64 1C A4 B2 30 88 A0 42 DE D8 01 20 1D E6 30 B5 0C 46 05 46 09 78 FE F7 D3 F9 00 28 0B D0 61 78 28 46 FE F7 CD F9 00 28 05 D0 A1 78 28 46 BD E8 30 40 FE F7 C5 B9 30 BD 70 B5 0C 46 06 46 09 78 FE F7 B0 FA 00 28 0B D0 20 78 01 28 09 D0 02 28 0C D0 04 F1 0C 05 03 28 11 D0 04 28 0F D0 00 20 CE E6 21 79 30 46 FE F7 AB F9 12 E0 21 79 30 46
9:00:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 4F 09 81 80 FE F7 A6 F9 00 28 F3 D0 04 F1 08 01 06 E0 21 1D 30 46 FE F7 39 FA 00 28 EA D0 29 46 30 46 FE F7 33 FA 00 28 E4 D0 01 20 B2 E6 70 B5 05 46 0C 46 FF F7 CA FF 00 28 07 D0 04 F1 14 01 28 46 FE F7 23 FA 00 28 00 D0 01 20 A2 E6 70 B5 0C 46 05 46 09 78 FE F7 6F FA 00 28 08 D0 20 78 38 B1 01 28 0A D0 02 28 11 D0 03 28 14 D0 00 20 90 E6 21 1D 28 46 FE F7 6D FF 18 E0 21 1D 28 46 FE F7 68 FF
9:00:33 AM
9:00:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 50 09 81 80 00 28 F3 D0 04 F1 0C 01 0C E0 21 1D 28 46 FF F7 CC FF 0A E0 21 1D 28 46 FF F7 C7 FF 00 28 E5 D0 04 F1 20 01 28 46 FE F7 EF F9 00 28 DE D0 01 20 6E E6 70 B5 0C 46 05 46 09 78 FE F7 49 F9 00 28 06 D0 21 1D 28 46 FF F7 C0 FF 00 28 00 D0 01 20 5E E6 70 B5 0C 46 05 46 09 78 FE F7 39 F9 00 28 13 D0 21 79 28 46 FE F7 33 F9 00 28 0D D0 28 46 A1 68 FE F7 51 F9 00 28 07 D0 04 F1 0C 01 28 46
9:00:34 AM
9:00:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 51 09 81 80 FE F7 C2 F9 00 28 00 D0 01 20 41 E6 70 B5 0C 46 05 46 09 78 FE F7 0E FA 00 28 05 D0 20 78 01 28 03 D0 02 28 06 D0 00 20 32 E6 21 1D 28 46 FF F7 C0 FF 03 E0 21 1D 28 46 FF F7 CB FF 00 28 F3 D0 01 20 25 E6 70 B5 0C 46 05 46 09 68 FE F7 AC F9 00 28 06 D0 21 1D 28 46 FF F7 D8 FF 00 28 00 D0 01 20 15 E6 7C B5 45 68 06 46 0C 00 30 D0 40 21 20 46 D6 F7 F2 FC 69 46 30 46 FE F7 1F FB 38 B3
9:00:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 52 09 81 80 9D F8 00 00 60 28 23 D1 01 A9 30 46 FE F7 DF FA 00 28 1E D0 28 46 DE F7 EE FA 00 78 80 28 08 D0 FB 48 20 60 28 46 DE F7 E6 FA 01 78 A1 29 0F D1 06 E0 21 46 30 46 FE F7 62 FB 00 28 09 D0 F1 E7 C1 78 42 78 89 1C 8A 42 02 D1 80 78 06 28 01 D0 00 20 7C BD A8 88 21 1D C0 1C A8 80 30 46 FE F7 B8 FA 00 28 F5 D0 EA 49 04 F1 0C 02 08 31 30 46 FE F7 E5 FB E6 49 04 F1 10 02 10 31 30 46 FE F7
9:00:35 AM
9:00:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 53 09 81 80 DE FB E3 49 04 F1 14 02 18 31 30 46 FE F7 D7 FB DF 49 04 F1 18 02 20 31 30 46 FE F7 D0 FB DC 49 04 F1 1C 02 28 31 30 46 FE F7 C9 FB D8 49 04 F1 20 02 30 31 30 46 FE F7 C2 FB D5 49 04 F1 24 02 38 31 30 46 FE F7 BB FB D1 49 04 F1 28 02 40 31 30 46 FE F7 B4 FB CE 49 04 F1 2C 02 48 31 30 46 FE F7 AD FB CA 49 04 F1 30 02 50 31 30 46 FE F7 A6 FB 28 46 DE F7 7F FA 00 78 AC 28 07 D1 A8 88
9:00:36 AM
9:00:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 54 09 81 80 04 F1 34 01 80 1C A8 80 30 46 FE F7 F2 FB C0 49 04 F1 38 02 58 31 30 46 FE F7 91 FB BC 49 04 F1 3C 02 60 31 30 46 FE F7 8A FB 01 20 7C BD 2D E9 FF 41 06 46 0C 00 D6 E9 01 57 0B D0 00 20 20 60 60 60 69 46 30 46 FE F7 79 FA 18 B1 9D F8 00 00 62 28 02 D0 00 20 04 B0 7F E4 02 A9 30 46 FE F7 36 FA 00 28 F7 D0 28 46 DE F7 45 FA 00 78 80 28 18 D1 A8 88 03 A9 40 1C A8 80 30 46 FE F7 27 FA
9:00:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 55 09 81 80 00 28 E8 D0 01 A9 30 46 FE F7 58 FA 00 28 E2 D0 01 21 38 46 DE F7 05 FA 20 60 00 28 DB D0 9D F8 04 10 01 70 9A 49 22 1D 68 31 30 46 FE F7 47 FB 01 20 D0 E7 7C B5 0C 46 05 46 61 21 FE F7 FA F8 00 28 7D D0 AA 88 28 68 00 21 86 18 28 46 FE F7 7E F8 00 28 7E D0 23 68 33 B1 03 22 80 21 28 46 FE F7 15 F9 00 28 75 D0 23 1D 06 22 A1 21 28 46 FE F7 0D F9 00 28 6D D0 01 20 AD F8 00 00 04 F1
9:00:37 AM
9:00:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 56 09 81 80 0C 00 01 90 6B 46 02 22 A2 21 28 46 FE F7 FF F8 00 28 5F D0 04 F1 0D 01 28 46 FE F7 C2 FB 00 28 58 D0 23 69 33 B1 04 22 A4 21 28 46 FE F7 EF F8 00 28 4F D0 63 69 33 B1 04 22 A5 21 28 46 FE F7 E6 F8 00 28 46 D0 A3 69 33 B1 04 22 A6 21 28 46 FE F7 DD F8 00 28 3D D0 E3 69 33 B1 04 22 A7 21 28 46 FE F7 D4 F8 00 28 34 D0 23 6A 33 B1 03 22 88 21 28 46 FE F7 CB F8 00 28 2B D0 63 6A 33 B1
9:00:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 57 09 81 80 06 22 89 21 28 46 FE F7 C2 F8 00 28 22 D0 A1 6A 29 B1 AA 22 28 46 FE F7 53 FB 00 28 1A D0 E3 6A 33 B1 19 22 BD 21 28 46 FE F7 B1 F8 00 28 11 D0 23 6B 43 B1 04 22 BE 21 28 46 FE F7 A8 F8 00 E0 08 E0 00 28 06 D0 A9 88 28 68 08 44 80 1B 40 1E 30 70 01 20 7C BD 70 B5 0D 46 04 46 63 21 FE F7 69 F8 00 28 2D D0 A2 88 20 68 00 21 86 18 20 46 FD F7 ED FF 00 28 24 D0 28 68 90 B1 80 21 20 46
9:00:38 AM
9:00:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 58 09 81 80 FE F7 58 F8 00 28 1C D0 01 21 20 46 FD F7 DF FF 00 28 16 D0 28 68 01 78 20 46 FD F7 59 FF 00 28 0F D0 6B 68 33 B1 04 22 BE 21 20 46 FE F7 6F F8 00 28 06 D0 A1 88 20 68 08 44 80 1B 40 1E 30 70 01 20 65 E4 70 B5 05 46 0C 46 FE F7 77 F9 00 28 07 D0 20 78 01 28 05 D0 02 28 08 D0 03 28 0B D0 00 20 55 E4 21 1D 28 46 FF F7 15 FB 08 E0 21 1D 28 46 FF F7 25 FB 03 E0 21 1D 28 46 FF F7 3E FB
9:00:39 AM
9:00:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 59 09 81 80 00 28 EE D0 01 20 43 E4 30 B5 0C 46 05 46 09 78 FD F7 1E FF 00 28 06 D0 61 78 28 46 FD F7 18 FF 00 28 00 D0 01 20 30 BD 70 B5 05 46 0C 46 FE F7 45 F9 00 28 15 D0 A1 1C 28 46 FF F7 C0 FA 00 28 0F D0 61 88 04 F1 0C 02 28 46 FF F7 9A FA 00 28 07 D0 04 F1 10 01 28 46 FE F7 3C FE 00 28 00 D0 01 20 15 E4 70 B5 05 46 0C 46 FE F7 27 F9 00 28 0C D0 21 1D 28 46 FE F7 46 F9 00 28 06 D0 04 F1
9:00:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 5A 09 81 80 08 01 28 46 BD E8 70 40 FE F7 E3 B8 21 E4 00 00 E0 45 06 00 70 B5 05 46 0C 46 FE F7 0F F9 00 28 13 D0 A1 1C 28 46 FF F7 8A FA 00 28 0D D0 61 88 04 F1 0C 02 28 46 FF F7 64 FA 00 28 05 D0 04 F1 10 01 28 46 BD E8 70 40 CC E7 72 E4 70 B5 05 46 0C 46 FE F7 F3 F8 00 28 04 D0 21 1D 28 46 BD E8 70 40 BF E7 65 E4 2D E9 F0 41 06 46 0D 46 FE F7 E5 F8 00 28 45 D0 29 1D 30 46 FE F7 A8 F8 00 28
9:00:40 AM
9:00:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 5B 09 81 80 3F D0 A8 88 00 05 01 0C B0 68 DE F7 8A F8 00 28 37 D0 04 46 00 27 A8 60 10 E0 21 46 30 46 FF F7 4E FA 00 28 2D D0 21 88 04 F1 0C 02 30 46 FF F7 28 FA 00 28 25 D0 10 34 7F 1C BF B2 A8 88 B8 42 EB D8 05 F1 0C 01 30 46 FE F7 81 F8 00 28 18 D0 A8 89 C0 04 01 0C B0 68 DE F7 63 F8 00 28 10 D0 04 46 00 27 28 61 08 E0 21 46 30 46 FE F7 B2 FD 00 28 06 D0 08 34 7F 1C BF B2 A8 89 B8 42 F3 D8
9:00:41 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:00:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 5C 09 81 80 01 20 34 E4 00 20 70 47 70 B5 45 68 06 46 0C 46 28 46 DE F7 83 F8 00 28 23 D0 A9 88 28 68 40 5C 20 70 A8 88 40 1C A8 80 20 78 05 28 18 D2 DF E8 00 F0 17 03 08 0D 12 00 21 1D 30 46 BD E8 70 40 32 E7 21 1D 30 46 BD E8 70 40 63 E7 21 1D 30 46 BD E8 70 40 7A E7 21 1D 30 46 BD E8 70 40 82 E7 00 20 85 E4 70 B5 05 46 0C 46 FE F7 67 F8 00 28 1B D0 A1 1C 28 46 FE F7 72 F8 00 28 15 D0 06 22
9:00:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 5D 09 81 80 21 1D 28 46 FE F7 B8 F8 00 28 0E D0 04 F1 0A 01 28 46 FE F7 53 F8 00 28 07 D0 04 F1 0C 01 28 46 FE F7 9B FD 00 28 00 D0 01 20 61 E4 00 20 70 47 00 20 70 47 70 B5 05 46 0C 46 FE F7 3F F8 00 28 19 D0 A1 1C 28 46 FE F7 4A F8 00 28 13 D0 06 22 21 1D 28 46 FE F7 90 F8 00 28 0C D0 04 F1 0A 01 28 46 FE F7 2B F8 00 28 05 D0 04 F1 0C 01 28 46 BD E8 70 40 F6 E6 3B E4 00 20 70 47 00 20 70 47
9:00:42 AM
9:00:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 5E 09 81 80 70 B5 44 68 06 46 0D 46 20 46 DE F7 07 F8 00 28 19 D0 A1 88 20 68 40 5C 28 70 A0 88 40 1C A0 80 28 78 05 28 0E D2 DF E8 00 F0 0D 03 0D 0D 08 00 29 1D 30 46 BD E8 70 40 94 E7 29 1D 30 46 BD E8 70 40 B7 E7 00 20 13 E4 70 B5 0C 46 05 46 09 78 FD F7 BE FD 00 28 07 D0 20 78 01 28 05 D0 02 28 08 D0 03 28 0B D0 00 20 1E E4 21 1D 28 46 FF F7 F5 F9 08 E0 21 1D 28 46 FF F7 12 FA 03 E0 21 1D
9:00:43 AM
9:00:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 5F 09 81 80 28 46 FF F7 3B FA 00 28 EE D0 01 20 0C E4 70 B5 0C 46 05 46 09 78 FD F7 9B FD 00 28 26 D0 20 78 06 28 22 D2 DF E8 00 F0 21 03 09 0F 15 1B 21 1D 28 46 BD E8 70 40 FF F7 56 BA 21 1D 28 46 BD E8 70 40 FF F7 5F BA 21 1D 28 46 BD E8 70 40 FF F7 68 BA 21 1D 28 46 BD E8 70 40 FF F7 77 BA 21 1D 28 46 BD E8 70 40 FF F7 97 BA 00 20 20 E4 70 B5 05 46 0C 46 FD F7 A2 FF 00 28 04 D0 20 78 18 B1
9:00:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 60 09 81 80 01 28 06 D0 00 20 13 E4 21 1D 28 46 FE F7 A2 FC 03 E0 21 1D 28 46 FD F7 91 FF 00 28 F3 D0 01 20 06 E4 70 B5 0C 46 05 46 09 78 FD F7 51 FD 00 28 04 D0 20 78 18 B1 01 28 06 D0 00 20 08 E4 21 1D 28 46 FE F7 45 FB 03 E0 21 79 28 46 FD F7 40 FD 00 28 F3 D0 01 20 18 E4 70 B5 0C 46 05 46 09 78 FD F7 36 FD 00 28 14 D0 21 79 28 46 FD F7 30 FD 00 28 0E D0 A0 68 68 B1 01 21 28 46 FD F7 28 FD
9:00:44 AM
9:00:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 61 09 81 80 00 28 06 D0 28 46 A1 68 FF F7 CB FF 00 28 00 D0 01 20 09 E4 00 21 28 46 FD F7 1A FD F6 E7 70 B5 0C 46 05 46 09 78 FD F7 13 FD 00 28 03 D0 20 78 01 28 01 D0 00 20 04 E4 21 1D 28 46 BD E8 70 40 CA E7 30 B5 05 46 87 B0 0C 46 08 68 03 A9 FD F7 D8 F9 68 B1 09 20 8D F8 00 00 0C 20 AD F8 04 00 69 46 28 46 02 94 FE F7 DB F9 00 28 0F D0 03 E0 00 21 28 46 FD F7 EC FC 21 1D 28 46 FF F7 B5 F8
9:00:45 AM
9:00:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 62 09 81 80 00 28 04 D0 04 F1 10 01 28 46 FE F7 E1 FA 07 B0 30 BD 2D E9 F0 41 05 46 0C 46 D5 E9 01 67 B1 88 30 68 08 44 29 88 21 F4 80 41 29 80 2A 69 00 21 82 F8 BA 10 2A 69 82 F8 BB 10 00 78 20 70 60 28 23 D0 62 28 2C D0 A0 F1 21 01 37 29 02 D9 C8 38 0F 28 0C D8 28 88 40 F4 80 40 28 80 28 46 01 F0 79 FA 00 28 10 D0 B1 88 30 68 40 5C 20 70 B0 88 40 1C B0 80 20 78 01 28 1D D0 C0 28 26 D0 C1 28
9:00:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 63 09 81 80 2F D0 C3 28 38 D0 00 20 3B E6 40 21 38 46 DD F7 88 FE 60 60 01 00 F7 D0 28 46 FF F7 A3 FB 35 E0 08 21 38 46 DD F7 7D FE 60 60 01 00 EC D0 28 46 FF F7 3D FC 2A E0 14 21 38 46 DD F7 72 FE 60 60 01 00 E1 D0 28 46 FF F7 C5 F9 1F E0 14 21 38 46 DD F7 67 FE 60 60 01 00 D6 D0 28 46 FF F7 32 FD 14 E0 24 21 38 46 DD F7 5C FE 60 60 01 00 CB D0 28 46 FF F7 09 FE 09 E0 20 21 38 46 DD F7 51 FE
9:00:46 AM
9:00:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 64 09 81 80 60 60 01 00 C0 D0 28 46 FF F7 7A FE 00 28 BB D0 01 20 F6 E5 70 B5 0C 46 09 78 05 46 60 29 36 D0 61 29 17 D0 62 29 32 D0 63 29 17 D0 01 22 21 46 DD F7 8B FE 00 28 2B D0 21 78 60 29 5C D0 18 DC 0E 29 35 D0 0E DC 08 29 23 D0 0C 29 26 D0 0D 29 1D D1 28 E0 61 68 BD E8 70 40 2B E4 61 68 BD E8 70 40 B8 E4 0F 29 28 D0 16 29 45 D0 18 29 0E D1 42 E0 C5 29 30 D0 06 DC 61 29 3D D0 C2 29 21 D0
9:00:47 AM
9:00:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 65 09 81 80 C4 29 04 D1 23 E0 C7 29 2B D0 D8 29 2E D0 00 20 D7 E4 28 46 61 68 FF F7 AC F9 2B E0 28 46 61 68 FF F7 C8 F9 26 E0 28 46 61 68 FF F7 0A FA 21 E0 28 46 61 68 FF F7 33 FA 1C E0 28 46 61 68 FF F7 01 FB 17 E0 28 46 61 68 FF F7 FB FE 12 E0 28 46 61 68 FF F7 39 FE 0D E0 28 46 61 68 FF F7 57 FE 08 E0 28 46 61 68 FF F7 DA FE 03 E0 28 46 61 68 FF F7 CA FC 00 28 CB D0 01 20 A2 E4 5D 20 70 47
9:00:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 66 09 81 80 5D 28 03 D2 02 49 51 F8 20 00 70 47 00 20 70 47 E8 5A 06 00 3E B5 04 46 68 46 DD F7 9F FB 21 46 68 46 FD F7 73 F8 3E BD 0E B5 02 78 62 F3 0F 21 42 78 62 F3 07 01 89 B2 40 F6 29 02 91 42 01 D9 00 20 0E BD 69 46 FD F7 9C F8 00 28 F9 D0 68 46 2F F0 C9 FA 01 20 0E BD 00 B5 87 B0 01 46 1C 22 68 46 D5 F7 88 FF 68 46 2F F0 85 FA 07 B0 00 BD 70 B5 86 B0 04 46 0D 46 16 46 68 46 FF F7 CA FF
9:00:48 AM
9:00:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 67 09 81 80 00 28 0C D0 0C 20 AD F8 0C 00 CD F8 10 D0 01 20 84 F8 89 00 32 46 03 A9 28 46 FD F7 35 F9 06 B0 70 BD 30 B5 87 B0 05 46 0C 46 68 46 DD F7 41 FB 00 98 3C 21 90 FB F1 F0 41 42 10 20 20 70 A1 80 01 20 85 F8 89 00 07 B0 30 BD 30 B5 8B B0 05 46 0C 46 0A A9 07 A8 DD F7 8E FB 68 46 DD F7 29 FB BD F8 28 00 00 21 C0 07 00 D0 80 21 11 20 20 70 21 71 01 20 85 F8 89 00 0B B0 30 BD 30 B5 0C 46
9:00:49 AM
9:00:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 68 09 81 80 8D B0 01 21 80 F8 89 10 15 46 68 46 DD F7 11 FB 80 4A FF 23 01 A9 07 A8 FC F7 AD FF 00 28 09 D0 0C 20 AD F8 28 00 07 A8 0B 90 2A 46 0A A9 20 46 FD F7 EA F8 0D B0 30 BD 30 B5 0C 46 8D B0 01 21 80 F8 89 10 15 46 68 46 DD F7 F3 FA 71 4A FF 23 0D F1 0E 01 07 A8 FC F7 8E FF 00 28 EA D0 0C 20 AD F8 28 00 07 A8 0B 90 2A 46 0A A9 20 46 FD F7 CB F8 DF E7 30 B5 87 B0 05 46 0C 46 68 46 DD F7
9:00:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 69 09 81 80 D8 FA 06 98 3C 21 90 FB F1 F1 0F 20 20 70 21 71 01 20 85 F8 89 00 96 E7 30 B5 87 B0 05 46 0C 46 68 46 DD F7 C6 FA 06 98 00 B1 01 20 03 21 21 70 20 71 01 20 85 F8 89 00 85 E7 01 22 16 23 0B 70 0A 71 80 F8 89 20 10 46 70 47 90 F8 B8 10 14 29 01 D0 00 20 70 47 01 22 00 F1 BC 01 80 F8 89 20 08 46 21 E7 10 B5 04 46 88 B0 01 20 84 F8 89 00 68 46 DD F7 9E FA 94 F8 B8 00 03 28 02 D0 00 20
9:00:50 AM
9:00:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 6A 09 81 80 08 B0 10 BD B4 F9 BC 00 C0 EB 00 10 80 00 40 42 00 90 68 46 DD F7 97 FA 68 46 FF F7 1D FF 01 20 EE E7 10 B5 04 46 88 B0 01 20 84 F8 89 00 68 46 DD F7 7F FA 94 F8 B8 00 14 28 01 D0 00 20 DF E7 04 F1 BC 00 01 A9 FC F7 9C FF 00 28 D8 D0 68 46 DD F7 79 FA 68 46 FF F7 FF FE 01 20 D0 E7 10 B5 04 46 88 B0 01 20 84 F8 89 00 68 46 DD F7 61 FA 94 F8 B8 00 14 28 01 D0 00 20 C1 E7 04 F1 BC 00
9:00:51 AM
9:00:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 6B 09 81 80 0D F1 0E 01 FC F7 7D FF 00 28 B9 D0 68 46 DD F7 5A FA 68 46 FF F7 E0 FE 01 20 B1 E7 10 B5 04 46 88 B0 01 20 84 F8 89 00 68 46 DD F7 42 FA 94 F8 B8 00 02 28 01 D0 00 20 A2 E7 94 F9 BC 00 C0 EB 00 10 80 00 06 90 68 46 DD F7 3D FA 68 46 FF F7 C3 FE 01 20 94 E7 10 B5 04 46 88 B0 01 20 84 F8 89 00 68 46 DD F7 25 FA 94 F8 B8 00 0A 28 01 D0 00 20 85 E7 94 F8 BC 00 01 28 09 D0 00 20 06 90
9:00:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 6C 09 81 80 68 46 DD F7 20 FA 68 46 FF F7 A6 FE 01 20 77 E7 06 98 F4 E7 00 80 FF FF 00 F1 88 00 81 70 4F F0 00 01 C1 70 41 60 C1 60 70 47 50 F8 94 2F 11 44 01 60 42 68 A0 F1 94 00 91 42 08 D3 00 F1 88 00 00 21 C1 70 C1 60 41 68 01 F1 01 01 41 60 4F F0 01 00 70 47 2D E9 FC 41 01 27 DD F8 20 E0 04 46 00 26 80 F8 89 70 80 20 6A B1 55 1E 95 FB F0 F5 6D 1C AD B2 94 F8 8A C0 BC F1 00 0F 05 D0 BC F1
9:00:52 AM
9:00:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 6D 09 81 80 01 0F 35 D1 0F E0 00 25 F4 E7 C4 F8 90 50 1F 70 9D 80 00 20 98 60 1D B1 04 F1 89 04 67 70 20 70 4F F0 01 06 24 E0 D4 E9 23 56 B5 42 02 D3 00 20 BD E8 FC 81 ED 05 2D 0C 52 1B 80 2A 00 DA 10 46 AD F8 00 00 48 19 01 90 72 46 69 46 18 46 FC F7 9B FF 06 46 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 01 D3 01 20 00 E0 00 20 84 F8 89 00 30 46 DD E7 FE B5 06 46 0D 46 14 46 01 A8 DA F7
9:00:53 AM
9:00:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 6E 09 81 80 56 FF 08 B1 00 20 FE BD 01 98 00 94 82 B2 2B 46 30 46 02 99 FF F7 9E FF FE BD 2D E9 F0 4F F5 B0 83 46 0D 46 14 46 68 46 38 F0 79 FA 00 28 15 D0 BD F8 00 10 4F F0 00 06 01 EB 41 00 00 EB C1 00 80 B2 88 46 5F EA 00 09 0B D0 01 46 20 46 DD F7 A8 FB 04 00 01 D0 00 27 39 E0 00 20 75 B0 BD E8 F0 8F 09 20 28 70 00 20 A8 80 A8 60 3A E0 68 46 00 EB 87 00 73 90 B0 F8 02 A0 AA F5 7F 41 FF 39
9:00:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 6F 09 81 80 32 D0 2A F0 78 00 07 F0 0B FC 68 B3 01 7A A1 55 76 1C B1 B2 62 18 D0 F8 02 30 13 60 C0 88 90 80 89 1D 88 B2 01 21 21 54 40 1C 80 B2 CA F3 C3 01 21 54 73 99 40 1C 80 B2 09 79 21 54 73 99 40 1C 80 B2 49 79 21 54 40 1C 7F 1C 86 B2 BF B2 47 45 CD D3 4E 45 03 D8 09 20 28 70 AE 80 AC 60 01 20 8B F8 89 00 01 20 B9 E7 01 21 8B F8 89 10 B4 E7 30 B5 13 88 CC 5C 5B 1C 84 71 9B B2 CC 18 9B 1D
9:00:54 AM
9:00:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 70 09 81 80 25 68 05 60 A4 88 9B B2 84 80 CC 5C 5B 1C 9B B2 C4 71 CC 5C 5B 1C 9B B2 84 72 CC 5C 5B 1C 9B B2 04 72 C9 5C 41 72 5B 1C 13 80 C0 79 01 28 00 D0 00 20 30 BD 2D E9 F0 41 90 F8 B8 10 F8 B0 16 29 02 D0 19 29 05 D0 4D E0 B0 F8 BC 40 00 F1 BE 06 02 E0 30 F8 BC 4F 46 68 4F F4 E6 71 68 46 D5 F7 3C FD 0B 20 B4 FB F0 F5 00 FB 15 40 D0 BB 00 20 AD F8 D8 01 04 46 6F 46 3B E0 76 AA 31 46 73 A8
9:00:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 71 09 81 80 FF F7 B6 FF 00 28 2E D0 9D F8 D2 11 73 A8 07 F0 13 FB 5F EA 00 08 25 D0 9D F8 D2 11 98 F8 08 00 81 42 1F D1 FF F7 2C FD E0 B1 40 68 9D F9 D6 11 00 78 81 42 16 DC B8 F8 00 00 40 EA C1 01 07 EB 84 00 41 80 9D F8 D4 11 01 71 9D F8 D5 11 01 F0 0F 02 07 2A 01 D9 0F 2A 04 D1 0A 09 07 2A 05 D9 0F 2A 03 D0 00 20 78 B0 BD E8 F0 81 64 1C 41 71 A4 B2 AC 42 C1 D3 AD F8 00 50 68 46 38 F0 C5 F9
9:00:55 AM
9:00:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 72 09 81 80 00 28 F0 D0 01 20 EE E7 08 B5 0B 46 00 92 4F F4 86 72 FD 49 FF F7 9E FE 08 BD 08 B5 0B 46 00 92 4F F4 01 72 F9 49 FF F7 95 FE 08 BD 2D E9 F0 43 95 B0 01 26 80 F8 89 60 04 46 90 F8 32 80 0D 46 91 46 00 27 03 A8 DC F7 84 FB 9D F8 0D 10 40 46 41 45 67 D9 0D A9 DC F7 AE FB 20 20 94 F8 8A 20 C1 01 4F F0 00 0C 12 B1 01 2A 79 D1 1C E0 0F 9A 52 1E B2 FB F0 F0 B2 FB F1 F1 40 1C 49 1C 89 B2
9:00:56 AM
9:00:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 73 09 81 80 80 B2 01 29 00 D9 80 20 44 F8 90 1F 01 21 A0 60 2E 70 54 F8 90 09 A8 80 20 46 C5 F8 08 C0 FF F7 3B FE 84 F8 89 C0 5A E0 D4 E9 23 23 9A 42 39 D2 57 1C 9F 42 0F D1 0F 9B 5B 1E B3 FB F0 F7 B3 FB F1 F1 7F 1C 49 1C 89 B2 BF B2 C1 F1 01 01 07 EB C1 11 C4 F8 98 10 94 F8 8B 10 11 B1 01 29 21 D1 0A E0 2E 70 D4 F8 98 00 A8 80 C5 F8 08 C0 84 F8 8B 60 C4 F8 94 C0 28 E0 D4 E9 25 13 99 42 11 D2
9:00:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 74 09 81 80 12 03 01 FB 00 21 0F 9A 89 B2 8A 42 0A D9 52 1A 20 2A 00 D8 10 46 86 B2 33 46 05 AA 40 46 DC F7 F2 FB 18 B1 00 20 15 B0 BD E8 F0 83 05 A8 11 90 AD F8 40 60 4A 46 10 A9 28 46 FC F7 E5 FD 01 21 20 46 FF F7 F2 FD 00 28 ED D0 D4 E9 23 01 88 42 02 D3 01 20 01 E0 03 E0 00 20 84 F8 89 00 01 27 38 46 E0 E7 2D E9 F0 47 05 46 86 B0 0F 46 14 46 95 F8 32 10 A6 4A 00 20 8D F8 10 10 4F F0 01 0A
9:00:57 AM
9:00:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 75 09 81 80 B9 B1 01 29 20 D1 10 88 C0 F3 0E 09 B9 F1 00 0F 1D D0 A6 88 E0 88 21 68 A0 EB 06 03 06 F1 01 00 01 44 B9 F1 FF 0F 01 AA 48 46 25 D2 DE F7 99 FE 24 E0 12 20 38 70 10 88 B8 80 55 F8 8C 0F 40 1C 28 60 05 F8 03 AC 01 20 06 B0 BD E8 F0 87 00 20 8D F8 10 00 04 A8 03 90 56 46 AD F8 08 A0 22 46 02 A9 38 46 FC F7 90 FD 05 F1 88 05 69 68 01 F1 01 01 69 60 6E 70 E7 E7 38 F0 58 F8 00 28 E3 D0
9:00:58 AM
9:00:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 76 09 81 80 01 98 FF 28 01 D9 00 20 DE E7 21 68 05 AB 88 55 01 98 E1 88 30 44 40 1C 1F FA 80 F8 A1 EB 08 00 00 90 21 68 B9 F1 FF 0F 01 EB 08 02 4F F0 00 01 48 46 02 D2 DE F7 CB FE 01 E0 38 F0 45 F8 00 28 C2 D0 05 99 08 EB 01 02 A2 80 09 22 3A 70 01 9A 11 44 49 1C B9 80 21 68 31 44 B9 60 55 F8 8C 1F 49 1C 29 60 05 F8 03 AC AE E7 01 46 01 22 81 F8 89 20 91 F8 B8 20 00 20 06 2A 0E D1 B1 F8 BC 00
9:00:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 77 09 81 80 63 49 08 80 01 04 07 D5 C0 F3 0E 00 FF 28 01 D2 DE F7 37 BF 38 F0 26 B8 01 20 70 47 2D E9 F7 4F 8C B0 4F F0 01 09 04 46 80 F8 89 90 58 4D 00 27 90 F8 32 00 0E 46 AD 1C 10 B1 01 28 15 D0 7C E0 FF 20 68 70 A8 71 E8 72 0C 20 AD F8 20 00 09 95 08 A9 30 46 0E 9A FC F7 17 FD 07 46 54 F8 8C 0F 40 1C 20 60 04 F8 03 9C 67 E0 0A A8 D9 F7 70 FC 95 F8 00 A0 0A 99 8A 45 02 D3 00 20 0F B0 AE E5
9:00:59 AM
9:00:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 78 09 81 80 A9 7A EA 79 68 7A 01 EB 02 61 2A 7A 4F F0 20 08 12 04 02 EB 00 20 AB 46 08 44 B0 FB F8 F5 0D B1 20 28 00 D2 01 25 20 21 68 46 D5 F7 56 FB 94 F8 8A 00 10 B1 01 28 40 D1 0C E0 04 F1 88 04 4F F0 00 01 A5 60 86 F8 00 90 B5 80 B1 60 84 F8 02 90 61 70 31 E0 D4 E9 23 10 81 42 2E D2 9B F8 05 20 9B F8 02 30 9B F8 04 00 02 EB 03 62 9B F8 03 30 1B 04 03 EB 00 20 02 44 01 FB 08 21 43 46 6A 46
9:00:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 79 09 81 80 50 46 D9 F7 8D FC C0 B9 20 20 AD F8 20 00 CD F8 24 D0 08 A9 30 46 0E 9A FC F7 B6 FC 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 01 D3 01 20 00 E0 00 20 84 F8 89 00 01 27 38 46 9E E7 38 B5 04 46 01 20 84 F8 89 00 B4 F8 BC 00 0C 28 21 D1 94 F8 B8 00 16 28 1D D1 68 46 D9 F7 F9 FB 94 F8 BE 00 00 99 88 42 15 D2 09 48 D4 F8 BE 10 C0 F8 02 10 D4 F8 C2 10 C0 F8 06 10 D4 F8 C6 10 C0 F8
9:01:00 AM
9:01:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 7A 09 81 80 0A 10 01 20 38 BD 00 00 BC 0C 00 10 C8 0D 00 10 A4 48 00 10 00 20 F5 E7 7F B5 0D 46 01 21 80 F8 89 10 18 21 10 46 DD F7 BC F8 04 00 0B D0 02 20 28 70 A8 80 6A 46 01 21 00 20 AC 60 2C F0 F9 FB 00 25 18 B1 03 E0 00 20 04 B0 70 BD 03 95 06 26 26 70 03 98 01 21 60 60 6A 46 08 46 2C F0 E9 FB 00 B9 03 95 26 73 03 98 20 61 01 20 EC E7 30 B4 01 23 80 F8 89 30 83 8D 41 F2 03 45 5C 1B AB 42
9:01:01 AM
9:01:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 7B 09 81 80 35 D0 1B DC 41 F2 86 35 A3 EB 05 04 AB 42 2E D0 0D DC B3 F5 10 6F 2C D0 A3 F5 10 63 01 3B 28 D0 A3 F5 10 63 7F 3B 2A D0 01 2B 1D D1 29 E0 7A 2C 1D D0 7B 2C 1B D0 7C 2C 16 D1 18 E0 04 2C 1A D0 06 DC 01 2C 13 D0 02 2C 11 D0 03 2C 0C D1 12 E0 A4 F5 80 64 04 3C 0A D0 A4 F5 70 64 FB 3C 0C D0 A4 F5 3C 44 FE 3C 0E D0 30 BC 07 F0 41 BB 30 BC 9C E5 30 BC 36 E6 30 BC D0 E6 30 BC 7A E4 30 BC
9:01:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 7C 09 81 80 82 E5 30 BC 89 E5 30 BC 87 E4 10 B5 01 21 80 F8 89 10 81 8D B1 F5 10 6F 0A D0 A1 F5 A0 51 06 39 09 D0 A1 F5 50 41 FA 39 08 D0 07 F0 6A FB 07 E0 FF F7 9B FE 04 E0 FF F7 42 FF 01 E0 FF F7 FA FC 00 28 00 D0 01 20 10 BD 2D E9 F0 41 07 46 90 F8 88 80 86 B0 0C 46 00 26 80 8D 18 F0 7D FE 05 46 01 28 0D D0 01 20 87 F8 89 00 40 46 6F 46 4F F0 16 08 05 28 1C D2 DF E8 00 F0 1B 1B 07 11 1D 00
9:01:02 AM
9:01:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 7D 09 81 80 00 20 06 B0 BD E8 F0 81 38 46 18 F0 0B FF 03 20 20 70 05 EB 85 00 07 EB 80 00 12 E0 38 46 18 F0 E3 FE 07 EB 85 00 84 F8 00 80 C0 78 20 71 01 26 30 46 E6 E7 38 46 18 F0 D7 FE 84 F8 00 80 07 EB 85 00 40 78 F2 E7 70 B5 04 46 90 F8 88 60 86 B0 80 8D 18 F0 41 FE 05 46 68 46 18 F0 C5 FE 00 28 22 D0 68 46 03 2E 02 D0 04 2E 1F D1 0B E0 94 F8 B8 10 09 29 1A D1 94 F8 BC 10 03 29 16 D2 00 EB
9:01:03 AM
9:01:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 7E 09 81 80 85 00 C1 70 0A E0 94 F8 B8 10 09 29 0E D1 94 F8 BC 10 07 29 0A D2 00 EB 85 00 41 70 68 46 18 F0 AB FE 00 28 00 D0 01 20 06 B0 70 BD 00 20 FB E7 70 B5 04 46 86 B0 00 25 80 8D 18 F0 0D FE 06 00 26 D1 20 78 04 28 08 D0 5F F0 01 00 94 F8 88 10 01 29 0D D0 02 29 17 D1 10 E0 68 46 18 F0 84 FE 9D F8 03 00 10 B9 B4 F8 84 00 80 B1 03 20 ED E7 B4 F8 84 20 31 46 18 F0 D0 FE 04 E0 B4 F8 84 20
9:01:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 7F 09 81 80 31 46 18 F0 C6 FF 05 46 20 78 04 28 00 D1 01 25 28 46 C9 E7 10 B5 01 23 80 F8 89 30 07 F0 68 FA 00 28 00 D0 01 20 10 BD 10 B5 01 23 80 F8 89 30 90 F8 33 30 07 F0 5C FA 00 28 00 D0 01 20 10 BD 38 B5 01 25 04 46 80 F8 89 50 90 F8 B8 00 02 28 0D D1 94 F9 BC 00 00 04 00 0C 08 D1 68 46 DC F7 FE FD A0 8D 20 F0 78 00 B0 F5 9C 4F 00 D0 00 25 28 46 38 BD 10 B5 01 23 80 F8 89 30 90 F8 33 30
9:01:04 AM
9:01:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 80 09 81 80 FF 2B 11 D0 1F 2B 0D D0 23 2B 0B D0 27 2B 09 D0 2B 2B 07 D0 2C 2B 05 D0 2D 2B 03 D0 BD E8 10 40 07 F0 26 BA 00 20 10 BD 07 F0 22 FA 00 28 FA D0 01 20 10 BD 7C B5 04 46 90 F8 34 00 0D 46 04 28 A0 8D 16 46 04 D0 69 46 23 F0 F1 FD 28 B1 0A E0 01 AA 69 46 28 F0 6B F8 05 E0 00 20 8D F8 00 00 FF 20 8D F8 01 00 01 20 84 F8 89 00 32 46 69 46 28 46 FC F7 16 FD 7C BD 01 21 80 F8 89 10 07 F0
9:01:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 81 09 81 80 40 BA 01 21 80 F8 89 10 07 F0 3B BA 16 28 20 D0 0B DC 10 28 1B D2 DF E8 00 F0 1A 1C 1A 1A 1A 1C 1C 1A 1C 1A 1A 1A 1C 1C 1C 20 C3 28 1D D0 08 DC 18 28 0E D0 C0 28 18 D0 C1 28 16 D0 C2 28 06 D1 13 E0 C4 28 11 D0 C5 28 0F D0 C7 28 0D D0 00 20 70 47 01 29 07 D0 40 21 0C E0 01 29 01 D0 DA 20 70 47 D9 20 70 47 20 21 04 E0 01 29 01 D0 10 21 00 E0 08 21 08 44 C0 B2 70 47 10 B5 13 88 23 F0
9:01:05 AM
9:01:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 82 09 81 80 02 03 13 80 01 23 02 22 56 28 48 D0 26 DC 38 28 42 D0 12 DC 2C 28 3F D0 08 DC 21 28 3C D0 25 28 3A D0 26 28 38 D0 28 28 43 D1 35 E0 2D 28 33 D0 2E 28 31 D0 36 28 3C D1 2E E0 48 28 2F D0 06 DC 41 28 2C D0 45 28 2A D0 46 28 32 D1 27 E0 4C 28 25 D0 4D 28 23 D0 4E 28 2B D1 20 E0 CF 28 21 D0 10 DC CA 28 1E D0 06 DC 58 28 18 D0 C8 28 19 D0 C9 28 1E D1 16 E0 CB 28 14 D0 CC 28 12 D0 CD 28
9:01:06 AM
9:01:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 83 09 81 80 17 D1 0F E0 A0 F1 D0 03 08 2B 12 D2 DF E8 03 F0 0D 0D 0D 0D 0D 0D 11 0D 0B 70 20 38 07 E0 0A 70 40 38 04 E0 0B 70 08 38 01 E0 0A 70 10 38 C0 B2 10 BD 00 20 08 70 10 BD 2D E9 FF 4F AD F5 6D 7D 80 46 F0 98 FA 9C 17 46 00 28 70 D0 FB 99 04 F1 B8 04 08 EB 07 05 08 80 E2 8C 21 78 28 78 FF F7 55 FF 82 46 14 F8 B8 09 01 28 0D D0 B4 F8 7C 10 D4 F8 A8 60 04 F1 7E 00 00 22 EA 92 6A 46 D8 F7
9:01:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 84 09 81 80 FB FA 00 28 7D D1 10 E0 94 F8 B9 00 40 06 05 D4 04 F1 3A 00 21 8F D4 F8 A0 60 ED E7 04 F1 5C 00 B4 F8 5A 10 D4 F8 A4 60 E6 E7 D4 E9 01 01 CD E9 E6 01 4F EA 16 6B C6 F3 07 40 8D F8 A0 B3 DB 90 8D F8 A1 03 C6 F3 07 20 DC 90 8D F8 A2 03 F0 B2 DD 90 8D F8 A3 03 0C 20 EB 90 94 F8 B9 60 8D F8 44 63 E2 8A 20 2A 4C D8 2A B1 04 F1 18 01 0D F2 45 30 D4 F7 95 FF E0 8A 40 1C 80 B2 EC 90 16 F0
9:01:07 AM
9:01:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 85 09 81 80 30 01 3E D0 F0 98 7E 1F 00 F1 05 09 10 29 0F D0 20 29 37 D0 30 29 5F D0 DD F8 A8 63 4F F0 01 09 00 2F EE D0 08 EB 07 05 05 F8 01 6D 77 E0 B0 E0 6A 46 E6 A8 EB 99 D8 F7 C8 FA 6A 46 D1 A8 EC 99 D8 F7 41 FB 6A 46 28 46 F0 99 D8 F7 3C FB 52 E0 9D F8 44 13 05 F8 05 1D 1F FA 89 F0 85 F8 01 B0 DB 99 A9 70 DC 99 E9 70 DD 99 29 71 29 18 DE 9A 0A 60 DF 9A 4A 60 B7 B2 E0 9A 0C 30 8A 60 86 B2
9:01:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 86 09 81 80 1B E0 85 E0 6A 46 E6 A8 EB 99 D8 F7 9E FA 6A 46 28 46 F0 99 D8 F7 1F FC 05 2F 79 D3 9D F8 44 03 05 F8 05 0D B7 B2 85 F8 01 B0 DB 98 A8 70 DC 98 E8 70 DD 98 1F FA 89 F6 28 71 80 2E AE D3 FF 2E 21 D8 4F F0 02 09 02 2F 62 D3 08 EB 07 05 81 20 05 F8 02 0D 6E 70 22 E0 6A 46 E6 A8 EB 99 D8 F7 74 FA 6A 46 D1 A8 EC 99 D8 F7 ED FA 6A 46 28 46 F0 99 D8 F7 42 FD 6A 46 0C 21 DE A8 D8 F7 B4 FC
9:01:08 AM
9:01:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 87 09 81 80 05 2F 45 D3 A4 E7 4F F0 03 09 03 2F 40 D3 08 EB 07 05 82 20 05 F8 03 0D 30 0A 68 70 AE 70 A7 EB 09 00 87 B2 4F F0 00 08 BA F1 D9 0F 02 D0 BA F1 DA 0F 1E D1 60 88 98 B1 80 1C 1F FA 80 F8 47 45 26 D3 A5 EB 08 05 01 20 28 70 60 88 68 70 62 88 21 1D A8 1C D4 F7 E4 FE A7 EB 08 00 87 B2 08 E0 4F F0 01 08 01 2F 13 D3 00 20 7F 1E 05 F8 01 0D BF B2 6F B1 09 F1 01 01 72 18 05 F8 01 AC 02 EB
9:01:09 AM
9:01:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 88 09 81 80 08 01 FB 9A 89 B2 68 1E 11 80 EE 9A 91 42 00 D9 00 20 0D F5 71 7D BD E8 F0 8F 2D E9 FF 4F AD F5 6D 7D 07 46 DD E9 FA 4A 94 46 1E 00 19 D0 07 EB 0C 05 AA F8 00 60 28 78 04 F1 DE 02 04 F1 BA 01 FF F7 5B FE 5F EA 00 09 0B D0 69 78 08 06 01 D4 02 20 10 E0 07 EB 0C 00 40 1C 81 29 02 D0 82 29 03 D0 99 E0 A9 78 03 20 05 E0 E9 78 40 78 01 EB 00 20 81 B2 04 20 86 42 74 D3 32 1A 8A 42 71 DB
9:01:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 89 09 81 80 2E 18 95 B2 05 2D 6D D3 30 78 84 F8 BB 00 94 F8 BA 10 01 29 09 D0 B4 F8 7C 10 04 F1 7E 00 6A 46 D8 F7 AA F9 00 28 77 D1 0A E0 40 06 03 D4 04 F1 3A 00 21 8F F3 E7 04 F1 5C 00 B4 F8 5A 10 EE E7 D4 F8 0E 00 DE 90 D4 F8 12 00 DF 90 D6 F8 01 00 E0 90 9D F8 80 03 4F F0 0C 0B 60 F3 1F 68 9D F8 81 03 60 F3 17 48 9D F8 82 03 60 F3 0F 28 9D F8 83 03 60 F3 07 08 30 78 8D F8 50 03 E2 8A 20 2A
9:01:10 AM
9:01:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 8A 09 81 80 4A D8 2A B1 04 F1 18 01 0D F2 51 30 D4 F7 48 FE E0 8A 40 1C 87 B2 94 F8 BB 00 10 F0 30 00 3C D0 10 28 04 D0 20 28 21 D0 30 28 2C D1 36 E0 11 2D 32 D3 6A 46 59 46 DE A8 D8 F7 87 F9 6A 46 39 46 D4 A8 D8 F7 00 FA A5 F1 11 01 6A 46 0F 46 70 1D D8 F7 F9 F9 6A 46 0C 21 E2 A8 D8 F7 C5 FB 40 1C 1B D0 35 E0 18 E0 76 1D BD B2 0C E0 6A 46 59 46 DE A8 D8 F7 6A F9 6A 46 69 1F 70 1D D8 F7 4A FC
9:01:11 AM
9:01:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 8B 09 81 80 76 1D 6D 1F AD B2 3D B1 EE 98 85 42 04 D2 AA F8 00 50 31 78 49 45 24 D0 00 20 3A E7 11 2D FB D3 6A 46 59 46 DE A8 D8 F7 50 F9 6A 46 39 46 D4 A8 D8 F7 C9 F9 A5 F1 11 01 6A 46 0F 46 70 1D D8 F7 29 FC 6A 46 0C 21 E2 A8 D8 F7 8E FB 00 28 E3 D1 71 19 0C 39 0C 22 E2 A8 D4 F7 B6 FD 00 28 DB D1 C1 E7 94 F8 BA 00 01 28 08 D0 D4 F8 B4 00 80 45 B4 F8 DE 00 26 D8 40 F0 01 00 25 E0 94 F8 BB 00
9:01:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 8C 09 81 80 40 06 0F D4 D4 F8 AC 00 80 45 B4 F8 DE 00 02 D8 40 F0 01 00 01 E0 20 F0 01 00 A4 F8 DE 00 C4 F8 AC 80 15 E0 D4 F8 B0 00 80 45 B4 F8 DE 00 02 D8 40 F0 01 00 01 E0 20 F0 01 00 A4 F8 DE 00 C4 F8 B0 80 05 E0 20 F0 01 00 A4 F8 DE 00 C4 F8 B4 80 30 46 DE E6 FE B5 04 46 40 68 DC F7 4C FC 06 46 60 68 DC F7 5B FC 03 46 05 46 02 A9 20 69 CD E9 00 01 00 22 19 46 30 46 FF F7 CF FE 00 28 0B D0
9:01:12 AM
9:01:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 8D 09 81 80 61 68 80 1B 8A 88 10 44 82 B2 8A 80 BD F8 08 00 08 B1 A8 42 01 D3 00 20 FE BD 61 68 10 44 C8 80 01 20 FE BD 2D E9 FF 4F AD F5 67 7D 5F EA 00 0B F4 9C 15 46 26 D0 E8 98 20 B3 11 2B 22 D3 04 F1 3A 00 21 8F 6A 46 D4 F8 A0 60 D8 F7 95 F8 C8 B9 D4 E9 01 01 37 0E C6 F3 07 48 8D F8 74 73 C6 F3 07 29 CD E9 DB 01 8D F8 75 83 8D F8 76 93 F6 B2 10 20 8D F8 77 63 8D F8 44 03 E2 8A 4F F0 0C 0A
9:01:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 8E 09 81 80 20 2A 03 D9 00 20 0D F5 6B 7D 84 E6 2A B1 04 F1 18 01 0D F2 45 30 D4 F7 43 FD E0 8A 6A 46 40 1C 84 B2 51 46 DB A8 D8 F7 90 F8 6A 46 21 46 D1 A8 D8 F7 09 F9 6A 46 58 46 E8 99 D8 F7 04 F9 6A 46 20 21 DF A8 D8 F7 D0 FA 9D F8 44 03 28 70 6F 70 85 F8 02 80 85 F8 03 90 2E 71 DF 98 C5 F8 05 00 E0 98 C5 F8 09 00 E1 98 C5 F8 0D 00 F5 98 11 21 01 80 01 20 C7 E7 2D E9 F0 41 AD F5 68 7D 06 00
9:01:13 AM
9:01:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 8F 09 81 80 EE 9D 88 46 14 46 4C D0 B8 F1 00 0F 49 D0 11 2B 47 D3 05 F1 3A 00 29 8F 6A 46 D8 F7 2D F8 E0 BB 20 78 8D F8 44 03 10 28 3B D1 61 78 A2 78 E0 78 23 79 D5 F8 0E 70 E3 97 D5 F8 12 70 8D F8 94 13 8D F8 95 23 8D F8 96 03 E4 97 8D F8 97 33 EA 8A 0C 27 20 2A 25 D8 2A B1 05 F1 18 01 0D F2 45 30 D4 F7 DE FC E8 8A 6A 46 40 1C 85 B2 39 46 E3 A8 D8 F7 2B F8 6A 46 29 46 D1 A8 D8 F7 A4 F8 6A 46
9:01:14 AM
9:01:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 90 09 81 80 41 46 30 46 D8 F7 9F F8 6A 46 0C 21 DB A8 D8 F7 6B FA 0C 22 61 1D DB A8 00 E0 02 E0 D4 F7 94 FC 20 B1 00 20 0D F5 68 7D BD E8 F0 81 01 20 F9 E7 00 F1 88 00 81 70 4F F0 00 01 C1 70 41 60 C1 60 70 47 50 F8 94 2F 11 44 01 60 42 68 A0 F1 94 00 91 42 08 D3 00 F1 88 00 00 21 C1 70 C1 60 41 68 01 F1 01 01 41 60 4F F0 01 00 70 47 2D E9 FC 47 4F F0 01 08 04 46 80 F8 89 80 00 26 90 F8 2F 00
9:01:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 91 09 81 80 0F 46 91 46 35 46 08 B1 40 1E C5 B2 94 F8 32 10 28 46 27 F0 5B FC 94 F8 8A 10 11 B1 01 29 73 D1 0F E0 04 F1 88 04 A0 60 87 F8 00 80 A0 68 B8 80 4F F0 00 00 B8 60 84 F8 02 80 60 60 E0 60 60 70 7D E0 D4 E9 23 01 88 42 73 D2 18 21 48 46 DC F7 E8 FA 06 00 6D D0 02 20 38 70 B8 80 BE 60 94 F8 32 30 F8 4A F8 48 F9 49 8B B1 01 2B 0F D0 02 2B 5F D1 4A E0 00 EB 40 01 38 F8 21 00 06 F0 50 FB
9:01:15 AM
9:01:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 92 09 81 80 D4 F8 94 10 49 1C C4 F8 94 10 58 B1 20 E0 90 46 05 EB 85 02 01 EB C2 07 05 EB 45 01 C1 EB 45 11 00 EB 41 05 D4 F8 94 10 28 89 FA 8C 08 44 29 8C 11 44 88 42 DE D3 3C E0 00 EB 40 01 38 F8 21 00 06 F0 2E FB D4 F8 94 10 49 1C C4 F8 94 10 38 B3 12 21 31 70 01 7A B1 80 06 21 80 1C AD F8 00 10 01 90 4A 46 69 46 06 F1 0C 00 FB F7 4D FE 00 28 20 D0 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04
9:01:16 AM
9:01:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 93 09 81 80 88 42 19 D3 01 20 18 E0 1A E0 90 46 05 EB 85 02 01 EB C2 07 05 EB 45 01 C1 EB 45 11 00 EB 41 05 F8 89 D4 F8 94 10 FA 8C 08 44 29 8C 11 44 88 42 C2 D3 00 20 BD E8 FC 87 00 20 84 F8 89 00 01 26 30 46 F7 E7 2D E9 F7 4F AD F5 4C 7D 4F F0 01 09 04 46 80 F8 89 90 0D 46 00 26 68 46 23 F0 AC F9 00 28 72 D0 94 F8 2F 00 00 21 08 B1 40 1E C1 B2 94 F8 32 00 00 B1 40 1E 00 EB 41 00 C7 B2 94 F8
9:01:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 94 09 81 80 8A 00 DF F8 CC A2 EB 46 4F F0 00 08 10 B1 01 28 7E D1 19 E0 0A EB C7 00 04 F1 88 04 81 88 01 EB 0B 00 01 78 A1 60 85 F8 00 90 00 78 A8 80 C5 F8 08 80 84 F8 02 90 84 F8 03 80 C4 F8 04 80 C4 F8 0C 80 84 F8 01 80 78 E0 D4 E9 23 10 81 42 6C D2 94 F8 8B 00 10 B1 01 28 67 D1 3D E0 18 21 CE 98 DC F7 1F FA 06 00 60 D0 02 20 28 70 A8 80 0A EB C7 00 AE 60 81 88 01 EB 0B 00 D4 F8 8C 10 01 EB
9:01:17 AM
9:01:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 95 09 81 80 C1 02 02 EB 01 11 08 44 41 78 AD F8 24 13 80 1C CA 90 C9 A9 30 46 CE 9A FB F7 B6 FD 00 28 45 D0 3A 46 68 46 D4 F8 8C 10 23 F0 64 F9 C4 F8 98 00 86 F8 0C 90 30 82 49 46 42 46 C6 F8 14 80 28 B1 84 F8 8B 10 C4 F8 94 20 29 E0 2F E0 D4 F8 8C 00 40 1C C4 F8 8C 00 22 E0 D4 E9 25 20 82 42 24 D2 52 1C 3B 46 58 46 23 F0 6D F9 11 21 29 70 28 71 54 F8 94 0F 40 1C 20 60 61 68 A4 F1 94 04 88 42
9:01:18 AM
9:01:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 96 09 81 80 0D D3 04 F1 88 04 84 F8 03 80 C4 F8 0C 80 00 E0 14 E0 60 68 00 F1 01 00 60 60 A4 F1 88 04 D4 E9 23 01 88 42 06 D3 01 20 05 E0 00 20 0D F5 4F 7D BD E8 F0 8F 00 20 84 F8 89 00 01 26 30 46 F5 E7 70 B5 04 46 AD F5 4C 7D 01 20 84 F8 89 00 0D 46 16 46 68 46 23 F0 F0 F8 00 28 1A D0 94 F8 2F 00 00 21 08 B1 40 1E C1 B2 94 F8 32 00 00 B1 40 1E 00 EB 41 00 56 49 C0 B2 01 EB C0 00 6A 46 81 88
9:01:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 97 09 81 80 C0 88 08 44 11 44 1D F8 00 00 0A 78 82 42 03 D8 00 20 0D F5 4C 7D 70 BD 00 EB C0 02 02 EB 00 10 08 44 32 46 41 78 80 1C AD F8 24 13 CA 90 C9 A9 28 46 FB F7 29 FD EC E7 2D E9 F0 4F AD F5 4B 7D 04 46 68 46 23 F0 B8 F8 00 28 79 D0 94 F8 2F 00 4F F0 00 09 10 B1 40 1E 00 F0 FF 09 94 F8 32 00 00 B1 40 1E 00 EB 49 00 C7 B2 94 F8 88 10 00 25 04 F1 BE 00 36 4E EA 46 C9 90 03 29 02 D0 04 29
9:01:19 AM
9:01:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 98 09 81 80 68 D1 97 E0 94 F8 B8 00 04 F1 66 01 8B 46 16 28 2F D0 02 28 5E D0 58 46 FC F7 C0 FC A0 F5 7F 41 80 46 FF 39 56 D0 94 F8 32 10 48 46 27 F0 8E FA 80 28 00 D3 80 20 80 45 4C D8 06 EB C7 06 B4 F8 6E 00 B1 78 88 42 00 D3 08 46 80 46 B4 F8 7C 70 58 46 FC F7 8C FC A0 F5 7F 41 C4 F8 8C 00 FF 39 38 D0 B2 88 02 EB 0A 06 58 B3 B4 F8 72 00 40 B3 3D E0 08 46 FC F7 92 FC A0 F5 7F 41 FF 39 29 D0
9:01:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 99 09 81 80 B4 F8 BC 10 08 29 25 D8 06 EB C7 00 B4 F8 7C 50 82 78 AA 42 1E D9 82 88 05 EB C5 00 02 EB 0A 06 00 EB 05 10 30 44 41 70 B4 F8 BC 20 80 1C C9 99 D4 F7 76 FA 30 78 A8 42 65 D8 6D 1C 35 70 62 E0 67 E0 08 E0 B0 4E 07 00 20 5D 07 00 5A 5D 07 00 F2 4D 07 00 60 E0 07 EB C7 00 00 EB 07 10 30 44 0A 30 10 21 D4 F7 20 FB B4 F8 72 00 D0 B1 94 F8 BC A0 94 F8 32 10 48 46 27 F0 28 FA 01 46 50 46
9:01:20 AM
9:01:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 9A 09 81 80 51 45 49 D3 02 46 94 F8 32 10 48 46 22 F0 BE FF 01 46 07 EB C7 00 00 EB 07 10 30 44 0A 30 22 F0 F8 FF 00 B1 01 25 A8 F1 01 00 87 42 2A DB 86 F8 00 80 28 E0 B4 F8 BC 00 08 28 2D D8 06 EB C7 08 00 26 B8 F8 04 10 01 EB 0A 07 18 E0 06 EB C6 01 01 EB 06 11 39 44 B4 F8 BC 00 4A 78 90 42 0C D1 89 1C C9 98 D4 F7 F0 F9 38 B9 B8 F8 04 10 B8 F8 06 00 01 25 01 44 01 F8 0A 60 76 1C F6 B2 38 78
9:01:21 AM
9:01:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 9B 09 81 80 B0 42 E3 D8 25 B1 68 46 22 F0 E5 FF 00 28 00 D0 01 20 0D F5 4B 7D CB E6 00 20 FA E7 81 70 00 23 C0 E9 01 32 C3 70 C0 E9 03 32 08 46 70 47 10 B5 00 22 70 B1 C3 68 00 21 5B 1C C3 60 04 69 A3 42 05 D3 C1 70 C1 60 41 68 49 1C 41 60 01 E0 41 70 01 22 10 46 10 BD 0E B5 05 28 01 D3 00 20 0E BD 00 EB 80 00 03 01 02 AA 50 20 CD E9 00 02 02 46 20 20 F5 F7 34 FC 0E BD 0E B5 05 28 01 D3 00 20
9:01:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 9C 09 81 80 0E BD 00 EB 80 00 03 01 02 AA 50 20 CD E9 00 02 02 46 20 20 F5 F7 63 FC 0E BD 2D E9 FC 41 05 46 0E 46 17 46 24 21 10 46 DC F7 3B F8 04 00 1C D0 02 20 30 70 03 20 B0 80 12 20 B4 60 20 70 28 88 A0 80 06 20 AD F8 00 00 A8 1C 01 90 3A 46 69 46 04 F1 0C 00 FB F7 D8 FB 00 28 04 D0 0F 20 20 76 28 7A 20 77 01 20 BD E8 FC 81 00 20 FB E7 2D E9 FC 41 06 46 0D 46 17 46 18 21 10 46 DC F7 11 F8
9:01:22 AM
9:01:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 9D 09 81 80 04 00 14 D0 02 20 28 70 A8 80 AC 60 06 20 AD F8 00 00 3A 46 69 46 20 46 01 96 FB F7 B5 FB 00 28 E1 D0 12 20 20 73 F0 88 20 82 01 20 DB E7 00 20 D9 E7 2D E9 F0 41 06 46 0D 46 17 46 18 21 10 46 DB F7 EF FF 04 00 14 D0 02 20 28 70 A8 80 3A 46 21 46 30 46 AC 60 FF F7 CA FF 00 28 09 D0 3A 46 04 F1 0C 01 06 F1 08 00 FF F7 C1 FF 00 28 00 D0 01 20 BD E8 F0 81 10 B5 00 B3 F9 B1 91 F8 3A 30
9:01:23 AM
9:01:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 9E 09 81 80 33 B9 91 F8 3B 20 01 2A 02 D1 B1 F8 42 20 22 B1 91 F8 8C 20 29 2A 11 D1 03 E0 00 21 80 F8 28 10 1B E0 B1 F8 42 20 D2 B2 02 2A 07 D8 01 EB 43 04 34 F8 4A 3F 64 88 DB B2 02 2C 01 D3 00 20 10 BD 80 F8 28 20 D1 F8 90 20 00 EB 03 10 3C B1 C0 F8 32 20 D1 F8 94 10 C0 F8 36 10 01 20 10 BD C0 F8 2A 20 D1 F8 94 10 C0 F8 2E 10 F6 E7 10 B5 18 B1 11 B1 0A 78 27 2A 01 D0 00 20 10 BD 0A 22 09 1D
9:01:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 9F 09 81 80 D4 F7 79 F9 01 20 10 BD 30 B5 D8 B1 D1 B1 B1 F8 42 20 D3 B2 02 2B 15 D8 91 F8 3A 40 91 F8 8C 50 01 EB 44 02 B2 F8 4E 20 D2 B2 55 B1 9A 42 09 D2 05 2D 0C D0 06 2D 0D D0 07 2D 13 D0 32 2D 01 D1 13 E0 0C B1 00 20 30 BD 00 21 01 74 16 E0 91 F8 90 10 01 E0 B1 F8 90 10 00 EB C2 02 00 24 C2 E9 06 14 0A E0 D1 F8 90 10 F6 E7 01 F1 90 01 00 EB C2 02 D1 E9 00 41 C2 E9 06 41 03 74 4F F0 01 00
9:01:24 AM
9:01:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A0 09 81 80 30 BD 01 46 6E 4A B1 F8 2C 10 00 20 00 EB 40 03 32 F8 23 30 99 42 04 D0 40 1C C0 B2 05 28 F5 D3 FF 20 70 47 2D E9 F0 4F 95 B0 0C 46 93 46 05 46 90 F8 88 80 00 26 FF F7 E4 FF 82 46 FF 28 34 D0 69 46 FF F7 C8 FE 00 28 30 D0 01 20 85 F8 89 00 6F 46 05 F1 88 09 4F F0 00 0C B8 F1 02 0F 06 D0 B8 F1 03 0F 4E D0 B8 F1 04 0F 74 D1 52 E0 95 F8 8A 10 11 B1 01 29 6E D1 0D E0 9D F8 10 60 51 E0
9:01:25 AM
9:01:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A1 09 81 80 02 26 51 E0 15 F8 89 0F 40 1C 28 70 40 E0 00 BF 85 F8 89 C0 3C E0 9D F8 10 00 D5 F8 94 50 02 28 00 D3 02 20 69 1C 88 42 03 D2 00 20 15 B0 BD E8 F0 8F 21 46 50 46 22 F0 CD FF 06 21 40 B1 20 78 06 28 06 D0 11 28 09 D0 12 28 0C D0 15 28 0F D0 21 70 07 EB C5 00 80 69 60 60 0F E0 07 EB C5 00 80 69 20 71 0A E0 07 EB C5 00 80 69 A0 80 05 E0 07 EB C5 01 D1 E9 06 01 C4 E9 01 01 48 46 FF F7
9:01:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A2 09 81 80 56 FE 05 E0 5A 46 21 46 38 46 FF F7 86 FE 00 B1 01 26 20 E0 95 F8 8A 10 11 B1 01 29 1B D1 0F E0 9D F8 28 60 02 2E AB D2 20 70 A6 80 32 46 01 21 48 46 C4 F8 08 C0 FF F7 31 FE 00 2E A8 D1 A1 E7 D5 F8 94 00 5A 46 07 EB 00 10 2A 30 21 46 FF F7 B0 FE 00 28 D2 D1 30 46 A8 E7 70 B5 94 B0 04 46 90 F8 88 60 FF F7 4D FF 05 46 FF 28 0D D0 69 46 FF F7 31 FE 00 28 09 D0 04 F1 2C 01 02 2E 07 D0
9:01:26 AM
9:01:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A3 09 81 80 03 2E 09 D0 04 2E 14 D1 15 E0 00 20 14 B0 70 BD 68 46 FF F7 F9 FE 04 E0 04 F1 B8 01 68 46 FF F7 E5 FE 00 28 F2 D0 69 46 28 46 FF F7 25 FE 00 28 EC D0 01 20 EA E7 68 46 FF F7 9D FE F1 E7 00 00 0C 4E 07 00 80 8D 1F F0 2D BF 00 F1 88 00 81 70 4F F0 00 01 C1 70 41 60 C1 60 70 47 18 B1 01 78 09 B1 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00 40 8A 70 47 20 B1 01 78 02 29 01 D3 06 29 02 D3
9:01:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A4 09 81 80 4F F6 FF 70 70 47 00 EB 41 00 80 88 70 47 2D E9 FF 5F 06 46 15 46 0F 46 08 46 21 F0 E8 FA 00 24 83 46 00 94 01 94 02 94 38 46 03 94 1F F0 89 FF 01 46 00 20 FE 4F 4F F0 06 0C 4F F6 FF 7A E9 46 15 E0 00 BF DB F8 00 20 0C EB 40 03 D3 5A 53 45 0F D0 09 EB D0 02 00 F0 07 08 64 1C 13 78 17 F8 08 80 40 1C 43 EA 08 03 A4 B2 13 70 80 B2 88 42 E8 D3 5C B1 10 21 28 46 D4 F7 56 F8 96 F8 40 00
9:01:27 AM
9:01:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A5 09 81 80 40 B1 01 28 0D D0 10 22 69 46 06 E0 00 20 04 B0 BD E8 F0 9F 10 22 06 F1 50 01 28 46 D3 F7 80 FF 18 E0 B6 F8 4C 00 00 28 F1 D0 40 1E B6 F8 4E 10 80 B2 01 B9 21 46 49 1E 89 B2 09 E0 05 EB D0 02 00 F0 07 06 13 78 BE 5D 33 43 40 1C 13 70 80 B2 88 42 F3 D9 01 21 00 20 2A 5C 02 B1 00 21 40 1C 80 B2 10 28 F8 D3 21 B1 10 22 69 46 28 46 D3 F7 57 FF 00 20 49 46 2A 5C 0B 5C 1A 40 2A 54 40 1C
9:01:28 AM
9:01:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A6 09 81 80 80 B2 10 28 F7 D3 20 46 C1 E7 17 B5 08 78 13 28 07 D1 48 68 00 28 05 D0 02 89 04 8A 13 1D A3 42 01 D3 00 20 1E BD C0 68 10 44 9D F8 03 20 02 70 9D F8 02 20 42 70 9D F8 01 20 82 70 9D F8 00 20 C2 70 48 68 01 89 09 1D 01 81 01 20 1E BD 70 B5 88 B0 0C 46 15 46 04 A9 DB F7 9C FB 00 28 43 D0 6A 46 01 A9 04 A8 DB F7 15 FC 00 28 3C D0 BD F8 04 10 64 22 B1 FB F2 F3 BD F8 00 00 02 FB 13 12
9:01:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A7 09 81 80 C0 F3 00 00 00 21 41 EA 40 56 9D F8 06 10 46 EA 42 20 01 F0 0F 01 40 EA 41 10 9D F8 07 10 2A 46 01 F0 1F 01 08 43 40 F0 00 40 21 46 FF F7 AD FF 00 28 19 D0 9D F8 09 00 9D F8 0A 10 00 F0 1F 00 46 EA 00 30 01 F0 3F 01 40 EA 81 10 9D F8 0B 10 2A 46 01 F0 3F 01 08 43 40 F0 40 40 21 46 FF F7 94 FF 00 28 00 D0 01 20 08 B0 70 BD 00 B5 FF F7 8C FF 00 28 00 D0 01 20 00 BD 2D E9 F0 47 AD F5
9:01:29 AM
9:01:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A8 09 81 80 91 6D 0D 46 90 46 99 46 82 46 20 F0 BA FB 04 00 7E D0 69 89 0D F2 2C 42 50 46 1D F0 81 FE 00 28 77 D0 29 88 62 8A A1 F1 18 00 B0 FB F2 F0 80 4F 10 F0 FF 00 0D F2 2C 46 0E D0 40 1E C0 B2 06 EB D0 03 00 F0 07 00 1B 7B 38 5C 03 42 60 D1 88 1A AD F8 50 04 68 89 29 E0 DD F8 30 04 CD F8 68 04 0D F5 8C 63 0D F5 8D 62 00 21 50 46 1F F0 5B FC 00 28 7F D0 0D F2 2C 42 BD F8 60 14 50 46 1D F0
9:01:30 AM
9:01:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 A9 09 81 80 4F FE 00 28 76 D0 9D F8 34 04 40 1E C0 B2 06 EB D0 01 00 F0 07 02 09 7B BA 5C 11 42 6E D1 61 8A 41 43 18 31 BD F8 60 04 AD F8 50 14 AD F8 5A 04 0D F5 8F 61 08 1D CD E9 00 01 0D F5 8A 63 40 F2 24 42 02 A9 50 46 21 F0 C0 F9 00 28 52 D0 02 9D 03 20 B0 EB 95 7F 51 D1 15 F0 E0 60 4E D0 B0 F1 80 7F 4B D0 62 8A BD F8 50 14 0D F2 54 43 0D F2 2C 40 1D F0 65 FE 00 28 3C D0 0D F2 6C 41 DD F8
9:01:31 AM
9:01:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 AA 09 81 80 54 04 DB F7 C7 FA 00 28 34 D0 0D F5 90 62 01 E0 34 E0 2F E0 0D F2 44 41 0D F2 6C 40 DB F7 3A FB 00 28 27 D0 25 F0 40 40 6F F3 0F 00 40 F0 00 41 BD F8 44 04 64 22 B0 FB F2 F3 02 FB 13 00 9D F8 46 24 40 02 02 F0 0F 02 40 EA 42 10 9D F8 47 24 02 F0 1F 02 10 43 08 43 4A 46 41 46 FF F7 D5 FE 00 28 07 D0 4A 46 41 46 28 46 FF F7 CE FE 00 28 00 D0 01 20 0D F5 91 6D BD E8 F0 87 00 20 F9 E7
9:01:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 AB 09 81 80 2D E9 FF 4F AD F2 3C 4D 80 46 0D F5 8E 60 0E 46 A0 C8 DD F8 48 04 21 F0 2A F9 CD F8 30 04 DD F8 48 04 1F F0 C7 FD 0D F5 87 61 CD F8 2C 04 08 1F CD E9 00 01 0D F1 08 09 2B 46 40 F2 24 42 49 46 DD F8 48 04 21 F0 41 F9 00 28 71 D0 68 89 C6 F8 9C 00 28 88 C6 F8 A0 00 DD F8 48 04 41 F6 10 11 00 24 00 EB 01 0A 4F F0 06 0B FB E0 DD F8 78 04 0F 4A 00 EB D4 00 04 F0 07 01 00 78 51 5C 08 42
9:01:32 AM
9:01:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 AC 09 81 80 7D D0 DD F8 2C 04 80 06 36 D5 13 21 88 F8 00 10 14 21 DD F8 44 04 DB F7 44 FC C8 F8 04 00 00 28 46 D0 00 21 01 80 D8 F8 04 00 14 22 41 60 01 E0 68 C1 01 00 D8 F8 04 00 02 82 D8 F8 04 00 01 81 11 46 DD F8 44 04 DB F7 2C FC D8 F8 04 10 C8 60 D6 F8 8C 00 80 B9 42 46 29 46 DD F8 44 34 DD F8 48 04 FF F7 CA FE 38 B9 68 68 41 46 DD F8 44 24 FF F7 6D FE 00 28 1B D0 DD F8 30 04 01 68 0B EB
9:01:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 AD 09 81 80 44 00 08 5A A0 F5 00 42 10 3A 26 D1 DD F8 2C 04 C0 06 0E D5 D6 F8 8C 00 78 B1 68 68 D6 F8 A4 20 09 68 80 1A 88 42 08 D1 00 20 88 F8 00 00 0E E0 7D E0 DD F8 2C 04 80 06 0B D4 42 46 29 1D 4D F2 04 00 DD F8 44 34 05 F0 C8 FD 00 28 6F D0 08 F1 0C 08 68 68 C6 F8 A4 00 82 E0 50 45 1D D1 DD F8 2C 04 80 06 7C D4 DD F8 48 04 1F F0 23 FD C0 07 09 D0 12 20 88 F8 00 00 BD F8 34 14 00 E0 40 E0
9:01:33 AM
9:01:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 AE 09 81 80 A8 F8 04 10 3A E0 12 20 88 F8 00 00 BD F8 08 10 A8 F8 04 10 09 F1 02 00 2F E0 11 28 F3 D0 12 28 F1 D0 13 28 EF D0 14 28 ED D0 15 28 EB D0 A0 F5 7F 41 FF 39 59 D0 DD F8 2C 14 89 06 09 D5 D9 F8 00 00 41 46 DD F8 44 24 FF F7 50 FE 00 28 4D D0 46 E0 1D F0 8B FB 00 90 00 28 47 D0 40 88 42 46 49 46 DD F8 44 34 05 F0 78 FD 00 28 3E D0 00 98 40 88 C0 F3 0A 01 01 EB 09 00 81 46 08 F1 0C 08
9:01:34 AM
9:01:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 AF 09 81 80 2E E0 DD F8 30 04 01 68 0B EB 44 00 08 5A A0 F5 00 41 10 39 24 D0 50 45 0A D1 DD F8 48 04 1F F0 C9 FC C0 07 1C D1 00 BF 09 F1 02 00 17 E0 1D E0 11 28 F9 D0 12 28 F7 D0 13 28 F5 D0 14 28 F3 D0 15 28 F1 D0 A0 F5 7F 41 FF 39 0E D0 1D F0 4E FB 00 28 0B D0 40 88 C0 F3 0A 01 01 EB 09 00 81 46 64 1C A4 B2 BC 42 FF F4 01 AF 01 20 0D F2 4C 4D BD E8 F0 8F 2D E9 F7 4F 07 46 90 B0 0C 46 08 46
9:01:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B0 09 81 80 FF F7 E0 FC 83 46 FF 28 4B D0 20 F0 F0 FF 5F EA 00 0A 46 D0 58 46 1F F0 8D FC 08 90 94 F8 3C 00 01 28 06 D1 94 F8 40 00 18 B9 D4 E9 12 01 88 42 37 D8 04 AA 59 46 20 46 FF F7 E9 FC 5F EA 00 08 2F D0 00 26 35 46 0D F1 10 09 00 BF 19 F8 05 00 DB F7 FA F9 6D 1C 30 44 AD B2 86 B2 10 2D F5 D3 FE B1 08 98 80 06 01 D5 3D 46 0C E0 06 EB 46 00 80 04 01 0C 12 98 DB F7 14 FB 05 00 11 D0 02 20
9:01:35 AM
9:01:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B1 09 81 80 38 70 BE 80 BD 60 54 F8 8C 0F D4 E9 02 12 A4 F1 8C 04 8A 42 08 D3 D4 F8 90 30 83 42 04 D9 01 26 03 E0 00 20 13 B0 A3 E7 00 26 DA F8 00 70 01 23 3F 79 01 2F 07 D1 94 F8 3C 70 1F B1 94 F8 40 70 01 2F 00 D1 00 23 06 B3 D4 F8 9C 60 AD F8 32 60 D4 F8 A0 60 AD F8 28 60 23 B1 0A AB 58 46 20 F0 47 FA 04 E0 01 46 0A AA 58 46 20 F0 32 FA 00 28 D8 D0 0A AA 8D E8 04 03 5B 46 21 46 28 46 12 9A
9:01:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B2 09 81 80 FF F7 3E FE 00 28 CD D0 12 E0 00 20 49 46 FC 4A 03 46 0B E0 01 EB D0 04 00 F0 07 06 24 78 96 5D 34 42 01 D0 05 F8 0C 3B 40 1C 80 B2 40 45 F1 D3 01 20 B7 E7 2D E9 FC 41 06 46 0D 46 17 46 30 21 10 46 DB F7 AE FA 04 00 20 D0 02 20 30 70 04 20 B0 80 B4 60 12 26 26 70 28 88 A0 80 06 20 AD F8 00 00 A8 1C 01 90 3A 46 69 46 04 F1 0C 00 FA F7 4B FE 00 28 08 D0 0F 20 20 76 28 7A 20 77 84 F8
9:01:36 AM
9:01:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B3 09 81 80 24 60 68 89 20 85 01 20 BD E8 FC 81 00 20 FB E7 10 B5 00 23 50 B1 04 7A 14 80 D0 F8 02 40 C2 F8 02 40 C0 88 D0 80 11 72 53 81 10 BD 13 60 53 60 93 60 10 BD 2D E9 F0 41 0F 46 05 46 FF F7 02 FC 06 46 FF 28 13 D0 20 F0 12 FF 00 28 10 D0 00 68 D5 F8 8C 10 06 22 02 EB 41 01 44 5A A4 F5 7F 40 FF 38 07 D0 24 F0 78 00 05 F0 DA FA 03 E0 00 20 BD E8 F0 81 00 20 3A 46 C4 F3 C3 01 FF F7 C8 FF
9:01:37 AM
9:01:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B4 09 81 80 D5 F8 8C 00 C1 B2 30 46 1F F0 68 FA 78 81 01 20 EE E7 2D E9 F7 4F 07 46 82 B0 0C 46 08 46 FF F7 D1 FB 83 46 FF 28 7D D0 20 F0 E1 FE 00 90 58 46 20 F0 EC FE 06 46 58 46 1F F0 7C FB 82 46 00 2E 70 D0 94 F8 3C 10 4F F0 00 09 31 B1 04 F1 40 00 01 29 0E D0 02 29 65 D1 2E E0 35 69 C4 E9 23 95 30 68 00 B1 40 1E C4 F8 94 00 70 68 C4 F8 98 00 4B E0 D0 E9 02 12 91 42 74 D8 30 68 08 B1 A0 F1
9:01:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B5 09 81 80 01 00 73 68 5F EA 4A 65 03 D5 81 42 05 D9 08 46 03 E0 4D 1E 85 42 00 D9 28 46 C4 F8 94 00 9A 42 00 D3 1A 46 01 46 58 46 C4 F8 98 20 20 F0 BE FE C4 E9 23 90 05 46 28 E0 41 68 99 B3 49 1E C4 F8 8C 10 80 68 00 B9 30 69 C4 F8 90 00 45 1A 30 68 00 B1 40 1E C4 F8 94 00 70 68 C4 F8 98 00 0C 21 04 98 DB F7 DE F9 02 00 3C D0 C2 F8 00 90 C2 F8 04 90 4F F6 FF 70 C2 F8 08 90 50 81 58 46 D4 F8
9:01:38 AM
9:01:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B6 09 81 80 8C 10 20 F0 26 F9 00 28 2D D0 5F EA 8A 60 4F F0 01 0A 2C D5 14 21 04 98 DB F7 C3 F9 06 00 21 D0 03 21 00 E0 1E E0 61 F3 0F 08 04 98 DB F7 B9 F9 00 28 18 D0 02 21 01 70 80 F8 01 A0 06 21 81 70 C6 E9 00 80 8D B1 00 98 40 8A 68 43 08 30 70 82 A6 F8 10 90 A6 F8 08 90 13 20 C6 F8 0C 90 38 70 7E 60 09 E0 00 20 05 B0 42 E6 00 20 EF E7 87 F8 00 A0 BD 80 C7 F8 08 90 84 F8 8A A0 25 B1 00 20
9:01:39 AM
9:01:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B7 09 81 80 84 F8 89 00 01 20 EE E7 01 20 F9 E7 10 B5 04 46 0B 46 00 20 01 21 84 F8 89 10 94 F8 8A 10 39 B1 01 29 04 D1 D4 E9 23 01 88 42 09 D3 00 20 10 BD 21 46 18 46 FF F7 2D FF 00 28 F8 D0 01 20 10 BD 21 46 18 46 FF F7 16 FE 00 28 F8 D0 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 01 D3 01 20 00 E0 00 20 84 F8 89 00 E8 E7 2D E9 FE 4F 4F F0 01 09 04 46 0D 46 92 46 00 26 80 F8 89 90 FF F7
9:01:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B8 09 81 80 E1 FA 07 46 FF 28 32 D0 20 F0 F1 FD 5F EA 00 08 2D D0 38 46 1F F0 95 FA 01 46 00 20 06 22 4F F6 FF 7C 08 E0 D8 F8 00 30 02 EB 40 07 DB 5B 63 45 03 D0 40 1C C0 B2 88 42 F4 D3 94 F8 8A 10 11 B1 01 29 33 D1 0F E0 C4 F8 90 00 85 F8 00 90 D4 F8 90 00 A8 80 00 22 01 21 20 46 AA 60 FF F7 B5 FA 84 F8 89 20 21 E0 D4 E9 23 01 88 42 02 D3 00 20 BD E8 FE 8F 69 46 20 46 FF F7 9C FE 00 28 F7 D0
9:01:40 AM
9:01:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 B9 09 81 80 52 46 69 46 28 46 FF F7 55 FE 00 28 F0 D0 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 01 D3 01 20 00 E0 00 20 84 F8 89 00 01 26 30 46 DF E7 10 B5 0C 46 01 21 80 F8 89 10 FF F7 83 FA FF 28 0A D0 20 F0 94 FD 00 28 05 D0 06 21 21 70 00 68 00 68 60 60 01 20 10 BD 00 20 10 BD 10 B5 0C 46 01 21 80 F8 89 10 FF F7 6D FA FF 28 0A D0 20 F0 7E FD 00 28 07 D0 00 68 00 79 28 B1 05 E0 00 00
9:01:41 AM
9:01:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 BA 09 81 80 68 C1 01 00 00 20 10 BD 01 20 16 21 21 70 20 71 01 20 10 BD FE B5 0D 46 01 21 16 46 80 F8 89 10 FF F7 50 FA 04 46 FF 28 0B D0 20 F0 60 FD 07 00 07 D0 20 46 1F F0 05 FA 02 46 38 68 41 79 91 42 01 D9 00 20 FE BD 91 B1 04 22 02 EB 41 01 44 5A 24 F0 78 00 05 F0 24 F9 6A 46 C4 F3 C3 01 FF F7 17 FE 32 46 69 46 28 46 FF F7 E4 FD FE BD C4 88 EE E7 10 B5 0C 46 01 21 80 F8 89 10 FF F7 22 FA
9:01:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 BB 09 81 80 FF 28 09 D0 20 F0 42 FD 00 28 04 D0 06 21 21 70 00 69 60 60 01 20 10 BD 00 20 10 BD 10 B5 0C 46 01 21 80 F8 89 10 FF F7 0D FA FF 28 09 D0 20 F0 2D FD 00 28 04 D0 06 21 21 70 40 69 60 60 01 20 10 BD 00 20 10 BD 2D E9 F0 47 04 46 AD F5 D6 6D 01 20 84 F8 89 00 20 46 FF F7 F4 F9 80 46 FF 28 78 D0 94 F8 B8 00 21 28 74 D1 04 F1 66 00 03 46 FF F7 F4 F9 4F F6 FF 72 C4 F8 8C 00 90 42 69 D0
9:01:42 AM
9:01:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 BC 09 81 80 18 46 FF F7 F7 F9 91 46 07 46 48 45 7C D0 00 2F 7A D0 40 46 1F F0 95 F9 D4 F8 8C 10 81 42 73 D2 11 B9 40 46 1F F0 7F F8 69 46 40 46 20 F0 45 FC 00 28 6A D0 B4 F8 BC 00 C1 B2 04 F1 BE 00 05 F0 3B F8 05 00 60 D0 B4 F8 BC 10 28 7A 81 42 5B D1 FD F7 56 FA F0 B3 40 68 94 F9 C4 10 00 78 81 42 52 DC 28 88 40 EA C1 00 85 B2 28 46 1C F0 FE FF 58 B1 40 88 1E 21 B1 EB D0 2F 03 D0 1C 21 B1 EB
9:01:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 BD 09 81 80 D0 2F 52 D1 B4 F8 C6 00 46 E0 40 F2 24 42 95 A9 0D F5 D4 60 DB F7 00 F8 25 F0 78 00 05 F0 80 F8 06 00 31 D0 30 7A AD F8 90 06 C5 F3 C3 00 8D F8 98 06 D6 F8 02 00 CD F8 92 06 F0 88 AD F8 96 06 0D F5 D2 61 42 A8 05 F0 1C F9 00 28 1D D0 0D F5 D4 62 00 E0 18 E0 0D F2 84 61 42 A8 05 F0 7B FF 00 28 12 D0 9D F8 84 06 09 28 04 D0 02 28 10 D0 01 28 0E D0 19 E0 9D F8 90 01 01 28 15 D0 31 7A
9:01:43 AM
9:01:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 BE 09 81 80 08 29 12 D1 02 28 10 D0 00 20 0D F5 D6 6D BD E8 F0 87 B4 F8 C6 00 40 B1 C2 B2 D4 F8 8C 00 C1 B2 40 46 1E F0 B1 FF 00 28 EF D0 D4 F8 8C 10 EA 46 0A EB 41 00 00 26 C1 88 A9 42 01 D0 C5 80 01 26 D4 F8 8C 00 40 1C B8 42 15 D1 40 46 1F F0 F9 F8 02 46 D4 F8 8C 00 53 46 40 1C C0 B2 49 46 08 E0 03 EB 40 04 E5 88 8D 42 01 D0 E1 80 01 26 40 1C C0 B2 90 42 F4 D3 2E B1 69 46 40 46 20 F0 D6 FB
9:01:44 AM
9:01:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 BF 09 81 80 00 28 C2 D0 01 20 C0 E7 30 B5 04 46 C3 B0 01 20 84 F8 89 00 20 46 FF F7 15 F9 05 46 FF 28 0A D0 D4 F8 BC 10 51 B1 1C 48 81 42 07 D0 49 1F 4F F6 1C 50 81 42 02 D3 00 20 43 B0 30 BD 69 46 28 46 20 F0 7B FB 00 28 F7 D0 D4 F8 BC 00 00 90 69 46 28 46 20 F0 AB FB EF E7 00 20 70 47 00 20 70 47 10 B5 01 21 80 F8 89 10 FF F7 EC F8 FF 28 03 D0 20 F0 4E FA 01 20 10 BD 00 20 10 BD 10 B5 01 21
9:01:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C0 09 81 80 80 F8 89 10 FF F7 DE F8 FF 28 03 D0 BD E8 10 40 20 F0 FE BA 00 20 10 BD 80 51 01 00 18 B1 01 78 09 B1 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00 40 8A 70 47 00 F1 88 00 81 70 4F F0 00 01 C1 70 41 60 C1 60 70 47 42 78 0A 70 02 78 4A 70 82 78 8A 70 C2 78 CA 70 00 79 08 71 01 20 70 47 0E B5 90 F8 2F 00 00 22 08 B1 40 1E C2 B2 A0 48 00 EB 82 00 02 AA 43 88 01 20 CD E9 00 02 02 46 03 20
9:01:45 AM
9:01:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C1 09 81 80 F4 F7 ED FA 0E BD 0E B5 90 F8 2F 00 00 22 08 B1 40 1E C2 B2 96 48 00 EB 82 00 02 AA 43 88 01 20 CD E9 00 02 02 46 03 20 F4 F7 19 FB 0E BD 90 F8 2F 20 00 21 0A B1 52 1E D1 B2 8D 4A D0 F8 8C 00 02 EB 81 01 02 22 49 88 02 EB C0 00 08 44 80 B2 70 47 3E B5 0C 46 FF F7 EA FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 3E BD 08 20 02 A9 CD E9 00 01 02 46 21 46 03 20 F4 F7 B2 FA 3E BD 3E B5 02 46
9:01:46 AM
9:01:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C2 09 81 80 0C 46 66 30 FF F7 8A FF 4F F6 FF 75 C2 F8 8C 00 A8 42 07 D0 80 28 05 D2 10 46 FF F7 C8 FF 03 46 A8 42 01 D1 00 20 3E BD 08 20 02 A9 CD E9 00 01 02 46 21 46 03 20 F4 F7 D2 FA 3E BD 2D E9 FF 41 05 46 16 46 1F 46 24 21 18 46 DA F7 AA FE 04 00 23 D0 02 20 28 70 03 20 A8 80 12 20 AC 60 20 70 F0 88 A0 80 02 A9 30 46 FF F7 6D FF 00 28 11 D0 05 20 AD F8 00 00 02 A8 01 90 3A 46 69 46 04 F1
9:01:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C3 09 81 80 0C 00 FA F7 41 FA 00 28 04 D0 11 20 20 76 70 79 20 77 01 20 04 B0 BD E8 F0 81 00 20 FA E7 00 22 02 60 42 60 8B 78 43 70 CB 78 03 70 0B 79 83 70 4B 79 C3 70 8A 79 02 71 CA 79 42 71 09 88 C1 80 01 20 70 47 2D E9 FE 43 00 26 4F F0 01 08 0D 46 80 F8 89 80 04 46 91 46 37 46 AD F8 00 60 69 46 FF F7 3D FF 00 28 27 D0 94 F8 2F 10 00 20 09 B1 49 1E C8 B2 3E 49 BD F8 00 20 11 F8 20 00 82 42
9:01:47 AM
9:01:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C4 09 81 80 00 D3 02 46 94 F8 8A 00 10 B1 01 28 13 D1 15 E0 C4 F8 90 20 85 F8 00 80 D4 F8 90 00 A8 80 01 21 20 46 AF 60 FF F7 06 FF 84 F8 89 70 1A B3 24 E0 84 F8 89 00 01 26 30 46 BD E8 FE 83 D4 E9 23 01 88 42 01 D3 00 20 F7 E7 01 A9 20 46 FF F7 41 FF 00 28 F1 D0 4B 46 01 AA 21 46 28 46 FF F7 6E FF 00 28 E9 D0 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 01 D3 01 20 DA E7 00 20 D8 E7 3E B5
9:01:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C5 09 81 80 04 46 01 20 84 F8 89 00 94 F8 B8 00 18 B1 1B 28 05 D0 00 20 3E BD 94 F8 66 00 F8 B1 F9 E7 04 F1 BC 01 01 A8 FF F7 7B FF 00 28 F3 D0 01 A9 20 46 FF F7 24 FF 00 28 ED D0 D4 E9 23 01 88 42 15 D1 94 F8 2F 00 00 21 08 B1 40 1E C1 B2 08 4A B4 F8 6E 00 12 F8 21 10 88 42 00 D3 08 46 AD F8 00 00 69 46 20 46 FF F7 CF FE 00 28 D3 D0 01 20 3E BD 14 42 06 00 2D E9 F0 47 04 46 AD F5 14 7D 0D 46
9:01:48 AM
9:01:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C6 09 81 80 92 46 80 8D 27 F0 03 FF 06 46 05 28 7D D2 68 46 27 F0 C2 FE 00 28 5F D0 01 22 84 F8 89 20 94 F8 88 10 00 20 00 29 71 D0 4F F0 02 09 6F 46 02 29 56 D0 03 29 6B D0 04 29 4E D1 C6 EB C6 01 C1 EB 86 11 07 EB 41 08 98 F8 05 10 0C 29 00 D9 0C 21 94 F8 8A 30 00 26 00 2B 7B D0 01 2B 3C D1 D4 E9 25 01 88 42 51 D2 18 21 50 46 DA F7 9A FD 07 00 4B D0 85 F8 00 90 A5 F8 04 90 AF 60 D4 F8 94 00
9:01:49 AM
9:01:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C7 09 81 80 04 21 00 EB C0 00 08 EB 00 05 A8 1D AD F8 3C 12 90 90 52 46 8F A9 38 46 FA F7 36 F9 00 28 1B D0 05 20 AD F8 3C 02 0A 35 52 46 8F A9 07 F1 0C 00 90 95 FA F7 29 F9 54 F8 94 1F 49 1C 21 60 62 68 A4 F1 94 04 91 42 68 D3 04 F1 88 04 E6 70 E6 60 61 68 01 F1 01 01 61 60 0D F5 14 7D BD E8 F0 87 18 21 50 46 DA F7 5D FD 04 00 54 D0 85 F8 00 90 A5 F8 04 90 FF 22 06 21 91 A8 AC 60 D3 F7 C1 FC
9:01:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C8 09 81 80 C6 EB C6 00 C0 EB 86 15 02 E0 44 E0 1F E0 21 E0 37 F8 15 00 20 F0 78 00 04 F0 C2 FD 28 B1 D0 F8 02 10 91 91 C0 88 AD F8 48 02 06 20 AD F8 3C 02 91 A8 90 90 52 46 8F A9 20 46 FA F7 E5 F8 00 28 CA D0 12 20 20 73 07 EB 45 00 40 88 20 82 01 20 C2 E7 0A E0 16 20 28 70 C6 EB C6 00 C0 EB 86 10 07 EB 40 00 00 79 28 71 F1 E7 04 F1 88 04 A1 60 2A 70 A9 80 AE 60 A2 70 E6 70 66 60 C4 E9 03 61
9:01:50 AM
9:01:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 C9 09 81 80 A4 F1 88 04 11 B1 84 F8 89 60 E0 E7 14 F8 89 0F 40 1C 20 70 DB E7 00 20 9E E7 84 F8 89 60 9B E7 38 B5 04 46 01 79 62 79 61 F3 0F 20 23 78 62 F3 07 00 3B B3 FF 2B 3B D0 61 78 FF 29 38 D0 A1 78 FF 29 35 D0 E1 78 FF 29 32 D0 80 B2 A0 F5 7F 41 FF 39 2D D0 A0 79 FD 38 02 28 29 D9 20 7A FF 28 26 D0 E0 79 FD 38 02 28 22 D9 68 46 DA F7 77 FB 20 46 00 99 27 F0 E6 FE E0 B1 00 99 88 42 17 D2
9:01:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 CA 09 81 80 02 20 38 BD 63 78 00 2B D6 D1 A3 78 00 2B D6 D1 E3 78 00 2B D6 D1 00 29 D7 D1 00 2A D5 D1 A1 79 00 29 D2 D1 21 7A 00 29 CF D1 E1 79 00 29 CC D1 00 20 38 BD 01 20 38 BD F8 B5 07 46 48 79 0D 46 0C 28 01 D9 00 20 F8 BD 00 26 34 46 20 E0 00 BF 04 EB C4 00 28 44 80 1D FF F7 A2 FF 01 28 15 D0 68 46 DA F7 3C FB 04 EB C4 00 28 44 80 1D 00 99 27 F0 A8 FE 03 46 21 46 38 46 00 9A 28 F0 24 FA
9:01:51 AM
9:01:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 CB 09 81 80 4F F0 01 06 38 B1 28 F0 31 FA 04 E0 64 1C A4 B2 68 79 A0 42 DC D8 30 46 F8 BD 2D E9 F0 41 04 46 AD F5 10 7D 00 27 80 8D 27 F0 B1 FD 06 46 05 28 58 D0 68 46 27 F0 70 FD 00 28 54 D0 C6 EB C6 00 C0 EB 86 11 68 46 00 EB 41 01 94 F8 88 00 0D 46 4F F6 FF 78 02 28 04 D0 03 28 19 D0 04 28 67 D1 1E E0 94 F8 B8 00 1F 28 3C D1 09 21 04 F1 BC 00 04 F0 62 FC 10 B1 01 7A 09 29 02 D0 A5 F8 00 80
9:01:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 CC 09 81 80 01 E0 00 88 28 80 B4 F8 C2 00 C0 B2 68 80 4A E0 94 F8 B8 00 09 28 25 D1 94 F8 BC 00 28 71 42 E0 94 F8 66 00 30 B9 94 F8 67 00 01 28 02 D1 B4 F8 6E 00 20 B1 94 F8 B8 00 20 28 13 D1 02 E0 00 20 48 71 30 E0 B4 F8 6E 00 40 45 0B D0 B4 F8 7C 20 C4 F8 8C 20 42 45 05 D0 0C 28 00 D3 0C 20 92 B2 0C 2A 04 D3 00 20 0D F5 10 7D BD E8 F0 81 6B 79 83 42 00 D0 68 71 40 1E 82 42 00 D1 01 27 02 EB
9:01:52 AM
9:01:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 CD 09 81 80 C2 00 08 44 D4 F8 BC 20 C0 F8 06 20 D4 F8 C0 20 C0 F8 0A 20 94 F8 C4 20 82 73 27 B1 30 46 FF F7 4B FF 00 28 DF D0 68 46 27 F0 53 FD 00 28 DA D0 01 20 D8 E7 1C B5 04 46 08 88 10 23 B3 EB D0 2F 0A D1 C0 F3 0A 00 89 1C AD F8 00 00 01 91 69 46 20 46 F9 F7 99 FF 1C BD C0 F3 0A 03 08 2B 05 D8 13 46 22 46 89 1C 04 F0 B8 FD 18 B9 11 20 20 70 00 20 20 71 01 20 1C BD 2D E9 F7 4F AD F5 EB 6D
9:01:53 AM
9:01:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 CE 09 81 80 4F F0 01 08 0F 46 80 F8 89 80 04 46 81 8D 00 26 68 46 28 F0 0B FC 18 B9 A1 8D 68 46 28 F0 7E F9 94 F8 8A 00 00 25 10 B1 01 28 1A D1 1E E0 BD F8 00 00 20 28 00 D3 20 20 04 F1 88 04 00 28 A0 60 87 F8 00 80 A2 68 BA 80 BD 60 84 F8 02 80 E5 70 65 60 E5 60 A4 F1 88 04 77 D0 BE E0 84 F8 89 00 01 26 30 46 0D F2 64 7D BD E8 F0 8F D4 E9 23 01 88 42 6B D2 00 EB 40 01 C1 EB 40 11 EA 46 0A EB
9:01:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 CF 09 81 80 41 00 46 88 04 2E 00 D3 04 26 94 F8 8B 00 4F F0 02 09 4F F0 12 0B 10 B1 01 28 57 D1 1C E0 18 21 DD F8 60 07 DA F7 7D FB 00 28 DB D0 87 F8 00 90 A7 F8 04 90 04 F1 88 04 B8 60 61 68 80 F8 00 B0 01 F1 01 01 81 80 80 F8 0C 80 06 82 45 61 84 F8 03 80 C4 E9 03 56 76 E0 D4 E9 25 01 88 42 7A D2 3C 21 DD F8 60 07 DA F7 5C FB 06 00 73 D0 87 F8 00 90 05 20 B8 80 BE 60 D4 F8 8C 00 1F 28 00 D3
9:01:54 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:01:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D0 09 81 80 1F 20 81 B2 D4 F8 94 00 03 28 00 D3 03 20 16 22 32 70 01 EB 41 02 80 B2 C2 EB 41 12 0A EB 42 01 C0 EB C0 00 01 EB 40 07 38 79 30 71 F8 88 20 F0 78 00 04 F0 B5 FB 50 B1 01 7A D0 F8 02 20 CD F8 44 27 C0 88 AD F8 48 07 06 E0 42 E0 43 E0 00 21 CD F8 44 57 CD F8 48 57 86 F8 0C B0 31 82 06 20 AD F8 4C 07 0D F2 44 70 CD F8 50 07 0D F2 4C 71 06 F1 18 00 DD F8 60 27 F9 F7 C6 FE 00 28 94 D0
9:01:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D1 09 81 80 0F 20 86 F8 24 00 F8 88 07 F1 08 01 C0 F3 C3 00 86 F8 28 00 06 F1 30 00 DD F8 60 27 FF F7 0A FF 00 28 EC D0 54 F8 94 0F 40 1C 20 60 61 68 A4 F1 94 04 88 42 09 D3 04 F1 88 04 E5 70 E5 60 60 68 00 F1 01 00 60 60 A4 F1 88 04 D4 E9 23 01 88 42 03 D3 01 20 42 E7 00 20 44 E7 00 20 3E E7 F0 B5 04 46 AD F2 44 7D 01 20 84 F8 89 00 00 27 A0 8D 28 F0 86 F8 00 28 71 D0 40 88 A0 F5 7F 41 FF 39
9:01:55 AM
9:01:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D2 09 81 80 6D D0 A1 8D 68 46 28 F0 11 FB 20 B9 40 F2 44 71 68 46 D2 F7 E2 FC 94 F8 88 00 02 28 7F D1 94 F8 66 00 02 28 6F D0 04 28 6D D1 B4 F8 7C 20 B4 F8 80 50 20 2A 73 D2 04 2D 71 D2 B4 F8 6E 00 20 28 00 D3 20 20 B4 F8 72 10 04 29 00 D3 04 21 BD F8 00 30 83 42 02 D0 AD F8 00 00 01 27 02 EB 42 00 C0 EB 42 12 68 46 00 EB 42 06 70 88 88 42 01 D0 71 80 01 27 C4 F8 8C 50 B4 F8 82 00 05 28 4E D2
9:01:56 AM
9:01:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D3 09 81 80 DF E8 00 F0 03 0F 1A 2E 42 00 94 F8 B8 00 09 28 49 D1 C5 EB C5 01 06 EB 41 01 94 F8 BC 00 08 71 42 E0 94 F8 B8 00 06 28 03 D0 FF 20 A4 F8 84 00 39 E0 B4 F8 BC 00 F9 E7 94 F8 B8 00 16 28 32 D1 B4 F8 84 00 C1 B2 04 F1 BE 00 04 F0 75 FA 00 B1 00 88 C5 EB C5 01 06 EB 41 01 12 E0 20 E0 1E E0 94 F8 B8 00 02 28 1E D1 94 F9 BC 00 10 28 1A DA C5 EB C5 01 06 EB 41 01 CA 88 22 F0 78 02 42 EA
9:01:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D4 09 81 80 C0 00 C8 80 10 E0 15 E0 C5 EB C5 00 06 EB 40 01 08 31 04 F1 B8 00 28 F0 07 FB 28 B9 03 E0 00 20 0D F2 44 7D F0 BD 2F B1 A1 8D 68 46 28 F0 B9 F9 00 28 F5 D0 01 20 F3 E7 38 B5 05 46 01 20 85 F8 89 00 95 F8 B8 00 06 28 76 D1 A8 8D 49 F2 06 12 B5 F8 BC 40 81 1A 90 42 6F D0 19 DC 49 F2 05 02 A0 EB 02 01 90 42 5A D0 0B DC B0 F5 10 4F 31 D0 A0 F5 10 40 02 38 47 D0 01 28 3F D0 02 28 19 D1
9:01:57 AM
9:01:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D5 09 81 80 62 E0 02 29 1B D0 7C 29 76 D0 FB 29 12 D1 6A E0 7C 29 6E D0 06 DC 01 29 6C D0 7A 29 6B D0 7B 29 08 D1 CA E0 A1 F5 80 71 FB 39 76 D0 01 29 75 D0 03 29 74 D0 28 46 28 F0 28 FB 01 20 38 BD 01 2C 02 D0 02 2C 38 D1 02 E0 2B F0 61 FC F5 E7 2B F0 64 FC F2 E7 28 78 04 28 03 D1 27 F0 6A FF 00 90 10 B9 68 46 DA F7 7B F8 0C B1 01 2C 24 D1 28 78 04 28 00 D0 02 20 22 F0 BB FA DE E7 01 2C 1B D1
9:01:58 AM
9:01:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D6 09 81 80 07 20 29 F0 27 FE D8 E7 01 2C 02 D0 02 2C 13 D1 01 E0 01 20 00 E0 05 20 2A F0 B6 FF CD E7 01 2C 0C D0 02 2C 0C D0 03 2C 0C D0 04 2C C5 D1 04 21 28 46 28 F0 BE FA C0 E7 77 E0 21 E0 01 21 F7 E7 02 21 F5 E7 03 21 F3 E7 01 2C 08 D0 02 2C 08 D0 03 2C B2 D1 5F F0 02 00 2A F0 EA F9 38 BD 00 20 FA E7 01 20 F8 E7 01 2C A7 D1 DB F7 38 F8 A4 E7 02 E0 67 E0 14 E0 54 E0 00 20 04 F0 F4 F8 38 BD
9:01:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D7 09 81 80 01 2C 52 D1 16 F0 F5 FB 04 20 29 F0 09 FE 00 28 93 D0 01 20 16 F0 61 FC 8F E7 58 E0 5A E0 5D E0 07 2C 8A D2 DF E8 04 F0 04 05 0E 17 20 29 32 00 83 E7 01 21 29 20 16 F0 13 FB 00 20 16 F0 60 FA E6 20 2B E0 00 21 29 20 16 F0 0A FB 00 20 16 F0 76 FA E7 20 22 E0 01 21 2A 20 16 F0 01 FB 01 20 16 F0 4E FA E8 20 19 E0 00 21 2A 20 16 F0 F8 FA 01 20 16 F0 64 FA E9 20 10 E0 01 21 2B 20 16 F0
9:01:59 AM
9:01:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D8 09 81 80 EF FA 02 20 16 F0 3C FA EA 20 07 E0 00 21 2B 20 16 F0 E6 FA 02 20 16 F0 52 FA EB 20 2D F0 AB FC 4B E7 01 2C 03 D0 02 2C 04 D0 00 20 38 BD 2B F0 37 FC 42 E7 2B F0 3A FC 3F E7 01 2C 97 D1 2B F0 60 FC 38 BD 01 2C 92 D1 2B F0 63 FC 38 BD 02 F0 2E FC 32 E7 E0 B2 25 F0 59 FF 38 BD 20 46 16 F0 2B FE 38 BD 18 B1 01 78 09 B1 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00 40 8A 70 47 00 F1 88 00
9:01:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 D9 09 81 80 81 70 4F F0 00 01 C1 70 41 60 C1 60 70 47 50 F8 94 2F 11 44 01 60 42 68 A0 F1 94 00 91 42 08 D3 00 F1 88 00 00 21 C1 70 C1 60 41 68 01 F1 01 01 41 60 4F F0 01 00 70 47 10 B5 90 F8 88 10 03 29 04 D0 07 29 04 D0 4F F6 FF 70 10 BD 00 21 00 E0 01 21 90 F8 2F 30 00 22 0B B1 5B 1E DA B2 02 EB 82 03 FA 4A D0 F8 8C 00 02 EB 83 02 C0 EB C0 00 93 88 14 8A D2 88 01 FB 04 31 02 EB 40 00 08 44
9:02:00 AM
9:02:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 DA 09 81 80 80 B2 10 BD 90 F8 88 10 03 29 04 D0 07 29 04 D0 4F F6 FF 70 70 47 00 21 00 E0 01 21 90 F8 2F 00 00 22 08 B1 40 1E C2 B2 E8 48 02 EB 82 02 00 EB 82 00 82 88 03 8A C0 88 01 FB 03 21 08 44 80 B2 70 47 3E B5 0C 46 FF F7 DD FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 3E BD 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 7A FC 3E BD 3E B5 0C 46 FF F7 C8 FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20
9:02:01 AM
9:02:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 DB 09 81 80 3E BD 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 A5 FC 3E BD 3E B5 0C 46 FF F7 8D FF A0 F5 7F 41 FF 39 01 D1 00 20 3E BD 40 1C 83 B2 0E 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 4F FC 3E BD 3E B5 0C 46 FF F7 77 FF A0 F5 7F 41 FF 39 01 D1 00 20 3E BD 40 1C 83 B2 0E 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 79 FC 3E BD 2D E9 FC 41 06 46 14 46 1F 46 24 21 18 46 DA F7 51 F8
9:02:02 AM
9:02:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 DC 09 81 80 05 00 28 D0 02 20 30 70 03 20 B0 80 B5 60 01 26 AD F8 00 60 3A 46 69 46 28 46 01 94 F9 F7 F4 FB 00 28 16 D0 0C 20 AD F8 00 00 60 1C 01 90 3A 46 69 46 05 F1 0C 00 F9 F7 E7 FB 00 28 09 D0 0D 34 AD F8 00 60 3A 46 69 46 05 F1 18 00 01 94 F9 F7 DB FB BD E8 FC 81 00 20 FB E7 90 F8 88 10 02 29 04 D0 06 29 04 D0 4F F6 FF 70 70 47 00 21 00 E0 01 21 90 F8 2F 00 00 22 08 B1 40 1E C2 B2 93 48
9:02:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 DD 09 81 80 02 EB 82 02 00 EB 82 00 82 88 00 8A 01 FB 00 20 80 B2 70 47 3E B5 0C 46 FF F7 DF FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 3E BD 16 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 D1 FB 3E BD 3E B5 0C 46 FF F7 CA FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 3E BD 16 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 FC FB 3E BD 90 F8 88 10 05 29 04 D0 09 29 04 D0 4F F6 FF 70 70 47 00 21 00 E0 01 21
9:02:03 AM
9:02:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 DE 09 81 80 90 F8 2F 00 00 22 08 B1 40 1E C2 B2 6F 48 02 EB 82 02 00 EB 82 00 82 88 03 8A 40 89 01 FB 03 21 08 44 80 B2 70 47 3E B5 0C 46 FF F7 DD FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 3E BD 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 88 FB 3E BD 3E B5 0C 46 FF F7 C8 FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 3E BD 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 B3 FB 3E BD 10 B5 04 46 FF F7
9:02:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 DF 09 81 80 B3 FF 4F F6 FF 71 88 42 01 D1 08 46 10 BD 94 F8 2F 20 00 21 0A B1 52 1E D1 B2 4C 4B 01 EB 81 01 03 EB 81 01 D4 F8 8C 20 49 8A 80 1C 02 FB 01 00 80 B2 10 BD 3E B5 0C 46 FF F7 DF FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 3E BD 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 41 FB 3E BD 3E B5 0C 46 FF F7 CA FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 3E BD 01 20 02 A9 CD E9 00 01 02 46 21 46
9:02:04 AM
9:02:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E0 09 81 80 04 20 F3 F7 6C FB 3E BD 3E B5 0C 46 FF F7 B5 FF A0 F5 7F 41 FF 39 01 D1 00 20 3E BD 40 1C 83 B2 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 16 FB 3E BD 3E B5 0C 46 FF F7 9F FF A0 F5 7F 41 FF 39 01 D1 00 20 3E BD 40 1C 83 B2 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 40 FB 3E BD 10 B5 90 F8 88 10 05 29 04 D0 09 29 04 D0 4F F6 FF 70 10 BD 00 22 00 E0 01 22 90 F8 2F 30 00 21
9:02:05 AM
9:02:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E1 09 81 80 0B B1 5B 1E D9 B2 01 EB 81 03 10 49 01 EB 83 01 8B 88 0C 8A 02 FB 04 32 50 F8 8C 4F 4B 89 49 8A 80 68 04 FB 01 31 11 44 00 EB 40 00 01 EB 40 00 00 1D 80 B2 10 BD 3E B5 0C 46 FF F7 D1 FF A0 F5 7F 41 03 46 FF 39 03 D1 00 20 3E BD 30 42 06 00 06 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 BE FA F2 E7 7C B5 05 46 08 78 28 70 48 78 0C 46 68 70 09 21 20 1D 03 F0 DF FE 10 B1 00 88 68 80
9:02:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E2 09 81 80 0F E0 4F F6 FF 70 68 80 FF 22 06 21 68 46 D2 F7 38 FE 06 22 69 46 20 1D D2 F7 16 F8 08 B1 00 20 7C BD 60 89 A8 80 01 20 7C BD 10 B5 86 B0 04 46 02 A8 FF F7 D7 FF 00 28 08 D0 20 46 FF F7 90 FF A0 F5 7F 41 03 46 FF 39 02 D1 00 20 06 B0 10 BD 06 20 04 A9 CD E9 00 01 02 46 02 A9 04 20 F3 F7 BE FA F3 E7 F0 B5 06 46 85 B0 15 46 1F 46 24 21 18 46 D9 F7 96 FE 04 00 44 D0 02 20 30 70 03 20
9:02:06 AM
9:02:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E3 09 81 80 B0 80 B4 60 28 78 8D F8 08 00 68 78 8D F8 09 00 00 20 8D F8 0A 00 8D F8 0B 00 04 20 AD F8 00 00 02 A8 01 90 3A 46 69 46 20 46 F9 F7 2D FA 00 28 26 D0 FF 22 06 21 03 A8 D2 F7 E3 FD 68 88 A0 F5 7F 41 FF 39 0A D0 20 F0 78 00 03 F0 E9 FE 28 B1 D0 F8 02 10 03 91 C0 88 AD F8 10 00 06 20 AD F8 00 00 03 A8 01 90 3A 46 69 46 04 F1 0C 00 F9 F7 0B FA 00 28 04 D0 12 20 20 76 A8 88 A0 83 01 20
9:02:07 AM
9:02:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E4 09 81 80 05 B0 F0 BD 00 20 FB E7 2D E9 FC 41 88 46 06 46 00 27 14 46 AD F8 00 70 69 46 40 46 FF F7 CA FE 00 28 29 D0 98 F8 2F 10 00 20 09 B1 49 1E C8 B2 00 EB 80 01 F9 48 BD F8 00 50 00 EB 81 00 C0 78 85 42 00 D3 05 46 18 21 20 46 D9 F7 2A FE 04 00 13 D0 02 20 30 70 B0 80 01 A9 40 46 B4 60 FF F7 D3 FE 00 28 08 D0 11 20 20 70 9D F8 04 00 20 71 01 20 20 73 25 82 67 61 EB E5 00 20 E9 E5 10 B5
9:02:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E5 09 81 80 90 F8 88 10 04 29 04 D0 08 29 04 D0 4F F6 FF 70 10 BD 00 21 00 E0 01 21 90 F8 2F 30 00 22 0B B1 5B 1E DA B2 02 EB 82 03 DC 4A D0 F8 8C 00 02 EB 83 02 93 88 14 8A 12 89 01 FB 04 31 02 EB C0 00 08 44 80 B2 10 BD 90 F8 88 10 04 29 04 D0 08 29 04 D0 4F F6 FF 70 70 47 00 21 00 E0 01 21 90 F8 2F 00 00 22 08 B1 40 1E C2 B2 CC 48 02 EB 82 02 00 EB 82 00 82 88 03 8A 00 89 01 FB 03 21 08 44
9:02:08 AM
9:02:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E6 09 81 80 80 B2 70 47 3E B5 0C 46 FF F7 DD FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 D7 E6 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 99 F9 CD E6 3E B5 0C 46 FF F7 C8 FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 C2 E6 01 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 C4 F9 B8 E6 3E B5 0C 46 FF F7 8F FF A0 F5 7F 41 FF 39 01 D1 00 20 AE E6 40 1C 83 B2 08 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7
9:02:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E7 09 81 80 6E F9 A2 E6 0A 68 02 60 49 68 41 60 01 20 70 47 00 B5 85 B0 03 46 02 A8 FF F7 F4 FF 00 28 07 D0 18 46 FF F7 6C FF A0 F5 7F 41 FF 39 02 D1 00 20 05 B0 00 BD 40 1C 83 B2 08 20 04 A9 CD E9 00 01 02 46 02 A9 04 20 F3 F7 8A F9 F1 E7 2D E9 FC 41 06 46 15 46 1F 46 60 21 18 46 D9 F7 62 FD 04 00 2F D0 02 20 30 70 08 20 B0 80 B4 60 01 20 AD F8 00 00 3A 46 69 46 20 46 01 95 F9 F7 05 F9 00 28
9:02:09 AM
9:02:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E8 09 81 80 1E D0 11 20 04 F8 0C 0F 69 78 21 71 20 73 A9 78 21 74 20 76 E9 78 21 77 84 F8 24 00 29 79 84 F8 28 10 84 F8 30 00 69 79 84 F8 34 10 84 F8 3C 00 A9 79 84 F8 40 10 04 F8 48 0F E8 79 20 71 01 20 07 E5 00 20 05 E5 00 B5 87 B0 03 A9 F9 F7 19 F8 58 B1 68 46 D9 F7 02 FB 03 A9 68 46 F3 F7 FA FB 00 28 02 DA 00 20 07 B0 00 BD 01 20 FB E7 90 F8 2F 00 00 21 08 B1 40 1E C1 B2 68 48 01 EB 81 01
9:02:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 E9 09 81 80 00 EB 81 00 81 88 C0 89 08 44 80 B2 70 47 3E B5 0C 46 FF F7 EC FF A0 F5 7F 41 03 46 FF 39 01 D1 00 20 12 E6 0C 20 02 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 D4 F8 08 E6 30 B5 0C 46 05 46 87 B0 0C 22 57 49 20 46 D1 F7 3F FE 08 B3 0C 22 55 49 20 46 D1 F7 39 FE D8 B1 20 78 FF 28 02 D1 60 78 FF 28 36 D0 A0 78 FF 28 33 D0 E0 78 FF 28 30 D0 60 79 FF 28 2D D0 A0 79 FF 28 2A D0 E0 79 FF 28
9:02:10 AM
9:02:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 EA 09 81 80 27 D0 20 7A FF 28 24 D0 20 46 FF F7 9C FF 00 BB 02 A9 20 46 F8 F7 B5 FF 00 28 1B D0 28 46 FF F7 A6 FF A0 F5 7F 41 03 46 FF 39 12 D0 0C 20 05 A9 CD E9 00 01 02 46 21 46 04 20 F3 F7 D0 F8 00 28 08 D0 95 F8 2F 00 00 24 30 B1 40 1E 10 F0 FF 04 02 D0 00 20 07 B0 30 BD 20 46 F4 F7 B8 F8 10 B1 20 46 F4 F7 13 F9 01 20 F4 E7 30 B5 0C 46 89 B0 01 21 80 F8 89 10 15 46 69 46 FF F7 8B FC 00 28
9:02:11 AM
9:02:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 EB 09 81 80 0B D0 9D F8 00 00 AD F8 18 00 0D F1 01 00 07 90 2A 46 06 A9 20 46 F9 F7 37 F8 09 B0 30 BD 2D E9 F0 43 85 B0 00 26 01 27 0D 46 80 F8 89 70 04 46 91 46 B0 46 AD F8 10 60 04 A9 FF F7 C2 FB 00 28 28 D0 94 F8 2F 10 00 20 09 B1 49 1E C8 B2 00 EB 80 01 12 48 BD F8 10 20 10 F8 21 00 82 42 00 D3 02 46 94 F8 8A 00 10 B1 01 28 12 D1 1C E0 C4 F8 90 20 2F 70 D4 F8 90 00 A8 80 01 21 20 46 C5 F8
9:02:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 EC 09 81 80 08 80 FF F7 3B FB 62 B3 2D E0 00 BF 84 F8 89 00 01 26 30 46 05 B0 BD E8 F0 83 00 00 30 42 06 00 24 42 06 00 18 42 06 00 D4 E9 23 01 88 42 01 D3 00 20 EF E7 69 46 20 46 FF F7 AD FB 00 28 E9 D0 4B 46 6A 46 21 46 28 46 FF F7 D1 FB 00 28 E1 D0 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 01 D3 01 20 D2 E7 00 20 D0 E7 2D E9 FE 43 00 26 01 27 0D 46 80 F8 89 70 04 46 91 46 B0 46 AD F8
9:02:12 AM
9:02:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 ED 09 81 80 00 60 69 46 FF F7 3E FE 00 28 29 D0 94 F8 2F 10 00 20 09 B1 49 1E C8 B2 00 EB 80 01 F8 48 BD F8 00 20 00 EB 81 00 40 78 82 42 00 D3 02 46 94 F8 8A 00 10 B1 01 28 12 D1 14 E0 C4 F8 90 20 2F 70 D4 F8 90 00 A8 80 01 21 20 46 C5 F8 08 80 FF F7 D5 FA 22 B3 25 E0 00 BF 84 F8 89 00 01 26 30 46 BD E8 FE 83 D4 E9 23 01 88 42 01 D3 00 20 F7 E7 01 A9 20 46 FF F7 30 FE 00 28 F1 D0 4B 46 01 AA
9:02:13 AM
9:02:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 EE 09 81 80 21 46 28 46 FF F7 62 FE 00 28 E9 D0 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 01 D3 01 20 DA E7 00 20 D8 E7 2D E9 F7 4F 84 B0 4F F0 00 09 4F F0 01 0B 0F 46 80 F8 89 B0 04 46 CA 46 AD F8 00 90 69 46 FF F7 EF FB 00 28 3C D0 94 F8 2F 10 00 20 09 B1 49 1E C8 B2 00 EB 80 01 C8 48 BD F8 00 50 00 EB 81 08 98 F8 02 00 85 42 00 D3 05 46 AD F8 00 A0 69 46 20 46 FF F7 1C FC 00 28 22 D0
9:02:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 EF 09 81 80 BD F8 00 60 98 F8 03 00 86 42 00 D3 06 46 94 F8 8A 00 10 B1 01 28 15 D1 18 E0 44 F8 90 5F 01 21 A6 60 87 F8 00 B0 54 F8 90 09 B8 80 20 46 C7 F8 08 A0 FF F7 63 FA DD B3 3E E0 00 BF 84 F8 89 00 4F F0 01 09 48 46 07 B0 BD E8 F0 8F D4 E9 23 01 88 42 2F D2 94 F8 8B 00 10 B1 01 28 2A D1 0B E0 21 46 38 46 06 9A FF F7 0F FD 00 28 EB D0 84 F8 8B B0 C4 E9 25 A6 17 E0 D4 E9 25 01 88 42 19 D2
9:02:14 AM
9:02:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F0 09 81 80 01 A9 20 46 FF F7 57 FC 00 28 DC D0 01 AA 21 46 38 46 06 9B FF F7 A6 FC 00 28 D4 D0 01 21 20 46 FF F7 35 FA 00 28 CE D0 D4 E9 23 01 88 42 03 D3 01 20 C3 E7 00 20 C6 E7 00 20 BF E7 30 B5 0C 46 85 B0 01 21 80 F8 89 10 15 46 69 46 FF F7 1F FE 00 28 09 D0 0C 20 AD F8 0C 00 CD F8 10 D0 2A 46 03 A9 20 46 F8 F7 D0 FE 05 B0 30 BD 30 B5 04 46 87 B0 01 20 84 F8 89 00 94 F8 B8 00 16 28 03 D1
9:02:15 AM
9:02:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F1 09 81 80 B4 F8 BC 50 15 2D 01 D9 00 20 63 E6 2A 46 04 F1 BE 01 0D F1 01 00 D1 F7 83 FC 8D F8 00 50 69 46 20 46 FF F7 0C FB 00 28 EF D0 10 20 2B F0 24 F9 01 20 4F E6 F8 B5 04 46 01 20 84 F8 89 00 94 F8 66 00 30 B9 94 F8 67 00 01 28 02 D1 B4 F8 6E 00 70 B1 04 F1 66 00 FF F7 C5 F9 A0 F5 7F 41 C4 F8 8C 00 FF 39 1C D0 94 F8 B8 10 1C 29 18 D1 0A E0 10 20 2B F0 01 F9 00 20 AD F8 00 00 69 46 20 46
9:02:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F2 09 81 80 FF F7 34 FA F8 BD 94 F8 2F 20 00 21 0A B1 52 1E D1 B2 5B 4D 01 EB 81 06 15 F8 26 10 88 42 01 D3 00 20 F8 BD 04 F1 BC 01 20 46 FF F7 4A FA 00 28 F7 D0 B4 F8 6E 00 15 F8 26 10 88 42 00 D3 08 46 AD F8 00 00 69 46 20 46 FF F7 10 FA 04 46 10 20 2B F0 D2 F8 20 46 F8 BD 38 B5 04 46 01 20 84 F8 89 00 94 F8 66 00 30 B9 94 F8 67 00 01 28 02 D1 B4 F8 6E 00 78 B1 04 F1 66 00 FF F7 73 F9 A0 F5
9:02:16 AM
9:02:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F3 09 81 80 7F 42 01 46 C4 F8 8C 00 FF 3A 1D D0 94 F8 B8 00 1D 28 19 D1 0A E0 10 20 2B F0 AE F8 00 20 AD F8 00 00 69 46 20 46 FF F7 C2 FC 38 BD 94 F8 2F 20 00 20 0A B1 52 1E D0 B2 00 EB 80 02 30 48 00 EB 82 05 68 78 81 42 01 D3 00 20 38 BD 04 F1 BC 01 20 46 FF F7 DD FC 00 28 F7 D0 B4 F8 6E 00 A9 78 88 42 00 D3 08 46 AD F8 00 00 69 46 20 46 FF F7 9E FC 00 28 E9 D0 10 20 2B F0 7E F8 01 20 38 BD
9:02:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F4 09 81 80 38 B5 00 F1 7C 04 4F F0 00 00 21 88 21 61 A2 88 A2 61 14 F8 4D 3C A4 F1 7C 04 0B B1 5B 1E D8 B2 00 EB 80 03 16 48 00 EB 83 05 A8 78 81 42 2C D2 01 20 84 F8 89 00 94 F8 66 00 30 B9 94 F8 67 00 01 28 02 D1 B4 F8 6E 00 40 B1 94 F8 B8 00 04 F1 BC 01 05 28 0D D0 1E 28 17 D1 13 E0 10 20 2B F0 4B F8 00 20 AD F8 00 00 69 46 20 46 FF F7 70 FA 38 BD 20 46 FF F7 DE FA 00 28 F9 D0 01 20 38 BD
9:02:17 AM
9:02:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F5 09 81 80 30 42 06 00 E8 78 82 42 01 D3 00 20 F7 E7 20 46 FF F7 4B FB 00 28 F2 D0 B4 F8 6E 00 A9 78 88 42 00 D3 08 46 AD F8 00 00 69 46 20 46 FF F7 50 FA 00 28 E4 D0 B4 F8 72 00 E9 78 88 42 00 D3 08 46 AD F8 00 00 69 46 20 46 FF F7 89 FA 00 28 D6 D0 10 20 2B F0 11 F8 D1 E7 10 B5 01 21 80 F8 89 10 90 F8 B8 10 14 29 01 D0 00 20 10 BD 00 F1 BC 01 FF F7 E2 FC 00 28 F8 D0 10 20 2A F0 FD FF 01 20
9:02:18 AM
9:02:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F6 09 81 80 10 BD 10 B5 01 46 01 20 81 F8 89 00 91 F8 2F 10 00 20 09 B1 49 1E C8 B2 F3 F7 38 FE 01 20 10 BD 00 F0 07 02 C0 F3 C2 03 00 20 8A 42 00 D2 01 20 8B 42 01 D2 40 F0 02 00 70 47 C0 F3 82 10 88 42 01 D2 01 20 70 47 00 20 70 47 2D E9 F8 4F 81 46 DD F8 28 A0 0E 46 15 46 1F 46 24 21 50 46 D9 F7 A0 F9 04 00 47 D0 02 20 30 70 03 20 B0 80 4F F0 0F 08 B4 60 84 F8 00 80 28 78 20 71 2A 78 39 46
9:02:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F7 09 81 80 48 46 03 F0 A0 FF 06 46 DA F7 D9 FD 40 05 01 D5 26 F0 02 06 69 46 14 20 DE F7 FA FD 01 27 08 B9 AD F8 00 70 2A F0 BE FC 00 21 08 B9 AD F8 00 10 BD F8 00 00 28 B1 B9 F8 48 01 00 04 01 D5 26 F0 02 06 68 78 B0 42 00 D2 06 46 16 20 20 73 26 74 AE 78 76 B1 06 EB 46 00 81 00 50 46 D9 F7 61 F9 01 00 08 D0 27 76 A6 83 21 62 00 20 FE 4C 43 46 13 E0 21 76 13 E0 00 20 BD E8 F8 8F AA 88 34 F8
9:02:19 AM
9:02:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F8 09 81 80 10 70 3A 42 07 D0 00 EB 40 02 47 1C 01 F8 22 30 01 EB 82 02 17 71 40 1C C0 B2 B0 42 EE D3 01 20 EA E7 2D E9 F0 41 05 46 0E 46 17 46 18 46 18 21 DD F8 18 80 D9 F7 35 F9 04 00 20 D0 02 20 28 70 A8 80 0F 20 AC 60 20 70 30 78 20 71 B8 89 41 46 FF F7 73 FF 05 46 DA F7 72 FD 40 05 07 D5 38 88 B0 F5 70 4F 02 D1 30 78 01 28 00 D0 00 25 70 78 A8 42 00 D2 05 46 16 20 20 73 25 74 01 20 BD E8
9:02:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 F9 09 81 80 F0 81 2D E9 F8 4F 04 46 DD F8 28 80 0F 00 92 46 99 46 0A D0 3D 78 4D B1 05 EB 45 00 81 00 18 46 D9 F7 FF F8 06 00 A7 D0 01 E0 00 25 00 26 01 20 20 70 A5 80 A6 60 00 24 11 E0 00 BF CD F8 00 80 78 68 4B 46 00 EB 44 01 04 EB 44 00 06 EB 80 00 52 46 FF F7 A6 FF 00 28 8E D0 64 1C E4 B2 AC 42 EC D3 01 20 88 E7 00 78 BF 49 31 F8 10 00 03 F0 7A B9 38 B5 04 46 00 78 BB 49 31 F8 10 00 D4 F8
9:02:20 AM
9:02:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 FA 09 81 80 8C 10 00 91 69 46 03 F0 8B F9 00 28 03 D0 00 98 C4 F8 8C 00 01 20 38 BD 2D E9 F7 4F 04 46 94 B0 0D 46 00 78 08 F0 DA FE 08 B1 01 27 0D E0 05 27 13 A9 14 20 DE F7 2C FD 18 B1 BD F8 4C 00 00 B9 07 27 2A F0 EF FB 00 B9 07 27 4F F0 01 0A 84 F8 89 A0 94 F8 8A 00 10 B1 01 28 7D D1 13 E0 20 46 FF F7 C1 FF 04 F1 88 04 80 B2 A0 60 85 F8 00 A0 A8 80 4F F0 00 00 A8 60 84 F8 02 A0 60 60 E0 70
9:02:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 FB 09 81 80 E0 60 60 70 37 E1 4F F0 01 09 20 46 FF F7 B1 FF 00 28 61 D0 D4 F8 8C 00 03 F0 87 F8 5F EA 00 08 F7 D0 98 F8 08 00 FB F7 AB FA 06 00 F1 D0 70 68 00 B1 00 78 08 90 B0 68 00 B1 00 78 83 46 00 20 0E 90 07 90 00 2D E4 D0 94 F8 8B 00 05 28 4A D2 DF E8 00 F0 03 4A 6B A2 D9 00 30 21 16 98 D9 F7 60 F8 03 90 00 28 D4 D0 02 20 28 70 04 20 A8 80 03 98 A8 60 03 98 12 21 11 22 01 70 03 98 98 F8
9:02:21 AM
9:02:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 FC 09 81 80 08 10 81 80 03 99 B0 78 0A 73 03 99 08 74 06 20 AD F8 24 00 08 F1 02 00 0A 90 03 98 09 A9 18 30 16 9A F8 F7 F1 FB 00 28 B3 D0 B9 F1 00 0F 02 D0 00 20 07 90 06 E0 18 21 16 98 D9 F7 32 F8 07 90 00 28 A6 D0 03 99 02 20 81 F8 24 00 03 99 08 85 03 99 07 98 C8 62 00 E0 82 E0 84 F8 8B A0 00 20 84 F8 89 00 07 9D BB E0 B9 F1 00 0F 1B D1 08 98 C8 B1 00 EB 40 00 80 04 01 0C 16 98 D9 F7 11 F8
9:02:22 AM
9:02:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 FD 09 81 80 00 28 6D D0 85 F8 00 A0 08 99 A9 80 04 F1 88 04 A8 60 02 21 E1 70 4F F0 00 01 E1 60 61 70 A4 F1 88 04 05 46 9C E0 00 20 EC E7 70 68 00 28 57 D0 D4 F8 94 10 40 68 01 EB 41 01 00 EB 41 00 03 90 0E 22 41 46 0F A8 D1 F7 6B F9 03 98 B8 F8 00 10 90 F9 00 00 41 EA C0 00 80 B2 12 A9 03 F0 60 FE 16 98 CD E9 00 07 0F AB 29 46 20 46 03 9A FF F7 2C FE A8 B3 D4 F8 94 00 0C 35 40 1C C4 F8 94 00
9:02:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 FE 09 81 80 08 99 88 42 04 D3 03 20 84 F8 8B 00 07 9D 0C 35 00 20 84 F8 89 00 63 E0 B9 F1 00 0F 0C D1 BB F1 00 0F 09 D0 0B EB 4B 00 80 04 01 0C 04 D0 16 98 D8 F7 B7 FF A0 B1 00 E0 00 20 85 F8 00 A0 A5 F8 04 B0 A8 60 05 46 BB F1 00 0F 0A D0 B0 68 40 68 38 B1 04 20 84 F8 8B 00 00 20 C4 F8 94 00 0D E0 44 E0 04 F1 88 04 00 20 E0 70 60 68 00 F1 01 00 60 60 4F F0 01 00 A4 F1 88 04 0E 90 4F F0 00 00
9:02:23 AM
9:02:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 01 FF 09 81 80 84 F8 89 00 26 E0 B0 68 80 B3 40 68 D4 F8 94 10 00 97 00 EB 41 01 42 46 28 46 16 9B FF F7 41 FE 20 B3 04 F1 88 04 00 21 61 70 E0 68 0C 35 00 F1 01 00 E0 60 A4 F1 88 04 58 45 11 D3 04 F1 88 04 4F F0 01 00 E1 70 0E 90 60 68 00 F1 01 00 60 60 A4 F1 88 04 20 46 FF F7 8C FE 08 B9 84 F8 89 A0 B9 F1 00 0F 07 D1 02 E0 A0 C1 01 00 07 E0 0E 98 00 28 3F F4 E7 AE 01 20 17 B0 BD E8 F0 8F 00 20
9:02:24 AM
9:02:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 00 09 81 80 FA E7 70 B5 04 46 0D 46 01 21 84 F8 89 10 10 46 18 21 D8 F7 46 FF 00 28 10 D0 02 21 29 70 A9 80 A8 60 61 68 59 B1 0F 21 01 70 61 68 09 78 01 71 12 21 01 73 61 68 49 88 01 82 01 20 70 BD 00 20 70 BD 01 28 07 D0 02 28 07 D0 03 28 07 D0 04 28 07 D0 00 20 70 47 F9 48 70 47 F9 48 70 47 F9 48 70 47 F9 48 70 47 10 B5 0B 46 01 21 80 F8 89 10 01 78 05 29 0B D2 40 78 FF F7 E3 FF 01 00 06 D0
9:02:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 01 09 81 80 18 46 F8 F7 C1 FA 00 28 00 D0 01 20 10 BD 00 20 10 BD 2D E9 FF 41 05 46 01 20 0E 46 85 F8 89 00 17 46 48 21 10 46 D8 F7 FC FE 04 00 36 D0 02 20 30 70 06 20 B0 80 B4 60 A8 68 00 28 2C D0 04 21 AD F8 00 10 01 90 3A 46 69 46 20 46 F8 F7 D4 FA 00 28 21 D0 12 20 20 73 A9 68 3A 46 89 88 21 82 20 76 A9 68 C9 88 A1 83 11 21 84 F8 24 10 A9 68 09 7A 84 F8 28 10 0F 21 84 F8 30 10 A9 68 49 7A
9:02:25 AM
9:02:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 02 09 81 80 84 F8 34 10 AD F8 08 00 A8 68 02 A9 0A 30 03 90 04 F1 3C 00 F8 F7 78 FA 04 B0 B0 E5 00 20 FB E7 70 B5 0C 46 01 21 80 F8 89 10 01 78 15 46 05 29 01 D3 00 20 70 BD 80 78 08 F0 D0 FE 01 46 2A 46 20 46 BD E8 70 40 F8 F7 5F BA 10 B5 01 21 80 F8 89 10 02 78 05 2A 10 D2 90 F8 B8 10 16 29 0C D1 B0 F8 BC 10 07 29 08 D1 10 F1 BE 01 05 D0 90 F8 C4 10 02 29 01 D0 05 29 01 D9 00 20 10 BD 10 46
9:02:26 AM
9:02:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 03 09 81 80 08 F0 CC FE 00 28 F9 D0 01 20 10 BD 70 B5 04 46 AD F5 AA 6D 01 20 84 F8 89 00 20 78 0D 46 16 46 05 28 03 D3 00 20 0D F5 AA 6D 70 BD 68 46 27 F0 77 FE 00 28 F7 D0 E0 78 41 1E 03 29 08 D8 40 1E 00 EB C0 01 68 46 00 EB 41 00 B0 F8 5A 12 05 E0 05 28 08 D3 BD F8 90 12 0D F1 36 00 AD F8 48 15 00 F5 17 70 04 E0 08 20 AD F8 48 05 97 48 40 68 CD F8 4C 05 32 46 0D F5 A9 61 28 46 F8 F7 04 FA
9:02:27 AM
9:02:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 04 09 81 80 00 28 D0 D0 01 20 CE E7 01 22 80 F8 89 20 16 20 08 70 02 20 08 71 10 46 70 47 3E B5 0C 46 01 21 80 F8 89 10 15 46 00 78 02 A9 08 F0 92 FC 9D F8 08 00 18 B1 01 28 04 D0 00 20 3E BD 4F F6 03 70 01 E0 4F F6 05 70 02 F0 AB FE 00 28 F5 D0 06 21 80 1C AD F8 00 10 01 90 2A 46 69 46 20 46 F8 F7 D3 F9 00 28 E9 D0 01 20 3E BD 10 B5 C1 68 D1 F8 A0 20 53 1C 0C D0 52 1C C1 F8 A0 20 C2 68 01 21
9:02:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 05 09 81 80 A0 32 00 20 28 F0 0D F9 00 28 00 D0 01 20 10 BD 00 20 10 BD 10 B5 C8 B0 0C 46 00 78 46 A9 08 F0 58 FC 00 28 13 D0 9D F8 18 11 68 46 27 F0 A2 FE 00 28 0C D0 BD F8 26 20 09 A9 10 2A 00 D3 10 22 22 80 32 B1 09 1D A0 1C D0 F7 6A FF 01 20 48 B0 10 BD 00 20 FB E7 10 B5 C8 B0 0C 46 00 78 46 A9 08 F0 37 FC 00 28 F2 D0 9D F8 18 11 68 46 27 F0 81 FE 00 28 EB D0 22 88 8A B1 10 2A 00 D3 10 22
9:02:28 AM
9:02:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 06 09 81 80 AD F8 26 20 0A A8 A1 1C D0 F7 4A FF 9D F8 18 11 68 46 27 F0 7E FE 00 28 D9 D0 01 20 D7 E7 00 20 D5 E7 70 B5 84 68 A4 B0 05 46 64 B3 B4 F8 5E 00 48 B3 40 28 27 D8 14 F1 60 00 24 D0 5E 34 16 A9 28 46 FF F7 A7 FF 00 28 1E D0 16 AE 68 46 D2 F7 01 FD 22 88 A1 1C 68 46 D3 F7 5A F8 BD F8 58 20 B1 1C 68 46 D3 F7 54 F8 1F A9 68 46 D3 F7 88 F8 B5 F8 BC 00 10 28 06 D1 10 22 1F A9 05 F1 BE 00
9:02:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 07 09 81 80 D0 F7 E2 FE 10 B1 00 20 24 B0 70 BD 01 20 FB E7 70 B5 84 68 A6 B0 05 46 64 B3 B4 F8 5E 00 48 B3 40 28 27 D8 14 F1 60 00 24 D0 5E 34 17 A9 28 46 FF F7 70 FF 00 28 1E D0 17 AE 68 46 D3 F7 F8 F8 22 88 A1 1C 68 46 D4 F7 30 F9 BD F8 5C 20 B1 1C 68 46 D4 F7 2A F9 20 A9 68 46 D4 F7 5E F9 B5 F8 BC 00 14 28 06 D1 14 22 20 A9 05 F1 BE 00 D0 F7 AB FE 10 B1 00 20 26 B0 70 BD 01 20 FB E7 38 B5
9:02:29 AM
9:02:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 08 09 81 80 02 46 80 68 70 B1 B0 F8 5E 10 59 B1 40 29 09 D8 10 F1 60 03 06 D0 D4 68 24 B1 B2 F8 BC 30 5E 30 11 2B 01 D0 00 20 38 BD BE 32 80 1C 00 94 FC F7 A2 F9 00 28 F7 D0 01 20 38 BD 00 00 78 45 06 00 88 45 06 00 98 45 06 00 A8 45 06 00 98 5C 06 00 10 B5 81 78 03 29 05 D0 04 29 06 D0 05 29 07 D0 00 20 10 BD FF F7 5D FF 04 E0 FF F7 91 FF 01 E0 FF F7 C5 FF 00 28 F4 D0 01 20 10 BD 2D E9 F0 41
9:02:30 AM
9:02:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 09 09 81 80 06 46 80 68 A8 B0 0F 46 90 46 B8 B3 81 8B A9 B3 40 29 34 D8 1E 30 32 D0 0C 21 10 46 D8 F7 01 FD 05 00 2C D0 B4 68 17 A9 1C 34 30 46 FF F7 F2 FE 00 28 20 D0 17 AE 68 46 D2 F7 4C FC 22 88 A1 1C 68 46 D2 F7 A5 FF BD F8 5C 20 B1 1C 68 46 D2 F7 9F FF 24 A9 68 46 D2 F7 D3 FF 10 20 AD F8 88 00 24 A8 23 90 42 46 22 A9 28 46 F8 F7 8D F8 00 28 01 D0 01 20 3D 60 28 B0 BD E8 F0 81 FF E7 00 20
9:02:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 0A 09 81 80 F9 E7 2D E9 F0 41 06 46 80 68 AA B0 0F 46 90 46 B0 B3 81 8B A1 B3 40 29 33 D8 1E 30 31 D0 0C 21 10 46 D8 F7 BE FC 05 00 2B D0 B4 68 18 A9 1C 34 30 46 FF F7 AF FE 00 28 20 D0 18 AE 68 46 D3 F7 37 F8 22 88 A1 1C 68 46 D4 F7 6F F8 BD F8 60 20 B1 1C 68 46 D4 F7 69 F8 25 A9 68 46 D4 F7 9D F8 14 20 AD F8 8C 00 25 A8 24 90 42 46 23 A9 28 46 F8 F7 4A F8 00 28 01 D0 01 20 3D 60 2A B0 BB E7
9:02:31 AM
9:02:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 0B 09 81 80 FF E7 00 20 FA E7 F0 B5 04 46 80 68 8D B0 0E 46 17 46 68 B3 81 8B 59 B3 40 29 29 D8 1E 30 27 D0 E0 68 28 B3 0C 21 10 46 D8 F7 7B FC 05 00 1F D0 D4 E9 02 01 0B AA CD E9 00 12 81 8B 1E 30 11 23 06 AA FC F7 6F F8 00 28 10 D0 20 46 FF F7 4D FE 11 20 AD F8 10 00 06 A8 05 90 3A 46 04 A9 28 46 F8 F7 12 F8 00 28 01 D0 01 20 35 60 0D B0 F0 BD 00 20 FB E7 10 B5 83 78 03 2B 05 D0 04 2B 06 D0
9:02:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 0C 09 81 80 05 2B 07 D0 00 20 10 BD FF F7 38 FF 04 E0 FF F7 78 FF 01 E0 FF F7 B7 FF 00 28 F4 D0 01 20 10 BD 70 B5 04 46 90 F8 B8 00 0D 46 16 46 16 28 0D D1 20 46 FF F7 0D FF 48 B1 32 46 29 46 20 46 FF F7 D9 FF 18 B1 20 78 2A F0 5C FB 20 B1 20 78 2A F0 14 FB 00 20 70 BD 01 20 70 BD 10 B5 C6 B0 0C 46 11 46 68 46 27 F0 C6 FC 00 28 06 D0 22 22 0D F1 4A 01 20 46 D0 F7 94 FD 01 20 46 B0 10 BD 10 B5
9:02:32 AM
9:02:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 0D 09 81 80 04 46 90 F8 B8 00 9C B0 16 28 24 D1 20 78 1A A9 08 F0 5F FA 00 28 1F D0 9D F8 68 20 09 A9 20 46 FF F7 DB FF 00 28 17 D0 BD F8 24 00 10 28 12 D1 B4 F8 BC 00 18 28 0E D3 30 28 0C D8 41 07 0A D1 49 1E 01 EB D0 01 12 AB 04 F1 BE 02 0D F1 26 00 D2 F7 EE FA 10 B1 00 20 1C B0 10 BD B4 F8 BC 00 12 A9 08 38 82 B2 AD F8 00 20 0D F1 02 00 D0 F7 57 FD 69 46 20 46 FF F7 EE FD 00 28 EC D0 01 20
9:02:33 AM
9:02:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 0E 09 81 80 EA E7 10 B5 01 24 80 F8 89 40 00 23 0B 60 90 F8 3A 30 01 2B 02 D0 02 2B 06 D1 02 E0 FF F7 80 FF 01 E0 FF F7 AC FF 00 B9 00 24 20 46 10 BD 00 00 2D E9 F0 41 0D 46 01 27 88 B0 00 21 04 46 80 F8 89 10 90 F8 8A 00 90 46 30 B1 01 28 0E D0 00 27 38 46 08 B0 BD E8 F0 81 01 20 28 70 A8 80 04 F1 88 04 A9 60 A0 70 C4 E9 01 10 F1 E7 D4 E9 23 01 88 42 2C D2 18 21 10 46 D8 F7 93 FB 06 00 26 D0
9:02:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 0F 09 81 80 02 20 28 70 A8 80 12 20 AE 60 30 70 13 48 01 88 B1 80 02 88 10 21 04 A8 18 F0 82 F8 AD F8 04 00 00 28 D6 D0 04 A8 02 90 42 46 01 A9 06 F1 0C 00 F7 F7 2A FF 00 28 CC D0 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 03 D3 01 20 02 E0 00 20 BF E7 00 20 84 F8 89 00 BA E7 00 00 C8 D8 06 00 10 B5 40 F2 96 21 D0 F7 9F FD 01 20 10 BD 0E B5 02 A9 40 F2 96 22 CD E9 00 21 01 46 00 23 07 20
9:02:34 AM
9:02:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 10 09 81 80 F1 F7 2D FF 00 28 00 D0 01 20 0E BD 0E B5 02 A9 40 F2 96 22 CD E9 00 21 01 46 00 23 07 20 F1 F7 5E FF 00 28 00 D0 01 20 0E BD F0 B5 AD F5 27 7D 01 26 04 46 80 F8 89 60 0D 46 17 46 68 46 FF F7 D6 FF 00 28 1C D0 94 F8 88 00 6A 46 80 1E C1 B2 00 20 01 29 17 D0 02 29 50 D0 61 D8 86 48 50 F8 21 40 EC B3 A0 F1 0C 00 3B 46 30 F8 11 00 10 44 81 4A A2 F1 06 02 32 F8 11 20 01 46 28 46 A0 47
9:02:35 AM
9:02:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 11 09 81 80 0D F5 27 7D F0 BD BD F8 02 10 05 29 00 D3 05 21 94 F8 8A 30 13 B1 01 2B 25 D1 0A E0 2E 70 A9 80 04 F1 88 04 A8 60 A6 70 C4 E9 01 01 A4 F1 88 04 15 E0 D4 E9 23 01 88 42 32 D2 C0 EB C0 00 00 EB 80 00 02 EB 40 01 09 1D 3A 46 28 46 F7 F7 FD FF 00 28 D5 D0 D4 F8 8C 00 40 1C C4 F8 8C 00 00 E0 1E E0 01 20 00 E0 00 20 D4 E9 23 12 91 42 01 D3 01 21 00 E0 00 21 84 F8 89 10 C1 E7 94 F8 8A 20
9:02:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 12 09 81 80 00 21 00 2A EF D1 2E 70 A9 80 04 F1 88 04 A8 60 A6 70 60 60 A0 60 A4 F1 88 04 4F F0 01 00 E7 E7 00 20 AD E7 F0 B5 04 46 AD F5 27 7D 01 20 84 F8 89 00 68 46 FF F7 5B FF 00 28 6F D0 94 F8 88 00 80 1E 10 F0 FF 00 04 D0 01 28 0B D0 02 28 75 D1 76 E0 94 F8 B8 00 09 28 7D D1 94 F8 BC 00 8D F8 00 00 66 E0 94 F8 B8 00 16 28 0F D0 06 28 0D D0 94 F8 66 00 E0 BB 94 F8 67 00 01 28 6B D1 B4 F8
9:02:36 AM
9:02:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 13 09 81 80 6E 00 A8 BB 00 20 AD F8 02 00 52 E0 04 F1 66 00 07 46 F8 F7 0F FE 4F F6 FF 75 06 46 A8 42 5A D0 38 46 F8 F7 EF FD 01 46 C4 F8 8C 00 A8 42 52 D0 05 2E 01 D2 30 46 00 E0 05 20 B4 F8 BC 60 0D 46 20 2E 00 D9 20 26 05 2D 45 D2 BD F8 02 10 81 42 01 D0 AD F8 02 00 38 46 F8 F7 C9 FD 02 00 68 46 04 F1 BE 01 05 D0 01 2A 0C D0 02 2A 33 D1 16 E0 31 E0 C5 EB C5 02 02 EB 82 02 00 EB 42 00 86 80
9:02:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 14 09 81 80 80 1D 07 E0 C5 EB C5 02 02 EB 82 02 00 EB 42 00 C6 84 28 30 32 46 D0 F7 C3 FB 0A E0 0F E0 C5 EB C5 02 02 EB 82 02 00 EB 42 00 B4 F8 BC 10 A0 F8 48 10 68 46 FF F7 EA FE 00 28 00 D0 01 20 1F E7 94 F8 66 00 38 B9 94 F8 67 00 01 28 03 D1 B4 F8 6E 00 00 28 F2 D0 00 20 12 E7 00 B5 AD F5 27 7D 68 46 FF F7 BD FE 00 28 02 D0 68 46 FF F7 CE FE 0D F5 27 7D 00 BD 00 00 AC 5C 06 00 2D E9 F0 4F
9:02:37 AM
9:02:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 15 09 81 80 04 46 90 F8 88 00 00 27 80 1E C6 B2 B2 48 93 B0 0D 46 30 F8 16 90 0A 30 93 46 30 F8 16 A0 05 2E 75 D8 68 46 00 F0 5A F9 00 28 18 D0 00 20 6A 46 4F F0 01 08 03 2E 15 D0 04 2E 4A D0 05 2E 66 D2 A5 48 14 30 50 F8 26 60 96 B3 02 EB 09 01 5B 46 52 46 28 46 B0 47 07 46 84 F8 89 80 38 46 13 B0 BD E8 F0 8F BD F8 04 10 02 29 00 D3 02 21 94 F8 8A 30 13 B1 01 2B 23 D1 0C E0 85 F8 00 80 A9 80
9:02:38 AM
9:02:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 16 09 81 80 04 F1 88 04 A8 60 84 F8 02 80 C4 E9 01 01 A4 F1 88 04 28 E0 D4 E9 23 01 88 42 38 D2 00 EB 40 00 02 EB C0 01 89 1D 5A 46 28 46 F7 F7 95 FE 29 E0 2D E0 00 BF D4 F8 8C 00 40 1C C4 F8 8C 00 12 E0 D4 E9 23 01 88 42 20 D3 5F F0 01 00 84 F8 89 00 C4 E7 BD F8 36 10 01 B1 01 21 94 F8 8A 30 00 2B CB D0 01 2B 01 D0 01 27 EA E7 D4 E9 23 01 88 42 0D D2 00 EB C0 00 02 EB 40 01 38 31 5A 46 28 46
9:02:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 17 09 81 80 F7 F7 93 FE 00 28 AA D0 D4 E7 00 20 DE E7 00 20 A5 E7 2D E9 F0 47 04 46 94 B0 01 20 84 F8 89 00 68 46 00 F0 DB F8 00 28 77 D0 94 F8 88 00 6A 4A 80 1E C1 B2 00 27 32 F8 11 30 0A 32 6D 46 32 F8 11 20 6B 44 04 F1 BC 01 04 F1 66 0A 4F F6 FF 79 05 28 7C D2 DF E8 00 F0 09 09 03 0D 62 00 B4 F8 BC 00 B4 28 01 D2 00 28 7B D1 18 46 D0 F7 D8 FA 95 E0 B4 F8 6E 00 20 B1 B4 F8 70 00 02 28 70 D1
9:02:39 AM
9:02:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 18 09 81 80 04 E0 CD F8 06 70 AD F8 04 70 88 E0 94 F8 B8 00 14 28 66 D1 50 46 F8 F7 CD FC 4F 46 06 46 B8 42 5F D0 50 46 F8 F7 AE FC C4 F8 8C 00 B8 42 58 D0 02 2E 00 D3 02 26 87 B2 02 2F 52 D2 BD F8 04 00 B0 42 01 D0 AD F8 04 60 50 46 F8 F7 90 FC 10 B1 01 28 46 D1 10 E0 07 EB 47 00 05 EB C0 00 D4 F8 BC 10 C0 F8 06 10 D4 F8 C0 10 C0 F8 0A 10 D4 F8 C4 10 C0 F8 0E 10 52 E0 07 EB 47 00 05 EB C0 00
9:02:40 AM
9:02:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 19 09 81 80 D4 F8 BC 10 C0 F8 12 10 D4 F8 C0 10 C0 F8 16 10 D4 F8 C4 10 C0 F8 1A 10 41 E0 23 E0 B4 F8 6E 00 18 B3 94 F8 B8 00 16 28 1B D1 50 46 F8 F7 76 FC 4E 46 80 46 B0 42 14 D0 50 46 F8 F7 58 FC C4 F8 8C 00 B0 42 0D D0 B8 F1 00 0F 03 D0 00 E0 08 E0 4F F0 01 08 B4 F8 BC 60 80 B2 0F 2E 00 D9 0F 26 30 B1 00 20 14 B0 BD E8 F0 87 4F F0 00 08 46 46 BD F8 36 00 40 45 01 D0 AD F8 36 80 AD F8 38 60
9:02:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 1A 09 81 80 B8 F1 00 0F 0A D0 05 F1 3A 00 32 46 04 F1 BE 01 D0 F7 46 FA A8 19 80 F8 3A 70 00 E0 0E 97 68 46 00 F0 23 FB 00 28 DD D0 01 20 DB E7 00 B5 93 B0 68 46 00 F0 29 FB 00 28 02 D0 68 46 00 F0 15 FB 13 B0 00 BD 10 B5 01 21 80 F8 89 10 00 22 10 46 00 F0 55 FB 01 20 10 BD B8 5C 06 00 0E B5 02 AA 4A 21 CD E9 00 12 0A 46 01 46 00 23 08 20 F1 F7 76 FC 00 28 00 D0 01 20 0E BD 10 B5 BE B0 FE 48
9:02:41 AM
9:02:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 1B 09 81 80 FF F7 EC FF 00 28 66 D0 36 20 3D AC CD E9 00 04 02 46 00 23 2F A9 0E 20 F1 F7 61 FC 00 28 5A D0 A0 20 CD E9 00 04 02 46 00 23 02 A9 0D 20 F1 F7 56 FC 00 28 4F D0 0E 20 CD E9 00 04 02 46 00 23 2A A9 0A 20 F1 F7 4B FC 00 28 44 D0 04 20 CD E9 00 04 02 46 00 23 2E A9 25 20 F1 F7 40 FC 00 28 39 D0 E5 4C 60 88 08 B9 B4 20 60 80 80 B2 4F F4 7A 71 48 43 A0 65 BD F8 B4 10 4F F4 61 60 09 B1
9:02:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 1C 09 81 80 81 42 01 D9 AD F8 B4 00 BD F8 BA 10 81 42 00 D8 09 B9 AD F8 BA 00 BD F8 BA 00 BD F8 B4 10 88 42 00 D8 08 46 4F F4 7A 71 48 43 20 65 BD F8 24 00 A4 F8 9E 00 D0 48 44 22 19 A9 A0 30 D0 F7 1B FA CD 48 2A 22 2F A9 74 30 D0 F7 15 FA D4 F8 E4 00 15 F0 98 FD 01 20 3E B0 10 BD 70 B5 D2 B0 05 46 28 F0 89 F8 C4 4C 00 26 61 6D 81 42 01 D1 00 2D 7A D0 60 65 02 A8 FF F7 71 FF 00 28 75 D0 36 20
9:02:42 AM
9:02:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 1D 09 81 80 51 AD CD E9 00 05 02 46 00 23 42 A9 0E 20 F1 F7 E6 FB 00 28 69 D0 A0 20 CD E9 00 05 02 46 00 23 15 A9 0D 20 F1 F7 DB FB 00 28 5E D0 0E 20 CD E9 00 05 02 46 00 23 3D A9 0A 20 F1 F7 D0 FB 00 28 53 D0 04 20 CD E9 00 05 02 46 00 23 41 A9 25 20 F1 F7 C5 FB 00 28 48 D0 BD F8 0A 00 10 B9 B4 20 AD F8 0A 00 BD F8 00 11 4F F4 61 60 09 B1 81 42 01 D9 AD F8 00 01 BD F8 06 11 81 42 00 D8 09 B9
9:02:43 AM
9:02:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 1E 09 81 80 AD F8 06 01 BD F8 06 51 BD F8 00 01 85 42 00 D8 05 46 4F F4 7A 70 45 43 B4 F8 9E 00 BD F8 70 10 88 42 16 D1 94 48 44 22 2C A9 A0 30 D0 F7 0C F9 78 B9 91 48 2A 22 42 A9 74 30 D0 F7 05 F9 40 B9 4A 22 8D 49 02 A8 D0 F7 FF F8 10 B9 20 6D A8 42 0A D0 04 F1 48 04 A0 78 40 F0 06 00 A0 70 D4 F8 9C 00 15 F0 0F FD 01 26 30 46 52 B0 70 BD 01 46 00 20 0A 88 A2 F5 7F 43 FF 3B 00 D1 08 20 8A 78
9:02:44 AM
9:02:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 1F 09 81 80 FF 2A 01 D1 40 F0 04 00 CA 78 FF 2A 01 D1 40 F0 02 00 0B 79 FF 2B 01 D1 40 F0 01 00 0F 28 09 D0 0C 28 12 D0 08 28 04 D1 FE 2A 01 D0 FD 2A 00 D1 09 20 70 47 4A 79 FF 2A 05 D0 8A 79 FF 2A 02 D0 C9 79 FF 29 F5 D1 FF 20 70 47 FE 2A 01 D0 FD 2A FA D1 0D 20 70 47 2D E9 F0 41 05 46 DD E9 07 64 10 46 00 22 06 9F 32 60 72 60 32 81 22 60 62 60 22 81 99 42 1A D0 09 29 0F D0 05 DC 49 B1 01 29
9:02:45 AM
9:02:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 20 09 81 80 07 D0 08 29 21 D1 08 E0 0C 29 0B D0 0D 29 1C D1 08 E0 01 2B 0A D0 C3 B9 08 E0 09 2B 06 D0 08 2B 13 D1 03 E0 0D 2B 01 D0 0C 2B 0E D1 01 46 32 46 28 46 DE F7 73 FC 40 B1 22 46 39 46 28 46 DE F7 6D FC 10 B1 01 20 BD E8 F0 81 00 20 FB E7 2D E9 F0 41 A0 B0 0C 46 16 46 1F 46 1D AB 1C AA 16 A9 DD F8 98 80 F7 F7 A9 F9 00 28 7D D0 1B AB 1A AA 0C A9 20 46 F7 F7 A1 F9 00 28 75 D0 16 A8 FF F7
9:02:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 21 09 81 80 76 FF 04 46 0C A8 FF F7 72 FF 05 46 FF 2C 6B D0 FF 2D 69 D0 1F AA 06 A9 40 46 D7 F7 7B FD 13 AA 03 A9 0C A8 8D E8 07 00 2B 46 16 AA 21 46 06 A8 FF F7 91 FF 00 28 7C D0 10 2C 55 D2 DF E8 04 F0 28 28 9D 9D 9D 9D 9D 9D 28 28 28 28 28 28 08 28 9D F8 34 00 9D F8 5C 10 42 1A 9D F8 1C 20 02 D4 8A 42 06 D8 14 E0 8A 42 01 D9 82 42 03 D2 8A 42 0E D2 82 42 0C D8 12 A9 03 A8 D7 F7 2F FC 00 28
9:02:46 AM
9:02:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 22 09 81 80 79 D0 1E 49 12 98 08 44 03 A9 12 90 D7 F7 C2 FC 9D F8 74 00 8D F8 2F 00 BD F8 70 00 01 12 8D F8 2D 10 8D F8 2E 00 BD F8 0C 00 01 0A 8D F8 24 10 8D F8 25 00 9D F8 0E 00 8D F8 26 00 9D F8 0F 00 8D F8 27 00 9D F8 10 00 8D F8 28 00 9D F8 11 00 8D F8 29 00 9D F8 12 00 8D F8 2A 00 9D F8 13 00 8D F8 2B 00 00 21 00 E0 47 E0 9D F8 6C 00 8D F8 2C 10 8D F8 47 00 03 E0 B4 48 00 10 80 C5 F6 FF
9:02:47 AM
9:02:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 23 09 81 80 BD F8 68 00 02 12 8D F8 45 20 8D F8 46 00 BD F8 4C 00 02 0A 8D F8 3C 20 8D F8 3D 00 9D F8 4E 00 8D F8 3E 00 9D F8 4F 00 8D F8 3F 00 9D F8 50 00 00 E0 20 E0 8D F8 40 00 9D F8 51 00 8D F8 41 00 9D F8 52 00 8D F8 42 00 9D F8 53 00 8D F8 43 00 8D F8 44 10 16 A9 09 A8 F7 F7 53 F9 0C A9 0F A8 F7 F7 4F F9 31 46 16 A8 D7 F7 B8 FB 39 46 0C A8 D7 F7 B4 FB 01 20 20 B0 25 E7 00 20 FB E7 7F B5
9:02:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 24 09 81 80 00 26 1E 80 15 46 1C 46 00 92 02 AB 01 AA FF F7 1E FF 00 28 08 D0 03 A9 28 46 D7 F7 9F FB DD E9 01 01 88 42 02 D3 00 20 04 B0 70 BD 03 9A 82 42 04 D3 8A 42 02 D8 01 20 20 80 00 E0 26 80 01 20 F2 E7 2D E9 FF 41 00 26 85 88 07 46 30 46 00 2D 1D D0 00 24 80 46 17 E0 68 46 D7 F7 FF FB 04 EB 44 00 07 EB C0 00 00 F1 12 01 AD F8 0C 80 80 1D 03 AB 6A 46 FF F7 C3 FF 20 B1 BD F8 0C 00 01 28
9:02:48 AM
9:02:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 25 09 81 80 05 D0 02 26 64 1C A4 B2 AC 42 E5 D3 F0 B2 04 B0 D9 E6 10 B5 A8 B9 F8 4C 94 F8 4A 00 C0 07 10 D0 00 23 02 22 01 21 D4 F8 E4 00 15 F0 48 FC 94 F8 4A 00 01 07 03 D5 20 F0 01 00 84 F8 4A 00 01 20 10 BD 00 20 10 BD 10 B5 02 28 01 D0 03 28 11 D1 E9 48 90 F8 4A 10 09 07 04 D5 01 78 67 29 09 D0 68 29 07 D0 D0 F8 E4 00 02 21 15 F0 54 FC 08 B1 01 20 10 BD 00 20 10 BD DF 48 10 B5 D0 F8 E4 00
9:02:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 26 09 81 80 D0 F8 B8 01 0B F0 08 FA 00 28 00 D0 01 20 10 BD D9 48 10 B5 D0 F8 E4 00 15 F0 5B FB 80 07 01 D5 01 20 10 BD 00 20 10 BD D3 49 10 B5 08 78 65 28 07 D0 66 28 05 D0 67 28 03 D0 68 28 01 D0 04 20 10 BD D1 F8 E4 00 15 F0 24 FB 07 28 0B D2 DF E8 00 F0 04 0A 08 06 08 08 08 00 00 20 10 BD 01 20 10 BD 02 20 10 BD 03 20 10 BD 0E B5 02 AA 4A 21 CD E9 00 12 0A 46 01 46 00 23 08 20 F1 F7 AF F9
9:02:49 AM
9:02:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 27 09 81 80 00 28 00 D0 01 20 0E BD 10 B5 04 46 4A 21 CF F7 CB FF 65 20 20 70 01 20 10 BD B7 48 10 B5 D0 F8 E4 00 15 F0 CC FA 00 28 00 D0 01 20 10 BD B2 48 D0 F8 E4 00 15 F0 CD BA 70 B5 06 46 AE 4C 00 20 10 80 D4 F8 E4 00 15 46 D0 F8 B8 21 AA B1 92 F8 32 20 0A B1 0A 70 04 E0 15 F0 C4 FA 68 B1 01 20 28 80 D4 F8 E4 00 10 22 D0 F8 B8 11 30 46 01 F2 35 11 CF F7 D5 FE 01 20 70 BD 00 20 70 BD 70 B5
9:02:50 AM
9:02:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 28 09 81 80 9D 4C 05 46 04 2D D4 F8 E4 00 48 D2 DF E8 05 F0 02 40 49 3C 22 78 66 2A 41 D0 03 DC 22 B3 01 2A 3D D1 05 E0 01 25 67 2A 0A D0 68 2A 37 D1 1C E0 01 29 34 D1 00 23 1A 46 19 46 15 F0 80 FB 2E E0 8D 48 FF F7 FE FE 01 28 29 D0 94 F8 4A 00 01 07 05 D4 84 F8 4B 50 40 F0 08 00 84 F8 4A 00 D4 F8 E4 00 0C E0 0C F0 5E FF 19 E0 94 F8 4A 10 0A 07 05 D4 04 F1 4A 04 41 F0 08 01 65 70 21 70 D0 F8
9:02:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 29 09 81 80 B8 11 91 F8 32 10 51 B1 00 21 15 F0 84 FB E9 E7 13 46 00 22 01 21 15 F0 52 FB 00 28 00 D0 01 20 70 BD 00 23 1A 46 19 46 15 F0 49 FB DA E7 72 4A 10 B5 3A 32 00 21 01 20 FF F7 A1 FF 00 28 05 D0 6D 48 4A 30 01 78 41 F0 10 01 01 70 10 BD 10 B5 04 46 E8 21 68 48 CF F7 00 FF 27 F0 4C FD 66 49 48 31 C1 F8 9C 40 C8 60 00 20 C8 70 08 71 48 71 88 78 20 F0 0E 00 40 F0 01 00 88 70 BD E8 10 40
9:02:51 AM
9:02:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 2A 09 81 80 3B E4 2D E9 F0 5F 5C 4C D4 F8 E4 00 15 F0 61 FA 06 46 00 20 FF F7 A1 FC D4 F8 E4 00 15 F0 39 FA 05 46 94 F8 4A 00 40 07 0C D5 B0 07 0A D4 02 21 D4 F8 E4 00 15 F0 2F FB 94 F8 4A 00 20 F0 04 00 84 F8 4A 00 94 F8 4A 00 81 07 08 D5 40 07 06 D4 05 2D 00 D0 1D B9 D4 F8 E4 00 FF F7 B8 FF 46 48 B4 F8 5C 10 5C 30 82 46 69 B1 D7 F7 63 FB A1 6D 88 42 08 D9 94 F8 4A 00 40 F0 01 00 84 F8 4A 00
9:02:52 AM
9:02:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 2B 09 81 80 50 46 D7 F7 4B FB 21 78 DF F8 EC B0 00 27 A0 46 4F F0 01 09 0B F1 6C 0B 65 29 04 D0 66 29 0E D0 67 29 3F D1 30 E0 98 F8 4A 10 40 46 C9 07 3C D0 90 F8 4B 10 03 29 38 D0 02 29 22 D1 35 E0 B0 07 33 D4 2D 48 FF F7 3D FE 01 46 01 28 98 F8 4D 20 40 46 04 D0 8A 42 25 D0 88 F8 4D 10 22 E0 01 2A 01 D0 80 F8 4D 10 90 F8 4A 10 C9 07 1D D0 90 F8 4B 10 03 29 19 D0 02 29 17 D0 06 2D 3E D0 07 2D
9:02:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 2C 09 81 80 3C D0 88 F8 4B 90 10 E0 B0 07 0E D4 1A 48 FF F7 18 FE 04 46 01 28 18 D0 98 F8 4D 10 A1 42 01 D0 88 F8 4D 40 28 46 FF F7 4E FE 98 F8 4A 00 44 46 02 28 73 D0 94 F8 4B 20 1A B3 03 21 01 2A 32 D0 02 2A 48 D0 03 2A 2D D1 74 E0 98 F8 4D 00 01 28 10 D0 98 F8 4A 10 0A 07 0A D5 21 F0 08 00 40 F0 01 01 88 F8 4C 70 88 F8 4A 10 58 46 D7 F7 D6 FA 88 F8 4D 40 40 46 B6 E7 B4 48 00 10 88 F8 4B 70
9:02:53 AM
9:02:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 2D 09 81 80 D3 E7 01 07 08 D5 20 F0 08 00 84 F8 4A 00 84 F8 4C 70 58 46 D7 F7 C2 FA 94 F8 4A 00 40 F0 01 00 84 F8 4A 00 5D E0 94 F8 4C 20 63 78 9A 42 03 D9 50 46 D7 F7 B3 FA 52 E0 03 2D 07 D0 28 46 FF F7 E8 FD 50 B3 02 20 84 F8 4B 00 4A E0 84 F8 4B 10 14 E0 58 46 1F E0 03 2D 07 D0 05 2D 11 D0 06 2D 0F D0 75 B1 01 2D E3 D0 3B E0 04 F1 4A 04 50 46 61 70 A7 70 D7 F7 92 FA 14 F8 4A 09 00 07 E8 D4
9:02:54 AM
9:02:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 2E 09 81 80 2F E0 84 F8 4B 90 00 07 09 D5 94 F8 4C 00 40 1C 84 F8 4C 00 50 46 D7 F7 85 FA 22 E0 4E E0 20 78 66 28 01 D0 67 28 1C D1 25 48 FF F7 8A FD 01 28 15 D1 16 E0 03 2D 12 D1 00 07 12 D5 B4 F8 6C 00 58 B1 58 46 D7 F7 76 FA 21 6D 88 42 07 D2 70 07 07 D5 58 46 D7 F7 62 FA 03 E0 B0 07 01 D4 84 F8 4B 70 94 F8 4A 00 C0 06 28 D5 D4 F8 E4 00 15 F0 44 F9 13 4D 64 35 38 B1 02 28 1F D0 03 28 1D D1
9:02:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 2F 09 81 80 B4 F8 64 00 50 B1 0C E0 14 F8 4A 0F 20 F0 10 00 20 70 28 46 BD E8 F0 5F D7 F7 40 BA 28 46 D7 F7 41 FA 28 46 D7 F7 46 FA 41 F2 88 31 88 42 05 D9 BD E8 F0 5F 00 22 11 46 03 20 20 E6 BD E8 F0 9F B4 48 00 10 10 B5 04 46 0E 21 CF F7 AD FD 40 F6 DB 70 20 80 4F F6 02 60 01 F0 E2 FB D0 F8 02 10 C4 F8 02 10 C0 88 E0 80 40 F2 B4 50 20 81 01 20 A0 72 B4 20 A0 81 01 20 10 BD 0E B5 02 AA 0E 21
9:02:55 AM
9:02:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 30 09 81 80 CD E9 00 12 0A 46 01 46 00 23 0A 20 F0 F7 27 FF 00 28 00 D0 01 20 0E BD 0E B5 02 AA 0E 21 CD E9 00 12 0A 46 01 46 00 23 0A 20 F0 F7 58 FF 00 28 00 D0 01 20 0E BD 2D E9 FF 47 05 46 90 F8 88 00 88 46 80 1E C4 B2 29 48 91 46 30 F8 14 60 0A 30 05 2C 30 F8 14 70 17 D8 68 46 FF F7 CE FF 00 28 0F D0 05 2C 10 D2 21 48 14 30 50 F8 24 40 5C B1 0D EB 06 01 4B 46 3A 46 40 46 A0 47 01 21 85 F8
9:02:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 31 09 81 80 89 10 04 B0 BD E8 F0 87 00 20 FA E7 1F B5 04 46 68 46 FF F7 B2 FF 00 28 1C D0 94 F8 88 00 13 49 80 1E 12 4A C0 B2 0A 32 31 F8 10 10 32 F8 10 20 0D EB 01 00 04 F1 BC 01 CF F7 72 FC BD F8 00 00 00 28 07 D0 68 46 FF F7 A7 FF 00 28 02 D0 01 20 84 F8 89 00 04 B0 10 BD 1F B5 68 46 FF F7 72 FF 00 28 F7 D0 68 46 FF F7 97 FF F3 E7 E0 5C 06 00 10 B5 04 46 90 21 CF F7 F0 FC 4F F6 04 60 01 F0
9:02:56 AM
9:02:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 32 09 81 80 4F FB 20 B1 D0 F8 02 10 21 60 C0 88 A0 80 01 20 10 BD 0E B5 02 AA 90 21 CD E9 00 12 0A 46 01 46 00 23 0B 20 F0 F7 9B FE 00 28 00 D0 01 20 0E BD 0E B5 02 AA 90 21 CD E9 00 12 0A 46 01 46 00 23 0B 20 F0 F7 CC FE 00 28 00 D0 01 20 0E BD 2D E9 F7 4F 04 46 90 F8 88 00 D0 B0 80 1E C6 B2 CB 48 0D 46 30 F8 16 70 12 30 09 2E 30 F8 16 00 4E 90 7E D8 02 A8 FF F7 CD FF 00 28 62 D0 DF F8 0C A3
9:02:57 AM
9:02:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 33 09 81 80 00 21 0D F1 08 09 4F F0 01 08 0D F5 9E 7B 0A F1 24 0A 01 2E 0A D0 02 2E 2E D0 03 2E 54 D0 04 2E 68 D0 09 2E 64 D2 5A F8 26 60 9F E0 04 91 FF 21 48 46 01 F0 81 FA E0 B1 00 88 A0 F5 7E 40 03 38 17 D0 01 28 15 D1 A0 21 CD E9 00 1B 0A 46 00 23 26 A9 0D 20 F0 F7 43 FE FF 21 26 A8 01 F0 6C FA 38 B1 01 88 4F F6 05 60 81 42 02 D1 04 A9 24 F0 DD F9 DA F8 04 60 79 E0 BD F8 14 00 00 B1 01 20
9:02:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 34 09 81 80 94 F8 8A 20 AA B3 01 2A 11 D1 D4 E9 23 01 88 42 76 D2 06 20 28 70 54 F8 8C 1F 09 EB 81 00 00 69 68 60 20 68 40 1C 44 F8 8C 09 01 20 00 E0 00 20 D4 E9 23 12 91 42 01 D3 01 21 00 E0 00 21 84 F8 89 10 53 B0 BD E8 F0 8F BD F8 1C 00 05 28 00 D3 05 20 94 F8 8A 20 62 B1 01 2A E8 D1 D4 E9 23 01 88 42 4D D2 00 EB 80 01 09 EB 81 01 16 31 02 E0 46 E0 0C E0 18 E0 28 46 52 9A F6 F7 6F FF 00 28
9:02:58 AM
9:02:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 35 09 81 80 DF D0 D4 F8 8C 00 40 1C C4 F8 8C 00 CD E7 85 F8 00 80 A8 80 04 F1 88 04 A9 60 84 F8 02 80 C4 E9 01 10 A4 F1 88 04 C0 E7 FF 21 48 46 01 F0 04 FA D0 B1 00 88 A0 F5 7E 40 04 38 15 D1 A0 20 CD E9 00 0B 02 46 00 23 26 A9 0D 20 F0 F7 C8 FD FF 21 26 A8 01 F0 F1 F9 38 B1 01 88 4F F6 05 60 81 42 02 D1 21 A9 24 F0 6D F9 DA F8 10 60 46 B1 09 EB 07 01 28 46 52 9B 4E 9A B0 47 84 F8 89 80 A0 E7
9:02:59 AM
9:02:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 36 09 81 80 00 20 9E E7 2D E9 F0 43 04 46 A5 B0 01 20 84 F8 89 00 68 46 FF F7 FD FE 00 28 78 D0 94 F8 88 00 5A 4A 80 1E C1 B2 00 25 32 F8 11 30 12 32 6F 46 32 F8 11 20 6B 44 4F F6 FF 76 04 F1 66 09 09 28 6E D2 DF E8 00 F0 05 05 09 36 05 05 05 05 05 00 04 F1 BC 01 18 46 83 E0 94 F8 B8 00 07 28 0C D0 94 F8 66 00 F0 BB 94 F8 67 00 01 28 58 D1 B4 F8 6E 00 B8 BB AD F8 0C 50 74 E0 48 46 F7 F7 0E FD
9:02:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 37 09 81 80 05 46 B0 42 4C D0 48 46 F7 F7 F1 FC C4 F8 8C 00 B0 42 45 D0 05 B1 01 25 00 04 00 0C 40 D1 BD F8 0C 00 A8 42 01 D0 AD F8 0C 50 D4 F8 BC 00 04 90 58 E0 94 F8 66 00 58 B3 48 46 F7 F7 FB FC 05 46 B0 42 2D D0 48 46 F7 F7 DD FC C4 F8 8C 00 B0 42 26 D0 05 2D 00 D3 05 25 B4 F8 BC 60 1F FA 80 F8 12 2E 00 E0 1C E0 00 D9 12 26 B8 F1 05 0F 17 D2 BD F8 14 00 A8 42 01 D0 AD F8 14 50 48 46 F7 F7
9:03:00 AM
9:03:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 38 09 81 80 B6 FC A0 B1 01 28 1A D0 02 28 09 D1 1F E0 08 E0 FF E7 94 F8 67 00 01 28 02 D1 B4 F8 6E 00 18 B1 00 20 25 B0 BD E8 F0 83 AD F8 14 50 1A E0 08 EB 88 01 07 EB 81 01 94 F8 BC 00 88 75 12 E0 08 EB 88 01 07 EB 81 01 94 F8 BC 00 C8 75 0A E0 08 EB 88 00 07 EB 80 00 32 46 06 83 1A 30 04 F1 BE 01 CF F7 9E FA 68 46 FF F7 63 FE 00 28 D9 D0 01 20 D7 E7 00 B5 A5 B0 68 46 FF F7 3A FE 00 28 02 D0
9:03:01 AM
9:03:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 39 09 81 80 68 46 FF F7 55 FE 25 B0 00 BD 00 00 08 5D 06 00 10 B5 04 46 A0 21 CF F7 20 FB 4F F6 05 60 01 F0 7F F9 20 B1 D0 F8 02 10 21 60 C0 88 A0 80 01 20 10 BD 0E B5 02 AA A0 21 CD E9 00 12 0A 46 01 46 00 23 0D 20 F0 F7 CB FC 00 28 00 D0 01 20 0E BD 0E B5 02 AA A0 21 CD E9 00 12 0A 46 01 46 00 23 0D 20 F0 F7 FC FC 00 28 00 D0 01 20 0E BD 70 B5 03 23 04 24 06 25 10 70 0E 28 23 D2 DF E8 00 F0
9:03:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 3A 09 81 80 22 07 0A 0F 22 12 22 15 18 1B 22 22 22 1E 54 70 14 31 01 E0 55 70 18 31 01 20 51 60 70 BD 54 70 1C 31 F9 E7 55 70 20 31 F6 E7 53 70 24 31 F3 E7 53 70 25 31 F0 E7 53 70 26 31 ED E7 18 20 50 70 28 31 E9 E7 00 20 70 BD 00 B5 08 28 1C D2 DF E8 00 F0 04 06 0F 11 13 15 17 19 01 20 00 E0 02 20 10 70 C0 B2 FF F7 C3 FF 00 28 00 D0 01 20 00 BD 03 20 F5 E7 05 20 F3 E7 07 20 F1 E7 08 20 EF E7
9:03:02 AM
9:03:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 3B 09 81 80 09 20 ED E7 0D 20 EB E7 00 20 00 BD 7C B5 05 46 0C 46 16 46 30 21 10 46 D7 F7 83 F8 00 28 1F D0 02 21 29 70 04 21 A9 80 03 21 A8 60 01 70 21 78 01 71 11 21 01 73 62 78 02 74 01 76 A1 78 01 77 A1 88 0F 29 00 D3 0F 21 AD F8 00 10 A4 1D 32 46 69 46 24 30 01 94 F6 F7 17 FC 00 28 00 D0 01 20 7C BD 2D E9 F0 41 05 46 0C 46 90 46 24 21 10 46 D7 F7 57 F8 00 28 32 D0 02 21 29 70 03 21 A9 80
9:03:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 3C 09 81 80 A8 60 11 22 02 70 23 78 03 71 02 73 63 78 03 74 26 78 12 23 06 25 0E 2E 20 D2 DF E8 06 F0 1F 07 0C 07 1F 0C 1F 11 11 13 1F 1F 1F 18 03 76 61 68 09 88 81 83 12 E0 05 76 61 68 09 68 C1 61 0D E0 01 76 00 E0 02 76 61 68 09 78 01 77 06 E0 42 46 18 30 61 68 FF F7 9A FF 00 28 00 D0 01 20 BD E8 F0 81 10 70 14 28 16 D0 04 DC 02 28 09 D0 03 28 05 D1 0A E0 03 23 15 28 11 D0 16 28 12 D0 00 20
9:03:03 AM
9:03:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 3D 09 81 80 70 47 04 20 50 70 48 31 02 E0 06 20 50 70 4C 31 01 20 51 60 70 47 0A 20 50 70 50 31 F8 E7 53 70 58 31 F5 E7 53 70 59 31 F2 E7 00 B5 05 28 15 D2 DF E8 00 F0 03 05 0E 10 12 00 02 20 00 E0 03 20 10 70 C0 B2 FF F7 CD FF 00 28 00 D0 01 20 00 BD 14 20 F5 E7 15 20 F3 E7 16 20 F1 E7 00 20 00 BD 70 B5 06 46 0C 88 0D 46 10 46 64 B1 01 24 30 21 D6 F7 D7 FF 00 28 18 D0 01 21 31 70 B4 80 00 22
9:03:04 AM
9:03:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 3E 09 81 80 06 23 B0 60 0E E0 00 20 F6 E7 00 BF 02 EB 42 01 05 EB 82 06 00 F8 21 30 00 EB 81 01 76 68 52 1C 92 B2 4E 60 A2 42 F1 D3 01 20 70 BD 70 B5 05 46 0C 46 16 46 24 21 10 46 D6 F7 B3 FF 00 28 32 D0 02 21 29 70 03 21 A9 80 11 22 A8 60 02 70 23 78 03 71 02 73 62 78 02 74 22 78 14 2A 16 D0 04 DC 02 2A 07 D0 03 2A 1D D1 0A E0 15 2A 16 D0 16 2A 18 D1 13 E0 12 21 01 76 61 68 09 88 81 83 11 E0
9:03:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 3F 09 81 80 06 21 01 76 61 68 09 68 C1 61 0B E0 32 46 18 30 61 68 FF F7 A5 FF 00 28 05 D0 03 E0 01 76 61 68 09 78 01 77 01 20 70 BD 2D E9 FC 41 05 46 0C 46 17 46 18 21 10 46 D6 F7 74 FF 06 00 25 D0 02 20 28 70 A8 80 AE 60 20 88 20 28 00 D3 20 20 AD F8 00 00 A0 1C 01 90 3A 46 69 46 30 46 F6 F7 14 FB 00 28 10 D0 60 8C 20 28 00 D3 20 20 AD F8 00 00 24 34 3A 46 69 46 06 F1 0C 00 01 94 F6 F7 04 FB
9:03:05 AM
9:03:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 40 09 81 80 00 28 00 D0 01 20 BD E8 FC 81 00 20 FB E7 2D E9 FC 41 06 46 0D 46 17 46 18 21 10 46 D6 F7 41 FF 04 00 19 D0 02 20 30 70 B0 80 B4 60 28 88 20 28 00 D3 20 20 AD F8 00 00 A8 1C 01 90 3A 46 69 46 20 46 F6 F7 E1 FA 00 28 DD D0 11 20 20 73 95 F8 22 00 20 74 01 20 D6 E7 00 20 D4 E7 70 B5 04 46 0D 46 10 46 24 21 D6 F7 1C FF 00 28 0C D0 02 21 21 70 03 21 A1 80 A0 60 01 70 29 78 01 71 69 78
9:03:06 AM
9:03:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 41 09 81 80 01 71 A9 78 01 71 01 20 70 BD 2D E9 F0 4F 04 46 90 F8 88 00 00 26 80 1E C7 B2 FA 48 AD B0 0D 46 30 F8 17 90 08 30 93 46 30 F8 17 A0 04 2F 7D D8 68 46 FF F7 FE FD 00 28 1D D0 94 F8 88 10 00 20 4F F0 01 08 03 29 19 D0 04 29 56 D0 05 29 7D D0 04 2F 6B D2 EB 48 10 30 50 F8 27 60 00 2E 65 D0 0D EB 09 01 5B 46 52 46 28 46 B0 47 4F EA 00 06 84 F8 89 80 30 46 2D B0 BD E8 F0 8F 9D F8 08 10
9:03:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 42 09 81 80 08 29 00 D3 08 21 94 F8 8A 20 12 B1 01 2A 2B D1 0C E0 85 F8 00 80 A9 80 04 F1 88 04 A8 60 84 F8 02 80 C4 E9 01 01 A4 F1 88 04 1C E0 D4 F8 8C 00 08 28 6E D2 D4 F8 90 10 88 42 6A D2 0D F1 09 01 28 AA 40 5C 69 46 FF F7 D2 FD 00 28 D3 D0 5A 46 28 A9 28 46 FF F7 45 FE 33 E0 00 BF D4 F8 8C 00 40 1C C4 F8 8C 00 01 26 D4 E9 23 01 88 42 2B D3 5F F0 01 00 84 F8 89 00 BC E7 9D F8 40 10 05 29
9:03:07 AM
9:03:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 43 09 81 80 00 D3 05 21 94 F8 8A 20 00 2A C2 D0 01 2A EB D1 D4 F8 8C 00 05 28 3C D2 D4 F8 90 10 88 42 38 D2 0D F1 41 01 2A AA 40 5C 69 46 01 E0 31 E0 0D E0 FF F7 57 FE 00 28 9E D0 5A 46 2A A9 28 46 FF F7 B5 FE 00 28 97 D0 C9 E7 00 20 D3 E7 BD F8 1C 20 5A B1 A2 F5 40 42 23 3A 17 A9 08 D0 B2 F5 00 7F 0A D0 B2 F5 01 7F 12 D1 0B E0 28 70 0F E0 5A 46 28 46 FF F7 D9 FE 08 E0 5A 46 28 46 FF F7 07 FF
9:03:07 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 44 09 81 80 03 E0 5A 46 28 46 FF F7 29 FF 00 28 9E D0 01 26 6E E7 00 20 6F E7 2D E9 F0 43 04 46 AD B0 01 20 84 F8 89 00 68 46 FF F7 44 FD 00 28 74 D0 94 F8 88 30 94 49 98 1E 93 4A C0 B2 08 32 31 F8 10 10 32 F8 10 20 0D EB 01 00 00 27 04 F1 BC 01 6D 46 88 46 02 2B 0A D0 00 22 56 39 04 F1 BE 09 03 2B 07 D0 04 2B 75 D0 05 2B 72 D1 D8 E0 CE F7 98 FF 98 E0 94 F8 66 00 50 B1 B4 F8 6E 00 08 28 00 D3
9:03:08 AM
9:03:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 45 09 81 80 08 20 B4 F8 7C 60 C4 F8 8C 60 5E B1 0D E0 94 F8 67 00 01 28 E8 D1 B4 F8 6E 00 00 28 E4 D1 8D F8 08 20 7F E0 8D F8 08 00 01 27 94 F8 66 00 02 28 02 D0 03 28 D8 D1 20 E0 08 46 F7 F7 58 F9 10 B1 02 28 6E D1 0C E0 94 F8 BC 00 28 AA 69 46 FF F7 0E FD 00 28 6C D0 A9 19 94 F8 BC 00 48 72 61 E0 A8 19 28 AA 40 7A 69 46 FF F7 01 FD 00 28 5F D0 9D F8 A1 20 29 98 92 1E 78 E0 A8 19 40 7A 0D 28
9:03:09 AM
9:03:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 46 09 81 80 26 D1 08 46 F7 F7 33 F9 38 B1 01 28 0A D0 02 28 0D D0 03 28 1C D1 0F E0 4A E0 94 F8 BC 00 8D F8 28 00 3F E0 94 F8 BC 00 8D F8 29 00 3A E0 94 F8 BC 00 8D F8 2A 00 35 E0 B4 F8 BC 20 0F 2A 00 D3 0F 22 AD F8 2C 20 49 46 0D F1 2E 00 8E E7 00 E0 4E E0 94 F8 66 00 50 B1 B4 F8 6E 00 05 28 00 D3 05 20 B4 F8 7C 60 C4 F8 8C 60 56 B1 0C E0 94 F8 67 00 01 28 3C D1 B4 F8 6E 00 C8 BB 8D F8 40 20
9:03:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 47 09 81 80 10 E0 8D F8 40 00 01 27 94 F8 66 00 02 28 02 D0 03 28 2D D1 2D E0 08 46 F7 F7 E9 F8 58 B1 02 28 17 D0 27 B1 68 46 FF F7 93 FC 00 28 00 D0 01 20 2D B0 BD E8 F0 83 94 F8 BC 00 2A AA 69 46 FF F7 50 FD 00 28 F4 D0 A9 19 94 F8 BC 00 81 F8 41 00 E8 E7 A8 19 2A AA 90 F8 41 00 69 46 FF F7 41 FD 00 28 E5 D0 9D F8 A9 20 2B 98 92 1E 41 46 3D E7 40 E0 A8 19 90 F8 41 00 14 28 60 D1 08 46 F7 F7
9:03:10 AM
9:03:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 48 09 81 80 B6 F8 B8 BB B4 F8 72 00 00 B1 01 20 34 F8 80 1F AD F8 50 00 05 EB 81 01 E0 6B 48 65 C2 E7 94 F8 66 00 01 28 4B D1 BD F8 1C 10 B4 F8 7C 00 00 29 BD D0 A1 F5 40 41 23 39 05 F1 5E 03 08 D0 B1 F5 00 7F 21 D0 B1 F5 01 7F 35 D0 AD F8 1C 20 A9 E7 94 F8 B8 10 16 29 32 D1 10 B3 01 28 A2 D1 B4 F8 BC 20 20 2A 00 D3 20 22 AD F8 7E 20 49 46 05 F1 80 00 FB E6 23 E0 00 BF AD F8 5C 20 49 46 18 46
9:03:11 AM
9:03:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 49 09 81 80 F4 E6 00 00 50 5D 06 00 30 B1 01 28 8A D1 94 F8 B8 00 05 28 13 D1 09 E0 94 F8 B8 00 16 28 0E D1 B4 F8 BC 20 20 2A E7 D3 20 22 E5 E7 94 F8 BC 00 8D F8 7E 00 76 E7 94 F8 B8 10 0A 29 01 D0 00 20 76 E7 40 B1 01 28 0B D0 02 28 A7 D1 94 F8 BC 00 8D F8 5E 00 66 E7 94 F8 BC 00 8D F8 5C 00 61 E7 94 F8 BC 00 8D F8 5D 00 5C E7 00 B5 A9 B0 68 46 FF F7 CE FB 00 28 02 D0 68 46 FF F7 E9 FB 29 B0
9:03:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 4A 09 81 80 00 BD 00 00 10 B5 36 21 CE F7 0E FF 01 20 10 BD 0E B5 02 AA 36 21 CD E9 00 12 0A 46 01 46 00 23 0E 20 F0 F7 9C F8 00 28 00 D0 01 20 0E BD 0E B5 02 AA 36 21 CD E9 00 12 0A 46 01 46 00 23 0E 20 F0 F7 CD F8 00 28 00 D0 01 20 0E BD F0 B5 8F B0 04 46 0E 46 17 46 68 46 FF F7 DA FF 00 28 16 D0 94 F8 88 00 35 49 80 1E C0 B2 51 F8 20 50 85 B1 0C 39 6A 46 31 F8 10 10 3B 46 11 44 2F 4A 92 1F
9:03:12 AM
9:03:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 4B 09 81 80 32 F8 10 20 30 46 A8 47 01 21 84 F8 89 10 0F B0 F0 BD 00 20 FB E7 70 B5 04 46 8E B0 01 20 84 F8 89 00 68 46 FF F7 B4 FF 00 28 18 D0 94 F8 88 00 22 4A 81 1E C9 B2 0C 3A 32 F8 11 30 92 1D 6B 44 32 F8 11 20 04 28 0C D0 04 F1 BC 01 18 46 CE F7 E7 FD 68 46 FF F7 AB FF 00 28 00 D0 01 20 0E B0 70 BD 94 F8 B8 00 05 28 10 D1 04 F1 66 00 06 46 F6 F7 C8 FF 05 46 30 46 F6 F7 B9 FF 4F F6 FF 71
9:03:13 AM
9:03:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 4C 09 81 80 88 42 03 D0 8D 42 01 D0 05 28 01 D3 00 20 E6 E7 69 46 2D B1 31 31 08 44 94 F8 BC 10 01 70 D8 E7 2C 31 F8 E7 00 B5 8F B0 68 46 FF F7 6B FF 00 28 02 D0 68 46 FF F7 7B FF 0F B0 00 BD 7C 5D 06 00 80 8D B0 F5 74 4F 09 D0 6F F4 74 41 40 18 07 D0 01 28 07 D0 02 28 07 D0 FF 20 70 47 00 20 04 E0 01 20 02 E0 02 20 00 E0 03 20 22 F0 91 B8 10 B5 0C 46 FF F7 E5 FF FF 28 06 D0 21 46 22 F0 DE F8
9:03:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 4D 09 81 80 00 28 00 D0 01 20 10 BD 00 20 10 BD 10 B5 0C 46 FF F7 D6 FF FF 28 06 D0 21 46 22 F0 FD F8 00 28 00 D0 01 20 10 BD 00 20 10 BD F0 B5 8B B0 0E 46 17 46 04 46 69 46 FF F7 DA FF 00 28 16 D0 94 F8 88 00 1F 49 80 1E C0 B2 51 F8 20 50 85 B1 20 39 6A 46 31 F8 10 10 3B 46 11 44 19 4A 10 3A 32 F8 10 20 30 46 A8 47 01 21 84 F8 89 10 0B B0 F0 BD 00 20 FB E7 10 B5 8A B0 04 46 69 46 FF F7 B7 FF
9:03:14 AM
9:03:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 4E 09 81 80 00 28 1B D0 94 F8 88 00 0D 49 80 1E 0C 4A C0 B2 20 39 10 3A 31 F8 10 10 32 F8 10 20 0D EB 01 00 04 F1 BC 01 CE F7 3C FD 01 20 84 F8 89 00 69 46 20 46 FF F7 AB FF 00 28 00 D0 01 20 0A B0 10 BD A8 5D 06 00 80 8D B0 F5 78 4F 09 D0 6F F4 78 41 41 18 05 D0 01 29 03 D0 02 29 01 D0 FF 20 70 47 C0 B2 22 F0 DB B8 2D E9 FF 41 0E 46 17 46 04 46 FF F7 E8 FF FF 28 1E D0 69 46 22 F0 1E F9 00 28
9:03:15 AM
9:03:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 4F 09 81 80 16 D0 94 F8 88 00 22 49 80 1E C0 B2 51 F8 20 50 8D B1 20 39 6A 46 31 F8 10 10 3B 46 11 44 1C 4A 10 3A 32 F8 10 20 30 46 A8 47 01 21 84 F8 89 10 04 B0 BD E8 F0 81 00 20 FA E7 7F B5 04 46 FF F7 C1 FF 05 46 FF 28 21 D0 69 46 22 F0 F6 F8 00 28 1A D0 94 F8 88 00 0E 49 80 1E 0D 4A C0 B2 20 39 10 3A 31 F8 10 10 32 F8 10 20 0D EB 01 00 04 F1 BC 01 CE F7 D5 FC 69 46 28 46 22 F0 EB F8 00 28
9:03:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 50 09 81 80 02 D0 01 20 84 F8 89 00 04 B0 70 BD 00 20 FB E7 E8 5D 06 00 80 8D A0 F5 7F 40 03 38 04 D0 01 28 01 D0 02 28 01 D0 FF 20 70 47 01 20 70 47 30 B5 C7 B0 05 46 0C 46 FF F7 ED FF 01 46 FF 28 0E D0 68 46 25 F0 D7 FB 00 28 07 D0 BD F8 00 00 16 21 21 70 20 71 01 20 85 F8 89 00 47 B0 30 BD 00 20 FB E7 30 B5 C7 B0 05 46 0C 46 FF F7 D3 FF 01 46 FF 28 0E D0 68 46 25 F0 BD FB 00 28 ED D0 BD F8
9:03:16 AM
9:03:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 51 09 81 80 00 00 16 21 00 0A 21 70 20 71 01 20 85 F8 89 00 E3 E7 00 20 E1 E7 1C B5 04 46 C0 68 0B 46 81 89 0E 30 AD F8 00 10 01 90 08 29 02 D9 08 20 AD F8 00 00 69 46 18 46 F5 F7 A7 FE 00 28 02 D0 01 20 84 F8 89 00 1C BD 1C B5 04 46 C0 68 0B 46 41 88 00 1D AD F8 00 10 01 90 08 29 02 D9 08 20 AD F8 00 00 69 46 18 46 F5 F7 8F FE 00 28 02 D0 01 20 84 F8 89 00 1C BD 30 B5 C7 B0 04 46 FF F7 8A FF
9:03:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 52 09 81 80 05 46 FF 28 0D D0 94 F8 B8 00 09 28 09 D1 29 46 68 46 25 F0 30 FB 00 28 9F D0 94 F8 BC 00 03 28 01 D9 00 20 99 E7 BD F8 00 10 01 F4 7F 41 01 43 AD F8 00 10 29 46 68 46 25 F0 3E FB 00 28 8C D0 25 F0 E6 FA 01 20 84 F8 89 00 86 E7 30 B5 C7 B0 04 46 FF F7 5F FF 05 46 FF 28 0C D0 94 F8 B8 00 09 28 08 D1 29 46 68 46 25 F0 05 FB 00 28 03 D0 94 F8 BC 00 08 B1 00 20 6F E7 BD F8 00 10 60 F3
9:03:17 AM
9:03:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 53 09 81 80 1F 21 AD F8 00 10 29 46 68 46 25 F0 15 FB 00 28 F2 D0 25 F0 BD FA 01 20 84 F8 89 00 5D E7 10 B5 04 46 90 F8 B8 00 16 28 03 D1 B4 F8 BC 00 08 28 01 D9 00 20 10 BD E1 68 88 81 E0 68 B4 F8 BC 20 0E 30 04 F1 BE 01 CE F7 EB FB 01 20 84 F8 89 00 10 BD 30 B5 C7 B0 04 46 FF F7 1C FF 05 46 FF 28 12 D0 94 F8 B8 00 09 28 0E D1 29 46 68 46 25 F0 C2 FA 00 28 09 D0 94 F8 BC 00 03 28 04 D8 BD F8
9:03:18 AM
9:03:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 54 09 81 80 00 10 CA B2 82 42 01 D3 00 20 26 E7 01 F4 7F 41 01 43 AD F8 00 10 29 46 68 46 25 F0 CD FA 00 28 F3 D0 25 F0 75 FA 01 20 84 F8 89 00 15 E7 10 B5 C6 B0 0C 46 11 46 68 46 25 F0 DC FA 00 28 06 D0 22 22 0D F1 4A 01 20 46 CE F7 AA FB 01 20 46 B0 10 BD 2D E9 F0 43 E1 B0 05 46 01 24 FF F7 DA FE 07 46 FF 28 12 D0 02 46 47 A9 28 46 FF F7 DF FF 00 28 0C D0 BD F8 1C 01 10 28 07 D1 95 F8 B8 00
9:03:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 55 09 81 80 2C 28 03 D1 95 F8 BC 60 02 2E 03 D9 00 20 61 B0 BD E8 F0 83 76 1C 39 46 68 46 25 F0 6C FA E0 B3 B5 F8 BE 00 18 28 40 D3 30 28 3E D8 41 07 3C D1 49 1E 01 EB D0 01 56 AB 05 F1 C0 02 0D F5 8F 70 D0 F7 F6 F8 48 BB B5 F8 BE 00 06 EB 06 11 08 38 82 B2 68 46 00 EB 41 00 56 A9 A0 F8 4A 20 4C 30 CE F7 5E FB 39 46 68 46 25 F0 66 FA A8 B1 4F F0 00 09 F1 B2 5E AA 88 46 38 46 CD F8 78 91 25 F0
9:03:19 AM
9:03:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 56 09 81 80 8E FC CD F8 4C 91 E9 68 0A 22 0C 31 50 A8 CE F7 B2 FB 50 AA 41 46 38 46 00 E0 06 E0 25 F0 E3 FC 25 F0 F6 F9 01 2E 02 D0 04 E0 00 24 FA E7 27 B1 01 2F 0C D0 01 2C 1B D0 0E E0 01 2C 01 D0 97 20 08 E0 93 20 29 F0 17 FD 01 21 2A 20 0E E0 01 2C 07 D0 98 20 29 F0 0F FD 01 20 85 F8 89 00 20 46 95 E7 94 20 29 F0 07 FD 01 21 2B 20 29 F0 7B FE B2 20 EF E7 90 F8 88 30 02 2B 07 D0 03 2B 06 D0
9:03:20 AM
9:03:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 57 09 81 80 04 2B 05 D0 05 2B 04 D0 00 20 70 47 4F E6 68 E6 81 E6 98 E6 90 F8 88 10 02 29 05 D0 03 29 04 D0 04 29 03 D0 00 20 70 47 A5 E6 CF E6 F7 E6 01 21 80 F8 89 10 90 F8 3A 10 01 29 03 D0 02 29 02 D0 00 20 70 47 05 E7 44 E7 2D E9 F0 41 90 B0 01 27 80 F8 89 70 0C 46 90 46 0B A8 D3 F7 AF FC E8 BB 68 46 D3 F7 ED FC C8 BB 0E A8 D3 F7 E0 FC A8 BB 9D F8 2C 00 03 28 0C D0 06 28 02 D1 00 98 06 28
9:03:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 58 09 81 80 07 D0 27 70 00 20 A0 80 A0 60 01 20 10 B0 BD E8 F0 81 0C 21 40 46 D6 F7 44 F9 06 00 2D D0 24 21 40 46 D6 F7 3E F9 05 00 27 D0 27 70 A7 80 A6 60 02 20 30 70 03 20 B0 80 06 20 B5 60 28 70 05 98 68 60 01 A8 10 24 0D 90 AD F8 30 40 42 46 0C A9 05 F1 0C 00 F5 F7 D8 FC 00 28 00 E0 0D E0 D5 D0 07 A8 0D 90 AD F8 30 40 42 46 0C A9 05 F1 18 00 F5 F7 CA FC 00 28 C9 D0 C7 E7 00 20 C6 E7 90 F8
9:03:21 AM
9:03:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 59 09 81 80 88 30 07 2B 01 D0 00 F0 F3 BB 9D E7 90 F8 88 10 05 29 01 D0 00 20 70 47 00 F0 33 BC 10 B5 88 B0 04 46 06 A8 D3 F7 3F FC 98 B9 9D F8 18 00 80 B1 20 88 10 28 0D D8 AD F8 00 00 22 88 A1 1C 0D F1 02 00 CE F7 6D FA 60 69 05 90 68 46 D3 F7 5D FC 10 B1 00 20 08 B0 10 BD 01 20 27 F0 58 FD 01 20 F8 E7 10 B5 86 B0 04 46 03 A8 D3 F7 1C FC B8 B9 9D F8 0C 00 A0 B1 04 A8 D3 F7 20 FC 80 B9 9D F8
9:03:22 AM
9:03:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 5A 09 81 80 10 00 00 28 0D D0 20 68 C0 01 00 90 A0 88 A4 1D CD E9 01 04 80 28 03 D8 68 46 D3 F7 A4 FC 10 B1 00 20 06 B0 10 BD 01 20 FB E7 1C B5 68 46 D3 F7 FA FB 30 B9 9D F8 00 00 18 B1 01 A8 D3 F7 FE FB 08 B1 00 20 1C BD 9D F8 04 00 00 28 FA D0 D3 F7 E9 F9 18 B1 87 20 29 F0 0E FC F2 E7 33 20 29 F0 0A FC 01 20 1C BD 0E B5 01 A8 D3 F7 DC FB 38 B9 9D F8 04 00 20 B1 02 A8 D3 F7 E0 FB 88 B9 01 E0
9:03:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 5B 09 81 80 00 20 0E BD 9D F8 08 00 03 28 05 D0 D3 F7 CA F9 38 B9 33 20 29 F0 EF FB 26 F0 5A FE D3 F7 A4 FA 18 B1 87 20 29 F0 E7 FB EA E7 69 46 02 20 25 F0 1D FC 30 B1 00 98 69 46 40 1C 00 90 02 20 25 F0 21 FC 34 20 29 F0 D7 FB 01 20 0E BD 10 B5 01 21 80 F8 89 10 90 F8 3A 20 00 F1 BC 01 01 2A 06 D0 02 2A 0C D0 03 2A 12 D0 04 2A 1D D1 18 E0 90 F8 B8 00 25 28 18 D1 08 46 FF F7 50 FF 1A E0 90 F8
9:03:23 AM
9:03:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 5C 09 81 80 B8 00 26 28 10 D1 08 46 FF F7 6B FF 12 E0 90 F8 B8 10 02 29 08 D1 90 F9 BC 00 FF F7 86 FF 09 E0 90 F8 B8 10 02 29 01 D0 00 20 10 BD 90 F9 BC 00 FF F7 99 FF 00 28 F8 D0 01 20 10 BD 10 B5 4A 79 43 79 FF 2A 01 D0 93 42 03 D1 06 22 CE F7 7C F9 08 B1 00 20 10 BD 01 20 10 BD 10 B5 06 22 CE F7 73 F9 08 B1 00 20 10 BD 01 20 10 BD 10 B5 04 46 27 F0 B9 FE 7C 49 04 EB C4 02 01 EB 42 02 7B 49
9:03:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 5D 09 81 80 13 68 01 28 0B 60 53 68 4B 60 13 7A 0B 72 05 D0 50 89 48 81 90 89 88 81 74 48 10 BD D0 89 48 81 10 8A F8 E7 40 F2 FB 50 70 47 40 F2 FB 51 88 42 00 D2 DB E7 00 20 70 47 2D E9 F0 47 DF F8 A8 91 82 46 0F 46 00 26 40 F2 FB 55 70 19 44 08 04 EB C4 01 09 EB 41 08 08 F1 02 01 50 46 FF F7 AE FF F0 B3 04 EB C4 00 09 EB 40 00 4D 46 00 7A B8 42 01 D1 20 46 31 E0 FF 2F 0E D0 01 26 33 E0 00 BF
9:03:24 AM
9:03:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 5E 09 81 80 04 EB C4 00 05 EB 40 01 10 39 50 46 FF F7 96 FF 00 28 EE D0 64 1E A4 B2 00 2C F1 D1 E9 E7 00 BF A4 EB 06 08 08 EB C8 00 05 EB 40 01 08 7A B8 42 04 D1 89 1C 50 46 FF F7 81 FF 68 B9 04 EB 06 08 08 EB C8 00 05 EB 40 01 08 7A B8 42 09 D1 89 1C 50 46 FF F7 73 FF 20 B1 40 46 BD E8 F0 47 85 E7 04 E0 76 1C B6 B2 A6 42 DA D9 0D E0 08 F1 02 01 06 22 50 46 CE F7 E8 F8 00 28 02 DD 64 1C A6 B2
9:03:25 AM
9:03:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 5F 09 81 80 00 E0 25 46 AE 42 A0 D3 00 20 BD E8 F0 87 10 B5 37 49 FF F7 53 FF 00 28 01 D0 35 48 80 1E 10 BD 10 B5 31 49 00 24 40 F2 FB 52 00 BF 04 EB C4 03 31 F8 13 30 83 42 11 D1 20 46 FF F7 57 FF 2B 48 40 89 10 F4 F8 5F 05 D0 C0 F3 04 20 28 F0 67 FD 00 28 07 D0 20 46 BD E8 10 40 47 E7 64 1C 94 42 E4 D3 00 20 10 BD 2D E9 F0 41 00 25 1F 4F 06 46 2C 46 40 F2 FB 58 20 46 FF F7 38 FF 78 89 30 42
9:03:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 60 09 81 80 08 D0 10 F4 F8 5F 04 D0 C0 F3 04 20 28 F0 47 FD 00 B1 6D 1C 64 1C 44 45 ED D3 28 46 BD E8 F0 81 2D E9 F0 41 0C 68 40 F2 FB 56 80 46 0D 46 B4 42 01 D3 00 20 F2 E7 0D 4F 12 E0 20 46 FF F7 16 FF 78 89 10 EA 08 0F 0A D0 10 F4 F8 5F 04 D0 C0 F3 04 20 28 F0 24 FD 10 B1 01 20 2C 60 DE E7 64 1C B4 42 EA D3 2C 60 E4 E7 08 5E 06 00 9C 49 00 10 B0 C9 06 00 01 20 70 47 70 B5 06 46 00 F1 2C 04
9:03:26 AM
9:03:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 61 09 81 80 08 88 0D 46 C1 B2 A8 1C FF F7 16 FF 01 00 0C D1 70 78 02 28 01 D0 04 28 1F D1 28 88 0C 28 04 D1 A8 1C FF F7 74 FF 01 00 18 D0 30 78 FE 4A 32 F8 10 00 91 B1 4A 89 02 42 0F D0 0E 22 20 46 CE F7 6F F8 D5 F8 02 00 C4 F8 02 00 E8 88 E0 80 28 7A A0 73 20 7A 29 88 88 42 01 D0 00 20 70 BD 00 20 60 63 84 F8 38 00 24 21 04 F1 5C 00 CE F7 F5 F8 28 7A 84 F8 5C 00 4F F0 FF 30 20 67 60 67 01 20
9:03:27 AM
9:03:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 62 09 81 80 70 BD 70 B5 0D 46 04 46 4F F4 A6 71 CE F7 E5 F8 04 20 20 70 01 21 61 70 E4 49 61 60 E0 70 E4 48 A0 60 00 20 E0 60 29 46 20 46 FF F7 A5 FF 00 28 00 D0 01 20 70 BD 10 B5 04 46 01 20 84 F8 64 00 94 F8 34 00 F8 F7 DC F8 00 28 16 D0 94 F8 89 20 00 21 0A B9 84 F8 64 10 94 F8 3A 30 63 B9 5A B1 40 68 94 F8 88 20 00 78 82 42 05 D2 52 1C 04 F8 88 2F A1 70 04 F8 24 1C 01 20 10 BD 10 B5 04 46
9:03:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 63 09 81 80 90 F8 34 10 2E 30 FF F7 97 FE 00 28 0C D0 21 78 C5 4A 32 F8 11 10 42 89 0A 42 04 D0 00 7A 94 F8 34 10 88 42 01 D0 00 20 10 BD 01 20 10 BD 70 B5 05 46 0C 46 90 F8 34 00 F8 F7 A2 F8 00 28 09 D0 01 21 21 70 40 68 00 78 A0 80 00 20 A0 60 85 F8 89 10 08 46 70 BD 1C B5 04 46 08 46 06 21 AD F8 00 10 04 F1 2E 01 01 91 69 46 F5 F7 0D FA 00 28 02 D0 01 20 84 F8 89 00 1C BD 00 F1 88 00 81 70
9:03:28 AM
9:03:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 64 09 81 80 4F F0 00 01 C1 70 41 60 C1 60 70 47 3E B5 0C 46 60 B1 69 46 D5 F7 3E FC 00 28 06 D0 21 46 68 46 F5 F7 F4 F8 00 28 00 D0 01 20 3E BD FF 22 0C 21 20 46 CE F7 A6 FD F7 E7 3E B5 0C 46 00 28 0B D0 69 46 F5 F7 1E F9 00 28 06 D0 21 46 68 46 D5 F7 85 FB 00 28 00 D0 01 20 3E BD F0 B5 1F 46 44 F2 02 06 14 46 83 1B 85 B0 05 46 00 F4 78 4C C0 F3 0A 02 B0 42 69 D0 16 DC 42 F2 04 06 A5 EB 06 03
9:03:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 65 09 81 80 B5 42 35 D0 06 DC 01 2D 28 D0 A0 F5 80 55 02 3D 1F D1 25 E0 A3 F5 00 63 04 3B 37 D0 A3 F5 E0 63 F9 3B 16 D1 4C E0 41 F6 FF 76 9D 1B B3 42 7D D0 08 DC A3 F5 80 53 02 3B 51 D0 A3 F5 00 63 04 3B 07 D1 5C E0 B5 F5 80 5F 7D D0 A5 F5 E0 45 03 3D 7B D0 CC F3 0B 00 00 28 6B D0 C7 E0 11 20 30 E0 0A 78 49 78 62 F3 07 00 61 F3 0F 20 12 21 33 E0 0A 78 62 F3 07 00 4A 78 62 F3 0F 20 8A 78 C9 78
9:03:29 AM
9:03:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 66 09 81 80 62 F3 17 40 61 F3 1F 60 06 21 35 E0 0A 78 62 F3 07 00 4A 78 62 F3 0F 20 8A 78 62 F3 17 40 CA 78 62 F3 1F 60 0A 79 62 F3 07 07 4A 79 62 F3 0F 27 8A 79 C9 79 62 F3 17 47 61 F3 1F 67 15 21 3C E0 0F 20 20 70 08 78 20 71 72 E0 0A 78 49 78 62 F3 07 00 61 F3 0F 20 10 21 21 70 A0 80 68 E0 0A 78 62 F3 07 00 4A 78 62 F3 0F 20 8A 78 C9 78 62 F3 17 40 61 F3 1F 60 05 21 21 70 60 60 58 E0 0A 78
9:03:30 AM
9:03:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 67 09 81 80 62 F3 07 00 4A 78 62 F3 0F 20 8A 78 62 F3 17 40 CA 78 62 F3 1F 60 0A 79 62 F3 07 07 4A 79 62 F3 0F 27 8A 79 C9 79 62 F3 17 47 03 E0 09 E0 0A E0 0B E0 21 E0 61 F3 1F 67 14 21 21 70 C4 E9 01 07 36 E0 03 20 BD E7 16 20 BB E7 0A 78 62 F3 07 00 4A 78 62 F3 0F 20 8A 78 C9 78 62 F3 17 40 61 F3 1F 60 02 A9 FF F7 12 FF 00 28 22 D0 0C 20 AD F8 00 00 02 A8 01 90 0F E0 4F EA 2C 30 0D 28 35 D2
9:03:31 AM
9:03:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 68 09 81 80 DF E8 00 F0 07 34 2F 34 34 34 34 34 10 19 07 27 2A 00 AD F8 00 20 01 91 3A 46 69 46 20 46 F5 F7 F3 F8 03 E0 3B 46 20 46 F5 F7 0E F9 00 28 00 D0 01 20 05 B0 F0 BD 08 88 90 42 00 D8 02 46 AD F8 00 20 89 1C 01 91 3A 46 69 46 20 46 F5 F7 FA FA EC E7 AD F8 00 20 F5 E7 3B 46 20 46 F5 F7 2C F9 E4 E7 3B 46 20 46 F5 F7 A2 F8 DF E7 00 20 E0 E7 F0 B5 04 46 AD F2 0C 4D 01 20 84 F8 89 00 E0 78
9:03:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 69 09 81 80 0D 46 00 F0 07 03 A0 8D 94 F8 88 10 16 46 40 EA C1 07 0D F5 81 60 00 90 40 F2 02 42 01 A9 38 46 17 F0 0C FD 50 B9 05 E0 A0 C1 01 00 4E D5 06 00 E6 D7 06 00 BD F8 08 04 00 28 1F D0 38 46 17 F0 D5 FC 00 28 1A D0 40 88 33 46 2A 46 01 A9 FF F7 C4 FE 00 28 12 D0 A0 8D 41 F6 01 01 88 42 0C D1 28 78 09 28 09 D1 A8 88 08 28 06 D3 60 68 40 88 01 28 02 D1 A9 68 4D 20 C8 71 01 20 0D F2 0C 4D
9:03:32 AM
9:03:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 6A 09 81 80 F0 BD 2D E9 F0 41 04 46 86 B0 01 20 84 F8 89 00 E0 78 38 21 01 EA C0 08 A0 8D 94 F8 88 10 40 EA C1 07 38 46 17 F0 A2 FC 00 28 7D D0 40 88 44 F2 02 03 C2 1A 00 F4 78 41 C0 F3 0A 06 04 F1 BC 05 98 42 40 D0 0E DC 01 28 29 D0 A0 F5 80 50 02 38 2A D0 A0 F5 80 50 02 38 2B D0 A0 F5 70 60 FD 38 0F D1 2B E0 A2 F5 80 52 02 3A 31 D0 A2 F5 70 62 FD 3A 37 D0 B2 F5 80 5F 2F D0 A2 F5 E0 42 03 3A
9:03:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 6B 09 81 80 36 D0 04 F1 BE 00 B1 F5 10 4F 6F D0 67 DC 71 B3 B1 F5 00 5F 6B D0 B1 F5 00 4F 04 D1 74 E0 94 F8 B8 00 05 28 5A D0 90 E0 94 F8 B8 00 06 28 55 D0 8B E0 94 F8 B8 00 07 28 50 D0 86 E0 94 F8 B8 00 02 28 4B D0 81 E0 94 F8 B8 00 03 28 46 D0 7C E0 94 F8 B8 00 04 28 7C D0 77 E0 94 F8 B8 00 09 28 77 D0 72 E0 94 F8 B8 00 0A 28 72 D0 6D E0 60 E0 94 F8 B8 00 16 28 68 D1 B4 F8 BC 00 0C 28 64 D1
9:03:33 AM
9:03:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 6C 09 81 80 14 F8 BE 0F 8D F8 04 00 60 78 8D F8 05 00 A0 78 8D F8 06 00 E0 78 8D F8 07 00 20 79 8D F8 08 00 60 79 8D F8 09 00 00 E0 50 E0 A0 79 8D F8 0A 00 E0 79 8D F8 0B 00 20 7A 8D F8 0C 00 60 7A 8D F8 0F 00 A0 7A 8D F8 0D 00 E0 7A 8D F8 0E 00 A4 F1 BE 04 29 46 01 A8 FF F7 EF FD 78 B3 39 E0 B1 F5 20 4F 05 D0 B1 F5 30 4F 2F D1 12 E0 16 E0 26 E0 94 F8 B8 10 16 29 01 D0 19 29 26 D1 B4 F8 BC 10
9:03:34 AM
9:03:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 6D 09 81 80 B1 42 22 D1 05 46 24 E0 94 F8 B8 00 16 28 09 D0 1B E0 94 F8 B8 10 17 29 17 D1 EF E7 94 F8 B8 00 17 28 12 D1 28 88 80 1C B0 42 12 D9 B0 1E 28 80 0F E0 94 F8 B8 10 16 29 07 D1 DF E7 05 E0 94 F8 B8 00 08 28 01 D1 08 2E 03 D0 00 20 06 B0 BD E8 F0 81 04 A8 00 90 43 46 32 46 29 46 38 46 17 F0 4B FC 00 28 F2 D0 A0 8D B0 F5 88 5F 23 D0 42 F2 01 71 88 42 1C D0 A0 F5 1C 51 02 39 18 D0 49 1E
9:03:35 AM
9:03:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 6E 09 81 80 16 D0 49 1E 14 D0 B0 F5 1E 5F 11 D0 42 F2 81 71 88 42 0D D0 A0 F5 1C 51 82 39 09 D0 49 1E 07 D0 49 1E 05 D0 49 1E 03 D0 49 1E 01 D0 49 1E 05 D1 24 F0 EE FB 40 E0 21 F0 27 FB 3D E0 A0 F5 C0 51 82 39 31 D0 41 F2 01 51 88 42 2D D0 A0 F5 A8 51 02 39 29 D0 89 1E 27 D0 49 1E 25 D0 B0 F5 CC 5F 22 D0 B0 F5 C0 7F 1F D0 B0 F5 C2 7F 1C D0 11 F5 9C 51 19 D0 A0 F5 C0 51 84 39 15 D0 49 1E 13 D0
9:03:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 6F 09 81 80 82 31 11 D0 A0 F5 90 51 02 39 0D D0 A0 F5 D8 51 84 39 09 D0 49 1E 07 D0 49 1E 05 D0 A0 F5 00 71 02 39 01 D0 49 1E 07 D1 24 F0 CD FF 24 F0 8F FF 25 F0 2C F9 25 F0 06 F9 01 20 87 E7 00 F1 8C 00 D0 E9 00 10 81 42 01 D3 01 20 70 47 00 20 70 47 00 F1 94 00 D0 E9 00 10 81 42 01 D3 01 20 70 47 00 20 70 47 50 F8 94 2F 11 44 01 60 42 68 A0 F1 94 00 91 42 08 D3 00 F1 88 00 00 21 C1 70 C1 60
9:03:36 AM
9:03:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 70 09 81 80 41 68 01 F1 01 01 41 60 4F F0 01 00 70 47 18 B1 01 78 09 B1 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00 40 8A 70 47 20 B1 01 78 02 29 01 D3 06 29 02 D3 4F F6 FF 70 70 47 00 EB 41 00 80 88 70 47 2D E9 F7 4F 84 B0 04 46 0D 46 10 21 06 98 CD F7 6B FD E5 B1 28 88 B0 B1 20 46 F9 F7 B3 FC 83 46 FF 28 14 D0 1A F0 C3 FF 82 46 58 46 1A F0 CE FF BA F1 00 0F 0B D0 50 B1 00 20 00 90 01 90 02 90
9:03:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 71 09 81 80 04 46 03 90 3C E0 01 20 07 B0 BD E8 F0 8F 00 20 FA E7 00 BF 68 68 04 EB 44 01 00 EB 81 06 30 88 C1 B2 B0 1C FF F7 08 FB 07 00 27 D0 58 46 19 F0 48 FC 80 46 00 20 F8 4A 4F F0 06 0E 1C E0 39 88 96 F9 08 30 DA F8 00 C0 41 EA C3 03 0E EB 40 01 3C F8 01 90 4B 45 0A D1 69 46 01 EB D0 0C 00 F0 07 03 9C F8 00 10 D3 5C 19 43 8C F8 00 10 B9 F1 00 0F 03 D0 40 1C C0 B2 40 45 E0 D3 64 1C A4 B2
9:03:37 AM
9:03:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 72 09 81 80 28 88 A0 42 C6 D8 10 22 69 46 06 98 CD F7 48 FC B9 E7 70 B5 06 46 0C 46 15 00 2F D0 44 B1 20 78 28 70 20 B3 20 79 28 71 38 B1 01 28 26 D1 1F E0 24 21 10 46 CD F7 D1 FC 1E E0 20 89 C1 B2 04 F1 0A 00 FF F7 B9 FA C8 B1 01 7A 22 89 91 42 15 D1 00 88 28 81 60 69 E8 60 A0 69 28 61 05 F1 14 02 04 F1 1C 01 30 46 FF F7 6B FF 00 28 05 D0 03 E0 08 34 08 35 07 CC 07 C5 01 20 70 BD 00 20 70 BD
9:03:38 AM
9:03:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 73 09 81 80 10 B5 90 F8 34 00 5B 28 0A D2 C4 49 51 F8 20 40 34 B1 21 68 21 B1 F7 F7 B3 FC 08 B1 20 46 10 BD 00 20 10 BD 10 B5 04 46 D2 F7 25 FE 04 28 02 D9 4F F0 01 00 10 BD 02 D2 4F F0 00 00 10 BD 94 F8 34 00 01 28 F4 D0 09 28 F6 D1 F1 E7 00 F0 07 02 C0 F3 C2 03 00 20 8A 42 00 D2 01 20 8B 42 01 D2 40 F0 02 00 70 47 70 B5 0D 46 09 7A 1C 46 23 F0 02 06 13 29 5D D0 08 DC 05 29 0B D0 06 29 1A D0
9:03:39 AM
9:03:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 74 09 81 80 07 29 1E D0 12 29 5C D1 48 E0 15 29 32 D0 16 29 57 D1 39 E0 08 2A 54 D1 28 88 6F F4 A0 41 01 44 40 F6 02 02 91 42 42 D9 6F F4 60 41 08 44 B0 F5 90 6F 3C D9 45 E0 04 2A 43 D1 00 78 02 28 36 D0 3F E0 04 2A 07 D1 28 88 A0 F5 E0 40 03 38 01 D0 04 28 00 D1 34 46 27 F0 C2 F8 C0 07 31 D0 28 88 B0 F5 E0 4F 03 D0 6F F4 E0 41 40 18 29 D1 24 F0 02 04 26 E0 04 2A 24 D0 28 88 A0 F5 76 40 86 38
9:03:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 75 09 81 80 15 D0 01 28 1D D1 12 E0 02 2A 1A D1 28 88 B0 F5 77 4F 0C D0 A0 F5 77 40 04 38 07 E0 27 F0 9F F8 80 07 0E D5 28 88 A0 F5 7F 40 06 38 48 B9 34 46 07 E0 07 2A 03 D0 08 2A 01 D0 09 2A 01 D1 23 F0 01 04 20 46 70 BD 2D E9 F8 43 80 46 0E 46 15 46 00 27 69 46 14 20 DA F7 5B FE 10 B9 01 20 AD F8 00 00 26 F0 1F FD 10 B9 00 20 AD F8 00 00 98 F8 00 00 04 F0 F3 FF 08 B1 01 24 04 E0 BD F8 00 00
9:03:40 AM
9:03:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 76 09 81 80 07 24 00 B1 05 24 70 89 10 F4 F8 5F 05 D0 C0 F3 04 20 27 F0 C4 FF 00 B9 00 24 B0 89 21 46 FF F7 55 FF 04 46 30 7A F7 F7 EB FB 18 B1 40 68 01 78 A9 42 02 D2 38 46 BD E8 F8 83 AD B1 69 1E C9 B2 40 68 01 EB 41 01 00 EB 41 00 43 78 BD F8 00 00 28 B1 2A 46 31 46 40 46 FF F7 45 FF 03 46 9C 42 00 D2 23 46 18 46 E6 E7 20 46 E4 E7 10 B5 8B 89 02 46 03 20 03 F0 07 01 07 29 04 D0 D4 78 07 2C
9:03:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 77 09 81 80 01 D0 8C 42 00 D2 02 20 C3 F3 C2 01 07 29 04 D0 D2 78 07 2A 01 D0 8A 42 01 D2 20 F0 02 00 10 BD 38 B5 0D 00 1C D0 2C 88 69 46 30 F0 85 F8 00 28 15 D0 BD F8 00 00 C1 43 09 07 13 D0 00 F0 07 02 C0 F3 03 10 22 F0 38 01 0F 28 0E D0 38 22 02 EA C0 00 08 43 04 F4 E0 71 01 43 29 80 01 20 38 BD 00 20 38 BD 04 F0 07 02 EA E7 04 F0 38 00 F0 E7 F8 B5 04 46 80 8D 94 F8 88 10 40 EA C1 00 04 F1
9:03:41 AM
9:03:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 78 09 81 80 38 01 FF F7 CD FF 04 F1 2C 01 94 F8 3A 20 0E 46 20 46 FF F7 58 FF 05 46 94 F8 3A 20 31 46 20 46 FF F7 A4 FF 05 40 D6 F7 8A FD 40 05 01 D5 25 F0 02 05 69 46 14 20 DA F7 AB FD 10 B9 01 20 AD F8 00 00 26 F0 6F FC 10 B9 00 20 AD F8 00 00 BD F8 00 00 28 B1 B4 F8 48 01 00 04 01 D5 25 F0 02 05 28 46 F8 BD 10 B5 FF F7 C3 FF 80 07 01 D4 00 20 10 BD 01 20 10 BD 10 B5 04 46 90 F8 34 00 F7 F7
9:03:42 AM
9:03:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 79 09 81 80 3F FB 00 28 06 D0 40 68 94 F8 88 10 00 78 81 42 06 D9 00 20 10 BD 00 00 68 C1 01 00 2C D1 06 00 01 20 F7 E7 10 B5 04 46 90 F8 34 00 F7 F7 28 FB 00 28 EF D0 80 68 94 F8 88 10 00 78 81 42 01 D9 00 20 E7 E7 01 20 E5 E7 10 B5 04 46 FF F7 90 FF C0 07 DF D0 20 8F 00 F0 07 00 07 28 04 D0 E1 78 07 29 01 D0 81 42 01 D2 00 20 D3 E7 01 20 D1 E7 10 B5 04 46 FF F7 7C FF 80 07 09 D5 20 8F C0 F3
9:03:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 7A 09 81 80 C2 00 07 28 04 D0 E1 78 07 29 01 D0 81 42 01 D2 00 20 BF E7 01 20 BD E7 F8 B5 04 46 00 8F C0 F3 82 16 94 F8 34 00 0F 28 0C D1 A0 8D B0 F5 70 4F 08 D1 94 F8 3A 00 01 28 04 D1 A0 78 02 28 01 D3 05 28 44 D9 01 20 AD F8 00 00 69 46 14 20 DA F7 1F FD 10 B9 00 20 AD F8 00 00 94 F8 34 00 F7 F7 CF FA 05 46 BD F8 00 00 90 B1 28 88 07 28 0F D1 26 F0 35 FF C0 07 0B D0 94 F8 3A 00 01 28 07 D1
9:03:43 AM
9:03:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 7B 09 81 80 A0 8D B0 F5 E0 4F 24 D0 6F F4 E0 41 40 18 20 D0 07 2E 1E D0 E0 78 07 28 1B D0 B0 42 19 D3 20 46 FF F7 EE FD A8 B1 81 68 99 B1 95 B1 AA 68 94 F8 88 00 13 78 98 42 0C D8 52 68 4F F0 FF 33 03 EB 40 03 D2 5C 2A B1 51 F8 20 00 00 28 00 D0 01 20 F8 BD 00 20 F8 BD 2D E9 F0 41 04 46 01 20 84 F8 64 00 0E 46 17 46 20 46 FF F7 02 FF C0 07 2F D0 20 8F 00 F0 07 00 07 28 2B D0 E1 78 07 29 28 D0
9:03:44 AM
9:03:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 7C 09 81 80 81 42 26 D3 20 46 FF F7 BB FD 05 00 20 D0 20 46 FF F7 C8 FD 00 28 1B D0 94 F8 34 00 F7 F7 70 FA 00 28 15 D0 40 68 94 F8 88 10 00 78 81 42 10 D8 28 68 50 F8 21 30 63 B1 3A 46 31 46 20 46 98 47 00 28 05 D0 20 46 FF F7 76 F9 00 28 00 D0 01 20 3D E4 00 20 3B E4 90 F8 34 10 08 29 03 D1 90 F8 3A 10 02 29 36 D0 81 8D B1 F5 90 5F 32 D0 41 F2 01 22 91 42 2E D0 41 F6 01 22 91 42 2A D0 A1 F5
9:03:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 7D 09 81 80 D0 52 02 3A 26 D0 7B 32 24 D0 B1 F5 D0 5F 21 D0 41 F6 81 12 91 42 1D D0 A1 F5 C8 52 82 3A 19 D0 A1 F5 80 72 81 3A 15 D0 B1 F5 C1 7F 12 D0 A1 F5 C8 52 83 3A 0E D0 12 F5 C0 52 0B D0 B1 F5 A8 5F 08 D0 B2 F5 9C 52 05 D0 B0 F8 48 11 41 F0 01 01 A0 F8 48 11 70 47 70 B5 04 46 FF F7 89 FE 80 07 2C D5 20 8F C0 F3 C2 00 07 28 27 D0 E1 78 07 29 24 D0 81 42 22 D3 20 46 FF F7 42 FD 05 00 1C D0
9:03:45 AM
9:03:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 7E 09 81 80 20 46 FF F7 4F FD 00 28 17 D0 94 F8 34 00 F7 F7 F7 F9 00 28 11 D0 40 68 94 F8 88 10 00 78 81 42 0C D8 68 68 50 F8 21 10 41 B1 20 46 88 47 00 28 03 D0 20 46 FF F7 8F FF 01 20 70 BD 00 20 70 BD 2D E9 F8 43 04 46 C0 8E 0E 46 90 46 10 F4 F8 5F 05 D0 C0 F3 04 20 27 F0 A2 FD 00 28 71 D0 20 8F 00 25 C0 F3 82 17 94 F8 34 00 0F 28 0D D1 A0 8D B0 F5 70 4F 09 D1 94 F8 3A 00 01 28 05 D1 A0 78
9:03:46 AM
9:03:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 7F 09 81 80 02 28 02 D3 05 28 00 D8 01 25 69 46 14 20 DA F7 FF FB 10 B9 01 20 AD F8 00 00 26 F0 C3 FA 10 B9 00 20 AD F8 00 00 8D B9 07 2F 4C D0 E0 78 07 28 49 D0 B8 42 47 D3 D6 F7 C2 FB 40 05 43 D4 BD F8 00 00 18 B1 B4 F8 48 01 00 04 3C D4 20 46 FF F7 D7 FC 05 00 37 D0 A8 68 A0 B3 20 46 FF F7 E2 FC 00 28 2E D0 94 F8 34 00 F7 F7 8A F9 00 28 28 D0 82 68 94 F8 88 10 12 78 91 42 24 D8 BD F8 00 10
9:03:47 AM
9:03:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 80 09 81 80 91 B1 00 88 07 28 0F D1 26 F0 E9 FD C0 07 0B D0 94 F8 3A 00 01 28 07 D1 A0 8D B0 F5 E0 4F 12 D0 6F F4 E0 41 40 18 0E D0 94 F8 88 10 A8 68 50 F8 21 30 3B B1 42 46 31 46 20 46 98 47 00 28 00 D0 01 20 78 E5 FF E7 00 20 75 E5 2D E9 F0 41 06 46 0D 46 17 46 30 21 10 46 D4 F7 23 FF 04 00 1A D0 02 20 30 70 04 20 B0 80 B4 60 12 26 26 70 28 88 A0 80 3B 46 06 22 A9 1C 04 F1 0C 00 F4 F7 DB FA
9:03:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 81 09 81 80 00 28 08 D0 0F 20 20 76 28 7A 20 77 84 F8 24 60 68 89 20 85 01 20 BD E8 F0 81 2D E9 F0 41 AD F5 08 7D 01 27 04 46 0D 46 80 F8 89 70 90 46 80 8D 86 A9 1A F0 F9 FF 00 28 6E D0 69 46 9D F8 18 02 1A F0 CB FE 00 28 67 D0 94 F8 88 00 00 21 80 1E C0 B2 12 22 6E 46 06 28 78 D2 DF E8 00 F0 03 23 42 78 7B 81 94 F8 8A 00 10 B1 01 28 7F D1 0B E0 9D F8 96 00 20 28 3F D3 20 20 3D E0 01 20 00 E0
9:03:48 AM
9:03:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 82 09 81 80 00 20 84 F8 89 00 6E E0 D4 E9 23 01 88 42 6E D2 00 EB 40 00 06 EB 80 01 98 31 42 46 28 46 FF F7 94 FF 47 E0 24 21 40 46 D4 F7 BB FE 04 00 5E D0 02 20 28 70 03 20 A8 80 AC 60 16 25 25 70 9D F8 00 00 20 71 BD F8 02 20 43 46 31 1D 04 F1 0C 00 F4 F7 71 FA 00 28 47 D0 25 76 9D F8 24 00 20 77 41 E0 94 F8 8A 00 10 B1 01 28 40 D1 15 E0 9D F8 34 00 04 28 00 D3 04 20 04 F1 88 04 A0 60 2F 70
9:03:49 AM
9:03:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 83 09 81 80 A8 80 A9 60 A7 70 E1 70 61 60 E1 60 A0 68 A4 F1 88 04 00 28 B4 D8 B1 E7 26 E0 D4 E9 23 01 88 42 25 D2 00 EB 40 00 06 EB C0 01 35 31 42 46 28 46 F4 F7 52 FB 00 28 17 D0 54 F8 8C 0F 40 1C 20 60 61 68 A4 F1 8C 04 88 42 9A D3 97 E7 0F E0 2A 70 0A 98 07 E0 11 20 28 70 9D F8 2C 00 28 71 02 E0 2A 70 0C 98 A8 80 01 20 0D F5 08 7D 53 E7 00 20 FA E7 2D E9 F0 47 AD F5 08 7D 04 46 01 20 84 F8
9:03:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 84 09 81 80 89 00 00 27 A0 8D 86 A9 1A F0 4E FF 00 28 75 D0 94 F8 88 00 69 46 80 1E C5 B2 9D F8 18 02 1A F0 1C FE 00 28 6A D0 00 21 04 F1 BC 0A 4F F6 FF 76 04 F1 66 09 E8 46 06 2D 79 D2 DF E8 05 F0 03 60 79 E6 F4 F2 94 F8 B8 00 10 B1 21 28 6F D1 02 E0 8D F8 96 10 06 E1 48 46 F5 F7 AC F9 C5 B2 B5 42 65 D0 48 46 F5 F7 8E F9 C4 F8 8C 00 B0 42 F7 D0 B4 F8 BC 00 C1 B2 04 F1 BE 00 FE F7 1D FE 00 28
9:03:50 AM
9:03:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 85 09 81 80 55 D0 B4 F8 BC 10 00 7A 81 42 50 D1 F7 F7 38 F8 00 28 4C D0 40 68 94 F9 C4 10 00 78 81 42 46 DC 9D F8 18 02 1A F0 17 FF 85 42 00 D2 28 46 D4 F8 8C 10 CA B2 82 42 3A D2 9D F8 96 30 83 42 06 D2 02 F1 01 01 8B 42 06 D2 8D F8 96 10 02 E0 02 D9 8D F8 96 00 01 27 02 EB 42 01 08 EB 81 05 05 F1 98 00 0C 22 51 46 CC F7 2F FF 00 28 7C D0 04 F1 BC 04 05 F1 98 05 07 CC 07 C5 B3 E0 A5 E0 94 F8
9:03:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 86 09 81 80 B8 00 31 28 13 D1 48 46 F5 F7 3C F9 C4 F8 8C 00 B0 42 0C D0 26 22 51 46 68 46 CC F7 15 FF 00 28 63 D0 26 22 51 46 68 46 CC F7 A5 FF 9A E0 77 E0 94 F8 B8 00 10 B1 14 28 72 D1 02 E0 8D F8 34 10 90 E0 48 46 F5 F7 36 F9 C5 B2 B5 42 7C D0 48 46 F5 F7 18 F9 C4 F8 8C 00 B0 42 75 D0 9D F8 18 02 1A F0 C0 FE 04 28 6F D8 85 42 00 D3 05 46 D4 F8 8C 00 C6 B2 04 2E 67 D2 48 46 F5 F7 F8 F8 10 B1
9:03:51 AM
9:03:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 87 09 81 80 01 28 61 D1 17 E0 06 EB 46 01 08 EB C1 05 05 F1 35 00 0C 22 51 46 CC F7 D7 FE 30 B3 D4 F8 BC 00 C5 F8 35 00 D4 F8 C0 00 C5 F8 39 00 D4 F8 C4 00 C5 F8 3D 00 56 E0 06 EB 46 01 08 EB C1 08 08 F1 41 00 0C 22 51 46 CC F7 BF FE 60 B1 D4 F8 BC 10 C8 F8 41 10 D4 F8 C0 10 C8 F8 45 10 D4 F8 C4 10 C8 F8 49 10 01 27 01 E0 3A E0 42 E0 9D F8 34 00 A8 42 06 D2 06 F1 01 06 B0 42 31 D2 8D F8 34 60
9:03:52 AM
9:03:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 88 09 81 80 30 E0 2D D9 8D F8 34 50 2C E0 94 F8 B8 00 06 28 1A D1 B4 F8 BC 00 0A 99 81 42 2A D0 0A 90 21 E0 12 E0 0D E0 FF E7 94 F8 B8 00 05 28 0C D1 9D F8 2C 10 94 F8 BC 00 81 42 1B D0 8D F8 2C 00 11 E0 94 F8 B8 00 06 28 04 D0 00 20 0D F5 08 7D BD E8 F0 87 B4 F8 BC 00 0C 99 81 42 0A D0 0C 90 01 E0 01 2F 06 D1 69 46 9D F8 18 02 1A F0 8E FE 00 28 EB D0 01 20 E9 E7 38 B5 00 24 01 21 80 F8 89 10
9:03:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 89 09 81 80 90 F8 BC 10 51 B9 80 8D 69 46 1A F0 0D FE 28 B1 9D F8 00 00 1A F0 0F FF 00 B1 01 24 20 46 38 BD 10 B5 04 46 D0 F8 5C 03 20 B1 EC F7 85 F9 00 20 C4 F8 5C 03 01 20 10 BD 70 B5 04 46 D0 F8 5C 03 0E 46 15 46 90 B1 EC F7 0E FC 33 46 2A B2 00 21 D4 F8 5C 03 EC F7 B2 F9 A8 42 0E D0 D4 F8 5C 03 EC F7 6A F9 00 20 C4 F8 5C 03 70 BD EC F7 22 F9 C4 F8 5C 03 00 28 F8 D0 E7 E7 01 20 70 BD 70 B5
9:03:53 AM
9:03:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 8A 09 81 80 04 46 D0 F8 5C 03 15 46 00 28 07 D0 0B 46 2A B2 00 21 EC F7 5A F9 A8 42 01 D0 00 20 70 BD D4 F8 5C 03 EC F7 49 F9 00 20 C4 F8 5C 03 01 20 70 BD D0 F8 5C 03 00 28 00 D0 80 8A 70 47 02 68 00 F2 94 41 10 46 04 F0 11 BF 02 68 00 F2 94 41 10 46 04 F0 15 BF 02 68 00 F2 94 41 10 46 04 F0 11 BF 02 68 00 F2 94 41 10 46 04 F0 16 BF 02 68 00 F2 94 41 10 46 05 F0 CA B8 02 68 00 F2 94 41 10 46
9:03:54 AM
9:03:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 8B 09 81 80 05 F0 2E B9 30 B4 13 46 0A 46 04 68 00 F2 94 41 20 46 30 BC 04 F0 2C BF 30 B4 13 46 0A 46 04 68 00 F2 94 41 20 46 30 BC 04 F0 3B BF 02 68 00 F2 94 41 10 46 05 F0 11 B8 02 68 00 F2 94 41 10 46 05 F0 20 B8 02 68 00 F2 94 41 10 46 05 F0 45 B8 F0 B5 C7 B0 06 46 0F 46 00 F2 94 44 FF F7 BA FF 05 46 1F B9 94 F8 E0 00 A8 42 32 D0 10 20 20 87 18 22 F8 49 04 F1 3A 00 CC F7 D2 FD 29 46 68 46
9:03:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 8C 09 81 80 23 F0 F8 FC 00 28 25 D0 BD F8 00 00 20 80 30 46 FF F7 94 FF 00 28 1D D0 30 46 FF F7 95 FF 00 28 18 D0 22 22 1B A9 04 F1 38 00 CC F7 24 FE 22 22 0D F1 8E 01 04 F1 5A 00 CC F7 B2 FD 22 22 2C A9 04 F1 16 00 CC F7 AC FD 30 46 FF F7 89 FF 00 28 00 D0 01 20 47 B0 F0 BD 40 68 00 78 40 1E 57 28 01 D8 01 20 70 47 00 20 70 47 40 68 00 78 21 38 37 28 01 D8 01 20 70 47 00 20 70 47 40 68 00 78
9:03:55 AM
9:03:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 8D 09 81 80 A0 F1 21 02 17 2A 01 D8 20 38 04 E0 A0 F1 41 02 17 2A 01 D8 40 38 C0 B2 08 70 01 20 70 47 FF 21 80 F8 74 15 01 20 70 47 30 B5 42 68 01 23 54 68 52 69 24 78 01 2C 01 D0 03 2C 03 D0 13 70 13 72 11 73 30 BD C4 8B 03 25 15 70 00 8C A0 42 0A D9 10 89 A0 42 07 D9 D0 68 04 EB 44 02 00 EB 82 00 03 70 01 71 30 BD 00 20 09 E0 00 BF 00 EB 40 05 D4 68 40 1C 04 EB 85 04 80 B2 23 70 21 71 14 89
9:03:56 AM
9:03:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 8E 09 81 80 84 42 F3 D8 30 BD 2D E9 F3 4F 97 B0 04 46 D4 F7 75 FA 10 90 61 68 04 F1 18 00 4F F0 00 08 D1 F8 04 90 4D 69 0E 90 A0 69 00 B1 01 20 83 46 99 F8 00 00 03 28 04 D0 02 28 04 D1 20 8C 01 28 01 D9 01 20 00 E0 00 20 0F 90 20 69 4F F4 A0 62 C0 88 90 42 01 D9 10 46 01 E0 10 28 73 D9 A0 F1 0C 00 86 B2 08 8C C0 07 07 D0 94 F8 4D 05 C0 06 01 D5 15 3E 00 E0 09 3E B6 B2 40 F2 2C 67 39 46 18 98
9:03:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 8F 09 81 80 D4 F7 8F FB 01 00 5D D0 3A 46 68 46 D4 F7 84 FB 40 F2 64 67 39 46 18 98 D4 F7 83 FB 01 00 F2 D0 3A 46 0A A8 D4 F7 78 FB 00 20 07 46 05 90 BB F1 00 0F 13 D1 0F 98 88 B1 0E 98 01 22 12 A9 00 89 AD F8 48 00 68 46 D4 F7 C0 FB 8D F8 44 70 01 22 11 A9 68 46 D4 F7 B9 FB 02 20 05 90 04 F2 66 30 04 90 04 F1 08 00 06 90 3C 30 BA 46 07 90 B4 F8 64 23 00 27 72 B1 68 46 04 99 D4 F7 A6 FB 00 B9
9:03:57 AM
9:03:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 90 09 81 80 01 27 A4 F8 64 A3 E0 8B 21 8C 88 42 02 D3 01 20 20 77 D9 E0 0F BB 0A AA 13 A9 06 98 FF F7 DB FA 88 B1 13 A9 68 46 F4 F7 3B FE E0 B1 BD F8 04 00 B0 42 25 D9 80 1B 87 B2 B7 F5 96 7F 16 D9 AD F8 2C A0 34 E0 82 E0 06 98 FF F7 3E FA 18 9A 40 B1 04 21 20 46 FF F7 28 FF 01 27 AD F8 2C A0 8F B1 25 E0 03 21 F5 E7 FA 21 18 9A F2 E7 00 98 3A 46 81 19 04 98 CC F7 94 FC A4 F8 64 73 AD F8 04 60
9:03:58 AM
9:03:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 91 09 81 80 AD F8 2C A0 94 F8 6C 00 00 28 4C D0 A0 69 70 B9 99 F8 00 00 01 28 22 D0 03 28 2C D0 FA 21 20 46 18 9A FF F7 01 FF 00 BF 94 F8 6C 00 D8 B3 E0 8B 40 1C 80 B2 E0 83 21 8C 88 42 76 D2 0F 98 98 B3 B4 F8 64 03 88 B3 B0 F5 96 7F 3F D2 04 99 00 F8 01 A0 B4 F8 64 03 40 1C A4 F8 64 03 30 E0 85 F8 08 A0 BD F8 04 10 05 98 08 1A A8 81 00 99 05 98 08 44 28 61 D8 E7 E0 8B 2A 89 E9 68 82 42 D6 D9
9:03:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 92 09 81 80 00 EB 40 00 01 F8 20 A0 BD F8 04 30 05 9A 01 EB 80 00 9A 1A 82 80 00 9A 05 99 11 44 81 60 BD F8 04 00 05 90 C0 E7 39 E0 0A E0 FF E7 8D F8 44 A0 01 22 11 A9 68 46 D4 F7 08 FB BD F8 04 00 05 90 0E 98 61 6A C0 88 01 EB 00 17 19 E0 FA 21 20 46 18 9A FF F7 A9 FE 19 B0 BD E8 F0 8F 39 46 06 98 FE F7 8A FB 18 B1 06 98 FF F7 85 F9 60 B9 04 21 20 46 18 9A FF F7 98 FE E0 8B 10 37 40 1C E0 83
9:03:59 AM
9:03:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 93 09 81 80 E1 8B 20 8C 81 42 E9 D3 E0 8B 21 8C 88 42 0E D2 F9 68 29 B1 24 22 07 98 CC F7 6D FC 07 E0 04 E0 24 21 07 98 CC F7 99 FC 01 E0 01 20 20 77 D4 F7 25 F9 10 99 A0 EB 01 08 20 7F 00 28 B4 F8 64 03 0A D0 08 B1 84 F8 1C A0 A0 69 BB F1 00 0F 0A D0 80 B1 11 E0 5C 5C 06 00 00 28 F3 D1 B8 F5 61 7F 7F F6 05 AF F0 E7 38 B9 B4 F8 64 03 10 B9 B8 F5 61 7F B0 D9 01 20 A0 61 02 20 28 70 99 F8 04 00
9:03:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 94 09 81 80 28 71 A0 69 E8 60 20 7F 28 72 85 F8 10 A0 BD F8 04 00 A8 82 00 98 A8 61 9D E7 2D E9 F0 4F 89 B0 4F F0 00 0A 14 46 82 F8 00 A0 0D 46 0A 78 00 F5 AA 71 00 F1 18 06 08 30 4F F0 0D 09 05 91 03 90 01 2A 04 D0 02 2A 6B D0 03 2A 69 D1 27 E0 10 21 05 98 D4 F7 26 FA 07 00 55 D0 01 20 30 81 F7 60 D5 F8 06 00 38 60 D5 F8 0A 00 78 60 E8 89 38 81 28 69 88 B1 39 46 03 98 FE F7 FE FA F0 B3 24 21
9:04:00 AM
9:04:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 95 09 81 80 05 98 D4 F7 0E FA F8 60 02 00 3C D0 29 69 03 98 FE F7 3F FF 90 B3 43 E0 C7 F8 0C A0 40 E0 2F 89 67 B3 38 05 01 0C 05 98 D4 F7 FB F9 5F EA 00 08 29 D0 37 81 C6 F8 0C 80 00 26 4F F0 0C 0B 2D E0 E8 68 0A 22 00 EB 06 11 40 46 CC F7 D4 FB E9 68 0B EB 06 10 01 90 08 58 D0 B1 41 46 03 98 FE F7 CB FA 58 B1 24 21 05 98 D4 F7 DB F9 C8 F8 0C 00 20 B1 EA 68 01 99 51 58 02 46 00 E0 03 E0 03 98
9:04:01 AM
9:04:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 96 09 81 80 FE F7 07 FF 30 B9 84 F8 00 90 00 20 09 B0 23 E7 C8 F8 0C A0 76 1C 08 F1 10 08 B6 B2 BE 42 CF D3 01 20 F3 E7 2D E9 FF 41 44 68 05 46 04 F1 24 00 00 90 04 F1 10 03 1F 46 22 46 05 F2 94 41 28 68 04 F0 7A FE 00 28 25 D0 28 68 00 89 00 28 21 D0 41 F2 22 30 21 18 40 F2 64 62 0E 46 01 A8 D4 F7 9B F9 39 46 01 A8 F6 F7 55 FB 00 28 12 D0 04 F5 80 54 BD F8 08 20 A4 F8 20 23 03 AB 31 46 28 68
9:04:02 AM
9:04:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 97 09 81 80 04 F0 4E F9 00 28 05 D0 28 46 FF F7 89 FC 00 28 00 D0 01 20 04 B0 BD E8 F0 81 2D E9 FF 41 44 68 05 46 D8 20 20 74 02 A8 60 61 01 20 8D F8 08 00 8D F8 09 00 28 68 04 F1 10 07 00 89 00 28 E9 D0 41 F2 22 30 21 18 40 F2 64 62 0E 46 68 46 D4 F7 63 F9 39 46 68 46 F6 F7 1D FB 00 28 DA D0 04 F5 80 54 BD F8 04 20 A4 F8 20 23 28 68 90 F8 98 13 1F 29 03 D1 01 68 09 88 C9 07 07 D0 81 79 03 29
9:04:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 98 09 81 80 0B D0 03 AB 31 46 04 F0 0B F9 0A E0 81 79 04 29 F7 D0 B0 F8 9C 13 00 29 F3 D1 4F F4 82 71 05 F0 75 FB 28 46 FF F7 3C FC 00 28 B3 D0 01 20 B1 E7 F0 B5 41 68 9B B0 00 23 06 46 0B 74 40 7A 01 F1 10 04 01 28 1B D0 03 28 19 D0 00 20 01 F5 80 55 B5 F8 20 23 02 2A 52 D3 95 F8 22 73 01 22 4F F0 0D 0C C0 2F 12 D0 0C DC 0D F1 08 0C 4F F0 0E 02 4F F0 04 0E 05 2F 43 D0 06 2F 7B D1 46 E0 01 20
9:04:03 AM
9:04:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 99 09 81 80 E4 E7 C1 2F 16 D0 C3 2F 74 D1 25 E0 B8 B3 95 F8 23 03 03 28 6E D8 C4 20 20 70 06 A8 60 60 8D F8 18 20 95 F8 24 03 8D F8 1C 00 8D F8 20 20 8D F8 24 C0 36 E0 18 B3 95 F8 23 03 05 28 5A D8 C5 20 20 70 13 A8 60 60 8D F8 4C 20 95 F8 24 03 8D F8 50 00 8D F8 51 C0 24 E0 88 B1 95 F8 23 03 06 28 48 D8 C7 20 20 70 0D A8 60 60 8D F8 34 20 95 F8 24 03 8D F8 38 00 8D F8 3C C0 10 93 11 E0 38 E0
9:04:04 AM
9:04:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 9A 09 81 80 B8 BB 22 70 05 20 C4 F8 04 C0 04 E0 88 BB 22 70 06 20 C4 F8 04 C0 8D F8 08 00 8D F8 09 E0 8D F8 0A 30 20 78 28 B3 30 68 00 89 00 28 1F D0 41 F2 22 30 01 44 40 F2 64 62 0F 46 04 A8 D4 F7 AC F8 21 46 04 A8 F6 F7 66 FA 00 28 10 D0 BD F8 14 20 A5 F8 20 23 19 AB 39 46 30 68 04 F0 61 F8 00 28 05 D0 30 46 FF F7 9C FB 00 28 00 D0 01 20 1B B0 F0 BD FF E7 30 46 FF F7 10 FF F5 E7 38 B5 81 7A
9:04:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 9B 09 81 80 04 46 89 1E 00 68 00 25 03 29 09 D9 81 7A 01 29 06 D0 E5 72 69 46 14 20 D9 F7 FA FC 18 B1 05 E0 C0 7A E0 72 F6 E7 01 20 AD F8 00 00 25 F0 BA FB 08 B9 AD F8 00 50 BD F8 00 00 00 28 06 D1 E0 7A 05 21 07 28 01 D0 04 28 01 D0 E1 72 38 BD 06 20 E0 72 38 BD 10 B5 04 46 00 68 4F F4 00 72 00 F1 0E 01 E1 60 41 69 21 61 04 F2 94 41 61 61 80 79 20 72 00 20 A4 F8 60 03 A4 F8 62 03 A4 F8 64 03
9:04:05 AM
9:04:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 9C 09 81 80 04 F5 AE 71 04 F5 AA 70 D4 F7 46 F8 1C 21 04 F1 18 00 CC F7 62 FA 20 68 00 68 00 88 00 07 05 D5 B4 F8 50 01 40 F4 00 40 A4 F8 50 01 20 46 FF F7 A5 FF 01 20 10 BD 2D E9 F8 43 04 46 40 68 1C 21 00 F1 10 05 46 68 24 30 80 46 D4 F7 2A F8 68 60 00 28 6F D0 C4 20 28 70 32 78 6D 68 01 21 04 F1 44 09 04 F1 08 07 01 2A 04 D0 02 2A 2C D0 03 2A 7E D1 61 E0 29 70 30 79 28 71 20 46 FF F7 AA FF
9:04:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 9D 09 81 80 00 28 57 D0 6A 46 31 46 20 46 FF F7 C6 FD 00 28 73 D0 65 6A 38 46 29 46 FE F7 EE F8 00 28 69 D0 38 46 FE F7 E8 FE 00 28 64 D0 7F E0 20 46 FF F7 FB FB 3E E0 24 22 48 46 CC F7 DD F9 0E E0 24 21 48 46 CC F7 0A FA 09 E0 A0 69 02 27 40 B3 B2 68 00 23 82 42 07 D1 40 1C A0 61 23 77 41 46 20 46 FF F7 11 FC 25 E0 52 1C 82 42 19 D1 2F 70 30 79 28 71 A0 69 E8 60 20 7F 28 72 2B 74 20 46 FF F7
9:04:06 AM
9:04:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 9E 09 81 80 17 FB A8 82 01 00 58 D0 40 46 D3 F7 CA FF A8 61 01 00 52 D0 AA 8A 20 46 FF F7 F1 FA 40 B3 08 E0 2F 70 30 79 28 71 A0 69 E8 60 29 72 29 74 0F 20 28 75 01 20 BD E8 F8 83 03 20 28 70 30 79 28 71 30 89 28 81 00 EB 40 00 80 04 01 0C 40 46 D3 F7 A8 FF E8 60 00 28 ED D0 20 46 FF F7 3B FF 00 28 E8 D0 6A 46 31 46 20 46 FF F7 57 FD 08 B1 02 E0 23 E0 02 E0 1E E0 65 6A 10 E0 42 46 9D F8 00 10
9:04:07 AM
9:04:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 9F 09 81 80 94 E7 29 46 38 46 FE F7 77 F8 18 B1 38 46 FE F7 72 FE 38 B9 E0 8B 10 35 40 1C E0 83 E0 8B 21 8C 88 42 EE D3 E0 8B 21 8C 88 42 03 D2 E9 68 00 29 85 D0 7F E7 42 46 04 21 78 E7 42 46 0B 21 75 E7 2D E9 F0 4F 93 B0 4F F0 00 0A DD F8 70 90 45 68 0F 46 A9 F8 00 A0 04 46 90 F9 90 10 93 46 1E 46 90 F8 3C 00 F3 F7 58 F9 5F EA 00 08 3A D0 C7 B3 79 68 B1 B3 3A 88 10 A8 D3 F7 4E FF 04 F1 34 00
9:04:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A0 09 81 80 08 90 24 35 10 A8 CD E9 06 05 08 99 AD F8 14 A0 FF 20 81 F8 80 00 08 99 8C 22 81 F8 3A 00 08 99 08 98 90 31 84 30 D3 F7 37 FF 30 46 D3 F7 76 FF 07 00 17 D0 30 46 D3 F7 5E FF 01 46 3A 46 01 A8 D3 F7 2A FF CD F8 34 A0 20 68 57 46 00 68 00 88 00 07 56 D5 B4 F8 50 01 40 F4 00 40 A4 F8 50 01 4F E0 FF E7 00 20 13 B0 76 E4 00 BF 08 9B 08 9A 08 98 CD F8 00 80 8C 33 80 32 3A 30 0A A9 F4 F7
9:04:08 AM
9:04:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A1 09 81 80 CA FE 28 B1 9D F8 28 10 00 20 01 29 04 D0 07 E0 01 21 A9 F8 00 10 E5 E7 BD F8 2C 10 01 B9 01 20 08 99 91 F8 8C 10 09 B9 01 28 2A D1 0D A9 04 F1 08 00 07 9A FE F7 44 FF 00 28 D4 D0 94 F8 3C 00 0F 28 0F D1 A0 8E B0 F5 70 4F 0B D1 94 F8 42 00 01 28 07 D1 A0 7A 02 28 04 D3 05 28 02 D8 20 68 04 F0 41 F8 0D 99 29 B1 01 A8 F4 F7 D9 F9 00 28 B9 D0 0D 97 08 99 08 98 90 31 84 30 8C 22 D3 F7
9:04:09 AM
9:04:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A2 09 81 80 CB FE 0A A9 05 A8 F4 F7 88 FC 00 28 AE D1 BD F8 08 00 90 B1 0C 21 28 46 D3 F7 C3 FE 00 28 A2 D0 07 70 BD F8 08 10 81 80 01 99 81 60 CB F8 00 00 B0 88 BD F8 08 10 08 44 B0 80 01 20 93 E7 1F B5 04 46 8A 88 09 68 68 46 D3 F7 A6 FE 01 22 02 A9 68 46 D3 F7 11 FF 00 28 04 D0 9D F8 08 00 09 28 02 D0 00 20 04 B0 10 BD 03 A9 68 46 F3 F7 18 FE 00 28 F7 D0 BD F8 0C 00 A4 F8 62 03 01 20 F1 E7
9:04:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A3 09 81 80 2D E9 FF 4F 83 B0 04 46 B0 F8 60 03 DD F8 44 B0 8A 46 91 46 00 28 59 D0 5F F0 00 05 BA F8 04 00 40 1B 1F FA 80 F8 10 46 D3 F7 B8 FE 02 90 40 44 86 B2 1A 20 84 F8 C0 00 04 F1 C4 07 31 46 06 98 D3 F7 6F FE B8 60 BE 80 B4 F8 60 03 38 80 B4 F8 62 03 78 80 B2 B2 68 46 B9 68 D3 F7 5D FE DA F8 00 00 42 46 41 19 68 46 D3 F7 AF FE 00 28 2A D0 D9 F8 00 10 68 46 02 9A D3 F7 A7 FE 00 28 22 D0
9:04:10 AM
9:04:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A4 09 81 80 94 F8 C0 00 01 25 50 B1 04 F1 08 00 FE F7 63 FE 40 B3 8C 22 39 46 04 F1 B8 00 D3 F7 3D FE 00 20 A4 F8 64 03 B4 F8 60 13 31 44 89 B2 A4 F8 60 13 B4 F8 62 23 91 42 05 D3 A4 F8 60 03 A4 F8 62 03 AB F8 00 50 01 20 07 B0 BD E8 F0 8F B4 F8 62 03 FF 28 01 D9 04 25 A1 E7 80 28 01 D3 03 25 9D E7 02 25 9B E7 10 98 B9 F8 04 10 01 80 AB F8 00 50 00 20 E8 E7 2D E9 F0 4F 95 B0 4F F0 00 0A DD F8
9:04:11 AM
9:04:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A5 09 81 80 78 90 A2 F8 00 A0 A3 F8 00 A0 A9 F8 00 A0 D0 F8 04 B0 04 46 15 46 1E 46 00 29 7C D0 48 68 00 28 FB D0 0A 88 01 46 09 A8 D3 F7 F6 FD D0 46 B4 F8 62 13 04 F2 66 30 47 46 01 90 51 B1 01 46 4F F4 96 72 0B A8 D3 F7 E8 FD B4 F8 64 03 AD F8 30 00 21 E0 B4 F8 64 03 F8 B1 4F F4 96 72 0B A8 01 99 D3 F7 DA FD B4 F8 64 03 AD F8 30 00 09 A9 0B A8 F4 F7 ED FB 40 B1 BD F8 30 00 AD F8 32 00 AD F8
9:04:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A6 09 81 80 30 A0 4F F0 01 08 07 E0 09 AA 0B A9 20 46 FF F7 16 FF 00 28 50 D0 01 27 00 20 AD F8 10 00 04 F1 34 00 07 90 B8 F1 00 0F 01 D0 0B A8 00 E0 09 A8 0B F1 24 0B CD E9 05 0B 94 F8 3C 00 5C 28 0A D8 94 F9 90 10 F2 F7 8A FF 5F EA 00 0A 03 D0 07 98 40 6B 18 B1 10 E0 05 98 80 88 84 E0 07 99 07 98 90 31 84 30 8C 22 D3 F7 97 FD 07 99 FF 20 81 F8 80 00 07 99 81 F8 3A 00 20 68 00 68 00 88 00 07
9:04:12 AM
9:04:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A7 09 81 80 05 D5 B4 F8 50 01 40 F4 00 40 A4 F8 50 01 04 F1 08 00 13 90 00 E0 67 E0 FE F7 64 FC 00 28 DA D0 EF B3 8D E8 60 02 5B 46 09 AA 0B A9 20 46 FF F7 E7 FE 00 28 CF D0 01 20 15 B0 45 E7 07 9B 07 9A 07 98 CD F8 00 A0 8C 33 80 32 3A 30 0D A9 F4 F7 22 FD 28 B1 9D F8 34 10 00 20 01 29 0B D0 0E E0 05 98 80 88 28 80 BD F8 10 00 C0 0B 30 80 01 21 A9 F8 00 10 38 E0 BD F8 38 10 01 B9 01 20 07 99
9:04:13 AM
9:04:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A8 09 81 80 91 F8 8C 10 09 B9 01 28 0C D1 13 98 FE F7 63 FD 60 B3 07 99 07 98 90 31 84 30 8C 22 00 E0 0C E0 D3 F7 3A FD B8 F1 00 0F 03 D0 09 A8 4F F0 00 08 05 90 BD F8 10 00 00 04 05 D4 0D A9 04 A8 F4 F7 EC FA 00 28 BA D1 00 20 A4 F8 64 03 BD F8 10 00 00 04 29 D4 05 98 05 99 80 88 C9 88 88 42 23 D2 94 F8 6C 10 51 B1 28 80 00 20 A5 E7 05 98 80 88 28 80 BD F8 10 00 C0 0B 30 80 F5 E7 05 98 D3 F7
9:04:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 A9 09 81 80 4D FD A4 F8 64 03 B0 F5 96 7F 3F F6 64 AF 05 98 D3 F7 31 FD 01 46 B4 F8 64 23 01 98 CB F7 80 FE 05 98 05 99 C0 88 88 80 05 98 80 88 28 80 BD F8 10 00 C0 0B 30 80 7E E7 2D E9 F0 4F 81 46 40 68 85 B0 00 F1 10 07 46 68 4F F0 00 08 24 30 45 46 14 21 00 90 D3 F7 E5 FC 78 60 00 28 6F D0 04 46 C5 20 38 70 31 78 09 F1 08 00 4F F0 03 0A 0D F1 0C 0B 04 90 06 29 70 D2 DF E8 01 F0 D1 03 30 75
9:04:14 AM
9:04:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 AA 09 81 80 95 CD 48 46 FF F7 66 FC 00 28 58 D0 B1 1D 04 98 FD F7 B2 FD 00 B9 04 25 04 98 FE F7 AC FB 10 B1 37 79 1D B1 16 E0 04 25 37 79 13 E0 02 AB 01 AA 06 F1 14 01 48 46 CD F8 00 B0 FF F7 9B FE 48 B9 BD F8 0C 00 08 B1 0C 25 04 E0 04 98 FE F7 D0 FB 10 B1 FA 25 01 20 44 E0 03 25 FB E7 48 46 FF F7 39 FC 00 B9 0B 25 B1 1D 04 98 FD F7 85 FD 10 B9 84 F8 00 A0 04 25 04 98 FE F7 7D FB 10 B1 37 79
9:04:15 AM
9:04:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 AB 09 81 80 3D B1 02 E0 84 F8 00 A0 37 79 84 F8 00 A0 0B 25 89 E0 D6 F8 18 80 C9 F8 68 80 B8 F1 01 0F 0F D0 B8 F1 02 0F 3B D2 02 AB 01 AA 06 F1 1C 01 48 46 CD F8 00 B0 FF F7 5E FE 80 B3 30 7D 2B E0 88 E0 8C 22 09 F1 C4 01 09 F1 B8 00 D3 F7 65 FC FF 20 89 F8 B4 00 89 F8 6E 00 E5 E7 60 E0 03 20 00 E0 02 20 20 70 5F E0 D9 F8 68 10 D6 F8 0C 80 37 79 49 1C 41 45 02 D0 84 F8 00 A0 11 25 C9 F8 68 80
9:04:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 AC 09 81 80 02 AB 01 AA 06 F1 10 01 48 46 CD F8 00 B0 FF F7 31 FE 18 B1 30 7A 00 28 E2 D0 DF E7 FF E7 84 F8 00 A0 11 25 3F E0 05 20 20 70 31 8A 21 81 00 98 D3 F7 37 FC E0 60 37 79 48 46 FF F7 CB FB 00 28 47 D0 00 20 22 E0 F1 68 00 25 01 EB 0A 11 04 98 FD F7 12 FD 00 B9 04 25 04 98 FE F7 0C FB 08 B1 15 B1 0D E0 04 25 0B E0 CD F8 00 B0 71 69 02 AB 01 EB CA 01 01 AA 48 46 FF F7 FC FD 00 B9 0B 25
9:04:16 AM
9:04:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 AD 09 81 80 E1 68 0A F1 01 00 80 B2 01 F8 0A 50 21 89 82 46 51 45 D8 D8 07 E0 37 79 01 20 20 70 77 E7 01 20 37 79 20 70 0D 25 20 78 01 28 06 D0 02 28 07 D0 03 28 07 D0 05 28 0B D1 09 E0 27 71 65 71 07 E0 27 71 01 E0 27 71 65 71 C4 F8 08 80 00 E0 27 71 01 20 05 B0 B8 E5 40 68 01 22 43 68 40 69 02 70 1A 79 02 71 00 22 02 72 C1 60 01 20 70 47 2D E9 F0 4F 81 46 40 68 87 B0 00 F1 10 06 45 68 24 30
9:04:17 AM
9:04:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 AE 09 81 80 83 46 18 21 D3 F7 CD FB 70 60 00 28 4A D0 18 21 CB F7 E3 FD 00 27 74 68 C7 20 02 97 30 70 28 78 01 26 01 28 04 D0 26 70 28 79 20 71 0B 20 4E E0 05 F1 06 08 48 46 FF F7 4D FB 00 28 32 D0 09 F1 08 00 41 46 01 90 FD F7 97 FC 4F F0 04 08 10 B3 01 98 FE F7 A7 FA F0 B1 28 69 4F F0 03 0A A0 B1 40 F2 64 61 58 46 D3 F7 9C FB 01 00 19 D0 40 F2 64 62 03 A8 D3 F7 90 FB 05 A8 00 90 03 AB 02 AA
9:04:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 AF 09 81 80 48 46 29 69 FF F7 1C FC 68 B1 48 46 02 99 FF F7 A2 FF 00 B3 1D E0 26 70 28 79 20 71 84 F8 08 80 16 E0 00 20 4F E5 01 98 FE F7 B6 FA 40 B1 BD F8 14 00 26 70 00 28 28 79 20 71 07 D0 0C 20 06 E0 26 70 28 79 20 71 84 F8 08 A0 01 E0 FA 20 20 72 E7 60 01 20 37 E5 01 98 FE F7 9E FA 00 28 EF D0 D9 E7 70 B5 D1 F8 78 55 06 46 05 F2 FC 45 00 24 28 88 10 B9 28 46 D3 F7 15 FA FB F7 95 FD 28 B1
9:04:18 AM
9:04:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B0 09 81 80 01 28 0E D0 02 28 06 D0 04 24 0B E0 00 22 11 46 10 46 FB F7 F4 FD 28 46 D3 F7 0C FA 36 B1 02 24 00 E0 01 24 28 46 D3 F7 F9 F9 02 E0 FE 49 88 42 F5 D8 20 46 70 BD 2D E9 F3 4F D1 F8 78 65 08 68 95 B0 00 27 D0 F8 A8 13 06 F2 1C 55 06 F2 04 5A 06 F5 20 74 BB 46 14 91 08 B1 D0 F8 A4 B3 00 21 00 91 8D F8 04 10 AD F8 4C 10 01 68 80 79 D6 F8 14 85 49 88 40 00 C1 40 11 F0 03 0F 02 D0 04 20
9:04:19 AM
9:04:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B1 09 81 80 28 70 27 E0 BA F8 00 00 10 B9 50 46 D3 F7 CA F9 28 78 4F F0 03 09 60 B9 94 F8 73 02 09 A9 19 F0 28 FC 10 B9 BD F8 26 00 90 B1 9D F8 48 00 84 F8 72 02 94 F8 73 02 C0 EB C0 00 04 EB 80 00 90 F8 9C 01 06 28 53 D2 DF E8 00 F0 0B 82 82 82 5C 93 85 F8 00 90 50 46 D3 F7 A1 F9 01 20 17 B0 B3 E4 D4 F8 30 02 4F F0 06 08 00 7B 00 28 6F D0 01 28 46 D1 BB F1 00 0F 6A D0 28 78 B0 B9 09 A9 20 46
9:04:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B2 09 81 80 19 F0 AE FF 01 28 62 D1 B4 F8 4A 02 78 BB B4 F8 70 22 43 46 04 F5 13 71 58 46 02 F0 0A F9 01 28 55 D1 28 70 50 46 D3 F7 7D F9 B4 F8 4A 02 F0 B9 6B 46 13 AA 01 A9 58 46 02 F0 55 F9 01 28 10 D1 04 F5 13 71 01 A8 E3 F7 C9 FC 40 B9 B4 F8 70 02 BD F8 4C 10 88 42 02 D1 00 98 06 28 08 D0 00 20 28 70 50 46 D3 F7 66 F9 15 99 79 BB 04 E0 2E E0 01 27 02 20 28 70 25 E0 4E F2 90 21 88 42 26 D8
9:04:20 AM
9:04:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B3 09 81 80 59 E0 14 98 18 B3 28 78 68 B9 04 F5 0D 70 15 21 80 46 CB F7 A2 FC BD F8 26 20 0A A9 40 46 CB F7 6A FC 01 20 28 70 14 98 11 F0 3C F8 98 B1 01 28 0D D1 04 F5 0D 71 14 98 11 F0 15 F9 38 B1 02 20 28 70 06 E0 50 46 D3 F7 29 F9 34 E0 08 E0 85 F8 00 90 01 27 F6 E7 50 46 D3 F7 2C F9 15 99 11 B1 86 F8 1A 95 F3 E7 D4 F8 6C 12 81 42 23 D8 EE E7 B8 F1 00 0F EB D0 D8 F8 C8 00 00 28 E7 D0 00 7A
9:04:21 AM
9:04:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B4 09 81 80 01 28 E4 D1 98 F8 0C 00 01 28 07 D0 50 46 D3 F7 11 F9 40 F6 B8 31 88 42 0B D3 D8 E7 D6 F8 0C 05 00 28 CC D0 50 46 D3 F7 05 F9 40 F2 DC 51 88 42 C5 D2 00 20 28 70 38 46 50 E7 2D E9 F0 4F 82 46 D1 F8 78 05 00 26 00 F2 19 55 00 F5 20 74 00 F2 04 5B 08 68 8B B0 B0 46 D0 F8 A8 93 08 B1 D0 F8 A4 83 00 20 0A 90 8D F8 00 00 AD F8 24 00 BB F8 00 00 10 B9 58 46 D3 F7 D5 F8 94 F8 73 02 03 27
9:04:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B5 09 81 80 C0 EB C0 00 04 EB 80 00 90 F8 9C 01 06 28 4D D2 DF E8 00 F0 03 30 4C 4C 32 4B D4 F8 30 02 00 7B 98 B3 01 28 44 D1 5F EA 08 00 3F D0 0A AB 09 AA 69 46 02 F0 98 F8 80 46 02 28 1B D0 58 46 D3 F7 B9 F8 BA F1 00 0F 15 D1 4E F2 90 21 88 42 2F D9 B8 F1 01 0F 2A D1 04 F5 13 71 68 46 E3 F7 FE FB 10 BB B4 F8 70 02 BD F8 24 10 88 42 1E D1 0A 98 06 28 1B D1 01 26 09 E0 5F EA 09 00 16 D0 10 F0
9:04:22 AM
9:04:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B6 09 81 80 91 FF 38 B1 01 28 11 D1 F4 E7 11 E0 58 46 D3 F7 85 F8 0D E0 58 46 D3 F7 8D F8 BA F1 00 0F 05 D1 D4 F8 6C 12 81 42 03 D8 00 E0 01 26 2F 70 ED E7 0B B0 30 46 BD E8 F0 8F 2D E9 F0 47 D0 F8 78 55 8A 46 40 F2 19 51 05 F2 1C 52 95 F8 F3 84 00 23 4B 55 10 78 05 F5 20 76 04 28 21 D0 96 F8 74 72 86 F8 75 32 A6 F8 78 32 13 70 C8 EB C8 00 C5 F8 0C 35 06 EB 80 04 AB 80 B4 F8 90 01 99 46 18 B1
9:04:23 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:04:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B7 09 81 80 04 F5 C8 70 D3 F7 4A F8 48 46 C4 F8 98 91 5F EA 0A 01 4F F0 06 09 4F F0 01 0A 09 D0 03 21 20 E0 13 70 95 F8 1B 15 40 46 BD E8 F0 47 19 F0 71 BB 94 F8 8C 11 94 F8 9D 21 91 42 11 D2 84 F8 8D A1 94 F8 8C 01 40 1C 84 F8 8C 01 B8 F1 00 0F 04 D0 A8 F1 01 00 86 F8 73 02 16 E0 86 F8 73 92 13 E0 04 21 84 F8 8D 11 84 F8 8C 01 95 F8 1B 15 40 46 19 F0 4F FB 40 46 19 F0 3B FB 06 2F 04 D0 7F 1E
9:04:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B8 09 81 80 86 F8 73 72 86 F8 74 92 94 F8 8D 01 01 28 07 D0 95 F8 1B 15 40 46 19 F0 15 FF 08 B1 84 F8 8D A1 04 F5 C6 71 40 46 01 E0 10 09 05 00 BD E8 F0 47 19 F0 01 BB F0 B5 04 46 00 20 D4 F8 78 35 24 68 03 F5 20 71 03 F2 19 52 91 F8 73 52 D4 F8 A4 43 C5 EB C5 05 01 EB 85 05 D3 F8 14 35 95 F8 9C 61 03 25 06 2E 10 D2 DF E8 06 F0 03 10 0F 0F 18 1A D1 F8 30 12 09 7B 31 B1 01 29 05 D1 00 2C 03 D0
9:04:24 AM
9:04:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 B9 09 81 80 B4 F8 C8 10 0E E0 15 70 F0 BD D1 F8 30 12 09 7B 00 29 F8 D0 01 29 F6 D0 F0 BD 01 20 F0 BD 00 2B FC D0 99 8C 00 29 F8 D0 F0 BD F0 B5 03 46 00 20 D3 F8 78 25 1B 68 02 F5 20 72 92 F8 73 62 C6 EB C6 06 02 EB 86 06 96 F8 9C 61 D3 E9 E9 45 06 2E 23 D2 DF E8 06 F0 03 22 22 22 13 21 D2 F8 30 12 09 7B 00 29 19 D0 01 29 17 D1 00 2C 15 D0 29 20 83 F8 98 03 01 20 A4 F8 D0 00 0D E0 00 2D 0C D0
9:04:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 BA 09 81 80 2A 20 83 F8 98 03 86 20 B1 FB F0 F0 40 1C 4C F2 50 31 48 43 C2 F8 6C 02 01 20 F0 BD 2D E9 F1 4F 9E B0 D2 F7 6B FF 17 90 00 20 81 46 0B 90 1E 98 4F F0 00 0B 00 F5 AF 62 D0 F8 78 05 DA 46 80 F8 F6 B4 1E 98 16 68 41 F2 F4 22 D0 F8 04 80 40 F2 E7 40 07 90 08 F1 24 00 06 F5 9A 75 06 F5 20 74 AD F8 60 B0 8D F8 64 B0 08 F1 2C 01 0D 90 01 90 D3 F7 92 F8 40 F2 64 67 39 46 01 98 D3 F7 91 F8
9:04:25 AM
9:04:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 BB 09 81 80 00 28 7C D0 01 46 3A 46 02 A8 D3 F7 85 F8 39 46 0D 98 D3 F7 86 F8 01 00 72 D0 3A 46 14 A8 D3 F7 7B F8 34 21 0D 98 D3 F7 7C F8 C8 F8 14 00 00 28 65 D0 0F 21 88 F8 10 10 07 46 20 78 00 28 5E D0 1E 98 B4 F8 78 12 00 F2 94 48 E9 BB 94 F8 75 02 00 EB 40 00 04 EB 80 00 41 88 AD F8 44 10 41 68 CD F8 46 10 00 89 AD F8 4A 00 94 F8 75 02 11 A9 00 EB 40 00 04 EB 80 00 80 7A 8D F8 4C 00 28 46
9:04:26 AM
9:04:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 BC 09 81 80 FD F7 7F F9 30 B1 28 46 C5 F8 0C 80 FD F7 33 FF 38 B1 0A E0 01 20 85 F8 64 00 81 46 C5 F8 0C 80 03 E0 01 20 85 F8 64 00 81 46 B4 F8 78 02 58 B9 20 78 48 B1 02 20 8D F8 64 00 01 22 19 A9 02 A8 D3 F7 83 F8 20 78 00 E0 06 E0 AD F8 60 00 01 22 18 A9 02 A8 D3 F7 79 F8 B2 88 92 B1 B1 1D 02 A8 D3 F7 73 F8 00 28 0A D0 A6 F8 04 B0 21 78 94 F8 75 02 81 42 05 D8 01 20 84 F8 76 02 ED E0 D3 E0
9:04:27 AM
9:04:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 BD 09 81 80 F4 E0 59 EA 0A 00 15 D1 94 F8 75 02 00 EB 40 00 04 EB 80 00 80 89 68 B1 95 F8 34 10 07 29 09 D1 95 F8 88 10 02 29 05 D1 4F F0 01 0A 29 46 19 F0 2D FA 18 B1 B9 F1 00 0F 04 D0 0B E0 01 20 85 F8 64 00 05 E0 14 AA 0E A9 28 46 FD F7 84 FF 08 B9 4F F0 01 09 59 EA 0A 00 18 D1 94 F8 75 02 4F F0 01 0A 00 EB 40 00 04 EB 80 00 80 89 70 B1 B0 F5 80 5F 05 D2 9D F8 38 10 02 29 01 D1 BD F8 3C 10
9:04:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 BE 09 81 80 01 20 85 F8 64 00 C5 F8 90 B0 07 E0 B9 F1 00 0F 04 D1 0E A9 02 A8 F3 F7 C3 FA B8 B9 8D F8 38 B0 0E A9 02 A8 F3 F7 BC FA 00 28 7D D0 95 F8 64 00 50 B1 D5 F8 8C 00 18 B1 D5 F8 90 10 81 42 03 D2 D5 F8 90 00 C5 F8 8C 00 4F F0 00 09 95 F8 64 00 60 B1 D5 E9 23 01 09 1A 01 29 07 D9 40 1C C5 F8 8C 00 4F F0 01 09 AD F8 54 B0 6E E0 BD F8 0C 00 07 99 88 42 14 D9 40 1A 80 B2 09 90 B0 F5 96 7F
9:04:28 AM
9:04:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 BF 09 81 80 74 D8 02 99 07 98 09 9A 01 44 B0 1D CB F7 08 F9 09 99 B1 80 07 98 AD F8 0C 00 01 20 A4 F8 78 02 AD F8 54 B0 95 F8 64 00 E8 B3 D6 F8 0C 05 88 B9 94 F8 75 02 21 78 40 1C 81 42 0B D8 01 20 38 71 87 F8 0C B0 02 98 78 61 BD F8 0C 00 38 82 95 F8 64 00 40 B3 94 F8 75 02 4F F0 00 0A 40 1C C0 B2 84 F8 75 02 21 78 81 42 2C D9 00 EB 40 00 04 EB 80 00 41 88 AD F8 44 10 41 68 CD F8 46 10 00 89
9:04:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C0 09 81 80 AD F8 4A 00 94 F8 75 02 11 A9 00 EB 40 00 04 EB 80 00 80 7A 8D F8 4C 00 28 46 FD F7 72 F8 30 B9 4F F0 01 09 01 E0 10 E0 5B E0 85 F8 64 90 28 46 C5 F8 0C 80 FD F7 1F FE 38 B9 4F F0 01 09 85 F8 64 90 02 E0 01 20 84 F8 76 02 D2 F7 D7 FD 17 99 40 1A 0B 90 94 F8 76 02 48 B1 B0 88 10 B1 00 BF 84 F8 76 B2 B4 F8 78 02 50 B1 17 E0 38 E0 B0 88 00 28 F5 D1 0B 98 B0 F5 61 7F 7F F6 ED AE F1 E7
9:04:29 AM
9:04:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C1 09 81 80 94 F8 76 02 28 B1 B0 88 18 B9 0B 98 B0 F5 61 7F 01 D9 01 20 00 E0 00 20 A4 F8 78 02 0C 21 0D 98 D2 F7 FF FE 05 00 1B D0 1A A8 D2 F7 D7 FC 00 28 17 D0 29 46 1A A8 F2 F7 A9 F9 00 28 11 D0 08 21 0D 98 D2 F7 EE FE 38 60 00 28 0A D0 0C 21 01 80 38 68 06 F2 0C 51 45 60 D6 F8 0C 05 18 B1 0D E0 00 20 1F B0 26 E5 96 F8 18 05 06 F5 A3 62 0F 28 02 D3 86 F8 18 B5 01 E0 40 1C 10 70 96 F8 18 05
9:04:30 AM
9:04:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C2 09 81 80 38 72 B4 F8 78 02 78 B1 D6 F8 0C 05 40 1C 08 60 02 20 38 71 08 68 38 61 94 F8 76 02 38 73 02 98 B8 61 BD F8 0C 00 B8 82 01 20 DA E7 10 B5 04 46 00 68 00 28 15 D0 80 79 02 F0 E6 FC 00 28 20 68 04 D0 4F F4 82 71 04 F0 E1 F8 09 E0 C0 79 02 28 08 D0 04 28 06 D0 20 46 FE F7 1F FD 00 28 00 D0 01 20 10 BD 20 46 FE F7 DD FC F7 E7 2D E9 FF 41 04 46 D4 E9 00 05 80 88 01 28 04 D0 20 46 FF F7
9:04:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C3 09 81 80 D5 FF BD E8 FF 81 68 68 C0 69 A8 B1 00 88 98 B1 08 28 11 D8 00 20 C4 F8 A2 04 C4 F8 A6 04 68 68 C0 69 00 88 A4 F8 A0 04 68 68 C0 69 02 88 41 68 04 F2 A2 40 CA F7 F4 FF 20 46 FE F7 C5 F9 00 28 DF D0 05 F1 24 00 00 90 05 F1 10 03 1F 46 2A 46 04 F2 94 41 20 68 03 F0 2F FB 00 28 D1 D0 68 69 00 7B 38 B9 20 68 C1 79 61 72 80 7A A0 72 68 69 00 7B 50 B1 68 69 41 7B 01 29 06 D1 80 7B 0D 28
9:04:31 AM
9:04:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C4 09 81 80 03 D1 20 68 80 79 24 F0 38 FD 20 68 00 89 00 B1 01 20 80 46 41 F2 22 30 29 18 40 F2 64 62 0E 46 01 A8 D2 F7 39 FE 39 46 01 A8 F4 F7 F3 FF 00 28 A7 D0 05 F5 80 57 BD F8 08 10 A7 F8 20 13 B8 F1 01 0F 05 D0 4F F4 82 71 20 68 04 F0 5F F8 98 E7 68 69 00 7B 18 B9 02 21 20 68 02 F0 8B FC B7 F8 20 23 03 AB 31 46 20 68 02 F0 DA FD 20 46 FE F7 17 F9 86 E7 2D E9 FF 41 44 68 05 46 04 F1 24 00
9:04:32 AM
9:04:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C5 09 81 80 00 90 04 F1 10 03 98 46 22 46 05 F2 94 41 28 68 03 F0 5E FD 00 28 21 D0 28 68 00 89 08 B1 01 27 00 E0 00 27 41 F2 22 30 21 18 40 F2 64 62 0E 46 01 A8 D2 F7 F1 FD 41 46 01 A8 F4 F7 AB FF 00 28 0C D0 04 F5 80 54 BD F8 08 20 A4 F8 20 23 28 68 01 2F 04 D0 4F F4 82 71 04 F0 18 F8 51 E7 03 AB 31 46 02 F0 9D FD 28 46 FE F7 DA F8 49 E7 2D E9 F0 47 8C B0 05 46 44 68 FE F7 9D FD 00 28 6A D0
9:04:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C6 09 81 80 28 68 00 28 67 D0 90 F8 98 13 1F 29 0D D1 01 68 09 88 C9 07 09 D1 81 79 04 29 06 D0 B0 F8 9C 03 08 B1 01 27 05 E0 00 27 03 E0 60 68 00 79 C0 F3 80 17 04 F1 0A 00 41 F2 22 39 00 EB 09 01 4F F0 0A 0A 88 46 40 F2 5A 62 06 A8 D2 F7 A5 FD 04 F1 10 01 06 A8 F4 F7 5E FF 00 28 3C D0 04 F5 80 56 BD F8 1C 00 A6 F8 20 03 A8 69 28 B1 60 69 01 78 02 29 01 D1 01 7C E1 B1 28 46 FE F7 91 F8 68 68
9:04:33 AM
9:04:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C7 09 81 80 00 8C C0 07 1B D0 03 A9 05 F2 94 40 CD E9 00 01 B6 F8 20 33 52 46 40 F2 64 61 04 EB 09 00 F5 F7 0B FF 04 00 17 D0 28 46 FE F7 E0 F8 00 28 12 D0 0A E0 82 8A 81 69 28 46 FE F7 7E F8 DF E7 B6 F8 20 03 44 46 AD F8 0C 00 28 68 01 2F 06 D0 4F F4 82 71 03 F0 9B FF 0C B0 BD E8 F0 87 09 AB BD F8 0C 20 21 46 02 F0 1C FD F5 E7 2D E9 F0 43 8B B0 05 46 FF F7 61 F8 00 28 52 D0 D5 E9 00 04 90 F8
9:04:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C8 09 81 80 98 13 1F 29 0D D1 01 68 09 88 C9 07 09 D1 81 79 04 29 06 D0 B0 F8 9C 03 08 B1 01 27 05 E0 00 27 03 E0 60 68 00 79 C0 F3 80 17 04 F1 0A 00 41 F2 22 38 00 EB 08 01 4F F0 0A 09 0E 46 40 F2 5A 62 06 A8 D2 F7 29 FD 04 F1 10 01 06 A8 F4 F7 E2 FE 00 28 25 D0 4F F4 99 50 BD F8 1C 30 03 53 68 68 00 8C C0 07 13 D0 03 A9 05 F2 94 40 CD E9 00 01 4A 46 40 F2 64 61 04 EB 08 00 F5 F7 9D FE 06 00
9:04:34 AM
9:04:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 C9 09 81 80 0E D0 28 46 FE F7 72 F8 00 28 09 D0 01 E0 AD F8 0C 30 28 68 01 2F 06 D0 4F F4 82 71 03 F0 36 FF 0B B0 BD E8 F0 83 09 AB BD F8 0C 20 31 46 02 F0 B7 FC 28 46 FD F7 F4 FF F2 E7 2D E9 F0 43 8B B0 05 46 FF F7 14 F9 00 28 EA D0 D5 E9 00 04 90 F8 98 13 1F 29 0D D1 01 68 09 88 C9 07 09 D1 81 79 04 29 06 D0 B0 F8 9C 03 08 B1 01 27 05 E0 00 27 03 E0 60 68 00 79 C0 F3 80 17 04 F1 0A 00 41 F2
9:04:35 AM
9:04:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 CA 09 81 80 22 38 00 EB 08 01 4F F0 0A 09 0E 46 40 F2 5A 62 06 A8 D2 F7 C1 FC 04 F1 10 01 06 A8 F4 F7 7A FE 00 28 BD D0 4F F4 99 50 BD F8 1C 30 03 53 68 68 00 8C C0 07 13 D0 03 A9 05 F2 94 40 CD E9 00 01 4A 46 40 F2 64 61 04 EB 08 00 F5 F7 35 FE 06 00 A6 D0 28 46 FE F7 0A F8 00 28 A1 D0 01 E0 AD F8 0C 30 28 68 01 2F 04 D0 4F F4 82 71 03 F0 CE FE 96 E7 09 AB BD F8 0C 20 31 46 02 F0 51 FC 28 46
9:04:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 CB 09 81 80 FD F7 8E FF 8C E7 01 68 89 79 04 29 1D D0 01 29 1B D0 B0 F8 94 14 C1 B1 01 29 04 D0 02 29 06 D0 03 29 10 D1 09 E0 90 F8 4F 05 C0 06 02 E0 90 F8 4F 05 80 06 00 28 08 DB 05 E0 90 F8 4F 05 C0 F3 01 10 03 28 01 D0 00 20 70 47 01 20 70 47 41 68 09 78 60 29 1C D0 42 7A 01 2A 06 D0 02 2A 0D D0 03 2A 07 D0 04 2A 11 D1 0D E0 90 F8 4F 05 10 F0 30 0F 0B D1 49 1E 57 29 08 D9 09 E0 90 F8 4F 05
9:04:36 AM
9:04:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 CC 09 81 80 10 F0 30 0F 02 D1 C0 39 18 29 01 D8 00 20 70 47 01 20 70 47 2D E9 F0 4F D0 F8 78 65 87 B0 07 46 06 F2 19 55 E8 1C 00 90 D4 F7 89 F8 10 F0 80 00 06 90 4F F0 00 08 D7 F8 04 90 06 F5 20 74 4F F0 14 0B AD F8 08 80 AD F8 0C 80 4F F0 03 0A 28 D0 94 F8 73 02 06 28 13 D0 D4 F8 30 12 4A 7A 01 21 81 40 0A 42 0C D0 C0 EB C0 00 04 EB 80 00 90 F8 8D 01 02 28 04 D1 00 21 38 46 06 9A FF F7 5C FA
9:04:37 AM
9:04:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 CD 09 81 80 96 F8 1A 05 03 28 06 D0 02 28 01 D0 86 F8 1A A5 07 B0 BD E8 F0 8F FA F7 2F FE 02 20 86 F8 1A 05 F6 E7 28 78 20 B1 01 28 7E D0 02 28 7D D1 59 E1 D4 F8 2C 02 01 21 02 78 D7 F8 78 05 90 F8 1B 05 81 40 0A 42 E4 D0 D4 F8 30 12 49 7A 89 B3 94 F8 73 02 06 28 01 D2 40 1C 5A E0 94 F8 74 02 06 28 0B D0 D4 F8 30 02 40 7A C0 07 03 D0 00 20 84 F8 73 02 04 E0 06 20 84 F8 74 02 84 F8 73 82 D4 F8
9:04:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 CE 09 81 80 30 02 94 F8 73 22 41 7A 01 20 90 40 01 42 3D D0 20 46 19 F0 5B F9 03 28 04 D0 01 28 0A D0 02 28 26 D0 2D E0 D7 F8 78 05 90 F8 1B 05 18 F0 AA FD AE E7 3B E0 01 20 28 70 94 F8 73 12 02 20 C1 EB C1 01 04 EB 81 01 81 F8 8D 01 94 F8 73 02 C0 EB C0 01 04 EB 81 01 01 F5 C6 71 18 F0 6C FD 94 F8 73 02 21 46 18 F0 EB FC B8 B9 85 F8 00 A0 14 E0 94 F8 73 02 C0 EB C0 00 04 EB 80 00 90 F8 8C 01
9:04:38 AM
9:04:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 CF 09 81 80 20 B1 00 21 38 46 06 9A FF F7 D6 F9 08 F1 01 00 00 F0 FF 08 B8 F1 06 0F 9F D3 B8 F1 06 0F 07 D1 06 20 84 F8 73 02 03 E0 05 E0 29 E0 18 F0 6A FD 28 78 01 28 2F D1 94 F8 73 02 C0 EB C0 00 04 EB 80 00 90 F8 9C 01 08 B1 01 28 25 D1 D4 F8 30 02 00 7B 01 28 20 D1 39 46 06 98 FF F7 02 F8 86 F8 1A 05 02 28 0C D0 04 28 0A D0 00 28 96 F8 F3 04 09 D0 88 B1 96 F8 F4 04 06 28 0D D0 00 20 C5 E0
9:04:39 AM
9:04:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D0 09 81 80 85 F8 00 A0 BB E0 00 28 05 D0 96 F8 F4 14 06 29 01 D1 86 F8 F4 04 AF E0 20 46 19 F0 3B F8 01 28 EE D1 94 F8 72 02 00 28 EA D1 38 46 FF F7 02 FA 00 28 55 D0 EA F7 DD FA 0E 28 51 D3 39 68 D0 46 81 F8 06 A0 FE 49 38 68 09 7B 81 73 38 68 81 79 FB 4A 02 EB 81 01 49 88 01 82 39 46 06 98 FE F7 EA FF E8 B3 00 98 00 78 03 28 3F D0 04 28 3D D0 38 46 FF F7 53 FA A0 B3 09 EB 0B 01 41 F2 22 30
9:04:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D1 09 81 80 01 44 AB F2 64 60 40 42 82 B2 8A 46 04 A8 D2 F7 03 FB 09 F1 10 01 04 A8 F4 F7 BC FC 08 B3 09 F5 80 56 BD F8 14 00 A6 F8 20 03 00 21 38 46 FD F7 8F FE D0 B3 38 46 FD F7 7F FE B0 B3 38 46 FD F7 81 FE 90 B3 B7 F8 94 14 07 F2 94 40 69 B3 01 22 87 F8 4C 25 01 29 0C D0 02 29 0C D0 03 29 01 E0 4A E0 03 E0 22 D0 85 F8 00 80 D1 E6 85 F8 00 80 45 E0 10 21 00 E0 20 21 87 F8 4D 15 02 A9 CD E9
9:04:40 AM
9:04:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D2 09 81 80 00 01 B6 F8 20 33 41 F2 22 36 5A 46 40 F2 64 61 09 EB 06 00 F5 F7 50 FC 5F EA 00 09 E6 D0 38 46 FD F7 24 FE 00 28 E1 D0 07 E0 01 E0 30 21 E3 E7 B6 F8 20 03 D1 46 AD F8 08 00 BD F8 08 10 38 46 FF F7 B3 F9 00 28 D1 D0 03 AB BD F8 08 20 49 46 38 68 02 F0 65 FA 00 28 C8 D0 94 F8 76 02 A0 B1 02 20 28 70 39 46 06 98 FF F7 67 F8 20 B1 01 21 38 46 06 9A FF F7 E0 F8 28 78 03 28 B5 D1 00 21
9:04:41 AM
9:04:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D3 09 81 80 38 46 06 9A FF F7 D8 F8 82 E6 01 20 28 70 7F E6 F0 B5 45 68 04 46 05 F5 80 56 87 B0 B6 F8 20 03 00 28 7D D0 05 F1 24 00 41 F2 F4 22 05 F1 2C 01 07 46 D2 F7 71 FA 41 F2 22 30 29 18 B6 F8 20 23 05 A8 D2 F7 69 FA 00 26 AD F8 00 60 05 A8 CD E9 01 07 04 F1 34 00 03 90 04 F2 94 40 04 90 31 46 20 46 FD F7 F5 FD 20 46 FD F7 E6 FD 20 46 FD F7 E9 FD 29 46 68 46 F4 F7 8C FB 50 B1 94 F8 4F 05
9:04:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D4 09 81 80 10 F0 30 0F 17 D0 20 68 80 79 24 F0 CC F9 20 B9 08 E0 BD F8 00 00 40 04 20 D5 20 68 80 79 24 F0 93 F9 1B E0 94 F8 4F 05 10 F0 30 0F 03 D0 20 46 FD F7 A2 FD 90 B1 BD F8 00 00 40 04 00 28 60 68 01 8C 10 DA 41 F0 01 01 01 84 94 F8 4E 05 84 F8 4C 05 94 F8 4F 05 84 F8 4D 05 0B E0 20 46 FE F7 E7 F8 07 B0 F0 BD 21 F0 01 01 01 84 84 F8 4C 65 84 F8 4D 65 2D 78 60 2D 05 D0 62 2D 03 D0 20 46
9:04:42 AM
9:04:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D5 09 81 80 FF F7 81 FD 60 B1 20 68 81 79 21 72 81 7A A1 72 80 79 02 F0 39 F8 78 B1 60 2D E2 D0 68 1E 00 E0 2D E0 57 28 01 D8 04 20 04 E0 A5 F1 C0 00 18 28 D7 D8 03 20 60 72 10 E0 20 68 62 2D C1 79 61 72 04 D1 C1 79 02 29 14 D0 04 29 12 D0 00 21 80 88 04 28 02 D0 60 2D 00 D0 89 B1 20 46 FF F7 77 FD 68 B1 C0 2D 17 D0 06 DC 60 2D 0C D0 62 2D 06 D1 0D E0 01 21 EB E7 C1 2D 11 D0 C3 2D 13 D0 20 46
9:04:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D6 09 81 80 FE F7 4B F8 AD E7 20 46 FF F7 30 FB A9 E7 20 46 FF F7 B0 FB A5 E7 20 46 FF F7 E9 FB A1 E7 20 46 FF F7 63 FC 9D E7 20 46 FF F7 C7 FC 99 E7 70 B5 AD F5 CE 5D 04 00 62 D0 20 68 00 28 5F D0 01 A8 60 60 D4 F8 78 05 10 B1 20 46 FF F7 63 FD 41 F2 24 33 6B 44 40 F2 2C 62 99 1C 20 68 02 F0 C9 F8 10 B1 20 46 FF F7 14 FF 68 46 D2 F7 38 F8 B4 F8 50 01 04 F2 84 55 C1 07 0C D0 20 F0 01 00 A4 F8
9:04:43 AM
9:04:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D7 09 81 80 50 01 00 98 C4 F8 8C 05 28 46 D2 F7 4B F8 80 20 23 F0 B2 FF 28 46 D2 F7 4D F8 41 F2 88 31 88 42 08 D8 21 68 B4 F9 84 05 89 88 01 29 00 D0 00 21 08 42 0B D0 D4 F8 8C 05 00 99 88 42 06 D0 28 46 D2 F7 2C F8 4F F0 FF 30 23 F0 B6 F8 20 68 81 88 04 F2 7C 50 05 46 01 29 14 D0 D2 F7 23 F8 00 BF B4 F8 50 01 01 07 0A D5 20 F0 08 00 A4 F8 50 01 CF F7 AA FC 00 28 02 D1 01 20 23 F0 C8 FD 0D F5
9:04:44 AM
9:04:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D8 09 81 80 CE 5D 70 BD D2 F7 16 F8 32 28 E9 D9 28 46 D2 F7 05 F8 B4 F8 50 01 81 07 06 D5 20 F0 02 00 A4 F8 50 01 01 20 D3 F7 A1 FD B4 F8 50 01 41 07 06 D5 20 F0 04 00 A4 F8 50 01 02 20 D3 F7 96 FD 01 E0 3E D5 06 00 B4 F8 50 01 C1 06 C9 D5 20 F0 10 00 A4 F8 50 01 00 20 23 F0 9A FD CF F7 8A FA BF E7 2D E9 F0 41 00 F1 A8 05 04 46 28 68 00 27 10 B1 E9 F7 A2 FD 2F 60 04 F1 AC 05 28 68 10 B1 E9 F7
9:04:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 D9 09 81 80 9B FD 2F 60 04 F1 B0 06 30 68 28 60 68 B1 40 68 30 60 00 B9 77 60 28 68 47 60 30 89 40 1E 30 81 28 68 10 B1 E9 F7 88 FD EE E7 C0 34 20 68 28 60 68 B1 40 68 20 60 00 B9 67 60 28 68 47 60 20 89 40 1E 20 81 28 68 10 B1 E9 F7 76 FD EE E7 01 20 BD E8 F0 81 70 B5 04 46 40 6B E9 F7 6D FD 00 25 65 63 A0 6B E9 F7 68 FD A5 63 E0 6B 60 B1 41 68 E1 63 01 B9 25 64 45 60 B4 F8 44 10 49 1E A4 F8
9:04:45 AM
9:04:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 DA 09 81 80 44 10 E9 F7 59 FD F0 E7 E0 6C 60 B1 41 68 E1 64 01 B9 25 65 45 60 B4 F8 54 10 49 1E A4 F8 54 10 E9 F7 4A FD F0 E7 01 20 70 BD 10 B5 04 46 FF F7 D1 FF 20 46 FF F7 94 FF 00 20 60 63 02 21 A0 63 A4 F8 46 10 A4 F8 56 10 20 70 60 70 42 1E A2 60 E2 60 22 61 A0 84 C4 F8 A8 00 C4 F8 AC 00 A4 F8 BA 10 A4 F8 CA 10 84 F8 5E 00 84 F8 5F 00 01 20 C4 F8 84 20 10 BD B2 F9 08 00 B2 F9 0A 30 98 42
9:04:46 AM
9:04:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 DB 09 81 80 03 DB 90 89 40 1C 90 81 0B E0 51 B1 00 20 48 60 50 68 40 B1 41 60 51 60 10 89 40 1C 10 81 01 20 70 47 00 20 70 47 11 60 F5 E7 10 B5 02 29 04 D1 D0 F8 D4 00 03 21 03 F0 A4 FA 01 20 10 BD 10 B5 FF F7 F3 FF 01 20 10 BD 10 B5 05 21 01 70 89 1F C1 60 01 61 00 21 80 F8 26 10 02 21 FF F7 EF FF 01 20 10 BD 10 B5 04 46 00 20 A1 78 11 B9 E0 68 29 F0 85 F8 A1 78 01 29 02 D1 20 69 29 F0 7F F8
9:04:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 DC 09 81 80 40 1C 03 D0 20 46 FF F7 DF FF 01 20 10 BD 30 B5 89 B0 0C 00 15 46 1C D0 01 A8 28 F0 76 FF 01 A9 28 46 28 F0 75 FF 00 20 07 90 08 90 07 A8 00 23 00 90 01 AA 19 46 28 46 28 F0 92 FF 00 28 06 D0 21 46 28 46 29 F0 D1 FA 00 28 00 D0 01 20 09 B0 30 BD 00 20 FB E7 0A 68 82 B9 02 68 0A 60 6A B1 53 68 00 22 03 60 03 B9 42 60 0B 68 5A 60 02 89 52 1E 02 81 08 68 08 B1 01 20 70 47 00 20 70 47
9:04:47 AM
9:04:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 DD 09 81 80 70 B5 86 B0 E9 B3 8A 68 DA B3 29 23 8D F8 15 30 04 24 8D F8 14 40 55 79 16 79 8D F8 11 30 05 EB 06 25 AD F8 16 50 8D F8 10 40 D3 78 94 78 00 F1 5C 00 03 EB 04 23 AD F8 12 30 05 AB 01 93 04 AB 02 93 00 23 03 93 8B 68 08 33 8B 60 8B 89 08 3B 8B 81 8B 8A 08 3B 8B 82 D3 78 94 78 03 EB 04 23 43 70 53 79 12 79 03 EB 02 22 02 70 80 6F 4F F0 01 03 01 AA 03 F0 F0 F8 00 28 00 D0 01 20 06 B0
9:04:48 AM
9:04:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 DE 09 81 80 70 BD FF E7 00 20 FA E7 FE B5 46 6B 00 27 04 46 01 25 00 97 01 97 6A 46 31 46 02 97 FF F7 B0 FF 18 B9 30 46 E9 F7 48 FC 00 25 28 46 67 63 FE BD 30 B1 80 68 20 B1 02 78 12 B9 42 78 01 2A 01 D0 00 20 70 47 C2 79 80 79 02 EB 00 20 08 80 01 20 70 47 2D E9 F0 47 04 46 0D 00 02 D0 60 6B 18 B1 07 E0 00 20 BD E8 F0 87 E9 F7 E4 FB 60 63 00 28 F8 D0 AF 8A 00 26 08 E0 94 F8 26 00 48 B1 01 28
9:04:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 DF 09 81 80 11 D0 02 28 50 D0 84 F8 26 60 00 2F F4 D1 01 20 E8 E7 60 6B 20 B9 E9 F7 CD FB 60 63 00 28 E1 D0 26 85 01 20 2C E0 21 8D A8 89 C1 F1 08 01 AA 68 88 42 00 D3 08 46 1F FA 80 F8 0F FA 88 F1 89 46 60 6B E9 F7 F0 FC 60 6B 49 46 80 8A 20 85 28 46 E9 F7 7F FD 04 E0 28 46 E9 F7 CB FB 05 00 02 D0 A8 89 00 28 F7 D0 20 8D 08 28 D0 D1 04 F1 2A 01 60 6B FF F7 9D FF 30 B1 A7 EB 08 00 87 B2 02 20
9:04:49 AM
9:04:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E0 09 81 80 84 F8 26 00 C1 E7 28 46 E9 F7 D6 FB 60 6B E9 F7 D3 FB 66 63 26 85 84 F8 26 60 20 46 FF F7 5A FE 20 46 FF F7 DF FE B2 E7 60 8D 21 8D AA 68 41 1A A8 89 08 31 81 42 00 D8 08 46 1F FA 80 F8 0F FA 88 F1 89 46 60 6B E9 F7 AE FC 60 6B 49 46 80 8A 20 85 28 46 E9 F7 3D FD 04 E0 28 46 E9 F7 89 FB 05 00 02 D0 A8 89 00 28 F7 D0 60 8D 21 8D 08 30 81 42 8C D1 20 46 FF F7 47 FF 10 B9 60 6B E9 F7
9:04:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E1 09 81 80 9B FB 84 F8 26 60 A7 EB 08 00 87 B2 26 85 7C E7 70 B5 04 46 00 78 8C B0 06 28 44 D1 04 F1 1C 00 06 46 D1 F7 C7 FD E1 6A 88 42 0B D9 20 46 FF F7 11 FE 20 46 FF F7 96 FE 01 28 37 D1 30 46 D1 F7 AD FD 33 E0 04 A8 28 F0 20 FE 04 A9 E0 68 28 F0 1F FE 00 25 02 A8 02 95 03 95 00 90 2B 46 2A 46 04 A9 E0 68 28 F0 3C FE 00 B3 0A 95 0A A9 E0 68 29 F0 31 F9 0A 99 71 B1 88 89 B8 B1 30 46 D1 F7
9:04:50 AM
9:04:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E2 09 81 80 91 FD 20 46 0A 99 FF F7 24 FF 01 28 10 D0 0A 98 E9 F7 52 FB 07 E0 01 28 05 D1 20 46 FF F7 DA FD 20 46 FF F7 5F FE 00 20 0C B0 E9 E6 01 20 FB E7 0A 95 FB E7 10 B5 04 46 00 F1 38 01 4C 30 FF F7 8A FE A1 6B 39 B1 20 46 E2 68 FF F7 60 FE 01 28 01 D1 00 20 A0 63 01 20 10 BD 2D E9 F0 41 04 46 10 F8 14 1B 9A B0 02 26 00 25 01 AF 80 46 08 29 74 D2 DF E8 01 F0 04 0C 29 39 59 74 BC E0 D4 F8
9:04:51 AM
9:04:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E3 09 81 80 D8 00 29 F0 05 FA 03 28 1D D1 01 20 2A E0 A0 78 58 B1 01 28 0C D0 25 70 A0 8C 40 1C A0 84 A0 68 40 1C 0C D0 26 70 A5 84 D6 E0 06 22 01 21 01 E0 11 22 02 21 02 20 28 F0 83 F8 A0 60 F0 E7 25 70 A0 8C 40 1C A0 84 BE E0 AD F8 40 60 A0 88 AD F8 42 00 11 95 10 22 10 A9 A0 68 28 F0 EB F8 40 1C 12 D0 03 20 20 70 B3 E0 A0 78 88 B1 01 28 0F D0 A0 68 28 F0 84 FE 25 70 A0 8C 40 1C A4 F8 24 00
9:04:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E4 09 81 80 29 F0 35 F9 76 28 08 D0 A0 68 28 F0 78 FE D6 E7 01 21 A0 68 28 F0 21 FA F2 E7 04 20 20 70 A5 84 40 46 D1 F7 FF FC 8E E0 40 46 D1 F7 03 FD B0 F5 FA 6F 09 D9 A0 68 28 F0 62 FE 25 70 A0 8C 40 1C A0 84 40 46 D1 F7 EA FC 01 21 A0 68 28 F0 05 FA 29 F0 0D F9 00 28 76 D1 05 20 C3 E7 72 E0 04 A8 28 F0 53 FD 04 A9 A0 68 28 F0 52 FD 01 95 00 97 02 95 00 23 1A 46 04 A9 A0 68 28 F0 71 FD C8 B1
9:04:52 AM
9:04:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E5 09 81 80 10 20 18 90 18 AA 14 A9 A0 68 28 F0 D9 FC E0 60 40 1C 17 D0 20 46 FF F7 1D FD 24 F8 46 6F 65 80 26 82 65 82 A4 F1 46 04 04 F1 1C 00 D1 F7 BA FC 06 20 20 70 60 78 C0 07 12 D0 A0 68 28 F0 1F FE 28 B1 0D E0 A0 68 28 F0 1A FE 25 70 F2 E7 07 20 20 70 60 78 20 F0 01 00 60 70 40 46 D1 F7 A2 FC D4 F8 D8 00 29 F0 54 F9 03 28 2B D1 2B E0 0A A8 28 F0 0B FD 0A A9 E0 68 28 F0 0A FD 01 95 00 97
9:04:53 AM
9:04:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E6 09 81 80 02 95 00 22 0A AB 11 46 E0 68 28 F0 29 FD 28 B1 20 46 FF F7 DF FC 20 46 FF F7 64 FD D4 F8 D8 00 29 F0 36 F9 03 28 0E D0 20 46 FF F7 D3 FC 20 46 FF F7 4A FD 07 E0 40 46 D1 F7 7C FC 41 F2 88 31 88 42 00 D9 25 70 A0 8C 42 F2 10 71 88 42 00 D9 A5 84 A0 68 40 1C 05 D0 20 46 FF F7 99 FE 20 46 FF F7 E8 FE 1A B0 B3 E4 10 B5 04 46 90 F8 5F 00 80 07 13 D4 94 F8 5E 00 09 28 11 D2 DF E8 00 F0
9:04:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E7 09 81 80 0E 0E 05 05 05 0E 0E 0E 0E 00 04 F1 98 00 D1 F7 49 FC 14 F8 5F 0F 40 F0 02 00 20 70 01 20 10 BD 00 20 10 BD 2D E9 F0 41 04 46 0D 00 03 D0 D4 F8 A8 00 10 B1 07 E0 00 20 8A E4 E9 F7 BB F9 C4 F8 A8 00 00 28 F8 D0 A9 89 AA 68 09 B2 D4 F8 A8 00 E9 F7 E9 FA 28 46 E9 F7 CC F9 05 00 F3 D1 04 F1 A0 04 4F F0 01 07 A0 68 62 88 4F F0 02 0C 81 8A 80 8A 60 80 A1 EB 02 01 A4 F1 A0 04 8B B2 04 F1
9:04:54 AM
9:04:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E8 09 81 80 A4 06 08 E0 94 F8 A0 00 48 B1 01 28 0A D0 02 28 21 D0 84 F8 A0 50 00 2B F4 D1 01 20 58 E4 84 F8 A0 70 F8 E7 B4 F8 A2 00 08 28 F6 D3 31 46 D4 F8 A8 00 FF F7 7D FD 20 B1 08 3B 9B B2 84 F8 A0 C0 E9 E7 04 F1 A0 04 A0 68 E9 F7 B6 F9 A5 60 65 80 04 F8 A0 59 06 E0 B4 F8 A4 00 B4 F8 A2 10 08 30 81 42 03 D9 20 46 FF F7 7F FF D6 E7 D5 D1 B4 F9 B8 00 B4 F9 BA 10 04 F1 A8 04 88 42 07 DB A0 8A
9:04:55 AM
9:04:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 E9 09 81 80 40 1C A0 82 54 F8 A8 09 E9 F7 96 F9 1C E0 20 68 81 68 08 31 81 60 20 68 81 89 08 39 81 81 21 68 88 8A 08 38 88 82 20 68 45 60 E0 68 A4 F1 A8 04 80 B1 D4 F8 A8 10 41 60 54 F8 A8 0F E0 60 20 8A 40 1C 20 82 A4 F1 A8 04 04 F1 A0 04 A5 60 65 80 25 70 A2 E7 D4 F8 A8 00 C4 F8 B0 00 EC E7 70 B5 04 46 90 F8 5E 00 8C B0 03 28 51 D1 94 F8 60 00 04 F1 90 05 01 28 28 46 04 D0 D1 F7 9B FB 4E F2
9:04:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 EA 09 81 80 90 21 03 E0 D1 F7 96 FB 41 F2 88 31 88 42 07 D9 20 46 FF F7 29 FF 78 B3 28 46 D1 F7 7F FB 39 E0 04 A8 28 F0 F2 FB 04 A9 D4 F8 84 00 28 F0 F0 FB 00 26 02 A8 02 96 03 96 00 90 33 46 32 46 04 A9 D4 F8 84 00 28 F0 0C FC B0 B1 0A 96 0A A9 D4 F8 84 00 28 F0 00 FF 0A 99 79 B1 88 89 60 B1 28 46 D1 F7 60 FB 20 46 0A 99 FF F7 1C FF 01 28 13 D0 0A 98 E9 F7 21 F9 0B E0 0C E0 01 28 08 D1 94 F8
9:04:56 AM
9:04:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 EB 09 81 80 5F 00 40 F0 04 00 84 F8 5F 00 20 46 FF F7 EC FE 00 20 C9 E5 01 20 C7 E5 0A 96 FB E7 10 B5 04 46 00 F1 AC 01 C0 30 FF F7 56 FC D4 F8 AC 10 69 B1 20 46 D4 F8 84 20 FF F7 2A FC 01 28 06 D1 04 F1 90 00 D1 F7 2F FB 00 20 C4 F8 AC 00 01 20 10 BD 70 B5 04 46 90 F8 5F 00 80 07 23 D5 D4 F8 AC 00 42 F2 10 76 04 F1 98 05 18 B9 B4 F9 C8 00 00 28 04 DD 28 46 D1 F7 1E FB B0 42 13 D3 94 F8 5F 00
9:04:57 AM
9:04:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 EC 09 81 80 40 07 0A D5 28 46 D1 F7 15 FB B0 42 0A D3 94 F8 5F 00 20 F0 04 00 84 F8 5F 00 28 46 D1 F7 0A FB B0 42 01 D2 00 20 6B E4 D4 F8 84 00 28 F0 67 FC 40 1C F8 D0 04 F1 5C 04 E0 78 20 F0 02 00 E0 70 28 46 D1 F7 EB FA 4F F0 FF 30 A0 62 00 20 84 F8 44 00 05 20 A0 70 04 F1 2C 00 D1 F7 E3 FA 01 20 4E E4 2D E9 F0 47 90 F8 5E 10 04 26 94 B0 77 1F 00 25 04 46 4F F0 08 09 0D F1 04 08 00 F1 88 0A
9:04:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 ED 09 81 80 09 29 7D D2 DF E8 01 F0 05 0D 60 A2 DA DE EB F3 FC 00 D4 F8 D8 00 28 F0 7B FF 03 28 34 D1 01 20 74 E0 94 F8 5F 00 C0 07 2E D0 94 F8 60 00 60 B3 01 28 2D D0 38 46 C4 F8 84 70 40 1C 41 D0 B4 F8 62 00 AD F8 42 00 02 26 AD F8 40 60 04 F1 64 01 D4 F8 84 00 2B F0 F0 F9 00 28 D4 F8 84 00 1F D0 08 22 10 A9 28 F0 8A F9 28 F0 C1 FE 76 28 1C D0 28 F0 BD FE C8 B1 04 F1 5C 04 A0 6A 28 F0 FF FB
9:04:58 AM
9:04:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 EE 09 81 80 A7 62 A5 70 A4 F1 5C 04 C9 E0 06 22 01 21 01 E0 11 22 02 21 02 20 27 F0 D3 FD C4 F8 84 00 CC E7 28 F0 ED FB C4 F8 84 70 B9 E0 50 46 D1 F7 7A FA 04 F8 5E 6F 60 78 20 F0 01 00 60 70 A4 F1 5E 04 AD E0 04 F8 5E 5F F5 E7 0A A8 28 F0 DE FA 0A A9 D4 F8 84 00 28 F0 DC FA 01 95 CD F8 00 80 02 95 00 22 46 46 0A AB 11 46 D4 F8 84 00 28 F0 F8 FA 40 B9 50 46 D1 F7 5E FA 4E F2 90 21 88 42 00 E0
9:04:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 EF 09 81 80 4C E0 06 D9 50 46 D1 F7 49 FA 07 20 84 F8 5E 00 85 E0 03 A8 28 F0 B9 FA 03 A9 D4 F8 84 00 28 F0 B7 FA 01 95 00 96 02 95 00 23 03 AA 19 46 D4 F8 84 00 28 F0 D5 FA 00 28 71 D0 03 20 84 F8 5E 00 50 46 D1 F7 2B FA 04 F1 90 00 45 E0 03 A8 28 F0 9C FA 03 A9 D4 F8 84 00 28 F0 9A FA 01 95 CD F8 00 80 02 95 00 23 47 46 03 AA 19 46 D4 F8 84 00 28 F0 B6 FA 90 B1 0A A8 28 F0 87 FA 0A A9 D4 F8
9:04:59 AM
9:04:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F0 09 81 80 84 00 28 F0 85 FA 01 95 00 97 02 95 00 22 0A AB 11 46 D4 F8 84 00 28 F0 A3 FA 10 B1 84 F8 5E 60 3D E0 D4 F8 D8 00 28 F0 B3 FE 03 28 F6 D1 20 46 FF F7 55 FE 20 46 FF F7 B1 FE 30 E0 20 46 FF F7 93 FD 2C E0 50 46 D1 F7 F5 F9 B0 F5 7A 7F 26 D9 06 20 84 F8 5E 00 50 46 D1 F7 E4 F9 1F E0 50 46 D1 F7 E0 F9 84 F8 5E 90 19 E0 09 E0 FF E7 D4 F8 84 00 28 F0 44 FB 40 1C 11 D0 C4 F8 84 70 EE E7
9:05:00 AM
9:05:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F1 09 81 80 50 46 D1 F7 D7 F9 40 F6 B8 31 88 42 07 D9 50 46 D1 F7 C4 F9 84 F8 5E 50 20 46 FF F7 E1 F9 20 46 FF F7 96 FE 14 B0 BD E8 F0 87 30 B5 04 46 87 B0 0E 20 06 A9 CD E9 00 01 02 46 00 23 02 A9 0A 20 EA F7 CD FE 00 28 2B D0 21 F0 55 FB 20 63 BD F8 08 00 18 B9 40 F6 DB 70 AD F8 08 00 BD F8 14 00 4F F4 61 61 08 B1 88 42 01 D9 AD F8 14 10 00 25 A5 70 BD F8 08 00 A0 80 BD F8 14 00 4F F4 7A 71
9:05:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F2 09 81 80 48 43 E0 62 20 46 FF F7 10 FA 04 F1 92 04 4F F0 01 00 04 F8 6C 5C 24 F8 6A 5C A5 73 25 82 E5 87 07 B0 30 BD 30 B5 87 B0 04 46 21 F0 24 FB 05 46 20 6B A8 42 2E D0 0E 20 06 A9 CD E9 00 01 02 46 00 23 02 A9 0A 20 EA F7 8A FE 00 28 E8 D0 25 63 BD F8 08 00 18 B9 40 F6 DB 70 AD F8 08 00 BD F8 14 00 4F F4 61 61 08 B1 88 42 01 D9 AD F8 14 10 BD F8 14 00 4F F4 7A 71 48 43 E0 62 A1 88 BD F8
9:05:01 AM
9:05:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F3 09 81 80 08 00 81 42 04 D0 A0 80 60 78 40 F0 01 00 60 70 01 20 C5 E7 00 20 C3 E7 70 B5 04 46 C0 68 28 F0 AE FA 40 1C 4F F0 FF 35 04 D1 28 F0 60 FD 82 28 1E D1 E5 60 20 69 28 F0 A2 FA 40 1C 04 D1 28 F0 56 FD 82 28 14 D1 25 61 A0 68 28 F0 98 FA 40 1C 04 D1 28 F0 4C FD 82 28 0A D1 A5 60 D4 F8 84 00 28 F0 8D FA 40 1C 07 D1 28 F0 41 FD 82 28 01 D0 00 20 18 E6 C4 F8 84 50 20 46 FF F7 6B F9 00 28
9:05:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F4 09 81 80 F7 D0 20 46 FF F7 2C F9 00 28 F2 D0 01 20 0A E6 10 B5 E9 B3 8A 8A DA B3 B0 F9 54 20 B0 F9 56 30 9A 42 04 DB 30 F8 58 1F 49 1C 01 80 37 E0 CA 7B D2 07 8A 68 A2 EB 01 02 01 D0 18 3A 00 E0 10 3A 08 2A 2C D3 D0 F8 D8 20 12 B3 D0 F8 D4 20 FA B1 8A 68 00 23 02 F8 08 3D 01 23 53 70 8B 8A 1C 0A 94 71 D3 71 90 F8 5D 30 1C 0A 14 71 53 71 90 F8 5C 30 1C 0A 94 70 D3 70 8A 68 08 3A 8A 60 8A 89
9:05:02 AM
9:05:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F5 09 81 80 08 32 8A 81 8A 8A 08 32 8A 82 00 F1 4C 02 00 E0 05 E0 FF F7 70 F9 00 28 00 D0 01 20 10 BD 00 20 10 BD 30 B5 F1 B3 8A 8A E2 B3 B0 F9 C8 20 B0 F9 CA 30 9A 42 04 DB 30 F8 CC 1F 49 1C 01 80 36 E0 CA 7B D2 07 8A 68 A2 EB 01 02 01 D0 18 3A 00 E0 10 3A 08 2A 2B D3 D0 F8 D8 20 1A B3 D0 F8 D4 40 04 B3 8B 68 00 22 03 F8 08 2D 01 22 5A 70 8A 8A 15 0A 9D 71 DA 71 94 F9 0E 20 15 0A 1D 71 5A 71
9:05:03 AM
9:05:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F6 09 81 80 22 8A 14 0A 9C 70 DA 70 8A 68 08 3A 8A 60 8A 89 08 32 8A 81 8A 8A 08 32 8A 82 00 F1 C0 02 FF F7 2A F9 00 E0 03 E0 00 28 00 D0 01 20 30 BD 00 20 30 BD 2D E9 F0 41 04 00 88 46 16 46 1D 46 21 D0 D4 F8 D8 00 28 F0 24 FD 03 28 1B D1 06 2D 01 D0 11 2D 17 D1 B6 B1 40 46 C9 F7 A2 FC 00 28 12 D0 00 20 06 2D 01 D0 11 2D 0A D0 84 F8 60 00 94 F8 5E 10 02 29 06 D0 04 F1 64 07 03 29 04 D0 25 E0
9:05:04 AM
9:05:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F7 09 81 80 01 20 F2 E7 00 20 17 E4 94 F8 60 00 10 B1 01 28 03 D0 04 E0 11 2D 0D D0 01 E0 06 2D 0A D0 00 25 B4 F8 62 00 B0 42 08 D1 41 46 38 46 E1 F7 96 FB 18 B9 01 E0 01 25 F3 E7 1D B1 20 46 FF F7 D4 FB 04 E0 94 F8 5F 00 10 F0 06 0F 0A D0 04 F1 5E 04 41 46 A6 80 38 46 C9 F7 C9 FB 60 78 40 F0 01 00 60 70 01 20 1A E4 2D E9 F0 41 04 46 0F 46 16 46 1D 46 D0 F8 D8 00 28 F0 CB FC 03 28 0A D1 94 F8
9:05:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F8 09 81 80 5F 00 10 F0 06 0F 01 D0 02 20 07 E4 94 F8 5E 00 03 28 01 D0 00 20 B6 E7 04 F1 64 01 38 46 C9 F7 A5 FB 04 F1 60 04 60 88 30 80 20 78 18 B1 01 28 03 D0 FF 20 02 E0 06 20 00 E0 11 20 28 60 01 20 A1 E7 D0 F8 B0 10 59 B1 4B 68 00 22 C0 F8 B0 30 0B B9 C0 F8 B4 20 4A 60 30 F8 B8 2F 52 1E 02 80 08 46 70 47 00 B5 B0 F8 D0 20 2A B1 00 22 A0 F8 D0 20 FF F7 16 FF 01 E0 FF F7 CA FE 00 28 00 D0
9:05:05 AM
9:05:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 F9 09 81 80 01 20 00 BD 10 B5 04 46 FF F7 67 FA 20 46 FF F7 E8 FC 20 46 BD E8 10 40 44 E6 FE B5 0D 46 04 46 81 8D 00 26 02 A8 00 F0 73 FB 50 B1 69 46 9D F8 08 00 00 F0 63 FA 20 B1 06 20 28 70 01 98 01 26 68 60 01 20 84 F8 89 00 30 46 FE BD FE B5 0D 46 04 46 81 8D 00 26 02 A8 00 F0 5A FB 58 B1 69 46 9D F8 08 00 00 F0 4A FA 28 B1 12 20 28 70 BD F8 00 00 A8 80 01 26 01 20 84 F8 89 00 30 46 FE BD
9:05:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 FA 09 81 80 3E B5 04 46 90 F8 B8 00 00 25 07 28 21 D1 A1 8D 02 A8 00 F0 3D FB E0 B1 69 46 9D F8 08 00 00 F0 2D FA B0 B1 01 99 D4 F8 BC 00 81 42 10 D0 01 90 9D F8 08 00 0B 21 0B 28 01 D8 00 20 00 E0 01 46 00 F0 4B FB 69 46 9D F8 08 00 00 F0 85 FA 00 B1 01 25 01 20 84 F8 89 00 28 46 3E BD 3E B5 04 46 90 F8 B8 00 00 25 06 28 2F D1 A1 8D 68 46 00 F0 0F FB 50 B3 B4 F8 BC 10 9D F8 00 00 00 F0 EF FA
9:05:06 AM
9:05:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 FB 09 81 80 18 B3 B4 F8 BC 00 00 B3 01 A9 9D F8 00 00 00 F0 F5 F9 D0 B1 BD F8 04 00 B4 F8 BC 10 88 42 13 D0 9D F8 00 00 1D 21 1D 28 01 D8 00 20 00 E0 01 46 00 F0 13 FB B4 F8 BC 00 AD F8 04 00 01 A9 9D F8 00 00 00 F0 49 FA 00 B1 01 25 01 20 84 F8 89 00 28 46 3E BD 00 21 21 28 05 D2 FF 4A FD 49 02 EB 00 10 C0 88 01 44 08 46 70 47 00 21 21 28 06 D2 F9 4A F8 49 02 EB 00 10 54 39 00 89 01 44 08 46
9:05:07 AM
9:05:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 FC 09 81 80 70 47 2D E9 F0 5F 0C 46 DD F8 28 B0 15 46 5F EA 03 08 4F F0 00 0A 2A D0 21 28 28 D8 EE 49 01 EB 00 19 99 F8 04 10 01 29 21 D0 FF F7 DE FF 07 00 1D D0 38 88 61 19 09 1A 00 29 02 DD BB F1 00 0F 18 D0 28 46 C6 B2 B9 F8 06 00 B2 00 00 F5 8E 60 00 EB 84 00 80 B2 08 EB 84 01 EA F7 D6 FC 30 B1 00 24 A8 1B 10 F0 FF 05 E3 D1 4F F0 01 0A 50 46 BD E8 F0 9F 00 1B E5 E7 10 B5 00 24 21 28 0C D2
9:05:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 FD 09 81 80 D5 4A 02 EB 00 10 40 79 00 F0 1F 02 01 2A 04 D1 40 09 1A F0 9E FA 00 B1 01 24 20 46 10 BD 39 B1 30 B1 B1 FB F0 F3 00 FB 13 13 1A B1 C8 1A 70 47 00 20 70 47 C0 1A 08 44 70 47 2D E9 F8 43 04 46 00 26 AC 21 C9 F7 09 FA 68 46 D0 F7 88 FE C2 4F 00 25 00 BF 07 EB 05 10 40 79 00 F0 1F 00 02 28 11 D1 28 46 FF F7 81 FF F0 B3 40 68 01 22 00 99 FF F7 D5 FF 04 EB 85 01 48 62 94 F8 A8 00 41 1C
9:05:08 AM
9:05:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 FE 09 81 80 84 F8 A8 10 25 54 6D 1C ED B2 21 2D E2 D3 94 F8 A8 70 01 2F 2A D9 01 20 84 F8 A8 00 05 46 21 E0 14 F8 05 80 40 46 FF F7 60 FF 5F EA 00 0C 1E D0 00 23 09 E0 E0 5C FF F7 58 FF A8 B1 DC F8 04 10 40 68 81 42 04 D0 5B 1C 94 F8 A8 00 98 42 F1 D8 94 F8 A8 00 98 42 04 D1 42 1C 84 F8 A8 20 04 F8 00 80 6D 1C BD 42 00 E0 01 E0 D9 D3 01 26 30 46 BD E8 F8 83 10 B5 00 24 58 B1 8A 42 01 D3 52 1A
9:05:09 AM
9:05:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 02 FF 09 81 80 00 E0 8A 1A 02 60 21 B1 1B B1 B2 FB F3 F1 01 24 01 60 20 46 10 BD 2D E9 F8 43 00 25 DD E9 08 96 04 46 17 46 98 46 21 28 17 D8 8B 48 00 EB 04 10 02 79 C0 88 01 2A 00 F5 8C 60 80 B2 4F F0 10 02 0D D0 EA F7 22 FC 40 B1 4B 46 42 46 39 46 20 46 00 96 FF F7 16 FF 00 B1 01 25 28 46 C8 E7 EA F7 14 FC F8 E7 2D E9 F0 43 DD B0 06 46 89 46 4F F0 00 08 21 28 3C D2 30 46 FF F7 EC FE 05 00 37 D0
9:05:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 00 09 81 80 75 48 00 EB 06 14 20 79 2C F0 42 F8 07 46 20 79 06 28 0C D2 DF E8 00 F0 0B 03 05 07 0B 09 01 24 06 E0 02 24 04 E0 0F 24 02 E0 5A 24 00 E0 00 24 4F F4 B4 71 02 A8 C9 F7 50 F9 39 46 28 46 C9 F7 4C F9 5C A8 D0 F7 CB FD 01 22 48 46 5C 99 FF F7 26 FF 5C 90 A8 60 01 21 02 A8 CD E9 00 01 E3 B2 00 22 29 46 30 46 FF F7 96 FF 08 B1 4F F0 01 08 5D B0 40 46 BD E8 F0 83 2D E9 F8 43 00 25 DF F8
9:05:10 AM
9:05:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 01 09 81 80 58 81 2C 46 20 46 FF F7 B0 FE 03 00 32 D0 08 EB 04 1C 9C F8 04 00 01 28 27 D0 18 88 01 28 24 D9 00 26 20 46 FF F7 96 FE 02 00 23 D0 00 20 19 88 05 E0 00 BF 02 EB 80 07 40 1C 3F 69 3E 44 5A 29 01 D2 0F 46 00 E0 5A 27 87 42 F3 D8 10 68 B0 42 0B D0 9C F8 05 00 00 F0 1F 00 01 28 0C D0 58 68 00 90 20 46 00 99 FF F7 7D FF 64 1C E4 B2 21 2C C8 D3 01 25 28 46 3B E7 69 46 20 46 FF F7 BC FE
9:05:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 02 09 81 80 00 28 F7 D0 ED E7 0E B5 02 AA 54 21 CD E9 00 12 0A 46 01 46 00 23 24 20 EA F7 A1 FA 00 28 00 D0 01 20 0E BD 0E B5 02 AA 54 21 CD E9 00 12 0A 46 01 46 00 23 24 20 EA F7 D2 FA 00 28 00 D0 01 20 0E BD 10 B5 04 46 20 F0 16 FF 22 49 54 39 D1 F8 A4 1D 81 42 00 D1 7C B1 1E 49 54 39 C1 F8 A4 0D 08 46 FF F7 D0 FF 00 28 05 D0 1C 48 FF F7 A5 FE 00 28 00 D0 01 20 10 BD 00 20 10 BD 2D E9 FF 41
9:05:11 AM
9:05:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 03 09 81 80 00 25 0E 46 2C 46 02 95 21 28 21 D2 12 49 01 EB 00 10 07 89 40 79 00 F0 1F 01 01 29 02 D0 02 29 09 D1 07 E0 40 09 02 24 80 00 02 A9 19 F0 2A F9 70 B1 00 E0 08 24 03 A8 CD E9 00 40 3B 46 22 46 31 46 24 20 EA F7 4B FA 02 98 00 B1 70 60 01 25 28 46 05 E0 AC 4A 00 10 EC D2 06 00 AC 49 00 10 04 B0 BD E8 F0 81 7C B5 00 26 05 46 21 28 20 D2 FF F7 FB FD 04 00 1C D0 69 46 28 46 FF F7 BE FF
9:05:12 AM
9:05:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 04 09 81 80 B8 B1 FB 48 00 EB 05 10 40 79 00 F0 1F 00 01 28 02 D0 02 28 04 D0 0C E0 BD F8 00 00 20 80 07 E0 DD E9 00 01 C4 E9 00 01 F2 48 FF F7 46 FE 00 B1 01 26 30 46 7C BD 3E B5 54 20 02 A9 CD E9 00 01 EB 49 02 46 01 24 00 23 54 39 24 20 EA F7 47 FA 00 B9 00 24 20 46 3E BD 2D E9 FE 43 00 24 89 46 21 28 3A D2 E2 49 02 AD 01 EB 00 16 72 79 33 89 02 F0 1F 02 01 2A 02 D0 02 2A 2D D1 25 E0 1D 27
9:05:13 AM
9:05:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 05 09 81 80 1D 28 10 D8 00 24 88 46 08 EB 04 10 02 22 03 89 CD E9 00 25 49 46 24 20 EA F7 21 FA 98 B1 64 1C BC 42 F1 DD 07 E0 02 22 CD E9 00 25 49 46 24 20 EA F7 15 FA 88 B1 70 79 D9 F8 04 10 40 09 80 00 1A F0 66 F8 40 B9 00 24 07 E0 08 22 CD E9 00 25 49 46 24 20 EA F7 03 FA 01 24 20 46 BD E8 FE 83 2D E9 F0 43 C4 48 4F F4 55 68 87 B0 00 25 41 46 81 46 C8 F7 F2 FF BE 4F 00 24 20 46 FF F7 75 FD
9:05:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 06 09 81 80 03 00 22 D0 20 46 FF F7 65 FD 06 00 1D D0 07 EB 04 10 40 79 00 F0 1F 00 01 28 19 D0 58 68 01 90 68 46 D0 F7 5C FC DD E9 00 10 01 22 FF F7 B7 FD 64 1C 00 90 E4 B2 B0 60 21 2C DE D3 42 46 49 46 4F F4 8C 60 EA F7 61 FA 01 25 28 46 07 B0 91 E6 01 A9 20 46 FF F7 90 FD 00 28 F6 D0 E0 E7 A4 4A 02 EB 00 10 00 79 06 28 10 D2 DF E8 00 F0 0F 03 07 0A 0F 0D 01 29 09 D8 01 20 70 47 02 29 FB D9
9:05:14 AM
9:05:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 07 09 81 80 04 E0 0F 29 F8 D9 01 E0 5A 29 F5 D9 00 20 70 47 10 B5 97 4B 00 22 00 BF 03 EB 02 14 64 88 8C 42 05 D1 03 EB 02 11 09 78 01 70 01 20 10 BD 52 1C 21 2A F1 D3 00 20 10 BD 10 B5 90 4B 00 22 00 BF 33 F8 12 40 8C 42 02 D1 02 70 01 20 10 BD 52 1C 92 B2 1E 2A F4 D3 00 20 10 BD 10 B5 00 22 81 42 10 D3 21 29 0E D2 84 4A 54 3A 02 44 02 F6 A9 52 5F F0 01 03 04 46 40 1C 02 F8 01 3B C0 B2 8C 42
9:05:15 AM
9:05:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 08 09 81 80 F8 D1 01 22 10 46 10 BD F0 B5 07 46 78 48 00 24 00 EB 07 15 0E 46 28 79 01 28 1D D0 38 46 FF F7 D9 FC 03 00 27 D0 38 46 FF F7 DF FC 01 00 22 D0 18 7B 0A 88 90 42 00 D3 00 20 E9 68 D9 B1 03 EB 80 00 1B 68 09 68 00 69 19 44 08 1A 9A B1 01 2A 07 D9 51 1C 49 08 05 E0 E8 68 60 B1 00 68 08 60 08 E0 00 21 00 28 01 DB 08 44 00 E0 40 1A 90 FB F2 F0 30 60 01 24 20 46 F0 BD 70 B5 0D 46 06 46
9:05:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 09 09 81 80 00 23 FF F7 A7 FC 04 00 1F D0 30 46 FF F7 AD FC D8 B1 02 88 03 2E 05 D0 BA B1 01 2A 17 D9 50 1C 40 08 15 E0 8A B1 01 2A 02 D9 50 1C 40 08 00 E0 00 20 21 68 00 29 03 DD 08 44 B0 FB F2 F0 02 E0 08 1A 90 FB F2 F0 01 23 28 60 18 46 70 BD 00 20 21 68 F1 E7 10 B5 0C 46 00 23 FF F7 7B FC 10 B1 40 68 01 23 20 60 18 46 10 BD 10 B5 0C 46 00 23 FF F7 70 FC 10 B1 80 68 01 23 20 60 18 46 10 BD
9:05:16 AM
9:05:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 0A 09 81 80 2D E9 FF 4F B3 B0 00 20 2F 90 9A 46 39 4F AC 21 02 A8 C8 F7 E2 FE 00 25 30 A8 D0 F7 60 FB 00 23 DF F8 CC B0 0D F1 08 09 BA F1 01 0F 03 D0 BA F1 02 0F 30 D0 21 E0 DD F8 D0 20 00 20 CC 46 5E 46 06 EB 00 11 4C 79 B2 EB 54 1F 0C D1 04 F0 1F 04 01 2C 08 D1 09 78 0C F8 03 10 9D F8 B0 10 5B 1C 49 1C 8D F8 B0 10 40 1C C0 B2 21 28 E8 D3 34 A9 D0 B2 19 F0 2E FF 00 28 7E D0 01 22 30 99 34 98
9:05:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 0B 09 81 80 FF F7 8D FC 2E 90 00 22 30 99 34 98 FF F7 87 FC 00 26 31 90 AA E1 21 24 0A E0 FC 5C 20 46 FF F7 24 FC 05 00 68 D0 68 68 34 99 88 42 04 D0 5B 1C 97 F8 A8 00 98 42 F0 D8 00 23 4E 46 DC 46 14 E0 20 46 FF F7 12 FC 00 28 56 D0 40 68 69 68 88 42 09 D1 0C EB 04 10 00 78 F0 54 9D F8 B0 00 5B 1C 40 1C 8D F8 B0 00 64 1C E4 B2 21 2C E8 D3 C4 E7 EC D2 06 00 AC 49 00 10 AC 4A 00 10 FC D4 06 00
9:05:17 AM
9:05:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 0C 09 81 80 35 98 03 28 16 D0 04 28 1A D0 05 28 14 D0 06 28 14 D0 04 21 FE 48 80 F8 CA 1D 19 F8 06 80 B8 F1 21 0F 29 D2 71 B1 01 29 0C D0 02 29 7E D0 03 29 7D D1 43 E1 00 21 ED E7 01 21 EB E7 02 21 E9 E7 03 21 E7 E7 0B EB 08 10 00 90 00 79 01 28 40 46 13 D0 FF F7 BF FB 04 00 0E D0 40 46 FF F7 C5 FB 05 00 09 D0 28 88 01 28 1E D0 E9 48 90 F8 CA 0D 60 B3 01 28 70 D0 F7 E0 6F E0 FF F7 B6 FB 05 00
9:05:18 AM
9:05:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 0D 09 81 80 6B D0 40 46 FF F7 A6 FB 01 00 66 D0 00 98 C0 68 00 68 08 60 33 98 48 60 2E 98 88 60 00 20 00 90 01 23 02 46 01 90 E8 E0 01 20 2D 90 00 99 20 7B 2F 90 C9 68 04 EB 80 00 09 68 01 61 00 98 C0 68 00 68 20 60 33 98 60 60 2E 98 3D E0 DD E9 33 13 2D A8 31 9A FF F7 4E FC 00 28 3E D0 20 7B 2F 90 28 88 2D 99 88 42 39 D3 00 20 15 E0 21 7B 04 EB 81 02 D2 F8 10 C0 48 B3 00 21 11 61 23 68 22 7B
9:05:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 0E 09 81 80 19 44 A1 EB 0C 01 21 60 52 1C 29 88 40 1C B2 FB F1 F3 01 FB 13 21 21 73 2D 99 88 42 E6 D3 DD E9 33 20 49 1E 01 FB 00 21 61 60 01 E0 AA E0 DC E0 2A 88 01 2A 0E D0 C2 F1 01 02 00 FB 02 10 A2 68 82 42 01 D3 8A 42 00 D9 A0 60 8D E0 00 99 C9 68 09 68 D2 E7 2E 98 F2 E7 1E E0 A3 E0 00 98 00 79 2B F0 96 FC 01 46 20 46 C8 F7 B7 FD 2D 99 DD E9 33 20 49 1E 01 FB 00 21 61 60 2A 88 01 2A 09 D0
9:05:19 AM
9:05:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 0F 09 81 80 C2 F1 01 02 00 FB 02 10 A0 60 28 88 2D 90 20 7B 2F 90 69 E0 2E 98 F7 E7 DD E9 33 13 2D A8 2E 9A FF F7 E8 FB 00 28 7D D0 A1 68 2E 98 81 42 50 D8 28 88 2D 99 88 42 4C D3 00 20 17 E0 21 7B 04 EB 81 02 11 69 48 B3 4F F0 00 0C 00 BF C2 F8 10 C0 23 68 22 7B 63 44 59 1A 21 60 29 88 0A 44 52 1E 92 FB F1 F3 01 FB 13 21 21 73 40 1C 2D 99 88 42 E4 D3 20 7B 29 88 00 F1 01 00 B0 FB F1 F2 01 FB
9:05:20 AM
9:05:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 10 09 81 80 12 00 C0 B2 20 73 2F 90 28 88 2D 99 40 1A 06 D4 DD E9 33 02 01 FB 12 00 02 E0 8C 46 D6 E7 00 20 60 60 2A 88 01 2A 06 D0 28 B1 52 1A 34 9B 52 1C 03 FB 12 02 00 E0 2E 9A A3 68 93 42 01 D3 83 42 00 D9 A2 60 28 88 88 42 0E D1 A0 68 34 99 40 1A 7A E7 00 98 00 79 2B F0 1B FC 01 46 20 46 C8 F7 3C FD 00 20 60 60 95 E7 00 21 04 F1 10 00 CD E9 00 01 2D 98 2F 9A C3 B2 21 46 40 46 FF F7 8B FB
9:05:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 11 09 81 80 00 28 38 D0 BA F1 02 0F 18 D1 A8 F1 1E 00 03 28 04 D3 0B EB 08 11 00 20 C9 68 08 60 01 22 68 68 30 99 00 E0 27 E0 FF F7 FA FA 01 46 07 EB 88 00 58 4A 41 62 02 EB 08 01 00 20 C8 70 54 48 41 46 00 EB 08 04 94 F8 A9 0D 01 28 0E D1 08 46 FF F7 8A FC 0B EB 08 10 00 79 01 28 03 D0 40 46 34 99 FF F7 80 FB 00 20 84 F8 A9 0D 76 1C 9D F8 B0 00 B0 42 3F F6 85 AE 37 B0 BD E8 F0 8F 2D E9 FE 43
9:05:21 AM
9:05:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 12 09 81 80 68 46 D0 F7 6C F9 40 F6 CC 51 41 48 C8 F7 E5 FC 41 48 00 24 AC 21 84 67 C4 67 C0 F8 80 40 A0 F5 60 60 C8 F7 DA FC 01 20 FF F7 0B FC D1 F7 07 FF 37 4D 40 07 4F F4 55 66 05 F1 54 05 4F F4 8C 68 16 D5 00 23 18 46 FF F7 45 FA 07 00 4C D0 18 46 FF F7 4B FA 00 28 47 D0 00 98 5B 1C C7 E9 01 40 DB B2 21 2B EE D3 32 46 29 46 40 46 E9 F7 4D FF 32 46 29 46 40 46 EA F7 13 F9 D1 F7 E0 FE 40 05
9:05:22 AM
9:05:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 13 09 81 80 32 D4 FF F7 79 FB 08 22 01 A9 10 46 EA F7 08 F9 1F 4E 00 25 AC 3E 23 E0 70 5D FF F7 26 FA 04 00 22 D0 01 99 01 22 60 68 FF F7 79 FA 07 46 02 99 01 22 60 68 FF F7 73 FA 87 42 10 D0 DD E9 01 01 88 42 01 D9 05 27 00 E0 03 27 01 46 00 22 60 68 FF F7 65 FA 02 23 3A 46 61 68 FF F7 91 FD 6D 1C 96 F8 A8 00 A8 42 D7 D8 78 E4 F8 B5 08 4E 01 27 AC 3E 68 46 D0 F7 F3 F8 05 48 00 99 90 F8 A8 0D
9:05:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 14 09 81 80 C9 B2 88 42 3A D0 00 24 06 F6 78 65 06 E0 00 00 58 4A 00 10 34 7B 00 10 AC 57 00 10 60 1C C1 B2 05 EB 84 02 00 20 1B F0 21 FC 64 1C 03 2C ED D3 00 24 1B E0 16 F8 04 C0 60 46 FF F7 D6 F9 05 00 1E D0 01 22 68 68 00 99 FF F7 29 FA 06 EB 8C 01 49 6A 81 42 09 D0 4F F0 00 02 68 68 FF F7 1F FA 02 23 03 22 69 68 FF F7 4B FD 64 1C 96 F8 A8 00 A0 42 DF D8 18 49 00 98 81 F8 A8 0D 38 46 F8 BD
9:05:23 AM
9:05:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 15 09 81 80 00 27 FB E7 F0 B5 14 4C 00 26 AC 3C 07 46 16 70 94 F8 A8 00 15 46 88 42 11 D8 00 23 0A E0 E0 5C FF F7 A3 F9 58 B1 40 68 47 F8 23 00 28 78 40 1C 28 70 5B 1C 94 F8 A8 00 98 42 F0 D8 01 26 30 46 F0 BD 00 B5 0B 46 FF F7 85 F9 00 28 02 D0 40 7B 18 70 01 20 00 BD 00 00 58 4A 00 10 05 28 01 D3 00 20 70 47 F7 49 31 F8 10 00 C0 07 F9 D0 01 20 70 47 05 28 06 D2 F3 49 31 F8 10 00 80 07 01 D5
9:05:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 16 09 81 80 01 20 70 47 00 20 70 47 05 28 06 D2 ED 49 31 F8 10 00 40 07 01 D5 01 20 70 47 00 20 70 47 05 28 06 D2 E8 49 31 F8 10 00 00 07 01 D5 01 20 70 47 00 20 70 47 05 28 0A D2 E2 49 31 F8 10 00 C1 07 05 D1 41 07 03 D4 80 07 01 D5 01 20 70 47 00 20 70 47 00 22 0A 70 05 28 01 D3 00 20 70 47 D9 4A 32 F8 10 00 C0 06 01 D5 01 20 08 70 01 20 70 47 01 20 70 47 F0 B5 82 88 01 24 0A B9 01 29 0D D0
9:05:24 AM
9:05:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 17 09 81 80 81 80 83 79 05 2B 34 D2 00 F1 18 02 15 46 9A 5C 59 55 04 29 17 D0 01 29 25 D0 2A E0 00 22 C9 4D 5F F0 04 06 35 F8 12 30 5B 07 00 EB 02 03 01 D5 1E 76 02 E0 1F 7E 07 B9 1C 76 52 1C 92 B2 05 2A F0 D3 81 80 15 E0 81 79 D0 F8 0E 30 00 EB 81 01 04 2A C1 F8 22 30 0C D0 82 79 00 F1 3B 01 51 5C 07 29 02 D1 05 E0 01 2A 03 D0 81 79 00 F5 58 70 0C 54 01 20 F0 BD 05 29 01 D3 00 20 70 47 08 44
9:05:25 AM
9:05:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 18 09 81 80 90 F8 60 03 70 47 70 B5 1C 46 05 2A 01 D3 00 20 70 BD 85 18 2B 7E 03 F0 0F 03 23 70 2E 7E 04 2E 03 D1 09 88 43 EA 01 11 21 70 15 F8 1D 1F 61 70 6B 7E A9 7F 63 F3 1F 11 A1 70 02 EB 82 01 00 EB 41 16 06 F1 40 00 04 F1 08 01 EF F7 61 FC 36 F8 44 0F A0 80 70 88 E0 80 70 79 E0 70 00 20 85 F8 43 03 01 20 70 BD 70 B5 0D 46 1C 46 05 2A 01 D3 00 20 70 BD 21 78 01 F0 0F 03 81 18 04 2B 0B 76
9:05:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 19 09 81 80 02 D1 23 78 1B 09 2B 80 63 78 01 F8 1D 3F A3 78 1B 09 4B 76 A3 78 03 F0 0F 03 8B 77 89 49 00 EB 82 03 14 39 01 EB 82 01 0D 78 83 F8 22 50 49 88 99 84 02 EB 82 01 00 EB 41 15 05 F1 40 00 04 F1 08 01 EF F7 2E FC A0 88 4F F4 A0 61 88 42 00 D3 08 46 A5 F8 44 00 E0 88 88 42 00 D3 08 46 25 F8 46 0F 06 20 A8 70 E0 78 E8 70 00 20 A8 80 01 20 70 BD 70 B5 1D 46 90 F8 65 33 53 B1 00 23 80 F8
9:05:26 AM
9:05:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 1A 09 81 80 65 33 D0 F8 68 43 B4 B1 66 68 C0 F8 68 63 16 B1 03 E0 00 20 70 BD C0 F8 6C 33 63 60 B0 F8 70 63 76 1E A0 F8 70 63 2B 80 A6 8A B2 42 05 D2 20 46 E7 F7 42 FD ED E7 2B 80 09 E0 0B 46 32 B2 00 21 20 46 E7 F7 42 FD 2E 80 20 46 E7 F7 35 FD 01 20 70 BD 43 88 7F 2B 06 D8 02 23 0B 70 43 88 8B 70 7F 23 CB 70 06 E0 04 23 0B 70 43 88 4B 80 43 F6 FF 73 8B 80 01 21 11 70 00 78 90 70 70 47 70 B5
9:05:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 1B 09 81 80 D0 F8 78 53 04 46 DD B1 69 68 00 20 C4 F8 78 13 09 B9 C4 F8 7C 03 68 60 B4 F8 80 03 40 1E A4 F8 80 03 94 F8 98 03 29 28 0C D0 2A 28 11 D0 D4 F8 A0 03 B0 B1 A1 7B 04 F1 0E 06 67 29 13 D0 19 E0 00 20 70 BD D4 F8 A4 03 30 B3 29 46 FE F7 4A FF 06 E0 D4 F8 A8 03 F8 B1 01 22 29 46 0D F0 0C FF D0 B1 01 20 70 BD 81 6A 30 46 01 F1 46 02 40 31 FF F7 AF FF A0 7B 66 28 08 D1 D4 F8 A0 03 81 6A
9:05:27 AM
9:05:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 1C 09 81 80 30 46 01 F1 46 02 40 31 FF F7 A3 FF 29 46 D4 F8 A0 03 0D F0 03 FB E3 E7 28 46 E7 F7 CD FC CF E7 2D E9 F0 41 05 46 88 46 16 46 1F 46 E7 F7 82 FC 04 00 0F D0 A0 68 43 46 11 30 A0 60 32 B2 00 21 20 46 E7 F7 FB FC 80 B2 38 80 B0 42 05 D0 20 46 E7 F7 B2 FC 00 20 BD E8 F0 81 00 20 60 60 D5 F8 7C 03 68 B1 C0 F8 04 40 C5 F8 7C 43 B5 F8 80 03 40 1C A5 F8 80 03 28 46 FF F7 81 FF 01 20 EA E7
9:05:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 1D 09 81 80 C5 F8 78 43 F0 E7 10 B5 04 46 01 46 0E 48 EF F7 49 FA 08 B1 01 20 10 BD 21 46 0C 48 EF F7 42 FA 08 B1 02 20 10 BD 21 46 09 48 EF F7 3B FA 08 B1 03 20 10 BD 21 46 07 48 EF F7 34 FA 60 B1 04 20 10 BD 00 00 52 D5 06 00 78 45 06 00 88 45 06 00 98 45 06 00 A8 45 06 00 FF 20 F1 E7 06 28 0E D2 DF E8 00 F0 0D 03 05 07 09 0B FD 48 70 47 FD 48 70 47 FD 48 70 47 FD 48 70 47 FD 48 70 47 FD 48
9:05:28 AM
9:05:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 1E 09 81 80 70 47 00 B5 02 46 FF F7 E9 FD 28 B9 10 46 FF F7 F0 FD 08 B1 F2 48 00 BD F6 48 00 BD 10 B5 0B 46 02 46 FF F7 07 FE 28 B1 19 46 10 46 21 F0 A0 FB 00 28 C5 D0 01 20 C3 E7 7C B5 05 46 00 20 08 70 0C 46 69 46 14 20 D5 F7 23 FC 10 B1 BD F8 00 00 90 B1 21 F0 E7 FA 78 B1 28 46 FF F7 EB FD 58 B1 01 A9 28 46 21 F0 72 FB 00 28 06 D0 BD F8 04 00 41 1E 04 29 00 D8 20 70 01 20 7C BD 10 B5 04 46
9:05:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 1F 09 81 80 01 46 DC 48 EF F7 CE F9 08 B1 00 20 98 E7 21 46 D3 48 EF F7 C7 F9 08 B1 01 20 91 E7 21 46 D1 48 EF F7 C0 F9 08 B1 02 20 8A E7 21 46 CE 48 EF F7 B9 F9 08 B1 03 20 83 E7 21 46 CC 48 EF F7 B2 F9 08 B1 04 20 7C E7 21 46 C9 48 EF F7 AB F9 08 B1 05 20 75 E7 FF 20 73 E7 F0 B5 8C 1C 03 25 B4 FB F5 F4 A4 00 DD F8 14 E0 A3 42 03 D2 00 20 CE F8 00 40 F0 BD B1 FB F5 F4 04 EB 44 06 13 46 00 25
9:05:29 AM
9:05:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 20 09 81 80 BD 4C 20 E0 07 78 04 EB 97 07 3F 78 1F 70 07 78 90 F8 01 C0 3F 01 07 EB 1C 17 07 F0 3F 07 E7 5D 5F 70 47 78 90 F8 02 C0 BF 00 07 EB 9C 17 07 F0 3F 07 E7 5D 9F 70 87 78 C0 1C 07 F0 3F 07 E7 5D DF 70 1B 1D ED 1C B5 42 DC D3 8D 42 24 D2 06 78 6D 1C 8D 42 01 D2 40 78 01 E0 4F F0 00 00 C6 F3 85 01 61 5C 19 70 4F EA 06 11 01 EB 10 11 01 F0 3F 01 61 5C 59 70 03 F1 02 03 05 D2 4F F0 3C 01
9:05:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 21 09 81 80 01 EA 80 00 20 5C 01 E0 4F F0 3D 00 18 70 4F F0 3D 00 58 70 03 F1 02 03 A3 EB 02 00 CE F8 00 00 4F F0 01 00 F0 BD 10 B5 0C 46 86 B0 00 21 21 70 10 21 10 46 A1 80 CF F7 F4 FE A0 60 00 28 22 D0 D1 F7 51 FB AD F8 04 00 D1 F7 4D FB AD F8 06 00 D1 F7 49 FB AD F8 08 00 D1 F7 45 FB AD F8 0A 00 D1 F7 41 FB AD F8 0C 00 D1 F7 3D FB AD F8 0E 00 04 A8 00 90 A3 88 0C 21 01 A8 A2 68 FF F7 6C FF
9:05:30 AM
9:05:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 22 09 81 80 00 28 00 D0 01 20 06 B0 DA E6 2D E9 F0 41 AD F5 A9 6D 05 46 0E 46 68 46 1E F0 C2 FE 07 27 C8 B1 03 24 E8 46 04 EB C4 01 08 EB 41 00 00 F2 5A 20 02 88 10 2A 01 D9 10 22 00 E0 3A B1 31 88 91 42 04 D1 80 1C 71 68 C7 F7 FF FF 40 B1 64 1E 24 B2 00 2C E7 DA EF 72 00 20 0D F5 A9 6D 7B E6 64 1C EC 72 01 20 F8 E7 03 21 C1 72 82 79 05 2A 07 D2 00 F1 3B 03 D1 54 82 79 00 F5 58 70 01 21 11 54
9:05:31 AM
9:05:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 23 09 81 80 01 20 70 47 70 B5 00 20 10 70 91 F9 00 30 5B 4D 05 EB 80 04 94 F9 00 60 9E 42 06 D1 64 88 4E 88 B4 42 02 D1 10 70 01 20 70 BD 40 1C C0 B2 05 28 EE D3 00 20 70 BD 30 B5 91 F9 00 20 4F 4C 00 20 04 EB 80 03 93 F9 00 50 95 42 03 D1 5B 88 4D 88 AB 42 04 D0 40 1C C0 B2 05 28 F1 D3 FF 20 30 BD 01 22 02 73 02 22 42 73 81 73 70 47 01 22 02 73 42 73 81 73 70 47 F0 B5 87 B0 04 46 DD E9 0D 75
9:05:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 24 09 81 80 01 20 0C 9E 20 73 61 73 50 B2 A0 73 8D F8 18 30 8D F8 19 60 8D F8 1A 70 00 20 20 63 40 21 28 46 CF F7 3F FE 01 00 1B D0 40 22 68 46 CF F7 34 FE 0E 20 8D F8 08 00 06 A8 03 90 02 A9 68 46 F1 F7 E9 FF 00 28 0C D0 08 21 28 46 CF F7 2A FE 20 63 00 28 05 D0 BD F8 04 10 01 80 21 6B 00 98 48 60 07 B0 F0 BD 2D E9 F0 43 87 B0 04 46 DD E9 0E 89 0D 46 16 46 1F 46 01 21 48 46 CF F7 12 FE 20 60
9:05:32 AM
9:05:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 25 09 81 80 00 B1 05 70 8D F8 18 60 8D F8 19 70 8D F8 1A 80 00 20 60 60 40 21 48 46 CF F7 03 FE 01 00 1B D0 40 22 68 46 CF F7 F8 FD 0E 20 8D F8 08 00 06 A8 03 90 02 A9 68 46 F1 F7 AD FF 00 28 0C D0 08 21 48 46 CF F7 EE FD 60 60 00 28 05 D0 BD F8 04 10 01 80 61 68 00 98 48 60 07 B0 BD E8 F0 83 00 00 9C 4A 06 00 AC 4A 06 00 BC 4A 06 00 CC 4A 06 00 DC 4A 06 00 8C 4A 06 00 86 D8 06 00 3E D5 06 00
9:05:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 26 09 81 80 43 69 4F F4 A0 62 91 42 9A 80 00 D3 11 46 40 69 C1 80 01 20 70 47 FF 20 10 70 05 29 01 D3 00 20 70 47 F9 48 40 5C 10 70 01 20 70 47 10 B5 83 79 05 2B 01 D3 00 20 C3 E5 F3 48 24 30 30 F8 13 00 88 B1 01 2A 02 D0 00 F1 02 00 02 E0 11 B9 00 F1 01 00 80 B2 EC 49 01 F1 1A 01 31 F8 13 10 49 07 01 D4 23 F0 08 F9 01 20 AA E5 08 46 10 B5 89 1C 00 1D 21 F0 75 FC 00 28 00 D0 01 20 A0 E5 01 20
9:05:33 AM
9:05:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 27 09 81 80 70 47 08 B5 00 21 8D F8 00 10 80 79 69 46 FF F7 E0 FB 9D F8 00 00 08 BD 7F B5 0C 46 FF F7 F1 FF 06 46 04 F1 A0 02 01 21 1F F0 5F F8 00 25 00 95 01 95 02 95 6A 46 01 21 30 46 03 95 1F F0 B9 F8 03 98 C4 F8 AC 00 04 F1 A4 02 02 21 30 46 1F F0 4C F8 00 95 01 95 02 95 6A 46 02 21 30 46 03 95 1F F0 A7 F8 03 98 C4 F8 B0 00 04 B0 01 20 70 BD 10 B5 10 46 00 22 01 F1 A0 04 01 2B 02 D0 02 2B
9:05:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 28 09 81 80 0D D1 04 E0 C1 F8 A0 20 22 46 01 21 03 E0 C1 F8 A4 20 22 46 02 21 1F F0 44 F8 00 28 00 D0 01 20 4E E5 2D E9 FF 41 0C 46 17 46 00 25 1E 46 0A 22 0C 31 68 46 03 95 C7 F7 1E FF 01 2E 02 D0 02 2E 0E D1 04 E0 6A 46 01 21 C4 F8 AC 50 03 E0 6A 46 02 21 C4 F8 B0 50 38 46 1F F0 8F F8 00 28 00 D0 01 20 04 B0 F7 E4 10 B5 0C 46 FF F7 8A FF D4 F8 A0 10 4A 1C 0B D0 49 1C C4 F8 A0 10 04 F1 A0 02
9:05:34 AM
9:05:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 29 09 81 80 01 21 1F F0 0E F8 00 28 00 D0 01 20 18 E5 00 20 16 E5 10 B5 0C 46 FF F7 74 FF D4 F8 A4 10 4A 1C 0B D0 49 1C C4 F8 A4 10 04 F1 A4 02 02 21 1E F0 F8 FF 00 28 00 D0 01 20 02 E5 00 20 00 E5 10 B5 03 46 00 20 08 70 0C 46 10 70 99 79 05 29 03 D2 93 F8 98 03 22 28 01 D0 00 20 F1 E4 18 46 FF F7 1A FF 00 28 F9 D0 88 49 98 79 1A 31 31 F8 10 00 C0 06 01 D5 01 20 20 70 01 20 E1 E4 10 B5 86 B0
9:05:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 2A 09 81 80 00 22 C1 F8 B4 20 04 46 03 92 0A 22 0C 31 68 46 C7 F7 B1 FE 05 AA 04 A9 20 46 FF F7 D0 FF 50 B1 9D F8 14 00 6A 46 00 1D C1 B2 9D F8 10 00 1F F0 24 F8 00 28 00 D0 01 20 E5 E5 1C B5 0C 46 00 21 C4 F8 A8 10 01 AA 69 46 FF F7 B9 FF 58 B1 9D F8 04 00 04 F1 A8 02 00 1D C1 B2 9D F8 00 00 1E F0 A0 FF 00 28 00 D0 01 20 1C BD 70 B5 05 46 10 46 12 88 8C B0 0C 46 20 2A 00 D3 20 22 A4 F8 7C 20
9:05:35 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:05:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 2B 09 81 80 41 68 04 F1 7E 00 06 46 C7 F7 0A FE B4 F8 7C 20 AD F8 00 20 31 46 0D F1 02 00 C7 F7 01 FE 0A AA 09 A9 28 46 FF F7 8B FF 40 B1 9D F8 28 20 9D F8 24 10 68 46 1E F0 11 FF 00 28 0C D0 21 46 28 46 FF F7 BB FF 00 28 06 D0 21 46 28 46 FF F7 96 FF 00 28 00 D0 01 20 0C B0 70 BD 10 B5 0C 46 C6 B0 00 21 21 80 21 46 FF F7 CC FE 01 46 68 46 1E F0 01 FD 00 28 04 D0 BD F8 00 00 C0 B2 20 80 01 20
9:05:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 2C 09 81 80 46 B0 5D E4 1C B5 01 F1 7C 04 01 AA 69 46 FF F7 56 FF 40 B1 9D F8 04 20 9D F8 00 10 20 46 1E F0 C5 FE 00 28 00 D0 01 20 1C BD 10 B5 86 B0 0C 46 05 AA 04 A9 FF F7 43 FF 68 B1 9D F8 14 00 6A 46 00 1D C1 B2 9D F8 10 00 1E F0 73 FF 00 28 03 D0 03 98 C4 F8 B4 00 01 20 55 E5 10 B5 FF F7 E5 FF 00 28 00 D0 01 20 2B E4 1C B5 0C 46 D1 F8 A8 10 01 AA 49 1C C4 F8 A8 10 69 46 FF F7 20 FF 58 B1
9:05:36 AM
9:05:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 2D 09 81 80 9D F8 04 00 04 F1 A8 02 00 1D C1 B2 9D F8 00 00 1E F0 07 FF 00 28 00 D0 01 20 1C BD 10 B5 04 46 86 B0 D1 F8 B4 00 03 90 0A 22 0C 31 68 46 C7 F7 E2 FD 05 AA 04 A9 20 46 FF F7 01 FF 50 B1 9D F8 14 00 6A 46 00 1D C1 B2 9D F8 10 00 1E F0 55 FF 00 28 00 D0 01 20 16 E5 10 B5 91 F8 B8 20 01 2A 02 D0 02 2A 0A D0 0D E0 91 F8 B9 20 52 06 02 D4 FF F7 B9 FE 04 E0 FF F7 CC FE 01 E0 FF F7 B4 FF
9:05:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 2E 09 81 80 00 28 00 D0 01 20 16 E4 38 D5 06 00 E4 E7 2D E9 FF 41 07 46 00 68 00 25 0C 46 00 88 80 07 00 D5 01 25 38 46 FF F7 2D FE 06 46 6D B3 B4 F8 DE 00 C0 07 29 D0 21 F0 04 FD 94 F8 BA 00 01 28 02 D0 02 28 19 D0 1E E0 94 F8 BB 00 6A 46 40 06 09 D4 01 21 30 46 1E F0 ED FE 00 28 14 D0 03 98 C4 F8 AC 00 0F E0 02 21 30 46 1E F0 E3 FE 00 28 0A D0 03 98 C4 F8 B0 00 05 E0 21 46 38 46 FF F7 55 FF
9:05:37 AM
9:05:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 2F 09 81 80 00 28 00 D0 00 20 6C E6 94 F8 BA 00 01 28 02 D0 02 28 1D D0 22 E0 94 F8 BB 00 04 F1 0C 01 40 06 09 D4 D4 F8 AC 00 03 90 0A 22 68 46 C7 F7 63 FD 6A 46 01 21 08 E0 D4 F8 B0 00 03 90 0A 22 68 46 C7 F7 59 FD 6A 46 02 21 30 46 1E F0 D6 FE 03 E0 21 46 38 46 FF F7 62 FF 00 28 D4 D0 01 20 40 E6 95 E7 38 B5 04 46 69 46 14 20 D4 F7 D1 FF 18 B1 BD F8 00 00 00 28 18 D0 20 F0 94 FE 00 28 14 D0
9:05:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 30 09 81 80 21 68 A3 79 00 20 4A 88 5B 00 E1 79 DA 40 12 F0 03 02 0A D0 01 2A 04 D0 02 2A 07 D0 03 2A 04 D1 08 E0 01 29 06 D0 03 29 04 D0 38 BD 02 29 01 D0 04 29 FA D1 01 20 38 BD 2D E9 F0 4F A1 B0 04 46 10 78 DD F8 A8 90 88 46 1E 46 60 28 24 D1 55 68 15 B3 61 20 30 70 34 21 48 46 CF F7 22 FB 70 60 00 28 1A D0 06 46 34 21 C7 F7 37 FD 00 21 31 73 4F F0 01 0B 86 F8 0D B0 B1 73 28 68 EE F7 62 FD
9:05:38 AM
9:05:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 31 09 81 80 70 B1 28 1D FF F7 FF FA 07 46 01 28 0D D0 02 28 0D D0 03 28 0B D1 0C E0 00 20 21 B0 BD E8 F0 8F 02 21 30 46 FF F7 9C FC 47 E2 FE 49 02 E0 02 21 6A E0 FD 49 D1 E9 00 01 C6 E9 01 01 A0 88 04 28 1F D0 04 F1 0E 01 20 46 FF F7 75 FC A0 71 E7 71 FF 28 1C D0 20 46 FF F7 84 FF 00 28 E7 D1 82 46 28 6B 10 B1 FF F7 4A FB 82 46 A0 79 FF F7 09 FB FF F7 44 FB 06 28 43 D2 DF E8 00 F0 0B 16 16 16
9:05:39 AM
9:05:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 32 09 81 80 16 16 04 22 06 21 8D E8 06 02 01 23 65 E1 01 21 3A E0 E8 6A B8 B1 00 21 EE F7 14 FD 98 B1 20 8A 01 28 10 D0 0E 21 2F E0 E8 6A 00 28 FA D0 29 6B 11 B3 BA F1 00 0F F5 D0 69 6B F9 B1 00 21 EE F7 01 FD 00 28 EE D0 00 20 A0 72 E0 72 82 46 E8 6A A8 B3 00 21 EE F7 F6 FC 88 B3 28 6B 60 B1 FF F7 0D FB 82 46 03 28 2B D0 12 DC C0 B1 01 28 18 D0 BA F1 02 0F 5E D1 12 E0 0C 21 05 E0 0D 21 03 E0
9:05:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 33 09 81 80 28 6B 00 28 F8 D0 0A E0 30 46 FF F7 2F FC D4 E1 04 28 15 D0 05 28 13 D0 BA F1 FF 0F 4A D1 0B 21 F2 E7 84 F8 0A B0 69 6B 00 29 E7 D0 08 78 00 28 E4 D1 09 1D 20 46 FF F7 A8 FB 00 28 DE D0 39 E0 84 F8 0A A0 68 6B 00 28 D8 D0 01 78 00 29 D5 D1 80 88 08 28 D2 D3 E8 6A 30 62 28 6B 70 62 0C 21 48 46 CF F7 5E FA B0 62 01 00 C7 D0 4A 46 20 46 FF F7 59 FB 00 28 C1 D0 68 6B 82 88 40 2A 00 D3
9:05:40 AM
9:05:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 34 09 81 80 40 22 60 69 82 83 69 6B 60 69 89 68 1E 30 C7 F7 C7 FB B0 6A 82 88 60 69 A0 F8 5E 20 B1 6A 60 69 89 68 60 30 C7 F7 BC FB 07 20 E0 72 86 F8 0D B0 0E 20 B0 73 A0 79 21 F0 64 F9 00 28 9E D1 A0 79 1C A9 FF F7 79 FA 00 28 3F F4 6C AF 9D F8 70 00 41 1E 04 29 02 D8 82 45 7F F4 64 AF A2 79 04 F1 1D 00 E1 79 11 54 A2 79 19 30 A1 7A 11 54 A2 79 40 1D E1 7A 11 54 E8 69 E0 B1 00 88 08 28 EB D1
9:05:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 35 09 81 80 02 2F 02 D8 BA F1 05 0F 1A D1 08 21 48 46 CF F7 08 FA 30 61 00 28 3F F4 00 AF 08 21 01 80 48 46 CF F7 FF F9 31 69 00 28 48 60 31 69 F3 D0 21 F0 D7 F8 05 E0 02 2F 3F F6 35 AF BA F1 05 0F C3 D0 E8 6B 00 28 3F F4 23 AF 02 88 00 2A FA D0 41 68 00 29 F7 D0 1E A8 CF F7 DF F9 1E A8 CD E9 14 09 CD F8 5C 80 E8 6B 40 68 10 B1 00 78 21 28 0B D0 00 25 0C A9 13 A8 F1 F7 0C FB 18 B1 9D F8 30 00
9:05:41 AM
9:05:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 36 09 81 80 01 28 03 D0 35 B9 02 E7 01 25 F2 E7 A0 79 21 F0 4A F9 18 B1 A0 79 21 F0 17 F9 F8 E6 41 46 20 46 FF F7 5B FD A1 79 01 20 01 29 00 D1 00 20 B8 F8 00 10 81 B1 78 B1 98 F8 BB 00 C0 F3 01 10 03 28 09 D0 02 21 03 22 CD E9 00 21 01 23 CD F8 08 90 0A 46 30 46 70 E0 20 68 00 88 40 07 09 D5 03 2F 01 D0 04 2F 05 D1 98 F8 BB 00 C0 F3 01 10 03 28 C9 D1 98 F8 BB 00 10 F0 30 0F 05 D0 41 46 20 46
9:05:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 37 09 81 80 FF F7 2E FE 00 28 BE D0 0D 98 02 68 5A B1 03 2F 25 D3 10 88 38 B1 10 28 21 D3 41 46 20 46 FF F7 E4 FC 00 28 AF D0 61 69 00 20 48 72 0D 98 04 A9 00 79 20 81 0D 98 0D 30 EE F7 AA FC 4F F6 9F 60 01 2F 08 D0 39 49 4F F4 7A 45 02 2F 0F D0 03 2F 01 D0 04 2F 0B D0 07 25 0A E0 01 22 3C E0 00 21 06 22 CD E9 00 21 01 23 CD F8 08 90 F5 E7 08 46 04 99 01 40 04 91 04 A9 60 69 EE F7 92 FC 0D 98
9:05:42 AM
9:05:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 38 09 81 80 41 8A 20 46 FF F7 7C FB 61 69 4F F0 06 0A 81 F8 08 A0 60 69 12 21 0A 30 C7 F7 86 FB 04 98 70 B1 0D 98 00 7B 06 28 0C D2 CD F8 00 A0 01 23 CD E9 01 B9 1A 46 19 46 30 46 FF F7 DD FA 7D E0 02 21 04 E0 0D 98 40 8A 12 28 08 D2 03 21 CD F8 00 A0 CD E9 01 19 01 23 1A 46 01 21 7A E7 08 20 8D F8 60 00 06 A8 19 90 0D 98 80 68 18 B1 00 78 8D F8 74 00 1D A8 06 90 60 69 40 21 00 7A 8D F8 1C 00
9:05:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 39 09 81 80 60 69 00 68 CD F8 1D 00 60 69 80 88 AD F8 22 00 AD F8 24 50 48 46 CF F7 04 F9 01 00 3F F4 33 AF 40 22 05 E0 78 45 06 00 98 45 06 00 20 1A 1C 00 0A A8 CF F7 F1 F8 0A 25 AD F8 2C 50 18 A9 0A A8 F1 F7 A8 FA 00 28 E9 D0 03 2F 09 D0 04 2F 07 D0 0A 9D BD F8 2C 00 0A 35 0A 38 AD F8 14 00 20 E0 D8 F8 B8 00 20 90 88 F8 B8 B0 30 21 88 F8 B9 10 05 A9 CD E9 00 81 BD F8 2C 00 BD F8 2E 10 0A 38
9:05:43 AM
9:05:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 3A 09 81 80 83 B2 2A 46 0A 98 F2 F7 57 FA 05 00 C6 D0 41 46 20 46 FF F7 FB FC 00 28 C0 D0 BD F8 80 10 A8 F8 B8 10 08 21 48 46 CF F7 BC F8 30 63 00 28 B5 D0 BD F8 14 10 01 80 30 6B 45 60 30 7B 30 B1 00 22 01 21 20 46 FF F7 F2 FA 01 20 A6 E5 01 22 F7 E7 2D E9 F0 4F 9F B0 06 46 10 78 01 27 DD F8 A0 90 D2 F8 04 A0 0D 46 98 46 62 28 55 D1 BA F1 00 0F 52 D0 63 20 88 F8 00 00 08 21 48 46 CF F7 91 F8
9:05:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 3B 09 81 80 C8 F8 04 00 E8 B3 4F F0 00 08 C0 F8 00 80 04 46 C0 F8 04 80 01 21 48 46 CF F7 83 F8 01 00 20 60 3A D0 81 F8 00 80 DA F8 04 00 00 28 7E D0 02 88 00 2A FB D0 41 68 1C A8 CF F7 6E F8 1C A8 CD E9 0E 09 11 95 DA F8 04 00 40 68 10 B1 00 78 21 28 18 D0 00 20 82 46 14 A9 0D A8 F1 F7 9A F9 4F F0 02 0B 18 B1 9D F8 50 00 01 28 17 D0 BA F1 00 0F 0A D0 06 21 CD E9 00 19 00 23 01 22 11 46 20 46
9:05:44 AM
9:05:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 3C 09 81 80 08 E0 09 E0 01 20 E5 E7 CD E9 00 B9 01 22 03 23 11 46 20 46 FF F7 26 FA 00 27 AA E0 95 F8 BB 00 10 F0 30 0F 05 D0 29 46 30 46 FF F7 D9 FC 00 28 DF D0 B1 79 01 20 01 29 00 D1 00 20 29 88 31 B1 28 B1 95 F8 BB 00 C0 F3 01 10 03 28 DC D1 30 68 00 88 40 07 0A D5 F0 79 03 28 01 D0 04 28 05 D1 95 F8 BB 00 C0 F3 01 10 03 28 CD D1 08 20 8D F8 60 00 09 A8 19 90 70 69 00 F1 09 01 09 91 00 7A
9:05:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 3D 09 81 80 8D F8 28 00 70 69 00 68 CD F8 29 00 70 69 80 88 AD F8 2E 00 F0 79 01 28 29 D0 03 28 27 D0 4F F4 7A 40 00 BF AD F8 30 00 40 21 00 E0 56 E0 48 46 CE F7 F7 FF 01 00 4E D0 40 22 07 A8 CE F7 EC FF 4F F0 0A 0A AD F8 20 A0 18 A9 07 A8 F1 F7 A2 F9 E8 B3 F0 79 03 28 0C D0 04 28 0A D0 07 98 00 F1 0A 0A BD F8 20 00 0A 38 AD F8 0C 00 24 E0 07 20 D8 E7 55 F8 B8 0F 1E 90 01 20 28 70 30 20 68 70
9:05:45 AM
9:05:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 3E 09 81 80 A5 F1 B8 05 03 A8 CD E9 00 50 BD F8 20 00 BD F8 22 10 A0 F1 0A 00 83 B2 52 46 07 98 F2 F7 4C F9 5F EA 00 0A 17 D0 29 46 30 46 FF F7 EF FB 70 B1 BD F8 78 00 A5 F8 B8 00 08 21 48 46 CE F7 B1 FF 60 60 B0 B1 BD F8 0C 10 01 80 61 68 00 E0 02 E0 C1 F8 04 A0 09 E0 C4 F8 04 80 0A E0 F0 79 03 28 0F D0 04 28 0D D0 C4 F8 04 80 01 21 30 46 FE F7 01 FE 3A 46 00 21 30 46 FF F7 D8 F9 01 20 1F B0
9:05:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 3F 09 81 80 8C E4 21 68 01 20 08 70 E5 E7 70 B5 D0 F8 88 13 41 B3 4B 68 00 22 C0 F8 88 33 0B B9 C0 F8 8C 23 4A 60 B0 F8 90 33 5B 1E A0 F8 90 33 B0 F9 04 40 00 23 05 2C 1A D2 DF E8 04 F0 03 05 19 19 05 00 00 20 70 BD 4A 60 D0 F8 6C 23 62 B1 C2 F8 04 10 00 F5 59 70 81 60 81 89 01 F1 01 01 81 81 4F F0 01 01 41 70 06 E0 C0 F8 68 13 F1 E7 13 B9 08 46 E6 F7 E2 FB 01 20 70 BD 10 B5 D0 F8 78 43 CC B1
9:05:46 AM
9:05:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 40 09 81 80 62 68 00 21 C0 F8 78 23 0A B9 C0 F8 7C 13 61 60 B0 F8 80 13 49 1E A0 F8 80 13 90 F8 98 13 29 29 0A D0 D0 F8 A0 03 18 B1 21 46 0C F0 F7 F9 50 B1 01 20 10 BD 00 20 10 BD D0 F8 A4 03 18 B1 21 46 FD F7 E6 FC F3 E7 20 46 E6 F7 B6 FB F2 E7 10 B5 0B 68 5B 78 80 F8 98 33 1F 2B 04 D0 29 2B 1C D0 2A 2B 2B D0 23 E0 0C 68 0C B3 4B 68 FB B1 64 78 1F 2C 1C D1 5C 78 1F 2C 19 D1 9C 78 01 2C 16 D1
9:05:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 41 09 81 80 1B 79 13 70 09 68 8B 78 02 2B 02 D0 04 2B 02 D0 0D E0 09 79 17 E0 89 88 15 E0 0C 68 3C B1 4B 68 2B B1 64 78 29 2C 02 D1 5C 78 29 2C 01 D0 00 20 10 BD 5B 88 13 70 09 68 49 88 04 E0 4B 68 9B 78 13 70 09 68 89 78 51 80 11 78 80 F8 9A 13 51 88 80 F8 99 13 01 20 10 BD 2D E9 FF 41 0E 46 11 46 1F 46 04 46 6A 46 FF F7 B2 FF 00 28 7E D0 01 AA 69 46 20 46 FF F7 46 F8 00 28 77 D0 9D F8 04 10
9:05:47 AM
9:05:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 42 09 81 80 02 23 60 18 DF F8 40 C2 00 7E 01 22 00 25 A0 80 4F F4 A0 68 01 28 06 D0 02 28 68 D0 03 28 66 D0 04 28 3B D1 3B E0 08 46 FE F7 EE FC 00 28 9D F8 04 00 A0 71 22 81 20 D0 FE F7 D0 FC 10 B1 A5 72 E5 72 01 E0 A2 72 E3 72 9D F8 04 00 A0 22 00 EB 80 00 0C EB 40 11 04 EB 40 10 40 30 C7 F7 20 F8 9D F8 04 00 41 46 00 EB 80 00 04 EB 40 10 40 30 60 61 20 46 FF F7 C4 F8 0D E0 21 18 00 EB 80 00
9:05:48 AM
9:05:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 43 09 81 80 11 F8 1D 2F E2 71 4A 7E A2 72 89 7F 04 EB 40 10 E1 72 40 30 60 61 00 98 C4 F8 0E 00 4B E0 08 46 FE F7 B2 FC 38 B3 9D F8 04 00 A0 71 22 81 FE F7 95 FC 10 B1 A5 72 E5 72 01 E0 A2 72 E3 72 9D F8 04 00 A0 22 00 EB 80 00 0C EB 40 11 04 EB 40 10 40 30 C6 F7 E5 FF 9D F8 04 00 41 46 00 EB 80 00 04 EB 40 10 40 30 60 61 20 46 01 E0 3B E0 3D E0 FF F7 86 F8 1F E0 9D F8 04 00 9D F9 00 10 04 EB
9:05:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 44 09 81 80 80 0C 9C F9 22 30 99 42 30 D1 BD F8 02 10 BC F8 24 30 99 42 2A D1 A0 71 21 18 22 81 11 F8 1D 2F E2 71 4A 7E A2 72 00 EB 80 00 89 7F 04 EB 40 10 E1 72 40 30 60 61 20 89 08 B9 01 2F 16 D0 AE B1 75 60 D4 F8 8C 03 98 B1 C0 F8 04 60 C4 F8 8C 63 B4 F8 90 03 40 1C A4 F8 90 03 A4 F8 9C 73 20 46 FF F7 93 FE 01 20 04 B0 BD E8 F0 81 00 20 FA E7 C4 F8 88 63 EA E7 70 B5 04 46 03 29 24 D1 01 21
9:05:49 AM
9:05:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 45 09 81 80 00 20 31 4B A1 80 14 3B 4F EA 00 05 33 F8 10 20 52 07 03 D4 22 18 11 76 82 F8 60 13 40 1C 80 B2 05 28 F3 D3 D4 F8 68 03 70 B1 41 68 C4 F8 68 13 09 B9 C4 F8 6C 53 45 60 B4 F8 70 13 49 1E A4 F8 70 13 E6 F7 79 FA ED E7 01 20 70 BD 70 B5 B1 F5 81 7F 14 D1 01 23 1C 4C 00 22 83 80 B4 F1 14 04 34 F8 12 50 6D 07 01 D4 85 18 2B 76 52 1C 92 B2 05 2A F5 D3 D0 F8 A0 03 08 B1 0C F0 DC F8 01 20
9:05:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 46 09 81 80 70 BD 10 B5 FF F7 B7 FF 01 20 10 BD 10 B5 FF F7 DD FF 01 20 10 BD 10 B5 04 46 B0 F9 04 00 05 28 0F D2 DF E8 00 F0 0E 07 03 0E 07 00 04 21 20 46 FE F7 20 FC 20 46 FF F7 28 FE 20 46 BD E8 10 40 5A E6 01 21 F3 E7 00 00 66 D5 06 00 2D E9 F3 4F 83 B0 03 98 CE F7 CF FD 06 46 03 98 CE F7 F1 FD 07 46 00 25 0D F1 04 08 2C 46 FF 22 06 21 04 98 C7 F7 07 FD C1 46 AA 46 DF F8 3C B4 BB E0 71 78
9:05:50 AM
9:05:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 47 09 81 80 30 78 28 29 00 D1 77 1C 71 1C B9 42 01 D1 01 21 00 E0 00 21 2D 28 0F D0 04 DC 26 28 6D D0 2A 28 04 D1 6A E0 2E 28 30 D0 3A 28 1B D0 03 2D 7A D3 00 20 05 B0 BD E8 F0 8F 03 2D F9 D8 09 F8 05 A0 00 2C F5 D1 6A 46 FD A1 01 A8 C7 F7 A7 FB 01 28 EE D1 04 99 BD F8 00 00 00 25 08 70 0D F1 04 08 01 24 87 E0 03 2D E3 D8 09 F8 05 A0 01 2C DF D8 6A 46 F2 A1 01 A8 C7 F7 91 FB 01 28 D8 D1 04 99
9:05:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 48 09 81 80 BD F8 00 00 02 24 48 70 33 E0 03 2D D0 D8 09 F8 05 A0 6A 46 E9 A1 01 A8 C7 F7 80 FB 80 B2 AC B1 02 2C 0E D3 01 28 0A D0 9D F8 04 10 E2 48 C7 F7 56 F8 20 B1 A0 EB 0B 00 60 30 AD F8 00 00 02 2C 06 D0 03 2C 0A D0 04 2C 0E D0 12 E0 02 24 E9 E7 04 99 BD F8 00 00 03 24 88 70 0A E0 04 99 BD F8 00 00 04 24 C8 70 04 E0 04 99 BD F8 00 00 05 24 08 71 0D F1 04 08 00 25 3C E0 03 2D 98 D8 09 F8
9:05:51 AM
9:05:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 49 09 81 80 05 A0 04 2C 94 D3 6A 46 CC A1 01 A8 C7 F7 46 FB 01 28 8D D1 04 99 BD F8 00 00 0D F1 04 08 08 71 00 25 38 E0 FF E7 6D 1C 08 F8 01 0B ED B2 09 B3 09 F8 05 A0 6A 46 C1 A1 01 A8 C7 F7 2F FB 80 B2 03 2C 01 D3 01 28 0C D0 9D F8 04 10 BA 48 C7 F7 06 F8 00 28 3F F4 6D AF A0 EB 0B 00 60 30 AD F8 00 00 03 2C 10 D0 BD F8 00 00 04 99 04 2C 11 D0 48 71 06 24 76 1C BE 42 FF F4 41 AF 31 46 03 98
9:05:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 4A 09 81 80 CE F7 FD FC 01 20 54 E7 04 99 BD F8 00 00 04 24 C8 70 EF E7 08 71 05 24 EC E7 70 B5 0E 46 05 46 14 46 11 46 CE F7 03 FD 00 28 06 D0 22 46 31 46 28 46 BD E8 70 40 CE F7 08 BD 70 BD 70 B5 0E 46 05 46 14 46 11 46 CE F7 F2 FC 00 28 06 D0 22 46 31 46 28 46 BD E8 70 40 CE F7 0E BD 70 BD F8 B5 07 46 16 46 0C 46 00 25 0F E0 00 BF 14 F8 01 2B 93 A1 68 46 DE F7 BE FB 82 B2 69 46 38 46 CE F7
9:05:52 AM
9:05:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 4B 09 81 80 E4 FC 00 28 04 D0 6D 1C AD B2 B5 42 EE D3 01 20 F8 BD 2D E9 FC 41 07 46 16 46 0C 46 00 25 15 E0 02 22 69 46 38 46 CE F7 E7 FC 00 28 07 D0 01 AA 83 A1 68 46 C7 F7 B2 FA 01 28 02 D0 00 20 BD E8 FC 81 01 98 6D 1C 04 F8 01 0B AD B2 B5 42 E7 D3 01 20 F4 E7 2D E9 F0 43 8B B0 06 46 12 98 0C 46 90 46 1D 46 00 27 D0 B1 06 AA 07 A9 20 46 CE F7 D1 FA 48 B9 20 68 07 90 60 68 08 90 B4 F8 08 00
9:05:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 4C 09 81 80 AD F8 24 00 AD F8 18 70 00 24 30 46 CE F7 73 FC 81 46 BD F8 18 00 C0 07 07 D0 31 27 06 E0 20 68 07 90 60 68 08 90 08 89 EA E7 30 27 29 46 30 46 CE F7 7D FC 00 28 5E D0 64 20 41 46 B8 F1 02 0F 05 D0 03 29 1D D0 B8 F1 04 0F 71 D1 44 E0 BD F8 1C 10 06 2D B1 FB F0 F2 00 FB 12 12 02 D0 07 2D 48 D1 05 E0 9D F8 1F 00 00 90 9D F8 1E 30 26 E0 9D F8 1F 10 9D F8 1E 00 13 46 3A 46 CD E9 00 01
9:05:53 AM
9:05:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 4D 09 81 80 28 E0 04 2D 06 D0 05 2D 0A D0 06 2D 10 D0 07 2D 71 D1 16 E0 9D F8 22 30 9D F8 21 20 4A A1 66 E0 9D F8 22 00 00 90 9D F8 21 30 3A 46 49 A1 5E E0 9D F8 23 00 9D F8 22 30 9D F8 21 20 00 90 48 A1 55 E0 9D F8 23 10 9D F8 22 00 9D F8 21 30 CD E9 00 01 3A 46 46 A1 4A E0 BD F8 1C 10 0A 2D B1 FB F0 F2 00 FB 12 12 09 D0 0B 2D 13 D0 0C 2D 20 D0 0D 2D 2C D0 00 20 0B B0 BD E8 F0 83 9D F8 1F 00
9:05:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 4E 09 81 80 9D F8 22 30 9D F8 21 10 8D E8 0B 00 9D F8 1E 30 3B A1 2C E0 9D F8 1E 00 9D F8 22 40 9D F8 21 30 9D F8 1F 10 8D E8 1B 00 13 46 3A 46 3A A1 1E E0 21 E0 9D F8 1F 00 9D F8 23 40 9D F8 22 30 9D F8 21 10 8D E8 1B 00 9D F8 1E 30 39 A1 0F E0 9D F8 1F 00 01 AD 9D F8 23 40 9D F8 22 30 9D F8 21 10 1B C5 9D F8 1E 00 13 46 3A 46 38 A1 00 90 48 46 DE F7 C0 FA 84 B2 B0 88 20 44 B0 80 01 20 BA E7
9:05:54 AM
9:05:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 4F 09 81 80 38 B5 01 24 00 94 FF F7 25 FF 38 BD FE B5 0C 46 05 46 11 21 CE F7 CB FB 00 28 7D D0 28 46 CE F7 AA FB 06 46 A0 78 63 28 01 D1 21 79 19 B1 21 79 E2 78 02 91 59 E0 70 E0 CA D8 06 00 25 68 75 00 25 30 32 58 00 00 00 00 25 30 32 75 25 30 32 75 00 00 00 00 25 63 25 30 32 75 25 30 32 75 00 00 25 30 32 75 25 30 32 75 25 30 32 75 00 00 00 00 25 63 25 30 32 75 25 30 32 75 25 30 32 75 00 00
9:05:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 50 09 81 80 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 00 00 00 00 25 63 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 00 00 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 00 00 00 00 25 63 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 25 30 32 75 00 00 16 E0 CD E9 00 02 63 78 22 78 FE A1 30 46 DE F7 3D FA A9 88 80 B2 01 44
9:05:55 AM
9:05:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 51 09 81 80 A9 80 62 79 30 44 FF 2A 05 D0 FC A1 DE F7 32 FA A9 88 08 44 A8 80 01 20 FE BD E2 78 F8 A1 30 46 DE F7 28 FA E9 E7 2D E9 FF 4F 83 B0 0F 46 91 46 1C 46 99 1C 10 9E 03 98 CE F7 39 FB 00 28 2F D0 6C B3 09 2C 2B D8 A6 42 29 D8 EF 48 3D 46 42 1C B7 FB F2 F1 02 FB 11 51 87 42 02 D9 B9 F1 08 0F 01 D1 85 42 01 DD 0D 46 07 E0 E8 48 85 42 04 DA 40 42 95 FB F0 F1 00 FB 11 75 03 98 CE F7 FB FA
9:05:56 AM
9:05:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 52 09 81 80 80 46 48 46 C4 F1 09 02 EA 46 02 EB 0A 09 4F F0 2E 0B 05 28 14 D0 06 28 04 D0 08 28 1C D0 00 20 07 B0 47 E5 2B 46 09 22 D9 A1 50 46 DE F7 E2 F9 49 46 22 46 40 46 C6 F7 88 FD 08 EB 04 01 3C E0 2B 46 09 22 D2 A1 50 46 DE F7 D4 F9 A0 1B C4 B2 4D 46 22 46 49 46 20 E0 00 2F 06 DA 60 1C C0 B2 09 2C 01 D2 04 46 00 E0 09 24 2B 46 09 22 CA A1 50 46 DE F7 BF F9 00 2F 01 DA 2D 22 03 E0 C4 F1
9:05:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 53 09 81 80 09 01 1A F8 01 20 C4 F1 09 01 A0 1B 0A F8 01 20 01 EB 0A 05 C4 B2 22 46 29 46 40 46 C6 F7 55 FD 08 EB 04 01 28 19 46 B1 81 F8 00 B0 4C 1C 01 46 32 46 20 46 C6 F7 49 FD A1 19 03 98 CE F7 9F FA 01 20 AD E7 2D E9 FF 5F 86 B0 14 46 DD E9 15 67 98 46 B1 1C DD F8 50 A0 06 98 CE F7 A8 FA 00 28 35 D0 9E B3 09 2E 31 D8 B7 42 2F D8 A6 49 45 46 4A 1C 00 20 09 1B A8 41 08 D2 BA F1 08 0F 05 D0
9:05:57 AM
9:05:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 54 09 81 80 00 23 20 46 41 46 DE F7 95 F8 10 E0 9E 49 00 20 09 1B A8 41 F4 DB 9D 48 20 1A 75 F1 FF 30 08 DA 9A 4A 00 23 52 42 20 46 41 46 DE F7 FA F8 14 46 1D 46 06 98 CE F7 5F FA 81 46 50 46 4F F0 2E 0B 0D F1 08 0A 05 28 05 D0 08 28 0D D0 00 20 0A B0 BD E8 F0 9F 09 22 92 A1 50 46 CD E9 00 45 DE F7 49 F9 C6 F1 09 01 1D E0 B8 F1 00 0F 06 DA 70 1C C0 B2 09 2E 01 D2 06 46 00 E0 09 26 09 22 8A A1
9:05:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 55 09 81 80 50 46 CD E9 00 45 DE F7 35 F9 B8 F1 00 0F 01 DA 2D 22 03 E0 C6 F1 09 01 1A F8 01 20 C6 F1 09 01 0A F8 01 20 F0 1B C5 B2 01 EB 0A 04 2A 46 21 46 48 46 C6 F7 CA FC 09 EB 05 01 60 19 47 B1 81 F8 00 B0 4C 1C 01 46 3A 46 20 46 C6 F7 BE FC E1 19 06 98 CE F7 14 FA 01 20 B9 E7 2D E9 FF 4F 85 B0 4F F0 00 08 82 F8 00 80 83 F8 00 80 12 99 92 46 9B 46 81 F8 00 80 01 AF 05 98 CE F7 FC F9 81 46
9:05:58 AM
9:05:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 56 09 81 80 05 98 CE F7 0B FA 00 26 04 46 35 46 00 96 8D F8 04 80 26 E0 C6 F7 DE FA 01 68 99 F8 00 00 09 5C 20 29 06 D0 2E 28 11 D0 C8 07 26 D0 00 98 D0 B9 13 E0 09 2E 20 D8 07 F8 01 0B 76 1C 00 98 09 F1 01 09 F6 B2 58 B1 6D 1C ED B2 08 E0 00 98 98 B9 01 20 09 F1 01 09 00 90 01 E0 09 F1 01 09 64 1E A4 B2 00 2C D6 D1 87 F8 00 80 51 A1 01 A8 06 9A C6 F7 D4 FF 01 28 02 D0 00 20 09 B0 1A E4 6D B1
9:05:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 57 09 81 80 5F F0 05 00 8A F8 00 00 8B F8 00 60 12 98 49 46 05 70 05 98 CE F7 B3 F9 01 20 EE E7 06 20 F1 E7 70 B5 0D 46 04 46 07 21 CE F7 C1 F9 00 28 0A D0 20 46 CE F7 A0 F9 2A 46 3E A1 DE F7 9B F8 A1 88 08 44 A0 80 01 20 70 BD 2D E9 FF 4F 99 B0 83 46 30 20 8D F8 38 00 1C 46 4F F0 00 0A 4F F0 01 09 58 46 CE F7 88 F9 12 90 58 46 CE F7 97 F9 06 46 1B 98 07 78 26 80 00 24 25 46 A8 46 67 B9 30 1F
9:05:59 AM
9:05:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 58 09 81 80 0A 28 6F D2 DF E8 00 F0 05 05 08 08 6E 6E 07 07 07 07 03 27 00 E0 04 27 0D A8 0D F1 1C 0C 02 2F 04 D0 03 2F 68 D0 04 2F 65 D1 A4 E0 06 2E 02 D0 07 2E 57 D1 09 E0 00 90 63 46 0C AA 20 A1 12 98 C6 F7 6C FF 03 28 F4 D1 09 E0 CD E9 00 C0 0C AB 0E AA 1F A1 12 98 C6 F7 61 FF 04 28 E9 D1 BD F8 30 00 00 F5 FA 60 60 F3 0F 05 3C E0 25 64 2D 25 64 3A 25 64 2E 25 64 2E 25 64 00 00 2A 25 64 00
9:05:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 59 09 81 80 50 2E 25 30 32 64 00 00 FF C9 9A 3B 00 1F 0A FA 25 30 2A 6C 75 00 00 00 25 30 2A 6C 64 00 00 00 25 30 2A 6C 6C 75 00 00 25 30 2A 6C 6C 64 00 00 25 6C 75 00 28 45 52 25 30 32 64 29 00 00 00 00 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 00 25 63 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 00 00 00 BC E0 BD F8 1C 00 60 F3 17 45 BD F8 34 00 60 F3 1F 65 8B E0 04 2E 06 D0 05 2E 0D D0
9:06:00 AM
9:06:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 5A 09 81 80 06 2E 16 D0 07 2E 94 D1 29 E0 63 46 0C AA 71 A1 12 98 C6 F7 03 FF 02 28 8B D1 19 E0 0C AB 0E AA 6F A1 CD F8 00 C0 12 98 C6 F7 F8 FE 03 28 8A D1 0E E0 63 46 0C AA AF F2 78 01 00 90 12 98 C6 F7 ED FE 03 28 8A D1 00 BF BD F8 34 00 60 F3 1F 64 BD F8 30 00 60 F3 0F 24 BD F8 1C 00 56 E0 0C AB 0E AA AF F2 94 01 CD E9 00 C0 12 98 C6 F7 D6 FE 04 28 75 D1 E8 E7 10 A9 0F AA 0A 2E 07 D0 0B 2E
9:06:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 5B 09 81 80 11 D0 15 AB 0C 2E 1C D0 0D 2E 69 D1 47 E0 CD E9 00 02 02 91 63 46 0C AA 55 A1 12 98 C6 F7 BE FE 05 28 5D D1 1E E0 03 91 CD F8 00 C0 CD E9 01 02 0C AB 0E AA 55 A1 12 98 C6 F7 B0 FE 06 28 4F D1 10 E0 CD E9 02 13 CD E9 00 02 63 46 0C AA 56 A1 12 98 C6 F7 A3 FE 06 28 42 D1 00 BF BD F8 54 00 60 F3 1F 64 BD F8 30 00 00 F5 FA 60 60 F3 0F 05 BD F8 1C 00 60 F3 17 45 BD F8 34 00 60 F3 1F 65
9:06:01 AM
9:06:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 5C 09 81 80 BD F8 3C 00 60 F3 0F 24 BD F8 40 00 60 F3 17 44 9D F8 38 00 32 28 11 D0 31 28 15 D0 16 E0 CD F8 00 C0 CD E9 03 13 CD E9 01 02 0C AB 0E AA 46 A1 12 98 C6 F7 73 FE 07 28 12 D1 CF E7 4F F0 00 09 09 A8 CD F7 0B FE 05 E0 4F F0 01 0A 17 A9 09 A8 CD F7 51 FE 02 2F 07 D0 03 2F 0E D0 04 2F 18 D0 00 20 1D B0 BD E8 F0 8F AD F8 24 50 28 0C 8D F8 26 00 28 0E 8D F8 27 00 0F E0 20 0A 8D F8 29 00
9:06:02 AM
9:06:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 5D 09 81 80 20 0C 8D F8 2A 00 20 0E 8D F8 2B 00 AD F8 2C 80 03 E0 CD F8 2C 80 CD E9 09 54 B9 F1 00 0F 07 D0 52 46 09 A8 1A 99 CD F7 3A FE 00 28 D9 D0 07 E0 1A 98 09 99 01 60 0A 99 41 60 BD F8 2C 10 01 81 1B 98 07 70 BB F8 04 00 30 44 AB F8 04 00 01 20 C7 E7 00 00 25 30 32 68 75 25 30 32 68 75 00 00 25 63 25 30 32 68 75 25 30 32 68 75 00 00 00 00 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25
9:06:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 5E 09 81 80 30 32 68 75 25 30 32 68 75 00 00 00 25 63 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 00 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 00 00 25 63 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 25 30 32 68 75 00 00 00 00 2D E9 FE 43 05 46 0E 00 14 46 1F 46 4F F0 00 08 09 D0 02 AA
9:06:03 AM
9:06:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 5F 09 81 80 FE A1 30 46 C6 F7 CA FD 02 98 5B 28 04 D0 51 28 04 D0 00 20 BD E8 FE 83 2B 20 20 70 B6 1C 78 08 85 42 00 D3 05 46 6D 1E 00 27 B9 46 1E E0 01 AB 6A 46 F3 A1 30 46 C6 F7 B1 FD 02 98 5B 28 9D F8 04 00 04 D0 04 F8 01 0B 9D F8 00 00 05 E0 60 70 9D F8 00 00 A4 1C 46 28 01 D0 20 70 03 E0 84 F8 00 90 4F F0 01 08 B6 1C 7F 1C FF B2 AF 42 DE D3 B8 F1 01 0F 01 D0 84 F8 01 90 01 20 CA E7 2D E9
9:06:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 60 09 81 80 F0 47 82 46 A4 B0 88 46 08 00 7C D0 00 21 02 AB 02 22 E5 F7 DA FB 02 28 75 D1 02 24 13 AA DA A1 02 A8 C6 F7 7B FD BD F8 4C 50 0B 2D 6B D8 18 21 15 A8 C6 F7 52 F9 9D B1 68 00 02 B2 02 AB 21 46 40 46 E5 F7 C2 FB BD F8 4C 50 B0 EB 45 0F E3 D1 80 1C 04 B2 16 23 15 AA 02 A9 28 46 FF F7 86 FF 02 AB 02 22 21 46 40 46 E5 F7 AF FB 02 28 D3 D1 A4 1C 24 B2 1D AA C4 A1 02 A8 C6 F7 4F FD BD F8
9:06:04 AM
9:06:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 61 09 81 80 74 00 81 07 C8 D1 40 06 3D D4 02 AB 02 22 21 46 40 46 E5 F7 9A FB 02 28 BE D1 A4 1C 25 B2 09 AA B9 A1 02 A8 C6 F7 3A FD BD F8 24 40 14 2C BD D8 18 21 0B A8 C6 F7 11 F9 DC B1 E0 07 00 D0 64 1C 60 08 80 B2 40 1C AD F8 24 00 40 00 02 B2 02 AB 29 46 40 46 E5 F7 79 FB BD F8 24 40 B0 EB 44 0F 9A D1 28 44 05 B2 16 23 0B AA 02 A9 20 46 FF F7 3D FF 0B A8 C6 F7 D4 F9 00 F0 FF 09 02 AB 04 22
9:06:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 62 09 81 80 29 46 40 46 00 E0 5A E0 E5 F7 5F FB 04 28 7F D1 2D 1D 2C B2 1E AB 23 AA 9D A1 02 A8 C6 F7 FE FC 02 AB 0E 22 21 46 40 46 E5 F7 4F FB 0E 28 6F D1 0E 34 25 B2 00 24 02 AE 0D F1 6C 07 06 EB 44 00 20 AB 1F AA 8E A1 C6 F7 E9 FC 9D F8 80 00 9D F8 7C 10 30 38 00 EB 80 00 01 EB 40 00 30 38 38 55 64 1C A4 B2 07 2C E9 D3 02 AB 02 22 29 46 40 46 E5 F7 2B FB 02 28 4B D1 AD 1C 2E B2 11 AA 82 A1
9:06:05 AM
9:06:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 63 09 81 80 02 A8 C6 F7 CB FC BD F8 44 00 8C 28 40 D8 18 B1 BD F8 78 10 49 07 3B D5 00 24 18 B3 E5 F7 CA FA 04 00 35 D0 00 25 19 E0 21 AB 02 22 31 46 40 46 E5 F7 0B FB 02 28 03 D0 20 46 E5 F7 FD FA 27 E0 B6 1C 36 B2 22 AA 70 A1 21 A8 C6 F7 A7 FC 22 AA 01 21 20 46 E5 F7 E7 FB 6D 1C AD B2 BD F8 44 00 85 42 E1 D3 82 B2 49 46 0B A8 02 F0 37 FF 68 B1 BD F8 44 00 30 B1 21 46 DA F8 78 01 0B F0 41 FC
9:06:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 64 09 81 80 00 28 D9 D0 01 20 24 B0 BD E8 F0 87 00 2C D3 D1 00 20 F8 E7 2D E9 F0 41 06 46 08 46 17 46 3A 21 C6 F7 5D F9 04 00 2C D0 14 F8 01 0F 20 28 FB D0 00 25 04 E0 C6 F7 53 F9 00 28 22 D0 44 1C BD 42 4F F0 2C 01 20 46 F5 D3 C6 F7 49 F9 21 78 22 29 00 D1 64 1C 38 B1 00 1B C5 B2 60 19 10 F8 01 0C 22 28 04 D0 05 E0 20 46 C6 F7 1A F9 F4 E7 6D 1E ED B2 2A 46 21 46 30 46 C5 F7 92 FF 00 20 70 55
9:06:06 AM
9:06:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 65 09 81 80 01 20 BD E8 F0 81 7F B5 52 B1 8E 68 14 46 05 25 48 B1 01 28 1D D0 02 28 2E D0 09 28 2A D1 2B E0 00 20 04 B0 70 BD 0A 22 3C A1 30 46 C5 F7 4C FF 00 BB 00 22 31 46 68 46 FF F7 AC FF 03 AA 3A A1 68 46 C6 F7 2B FC 65 71 A0 8D 40 F4 C0 50 A0 85 10 E0 A0 8D 40 05 08 D5 94 F8 3C 00 94 F8 3D 10 88 42 02 D8 01 20 50 71 04 E0 65 71 A0 8D 40 F4 00 60 90 85 01 20 D4 E7 65 71 A0 8D 40 F4 C0 50
9:06:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 66 09 81 80 F7 E7 10 B5 1A B1 8B 68 14 46 70 B9 01 E0 00 20 10 BD 01 22 25 A1 18 46 C5 F7 16 FF 28 B9 03 20 60 71 04 F1 8C 00 CD F7 7D FC 01 20 10 BD 2D E9 F0 41 EE B0 04 46 E5 F7 FD F9 06 00 7D D0 00 22 1B A1 04 A8 DD F7 D6 FC 04 AA 02 21 30 46 E5 F7 2A FB A0 8D 40 05 01 D5 51 22 00 E0 11 22 14 A1 04 A8 DD F7 C7 FC 04 AA 02 21 30 46 E5 F7 1B FB 04 F1 2C 04 E2 7C 02 F1 01 00 1D E0 25 32 75 00
9:06:07 AM
9:06:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 67 09 81 80 25 63 25 63 00 00 00 00 25 32 68 78 00 00 00 00 25 32 68 78 25 32 68 78 00 00 00 00 2B 43 4D 53 20 45 52 52 4F 52 00 00 25 75 00 00 3E 00 00 00 25 30 32 58 00 00 00 00 E0 74 AF F2 0C 01 04 A8 DD F7 98 FC 04 AA 02 21 30 46 E5 F7 EC FA E2 7B AF F2 24 01 04 A8 DD F7 8D FC 04 AA 02 21 30 46 E5 F7 E1 FA 34 F8 2C 09 80 05 01 D5 81 22 00 E0 91 22 AF F2 44 01 04 A8 DD F7 7C FC 04 AA 02 21
9:06:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 68 09 81 80 30 46 E5 F7 D0 FA 04 F1 94 00 05 46 C6 F7 48 F8 01 B2 2A 46 30 46 E5 F7 C6 FA 00 22 AF F2 70 01 04 A8 DD F7 67 FC 04 AA 02 21 30 46 E5 F7 BB FA F4 22 AF F2 84 01 04 A8 00 E0 26 E0 DD F7 5A FC 04 AA 02 21 30 46 E5 F7 AE FA A7 22 AF F2 A0 01 04 A8 DD F7 4F FC 04 AA 02 21 30 46 E5 F7 A3 FA B4 F8 40 20 AF F2 B8 01 04 A8 DD F7 43 FC 04 AA 02 21 30 46 E5 F7 97 FA A0 8D 40 05 26 D5 94 F8
9:06:08 AM
9:06:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 69 09 81 80 3C 00 94 F8 3D 10 88 42 02 D9 00 20 6E B0 F8 E6 04 F1 3C 04 4F F0 03 03 A2 88 A2 F1 06 02 A2 80 A2 78 CD E9 02 10 CD E9 00 32 4F F0 00 03 4F F0 05 02 FB A1 04 A8 DD F7 1D FC 04 AA 0C 21 30 46 E5 F7 71 FA 20 78 40 1C 04 F8 3C 09 04 AB B4 F9 40 20 00 21 D4 F8 74 01 E5 F7 77 F9 B4 F9 40 10 D4 F8 74 01 E5 F7 F5 FA 00 25 04 AF 0D F1 9C 08 07 E0 7A 5D 08 EB 45 00 EE A1 DD F7 FB FB 6D 1C
9:06:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 6A 09 81 80 AD B2 B4 F8 40 00 A8 42 F3 D8 00 04 C0 0B 01 B2 27 AA 30 46 E5 F7 47 FA 4C F2 50 30 00 90 E7 4B 32 46 01 21 D4 F8 7C 01 E8 F7 6B FC 38 B1 30 46 E5 F7 42 F9 D4 F8 74 01 E5 F7 3E F9 A5 E7 94 F8 3C 00 94 F8 3D 10 88 42 02 D8 A0 8D 40 05 03 D4 D4 F8 74 01 E5 F7 30 F9 01 20 97 E7 10 B5 42 B1 14 46 B8 B1 04 F1 84 02 01 28 04 D0 02 28 11 D1 07 E0 00 20 10 BD 04 20 20 71 10 46 CD F7 52 FB
9:06:09 AM
9:06:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 6B 09 81 80 08 E0 03 20 20 71 10 46 CD F7 4C FB A0 8D 20 F0 04 00 A0 85 01 20 10 BD 70 B5 3A B1 8D 68 14 46 30 B1 01 28 19 D0 02 28 1E D1 1B E0 00 20 70 BD A0 8D 80 07 06 D5 10 46 FF F7 21 FD A0 8D 20 F0 02 00 A0 85 06 22 BE A1 28 46 C5 F7 BD FD 58 B9 A0 8D 40 F0 02 00 A0 85 06 E0 A0 8D 40 F0 04 00 90 85 01 E0 05 20 10 71 01 20 70 BD 10 B5 B6 4B 90 F8 2F 20 9C 79 22 42 02 D1 5C 79 22 42 01 D0
9:06:10 AM
9:06:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 6C 09 81 80 00 20 10 BD 09 B1 99 79 00 E0 59 79 0A 43 80 F8 2F 20 00 21 41 70 04 21 00 F8 44 1B CD F7 02 FB AA 49 01 20 88 71 10 BD 30 B5 85 B0 62 B1 14 46 00 22 04 92 8D 68 50 B1 A5 49 01 28 2A D0 02 28 34 D0 09 28 30 D1 31 E0 00 20 05 B0 30 BD 06 22 A0 A1 28 46 C5 F7 78 FD 18 BB 6A 46 9F A1 A8 1D C6 F7 5C FA 05 22 9F A1 68 46 C5 F7 6D FD 60 B1 2C 21 68 46 C5 F7 33 FF 40 1C 04 AA 9B A1 C6 F7
9:06:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 6D 09 81 80 4D FA 04 98 84 F8 3A 00 0E E0 00 21 20 46 FF F7 AD FF 09 E0 20 79 04 28 04 D0 60 69 89 69 88 43 60 61 01 E0 05 20 20 71 01 20 CE E7 60 69 89 69 08 43 F5 E7 1A B1 40 B1 01 28 06 D1 01 E0 00 20 70 47 90 8D 40 F0 40 00 90 85 01 20 70 47 70 B5 2A B1 8D 68 14 46 20 B1 01 28 26 D1 17 E0 00 20 70 BD A0 8D 01 06 20 D4 C0 07 1E D1 06 22 80 A1 28 46 C5 F7 29 FD C0 B9 04 F1 18 02 7B A1 A8 1D
9:06:11 AM
9:06:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 6E 09 81 80 C6 F7 0C FA A0 8D 40 F0 81 00 A0 85 0D E0 A0 8D 20 F0 60 00 A0 85 01 06 20 F0 80 00 01 D5 90 85 03 E0 A0 85 00 20 82 F8 3A 00 01 20 70 BD 10 B5 32 B1 14 46 78 B1 01 28 04 D0 02 28 19 D1 0A E0 00 20 10 BD 94 F8 2E 10 61 4A E0 68 52 F8 21 10 88 43 E0 60 0D E0 D4 F8 7C 01 E8 F7 1D FB 40 B9 4F F4 7A 70 60 62 01 20 20 70 04 F1 4C 00 CD F7 59 FA 01 20 10 BD 10 B5 01 46 32 B1 10 46 79 B1
9:06:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 6F 09 81 80 01 29 04 D0 02 29 14 D1 0A E0 00 20 10 BD 90 F8 2E 20 4F 4B C1 68 53 F8 22 20 91 43 C1 60 08 E0 4F F4 7A 71 41 62 01 21 01 70 02 F1 4C 00 CD F7 39 FA 01 20 10 BD 10 B5 01 46 32 B1 10 46 79 B1 01 29 04 D0 02 29 14 D1 0A E0 00 20 10 BD 90 F8 2E 20 3F 4B C1 68 53 F8 22 20 91 43 C1 60 08 E0 4F F4 7A 71 41 62 01 21 01 70 02 F1 4C 00 CD F7 19 FA 01 20 10 BD 1A B1 60 B1 01 28 0A D1 01 E0
9:06:12 AM
9:06:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 70 09 81 80 00 20 70 47 92 F8 2E 10 31 4B D0 68 53 F8 21 10 88 43 D0 60 01 20 70 47 32 B1 2D 49 88 B1 01 28 04 D0 02 28 11 D1 0C E0 00 20 70 47 92 F8 2E 30 D0 68 51 F8 23 30 98 43 D0 60 90 68 C9 68 88 43 02 E0 90 68 C9 68 08 43 90 60 01 20 70 47 32 B1 1F 49 88 B1 01 28 04 D0 02 28 11 D1 0C E0 00 20 70 47 92 F8 2E 30 D0 68 51 F8 23 30 98 43 D0 60 90 68 09 69 88 43 02 E0 90 68 09 69 08 43 90 60
9:06:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 71 09 81 80 01 20 70 47 2D E9 F0 41 0F 46 42 B1 0F 4D BE 68 14 46 88 B3 01 28 42 D0 02 28 40 D1 38 E0 2C E0 25 30 32 58 25 30 32 58 25 30 32 58 25 30 32 58 25 30 32 58 25 30 32 58 00 00 00 00 87 B2 03 00 2B 43 4D 47 52 3A 00 00 68 C1 01 00 30 58 00 10 C0 C1 01 00 2B 43 50 4D 53 3A 00 00 25 31 30 73 00 00 00 00 22 4D 45 22 00 00 00 00 25 32 64 00 2B 43 4D 47 4C 3A 00 00 01 E0 00 20 C1 E4 10 21
9:06:13 AM
9:06:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 72 09 81 80 E8 1D C5 F7 11 FD 30 46 C5 F7 CA FD 0F 28 08 D0 FE A0 01 68 C5 F8 07 10 80 88 A5 F8 0B 00 01 20 AF E4 B7 F9 0C 20 0F 2A 00 DD 0F 22 31 46 E8 1D C5 F7 36 FC 94 F8 2E 10 F6 4A E0 68 52 F8 21 10 88 43 E0 60 EB E7 2D E9 F0 41 5A B1 F2 4D F1 4F 8E 68 14 46 05 F1 17 08 30 B1 01 28 2E D0 02 28 2C D1 1D E0 00 20 8C E4 17 21 40 46 C5 F7 DC FC 07 22 EA A1 30 46 C5 F7 E7 FB C0 B9 F0 1D C5 F7
9:06:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 73 09 81 80 8F FD 16 28 13 D8 00 22 31 46 40 46 FF F7 42 FC 94 F8 2E 10 E0 68 57 F8 21 10 88 43 E0 60 0D E0 DD 48 07 22 DF A1 3F 30 C5 F7 CE FB 40 B1 D7 A0 01 68 C5 F8 17 10 80 88 A5 F8 1B 00 01 20 60 E4 94 F8 2E 10 E0 68 0E 22 57 F8 21 10 88 43 E0 60 D6 A1 40 46 C5 F7 E4 FB F0 E7 70 B5 1A B1 8D 68 14 46 D0 B9 01 E0 00 20 70 BD 28 46 C5 F7 58 FD 10 28 03 D2 28 46 C5 F7 53 FD 00 E0 10 20 C2 B2
9:06:14 AM
9:06:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 74 09 81 80 C5 48 29 46 2E 30 C5 F7 CB FB 94 F8 2E 10 C1 4A E0 68 52 F8 21 10 88 43 E0 60 01 20 70 BD 70 B5 1A B1 8D 68 14 46 20 BB 01 E0 00 20 70 BD 28 46 C5 F7 36 FD 10 28 03 D2 28 46 C5 F7 31 FD 00 E0 10 20 C2 B2 B4 48 29 46 3F 30 05 46 C5 F7 A8 FB 94 F8 2E 10 AF 4A E0 68 52 F8 21 10 06 22 88 43 E0 60 B6 A1 28 46 C5 F7 6F FB 10 B9 00 20 09 F0 E6 FE 01 20 70 BD 70 B5 1A B1 8D 68 14 46 F8 B9
9:06:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 75 09 81 80 01 E0 00 20 70 BD A4 48 33 21 50 30 06 46 C5 F7 4B FC 28 46 C5 F7 04 FD 32 28 03 D2 28 46 C5 F7 FF FC 00 E0 32 20 C2 B2 29 46 30 46 C5 F7 78 FB 94 F8 2E 10 97 4A E0 68 52 F8 21 10 88 43 E0 60 01 20 70 BD 1A B1 60 B1 01 28 0A D1 01 E0 00 20 70 47 92 F8 2E 10 8F 4B D0 68 53 F8 21 10 88 43 D0 60 01 20 70 47 2D E9 F0 41 1A B1 8D 68 14 46 30 BB 01 E0 00 20 01 E7 94 F8 2E 10 85 4E E0 68
9:06:15 AM
9:06:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 76 09 81 80 56 F8 21 10 08 42 1B D0 83 48 24 21 83 30 07 46 C5 F7 0A FC 28 46 C5 F7 C3 FC 23 28 03 D2 28 46 C5 F7 BE FC 00 E0 23 20 C2 B2 29 46 38 46 C5 F7 37 FB 94 F8 2E 10 E0 68 56 F8 21 10 88 43 E0 60 01 20 DB E6 32 B1 73 49 88 B1 01 28 04 D0 02 28 11 D1 0C E0 00 20 70 47 92 F8 2E 30 D0 68 51 F8 23 30 98 43 D0 60 90 68 C9 6A 88 43 02 E0 90 68 C9 6A 08 43 90 60 01 20 70 47 32 B1 65 49 88 B1
9:06:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 77 09 81 80 01 28 04 D0 02 28 11 D1 0C E0 00 20 70 47 92 F8 2E 30 D0 68 51 F8 23 30 98 43 D0 60 90 68 09 6B 88 43 02 E0 90 68 09 6B 08 43 90 60 01 20 70 47 32 B1 58 49 88 B1 01 28 04 D0 02 28 11 D1 0C E0 00 20 70 47 92 F8 2E 30 D0 68 51 F8 23 30 98 43 D0 60 90 68 49 6B 88 43 02 E0 90 68 49 6B 08 43 90 60 01 20 70 47 10 B5 03 46 3A B1 49 49 10 46 D3 B1 01 2B 04 D0 02 2B 20 D1 15 E0 00 20 10 BD
9:06:16 AM
9:06:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 78 09 81 80 90 F8 2E 30 C2 68 51 F8 23 30 9A 43 C2 60 82 68 89 6B 8A 43 82 60 81 8D C9 06 0F D5 04 21 01 71 84 30 CC F7 FF FF 09 E0 82 68 89 6B 0A 43 82 60 81 8D C9 06 02 D5 00 21 FF F7 D8 FC 01 20 10 BD 2D E9 F0 41 6A B1 34 4E 32 4D 8F 68 14 46 4F F0 FF 08 40 B1 01 28 3F D0 02 28 56 D0 09 28 3B D1 19 E0 00 20 4A E6 07 22 36 A1 38 46 C5 F7 6C FA 88 B9 05 22 35 A1 F8 1D C5 F7 66 FA 70 B1 07 22
9:06:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 79 09 81 80 34 A1 F8 1D C5 F7 60 FA 38 B3 07 22 33 A1 F8 1D C5 F7 5A FA C0 B3 86 F8 00 80 2D E0 00 20 30 70 A0 68 69 69 88 43 A0 60 60 69 29 68 88 43 60 61 94 F8 39 00 40 07 09 D4 4F F4 8B 70 20 F0 5B FC 94 F8 39 00 40 F0 04 00 84 F8 39 00 D4 F8 7C 01 C1 7A 21 F0 01 01 C1 72 45 E0 01 20 30 70 B4 F8 80 01 18 B1 E0 68 A9 69 08 43 E0 60 D4 F8 7C 01 C1 7A 21 F0 01 01 C1 72 A0 68 69 69 08 43 A0 60
9:06:17 AM
9:06:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 7A 09 81 80 60 69 29 68 88 43 2D E0 33 E0 35 E0 45 72 72 6F 72 00 00 00 C0 C1 01 00 30 58 00 10 2B 43 43 49 44 3A 20 00 53 4C 38 30 38 32 00 00 4E 6F 74 20 53 75 70 70 6F 72 74 65 64 00 00 00 53 4C 36 30 38 37 00 00 2B 43 50 49 4E 3A 20 00 52 45 41 44 59 00 00 00 53 49 4D 20 50 49 4E 00 53 49 4D 20 50 55 4B 00 60 61 E0 68 69 69 88 43 E0 60 01 20 C4 E5 02 20 30 70 B9 E7 60 69 29 68 08 43 C2 E7
9:06:18 AM
9:06:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 7B 09 81 80 2D E9 FC 41 6A B1 FF 4D FF 4E 8F 68 14 46 4F F0 FF 08 48 B1 01 28 3F D0 02 28 2F D0 09 28 3B D1 30 E0 00 20 BD E8 FC 81 06 22 F8 A1 38 46 C5 F7 CB F9 28 B1 86 F8 01 80 60 69 69 68 08 43 17 E0 01 AB 6A 46 F3 A1 B8 1D C5 F7 A8 FE BD F8 00 00 10 F0 FF 00 70 70 BD F8 04 10 B1 70 0A D0 63 28 08 D0 A0 68 A9 69 88 43 A0 60 60 69 69 68 88 43 60 61 11 E0 A0 68 A9 69 08 43 F5 E7 60 69 69 68
9:06:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 7C 09 81 80 08 43 08 E0 86 F8 01 80 A0 68 A9 69 08 43 A0 60 60 69 69 68 88 43 50 61 01 20 C3 E7 2D E9 FC 41 6A B1 D8 4D D8 4E 8F 68 14 46 4F F0 FF 08 40 B1 01 28 3B D0 02 28 2B D0 09 28 37 D1 2C E0 00 20 B0 E7 07 22 D5 A1 38 46 C5 F7 7E F9 28 B1 86 F8 03 80 60 69 A9 68 08 43 14 E0 6B 46 01 AA CD A1 F8 1D C5 F7 5B FE BD F8 00 00 C0 B2 F0 70 01 28 0A D0 05 28 08 D0 A0 68 E9 69 08 43 A0 60 60 69
9:06:19 AM
9:06:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 7D 09 81 80 A9 68 88 43 60 61 11 E0 A0 68 E9 69 88 43 F5 E7 60 69 A9 68 08 43 08 E0 86 F8 03 80 A0 68 E9 69 08 43 A0 60 60 69 A9 68 88 43 50 61 01 20 79 E7 2D E9 FC 41 6A B1 B4 4E B2 4D 8F 68 14 46 4F F0 FF 08 40 B1 01 28 32 D0 02 28 22 D0 09 28 2E D1 23 E0 00 20 66 E7 08 22 B2 A1 38 46 C5 F7 34 F9 30 B1 86 F8 04 80 60 69 E9 68 08 43 60 61 1E E0 6B 46 01 AA A7 A1 F8 1D C5 F7 10 FE BD F8 00 00
9:06:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 7E 09 81 80 30 71 A0 68 29 6A 88 43 A0 60 60 69 E9 68 88 43 EC E7 60 69 E9 68 08 43 08 E0 86 F8 04 80 A0 68 29 6A 08 43 A0 60 60 69 E9 68 88 43 50 61 01 20 38 E7 F0 B5 93 B0 42 B1 92 4D 8E 68 14 46 38 B1 01 28 48 D0 02 28 46 D1 41 E0 00 20 13 B0 F0 BD 3C 21 01 A8 C5 F7 C1 F9 07 22 95 A1 30 46 C5 F7 F3 F8 89 4F 80 37 58 B1 AF F2 60 20 01 68 C7 F8 27 10 80 88 A7 F8 2B 00 60 69 29 69 08 43 24 E0
9:06:20 AM
9:06:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 7F 09 81 80 30 46 C5 F7 8D FA 3B 28 0A D9 8B A0 01 68 C7 F8 27 10 41 68 C7 F8 2B 10 00 89 A7 F8 2F 00 1A E0 01 A8 00 90 11 AB 10 AA 86 A1 F0 1D C5 F7 B6 FD 75 48 25 22 01 A9 A7 30 C5 F7 F2 F8 72 49 00 20 81 F8 CC 00 60 69 29 69 88 43 60 61 03 E0 60 69 29 69 08 43 50 61 01 20 B8 E7 2D E9 FC 41 6A B1 69 4E 68 4D 8F 68 14 46 4F F0 FF 08 40 B1 01 28 3D D0 02 28 2D D0 09 28 39 D1 2E E0 00 20 D1 E6
9:06:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 80 09 81 80 08 22 75 A1 38 46 C5 F7 9F F8 60 B1 09 22 75 A1 38 46 C5 F7 99 F8 50 B3 86 F8 05 80 60 69 69 69 08 43 60 61 23 E0 01 AB 6A 46 5A A1 07 F1 08 00 C5 F7 74 FD BD F8 00 00 01 28 18 D1 BD F8 04 00 70 71 A0 68 69 6A 88 43 A0 60 60 69 69 69 88 43 E7 E7 60 69 69 69 08 43 08 E0 86 F8 05 80 A0 68 69 6A 08 43 A0 60 60 69 69 69 88 43 50 61 01 20 98 E6 2D E9 F0 47 0D 46 22 B1 AE 68 28 B1 01 28
9:06:21 AM
9:06:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 81 09 81 80 53 D1 4A E0 00 20 BD E8 F0 87 40 F2 91 11 58 48 C5 F7 4A F9 06 22 3D A1 30 46 C5 F7 55 F8 D8 B3 07 22 54 A1 30 46 C5 F7 4F F8 4F F0 00 09 50 B1 4F 49 52 A0 48 39 02 68 8A 64 80 88 A1 F8 4C 00 81 F8 4E 90 31 E0 AC 8A 4F F4 C8 70 84 42 00 D9 04 46 F1 1D 07 22 00 26 DF F8 AC 80 16 E0 00 BF B5 F9 0C 00 A0 42 00 DB 20 46 80 1A 87 B2 08 EB 06 00 00 F5 E4 70 3A 46 C5 F7 52 F8 E0 1B 84 B2
9:06:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 82 09 81 80 F0 19 2D 68 86 B2 1D B1 A9 68 00 22 00 2C E7 D1 08 EB 06 01 81 F8 C8 91 07 E0 92 F8 2E 10 19 4B D0 68 53 F8 21 10 88 43 D0 60 01 20 AB E7 2D E9 F0 4F AD F5 07 7D 0C 46 12 B3 15 46 10 B1 01 28 68 D1 1C E0 E4 B1 10 48 A6 68 CD 30 FB 21 84 90 C5 F7 EA F8 07 22 16 A1 30 46 C4 F7 F5 FF DF F8 90 B0 4F F0 00 09 AB F1 48 0B 50 B1 23 A1 0A 68 CB F8 48 20 89 88 AB F8 4C 10 8B F8 4E 90 41 E0
9:06:22 AM
9:06:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 83 09 81 80 4D E0 4E E0 C0 C1 01 00 30 58 00 10 2B 43 53 51 3A 20 00 00 25 68 75 2C 25 68 75 00 2B 43 52 45 47 3A 20 00 2B 43 47 52 45 47 3A 20 00 00 00 00 2B 43 4F 50 53 3A 20 00 45 72 72 6F 72 20 6C 65 6E 00 00 00 25 68 75 2C 25 68 75 2C 25 33 37 5B 5E 0A 5D 73 00 00 00 00 2B 43 47 41 43 54 3A 20 00 00 00 00 41 54 2B 43 47 41 43 54 3F 00 00 00 F8 59 00 10 2B 43 43 45 44 3A 20 00 45 72 72 6F
9:06:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 84 09 81 80 72 21 00 00 95 F8 2E 10 FE 4A E8 68 52 F8 21 10 88 43 E8 60 01 20 0D F5 07 7D BD E8 F0 8F 00 20 F9 E7 A7 8A B7 F5 FA 7F 01 D3 40 F2 F3 17 F1 1D 07 22 00 26 0D F1 08 0A 17 E0 00 BF B4 F9 0C 00 B8 42 00 DB 38 46 80 1A 1F FA 80 F8 0A EB 06 00 42 46 C4 F7 A5 FF A7 EB 08 00 87 B2 06 EB 08 00 24 68 86 B2 1C B1 A1 68 00 22 00 2F E6 D1 4F F4 FA 70 86 42 00 D3 06 46 4C 46 0A F8 06 90 28 21
9:06:23 AM
9:06:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 85 09 81 80 02 A8 C5 F7 2C F9 E8 B3 DF F8 7C 93 4F F0 00 0A 89 F8 CD 40 10 F8 01 7F 22 21 C5 F7 20 F9 90 B3 40 1C 80 46 22 21 C5 F7 1A F9 06 00 44 D0 A6 EB 08 00 10 28 00 DB 10 20 80 B2 02 46 00 90 41 46 7F A8 C4 F7 6D FF 00 98 7F A9 0C 54 2C 21 30 46 C5 F7 05 F9 B8 B1 40 1C 2C 21 C5 F7 00 F9 90 B1 22 21 C5 F7 FC F8 70 B1 40 1C 80 46 22 21 C5 F7 F6 F8 06 00 20 D0 A6 EB 08 00 05 28 00 DB 05 20
9:06:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 86 09 81 80 81 B2 01 E0 10 E0 17 E0 0A 46 00 91 41 46 85 A8 C4 F7 46 FF 00 99 85 A8 44 54 16 F8 01 1F 2C 29 07 D0 29 29 1D D0 07 E0 B8 A1 84 98 DC F7 E2 FC 70 E7 B1 78 29 29 0A D0 AF F2 40 11 0A 68 CB F8 48 20 89 88 AB F8 4C 10 8B F8 4E 40 17 E7 71 78 7F AB CD E9 00 01 09 EB 0A 00 CD 30 3A 46 B1 A1 06 E0 00 90 09 EB 0A 00 CD 30 7F AB 3A 46 B1 A1 DC F7 C0 FC 84 98 C5 F7 93 F8 1F FA 80 FA 28 21
9:06:24 AM
9:06:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 87 09 81 80 30 46 C5 F7 AC F8 00 28 E0 D0 BA F1 DA 0F 81 D3 F5 E6 2D E9 F0 41 72 B1 14 46 DF F8 68 82 02 F2 6D 12 8E 68 15 46 40 B1 01 28 3C D0 02 28 4B D0 09 28 4E D1 48 E0 00 20 54 E4 94 F8 2E 10 28 27 01 EB 81 02 02 EB 41 11 D4 F8 84 01 07 EB 41 01 08 44 C5 F7 65 F8 94 F8 2E 10 02 46 01 EB 81 03 03 EB 41 11 D4 F8 84 01 07 EB 41 01 01 44 30 46 C4 F7 AA FE 48 B1 14 F8 2E 0F 41 5D 49 1C 41 55
9:06:25 AM
9:06:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 88 09 81 80 60 7A 40 F0 01 00 60 72 23 E0 94 F8 37 00 40 F0 01 00 84 F8 37 00 94 F8 2E 20 20 69 58 F8 22 10 88 43 20 61 15 E0 94 F8 37 00 C0 07 06 D1 94 F8 2E 20 21 69 58 F8 22 00 81 43 21 61 14 F8 37 0F 20 F0 01 00 20 70 04 E0 94 F8 2E 00 41 5D 49 1C 81 54 01 20 06 E4 00 28 01 D0 90 F8 30 00 70 47 2D E9 F0 47 80 46 7A B1 75 4D 00 27 8E 68 14 46 02 F1 64 09 B8 F1 09 0F 30 D2 DF E8 08 F0 67 A2
9:06:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 89 09 81 80 A2 07 41 A2 4C A2 4C 00 00 20 FC E5 D4 F8 7C 01 80 78 01 28 1E D1 05 22 6A A1 06 F1 08 00 C4 F7 53 FE 00 28 94 F8 38 00 E9 78 18 D0 30 EA 01 00 84 F8 38 00 A9 78 C0 B2 04 F1 30 04 88 43 20 72 20 78 00 F1 01 00 20 70 67 70 A4 F1 30 04 48 46 CC F7 A8 FB D4 F8 7C 01 80 78 10 B1 71 E0 08 43 E6 E7 94 F8 31 00 40 1C C0 B2 84 F8 31 00 03 28 67 D9 00 21 20 46 FF F7 79 F8 84 F8 31 70 60 E0
9:06:26 AM
9:06:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 8A 09 81 80 04 F1 5C 00 CC F7 8A FB 03 20 A0 70 D4 F8 78 01 0A F0 95 FA 55 E0 A7 70 D4 F8 78 01 0A F0 90 FA 94 F8 38 00 29 78 88 43 69 78 88 43 E9 78 88 43 84 F8 38 00 B8 F1 06 0F 43 D1 D4 F8 7C 01 80 78 01 28 3E D1 F6 20 20 F0 16 F8 3A E0 D4 F8 7C 01 80 78 01 28 35 D1 07 22 3C A1 30 46 C4 F7 F4 FD A8 B9 00 22 31 46 04 F2 35 10 FE F7 53 FE 70 B1 04 F1 32 04 A9 78 A0 79 20 EA 01 00 A0 71 20 78
9:06:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 8B 09 81 80 00 F1 01 00 04 F8 32 09 48 46 CC F7 4B FB 06 22 30 A1 30 46 C4 F7 D8 FD 98 B9 A0 8D C0 07 10 D1 30 46 04 F1 18 05 2C 21 C4 F7 99 FF 28 B1 40 1C 2A 46 AF F6 C8 41 C5 F7 B1 FA A0 8D 40 F0 01 00 A0 85 01 20 5F E5 10 B5 4A B1 14 46 09 28 4B D2 DF E8 00 F0 4A 44 07 4A 44 07 07 07 07 00 00 20 10 BD 00 20 A0 70 D4 F8 78 01 0A F0 29 FA 14 49 94 F8 38 00 0A 78 49 78 90 43 88 43 84 F8 38 00
9:06:27 AM
9:06:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 8C 09 81 80 32 E0 00 00 C0 C1 01 00 30 58 00 10 4E 6F 20 6E 65 74 77 6F 72 6B 20 64 65 74 65 63 74 65 64 21 00 00 00 00 28 25 63 2C 25 73 2C 25 73 2C 25 63 29 00 00 00 28 25 63 2C 25 73 2C 25 73 29 00 00 68 C1 01 00 56 4F 49 43 45 00 00 00 2B 43 4C 49 50 3A 20 00 2B 43 4D 54 49 3A 00 00 03 20 A0 70 D2 F8 78 01 0A F0 EB F9 01 20 10 BD 0A 28 05 D1 FC 49 12 F8 36 0F 09 78 08 43 10 70 01 20 70 47
9:06:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 8D 09 81 80 0A 28 05 D1 F7 49 12 F8 36 0F 49 78 08 43 10 70 01 20 70 47 70 B5 05 46 0E 46 62 B1 14 46 02 F1 74 00 CC F7 BF FA 32 46 29 46 D4 F8 78 01 0A F0 D3 F9 01 20 70 BD 00 20 70 BD 12 B1 01 28 02 D0 0A E0 00 20 70 47 02 20 50 70 E7 49 00 20 82 F8 34 00 C8 70 08 71 48 71 01 20 70 47 10 B5 1A B1 14 46 01 28 02 D0 15 E0 00 20 10 BD 08 20 60 70 00 20 84 F8 34 00 94 F8 39 00 80 07 0A D4 F2 20
9:06:28 AM
9:06:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 8E 09 81 80 1F F0 39 FF 94 F8 39 00 C1 07 03 D0 40 F0 02 00 84 F8 39 00 01 20 10 BD 70 B5 D2 4D 04 46 90 F8 2F 00 E9 79 08 42 01 D0 00 20 70 BD 01 21 20 46 FE F7 5C FF 14 F8 2F 0F E9 79 08 43 20 70 01 20 70 BD 70 B5 04 46 00 78 0D 46 01 28 01 D0 03 28 17 D1 B5 B1 08 46 C4 F7 A3 FE 16 28 11 D8 A0 8D C0 05 0E D4 28 46 C4 F7 9B FE C2 B2 29 46 00 20 0C E0 0B 78 A3 F1 30 06 0A 2E 04 D3 08 B9 2B 2B
9:06:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 8F 09 81 80 01 D0 00 20 70 BD 49 1C 40 1C C0 B2 90 42 F0 D3 14 20 84 F8 3B 00 04 F1 3B 03 04 F1 94 02 29 46 20 46 01 F0 F6 F8 00 28 EC D0 A0 8D 20 F4 80 50 40 F4 00 60 A0 85 01 20 70 BD 10 B5 02 78 01 2A 01 D0 03 2A 17 D1 82 8D 13 05 14 D5 99 B1 D2 05 11 D4 B1 F9 14 20 48 F2 7A 53 92 1C 9A 42 0A DC CA 7B D2 07 8A 68 A2 EB 01 02 01 D0 18 3A 00 E0 10 3A 02 2A 01 DA 00 20 10 BD 8A 68 66 23 02 F8
9:06:29 AM
9:06:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 90 09 81 80 02 3D 01 23 53 70 8A 68 92 1E 8A 60 8A 89 92 1C 8A 81 8A 8A 92 1C 8A 82 82 8D 22 F4 80 62 82 85 80 F8 3D 30 B1 F9 14 40 8C 2C 10 DD 42 F4 80 62 20 F8 2C 2F 03 74 B1 F9 14 20 86 23 92 FB F3 F2 52 1C 42 74 82 7C 52 1C 82 74 A0 F1 2C 00 C0 F8 74 11 81 8D 21 F4 C0 51 41 F4 80 71 81 85 4F F0 01 00 10 BD 7C B5 04 46 15 46 0E 46 08 46 C4 F7 17 FE 10 28 0D D8 A0 78 58 B9 7C 48 A5 62 CD E9
9:06:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 91 09 81 80 00 05 7B 4B 32 46 01 21 D4 F8 7C 01 E7 F7 71 FB 08 B1 00 20 7C BD 04 F1 5C 00 CC F7 C3 F9 02 20 70 49 A0 70 94 F8 38 00 09 78 08 43 84 F8 38 00 01 20 7C BD 00 20 70 47 F8 B5 04 46 90 F8 30 00 00 28 2B D0 A0 78 00 25 38 BB 47 F2 30 50 A0 62 00 90 66 4B 66 4A 01 21 D4 F8 7C 01 E7 F7 86 FB D8 B9 04 F1 5C 00 CC F7 9D F9 02 20 5D 4E A0 70 94 F8 38 00 71 78 01 25 08 43 84 F8 38 00 00 20
9:06:30 AM
9:06:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 92 09 81 80 84 F8 30 00 84 F8 32 00 04 F1 64 00 CC F7 86 F9 14 F8 38 0F F1 78 88 43 20 70 28 46 F8 BD 10 B5 04 46 80 78 08 B1 03 28 11 D1 01 21 D4 F8 7C 01 E7 F7 24 FC 18 B1 03 28 01 D0 02 28 07 D1 43 F6 98 22 01 21 D4 F8 7C 01 E7 F7 BA FB 08 B1 00 20 10 BD 04 20 A0 70 00 20 E0 70 84 F8 30 00 84 F8 32 00 04 F1 64 00 CC F7 59 F9 04 F1 5C 00 CC F7 59 F9 3C 49 14 F8 38 0F C9 78 88 43 20 70 01 20
9:06:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 93 09 81 80 10 BD 10 B5 04 46 0A 46 D0 F8 7C 01 01 21 E7 F7 C8 FB 00 28 04 D0 04 F1 7C 00 CC F7 43 F9 01 20 10 BD 01 78 02 29 05 D0 03 29 01 D0 04 29 03 D0 01 20 70 47 00 20 70 47 40 78 08 28 01 D0 02 20 70 47 03 20 70 47 80 78 05 28 0A D2 DF E8 00 F0 09 09 03 05 07 00 01 20 70 47 02 20 70 47 03 20 70 47 00 20 70 47 80 8D C1 04 01 D5 02 20 70 47 00 05 01 D5 01 20 70 47 00 20 70 47 30 B5 00 21
9:06:31 AM
9:06:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 94 09 81 80 1C 4C D0 F8 84 21 06 E0 54 F8 21 50 03 69 2B 43 49 1C C9 B2 03 61 13 88 8B 42 F5 D8 00 21 C0 F8 6D 11 80 F8 71 11 30 BD 10 B5 12 4B 00 22 00 F1 6C 04 19 B1 01 29 25 D0 00 20 10 BD C1 68 DB 6C 19 43 C1 60 08 48 0C A1 80 30 0B 68 C0 F8 4D 30 4B 68 C0 F8 51 30 09 89 A0 F8 55 10 80 F8 57 20 20 E0 00 00 68 C1 01 00 30 58 00 10 95 C6 03 00 C7 C5 03 00 C0 C1 01 00 52 65 61 64 69 6E 67 2E
9:06:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 95 09 81 80 2E 2E 00 00 C1 68 1B 6D 19 43 C1 60 F9 48 AF F2 18 01 0B 68 83 64 4B 68 C3 64 09 89 A0 F8 50 10 80 F8 52 20 20 46 CC F7 B9 F8 01 20 10 BD 2D E9 F0 47 04 46 0F 46 40 F2 59 31 EF 48 C4 F7 34 FC DF F8 B4 93 48 46 AF F2 50 01 0A 68 C9 F8 07 20 4A 68 C9 F8 0B 20 09 89 A9 F8 0F 10 00 25 89 F8 11 50 AF F2 6C 01 0A 68 C9 F8 17 20 4A 68 C9 F8 1B 20 09 89 A9 F8 1F 10 80 F8 21 50 09 F1 80 08
9:06:32 AM
9:06:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 96 09 81 80 AF F2 8C 01 0A 68 C8 F8 27 20 4A 68 C8 F8 2B 20 09 89 A8 F8 2F 10 88 F8 31 50 04 F1 4C 00 CC F7 7D F8 04 F1 74 00 CC F7 7D F8 04 F1 7C 00 CC F7 79 F8 04 F1 44 00 CC F7 71 F8 E0 68 A5 62 00 F4 C0 16 1C 34 B4 20 60 76 A5 76 42 F2 10 70 A0 60 CD F7 09 FE 3C 21 B0 FB F1 F2 01 FB 12 00 B4 30 4F F4 7A 71 48 43 60 60 A5 74 25 75 A5 75 E5 75 25 76 E5 74 E5 76 44 F8 10 5C 44 F8 0C 5C 44 F8
9:06:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 97 09 81 80 08 5C 25 82 44 F8 04 5C 25 60 E5 77 25 77 A4 F1 1C 04 01 2F 01 D1 84 F8 39 50 B8 4F 00 20 00 BF 57 F8 20 20 E1 68 40 1C 11 43 C0 B2 E1 60 15 28 F6 D3 08 46 B9 69 88 43 E0 60 F9 6C 31 42 0D D0 AF F2 4C 11 0A 68 C8 F8 4D 20 4A 68 C8 F8 51 20 09 89 A8 F8 55 10 88 F8 57 50 08 E0 F9 6C 0D 22 88 43 E0 60 A3 48 A6 A1 B3 38 C4 F7 D9 FA 38 6D 30 42 0D D0 AF F2 80 11 0A 68 C8 F8 4D 20 4A 68
9:06:33 AM
9:06:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 98 09 81 80 C8 F8 51 20 09 89 A8 F8 55 10 88 F8 57 50 09 E0 E0 68 39 6D 0D 22 88 43 E0 60 96 48 98 A1 48 30 C4 F7 BE FA 00 20 D4 F8 84 11 06 E0 57 F8 20 30 22 69 1A 43 40 1C C0 B2 22 61 0A 88 82 42 F5 D8 C4 F8 6D 51 84 F8 71 51 15 21 04 F1 94 00 C4 F7 44 FB 8C 21 04 F1 A9 00 C4 F7 66 FB A5 60 25 70 65 70 04 F1 54 00 CB F7 DD FF 01 20 A0 70 E5 70 25 71 65 71 A0 8D 00 21 40 F4 00 60 A0 85 89 F8
9:06:34 AM
9:06:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 99 09 81 80 06 50 D4 F8 7C 01 D0 F8 08 01 BD E8 F0 47 0B F0 73 B9 F0 B5 01 79 01 22 00 23 87 B0 04 46 40 F6 B8 36 42 F2 10 75 00 F1 84 07 06 29 6B D2 DF E8 01 F0 03 10 37 48 57 5F A0 8D C0 07 63 D0 A0 78 03 28 60 D0 22 71 07 B0 38 46 BD E8 F0 40 CB F7 A9 BF A0 8D 00 07 17 D4 6D A2 6F A1 01 A8 A3 69 DC F7 08 F8 00 96 6E 4B 01 AA 01 21 D4 F8 7C 01 E7 F7 CE F8 40 B9 A0 8D 40 F0 08 00 A0 85 02 20
9:06:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 9A 09 81 80 20 71 38 46 CB F7 8E FF 38 46 CB F7 93 FF A8 42 39 D9 07 B0 20 46 BD E8 F0 40 00 21 FE F7 66 BC A0 8D 40 07 F0 D5 5F A1 01 A8 A2 69 DB F7 E2 FF 00 96 5F 4B D4 F8 7C 01 01 AA 01 21 E7 F7 A8 F8 E2 E7 00 96 5B 4B 5C A2 01 21 D4 F8 7C 01 E7 F7 9F F8 00 28 D8 D0 A0 8D 40 F0 10 00 A0 85 D3 E7 4F F4 FA 60 00 90 57 4B 57 A2 D4 F8 7C 01 E4 E7 A0 8D 20 F0 1D 00 A0 85 23 71 07 B0 38 46 BD E8
9:06:35 AM
9:06:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 9B 09 81 80 F0 40 CB F7 4B BF 07 B0 F0 BD 2D E9 F0 41 41 79 05 25 04 46 4F F4 7A 76 00 F1 8C 07 06 29 21 D2 DF E8 01 F0 03 15 22 28 33 45 A0 8D C0 05 19 D5 A0 78 00 28 16 D1 20 78 01 28 01 D0 03 28 11 D1 01 20 60 71 38 46 BD E8 F0 41 CB F7 2B BF 20 46 00 F0 23 FE 08 B1 02 20 12 E0 38 46 CB F7 2A FF B0 42 19 D8 BD E8 F0 81 38 46 CB F7 23 FF 40 F2 4C 41 0F E0 20 46 FE F7 9A FA 00 28 ED D0 04 20
9:06:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 9C 09 81 80 60 71 38 46 CB F7 0E FF E7 E7 38 46 CB F7 12 FF 4C F2 38 71 88 42 E5 D9 A0 8D 40 F4 80 50 A0 85 65 71 D4 F8 74 01 BD E8 F0 41 E3 F7 C5 BC A0 8D 20 F4 80 70 A0 85 00 20 60 71 38 46 BD E8 F0 41 CB F7 EC BE 2D E9 F0 4F 04 46 A1 B0 10 F8 4C 1B 03 90 00 27 09 4D 04 F1 54 00 1D 4E 4F F0 03 09 4F F0 02 0A 4F F0 01 08 4F F0 06 0B 01 90 05 29 44 D2 2F E0 B0 59 00 10 30 58 00 10 C0 C1 01 00
9:06:36 AM
9:06:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 9D 09 81 80 55 6E 61 76 61 69 6C 61 62 6C 65 2E 00 00 00 00 2B 43 4D 47 52 3D 00 00 25 73 25 64 00 00 00 00 99 B5 03 00 2B 43 4D 47 44 3D 25 64 00 00 00 00 5D B5 03 00 E7 BB 03 00 2B 43 4D 47 44 3D 31 2C 34 00 00 00 29 B6 03 00 2B 43 50 4D 53 3F 00 00 68 C1 01 00 DF E8 01 F0 03 3C B6 F0 EF 00 60 78 30 B1 01 28 0D D0 02 28 18 D0 03 28 2E D1 22 E0 01 98 CB F7 9F FE B0 F5 96 7F 71 D8 21 B0 BD E8
9:06:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 9E 09 81 80 F0 8F 01 98 CB F7 96 FE B0 F5 FA 7F F6 D9 01 20 08 F0 95 FC 01 98 CB F7 85 FE BD E0 01 98 CB F7 89 FE B0 F5 C8 7F E9 D9 00 20 08 F0 7E FC 01 98 CB F7 78 FE 51 E3 01 98 CB F7 7C FE B0 F5 FA 6F DC D9 01 98 CB F7 6E FE 84 F8 00 A0 67 70 D5 E7 04 F1 6C 00 CB F7 6E FE 4E F6 60 21 88 42 51 D9 A0 68 A9 68 08 42 0B D0 94 F8 39 00 C0 07 42 D1 EC 20 1F F0 00 FB 94 F8 39 00 40 F0 01 00 17 E0
9:06:37 AM
9:06:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 9F 09 81 80 4F F4 89 72 68 B3 D5 E9 05 13 19 43 D5 E9 07 36 33 43 19 43 6B 6A 19 43 01 42 23 D0 69 69 08 42 09 D0 ED 20 1F F0 E7 FA 94 F8 39 00 20 F0 04 00 84 F8 39 00 1F E0 A9 69 08 42 03 D0 4F F4 8A 70 1F F0 D9 FA A0 68 69 6A 08 42 03 D0 40 F2 15 10 1F F0 D1 FA A0 68 E9 69 08 42 0C D0 EE 20 08 E0 62 E2 0D E0 29 68 08 42 02 D1 69 68 08 40 10 B1 10 46 1F F0 C0 FA 00 21 20 46 FE F7 F7 FA 7D E7
9:06:37 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A0 09 81 80 60 69 F4 E7 03 98 CB F7 15 FE 61 6A 88 42 9E D9 E0 68 38 B1 84 F8 00 A0 67 70 A0 68 A9 68 08 43 A0 60 09 E0 20 69 20 B1 84 F8 00 A0 07 20 60 70 02 E0 84 F8 00 90 67 70 84 F8 2E 70 03 98 CB F7 F1 FD 79 E1 60 78 09 28 D9 D2 DF E8 00 F0 05 14 28 36 54 6E B7 F9 F8 00 D4 F8 7C 01 E6 F7 9C FE 00 28 07 D1 00 94 D4 F8 7C 01 F7 4B F7 4A 41 78 E6 F7 5E FE 05 E1 01 98 CB F7 DC FD B0 F5 FA 7F
9:06:38 AM
9:06:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A1 09 81 80 BD D9 01 21 D4 F8 7C 01 E6 F7 84 FE D4 F8 7C 01 D0 F8 08 01 0A F0 AD FF 84 F8 01 A0 2E E7 D4 F8 7C 01 00 22 11 46 D0 F8 08 01 0A F0 AE FF 88 B1 84 F8 01 90 0E E0 22 E2 A7 E1 D4 F8 7C 01 D0 F8 08 01 90 F8 38 00 03 28 04 D1 01 98 CB F7 AA FD 04 20 60 70 01 98 CB F7 AD FD 4E F6 60 21 88 42 8D D9 84 F8 00 80 4F F4 7A 70 60 62 A5 E0 00 BF CB F7 98 FD 02 E7 01 98 CB F7 9C FD FA 28 CD D9
9:06:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A2 09 81 80 00 94 D1 4B D1 4A 00 21 D4 F8 7C 01 E6 F7 10 FE 05 20 60 70 01 98 CB F7 81 FD EF E6 40 1C C0 B2 84 F8 2E 00 15 28 01 D3 09 E0 E1 68 94 F8 2E 00 55 F8 20 20 11 42 F1 D0 C1 B2 15 29 02 D3 84 F8 2E 70 AA E2 04 28 12 D2 00 EB 80 01 C0 48 00 EB C1 02 50 6A 00 90 D4 F8 7C 01 13 6A 41 78 1A E0 88 43 00 E0 08 43 A0 60 84 F8 01 B0 E4 E0 06 28 18 D0 00 EB 80 01 B6 48 00 EB C1 02 94 F8 2E 00
9:06:39 AM
9:06:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A3 09 81 80 00 EB 80 01 B2 48 00 EB C1 00 41 6A 00 91 03 6A 00 21 D4 F8 7C 01 E6 F7 7B FE 00 28 A0 68 69 68 E0 D1 DD E7 B4 F8 80 21 AA A1 07 A8 DB F7 A2 FD E0 68 A9 69 07 AA 88 43 E0 60 DF E7 94 F8 2E 00 04 28 D4 F8 7C 01 01 D2 41 78 00 E0 00 21 E6 F7 D5 FF 07 46 01 98 CB F7 2D FD 94 F8 2E 10 01 EB 81 02 9B 49 01 EB C2 01 49 6A 01 F5 7A 71 88 42 04 D2 A0 68 69 68 08 42 8F D1 08 E0 94 F8 36 00
9:06:40 AM
9:06:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A4 09 81 80 31 78 08 43 84 F8 36 00 01 98 CB F7 07 FD 94 F8 36 00 31 78 08 42 14 D0 32 78 A1 68 11 43 A1 60 31 78 88 43 84 F8 36 00 94 F8 2E 00 04 28 1A D2 4F F4 7A 70 60 62 84 F8 00 80 03 98 58 E7 A2 E0 22 E0 0F B1 03 2F D7 D1 A0 68 29 68 88 43 A0 60 E1 68 41 B9 A9 68 88 43 A0 60 94 F8 39 00 20 F0 03 00 84 F8 39 00 14 F8 2E 0F 40 1C 20 70 01 98 CB F7 D8 FC 14 F8 2E 09 04 28 02 D1 84 F8 01 80
9:06:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A5 09 81 80 3C E6 05 20 60 70 39 E6 D4 F8 84 01 01 88 91 B3 21 69 04 F2 6D 16 79 B3 94 F8 2E 20 92 5D 64 2A 07 D3 4D E0 52 1C D2 B2 84 F8 2E 20 03 88 9A 42 05 D2 94 F8 2E 20 55 F8 22 30 19 42 F2 D0 D1 B2 02 88 91 42 19 D3 84 F8 00 90 67 70 84 F8 2E 70 03 98 CB F7 A7 FC 01 98 CB F7 A4 FC D4 F8 7C 01 D0 F8 08 01 90 F8 7C 00 03 28 C9 D0 84 F8 02 80 84 F8 03 80 02 E6 35 E0 22 E0 01 EB 81 02 02 EB
9:06:41 AM
9:06:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A6 09 81 80 41 11 4A 22 84 F8 37 70 02 EB 41 02 82 5A 54 4B 02 F5 7A 72 00 92 04 22 02 EB 41 01 42 18 00 21 D4 F8 7C 01 E6 F7 B4 FD 00 28 A0 68 69 68 05 D0 08 43 A0 60 08 20 60 70 01 98 D9 E6 88 43 F8 E7 94 F8 2E 00 55 F8 20 20 11 42 0B D0 80 5D 64 28 08 D1 40 F2 13 10 1F F0 0E F9 94 F8 2E 10 88 5D 40 1C 88 55 84 F8 00 90 67 70 D4 F8 7C 01 D0 F8 08 01 90 F8 7C 00 03 28 3F F4 53 AE 84 F8 02 80
9:06:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A7 09 81 80 84 F8 03 80 58 E6 00 21 D4 F8 7C 01 E6 F7 F6 FE 07 46 01 98 CB F7 4E FC 94 F8 2E 10 D4 F8 84 21 01 EB 81 03 03 EB 41 13 4A 21 01 EB 43 01 51 5A 01 F5 7A 71 88 42 04 D2 A0 68 69 68 08 42 99 D1 08 E0 94 F8 36 00 31 78 08 43 84 F8 36 00 01 98 CB F7 24 FC 94 F8 36 00 31 78 08 42 08 D0 32 78 A1 68 11 43 A1 60 31 78 88 43 84 F8 36 00 06 E0 0F B1 03 2F E3 D1 A0 68 29 68 88 43 A0 60 94 F8
9:06:42 AM
9:06:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A8 09 81 80 2E 00 40 1C 84 F8 2E 00 44 E1 60 78 DF F8 54 90 50 B3 01 28 D3 D1 00 21 D4 F8 7C 01 E6 F7 AE FE 80 46 01 98 CB F7 06 FC 94 F8 2E 10 01 EB 81 02 09 EB C2 01 49 6A 01 F5 7A 71 88 42 35 D2 A0 68 69 68 08 42 BB D1 39 E0 6D C6 03 00 61 C4 03 00 D0 D8 06 00 2B 43 50 49 4E 3D 25 30 34 75 00 00 93 C3 03 00 18 DC 06 00 FF E7 94 F8 2E 00 07 28 05 D3 42 F2 10 70 60 62 84 F8 00 80 3E E5 00 EB
9:06:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 A9 09 81 80 80 01 09 EB C1 02 00 21 50 6A 00 90 13 6A D4 F8 7C 01 E6 F7 FD FC 00 28 A0 68 69 68 02 D0 08 43 A0 60 EB E6 88 43 A0 60 63 E0 94 F8 36 00 31 78 08 43 84 F8 36 00 01 98 CB F7 B0 FB 94 F8 36 00 31 78 08 42 08 D0 A1 68 2A 68 11 43 A1 60 31 78 88 43 84 F8 36 00 09 E0 B8 F1 00 0F 02 D0 B8 F1 03 0F CB D1 A0 68 29 68 88 43 A0 60 94 F8 2E 00 40 1C 84 F8 2E 00 01 98 CB F7 94 FB 26 E5 04 F1
9:06:43 AM
9:06:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 AA 09 81 80 44 00 05 46 CB F7 96 FB 21 6A 4A F6 C8 72 11 44 88 42 0A D9 28 46 CB F7 81 FB 01 20 08 F0 85 F9 01 98 CB F7 7F FB 07 20 60 70 60 78 08 28 A5 D2 DF E8 00 F0 04 23 4B 56 6E 82 A7 B5 D4 F8 7C 01 E6 F7 2A FC 01 28 03 D0 D4 F8 7C 01 41 78 00 E0 00 21 94 F8 2F 20 B0 79 FB 4B 02 42 4F F4 7A 60 00 90 D4 F8 7C 01 01 D0 F8 A2 00 E0 F9 A2 E6 F7 8F FC 01 98 CB F7 56 FB 80 E6 01 98 CB F7 5A FB
9:06:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 AB 09 81 80 41 F2 88 31 88 42 08 D9 94 F8 36 00 31 78 08 43 84 F8 36 00 01 98 CB F7 41 FB 94 F8 36 00 31 78 08 42 3F F4 D4 AC 31 78 04 F1 34 04 88 43 A0 70 01 98 CB F7 33 FB 20 78 40 1C C0 B2 04 F8 34 09 02 28 9B D9 84 F8 34 70 1F E0 D4 F8 7C 01 D0 F8 08 01 0A F0 EE FD 00 28 E3 D0 84 F8 01 90 8D E4 D4 F8 7C 01 D0 F8 08 11 8A 79 07 2A 01 D0 00 2A F5 D1 09 79 49 B9 00 21 E6 F7 CC FB 94 F8 2F 00
9:06:44 AM
9:06:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 AC 09 81 80 71 79 08 42 01 D0 04 20 3C E6 84 F8 01 B0 75 E4 28 46 CB F7 0F FB 21 6A 88 42 E0 D9 4F F4 FA 50 00 90 D4 F8 7C 01 CD 4B CD A2 41 78 E6 F7 30 FC 01 98 CB F7 F7 FA 24 E6 01 98 CB F7 FB FA 42 F2 28 31 88 42 08 D9 94 F8 36 00 31 78 08 43 84 F8 36 00 01 98 CB F7 E2 FA 94 F8 36 00 31 78 08 42 BD D0 31 78 04 F1 34 04 88 43 A0 70 01 98 CB F7 D5 FA 20 78 40 1C C0 B2 04 F8 34 09 02 28 C2 D9
9:06:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 AD 09 81 80 A0 E7 28 46 CB F7 D6 FA 21 6A 88 42 A7 D9 01 20 08 F0 CB F8 01 98 CB F7 C5 FA 07 20 F2 E5 01 98 CB F7 C8 FA C8 28 9A D9 00 20 08 F0 BE F8 08 20 60 70 94 F8 39 00 80 07 91 D4 F3 20 1E F0 5B FF 94 F8 39 00 C1 07 8A D0 40 F0 02 00 84 F8 39 00 14 E4 2D E9 F8 4F 04 46 FF F7 DB FA 20 46 00 F0 D2 F9 20 46 FF F7 51 FB A1 78 01 27 00 26 9F 4D 4F F0 03 0A 4F F4 FA 69 04 F1 5C 08 05 29 4F D2
9:06:45 AM
9:06:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 AE 09 81 80 DF E8 01 F0 03 18 62 8A AC 00 94 F8 36 00 69 78 08 42 45 D0 CD F8 00 90 00 23 95 A2 01 21 D4 F8 7C 01 E6 F7 B5 FB 00 28 3A D1 14 F8 36 0F 69 78 88 43 AD E0 E0 78 4E F6 60 25 05 28 30 D2 DF E8 00 F0 2F 03 0E 1D 31 00 00 94 8B 4B 8B 4A 01 21 D4 F8 7C 01 E6 F7 EC FA 02 20 E0 70 B9 E0 D4 F8 7C 01 00 22 01 21 D0 F8 08 01 0A F0 4E FC 90 B1 84 F8 03 A0 0F E0 A7 70 E6 70 B4 E0 D4 F8 7C 01
9:06:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 AF 09 81 80 D0 F8 08 01 90 F8 7C 00 03 28 04 D1 04 20 E0 70 40 46 CB F7 47 FA 40 46 CB F7 4C FA A8 42 EA D8 BD E8 F8 8F 40 46 CB F7 45 FA FA 28 F8 D9 CD F8 00 90 00 23 6E A2 01 21 D4 F8 7C 01 E6 F7 68 FB 40 46 CB F7 2B FA 4D E0 01 21 D4 F8 7C 01 E6 F7 D5 FC 10 B1 02 28 02 D0 06 E0 A6 70 01 E0 84 F8 02 A0 40 46 CB F7 1A FA 94 F8 36 00 69 78 08 42 03 D0 69 78 88 43 84 F8 36 00 40 46 CB F7 1A FA
9:06:46 AM
9:06:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B0 09 81 80 01 46 A0 6A 06 22 B0 FB F2 F2 10 44 81 42 C7 D9 40 46 CB F7 03 FA AE E7 94 F8 38 00 29 78 08 42 06 D0 F4 20 1E F0 A7 FE 94 F8 38 00 29 78 08 E0 69 78 08 42 08 D0 F5 20 1E F0 9D FE 94 F8 38 00 69 78 88 43 84 F8 38 00 01 21 D4 F8 7C 01 E6 F7 95 FC 08 B1 01 28 A3 D1 A6 70 1E E0 E0 78 18 B1 01 28 9D D1 A6 70 9B E7 01 21 D4 F8 7C 01 E6 F7 85 FC 00 28 40 46 0D D0 CB F7 DC F9 B0 F5 7A 5F
9:06:47 AM
9:06:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B1 09 81 80 10 D3 40 46 CB F7 CA F9 14 F8 36 0F 69 78 08 43 20 70 85 E7 CB F7 C2 F9 E7 70 BD E8 F8 4F F6 20 1E F0 69 BE 94 F8 36 00 69 78 08 42 DB D0 69 78 88 43 84 F8 36 00 94 F8 33 00 02 28 0E D2 40 1C 84 F8 33 00 43 F6 98 22 01 21 D4 F8 7C 01 E6 F7 F7 FB 40 46 BD E8 F8 4F CB F7 A4 B9 84 F8 33 60 40 46 CB F7 9B F9 20 46 BD E8 F8 4F 00 21 FD F7 7D BE 00 29 03 D0 D0 F8 7C 01 E6 F7 64 BC 70 47
9:06:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B2 09 81 80 70 B5 04 46 64 30 05 46 CB F7 94 F9 41 F2 70 71 88 42 0D D9 00 20 04 F8 30 0F A0 70 28 46 CB F7 7D F9 12 49 20 7A 89 78 08 43 20 72 A4 F1 30 04 04 F1 6C 00 A1 68 09 B9 61 69 09 B3 B4 F8 6C 10 01 BB CB F7 6F F9 1D E0 BB C6 03 00 2B 43 46 55 4E 3D 30 00 2B 43 46 55 4E 3D 34 00 DD C6 03 00 2B 43 46 55 4E 3D 31 2C 31 00 00 00 68 C1 01 00 45 30 56 31 00 00 00 00 81 C6 03 00 61 C4 03 00
9:06:48 AM
9:06:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B3 09 81 80 CB F7 4C F9 20 46 FF F7 5D FA 20 46 BD E8 70 40 9F E6 2D E9 F0 41 05 46 80 8D 0C 46 40 F4 00 70 16 46 A8 85 1F 46 01 22 4D A1 20 46 C3 F7 CC FB 20 B9 A8 8D 64 1C 20 F4 00 70 A8 85 02 22 49 A1 20 46 C3 F7 C1 FB 20 B9 A8 8D A4 1C 20 F4 00 70 A8 85 20 46 C3 F7 64 FD 10 F0 FF 00 04 D0 39 78 81 42 01 D3 14 28 02 D9 00 20 BD E8 F0 81 00 25 3D 70 29 46 0C E0 23 78 62 78 02 B9 46 22 32 70
9:06:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B4 09 81 80 73 70 3A 78 B6 1C 92 1C A4 1C 89 1C 3A 70 C9 B2 81 42 F0 D3 35 70 01 20 E7 E7 10 B5 04 46 98 B0 94 30 C3 F7 3D FD D4 F8 74 11 C0 F3 4F 00 89 8A A4 F8 40 10 A2 8D 52 05 02 D5 89 1D A4 F8 40 10 89 B2 8C 29 02 D9 8C 21 A4 F8 40 10 89 B2 08 30 08 44 82 B2 24 A1 01 A8 DB F7 4C F9 4F F4 7A 70 00 90 24 4B 01 AA 01 21 D4 F8 7C 01 E6 F7 10 FA 10 B1 00 20 18 B0 10 BD 01 21 D4 F8 7C 01 E6 F7
9:06:49 AM
9:06:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B5 09 81 80 B9 F9 01 20 F6 E7 38 B5 04 46 90 F8 3A 00 00 28 24 D0 A0 8D C1 07 21 D1 80 06 40 F6 B8 35 0C D4 00 95 15 4B 15 A2 01 21 D4 F8 7C 01 E6 F7 F0 F9 18 B1 A0 8D 40 F0 20 00 A0 85 A0 8D 40 06 0D D5 00 95 10 4B 10 A2 01 21 D4 F8 7C 01 E6 F7 E0 F9 00 28 03 D0 A0 8D 20 F0 40 00 A0 85 38 BD 00 00 2B 00 00 00 30 30 00 00 2B 43 4D 47 53 3D 25 64 00 00 00 00 03 B3 03 00 B5 B6 03 00 2B 43 4D 47
9:06:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B6 09 81 80 4C 3D 30 00 CF B6 03 00 2B 43 4D 47 4C 3D 31 00 0E B5 02 A9 41 F2 7A 12 CD E9 00 21 01 46 00 23 09 20 E4 F7 9C FD 00 28 00 D0 01 20 0E BD 0E B5 02 A9 41 F2 7A 12 CD E9 00 21 01 46 00 23 09 20 E4 F7 CD FD 00 28 00 D0 01 20 0E BD 3E B5 05 46 1B F0 11 FA FE 4C A1 68 81 42 00 D1 FD B1 A0 60 3A 20 02 A9 CD E9 00 01 F9 49 02 46 00 23 18 31 09 20 E4 F7 74 FD 00 28 12 D0 F5 48 E1 78 18 30
9:06:50 AM
9:06:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B7 09 81 80 90 F8 34 00 88 42 0A D0 08 B1 02 28 04 D1 00 21 A1 70 61 70 E1 70 A1 80 01 28 00 D1 E0 70 01 20 3E BD 10 B5 41 F2 7A 11 C3 F7 BE FB 01 20 10 BD F0 B5 97 B0 0E 46 14 46 1D 46 0F AB 0E AA 10 A9 1C 9F EA F7 FA FB 00 28 52 D0 0D AB 0C AA 13 A9 30 46 EA F7 F2 FB 00 28 7A D0 6A 46 10 A9 38 46 D1 F7 9C FE 00 28 73 D0 03 AA 13 A9 38 46 D1 F7 95 FE E8 B3 9D F8 3C 00 8D F8 23 00 BD F8 38 00
9:06:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B8 09 81 80 01 12 8D F8 21 10 8D F8 22 00 BD F8 00 00 01 0A 8D F8 18 10 8D F8 19 00 9D F8 02 00 8D F8 1A 00 9D F8 03 00 8D F8 1B 00 9D F8 04 00 8D F8 1C 00 9D F8 05 00 8D F8 1D 00 9D F8 06 00 8D F8 1E 00 9D F8 07 00 00 21 8D F8 1F 00 8D F8 20 10 9D F8 34 00 8D F8 2F 00 BD F8 30 00 02 12 8D F8 2D 20 8D F8 2E 00 BD F8 0C 00 02 0A 8D F8 24 20 00 E0 2E E0 8D F8 25 00 9D F8 0E 00 8D F8 26 00 9D F8
9:06:51 AM
9:06:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 B9 09 81 80 0F 00 8D F8 27 00 9D F8 10 00 8D F8 28 00 9D F8 11 00 8D F8 29 00 9D F8 12 00 8D F8 2A 00 9D F8 13 00 8D F8 2B 00 8D F8 2C 10 10 A9 06 A8 EA F7 E8 FB 13 A9 09 A8 EA F7 E4 FB 21 46 10 A8 CA F7 4D FE 29 46 13 A8 CA F7 49 FE 01 20 17 B0 F0 BD 00 20 FB E7 2D E9 F0 43 89 B0 91 46 DD E9 10 58 06 46 0F 46 1C 46 07 AA 01 A9 48 46 CA F7 52 FF 01 A8 00 90 05 AB 04 AA 39 46 30 46 FF F7 58 FF
9:06:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 BA 09 81 80 00 28 08 D0 06 A9 48 46 CA F7 28 FE DD E9 04 01 88 42 03 D3 00 20 09 B0 BD E8 F0 83 06 9A 82 42 06 D3 8A 42 04 D8 28 60 01 20 C8 F8 00 10 00 E0 00 20 20 80 01 20 EE E7 F0 B5 89 B0 17 46 05 46 0E 46 1C 46 07 AA 01 A9 38 46 CA F7 23 FF 01 A8 00 90 05 AB 04 AA 31 46 28 46 FF F7 29 FF 00 28 08 D0 06 A9 38 46 CA F7 F9 FD DD E9 04 01 88 42 02 D3 00 20 09 B0 F0 BD 06 9A 82 42 01 D3 8A 42
9:06:52 AM
9:06:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 BB 09 81 80 01 D9 01 20 00 E0 00 20 20 80 01 20 F2 E7 1F B5 6F 4C 20 46 A2 88 D0 E9 03 10 01 2A 01 D1 81 42 1E D1 00 29 1C D0 00 28 1A D0 68 46 CA F7 56 FE 03 A9 68 46 CA F7 D2 FD 60 69 03 99 08 1A 00 D5 40 42 61 61 03 28 0B DD E0 68 88 42 02 D8 20 69 88 42 05 D2 01 20 A0 80 00 20 E0 70 A0 70 60 70 1F BD 2D E9 F1 4F 88 B0 02 A8 CA F7 37 FE 58 48 18 30 46 88 66 B1 56 4D 01 27 4F F0 00 04 A9 88
9:06:53 AM
9:06:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 BC 09 81 80 51 B1 A0 46 81 46 0D F1 1C 0A 0D F1 18 0B 33 E0 00 20 09 B0 BD E8 F0 8F 80 46 12 E0 04 EB 44 01 08 EB C1 00 00 F1 10 01 00 1D 05 AB 02 AA FF F7 83 FF 08 B9 AD F8 14 70 BD F8 14 00 F0 B1 64 1C A4 B2 B4 42 EA D3 AF 80 18 E0 00 BF 04 EB 44 01 09 EB C1 00 CD E9 00 BA 00 F1 10 01 00 1D 05 AB 02 AA FF F7 37 FF 08 B9 AD F8 14 80 BD F8 14 00 01 28 05 D0 64 1C A4 B2 B4 42 E7 D3 01 20 C8 E7
9:06:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 BD 09 81 80 A5 F8 04 80 06 98 E8 60 07 98 28 61 08 98 07 80 F4 E7 2D E9 F0 47 2E 4D 01 27 18 35 88 B0 6E 88 1E B3 02 A8 CA F7 DA FD 00 24 A0 46 0D F1 1C 09 0D F1 18 0A 17 E0 00 BF AD F8 14 80 04 EB 44 00 05 EB C0 00 CD E9 00 A9 00 F1 10 01 00 1D 05 AB 02 AA FF F7 FF FE 20 B1 BD F8 14 00 01 28 08 D0 02 27 64 1C A4 B2 B4 42 E6 D3 38 46 08 B0 BD E8 F0 87 04 20 FA E7 2D E9 FF 4F A7 B0 06 46 91 46
9:06:54 AM
9:06:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 BE 09 81 80 4F F0 00 0B 05 88 1C 46 DD F8 D0 A0 81 E0 25 A9 8A 20 CD E9 00 01 04 EB 84 00 00 EB 84 11 3A 20 00 EB 41 00 83 B2 8A 22 02 A9 09 20 E4 F7 97 FB 00 28 74 D0 9D F8 0A 00 2A 28 0B D0 BD F8 08 80 00 20 01 46 A8 F1 01 07 0D F1 08 0C 51 E0 00 00 8C 5B 00 10 BD F8 08 00 01 22 00 27 01 28 5B D0 0D F1 09 01 41 5C 2A 29 11 D0 A5 EB 00 01 01 F1 01 01 8B B2 A5 EB 00 01 39 44 49 1C 4C D4 A0 EB
9:06:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 BF 09 81 80 07 0E 00 21 AE F1 01 00 0D F1 08 08 14 E0 00 23 01 27 EF E7 03 EB 01 0C 08 EB 02 07 B4 44 BF 78 9C F8 02 C0 67 45 01 D0 3F 2F 2E D1 90 42 06 DD 52 1C 49 1C 92 B2 89 B2 88 42 EB DC 1B E0 AE F1 02 00 88 42 2D D0 20 E0 0C EB 00 02 73 18 92 78 9B 78 9A 42 07 D0 3F 2A 05 D0 0C EB 00 01 89 78 2A 29 0F D0 11 E0 87 42 09 DD 40 1C 49 1C 80 B2 89 B2 A9 42 E8 D3 BB F1 01 0F 12 D0 07 E0 A8 45
9:06:55 AM
9:06:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C0 09 81 80 0F D0 02 E0 40 1C 80 45 0B D0 4F F0 00 0B 64 1C A4 B2 4C 45 FF F4 7B AF AA F8 00 40 00 20 2B B0 F8 E6 AA F8 00 40 28 98 9D F8 90 10 01 70 01 20 F5 E7 10 B5 00 78 18 B1 01 28 0B D0 00 20 10 BD F3 F7 AB F9 20 B9 00 22 01 21 02 20 F3 F7 D7 F9 01 20 10 BD 00 22 01 21 10 46 F7 E7 70 B5 0C 46 49 1C A6 B0 15 46 86 29 1E D8 01 46 62 1C 0D F1 06 00 C3 F7 95 F8 AD F8 04 40 00 23 24 AE F8 4C
9:06:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C1 09 81 80 0E E0 23 A9 01 A8 00 96 FF F7 35 FF 01 28 0B D1 9D F8 8C 00 01 28 0A D0 BD F8 90 00 40 1C 83 B2 22 8F 50 1E 98 42 EC DA 00 20 26 B0 70 BD 25 B9 00 22 01 21 10 46 F3 F7 A2 F9 01 20 F5 E7 2D E9 FE 43 80 46 00 20 AD F8 08 00 03 46 B8 F8 00 00 00 28 43 D0 E2 4C 22 8F 22 B3 02 AE 01 A9 40 46 00 96 FF F7 08 FF 01 28 37 D1 9D F8 04 00 01 27 01 28 01 D0 D0 B1 30 E0 BD F8 08 00 40 1C 85 B2
9:06:56 AM
9:06:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C2 09 81 80 0C E0 2B 46 01 A9 40 46 00 96 FF F7 F4 FE 01 28 02 D1 9D F8 04 00 30 B1 6D 1C AD B2 22 8F 50 1E A8 42 EE DA 19 E0 8D F8 04 70 19 E0 BD F8 08 00 40 1C 85 B2 0D E0 2B 46 01 A9 40 46 00 96 FF F7 DA FE 01 28 03 D1 9D F8 04 00 01 28 08 D0 6D 1C AD B2 22 8F 50 1E A8 42 ED DA 01 20 BD E8 FE 83 01 A8 FF F7 66 FF F8 E7 2D E9 FE 4F 4F F0 00 06 83 46 0F 00 AD F8 08 60 B0 46 62 D0 BB F8 00 00
9:06:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C3 09 81 80 00 28 30 D0 DF F8 D8 92 A9 F1 18 04 B9 F8 38 20 F2 B3 0D F1 08 0A 00 23 01 A9 58 46 CD F8 00 A0 FF F7 A9 FE 01 28 22 D1 9D F8 04 00 01 28 1E D1 BD F8 08 00 40 1C 85 B2 0D E0 2B 46 01 A9 58 46 CD F8 00 A0 FF F7 97 FE 01 28 02 D1 9D F8 04 00 58 B1 6D 1C AD B2 B9 F8 38 20 50 1E A8 42 EC DA 01 A8 FF F7 26 FF BD E8 FE 8F 4F F0 01 08 B9 F8 38 20 4D 46 62 B1 00 23 01 A9 58 46 CD F8 00 A0
9:06:57 AM
9:06:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C4 09 81 80 FF F7 79 FE 01 28 1D D0 28 78 01 28 14 D1 00 E0 18 E0 E0 78 01 28 0F D1 95 F8 35 00 60 B1 A1 78 49 1C C9 B2 A1 70 81 42 06 D3 F8 20 1E F0 A3 F9 E6 70 A6 80 A6 70 66 70 00 22 01 21 03 20 F3 F7 DE F8 4E E0 99 F8 37 00 99 F8 36 10 4D 46 88 42 0A D0 FF F7 1E FE 01 28 1C D0 02 28 0C D0 04 28 12 D1 95 F8 36 00 10 B1 B8 42 3A D8 0C E0 95 F8 37 00 07 E0 66 70 34 E0 95 F8 37 00 00 28 F3 D1
9:06:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C5 09 81 80 95 F8 36 00 00 28 F5 D1 28 78 01 28 05 D0 02 28 03 D0 28 E0 28 78 78 B3 EC E7 95 F8 37 10 95 F8 36 20 91 42 1F D0 E0 78 01 28 1A D1 95 F8 35 00 A8 B1 29 8F 69 B1 A1 78 49 1C C9 B2 A1 70 81 42 21 D3 F8 20 1E F0 57 F9 E6 70 A6 80 A6 70 66 70 19 E0 00 22 01 21 02 20 F3 F7 91 F8 20 E0 A6 70 0E E0 00 20 7F E7 38 B1 95 F8 37 10 95 F8 36 20 91 42 0C D1 03 28 0A D0 A6 70 01 20 E0 70 A6 80
9:06:58 AM
9:06:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C6 09 81 80 28 8F 00 28 E5 D0 B8 F1 01 0F 02 D0 03 E0 A6 70 E7 E7 8D F8 04 60 01 A8 FF F7 8B FE 00 28 E1 D0 01 20 60 E7 4E 49 01 20 18 39 C8 80 70 47 0E B5 4B 48 00 21 18 38 00 23 81 80 41 70 81 70 C1 70 47 49 02 20 81 F8 34 00 3A 20 02 A9 CD E9 00 01 02 46 43 49 09 20 E4 F7 C2 F9 00 28 00 D0 01 20 0E BD 2D E9 F0 41 AC B0 00 20 FF F7 EF FB 3C 4F 4F F0 00 08 AD F8 A8 80 A7 F1 18 04 97 F8 34 60
9:06:59 AM
9:06:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C7 09 81 80 20 78 01 25 08 B1 01 28 01 D0 25 70 4C E0 E0 78 18 B1 01 28 16 D1 01 26 14 E0 02 2E 00 D0 00 26 AD F8 A4 80 29 A8 FF F7 1C FD 30 B1 BD F8 A4 00 01 28 02 D1 84 F8 02 80 E5 70 38 78 10 B9 84 F8 02 80 E5 70 FF F7 E3 FC A4 F8 06 80 45 46 8D F8 90 80 2A AA 24 A9 25 A8 F2 F7 EE FF 18 B3 61 78 9D F8 90 00 0D F1 08 08 81 42 33 D2 25 A8 C3 F7 57 F8 AD F8 08 00 10 22 25 A9 08 F1 02 00 C2 F7
9:06:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C8 09 81 80 CF FE F2 F7 85 FF 28 B1 00 22 01 21 03 20 F2 F7 F6 FF 08 E0 9D F8 90 10 02 A8 FF F7 A5 FE B0 B1 E0 88 00 28 F0 D0 65 70 97 F8 34 00 B0 42 0B D0 3A 20 87 F8 34 60 2B A9 CD E9 00 01 02 46 00 23 07 49 09 20 E4 F7 4B F9 2C B0 BD E8 F0 81 9D F8 90 00 03 E0 BD F8 A8 10 01 29 03 D0 60 70 E3 E7 A4 5B 00 10 25 A8 C3 F7 1B F8 AD F8 08 00 10 22 25 A9 08 F1 02 00 C2 F7 93 FE 9D F8 90 10 02 A8
9:07:00 AM
9:07:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 C9 09 81 80 FF F7 1D FE F2 F7 93 FF CE E7 1F B5 01 20 FF F7 5D FB 00 28 1E D0 1A F0 6E FD 10 4C 04 F1 18 01 A0 60 00 20 60 70 20 70 A0 70 E0 60 20 61 60 61 91 F8 34 10 02 29 0E D0 69 B1 01 20 E0 70 A0 80 68 46 CA F7 CB FA 03 A9 68 46 CA F7 47 FA 03 98 E0 60 20 61 1F BD E0 70 A0 80 1F BD 8C 5B 00 10 81 70 00 23 C0 E9 01 32 C3 70 C0 E9 03 32 08 46 70 47 10 B5 00 22 70 B1 C3 68 00 21 5B 1C C3 60
9:07:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 CA 09 81 80 04 69 A3 42 05 D3 C1 70 C1 60 41 68 49 1C 41 60 01 E0 41 70 01 22 10 46 10 BD 16 22 0A 70 00 78 08 71 01 20 70 47 2D E9 F0 41 05 46 0E 46 17 46 18 21 10 46 CA F7 B5 FC 04 00 11 D0 02 20 30 70 B0 80 B4 60 2A 88 3B 46 A9 1C 20 46 EA F7 73 F8 00 28 05 D0 16 20 20 73 95 F8 88 00 20 74 01 20 BD E8 F0 81 2D E9 F0 5F AD F5 8C 5D 90 F8 88 80 01 27 04 46 80 F8 89 70 EA 46 0D 46 93 46 00 26
9:07:01 AM
9:07:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 CB 09 81 80 50 46 FF F7 C5 FA 00 28 75 D0 41 46 16 20 4F F0 00 08 08 29 70 D2 DF E8 01 F0 85 A7 04 08 3F 43 49 66 28 70 9D F8 00 00 3E E0 BD F8 02 00 02 28 00 D3 02 20 94 F8 8A 10 C0 B2 11 B1 01 29 21 D1 0B E0 2F 70 A8 80 04 F1 88 04 C5 F8 08 80 A7 70 C4 E9 01 80 A4 F1 88 04 13 E0 D4 E9 23 01 88 42 4A D2 00 EB 40 01 0A EB C1 01 09 1D 5A 46 28 46 EA F7 32 F9 00 28 57 D0 D4 F8 8C 00 40 1C C4 F8
9:07:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 CC 09 81 80 8C 00 01 26 D4 E9 23 01 88 42 02 D3 84 F8 89 70 49 E0 84 F8 89 80 46 E0 28 70 9D F8 34 00 03 E0 11 20 28 70 9D F8 35 00 28 71 3B E0 08 21 58 46 CA F7 37 FC 04 00 57 D0 02 20 28 70 A8 80 02 46 5B 46 0D F1 36 01 20 46 AC 60 E9 F7 7F FF 00 28 2A D0 5B 46 02 22 0D F1 37 01 04 F1 0C 00 E9 F7 75 FF 06 46 1F E0 94 F8 8A 10 04 F1 88 09 21 B1 01 29 18 D1 21 E0 17 E0 36 E0 BD F8 38 00 20 28
9:07:02 AM
9:07:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 CD 09 81 80 00 D3 20 20 C6 B2 C4 F8 90 60 2F 70 AE 80 47 46 32 46 01 21 48 46 C5 F8 08 80 FF F7 21 FF 3E B1 84 F8 89 70 01 26 30 46 0D F5 8C 5D BD E8 F0 9F 14 F8 89 0F 40 1C 20 70 F4 E7 04 F1 94 04 D4 E9 00 01 88 42 10 D2 00 EB 80 01 01 EB 80 11 0A EB 41 00 3A 30 5A 46 29 46 FF F7 25 FF 00 28 E3 D0 48 46 FF F7 06 FF DD E7 00 20 DD E7 2D E9 F0 47 AD F5 8C 5D 04 46 90 F8 88 50 01 20 84 F8 89 00
9:07:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 CE 09 81 80 E8 46 40 46 FF F7 04 FA 00 28 6E D0 AD 1E 00 27 4F F6 FF 76 04 F1 66 09 06 2D 67 D2 DF E8 05 F0 03 0C 51 5C 67 73 94 F8 B8 00 09 28 5E D1 94 F8 BC 00 8D F8 00 00 BF E0 B4 F8 6E 00 B8 B1 94 F8 B8 00 14 28 52 D1 48 46 EA F7 34 FF 05 46 B0 42 4C D0 48 46 EA F7 16 FF C4 F8 8C 00 B0 42 45 D0 02 2D 00 D3 02 25 86 B2 02 2E 7F D2 01 E0 00 25 2E 46 BD F8 02 00 A8 42 01 D0 AD F8 02 50 48 46
9:07:03 AM
9:07:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 CF 09 81 80 EA F7 F5 FE 10 B1 01 28 70 D1 0A E0 AD B1 06 EB 46 01 08 EB C1 00 04 F1 BC 04 00 F1 04 00 0E CC 09 E0 55 B1 06 EB 46 01 04 F1 BC 04 08 EB C1 00 0E CC 00 F1 10 00 0E C0 7E E0 01 97 AD F8 02 70 7A E0 94 F8 BC 00 02 28 50 D8 94 F8 B8 10 09 29 4C D1 8D F8 34 00 6F E0 94 F8 B8 00 05 28 45 D1 94 F8 BC 00 8D F8 35 00 66 E0 40 E0 3E E0 94 F8 B8 00 2F 28 3A D1 14 F8 BC 0F 8D F8 36 00 60 78
9:07:04 AM
9:07:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D0 09 81 80 8D F8 37 00 58 E0 B4 F8 6E 00 F0 B1 94 F8 B8 00 16 28 04 D0 09 28 29 D1 BD F8 38 00 09 E0 48 46 EA F7 B0 FE C4 F8 8C 00 B0 42 1F D0 48 46 EA F7 C1 FE B0 42 1A D0 20 28 00 D3 20 20 05 46 D4 F8 8C 00 86 B2 20 2E 11 D2 01 E0 00 25 2E 46 BD F8 38 00 A8 42 01 D0 AD F8 38 50 48 46 EA F7 87 FE 01 00 0D F1 3A 00 06 D0 01 29 12 D0 00 20 0D F5 8C 5D BD E8 F0 87 D5 B1 06 EB 86 00 00 EB 86 11
9:07:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D1 09 81 80 08 EB 41 00 3A 30 88 22 04 F1 BC 01 C2 F7 88 FC 12 E0 65 B1 94 F8 BC 00 02 28 0D D2 06 EB 86 01 01 EB 86 12 08 EB 42 01 81 F8 C2 00 04 E0 8A 21 C2 F7 3A FD AD F8 38 70 40 46 FF F7 38 F9 00 28 D5 D0 01 20 D3 E7 10 B5 AD F5 8C 5D 6C 46 20 46 FF F7 67 F9 00 28 02 D0 20 46 FF F7 28 F9 0D F5 8C 5D 10 BD 02 7B 8A 42 00 D0 01 73 70 47 0A 28 03 D2 F7 49 51 F8 20 00 70 47 4F F4 E1 30 70 47
9:07:05 AM
9:07:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D2 09 81 80 01 68 4A 78 02 75 8A 78 42 75 8A 88 C2 82 C9 88 01 83 70 47 02 78 CA 70 42 78 8A 70 82 78 4A 70 C0 78 08 70 70 47 03 B5 9D F8 07 10 01 70 9D F8 06 10 41 70 9D F8 05 10 81 70 9D F8 04 10 C1 70 0C BD 02 78 4A 70 40 78 08 70 70 47 03 B5 9D F8 05 10 01 70 9D F8 04 10 41 70 0C BD 10 B5 0C 46 03 46 11 46 01 2C 06 D0 02 2C 07 D0 04 2C 0E D0 00 20 10 60 10 BD 00 78 10 60 0A E0 1A 78 62 F3
9:07:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D3 09 81 80 0F 20 5A 78 62 F3 07 00 80 B2 08 60 01 E0 FF F7 C1 FF 20 46 10 BD 30 B5 0C 46 05 46 11 46 FF 2A 01 D8 01 20 05 E0 B1 F5 80 3F 01 D2 02 20 00 E0 04 20 13 B1 84 42 00 D3 04 46 01 2C 05 D0 02 2C 05 D0 04 2C 08 D0 00 20 30 BD 2A 70 07 E0 91 B2 28 46 FF F7 BB FF 02 E0 28 46 FF F7 A4 FF 20 46 30 BD 30 B5 04 46 01 23 05 E0 04 2B 0F D8 5B 1C 49 1E DB B2 89 B2 14 F8 01 5B ED 07 01 D1 00 29
9:07:06 AM
9:07:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D4 09 81 80 F3 D1 01 2B 05 D0 02 2B 07 D0 04 2B 0C D0 00 20 30 BD 01 78 49 08 91 70 12 E0 01 78 49 08 91 70 41 78 49 08 D1 70 0B E0 01 78 45 78 C9 01 01 EB 55 01 51 80 81 78 C5 78 C9 01 01 EB 55 01 91 80 20 1A 13 70 80 B2 30 BD 10 B5 14 78 01 23 01 2C 04 D0 02 2C 09 D0 04 2C 24 D1 11 E0 11 B3 91 78 03 EB 41 01 01 70 01 20 10 BD 02 29 1A D3 91 78 49 00 01 70 D1 78 03 EB 41 01 41 70 02 20 10 BD
9:07:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D5 09 81 80 04 29 0F D3 51 88 C9 09 01 70 91 78 49 00 41 70 D1 78 C9 09 81 70 D1 78 49 00 41 F0 01 01 C1 70 04 20 10 BD 00 20 10 BD 08 22 0A 70 1F 22 4A 70 02 68 C1 F8 02 20 80 88 C8 80 70 47 02 78 0B 78 9A 42 0F D1 01 2A 0D D0 02 2A 02 D0 04 2A 09 D1 02 E0 C0 78 C9 78 01 E0 80 88 89 88 88 42 01 D1 01 20 70 47 00 20 70 47 0A 78 01 2A 14 D1 02 78 02 2A 11 D1 89 78 80 78 02 29 08 D0 10 29 06 D0
9:07:07 AM
9:07:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D6 09 81 80 01 29 04 D0 66 29 02 D0 68 29 03 D0 04 E0 01 28 04 D0 01 E0 69 28 01 D0 00 20 70 47 01 20 70 47 70 B5 00 23 0B 80 13 80 05 78 01 23 02 24 01 2D 0F D0 02 2D 15 D0 04 2D 0A D1 45 88 43 F6 FF 76 FD B1 B5 42 00 D1 0C 80 80 88 C0 B1 B0 42 14 D0 70 BD 80 78 18 B1 7F 28 FA D1 0C 80 70 BD 0B 80 70 BD 85 78 15 B1 7F 2D 02 D0 02 E0 0B 80 00 E0 0C 80 C0 78 18 B1 7F 28 F2 D1 14 80 70 BD 13 80
9:07:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D7 09 81 80 70 BD 0B 80 E0 E7 7C B5 14 46 06 46 0D 46 01 AA 69 46 20 46 FF F7 C4 FF BD F9 00 00 BD F9 04 10 08 43 0C D1 01 AA 69 46 28 46 FF F7 B9 FF BD F9 00 10 BD F9 04 00 01 43 03 D0 02 28 0D D0 00 20 7C BD 29 46 30 46 FF F7 79 FF 00 28 F8 D0 21 46 28 46 FF F7 89 FF 00 28 F2 D0 01 20 7C BD 70 B5 00 25 04 46 80 F8 3C 50 D0 F8 90 00 20 B1 09 B1 E1 F7 E2 FD C4 F8 90 50 04 F1 5C 00 BD E8 70 40
9:07:08 AM
9:07:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D8 09 81 80 CA F7 0C B8 70 B5 85 68 06 46 0C 46 28 78 08 70 68 78 C8 70 A8 78 88 70 ED 1C 0A 1D 04 21 28 46 FF F7 DF FE 00 28 30 D0 05 44 04 F1 0A 02 04 21 28 46 FF F7 D6 FE 00 28 27 D0 28 44 01 78 21 74 41 78 E1 74 81 78 A1 74 B1 68 C0 1C 41 1A 8A B2 61 88 93 1C C1 F3 0A 01 99 42 0B D3 89 1A 49 1E 89 B2 A1 82 A0 61 08 44 01 78 61 77 41 78 80 1C 21 77 07 E0 00 20 A0 82 A0 61 60 77 20 77 B0 68
9:07:09 AM
9:07:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 D9 09 81 80 49 1C 08 44 00 78 A0 77 01 20 70 BD C1 07 17 D0 00 F0 0F 01 01 29 15 D0 05 29 15 D0 00 F0 EF 00 83 28 13 D0 43 28 15 D0 63 28 15 D0 0F 28 15 D0 87 28 15 D0 03 28 15 D0 AF 28 15 D0 00 20 70 47 01 20 70 47 02 20 70 47 03 20 70 47 04 20 70 47 30 DD 06 00 05 20 FA E7 06 20 F8 E7 07 20 F6 E7 08 20 F4 E7 09 20 F2 E7 0A 20 F0 E7 00 7C CD E7 2D E9 F0 41 00 24 06 46 4F EA 04 07 06 EB 84 05
9:07:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 DA 09 81 80 D5 F8 98 00 18 B1 E1 F7 57 FD C5 F8 98 70 64 1C E4 B2 08 2C F2 D3 01 20 BD E8 F0 81 2D E9 F0 41 04 46 08 78 21 7C 40 1A 08 30 C1 17 00 EB 51 71 21 F0 07 01 40 1A 00 25 C6 B2 2F 46 13 E0 20 7C 04 EB 80 00 D0 F8 98 00 30 B1 E1 F7 35 FD 20 7C 04 EB 80 00 C0 F8 98 70 20 7C 40 1C 00 F0 07 00 6D 1C 20 74 ED B2 B5 42 E9 D3 01 20 D4 E7 82 42 06 D9 88 42 07 D9 01 E0 01 20 A8 E7 00 20 A6 E7
9:07:10 AM
9:07:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 DB 09 81 80 04 D2 88 42 F8 D9 91 42 F8 D8 F5 E7 91 42 F5 D1 F2 E7 37 B5 03 46 00 7C 9D F8 04 10 14 46 88 42 01 D1 01 20 3E BD 9A 7B FF F7 E1 FF 00 28 F9 D0 22 46 01 A9 18 46 FF F7 B1 FF F2 E7 42 7C 8A 42 03 D0 C2 7B 8A 42 02 D1 41 74 01 20 7F E7 00 20 7D E7 2D E9 F8 41 5F EA 00 0C 4F F0 01 00 90 60 15 46 50 60 4F F0 9A 02 6A 80 2A 80 0D D0 61 B1 9C F8 00 10 0C F1 01 04 81 29 04 D1 14 F8 01 0B
9:07:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 DC 09 81 80 80 28 04 D0 02 20 BD E8 F8 81 00 20 FB E7 14 F8 01 7B 4F F0 00 08 40 E0 20 78 66 78 A4 1C 05 28 06 D0 06 28 11 D0 07 28 1C D0 08 28 23 D1 28 E0 40 46 01 2E 03 D9 14 F8 01 1B 61 F3 0F 20 14 F8 01 1B 61 F3 07 00 28 80 15 E0 40 46 01 2E 03 D9 14 F8 01 1B 61 F3 0F 20 14 F8 01 1B 61 F3 07 00 68 80 08 E0 6A 46 31 46 20 46 FF F7 77 FD 08 B1 00 98 68 60 34 44 B0 1C 87 42 0C D9 B8 1B 80 1E
9:07:11 AM
9:07:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 DD 09 81 80 0A E0 6A 46 31 46 20 46 FF F7 68 FD 00 28 F1 D0 00 98 A8 60 EE E7 00 20 C7 B2 00 2F BC D1 A4 EB 0C 00 00 B2 AF E7 F0 B5 15 46 15 29 01 D2 00 20 F0 BD 81 21 01 70 80 21 41 70 84 1C 05 22 00 F8 03 2F 2E 88 00 21 40 1C 02 22 01 23 FF 2E 05 D9 02 70 69 78 41 70 80 1C 01 21 01 E0 00 F8 01 3B 2E 78 06 70 C9 1C CE B2 06 21 41 70 69 88 80 1C FF 29 06 D9 02 70 E9 78 41 70 80 1C 76 1C F6 B2
9:07:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 DE 09 81 80 01 E0 00 F8 01 3B A9 78 01 70 07 21 41 70 87 1C F6 1C 00 23 04 21 C0 1C 6A 68 FF F7 3C FD 01 46 38 70 78 18 0E 44 08 21 41 70 87 1C B6 1C 00 23 04 21 C0 1C AA 68 FF F7 2E FD 38 70 30 44 80 1C C0 B2 20 70 C0 1C F0 BD 30 B5 15 46 0D 29 01 DA 00 20 30 BD 81 21 01 70 61 21 41 70 0A 21 81 70 01 21 00 F8 03 1F 44 1C 04 20 04 F8 01 0B 20 46 29 68 FF F7 D8 FC 02 21 21 71 61 71 A0 1D A9 88
9:07:12 AM
9:07:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 DF 09 81 80 FF F7 E4 FC 0D 20 30 BD F0 B5 04 46 00 20 90 80 10 60 20 78 63 1C 15 46 81 28 01 D0 01 20 F0 BD 13 F8 01 0B 61 28 01 D0 02 20 F0 BD 13 F8 01 7B 1D E0 18 78 5E 78 9B 1C 01 28 02 D0 02 28 07 D1 0C E0 04 2E 03 D1 29 46 18 46 FF F7 A3 FC 33 44 B0 1C 87 42 09 D9 B8 1B 80 1E 07 E0 02 2E F6 D1 19 78 69 71 59 78 29 71 F1 E7 00 20 C7 B2 00 2F DF D1 18 1B 00 B2 F0 BD 0E B5 0B 46 11 46 02 7D
9:07:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E0 09 81 80 02 92 42 7D 01 92 C2 8A AD F8 02 20 00 8B AD F8 00 00 6A 46 09 B2 18 46 FF F7 45 FF 0E BD 0C B5 0B 46 11 46 82 68 00 92 00 68 6A 46 09 B2 80 89 AD F8 04 00 18 46 FF F7 87 FF 0C BD 2D E9 F0 43 89 B0 4F F0 7E 08 0C 46 99 46 8D F8 00 80 10 9B D0 F8 46 10 01 91 B0 F8 4A 10 AD F8 08 10 01 6C CD F8 0A 10 B0 F8 44 10 AD F8 0E 10 9D F8 0A 10 00 25 02 29 05 D0 04 29 08 D0 00 20 09 B0 BD E8
9:07:13 AM
9:07:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E1 09 81 80 F0 83 06 68 B6 89 8D F8 0D 60 03 E0 06 68 B6 89 AD F8 0E 60 9D F8 04 60 4F F0 00 0C 0E 44 B1 1D 89 B2 0B 2A 30 D2 DF E8 02 F0 88 6E 0C 88 88 88 1B 46 06 4F 30 00 87 20 8D F8 10 00 D3 B3 97 20 0B E0 01 21 8D F8 10 10 13 B1 11 21 8D F8 10 10 C1 7B 9D F8 10 00 61 F3 47 10 8D F8 10 00 30 E0 63 22 8D F8 10 20 13 B1 73 22 8D F8 10 20 A2 89 A3 68 1A 44 A2 1A 52 1A C6 32 19 44 92 B2 06 91
9:07:14 AM
9:07:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E2 09 81 80 FF F7 7A FF 13 E0 01 25 57 E0 AF 22 8D F8 10 20 13 B1 BF 22 8D F8 10 20 A2 89 A3 68 1A 44 A2 1A 52 1A C6 32 19 44 92 B2 06 91 FF F7 78 FF AD F8 14 00 E8 E7 05 E0 0F 20 8D F8 10 00 0B B1 1F 20 CB E7 AD F8 14 C0 DE E7 03 20 8D F8 10 00 13 B1 13 20 8D F8 10 00 A0 68 06 90 A0 8A AD F8 14 00 E0 7B C0 07 A0 68 A0 EB 04 00 24 D0 18 38 88 42 23 DB A0 68 40 1A A0 60 A0 89 08 44 A0 81 A0 8A
9:07:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E3 09 81 80 08 44 A0 82 BF E7 8D F8 10 C0 13 B1 10 22 8D F8 10 20 C3 7B 9D F8 10 20 63 F3 47 12 8D F8 10 20 83 7B 63 F3 43 02 8D F8 10 20 82 7B 52 1C 02 F0 07 02 82 73 CF E7 10 38 D9 E7 76 1D BD F8 14 00 B7 B2 10 B1 BF 1C 38 44 87 B2 39 46 69 F3 DF 21 41 F4 20 40 AD F8 02 00 8D F8 1E 80 A6 68 9D F8 00 00 01 AA 30 70 9D F8 03 00 70 70 9D F8 02 00 B0 70 06 F1 03 06 4F F0 04 01 30 46 FF F7 24 FC
9:07:15 AM
9:07:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E4 09 81 80 06 44 0D F1 0A 02 04 21 30 46 FF F7 1D FC 06 44 9D F8 10 00 06 F8 01 0B A0 68 4F F6 FF 79 00 F1 01 08 A6 EB 08 00 81 B2 4A 46 40 46 C9 F7 0A FE 80 EA 09 00 AD F8 12 00 9D F8 12 00 30 70 9D F8 13 00 70 70 BD F8 14 00 B6 1C 90 B1 06 44 A6 EB 08 00 81 B2 4A 46 40 46 C9 F7 F4 FD 80 EA 09 00 AD F8 1C 00 9D F8 1C 00 30 70 9D F8 1D 00 70 70 B6 1C 9D F8 1E 00 30 70 BF 1C A7 81 A7 82 28 46
9:07:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E5 09 81 80 FC E6 70 B5 04 46 D0 F8 C8 00 08 B1 05 F0 14 FB E0 69 88 B1 41 68 00 25 E1 61 09 E0 45 60 A1 8C 49 1E A1 84 E1 F7 88 FA E0 69 28 B1 41 68 E1 61 00 29 F3 D1 25 62 F1 E7 04 F1 7C 00 C9 F7 AE FC 01 20 70 BD F8 B5 0E 46 05 46 FF F7 DA FF E1 F7 31 FA 04 00 1E D0 01 20 00 90 00 23 08 22 21 46 28 46 FF F7 AB FE B8 B1 00 20 60 60 28 6A B8 B1 44 60 2C 62 A8 8C 00 F1 01 00 A8 84 30 7C C0 06
9:07:16 AM
9:07:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E6 09 81 80 10 D5 06 21 28 46 FF F7 ED FA 05 F1 74 00 C9 F7 89 FC 0B E0 00 20 F8 BD 20 46 E1 F7 4D FA F9 E7 EC 61 E6 E7 02 21 28 46 FF F7 DC FA 01 20 F8 BD F8 B5 0E 46 05 46 FF F7 A4 FF E1 F7 FB F9 04 00 1E D0 01 20 00 90 00 23 07 22 21 46 28 46 FF F7 75 FE B8 B1 00 20 60 60 28 6A B8 B1 44 60 2C 62 A8 8C 00 F1 01 00 A8 84 30 7C C0 06 10 D5 05 21 28 46 FF F7 B7 FA 05 F1 74 00 C9 F7 53 FC 0B E0
9:07:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E7 09 81 80 00 20 F8 BD 20 46 E1 F7 17 FA F9 E7 EC 61 E6 E7 01 21 28 46 FF F7 A6 FA 01 20 F8 BD 10 B5 04 46 D0 F8 C8 00 08 B1 05 F0 41 FA 20 46 FF F7 A8 FA 01 20 10 BD 70 B5 04 46 00 25 E0 69 50 B1 41 68 E1 61 01 B9 25 62 45 60 A1 8C 49 1E A1 84 E1 F7 F3 F9 F2 E7 04 F1 7C 00 C9 F7 20 FC 01 20 70 BD 10 B5 04 46 D0 F8 BC 00 00 28 05 D0 E1 F7 E4 F9 00 20 C4 F8 BC 00 01 20 10 BD 10 B5 04 46 D0 F8
9:07:17 AM
9:07:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E8 09 81 80 B8 00 00 28 05 D0 E1 F7 D7 F9 00 20 C4 F8 B8 00 01 20 10 BD 10 B5 04 46 FF F7 EF FF 20 46 FF F7 DF FF 20 46 FF F7 64 FC 20 46 FF F7 C3 FF 01 21 20 46 FF F7 57 FA 02 21 D4 F8 CC 00 07 F0 36 F8 01 20 10 BD 10 B5 04 46 FF F7 E4 FF 20 46 FF F7 A5 FF 01 20 10 BD 10 B5 04 46 B0 F9 24 00 18 B1 E1 69 09 B9 21 6A B1 B1 B4 F9 26 10 88 42 15 DB 04 F1 7C 00 C9 F7 DE FB D4 F8 8C 10 81 42 01 D2
9:07:18 AM
9:07:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 E9 09 81 80 C4 F8 8C 00 4E F6 60 21 88 42 02 D9 20 46 FF F7 D9 FF 00 20 10 BD 00 20 A0 84 F7 E7 01 20 10 BD 2D E9 FF 41 00 26 C6 73 86 73 06 74 0F 46 04 46 46 74 FF F7 E6 FE 00 28 65 D0 E1 F7 3B F9 05 00 60 D0 B7 F9 14 10 01 AA B8 69 FF F7 82 FC 21 68 02 9A 48 78 90 42 00 D3 10 46 C0 B2 20 75 07 28 00 D3 07 20 20 75 01 28 00 D8 01 20 20 75 88 78 03 9A 90 42 00 D3 10 46 C0 B2 60 75 07 28 00 D3
9:07:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 EA 09 81 80 07 20 60 75 01 28 00 D8 01 20 60 75 8A 88 BD F8 06 00 82 42 00 D2 10 46 E0 82 9A 28 00 D3 9A 20 E0 82 C8 88 BD F8 04 10 88 42 00 D3 08 46 20 83 9A 28 00 D3 9A 20 20 83 01 20 00 90 00 23 06 22 29 46 20 46 FF F7 7A FD 00 B3 6E 60 20 6A 08 B3 45 60 25 62 A0 8C 40 1C 00 B2 A0 84 B4 F9 26 10 88 42 03 DB 04 F1 7C 00 C9 F7 5C FB 38 7C C0 06 12 D5 06 21 20 46 FF F7 B5 F9 04 F1 74 00 C9 F7
9:07:19 AM
9:07:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 EB 09 81 80 51 FB 0D E0 00 20 04 B0 BD E8 F0 81 28 46 E1 F7 13 F9 F7 E7 E5 61 DC E7 02 21 20 46 FF F7 A2 F9 01 20 F0 E7 2D E9 F8 43 04 46 D0 F8 BC 00 00 28 54 D0 20 46 FF F7 4F FF 00 28 4F D0 21 7C 60 7D 08 44 40 1E C1 17 00 EB 51 71 21 F0 07 01 40 1A 5F FA 80 F7 E1 F7 AE F8 05 00 33 D0 A8 68 0F 30 A8 60 D4 F8 BC 20 20 8B B2 F9 14 10 88 42 00 DB 08 46 06 B2 56 B3 B2 F9 0C 00 B0 42 06 DA 31 46
9:07:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 EC 09 81 80 10 46 E1 F7 D1 FA C4 F8 BC 00 18 B3 54 F8 BC 0F 32 46 00 21 83 68 28 46 E1 F7 10 F9 01 46 20 68 E1 F7 57 FA A0 88 A4 F1 BC 04 00 28 D4 F8 BC 00 B0 F9 14 00 22 D0 00 28 16 DD A0 7B B8 42 0F D1 01 26 0E E0 20 46 FF F7 CB FE 06 E0 28 46 E1 F7 B3 F8 F7 E7 28 46 E1 F7 AF F8 00 20 BD E8 F8 83 00 26 4F F0 01 08 05 E0 4F F0 00 08 01 26 20 46 FF F7 B6 FE 43 46 01 22 00 96 0E E0 00 28 03 DD
9:07:20 AM
9:07:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 ED 09 81 80 4F F0 01 08 00 26 05 E0 4F F0 00 08 01 26 20 46 FF F7 A6 FE 43 46 09 22 00 96 29 46 20 46 FF F7 CD FC A8 B1 00 20 68 60 20 6A A8 B1 45 60 25 62 A0 8C 40 1C 00 B2 A0 84 B4 F9 26 10 88 42 03 DB 04 F1 7C 00 C9 F7 AE FA 00 2E 83 D0 01 20 C5 E7 20 46 FF F7 85 FE BD E7 E5 61 E8 E7 10 B5 04 46 FF F7 60 FF 00 28 0B D0 20 7B 01 28 07 D1 05 21 20 46 FF F7 F7 F8 04 F1 74 00 C9 F7 93 FA 01 20
9:07:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 EE 09 81 80 10 BD F8 B5 04 46 08 7C 0E 46 47 09 00 22 39 46 20 46 FF F7 3E FB 00 28 56 D0 A0 7B 00 25 B8 42 03 D1 20 46 FF F7 DA FF 17 E0 07 F0 07 00 11 E0 04 EB 80 02 D2 F8 98 10 49 B1 4D 60 23 6A 7B B1 59 60 21 62 A1 8C 49 1C A1 84 C2 F8 98 50 40 1C 00 F0 07 00 A1 7B 81 42 EA D1 A0 8C 10 B1 1F E0 E1 61 EE E7 E0 F7 E6 FF 07 00 25 D0 01 20 00 90 00 23 02 22 39 46 20 46 FF F7 60 FC F0 B1 7D 60
9:07:21 AM
9:07:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 EF 09 81 80 20 6A F8 B1 47 60 27 62 A0 8C 40 1C 00 B2 A0 84 B4 F9 26 10 88 42 03 DB 04 F1 7C 00 C9 F7 42 FA 30 7C C0 06 15 D5 06 21 20 46 FF F7 9B F8 04 F1 74 00 C9 F7 37 FA 10 E0 00 20 F8 BD 38 46 E0 F7 FB FF F9 E7 E7 61 DE E7 31 46 20 46 FF F7 7A FD 03 E0 02 21 20 46 FF F7 85 F8 01 20 F8 BD F8 B5 04 46 0E 46 E0 F7 A6 FF 05 00 2E D0 20 46 FF F7 48 FD 70 B3 21 7B 01 20 01 29 4F F0 00 03 00 90
9:07:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F0 09 81 80 25 D0 06 22 29 46 20 46 FF F7 18 FC 08 B3 00 20 68 60 20 6A 10 B3 45 60 25 62 A0 8C 40 1C 00 B2 A0 84 B4 F9 26 10 88 42 03 DB 04 F1 7C 00 C9 F7 F9 F9 30 7C C0 06 13 D5 05 21 20 46 FF F7 52 F8 04 F1 74 00 C9 F7 EE F9 0D E0 00 20 F8 BD 07 22 D8 E7 FF E7 28 46 E0 F7 AF FF F6 E7 E5 61 DB E7 20 46 FF F7 EF FD 01 20 F8 BD 00 F0 7F 00 10 30 70 47 70 B5 04 46 D0 F8 C8 00 0E 46 18 B1 40 7A
9:07:22 AM
9:07:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F1 09 81 80 04 F0 8A FF 01 E0 4F F4 E1 30 FE 49 B1 FB F0 F5 A0 68 31 68 44 1A 16 D0 CA F7 65 FF 14 21 B0 FB F1 F2 01 FB 12 00 04 F0 1F 01 01 EB 81 01 00 EB 81 00 68 43 00 EB C0 01 01 EB 00 10 4F F4 7A 71 B0 FB F1 F0 70 BD 00 20 70 BD FE B5 04 46 0E 46 E0 F7 30 FF 05 00 12 D0 B6 F9 14 10 01 AA B0 69 FF F7 52 FB 28 B3 BD F8 08 00 A0 B1 A0 F5 7F 41 FF 39 06 D1 A0 68 00 F0 7F 00 10 30 05 E0 00 20
9:07:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F2 09 81 80 FE BD A1 68 01 9A 91 42 13 D1 21 68 88 81 60 7B 40 F0 01 00 60 73 01 20 00 90 00 23 0A 22 29 46 20 46 FF F7 8B FB 20 B1 E0 69 68 60 20 6A 20 B1 04 E0 28 46 E0 F7 40 FF E1 E7 25 62 E5 61 A0 8C 40 1C 00 B2 A0 84 B4 F9 26 10 88 42 03 DB 04 F1 7C 00 C9 F7 67 F9 01 A9 20 46 FF F7 8A FF C4 F8 88 00 30 7C C0 06 08 D5 07 21 20 46 FE F7 BA FF 04 F1 74 00 C9 F7 56 F9 02 E0 20 46 FF F7 62 FD
9:07:23 AM
9:07:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F3 09 81 80 01 20 FE BD F8 B5 04 46 0E 46 E0 F7 D3 FE 05 00 0D D0 01 20 00 90 00 23 02 22 29 46 20 46 FF F7 4D FB 30 B1 E0 69 68 60 20 6A 30 B1 06 E0 00 20 F8 BD 28 46 E0 F7 00 FF F9 E7 25 62 E5 61 A0 8C 40 1C 00 B2 A0 84 B4 F9 26 10 88 42 03 DB 04 F1 7C 00 C9 F7 27 F9 30 7C C0 06 08 D5 06 21 20 46 FE F7 80 FF 04 F1 74 00 C9 F7 1C F9 03 E0 02 21 20 46 FE F7 77 FF 01 20 F8 BD 2D E9 F0 41 15 46
9:07:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F4 09 81 80 88 B0 92 69 04 46 8A 60 A8 8A 0E 46 88 81 B5 F9 14 10 B1 82 4F F0 00 08 D4 F8 B8 00 47 46 58 B1 E0 F7 C1 FF B6 F9 14 10 81 42 0A D0 54 F8 B8 0F E0 F7 C2 FE 27 60 10 E0 4F F0 01 08 C4 F8 B8 60 0E E0 D4 F8 B8 00 40 F2 03 52 B0 F9 14 10 91 42 06 DD E0 F7 B1 FE C4 F8 B8 70 00 20 08 B0 93 E5 68 88 00 05 19 D4 03 A9 04 F1 40 00 FF F7 1C F8 05 A9 04 F1 46 00 FF F7 17 F8 03 A8 00 90 05 A8
9:07:24 AM
9:07:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F5 09 81 80 CD E9 01 07 00 23 6A 46 D4 F8 B8 10 D4 F8 CC 00 06 F0 A5 FC 90 B1 C4 F8 B8 70 28 7C C0 06 0B D5 20 7B 04 F1 74 03 01 28 0E D0 06 21 20 46 FE F7 19 FF 18 46 C9 F7 B6 F8 40 46 CF E7 54 F8 B8 0F E0 F7 7A FE 27 60 F7 E7 05 21 EF E7 2D E9 F0 41 04 46 10 7C 0E 46 15 46 4F F0 00 08 41 09 C0 F3 42 07 88 B0 42 46 20 46 FF F7 53 F9 30 B3 00 22 39 46 20 46 FF F7 62 F9 28 B3 7F 1C 07 F0 07 00
9:07:25 AM
9:07:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F6 09 81 80 E0 73 AA 69 B2 60 A8 8A B0 81 B5 F9 14 10 B1 82 D4 F8 B8 00 00 27 E0 B1 E0 F7 45 FF B6 F9 14 10 88 42 D4 F8 B8 00 05 D1 B0 F9 14 10 40 F2 03 52 91 42 12 DD E0 F7 40 FE C4 F8 B8 70 29 46 20 46 FF F7 C0 FB 03 E0 29 46 20 46 FF F7 1B FF 00 20 84 E7 4F F0 01 08 C4 F8 B8 60 68 88 00 05 04 D5 29 46 20 46 FF F7 0E FF 21 E0 03 A9 04 F1 40 00 FE F7 9A FF 05 A9 04 F1 46 00 FE F7 95 FF 03 A8
9:07:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F7 09 81 80 00 90 05 A8 CD E9 01 07 01 23 6A 46 D4 F8 B8 10 D4 F8 CC 00 06 F0 23 FC 38 B9 D4 F8 B8 00 E0 F7 0B FE 29 46 20 46 FF F7 8D FB C4 F8 B8 70 28 7C C0 06 08 D5 06 21 20 46 FE F7 94 FE 04 F1 74 00 C9 F7 30 F8 03 E0 02 21 20 46 FE F7 8B FE 40 46 44 E7 2D E9 F0 41 04 46 00 7B 8A B0 01 28 01 D0 02 28 21 D1 E5 6A FD B1 68 68 00 26 E0 62 00 B9 26 63 6E 60 A0 8E 00 27 40 1E A0 86 69 46 28 46
9:07:26 AM
9:07:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F8 09 81 80 FF F7 00 F8 04 F1 5C 08 D8 B3 20 68 80 89 7F 28 0D D8 02 20 8D F8 20 00 7F 20 8D F8 22 00 20 68 80 89 8D F8 23 00 0D E0 01 20 0A B0 AC E4 04 20 8D F8 20 00 43 F6 FF 70 AD F8 22 00 20 68 80 89 AD F8 24 00 0D F1 0A 02 01 A9 08 A8 FE F7 9B FF B8 B1 04 F1 6C 00 C8 F7 E5 FF 01 98 20 64 BD F8 08 00 A4 F8 44 00 DD F8 0A 00 C4 F8 46 00 BD F8 0E 00 A4 F8 4A 00 BD F8 02 00 E0 87 9D F8 10 00
9:07:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 F9 09 81 80 02 E0 0D E0 80 96 98 00 84 F8 4C 00 68 46 FF F7 2D F8 21 7B 03 29 50 D2 DF E8 01 F0 4F 0C 35 00 28 46 E0 F7 89 FD 84 F8 3C 60 40 46 C8 F7 B6 FF 00 20 BA E7 0B 28 21 D2 DF E8 00 F0 20 0B 0B 20 06 10 20 20 20 15 1B 00 69 46 20 46 FF F7 E8 FB 34 E0 69 46 20 46 FF F7 2B FB 2F E0 69 46 20 46 FF F7 7D FD 2A E0 6A 46 29 46 20 46 FF F7 85 FE 22 E0 69 46 20 46 FF F7 E8 FD 1F E0 69 46 20 46
9:07:27 AM
9:07:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 FA 09 81 80 FF F7 E0 FA 1A E0 0B 28 F8 D2 DF E8 00 F0 0A 10 0B 0A 09 08 0A 0A 0A 07 06 00 EA E7 E3 E7 DD E7 D2 E7 EB E7 69 46 20 46 FF F7 EB FC 06 E0 6A 46 29 46 20 46 FF F7 CA FE 07 46 17 B9 28 46 E0 F7 3B FD 84 F8 3C 60 40 46 C8 F7 68 FF 6C E7 01 20 70 47 01 20 70 47 2D E9 F3 41 04 46 90 F8 3C 00 4F F6 FF 75 4F F0 00 08 D8 B1 01 28 15 D9 07 28 07 D2 B4 F8 52 20 01 21 01 A8 C9 F7 63 F8 A4 F8
9:07:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 FB 09 81 80 52 00 94 F8 3C 00 0A 28 07 D2 B4 F8 54 20 01 21 01 A8 C9 F7 57 F8 A4 F8 54 00 D4 F8 90 00 90 B1 17 E0 04 F1 3C 04 60 6D E0 F7 9D FF 65 82 A5 82 E5 82 25 83 01 20 20 70 A4 F8 1A 80 A4 F8 1C 80 A4 F1 3C 04 E9 E7 E0 F7 B5 FC C4 F8 90 00 00 28 7D D0 94 F8 3C 00 0C 26 0A 27 0D 28 78 D2 DF E8 00 F0 77 07 20 3C 50 63 7C 8D A1 C4 E7 FE FB 00 D4 F8 90 00 E0 F7 77 FF 9D F8 04 00 7E 28 68 D1
9:07:28 AM
9:07:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 FC 09 81 80 01 AA 01 21 D4 F8 90 00 E0 F7 CD FD 01 28 5E D1 04 F1 3C 04 60 8B 00 F1 01 00 60 83 4F F0 02 00 17 E0 9D F8 04 00 B7 EB 10 1F 51 D1 01 AA 01 21 D4 F8 90 00 E0 F7 B7 FD 01 28 E8 D1 04 F1 3C 04 60 8B 00 F1 01 00 60 83 9D F8 04 00 E0 70 4F F0 03 00 20 70 A4 F1 3C 04 29 E1 01 AA 01 21 D4 F8 90 00 E0 F7 A0 FD 01 28 31 D1 04 F1 3C 04 60 8B 00 F1 01 00 60 83 9D F8 04 00 A0 70 4F F0 04 00
9:07:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 FD 09 81 80 E7 E7 01 AA 01 21 D4 F8 90 00 E0 F7 8C FD 01 28 1D D1 B4 F8 56 00 40 1C A4 F8 56 00 9D F8 04 00 C0 07 16 D0 05 20 11 E0 01 AA 01 21 D4 F8 90 00 E0 F7 79 FD 01 28 0A D1 B4 F8 56 00 40 1C A4 F8 56 00 9D F8 04 00 C0 07 EB D0 06 20 02 E0 85 E0 E5 E0 DF E0 84 F8 3C 00 E9 E0 01 AA 01 21 D4 F8 90 00 E0 F7 60 FD 01 28 78 D1 04 F1 3C 04 60 8B 00 F1 01 00 60 83 4F F0 07 00 AA E7 01 AA 01 21
9:07:29 AM
9:07:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 FE 09 81 80 D4 F8 90 00 E0 F7 4F FD 01 28 67 D1 04 F1 3C 04 60 8B 00 F1 01 00 60 83 9D F8 04 00 A0 74 4F F0 08 00 96 E7 01 AA 01 21 D4 F8 90 00 E0 F7 3B FD 01 28 77 D1 04 F1 3E 04 20 8B 00 F1 01 00 80 B2 20 83 9D F8 04 10 61 74 21 8A 81 EA 05 01 21 82 34 F8 3E 19 C1 F3 0A 01 88 42 04 D9 A4 F8 54 50 84 F8 3C 60 A3 E0 09 20 B0 E7 B4 F8 58 00 E1 8A 88 42 07 D2 01 AA 01 21 D4 F8 90 00 E0 F7 13 FD
9:07:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 03 FF 09 81 80 01 28 4F D1 04 F1 3E 04 20 8B 00 F1 01 00 80 B2 20 83 61 8B 01 F1 01 01 61 83 34 F8 3E 19 C1 F3 0A 01 A1 F1 02 01 88 42 7D DD 84 F8 3C 70 7E E0 01 AA 01 21 D4 F8 90 00 E0 F7 F5 FC 01 28 31 D1 04 F1 3C 04 60 8B 00 F1 01 00 60 83 9D F8 04 00 20 75 4F F0 0B 00 3C E7 18 E0 00 E0 22 E0 01 AA 01 21 D4 F8 90 00 E0 F7 DE FC 01 28 1A D1 04 F1 3C 04 60 8B 00 F1 01 00 60 83 9D F8 04 00 60 75
9:07:30 AM
9:07:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 00 09 81 80 A0 8A 80 EA 05 00 A0 82 26 70 23 E7 9D F8 04 00 7E 28 44 D1 01 AA 01 21 D4 F8 90 00 E0 F7 C3 FC 01 28 02 D0 00 20 BD E8 FC 81 B4 F8 56 00 40 1C 80 B2 A4 F8 56 00 B4 F8 58 10 E2 8A 91 42 2E D8 E1 8F C1 F3 0A 01 89 1C 81 42 28 D1 B4 F8 4E 00 B4 F8 52 10 88 42 22 D1 B4 F8 50 00 B4 F8 54 10 88 42 1C D1 D4 F8 90 00 45 46 C0 F8 04 80 20 6B 88 B1 D4 F8 90 10 41 60 D4 F8 90 00 20 63 A0 8E
9:07:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 01 09 81 80 40 1C A0 86 20 46 C4 F8 90 50 FF F7 A2 FD 84 F8 3C 50 10 E0 07 E0 D4 F8 90 00 E0 62 EC E7 01 21 20 46 FE F7 9C FD 94 F8 3C 00 01 28 03 D9 04 F1 5C 00 C8 F7 B7 FD 01 20 B5 E7 2D E9 F0 41 04 46 00 7B 0D 46 17 46 07 28 21 D1 04 F1 74 00 80 46 C8 F7 B0 FD 06 46 03 28 0D D2 CA F7 44 FB C6 F1 2B 01 B0 FB F1 F2 01 FB 12 00 D4 F8 88 10 08 44 C4 F8 88 00 0B E0 2B 28 09 D3 40 46 C8 F7 8E FD
9:07:31 AM
9:07:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 02 09 81 80 20 46 FF F7 BE F8 01 21 20 46 FE F7 EB FB 04 F1 64 00 C8 F7 87 FD 00 26 06 E0 29 78 20 46 FF F7 1A FE 6D 1C 76 1C B6 B2 BE 42 F6 D3 01 20 BD E8 F0 81 70 B5 04 46 01 25 5C 30 C8 F7 7B FD 21 68 09 89 88 42 03 D3 01 21 20 46 FE F7 48 FD 04 F1 64 00 06 46 C8 F7 6E FD D4 F8 84 10 88 42 09 D3 01 21 20 46 FE F7 3B FD 30 46 C8 F7 57 FD 20 46 FF F7 68 F9 04 F1 6C 00 06 46 C8 F7 5B FD D4 F8
9:07:32 AM
9:07:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 03 09 81 80 84 10 88 42 09 D3 01 21 20 46 FE F7 28 FD 30 46 C8 F7 44 FD 20 46 FF F7 55 F9 28 46 70 BD 70 B5 04 46 E0 F7 C7 FA 05 00 10 D0 D4 F8 94 40 0F E0 B4 F9 0C 10 28 46 A2 68 E0 F7 F5 FB B4 F9 0C 10 88 42 04 D0 28 46 E0 F7 F7 FA 00 20 70 BD 24 68 00 2C ED D1 28 46 70 BD D0 F8 94 00 00 28 01 D0 80 68 80 1D 70 47 00 B5 D0 F8 94 00 00 28 06 D0 80 68 80 79 FE F7 4A FD 01 28 00 D0 00 20 00 BD
9:07:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 04 09 81 80 2D E9 F0 47 04 46 4F F0 00 08 D0 F8 94 00 46 46 A8 B9 E0 69 C4 F8 94 00 98 B3 41 68 E1 61 01 B9 26 62 46 60 A0 8C 40 1E A0 84 D4 F8 94 00 40 B3 04 F1 7C 00 C8 F7 F2 FC D4 F8 94 00 A8 B3 81 89 19 B3 20 46 FF F7 CF FF 81 46 01 28 22 D0 00 27 4F EA 07 05 D4 F8 C8 00 38 B3 D4 F8 94 10 04 F0 99 FB 5F EA 00 08 21 D0 B9 F1 00 0F 26 D0 04 EB 87 07 D7 F8 98 00 08 B1 E0 F7 9E FA C7 F8 98 50
9:07:33 AM
9:07:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 05 09 81 80 1C E0 FF E7 00 20 BD E8 F0 87 E0 F7 95 FA C4 F8 94 60 F7 E7 20 46 FF F7 9F FF 00 78 C0 F3 42 07 20 46 FF F7 7C FF 05 46 D4 E7 09 E0 15 B1 28 46 E0 F7 82 FA D4 F8 94 00 E0 F7 7E FA C4 F8 94 60 40 46 E0 E7 10 B5 01 29 01 D1 FF F7 BB F8 01 20 10 BD 10 B5 B1 F5 80 7F 06 D0 A1 F5 80 71 03 39 05 D0 01 29 17 D1 0B E0 FF F7 AC F8 13 E0 01 7B 05 29 01 D0 06 29 0E D1 74 30 C8 F7 93 FC 0A E0
9:07:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 06 09 81 80 01 7B 05 29 02 D0 06 29 02 D0 04 E0 01 21 00 E0 02 21 FE F7 E7 FA 01 20 10 BD 10 B5 61 B1 00 22 4A 60 02 6B 52 B1 51 60 01 63 81 8E 49 1C 81 86 FF F7 4F FC 01 20 10 BD 00 20 10 BD C1 62 F3 E7 10 B5 FF F7 BF FF 01 20 10 BD 10 B5 FF F7 C1 FF 01 20 10 BD 10 B5 D0 F8 BC 30 0B B1 00 20 10 BD C0 F8 BC 10 A0 F8 C0 20 FF F7 B8 F9 01 20 10 BD D0 F8 C8 20 00 21 42 B1 02 68 32 B1 D2 78 D2 07
9:07:34 AM
9:07:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 07 09 81 80 03 D0 40 68 00 78 10 B1 C8 21 08 46 70 47 14 21 FB E7 10 B5 04 46 00 23 FF F7 EA FF 10 B1 03 46 18 46 10 BD D4 F8 C8 00 00 28 F9 D0 41 68 09 78 00 29 F5 D1 40 7A 04 F0 EF F9 18 B1 4B 49 B1 FB F0 F3 ED E7 C8 23 EB E7 70 B5 04 46 D0 F8 C8 00 18 B9 D4 F8 C4 00 00 28 7B D0 20 7B 40 F6 B8 35 04 F1 74 06 09 28 7C D2 DF E8 00 F0 05 0A 0A 11 7B 13 3A 48 65 00 20 46 FE F7 82 FA 03 21 6D E0
9:07:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 08 09 81 80 A0 8E 00 28 6D D0 20 46 FF F7 E3 FB 69 E0 01 21 64 E0 B4 F8 74 00 70 B1 30 46 C8 F7 0B FC A8 42 50 D2 30 46 C8 F7 06 FC 03 46 20 46 FF F7 A0 FF 83 42 38 D2 55 E0 20 46 FF F7 E2 FE A0 8C C8 BB D4 F8 94 00 B0 BB 20 46 FF F7 A3 FF C4 F8 88 00 08 21 20 46 FE F7 46 FA 30 46 C8 F7 E3 FB 40 E0 B4 F8 74 00 00 28 D7 D1 20 46 FF F7 C9 FE A0 8C 00 BB D4 F8 94 00 E8 B9 02 21 2F E0 D4 F8 88 00
9:07:35 AM
9:07:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 09 09 81 80 A8 42 01 D3 C4 F8 88 50 B4 F8 74 00 28 B3 30 46 C8 F7 D0 FB D4 F8 88 10 88 42 22 D3 30 46 C8 F7 C9 FB A8 42 0E D2 20 46 FF F7 AA FE 10 B1 30 46 C8 F7 B4 FB 15 E0 30 46 C8 F7 BC FB D4 F8 88 10 88 42 07 D9 30 46 C8 F7 A9 FB 20 46 FE F7 BA FF 07 E0 0A E0 B4 F8 74 00 18 B9 00 21 20 46 FE F7 01 FA 20 46 BD E8 70 40 23 E6 70 BD 00 CA 08 00 70 B5 00 25 04 46 80 F8 5C 50 D0 F8 94 00 20 B1
9:07:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 0A 09 81 80 09 B1 E0 F7 59 F9 C4 F8 94 50 04 F1 6C 00 BD E8 70 40 C8 F7 83 BB 10 B5 04 46 D0 F8 98 00 00 28 05 D0 09 B1 E0 F7 48 F9 00 20 C4 F8 98 00 10 BD 02 46 00 20 D2 F8 9C 20 00 2A 02 D0 10 46 04 F0 34 B9 70 47 00 28 04 D0 D0 F8 9C 00 40 7A 08 70 01 20 70 47 02 46 00 20 D2 F8 9C 10 00 29 07 D0 48 68 00 78 08 72 D2 F8 9C 00 41 6D 09 B1 01 20 70 47 41 68 49 78 04 F0 18 B9 70 B5 04 46 D0 F8
9:07:36 AM
9:07:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 0B 09 81 80 9C 00 00 25 80 B1 01 22 02 72 D4 F8 9C 00 42 6D 0A B1 01 25 02 E0 04 F0 08 F9 05 46 D4 F8 9C 00 40 6C 64 30 C8 F7 3E FB 28 46 70 BD F8 B5 0E 46 04 46 FC A2 01 21 30 46 E0 F7 F5 F9 01 28 30 D1 A0 68 03 21 02 68 30 46 E0 F7 ED F9 03 28 28 D1 20 68 6A 46 01 21 80 78 30 30 8D F8 00 00 30 46 E0 F7 E1 F9 01 28 1C D1 EF A2 02 21 30 46 E0 F7 DA F9 02 28 15 D1 A0 68 40 68 C0 F7 51 FF 85 B2
9:07:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 0C 09 81 80 10 2D 0E D8 A0 68 29 B2 42 68 30 46 E0 F7 CB F9 A8 42 06 D1 E5 A2 02 21 30 46 E0 F7 C4 F9 02 28 01 D0 00 20 F8 BD 20 68 B5 68 C0 78 18 B9 E8 78 C0 F7 58 FD E8 70 01 20 F8 BD 10 B5 08 46 DC A2 01 21 E0 F7 B0 F9 01 28 00 D0 00 20 10 BD 10 B5 08 46 D8 A2 01 21 E0 F7 A6 F9 01 28 00 D0 00 20 10 BD 04 E0 11 F8 01 3B 58 40 52 1E 92 B2 00 2A F8 D1 70 47 F8 B5 0C 46 17 46 1E 46 CE A2 01 21
9:07:37 AM
9:07:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 0D 09 81 80 20 46 06 9D E0 F7 8F F9 01 28 2C D1 3A 46 02 21 20 46 E0 F7 88 F9 02 28 25 D1 C8 A2 01 21 20 46 E0 F7 81 F9 01 28 1E D1 32 46 29 B2 20 46 E0 F7 7A F9 A8 42 17 D1 C2 A2 01 21 20 46 E0 F7 73 F9 01 28 10 D1 A0 8A A1 68 40 1E 82 B2 49 1C 00 20 FF F7 C7 FF 8D F8 00 00 6A 46 01 21 20 46 E0 F7 62 F9 01 28 00 D0 00 20 F8 BD 2D E9 F0 47 04 46 DD E9 08 75 89 46 16 46 98 46 15 F0 05 0F 1A D0
9:07:38 AM
9:07:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 0E 09 81 80 00 20 A4 F8 66 00 84 F8 68 00 0D 2E 07 D0 AB A2 01 21 48 46 E0 F7 47 F9 01 28 48 D1 0B E0 20 46 FF F7 44 FF 00 28 43 D0 A0 A2 02 21 48 46 E0 F7 3A F9 02 28 3B D1 42 46 39 B2 48 46 E0 F7 33 F9 B8 42 34 D1 94 F8 68 00 3A 46 41 46 FF F7 89 FF 84 F8 68 00 15 F0 0A 0F 2C D0 0D 2E 2A D0 04 F1 68 07 0A 2E 0D D1 A8 07 0B D4 96 A2 01 21 48 46 E0 F7 19 F9 01 28 1A D1 94 F8 68 00 01 22 91 A1
9:07:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 0F 09 81 80 0A E0 8F A2 01 21 48 46 E0 F7 0D F9 01 28 0E D1 94 F8 68 00 01 22 8A A1 FF F7 63 FF 84 F8 68 00 3A 46 01 21 48 46 E0 F7 FE F8 01 28 02 D0 00 20 BD E8 F0 87 A4 F8 66 50 01 20 F9 E7 2D E9 F0 41 05 46 0F 46 00 26 DF F7 B5 FF 04 00 06 D0 02 2F 07 D0 05 2F 0A D0 06 2F 21 D1 19 E0 00 20 BD E8 F0 81 01 46 28 46 FF F7 E1 FE 03 E0 01 46 28 46 FF F7 23 FF 06 00 12 D0 00 20 60 60 28 6C 60 B1
9:07:39 AM
9:07:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 10 09 81 80 C0 F8 04 40 45 F8 40 4F A8 88 40 1C A8 80 09 E0 01 46 28 46 FF F7 1B FF EC E7 EC 63 F2 E7 20 46 DF F7 A7 FF 30 46 DA E7 2D E9 F8 4F 05 46 0F 46 91 46 9A 46 00 26 DD F8 28 80 DF F7 7B FF 04 00 02 D0 07 2F 1A D1 02 E0 00 20 BD E8 F8 8F 53 46 4A 46 21 46 28 46 CD F8 00 80 FF F7 0B FF 06 00 0C D0 00 20 60 60 28 6C 30 B1 44 60 45 F8 40 4F A8 88 40 1C A8 80 04 E0 EC 63 F7 E7 20 46 DF F7
9:07:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 11 09 81 80 78 FF 30 46 E1 E7 2D E9 FC 47 04 46 0F 46 B0 F9 44 00 B4 F9 46 10 00 26 DD F8 28 90 92 46 98 46 88 42 0C DA DF F7 46 FF 05 00 08 D0 04 2F 09 D0 09 2F 07 D0 0A 2F 05 D0 0D 2F 1B D1 02 E0 00 20 BD E8 FC 87 53 46 3A 46 29 46 20 46 CD E9 00 89 FF F7 0B FF 06 00 0D D0 00 20 68 60 20 6C 38 B1 C0 F8 04 50 44 F8 40 5F A0 88 40 1C A0 80 04 E0 E5 63 F7 E7 28 46 DF F7 3C FF 30 46 E0 E7 00 F0
9:07:40 AM
9:07:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 12 09 81 80 7F 01 31 48 40 5C 08 43 70 47 F8 B5 05 46 D0 F8 9C 00 0E 46 40 6D C0 B1 5F F0 00 07 DF F7 0A FF 04 00 67 D0 B4 F9 0C 10 A0 68 08 44 20 1A C6 30 06 28 5F DB 06 20 8D F8 00 00 6A 46 01 21 20 46 E0 F7 31 F8 01 28 55 D1 01 E0 01 27 E6 E7 30 78 0F B1 FF F7 D4 FF 8D F8 00 00 6A 46 01 21 20 46 E0 F7 21 F8 01 28 45 D1 70 78 0F B1 FF F7 C7 FF 8D F8 00 00 6A 46 01 21 20 46 E0 F7 14 F8 01 28
9:07:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 13 09 81 80 38 D1 B0 78 0F B1 FF F7 BA FF 8D F8 00 00 6A 46 01 21 20 46 E0 F7 07 F8 01 28 2B D1 B7 B1 8D 20 15 E0 00 00 2F 00 00 00 5C 32 00 00 0D 0A 00 00 06 00 00 00 15 00 00 00 01 00 00 00 02 00 00 00 03 00 00 00 04 00 00 00 58 DD 06 00 0D 20 8D F8 00 00 6A 46 01 21 20 46 DF F7 E5 FF 01 28 09 D1 0A 20 8D F8 00 00 6A 46 01 21 20 46 DF F7 DB FF 01 28 01 D0 00 20 F8 BD 00 20 60 60 28 6C 40 B1
9:07:41 AM
9:07:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 14 09 81 80 C0 F8 04 40 45 F8 40 4F A8 88 40 1C A8 80 01 20 F8 BD EC 63 F6 E7 2D E9 FF 47 8D 68 04 46 6D 1C 04 F1 8C 0A A8 78 30 28 07 D0 4F F0 00 08 31 28 15 D0 29 78 32 29 44 D0 56 E0 01 20 20 83 E0 82 21 68 68 78 49 78 30 38 88 42 03 D0 C1 B2 20 46 FF F7 6E FD 50 46 C8 F7 E5 F8 04 20 42 E0 28 20 8D F8 04 00 0D F1 05 06 00 27 4F F0 0A 09 00 BF C9 F7 79 FE B0 FB F9 F2 09 FB 12 00 E1 19 30 30
9:07:41 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 15 09 81 80 7F 1C 88 73 3F B2 06 F8 01 0B 08 2F F0 DB 29 20 30 70 01 AB F7 A2 07 21 20 46 CD F8 00 90 FF F7 C3 FE 08 B3 21 68 68 78 49 78 30 38 88 42 03 D0 C1 B2 20 46 FF F7 3C FD 50 46 C8 F7 B3 F8 05 20 10 E0 32 28 10 D1 29 46 20 46 FF F7 1E FF 58 B1 68 78 30 38 C1 B2 20 46 FF F7 4F FD 50 46 C8 F7 A1 F8 09 20 20 73 01 E0 84 F8 0C 80 00 20 04 B0 5E E6 10 B5 04 46 8B 68 90 F8 60 00 9B 1C 20 28
9:07:42 AM
9:07:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 16 09 81 80 01 D2 02 46 00 E0 20 22 28 B1 21 68 18 46 09 1D C0 F7 50 FC 50 B9 02 21 20 46 FF F7 4F FE 20 B1 04 F1 8C 00 C8 F7 7E F8 02 20 20 73 00 20 10 BD 30 B5 50 B1 49 B1 45 18 00 21 C2 E9 00 01 91 60 91 81 D1 81 03 46 11 82 25 E0 00 20 30 BD 1C 78 28 2C 09 D0 29 2C 10 D0 2A 2C 09 D0 79 B1 01 29 11 D0 02 29 16 D1 12 E0 59 1C 51 60 01 21 11 E0 29 B1 59 1C 91 60 02 21 0C E0 03 21 0A E0 94 89
9:07:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 17 09 81 80 64 1C 94 81 06 E0 D4 89 64 1C D4 81 02 E0 14 8A 64 1C 14 82 5B 1C AB 42 01 D2 03 29 D7 D3 03 29 02 D0 00 20 80 B2 30 BD 18 1A FB E7 2D E9 F0 47 04 46 88 68 0D 46 00 F1 04 09 41 78 87 78 86 B0 0E 46 AD A0 C0 F7 8B FC 00 28 2D D0 04 F1 8C 0A 4F F0 00 08 42 2E 02 D0 50 2E 07 D0 08 E0 30 2F 06 D1 84 F8 0C 80 A4 F8 16 80 4D E0 31 2F 1D D0 94 F8 5D 00 08 28 49 D0 03 20 E0 82 01 20 20 83
9:07:43 AM
9:07:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 18 09 81 80 8D B3 C5 F8 04 80 20 6B C8 B3 45 60 25 63 A0 8E 40 1C A0 86 94 F8 5D 00 08 28 3B D0 0B 20 20 73 50 46 C7 F7 FF FF 01 20 06 B0 C1 E5 48 46 6A 46 0A 21 FF F7 7D FF 60 B1 BD F8 0E 10 01 98 45 46 08 22 00 F8 01 80 21 68 01 98 0D 31 C0 F7 B2 FB 50 B1 06 21 20 46 FF F7 B1 FD 98 B1 08 20 20 73 50 46 C7 F7 DF FF 0F E0 60 7B 05 21 40 F0 01 00 60 73 20 46 FF F7 A2 FD 10 B1 07 20 EF E7 07 E0
9:07:44 AM
9:07:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 19 09 81 80 25 73 01 E0 84 F8 0C 80 00 20 CD E7 04 20 B4 E7 E5 62 BB E7 07 20 C2 E7 10 B5 8A 68 12 78 06 2A 01 D0 15 2A 12 D1 01 22 02 83 79 B1 00 22 4A 60 02 6B 6A B1 51 60 01 63 81 8E 49 1C 81 86 0B 21 01 73 8C 30 C7 F7 AE FF 01 20 10 BD 00 20 10 BD C1 62 F0 E7 70 B5 C5 6C 04 46 BD B1 68 68 00 26 E0 64 00 B9 26 65 6E 60 B4 F8 54 00 40 1E A4 F8 54 00 21 7B 00 20 0E 29 41 D2 DF E8 01 F0 40 09
9:07:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 1A 09 81 80 40 12 40 40 29 40 40 40 2C 40 40 20 01 20 70 BD 94 F8 5D 00 01 28 33 D1 29 46 20 46 FF F7 E9 FE 2D E0 94 F8 5D 00 03 28 04 D0 07 28 1E D0 08 28 26 D1 1B E0 29 46 20 46 FF F7 6D FE 1F E0 94 F8 5D 00 05 28 17 D0 06 28 15 D0 07 28 18 D1 0D E0 94 F8 5D 00 E9 E7 94 F8 5D 00 07 28 06 D0 08 28 04 D0 05 28 07 D0 06 28 05 D0 09 E0 29 46 20 46 FF F7 1C FF 03 E0 29 46 20 46 FF F7 8D FF 10 B9
9:07:45 AM
9:07:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 1B 09 81 80 28 46 DF F7 19 FD 84 F8 5C 60 04 F1 6C 00 C7 F7 45 FF BB E7 2D E9 F3 5F 04 46 90 F8 5C 00 01 26 00 25 68 B9 04 F1 5C 04 A0 6B DF F7 9C FF A5 70 E5 70 26 70 E5 80 25 71 25 81 65 70 A4 F1 5C 04 D4 F8 94 00 00 28 7D D0 94 F8 5C 10 08 29 08 D3 0A 29 06 D2 94 F8 5F 20 9D F8 04 30 5A 40 84 F8 5F 20 0A 27 4F F0 08 0B 4F F0 07 08 4F F0 05 0A 4F F0 03 09 4F F4 96 72 0C 29 71 D2 DF E8 01 F0
9:07:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 1C 09 81 80 70 06 81 91 B6 C6 D6 F1 EF EE ED EC DF F7 6B FF 9D F8 04 00 2F 28 07 D0 06 26 06 28 11 D0 15 28 3F D0 01 28 5D D0 6A E1 04 F1 5C 04 01 AA 4F F0 01 01 A0 6B DF F7 B7 FD E0 88 40 1C E0 80 02 20 17 E1 04 F1 40 04 01 AA 4F F0 01 01 60 6D DF F7 AA FD 60 8C 40 1C 80 B2 60 84 26 77 14 F8 34 1C A4 F1 40 04 0D 29 4B D1 01 28 FC D1 84 F8 5D A0 2C E0 00 00 50 30 00 00 50 57 52 45 42 00 00 00
9:07:46 AM
9:07:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 1D 09 81 80 04 F1 50 04 60 6C 20 60 A0 88 00 F1 01 00 A0 80 65 64 A4 F1 50 04 20 46 FF F7 1C FF 84 F8 5C 50 35 E1 01 AA 01 21 D4 F8 94 00 DF F7 7C FD B4 F8 62 00 40 1C 80 B2 A4 F8 62 00 21 7B 0D 29 B2 D1 01 28 00 E0 24 E1 AE D1 84 F8 5D 60 D4 F8 94 00 45 60 20 6D 00 28 72 D0 D4 F8 94 10 41 60 CF E7 6C E0 04 F1 5C 04 01 AA 4F F0 01 01 A0 6B DF F7 5A FD E0 88 40 1C E0 80 84 F8 00 B0 A4 F1 5C 04
9:07:47 AM
9:07:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 1E 09 81 80 01 E1 9D F8 04 10 3F 29 58 D1 01 AA 01 21 DF F7 4A FD B4 F8 62 00 40 1C A4 F8 62 00 84 F8 5C 90 F1 E0 9D F8 04 10 21 29 13 D0 94 F8 60 10 20 29 44 D2 01 AA 01 21 DF F7 36 FD 04 F1 60 04 60 88 00 F1 01 00 60 80 20 78 00 F1 01 00 04 F8 60 09 D5 E0 01 AA 01 21 DF F7 26 FD 04 F1 5C 04 E0 88 00 F1 01 00 E0 80 4F F0 04 00 82 E0 9D F8 04 10 0D 29 23 D1 01 AA 01 21 DF F7 15 FD B4 F8 62 00
9:07:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 1F 09 81 80 40 1C A4 F8 62 00 84 F8 5C A0 BC E0 9D F8 04 10 0A 29 13 D1 01 AA 01 21 DF F7 05 FD 04 F1 50 04 60 8A 00 F1 01 00 60 82 66 73 99 E0 9D F8 04 10 0D 29 05 D0 B4 F8 62 10 04 29 2D D3 9B E0 96 E0 01 AA 01 21 DF F7 EF FC B4 F8 62 00 40 1C A4 F8 62 00 84 F8 5C 80 96 E0 6E E0 58 E0 37 E0 11 E0 FF E7 9D F8 04 10 0A 29 7D D1 01 AA 01 21 DF F7 DA FC 04 F1 50 04 60 8A 00 F1 01 00 60 82 84 F8
9:07:48 AM
9:07:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 20 09 81 80 0D 90 6D E0 9D F8 04 10 02 29 0F D0 03 29 32 D0 B4 F8 62 10 91 42 6E D2 01 AA 01 21 DF F7 C3 FC B4 F8 62 00 40 1C A4 F8 62 00 68 E0 B4 F8 62 10 04 29 60 D2 01 AA 01 21 DF F7 B5 FC 04 F1 5C 04 E0 88 00 F1 01 00 E0 80 4F F0 09 00 11 E0 9D F8 04 10 03 29 0F D0 04 29 DA D1 01 AA 01 21 DF F7 A2 FC 04 F1 5C 04 E0 88 00 F1 01 00 E0 80 4F F0 0B 00 20 70 42 E7 01 AA 01 21 DF F7 94 FC 04 F1
9:07:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 21 09 81 80 5C 04 E0 88 00 F1 01 00 E0 80 27 70 36 E7 9D F8 04 10 84 F8 5E 10 94 F8 5F 20 8A 42 2B D1 01 AA 01 21 DF F7 80 FC 04 F1 50 04 60 8A 00 F1 01 00 60 82 84 F8 0D 80 13 E0 9D F8 04 10 84 F8 5E 10 94 F8 5F 20 8A 42 16 D1 01 AA 01 21 DF F7 6B FC 04 F1 50 04 60 8A 00 F1 01 00 60 82 84 F8 0D B0 60 6C 45 60 00 E0 06 E0 54 F8 50 09 F2 E6 D4 F8 94 00 E0 64 C4 E6 01 21 20 46 FF F7 F9 F9 94 F8
9:07:49 AM
9:07:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 22 09 81 80 5C 00 01 28 03 D9 04 F1 6C 00 C7 F7 8B FD 01 20 BD E8 FC 9F 10 B5 04 46 A0 21 C0 F7 DE F8 04 F1 46 04 03 20 20 82 20 80 4F F0 01 00 10 BD 2D E9 F0 47 04 46 00 8B 08 9E 91 46 00 28 32 D0 00 20 20 83 E2 8A 0A 80 E5 6A 05 B3 69 68 E1 62 01 B9 20 63 68 60 A1 8E 80 46 49 1E A1 86 30 80 B5 F9 14 00 04 28 14 DD 00 1F 87 B2 BB 42 16 D3 4B 46 02 22 01 21 28 46 DF F7 28 FB B8 1E 02 B2 09 F1
9:07:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 23 09 81 80 02 03 04 21 28 46 DF F7 20 FB 16 E0 30 80 18 E0 94 F8 5D 00 05 28 07 D0 06 28 05 D0 28 46 DF F7 0B FB 00 20 BD E8 F0 87 01 27 4B 46 3A 46 00 21 28 46 DF F7 0A FB 84 F8 5D 80 37 80 28 46 DF F7 FB FA 01 20 EE E7 38 B5 05 46 04 9C 0A 29 07 D0 0B 29 08 D0 0C 29 0B D0 0D 29 0F D0 00 20 38 BD 09 21 00 94 01 E0 0A 21 00 94 FF F7 4C FB 38 BD 05 21 FF F7 E3 FA A5 F8 66 40 38 BD 0D 21 00 94
9:07:50 AM
9:07:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 24 09 81 80 F3 E7 2D E9 F0 41 06 00 0C 46 17 46 07 D0 06 F1 74 00 C7 F7 07 FD D6 F8 94 00 18 B1 08 E0 00 20 BD E8 F0 81 DF F7 86 FA C6 F8 94 00 00 28 F7 D0 00 25 06 E0 21 78 30 46 FF F7 AC FD 64 1C 6D 1C AD B2 BD 42 F6 D3 01 20 EA E7 01 29 01 D1 00 21 01 73 01 20 70 47 D0 F8 98 10 99 B9 C1 6B C0 F8 98 10 79 B1 4B 68 00 22 C3 63 03 B9 02 64 4A 60 B0 F8 44 10 49 1E A0 F8 44 10 D0 F8 98 00 08 B1
9:07:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 25 09 81 80 01 20 70 47 00 20 70 47 D0 F8 9C 00 08 B1 00 7A 08 B1 00 20 70 47 01 20 70 47 18 B1 40 68 08 B1 00 88 70 47 40 F2 DC 50 70 47 2D E9 F8 43 04 46 4F F0 01 08 6C 30 C7 F7 BD FC 01 46 20 46 FF F7 EC FF 81 42 03 D3 01 21 20 46 FF F7 11 F9 D4 F8 9C 00 00 26 04 F1 74 05 60 B3 40 6D 41 F2 70 77 00 28 28 46 0B D0 C7 F7 A5 FC B8 42 22 D3 D4 F8 9C 00 00 7A F0 B9 20 7B 01 28 16 D0 1A E0 C7 F7
9:07:51 AM
9:07:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 26 09 81 80 99 FC B8 42 16 D3 D4 F8 9C 00 00 7A 90 B9 20 7B 01 28 0F D1 69 46 20 46 FF F7 14 F9 50 B1 20 68 9D F8 00 10 40 78 88 42 04 D0 01 21 20 46 FF F7 DF F8 26 73 28 46 C7 F7 7D FC 4E F6 60 21 88 42 10 D3 20 46 FF F7 A0 FF 48 B1 01 21 20 46 FF F7 CF F8 01 21 20 46 FF F7 DE F8 26 73 E6 82 28 46 C7 F7 5C FC 40 46 BD E8 F8 83 70 B5 B0 F8 66 20 C1 8A 95 07 4F F0 01 03 4F F0 00 04 0C D5 07 29
9:07:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 27 09 81 80 21 D2 DF E8 01 F0 20 04 04 06 20 06 04 00 03 73 19 E0 0A 21 01 73 16 E0 07 29 14 D2 DF E8 01 F0 13 04 04 06 13 06 04 00 02 21 00 E0 05 21 C1 82 11 07 02 D5 C1 8A 05 29 08 D0 03 83 8C 30 C7 F7 31 FC 01 20 70 BD C4 82 00 20 70 BD 0D 21 01 73 F4 E7 70 B5 D0 F8 98 10 04 46 00 25 81 B1 D4 F8 9C 00 68 B1 03 F0 D6 FA 05 00 09 D0 00 20 C4 F8 98 00 20 46 FF F7 B9 FF 04 F1 74 00 C7 F7 12 FC
9:07:52 AM
9:07:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 28 09 81 80 28 46 70 BD 2D E9 F0 41 04 46 D0 F8 9C 00 00 25 00 28 77 D0 00 78 FF 28 74 D0 20 7B 0A 26 04 F1 8C 07 0C 28 17 D2 DF E8 00 F0 06 8A 17 8A 27 37 8A 5B 5B 60 8A 70 38 46 C7 F7 F0 FB 04 F1 74 00 C7 F7 EC FB 00 25 84 F8 5D 50 20 46 FF F7 82 F8 65 73 01 20 20 73 72 E0 20 68 C0 78 50 B1 C8 25 38 46 C7 F7 E7 FB A8 42 69 D9 20 46 FF F7 F3 FE 03 20 1E E0 14 25 F3 E7 B4 F8 66 00 C0 07 4A D1
9:07:53 AM
9:07:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 29 09 81 80 4E E0 14 25 4C E0 C8 25 4A E0 20 46 FF F7 E3 FE 80 B9 4B E0 26 73 0D E0 20 68 C0 78 70 B1 C8 25 38 46 C7 F7 C7 FB A8 42 49 D9 20 46 FF F7 D3 FE 06 20 20 73 38 46 C7 F7 B1 FB 40 E0 14 25 EF E7 14 25 00 E0 C8 25 38 46 C7 F7 B4 FB A8 42 36 D9 20 46 FF F7 C0 FE 38 46 C7 F7 A0 FB 26 73 2E E0 20 68 C0 78 00 28 ED D1 EA E7 20 68 C0 78 50 B1 C8 25 38 46 C7 F7 9E FB A8 42 20 D9 20 46 FF F7
9:07:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 2A 09 81 80 AA FE C7 E7 22 E0 14 25 F3 E7 B4 F8 66 00 81 07 01 D4 00 07 04 D5 20 68 C0 78 00 28 B3 D1 B0 E7 38 46 C7 F7 87 FB A8 42 AF D8 08 E0 38 46 C7 F7 81 FB 01 46 20 46 FF F7 B0 FE 81 42 AA D8 20 46 FF F7 B3 FE 20 46 BD E8 F0 41 42 E7 68 E6 00 00 0D 28 05 D2 F9 49 01 EB C0 01 D1 E9 00 01 70 47 01 20 00 21 70 47 10 B5 00 F5 E8 74 AD F5 A9 6D 00 20 20 80 10 20 20 87 18 22 F1 49 04 F1 3A 00
9:07:54 AM
9:07:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 2B 09 81 80 BF F7 0E FE 68 46 16 F0 8B FC 00 28 09 D0 BD F8 58 02 20 80 22 22 B1 A9 04 F1 38 00 BF F7 6B FE 01 20 0D F5 A9 6D 10 BD 10 B5 FF F7 DC FF 01 20 10 BD 1C B5 04 46 0A 20 E0 80 40 F6 34 02 68 46 E1 68 C7 F7 69 FC B4 F8 D0 12 68 46 F9 F7 E8 FA 00 28 03 D0 BD F8 04 00 20 81 01 20 1C BD 02 21 A0 F8 BC 12 D0 F8 B4 12 11 B9 03 21 A0 F8 BC 12 DF E7 0C 22 C2 80 09 B1 06 21 00 E0 15 21 C2 68
9:07:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 2C 09 81 80 11 70 01 21 01 81 08 46 70 47 70 B5 0D 46 04 46 C7 F7 71 FC 06 46 20 46 C7 F7 80 FC 01 46 2A 46 30 46 FF F7 85 FA 00 28 05 D0 69 68 21 B1 A1 88 08 44 A0 80 01 20 70 BD 00 20 70 BD 10 B5 86 B0 0C 46 69 46 FF F7 E1 FF 00 28 07 D0 22 46 BD A1 01 98 C0 F7 63 FA 00 28 00 D0 01 20 06 B0 10 BD 10 B5 86 B0 0C 46 69 46 FF F7 CF FF 00 28 F5 D0 22 46 B6 A1 01 98 C0 F7 51 FA 00 28 EE D0 01 20
9:07:55 AM
9:07:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 2D 09 81 80 EC E7 30 B5 85 B0 0D 46 14 46 69 46 FF F7 BD FF 00 28 09 D0 BD F8 0E 20 A2 42 00 D3 22 46 28 46 01 99 BF F7 D2 FE 01 20 05 B0 30 BD F0 B5 87 B0 0C 46 15 46 01 A9 FF F7 A8 FF 00 28 1A D0 00 20 20 80 B4 B1 60 60 BD F8 12 00 41 08 21 80 1C D0 28 46 C7 F7 E6 FB 60 60 00 28 0B D0 05 46 00 26 02 9F 0F E0 6A 46 9B A1 38 46 C0 F7 17 FA 01 28 02 D0 00 20 07 B0 F0 BD BF 1C 00 98 76 1C 05 F8
9:07:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 2E 09 81 80 01 0B B6 B2 20 88 B0 42 EC D8 01 20 F2 E7 F8 B5 0D 00 07 46 08 D0 01 22 90 A1 6E 68 C7 F7 15 FC 00 28 02 D0 00 24 10 E0 00 20 F8 BD 16 F8 01 2B 88 A1 68 46 D7 F7 DE FA 82 B2 69 46 38 46 C7 F7 04 FC 00 28 F1 D0 64 1C A4 B2 28 88 A0 42 ED D8 01 22 83 A1 38 46 C7 F7 F8 FB 00 28 E5 D0 01 20 F8 BD 70 B5 05 46 0C 00 13 D0 21 68 89 B1 08 88 20 B1 28 46 FF F7 CB FF 00 28 09 D0 21 68 08 89
9:07:56 AM
9:07:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 2F 09 81 80 28 B1 08 31 28 46 FF F7 C2 FF 00 28 00 D0 01 20 70 BD 00 20 70 BD 30 B5 93 B0 05 46 0C 46 28 21 08 A8 BF F7 9A FD 00 2C 6C D0 22 78 6D A1 68 46 D7 F7 A0 FA 82 B2 69 46 28 46 C7 F7 C6 FB 00 28 53 D0 21 78 00 20 0F 29 36 D0 0A DC 0E 29 21 D2 DF E8 01 F0 20 1A 1A 56 27 2C 2F 58 20 27 27 20 20 32 15 29 45 D0 08 DC A1 F1 10 01 05 29 11 D2 DF E8 01 F0 25 29 2B 2E 3D 00 16 29 40 D0 17 29
9:07:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 30 09 81 80 40 D0 18 29 2A D1 3D E0 A2 88 1A E0 68 46 D7 F7 71 FA 00 B2 10 B3 82 B2 69 46 28 46 C7 F7 95 FB 1A E0 21 1D 28 46 FF F7 72 FF 15 E0 4F A1 62 68 EC E7 50 A1 62 68 E9 E7 94 F9 04 20 01 E0 B4 F9 04 20 48 A1 E2 E7 22 79 00 E0 A2 88 4B A1 DD E7 21 1D 28 46 FF F7 85 FF 00 28 06 D0 21 46 08 A8 E7 F7 13 FE 04 00 A0 D1 01 20 13 B0 30 BD 45 A1 00 E0 46 A1 D4 E9 01 23 68 46 D7 F7 3B FA C8 E7
9:07:57 AM
9:07:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 31 09 81 80 22 79 DE E7 00 20 F0 E7 2D E9 FC 41 05 46 0C 46 D5 E9 01 60 80 46 E8 68 B7 88 3A 30 17 D0 69 46 30 46 FF F7 CB FE 00 28 3E D0 00 98 C1 B2 00 20 21 70 0F 29 3C D0 0F DC 0E 29 71 D2 DF E8 01 F0 71 1A 1A 38 20 26 2C 33 70 20 20 70 70 79 28 88 40 F4 00 40 28 80 26 E0 15 29 71 D0 07 DC A1 F1 10 01 03 29 5C D2 DF E8 01 F0 05 64 55 00 16 29 66 D1 5E E0 69 46 30 46 FF F7 A0 FE 00 99 4E E0
9:07:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 32 09 81 80 42 46 21 1D 30 46 FF F7 D1 FE 49 E0 69 46 30 46 FF F7 94 FE 00 99 04 E0 01 A9 30 46 FF F7 A0 FE 01 99 61 60 3C E0 00 20 BD E8 FC 81 21 71 37 E0 69 46 30 46 FF F7 82 FE 00 99 F7 E7 D8 DD 06 00 5C 5C 06 00 25 6C 64 29 00 00 00 00 25 6C 75 29 00 00 00 00 25 30 32 58 00 00 00 00 28 00 00 00 29 00 00 00 28 25 64 29 00 00 00 00 28 25 6C 64 29 00 00 00 28 25 6C 75 29 00 00 00 28 25 75 29
9:07:58 AM
9:07:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 33 09 81 80 00 00 00 00 28 25 6C 6C 64 29 00 00 28 25 6C 6C 75 29 00 00 01 A9 30 46 FF F7 62 FE 01 99 A1 80 68 B1 21 46 28 46 E7 F7 12 FE 00 28 BC D0 01 20 BA E7 01 A9 30 46 FF F7 53 FE 01 99 B6 E7 FF E7 68 68 87 80 AF E7 70 B5 04 46 40 8A 20 F0 78 00 F1 F7 E6 FA 05 00 13 D0 01 46 0E 22 04 F1 60 00 BF F7 DE FB 60 8A C0 F3 C3 00 84 F8 BC 00 D5 F8 02 00 60 61 E8 88 20 83 28 7A 84 F8 30 00 01 20
9:07:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 34 09 81 80 70 BD 10 B5 04 46 90 F8 30 10 14 30 F1 F7 54 FA 01 00 0A D0 08 88 60 82 0E 22 04 F1 60 00 BF F7 BF FB 02 20 84 F8 BC 00 01 20 10 BD 1C B5 82 89 01 68 14 46 05 E0 0B 78 3B 2B 06 D0 49 1C 64 1E A4 B2 00 2C F7 D1 FF 20 1C BD 04 2C FB D8 12 1B 82 81 49 1C 62 1E 68 46 BF F7 A2 FB 0D EB 04 01 00 20 01 F8 01 0C 01 AA FB A1 68 46 C0 F7 56 F8 01 28 E8 D1 BD F8 04 00 C0 B2 1C BD 10 B5 F7 4A
9:07:59 AM
9:07:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 35 09 81 80 00 21 00 BF 01 EB 41 03 32 F8 13 40 84 42 0A D8 02 EB 43 03 5B 88 83 42 05 D3 01 EB 41 00 02 EB 40 00 00 79 10 BD 49 1C 89 B2 6C 29 EA D3 00 20 10 BD 07 28 03 D0 0A 28 01 D0 0C 28 06 D1 21 F0 78 02 42 F0 28 02 8A 42 00 D1 15 20 70 47 01 29 05 D0 02 29 05 D0 04 29 05 D0 00 20 70 47 00 78 02 E0 00 88 00 E0 00 68 10 60 01 20 70 47 01 29 05 D0 02 29 05 D0 04 29 05 D0 00 20 70 47 02 70
9:07:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 36 09 81 80 02 E0 02 80 00 E0 02 60 01 20 70 47 2D E9 FF 4F B1 B0 00 26 31 98 14 46 1F 46 35 46 20 F0 78 00 DD F8 F8 B0 F1 F7 3C FA 81 46 80 21 0E A8 BF F7 D4 FB 80 22 0E A9 08 A8 C7 F7 AE F9 AF F2 F8 18 58 46 C7 4A 4F F0 0C 0A 4F F0 05 0B 18 28 74 D2 DF E8 00 F0 73 0C 27 41 A3 FE 12 FD 73 FC FB FA F9 F8 F7 73 F6 F5 F4 5C 5A 74 F3 F2 3A 46 21 46 08 A8 F8 F7 D2 FC E5 E2 07 AA 39 46 20 46 FF F7
9:08:00 AM
9:08:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 37 09 81 80 A6 FF 05 00 59 D0 07 99 B1 F5 80 3F 01 D3 09 23 00 E0 05 23 FF 29 00 D8 03 23 00 20 06 22 00 90 F7 E3 04 2F 02 D0 06 23 03 22 33 E0 FF 22 0A 21 0B A8 C0 F7 E6 F8 20 78 8D F8 31 00 60 78 8D F8 32 00 A0 78 06 23 8D F8 33 00 03 22 33 E0 08 A8 F8 F7 D6 FD FE E3 05 2F 02 D0 06 23 02 22 19 E0 FF 22 0A 21 0B A8 C0 F7 CC F8 20 78 8D F8 2D 00 60 78 8D F8 2C 00 A0 78 8D F8 2E 00 E0 78 06 23
9:08:01 AM
9:08:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 38 09 81 80 8D F8 2F 00 02 22 16 E0 4F F0 0A 0A 04 2F 03 D0 53 46 04 22 21 46 DA E7 FF 22 0A 21 0B A8 C0 F7 B0 F8 0B A9 20 68 C6 F7 35 FF 00 28 AA D0 20 68 50 B3 53 46 04 22 0B A9 C9 E7 D1 E0 FF 22 0A 21 0B A8 C0 F7 9E F8 20 78 8D F8 2D 00 60 78 8D F8 2C 00 A0 78 8D F8 2E 00 E0 78 8D F8 2F 00 60 79 8D F8 31 00 A1 79 8D F8 32 10 E1 79 8D F8 33 10 BD F8 2C 10 A1 F5 7F 42 FF 3A 05 D1 FF 28 03 D1
9:08:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 39 09 81 80 00 20 0B A9 C6 F7 06 FF 00 20 00 90 53 46 04 22 0B A9 08 A8 F8 F7 9E FC 9C E3 90 7C 92 46 00 09 0C D0 01 28 0D D0 02 28 0F D0 03 28 10 D0 1F 26 01 20 16 F0 75 FD 70 B1 08 20 0F E0 00 27 69 A0 01 E0 03 27 68 A0 80 46 F2 E7 06 27 68 A0 FA E7 09 27 69 A0 F7 E7 9A F8 00 00 00 09 81 46 01 20 16 F0 5E FD 18 B1 9A F8 13 00 00 09 03 E0 9A F8 00 00 00 F0 0F 00 82 46 B9 F1 00 0F 6F D0 B9 F1
9:08:02 AM
9:08:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 3A 09 81 80 09 0F 6C D8 CA 45 6A D2 00 2E 69 D1 0A AA 05 A9 31 98 12 F0 0C FA 9D F8 14 00 39 1A A1 EB 0A 00 40 B2 00 28 22 DA 40 42 C0 B2 FF F7 11 FC 0A 9A 00 23 A0 FB 02 57 0C E0 62 E2 05 E3 44 E3 2C E3 A1 E2 90 E2 71 E2 FE E1 85 E1 1B E1 AE E0 27 E0 65 E2 01 FB 02 71 00 FB 03 13 D4 E9 00 12 A5 FB 01 04 03 FB 01 41 05 FB 02 11 12 E0 C0 B2 FF F7 EF FB D4 E9 00 34 0A 9A 84 46 A3 FB 02 07 04 FB
9:08:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 3B 09 81 80 02 72 00 25 03 FB 05 24 0B 46 62 46 21 46 D6 F7 48 FF 08 24 8D E8 10 06 02 46 0B 46 08 A8 CF E1 90 7C 93 46 10 F0 0F 00 0C D0 01 28 0D D0 02 28 0F D0 03 28 10 D0 1F 26 01 20 16 F0 F1 FC 80 B1 07 20 11 E0 00 27 2E A0 01 E0 03 27 2D A0 80 46 F2 E7 06 27 2C A0 FA E7 09 27 2C A0 F7 E7 8F E0 8F E0 9B F8 01 00 00 09 99 F8 05 10 02 29 05 D1 81 1C 09 29 01 D2 80 1C 00 E0 09 20 00 F0 FF 0A
9:08:03 AM
9:08:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 3C 09 81 80 01 20 16 F0 CD FC 10 B1 9B F8 13 00 01 E0 9B F8 01 00 BA F1 00 0F 00 F0 0F 09 71 D0 BA F1 09 0F 6E D8 D1 45 6C D2 00 2E 6B D1 0A AA 05 A9 31 98 12 F0 7D F9 9D F8 14 00 39 1A A1 EB 09 00 40 B2 00 28 25 DA 40 42 C0 B2 FF F7 82 FB 0A 99 48 43 21 68 48 43 24 E0 00 00 25 68 75 00 40 DE 06 00 08 48 00 10 2A 57 68 00 2A 6B 57 68 00 00 00 00 2A 4D 57 68 00 00 00 00 2A 47 57 68 00 00 00 00
9:08:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 3D 09 81 80 2A 57 00 00 2A 6B 57 00 2A 4D 57 00 2A 47 57 00 C0 B2 FF F7 5D FB 21 68 0A 9A 51 43 91 FB F0 F0 53 46 08 22 CD F8 00 90 07 90 71 E2 90 7C 92 46 00 09 0C D0 01 28 0D D0 02 28 0F D0 03 28 10 D0 1F 26 01 20 16 F0 6C FC 70 B1 08 20 0F E0 00 27 F9 A0 01 E0 03 27 FA A0 80 46 F2 E7 06 27 FA A0 FA E7 09 27 FA A0 F7 E7 9A F8 00 00 00 09 81 46 01 20 16 F0 55 FC 28 B1 9A F8 13 00 00 09 05 E0
9:08:04 AM
9:08:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 3E 09 81 80 86 E0 86 E0 9A F8 00 00 00 F0 0F 00 82 46 B9 F1 00 0F 7D D0 B9 F1 09 0F 7A D8 CA 45 78 D2 00 2E 77 D1 0A AA 05 A9 31 98 12 F0 01 F9 9D F8 14 00 39 1A A1 EB 0A 00 40 B2 00 28 12 DA 40 42 C0 B2 FF F7 06 FB 0A 9A 00 23 A0 FB 02 57 01 FB 02 71 00 FB 03 13 D4 E9 00 12 A5 FB 01 04 03 FB 01 41 D1 E0 C0 B2 FF F7 F4 FA D4 E9 00 54 0A 9A 0B 46 A5 FB 02 1C 04 FB 02 C2 00 27 05 FB 07 24 02 46
9:08:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 3F 09 81 80 08 46 D3 E0 90 7C 93 46 10 F0 0F 00 0C D0 01 28 0D D0 02 28 0F D0 03 28 10 D0 1F 26 01 20 16 F0 FF FB 70 B1 07 20 0F E0 00 27 CB A0 01 E0 03 27 CB A0 80 46 F2 E7 06 27 CB A0 FA E7 09 27 CC A0 F7 E7 9B F8 01 00 00 09 99 F8 05 10 02 29 05 D1 81 1C 09 29 01 D2 80 1C 00 E0 09 20 00 F0 FF 0A 01 20 16 F0 DD FB 10 B1 9B F8 13 00 01 E0 9B F8 01 00 BA F1 00 0F 00 F0 0F 09 09 D0 BA F1 09 0F
9:08:05 AM
9:08:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 40 09 81 80 06 D8 D1 45 04 D2 00 2E 8A D1 0A AA 05 A9 01 E0 C4 E0 03 E1 31 98 12 F0 8A F8 9D F8 14 00 39 1A A1 EB 09 00 40 B2 00 28 08 DA 40 42 C0 B2 FF F7 8F FA 0A 99 48 43 21 68 48 43 07 E0 C0 B2 FF F7 87 FA 21 68 0A 9A 51 43 B1 FB F0 F0 53 46 CD F8 00 90 07 90 9B E1 90 7C 92 46 00 09 0C D0 01 28 0D D0 02 28 0F D0 03 28 10 D0 1F 26 01 20 16 F0 97 FB 70 B1 08 20 0F E0 00 27 9F A0 01 E0 03 27
9:08:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 41 09 81 80 9F A0 80 46 F2 E7 06 27 9F A0 FA E7 09 27 A0 A0 F7 E7 9A F8 00 00 00 09 81 46 01 20 16 F0 80 FB 18 B1 9A F8 13 00 00 09 03 E0 9A F8 00 00 00 F0 0F 00 82 46 B9 F1 00 0F 70 D0 B9 F1 09 0F 6D D8 CA 45 6B D2 00 2E 9F D1 0A AA 05 A9 31 98 12 F0 2E F8 9D F8 14 00 39 1A A1 EB 0A 00 40 B2 00 28 14 DA 40 42 C0 B2 FF F7 33 FA 0A 9A 00 23 A0 FB 02 57 01 FB 02 71 00 FB 03 11 D4 E9 00 32 A5 FB
9:08:06 AM
9:08:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 42 09 81 80 03 04 01 FB 03 41 05 FB 02 11 12 E0 C0 B2 FF F7 1F FA D4 E9 00 34 0A 9A 84 46 A3 FB 02 07 04 FB 02 72 00 25 03 FB 05 24 62 46 0B 46 21 46 D6 F7 01 FD CD F8 00 B0 CD E9 01 9A 02 46 0B 46 08 A8 F8 F7 40 FC 46 E1 90 7C 93 46 10 F0 0F 00 0C D0 01 28 0D D0 02 28 0F D0 03 28 10 D0 1F 26 01 20 16 F0 1E FB 70 B1 07 20 0F E0 00 27 6A A0 01 E0 03 27 6A A0 80 46 F2 E7 06 27 6A A0 FA E7 09 27
9:08:07 AM
9:08:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 43 09 81 80 6A A0 F7 E7 9B F8 01 00 00 09 99 F8 05 10 02 29 06 D1 81 1C 09 29 02 D2 80 1C 01 E0 15 E0 09 20 00 F0 FF 0A 01 20 16 F0 FB FA 10 B1 9B F8 13 00 01 E0 9B F8 01 00 BA F1 00 0F 00 F0 0F 09 04 D0 BA F1 09 0F 01 D8 D1 45 01 D3 1F 26 03 E1 2E BB 0A AA 05 A9 31 98 11 F0 AA FF 9D F8 14 00 39 1A A1 EB 09 00 40 B2 00 28 FF F6 1F AF C0 B2 FF F7 AF F9 01 46 20 68 0A 9A 50 43 B0 FB F1 F0 25 E7
9:08:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 44 09 81 80 BD F8 24 10 08 98 22 68 08 44 4A A1 D6 F7 72 FD BD F8 24 10 01 25 08 44 AD F8 24 00 DB E0 3A 46 21 46 08 A8 F8 F7 9B F9 D4 E0 0F F2 10 18 10 7D 00 F0 0F 07 1B E0 0A AA 05 A9 31 98 11 F0 77 FF 9D F8 14 00 40 42 C0 1B 40 B2 00 28 12 DA 40 42 C0 B2 FF F7 7D F9 0A 99 48 43 21 68 48 43 06 23 00 97 07 90 93 E0 0F F2 D8 08 10 7D 07 09 06 2F E1 D3 AA E7 C0 B2 FF F7 6B F9 21 68 0A 9A 51 43
9:08:08 AM
9:08:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 45 09 81 80 B1 FB F0 F0 EB E7 0F F2 BC 08 01 25 0A AA 05 A9 31 98 11 F0 4C FF 9D F8 14 00 C0 F1 FF 30 86 E0 40 42 C0 B2 FF F7 54 F9 0A 99 48 43 21 68 48 43 04 23 00 95 07 90 6A E0 2A 76 61 72 68 00 00 00 2A 6B 76 61 72 68 00 00 2A 4D 76 61 72 68 00 00 2A 47 76 61 72 68 00 00 2A 76 61 72 00 00 00 00 2A 6B 76 61 72 00 00 00 2A 4D 76 61 72 00 00 00 2A 47 76 61 72 00 00 00 2A 56 41 68 00 00 00 00
9:08:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 46 09 81 80 2A 6B 56 41 68 00 00 00 2A 4D 56 41 68 00 00 00 2A 47 56 41 68 00 00 00 2A 56 41 00 2A 6B 56 41 00 00 00 00 2A 4D 56 41 00 00 00 00 2A 47 56 41 00 00 00 00 25 30 38 6C 58 00 00 00 2A 41 00 00 2A 56 00 00 2A 48 7A 00 0F F2 EC 48 01 25 0A AA 05 A9 31 98 11 F0 EB FE 9D F8 14 00 C0 F1 FF 30 40 B2 00 28 08 DA 40 42 C0 B2 FF F7 F1 F8 0A 99 48 43 21 68 48 43 07 E0 C0 B2 FF F7 E9 F8 21 68
9:08:09 AM
9:08:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 47 09 81 80 0A 9A 51 43 B1 FB F0 F0 03 23 00 95 07 90 05 22 01 46 08 A8 F8 F7 87 FA 1C E0 03 25 0A AA 05 A9 31 98 11 F0 C4 FE 9D F8 14 00 40 42 C0 1E 40 B2 00 28 FF F6 75 AF C0 B2 FF F7 CA F8 21 68 0A 9A 51 43 B1 FB F0 F0 73 E7 21 46 06 2F 03 D1 08 A8 F8 F7 DC F9 05 46 40 98 C0 B1 40 46 BF F7 60 F8 01 28 0B D9 08 F1 01 04 40 46 BF F7 59 F8 40 1E 82 B2 21 46 32 98 F8 F7 90 F8 05 46 AF F2 24 11
9:08:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 48 09 81 80 40 46 D6 F7 6B FF A8 B9 01 25 13 E0 BD F8 24 20 00 20 AD F8 24 00 08 A9 32 98 C6 F7 C6 FD 3F 98 40 B1 40 46 BF F7 3C F8 82 B2 41 46 32 98 F8 F7 74 F8 05 46 55 EA 06 00 11 D0 66 B1 32 98 C6 F7 5A FD 32 46 FD A1 D6 F7 55 FC 32 99 01 25 89 88 08 44 32 99 88 80 35 B0 28 46 BD E8 F0 8F 0B 26 EC E7 2D E9 FC 41 16 46 8D 19 6D 1E 07 46 00 24 16 E0 02 22 69 46 38 46 C6 F7 7E FD 00 28 08 D0
9:08:10 AM
9:08:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 49 09 81 80 01 AA AF F6 30 31 68 46 BF F7 48 FB 01 28 02 D0 00 20 BD E8 FC 81 01 98 64 1C 05 F8 01 09 A4 B2 B4 42 E6 D3 01 20 F4 E7 2D E9 F0 41 86 B0 00 24 0C 9E 07 46 88 46 15 46 34 80 03 A8 18 2B 60 D2 DF E8 03 F0 5F 0C 2F 33 42 4E 1D 42 5F 42 42 42 42 5F 5F 5F 5F 5F 5F 5F 5F 5F 5F 56 38 46 C6 F7 1D FD A8 42 04 D2 38 46 C6 F7 18 FD 04 46 00 E0 2C 46 22 46 41 46 38 46 F8 F7 20 F8 3F E0 00 90
9:08:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 4A 09 81 80 05 AB 01 AA 04 A9 38 46 F8 F7 E7 FA 00 28 3B D0 29 46 40 46 04 9A FF F7 EA FA 00 28 34 D0 2C 46 2F E0 03 20 02 E0 0A 24 18 E0 02 20 8D F8 04 00 F8 88 AD F8 08 00 02 AB 01 AA 41 46 38 46 F8 F7 43 FB 00 28 20 D0 EE E7 00 90 05 AB 01 AA 41 46 38 46 F8 F7 C2 FA 00 28 16 D0 04 24 34 80 12 E0 F8 88 41 46 44 08 22 46 38 46 F8 F7 12 F8 06 E0 F8 88 41 46 44 08 22 46 38 46 FF F7 72 FF 00 28
9:08:11 AM
9:08:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 4B 09 81 80 02 D0 34 80 1C B1 01 20 06 B0 BD E8 F0 81 00 20 FA E7 2D E9 F0 43 AD F2 4C 5D 05 46 89 46 16 46 68 46 15 F0 7D FC 07 27 B8 B1 03 24 4F EA 0D 08 04 EB C4 01 08 EB 41 00 00 F2 5A 20 02 88 10 2A 00 D9 10 22 B2 42 04 D1 49 46 80 1C BE F7 BC FD 50 B1 64 1E 24 B2 00 2C EA DA 85 F8 37 70 00 20 0D F2 4C 5D BD E8 F0 83 64 1C 85 F8 37 40 01 20 F6 E7 38 B5 04 46 00 68 4F F0 00 05 41 7B 8A 07
9:08:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 4C 09 81 80 11 D5 00 68 16 30 BE F7 4B FF 08 28 01 D9 08 20 04 E0 20 68 00 68 16 30 BE F7 42 FF 82 B2 20 68 01 68 16 31 12 E0 C9 07 14 D0 00 68 0D 30 BE F7 37 FF 08 28 01 D9 08 20 04 E0 20 68 00 68 0D 30 BE F7 2E FF 82 B2 20 68 01 68 0D 31 20 46 FF F7 A0 FF 01 E0 84 F8 37 50 69 46 14 20 CC F7 98 F8 10 B9 01 20 AD F8 00 00 17 F0 5C FF 08 B9 AD F8 00 50 BD F8 00 00 00 28 08 D1 94 F8 37 10 05 20
9:08:12 AM
9:08:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 4D 09 81 80 07 29 01 D0 04 29 02 D0 84 F8 37 00 38 BD 06 20 FA E7 10 B5 88 B0 04 46 E1 B1 0A 78 10 2A 38 D0 0C DC A2 F1 03 02 0D 2A 14 D2 DF E8 02 F0 16 18 1D 2B 13 13 18 18 13 13 2F 13 2F 00 15 2A 09 D0 06 DC 11 2A 2A D0 12 2A 2A D0 13 2A 02 D1 2B E0 16 2A 02 D0 00 20 08 B0 10 BD 0A 79 1B E0 09 1D 20 46 FF F7 14 F8 22 E0 4A 68 AF F6 80 51 68 46 D6 F7 00 FB 01 B2 E1 B1 8A B2 69 46 20 46 C6 F7
9:08:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 4E 09 81 80 24 FC 14 E0 4A 68 AF F6 94 51 F0 E7 91 F9 04 20 01 E0 B1 F9 04 20 AF F6 B4 51 E8 E7 0A 79 00 E0 8A 88 AF F6 A8 51 E2 E7 09 1D FF F7 1A F8 00 28 D1 D0 01 20 CF E7 3E B5 04 46 90 F8 30 10 14 30 F0 F7 BA FB 01 00 21 D0 0E 22 04 F1 60 00 BE F7 27 FD 60 69 C4 F8 62 00 21 8B A4 F8 66 10 94 F8 68 10 AD F8 00 10 CD F8 02 00 B4 F8 66 00 AD F8 06 00 94 F8 BC 00 8D F8 08 00 69 46 04 F1 34 00
9:08:13 AM
9:08:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 4F 09 81 80 F0 F7 BF FC 00 28 00 D0 01 20 3E BD 17 20 A4 F8 D0 02 00 20 3E BD 30 B5 A5 B0 04 46 0D 46 80 22 69 46 23 A8 C6 F7 78 FB 23 AA 20 A9 04 F1 34 00 F1 F7 11 FB 00 28 06 D0 20 A9 28 46 FF F7 69 FF 00 28 00 D0 01 20 25 B0 30 BD 10 B5 00 23 00 F8 70 3F 03 71 51 EA 02 03 01 D0 01 23 03 70 C1 60 0A B1 02 61 01 E0 17 49 01 61 48 F2 10 01 01 81 FF 22 10 21 14 30 BF F7 C4 FA 01 20 10 BD 2D E9
9:08:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 50 09 81 80 F0 43 9D B0 07 46 06 6A 1E 22 20 21 0A A8 BF F7 B8 FA 00 20 01 90 00 90 3B 21 30 46 BE F7 5F FE 04 00 6E D0 A2 1B 30 46 4F F0 0B 08 4F F0 04 09 0B 2A 09 D0 02 B3 6E E0 2A 25 00 00 45 52 25 30 32 64 00 00 7F 49 50 F4 01 46 0A A8 BE F7 A8 FC 8D F8 6C 90 42 46 AD F8 70 80 0A A9 13 A8 C6 F7 1B FB 1C AB 1B AA 15 A9 13 A8 F8 F7 AD F9 18 B1 69 46 15 A8 C6 F7 72 F8 3B 21 60 1C BE F7 2F FE
9:08:14 AM
9:08:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 51 09 81 80 05 00 01 D0 28 1B 04 E0 29 21 30 46 BE F7 27 FE 00 1B 40 1E 0B 28 01 D0 08 B3 3C E0 D4 F8 01 00 02 90 D4 F8 05 00 03 90 B4 F8 09 00 AD F8 10 00 E0 7A 8D F8 12 00 8D F8 6C 90 42 46 AD F8 70 80 02 A9 13 A8 C6 F7 E8 FA 1C AB 1B AA 18 A9 13 A8 F8 F7 7A F9 18 B1 01 A9 18 A8 C6 F7 3F F8 85 B1 29 21 30 46 BE F7 FB FD 40 1B 40 1E 04 28 12 DA 12 AA FE A1 28 46 BF F7 11 F9 BD F8 48 00 A7 F8
9:08:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 52 09 81 80 C8 02 DD E9 00 12 38 46 FF F7 5F FF 00 28 00 D0 01 20 1D B0 66 E6 00 20 FB E7 70 B5 0C 46 00 21 21 70 0A 46 01 68 06 23 4F F6 FF 75 03 EB 42 00 08 5A 20 F0 78 00 A8 42 10 D0 A0 F5 9A 46 87 2E 08 D8 20 F0 78 00 F0 F7 2B FB 80 79 40 1E 20 70 01 20 70 BD 52 1C D2 B2 20 2A E7 D3 00 20 70 BD 20 F0 78 01 40 F2 04 42 A1 F2 04 40 91 42 1F D0 07 DC 08 29 1A D2 DF E8 01 F0 19 1B 1B 1B 1B 1B
9:08:15 AM
9:08:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 53 09 81 80 1B 1B 41 F2 FE 42 81 1A 90 42 11 D0 08 DC 01 28 0E D0 A0 F5 A0 50 FC 38 0A D0 01 28 06 D1 07 E0 01 29 05 D0 A1 F5 CC 41 FE 39 01 D0 00 20 70 47 01 20 70 47 00 7C 52 28 01 D0 01 20 70 47 00 20 70 47 00 21 01 74 41 74 70 47 01 46 00 20 89 1E 0D 29 09 D2 DF E8 01 F0 07 07 08 08 08 08 07 07 07 07 07 07 07 00 01 20 70 47 01 46 00 20 0F 29 0A D2 DF E8 01 F0 08 08 08 08 09 09 09 08 08 08
9:08:16 AM
9:08:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 54 09 81 80 08 08 08 08 08 00 01 20 70 47 2D E9 F7 4F AD F5 9E 6D 4F F0 00 0B CD F8 D4 B4 CD F8 D8 B4 B0 F8 60 00 0A F0 FF FA 05 46 0B F0 E1 FE 07 46 28 46 0B F0 EC FE 00 2F 65 D0 00 28 63 D0 0D F2 D4 40 CD F8 0C 04 03 AC 20 21 B4 38 BE F7 46 FC 01 20 CD F8 C4 04 80 22 0D F2 44 41 0D F2 CC 40 C6 F7 1B FA 28 46 0A F0 6D FB 00 25 4F F0 06 0A 09 E0 3A 68 0A EB 45 01 52 5A A2 F5 7F 41 FF 39 03 D0
9:08:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 55 09 81 80 6D 1C AD B2 85 42 F3 D3 00 20 06 46 CD F8 E8 04 7A E0 00 BF 39 68 0A EB 46 00 08 5A 80 46 FF F7 5F FF 00 B1 01 20 A8 F5 7F 41 81 46 FF 39 01 D1 4F F0 01 09 80 21 DD F8 CC 04 BE F7 35 FC AD F8 D0 B4 B9 F1 00 0F 5D D1 28 F0 78 00 F0 F7 68 FA 81 46 40 46 FE F7 D2 FF 02 46 B9 F1 00 0F 11 D0 41 46 10 46 FE F7 E5 FF 03 A9 61 1A 40 F2 E2 33 0D F5 84 62 99 42 09 D9 7E A1 20 46 D6 F7 FA F8
9:08:17 AM
9:08:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 56 09 81 80 04 44 43 E0 00 20 0D F2 FC 4D A6 E4 01 23 DD F8 C4 14 8D E8 0B 00 00 23 0D F2 CC 41 40 46 FE F7 F5 FF 00 28 54 D0 DD F8 0C 04 C0 F8 00 B0 C0 F8 04 B0 BD F8 D0 24 08 2A 05 D2 DD F8 CC 14 DD F8 0C 04 BE F7 2D FB 99 F8 06 00 48 B1 DD F8 0C 14 CD E9 00 01 99 F8 05 30 99 F8 04 20 69 A1 07 E0 DD F8 0C 04 00 90 99 F8 05 30 99 F8 04 20 69 A1 20 46 D6 F7 BF F8 04 44 DD F8 E8 04 40 1C C0 B2
9:08:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 57 09 81 80 CD F8 E8 04 76 1C B6 B2 AE 42 83 D3 0D F5 9C 65 63 49 28 46 DD F8 E8 24 D6 F7 AC F8 28 44 29 46 40 1A 82 B2 DD F8 F4 04 C6 F7 CF F9 00 28 AA D0 5C A1 20 46 D6 F7 9E F8 20 44 03 A9 40 1A 82 B2 DD F8 F4 04 C6 F7 C1 F9 00 28 9C D0 01 20 9A E7 99 F8 06 00 00 90 99 F8 05 30 99 F8 04 20 52 A1 C6 E7 F0 B5 A7 B0 04 46 00 20 22 90 23 90 0F 46 B4 F8 60 00 0A F0 16 FA 06 46 0B F0 F8 FD 05 46
9:08:18 AM
9:08:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 58 09 81 80 30 46 0B F0 03 FE 00 2D 49 D0 00 28 47 D0 24 A9 D4 F8 C8 00 C5 F7 3E FF 01 22 47 A1 38 46 F7 F7 7C FC 00 28 39 D0 0C 23 04 22 24 A9 38 46 F7 F7 A7 FD 00 28 31 D0 01 22 2D A1 38 46 F7 F7 6D FC 00 28 2A D0 28 68 3C 21 01 AE 00 68 00 22 B0 FB F1 F3 01 20 00 90 39 A1 30 46 D6 F7 4B F8 06 44 60 7D 21 A9 40 1E C4 B2 28 46 FF F7 56 FE 00 28 13 D0 22 A8 9D F8 84 30 00 90 5B 1C 62 1C 33 A1
9:08:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 59 09 81 80 30 46 D6 F7 37 F8 30 44 01 A9 40 1A 82 B2 38 46 C6 F7 5B F9 00 28 00 D0 01 20 27 B0 F0 BD 00 20 FB E7 7F B5 0E 46 14 46 B0 F8 60 00 0A F0 BA F9 0B F0 9D FD 00 68 01 22 1F A1 C5 88 20 46 F7 F7 2C FC 00 28 65 D0 00 20 00 90 01 23 06 22 02 21 20 46 F7 F7 E8 FD 00 28 5B D0 01 22 04 A1 20 46 F7 F7 1B FC 00 28 54 D0 12 22 3B E0 3B 25 68 75 29 00 00 00 21 6F 75 74 20 6F 66 20 62 75 66 21
9:08:19 AM
9:08:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 5A 09 81 80 00 00 00 00 28 25 64 2E 25 64 2E 25 64 29 28 25 73 29 00 00 28 25 64 2E 25 64 29 28 25 73 29 00 7C 19 04 00 0D 0A 00 00 28 25 64 2E 25 64 2E 25 64 29 28 29 00 00 00 00 28 00 00 00 28 25 30 32 75 29 28 25 75 29 28 25 75 29 00 00 28 30 2D 25 64 3A 32 34 2E 32 2E 25 64 29 28 25 73 29 0D 0A 00 00 00 00 FD A1 20 46 F7 F7 D7 FB 00 28 10 D0 B1 68 01 F1 0C 03 08 7B 12 28 04 D1 98 88 A0 F5
9:08:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 5B 09 81 80 00 42 40 3A 04 D1 25 F0 78 00 B0 F5 00 4F 02 D0 00 20 04 B0 70 BD 08 78 09 28 3D D1 31 F8 04 0F 0C 28 3B D1 48 68 01 A9 E5 F7 6B FB 01 22 AF F2 78 01 20 46 F7 F7 B1 FB 00 28 EA D0 07 23 03 22 01 A9 20 46 F7 F7 DC FC 00 28 E2 D0 01 22 AF F2 E0 01 20 46 F7 F7 A1 FB 00 28 DA D0 01 22 AF F2 A8 01 20 46 F7 F7 99 FB 00 28 D2 D0 07 23 02 22 01 A9 20 46 F7 F7 C4 FC 00 28 CA D0 01 22 AF F2
9:08:20 AM
9:08:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 5C 09 81 80 10 11 20 46 F7 F7 89 FB 00 28 C2 D0 02 22 AF F2 EC 01 20 46 F7 F7 81 FB 00 28 BA D0 01 20 B8 E7 2D E9 FF 4F C1 B0 05 46 0C 46 98 46 20 21 22 A8 DD F8 38 91 BE F7 51 FA D5 F8 E0 02 01 90 22 AE 80 21 02 A8 BE F7 49 FA 80 22 02 A9 2A A8 C6 F7 23 F8 B5 F8 60 00 0A F0 E5 F8 00 90 0B F0 C7 FC 00 68 00 27 B8 F1 00 0F C1 88 D0 F8 00 A0 38 91 00 89 3F 90 A4 68 02 D0 00 20 A8 F8 00 00 B9 F1
9:08:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 5D 09 81 80 00 0F 02 D0 00 20 89 F8 00 00 00 98 FF F7 9D FD 83 46 00 98 FF F7 A9 FD 30 B1 05 F1 14 01 2A A8 F7 F7 74 FC 00 28 7D D0 38 98 20 F0 78 00 B0 F5 00 4F 22 D0 27 78 01 22 AF F2 84 11 2A A8 F7 F7 2C FB 00 28 6E D0 2A 22 A9 A1 2A A8 F7 F7 25 FB 00 28 67 D0 00 20 00 90 04 23 06 22 39 46 2A A8 F7 F7 E1 FC 00 28 5D D0 01 22 AF F2 FC 11 2A A8 F7 F7 13 FB 00 28 55 D0 08 E0 20 78 09 28 01 D0
9:08:21 AM
9:08:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 5E 09 81 80 28 B3 5D E0 A1 88 20 1D 0C 29 01 D0 01 27 57 E0 40 68 3B A9 E5 F7 B5 FA 01 A9 3B A8 C5 F7 1E FD 01 98 01 22 AF F2 F0 11 C5 F8 E0 02 2A A8 F7 F7 F4 FA 00 28 36 D0 BB F1 00 0F 01 D0 0C 23 00 E0 0A 23 04 22 3B A9 2A A8 F7 F7 1A FC CA E7 01 22 AF F2 1C 21 2A A8 F7 F7 E0 FA 00 28 22 D0 38 A9 01 98 C5 F7 97 FD 3E AA 2C A9 38 A8 C5 F7 12 FE 01 99 01 EB 0A 00 38 A9 01 90 C5 F7 8B FD 3E AA
9:08:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 5F 09 81 80 2F A9 38 A8 C5 F7 06 FE 01 98 C5 F8 E0 02 9D F8 BF 00 9D F8 B3 10 88 42 00 D0 01 27 0A 23 04 22 38 A9 00 E0 7D E0 2A A8 F7 F7 EA FB 00 28 78 D0 01 22 AF F2 C4 21 2A A8 F7 F7 AF FA 00 28 70 D0 0C 34 3F 98 FF F7 CC FC 01 00 4F F0 3C 00 02 D0 21 78 12 29 08 D0 00 22 BB F1 00 0F 3E D0 6F A1 30 46 D5 F7 87 FE 40 E0 A4 88 BB F1 00 0F 1C D0 22 46 6D A1 30 46 D5 F7 7D FE 30 44 22 A9 40 1A
9:08:22 AM
9:08:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 60 09 81 80 82 B2 2A A8 C5 F7 A1 FF 00 28 4A D0 20 2C 36 D1 34 A8 17 F0 E6 FA 9D F8 D0 00 80 BB B9 F1 00 0F 2D D0 02 21 89 F8 00 10 29 E0 BA FB F0 F3 E2 B2 60 A1 30 46 D5 F7 5E FE 30 44 22 A9 40 1A 82 B2 2A A8 C5 F7 82 FF 00 28 2B D0 B5 F8 CA 02 A5 F8 CA 42 00 06 B0 EB 04 6F 11 D1 0F E0 BA FB F0 F3 00 22 54 A1 30 46 D5 F7 45 FE 30 44 22 A9 40 1A 82 B2 2A A8 C5 F7 69 FF 00 28 12 D0 87 B1 BD F8
9:08:23 AM
9:08:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 61 09 81 80 AC 20 00 20 AD F8 AC 00 2A A9 43 98 C5 F7 8D FF 00 28 06 D0 B8 F1 00 0F 02 D0 01 21 A8 F8 00 10 01 20 45 B0 BD E8 F0 8F 2D E9 F7 4F 84 B0 0C 46 B0 F8 60 00 09 F0 B6 FF 05 46 0B F0 98 FB 80 46 A4 68 28 46 0A F0 3D F8 07 46 00 25 41 E0 D8 F8 00 10 06 20 00 EB 45 00 0E 5A A6 F5 7F 40 FF 38 39 D0 30 46 FF F7 3C FC 80 BB 4F F0 08 0B 04 F1 04 0A 30 46 FE F7 C2 FC 31 46 FE F7 DA FC 5F EA
9:08:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 62 09 81 80 00 09 5D D0 B9 F1 06 0F 5A D0 20 78 09 28 5C D0 0A 28 5A D0 01 22 AF F2 E0 31 06 98 F7 F7 FD F9 00 28 19 D0 00 20 CD E9 00 90 02 90 5B 46 52 46 30 46 06 99 FE F7 EA FC 00 28 0D D0 01 22 AF F2 50 41 06 98 F7 F7 E9 F9 00 28 05 D0 0C 34 6D 1C AD B2 BD 42 BB D3 01 20 07 B0 A3 E7 28 30 2E 39 2E 31 29 28 29 28 30 2E 39 2E 32 29 28 29 00 00 45 52 52 2C 20 4F 42 49 53 5F 4F 42 4A 45 43 54
9:08:24 AM
9:08:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 63 09 81 80 5F 49 44 5F 43 4C 4F 43 4B 20 65 78 70 65 63 74 65 64 2E 20 54 79 70 65 3D 20 00 00 28 25 30 32 78 29 28 29 00 00 00 00 28 25 30 34 78 29 28 29 00 00 00 00 28 25 30 32 78 29 28 25 75 29 00 00 21 46 06 98 FF F7 65 FA BE E7 B4 F8 04 B0 D4 F8 08 A0 9F E7 10 B5 04 46 00 F1 BC 01 24 22 00 F5 C0 70 BE F7 48 F8 D4 F8 94 00 C4 F8 C8 01 D4 F8 E0 02 C4 F8 E8 02 B4 F8 CA 02 A4 F8 CE 02 01 20
9:08:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 64 09 81 80 10 BD 10 B5 04 46 00 F5 C0 71 24 22 BC 30 BE F7 32 F8 D4 F8 C8 01 C4 F8 94 00 D4 F8 E8 02 C4 F8 E0 02 B4 F8 CE 02 A4 F8 CA 02 01 20 10 BD 10 B5 04 46 00 F1 BC 01 24 22 00 F5 D2 70 BE F7 1B F8 D4 F8 94 00 C4 F8 CC 01 D4 F8 E0 02 C4 F8 E4 02 B4 F8 CA 02 A4 F8 CC 02 01 20 10 BD 10 B5 04 46 00 F5 D2 71 24 22 BC 30 BE F7 05 F8 D4 F8 CC 01 C4 F8 94 00 D4 F8 E4 02 C4 F8 E0 02 B4 F8 CC 02
9:08:25 AM
9:08:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 65 09 81 80 A4 F8 CA 02 01 20 10 BD B0 F8 C4 12 49 1C 89 B2 A0 F8 C4 12 B0 F8 C8 22 91 42 0C D3 0B 21 C1 80 B0 F8 BC 12 41 F0 08 01 A0 F8 BC 12 00 21 A0 F8 C4 12 01 20 70 47 00 20 70 47 2D E9 F0 41 AD F5 84 6D 04 46 0D 46 00 26 8D F8 18 64 4F F4 80 62 01 A9 0D F5 82 60 C5 F7 DF FD B4 F8 C8 02 28 B1 B4 F8 C4 02 10 B9 20 46 FF F7 74 FF 04 F1 34 00 D4 F8 94 10 80 46 01 27 91 B9 0D F5 82 62 0D F2
9:08:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 66 09 81 80 04 41 EA F7 43 FC 00 28 7E D0 BD F8 08 04 70 B1 AD F8 14 64 BD F8 16 14 DD F8 10 04 BE F7 04 F8 B4 F8 C8 02 80 B1 B4 F8 C4 02 38 B1 0C E0 84 F8 98 70 26 21 28 46 F7 F7 33 FC 46 E0 B4 F8 BC 02 40 F0 04 00 A4 F8 BC 02 0D F5 82 62 0D F2 04 41 40 46 EA F7 1B FC 00 28 56 D0 BD F8 08 04 28 B3 0D F5 83 60 03 1D 00 90 2A 46 0D F2 04 41 20 46 FF F7 56 FD 00 28 71 D0 9D F8 18 04 78 B1 0D F5
9:08:26 AM
9:08:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 67 09 81 80 82 62 0D F2 04 41 40 46 EA F7 00 FC 00 28 65 D0 2A 46 0D F2 04 41 20 46 FF F7 83 FC A0 B3 BD F8 1C 04 D0 B1 9D F8 18 04 88 B1 16 E0 01 22 AF F2 78 61 28 46 F7 F7 B1 F8 30 B3 84 F8 98 70 01 22 AF F2 D4 61 28 46 F7 F7 A8 F8 E8 B1 38 E0 00 22 29 46 20 46 FF F7 19 FB B0 B1 9D F8 04 04 B5 F8 04 80 02 28 06 D1 2A 46 0D F2 04 41 20 46 FF F7 5B FE 48 B1 A9 88 41 45 09 D0 02 22 AF F2 DC 61
9:08:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 68 09 81 80 28 46 F7 F7 8A F8 00 E0 28 E0 00 28 19 D0 94 F8 BD 00 08 B1 84 F8 98 70 E8 88 A9 88 B0 EB 81 0F B4 F8 C8 02 07 D2 18 B1 20 46 FF F7 2D FF 38 B9 0A 20 E0 80 04 E0 40 B1 20 46 FF F7 25 FF 20 B1 01 20 0D F5 84 6D BD E8 F0 81 AD F8 14 64 BD F8 16 14 DD F8 10 04 BD F7 67 FF F1 E7 AE 80 84 F8 98 70 00 20 ED E7 2D E9 F0 43 A5 B0 81 46 88 46 14 46 1E 46 80 21 03 A8 2C 9F BD F7 2E FF 23 A8
9:08:27 AM
9:08:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 69 09 81 80 00 90 23 46 80 22 03 A9 48 46 07 F0 17 FD BD F8 8C 10 08 43 35 D0 48 46 07 F0 E8 FC 00 28 2D D0 40 88 BD F8 8C 40 00 F4 78 41 03 AD B1 F5 00 4F 07 D1 BD F8 0C 40 AD 1C C0 F3 0A 00 A0 42 00 D2 04 46 01 22 AF F2 90 71 40 46 F7 F7 26 F8 00 28 14 D0 00 20 00 96 CD E9 01 70 23 46 2A 46 41 46 48 46 FE F7 13 FB 00 28 08 D0 01 22 AF F6 00 01 40 46 F7 F7 12 F8 00 28 00 D0 01 20 25 B0 BD E8
9:08:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 6A 09 81 80 F0 83 17 21 40 46 F7 F7 4B FB F4 E7 2D E9 F7 4F A8 B0 4F F0 00 0A A0 F8 08 A0 04 46 0E 46 B0 F8 C2 B2 15 46 80 21 03 A8 BD F7 D7 FE 03 A8 26 90 40 F6 34 02 23 A8 E1 68 C5 F7 AE FC FD B1 04 F1 14 01 23 A8 F7 F7 22 F9 00 28 37 D0 20 7C 52 28 15 D0 01 22 FB A1 23 A8 C5 F7 F7 FC 00 28 2D D0 58 46 E1 F7 25 FB 02 46 F7 A1 25 A8 D5 F7 C2 FB 82 B2 25 A9 23 A8 C5 F7 E8 FC 00 28 1E D0 01 22
9:08:28 AM
9:08:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 6B 09 81 80 AF F6 4C 01 23 A8 F6 F7 C8 FF 00 28 16 D0 80 22 59 46 30 46 26 9B 10 F0 96 FF 26 F0 78 01 4F F4 00 48 4F F0 01 09 41 45 0A D0 30 B1 02 28 07 D0 01 28 11 D0 03 28 7D D0 87 E0 01 20 2B B0 71 E5 A6 F5 B8 50 17 38 3A D1 80 22 59 46 30 46 26 9B 10 F0 F2 FF 00 28 70 D0 30 46 07 F0 47 FC 00 28 EC D0 41 88 03 AF 01 F4 78 40 C1 F3 0A 05 40 45 05 D1 BD F8 0C 00 BF 1C 85 42 00 D3 05 46 30 46
9:08:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 6C 09 81 80 FE F7 3C FA 80 46 8D E8 00 07 2B 46 3A 46 23 A9 30 46 FE F7 7B FA 00 28 D0 D0 01 22 AF F6 30 11 23 A8 F6 F7 7A FF 00 28 C8 D0 40 46 B8 F1 07 0F 1C D0 0A 28 1A D0 B8 F1 0C 0F 46 D1 16 E0 01 22 AF F6 54 11 23 A8 F6 F7 68 FF 00 28 B6 D0 20 7C 52 28 07 D0 02 22 AF F6 34 11 23 A8 F6 F7 5D FF 00 28 AB D0 BD F8 90 00 20 81 A6 E7 94 F8 65 00 06 28 2A D1 B4 F8 60 00 13 26 40 F0 28 00 29 90
9:08:29 AM
9:08:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 6D 09 81 80 80 22 59 46 26 9B 10 F0 1E FF 80 46 01 22 AF F6 58 11 23 A8 F6 F7 41 FF 00 28 8F D0 B8 F1 01 0F 0B D1 8D E8 40 06 2B 46 3A 46 23 A9 29 98 FE F7 2D FA 00 E0 01 E0 00 28 80 D0 01 22 AF F6 D0 11 23 A8 F6 F7 2A FF 00 28 8A D0 20 7C 52 28 07 D0 02 22 AF F6 B0 11 23 A8 F6 F7 1F FF 00 28 9B D0 84 F8 98 90 BE E7 2D E9 F0 4F 04 46 B0 F8 D2 02 A5 B0 0D 46 93 46 4F F0 00 09 08 B1 0D 20 00 E0
9:08:30 AM
9:08:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 6E 09 81 80 0A 20 E0 80 00 26 26 81 40 F6 34 02 01 A8 E1 68 C5 F7 C2 FB C5 B1 BB F1 00 0F 15 D0 D4 F8 94 00 90 B9 94 F8 68 00 04 F1 14 07 07 28 06 D1 B4 F8 60 00 09 F0 77 FC FF F7 58 F9 28 B9 39 46 01 A8 F7 F7 24 F8 00 28 7C D0 94 F8 37 00 94 F8 BC 10 00 F0 07 0A B4 F8 60 00 40 EA C1 0C 60 46 FE F7 8D F9 07 46 AD F8 8C 60 94 F8 68 00 B0 46 07 28 0A D0 01 26 46 28 14 D0 60 7E E8 B1 FF 28 1B D0
9:08:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 6F 09 81 80 A4 F8 C2 02 5A 46 1B E0 01 A9 20 46 FF F7 95 FD 00 28 7D D1 17 21 01 A8 F7 F7 02 FA 00 28 50 D0 76 E0 01 A9 20 46 FE F7 F6 FF 00 28 6E D1 17 21 01 A8 F7 F7 F5 F9 67 E0 B4 F8 C2 02 38 B1 01 22 61 46 20 46 FF F7 A2 FE 84 F8 98 60 73 E0 3B 46 52 46 01 A9 60 46 00 95 FF F7 45 FE 00 28 6B D0 07 2F 03 D0 0A 2F 01 D0 0C 2F 4F D1 B4 F8 60 00 13 23 40 F0 28 07 94 F8 65 00 06 28 02 D0 04 28
9:08:31 AM
9:08:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 70 09 81 80 07 D0 43 E0 52 46 01 A9 38 46 00 95 FF F7 2B FE 3C E0 80 21 03 A8 BD F7 60 FD 23 A8 00 90 53 46 80 22 03 A9 38 46 07 F0 49 FB BD F8 8C 10 08 43 05 D0 B4 F8 60 00 24 A9 10 F0 DA FE 81 46 01 22 00 E0 39 E0 AF F6 10 31 01 A8 F6 F7 66 FE 00 28 32 D0 03 23 06 22 49 46 01 A8 CD F8 00 80 F7 F7 22 F8 00 28 28 D0 BD F8 90 00 10 B1 04 22 38 A1 01 E0 02 22 38 A1 01 A8 F6 F7 4F FE 01 22 AF F6
9:08:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 71 09 81 80 90 31 01 A8 F6 F7 49 FE 00 28 15 D0 84 F8 98 60 75 B1 94 F8 68 00 07 28 0A D0 20 7C 52 28 07 D0 02 22 AF F6 80 31 01 A8 F6 F7 37 FE 00 28 03 D0 BD F8 08 00 20 81 01 20 25 B0 BD E8 F0 8F 0A 46 11 E7 70 B5 04 46 98 B0 0A 20 E0 80 00 20 20 81 62 8D 14 A8 21 6A C5 F7 DF FA B4 F8 60 00 94 F8 BC 10 40 EA C1 05 28 46 FE F7 C8 F8 06 46 28 46 07 F0 BC FA 00 28 05 D0 40 88 C0 F3 0A 02 40 2A
9:08:32 AM
9:08:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 72 09 81 80 02 D9 00 20 18 B0 70 BD 11 A8 00 90 33 46 01 A9 14 A8 FE F7 C9 FD 00 28 F4 D0 94 F8 37 00 38 21 01 EA C0 03 16 A8 00 90 BD F8 44 20 01 A9 28 46 07 F0 22 FB 00 28 E5 D0 04 F1 34 00 F0 F7 8B FA 01 20 DF E7 2A 00 00 00 25 30 32 64 00 00 00 00 2A 6D 69 6E 00 00 00 00 2A 25 00 00 2D E9 F0 43 04 46 C3 B0 04 20 81 46 01 A9 0A F0 A6 FE 00 28 0D D0 48 46 09 F0 E5 FB A1 88 01 26 00 25 01 AA
9:08:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 73 09 81 80 01 29 06 D0 06 29 15 D0 02 29 2F D0 00 20 43 B0 B5 E5 A4 F8 D2 52 C4 F8 B4 52 A4 F8 C0 52 BD F8 0A 00 60 82 20 46 FE F7 0E F8 00 28 EF D0 A4 F8 C2 52 0D E0 A4 F8 D2 62 C4 F8 B4 52 A4 F8 C0 52 BD F8 0A 00 60 82 20 46 FD F7 FD FF 00 28 DE D0 20 46 FE F7 B0 FE 00 28 D9 D0 01 21 20 46 FF F7 6E FF 00 28 D3 D0 A4 F8 BC 62 2E E0 B4 F8 C0 12 02 27 4F F0 03 08 81 42 1F D2 02 EB 41 00 C0 88
9:08:33 AM
9:08:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 74 09 81 80 A0 F5 7F 41 FF 39 18 D0 60 82 D4 F8 94 00 48 B9 20 46 FD F7 D8 FF 00 28 B9 D0 20 46 FE F7 8B FE 00 28 B4 D0 01 21 20 46 FF F7 49 FF 00 28 AE D0 84 F8 98 60 A4 F8 BC 52 07 E0 F8 A1 E0 68 BD F7 95 FC A4 F8 08 80 A4 F8 BC 72 B4 F8 BC 02 00 90 23 89 E1 88 E2 68 20 68 FD F7 B5 FB 94 F8 98 00 48 B1 04 F2 C2 22 00 23 91 1E 48 46 E1 F7 1A F9 C4 F8 94 50 04 E0 D4 F8 94 00 40 1C C4 F8 94 00
9:08:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 75 09 81 80 D4 F8 B4 02 40 1C C4 F8 B4 02 01 20 7F E7 F0 B5 C3 B0 04 46 01 A9 04 20 0A F0 0F FE 00 28 0D D0 04 20 09 F0 4E FB A1 88 01 26 00 25 01 AA 01 29 06 D0 06 29 07 D0 02 29 21 D0 00 20 43 B0 F0 BD A4 F8 D2 52 01 E0 A4 F8 D2 62 C4 F8 B4 52 A4 F8 C0 52 BD F8 0A 00 60 82 20 46 FD F7 74 FF 00 28 EC D0 20 46 FE F7 27 FE 00 28 E7 D0 01 21 20 46 FF F7 E5 FE 00 28 E1 D0 A4 F8 BC 62 22 E0 B4 F8
9:08:34 AM
9:08:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 76 09 81 80 C0 12 02 26 03 27 81 42 30 D2 02 EB 41 00 C0 88 A0 F5 7F 41 FF 39 29 D0 D4 F8 94 10 51 B9 60 82 20 46 FD F7 50 FF 00 28 C8 D0 20 46 FE F7 03 FE 00 28 C3 D0 01 21 20 46 FF F7 C1 FE 00 28 BD D0 A4 F8 BC 52 B4 F8 BC 02 00 90 23 89 E1 88 E2 68 20 68 FD F7 38 FB 94 F8 98 00 68 B1 B4 F8 C0 02 40 1C A4 F8 C0 02 C4 F8 94 50 0A E0 AB A1 E0 68 BD F7 FC FB 27 81 BF E7 D4 F8 94 00 40 1C C4 F8
9:08:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 77 09 81 80 94 00 D4 F8 B4 02 40 1C C4 F8 B4 02 01 20 95 E7 01 78 FF 29 01 D1 01 21 01 70 42 78 00 21 FF 2A 00 D1 41 70 82 78 63 2A 03 D1 02 79 FF 2A 00 D1 01 71 70 47 10 B5 04 46 00 89 8A B0 80 1E 81 B2 E0 68 02 AA 80 1C FC F7 B3 FF 20 B3 02 A8 FD F7 2D FF 84 F8 30 00 BD F8 14 20 07 A8 02 99 C5 F7 5B F9 69 46 07 A8 F6 F7 B1 FB B0 B1 68 46 FF F7 CF FF 00 98 60 61 BD F8 04 00 20 83 20 46 FD F7
9:08:35 AM
9:08:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 78 09 81 80 00 FF 60 B1 14 22 02 A9 04 F1 1C 00 BD F7 33 FB 01 20 0A B0 10 BD 03 20 02 E0 0B 20 00 E0 17 20 A4 F8 D0 02 00 20 F4 E7 10 B5 04 46 FF F7 C2 FF 00 28 13 D0 20 46 FE F7 DC FC 94 F8 37 00 07 28 0E D0 00 20 A4 F8 C2 02 02 46 01 21 20 46 FF F7 4A FD 20 B1 03 20 A4 F8 BC 02 01 20 10 BD 21 20 A4 F8 D0 02 00 20 10 BD 10 B5 04 46 FF F7 A2 FF 00 28 13 D0 20 46 FE F7 BC FC 94 F8 37 00 07 28
9:08:36 AM
9:08:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 79 09 81 80 0D D0 60 B1 20 46 FF F7 1C FE 50 B1 01 21 20 46 FD F7 AF FC 03 20 A4 F8 BC 02 01 20 10 BD 07 20 00 E0 20 20 A4 F8 D0 02 00 20 10 BD 10 B5 04 46 FF F7 80 FF 00 28 0B D0 20 46 FE F7 9A FC 94 F8 37 00 07 28 05 D0 20 B1 03 20 A4 F8 BC 02 01 20 10 BD 07 20 A4 F8 D0 02 00 20 10 BD 70 B5 04 46 00 F1 60 05 D0 F8 B4 02 E8 B9 20 46 FE F7 23 FD 00 26 A4 F8 C2 62 20 46 FF F7 5C FF 00 28 21 D0
9:08:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 7A 09 81 80 20 46 FE F7 76 FC 94 F8 37 00 07 28 17 D0 20 46 FE F7 75 FD 80 B1 A4 F8 C4 62 6E 63 85 F8 38 60 70 1E 28 67 68 67 01 21 20 46 FF F7 C8 FD 28 B1 D4 F8 B4 02 38 B1 0C E0 03 20 00 E0 21 20 A4 F8 D0 02 00 20 70 BD B4 F8 BC 02 40 F0 01 00 A4 F8 BC 02 94 F8 98 00 28 B1 B4 F8 BC 02 40 F0 02 00 A4 F8 BC 02 54 F8 94 0F 40 1C 20 60 01 20 70 BD 2D E9 FF 47 0D 46 09 78 17 46 1C 46 00 29 6E D0
9:08:37 AM
9:08:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 7B 09 81 80 C0 68 40 79 40 1E C0 B2 80 46 0A F0 30 FD 06 46 40 46 0A F0 3B FD 2E B3 20 B3 38 78 30 B1 01 28 11 D0 02 28 15 D0 03 28 1C D1 18 E0 28 78 21 28 18 D1 A8 88 C1 B2 A8 1D EF F7 7E F8 00 28 12 D0 00 88 20 80 4B E0 28 78 07 28 0B D1 68 68 60 60 45 E0 28 78 07 28 05 D1 68 68 A0 60 3F E0 28 78 21 28 03 D0 00 20 04 B0 BD E8 F0 87 A8 88 C1 B2 A8 1D EF F7 61 F8 05 00 4F F0 00 00 00 90 01 90
9:08:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 7C 09 81 80 02 90 03 90 27 D0 40 46 09 F0 9B F9 01 46 00 20 4F F0 06 09 EA 46 02 4B 1B E0 00 00 21 0D 0A 00 68 C1 01 00 37 68 09 EB 40 02 37 F8 02 C0 2A 88 94 45 09 D1 0A EB D0 08 00 F0 07 07 98 F8 00 20 DF 5D 3A 43 88 F8 00 20 BC F1 00 0F 03 D0 40 1C C0 B2 88 42 E6 D3 9D E8 0F 00 0C 34 0F C4 01 20 C1 E7 2D E9 F0 41 86 B0 04 46 88 46 15 46 5B B1 28 78 00 28 7E D0 00 BF 95 F9 00 10 40 46 E4 F7
9:08:38 AM
9:08:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 7D 09 81 80 4F FA 06 00 4F D0 6F E0 E0 68 20 21 3A 30 BD F7 4B FA E0 68 00 27 00 F1 80 01 C0 F8 80 70 4F 60 8F 60 E0 68 8C 21 90 30 BD F7 17 FA E0 68 FF 26 04 A9 80 F8 3A 60 60 68 FD F7 D2 FB B8 B3 04 98 B8 F1 07 0F C1 B2 29 70 03 D1 01 29 06 D0 02 29 06 D0 20 88 40 F4 00 40 20 80 4B E0 2F 71 01 E0 01 20 28 71 E0 68 00 28 1E D0 00 F1 90 01 84 30 8C 22 C4 F7 D1 FF E0 68 80 F8 80 60 BC E7 00 96
9:08:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 7E 09 81 80 E0 68 01 A9 00 F1 8C 03 00 F1 80 02 3A 30 E5 F7 82 FF 00 28 08 D0 E1 68 91 F8 8C 00 20 B3 28 79 30 B1 01 28 0F D0 00 20 06 B0 BD E8 F0 81 21 E0 01 F1 80 02 8C 31 05 F1 08 03 20 46 FF F7 18 FF 00 28 F1 D0 07 E0 01 F1 90 01 D1 E9 00 02 89 68 29 61 C5 E9 02 02 E0 68 4F F0 8C 02 00 F1 90 01 00 F1 84 00 C4 F7 98 FF 01 A9 20 46 FD F7 8C FC 00 28 C4 D1 01 20 D7 E7 90 F8 68 10 13 29 09 D1
9:08:39 AM
9:08:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 7F 09 81 80 90 F8 BC 10 07 29 05 D3 09 29 03 D8 90 F8 37 00 00 28 00 D0 01 20 70 47 F0 B5 8B B0 00 27 04 46 C0 F8 B8 72 FE F7 25 FB 94 F8 37 00 78 B1 02 25 01 26 08 A9 28 46 F4 F7 BF FF 30 B1 9D F8 20 00 41 1E 04 29 06 D8 86 42 04 D0 07 20 60 E0 01 25 00 26 EE E7 04 F8 34 5F 01 20 60 70 F6 48 A6 70 00 EB 85 00 60 60 F5 49 05 EB 85 00 01 EB 40 10 A0 60 A4 F1 34 04 04 F5 E8 70 20 64 4F F4 8E 71
9:08:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 80 09 81 80 04 F1 60 00 BD F7 69 F9 A4 F8 BE 72 20 89 02 AA 80 1E 81 B2 E0 68 80 1C FC F7 8A FD 0B 25 90 B3 02 A8 FD F7 03 FD 84 F8 30 00 BD F8 14 20 09 A8 02 99 C4 F7 31 FF 69 46 09 A8 F6 F7 87 F9 10 B3 68 46 FF F7 A5 FD 00 98 60 61 BD F8 04 00 20 83 20 46 FD F7 D6 FC D0 B1 14 22 02 A9 04 F1 1C 00 BD F7 09 F9 60 69 C4 F8 62 00 20 8B A4 F8 66 00 BD F8 16 00 E8 B1 07 AA D1 49 03 98 BD F7 4E FD
9:08:40 AM
9:08:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 81 09 81 80 01 28 0A D0 15 E0 FF E7 A4 F8 D0 52 02 E0 17 20 A4 F8 D0 02 00 20 0B B0 F0 BD 04 F1 6C 04 07 98 A0 70 84 F8 50 00 4F F0 FF 30 60 66 A0 66 A4 F1 6C 04 4F F0 8C 02 84 F8 70 70 04 F1 F0 01 04 F1 E4 00 C4 F7 E9 FE FF 20 84 F8 E0 00 01 20 E2 E7 70 B5 AD F5 D3 6D 04 46 0A 20 E0 80 4F F4 C8 62 69 46 0D F2 84 60 C4 F7 D7 FE D4 F8 B4 02 00 26 F0 BB 20 89 E1 68 80 1E 82 B2 89 1C 0D F5 C8 60
9:08:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 82 09 81 80 C4 F7 CA FE 20 89 0D F5 CC 62 80 1E 81 B2 E0 68 80 1C FC F7 0D FD 05 00 08 D0 BD F8 6C 06 48 B1 20 46 FF F7 39 FF 00 28 6D D0 04 E0 02 20 A4 F8 D0 02 7A E0 00 25 BD F8 44 06 AD F8 4C 66 28 44 AD F8 44 06 0D F5 C8 60 CD F8 50 06 44 30 CD F8 54 06 04 F1 60 00 CD F8 58 06 94 F8 68 10 04 F1 70 02 0D F2 4C 60 D4 F8 B8 32 FF F7 7A FE 00 E0 04 E0 03 23 E8 B1 A0 88 04 28 1D D0 26 81 20 46
9:08:41 AM
9:08:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 83 09 81 80 FF F7 FA FE 07 25 E8 B3 0D F2 84 62 0D F2 8C 61 04 F1 34 00 EF F7 1F FE A0 B3 40 F6 34 02 0D F5 C8 60 E1 68 C4 F7 78 FE D4 F8 B4 02 1F 25 58 B1 21 E0 A4 F8 D0 32 38 E0 01 21 20 46 FD F7 19 FA 04 F5 2E 74 A3 80 45 E0 04 F1 14 01 0D F5 C8 60 F6 F7 DC FA B0 B1 7A 49 94 F8 6E 20 20 31 0D F2 74 60 D4 F7 87 FD 82 B2 0D F2 74 61 0D F5 C8 60 F6 F7 93 F9 30 B1 0D F2 8C 61 0D F5 C8 60 FD F7
9:08:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 84 09 81 80 CA FA 01 E0 0F E0 11 E0 68 B1 02 22 6D A1 0D F5 C8 60 F6 F7 82 F9 30 B1 BD F8 44 06 20 81 D4 F8 B4 02 30 B1 0B E0 A4 F8 D0 52 00 20 0D F5 D3 6D 70 BD B4 F8 BC 02 40 F0 01 00 A4 F8 BC 02 94 F8 98 00 28 B1 B4 F8 BC 02 40 F0 02 00 A4 F8 BC 02 04 F1 94 04 20 68 00 F1 01 00 20 60 4F F0 01 00 E4 E7 70 B5 04 46 00 89 AD F5 D1 6D 80 1E 81 B2 E0 68 0D F2 64 62 80 1C FC F7 5A FC 05 00 08 D0
9:08:42 AM
9:08:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 85 09 81 80 BD F8 70 06 38 B1 20 46 FF F7 86 FE 00 28 4C D0 02 E0 02 20 46 E0 00 25 94 F8 37 00 E8 B3 4F F4 C8 62 01 A9 0D F5 CF 60 C4 F7 F6 FD 20 89 40 1B 80 1E 82 B2 E0 68 AD 1C 41 19 0D F5 D0 60 C4 F7 EB FD 00 20 AD F8 50 06 0D F5 CF 60 CD F8 58 06 08 30 CD F8 54 06 04 F1 60 00 CD F8 5C 06 94 F8 68 00 5C 28 20 D8 94 F9 BC 10 02 29 1C DB E3 F7 B5 FF 05 00 18 D0 20 68 4F F0 14 06 D0 F8 9C 00
9:08:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 86 09 81 80 40 6C D0 F8 CC 00 40 6A 00 68 00 88 00 07 3C D5 B4 F8 7C 01 40 F4 00 40 00 E0 02 E0 A4 F8 7C 01 33 E0 07 20 A4 F8 D0 02 00 20 0D F5 D1 6D 70 BD DD F8 5C 36 DD F8 5C 26 DD F8 5C 06 00 95 8C 33 80 32 3A 30 0D F2 44 61 E5 F7 65 FD E0 B3 9D F8 44 16 00 20 01 29 03 D1 BD F8 48 16 01 B9 01 20 DD F8 5C 16 91 F8 8C 10 09 B9 01 28 0D D1 04 F1 34 00 EF F7 B0 FD 38 B3 DD F8 5C 16 DD F8 5C 06
9:08:43 AM
9:08:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 87 09 81 80 90 31 84 30 8C 22 C4 F7 87 FD 0D F2 44 61 0D F5 CA 60 FD F7 79 FA 00 28 CA D1 01 21 20 46 FD F7 28 F9 04 F5 2E 74 03 20 A0 80 20 68 00 F1 01 00 20 60 4F F0 01 00 B8 E7 3E D5 06 00 66 D5 06 00 44 19 04 00 0D 0A 00 00 FF E7 A4 F8 D0 62 AB E7 70 B5 04 46 00 89 AD F5 D4 6D 80 1E 81 B2 E0 68 0D F5 CF 62 80 1C FC F7 A3 FB 05 00 08 D0 BD F8 84 06 38 B1 20 46 FF F7 CF FD 00 28 49 D0 02 E0
9:08:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 88 09 81 80 02 20 43 E0 00 25 94 F8 37 00 E8 B3 4F F4 C8 62 01 A9 0D F2 8C 60 C4 F7 3F FD 20 89 40 1B 80 1E 82 B2 E0 68 AD 1C 41 19 0D F2 94 60 C4 F7 34 FD 0D F2 8C 61 CD F8 4C 16 08 31 00 20 CD F8 48 16 AD F8 44 06 04 F1 60 01 CD F8 50 16 CD F8 6C 06 94 F9 BC 10 94 F8 68 00 E3 F7 1E FF 05 00 17 D0 20 68 4F F0 14 06 D0 F8 9C 00 40 6C D0 F8 CC 00 40 6A 00 68 00 88 00 07 3F D5 B4 F8 7C 01 40 F4
9:08:44 AM
9:08:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 89 09 81 80 00 40 A4 F8 7C 01 38 E0 FF E7 07 20 A4 F8 D0 02 00 20 0D F5 D4 6D 70 BD DD F8 50 36 DD F8 50 26 DD F8 50 06 00 95 8C 33 80 32 3A 30 0D F5 CC 61 E5 F7 B1 FC C0 B3 9D F8 60 16 00 20 01 29 03 D1 BD F8 64 16 01 B9 01 20 DD F8 50 16 91 F8 8C 10 09 B9 01 28 11 D1 0D F2 8C 62 0D F2 6C 61 04 F1 34 00 EF F7 2D FD F8 B1 DD F8 50 16 DD F8 50 06 90 31 84 30 8C 22 C4 F7 CF FC 0D F5 CC 61 0D F2
9:08:45 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:08:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 8A 09 81 80 44 60 FD F7 C1 F9 00 28 C6 D1 01 21 20 46 FD F7 70 F8 04 F5 2E 74 03 20 A0 80 20 68 00 F1 01 00 20 60 4F F0 01 00 B4 E7 FF E7 A4 F8 D0 62 AF E7 2D E9 FC 41 00 26 A0 F8 D2 62 A0 F8 D0 62 04 46 A0 F8 BC 62 80 88 35 46 03 28 04 D0 04 28 02 D0 05 28 0B D0 13 E0 C4 F8 B4 52 20 89 02 28 0E D3 E0 68 01 78 21 74 40 78 60 74 0E E0 20 89 01 28 0B D1 E0 68 00 78 15 28 04 D0 06 28 05 D0 00 20
9:08:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 8B 09 81 80 BD E8 FC 81 20 46 FE F7 3C FE 01 A9 14 20 CA F7 FF F8 01 27 08 B9 AD F8 04 70 15 F0 C3 FF 08 B9 AD F8 04 50 B4 F8 D0 01 18 B1 BD F8 04 00 01 28 09 D0 20 7C 45 28 34 D0 52 28 08 D0 57 28 22 D0 A4 F8 D0 72 3B E0 07 20 A4 F8 D0 02 37 E0 60 7C 31 28 06 D0 35 28 08 D0 36 28 08 D0 39 28 2E D1 0D E0 20 46 FF F7 20 FB 28 E0 A4 F8 C8 52 01 26 20 46 FE F7 1C FE 20 46 FF F7 70 FB 1E E0 20 46
9:08:46 AM
9:08:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 8C 09 81 80 FF F7 66 FD 1A E0 60 7C 31 28 02 D0 39 28 16 D1 03 E0 20 46 FF F7 28 FB 10 E0 20 46 FF F7 21 FE 0C E0 60 7C 31 28 02 D0 39 28 08 D1 03 E0 20 46 FF F7 3C FB 02 E0 20 46 FF F7 CA FE 10 B9 20 46 FC F7 CD FF 23 89 93 B1 B4 F8 BC 02 00 90 E1 88 E2 68 20 68 FC F7 B7 FD 28 B1 D4 F8 B4 02 40 1C C4 F8 B4 02 03 E0 16 B1 20 46 FE F7 F7 FD 01 20 86 E7 81 88 07 29 0B D2 DF E8 01 F0 0A 04 04 09
9:08:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 8D 09 81 80 09 09 04 00 00 21 01 74 41 74 FF F7 67 B9 4F E7 00 20 70 47 30 B5 AD F6 3C 0D 01 AA 04 00 C2 60 77 D0 20 68 00 28 74 D0 04 F1 08 01 00 91 40 F6 34 03 21 1D FC F7 3B FD 10 B1 20 46 FF F7 D9 FF 0D F6 38 00 C4 F7 8B FA B4 F8 7C 11 04 F5 35 75 CA 07 0D D0 21 F0 01 00 A4 F8 7C 01 DD F8 38 08 C4 F8 DC 02 28 46 C4 F7 9D FA 80 20 16 F0 04 FA 28 46 C4 F7 9F FA 41 F2 88 31 88 42 08 D8 21 68
9:08:47 AM
9:08:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 8E 09 81 80 B4 F9 D4 02 09 7B 01 29 00 D0 00 21 08 42 0C D0 D4 F8 DC 02 DD F8 38 18 88 42 06 D0 28 46 C4 F7 7D FA 4F F0 FF 30 15 F0 07 FB 20 68 00 7B 01 28 22 D1 B4 F8 7C 01 81 07 06 D5 20 F0 02 00 A4 F8 7C 01 01 20 C6 F7 11 F8 B4 F8 7C 01 41 07 06 D5 20 F0 04 00 A4 F8 7C 01 02 20 C6 F7 06 F8 B4 F8 7C 01 C1 06 08 D5 20 F0 10 00 A4 F8 7C 01 00 20 16 F0 0D F8 C1 F7 FD FC B4 F8 7C 01 01 07 08 D5
9:08:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 8F 09 81 80 20 F0 08 00 A4 F8 7C 01 01 20 16 F0 00 F8 C1 F7 DB FE 0D F6 3C 0D 30 BD 0A 28 03 D2 B1 49 51 F8 20 00 70 47 4F F4 96 70 70 47 2D E9 FC 41 04 46 40 6D 0F 46 E0 B9 20 78 FF 28 1C D0 67 72 C9 F7 70 FC 02 46 20 7A 00 25 01 23 02 26 00 28 38 46 13 D0 FF F7 E1 FF CD E9 00 32 01 46 20 78 00 23 08 22 C9 F7 4E FC E6 84 25 85 0E 20 E0 86 25 87 01 20 BD E8 FC 81 00 20 FB E7 FF F7 CD FF CD E9
9:08:48 AM
9:08:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 90 09 81 80 00 32 01 46 20 78 01 23 07 22 C9 F7 3A FC E6 84 25 85 E6 86 EB E7 01 78 FF 29 05 D0 41 68 19 B1 0A 78 02 72 49 78 C0 E7 00 20 70 47 70 B5 04 46 00 78 FF 28 0A D0 60 68 40 B1 21 7A 00 78 01 25 81 42 11 D0 61 6D 19 B1 20 72 05 E0 00 20 70 BD 20 46 FF F7 E0 FF 05 46 60 68 00 78 20 B9 E0 6C 10 B1 01 21 FC F7 F1 FC 28 46 70 BD F8 B5 04 46 80 6C 0E 46 17 46 04 F1 0C 05 38 B1 6B 46 20 46
9:08:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 91 09 81 80 1F F0 AF F8 9D F8 00 00 01 28 10 D0 20 7A 18 B1 01 28 07 D0 00 20 F8 BD 3A 46 31 46 E0 6C FC F7 B0 FC 04 E0 3A 46 31 46 60 6C FB F7 06 FC 28 46 C4 F7 B8 F9 01 20 F8 BD 70 B5 04 46 40 6D 08 B1 02 F0 E6 F9 E0 6A 88 B1 41 68 00 25 E1 62 09 E0 45 60 A1 8E 49 1E A1 86 DB F7 6E FF E0 6A 28 B1 41 68 E1 62 00 29 F3 D1 25 63 F1 E7 01 20 70 BD 01 6C 79 B9 C1 6A 01 64 61 B1 4B 68 00 22 C3 62
9:08:49 AM
9:08:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 92 09 81 80 03 B9 02 63 4A 60 81 8E 49 1E 81 86 00 6C 08 B1 01 20 70 47 00 20 70 47 F8 B5 04 46 14 30 06 46 C4 F7 88 F9 40 F2 DC 51 88 42 02 D9 30 46 C4 F7 75 F9 20 46 FF F7 DC FF 20 6C 30 B9 28 E0 00 BF DB F7 17 FF 20 64 00 28 1E D0 85 89 00 2D F7 D0 20 6C 6B 46 2A 46 81 68 20 78 C9 F7 BA FB BD F8 00 10 81 B1 09 B2 20 6C DC F7 B3 F8 BD F8 00 00 28 1A 85 B2 30 46 C4 F7 55 F9 00 2D E8 D1 20 6C
9:08:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 93 09 81 80 81 89 11 B1 04 E0 00 20 F8 BD DB F7 F2 FE 20 64 01 20 F8 BD 70 B5 04 46 40 6D 0D 46 58 B1 00 21 01 F0 A4 FE 38 B1 65 B3 29 46 60 6D BD E8 70 40 00 22 02 F0 21 B9 20 6D 18 B1 1E F0 5D FB 01 28 09 D0 B4 F9 34 00 B4 F9 36 10 88 42 0A DB 20 8F 40 1C 20 87 15 E0 A5 B1 29 46 20 6D BD E8 70 40 1E F0 C3 BB 6D B1 00 20 68 60 20 6B 58 B1 45 60 25 63 A0 8E 40 1C A0 86 20 46 FF F7 8D FF 01 20
9:08:50 AM
9:08:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 94 09 81 80 70 BD 00 20 70 BD E5 62 F2 E7 30 B5 04 46 0C 30 85 B0 05 46 C4 F7 0E F9 40 F2 DC 51 88 42 02 D9 28 46 C4 F7 FB F8 20 78 04 AB 10 22 69 46 C9 F7 5B FB 00 28 07 D0 BD F8 10 20 1A B1 69 46 20 46 FF F7 14 FF 01 20 05 B0 30 BD 10 B5 04 46 00 78 FF 28 06 D0 20 46 FF F7 D8 FF 20 46 BD E8 10 40 5A E7 10 BD C8 E0 06 00 0E B5 02 AA 68 21 CD E9 00 12 0A 46 01 46 00 23 12 20 DD F7 F0 FD 00 28
9:08:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 95 09 81 80 00 D0 01 20 0E BD 0E B5 02 AA 68 21 CD E9 00 12 0A 46 01 46 00 23 12 20 DD F7 21 FE 00 28 00 D0 01 20 0E BD 10 B5 04 46 68 21 BC F7 16 FC FA 49 00 20 00 BF 04 EB 80 02 8B 68 40 1C D3 60 10 F0 FF 00 F7 D0 42 F2 10 70 E0 64 20 65 60 65 D1 F8 12 00 60 64 D1 F8 16 00 A0 64 50 20 24 F8 64 0F 01 20 A0 70 10 BD 0E B5 02 AA 18 21 CD E9 00 12 0A 46 01 46 4C 23 12 20 DD F7 B1 FD 00 28 00 D0
9:08:51 AM
9:08:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 96 09 81 80 01 20 0E BD 3E B5 04 46 18 20 02 A9 CD E9 00 01 02 46 4C 23 21 46 12 20 DD F7 E1 FD 00 28 0B D0 18 22 21 46 DD 48 BC F7 A6 FB DC 48 18 22 21 46 94 30 BC F7 A0 FB 01 20 3E BD 00 B5 9B B0 68 46 FF F7 B0 FF 00 28 05 D0 68 46 FF F7 9C FF 00 28 00 D0 01 20 1B B0 00 BD CF 4A 00 21 12 F1 04 02 02 EB 81 03 5B 88 83 42 02 D1 12 F8 21 00 70 47 49 1C 11 F0 FF 01 F3 D0 01 20 70 47 00 20 70 47
9:08:52 AM
9:08:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 97 09 81 80 10 B5 00 28 08 D0 01 46 14 22 4F F4 79 70 DE F7 07 F8 00 28 00 D0 01 20 10 BD 10 B5 00 28 08 D0 01 46 14 22 4F F4 79 70 DD F7 2F FE 00 28 00 D0 01 20 10 BD 09 28 04 D2 B7 49 1C 31 01 EB C0 00 70 47 B5 48 1C 30 70 47 30 B5 0A 46 07 28 1D D2 E2 B1 B1 49 53 78 64 31 01 EB C0 04 01 2B 00 D0 24 1D 00 23 E0 5C FF F7 E5 FF 01 78 59 B1 11 78 05 79 A9 42 07 D1 51 78 45 79 A9 42 03 D1 91 78
9:08:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 98 09 81 80 85 79 A9 42 06 D0 5B 1C 04 2B EB D3 BD E8 30 40 00 20 CF E7 30 BD 70 47 38 B5 C8 B9 9F 4C 01 25 40 3C 60 78 8D F8 00 10 8D F8 01 20 E1 78 8D F8 02 10 69 46 FF F7 C8 FF 01 78 49 B1 C0 79 E0 70 A4 F1 0C 00 FF F7 1F FF 00 28 00 D0 28 46 38 BD 00 20 38 BD 03 46 08 46 02 22 19 46 DC E7 03 46 08 46 01 22 19 46 D7 E7 00 28 04 D0 8B 49 B0 39 09 6F 01 60 01 20 70 47 70 B5 04 00 10 D0 87 48
9:08:53 AM
9:08:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 99 09 81 80 4C 38 05 46 FF F7 F0 FE 50 B1 84 48 21 68 B0 38 01 67 28 46 FF F7 F7 FE 00 28 00 D0 01 20 70 BD 00 20 70 BD 10 B5 00 28 05 D0 7C 49 14 22 60 39 BC F7 E1 FA 01 20 10 BD 10 B5 00 28 0C D0 01 46 76 48 14 22 60 38 04 46 BC F7 D5 FA 20 46 FF F7 64 FF 00 28 00 D0 01 20 10 BD 10 B5 03 46 31 B1 2A B1 00 20 00 2B 03 D1 4B 78 13 B1 08 E0 00 20 10 BD 54 78 01 2C 03 D0 01 20 50 70 C8 70 0A E0
9:08:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 9A 09 81 80 66 49 80 39 09 78 02 29 F2 D0 54 78 8C 42 EF D0 00 2B ED D0 51 70 01 20 10 BD 2D E9 F0 41 5F 4C 0D 46 B0 3C 03 28 34 F8 15 60 02 D0 02 28 42 D0 4D E0 B2 F5 7B 4F 35 D0 11 DC 4F F2 83 63 A2 EB 03 01 9A 42 22 D0 05 DC FA B1 A2 F5 24 52 02 3A 12 D1 24 E0 01 29 1C D0 02 29 0D D1 1C E0 6F F4 7B 41 51 18 21 D0 01 29 22 D0 B1 F5 80 6F 05 D0 A1 F5 80 61 01 39 04 D0 00 27 2C E0 46 F0 01 01
9:08:54 AM
9:08:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 9B 09 81 80 01 E0 46 F0 02 01 24 F8 15 10 20 E0 46 F0 04 01 F9 E7 46 F0 08 01 F6 E7 46 F0 10 01 F3 E7 46 F0 40 01 F0 E7 46 F0 80 01 ED E7 46 F4 80 71 EA E7 46 F4 00 71 E7 E7 39 49 80 39 01 EB 85 01 91 F8 41 10 01 29 17 D0 02 29 15 D0 05 29 13 D0 29 46 FF F7 45 FF 07 46 34 F8 15 00 B0 42 08 D0 41 F2 12 20 04 EB 45 01 00 EB 45 00 02 22 DD F7 0D FD 38 46 BD E8 F0 81 46 F0 20 01 C4 E7 00 29 11 D0
9:08:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 9C 09 81 80 26 4A B0 3A 32 F8 10 20 00 2A 0B D0 C9 78 01 29 08 D1 91 06 01 D5 02 23 00 E0 03 23 01 46 00 22 18 46 7A E7 70 47 70 B5 1C 4E 00 24 B6 F1 80 06 04 EB 84 00 06 EB 84 05 06 EB 80 02 40 35 20 32 29 46 20 46 FF F7 49 FF 18 B1 14 48 60 38 FF F7 A4 FE 68 78 18 B1 29 46 20 46 FF F7 CF FF 64 1C 14 F0 FF 04 E4 D0 70 BD 70 B5 0C 4E 02 24 05 46 24 36 06 EB 84 01 28 78 89 78 88 42 06 D1 36 F8
9:08:55 AM
9:08:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 9D 09 81 80 24 00 B5 F9 02 10 00 B2 C9 F7 41 FC 64 1C E4 B2 08 2C EE D3 70 BD 00 00 F0 E0 06 00 90 5C 00 10 2D E9 F0 41 FC 4C 05 46 00 F0 03 00 D4 F8 9C 20 04 F1 9C 06 41 F2 0C 27 02 F0 03 01 02 28 01 D1 01 29 09 D0 01 28 01 D1 02 29 05 D0 91 07 07 D0 D1 43 89 07 04 D0 0E E0 08 20 0C F0 C9 F8 03 E0 02 28 01 D0 01 28 06 D1 04 22 31 46 38 46 C4 F8 9C 50 DD F7 8A FC E9 48 04 46 C3 F7 9B FE 40 F6
9:08:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 9E 09 81 80 B8 31 88 42 04 D9 20 46 BD E8 F0 41 C3 F7 86 BE 6F E7 2D E9 F0 41 E0 4C 0D 46 30 3C DE 49 00 27 34 F8 15 60 01 EB 85 01 03 28 02 D0 02 28 42 D0 49 E0 B2 F5 7B 4F 34 D0 11 DC 4F F2 83 67 A2 EB 07 03 BA 42 21 D0 05 DC 8A B3 A2 F5 24 52 02 3A 4D D1 23 E0 01 2B 1B D0 02 2B 48 D1 1B E0 6F F4 7B 43 D2 18 20 D0 01 2A 22 D0 B2 F5 80 6F 04 D0 A2 F5 80 62 01 3A 3A D1 02 E0 26 F0 01 02 01 E0
9:08:56 AM
9:08:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 9F 09 81 80 26 F0 02 02 24 F8 15 20 1D E0 26 F0 04 02 F9 E7 26 F0 08 02 F6 E7 26 F0 10 02 F3 E7 26 F0 40 02 F0 E7 26 F0 80 02 ED E7 26 F4 80 72 EA E7 0A E0 26 F4 00 72 E6 E7 91 F8 41 20 01 2A 11 D0 02 2A 0F D0 05 2A 0D D0 34 F8 15 20 C2 B1 03 28 0E D0 02 28 0C D0 91 F8 41 10 02 29 0A D0 04 29 08 D0 0D E0 36 F0 20 02 0E D1 26 F0 20 02 CA E7 00 27 09 E0 01 28 03 D1 22 F0 20 01 24 F8 15 10 29 46
9:08:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A0 09 81 80 FF F7 28 FE 07 46 34 F8 15 00 B0 42 08 D0 41 F2 12 20 04 EB 45 01 00 EB 45 00 02 22 DD F7 F5 FB 38 46 E6 E6 08 B5 68 46 C3 F7 D9 FD 00 28 0A D0 9B 4A DD F8 00 10 00 20 42 F8 20 10 40 1C C0 B2 03 28 F9 D3 01 20 08 BD 10 B5 00 28 09 D0 41 F2 E8 13 01 46 24 22 18 46 DD F7 A2 FD 00 28 00 D0 01 20 10 BD 10 B5 00 28 09 D0 41 F2 E8 13 01 46 24 22 18 46 DD F7 C9 FB 00 28 00 D0 01 20 10 BD
9:08:57 AM
9:08:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A1 09 81 80 38 B5 04 46 03 28 01 D3 00 20 38 BD 84 4D 68 46 24 3D C3 F7 A4 FD 82 49 00 98 41 F8 24 00 04 EB 44 00 05 EB 80 00 01 89 49 1C 01 81 01 21 41 81 28 46 FF F7 D7 FF 00 28 E7 D0 01 20 38 BD 10 B5 03 28 01 D3 00 20 10 BD 75 49 00 EB 40 00 24 39 01 EB 80 00 00 22 42 81 08 46 FF F7 C3 FF 00 28 F1 D0 01 20 10 BD 6E 48 10 B5 24 38 00 21 0A 46 01 EB 41 04 00 EB 84 03 49 1C 1A 81 40 F8 24 20
9:08:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A2 09 81 80 5C 89 C9 B2 44 F0 02 04 5C 81 03 29 F0 D3 FF F7 A9 FF 00 28 00 D0 01 20 10 BD 61 48 10 B5 24 21 24 38 BC F7 DA F8 5E 48 24 38 FF F7 9B FF 00 28 00 D0 01 20 10 BD 2D E9 F8 43 59 4D 68 46 24 3D C3 F7 4D FD 00 26 DF F8 58 81 56 4F 34 46 00 BF 04 EB 44 01 05 EB 81 00 42 89 93 07 03 D5 22 F0 02 01 41 81 17 E0 D2 07 17 D0 58 F8 24 20 00 9B 9A 42 17 D2 9A 1A 55 F8 21 30 13 44 45 F8 21 30
9:08:58 AM
9:08:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A3 09 81 80 41 68 11 44 41 60 00 98 48 F8 24 00 37 F8 14 00 01 21 17 F0 68 FB 01 26 04 E0 37 F8 14 00 00 21 17 F0 61 FB 64 1C E4 B2 03 2C D1 D3 26 B1 28 46 FF F7 58 FF 00 28 00 D0 01 20 BD E8 F8 83 01 00 0C D0 2F 29 0A D2 36 4A 98 3A 00 20 93 78 8B 42 05 D0 40 1C 92 1D C0 B2 0D 28 F7 D3 FF 20 70 47 10 B5 0C 46 FF F7 EB FF FF 28 04 D0 21 46 C9 F7 8E FA 01 28 00 D0 00 20 10 BD 70 B5 28 4D 24 3D
9:08:59 AM
9:08:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A4 09 81 80 28 46 FF F7 21 FF 00 28 1C D0 05 F1 18 00 00 21 C1 60 01 61 41 61 FF F7 05 FF 22 4E 00 24 0C 3E 04 EB 44 00 05 EB 80 00 40 89 C0 07 30 5D 01 D0 01 21 00 E0 00 21 FF F7 D3 FF 64 1C E4 B2 03 2C EE D3 01 20 26 E6 16 49 00 EB 40 00 24 39 01 EB 80 00 40 89 00 F0 01 00 70 47 10 B5 04 00 06 D0 C5 F7 81 FA B0 FB F4 F1 04 FB 11 00 10 BD 00 20 10 BD 01 00 4F F0 00 00 17 D0 8A 88 4F F4 7A 73
9:08:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A5 09 81 80 09 78 5A 43 03 29 0F D0 04 29 03 D0 05 29 0B D0 06 29 0A D1 10 46 E0 E7 10 5C 00 10 F8 7A 00 10 6C 5D 00 10 FC E0 06 00 10 46 70 47 01 00 4F F0 00 00 0D D0 4A 88 4F F4 7A 73 09 78 5A 43 07 29 06 D2 DF E8 01 F0 05 04 06 04 04 06 06 00 10 46 70 47 10 46 C1 E7 FE 49 4A 6E 02 60 B1 F8 68 10 81 80 70 47 3E B5 05 46 06 20 02 A9 CD E9 00 01 02 46 01 24 00 23 29 46 12 20 DD F7 F0 F9 00 B9
9:09:00 AM
9:09:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A6 09 81 80 00 24 F3 48 29 68 41 66 A9 88 A0 F8 68 10 20 46 3E BD 70 B5 EE 4A 00 23 05 20 30 32 02 EB 80 01 44 31 8C 78 15 3C 0C 2C 06 D8 0D 88 B2 F8 98 40 A5 42 01 D0 0C 80 01 23 40 1C C0 B2 0D 28 ED D3 2B B1 E3 48 64 30 FF F7 9E FB 00 28 00 D0 01 20 A0 E5 10 B5 C4 F7 23 FC 08 B1 00 20 10 BD 01 20 10 BD 10 B5 C4 F7 2A FC 08 B1 00 20 10 BD 01 20 10 BD 2D E9 F0 4F D7 A0 87 B0 00 68 05 90 D6 A0
9:09:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A7 09 81 80 D3 4F 00 68 02 90 78 88 08 B1 00 20 00 E0 01 20 CF 4C 78 80 28 34 20 46 D0 4B 00 F1 04 08 00 21 0D F1 14 0C 00 F5 8E 7B 0D F1 0C 0A 0D F1 08 09 85 78 00 22 02 EB 42 06 9E 5D B5 42 09 D1 02 EB 42 02 D5 18 AA 78 0C F8 01 20 6D 78 09 F8 01 50 03 E0 52 1C D2 B2 0D 2A EC D3 1C F8 01 50 00 1D 5B F8 25 50 4A F8 21 50 49 1C C9 B2 02 29 DF D3 78 88 60 B1 DD E9 03 10 CD E9 03 01 9D F8 08 00
9:09:01 AM
9:09:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A8 09 81 80 9D F8 09 10 8D F8 08 10 44 46 8D F8 09 00 00 25 D0 46 4E 46 58 F8 25 00 01 90 E0 78 C0 F3 40 00 8D F8 00 00 20 88 AD F8 02 00 71 5D 01 F0 1F 00 40 F0 60 00 8D F8 01 00 69 46 28 46 FF F7 91 FF 78 88 08 B1 24 1F 00 E0 24 1D 6D 1C ED B2 02 2D E0 D3 01 20 07 B0 BD E8 F0 8F 2D E9 F0 4F 9D A1 87 B0 09 68 05 91 9C A1 09 68 02 91 98 49 18 B1 0A 25 B1 F9 02 00 01 E0 01 25 00 20 94 4F 48 80
9:09:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 A9 09 81 80 28 37 81 46 3C 46 95 4A 8A 46 04 F1 04 08 00 20 0D F1 14 0C 0D F1 0C 0E 0D F1 08 0B A3 78 00 21 01 EB 41 06 96 5D B3 42 09 D1 01 EB 41 01 8B 18 99 78 0C F8 00 10 5B 78 0B F8 00 30 03 E0 49 1C C9 B2 0D 29 EC D3 1C F8 00 30 85 49 24 1D 51 F8 23 30 4E F8 20 30 40 1C C0 B2 02 28 DE D3 56 46 B9 F1 00 0F 0C D0 DD E9 03 20 CD E9 03 02 9D F8 08 00 9D F8 09 20 8D F8 08 20 47 46 8D F8 09 00
9:09:02 AM
9:09:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 AA 09 81 80 00 24 F1 46 4F EA 0B 08 59 F8 24 00 68 43 01 90 F8 78 C0 F3 40 00 8D F8 00 00 38 88 AD F8 02 00 18 F8 04 10 01 F0 1F 00 40 F0 60 00 8D F8 01 00 69 46 20 46 FF F7 15 FF 70 88 08 B1 3F 1F 00 E0 3F 1D 64 1C E4 B2 02 2C DE D3 01 20 82 E7 2D E9 F0 4F 87 B0 0F 46 10 99 5F EA 00 0A 15 46 1E 46 02 D1 78 1F 08 28 7A D2 11 98 FF 22 DF F8 6C B1 02 70 A8 78 00 24 00 BF 04 EB 44 03 1B F8 03 20
9:09:03 AM
9:09:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 AB 09 81 80 90 42 03 D0 00 28 70 D1 00 29 6E D0 BA F1 01 0F 08 D0 4F F0 02 09 4F F0 08 08 51 4A FF 21 48 46 70 3A 2E E0 4F F0 00 09 4F F0 02 08 00 28 F4 D1 4A 48 DE 38 00 EB 87 00 00 68 28 60 68 46 FF F7 92 FA 00 28 4A D0 42 F2 10 70 3F B1 02 24 01 90 68 46 FF F7 97 FA 00 28 40 D0 DE E7 00 24 00 90 F6 E7 00 BF 32 F8 20 30 BB 42 01 D1 01 46 0A E0 02 EB 80 03 DB 78 13 B9 FF 29 00 D1 01 46 40 1C
9:09:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 AC 09 81 80 C0 B2 40 45 EE D3 FF 29 33 D0 02 EB 81 03 A8 78 D8 70 32 48 28 30 50 F8 21 00 98 70 22 F8 21 70 11 98 01 70 A8 78 E0 B1 04 EB 44 01 59 44 BA F1 01 0F 88 78 01 D0 C0 1C C0 B2 29 4A 52 F8 20 00 70 60 E8 78 C0 F3 40 00 30 70 28 88 70 80 49 78 01 F0 1F 00 40 F0 60 00 70 70 01 20 FA E6 08 E0 03 E0 00 20 30 60 70 60 F7 E7 64 1C E4 B2 0D 2C 82 D3 00 20 EE E6 2D E9 FC 41 05 46 03 28 02 D2
9:09:04 AM
9:09:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 AD 09 81 80 00 24 02 27 01 E0 02 24 08 27 DF F8 54 80 13 4E A8 F1 70 08 08 EB 84 00 43 46 C1 78 31 B3 00 20 00 EB 40 02 B2 5C 91 42 1C D1 00 EB 40 00 81 19 03 2D 88 78 01 D3 C0 1C C0 B2 A8 42 32 D1 38 F8 24 00 02 2C 13 D2 02 4A 28 32 02 EB 80 00 12 E0 E0 5B 00 10 00 01 00 00 02 0C 00 00 E0 E1 06 00 24 5D 00 10 40 1C C0 B2 0D 28 D9 D3 1A E0 FE 4A 02 EB 80 00 44 30 FD 4A 52 F8 25 20 01 92 C2 78
9:09:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 AE 09 81 80 C2 F3 40 02 8D F8 00 20 00 88 AD F8 02 00 49 78 01 F0 1F 00 40 F0 60 00 8D F8 01 00 69 46 20 46 FF F7 1F FE 64 1C E4 B2 BC 42 B3 D3 BD E8 FC 81 70 B5 04 46 00 78 0D 46 02 26 A0 B1 01 28 1F D0 02 28 0F D1 20 1D C3 F7 75 FA E1 68 88 42 09 D3 20 1D C3 F7 63 FA 00 20 E0 60 68 78 01 28 00 D0 00 20 20 70 6E E5 68 78 01 28 FB D1 08 46 FF F7 9D FD E0 60 26 70 20 1D BD E8 70 40 C3 F7 52 BA
9:09:05 AM
9:09:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 AF 09 81 80 48 78 00 28 EE D1 26 70 5C E5 70 B5 04 46 0D 46 00 1D C3 F7 43 FA 68 78 01 28 02 D0 00 20 20 70 50 E5 28 46 FF F7 65 FD E0 60 02 20 20 70 20 1D BD E8 70 40 C3 F7 36 BA 10 B5 04 46 14 21 BB F7 8C FD 20 46 BD E8 10 40 FF F7 DA B9 1C B5 01 A9 0F 20 C8 F7 DD FF 69 46 0F 20 C9 F7 DC F8 9D F8 00 00 00 F0 80 01 0F 20 C9 F7 C9 F8 BD F8 04 00 00 28 05 D0 9D F8 00 00 10 F0 06 0F 01 D0 02 20
9:09:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B0 09 81 80 1C BD 01 20 1C BD 10 B5 28 B1 01 21 15 20 C8 F7 7E FF 01 21 04 E0 00 21 15 20 C8 F7 78 FF 00 21 16 20 C8 F7 74 FF 01 20 10 BD 10 B5 08 B1 01 21 00 E0 00 21 17 20 C8 F7 6A FF 01 20 10 BD 10 B5 08 B1 01 21 00 E0 00 21 18 20 C8 F7 60 FF 01 20 10 BD 10 B5 A4 4C 94 F8 A0 00 90 B1 5F F0 00 00 A2 49 04 F8 A0 0F 01 22 74 39 41 F2 10 20 DC F7 CC FF 20 78 38 B1 00 21 27 20 FF F7 B1 FC 01 21
9:09:06 AM
9:09:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B1 09 81 80 06 E0 01 20 EC E7 01 21 27 20 FF F7 A9 FC 00 21 28 20 FF F7 A5 FC 01 20 10 BD 10 B5 0C 46 FF F7 8E FC FF 28 06 D0 21 46 C9 F7 0F F8 00 28 00 D0 01 20 10 BD 00 20 10 BD 01 28 05 D0 02 28 06 D0 03 28 07 D0 00 20 70 47 01 21 2C 20 04 E0 01 21 2D 20 01 E0 01 21 2E 20 DF E7 10 B5 04 46 13 F0 4A FB 81 49 30 39 4A 68 82 42 00 D1 AC B1 48 60 7D 48 34 30 FF F7 B8 F8 00 28 0D D0 FF F7 09 FD
9:09:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B2 09 81 80 79 48 90 F8 9A 00 C0 07 01 D0 58 21 00 E0 00 21 13 20 C8 F7 8A FE 01 20 10 BD 00 20 10 BD 38 B5 0D 28 02 D2 8A 78 2F 2A 01 D3 00 20 38 BD 6F 4B 00 EB 40 00 50 3B 03 EB 40 04 A2 70 08 88 20 80 C8 78 E0 70 88 78 6A 49 08 5C 20 71 D0 B2 12 28 13 D1 20 88 88 B9 69 46 00 20 0B F0 53 FD 00 28 E4 D0 00 98 41 F6 99 11 88 42 03 D8 00 EB 80 00 40 00 01 E0 4F F6 FF 70 20 80 01 20 38 BD 70 B5
9:09:07 AM
9:09:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B3 09 81 80 05 46 14 28 01 D9 00 20 5C E4 00 21 C8 F7 D9 FF 90 26 0D 2D 4B D2 55 49 05 EB 45 00 50 39 01 EB 40 04 E0 78 C0 07 01 D0 00 21 00 E0 01 21 28 46 C8 F7 93 FE 20 79 54 28 10 D0 21 88 00 22 28 46 C8 F7 45 FF 00 21 28 46 C8 F7 A1 FE 21 79 28 46 C8 F7 2B FE 20 79 86 43 4D D0 50 E0 E0 78 40 07 1B D5 20 88 C8 28 01 D2 C8 20 20 80 E0 78 C0 07 02 D0 21 88 03 22 01 E0 22 88 03 21 28 46 C8 F7
9:09:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B4 09 81 80 26 FF A0 78 09 28 0B D0 00 21 28 46 C8 F7 4B FE 00 21 28 46 C8 F7 3E FF D4 E7 21 88 0A 46 ED E7 64 21 28 46 C8 F7 3F FE 40 F6 C4 11 F1 E7 A5 F1 0D 00 2F 49 C0 B2 00 EB 40 00 9C 39 01 EB 80 04 28 46 21 78 C8 F7 49 FE E2 88 A1 88 28 46 C8 F7 FE FE 61 88 28 46 C8 F7 26 FE 00 21 28 46 C8 F7 56 FE A1 7A 28 46 C8 F7 E0 FD 21 89 28 46 C8 F7 11 FF A0 7A AF E7 00 21 28 46 C8 F7 48 FE 01 21
9:09:08 AM
9:09:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B5 09 81 80 28 46 C8 F7 5E FF 01 20 62 E4 2D E9 F0 47 16 4C 98 B0 30 3C 04 F1 80 00 18 22 81 6A A1 62 C0 6A E0 62 04 F1 B0 01 11 48 BB F7 E5 FB 20 21 04 F1 D4 00 BB F7 39 FC 4E 21 04 F1 F4 00 BB F7 34 FC 04 F5 80 70 00 25 C5 65 05 66 45 66 40 21 03 A8 BB F7 03 FC DF F8 10 80 65 80 00 24 08 F1 C4 0A 16 AF 0D F1 0C 09 05 E0 10 5C 00 10 24 5D 00 10 28 E2 06 00 08 EB 84 06 44 36 31 46 20 46 FF F7
9:09:09 AM
9:09:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B6 09 81 80 0E FF CD E9 00 57 14 AB 32 46 21 46 00 20 FF F7 1E FD 38 B1 9D F8 58 10 09 EB C1 00 DD E9 14 12 C0 E9 00 12 04 EB 44 01 0A EB 41 00 80 78 07 28 01 D0 08 28 03 D1 17 A9 20 46 C8 F7 29 FE 64 1C E4 B2 0D 2C CF D3 F8 4E 00 24 00 BF CD E9 00 57 06 EB 84 02 14 AB 21 46 01 20 FF F7 F8 FC 38 B1 9D F8 58 10 09 EB C1 00 DD E9 14 12 C0 E9 00 12 64 1C E4 B2 02 2C E9 D3 EC 48 C3 F7 FC FB 03 A8
9:09:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B7 09 81 80 FF F7 E7 FB 00 24 20 46 FF F7 F9 FE 64 1C E4 B2 14 2C F8 D3 E4 49 01 22 A8 31 41 F2 10 20 DC F7 FF FF 98 F8 A0 00 28 B1 00 21 27 20 FF F7 18 FB 01 21 04 E0 01 21 27 20 FF F7 12 FB 00 21 28 20 FF F7 0E FB D8 49 04 22 A4 31 41 F2 0C 20 DC F7 E7 FF 18 B0 BD E8 F0 87 70 B5 C4 F7 B0 FD D2 4C 40 07 4F F0 00 06 04 F1 08 04 0A D5 FE F7 A5 FF 04 22 04 F1 9C 01 41 F2 0C 20 C4 F8 9C 60 DC F7
9:09:10 AM
9:09:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B8 09 81 80 04 FE 01 20 FF F7 69 FE FF F7 3F FF 94 F8 9A 00 C0 07 01 D0 58 21 00 E0 00 21 13 20 C8 F7 05 FD C4 F7 8D FD 40 05 24 D4 14 F0 E2 FF 05 46 C2 F7 E5 FF 68 40 C4 F7 95 FD 94 F8 34 00 03 28 05 D0 04 28 03 D0 05 28 01 D0 06 28 0B D1 20 8F 48 B1 01 21 FF 20 C8 F7 1E FE B3 48 84 F8 21 60 28 30 FE F7 9B FF B0 49 BD E8 70 40 3C 31 A1 F1 34 00 8B E5 77 E5 2D E9 F0 41 AB 49 48 31 A1 F1 20 00
9:09:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 B9 09 81 80 FF F7 9A FD A8 4D 41 F2 12 28 28 3D 00 26 2E 80 34 46 2F 46 07 EB 44 01 08 EB 44 00 02 22 DC F7 7F FF 64 1C 14 F0 FF 04 F4 D0 AE 61 EE 61 2E 62 6E 62 AE 60 EE 60 2E 61 6E 61 C4 F7 40 FD 40 05 03 D4 BD E8 F0 41 FF F7 98 BA BD E8 F0 81 F0 B5 DF F8 54 E2 4F F0 00 0C 05 22 A1 F1 15 04 0E F1 08 0E 0C 2C 1A D8 0E EB 82 05 91 4E 95 F8 46 50 00 23 00 BF 03 EB 43 07 F7 5D BD 42 09 D1 90 42
9:09:11 AM
9:09:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 BA 09 81 80 27 D0 0C F1 01 0C 0C F0 FF 0C BC F1 06 0F 0F D2 1B E0 5B 1C DB B2 0D 2B EC D3 16 E0 0E EB 82 03 12 29 93 F8 46 30 05 D0 8B 42 0E D1 90 42 10 D0 00 20 F0 BD 12 2B 08 D1 90 42 0A D0 0C F1 01 0C 0C F0 FF 0C BC F1 02 0F F2 D2 52 1C D2 B2 0D 2A C7 D3 01 20 F0 BD 74 4B 10 B5 00 22 13 F1 08 03 03 EB 82 04 94 F8 46 40 8C 42 03 D1 90 42 05 D0 00 20 10 BD 52 1C D2 B2 05 2A F1 D3 01 20 10 BD
9:09:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 BB 09 81 80 00 B5 09 B3 05 28 0E D2 10 29 1F D2 DF E8 01 F0 1E 08 08 08 08 08 08 08 08 08 08 08 08 08 08 08 5D F8 04 EB D7 E7 0D 28 07 D2 A1 F1 10 02 1E 2A 0C D8 FF F7 8C FF 38 B9 08 E0 1E 28 01 D0 1F 28 04 D1 15 39 0C 29 01 D8 01 20 00 BD 00 20 00 BD 0D 28 05 D2 54 4A 08 32 02 EB 80 00 40 6C 0A E0 51 4A 58 32 1E 28 03 D0 1F 28 03 D0 00 20 70 47 90 6A 00 E0 D0 6A 08 60 01 20 70 47 30 B5 9B B0
9:09:12 AM
9:09:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 BC 09 81 80 05 46 0C 46 68 46 FE F7 2F FE 00 28 13 D0 0D 2D 0C D2 A0 78 15 38 0C 28 02 D8 BD F8 64 00 20 80 68 46 00 EB 85 00 21 68 01 61 13 E0 1E 2D 04 D0 1F 2D 09 D0 00 20 1B B0 30 BD E0 78 40 F0 01 00 E0 70 20 68 11 90 05 E0 E0 78 40 F0 01 00 E0 70 20 68 12 90 68 46 FE F7 16 FE 00 28 EB D0 01 20 E9 E7 10 B5 0C 46 FF F7 AA F9 FF 28 04 D0 21 46 C8 F7 8E FC 01 28 00 D0 00 20 10 BD 10 B5 0C 46
9:09:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 BD 09 81 80 FF F7 9D F9 FF 28 06 D0 21 46 C8 F7 84 FD 00 28 00 D0 01 20 10 BD 00 20 10 BD 10 B5 0C 46 FF F7 8E F9 FF 28 06 D0 21 46 C8 F7 69 FD 00 28 00 D0 01 20 10 BD 00 20 10 BD 0C 28 07 D0 0D 28 07 D0 0E 28 07 D0 0F 28 07 D0 00 20 70 47 00 20 04 E0 01 20 02 E0 02 20 00 E0 03 20 16 4A 10 44 02 7A 0A 80 00 21 01 72 01 20 70 47 2D E9 FC 41 0E 4E 02 24 08 36 06 F1 A4 05 00 27 35 F8 24 20 05 20
9:09:13 AM
9:09:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 BE 09 81 80 06 EB 80 01 44 31 82 42 16 D1 89 78 C1 B9 05 EB 84 00 C1 70 25 F8 24 70 87 70 00 97 69 46 20 46 01 97 FF F7 1E FA 0B E0 08 5C 00 10 69 4E 04 00 E0 E1 06 00 3C 5D 00 10 40 1C C0 B2 0D 28 DF D3 64 1C E4 B2 08 2C D8 D3 BD E8 FC 81 2D E9 F0 47 DF F8 58 84 86 B0 00 24 A8 F5 8A 75 08 EB 84 07 05 EB 84 06 06 F1 80 01 04 22 38 46 BB F7 EC F8 28 B1 D6 F8 80 00 38 60 20 46 FF F7 7C FB 64 1C
9:09:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 BF 09 81 80 E4 B2 06 2C EA D3 FF F7 B0 FF DF F8 20 A4 00 24 AA F1 50 0A 4F F0 01 08 0D F1 10 09 04 EB 44 01 05 EB 84 06 0A EB 41 07 44 36 01 22 B1 1C B8 1C BB F7 CA F8 58 B9 02 22 31 46 38 46 BB F7 C4 F8 28 B9 01 22 F1 1C F8 1C BB F7 BE F8 A0 B1 31 46 20 46 FF F7 A4 FC 02 AB 32 46 21 46 00 20 CD E9 00 89 FF F7 B4 FA 20 B1 02 A9 9D F8 10 00 FF F7 B8 F9 20 46 FF F7 C3 FC 64 1C E4 B2 0D 2C CD D3
9:09:14 AM
9:09:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C0 09 81 80 DF F8 AC A3 00 24 00 BF 0A EB 84 07 05 EB 84 06 06 F1 78 01 04 22 38 46 BB F7 96 F8 78 B1 B0 6F 38 60 02 AB 3A 46 21 46 01 20 CD E9 00 89 FF F7 8E FA 20 B1 02 A9 9D F8 10 00 FF F7 92 F9 64 1C E4 B2 02 2C E0 D3 06 B0 C4 E5 2D E9 FC 47 D7 4D 4F F0 00 09 04 27 4C 46 4F F0 01 08 18 35 20 B2 69 46 06 46 C8 F7 94 FB B7 EB D4 0F 10 D9 BD F8 00 00 04 F0 07 02 00 28 05 EB D4 00 08 FA 02 F1
9:09:15 AM
9:09:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C1 09 81 80 00 78 01 D0 08 43 00 E0 88 43 05 EB D4 01 08 70 0D 2C 52 D2 C5 49 04 EB 44 00 50 39 01 EB 40 01 00 20 89 78 00 29 48 D0 2F 29 46 D2 DF E8 01 F0 92 18 1A 1C 1E 20 22 24 2B 33 46 4A 7A 7A 7A 7A 50 7A 53 56 59 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 7A 5C 5F 62 65 68 6B 6E 7A 7A 7A 71 74 77 00 80 20 60 E0 40 20 5E E0 20 20 5C E0 10 20 5A E0 08 20 58 E0 04 20 56 E0 BD F8 00 10 02 20 49 B3
9:09:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C2 09 81 80 49 F0 02 01 05 E0 BD F8 00 10 01 20 11 B3 49 F0 01 01 89 46 47 E0 01 A9 30 46 C8 F7 3C FC 9D F8 04 00 C0 06 56 D5 08 20 0A F0 A2 FF 9D F8 04 00 00 F0 80 01 30 46 C8 F7 22 FC 4B E0 BD F9 00 10 00 20 02 E0 BD F9 00 10 01 20 15 F0 09 F8 41 E0 4F F4 00 40 27 E0 4F F4 80 40 24 E0 4F F4 00 50 21 E0 4F F4 80 50 1E E0 4F F4 00 60 1B E0 4F F4 80 60 18 E0 4F F4 00 70 15 E0 4F F4 80 70 12 E0
9:09:16 AM
9:09:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C3 09 81 80 4F F4 00 00 0F E0 4F F4 80 00 0C E0 4F F4 00 10 09 E0 4F F4 80 30 06 E0 4F F4 00 30 03 E0 4F F4 80 20 00 E0 B0 B1 BD F9 00 60 00 21 CB 00 20 FA 03 F2 12 F0 FF 0F 09 D0 05 EB 01 03 D2 B2 1B 79 0E B1 13 43 00 E0 93 43 6A 18 13 71 49 1C C9 B2 04 29 EB D3 64 1C A4 B2 1D 2C FF F4 40 AF 48 46 FE F7 5E FE BD E8 FC 87 7C B5 68 46 C8 F7 14 FA 6E 4E 0D 24 50 3E 1A E0 04 EB 44 00 06 EB 40 05
9:09:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C4 09 81 80 28 79 40 06 03 D5 01 A9 20 46 C8 F7 C1 FA 9D F8 01 00 A0 42 09 D9 28 79 92 28 06 D0 94 28 04 D1 BD F9 04 10 20 46 C8 F7 72 FA 64 1C E4 B2 9D F8 00 00 A0 42 E0 D8 7C BD 38 B5 01 24 68 46 C3 F7 29 F9 30 B9 9D F8 00 00 C1 09 13 20 FE F7 C8 FF 00 B9 00 24 68 46 15 F0 D4 FA 30 B9 9D F8 00 00 C1 09 14 20 FE F7 BC FF 00 B9 00 24 20 46 38 BD 2D E9 F0 41 00 20 FF F7 30 FB 4D 4E 48 36 30 B1
9:09:17 AM
9:09:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C5 09 81 80 FF F7 64 FE 31 46 A6 F1 20 00 FF F7 95 FA FF F7 DC FE 47 4C 00 27 3C 34 A5 1D 4F F4 7A 40 FE F7 5B FC 06 EB 80 00 4F F0 01 08 C0 78 BC 46 48 B1 01 28 02 D0 02 28 0B D1 04 E0 60 78 40 B9 84 F8 01 80 04 E0 60 78 01 28 02 D1 84 F8 01 C0 01 27 4F F6 01 20 FE F7 40 FC 06 EB 80 00 C0 78 48 B1 01 28 02 D0 02 28 08 D1 04 E0 68 78 28 B9 85 F8 01 80 07 E0 68 78 01 28 02 D0 01 2F 02 D0 04 E0
9:09:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C6 09 81 80 85 F8 01 C0 20 46 FE F7 BE FB 29 48 21 46 08 30 FF F7 0E FA 26 4C 42 F2 10 75 08 34 20 78 01 28 16 D1 A4 F1 18 00 00 88 28 B1 A4 F1 18 00 C2 F7 81 FC A8 42 0C D9 12 F0 9F FB 4F F0 01 01 60 B1 5F F0 0E 00 C8 F7 A6 FA 19 48 10 38 C2 F7 6A FC 20 78 20 B1 02 28 02 D0 1C E0 0D 20 F2 E7 14 48 10 38 C2 F7 5B FC 12 48 08 38 00 88 28 B1 10 48 08 38 C2 F7 5F FC A8 42 0C D9 12 F0 7D FB 4F F0
9:09:18 AM
9:09:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C7 09 81 80 01 01 80 B1 5F F0 0D 00 C8 F7 84 FA 08 48 08 38 C2 F7 48 FC FE F7 47 FD FF F7 26 FF FE F7 CB FE BD E8 F0 41 48 E7 0E 20 EE E7 61 E7 24 5D 00 10 08 5C 00 10 01 20 70 47 03 B5 01 20 08 70 23 20 48 70 9D F8 00 00 88 70 0C BD A0 F1 19 01 06 29 03 D9 39 28 01 D0 00 20 70 47 01 20 70 47 70 B5 49 B1 8C 68 3C B1 25 78 E6 2D 04 D1 65 78 E6 2D 01 D1 A5 78 0D B1 00 20 70 BD E4 1C 8C 60 8C 89
9:09:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C8 09 81 80 E4 1E 8C 81 8C 8A E4 1E 8C 82 40 6A 00 28 F3 D0 F3 F7 62 FE 00 28 EF D0 01 20 70 BD 10 B5 CA 7B 8B 68 D4 07 A3 EB 01 02 01 D0 18 3A 00 E0 10 3A 03 2A 01 D2 00 20 10 BD 42 6A E6 24 B2 F9 9C 23 03 F8 03 4D E7 24 5C 70 00 24 9C 70 8B 68 DB 1E 8B 60 8B 89 DB 1C 8B 81 8B 8A DB 1C 8B 82 80 6A 00 28 E8 D0 F9 F7 76 FF 00 28 E4 D0 01 20 10 BD 10 B5 02 29 03 D1 40 6A 03 21 F3 F7 42 FF 01 20
9:09:19 AM
9:09:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 C9 09 81 80 10 BD 10 B5 A1 F5 80 71 03 39 02 D0 01 29 0B D1 04 E0 80 6A 40 B1 40 F2 03 11 03 E0 80 6A 18 B1 4F F4 82 71 F9 F7 51 FF 01 20 10 BD 10 B5 FF F7 DF FF 01 20 10 BD 10 B5 FF F7 E3 FF 01 20 10 BD 01 78 00 29 01 D1 01 21 01 70 70 47 F0 B5 04 46 90 F8 7D 01 D9 B0 01 28 04 D0 02 28 02 D0 01 20 59 B0 F0 BD 36 20 57 AD CD E9 00 05 02 46 00 23 49 A9 0E 20 DC F7 B3 F8 00 28 F1 D0 A0 20 CD E9
9:09:20 AM
9:09:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 CA 09 81 80 00 05 02 46 00 23 21 A9 0D 20 DC F7 A8 F8 00 28 E6 D0 BD F8 24 71 01 26 8D F8 08 60 3A 46 0D F5 93 71 0D F1 0A 00 BA F7 3B FE 0D F1 0A 00 00 25 3D 54 9D F8 8C 00 8D F8 33 60 D8 B3 00 21 21 AA 05 E0 53 18 5B 7A 03 2B 05 D0 49 1C C9 B2 88 42 F7 D8 03 20 C4 E7 BD F8 A0 00 A0 F5 40 41 23 39 29 D1 8D F8 34 60 BD F8 E0 60 0D F1 35 00 32 46 0D F1 E2 01 07 46 BA F7 13 FE F5 55 BD F8 02 61
9:09:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 CB 09 81 80 0D F1 56 00 32 46 41 A9 07 46 BA F7 09 FE F5 55 8D F8 09 50 F8 4A 02 A9 D4 F8 BC 01 19 F0 9E FF 0C 28 D6 D1 04 F5 D0 70 C2 F7 3C FB 03 20 84 F8 7D 01 CE E7 01 E0 4C F2 23 21 02 20 90 E7 2D E9 F0 4F AD F5 2B 7D 4F F0 02 0A A9 AC CD E9 00 A4 05 46 2A 23 52 46 A8 A9 0E 20 DC F7 40 F8 00 28 7E D0 40 F2 96 22 CD E9 00 24 00 23 02 A9 07 20 DC F7 35 F8 00 28 75 D0 BD F8 A0 02 42 F2 0F 71
9:09:21 AM
9:09:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 CC 09 81 80 88 42 00 D9 00 20 D5 F8 B8 11 00 26 A1 F8 80 01 BD F8 0A 80 57 E0 00 BF C6 EB C6 00 00 EB 80 01 02 A8 05 F5 DC 75 00 EB 41 04 28 68 A1 88 D0 F8 84 21 06 EB 86 00 00 EB 46 17 0A EB 47 00 11 52 29 68 4F F0 26 02 E0 8C D1 F8 84 11 02 EB 47 02 88 52 28 68 A2 88 D0 F8 84 11 4F F0 04 00 00 EB 47 09 01 EB 09 00 04 F1 06 01 BA F7 99 FD 28 68 A2 88 4F F0 00 0B D0 F8 84 01 02 44 02 F8 09 B0
9:09:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 CD 09 81 80 28 68 E2 8C D0 F8 84 11 28 20 00 EB 47 09 01 EB 09 00 04 F1 28 01 BA F7 83 FD 28 68 E2 8C 06 F1 01 06 D0 F8 84 01 F6 B2 02 44 02 F8 09 B0 29 68 4F F0 4A 02 B4 F8 48 00 D1 F8 84 11 02 EB 47 02 A5 F5 DC 75 88 52 46 45 A6 D3 D5 F8 B8 11 BD F8 0A 00 D1 F8 84 11 08 80 9D F8 08 00 28 80 00 E0 00 E0 01 20 0D F5 2B 7D BD E8 F0 8F 10 B5 21 B1 01 29 0D D0 02 29 0B D1 06 E0 D0 F8 B8 01 F6 F7
9:09:22 AM
9:09:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 CE 09 81 80 62 F9 02 28 06 D0 03 E0 90 F8 7D 01 05 28 01 D0 00 20 10 BD 01 20 10 BD 70 B5 05 46 0E 46 12 F0 2A FC 04 46 D5 F8 84 01 A0 42 00 D1 46 B1 28 46 FF F7 45 FF 00 28 02 D0 01 20 C5 F8 84 41 70 BD 00 20 70 BD 2D E9 F0 5F 90 F8 7D 11 0A 25 00 26 DF F8 28 A2 06 27 DF F8 28 92 04 46 00 F5 D0 7B 47 F2 30 58 0B 29 13 D2 DF E8 01 F0 12 06 14 37 60 71 8A 95 A8 D4 E2 00 D4 F8 B8 01 F6 F7 23 F9
9:09:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 CF 09 81 80 00 28 05 D1 58 46 C2 F7 4D FA 02 20 84 F8 7D 01 BD E8 F0 9F 9A F8 03 00 01 28 01 D0 05 28 F7 D1 D4 F8 BC 01 19 F0 F4 FE 38 B1 10 28 05 D0 58 46 C2 F7 40 FA 4A F6 C8 71 79 E0 20 46 FF F7 86 FE 02 28 E5 D1 04 F2 7D 14 A0 78 40 F0 02 00 A0 70 26 70 DD E7 84 F8 7D 51 DA E7 D4 F8 BC 01 19 F0 D7 FE 03 28 58 46 0C D0 C2 F7 24 FA 62 49 88 42 CE D9 04 20 84 F8 7D 01 BD E8 F0 5F EF 20 15 F0
9:09:23 AM
9:09:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D0 09 81 80 BA BE C2 F7 0F FA 04 F2 7D 14 05 20 20 70 E0 78 99 F8 00 10 20 EA 01 00 E0 70 4F F0 F0 00 15 F0 AA FE BD E8 F0 5F 00 20 08 F0 45 BD D4 F8 B8 01 F6 F7 C9 F8 00 28 AB D1 58 46 C2 F7 F3 F9 04 F2 7D 14 27 70 A0 78 40 F0 01 00 A0 70 A0 E7 D4 F8 BC 01 19 F0 9D FE 03 28 04 D0 58 46 C2 F7 E2 F9 84 F8 7D 71 94 F8 80 01 99 F8 00 20 10 42 8F D0 84 F8 7D 71 99 F8 00 10 88 43 84 F8 80 01 87 E7
9:09:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D1 09 81 80 D4 F8 B8 01 F6 F7 9F F8 00 28 81 D1 58 46 C2 F7 C9 F9 07 20 7A E7 41 46 D4 F8 BC 01 19 F0 B4 FE 0C 28 58 46 06 D0 C2 F7 C5 F9 49 F6 40 41 88 42 90 D8 6D E7 C2 F7 B6 F9 08 20 67 E7 D4 F8 BC 01 19 F0 66 FE 40 F6 B8 37 05 28 1D D0 04 DC 38 B1 02 28 7F F4 7F AF 11 E0 0F 28 0F D0 10 28 F8 D1 58 46 C2 F7 A7 F9 B8 42 B0 D9 09 20 84 F8 7D 01 F1 20 15 F0 40 FE 8A F8 03 60 49 E7 58 46 C2 F7
9:09:24 AM
9:09:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D2 09 81 80 99 F9 40 45 D4 D8 43 E7 58 46 C2 F7 93 F9 B8 42 CE D8 3D E7 94 F8 7F 01 C1 07 06 D0 84 F8 7D 51 20 F0 01 00 84 F8 7F 01 32 E7 84 F8 7D 61 2F E7 00 21 D4 F8 B8 01 F4 F7 59 FE 0B 20 26 E7 D0 F8 B8 01 0F 49 90 F8 38 00 C9 78 08 40 00 D0 01 20 70 47 D0 F8 B8 01 0A 4A 10 F8 38 1F 92 78 91 43 01 70 70 47 D0 F8 B8 01 05 49 90 F8 38 00 89 78 08 40 00 D0 01 20 70 47 90 5F 01 00 30 58 00 10
9:09:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D3 09 81 80 68 C1 01 00 90 F8 7F 11 21 F0 02 01 80 F8 7F 11 F1 E7 90 F8 7D 11 0B 29 19 D2 DF E8 01 F0 06 0E 0E 0E 0E 10 12 12 12 14 16 00 90 F8 7F 01 80 07 01 D5 01 20 DF E7 00 20 DD E7 02 20 DB E7 03 20 D9 E7 04 20 D7 E7 05 20 D5 E7 06 20 D3 E7 07 20 D1 E7 70 B5 05 46 01 24 D0 F8 BC 01 1C F0 97 F8 00 B1 02 24 D5 F8 BC 01 1C F0 AD F8 18 B1 24 F0 01 00 40 F0 04 04 20 46 70 BD 10 B5 D0 F8 B8 01
9:09:25 AM
9:09:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D4 09 81 80 F5 F7 E1 FF 00 28 06 D0 01 28 05 D0 02 28 05 D0 03 28 05 D0 00 20 10 BD 02 20 10 BD 03 20 10 BD 04 20 10 BD 10 B5 D0 F8 B8 01 F5 F7 DC FF 00 28 04 D0 01 28 02 D0 02 28 00 D0 02 20 10 BD 9A E7 D0 F8 B0 01 00 28 96 D0 41 6C 11 B1 08 46 F8 F7 F9 BC FD F7 EB BE 8E E7 70 B5 04 46 0D 46 16 46 00 F5 C8 70 C2 F7 DE F8 94 F8 7B 01 00 28 07 D1 32 46 29 46 D4 F8 B0 01 BD E8 70 40 FD F7 F6 BE
9:09:26 AM
9:09:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D5 09 81 80 70 BD 10 B5 0C 46 02 46 B1 F9 14 10 A0 68 8C B0 02 29 05 DD 01 78 40 78 01 29 01 D1 66 28 02 D0 00 20 0C B0 10 BD 2A 23 01 21 8D F8 15 30 8D F8 14 10 8D F8 16 00 01 A8 09 90 8D F8 05 30 05 A8 8D F8 04 10 0A 90 8D F8 06 10 00 20 0B 90 A0 68 00 23 80 1C A0 60 A0 89 21 46 80 1E A0 81 A0 8A 80 1E A0 82 D2 F8 B4 01 09 AA F3 F7 F5 FA 08 B1 01 20 D6 E7 20 46 D9 F7 5F FE D1 E7 70 B5 04 46
9:09:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D6 09 81 80 90 F8 7D 01 0B 25 02 28 11 D0 03 DC 78 B1 01 28 04 D1 0C E0 09 28 0A D0 0A 28 08 D0 29 B1 D4 F8 B8 01 F4 F7 63 FD 84 F8 7D 51 00 20 70 BD D4 F8 B8 01 F4 F7 5B FD 84 F8 7D 51 01 20 70 BD 10 B5 04 46 22 B1 01 2A 24 D0 02 2A 22 D1 11 E0 11 B1 01 29 05 D0 1D E0 D0 F8 B8 01 F5 F7 AD FE 18 E0 D0 F8 B8 01 71 4A 19 46 F5 F7 7C FE 88 B1 01 20 10 BD 71 B1 01 29 0C D1 94 F8 7D 01 48 B9 04 F5
9:09:27 AM
9:09:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D7 09 81 80 D0 70 C2 F7 4F F8 02 20 84 F8 7A 01 01 20 84 F8 7D 01 00 20 10 BD 10 B5 04 46 21 B1 01 29 17 D0 02 29 15 D1 05 E0 D0 F8 B8 01 88 B1 F5 F7 B7 FE 0E E0 FF F7 EE FE 94 F8 7A 11 02 29 08 D1 02 28 01 D0 03 28 04 D1 D4 F8 BC 01 1B F0 A0 FF 08 B1 00 20 10 BD 56 49 94 F8 80 01 09 78 08 43 84 F8 80 01 01 20 10 BD 10 B5 D0 F8 B8 01 F5 F7 A9 FD 00 28 00 D0 01 20 10 BD 70 B5 04 46 0D 46 00 20
9:09:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D8 09 81 80 3A B1 01 2A 10 D1 D4 F8 B8 01 BD E8 70 40 F5 F7 D4 BD 04 F5 C4 70 C2 F7 05 F8 29 46 D4 F8 B8 01 BD E8 70 40 F5 F7 AD BE 70 BD 10 B5 04 46 90 F8 78 01 D4 F8 B8 11 D1 F8 7C 11 48 70 D4 F8 B8 11 4F F4 E1 30 D1 F8 7C 11 48 60 12 F0 94 F9 C4 F8 84 01 D4 F8 B8 11 A0 1C C1 F8 84 01 20 46 FF F7 AE FC 04 F5 BE 74 00 20 60 70 E1 78 21 F0 01 01 E1 70 20 71 E0 6B D0 F8 7C 01 DD F7 4B F8 01 21
9:09:28 AM
9:09:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 D9 09 81 80 E0 6B F5 F7 14 FF 20 6C BD E8 10 40 18 F0 D8 BA 01 20 70 E6 00 29 03 D0 D0 F8 B8 01 F6 F7 29 BE 69 E6 10 B5 04 46 00 21 FF F7 36 FD 18 B1 D4 F8 B8 01 F5 F7 A3 FE D4 F8 B8 01 F5 F7 72 FE 38 B3 01 28 25 D0 02 28 23 D0 03 28 21 D1 04 F5 BE 74 4F F0 01 01 E0 6B F6 F7 0C FE E0 6B 00 21 D0 F8 7C 01 D0 F8 08 01 01 F0 47 F9 E0 6B D0 F8 7C 01 DD F7 10 F8 00 21 E0 6B F5 F7 D9 FE 20 6C 19 F0
9:09:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 DA 09 81 80 0F FD 20 6C 18 F0 9C FA 00 20 60 70 A4 F5 BE 74 94 F8 7A 01 00 28 07 D0 01 28 05 D0 02 28 03 D1 20 46 BD E8 10 40 0D E5 10 BD 00 00 C0 D4 01 00 68 C1 01 00 10 B5 FF 22 F7 4B 03 E0 10 F8 01 4B 54 40 1A 5D 0C 00 A1 F1 01 01 89 B2 F6 D1 C2 F1 FF 00 10 BD 70 B5 00 25 04 46 C5 71 D0 F8 48 01 00 28 04 D0 09 B1 D9 F7 27 FD C4 F8 48 51 70 BD 02 46 01 20 08 70 13 78 58 08 DB 07 07 D1 52 78
9:09:29 AM
9:09:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 DB 09 81 80 22 F0 01 02 00 EB 82 10 02 22 80 B2 0A 70 70 47 CB B2 5A 06 12 0E 02 70 7F 29 0C D9 C1 F3 07 21 89 00 41 EA 93 11 22 F0 01 02 02 70 41 F0 01 01 41 70 02 20 70 47 42 F0 01 01 01 70 01 20 70 47 F8 B5 84 68 06 46 0D 46 20 78 88 70 60 78 C8 70 A0 78 08 71 E4 1C 69 46 20 46 FF F7 C9 FF 28 80 9D F8 00 20 64 1C D1 1C 01 2A 00 D9 64 1C 10 B1 AC 60 04 44 01 E0 00 20 A8 60 20 78 28 73 60 78
9:09:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 DC 09 81 80 68 73 30 46 D9 F7 65 FE 6F F0 01 01 30 46 D9 F7 60 FE F8 BD 40 F0 10 01 81 42 05 D0 3F 29 0F D0 53 29 0D D0 73 29 0B D0 53 29 0F D0 04 DC 0F 29 10 D0 3F 29 04 D1 07 E0 73 29 09 D0 FF 29 01 D0 00 20 70 47 01 20 70 47 02 20 70 47 03 20 70 47 04 20 70 47 05 20 70 47 2D E9 F0 41 86 B0 00 20 0C 9F 90 46 1D 46 01 90 02 90 03 90 04 90 71 B1 0C 46 F9 26 07 20 8D F8 06 60 00 EB 85 00 8D F8
9:09:30 AM
9:09:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 DD 09 81 80 07 00 04 2F 14 D2 DF E8 07 F0 13 07 0B 0D D9 F7 51 FC 04 00 61 D0 EC E7 EF 20 8D F8 08 00 07 E0 3F 20 00 E0 53 20 8D F8 08 00 A0 68 40 1D A0 60 1F FA 88 F1 AD F8 04 10 9D F8 07 00 8D F8 00 00 9D F8 08 00 8D F8 01 00 0D F1 02 00 FF F7 60 FF 05 46 81 1C 68 46 FF F7 2D FF 8D F8 10 00 8D F8 11 60 E0 7B C0 07 A0 68 A0 EB 04 00 01 D0 18 38 00 E0 10 38 E9 1C 88 42 2C DB A0 68 40 1B C0 1E
9:09:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 DE 09 81 80 A0 60 9D F8 06 20 02 70 9D F8 07 20 42 70 9D F8 08 20 82 70 9D F8 02 20 C2 70 BD F8 04 20 00 1D 7F 2A 02 D9 9D F8 03 20 02 70 A0 89 04 AA 08 44 A0 81 A0 8A 08 44 A0 82 01 21 20 46 D9 F7 33 FD 01 28 07 D1 0D F1 11 02 01 21 20 46 D9 F7 2B FD 01 28 05 D0 20 46 D9 F7 0C FC 06 B0 BD E8 F0 81 20 46 FA E7 70 B5 00 25 04 46 04 29 0F D3 FF 29 0C D1 04 F5 B8 70 C1 F7 51 FE B4 F8 78 01 18 B1
9:09:31 AM
9:09:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 DF 09 81 80 04 F5 BC 70 C1 F7 4A FE A5 70 E5 70 70 BD 01 EB 01 10 04 EB 80 04 04 F1 6C 00 C1 F7 3F FE 04 F8 39 5F 65 70 70 BD 10 B5 04 29 04 D3 FF 29 0E D1 00 F5 A6 74 04 E0 01 EB 01 11 00 EB 81 04 44 34 20 68 00 28 03 D0 D9 F7 F7 FB 00 20 20 60 10 BD 10 B5 04 29 04 D3 FF 29 0E D1 00 F5 A4 74 04 E0 01 EB 01 11 00 EB 81 04 48 34 20 68 00 28 03 D0 D9 F7 E2 FB 00 20 20 60 10 BD 70 B5 04 29 04 D3
9:09:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E0 09 81 80 FF 29 16 D1 00 F5 A8 74 04 E0 01 EB 01 11 00 EB 81 04 5C 34 00 25 20 68 00 28 0A D0 41 68 21 60 01 B9 65 60 45 60 21 89 49 1E 21 81 D9 F7 C4 FB F1 E7 70 BD 70 B5 04 29 04 D3 FF 29 16 D1 00 F5 B0 74 04 E0 01 EB 01 11 00 EB 81 04 4C 34 00 25 20 68 00 28 0A D0 41 68 21 60 01 B9 65 60 45 60 21 89 49 1E 21 81 D9 F7 A7 FB F1 E7 70 BD 70 B5 05 46 0C 46 04 29 01 D3 FF 2C 0E D1 FF F7 93 FF
9:09:32 AM
9:09:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E1 09 81 80 21 46 28 46 FF F7 A4 FF 21 46 28 46 FF F7 B5 FF 21 46 28 46 BD E8 70 40 CC E7 70 BD 2D E9 FF 47 04 46 80 79 0F 46 91 46 03 28 74 D1 10 22 1B A1 48 46 BA F7 49 F8 00 28 6C D0 D9 F7 3B FB 05 00 69 D0 A8 68 02 AA 00 1D A8 60 27 F0 02 00 8D F8 08 00 01 21 28 46 D9 F7 66 FC 00 26 AD F8 04 60 4F F0 01 08 83 2F 2F D0 06 DC 43 2F 2C DA 13 2F 1E D0 23 2F 28 D1 05 E0 C3 2F 25 DD D3 2F 23 D0
9:09:33 AM
9:09:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E2 09 81 80 E3 2F 21 D1 03 A9 48 46 FF F7 32 FE AD F8 04 00 00 04 00 0C 0F D1 17 E0 B0 E2 06 00 21 4D 55 58 5F 54 45 53 54 5F 53 54 52 49 4E 47 00 00 00 00 40 46 AD F8 04 80 13 2F 17 D0 80 B2 40 1C 01 B2 4A 46 28 46 D9 F7 2F FC BD F8 04 00 FF 23 80 1C 02 B2 CD F8 00 80 29 46 20 46 FF F7 7D FE 05 00 19 D0 D4 F8 4C 01 D0 B1 2D E0 80 B2 08 EB 40 00 AD F8 04 00 47 46 01 AA 01 21 28 46 D9 F7 13 FC
9:09:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E3 09 81 80 A9 F1 01 02 01 21 28 46 D9 F7 0D FC AD F8 04 70 DA E7 00 E0 45 E0 00 20 04 B0 BD E8 F0 87 D4 F8 50 01 C4 F8 4C 01 A8 B1 41 68 C4 F8 50 11 09 B9 C4 F8 54 61 46 60 B4 F8 58 01 40 1E A4 F8 58 01 D4 F8 4C 01 30 B1 D4 F8 54 01 A0 B1 01 68 21 B1 08 46 FB E7 C4 F8 4C 51 23 E0 B0 F9 0C 20 B5 F9 0C 10 0A 44 AE 2A 06 D8 AA 68 D9 F7 DC FB 28 46 D9 F7 E2 FA 15 E0 B4 F9 58 01 B4 F9 5A 11 88 42
9:09:34 AM
9:09:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E4 09 81 80 03 DB 28 46 D9 F7 D8 FA C5 E7 6E 60 D4 F8 54 01 50 B1 45 60 04 F5 AA 74 25 60 A0 88 00 F1 01 00 A0 80 4F F0 01 00 B7 E7 C4 F8 50 51 F2 E7 30 B4 4B 78 FF 25 14 46 05 EB 93 03 4A 1C DB B2 04 2B 01 D3 FF 2B 17 D1 84 B1 04 2B 0A D2 52 78 92 07 01 D5 01 22 00 E0 00 22 03 EB 03 13 00 EB 83 03 DA 87 0A 46 30 BC E3 21 18 E7 81 78 C3 29 02 D0 30 BC FF 21 76 E6 30 BC 70 47 00 2A 02 D0 0A 46
9:09:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E5 09 81 80 13 21 0B E7 70 47 00 2A 02 D0 0A 46 43 21 05 E7 70 47 70 B5 04 46 07 25 2A B1 A5 71 BD E8 70 40 0A 46 C3 21 FA E6 FF 21 FF F7 E1 FE FF 21 20 46 FF F7 58 FE 00 20 60 71 20 71 FF 21 61 70 E0 71 A5 71 70 BD 12 B1 0A 46 23 21 E7 E6 81 78 C3 29 01 D0 FF 21 46 E6 70 47 10 B5 04 46 42 B1 0A 46 63 21 FF F7 DB FE 00 28 01 D0 01 20 60 71 10 BD A0 78 C3 28 FB D0 20 46 BD E8 10 40 FF 21 31 E6
9:09:35 AM
9:09:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E6 09 81 80 10 B5 04 46 32 B1 0A 46 A3 21 FF F7 C7 FE 00 20 60 71 10 BD A0 78 C3 28 FB D0 20 46 BD E8 10 40 FF 21 1F E6 00 2A 04 D1 81 78 C3 29 01 D0 FF 21 18 E6 70 47 00 2A 02 D0 0A 46 13 21 AE E6 70 47 00 2A 02 D0 0A 46 13 21 A8 E6 70 47 00 2A 02 D0 0A 46 13 21 A2 E6 70 47 30 B4 89 68 01 22 11 F8 01 3B 9C 07 02 D4 43 F0 02 03 00 22 83 2B 1E D0 0E DC 43 2B 1D D0 05 DC 13 2B 1E D0 23 2B 24 D1
9:09:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E7 09 81 80 30 BC 9F E7 53 2B 1C D0 63 2B 1E D1 30 BC A3 E7 C3 2B 10 D0 05 DC 93 2B 11 D0 A3 2B 15 D1 30 BC AE E7 D3 2B 0F D0 E3 2B 0F D1 30 BC 3F E7 30 BC 63 E7 30 BC 67 E7 30 BC 6B E7 30 BC B2 E7 30 BC B8 E7 30 BC BC E7 30 BC C0 E7 54 E7 10 B5 D2 78 FF 23 03 EB 92 02 D2 B2 04 2A 09 D3 FF 2A 15 D1 82 79 03 2A 01 D0 06 2A 10 D1 FF F7 B5 FF 0D E0 02 EB 02 12 00 EB 82 00 90 F8 38 20 03 2A 05 D1
9:09:36 AM
9:09:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E8 09 81 80 B0 F9 54 20 B0 F9 56 30 9A 42 01 DB 00 20 10 BD 00 22 4A 60 02 6D 42 B1 C2 F8 04 10 40 F8 50 1F 81 88 49 1C 81 80 01 20 10 BD C1 64 F6 E7 70 B5 06 46 C8 78 FF 21 01 EB 90 00 C4 B2 03 20 04 2C 06 D3 FF 2C 1C D1 B1 79 02 29 19 D1 B0 71 1A E0 04 EB 04 11 06 EB 81 05 95 F8 38 10 02 29 10 D0 04 29 0D D1 21 46 30 46 FF F7 01 FE 21 46 30 46 FF F7 78 FD 00 20 E8 87 A8 87 05 20 85 F8 38 00
9:09:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 E9 09 81 80 70 BD 85 F8 38 00 21 46 30 46 BD E8 70 40 69 E5 70 B5 06 46 C8 78 FF 21 01 EB 90 00 C4 B2 04 2C 15 D2 04 EB 04 10 06 EB 80 05 95 F8 38 00 04 28 0D D1 21 46 30 46 FF F7 DA FD 21 46 30 46 FF F7 51 FD 00 20 E8 87 A8 87 05 20 85 F8 38 00 70 BD 2D E9 FF 41 D0 F8 60 51 04 46 00 26 DD B1 68 68 00 27 C4 F8 60 01 08 B9 C4 F8 64 71 6F 60 B4 F8 68 01 69 46 40 1E A4 F8 68 01 28 46 FF F7 60 FC
9:09:37 AM
9:09:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 EA 09 81 80 9D F8 04 00 FF F7 86 FC 06 28 0D D2 DF E8 00 F0 0C 06 0C 0C 0E 13 01 20 04 B0 1F E5 6A 46 29 46 20 46 FF F7 53 FF 06 46 4E B1 0B E0 69 46 20 46 FF F7 7D FF 03 E0 69 46 20 46 FF F7 A9 FF 28 46 D9 F7 3A F9 E7 71 E6 E7 2D E9 F3 47 04 46 C0 79 00 25 78 B9 D4 F8 48 01 D9 F7 C5 FB 01 20 E0 71 65 82 25 82 65 72 25 72 00 20 21 18 40 1C CD 72 04 28 FA D3 D4 F8 48 01 28 B9 D9 F7 DB F8 C4 F8
9:09:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 EB 09 81 80 48 01 00 28 7A D0 E0 79 07 27 04 26 4F F0 06 09 4F F0 03 08 09 28 72 D2 DF E8 00 F0 D7 05 1A 2F 3F 5B 72 8A 9B 00 D4 F8 48 01 D9 F7 9C FB 9D F8 04 00 F9 28 20 D1 01 AA 01 21 D4 F8 48 01 D9 F7 F2 F9 01 28 5A D1 60 8A 40 1C 60 82 02 20 7E E0 9D F8 04 00 F9 28 0F D0 01 AA 01 21 D4 F8 48 01 D9 F7 E1 F9 01 28 49 D1 9D F8 04 00 E0 72 60 8A 40 1C 60 82 84 F8 07 80 AB E0 01 AA 01 21 D4 F8
9:09:38 AM
9:09:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 EC 09 81 80 48 01 D9 F7 D0 F9 01 28 38 D1 9D F8 04 00 20 73 60 8A 40 1C 60 82 E6 71 9B E0 01 AA 01 21 D4 F8 48 01 D9 F7 C0 F9 01 28 28 D1 9D F8 04 10 61 73 4A 08 22 82 60 8A 05 23 40 1C 80 B2 60 82 E3 71 C9 07 05 D0 84 F8 08 80 60 72 7A B3 84 F8 07 90 7F E0 01 AA 01 21 D4 F8 48 01 D9 F7 A4 F9 01 28 7A D1 9D F8 04 00 A0 73 21 8A 01 EB D0 10 20 82 60 8A 40 1C 60 82 26 72 60 72 E7 E7 6C E0 64 E0
9:09:39 AM
9:09:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 ED 09 81 80 20 8A 28 B3 A1 8A 88 42 0A D8 01 AA 01 21 D4 F8 48 01 D9 F7 88 F9 01 28 5E D1 60 8A 40 1C 60 82 60 8A 61 7A 40 1A 21 8A 88 42 52 DB E7 71 50 E0 01 AA 01 21 D4 F8 48 01 D9 F7 75 F9 01 28 4B D1 60 8A 40 1C 60 82 9D F8 04 00 A0 72 08 20 E0 71 3F E0 9D F8 04 00 F9 28 37 D1 01 AA 01 21 D4 F8 48 01 D9 F7 60 F9 01 28 36 D1 60 8A 40 1C 60 82 21 7A 04 F1 0B 00 FF F7 1D FB A1 7A 88 42 24 D1
9:09:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 EE 09 81 80 B4 F9 68 01 B4 F9 6A 11 88 42 25 DA D4 F8 48 01 45 60 D4 F8 64 01 98 B1 D4 F8 48 11 C0 F8 04 10 04 F5 A4 74 20 68 E0 61 20 8C 00 F1 01 00 20 84 25 60 A4 F5 A4 74 20 46 FF F7 CA FE E5 71 08 E0 D4 F8 48 01 C4 F8 60 01 EA E7 01 21 20 46 FF F7 01 FB 01 20 BD E8 FC 87 01 21 20 46 FF F7 FA FA 00 20 F7 E7 2D E9 F0 41 07 46 16 46 0C 46 00 25 06 E0 21 78 38 46 FF F7 E7 FE 64 1C 6D 1C AD B2
9:09:40 AM
9:09:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 EF 09 81 80 B5 42 F6 D3 01 20 BD E8 F0 81 10 B5 04 46 80 79 A4 B0 01 28 11 D0 20 78 22 AB 86 22 69 46 C6 F7 A3 FC 00 28 07 D0 BD F8 88 20 1A B1 69 46 20 46 FF F7 D8 FF 01 20 24 B0 10 BD 00 20 FB E7 70 B5 42 78 04 23 D0 F8 50 11 00 24 C0 F8 4C 11 59 B1 4D 68 C0 F8 50 51 0D B9 C0 F8 54 41 4C 60 B0 F8 58 11 49 1E A0 F8 58 11 FF 25 52 1C D2 B2 04 2A 00 D3 00 22 02 EB 02 11 00 EB 81 01 91 F8 38 60
9:09:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F0 09 81 80 03 2E 0A D1 B1 F8 64 60 3E B1 EB B1 02 EB 02 13 00 EB 83 03 DB 8F BB B9 04 E0 5B 1E 13 F0 FF 03 E3 D1 11 E0 CB 6D 4B 64 73 B1 5E 68 CE 65 06 B9 0C 66 5C 60 B1 F8 64 30 5B 1E A1 F8 64 30 49 6C 11 B1 42 70 01 20 70 BD 45 70 00 20 70 BD 00 20 B1 F9 0C 30 18 44 7F 28 01 DB 7F 20 04 E0 09 68 00 B2 09 B1 7F 28 F3 DB 04 21 11 70 7F 28 01 DD 05 21 11 70 70 47 38 B5 04 46 05 E0 D8 F7 79 FF
9:09:41 AM
9:09:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F1 09 81 80 C4 F8 4C 01 00 28 32 D0 D4 F8 4C 01 85 89 00 2D F4 D0 61 78 04 29 0E D2 68 B1 01 EB 01 10 04 EB 80 00 74 30 C1 F7 BE F9 60 78 00 EB 00 10 04 EB 80 00 A0 F8 40 50 D4 F8 4C 01 6B 46 2A 46 81 68 20 78 C6 F7 06 FC BD F8 00 10 79 B1 09 B2 D4 F8 4C 01 D9 F7 FE F8 BD F8 00 00 28 1A 05 04 2D 0C E9 D1 D4 F8 4C 01 81 89 11 B1 05 E0 00 20 38 BD D8 F7 3F FF C4 F8 4C 01 01 20 38 BD 2D E9 FC 41
9:09:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F2 09 81 80 04 46 45 1C 00 20 8D F8 04 00 A0 79 00 28 78 D0 D4 F8 4C 01 00 28 76 D1 28 78 FF 28 09 D0 00 EB 00 10 04 EB 80 00 90 F8 38 10 03 29 01 D1 40 6C 40 B9 20 46 FF F7 43 FF 00 28 62 D0 D4 F8 4C 01 00 28 60 D1 D8 F7 F6 FE C4 F8 4C 01 00 28 58 D0 28 78 00 EB 00 10 04 EB 80 00 74 30 C1 F7 6A F9 01 46 D4 F8 84 01 0A 22 4F F4 7A 76 40 68 B0 FB F2 F3 28 78 00 EB 00 10 04 EB 80 00 B0 F8 40 20
9:09:42 AM
9:09:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F3 09 81 80 72 43 B2 FB F3 F2 52 1C 91 42 39 D3 41 6C 01 AA 20 46 FF F7 5C FF 06 00 32 D0 D4 F8 4C 01 9D F8 04 20 81 68 11 44 81 60 28 78 00 EB 00 10 04 EB 80 00 40 6C B0 F9 0C 10 B1 42 0A DA AE 2E 08 D2 31 46 D9 F7 F1 F8 29 78 01 EB 01 11 04 EB 81 01 48 64 28 78 00 EB 00 10 04 EB 80 00 40 6C 98 B1 83 68 32 46 00 21 D4 F8 4C 01 D8 F7 27 FF 07 46 B7 42 0B D0 D4 F8 4C 01 D8 F7 BB FE C4 F8 4C 01
9:09:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F4 09 81 80 00 20 BD E8 FC 81 2B E0 00 27 F1 E7 01 20 00 90 2B 78 3A 46 20 46 D4 F8 4C 11 FF F7 1D FA C4 F8 4C 01 00 28 ED D0 28 78 39 46 00 EB 00 10 04 EB 80 00 40 6C D9 F7 4D F8 09 E0 00 BF D8 F7 99 FE 29 78 01 EB 01 11 04 EB 81 01 48 64 40 B1 28 78 00 EB 00 10 04 EB 80 00 40 6C 81 89 00 29 ED D0 20 46 FF F7 08 FF 00 28 CB D0 01 20 C9 E7 38 B5 04 46 A2 B9 02 20 0B 46 00 22 00 90 11 46 20 46
9:09:43 AM
9:09:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F5 09 81 80 FF F7 EA F9 00 28 0B D0 D4 F8 4C 11 49 B1 B4 F9 58 11 B4 F9 5A 21 91 42 06 DB D8 F7 8D FE 00 20 38 BD C4 F8 4C 01 0C E0 00 21 41 60 D4 F8 54 11 51 B1 48 60 04 F5 AA 74 20 60 A0 88 00 F1 01 00 A0 80 4F F0 01 00 38 BD C4 F8 50 01 F2 E7 10 B5 81 79 01 29 03 D0 02 29 01 D0 00 20 10 BD 00 22 FF 21 FF F7 C4 FF 00 28 F8 D0 01 20 10 BD 38 B5 04 46 03 20 0B 46 00 22 00 90 11 46 20 46 FF F7
9:09:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F6 09 81 80 AB F9 00 28 0B D0 D4 F8 4C 11 49 B1 B4 F9 58 11 B4 F9 5A 21 91 42 06 DB D8 F7 4E FE 00 20 38 BD C4 F8 4C 01 0D E0 00 21 41 60 D4 F8 54 11 59 B1 C1 F8 04 00 04 F5 AA 74 20 60 A0 88 00 F1 01 00 A0 80 4F F0 01 00 38 BD C4 F8 50 01 F2 E7 F3 B5 05 46 80 79 85 B0 02 28 03 D0 03 28 01 D0 06 28 37 D1 D8 F7 E7 FD 06 00 33 D0 00 27 01 97 9D F8 18 10 3C 46 38 46 02 97 83 29 16 D0 0A DC 43 29
9:09:44 AM
9:09:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F7 09 81 80 21 D0 04 DC 13 29 1D D0 23 29 1C D1 0F E0 53 29 19 D1 15 E0 C3 29 16 D0 02 DC 93 29 13 D1 11 E0 D3 29 0F D0 E3 29 0E D1 0A E0 08 24 0B E0 04 24 01 AA FF 21 11 54 40 1C C0 B2 A0 42 FA D3 02 E0 02 24 00 E0 01 24 21 46 03 A8 FF F7 E1 F8 01 28 02 D9 00 20 07 B0 F0 BD B0 68 06 AA 00 1D B0 60 01 21 30 46 D8 F7 DF FE 03 AA 01 21 30 46 D8 F7 DA FE 24 B1 01 AA 21 46 30 46 D8 F7 D4 FE 01 20
9:09:45 AM
9:09:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F8 09 81 80 00 90 B6 F9 0C 20 FF 23 31 46 28 46 FF F7 24 F9 00 28 DF D0 D5 F8 4C 11 41 B1 B5 F9 58 11 B5 F9 5A 21 91 42 05 DB D8 F7 C7 FD D2 E7 C5 F8 4C 01 0B E0 47 60 D5 F8 54 11 51 B1 48 60 05 F5 AA 75 28 60 A8 88 00 F1 01 00 A8 80 4F F0 01 00 C1 E7 C5 F8 50 01 F2 E7 01 22 04 29 0E D3 FF 29 19 D1 81 78 C3 29 C1 78 03 D0 03 7F 99 42 02 D8 11 E0 01 29 0F D9 02 71 10 46 70 47 01 EB 01 11 00 EB
9:09:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 F9 09 81 80 81 01 90 F8 22 00 91 F8 3A 30 83 42 02 D9 10 46 8A 87 70 47 00 20 70 47 70 B5 16 46 05 46 0C 46 C3 2A 03 D0 FF F7 D7 FF 48 BB 05 E0 E8 78 01 28 02 D9 01 20 28 71 22 E0 04 2C 01 D3 FF 2C 1E D1 04 EB 04 10 05 EB 80 00 02 2E 04 D0 03 2E 0E D0 C3 2E 14 D1 1A E0 04 2C 03 D8 90 F8 38 00 02 28 0D D1 21 46 28 46 BD E8 70 40 00 22 BF E6 04 2C 05 D8 90 F8 38 00 04 28 03 D0 03 28 01 D0 00 20
9:09:46 AM
9:09:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 FA 09 81 80 70 BD 21 46 28 46 BD E8 70 40 F0 E6 31 46 28 46 BD E8 70 40 1B E7 2D E9 F0 47 04 46 0E 46 01 EB 06 10 04 EB 80 05 04 29 06 D3 FF 2E 02 D0 00 20 BD E8 F0 87 27 79 01 E0 A8 8F C7 B2 67 B1 4F F0 00 08 4F F0 05 09 02 2A 08 D0 03 2A 15 D0 C3 2A 20 46 18 D0 FF F7 06 F9 38 46 E9 E7 20 46 FF F7 01 F9 04 2E 04 D9 40 46 84 F8 05 80 A0 71 F3 E7 A5 F8 3E 80 85 F8 38 90 EE E7 20 46 FF F7 F2 F8
9:09:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 FB 09 81 80 04 2E F5 D3 E8 E7 FF F7 ED F8 FF 21 84 F8 05 80 61 70 84 F8 07 80 07 20 E8 E7 2D E9 F0 41 04 46 80 78 4F F0 FF 08 60 B3 04 F5 BC 76 C3 28 05 D1 E0 78 01 28 02 D9 35 46 67 8B 02 E0 27 8B 04 F5 B8 75 28 46 C0 F7 36 FF B8 42 1A D9 28 46 C0 F7 25 FF A2 78 41 46 20 46 FF F7 5E FF 38 B9 A2 78 41 46 20 46 FF F7 97 FF 10 F0 FF 0F 09 D1 E0 78 40 1C E0 70 A0 78 C3 28 00 D1 35 46 28 46 C0 F7
9:09:47 AM
9:09:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 FC 09 81 80 11 FF A0 79 03 28 01 D0 06 28 2C D1 5F F0 00 06 06 EB 06 10 04 EB 80 05 95 F8 39 00 F8 B1 05 F1 6C 00 07 46 C0 F7 06 FF 21 8C 88 42 17 D3 38 46 C0 F7 F4 FE 95 F8 39 20 31 46 20 46 FF F7 2C FF 30 B9 95 F8 39 20 31 46 20 46 FF F7 64 FF 30 B9 15 F8 3A 0F 40 1C 28 70 38 46 C0 F7 E3 FE 76 1C F6 B2 04 2E D4 D3 8E E4 2D E9 F0 41 05 46 0E 46 04 29 07 D2 06 EB 06 10 05 EB 80 04 94 F8 38 00
9:09:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 FD 09 81 80 03 28 01 D0 00 20 7E E4 A0 8F 00 27 00 B1 A7 87 A8 78 C3 28 1B D0 28 46 FF F7 64 F8 31 46 28 46 FF F7 E5 F8 31 46 28 46 FF F7 21 FE 00 28 EA D0 A0 8F 00 B1 A7 87 04 20 04 F8 38 0F 03 20 60 70 A0 78 40 1C A0 70 04 F1 34 00 C0 F7 AB FE 01 20 59 E4 2D E9 F0 41 00 25 06 46 05 27 05 EB 05 10 06 EB 80 04 94 F8 38 00 02 28 1A D0 03 28 02 D0 04 28 18 D0 20 E0 29 46 30 46 FF F7 B5 FF 80 B9
9:09:48 AM
9:09:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 FE 09 81 80 05 EB 05 11 06 EB 81 01 04 20 81 F8 38 00 03 20 04 F8 39 0F 60 78 40 1C 60 70 04 F1 33 00 C0 F7 81 FE 00 20 2F E4 A0 8F 00 28 FB D0 84 F8 38 70 29 46 30 46 FF F7 9B F8 6D 1C ED B2 04 2D CD D3 01 20 20 E4 10 B5 04 46 80 78 00 28 13 D1 20 46 FF F7 BF FF 00 28 0E D0 C3 21 20 46 FF F7 F7 FD E0 78 40 1C E0 70 C3 20 A0 70 04 F5 B8 70 BD E8 10 40 C0 F7 57 BE 10 BD 2D E9 F0 47 04 46 FF 20
9:09:48 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 04 FF 09 81 80 60 70 00 20 A0 70 E0 70 20 71 60 71 A0 71 E0 71 04 20 C6 4E A4 F8 6A 01 A4 F8 5A 01 D6 F8 06 00 60 61 D6 F8 0A 00 A0 61 F0 89 A0 83 00 25 4F F0 09 08 4F F0 03 09 00 BF 05 EB 45 00 04 EB 40 00 31 68 C0 F8 1E 10 B1 88 41 84 05 EB 05 10 B7 49 04 EB 80 07 07 F1 38 00 44 22 10 31 B9 F7 4B F9 6D 1C A7 F8 56 80 ED B2 A7 F8 66 90 04 2D E3 D3 9E E6 81 79 09 B1 00 20 70 47 01 79 09 B1 00 21
9:09:49 AM
9:09:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 00 09 81 80 01 71 01 21 81 71 08 46 70 47 70 B5 83 79 03 2B 29 D1 04 29 27 D2 01 EB 01 13 00 EB 83 04 94 F8 38 30 02 2B 1F D0 04 2B 1D D0 03 2B 19 D0 FF F7 1E FD 00 28 16 D0 A0 8F 00 25 00 B1 A5 87 02 20 04 F8 38 0F 60 70 01 20 A0 70 A4 F1 38 04 04 F1 6C 00 C0 F7 E7 FD 04 F1 74 00 C0 F7 E3 FD A4 F8 40 50 01 20 70 BD 00 20 70 BD 2D E9 F0 47 4F F0 00 08 08 9F 04 29 A7 F8 00 80 07 D2 01 EB 01 11
9:09:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 01 09 81 80 00 EB 81 04 94 F8 38 00 03 28 01 D0 00 20 4F E6 A0 6C 88 B9 E0 6C A0 64 00 28 5D D0 41 68 E1 64 09 B9 C4 F8 50 80 C0 F8 04 80 B4 F8 54 00 40 1E A4 F8 54 00 A0 6C E8 B3 01 46 B0 F9 0C 00 1E 46 B0 42 00 DB 18 46 85 B2 89 68 91 46 26 E0 00 BF B9 F7 66 F8 38 88 28 44 38 80 A0 6C D8 F7 49 FB A0 64 40 B3 10 E0 E0 6C A0 64 20 B3 41 68 E1 64 09 B9 C4 F8 50 80 C0 F8 04 80 B4 F8 54 00 40 1E
9:09:50 AM
9:09:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 02 09 81 80 A4 F8 54 00 A0 6C B0 B1 81 68 72 1B B0 F9 0C 00 96 B2 A9 44 B0 42 00 DB 30 46 85 B2 AE 42 2A 46 48 46 D5 D8 B9 F7 3C F8 38 88 29 B2 28 44 38 80 A0 6C 01 E0 10 E0 02 E0 D8 F7 CB FC 08 E0 B4 F8 54 00 00 28 CF D1 07 E0 D8 F7 13 FB A0 64 18 B1 A0 6C 81 89 00 29 F7 D0 01 20 E9 E5 70 B5 00 24 1C 80 04 29 11 D2 01 EB 01 11 00 EB 81 01 91 F8 38 50 03 2D 09 D1 45 79 3D B9 CD 8F 2D B9 B1 F9
9:09:51 AM
9:09:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 03 09 81 80 64 50 B1 F9 66 60 B5 42 01 DB 00 20 70 BD 54 60 0C 6E 64 B1 C4 F8 04 20 41 F8 60 2F 8C 88 64 1C 8C 80 91 8A 19 80 FF F7 A9 FB 01 20 70 BD CA 65 F2 E7 70 B5 06 46 80 79 07 28 04 D0 18 B1 03 28 03 D0 00 20 70 BD 01 20 70 BD FF 21 30 46 FE F7 C9 FE 00 25 05 EB 05 10 06 EB 80 04 94 F8 38 00 03 28 1B D1 29 46 30 46 FE F7 BC FE 29 46 30 46 FE F7 3D FF 29 46 30 46 FF F7 79 FC 04 F1 38 04
9:09:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 04 09 81 80 A0 78 00 F1 01 00 A0 70 4F F0 04 00 20 70 4F F0 03 00 60 70 04 F1 34 00 C0 F7 04 FD 6D 1C ED B2 04 2D D7 D3 06 20 B0 71 30 46 FF F7 8B FE CA E7 70 B5 05 46 00 24 21 46 28 46 FE F7 18 FF 64 1C E4 B2 04 2C F7 D3 28 46 BD E8 70 40 FF 21 FE F7 0E BF 70 B5 04 46 00 78 FF 28 25 D0 A0 79 08 28 18 D2 DF E8 00 F0 21 04 17 17 17 17 11 15 20 46 FF F7 2D FC 02 25 A5 70 01 20 E0 70 04 F5 B8 70
9:09:52 AM
9:09:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 05 09 81 80 C0 F7 D0 FC A5 71 05 E0 20 46 FF F7 5B FE 01 E0 00 20 A0 71 20 46 FF F7 31 FB 20 46 FF F7 75 FA 20 46 BD E8 70 40 78 E5 70 BD 00 00 5C E2 06 00 38 B5 04 46 00 20 E0 81 20 89 06 28 0C D3 68 46 0C F0 79 FC 00 28 08 D0 20 88 B0 F5 29 6F 05 D0 A0 F5 20 60 91 38 05 D0 00 20 38 BD 69 46 00 20 62 68 02 E0 69 46 01 20 62 68 1B F0 33 FB 00 28 F3 D0 E0 81 01 20 38 BD 38 B5 04 46 00 20 E0 81
9:09:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 06 09 81 80 20 89 06 28 0C D8 68 46 0C F0 55 FC 00 28 08 D0 20 88 B0 F5 29 6F 05 D0 A0 F5 20 60 91 38 06 D0 00 20 38 BD 23 89 69 46 00 20 62 68 03 E0 23 89 69 46 01 20 62 68 1B F0 24 FB 00 28 F1 D0 68 46 0C F0 3A FC 00 28 EC D0 20 89 E0 81 01 20 38 BD FE 49 08 B5 C9 68 FE 4A B1 FB F2 F1 AD F8 00 10 41 68 BD F8 00 20 0A 80 02 21 C1 81 01 20 08 BD 10 B5 04 46 00 89 8A B0 04 28 02 D2 00 20 0A B0
9:09:53 AM
9:09:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 07 09 81 80 10 BD 20 88 F0 30 C0 B2 0C F0 02 FA 69 46 0C F0 55 FA 00 28 F3 D0 60 68 01 99 01 60 02 99 41 60 08 20 E0 81 01 20 EA E7 30 B5 04 46 00 89 8B B0 04 28 02 D2 00 20 0B B0 30 BD 20 88 F0 30 C0 B2 0C F0 E6 F9 05 46 69 46 0C F0 38 FA 00 28 F2 D0 60 68 01 68 01 91 40 68 02 90 69 46 28 46 0C F0 5B FA 00 28 E7 D0 08 20 E0 81 01 20 E3 E7 70 B5 AD F5 4A 7D 04 46 68 46 07 F0 9E FC 00 28 23 D0
9:09:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 08 09 81 80 23 88 6A 46 50 1C D3 49 97 2B 03 D0 B3 F5 CB 7F 26 D1 1C E0 8B 88 CD 88 1D 44 13 46 52 5D 8D 88 1B E0 A9 B2 0D 18 02 EB C2 01 01 EB 02 16 60 68 A9 5D 20 F8 02 1B 71 19 AA 5D 49 1C B8 F7 B0 FE A8 5D 80 1C E0 81 01 20 0D F5 4A 7D 70 BD 8B 89 CD 89 1D 44 13 46 52 5D 8D 89 5B 5D 9A 42 E0 D3 00 20 F1 E7 7C B5 05 46 00 88 20 F0 78 04 A4 F5 80 74 07 2C 17 D8 04 EB D4 76 C6 F3 47 00 0C F0
9:09:54 AM
9:09:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 09 09 81 80 4D FA 26 F0 01 01 61 1A CC B2 69 46 0C F0 FE FA 00 28 07 D0 69 68 02 20 3C B1 BD F8 02 20 0A 80 E8 81 01 20 7C BD 00 20 7C BD BD F8 00 20 F6 E7 2D E9 FC 41 05 46 00 88 20 F0 78 04 A4 F5 80 74 07 2C 20 D8 04 EB D4 76 C6 F3 47 00 0C F0 26 FA 07 46 26 F0 01 00 20 1A C4 B2 69 46 38 46 0C F0 D5 FA 00 28 0D D0 69 68 02 20 09 88 6C B1 AD F8 02 10 E8 81 69 46 38 46 0C F0 D5 FA 00 28 00 D0
9:09:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 0A 09 81 80 01 20 BD E8 FC 81 00 20 FB E7 AD F8 00 10 F0 E7 1F B5 04 46 00 88 20 F0 78 00 A0 F5 7A 41 80 39 08 D0 01 29 06 D0 02 29 04 D0 03 29 02 D0 00 20 04 B0 10 BD 80 30 C0 B2 0C F0 F0 F9 69 46 0C F0 3C FA 00 28 F4 D0 60 68 9D F8 03 10 01 70 01 20 E0 81 ED E7 7F B5 04 46 00 88 20 F0 78 00 A0 F5 7A 41 80 39 08 D0 01 29 06 D0 02 29 04 D0 03 29 02 D0 00 20 04 B0 70 BD 80 30 C0 B2 0C F0 CE F9
9:09:55 AM
9:09:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 0B 09 81 80 05 46 69 46 0C F0 19 FA 00 28 F3 D0 60 68 69 46 00 78 8D F8 03 00 01 20 E0 81 28 46 0C F0 1A FA 00 28 E7 D0 01 20 E5 E7 10 B5 90 B0 04 46 68 46 10 F0 2F F9 00 28 05 D0 61 68 9D F8 38 00 08 70 01 20 E0 81 10 B0 10 BD 30 B5 04 46 40 68 8F B0 05 78 02 2D 0F D2 68 46 10 F0 1B F9 00 28 08 D0 8D F8 38 50 68 46 10 F0 3A F9 00 28 01 D0 01 20 E0 81 0F B0 30 BD 00 20 FB E7 10 B5 90 B0 04 46
9:09:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 0C 09 81 80 68 46 10 F0 06 F9 00 28 DC D0 61 68 9D F8 39 00 08 70 01 20 E0 81 D5 E7 30 B5 04 46 40 68 8F B0 05 78 02 2D 0E D2 68 46 10 F0 F3 F8 00 28 E0 D0 8D F8 39 50 68 46 10 F0 12 F9 00 28 D9 D0 01 20 E0 81 D6 E7 00 20 D4 E7 30 B5 41 68 04 46 95 B0 08 88 20 28 02 D0 00 20 15 B0 30 BD D1 F8 02 00 02 90 D1 F8 06 00 03 90 88 7A 60 F3 1F 62 C8 7A 60 F3 17 42 08 7B 60 F3 0F 22 48 7B 0E 31 60 F3
9:09:56 AM
9:09:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 0D 09 81 80 07 02 04 92 14 22 05 A8 B8 F7 8A FD 38 25 20 22 02 A9 0B A8 B8 F7 EF FD 01 20 8D F8 28 00 0A A8 0E F0 B7 FE 00 28 D7 D0 24 20 13 A9 CD E9 00 01 02 46 2B 46 0A A9 01 20 DA F7 11 F8 00 28 CB D0 20 20 E0 81 01 20 C7 E7 30 B5 04 46 9F B0 00 20 E0 81 20 89 04 28 08 D3 20 88 4F F0 04 05 A0 F5 90 50 10 38 04 D0 05 28 1A D0 00 20 1F B0 30 BD 1D A9 1A A8 C0 F7 FF F9 00 28 F7 D0 61 68 9D F8
9:09:57 AM
9:09:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 0E 09 81 80 6D 00 08 70 61 68 9D F8 6E 00 48 70 61 68 9D F8 6F 00 88 70 BD F8 70 00 0A 21 B0 FB F1 F0 12 E0 68 46 0F F0 A5 FF 00 28 E0 D0 61 68 9D F8 56 00 08 70 61 68 9D F8 57 00 48 70 61 68 9D F8 58 00 88 70 9D F8 59 00 61 68 C8 70 05 E0 24 7B 00 10 80 51 01 00 F2 4D 07 00 E5 81 01 20 C6 E7 10 B5 04 46 9A B0 00 20 E0 81 20 88 A0 F5 90 50 10 38 02 D0 05 28 39 D1 09 E0 20 89 0A 28 35 D3 60 68
9:09:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 0F 09 81 80 12 F0 B1 F8 00 28 2E D0 0A 20 2A E0 20 89 04 28 2B D3 60 68 01 78 17 29 27 D8 41 78 3B 29 24 D8 81 78 3B 29 21 D8 C0 78 63 28 1E D8 68 46 0F F0 5F FF 00 28 17 D0 60 68 00 78 8D F8 56 00 60 68 40 78 8D F8 57 00 60 68 80 78 8D F8 58 00 60 68 C0 78 8D F8 59 00 68 46 0F F0 59 FF 00 28 02 D0 04 20 E0 81 01 20 1A B0 10 BD 00 20 FB E7 1F B5 04 46 00 89 05 28 01 D2 00 20 99 E6 03 A9 68 46
9:09:58 AM
9:09:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 10 09 81 80 C0 F7 79 F9 DE F7 31 FF 50 B1 13 F0 57 F9 01 28 06 D1 69 46 01 22 08 46 13 F0 97 FA 00 28 EC D0 BD F8 00 00 62 68 01 0A 11 70 61 68 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00 C8 70 61 68 9D F8 04 00 08 71 05 20 E0 81 01 20 70 E6 7F B5 04 46 00 89 0A 28 0D D3 65 68 03 AA 69 46 28 46 C0 F7 98 F9 00 28 06 D0 BD F8 00 00 40 F6 29 01 88 42 01 D9 00 20 7D E6 28 46 12 F0 34 F8 0A 20
9:09:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 11 09 81 80 E0 81 01 20 76 E6 01 89 04 29 01 D2 00 20 70 47 F7 49 42 68 49 68 11 60 04 21 C1 81 01 20 70 47 FE B5 0D 46 16 46 04 46 10 29 01 D2 00 20 FE BD 07 27 20 22 08 21 B9 F7 64 FA 3A 46 ED A1 20 46 B8 F7 6E FC 10 2E 13 D0 01 2E 13 D0 45 20 E0 71 02 A9 08 20 CD E9 00 01 08 3D 00 23 AA B2 04 F1 08 01 01 20 D9 F7 BB FE 00 28 E0 D0 10 20 FE BD 50 20 EC E7 4D 20 EA E7 10 B5 04 46 01 89 40 68
9:09:59 AM
9:09:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 12 09 81 80 10 22 FF F7 CD FF 10 B1 E0 81 01 20 10 BD 00 20 E0 81 10 BD 10 B5 04 00 C2 B0 4F F0 00 00 E0 81 13 D0 21 88 A1 F5 A0 41 14 39 10 D0 B1 F5 80 7F 0B D1 69 46 5F F0 01 00 05 F0 BF FE 00 28 04 D0 61 68 00 9A 0A 60 04 21 E1 81 42 B0 10 BD 69 46 00 20 F1 E7 30 B5 04 00 C3 B0 4F F0 00 00 E0 81 20 D0 21 88 4F F4 80 75 A1 F5 A0 41 14 39 1B D0 A9 42 17 D1 69 46 01 20 05 F0 9F FE 00 28 11 D0
9:09:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 13 09 81 80 60 68 00 68 00 90 20 88 A0 F5 A0 40 14 38 0E D0 A8 42 0F D1 69 46 01 20 05 F0 C8 FE 00 28 01 D0 04 21 E1 81 43 B0 30 BD 69 46 00 20 E4 E7 69 46 00 20 F1 E7 00 20 F5 E7 10 B5 04 46 00 89 10 28 0F D3 20 88 04 F0 D1 FB FF 28 0A D0 05 F0 1E FF 00 28 05 D0 61 68 00 8C 08 80 02 20 E0 81 01 20 10 BD 00 20 10 BD 10 B5 04 46 00 89 10 28 12 D3 20 88 A0 F5 82 61 03 29 0D D8 A0 F2 11 30 C0 B2
9:10:00 AM
9:10:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 14 09 81 80 05 F0 04 FF 00 28 05 D0 61 68 40 6A 08 60 04 20 E0 81 01 20 10 BD 00 20 10 BD 38 B5 04 46 00 89 10 28 1D D3 21 88 FF 20 17 29 23 D0 08 DC A1 F1 11 01 06 29 14 D2 DF E8 01 F0 15 17 22 22 19 1B 93 29 1C D0 06 DC 90 29 19 D0 91 29 17 D0 92 29 06 D1 14 E0 A1 F5 80 61 14 39 0D D0 01 29 0D D0 00 20 38 BD 02 20 0A E0 08 20 08 E0 09 20 06 E0 0A 20 04 E0 0B 20 02 E0 0C 20 00 E0 0D 20 69 46
9:10:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 15 09 81 80 05 F0 7C FF 00 28 EC D0 60 68 BD F8 00 10 01 80 02 20 E0 81 01 20 38 BD 01 89 10 29 07 D3 02 88 76 49 A2 F5 A8 52 10 3A 03 D0 03 2A 03 D0 00 20 70 47 89 68 00 E0 89 69 42 68 11 60 04 21 C1 81 01 20 70 47 10 B5 02 88 04 46 A2 F5 A8 52 6B 49 10 3A 4F F0 00 00 02 D0 03 2A 0B D0 10 BD 88 60 66 49 04 22 08 31 84 20 D9 F7 8F FE 2C 20 13 F0 42 FD 06 E0 88 61 61 49 04 22 18 31 88 20 D9 F7
9:10:01 AM
9:10:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 16 09 81 80 84 FE 04 20 E0 81 01 20 10 BD 10 B5 04 46 00 89 9A B0 10 28 0A D3 68 46 0F F0 C8 FD 20 88 B0 F5 C8 7F 07 D0 A0 F5 C8 50 90 38 01 D0 00 20 5A E6 04 98 00 E0 08 98 61 68 08 60 04 20 E0 81 01 20 51 E6 30 B5 04 46 40 68 9B B0 05 68 68 46 0F F0 AD FD 20 88 B0 F5 C8 7F 08 D0 A0 F5 C8 50 90 38 02 D0 00 20 1B B0 30 BD 04 95 00 E0 08 95 68 46 0F F0 A3 FD 04 20 E0 81 01 20 F3 E7 10 B5 01 89
9:10:02 AM
9:10:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 17 09 81 80 10 29 1E D3 02 88 40 F6 11 34 3D 49 A2 F6 11 33 A2 42 1E D0 0C DC A2 F5 80 72 91 3A 19 D0 01 2A 1B D0 02 2A 11 D0 A2 F5 10 62 7F 3A 09 D1 0E E0 B3 F5 68 6F 0B D0 A3 F5 60 63 81 3B 0B D0 01 2B 01 D0 00 20 10 BD 09 68 08 E0 C9 68 06 E0 49 68 04 E0 09 69 02 E0 89 68 00 E0 49 69 42 68 11 60 04 21 C1 81 01 20 10 BD 2D E9 F0 41 44 68 04 22 23 4B D4 F8 00 C0 C2 81 05 88 40 F6 11 37 A5 F6
9:10:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 18 09 81 80 11 36 4F F0 00 0E 03 F1 0C 01 BD 42 45 D0 0C DC A5 F5 80 75 91 3D 35 D0 01 2D 4A D0 02 2D 19 D0 A5 F5 10 65 7F 3D 09 D1 32 E0 B6 F5 68 6F 1C D0 A6 F5 60 66 81 3E 35 D0 01 2E 04 D0 A0 F8 0E E0 00 20 BD E8 F0 81 C3 F8 00 E0 C2 81 0C 22 0C 49 8C 20 04 E0 C3 F8 0C E0 C2 81 0C 22 98 20 D9 F7 D4 FD 2D 20 13 F0 87 FC 10 E0 21 68 13 E0 00 00 24 7B 00 10 49 53 4B 54 38 38 30 00 50 80 00 10
9:10:03 AM
9:10:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 19 09 81 80 28 81 00 10 24 68 0B E0 D9 F7 BF FD 01 20 D8 E7 59 68 21 EA 0C 01 59 60 06 E0 1C 69 24 EA 0C 04 1C 61 08 E0 21 68 99 60 C2 81 0C 22 FC 49 8C 20 EA E7 24 68 5C 61 C2 81 0C 22 98 20 E4 E7 38 B5 04 46 68 46 10 F0 80 F8 00 28 05 D0 60 68 9D F8 00 10 01 70 01 20 E0 81 38 BD 10 B5 04 46 00 20 E0 81 60 68 00 78 10 F0 59 F8 00 28 01 D0 01 20 E0 81 10 BD 10 B5 04 46 00 88 A0 F5 C8 51 96 39
9:10:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 1A 09 81 80 01 D0 00 20 10 BD 60 68 11 F0 72 FD 18 B1 02 20 E0 81 01 20 10 BD 00 20 E0 81 F2 E7 3E B5 04 46 68 46 11 F0 C1 FD 00 28 10 D0 22 88 4F F0 01 00 A2 F5 B0 52 11 3A 0A D0 04 21 01 2A 0B D0 A2 F5 C8 52 82 3A 0A D0 04 2A 0D D0 00 20 3E BD 9D F8 05 20 61 68 0A E0 60 68 02 9A 01 E0 60 68 00 9A 02 60 E1 81 04 E0 9D F8 04 20 61 68 0A 70 E0 81 01 20 3E BD 70 B5 86 B0 04 46 02 A8 11 F0 94 FD
9:10:04 AM
9:10:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 1B 09 81 80 00 28 2F D0 20 88 4F F0 01 05 A0 F5 B0 50 11 38 0A D0 04 26 01 28 0C D0 A0 F5 C8 50 82 38 05 A9 0B D0 04 28 1D D1 17 E0 60 68 00 78 8D F8 0D 00 26 E0 60 68 00 68 04 90 0C E0 60 68 24 23 04 22 00 68 00 96 CD E9 01 10 01 20 61 68 D9 F7 87 FC 00 28 07 D0 E6 81 14 E0 60 68 00 78 20 B1 01 28 02 D0 00 20 06 B0 70 BD CD E9 00 51 8D F8 0C 00 01 22 28 23 10 46 61 68 D9 F7 71 FC 00 28 F1 D0
9:10:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 1C 09 81 80 E5 81 02 A8 11 F0 60 FD 00 28 EB D0 01 20 E9 E7 70 B5 04 46 00 20 E0 81 12 F0 F5 F8 22 88 40 F6 96 65 01 21 A2 F6 96 63 AA 42 20 D0 06 DC A2 F5 60 62 94 3A 0F D0 01 2A 22 D1 13 E0 01 2B 1B D0 B3 F5 D0 6F 1C D1 21 89 04 29 19 D3 61 68 08 60 04 20 E0 81 04 E0 22 89 92 B1 62 68 10 70 E1 81 01 20 70 BD 22 89 5A B1 C0 F3 07 20 F5 E7 22 89 32 B1 C0 F3 07 40 F0 E7 22 89 0A B1 00 0E EC E7
9:10:05 AM
9:10:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 1D 09 81 80 00 20 70 BD 10 B5 04 00 2B D0 00 20 E0 81 12 F0 74 F8 22 88 01 21 A2 F5 71 62 05 2A 21 D2 DF E8 02 F0 03 0B 12 17 1C 00 21 89 04 29 19 D3 61 68 08 60 04 20 E0 81 04 E0 22 89 92 B1 62 68 10 70 E1 81 01 20 10 BD 22 89 5A B1 C0 F3 07 20 F5 E7 22 89 32 B1 C0 F3 07 40 F0 E7 22 89 0A B1 00 0E EC E7 00 20 10 BD 10 B5 04 00 4F F0 00 00 09 D0 00 21 E1 81 21 88 A1 F5 A0 42 10 3A 03 D1 61 68
9:10:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 1E 09 81 80 07 E0 E1 81 10 BD A1 F5 68 52 17 3A 07 D1 08 20 61 68 08 F0 77 FA 01 28 0B D1 04 21 F1 E7 A1 F5 70 62 17 3A EE D1 0C 20 61 68 08 F0 6B FA 01 28 01 D0 00 21 E5 E7 01 21 E3 E7 70 B5 04 46 00 88 00 25 A0 F5 A0 41 10 39 01 D1 00 20 0A E0 A0 F5 68 51 17 39 01 D1 08 20 04 E0 A0 F5 70 61 17 39 09 D1 0C 20 61 68 09 68 09 F0 12 FA 18 B1 04 20 E0 81 01 20 70 BD E5 81 00 20 70 BD 1C B5 04 46
9:10:06 AM
9:10:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 1F 09 81 80 00 88 69 46 20 F0 78 00 0A F0 5D FC 18 B3 61 68 9D F8 00 00 08 70 61 68 9D F8 01 00 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00 C8 70 61 68 9D F8 04 00 08 71 61 68 9D F8 05 00 48 71 61 68 9D F8 06 00 88 71 61 68 9D F8 07 00 C8 71 08 20 E0 81 01 20 1C BD 00 20 E0 81 1C BD 01 20 70 47 30 B5 03 46 01 20 A9 B1 48 F2 80 15 5C 1B AB 42 22 D0 09 DC B3 F5 01 4F 0E D0 6F F4 01 44 1B 19
9:10:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 20 09 81 80 0E D0 01 2B 06 D1 0F E0 01 2C 18 D0 02 2C 1A D0 03 2C 0D D0 00 20 30 BD 01 24 4F F4 40 53 15 E0 01 24 43 F2 01 03 11 E0 01 24 43 F2 02 03 0D E0 01 24 4D F2 81 03 09 E0 01 24 A3 03 06 E0 01 24 44 F2 01 03 02 E0 01 24 44 F2 02 03 0B 80 00 2A E1 D0 14 80 30 BD 70 B5 86 B0 04 46 01 20 AD F8 04 00 21 88 01 AA 21 F0 78 00 C1 F3 C3 06 69 46 FF F7 B6 FF 00 25 80 B1 BD F8 00 00 04 AB 40 EA
9:10:07 AM
9:10:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 21 09 81 80 C6 00 80 B2 AD F8 00 00 08 22 BD F8 04 10 0B F0 1A FA 03 28 06 D0 01 28 07 D0 E5 81 00 20 A1 E6 28 81 00 10 00 20 CD E9 04 00 61 68 9D F8 10 00 08 70 61 68 9D F8 11 00 48 70 61 68 9D F8 12 00 88 70 61 68 9D F8 13 00 C8 70 61 68 9D F8 14 00 08 71 61 68 9D F8 15 00 48 71 61 68 9D F8 16 00 88 71 61 68 9D F8 17 00 C8 71 08 20 E0 81 01 20 78 E6 01 20 70 47 3E B5 04 46 01 20 AD F8 04 00
9:10:08 AM
9:10:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 22 09 81 80 20 88 01 AA 20 F0 78 00 69 46 FF F7 69 FF 00 25 78 B1 BD F8 00 00 02 AB 40 F0 28 00 AD F8 00 00 04 22 BD F8 04 10 0B F0 CE F9 03 28 04 D0 01 28 03 D0 E5 81 00 20 3E BD 02 95 61 68 9D F8 08 00 08 70 61 68 9D F8 09 00 48 70 61 68 9D F8 0A 00 88 70 61 68 9D F8 0B 00 C8 70 04 20 E0 81 01 20 3E BD 01 20 70 47 1C B5 04 46 00 88 69 46 20 F0 78 00 0A F0 B7 FB 18 B3 61 68 9D F8 00 00 08 70
9:10:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 23 09 81 80 61 68 9D F8 01 00 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00 C8 70 61 68 9D F8 04 00 08 71 61 68 9D F8 05 00 48 71 61 68 9D F8 06 00 88 71 61 68 9D F8 07 00 C8 71 08 20 E0 81 01 20 1C BD 00 20 E0 81 1C BD 1C B5 04 46 00 88 69 46 20 F0 78 00 0A F0 C9 FC 18 B3 61 68 9D F8 00 00 08 70 61 68 9D F8 01 00 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00 C8 70 61 68 9D F8 04 00 08 71
9:10:09 AM
9:10:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 24 09 81 80 61 68 9D F8 05 00 48 71 61 68 9D F8 06 00 88 71 61 68 9D F8 07 00 C8 71 08 20 E0 81 01 20 1C BD 00 20 E0 81 1C BD 1C B5 04 46 00 88 69 46 20 F0 78 00 0A F0 B0 FC 18 B3 61 68 9D F8 00 00 08 70 61 68 9D F8 01 00 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00 C8 70 61 68 9D F8 04 00 08 71 61 68 9D F8 05 00 48 71 61 68 9D F8 06 00 88 71 61 68 9D F8 07 00 C8 71 08 20 E0 81 01 20 1C BD
9:10:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 25 09 81 80 00 20 E0 81 1C BD 1C B5 04 46 00 88 69 46 20 F0 78 00 0A F0 EB FD 18 B3 61 68 9D F8 00 00 08 70 61 68 9D F8 01 00 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00 C8 70 61 68 9D F8 04 00 08 71 61 68 9D F8 05 00 48 71 61 68 9D F8 06 00 88 71 61 68 9D F8 07 00 C8 71 08 20 E0 81 01 20 1C BD 00 20 E0 81 1C BD 1F B5 04 46 10 20 02 46 69 46 D9 F7 56 FC A0 B1 BD F8 00 00 BD F8 02 10 40 1A
9:10:10 AM
9:10:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 26 09 81 80 61 68 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 04 B0 10 BD 00 20 E0 81 FA E7 1F B5 04 46 50 20 10 22 69 46 D9 F7 36 FC 50 B1 61 68 BD F8 00 00 08 70 61 68 00 0A 48 70 04 20 E0 81 01 20 E7 E7 00 20 E0 81 E4 E7 10 B5 04 46 00 88 20 F0 78 00 7E 30 C0 B2 04 28 01 D3 00 20 10 BD 0B F0 49 FC 61 68 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68
9:10:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 27 09 81 80 C8 70 04 20 E0 81 01 20 10 BD 38 B5 04 46 00 88 A0 F5 E2 61 86 29 2D D8 20 F0 78 00 E9 F7 00 FE 00 28 26 D0 21 88 A1 F5 E0 62 95 3A 01 D1 1E 20 08 E0 A1 F5 E0 62 96 3A 01 D1 1F 20 02 E0 80 79 40 1E 80 B2 69 46 FC F7 03 FD 61 68 9D F8 02 00 08 70 61 68 9D F8 03 00 48 70 BD F8 00 00 61 68 00 0A 88 70 61 68 BD F8 00 00 C8 70 04 20 E0 81 01 20 38 BD 00 20 E0 81 38 BD F8 B5 04 46 00 88
9:10:11 AM
9:10:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 28 09 81 80 A0 F5 E2 61 86 29 31 D8 20 F0 78 00 E9 F7 C8 FD 00 28 2A D0 61 68 04 26 09 78 8D F8 02 10 62 68 52 78 8D F8 03 20 62 68 93 78 D2 78 42 EA 03 22 AD F8 00 20 22 88 A2 F5 E0 63 95 3B 01 D1 1E 25 08 E0 A2 F5 E0 63 96 3B 01 D1 1F 25 02 E0 80 79 40 1E 85 B2 28 46 FC F7 93 FC 38 B1 69 46 28 46 FC F7 CC FC 10 B1 E6 81 01 20 F8 BD 00 20 E0 81 F8 BD 42 68 00 21 11 70 01 21 C1 81 08 46 70 47
9:10:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 29 09 81 80 FE B5 04 46 00 88 00 25 20 F0 78 06 01 A8 C0 F7 7B FA B6 F5 4F 4F 00 D1 18 B1 00 20 E0 81 28 46 FE BD 00 20 AD F8 00 00 BD F8 04 00 28 B9 BD F8 06 00 10 B9 BD F8 08 00 08 B1 AD F8 00 00 60 68 BD F8 00 10 01 25 01 80 02 20 E7 E7 08 B5 01 88 6F F4 4F 42 21 F0 78 01 89 18 03 D0 01 29 05 D0 00 20 08 BD FA 49 B1 F8 30 1B 02 E0 F8 49 B1 F8 98 1B AD F8 00 10 41 68 BD F8 00 20 0A 80 02 21
9:10:12 AM
9:10:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 2A 09 81 80 C1 81 01 20 08 BD F8 B5 04 46 00 88 04 27 20 F0 78 06 A6 F5 6A 55 03 2D 06 D8 6D 1C 6A 46 E9 B2 00 20 0A F0 A3 FE 58 B9 A6 F5 68 56 84 3E 02 2E 19 D8 76 1C 6A 46 F1 B2 00 20 0A F0 09 FF 90 B1 61 68 9D F8 00 00 08 70 61 68 9D F8 01 00 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00 C8 70 E7 81 01 20 F8 BD 00 20 E0 81 F8 BD 38 B5 04 46 00 88 4C F2 80 43 20 F0 78 00 00 21 C2 1A 98 42
9:10:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 2B 09 81 80 21 D0 08 DC A0 F5 44 40 06 28 3E D2 DF E8 00 F0 0D 0B 0A 14 12 11 06 2A 37 D2 DF E8 02 F0 36 12 11 1B 19 18 01 21 49 1C C9 B2 49 1C C9 B2 01 20 13 E0 01 21 49 1C C9 B2 49 1C C9 B2 02 20 0C E0 01 21 49 1C C9 B2 49 1C C9 B2 06 20 05 E0 01 21 49 1C C9 B2 49 1C C9 B2 09 20 6A 46 0A F0 B8 FE A8 B1 61 68 9D F8 00 00 08 70 61 68 9D F8 01 00 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00
9:10:13 AM
9:10:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 2C 09 81 80 C8 70 04 20 E0 81 01 20 38 BD 00 20 38 BD 00 20 E0 81 FA E7 38 B5 04 46 00 88 4C F2 80 53 20 F0 78 00 00 21 C2 1A 98 42 21 D0 08 DC A0 F5 45 40 06 28 3E D2 DF E8 00 F0 0D 0B 0A 14 12 11 06 2A 37 D2 DF E8 02 F0 36 12 11 1B 19 18 01 21 49 1C C9 B2 49 1C C9 B2 01 20 13 E0 01 21 49 1C C9 B2 49 1C C9 B2 02 20 0C E0 01 21 49 1C C9 B2 49 1C C9 B2 06 20 05 E0 01 21 49 1C C9 B2 49 1C C9 B2
9:10:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 2D 09 81 80 09 20 6A 46 0A F0 F2 FD A8 B1 61 68 9D F8 00 00 08 70 61 68 9D F8 01 00 48 70 61 68 9D F8 02 00 88 70 61 68 9D F8 03 00 C8 70 04 20 E0 81 01 20 38 BD 00 20 38 BD 00 20 E0 81 FA E7 F0 B5 04 46 00 88 89 B0 20 F0 78 07 00 25 02 A8 C0 F7 09 FA 06 46 04 A8 C0 F7 2F FA 01 46 A7 F5 46 47 02 20 06 2F 31 D2 DF E8 07 F0 08 0D 1F 03 24 29 5E BB BD F8 08 20 61 68 24 E0 31 BB BD F8 10 20 61 68
9:10:14 AM
9:10:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 2E 09 81 80 1F E0 09 BB BD F8 14 10 4F F4 B4 72 C1 F5 B4 71 89 B2 B1 FB F2 F3 02 FB 13 11 AD F8 00 10 BD F8 00 20 61 68 0D E0 79 B9 BD F8 12 20 61 68 08 E0 56 B9 BD F8 0A 20 61 68 03 E0 2E B9 BD F8 0C 20 61 68 01 25 0A 80 E0 81 09 B0 28 46 F0 BD 7E B5 60 4C 4F F4 00 75 1C CC 8D E8 1C 00 00 22 0A 70 13 46 6C 46 34 F8 12 60 86 1B AE 42 08 DA 34 F8 12 30 03 2A 01 D2 52 1C 00 E0 92 1E 0A 70 03 E0
9:10:15 AM
9:10:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 2F 09 81 80 52 1C D2 B2 06 2A ED D3 09 78 A1 B1 9B B1 00 21 C0 1A CA 01 80 32 82 42 09 DD B0 F5 C3 7F 0A DC A1 EB 01 11 00 EB C1 00 40 1C C0 B2 7E BD 49 1C C9 B2 04 29 ED D3 00 20 7E BD 1F B5 04 46 00 20 E0 81 20 89 02 28 13 D3 20 88 69 46 20 F0 78 00 FF F7 BD FF 01 00 0B D0 01 A8 C0 F7 58 F8 38 B9 9D F8 00 00 01 28 05 D0 02 28 05 D0 03 28 0A D0 00 20 93 E5 01 98 00 E0 02 98 61 68 08 80 02 20
9:10:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 30 09 81 80 E0 81 01 20 8A E5 03 98 F7 E7 1F B5 04 46 00 20 E0 81 20 89 02 28 16 D3 20 88 69 46 20 F0 78 00 FF F7 95 FF 01 46 9D F8 00 00 00 28 0C D0 01 A8 BF F7 91 FF 38 B9 9D F8 00 00 01 28 05 D0 02 28 05 D0 03 28 0A D0 00 20 68 E5 01 98 00 E0 02 98 61 68 08 80 02 20 E0 81 01 20 5F E5 03 98 F7 E7 3E B5 04 46 00 20 E0 81 20 89 02 28 0C D3 68 46 C0 F7 4D F8 40 B9 20 88 A0 F5 46 40 93 38 05 D0
9:10:16 AM
9:10:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 31 09 81 80 01 28 05 D0 02 28 0A D0 00 20 3E BD 00 98 00 E0 01 98 61 68 08 80 02 20 E0 81 01 20 3E BD 02 98 F7 E7 3E B5 04 46 00 20 E0 81 20 89 02 28 0C D3 68 46 BF F7 90 FF 40 B9 20 88 A0 F5 46 40 90 38 0A D0 01 28 0A D0 02 28 0F D0 00 20 3E BD 00 00 E8 6C 00 10 C0 44 07 00 00 98 00 E0 01 98 61 68 08 80 02 20 E0 81 01 20 F0 E7 02 98 F7 E7 2D E9 F0 47 82 46 00 88 4C F6 04 57 20 F0 78 05 FA 48
9:10:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 32 09 81 80 EE 1B 00 F6 38 4C 00 F6 08 49 00 F5 41 61 00 F6 18 42 00 F5 44 63 00 F5 42 68 00 F6 28 44 00 F5 43 60 BD 42 5E D0 1E DC 4C F6 86 47 A5 EB 07 06 BD 42 41 D0 0A DC A5 F5 00 45 A5 F5 99 45 06 2D 7B D2 DF E8 05 F0 28 2A 2D 30 33 36 7B 2E 3D D0 04 DC 01 2E 33 D0 7A 2E 6F D1 33 E0 7C 2E 39 D0 7D 2E 6A D1 3A E0 7E 2E 51 D0 0C DC 03 2E 45 D0 04 DC 01 2E 3A D0 02 2E 5F D1 3B E0 7C 2E 40 D0
9:10:17 AM
9:10:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 33 09 81 80 7D 2E 5A D1 40 E0 7F 3E 05 2E 56 D2 DF E8 06 F0 42 45 48 4C 4F 00 D5 4D 16 E0 D4 4D 30 3D 17 E0 D2 4D 28 3D 18 E0 D1 4D 20 3D 19 E0 CF 4D 08 35 1A E0 CE 4D 18 3D 1B E0 CC 4D 10 3D 1C E0 CB 4D 08 3D 36 E0 C9 4D 40 35 60 46 32 E0 C7 4D 10 35 48 46 2E E0 C5 4D 18 35 08 46 2A E0 C3 4D 20 35 10 46 26 E0 C1 4D 48 35 18 46 22 E0 BF 4D 28 35 40 46 1E E0 BD 4D 30 35 20 46 1A E0 BB 4D 38 35
9:10:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 34 09 81 80 17 E0 BA 4D 80 35 DF E7 B8 4D 50 35 E0 E7 B7 4D 58 35 E1 E7 B5 4D 60 35 E2 E7 B4 4D 88 35 E3 E7 B2 4D 68 35 E4 E7 08 E0 B0 4D 70 35 E4 E7 AF 4D 78 35 69 68 21 B1 28 68 05 E0 00 20 BD E8 F0 87 41 68 21 B1 00 68 B0 FB F1 F0 80 B2 00 E0 00 20 DA F8 04 10 08 70 01 0A DA F8 04 00 41 70 02 21 AA F8 0E 10 01 20 E9 E7 F8 B5 04 46 00 88 00 21 20 F0 78 02 4D F2 06 33 D0 1A 0D 46 9A 42 7B D0
9:10:18 AM
9:10:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 35 09 81 80 48 DC 43 F6 81 33 A2 EB 03 00 9A 42 75 D0 29 DC 43 F6 03 33 A2 EB 03 00 9A 42 79 D0 15 DC B2 F5 6C 5F 6B D0 0A DC A2 F5 54 52 86 3A 67 D0 01 2A 66 D0 A2 F5 A0 62 01 3A 63 D1 6F E0 6F F4 6C 50 10 18 7B D0 01 28 5C D1 62 E0 03 28 04 D0 04 DC 01 28 5D D0 02 28 54 D1 AD E0 04 28 70 D0 7D 28 4F D1 AE E0 49 F2 7F 76 83 1B B0 42 60 D0 0A DC A0 F5 16 40 A0 F5 81 70 05 28 42 D2 DF E8 00 F0
9:10:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 36 09 81 80 50 50 50 58 58 00 06 2B 3B D2 DF E8 03 F0 AE 60 5A 5A 5A 78 FC 28 76 D0 1C DC 7E 28 61 D0 0C DC 7B 28 56 D0 04 DC 01 28 7B D0 7A 28 29 D1 80 E0 7C 28 4E D0 7D 28 24 D1 4B E0 81 28 59 D0 04 DC 7F 28 4E D0 80 28 1C D1 4B E0 FA 28 51 D0 FB 28 17 D1 4E E0 B0 F5 BD 7F 65 D0 08 DC A0 F1 FD 00 05 28 0E D2 DF E8 00 F0 4F 4F 57 57 57 00 A0 F2 7B 10 05 28 79 D2 06 E0 4B E0 6A E0 16 E0 2E E0
9:10:19 AM
9:10:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 37 09 81 80 35 E0 72 E0 1A E0 DF E8 00 F0 4E 4E 5E 5E 5E 00 43 F6 02 31 10 46 1A F0 8D FA 01 46 00 20 59 E0 4D F2 83 21 10 46 1A F0 85 FA 01 46 01 20 51 E0 4D F2 86 21 10 46 1A F0 7D FA 01 46 0A 20 49 E0 39 E0 4D F2 02 31 10 46 1A F0 74 FA 01 46 0B 20 40 E0 4D F2 81 31 10 46 1A F0 6C FA 01 46 02 20 38 E0 4D F2 84 31 10 46 1A F0 64 FA 01 46 03 20 30 E0 4D F2 87 31 10 46 1A F0 5C FA 01 46 04 20
9:10:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 38 09 81 80 28 E0 00 E0 0D E0 4D F2 02 41 10 46 1A F0 52 FA 01 46 05 20 1E E0 4D F2 05 41 10 46 1A F0 4A FA 01 46 06 20 16 E0 4D F2 80 41 10 46 1A F0 42 FA 01 46 07 20 0E E0 43 F6 05 31 10 46 1A F0 3A FA 01 46 08 20 06 E0 4D F2 83 41 10 46 1A F0 32 FA 01 46 09 20 6A 46 11 F0 A6 FB 30 B1 60 68 00 99 01 60 04 20 E0 81 01 20 F8 BD E5 81 00 20 F8 BD 7C B5 00 24 05 46 00 94 00 88 20 F0 78 01 C0 F3
9:10:20 AM
9:10:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 39 09 81 80 C3 06 01 A8 EE F7 84 FB 50 B1 02 2E 0C D0 03 2E 16 D0 06 2E 1A D0 07 2E 20 D0 68 68 00 99 01 60 00 20 E8 81 20 46 7C BD 69 46 9D F8 04 00 EE F7 AB FB 10 E0 68 68 00 99 01 24 01 60 04 20 F0 E7 69 46 9D F8 04 00 EE F7 D8 FB 04 E0 69 46 9D F8 04 00 EE F7 FF FB 00 28 E2 D0 EB E7 69 46 9D F8 04 00 EE F7 02 FC F6 E7 E8 6C 00 10 F0 79 00 10 7C B5 04 46 00 88 20 F0 78 01 00 20 05 46 00 90
9:10:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 3A 09 81 80 01 A8 EE F7 59 FB 58 B1 69 46 9D F8 04 00 EE F7 B4 FB 28 B1 60 68 00 99 01 25 01 60 04 20 00 E0 00 20 E0 81 28 46 7C BD 38 B5 04 46 74 20 02 22 69 46 D8 F7 35 FF 00 28 13 D0 BD F8 00 00 48 B1 E9 F7 2E F9 30 B1 61 68 D0 F8 02 20 0A 60 C0 88 88 80 03 E0 60 68 00 21 01 60 81 80 06 20 E0 81 01 20 38 BD 00 B5 9B B0 68 46 0E F0 9F FC BD F8 00 00 01 28 00 D0 00 20 1B B0 00 BD 1F B5 04 46
9:10:21 AM
9:10:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 3B 09 81 80 68 46 BC F7 0E FC 10 B1 00 20 E0 81 31 E5 61 68 00 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 21 E5 1F B5 04 46 68 46 BC F7 F5 FB 10 B1 00 20 E0 81 18 E5 61 68 01 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 08 E5 7C B5 04 46 68 46 BC F7 E2 FB 01 00 4F F0 00 00 0A D1 00 99 8A B2 4F F4 E0 71 8A 42 00 D3 0A 46
9:10:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 3C 09 81 80 21 89 95 1C A9 42 02 D2 E0 81 00 20 7C BD 60 68 02 80 60 68 01 99 80 1C B7 F7 C2 F9 E5 81 01 20 7C BD 1F B5 04 46 68 46 BC F7 BB FB 10 B1 00 20 E0 81 DE E4 61 68 02 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 CE E4 70 B5 A8 B0 04 46 22 A8 BC F7 A1 FB 00 26 D0 B9 FF F7 7E FF 01 00 4F F0 02 00 0A D0 25 99 49 1C 07 D0 26 AB 86 21 68 46 25 9A BC F7
9:10:22 AM
9:10:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 3D 09 81 80 56 FC 50 B9 03 E0 61 68 0E 80 E0 81 11 E0 26 98 82 B2 20 89 95 1C A8 42 03 D2 E6 81 00 20 28 B0 70 BD 60 68 69 46 02 80 60 68 80 1C B7 F7 78 F9 E5 81 01 20 F3 E7 70 B5 04 46 40 68 00 26 05 88 2D B1 FF F7 4F FF 50 B1 86 2D 08 D1 01 E0 E6 81 0A E0 60 68 29 46 80 1C BC F7 06 FC 10 B1 E6 81 00 20 70 BD 20 89 E0 81 01 20 70 BD 10 B5 8C B0 04 46 68 46 BC F7 64 FB 18 B1 00 20 E0 81 0C B0
9:10:23 AM
9:10:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 3E 09 81 80 10 BD 61 68 00 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 ED E7 10 B5 8C B0 04 46 68 46 BC F7 49 FB 10 B1 00 20 E0 81 E3 E7 10 22 01 A9 60 68 B7 F7 30 F9 10 20 E0 81 01 20 DA E7 10 B5 8C B0 04 46 68 46 BC F7 36 FB 10 B1 00 20 E0 81 D0 E7 61 68 05 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 C0 E7 10 B5 8C B0
9:10:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 3F 09 81 80 04 46 68 46 BC F7 1C FB 10 B1 00 20 E0 81 B6 E7 10 22 07 A9 60 68 B7 F7 03 F9 10 20 E0 81 01 20 AD E7 10 B5 8C B0 04 46 68 46 BC F7 11 FB 10 B1 00 20 E0 81 A3 E7 61 68 00 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 93 E7 10 B5 8C B0 04 46 68 46 BC F7 F7 FA 10 B1 00 20 E0 81 89 E7 10 22 01 A9 60 68 B7 F7 D6 F8 10 20 E0 81 01 20 80 E7 10 B5 8C B0
9:10:24 AM
9:10:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 40 09 81 80 04 46 68 46 BC F7 E4 FA 10 B1 00 20 E0 81 76 E7 61 68 05 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 66 E7 10 B5 8C B0 04 46 68 46 BC F7 CA FA 10 B1 00 20 E0 81 5C E7 10 22 07 A9 60 68 B7 F7 A9 F8 10 20 E0 81 01 20 53 E7 10 B5 8C B0 04 46 68 46 BC F7 BF FA 10 B1 00 20 E0 81 49 E7 61 68 00 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68
9:10:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 41 09 81 80 C8 70 04 20 E0 81 01 20 39 E7 10 B5 8C B0 04 46 68 46 BC F7 A5 FA 10 B1 00 20 E0 81 2F E7 10 22 01 A9 60 68 B7 F7 7C F8 10 20 E0 81 01 20 26 E7 10 B5 8C B0 04 46 68 46 BC F7 92 FA 10 B1 00 20 E0 81 1C E7 61 68 05 98 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70 61 68 C8 70 04 20 E0 81 01 20 0C E7 10 B5 8C B0 04 46 68 46 BC F7 78 FA 10 B1 00 20 E0 81 02 E7 10 22 07 A9 60 68 B7 F7
9:10:25 AM
9:10:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 42 09 81 80 4F F8 10 20 E0 81 01 20 F9 E6 01 01 41 EA 10 10 00 F0 33 01 89 00 00 F0 CC 00 41 EA 90 00 00 F0 55 01 49 00 00 F0 AA 00 41 EA 50 00 70 47 00 B5 02 46 0B 46 04 E0 10 78 FF F7 E7 FF 02 F8 01 0B 18 00 A3 F1 01 03 9B B2 F5 D1 00 BD 70 B5 8E B0 04 46 03 A8 BC F7 34 FA 00 26 B8 B9 01 A8 BC F7 26 FA 98 B9 68 46 BC F7 E9 F9 78 B9 9D F8 00 00 80 B1 01 98 4F F4 E0 71 80 B2 88 42 00 D3 08 46
9:10:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 43 09 81 80 40 1C 85 B2 21 89 E8 1C 81 42 0C D2 E6 81 00 20 0E B0 70 BD 61 68 01 20 08 80 61 68 08 20 88 70 03 20 E0 81 11 E0 60 68 6A 1E 05 80 60 68 86 70 60 68 02 99 C0 1C B6 F7 F3 FF 60 68 69 1E C0 1C 89 B2 FF F7 B4 FF AD 1C E5 81 01 20 E0 E7 1F B5 04 46 68 46 BC F7 E5 F9 01 00 4F F0 00 00 01 D0 E0 81 D3 E5 01 99 11 B1 02 98 B0 FB F1 F0 61 68 08 70 62 68 01 0A 51 70 62 68 01 0C 00 0E 91 70
9:10:26 AM
9:10:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 44 09 81 80 61 68 C8 70 04 20 E0 81 01 20 BF E5 38 B5 04 46 68 46 BC F7 88 F9 10 B1 00 20 E0 81 38 BD 61 68 9D F8 00 00 08 70 01 20 E0 81 38 BD 10 B5 04 46 40 68 00 78 BC F7 7D F9 10 B1 00 20 E0 81 10 BD 01 20 E0 81 10 BD 38 B5 04 46 68 46 BC F7 76 F9 10 B1 00 20 E0 81 38 BD 61 68 9D F8 00 00 08 70 01 20 E0 81 38 BD FA 49 40 F6 02 02 09 88 11 40 F8 4A D3 78 01 2B 01 D0 05 2B 01 D1 41 F0 01 01
9:10:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 45 09 81 80 13 79 01 2B 01 D0 05 2B 01 D1 41 F0 04 01 53 79 01 2B 01 D1 41 F0 08 01 93 79 01 2B 01 D1 41 F4 80 61 12 78 2A B1 01 2A 09 D0 02 2A 07 D0 41 F4 80 71 42 68 11 80 02 21 C1 81 01 20 70 47 41 F4 00 71 F6 E7 41 68 E2 4A 09 88 13 88 01 F0 02 01 03 F4 00 63 19 43 11 80 02 21 C1 81 01 20 70 47 2D E9 F0 41 06 46 45 68 00 88 42 F6 11 62 81 1A 90 42 2A D0 0A DC A0 F5 C8 50 97 38 0F D0 79 28
9:10:27 AM
9:10:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 46 09 81 80 10 D0 A0 F5 A0 50 79 38 06 D1 16 E0 01 29 1F D0 02 29 20 D0 03 29 21 D0 00 20 BD E8 F0 81 CD 48 17 30 1C E0 CB 48 50 30 19 E0 A8 1C B6 F7 38 FF 2C 80 A4 1C F4 81 01 20 EF E7 C6 4F F8 1D B7 F7 AF F8 84 B2 22 46 F9 1D EF E7 C2 48 A7 30 06 E0 C0 48 83 30 03 E0 BF 48 CD 30 00 E0 BE 48 07 46 B7 F7 9E F8 84 B2 22 46 39 46 DE E7 38 B5 05 46 00 20 00 90 01 46 68 46 6C 68 11 F0 91 FA A0 70
9:10:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 47 09 81 80 9D F8 00 00 E0 70 9D F8 01 00 20 71 03 20 20 80 05 20 E8 81 01 20 38 BD 70 B5 04 46 00 88 4F F0 01 05 A0 F5 28 50 12 38 09 D0 01 28 09 D0 00 20 E0 81 70 BD 61 68 08 70 E5 81 01 20 70 BD 4F F4 80 70 0E F0 ED F9 00 28 F4 D0 01 20 F2 E7 2D E9 F0 41 05 46 80 89 00 24 01 28 01 D0 00 20 9C E7 68 68 06 78 28 88 A0 F5 28 50 12 38 0A D0 01 28 25 D1 16 B1 0F F0 48 FB 01 E0 0E F0 AB F9 04 00
9:10:28 AM
9:10:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 48 09 81 80 1B D1 1C E0 4F F4 80 74 20 46 0E F0 C9 F9 08 B1 01 27 00 E0 00 27 20 46 3E B1 0F F0 35 FB 04 00 0D D0 B7 42 09 D0 8B 20 05 E0 0E F0 93 F9 04 00 05 D0 17 B1 8C 20 12 F0 9E F8 01 20 00 E0 00 20 E8 81 20 46 69 E7 02 88 84 49 B2 F5 21 6F 0D D0 A2 F5 A0 52 96 3A 05 D0 01 2A 05 D0 00 21 C1 81 08 46 70 47 09 68 02 E0 89 69 00 E0 49 69 42 68 11 60 04 21 C1 81 01 20 70 47 10 B5 04 46 77 48
9:10:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 49 09 81 80 0F F0 06 FC 00 28 0C D0 21 88 74 48 B1 F5 21 6F 10 D0 A1 F5 A0 51 96 39 04 D0 01 29 06 D0 00 20 E0 81 10 BD 61 68 09 68 01 60 06 E0 61 68 09 68 81 61 02 E0 61 68 09 68 41 61 82 69 01 68 11 44 01 61 66 48 0F F0 DE FB 00 28 EA D0 04 20 E0 81 01 20 10 BD 10 B5 02 88 4C F2 15 74 13 1B 60 49 A2 42 21 D0 0A DC A2 F5 40 42 A2 F5 E2 62 05 2A 0C D2 DF E8 02 F0 0F 11 13 15 17 00 01 2B 15 D0
9:10:29 AM
9:10:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 4A 09 81 80 02 2B 15 D0 7B 2B 15 D0 7C 2B 15 D0 00 21 C1 81 08 46 10 BD 09 68 10 E0 49 68 0E E0 89 68 0C E0 C9 68 0A E0 09 69 08 E0 49 69 06 E0 89 69 04 E0 C9 69 02 E0 09 6A 00 E0 49 6A 42 68 11 60 04 21 C1 81 01 20 10 BD 70 B5 04 46 40 68 4C F2 15 75 43 4A 01 68 20 88 43 1B A8 42 20 D0 0A DC A0 F5 40 40 A0 F5 E2 60 05 28 0C D2 DF E8 00 F0 0E 10 12 14 16 00 01 2B 14 D0 02 2B 14 D0 7B 2B 14 D0
9:10:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 4B 09 81 80 7C 2B 14 D0 00 20 E0 81 70 BD 11 60 10 E0 51 60 0E E0 91 60 0C E0 D1 60 0A E0 11 61 08 E0 51 61 06 E0 91 61 04 E0 D1 61 02 E0 11 62 00 E0 51 62 2B 48 0F F0 97 FB 00 28 E6 D0 04 20 E0 81 01 20 70 BD F8 B5 04 46 00 88 00 25 20 F0 78 00 4F F4 7A 76 B0 F5 40 4F 06 D0 4C F2 01 01 88 42 05 D1 4F F4 67 70 24 E0 4F F4 57 70 21 E0 A0 F5 40 41 02 39 02 D1 4F F4 4B 70 1A E0 A0 F5 40 41 04 39
9:10:30 AM
9:10:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 4C 09 81 80 02 D1 4F F4 4F 70 13 E0 A0 F5 40 41 06 39 02 D1 4F F4 53 70 0C E0 A0 F5 40 41 03 39 02 D1 4F F4 5B 70 05 E0 A0 F5 40 41 05 39 1B D1 4F F4 5F 70 04 22 69 46 D8 F7 B4 FA D8 B1 00 98 01 25 B0 FB F6 F0 00 90 60 68 00 99 01 60 04 20 12 E0 00 00 02 3E 00 20 30 58 00 10 F8 59 00 10 40 81 00 10 64 81 00 10 A0 F5 40 41 07 39 02 D1 4F F4 63 70 DE E7 00 20 E0 81 28 46 F8 BD 70 B5 04 46 00 88
9:10:31 AM
9:10:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 4D 09 81 80 86 B0 20 F0 78 05 00 20 E0 81 01 A8 10 F0 CE FE 06 46 03 A8 10 F0 B8 FF 30 43 2B D1 A5 F5 4E 45 08 2D 27 D2 DF E8 05 F0 04 07 14 17 1A 1D 20 23 BD F8 04 00 01 E0 BD F8 06 00 AD F8 00 00 60 68 BD F8 00 10 01 80 02 20 E0 81 01 20 06 B0 70 BD BD F8 08 00 F1 E7 BD F8 0A 00 EE E7 BD F8 0C 00 EB E7 BD F8 0E 00 E8 E7 BD F8 10 00 E5 E7 BD F8 12 00 E2 E7 00 20 E9 E7 70 B5 46 68 04 46 00 25
9:10:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 4E 09 81 80 B0 1C BE F7 4D FD 01 00 4F F0 56 00 04 D0 30 80 00 20 E0 81 28 46 70 BD 01 25 30 80 58 20 F8 E7 30 B5 04 46 00 88 42 F2 92 72 81 1A 00 25 89 B0 90 42 26 D0 14 DC 42 F2 14 72 A0 EB 02 01 90 42 15 D0 08 DC A0 F5 1C 51 11 39 10 D0 01 29 0E D0 02 29 2E D1 0B E0 7C 29 13 D0 7D 29 29 D1 10 E0 06 29 26 D2 DF E8 01 F0 25 0D 1C 1C 1C 1C EF 30 C3 B2 00 22 11 46 68 46 0D F0 64 FC C8 B1 12 25
9:10:32 AM
9:10:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 4F 09 81 80 05 E0 70 30 01 22 C3 B2 00 21 0D E0 22 25 2A 46 69 46 60 68 B6 F7 04 FD E5 81 01 20 09 B0 30 BD 6C 30 01 22 C3 B2 11 46 68 46 0D F0 4B FC 00 28 EC D1 E5 81 00 20 F1 E7 F0 B5 06 88 05 46 42 F2 92 71 70 1A 00 27 89 B0 8E 42 29 D0 14 DC 42 F2 14 71 A6 EB 01 00 8E 42 15 D0 08 DC A6 F5 1C 50 11 38 10 D0 01 28 0E D0 02 28 3C D1 0B E0 7C 28 16 D0 7D 28 37 D1 13 E0 06 28 34 D2 DF E8 00 F0
9:10:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 50 09 81 80 33 10 25 25 25 25 2C 89 12 2C 00 D3 12 24 22 46 68 46 69 68 B6 F7 C4 FC EF 36 F3 B2 00 22 0B E0 2C 89 22 2C 00 D3 22 24 22 46 68 46 69 68 B6 F7 B7 FC 70 36 F3 B2 01 22 00 21 68 46 0D F0 5C FC 88 B1 EC 81 01 20 09 B0 F0 BD 2C 89 22 2C 00 D3 22 24 22 46 68 46 69 68 B6 F7 A2 FC 6C 36 01 22 F3 B2 11 46 E9 E7 EF 81 00 20 EC E7 70 B5 05 46 44 68 00 88 A4 B0 00 26 20 F0 78 00 8D F8 8C 60
9:10:33 AM
9:10:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 51 09 81 80 A0 F5 30 51 EE 81 06 39 0B D1 23 A8 BE F7 02 FD 00 28 7D D1 68 68 9D F8 8C 10 01 26 01 70 30 46 FA E0 A0 F5 30 51 84 39 5D D1 68 46 BE F7 11 FD 00 28 EE D1 4F EA 0D 01 01 EB 80 02 D3 78 23 70 93 78 63 70 52 78 A2 70 11 F8 20 20 E2 70 40 1C 24 1D C0 B2 03 28 EF D3 5F F0 00 00 01 EB 80 02 40 1C D3 7B 23 70 93 7B 63 70 53 7B A3 70 12 7B E2 70 24 1D C0 B2 03 28 F0 D3 00 20 01 EB 40 02
9:10:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 52 09 81 80 40 1C 53 7E 23 70 12 7E 62 70 A4 1C C0 B2 03 28 F4 D3 00 20 01 EB 80 02 02 F1 20 02 00 F1 01 00 D3 78 23 70 93 78 63 70 53 78 A3 70 12 78 E2 70 C0 B2 04 F1 04 04 03 28 EC D3 00 20 01 EB 80 02 02 F1 2C 02 00 F1 01 00 D3 78 23 70 93 78 63 70 53 78 A3 70 12 78 E2 70 C0 B2 04 F1 04 04 03 28 EC D3 36 20 98 E0 A0 F5 30 51 85 39 10 D1 68 46 BE F7 AF FC 00 28 0B D1 00 21 68 46 00 EB 81 02
9:10:34 AM
9:10:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 53 09 81 80 02 F1 38 02 D3 78 23 70 93 78 63 70 53 78 00 E0 83 E0 A3 70 12 78 01 F1 01 01 E2 70 C9 B2 04 F1 04 04 03 29 EA D3 00 21 00 EB 81 02 02 F1 44 02 01 F1 01 01 D3 78 23 70 93 78 63 70 53 78 A3 70 12 78 E2 70 C9 B2 04 F1 04 04 03 29 EC D3 00 21 00 EB 81 02 02 F1 50 02 01 F1 01 01 D3 78 23 70 93 78 63 70 53 78 A3 70 12 78 E2 70 C9 B2 04 F1 04 04 03 29 EC D3 00 21 00 EB 81 02 02 F1 5C 02
9:10:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 54 09 81 80 01 F1 01 01 D3 78 23 70 93 78 63 70 53 78 A3 70 12 78 E2 70 C9 B2 04 F1 04 04 03 29 EC D3 00 21 00 EB 81 02 02 F1 68 02 01 F1 01 01 D3 78 23 70 93 78 63 70 53 78 A3 70 12 78 E2 70 C9 B2 04 F1 04 04 03 29 EC D3 00 21 00 EB 81 02 02 F1 74 02 01 F1 01 01 D3 78 23 70 93 78 63 70 53 78 A3 70 12 78 E2 70 C9 B2 04 F1 04 04 03 29 EC D3 00 21 00 EB 81 02 02 F1 80 02 01 F1 01 01 D3 78 23 70
9:10:35 AM
9:10:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 55 09 81 80 93 78 63 70 53 78 A3 70 12 78 E2 70 C9 B2 04 F1 04 04 03 29 EC D3 54 20 E8 81 24 B0 30 46 70 BD 2D E9 F0 43 05 46 00 88 6C 68 00 27 20 F0 78 00 42 F6 04 43 21 68 C2 1A 04 26 A3 B0 B9 46 98 42 26 D0 0B DC B0 F5 30 5F 17 D0 6F F4 30 52 80 18 15 D0 01 28 18 D0 02 28 09 D1 17 E0 01 2A 19 D0 4F F0 8A 08 6E 46 80 2A 18 D0 81 2A 7A D0 A5 F8 0E 90 00 20 23 B0 BD E8 F0 83 00 20 00 E0 01 20
9:10:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 56 09 81 80 BE F7 9C FB EE 81 0D E1 02 20 F9 E7 00 20 02 E0 01 20 00 E0 02 20 BE F7 9C FB F3 E7 8C 21 30 46 B6 F7 DB FB 28 89 86 28 01 D9 D4 F8 02 40 68 46 BE F7 CF FB 00 28 7D D1 06 EB 80 01 22 78 CA 70 62 78 8A 70 A2 78 4A 70 E1 78 06 F8 20 10 40 1C 24 1D C0 B2 03 28 EF D3 00 20 06 EB 80 01 22 78 CA 73 62 78 8A 73 A2 78 4A 73 E2 78 40 1C 24 1D C0 B2 0A 73 03 28 F0 D3 00 20 06 EB 40 01 22 78
9:10:36 AM
9:10:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 57 09 81 80 4A 76 62 78 40 1C A4 1C C0 B2 0A 76 03 28 F4 D3 00 20 06 EB 80 01 01 F1 20 01 22 78 CA 70 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EC D3 00 20 06 EB 80 01 01 F1 2C 01 22 78 CA 70 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EC D3 9B E0 FF E7 8C 21 30 46 B6 F7 77 FB 28 89 86 28 01 D9 D4 F8 02 40 68 46 BE F7 6B FB 00 28 19 D1
9:10:37 AM
9:10:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 58 09 81 80 06 EB 80 01 01 F1 38 01 22 78 CA 70 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EC D3 00 20 06 EB 80 01 22 78 01 F1 44 01 00 E0 77 E0 CA 70 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EA D3 00 20 06 EB 80 01 01 F1 50 01 22 78 CA 70 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EC D3 00 20 06 EB 80 01
9:10:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 59 09 81 80 01 F1 5C 01 22 78 CA 70 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EC D3 00 20 06 EB 80 01 01 F1 68 01 22 78 CA 70 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EC D3 00 20 06 EB 80 01 01 F1 74 01 22 78 CA 70 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EC D3 00 20 06 EB 80 01 01 F1 80 01 22 78 CA 70
9:10:38 AM
9:10:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 5A 09 81 80 62 78 8A 70 A2 78 4A 70 E2 78 00 F1 01 00 C0 B2 04 F1 04 04 0A 70 03 28 EC D3 68 46 BE F7 C2 FA A5 F8 0E 80 18 B1 A5 F8 0E 90 38 46 E2 E6 01 27 FB E7 70 B5 04 46 00 88 01 25 20 F0 78 00 A0 F5 30 50 87 38 2E 46 04 D0 7B 28 05 D0 00 25 28 46 70 BD 10 F0 9F FD 01 E0 10 F0 96 FD 61 68 08 70 E6 81 F4 E7 00 21 01 2A 09 D0 A2 F5 80 52 02 3A 09 D0 A2 F5 80 52 02 3A 0C D0 00 20 70 47 00 78
9:10:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 5B 09 81 80 60 F3 07 01 12 E0 02 78 40 78 62 F3 07 01 60 F3 0F 21 0B E0 02 78 62 F3 07 01 42 78 62 F3 0F 21 82 78 C0 78 62 F3 17 41 60 F3 1F 61 01 20 19 60 70 47 43 F6 11 22 81 1A 90 42 2F D0 19 DC 43 F6 95 12 A0 EB 02 01 90 42 28 D0 0B DC A0 F5 70 60 97 38 23 D0 A0 F5 A0 50 FD 38 1F D0 B0 F5 A8 5F 1A D1 1B E0 01 29 19 D0 02 29 17 D0 7B 29 13 D1 14 E0 05 29 12 D0 06 DC 01 29 0F D0 02 29 0D D0
9:10:39 AM
9:10:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 5C 09 81 80 04 29 09 D1 0A E0 A1 F5 A8 51 FF 39 06 D0 04 29 04 D0 B1 F5 82 7F 01 D0 00 20 70 47 01 20 70 47 1F B5 20 F0 78 00 CD E9 02 12 00 23 AD F8 04 00 00 93 74 20 0C 22 01 A9 D7 F7 E7 FC 00 28 13 D0 68 46 BD F7 CC FE 0E 24 01 23 00 22 20 46 00 99 03 F0 EA F9 00 28 07 D0 20 46 03 F0 B8 FD 10 B1 E0 20 11 F0 88 FB 01 20 04 B0 10 BD 30 B5 A0 F5 7F 41 FF 39 18 D0 8C 4C 00 23 40 F2 DD 72 99 18
9:10:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 5D 09 81 80 49 08 01 EB 41 05 34 F8 25 50 85 42 04 D1 01 EB 41 00 04 EB 80 00 30 BD 03 D2 01 F1 01 01 8B B2 00 E0 0A 46 93 42 EA D3 00 20 30 BD 01 20 70 47 02 28 01 D0 FF 20 70 47 D7 F7 5E BC 2D E9 F0 41 86 B0 4F F0 00 0C 0C 9E 88 46 17 46 1D 46 A6 F8 00 C0 FF F7 CB FF 04 00 48 D0 21 79 05 F0 07 00 01 F0 07 01 88 42 41 D3 60 88 C0 F3 0A 05 BD 42 3C D8 60 79 01 28 06 D0 02 28 0A D0 03 28 14 D0
9:10:40 AM
9:10:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 5E 09 81 80 04 28 33 D1 1C E0 2A 46 40 46 A1 68 B6 F7 48 F9 09 E0 60 89 C0 B2 FF F7 CB FF 21 89 2B 46 42 46 BD F7 71 F9 10 BB 35 80 24 E0 CD E9 00 56 23 89 60 89 3A 46 41 46 D7 F7 92 FB 00 28 17 D0 19 E0 20 88 AD F8 10 70 AD F8 14 50 AD F8 08 00 CD F8 0C 80 AD F8 12 C0 AD F8 16 C0 A0 68 01 68 02 A8 88 47 00 28 BD F8 16 00 30 80 03 D1 00 20 06 B0 BD E8 F0 81 01 20 FA E7 2D E9 FF 4F 8F B0 00 26
9:10:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 5F 09 81 80 1C 9F 89 46 90 46 3E 80 9B 46 4F F0 0A 0A 0F 98 FF F7 6C FF 04 00 7C D0 20 79 C0 F3 C2 01 CB F3 C2 00 81 42 7E D8 60 88 C0 F3 0A 05 45 45 79 D8 0F 98 FF F7 FE FE 30 B3 0D A8 0F F0 19 FC BD F8 34 00 C1 05 06 D5 80 05 04 D5 0E 20 03 F0 FF FC 00 28 67 D1 0E A8 05 96 00 90 03 96 04 96 5B 46 52 46 03 A9 0F 98 FF F7 69 FF 0B 96 62 88 0B AB 51 46 03 A8 FF F7 B6 FE 0C 96 62 88 0C AB 41 46
9:10:41 AM
9:10:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 60 09 81 80 48 46 FF F7 AF FE 60 79 01 28 06 D0 02 28 0A D0 03 28 14 D0 04 28 45 D1 1C E0 2A 46 49 46 A0 68 B6 F7 BE F8 09 E0 60 89 C0 B2 FF F7 41 FF 21 89 2B 46 4A 46 BD F7 0D F9 58 BB 3D 80 1F E0 CD E9 00 57 23 89 60 89 42 46 49 46 D7 F7 48 FB 00 28 25 D0 14 E0 20 88 AD F8 20 80 AD F8 18 00 CD F8 1C 90 AD F8 22 60 AD F8 24 50 A0 68 41 68 81 B1 06 A8 88 47 00 28 12 D0 BD F8 26 00 38 80 0F 98
9:10:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 61 09 81 80 FF F7 97 FE 50 B1 DD E9 0B 12 91 42 06 D0 0F 98 00 E0 07 E0 FF F7 C4 FE 00 28 00 D0 01 20 13 B0 BD E8 F0 8F 00 20 FA E7 64 E6 06 00 4F F6 FE 71 88 42 01 D2 80 B2 70 47 FE 4A 90 42 01 D1 08 46 70 47 4F F6 FF 70 70 47 A0 F5 7F 41 FE 39 03 D0 01 29 00 D1 00 20 70 47 F6 48 70 47 10 B5 14 46 A1 F5 7F 42 FF 3A 01 D1 00 20 10 BD 0A 46 04 23 21 46 02 F0 AC FD 00 28 F7 D0 01 20 10 BD 10 B5
9:10:42 AM
9:10:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 62 09 81 80 14 46 A1 F5 7F 42 FF 3A 01 D1 00 20 10 BD 0A 46 04 23 21 46 02 F0 AC FD 00 28 F7 D0 01 20 10 BD 38 B5 14 46 A1 F5 7F 42 FF 3A 11 D0 E2 4B 00 EB 80 02 03 EB 82 02 92 78 92 07 0B D5 0A 04 09 D5 18 20 00 90 00 23 22 46 02 20 D6 F7 2F FE 40 B1 00 20 38 BD 0A 46 18 23 21 46 02 F0 78 FD 00 28 F7 D0 01 20 38 BD 10 B5 14 46 A1 F5 7F 42 FF 3A 09 D0 D1 4B 00 EB 80 02 03 EB 82 02 92 78 92 07
9:10:43 AM
9:10:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 63 09 81 80 03 D5 0A 04 01 D5 00 20 10 BD 0A 46 18 23 21 46 02 F0 6E FD 00 28 F7 D0 01 20 10 BD 10 B5 00 24 1C 80 18 29 07 D3 32 B1 18 39 B1 FB F2 F1 00 7A 89 B2 88 42 01 D8 00 20 10 BD 19 80 01 20 10 BD F8 B5 1D 46 04 46 6B 46 FF F7 E8 FF 00 28 2E D0 BD F8 00 00 78 B1 00 22 C0 F3 C7 06 00 F0 07 07 2E B1 31 46 04 F1 0C 00 BD F7 6C FD C2 B2 00 20 B2 4B A1 19 0B E0 20 68 17 E0 0E 7B 13 F8 00 C0
9:10:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 64 09 81 80 16 EA 0C 0F 01 D0 52 1C D2 B2 40 1C C0 B2 B8 42 F3 D9 60 89 FF F7 58 FF 21 68 02 FB 00 11 29 60 22 7B 1B 78 1A 42 01 D0 08 1A 28 60 01 20 F8 BD F0 B5 00 20 DD F8 14 C0 18 70 08 7A 0D 46 00 28 27 D0 68 89 FF F7 40 FF 9C 49 86 46 28 7B 0E 78 2C 68 30 42 1E D0 94 42 21 D2 00 20 16 E0 00 BF 05 EB D0 06 00 F0 07 07 36 7B CF 5D 3E 42 06 D0 94 42 0E D2 1E 78 74 44 76 1C 1E 70 04 E0 BC F1
9:10:44 AM
9:10:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 65 09 81 80 00 0F 01 D1 94 42 04 D8 40 1C C0 B2 2E 7A 86 42 E6 D8 F0 BD BC F1 00 0F 03 D1 94 42 01 D3 00 20 F0 BD 00 20 16 E0 00 BF 05 EB D0 06 00 F0 07 07 36 7B CF 5D 3E 42 06 D0 1E 78 74 44 76 1C 1E 70 94 42 ED D2 04 E0 BC F1 00 0F 01 D1 94 42 E7 D8 40 1C C0 B2 2E 7A 86 42 E6 D8 F0 BD 3C B5 0D 46 00 93 00 24 01 AB FF F7 A3 FF 29 7A 81 42 00 D9 0C 1A 20 46 3C BD 2D E9 FC 43 81 46 48 89 0C 46
9:10:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 66 09 81 80 16 46 09 9D A0 F5 7F 41 1A 46 FF 39 1E D0 FF F7 DB FE 94 F8 08 80 B8 F1 00 0F 17 D0 DF F8 9C C1 61 7A 23 68 27 7B 9C F8 00 C0 01 FB 00 31 17 EA 0C 0F 00 D0 09 1A B3 42 02 D9 91 42 00 D8 45 B1 93 42 01 D8 B1 42 06 D2 00 26 34 E0 00 20 BD E8 FC 83 40 46 FB E7 B3 42 13 D9 91 42 11 D9 01 AB 52 1C 21 46 48 46 00 95 FF F7 62 FF 06 46 15 B3 00 95 01 AB 21 46 48 46 22 68 FF F7 59 FF 36 1A
9:10:45 AM
9:10:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 67 09 81 80 19 E0 91 42 07 D8 2B 46 32 46 21 46 48 46 FF F7 A5 FF 06 46 0F E0 01 AB 52 1C 21 46 48 46 00 95 FF F7 46 FF 07 46 01 AB 32 46 21 46 48 46 00 95 FF F7 3E FF 3E 1A 30 46 C9 E7 CA 08 01 F0 07 01 0C 2A 01 D9 00 20 70 47 3C 4B 10 44 02 7B 59 5C 0A 43 02 73 01 20 70 47 10 B5 0C 46 02 F0 D1 FB 00 28 0D D0 A4 F5 7F 41 FF 39 08 D0 01 8A A1 42 05 D9 C0 8A B4 FB F0 F1 00 FB 11 40 08 B1 00 20
9:10:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 68 09 81 80 10 BD 01 20 10 BD FE B5 06 46 00 20 0D 46 17 46 01 46 00 90 01 AB 02 AA 30 46 01 F0 32 FC 01 00 4F F6 FF 70 0C D0 BD F8 04 10 04 46 A1 42 07 D0 69 80 3A 46 30 46 FF F7 73 FE 10 B1 BD F8 04 00 FE BD 20 46 FE BD F0 B5 87 B0 0D 46 07 46 02 F0 98 FB 06 00 4F F6 FF 74 15 D0 17 49 07 EB 87 00 01 EB 80 00 80 78 40 06 0F D5 6A 46 29 46 38 46 FF F7 C9 FF 01 46 20 46 81 42 02 D0 01 98 B0 63
9:10:46 AM
9:10:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 69 09 81 80 68 88 07 B0 F0 BD 20 46 FB E7 29 46 38 46 02 F0 00 FC 60 B1 29 88 38 46 FF F7 9E FF 38 B1 06 A9 38 46 02 F0 0B FC 10 B1 28 88 A0 42 08 D1 20 46 12 E0 00 00 80 51 01 00 EC 44 07 00 68 C1 01 00 71 8B 06 9A 91 42 06 D2 F1 8A 32 8A 08 44 80 B2 01 44 91 42 00 D9 00 20 68 80 D2 E7 1C B5 0C 46 6B 46 01 AA 00 21 01 F0 E8 FB 4F F6 FF 72 18 B1 BD F8 00 00 90 42 01 D1 10 46 1C BD 60 80 1C BD
9:10:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 6A 09 81 80 F8 B5 0D 46 07 46 02 F0 3C FB 06 00 4F F6 FF 74 11 D0 FF 49 07 EB 87 00 01 EB 80 00 29 46 80 78 40 06 38 46 09 D5 FF F7 D9 FF 01 46 20 46 81 42 00 D0 68 88 F8 BD 20 46 F8 BD 02 F0 AA FB 90 B1 69 46 38 46 02 F0 BA FB 68 B1 28 88 A0 42 0A D0 00 99 41 B1 72 8B 8A 42 03 D3 F0 8A 49 1E 48 43 80 B2 68 80 F8 BD 20 46 FB E7 2D E9 F8 4F 0C 46 91 46 82 46 02 F0 05 FB 05 00 4F F6 FF 76 16 D0
9:10:47 AM
9:10:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 6B 09 81 80 21 46 50 46 02 F0 85 FB 88 B1 2C 8D 30 46 84 42 0E D0 69 8D B0 46 81 42 0A D0 28 6B 86 B2 E8 8A 08 44 87 B2 28 8A B8 42 18 D8 00 27 16 E0 30 46 BD E8 F8 8F 6A 46 21 46 50 46 FF F7 8F FD 80 B1 49 46 00 98 02 F0 99 FB 68 B1 E8 8A 20 44 84 B2 28 8A A0 42 00 D8 00 24 76 1E B6 B2 0E B1 BC 42 E8 D1 40 46 E4 E7 20 46 E2 E7 2D E9 FF 41 0C 46 07 46 16 46 49 88 FF F7 93 FD 01 00 4F F6 FF 70
9:10:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 6C 09 81 80 17 D0 71 68 05 46 AD F8 0C 00 03 A8 02 91 00 90 01 AB 02 AA 00 21 38 46 01 F0 69 FB 60 B1 BD F8 04 10 61 80 32 46 38 46 FF F7 7A FD 20 B1 BD F8 04 00 04 B0 BD E8 F0 81 28 46 FA E7 F0 B5 87 B0 0C 46 05 46 02 F0 9D FA 02 00 4F F6 FF 70 0C D0 AF 4B 05 EB 85 01 03 EB 81 01 89 78 49 06 05 D5 6A 46 21 46 28 46 FF F7 C0 FF 0A E7 53 8D 66 88 83 42 FA D0 D1 8A 12 8A 0B 44 9B B2 CF 18 97 42
9:10:48 AM
9:10:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 6D 09 81 80 00 D9 00 23 86 42 04 D1 21 46 28 46 FF F7 DB FE F7 E6 8D 19 AF B2 39 44 91 42 00 D9 00 27 9F 42 00 D1 07 46 67 80 38 46 EB E6 2D E9 F8 43 0E 46 15 46 80 46 02 F0 65 FA 04 00 0B D0 4F F6 FF 77 2F 80 60 8B B0 42 05 D9 69 46 40 46 FF F7 BB FE B8 42 02 D1 00 20 BD E8 F8 83 BD F8 02 00 E3 8A 22 8A 06 FB 03 00 80 B2 19 18 91 42 03 D9 61 8B 03 FB 11 00 80 B2 28 80 01 20 EC E7 F8 B5 0C 46
9:10:49 AM
9:10:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 6E 09 81 80 16 46 07 46 02 F0 3D FA 05 00 0C D0 00 20 30 80 28 8A A0 42 07 D9 69 46 38 46 FF F7 94 FE A0 F5 7F 41 FF 39 01 D1 00 20 F8 BD BD F8 02 00 A0 42 04 D9 69 8B EA 8A 01 FB 02 41 8C B2 E9 8A 20 1A 90 FB F1 F0 30 80 01 20 F8 BD 2D E9 F0 47 88 B0 0E 46 14 46 82 46 02 F0 14 FA 05 00 58 D0 61 89 4F F6 FF 77 04 F1 08 00 81 46 4F F0 18 08 B9 42 02 AA 29 D1 01 46 50 46 FF F7 45 FE B8 42 47 D0
9:10:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 6F 09 81 80 03 98 A9 6B 40 1A 86 42 04 D3 9D F8 10 10 01 44 B1 42 09 D8 02 AA 49 46 50 46 FF F7 26 FF B8 42 36 D0 A4 F8 00 80 EB E7 30 1A AD F8 04 00 69 8A 23 1D 41 43 18 31 89 B2 21 80 6A 8A 02 A8 FF F7 FF FC 00 28 25 D0 2B E0 50 46 FF F7 A9 FC 00 28 1F D0 20 88 69 8A 01 AB 08 44 81 B2 21 80 6A 8A 02 A8 FF F7 DB FC 60 B1 9D F8 10 00 BD F8 04 10 88 42 06 D9 6A 8A 21 88 23 1D 02 A8 FF F7 E0 FC
9:10:50 AM
9:10:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 70 09 81 80 70 B9 02 AA 49 46 50 46 FF F7 EF FE B8 42 03 D1 00 20 08 B0 BD E8 F0 87 A4 F8 00 80 02 98 60 60 01 20 F6 E7 7C B5 14 46 05 46 39 4A 00 EB 85 00 02 EB 80 00 80 78 40 06 04 D5 22 46 28 46 FF F7 84 FF 7C BD 04 20 20 80 6A 46 89 B2 28 46 FF F7 2C FF 00 28 F5 D0 01 AA BD F8 00 10 28 46 FF F7 3D FC 00 28 ED D0 BD F8 00 00 60 81 01 98 60 60 01 20 7C BD 2D E9 FF 4F 85 B0 8A 46 59 88 4F F6
9:10:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 71 09 81 80 FF 76 12 9C 93 46 1D 46 0D F1 08 09 B1 42 2F D1 00 20 01 46 00 90 03 AB 01 AA 05 98 01 F0 F1 F9 00 28 04 D0 BD F8 0C 00 B0 42 03 D1 00 20 09 B0 BD E8 F0 8F 68 80 81 B2 22 46 05 98 FF F7 30 FC 00 28 F4 D0 60 89 FF F7 FF FB DF F8 48 80 62 7A 21 68 23 7B 98 F8 00 70 02 FB 00 12 3B 42 00 D0 12 1A 8B 45 20 D3 92 45 1E D8 AD F8 08 60 43 E0 22 46 05 98 FF F7 14 FC 00 28 D8 D0 60 68 01 90
9:10:51 AM
9:10:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 72 09 81 80 AD F8 08 60 03 AB 01 AA 00 21 CD F8 00 90 03 E0 EC 44 07 00 68 C1 01 00 05 98 01 F0 E8 F9 00 28 C5 D0 BD F8 0C 00 C5 E7 AD F8 08 60 4E 46 60 68 03 AB CD E9 00 60 01 AA 00 21 05 98 01 F0 D7 F9 00 28 B4 D0 BD F8 0C 10 69 80 22 46 05 98 FF F7 E7 FB 00 28 AB D0 60 89 FF F7 B6 FB 61 7A 27 68 22 7B 98 F8 00 30 01 FB 00 71 1A 42 00 D0 09 1A BB 45 DC D3 8A 45 DA D8 01 20 98 E7 2D E9 F8 43
9:10:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 73 09 81 80 81 46 0E 46 90 46 1C 46 4F F6 FF 75 08 9F 0D E0 61 88 6A 46 48 46 FF F7 A1 FB 00 28 10 D0 00 98 B0 42 03 D9 40 45 01 D8 38 60 05 E0 21 46 48 46 FF F7 44 FE A8 42 EB D1 60 88 A8 42 01 D1 00 20 89 E6 01 20 87 E6 2D E9 F0 4F 89 B0 89 46 92 46 1C 46 83 46 02 F0 D5 F8 05 00 3E D0 61 89 01 AF A1 F5 7F 40 4F F0 00 08 04 F1 08 06 FF 38 15 D0 3A 46 58 46 FF F7 94 FB 00 28 2D D0 20 88 69 8A
9:10:52 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:10:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 74 09 81 80 23 1D 08 44 81 B2 21 80 6A 8A 01 A8 FF F7 D8 FB 20 B1 62 68 4A 45 01 D3 52 45 1C D9 33 46 52 46 49 46 58 46 00 97 FF F7 25 FF 00 28 14 D0 07 AB 4A 46 01 A9 58 46 CD F8 00 80 FF F7 F9 FB 69 8A 23 1D 41 43 18 31 89 B2 21 80 6A 8A 01 A8 FF F7 B7 FB 00 28 00 D0 01 20 29 E7 00 20 27 E7 FE B5 05 46 0E 46 17 46 1C 46 00 EB 85 00 FE 49 01 EB 80 00 80 78 40 06 04 D5 31 46 28 46 FF F7 A3 FF
9:10:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 75 09 81 80 FE BD 61 89 01 AA 28 46 FF F7 38 FE 10 B9 00 20 AD F8 04 00 02 A8 00 90 04 F1 08 03 3A 46 31 46 28 46 FF F7 6B FF 28 B1 02 98 60 60 04 20 20 80 01 20 FE BD 4F F0 FF 30 60 60 00 0C 60 81 00 20 FE BD 2D E9 F0 43 8B B0 81 46 02 F0 5A F8 00 28 61 D0 00 F1 20 04 00 20 20 60 60 60 4F F6 FF 75 A5 81 08 AF 01 46 07 AB 09 AA 48 46 00 97 01 F0 C8 F8 00 28 4F D0 BD F8 1C 00 A8 42 4A D0 BD F8
9:10:53 AM
9:10:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 76 09 81 80 20 00 A8 42 46 D0 00 26 B8 46 01 AA BD F8 1C 10 48 46 FF F7 05 FB 48 B3 D3 49 09 EB 89 00 01 EB 80 00 80 78 80 07 07 D5 BD F8 1C 00 01 04 03 D4 A1 89 A9 42 00 D1 A0 81 BD F8 0E 00 FF F7 C4 FA 9D F8 0D 30 01 9A C9 4F 03 FB 00 21 9D F8 10 30 3F 78 3B 42 00 D0 09 1A 20 68 08 B1 90 42 00 D9 22 60 60 68 08 B1 88 42 00 D2 61 60 07 AB 09 AA 00 21 48 46 CD F8 00 80 01 F0 B9 F8 00 B9 01 26
9:10:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 77 09 81 80 BD F8 1C 00 A8 42 05 D0 BD F8 20 00 A8 42 01 D0 00 2E BA D0 01 20 0B B0 BD E8 F0 83 FE B5 06 46 01 F0 EF FF 00 28 0A D0 AF 49 06 EB 86 02 01 EB 82 01 8A 78 52 06 03 D5 30 46 FF F7 82 FF FE BD 00 F1 20 04 4F F0 00 00 20 60 60 60 88 78 80 07 01 D5 20 89 A0 81 00 25 15 E0 6A 46 29 46 30 46 FF F7 20 FE 90 B1 20 68 10 B1 01 99 81 42 01 D2 01 98 20 60 60 68 10 B1 01 99 81 42 01 D9 01 98
9:10:54 AM
9:10:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 78 09 81 80 60 60 6D 1C AD B2 20 69 A8 42 E6 D8 01 20 FE BD 10 B5 04 46 01 F0 B5 FF 00 28 0A D0 92 4A 04 EB 84 01 02 EB 81 01 89 78 49 06 03 D5 38 30 03 C8 08 1A 10 BD C1 6B 40 8B 81 42 FA D2 08 46 10 BD 38 B5 05 46 01 F0 9D FF 00 28 14 D0 00 F1 20 04 69 46 28 46 FF F7 F7 FB 20 81 69 46 28 46 FF F7 4F FC 60 81 28 46 FF F7 D3 FF 81 B2 28 46 21 61 FF F7 94 FF 01 20 38 BD 00 20 70 47 2D E9 F0 4F
9:10:55 AM
9:10:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 79 09 81 80 8D B0 89 46 92 46 00 25 07 AF 83 46 08 AB 0A AA 29 46 00 97 00 F0 F5 FF 00 28 0A D0 BD F8 20 00 4F F6 FF 74 A0 42 03 D0 BD F8 1C 00 A0 42 02 D1 00 20 0D B0 FC E5 00 26 B0 46 01 AA BD F8 20 10 58 46 FF F7 2D FA 48 B1 53 46 4A 46 01 A9 58 46 CD F8 00 80 FF F7 0F FB 28 44 85 B2 08 AB 0A AA 00 21 58 46 00 97 01 F0 02 F8 00 B9 01 26 BD F8 20 00 A0 42 05 D0 BD F8 1C 00 A0 42 01 D0 00 2E
9:10:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 7A 09 81 80 DB D0 28 46 D5 E7 2D E9 FE 43 16 46 0D 46 81 46 B1 42 02 D9 00 20 BD E8 FE 83 01 F0 32 FF 00 28 F9 D0 51 4A 09 EB 89 01 02 EB 81 01 89 78 49 06 05 D5 32 46 29 46 48 46 FF F7 A0 FF EB E7 01 6A A9 42 04 D9 41 6A B1 42 01 D8 00 6B E3 E7 01 6B 40 8B 81 42 00 D3 01 46 4F F0 00 08 8F B2 44 46 10 E0 6A 46 21 46 48 46 FF F7 5C FD 60 B1 01 98 A8 42 05 D9 B0 42 03 D8 08 F1 01 00 1F FA 80 F8
9:10:56 AM
9:10:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 7B 09 81 80 64 1C A4 B2 BC 42 EC D3 40 46 C4 E7 10 B5 01 F0 60 FB 04 46 01 46 02 20 D5 F7 6C FE 58 B1 21 46 02 20 D6 F7 A6 F8 20 B9 21 46 02 20 D5 F7 62 FE 08 B1 00 20 10 BD 01 20 10 BD FE B5 07 46 01 F0 E0 FE 04 00 1D D0 00 25 4F F6 FF 76 01 AB 02 AA 00 21 38 46 00 95 00 F0 54 FF F0 B1 BD F8 04 10 B1 42 1A D0 08 04 0E D5 02 20 D5 F7 80 FF BD F8 04 30 00 21 38 46 02 9A 00 F0 EB FE 00 28 E5 D1
9:10:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 7C 09 81 80 FE BD 00 20 FE BD 02 98 A0 63 BD F8 04 20 22 85 E2 6B 10 1A 20 63 A1 85 03 E0 A5 63 26 85 25 63 A6 85 38 46 FF F7 4D FE 00 28 EB D0 38 46 FF F7 AD FF 00 28 E6 D0 01 20 FE BD 2D E9 FE 43 80 46 01 F0 9F FE 04 00 2A D0 D4 E9 0C 06 21 8B 08 44 B0 42 08 D8 40 46 FF F7 99 FF 20 B1 00 21 40 46 00 F0 7B FF F0 BB 03 E0 EC 44 07 00 68 C1 01 00 00 25 01 AB 02 AA 29 46 40 46 00 95 00 F0 01 FF
9:10:57 AM
9:10:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 7D 09 81 80 4F F6 FF 77 18 B9 BD F8 04 00 B8 42 3D D1 BD F8 04 00 00 04 39 D5 BE F7 52 FC 00 06 01 D5 00 20 39 E7 BD F8 04 10 02 20 D5 F7 21 FF BD F8 04 30 00 21 40 46 02 9A 00 F0 8C FE 00 28 F0 D0 01 AB 02 AA 00 21 40 46 00 95 00 F0 DB FE C8 B1 BD F8 04 00 B8 42 15 D0 02 99 A1 63 20 85 E2 6B A2 EB 01 01 00 E0 16 E0 21 63 02 04 00 D4 A0 85 20 8B 08 44 B0 42 CB D8 40 46 FF F7 48 FF 00 28 C6 D0
9:10:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 7E 09 81 80 03 E0 A5 63 27 85 25 63 A7 85 40 46 FF F7 3E FF 00 28 C5 D0 01 20 FE E6 2D E9 F0 47 C6 B0 0E 46 82 46 01 F0 2E FE 05 00 47 D0 A9 8D 32 46 50 46 FF F7 F6 F8 00 28 41 D0 45 AB 00 21 50 46 72 68 00 F0 81 FE 00 28 39 D0 34 7A 68 8A 44 43 18 34 BE F7 F5 FB 00 06 30 D4 22 46 41 A9 02 20 D5 F7 CB FD 50 B1 21 46 02 20 D5 F7 C3 FF 28 BB 22 46 41 A9 02 20 D5 F7 C0 FD F8 B9 00 27 A4 B2 4F F4
9:10:58 AM
9:10:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 7F 09 81 80 80 70 84 42 01 D9 01 46 00 E0 21 46 88 46 81 46 21 E0 A8 8D 43 46 38 44 82 B2 01 A9 50 46 01 F0 56 FE 00 28 0A D0 CD F8 00 80 3B 46 01 AA BD F8 04 11 02 20 D5 F7 4C FF 10 B1 00 20 46 B0 29 E4 07 EB 08 00 87 B2 A4 EB 08 00 84 B2 48 46 84 42 00 D8 20 46 80 46 00 2C DB D1 BD F8 04 31 00 21 50 46 72 68 00 F0 12 FE 00 28 E7 D0 70 68 43 90 BD F8 04 01 AD F8 08 01 4F F6 FF 70 AD F8 10 01
9:10:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 80 09 81 80 44 A8 00 90 42 AB 43 AA 00 21 50 46 00 F0 6F FE 00 28 D3 D0 BD F8 08 01 A8 85 50 46 FF F7 0D FF 00 28 CB D0 01 20 C9 E7 F0 B5 87 B0 0D 46 06 46 01 F0 A7 FD 04 00 07 D0 A2 8D 60 8D 4F F6 FF 71 8A 42 01 D0 88 42 02 D1 00 20 07 B0 F0 BD 05 44 95 42 01 D8 52 1B 04 E0 20 8A 40 1B 90 42 00 DD 02 46 97 B2 00 21 30 46 00 F0 77 FE C0 B9 E0 8A B8 42 03 D2 30 46 FF F7 E0 FE 14 E0 69 46 30 46
9:10:59 AM
9:10:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 81 09 81 80 FF F7 4A FF 00 28 E0 D0 A0 8D 85 42 01 D8 40 1B 05 E0 21 8A 49 1B 81 42 01 DD 8F B2 00 E0 87 B2 E0 8A B8 42 EA D8 01 20 CF E7 2D E9 F0 43 8B B0 0E 46 81 46 01 F0 65 FD 04 00 46 D0 4F F0 00 08 01 AB 02 AA 41 46 48 46 CD F8 00 80 00 F0 D9 FD 00 28 3B D0 09 AB 0A AA 00 21 48 46 00 F0 ED FD 00 28 33 D0 BD F8 04 20 4F F6 FF 75 AA 42 2C D0 BD F8 24 00 A8 42 28 D0 30 44 90 42 01 D8 12 1A
9:10:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 82 09 81 80 04 E0 21 8A 08 1A 90 42 00 DD 02 46 97 B2 00 21 48 46 00 F0 22 FE 00 21 30 BB 00 BF BD F8 04 30 00 21 48 46 02 9A 00 F0 54 FD 00 28 0E D0 01 AB 02 AA 00 21 48 46 CD F8 00 80 00 F0 A2 FD 00 28 04 D0 BD F8 04 00 A8 42 01 D1 00 20 23 E5 BD F8 24 20 01 21 32 44 82 42 01 D8 80 1A 05 E0 23 8A 9A 1A 82 42 01 DD 97 B2 00 E0 87 B2 E0 8A B8 42 D4 D8 A1 B1 03 AA BD F8 04 10 48 46 FE F7 D0 FF
9:11:00 AM
9:11:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 83 09 81 80 68 B1 BD F8 04 00 20 85 04 99 A1 63 C9 4A 09 EB 89 01 02 EB 81 01 89 78 89 07 00 D5 A0 85 01 20 F9 E4 2D E9 FF 5F 0F 46 DD E9 0E 4B 90 46 1E 46 00 98 01 F0 E6 FC 05 00 7E D0 77 60 06 F1 08 01 00 98 01 F0 66 FD 00 28 76 D0 31 89 71 81 00 98 B8 4A 00 EB 80 00 A1 F5 7F 43 02 EB 80 09 4F F0 00 0A FF 3B 27 D1 4F F0 01 0C AB F8 00 C0 A6 F8 0A A0 27 60 E8 6B 60 60 53 46 84 F8 08 C0 40 46
9:11:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 84 09 81 80 B8 F1 01 0F 00 D0 00 20 60 72 28 68 00 68 FE F7 4D FF 60 81 E3 60 23 61 63 61 B8 F1 00 0F 01 D0 84 F8 0C C0 2B 85 E8 6B A8 63 99 F8 02 00 80 07 7E D5 AB 85 7C E0 22 46 00 98 FE F7 71 FF 00 28 7D D0 60 89 FE F7 40 FF 63 7A 22 68 01 46 03 FB 01 20 99 4B 22 7B 1B 78 1A 42 00 D0 40 1A 42 18 B8 F1 00 0F 02 D0 97 42 04 D0 06 E0 87 42 04 D3 97 42 02 D2 4F F0 01 0C 01 E0 4F F0 00 0C 20 7A
9:11:01 AM
9:11:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 85 09 81 80 62 68 EB 6B 02 44 9A 42 1A D1 2A 68 12 68 8A 42 16 D1 29 8B 88 42 13 D2 BC F1 00 0F 10 D0 40 1C C0 B2 20 72 B8 F1 00 0F 42 D0 40 1E C1 B2 20 46 FF F7 83 F8 60 7A 00 E0 41 E0 40 1C 60 72 37 E0 69 8A 48 43 18 30 81 B2 70 89 08 44 80 B2 70 81 EA 8A 10 44 2A 8A 90 42 01 D9 A6 F8 0A A0 01 20 AB F8 00 00 99 F8 02 00 80 07 00 98 02 D5 FF F7 9B FE 01 E0 FF F7 D9 FE 00 28 20 D0 27 60 E8 6B
9:11:02 AM
9:11:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 86 09 81 80 01 23 60 60 23 72 40 46 B8 F1 01 0F 00 D0 00 20 60 72 28 68 00 68 FE F7 C9 FE 60 81 C4 F8 0C A0 C4 F8 10 A0 C4 F8 14 A0 B8 F1 00 0F 00 D0 23 73 20 7A 69 8A 40 1E 48 43 18 30 30 80 01 20 04 B0 BD E8 F0 9F 2D E9 F0 41 8A B0 0E 46 17 46 1C 46 80 46 01 F0 16 FC 05 00 1E D0 00 20 AD F8 20 00 28 68 00 68 40 B1 55 49 88 42 05 D0 29 8B 01 29 02 D0 B6 FB F0 F6 46 43 08 AA 02 A8 CD E9 00 02
9:11:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 87 09 81 80 31 46 23 46 3A 46 40 46 FF F7 0B FF 00 28 04 D0 BE F7 D5 F9 00 06 03 D5 00 20 0A B0 BD E8 F0 81 61 89 02 AA 40 46 FE F7 DE FE 00 28 F5 D0 60 89 68 85 BD F8 20 00 60 B1 63 89 00 21 40 46 EA 6B 00 F0 EA FB 00 28 E8 D0 40 46 FF F7 7A FB 00 28 E3 D0 61 89 40 46 01 F0 6A FC 00 28 DD D0 60 89 20 81 01 20 D9 E7 2D E9 F8 43 81 46 0E 46 00 EB 89 01 30 48 1D 46 00 EB 81 07 B8 78 40 06 05 D5
9:11:03 AM
9:11:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 88 09 81 80 31 46 48 46 FF F7 9E FF BD E8 F8 83 48 46 01 F0 B8 FB 04 00 0C D0 20 68 00 68 58 B1 27 4A 90 42 08 D0 21 8B 01 29 05 D0 B6 FB F0 F1 41 43 02 E0 00 20 E9 E7 31 46 88 46 05 F1 08 01 48 46 6E 60 01 F0 27 FC 00 28 DF D0 28 89 A0 F5 7F 41 FF 39 06 D0 E1 8A 08 44 86 B2 88 19 21 8A 88 42 00 D9 00 26 6E 81 6A 46 31 46 48 46 CD F8 00 80 FE F7 46 FE 00 28 C8 D0 04 20 28 80 66 85 61 8B E0 6B
9:11:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 89 09 81 80 88 42 06 D8 00 20 20 85 B9 78 89 07 08 D5 A0 85 06 E0 28 89 20 85 B8 78 80 07 01 D5 28 89 F6 E7 31 46 48 46 01 F0 03 FC 00 28 AD D0 2E 81 01 20 AA E7 00 00 EC 44 07 00 68 C1 01 00 80 51 01 00 70 B5 0D 46 14 46 01 F0 5C FB 00 28 13 D0 8D B9 A4 F5 7F 41 FF 39 0D D0 04 2C 0B D3 B0 F8 4E 10 A1 42 07 D9 B0 F8 4C 00 B4 FB F0 F1 00 FB 11 40 04 28 01 D0 00 20 70 BD 01 20 70 BD 2D E9 F0 41
9:11:04 AM
9:11:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 8A 09 81 80 80 46 0D 46 17 46 1C 46 06 9E 01 F0 3A FB 00 28 0B D0 4D B9 C1 89 39 B1 B0 F8 4E 20 A1 19 91 42 02 D8 90 F8 49 10 11 B1 00 20 BD E8 F0 81 80 89 33 46 02 19 39 46 40 46 01 F0 2F FB 00 28 F4 D0 01 20 F2 E7 2D E9 F0 41 80 46 0D 46 17 46 1C 46 06 9E 01 F0 16 FB 00 28 E7 D0 4D B9 C1 89 39 B1 B0 F8 4E 20 A1 19 91 42 02 D8 90 F8 49 10 09 B1 00 20 DA E7 80 89 33 46 02 19 39 46 40 46 00 F0
9:11:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 8B 09 81 80 C0 FF 00 28 D1 D0 01 20 CF E7 F8 B5 1D 46 06 46 0F 46 14 46 FF F7 94 FF 00 28 0A D0 06 20 00 90 23 46 2A 46 39 46 30 46 FF F7 A8 FF 00 28 00 D0 01 20 F8 BD F8 B5 1D 46 06 46 0F 46 14 46 FF F7 7F FF 00 28 0A D0 06 20 00 90 23 46 2A 46 39 46 30 46 FF F7 B7 FF 00 28 00 D0 01 20 F8 BD 2D E9 FE 43 0C 46 16 46 1F 46 80 46 01 F0 CA FA 05 00 2A D0 01 2C 28 D8 6A 46 21 46 40 46 00 F0 C2 FB
9:11:05 AM
9:11:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 8C 09 81 80 00 28 22 D0 BD F8 00 20 4F F6 FF 71 01 96 AD F8 08 70 8A 42 03 D0 BD F8 02 00 88 42 05 D1 04 22 AD F8 00 20 AD F8 02 20 13 E0 04 EB 44 01 05 EB 81 01 31 F8 4C 3F 1A 44 92 B2 49 88 13 44 8B 42 00 D9 04 22 90 42 02 D1 00 20 BD E8 FE 83 AD F8 00 20 01 AB 21 46 40 46 FF F7 AC FF 00 28 F4 D0 6A 46 21 46 40 46 00 F0 97 FB 00 28 ED D0 01 20 EB E7 2D E9 F0 47 86 B0 0D 46 91 46 98 46 82 46
9:11:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 8D 09 81 80 01 F0 7F FA 06 00 01 D0 01 2D 03 D9 00 20 06 B0 BD E8 F0 87 01 AA 29 46 50 46 00 F0 73 FB 00 28 F5 D0 05 EB 45 00 06 EB 80 06 BD F8 06 40 B6 F8 4C 70 23 E0 03 AB 22 46 29 46 50 46 FF F7 65 FF 00 28 E4 D0 03 99 49 45 0A D1 AD F8 10 80 03 AB 22 46 29 46 50 46 FF F7 6D FF 00 28 D7 D0 14 E0 BD F8 04 00 A0 42 10 D0 E0 19 84 B2 B6 F8 4C 00 B6 F8 4E 10 20 44 88 42 00 D9 04 24 22 46 29 46
9:11:06 AM
9:11:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 8E 09 81 80 50 46 FF F7 DD FE 00 28 D4 D1 01 20 BF E7 2D E9 FE 43 0C 46 16 46 1F 46 80 46 01 F0 32 FA 05 00 18 D0 01 2C 16 D8 6A 46 21 46 40 46 00 F0 2A FB 00 28 8A D0 BD F8 02 20 01 AB 21 46 40 46 FF F7 24 FF 00 28 81 D0 01 98 B0 42 03 D1 BD F8 08 00 B8 42 01 D0 00 20 78 E7 04 EB 44 01 05 EB 81 01 BD F8 02 00 31 F8 4C 2F 10 44 80 B2 49 88 02 44 8A 42 00 D9 04 20 BD F8 00 10 81 42 03 D1 4F F6
9:11:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 8F 09 81 80 FF 70 AD F8 00 00 AD F8 02 00 6A 46 21 46 40 46 00 F0 02 FB 00 28 DE D0 01 20 56 E7 2D E9 FE 4F 82 46 4F F6 FF 70 18 80 0D 46 91 46 1E 46 50 46 01 F0 E7 F9 07 00 01 D0 01 2D 02 D9 00 20 BD E8 FE 8F 6A 46 29 46 50 46 00 F0 DC FA 00 28 F6 D0 05 EB 45 00 07 EB 80 07 BD F8 02 40 B7 F8 4C 80 1C E0 01 AB 22 46 29 46 50 46 FF F7 CE FE E0 B1 01 99 49 45 03 D1 BD F8 08 00 30 80 15 E0 BD F8
9:11:07 AM
9:11:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 90 09 81 80 00 00 A0 42 11 D0 04 EB 08 00 84 B2 B7 F8 4C 00 B7 F8 4E 10 20 44 88 42 00 D9 04 24 22 46 29 46 50 46 FF F7 4D FE 00 28 DB D1 01 20 C7 E7 2D E9 FE 4F 4F F6 FF 74 0C 9F 83 46 88 46 15 46 99 46 1C 80 01 F0 9E F9 06 00 7E D0 40 46 B8 F1 01 0F 7A D8 01 46 6A 46 58 46 00 F0 94 FA 00 28 74 D0 BD F8 00 20 41 46 58 46 FF F7 2A FE 00 28 7E D0 BD F8 02 20 41 46 58 46 FF F7 22 FE 00 28 76 D0
9:11:08 AM
9:11:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 91 09 81 80 BD F8 02 00 BD F8 00 10 88 42 70 D0 3A 88 41 46 58 46 FF F7 15 FE 01 00 29 68 08 EB 48 00 01 91 22 D0 AD F8 08 40 39 88 3C 80 BD F8 00 20 8A 42 5D D0 06 EB 80 00 30 F8 4C 2F 11 44 8C B2 40 88 11 19 81 42 00 D9 04 24 22 46 41 46 58 46 FF F7 F7 FD 00 28 39 D0 01 AB 22 46 41 46 58 46 FF F7 54 FE 00 28 31 D0 4F E0 A2 46 AD F8 08 40 BD F8 02 40 06 EB 80 06 3C E0 01 AB 22 46 41 46 58 46
9:11:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 92 09 81 80 FF F7 43 FE 00 28 20 D0 BD F8 00 00 A0 42 2E D0 01 98 29 68 88 42 1C D1 36 F8 4C 0F 01 19 8C B2 71 88 20 44 88 42 00 D9 04 24 BD F8 02 00 A0 42 1D D0 01 AB 22 46 41 46 58 46 FF F7 26 FE 00 28 03 D0 01 98 29 68 01 E0 11 E0 11 E0 88 42 0E D0 16 E0 B6 F8 4C 00 01 19 8C B2 B6 F8 4E 10 20 44 88 42 00 D9 04 24 BD F8 02 00 A0 42 01 D1 00 20 25 E7 22 46 41 46 58 46 FF F7 A2 FD 00 28 BB D1
9:11:09 AM
9:11:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 93 09 81 80 BD F8 08 10 51 45 06 D0 01 98 28 60 BD F8 08 10 A9 F8 00 10 3C 80 01 20 11 E7 2D E9 FF 4F 83 B0 4F F6 FF 78 A3 F8 00 80 0E 46 92 46 1F 46 03 98 01 F0 E7 F8 5F EA 00 09 01 D0 01 2E 03 D9 00 20 07 B0 BD E8 F0 8F 6A 46 31 46 03 98 00 F0 DA F9 00 28 F5 D0 06 EB 46 01 09 EB 81 09 68 F3 0F 04 00 25 BD F8 02 80 B9 F8 4C B0 25 E0 01 AB 42 46 31 46 03 98 FF F7 C9 FD 28 B3 01 99 DA F8 00 00
9:11:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 94 09 81 80 81 42 03 D1 CA F8 00 50 3C 80 1C E0 BD F8 00 10 41 45 18 D0 08 EB 0B 00 1F FA 80 F8 B9 F8 4C 10 B9 F8 4E 00 41 44 81 42 01 D9 4F F0 04 08 BD F8 08 00 01 9D 60 F3 0F 04 42 46 31 46 03 98 FF F7 3F FD 00 28 D2 D1 01 20 BA E7 2D E9 FF 47 80 46 00 20 0C 9C 10 60 4F F6 FF 70 89 46 15 46 1E 46 18 80 04 B1 20 80 03 AA 40 46 00 F0 8B F9 00 28 10 D0 BD F8 0E 70 6B 46 3A 46 49 46 40 46 FF F7
9:11:10 AM
9:11:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 95 09 81 80 84 FD 30 B1 00 98 28 60 BD F8 04 00 30 80 04 B1 27 80 01 20 04 B0 FB E5 FE B5 06 46 00 20 10 60 4F F6 FF 70 14 46 18 80 1D 46 0F 46 6A 46 30 46 00 F0 68 F9 00 28 0D D0 BD F8 00 20 01 AB 39 46 30 46 FF F7 62 FD 20 B1 01 98 20 60 BD F8 08 00 28 80 01 20 FE BD F8 B5 0D 46 06 46 01 F0 51 F8 04 00 1F D0 6A 46 29 46 30 46 00 F0 4B F9 00 28 19 D0 BD F8 00 20 4F F6 FF 70 82 42 14 D0 BD F8
9:11:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 96 09 81 80 02 30 83 42 10 D0 05 EB 45 00 04 EB 80 04 34 F8 4C 1F 50 18 80 B2 62 88 01 44 91 42 00 D9 04 20 83 42 01 D1 00 20 F8 BD 01 20 F8 BD 01 20 70 47 2D E9 F8 43 0F 46 14 46 80 46 01 F0 22 F8 05 00 17 D0 07 EB 47 06 B4 B1 4F F6 FF 74 AD F8 00 40 AD F8 02 40 6A 46 39 46 40 46 00 F0 1D F9 00 28 05 D0 05 EB 86 00 20 F8 50 4F 44 80 01 20 BD E8 F8 83 00 20 FB E7 6A 46 39 46 40 46 00 F0 02 F9
9:11:11 AM
9:11:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 97 09 81 80 00 28 F4 D0 05 EB 86 00 BD F8 00 10 20 F8 50 1F BD F8 02 10 41 80 E9 E7 2D E9 F0 41 0C 46 16 46 1F 46 05 46 00 F0 ED FF 00 28 07 D0 04 EB 44 01 00 EB 81 00 90 F8 48 00 08 B1 00 20 B5 E4 3B 46 32 46 21 46 28 46 FF F7 0A FD 00 28 F6 D0 01 20 AB E4 2D E9 F0 41 0C 46 16 46 1F 46 05 46 00 F0 D0 FF 00 28 07 D0 04 EB 44 01 00 EB 81 00 90 F8 48 00 08 B1 00 20 98 E4 3B 46 32 46 21 46 28 46
9:11:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 98 09 81 80 FF F7 85 FD 00 28 F6 D0 01 20 8E E4 2D E9 F0 41 0C 46 16 46 1F 46 05 46 00 F0 B3 FF 00 28 07 D0 04 EB 44 01 00 EB 81 00 90 F8 48 00 08 B1 00 20 7B E4 3B 46 32 46 21 46 28 46 FF F7 1A FD 00 28 F6 D0 01 20 71 E4 2D E9 F0 41 06 46 4F F6 FF 70 18 80 0C 46 17 46 1D 46 30 46 00 F0 92 FF 00 28 04 D0 14 B9 90 F8 48 00 08 B1 00 20 5D E4 2B 46 3A 46 21 46 30 46 FF F7 91 FD 00 28 F6 D0 01 20
9:11:12 AM
9:11:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 99 09 81 80 53 E4 2D E9 F8 43 06 46 0C 46 17 46 98 46 08 9D 00 F0 77 FF 00 28 04 D0 14 B9 90 F8 48 00 08 B1 00 20 64 E7 43 46 3A 46 21 46 30 46 00 95 FF F7 CC FE 00 28 F5 D0 01 20 59 E7 2D E9 F0 41 0C 46 16 46 1F 46 05 46 00 F0 5C FF 00 28 04 D0 14 B9 90 F8 48 00 08 B1 00 20 27 E4 3B 46 32 46 21 46 28 46 FF F7 D9 FE 00 28 F6 D0 01 20 1D E4 2D E9 F8 43 06 46 0C 46 17 46 98 46 08 9D 00 F0 41 FF
9:11:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 9A 09 81 80 00 28 04 D0 14 B9 90 F8 48 00 08 B1 00 20 2E E7 43 46 3A 46 21 46 30 46 00 95 FF F7 88 FD 00 28 F5 D0 01 20 23 E7 2D E9 F0 41 0C 46 16 46 1F 46 05 46 00 F0 26 FF 00 28 04 D0 14 B9 90 F8 48 00 08 B1 00 20 15 E4 3B 46 32 46 21 46 28 46 FF F7 24 FE 00 28 F6 D0 01 20 0B E4 70 B5 0C 46 05 46 00 F0 0F FF 00 28 04 D0 14 B9 90 F8 48 00 08 B1 00 20 70 BD 21 46 28 46 FF F7 AD FE 00 28 F8 D0
9:11:13 AM
9:11:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 9B 09 81 80 01 20 70 BD 08 B5 04 23 00 93 00 23 FF F7 B6 FB 00 28 00 D0 01 20 08 BD 08 B5 04 23 00 93 00 23 FF F7 D0 FB 00 28 00 D0 01 20 08 BD 10 28 01 D3 00 20 70 47 F6 4A F5 49 32 F8 10 00 08 44 70 47 70 B5 02 46 10 28 16 D2 F1 4B 33 F8 12 00 03 EB 42 02 0B 46 52 88 EF 49 12 1A 12 04 12 0C 0A D0 84 18 40 F2 AC 45 AC 42 05 D2 01 44 18 46 B4 F7 D7 F9 01 20 70 BD 00 20 70 BD 0E B5 10 28 01 D3
9:11:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 9C 09 81 80 00 20 0E BD E2 4A 32 F8 10 30 02 EB 40 00 40 88 C0 1A 82 B2 02 A8 CD E9 00 20 29 20 D5 F7 1F FC 0E BD 0E B5 02 AA 2C 21 CD E9 00 12 0A 46 01 46 00 23 29 20 D5 F7 53 FC 0E BD 10 B5 2C 22 D5 49 B4 F7 AE F9 01 20 10 BD 00 B5 8B B0 68 46 FF F7 F4 FF 00 28 02 D0 68 46 FF F7 E3 FF 0B B0 00 BD 0E B5 10 28 01 D3 00 20 0E BD C9 4A 32 F8 10 30 02 EB 40 00 40 88 C0 1A 82 B2 02 A8 CD E9 00 20
9:11:14 AM
9:11:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 9D 09 81 80 29 20 D5 F7 2C FC 0E BD 7F B5 0E 46 14 46 05 46 10 28 13 D2 94 B1 69 46 FF F7 AF FF 00 28 0E D0 9D F8 00 10 51 B1 00 23 68 46 05 E0 00 EB 43 02 52 88 32 B1 5B 1C DB B2 99 42 F7 D8 00 20 04 B0 70 BD 00 EB 43 00 44 EA 06 21 41 80 69 46 28 46 FF F7 C6 FF 00 28 F2 D0 01 20 F0 E7 1F B5 0C 46 10 28 1E D2 69 46 FF F7 88 FF 00 28 13 D0 9D F8 00 10 B1 B1 00 20 6A 46 11 E0 00 BF 02 EB 40 03
9:11:15 AM
9:11:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 9E 09 81 80 5B 88 B4 EB 13 2F 08 D1 13 F0 FF 0F 05 D0 02 EB 40 00 40 88 C0 B2 04 B0 10 BD 40 1C C0 B2 81 42 EC D8 00 20 F7 E7 1F B5 04 46 10 28 01 D3 00 20 F1 E7 69 46 FF F7 61 FF 00 28 EC D0 9D F8 00 00 50 B1 41 00 0D F1 02 00 B4 F7 EE F9 69 46 20 46 FF F7 86 FF 00 28 DE D0 01 20 DC E7 2D E9 F0 41 04 00 08 46 15 46 43 D0 88 B3 85 B3 23 78 00 21 02 26 01 22 10 2B 42 D0 0D DC 4F F0 04 06 10 2B
9:11:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 9F 09 81 80 23 D2 DF E8 03 F0 22 25 25 27 2B 38 38 35 22 47 47 22 22 27 22 27 17 2B 2A D0 0A DC A3 F1 11 03 4F F0 08 0C 06 2B 10 D2 DF E8 03 F0 14 29 21 2C 2C 14 1A 2B 1C D0 04 DC 18 2B 19 D0 19 2B 04 D1 28 E0 1B 2B 14 D0 FF 2B 12 D0 29 80 20 E0 0F E0 A0 88 0A E0 21 79 01 70 2A 80 19 E0 A3 68 33 B1 A2 88 19 46 B4 F7 DC F8 0C 20 28 80 10 E0 29 80 00 20 BD E8 F0 81 61 68 01 60 2E 80 08 E0 A1 88
9:11:16 AM
9:11:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A0 09 81 80 01 80 FA E7 61 68 01 60 A1 68 41 60 A5 F8 00 C0 01 20 EE E7 A3 68 00 2B E9 D0 A2 88 19 46 B4 F7 BF F8 D5 E7 30 B5 03 46 A0 F5 7F 40 FF 38 10 D0 00 22 59 4C 10 21 50 18 40 08 34 F8 10 50 9D 42 08 D0 03 D2 00 F1 01 00 C2 B2 00 E0 01 46 8A 42 F1 D3 FF 20 30 BD 10 28 01 D3 00 20 70 47 50 4A 4E 49 32 F8 10 00 08 44 70 47 10 B5 40 F2 AC 42 4C 49 B4 F7 00 F9 01 20 10 BD 0E B5 02 A9 40 F2
9:11:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A1 09 81 80 AC 42 CD E9 00 21 01 46 00 23 06 20 D5 F7 E7 FA 0E BD 70 B5 02 46 10 28 16 D2 41 4B 33 F8 12 00 03 EB 42 02 0B 46 52 88 3E 49 12 1A 12 04 12 0C 0A D0 84 18 40 F2 AC 45 AC 42 05 D2 01 44 18 46 B4 F7 6E F8 01 20 70 BD 00 20 70 BD 0E B5 10 28 01 D3 00 20 0E BD 32 4A 32 F8 10 30 02 EB 40 00 40 88 C0 1A 82 B2 02 A8 CD E9 00 20 06 20 D5 F7 B6 FA 0E BD 0E B5 02 A9 40 F2 AC 42 CD E9 00 21
9:11:17 AM
9:11:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A2 09 81 80 01 46 00 23 06 20 D5 F7 EA FA 0E BD 0E B5 10 28 01 D3 00 20 0E BD 22 4A 32 F8 10 30 02 EB 40 00 40 88 C0 1A 82 B2 02 A8 CD E9 00 20 06 20 D5 F7 D6 FA 0E BD 1C 49 00 EB 80 00 01 EB 80 00 80 78 70 47 00 EB 80 01 18 48 00 EB 81 00 80 78 41 07 01 D5 02 20 70 47 01 07 01 D5 06 20 70 47 00 06 01 D5 80 20 70 47 20 20 70 47 A0 F5 C8 50 10 38 03 28 09 D2 DF E8 00 F0 02 04 06 00 00 20 70 47
9:11:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A3 09 81 80 01 20 70 47 07 20 70 47 FF 20 70 47 18 68 00 10 26 4B 07 00 FA 4A 07 00 CC 44 07 00 6C 63 00 10 D8 4A 07 00 2C 46 07 00 EC 44 07 00 2D E9 F0 43 AD F2 AC 5D 88 46 81 46 00 24 FF F7 C2 FF C7 B2 00 25 E7 E0 38 F8 15 00 A0 F5 00 41 10 39 17 D0 FF F7 CB FF 49 46 48 45 04 D1 08 46 FF F7 AA FF C0 07 0D D1 38 F8 15 00 A0 F5 7F 41 FF 39 73 D0 FD F7 3C FE 28 B1 40 88 C0 F3 0A 00 20 44 84 B2
9:11:18 AM
9:11:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A4 09 81 80 C6 E0 A4 F2 24 40 40 42 82 B2 53 A9 0D F5 B4 60 BB F7 42 FE 38 F8 15 00 20 F0 78 00 E5 F7 C0 FE 00 28 7D D0 01 7A AD F8 84 15 38 F8 15 10 C1 F3 C3 01 8D F8 8C 15 D0 F8 02 10 CD F8 86 15 C0 88 AD F8 8A 05 0D F2 84 51 68 46 E5 F7 5A FF 00 28 69 D0 29 46 48 46 FF F7 41 FE 8D F8 3B 00 92 E0 0D F5 B4 62 0D F5 B2 61 68 46 E6 F7 B4 FD 00 28 59 D0 9D F8 90 05 09 28 03 D1 9D F8 88 00 01 28
9:11:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A5 09 81 80 4D D1 0D F5 B0 61 0D F5 B2 60 DC F7 96 FE 00 28 49 D0 9D F8 90 05 02 28 02 D0 BD F8 80 05 18 E0 9D F8 8C 05 C8 B1 9D F8 3B 00 D0 B3 00 EB 40 00 6F F0 0B 01 01 EB 80 00 DD F8 98 25 0D F2 7C 51 10 44 CD F8 98 05 DC F7 78 FE 00 28 2B D0 BD F8 7C 05 20 44 84 B2 56 E0 5F E0 00 26 35 E0 00 BF 9D F8 8C 05 0D F2 84 51 40 1C 8D F8 8C 05 68 46 E5 F7 07 FF 00 28 16 D0 0D F5 B4 62 0D F5 B2 61
9:11:19 AM
9:11:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A6 09 81 80 68 46 E6 F7 68 FD 00 28 0D D0 9D F8 90 05 02 28 05 D0 09 28 0B D1 9D F8 88 00 01 28 07 D0 01 E0 01 E0 17 E0 00 20 0D F2 AC 5D BD E8 F0 83 0D F2 7C 51 0D F5 B2 60 DC F7 40 FE 00 28 F3 D0 BD F8 7C 05 76 1C 20 44 84 B2 F6 B2 BD F8 80 05 86 42 19 D2 C5 E7 00 26 12 E0 0D F2 7C 51 DD F8 98 05 DC F7 2B FE 00 28 DE D0 BD F8 7C 05 20 44 84 B2 DD F8 98 05 0C 30 76 1C F6 B2 CD F8 98 05 BD F8
9:11:20 AM
9:11:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A7 09 81 80 80 05 86 42 E8 D3 9D F8 64 00 00 28 3F F4 68 AF 6D 1C ED B2 BD 42 FF F4 15 AF 20 46 C3 E7 FF 49 00 EB 80 00 01 EB 80 00 40 78 70 47 00 EB 80 01 FA 48 00 EB 81 00 80 78 41 07 03 D5 80 06 03 D4 28 20 70 47 01 07 01 D5 30 20 70 47 00 06 02 D5 4F F4 92 70 70 47 64 20 70 47 F0 4A 00 EB 80 03 02 EB 83 02 93 78 5B 06 1C D5 C0 EB C0 03 03 EB 00 10 EB 4B 01 EB 41 01 03 EB 80 00 00 EB 81 00
9:11:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A8 09 81 80 12 8A 90 F8 48 00 30 B1 52 1E 01 20 00 EB D2 00 34 21 48 43 03 E0 02 EB 42 00 40 00 00 1D B0 F5 80 3F 00 D3 00 20 80 B2 70 47 00 B5 02 46 FF F7 B6 FF 01 28 01 D0 00 20 00 BD D8 49 02 EB 82 00 01 EB 80 00 80 78 40 06 01 D5 18 20 00 BD 04 20 00 BD 10 B5 00 20 D1 4C D1 4B 01 46 01 EB 81 02 04 EB 82 02 92 78 92 07 09 D5 C1 EB C1 02 02 EB 01 12 03 EB 82 02 D2 8A 82 42 00 D9 10 46 49 1C
9:11:21 AM
9:11:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 A9 09 81 80 10 29 EB D3 10 BD 10 B5 0B 46 02 46 10 28 01 D3 00 20 10 BD FF F7 83 FF FF 28 05 D0 99 1D 10 46 FF F7 84 FE 00 28 F4 D0 01 20 10 BD 30 B5 CA 8A 00 24 1A B1 8B 89 8D 68 9D 42 01 D2 4C 83 30 BD CC 89 EB 1A 1B 1B B3 FB F2 F2 12 04 12 0C 4A 83 F5 D0 00 EB 80 03 B1 48 00 EB 83 00 C0 68 82 42 ED D9 48 83 30 BD 30 B5 04 46 0D 46 FF F7 DE FF 29 46 20 46 FF F7 DA FF 29 46 20 46 BD E8 30 40
9:11:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 AA 09 81 80 D4 E7 70 B5 10 28 17 D2 C0 EB C0 04 A4 4D 04 EB 00 14 05 EB 84 05 A3 4C AD 68 04 EB C0 00 D6 18 00 F5 9D 60 AE 42 07 D8 00 68 85 18 0A 46 20 78 29 46 BA F7 8E FE 08 B1 00 20 70 BD 01 20 70 BD 13 B5 04 23 20 22 01 A9 FF F7 DB FF 1C BD 2D E9 F8 43 06 46 10 28 02 D3 00 20 BD E8 F8 83 C6 EB C6 00 00 EB 06 11 8E 48 00 EB 81 04 30 46 FF F7 72 FD 20 60 30 46 FF F7 19 FC 60 60 30 46 FF F7
9:11:22 AM
9:11:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 AB 09 81 80 0E FF FF 28 0B D1 20 21 20 46 B3 F7 A6 FE 30 46 FF F7 61 FD 20 60 30 46 FF F7 08 FC 60 60 81 48 00 25 00 EB C6 00 00 F5 9D 68 30 46 21 68 FF F7 8D FD 40 B9 BD F7 C3 F8 40 05 04 D4 30 46 21 68 FF F7 67 FD 01 25 30 46 21 68 FF F7 5C FF 40 B9 BD F7 B5 F8 40 05 04 D4 30 46 21 68 FF F7 59 FD 00 E0 75 B1 30 46 21 68 FF F7 90 FD 00 28 B4 D0 68 46 BB F7 F4 FA 30 46 00 99 FF F7 A1 FF 00 28
9:11:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 AC 09 81 80 AB D0 30 46 61 68 FF F7 F8 FB 38 B9 BD F7 97 F8 40 05 03 D4 30 46 61 68 FF F7 D2 FB 30 46 FF F7 BE FE FF 28 71 D0 4F F0 00 0C 04 F1 48 05 84 F8 48 C0 84 F8 49 C0 4F F6 FF 70 28 81 68 81 61 46 30 46 FF F7 CA FE E8 80 28 78 48 B1 34 20 A8 80 28 78 01 27 A0 B1 E8 88 34 28 03 D2 00 20 0F E0 06 20 F4 E7 34 21 B0 FB F1 F1 49 1E C8 08 C2 07 12 F1 00 42 3C D0 07 EB D1 00 20 F0 01 00 80 1C
9:11:23 AM
9:11:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 AD 09 81 80 A8 70 D8 F8 04 00 A0 60 30 46 FF F7 8F FE A0 81 A4 F8 0E C0 E8 88 E0 81 A2 89 A1 68 89 1A 08 1A 20 82 21 68 30 46 89 1D FF F7 80 FD 60 82 30 46 FF F7 BB FE A0 82 20 8A 03 21 B0 FB F1 F0 40 F6 18 21 E0 82 88 42 00 D3 08 46 E0 82 A1 8A 06 EB 86 02 40 1A 61 8A 90 FB F1 F0 00 04 2F 49 00 0C 20 83 01 EB 82 01 07 D0 C8 68 01 28 03 D0 03 E0 00 F1 01 00 C4 E7 27 83 88 78 40 06 03 D5 0A 8A
9:11:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 AE 09 81 80 C8 68 90 42 02 D1 27 83 05 E0 1D E0 20 8B 60 28 01 D9 60 20 20 83 A0 8A 22 8B 63 8A 02 FB 03 00 80 B2 E0 82 22 8A B2 FB F0 F0 60 83 22 8B 01 2A 0A D1 8A 78 52 06 07 D4 C9 68 88 42 00 D3 08 46 60 83 E1 8A 48 43 20 82 01 20 06 E7 70 B5 06 46 10 28 01 D3 00 20 70 BD C6 EB C6 00 00 EB 06 11 0F 48 00 EB 81 04 04 F1 20 05 28 21 28 46 B3 F7 B4 FD 4F F6 FF 71 29 81 69 81 A9 81 E0 8A 18 B3
9:11:24 AM
9:11:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 AF 09 81 80 06 48 06 EB 86 01 00 EB 81 00 81 78 89 07 1D D5 94 F8 48 10 79 B9 E1 89 09 1F 05 E0 EC 44 07 00 84 5D 00 10 64 63 00 10 B4 F8 4C 20 B1 FB F2 F1 22 8B 51 43 69 61 6A 69 C1 68 8A 42 04 D9 20 8B B1 FB F0 F1 41 43 69 61 01 20 70 BD 21 8B 62 8B EF E7 10 B5 04 46 10 28 0F D2 C4 EB C4 01 FD 4A 01 EB 04 11 02 EB 81 01 00 20 48 65 20 46 FF F7 AE FE 20 46 BD E8 10 40 A8 E7 10 BD 2D E9 F0 41
9:11:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B0 09 81 80 05 46 0C 46 10 28 02 D3 00 20 BD E8 F0 81 4F F4 92 71 20 46 B3 F7 61 FD 28 46 FF F7 C7 FD 20 80 ED 4A 00 21 05 EB 85 00 61 80 02 EB 80 00 25 71 40 78 60 71 C5 EB C5 00 E6 4B 00 EB 05 12 03 EB 82 00 86 68 A6 60 46 8A A6 81 C6 8A E6 81 06 8B 26 82 40 8B 60 82 53 F8 22 00 00 79 20 76 53 F8 22 00 40 79 60 76 53 F8 22 00 00 68 60 61 4F F6 FF 70 60 83 28 46 E1 61 FF F7 63 FC 01 46 00 20
9:11:25 AM
9:11:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B1 09 81 80 06 25 09 E0 53 F8 22 60 05 EB 40 07 F6 5B 04 EB 40 07 40 1C BE 84 80 B2 88 42 F3 D3 01 20 B4 E7 70 B5 0B 46 14 46 05 46 FF F7 4B FC 02 46 28 46 FF F7 7C FD 19 88 88 42 2B D1 18 79 21 79 88 42 27 D1 58 79 61 79 88 42 23 D1 98 68 A1 68 88 42 1F D1 98 89 A1 89 88 42 1B D1 D8 89 E1 89 88 42 17 D1 18 8A 21 8A 88 42 13 D1 18 7E 21 7E 88 42 0F D1 58 7E 61 7E 88 42 0B D1 58 69 61 69 88 42
9:11:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B2 09 81 80 07 D1 52 00 04 F1 24 01 03 F1 24 00 B3 F7 1C FC 08 B1 00 20 70 BD 01 20 70 BD 2D E9 F0 43 AD F5 13 7D 04 46 89 46 10 28 43 D2 AB 48 04 EB 84 01 00 EB 81 07 78 78 FF 28 15 D0 A8 4E 20 46 06 EB C4 02 02 F5 9D 62 FF F7 31 FD 51 68 05 46 A9 42 2F D3 D2 F8 00 80 30 78 2B 46 6A 46 41 46 BA F7 52 FC 30 BB 03 E0 01 20 0D F5 13 7D DD E4 49 A9 20 46 FF F7 43 FF 00 28 F6 D0 49 AA 69 46 20 46
9:11:26 AM
9:11:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B3 09 81 80 FF F7 8E FF 10 B1 B9 F1 00 0F 03 D0 BC F7 D7 FE 40 05 01 D5 00 22 0F E0 4F F4 92 72 49 A9 68 46 B3 F7 69 FC 30 78 2B 46 6A 46 41 46 BA F7 51 FC 08 B1 00 20 D8 E7 01 22 B8 78 40 06 03 D5 00 21 20 46 FF F7 B5 F8 C4 EB C4 00 00 EB 04 12 81 48 BD F8 02 10 00 EB 82 00 A0 F8 40 10 07 99 C1 63 C1 E7 2D E9 FC 41 80 21 7D 48 B3 F7 76 FC 7B 4C 08 23 6A 46 20 78 00 21 BA F7 05 FC 10 B1 00 20
9:11:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B4 09 81 80 BD E8 FC 81 01 98 08 22 08 38 73 4D 00 21 00 BF 01 EB 81 03 05 EB 83 03 5E 78 FF 2E 12 D0 DE 78 86 B9 9E 68 76 B1 5B 68 73 43 98 42 00 D2 03 46 B3 FB F6 F3 73 43 04 EB C1 06 06 F5 9D 66 C0 1A 0C C6 1A 44 49 1C C9 B2 10 29 E1 D3 06 46 00 21 4F F4 7A 7C 01 EB 81 03 05 EB 83 03 5F 78 FF 2F 19 D0 DF 78 01 2F 16 D1 9F 68 A7 B1 5B 68 63 45 00 D3 63 46 06 FB 03 FE BE FB FC F3 98 42 00 D2
9:11:27 AM
9:11:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B5 09 81 80 03 46 B3 FB F7 F3 7B 43 04 EB C1 07 07 F5 9D 67 C0 1A 0C C7 1A 44 49 1C C9 B2 10 29 DA D3 01 20 AE E7 2D E9 F0 41 06 46 01 25 FF F7 9A FF 00 28 1E D0 48 4F 00 24 00 BF C4 EB C4 00 00 EB 04 10 07 EB 80 00 5C 21 B3 F7 08 FC 20 46 FF F7 81 FE 64 1C E4 B2 10 2C EF D3 00 24 31 46 20 46 FF F7 1C FF 00 B9 00 25 64 1C E4 B2 10 2C F5 D3 28 46 8B E6 70 B5 39 4D 88 B0 FF 20 28 70 00 26 06 A8
9:11:28 AM
9:11:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B6 09 81 80 BA F7 A7 FA 00 20 02 A9 BA F7 B1 FA 68 BB 04 9C 46 F6 FF 70 84 42 00 D3 04 46 00 20 2F 4A 21 46 68 60 BA F7 DA FA 00 BB 06 A8 BA F7 92 FA 28 78 FF 28 1A D0 08 23 6A 46 00 21 6C 60 BA F7 63 FB 98 B9 BC F7 FC FD 40 05 13 D4 26 48 00 99 81 42 02 D1 01 99 A1 42 0C D0 CD E9 00 04 28 78 08 23 6A 46 00 21 BA F7 75 FB 10 B1 00 20 08 B0 70 BD 01 26 31 46 02 20 D3 F7 7C FF 01 20 F6 E7 17 48
9:11:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B7 09 81 80 70 47 10 28 01 D3 00 20 70 47 C0 EB C0 01 01 EB 00 10 10 49 01 EB 80 00 70 47 70 B5 10 28 17 D2 C0 EB C0 04 0B 4D 04 EB 00 14 05 EB 84 05 0B 4C AD 68 04 EB C0 00 D6 18 00 F5 9D 60 AE 42 07 D8 00 68 85 18 0A 46 20 78 29 46 BA F7 1C FB 58 B1 00 20 70 BD 84 5D 00 10 EC 44 07 00 64 63 00 10 4C 68 00 10 BE AB BB AA 01 20 F2 E7 70 B5 0D 46 04 46 FF F7 DB FB 03 00 EB D0 29 46 20 46 BD E8
9:11:29 AM
9:11:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B8 09 81 80 70 40 00 22 C9 E7 E4 E7 70 B5 0D 46 04 46 FF F7 CD FB 03 00 DD D0 29 46 20 46 BD E8 70 40 00 22 6F E4 D6 E7 10 B5 0B 46 4F F0 FF 31 11 60 FF F7 A8 FF 00 28 07 D0 81 89 C4 89 80 68 21 44 19 44 88 42 01 D8 00 20 10 BD 01 20 11 60 10 BD F8 B5 0D 46 11 46 1E 46 04 46 6A 46 FF F7 E3 FF 00 28 05 D0 33 46 29 46 20 46 00 9A FF F7 96 FF F8 BD F8 B5 0D 46 11 46 1E 46 04 46 6A 46 FF F7 D2 FF
9:11:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 B9 09 81 80 00 28 05 D0 33 46 29 46 20 46 00 9A FF F7 39 FC F8 BD 10 B5 0C 46 02 23 1A 22 FF F7 7E FF 08 B1 01 20 10 BD 4F F6 FF 70 20 80 00 20 10 BD 13 B5 02 23 1A 22 01 A9 FF F7 24 FC 1C BD 10 B5 0C 46 04 23 1C 22 FF F7 69 FF 08 B1 01 20 10 BD 00 20 20 60 10 BD 13 B5 04 23 1C 22 01 A9 FF F7 11 FC 1C BD 10 B5 0C 46 04 23 20 22 FF F7 56 FF 08 B1 01 20 10 BD 00 20 20 60 10 BD 88 42 02 D9 4F F0
9:11:30 AM
9:11:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 BA 09 81 80 FF 30 70 47 02 D2 4F F0 01 00 70 47 4F F0 00 00 70 47 10 B5 0B 46 02 46 FF F7 41 FB 01 28 02 D0 4F F6 FF 70 10 BD BD E8 10 40 19 46 10 46 FD F7 85 BC 10 B5 03 46 0C 46 FF F7 31 FB 01 28 02 D0 4F F6 FF 70 10 BD 21 46 BD E8 10 40 18 46 FD F7 0C BC 10 B5 03 46 0C 46 FF F7 21 FB 01 28 01 D0 00 20 10 BD 21 46 BD E8 10 40 18 46 FD F7 5A BD 70 B5 04 46 0D 46 FF F7 12 FB 01 28 01 D0 00 20
9:11:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 BB 09 81 80 27 E7 29 46 20 46 BD E8 70 40 FD F7 68 BE 13 B5 02 23 1A 46 01 A9 FF F7 B4 FB 1C BD 30 B4 10 28 10 D2 C0 EB C0 02 02 EB 00 13 F7 4A 02 EB 83 04 34 F8 40 2F 42 EA 01 03 23 80 19 46 93 42 01 D0 30 BC E4 E7 30 BC 70 47 2D E9 FF 4F AD F2 CC 5D 0C 46 DD F8 D8 05 00 21 15 46 01 80 DD F8 CC 05 10 28 5F D2 C0 EB C0 01 01 EB 00 10 E6 49 01 EB 80 06 71 8A A9 42 55 D8 30 68 00 28 53 D0 20 46
9:11:31 AM
9:11:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 BC 09 81 80 B3 F7 92 FA A8 46 00 25 AA 46 CD F8 BC 55 CD F8 AC 55 DD F8 CC 05 FF F7 94 F9 83 46 00 20 3B E0 32 68 06 21 01 EB 49 07 D0 5B A0 F5 7F 41 FF 39 35 D0 A0 F5 00 41 10 39 2B D0 FF F7 96 F9 DD F8 CC 15 88 42 05 D1 08 46 FF F7 74 F9 C0 07 20 D1 A2 46 0D F2 8C 50 00 90 30 68 42 46 21 46 C0 5B DD F8 AC 35 FD F7 2A F8 50 B9 BD F8 8C 05 F0 B1 04 21 DD F8 CC 05 FF F7 91 FF 01 20 CD F8 BC 05
9:11:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 BD 09 81 80 BD F8 8C 05 A8 EB 00 01 04 44 28 44 1F FA 81 F8 85 B2 09 F1 01 00 80 B2 81 46 58 45 C0 D3 70 8A A8 42 70 D0 00 20 0D F2 DC 5D BD E8 F0 8F 40 F2 24 42 54 A9 0D F5 B8 60 BA F7 EE FF 30 68 C0 5B 20 F0 78 00 E5 F7 6C F8 00 28 EC D0 01 7A AD F8 9C 15 31 68 C9 5B C1 F3 C3 01 8D F8 A4 15 D0 F8 02 10 CD F8 9E 15 C0 88 AD F8 A2 05 0D F2 9C 51 01 A8 E5 F7 06 F9 00 28 D5 D0 09 F0 FF 01 DD F8
9:11:32 AM
9:11:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 BE 09 81 80 CC 05 FE F7 EB FF 8D F8 3F 00 9C E0 0D F5 B8 62 0D F5 B2 61 01 A8 E5 F7 5E FF 00 28 C3 D0 0D F5 B0 62 21 46 0D F5 B2 60 FF F7 18 F8 00 28 BA D0 9D F8 90 05 02 28 04 D0 01 28 02 D0 BD F8 80 05 19 E0 9D F8 A4 05 F8 B1 9D F8 3F 00 E8 B3 00 EB 40 00 6F F0 0B 02 02 EB 80 00 DD F8 98 15 0D F5 B1 62 08 44 21 46 CD F8 98 05 FE F7 F7 FF 00 28 99 D0 BD F8 88 05 A8 EB 00 01 04 44 28 44 1F FA
9:11:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 BF 09 81 80 81 F8 85 B2 5F E0 64 E0 00 27 38 E0 9D F8 A4 05 0D F2 9C 51 40 1C 8D F8 A4 05 01 A8 E5 F7 B1 F8 00 28 80 D0 0D F5 B8 62 0D F5 B2 61 01 A8 E5 F7 12 FF 00 28 89 D0 9D F8 90 05 02 28 3F F4 72 AF 01 28 FB D0 09 28 06 D1 00 E0 1D E0 9D F8 8C 00 01 28 7F F4 67 AF 0D F5 B1 62 21 46 0D F5 B2 60 FE F7 BC FF 00 28 87 D0 BD F8 88 05 7F 1C A8 EB 00 01 04 44 28 44 1F FA 81 F8 85 B2 BF B2 BD F8
9:11:33 AM
9:11:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C0 09 81 80 80 05 87 42 1F D2 C1 E7 00 27 18 E0 0D F5 B1 62 21 46 DD F8 98 05 FE F7 A1 FF 00 28 87 D0 BD F8 88 05 04 44 A8 EB 00 01 28 44 85 B2 DD F8 98 05 1F FA 81 F8 0C 30 7F 1C BF B2 CD F8 98 05 BD F8 80 05 87 42 E2 D3 9D F8 68 00 00 28 3F F4 5E AF 16 E7 DD F8 BC 05 30 B1 BA F1 00 0F 03 D0 B6 F8 40 10 AA F8 00 10 DD F8 D8 05 71 8A 01 80 01 20 19 E7 00 B5 45 4A 89 B0 04 A9 10 44 BA F7 0A FD
9:11:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C1 09 81 80 07 AA 69 46 04 A8 BA F7 85 FD 00 20 8D F8 05 00 8D F8 06 00 8D F8 07 00 02 46 04 A9 68 46 BA F7 3E FD 03 A9 04 A8 BA F7 59 FC 03 98 09 B0 00 BD 00 B5 89 B0 04 A9 BA F7 ED FC 07 AA 01 A9 04 A8 BA F7 68 FD 01 20 8D F8 07 00 00 20 8D F8 09 00 8D F8 0A 00 8D F8 0B 00 02 46 04 A9 01 A8 BA F7 1E FD 69 46 04 A8 BA F7 39 FC 00 98 DE E7 00 B5 89 B0 04 A9 BA F7 CE FC 07 AA 69 46 04 A8 BA F7
9:11:34 AM
9:11:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C2 09 81 80 49 FD 00 20 8D F8 05 00 8D F8 06 00 8D F8 07 00 02 46 04 A9 68 46 BA F7 02 FD 03 A9 04 A8 BA F7 1D FC 03 98 C2 E7 B1 F5 61 6F 06 D8 00 29 03 D0 B0 FB F1 F0 40 1C 48 43 70 47 14 4A 91 42 FB D1 97 E7 2D E9 FF 47 06 46 0E 9F 90 46 00 20 0C 9A 38 80 89 46 1D 46 30 46 FF F7 13 FD 04 00 0E D0 30 46 FF F7 1C F9 01 28 09 D1 01 AB 29 46 30 46 FE F7 39 F9 00 28 03 D0 63 8A 43 45 08 D9 00 20
9:11:35 AM
9:11:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C3 09 81 80 04 B0 BD E8 F0 87 00 00 84 5D 00 10 80 51 01 00 BD F8 0E 00 BD F8 04 10 08 44 82 B2 49 46 30 46 FF F7 66 FD 00 28 EB D0 60 8A 38 80 E1 6B 30 46 49 1C E1 63 FF F7 8E FD 00 28 E1 D0 68 46 BA F7 0E FD 30 46 00 99 FF F7 BB F9 00 28 D8 D0 FB 49 06 EB 86 00 01 EB 80 00 80 78 40 06 0C D5 D4 E9 0E 10 40 1A 20 63 20 68 F5 49 00 68 88 42 10 D0 B5 FB F0 F5 45 43 0C E0 C6 EB C6 01 F1 4A 01 EB
9:11:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C4 09 81 80 06 11 02 EB 81 01 20 6B 49 8B 88 42 01 D2 40 1C 20 63 60 6A A8 42 00 D2 65 62 20 6A 08 B1 A8 42 00 D9 25 62 01 20 AB E7 2D E9 F0 41 AD F5 87 6D 06 46 0D 46 17 46 98 46 10 28 03 D3 00 20 0D F5 87 6D 55 E4 E0 49 C6 EB C6 00 DE 4A 00 EB 06 10 02 EB 80 04 8D 42 26 D3 0D F5 86 63 40 F2 24 42 03 A9 30 46 FF F7 B0 FD E8 B1 B4 F8 40 00 0D F2 34 41 00 97 CD E9 01 01 2B 46 BD F8 30 24 03 A9
9:11:36 AM
9:11:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C5 09 81 80 30 46 FF F7 5E FF 70 B1 B8 F1 00 0F 06 D0 00 21 A4 F8 40 10 30 46 FF F7 7A FD 20 B1 57 B1 26 B1 01 2E 05 D0 06 E0 65 65 C8 E7 04 F0 3A F8 01 E0 04 F0 52 F8 01 20 65 65 C1 E7 2D E9 FC 47 81 46 0F 46 01 A8 BA F7 8B FC DF F8 F8 82 00 24 00 BF C4 EB C4 00 00 EB 04 11 08 EB 81 05 28 68 06 68 00 97 96 B3 69 46 20 46 FF F7 FB FC 31 46 00 98 FF F7 19 FF 00 90 31 46 01 98 FF F7 14 FF 00 99
9:11:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C6 09 81 80 88 42 22 D0 01 23 1A 46 20 46 FF F7 8D FF B9 F1 20 0F 03 D0 A9 F5 00 41 40 39 16 D1 28 68 01 99 00 68 B1 FB F0 F2 00 FB 12 10 70 B1 B9 F1 20 0F 12 D0 A9 F5 00 40 40 38 10 D0 00 21 35 F8 40 0F 01 43 29 80 20 46 FF F7 22 FD 64 1C E4 B2 10 2C BE D3 01 20 BD E8 FC 87 20 21 EF E7 4F F4 00 41 EC E7 C0 EB C0 01 01 EB 00 10 96 49 10 B5 01 EB 80 00 20 30 28 21 B2 F7 B0 FF 01 20 10 BD 10 B5
9:11:37 AM
9:11:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C7 09 81 80 CA B0 04 46 FF F7 FD FB 00 28 2F D0 8B 49 04 EB 84 00 01 EB 80 00 40 78 FF 28 1D D0 69 46 20 46 FF F7 24 FC 00 28 21 D0 20 46 FF F7 CF F9 00 28 1C D0 C4 EB C4 00 00 EB 04 12 82 48 BD F8 02 10 00 EB 82 00 A0 F8 40 10 07 99 C1 63 20 46 FE F7 E6 FF 01 28 04 D0 08 E0 20 46 FF F7 C2 FF 04 E0 20 46 FD F7 2D FC 00 28 00 D0 01 20 4A B0 10 BD 2D E9 F0 47 4F F4 AD 61 74 48 B2 F7 6E FF 71 48
9:11:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C8 09 81 80 00 25 08 38 05 60 45 60 FE F7 90 FB 6D 4E 00 24 A8 46 06 F5 B8 69 00 BF C4 EB C4 00 00 EB 04 17 06 EB 87 05 5C 21 28 46 B2 F7 57 FF 29 F8 14 80 20 46 FE F7 10 FE 46 F8 27 00 20 46 FE F7 B6 FC 64 1C E4 B2 68 60 10 2C E6 D3 FF F7 52 FB 00 28 10 D0 00 20 FF F7 25 FB 00 28 0B D0 5B 49 01 20 00 24 48 80 20 46 FF F7 8A FF 64 1C E4 B2 10 2C F8 D3 01 20 85 E6 10 B5 02 46 FE F7 90 FF 01 28
9:11:38 AM
9:11:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 C9 09 81 80 04 D1 10 46 FD F7 99 FC 00 28 00 D0 01 20 10 BD 2D E9 F1 41 81 B0 9D F8 04 00 10 28 4F D2 C0 EB C0 01 48 4C 01 EB 00 11 04 EB 81 01 DF F8 0C 81 00 EB 80 02 0F 6B 08 EB 82 01 4F F0 00 05 89 78 89 07 03 D5 FF F7 D7 FF 00 B9 01 25 9D F8 04 00 C0 EB C0 01 01 EB 00 10 04 EB 80 00 5C 21 B0 F8 40 60 B2 F7 FA FE 9D F8 04 00 FF F7 72 F9 01 21 9D F8 04 00 FF F7 11 FA 00 28 21 D0 9D F8 04 00
9:11:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 CA 09 81 80 B8 B9 01 21 00 20 42 46 00 EB 80 03 02 EB 83 03 9B 78 9B 07 08 D5 C0 EB C0 03 03 EB 00 13 04 EB 83 03 1B 6B 03 B1 00 21 40 1C C0 B2 10 28 EB D3 01 B9 3D B1 01 21 02 20 D3 F7 9B FA 10 B1 00 20 BD E8 FC 81 9D F8 04 00 FF F7 19 FF 00 28 F7 D0 9D F8 04 00 C0 EB C0 01 01 EB 00 11 04 EB 81 01 A1 F8 40 60 31 46 FF F7 12 FC 01 A9 01 20 0C F0 F1 FD 67 B1 9D F8 04 00 20 B1 01 28 02 D0 07 28
9:11:39 AM
9:11:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 CB 09 81 80 05 D1 01 E0 B6 20 00 E0 DF 20 0D F0 F4 FF 9D F8 04 00 80 1E 0C 28 25 D2 DF E8 00 F0 06 24 24 24 24 24 08 1A 1C 1E 20 22 0D 20 00 E0 A1 20 0D F0 E2 FF 9D F8 04 00 B8 B1 18 E0 00 00 EC 44 07 00 80 51 01 00 84 5D 00 10 00 A6 CE 12 64 63 00 10 A8 20 EC E7 B8 20 EA E7 B9 20 E8 E7 BA 20 E6 E7 BB 20 E4 E7 0E 20 E2 E7 03 F0 9B FE 9D F8 04 00 01 28 01 D1 03 F0 B0 FE 68 46 BA F7 F0 FA 9D F8
9:11:40 AM
9:11:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 CC 09 81 80 04 00 00 99 FE F7 9C FF 00 28 99 D0 01 20 97 E7 38 B5 04 46 10 28 08 D2 FC 48 04 EB 84 01 10 F8 21 00 04 28 03 D0 05 28 01 D0 00 20 38 BD 68 46 BA F7 D5 FA 01 23 00 22 20 46 00 99 FF F7 F4 FD 01 20 38 BD 2C 22 04 23 FF F7 A7 BA 13 B5 2C 22 04 23 01 A9 FE F7 55 FF 1C BD 13 B5 14 22 04 23 01 A9 FE F7 4E FF 1C BD C0 EB C0 02 02 EB 00 10 E7 4A 02 EB 80 00 C0 69 08 60 01 20 70 47 10 B5
9:11:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 CD 09 81 80 69 B1 B1 F5 16 7F 0A D0 B1 F5 61 7F 07 D0 B1 F5 E1 6F 04 D0 B1 F5 61 6F 01 D0 00 20 10 BD C0 EB C0 02 DB 4B 02 EB 00 12 03 EB 82 02 D1 61 FF F7 CD FF 00 28 F2 D0 01 20 10 BD FE F7 07 BD 30 B5 05 46 C0 EB C5 00 D2 49 00 EB 05 10 01 EB 80 00 C3 B0 C4 69 B4 F5 16 7F 08 D0 B4 F5 61 7F 05 D0 B4 F5 E1 6F 02 D0 B4 F5 61 6F 19 D1 69 46 28 46 FF F7 E3 FF 69 46 28 46 00 94 FE F7 07 FD 78 B1
9:11:41 AM
9:11:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 CE 09 81 80 21 46 28 46 FF F7 A9 FF 50 B1 28 46 FE F7 1F FF 30 B1 00 21 28 46 FF F7 B2 FF 01 20 43 B0 30 BD 00 21 28 46 FF F7 AB FF 00 20 F7 E7 2D E9 FF 41 0F 46 04 46 B5 49 00 EB 84 00 01 EB 80 00 B4 4E 80 78 C4 EB C4 01 80 06 01 EB 04 15 09 D5 56 F8 25 00 39 68 00 68 81 42 03 D0 20 46 FF F7 8F FF 31 E0 39 46 20 46 FE F7 D1 FC 00 28 2E D0 69 46 20 46 FE F7 42 FB 00 28 28 D0 A6 48 00 EB 44 01
9:11:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 CF 09 81 80 30 F8 14 00 49 88 08 1A 82 B2 56 F8 25 10 38 46 B2 F7 DA FC C4 EB C4 01 9D 4A 01 EB 04 11 02 EB 81 05 40 B9 69 68 11 F8 02 0B 42 00 0D F1 02 00 B2 F7 CA FC 20 B1 15 F8 58 0F 40 F0 01 00 28 70 20 46 FE F7 C4 FE 00 28 00 D0 01 20 04 B0 BD E8 F0 81 00 B5 AD F2 AC 4D 68 46 FE F7 46 FC 00 28 02 D0 68 46 FE F7 86 FC 0D F2 AC 4D 00 BD 8A 49 49 88 09 B1 10 28 01 D3 00 20 70 47 C0 EB C0 01
9:11:42 AM
9:11:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D0 09 81 80 01 EB 00 10 82 49 01 EB 80 00 70 47 82 49 49 88 09 B1 10 28 01 D3 00 20 70 47 C0 EB C0 01 01 EB 00 10 7B 49 01 EB 80 00 20 30 70 47 10 B5 03 46 0C 46 FE F7 B4 FD 01 28 01 D0 00 20 10 BD 21 46 BD E8 10 40 18 46 FD F7 5E BA F8 B5 0F 46 DD E9 06 15 84 46 00 20 28 80 08 80 60 46 FF F7 91 F9 04 00 18 D0 60 46 FE F7 9A FD 01 28 12 D1 59 89 1E 88 63 8A 88 19 93 42 0C D8 A1 F5 7F 42 FF 3A
9:11:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D1 09 81 80 08 D0 0A 04 08 D5 00 93 33 46 3A 46 02 20 D3 F7 8D FA 40 B1 00 20 F8 BD 82 B2 39 46 60 46 FF F7 D6 F9 00 28 F7 D0 60 8A 28 80 01 20 F8 BD 2D E9 F0 43 85 B0 07 46 DD E9 0D 45 00 20 0C 9E 28 80 20 80 88 46 91 46 38 46 FF F7 5B F9 00 28 19 D0 4F F6 FF 70 AD F8 12 00 19 46 4F F0 FF 32 02 AB 38 46 FF F7 45 FA 00 28 0C D0 03 98 30 60 02 AB 4A 46 41 46 38 46 CD E9 00 45 FF F7 A6 FF 00 28
9:11:43 AM
9:11:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D2 09 81 80 00 D0 01 20 05 B0 BD E8 F0 83 30 B4 10 28 11 D2 C0 EB C0 02 02 EB 00 13 3D 4A 02 EB 83 04 34 F8 40 2F 22 EA 01 03 23 80 19 46 93 42 02 D0 30 BC FF F7 2D BA 30 BC 70 47 70 B5 05 46 00 24 29 46 20 46 FF F7 2B FA 64 1C E4 B2 10 2C F7 D3 70 BD 70 B5 05 46 00 24 29 46 20 46 FF F7 D6 FF 64 1C E4 B2 10 2C F7 D3 70 BD 10 28 01 D3 00 20 70 47 29 4A 20 3A 22 F8 10 10 01 20 70 47 10 28 01 D3
9:11:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D3 09 81 80 00 20 70 47 24 4A 20 3A 32 F8 10 00 08 80 01 20 70 47 38 B5 04 46 10 28 06 D2 1C 4A 04 EB 84 00 12 F8 20 00 02 28 01 D0 00 20 38 BD 1A 48 20 38 20 F8 14 10 68 46 BA F7 12 F9 00 23 1A 46 20 46 00 99 FF F7 31 FC 00 28 EF D0 01 20 38 BD 10 28 0C D2 C0 EB C0 01 01 EB 00 10 0D 49 01 EB 80 00 D0 E9 0C 10 81 42 01 D1 01 20 70 47 00 20 70 47 10 28 08 D2 C0 EB C0 01 01 EB 00 10 04 49 01 EB
9:11:44 AM
9:11:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D4 09 81 80 80 00 00 6B 50 B1 00 20 70 47 00 00 EC 44 07 00 84 5D 00 10 D8 4A 07 00 64 63 00 10 01 20 F3 E7 70 B5 BA F7 EB F8 3E 4C 00 25 20 79 10 28 00 D3 25 71 20 79 FF F7 A3 FC 20 79 40 1C C0 B2 20 71 10 28 00 D3 25 71 BD E8 70 40 BA F7 D7 B8 70 B5 34 48 88 B0 40 88 00 28 5F D0 68 46 BA F7 BF F8 07 A9 03 A8 BA F7 47 F8 20 B9 FF 22 0A 21 03 A8 B3 F7 87 F9 2A 4E 00 24 16 F1 08 06 C4 EB C4 00
9:11:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D5 09 81 80 00 EB 04 10 06 EB 80 05 95 F8 58 00 C0 07 09 D0 20 46 FF F7 FD FC 68 B3 95 F8 58 00 20 F0 01 00 85 F8 58 00 20 49 04 EB 84 00 01 EB 80 00 40 78 FF 28 1F D0 28 68 00 68 E0 B1 1C 49 88 42 0A D1 9D F8 11 00 B0 B9 9D F8 12 00 98 B9 9D F8 13 00 80 B9 00 99 03 E0 00 99 B1 FB F0 F1 41 43 00 98 88 42 07 D1 68 6D 88 42 04 D0 01 23 1A 46 20 46 FF F7 9A FB 64 1C E4 B2 10 2C BF D3 00 98 4F F4
9:11:45 AM
9:11:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D6 09 81 80 61 51 B0 FB F1 F4 4C 43 A0 42 06 D1 04 4D 28 68 A0 42 02 D0 FF F7 84 FF 2C 60 08 B0 70 BD 00 00 7C 5D 00 10 64 63 00 10 EC 44 07 00 80 51 01 00 00 B5 A5 B0 90 21 68 46 B2 F7 CF FB 68 46 E2 F7 E8 FE 38 B1 FF 21 68 46 E4 F7 B6 F9 10 B1 00 88 25 B0 00 BD 00 20 FB E7 00 20 70 47 01 22 82 40 05 29 0B D2 DF E8 01 F0 0A 0A 03 0A 05 00 FE 48 01 E0 FD 48 10 30 41 7A 11 43 41 72 70 47 FA 49
9:11:46 AM
9:11:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D7 09 81 80 01 23 09 1F 83 40 0A 78 1A 43 0A 70 70 47 F6 49 01 23 09 1F 83 40 8A 78 1A 43 8A 70 70 47 10 B5 A2 F5 7E 42 04 46 03 3A 11 D0 01 2A 0F D1 09 B1 01 29 0C D1 FF F7 EB FF 04 20 FF F7 E0 FF 04 21 20 46 FF F7 CB FF E8 49 01 20 10 31 08 73 10 BD 10 B5 04 46 00 29 0A D0 48 88 00 28 07 D0 02 20 FF F7 CD FF 20 46 BD E8 10 40 02 21 B6 E7 10 BD 2D E9 FC 43 89 46 00 28 43 D0 41 88 10 F8 04 4F
9:11:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D8 09 81 80 CE B2 00 21 0B 46 0A 46 E8 46 2A E0 2E 2C 20 D1 06 2B 35 D8 03 29 33 D8 00 25 2C 46 0E E0 00 BF 18 F8 04 70 A7 F1 30 0C BC F1 0A 0F 28 D2 05 EB 85 05 6D 00 30 3D 64 1C 3D 44 E4 B2 8C 42 EF D3 09 F8 03 50 52 1C 00 21 10 F8 01 4F 5B 1C D2 B2 DB B2 08 F8 01 40 49 1C 10 F8 01 4F 52 1C C9 B2 D2 B2 B2 42 D2 D3 C9 B1 06 2B 09 D8 00 22 10 46 10 E0 00 BF 18 F8 00 40 A4 F1 30 05 0A 2D 02 D3
9:11:47 AM
9:11:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 D9 09 81 80 00 20 BD E8 FC 83 02 EB 82 02 52 00 30 3A 40 1C 22 44 C0 B2 88 42 ED D3 09 F8 03 20 01 20 F0 E7 3E B5 05 46 00 20 0C 46 01 90 02 90 AD F8 00 00 69 46 14 20 BF F7 6C FD 00 2C 31 D0 62 88 00 2A 2E D0 06 2A 2C D8 21 1D 01 A8 B2 F7 69 FA FF 21 01 A8 E4 F7 F1 F8 00 28 22 D0 00 88 A0 F5 78 41 02 39 1D D1 A0 49 08 68 00 28 19 D0 BD F8 00 20 2A B1 00 68 40 88 C0 F3 81 10 00 28 10 D1 48 68
9:11:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 DA 09 81 80 00 28 0D D0 D0 F8 C8 00 00 28 09 D0 00 7A 01 28 06 D1 02 20 FF F7 33 FF 02 21 28 46 FF F7 1E FF 3E BD 70 B5 05 46 00 29 1B D0 0C 78 06 2C 18 D2 DF E8 04 F0 03 03 17 17 0F 13 08 79 5B 28 10 D0 FF F7 F6 FE 02 00 0C D0 21 46 28 46 BD E8 70 40 25 E7 28 46 BD E8 70 40 3A E7 28 46 BD E8 70 40 9E E7 70 BD 3E B5 05 46 0C 46 06 28 1C D2 DC B1 61 21 20 46 B2 F7 D8 FA 7C 48 05 EB C5 01 00 EB
9:11:48 AM
9:11:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 DB 09 81 80 41 00 C3 89 00 89 C0 1A 82 B2 61 2A 00 D9 61 22 02 A8 CD E9 00 20 61 22 21 46 26 20 D3 F7 5F FC 00 28 00 D0 01 20 3E BD 00 20 3E BD 6E 4A 01 21 81 40 D3 7A 0B 43 D3 72 10 32 D0 7A 08 43 D0 72 70 47 01 22 82 40 05 29 0B D2 DF E8 01 F0 0A 0A 03 0A 05 00 64 48 01 E0 63 48 10 30 C1 7A 91 43 C1 72 70 47 60 4A 01 21 81 40 93 7A 0B 43 93 72 10 32 90 7A 08 43 90 72 70 47 01 22 82 40 05 29
9:11:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 DC 09 81 80 0B D2 DF E8 01 F0 0A 0A 03 0A 05 00 56 48 01 E0 55 48 10 30 81 7A 91 43 81 72 70 47 53 4A 00 EB C0 00 10 B5 02 EB 40 00 41 F2 28 22 80 88 10 44 80 B2 02 22 D3 F7 B4 FE 00 28 00 D0 01 20 10 BD C0 EB C0 02 10 B5 01 EB 82 01 01 F5 C6 71 FF F7 E5 FF 00 28 00 D0 01 20 10 BD FE B5 0E 46 06 28 01 D3 00 20 FE BD 00 EB C0 01 40 48 02 AD 00 EB 41 04 4F F4 06 72 E3 88 20 89 31 46 C0 1A 80 B2
9:11:49 AM
9:11:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 DD 09 81 80 CD E9 00 05 26 20 D3 F7 EA FB 00 28 EA D0 21 7B 60 89 01 EB 41 01 23 89 00 EB 81 00 C0 1A 82 B2 CD E9 00 25 06 F1 96 01 26 20 D3 F7 D8 FB 00 28 D8 D0 01 20 FE BD 30 B5 AD F5 07 7D 04 46 0D 46 4F F4 06 71 68 46 B2 F7 08 FA 69 46 20 46 FF F7 C4 FF 00 28 13 D0 C4 EB C4 00 05 EB 80 00 00 F5 C4 70 00 21 01 60 9D F8 34 20 82 75 9D F8 2C 20 42 75 9D F8 00 20 02 75 01 61 4F F0 01 00 0D F5
9:11:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 DE 09 81 80 07 7D 30 BD 2D E9 F0 43 04 46 A1 B0 00 20 AD F8 70 00 06 46 89 46 02 27 1D A8 B9 F7 9F FD 64 21 68 46 B2 F7 DA F9 94 F8 73 02 69 46 FF F7 1A FF E8 46 E0 BB 51 E0 00 BF 06 EB 46 01 08 EB C1 05 68 1C 4B 46 1C AA 1D A9 D9 F7 59 FC 80 B3 68 1C 1A AA 1D A9 D9 F7 08 FC 50 B3 19 A9 1D A8 B9 F7 FD FC BD F8 70 00 03 E0 D0 68 00 10 48 4B 07 00 98 B9 94 F8 73 02 1A 9A C0 EB C0 00 04 EB 80 00
9:11:50 AM
9:11:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 DF 09 81 80 D0 F8 84 11 91 42 22 D9 D0 F8 88 01 1B 99 88 42 1D D3 08 46 19 99 88 42 19 D9 94 F8 73 12 1A 98 C1 EB C1 01 04 EB 81 01 C1 F8 84 01 01 E0 10 E0 0D E0 94 F8 73 12 1B 98 C1 EB C1 01 04 EB 81 01 C1 F8 88 01 BD F8 70 00 08 B1 01 27 05 E0 76 1C B6 B2 9D F8 00 00 B0 42 AE D8 21 B0 38 46 BD E8 F0 83 7C B5 05 46 00 20 01 90 AD F8 00 00 95 F8 73 02 02 24 C0 EB C0 00 05 EB 80 00 01 26 90 F8
9:11:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E0 09 81 80 9E 01 90 B1 01 A8 B9 F7 EA FD D8 B1 95 F8 73 02 01 99 C0 EB C0 00 05 EB 80 00 D0 F8 84 21 8A 42 07 D8 D0 F8 88 21 8A 42 03 D9 01 24 AD F8 00 60 08 E0 D0 F8 88 01 88 42 04 D2 69 46 28 46 FF F7 61 FF 04 46 BD F8 00 00 00 B9 04 24 20 46 7C BD 0E B5 02 A9 4F F4 13 62 CD E9 00 21 01 46 00 23 26 20 D3 F7 FC FA 00 28 00 D0 01 20 0E BD 0E B5 02 A9 4F F4 13 62 CD E9 00 21 01 46 00 23 26 20
9:11:51 AM
9:11:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E1 09 81 80 D3 F7 2D FB 00 28 00 D0 01 20 0E BD 00 B5 AD F6 34 1D 4F F4 13 61 68 46 B2 F7 1F F9 68 46 FF F7 E6 FF 0D F6 34 1D 00 BD 10 B5 F9 4B 00 22 00 BF 02 EB C2 04 03 EB 44 04 64 88 84 42 06 D1 02 EB C2 00 13 F8 10 00 08 70 01 20 10 BD 52 1C 06 2A EE D3 00 20 10 BD EE 49 00 EB C0 00 01 EB 40 00 00 7B 70 47 EA 49 00 EB C0 00 01 EB 40 00 00 7C 70 47 30 B5 AD F5 07 7D 05 46 0C 46 06 28 01 D3
9:11:52 AM
9:11:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E2 09 81 80 00 20 FC E6 4F F4 06 71 68 46 B2 F7 E6 F8 69 46 28 46 FF F7 A2 FE 00 28 F3 D0 9D F8 24 00 84 F8 24 00 9D F8 00 00 20 70 BD F8 02 00 60 80 BD F8 02 20 01 A9 20 1D B2 F7 33 F8 01 20 DF E6 3E B5 05 46 0C 46 06 28 1E D2 EC B1 4F F4 C1 71 20 46 B2 F7 EA F8 CE 48 05 EB C5 01 00 EB 41 00 03 89 41 89 00 7B 00 EB 40 00 01 EB 80 00 C0 1A 82 B2 02 A8 CD E9 00 20 21 46 26 20 D3 F7 70 FA 00 28
9:11:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E3 09 81 80 00 D0 01 20 3E BD 00 20 3E BD FE B5 05 46 0F 46 06 28 01 D3 00 20 FE BD BD 48 05 EB C5 01 00 EB 41 04 02 AE E3 88 20 89 4F F4 06 72 C0 1A 80 B2 CD E9 00 06 39 46 26 20 D3 F7 91 FA 00 28 EA D0 21 7B 60 89 01 EB 41 01 23 89 00 EB 81 00 C0 1A 80 B2 CD E9 00 06 4F F4 C1 72 07 F1 96 01 26 20 D3 F7 7D FA 00 28 D6 D0 28 46 FF F7 FB FD 01 20 FE BD 10 B5 01 46 0C 22 41 F2 28 20 D3 F7 D0 FC
9:11:53 AM
9:11:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E4 09 81 80 00 28 00 D0 01 20 10 BD 10 B5 01 46 0C 22 41 F2 28 20 D3 F7 FA FA 00 28 00 D0 01 20 10 BD 0E B5 00 20 00 90 01 90 02 90 68 46 FF F7 ED FF 00 28 00 D0 01 20 0E BD 70 B5 0D 46 04 46 94 49 00 EB C4 00 01 EB 40 00 41 F2 28 21 80 88 02 22 08 44 80 B2 29 46 D3 F7 D9 FA 00 28 05 D0 05 2C 02 D1 8C 49 68 78 48 70 01 20 70 BD 8A 48 40 78 70 47 88 49 01 23 83 40 8A 78 9A 43 8A 70 70 47 85 48
9:11:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E5 09 81 80 80 78 70 47 83 49 01 23 83 40 0A 78 9A 43 0A 70 70 47 01 22 82 40 05 29 0C D2 DF E8 01 F0 0B 0B 03 0B 06 00 7B 48 00 1D 01 E0 7A 48 14 30 41 7A 91 43 41 72 70 47 10 B5 AD F5 08 7D 04 46 00 20 86 90 86 A9 20 46 FF F7 A9 FD 00 28 1B D0 4F F4 06 71 68 46 B2 F7 01 F8 69 46 20 46 FF F7 BD FD 00 28 10 D0 01 20 8D F8 19 02 86 A9 20 46 FF F7 A2 FF 00 28 07 D0 69 46 20 46 FF F7 12 FD 20 46
9:11:54 AM
9:11:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E6 09 81 80 FF F7 54 FD 01 20 0D F5 08 7D 10 BD 2D E9 F0 47 98 B0 00 25 0C 46 2F 46 0B 95 60 B3 C6 B2 00 0A 00 F0 0F 09 4F EA 10 1A 13 A8 B9 F7 97 FB 00 28 7B D0 0B A9 13 A8 B9 F7 11 FB 00 28 75 D0 10 AA 04 A9 13 A8 B9 F7 26 FC 00 28 6E D0 AA F1 02 01 01 20 0D 29 29 D8 04 F8 3C 0F 48 F2 10 01 25 71 21 81 A4 F1 3C 04 0C 95 0D 95 0E 95 0D F1 30 08 49 4A 0F 95 0E E0 81 F8 3C 50 55 E0 08 EB D7 0C
9:11:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E7 09 81 80 07 F0 07 03 9C F8 00 10 D3 5C 19 43 7F 1C 8C F8 00 10 FF B2 4F 45 F1 D3 0D F1 30 08 B8 E8 8E 00 04 F1 50 08 A8 E8 8E 00 06 E0 02 21 04 F8 3C 1F 20 71 20 82 A4 F1 3C 04 4F F0 0C 07 BA F1 10 0F 6C D2 DF E8 0A F0 6B 08 6B 6B 6B 6B 6B 93 BA E5 45 7B 7F A4 CD FB A0 8D FD F7 24 FE FF F7 16 FA 00 69 86 42 00 D9 C6 B2 81 1B A4 F8 4E 90 49 1C C4 E9 11 10 18 E0 0B A9 07 A8 B9 F7 AF FA 00 28
9:11:55 AM
9:11:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E8 09 81 80 13 D0 0B 99 A6 EB 06 10 01 EB 80 00 0B E0 0B A9 07 A8 B9 F7 A3 FA 00 28 07 D0 6F F0 E0 00 46 43 0B 98 00 EB 06 10 A0 64 01 20 18 B0 BD E8 F0 87 0B A9 07 A8 B9 F7 92 FA 00 28 F6 D0 A6 EB 06 10 00 EB 40 00 0B 99 C0 EB 00 10 01 EB C0 10 EA E7 0B 99 E1 64 B6 FB F7 F1 07 FB 11 62 0D F1 10 08 B8 E8 C8 00 8D E8 C8 00 8D F8 03 00 8D F8 07 50 9D F8 02 00 8D F8 06 50 8D F8 05 50 90 42 0E D8
9:11:55 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 E9 09 81 80 10 1A C0 F1 0C 00 49 1C 8D F8 02 00 C9 B2 09 E0 48 4B 07 00 CC 68 00 10 68 C1 01 00 DC E0 80 1A 8D F8 02 00 BD F8 00 00 40 1A CA E0 0B A9 07 A8 B9 F7 54 FA 00 28 B8 D0 0B 98 B4 E7 0B 98 E0 64 80 1B B0 E7 04 AB 07 CB 8D E8 07 00 8D F8 07 50 BD F8 40 20 07 A9 68 46 B9 F7 21 FB 00 28 A4 D0 0B A9 07 A8 B9 F7 3A FA 00 28 9E D0 0B 98 04 AB E0 64 07 CB 8D E8 07 00 8D F8 07 50 BD F8 40 20
9:11:56 AM
9:11:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 EA 09 81 80 07 A9 68 46 B9 F7 0B FB 00 28 8E D0 73 E7 04 AB 07 CB 8D E8 07 00 8D F8 07 50 8D F8 06 50 BD F8 40 20 07 A9 68 46 B9 F7 FA FA 00 28 85 D0 0B A9 07 A8 B9 F7 13 FA 00 28 BD D0 0B 98 04 AB E0 64 07 CB 8D E8 07 00 8D F8 07 50 8D F8 06 50 BD F8 40 20 07 A9 68 46 B9 F7 E2 FA 00 28 AB D0 56 E7 04 AB 07 CB 8D E8 07 00 8D F8 07 50 8D F8 06 50 8D F8 05 50 BD F8 40 20 07 A9 68 46 B9 F7 CF FA
9:11:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 EB 09 81 80 00 28 98 D0 0B A9 07 A8 B9 F7 E8 F9 00 28 92 D0 0B 98 04 AB E0 64 07 CB 8D E8 07 00 8D F8 07 50 8D F8 06 50 8D F8 05 50 BD F8 40 20 07 A9 68 46 B9 F7 B5 FA 00 28 92 D0 3A E7 FF E7 0D F1 10 08 B8 E8 0E 00 8D E8 0E 00 8D F8 07 50 8D F8 06 50 8D F8 05 50 80 46 8D F8 03 00 BD F8 40 20 07 A9 68 46 B9 F7 9C FA 00 28 8F D0 0B A9 07 A8 B9 F7 B5 F9 00 28 89 D0 0B 98 E0 64 B6 FB F7 F0 07 FB
9:11:57 AM
9:11:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 EC 09 81 80 10 61 0D F1 10 09 B9 E8 4C 00 8D E8 4C 00 8D F8 03 80 8D F8 07 50 9D F8 02 20 8D F8 06 50 8D F8 05 50 8A 42 07 D8 89 1A C1 F1 0C 01 40 1C 8D F8 02 10 C0 B2 02 E0 51 1A 8D F8 02 10 BD F8 00 10 08 1A AD F8 00 00 BD F8 40 20 07 A9 68 46 B9 F7 66 FA 00 28 95 D0 29 E7 00 20 E6 E6 2D E9 FE 4F 8A 46 93 46 00 28 71 D0 41 88 10 F8 04 4F CE B2 00 21 CA F8 00 10 0A 46 0B 46 0D F1 04 09 E8 46
9:11:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 ED 09 81 80 00 91 2C E0 2E 2C 02 D0 3A 2C 31 D0 1F E0 03 29 73 D8 03 2A 71 D8 00 27 3C 46 0D E0 19 F8 04 50 A5 F1 30 0C BC F1 0A 0F 67 D2 07 EB 87 07 7F 00 30 3F 64 1C 2F 44 E4 B2 94 42 EF D3 08 F8 01 70 5B 1C 00 22 10 F8 01 4F 49 1C DB B2 C9 B2 09 F8 02 40 52 1C 10 F8 01 4F 5B 1C D2 B2 DB B2 B3 42 D0 D3 92 B3 03 29 48 D8 00 23 18 46 4C 46 4E E0 03 29 42 D8 03 2A 40 D8 00 27 3D 46 4C 46 0E E0
9:11:58 AM
9:11:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 EE 09 81 80 14 F8 05 C0 E1 46 AC F1 30 0C BC F1 0A 0F 34 D2 07 EB 87 07 7F 00 30 3F 6D 1C 4F 44 ED B2 95 42 EE D3 08 F8 01 70 00 22 49 1C C9 B2 06 E0 04 2A 23 D8 10 F8 01 5F A5 54 52 1C D2 B2 5B 1C DB B2 B3 42 F4 D3 00 23 18 46 0D E0 26 E0 16 E0 25 5C A5 F1 30 06 0A 2E 10 D2 03 EB 83 03 5B 00 30 3B 40 1C 2B 44 C0 B2 90 42 F1 D3 AB F8 00 30 14 E0 25 5C A5 F1 30 06 0A 2E 02 D3 00 20 BD E8 FE 8F
9:11:59 AM
9:11:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 EF 09 81 80 03 EB 83 03 5B 00 30 3B 40 1C 2B 44 C0 B2 90 42 EE D3 08 F8 01 30 49 1C C9 B2 08 46 08 E0 0A 1A 18 F8 02 30 0A EB 00 02 40 1E 02 F8 01 3C C0 B2 00 28 F4 D1 01 20 E1 E7 2D E9 F7 4F 00 21 92 46 8A B0 0A 46 00 28 25 D0 43 88 04 1D 00 25 DF B2 06 79 0D F1 20 08 AB 46 E9 46 3D E0 01 2A 0D D0 3A 2E 26 D0 7A B3 35 E0 04 29 12 D8 14 F8 01 0F 50 54 49 1C 6D 1C C9 B2 ED B2 00 E0 42 46 BD 42
9:11:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F0 09 81 80 F2 D3 00 23 18 46 0F E0 14 5C A4 F1 30 05 0A 2D 03 D3 00 20 0D B0 BD E8 F0 8F 03 EB 83 03 5B 00 30 3B 40 1C 23 44 C0 B2 88 42 ED D3 AA F8 00 30 14 E0 7A B9 09 F8 01 B0 69 46 0B 98 B1 F7 96 FD 00 21 01 22 06 E0 FF E7 09 F8 01 60 49 1C 14 F8 01 6F C9 B2 6D 1C ED B2 BD 42 BF D3 01 20 D9 E7 10 B5 0B 00 10 D0 19 79 5B 29 0F D0 00 21 A0 F8 4A 12 00 F5 1C 72 00 F5 13 71 18 46 FF F7 9C FF
9:12:00 AM
9:12:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F1 09 81 80 00 28 00 D0 01 20 10 BD 00 20 10 BD 01 21 A0 F8 4A 12 F7 E7 F0 B5 90 F8 73 72 04 46 C7 EB C7 00 04 EB 80 00 00 F5 C8 75 D0 F8 98 01 AD F5 07 7D 00 26 A0 BB 4F F4 06 71 68 46 B1 F7 0E FD 69 46 38 46 FF F7 CA FA A0 B3 94 F8 73 02 01 21 C0 EB C0 00 04 EB 80 00 90 F8 8C 21 22 B1 0C 9A BA B1 C0 F8 98 21 16 E0 0A 9A 92 B1 BA F7 3C FF 0A 99 4F F4 7A 72 51 43 B0 FB F1 F2 01 FB 12 00 94 F8
9:12:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F2 09 81 80 73 12 C1 EB C1 01 04 EB 81 01 C1 F8 98 01 01 E0 C0 F8 98 11 28 88 10 B1 28 46 B9 F7 7F F9 94 F8 73 02 C0 EB C0 00 04 EB 80 00 90 F8 8C 11 29 B1 25 E0 FF E7 02 20 0D F5 07 7D F0 BD D0 F8 98 01 01 28 3F D9 28 88 40 B9 20 46 FF F7 4A FB 06 46 01 28 0F D1 28 46 B9 F7 65 F9 28 46 B9 F7 6A F9 94 F8 73 12 C1 EB C1 01 04 EB 81 01 D1 F8 98 21 82 42 01 D9 00 20 DE E7 91 F8 8C 01 10 B3 94 F8
9:12:01 AM
9:12:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F3 09 81 80 73 02 C0 EB C0 00 04 EB 80 00 D0 F8 98 01 01 28 18 D9 28 88 10 B9 28 46 B9 F7 44 F9 28 46 B9 F7 49 F9 94 F8 73 12 C1 EB C1 01 04 EB 81 01 D1 F8 98 11 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 01 D2 30 46 B8 E7 20 46 FF F7 0C FB B4 E7 70 B5 04 46 D0 F8 30 02 01 25 81 7A 94 F8 73 02 05 FA 00 F2 11 42 0A D0 21 46 FF F7 66 FA 28 B3 D4 F8 30 02 01 7A 94 F8 73 02 FF F7 00 FA D4 F8 30 02 C1 7A
9:12:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F4 09 81 80 94 F8 73 02 85 40 29 42 0A D0 21 46 FF F7 18 FA 90 B1 D4 F8 30 02 01 7A 94 F8 73 02 FF F7 D1 F9 94 F8 73 02 C0 EB C0 00 04 EB 80 00 90 F8 8D 01 01 28 03 D0 02 28 01 D0 04 20 70 BD 20 46 BD E8 70 40 27 E7 58 4B 10 B5 1C 7A 01 22 82 40 8C 42 02 D0 58 7A 10 42 07 D1 53 48 10 30 03 7A 8B 42 04 D0 40 7A 10 42 01 D0 01 20 10 BD 00 20 10 BD 2D E9 F0 41 8A B0 00 28 3B D0 05 46 00 F5 20 74
9:12:02 AM
9:12:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F5 09 81 80 90 F8 1B 65 4F F4 1F 71 20 46 B1 F7 26 FC BA F7 56 FE 45 4A 00 21 12 1F C3 B2 05 2E 15 D2 DF E8 06 F0 14 14 03 14 07 00 D1 60 3F 48 11 61 03 E0 3D 48 D1 61 10 30 11 62 06 72 D5 F8 10 75 07 60 D5 F8 14 55 45 60 C4 F8 30 02 58 07 36 4B 1B 1F 00 28 01 DA 11 80 91 70 4F F0 06 00 84 F8 73 02 84 F8 74 02 98 46 18 46 C4 F8 2C 32 04 DA FF F7 96 FB 0A B0 BD E8 F0 81 00 25 21 46 28 46 FF F7
9:12:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F6 09 81 80 DA F9 90 B3 31 46 28 46 FF F7 77 F9 C5 EB C5 00 04 EB 80 07 07 F5 C6 71 28 46 FF F7 7F F9 68 B3 31 46 28 46 FF F7 4D F9 97 F8 8D 01 01 28 01 D0 02 28 17 D1 28 21 68 46 B1 F7 CF FB 69 46 28 46 FF F7 D7 FA 70 B1 69 46 28 46 FF F7 EA F8 97 F8 8D 01 02 28 06 D1 94 F8 73 02 06 28 06 D0 01 20 87 F8 8D 01 05 2D 04 D0 0F E0 0B E0 84 F8 73 52 F8 E7 94 F8 19 12 88 F8 01 10 06 E0 28 46 FF F7
9:12:03 AM
9:12:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F7 09 81 80 15 F9 02 E0 28 46 FF F7 2D F9 6D 1C ED B2 06 2D B3 D3 94 F8 73 02 06 28 AB D0 00 28 A9 D0 6D 1E 84 F8 73 52 A5 E7 00 00 D0 68 00 10 70 B5 0C 46 00 21 62 78 0D 46 1B 3A 09 2A 24 D2 DF E8 02 F0 24 24 24 24 24 24 14 23 05 00 A0 F5 10 50 84 38 2B D0 A0 F5 1E 40 02 38 27 D0 01 28 25 D0 7A 28 23 D0 02 F0 6F FB 0B E0 A0 F5 42 40 85 38 1C D0 01 28 1A D0 02 28 18 D0 7B 28 16 D0 02 F0 5A FC
9:12:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F8 09 81 80 98 B1 25 70 11 E0 81 B1 B9 F7 EB FF 00 28 F8 D0 01 28 04 D0 02 28 04 D0 03 28 06 D1 03 E0 FF 20 02 E0 FE 20 00 E0 FD 20 20 70 01 20 70 BD 70 B5 00 22 0A 70 FF 22 4A 70 E1 B1 13 4B 00 22 00 BF 02 EB 42 04 33 F8 14 50 85 42 10 D8 03 EB 44 04 64 88 84 42 0B D3 02 EB 42 02 03 EB 42 02 13 79 0B 70 52 79 4A 70 FF F7 A1 FF 01 20 70 BD 52 1C 5E 2A E5 D3 00 20 70 BD 00 28 00 DA 00 20 02 49
9:12:04 AM
9:12:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 F9 09 81 80 0A 39 31 F8 10 00 70 47 BE 4B 07 00 2D E9 F0 47 04 46 0D 46 91 46 03 20 0B F0 01 FF 10 B1 48 46 BD E8 F0 87 CA 4A 04 EB 84 00 02 EB C0 02 C7 49 04 EB 44 00 C0 EB 44 10 01 EB 40 00 25 B1 01 2D 05 D0 02 2D 23 D1 0A E0 00 24 00 8C 09 E0 00 8C 00 24 00 27 C6 B2 01 25 DF F8 F8 82 15 E0 00 8C C4 B2 D1 8C 08 44 F4 E7 04 EB 44 01 38 F8 21 00 E3 F7 56 F9 28 B1 7F 1C FF B2 4F 45 01 D1 28 46
9:12:05 AM
9:12:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 FA 09 81 80 CE E7 6D 1C 64 1C ED B2 E4 B2 B4 42 EC D3 00 20 C6 E7 78 B1 80 29 0D D8 61 B1 49 1E C9 B2 00 EB D1 00 01 F0 07 03 02 78 01 21 99 40 0A 43 02 70 01 20 70 47 00 20 70 47 0E B5 02 A9 4F F4 49 72 CD E9 00 21 01 46 00 23 0F 20 D2 F7 88 FC 00 28 00 D0 01 20 0E BD 0E B5 02 A9 4F F4 49 72 CD E9 00 21 01 46 00 23 0F 20 D2 F7 B9 FC 00 28 00 D0 01 20 0E BD 2D E9 F0 41 97 4B 40 1C 03 EB C2 02
9:12:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 FB 09 81 80 00 25 92 88 93 4F 10 44 01 EB C1 02 02 EB 01 11 2C 46 0E 18 04 EB 44 00 37 F8 20 00 E3 F7 00 F9 48 B1 06 EB D4 00 04 F0 07 01 40 7A C8 40 C0 07 01 D0 6D 1C ED B2 64 1C E4 B2 80 2C EA D3 28 46 BD E8 F0 81 2D E9 F0 47 91 46 83 4A 40 1C 02 EB C3 02 00 25 92 88 DF F8 FC 81 10 44 01 EB C1 02 02 EB 01 11 2E 46 2C 46 11 EB 00 07 04 EB 44 01 38 F8 21 00 E3 F7 D4 F8 78 B1 07 EB D4 00 76 1C
9:12:06 AM
9:12:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 FC 09 81 80 40 7A 04 F0 07 01 C8 40 F6 B2 C0 07 05 D0 6D 1C ED B2 4D 45 01 D1 30 46 42 E7 64 1C E4 B2 80 2C E4 D3 00 20 3C E7 2D E9 F0 4F AD F5 4B 7D 4F F4 49 71 68 46 B1 F7 51 FA DF F8 90 B1 00 21 66 4B 68 46 03 EB C1 09 0C 24 B9 F8 04 20 4F F0 07 0C 02 EB 00 0E 4A 08 02 EB 42 05 00 20 C5 EB 42 12 45 E0 00 EB C0 03 03 EB 00 16 06 EB 0E 08 02 25 46 1C 88 F8 01 50 33 0A C9 96 88 F8 02 30 56 4B
9:12:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 FD 09 81 80 88 F8 03 60 33 F8 31 30 B3 F5 C0 4F 04 D0 6F F4 C0 45 5B 19 29 D1 26 E0 00 23 10 E0 4F 4E 08 EB D0 0A 00 F0 07 07 9A F8 0A 50 F6 5D 35 43 8A F8 0A 50 1B F8 12 50 5B 1C 28 44 C0 B2 DB B2 A3 42 EC D3 12 E0 45 4E 08 EB D0 0A 00 F0 07 07 9A F8 0A 50 F6 5D 35 43 8A F8 0A 50 1B F8 12 50 5B 1C 28 44 C0 B2 DB B2 63 45 EC D3 C9 98 C0 B2 1B F8 12 30 83 42 B5 D8 B9 F8 04 30 B9 F8 06 00 00 24
9:12:07 AM
9:12:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 FE 09 81 80 18 44 6B 46 49 1C C4 54 B9 F8 04 00 1B F8 12 20 C9 B2 C2 54 02 29 92 D3 68 46 FF F7 1C FF 0D F5 4B 7D BD E8 F0 8F 03 B5 2B 48 83 B0 00 EB C1 00 81 88 C0 88 08 44 83 B2 01 20 02 A9 CD E9 00 01 02 46 03 A9 0F 20 D2 F7 CA FB 00 28 00 D0 01 20 05 B0 00 BD 0E B5 20 4A 02 EB C1 01 8A 88 C9 88 11 44 8B B2 02 AA 01 21 CD E9 00 12 0A 46 01 46 0F 20 D2 F7 74 FB 00 28 00 D0 01 20 0E BD 70 B5
9:12:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 05 FF 09 81 80 AD F5 4A 7D 04 46 0E 46 15 46 68 46 FF F7 D4 FE 00 28 08 D0 10 48 69 46 00 EB C5 00 80 88 41 5C A1 42 03 D8 00 20 0D F5 4A 7D 70 BD 0D F1 01 01 08 44 04 EB C4 01 01 EB 04 11 01 44 09 31 10 22 30 46 B1 F7 ED F8 01 20 ED E7 00 00 20 5D 07 00 5A 5D 07 00 B0 4E 07 00 F2 4D 07 00 68 C1 01 00 0E B5 02 A9 4F F4 C8 72 CD E9 00 21 01 46 00 23 20 20 D2 F7 34 FB 0E BD 0E B5 02 A9 4F F4 C8 72
9:12:08 AM
9:12:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 00 09 81 80 CD E9 00 21 01 46 00 23 20 20 D2 F7 68 FB 0E BD 10 B5 FD 48 4F F4 C8 71 04 46 B1 F7 5E F9 20 46 FF F7 EA FF 00 28 00 D0 01 20 10 BD 70 B5 05 46 08 F0 A1 FF F4 4C 08 3C 21 68 81 42 00 D1 3D B1 20 60 F1 48 FF F7 CC FF 01 20 A4 F8 86 03 70 BD 00 20 70 BD 30 B5 F9 B0 04 46 0D 46 05 28 02 D3 00 20 79 B0 30 BD 80 22 53 A9 76 A8 B8 F7 14 FF E5 48 04 EB 84 01 08 38 00 EB 01 10 01 89 AD F8
9:12:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 01 09 81 80 CC 11 D0 F8 0A 10 CD F8 CE 11 C1 89 AD F8 D2 11 00 7C 8D F8 D4 01 73 A9 68 46 E3 F7 32 F8 00 28 DF D0 76 AA 29 46 68 46 E3 F7 95 FE 00 28 D8 D0 01 20 D6 E7 70 B5 0E 46 FA B0 05 46 09 21 E2 F7 FB FE 04 00 32 D0 80 22 56 A9 77 A8 B8 F7 E4 FE 00 20 76 90 20 7A AD F8 4C 01 D4 F8 02 00 CD F8 4E 01 E0 88 AD F8 52 01 01 20 8D F8 54 01 53 A9 68 46 E3 F7 06 F8 00 28 16 D0 06 20 8D F8 B8 00
9:12:09 AM
9:12:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 02 09 81 80 E8 88 AD F8 BC 00 AD F8 84 60 77 AA 76 A9 68 46 DE F7 92 FC 00 28 07 D0 BD F8 48 01 C0 07 02 D0 01 20 F5 F7 DA FB 01 20 7A B0 70 BD 00 20 FB E7 05 28 01 D3 00 20 70 47 B4 4A 02 EB 00 10 D0 F8 0A 20 0A 60 D0 F8 0E 00 48 60 01 20 70 47 AE 48 10 B5 4F F4 62 71 08 38 B1 F7 BF F8 01 20 FF F7 65 FF A9 49 4F F4 C8 72 01 F5 C8 70 B1 F7 83 F8 64 22 A6 49 4F F4 7E 70 D2 F7 12 FD 00 28 05 D1
9:12:10 AM
9:12:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 03 09 81 80 BD E8 10 40 64 21 A1 48 B1 F7 A7 B8 10 BD 2D E9 F0 47 88 46 00 25 9C 49 06 46 08 39 08 EB 88 00 2C 46 01 EB 00 17 1E E0 07 EB 04 10 00 F5 E1 71 32 30 8A 46 81 46 10 22 B0 F7 C6 FF 88 B1 10 22 49 46 50 46 B0 F7 EC FF 90 49 01 25 01 EB 08 10 8F 49 00 EB C4 00 0A 68 C0 F8 0A 20 49 68 C0 F8 0E 10 64 1C E4 B2 B4 42 DE D3 00 2D 07 D0 BD E8 F0 47 64 22 85 49 4F F4 7E 70 D2 F7 06 BB BD E8
9:12:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 04 09 81 80 F0 87 2D E9 F0 4F 06 46 80 48 8D B0 00 EB 46 09 00 EB 06 10 05 90 7E 48 00 24 DF F8 EC 81 06 EB 46 0A 08 30 00 EB 8A 00 A8 F1 08 08 8B 46 0B 90 08 EB 06 10 06 EB 86 01 15 46 08 EB 01 17 03 90 EF E0 00 BF 07 EB C4 00 0C 90 D0 E9 08 10 4B 1B 70 F1 00 02 09 D3 69 40 01 43 63 D1 03 98 00 EB C4 00 B0 F8 28 03 00 28 7A D0 19 F8 04 00 00 28 76 D1 05 98 07 EB 04 11 00 EB C4 00 07 90 06 91
9:12:11 AM
9:12:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 05 09 81 80 0A 30 3A 31 08 22 09 90 B0 F7 5E FF 30 B1 08 22 5F 49 09 98 B0 F7 58 FF 00 28 33 D1 0B 98 40 88 88 B3 03 98 00 EB C4 00 B0 F8 28 23 00 F5 4A 70 52 B3 01 90 B8 F7 BE FC 4F F4 7A 71 B0 FB F1 F1 D8 F8 78 03 81 42 1D D3 51 4A 06 98 08 32 32 30 32 F8 2A 10 FF F7 EE FE 01 20 09 F8 04 00 DD E9 06 10 D1 F8 32 20 C0 F8 0A 20 D1 F8 36 10 C0 F8 0E 10 64 22 45 49 4F F4 7E 70 D2 F7 86 FA 01 98
9:12:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 06 09 81 80 B8 F7 8C FC 8B E0 10 E0 FF E7 B8 F7 8B FC 26 B1 01 2E 04 D0 02 2E 23 D1 05 E0 9B 20 00 E0 9D 20 0C F0 29 F9 1C E0 9F 20 FA E7 39 4A 06 98 08 32 32 30 32 F8 2A 10 FF F7 BD FE 01 20 09 F8 04 00 DD E9 06 10 D1 F8 32 20 C0 F8 0A 20 D1 F8 36 10 C0 F8 0E 10 64 22 2D 49 4F F4 7E 70 D2 F7 55 FA 0C 98 D0 E9 08 12 00 20 69 1A 90 41 57 D2 0B 98 40 88 28 B1 03 98 00 EB C4 00 B0 F8 28 03 A0 BB
9:12:12 AM
9:12:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 07 09 81 80 19 F8 04 00 F0 B3 05 98 07 EB 04 11 00 EB C4 00 08 90 06 91 0A 30 32 31 08 22 09 90 B0 F7 D4 FE 28 B1 08 22 1A 49 09 98 B0 F7 CE FE 50 BB 18 49 06 98 08 31 3A 30 31 F8 2A 10 FF F7 7B FE 00 21 09 F8 04 10 06 98 08 99 D0 F8 3A 20 C1 F8 0A 20 D0 F8 3E 00 C1 F8 0E 00 64 22 0C 49 4F F4 7E 70 D2 F7 13 FA 0B 98 40 88 60 B1 03 98 00 EB C4 00 00 F5 4A 70 B8 F7 12 FC 66 B1 01 2E 0C D0 02 2E
9:12:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 08 09 81 80 0D D1 14 E0 0B E0 00 00 F8 68 00 10 78 6C 00 10 04 4E 07 00 9C 20 00 E0 9E 20 0C F0 AC F8 64 1C E4 B2 5C 45 FF F4 0E AF 0D B0 BD E8 F0 8F A0 20 F3 E7 02 46 09 68 12 68 00 20 32 EA 01 03 01 D0 01 20 70 47 91 43 FC D0 02 20 70 47 2D E9 F7 4F 06 46 0F 46 00 24 49 4A 06 EB 86 01 25 46 20 46 02 EB 01 18 06 EB 46 09 DF F8 14 A1 34 E0 00 28 34 D1 03 2E 02 D0 04 2E 08 D1 03 E0 41 4C 04 F1
9:12:13 AM
9:12:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 09 09 81 80 68 05 03 E0 3F 4C 24 1D 04 F1 68 05 1C B3 15 B3 04 22 21 46 02 A8 B0 F7 57 FE E0 B1 21 46 02 A8 FF F7 C7 FF 01 28 02 D0 02 28 09 D1 02 E0 08 F1 32 00 01 E0 08 F1 3A 00 3A F8 29 10 FF F7 FA FD 02 98 20 60 02 98 2F 49 28 60 64 22 0C 31 4F F4 7E 70 D2 F7 9A F9 01 20 B8 42 C8 D3 BD E8 FE 8F 2D E9 FF 41 68 46 B8 F7 7A FB 24 4F 00 99 97 F8 84 03 C9 B2 88 42 3E D0 00 20 A7 F8 86 03 FF F7
9:12:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 0A 09 81 80 95 FD 00 24 01 A9 20 46 FF F7 A4 FD 60 B3 9D F8 04 00 06 28 0C D0 11 28 04 D0 12 28 05 D0 15 28 22 D1 05 E0 9D F8 08 50 03 E0 BD F8 08 50 00 E0 02 9D 04 EB 84 00 07 EB 00 10 06 7E 90 F8 30 00 86 42 00 D3 06 46 B7 F8 86 03 18 B1 21 46 30 46 FF F7 1D FE 0A 49 04 EB 44 00 01 EB 80 00 2A 46 83 68 31 46 20 46 98 47 64 1C E4 B2 05 2C C9 D3 00 98 87 F8 84 03 BD E8 FF 81 00 00 F0 68 00 10
9:12:14 AM
9:12:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 0B 09 81 80 0C 4E 07 00 6C 6C 00 10 F0 B5 DF F8 0C C4 00 22 02 EB 42 03 3C F8 23 30 83 42 23 D1 FF 4F 13 46 00 24 00 BF 04 EB 44 05 C5 EB 44 15 07 EB 45 06 35 8C 36 89 2E 44 B6 B2 B2 42 19 D3 5B 1B F7 4D 04 EB 84 06 3A 35 05 EB C6 06 9B B2 F5 8C F6 89 2E 44 B6 B2 B2 42 0B D3 5B 1B 64 1C 24 04 9B B2 24 0C DF D0 52 1C 92 B2 C0 2A D1 D3 00 20 F0 BD 01 EB D3 00 03 F0 07 01 00 78 C8 40 C0 07 F6 D0
9:12:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 0C 09 81 80 01 20 F0 BD 2D E9 F0 4F AD F5 7D 7D 4F F4 7C 72 69 46 03 20 D2 F7 FD F9 00 99 0A 98 08 44 0A 90 01 99 0B 98 08 44 0B 90 02 99 0C 98 08 44 0C 90 03 99 0D 98 08 44 0D 90 14 99 20 98 08 44 20 90 15 99 21 98 08 44 21 90 16 99 22 98 08 44 22 90 17 99 23 98 08 44 23 90 18 99 24 98 08 44 24 90 19 99 25 98 08 44 25 90 2C 99 34 98 08 44 34 90 2D 99 35 98 08 44 35 90 04 99 0E 98 08 44 0E 90
9:12:15 AM
9:12:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 0D 09 81 80 05 99 0F 98 08 44 0F 90 06 99 10 98 08 44 10 90 07 99 11 98 08 44 11 90 08 99 12 98 08 44 12 90 09 99 13 98 08 44 13 90 1A 99 26 98 08 44 26 90 1B 99 27 98 DF F8 E4 E2 08 44 27 90 1C 99 28 98 00 22 08 44 28 90 1D 99 29 98 0E F1 3A 0E 08 44 29 90 1E 99 2A 98 08 44 2A 90 1F 99 2B 98 08 44 2B 90 2E 99 36 98 08 44 36 90 2F 99 37 98 08 44 37 90 30 99 38 98 08 44 38 90 31 99 39 98 08 44
9:12:16 AM
9:12:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 0E 09 81 80 39 90 32 99 3A 98 08 44 3A 90 33 99 3B 98 08 44 CD F8 EC 00 02 EB 82 0A 0E EB CA 03 68 46 5C 88 5D 89 04 EB 00 08 9C 88 05 EB 00 09 04 EB 00 0B DC 88 04 EB 00 0C 1C 89 9B 89 04 44 1D 18 00 20 46 E0 00 BF 0B EB 00 11 08 EB 00 13 0E 68 1F 68 3E 44 0E 60 4E 68 5F 68 3E 44 4E 60 8E 68 9F 68 3E 44 8E 60 CE 68 DB 68 33 44 CB 60 00 EB 40 03 54 F8 33 10 5C F8 33 60 31 44 44 F8 33 10 04 EB
9:12:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 0F 09 81 80 C3 01 0C EB C3 03 4E 68 5F 68 3E 44 4E 60 8E 68 9F 68 3E 44 8E 60 CE 68 DF 68 3E 44 CE 60 0E 69 1F 69 3E 44 0E 61 4E 69 5B 69 33 44 4B 61 55 F8 30 30 59 F8 30 10 05 EB C0 06 19 44 45 F8 30 10 09 EB C0 01 73 68 49 68 40 1C 19 44 C0 B2 71 60 1E F8 3A 10 81 42 B5 D8 52 1C 12 F0 FF 02 99 D0 4F F4 7C 72 69 46 03 20 D2 F7 44 F9 0D F5 7D 7D BD E8 F0 8F 2D E9 F0 4F AD F5 7D 7D 4F F4 7C 72
9:12:17 AM
9:12:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 10 09 81 80 69 46 03 20 D2 F7 05 F9 4F F0 00 0B 5C 46 CD F8 00 B0 CD F8 04 B0 CD F8 08 B0 18 21 04 A8 CD F8 0C B0 B0 F7 5A FD 18 21 14 A8 B0 F7 56 FD 18 21 1A A8 B0 F7 52 FD 2C 94 18 21 2E A8 2D 94 B0 F7 4C FD DF F8 58 A1 00 25 0A F1 3A 0A 05 EB 85 06 0A EB C6 02 69 46 53 88 5F 18 D3 88 52 89 03 EB 01 08 02 EB 01 09 00 24 19 E0 00 BF 07 EB 04 11 C1 F8 00 B0 C1 F8 04 B0 C1 F8 08 B0 C1 F8 0C B0
9:12:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 11 09 81 80 04 EB 44 01 08 EB C1 00 18 21 B0 F7 26 FD 09 EB C4 01 64 1C C1 F8 00 B0 E4 B2 C1 F8 04 B0 1A F8 36 00 A0 42 E2 D8 6D 1C 15 F0 FF 05 CE D0 4F F4 7C 72 69 46 03 20 D2 F7 DD F8 97 E7 2D E9 F7 4F 9E B0 37 4C 1E 98 0D 46 00 F0 40 01 11 43 04 F6 44 49 04 F5 44 6A 04 F6 3C 4B 04 F6 38 48 7C D0 05 A8 B8 F7 1A FF A8 BB 0D F1 14 0E 10 AA 5E F8 20 10 42 F8 20 10 04 EB 80 02 D2 F8 9C 3B 1B B1
9:12:18 AM
9:12:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 12 09 81 80 D2 F8 70 3B 99 42 03 D9 C2 F8 9C 5B C2 F8 70 1B D2 F8 34 3B 1B B1 D2 F8 08 3B 99 42 03 D2 C2 F8 34 5B C2 F8 08 1B 04 EB C0 03 03 F6 D8 3C D3 F8 D8 7B D3 F8 DC 2B 79 18 42 F1 00 02 CC E9 00 12 B3 F8 DE 2B 40 F6 DE 31 52 1C 40 1C C0 B2 CA 52 03 28 CB D3 05 A8 B8 F7 7B FF E0 BB 0D F1 14 0E 13 AA 5E F8 20 10 42 F8 20 10 04 EB 80 02 D2 F8 A8 3B 1B B1 D2 F8 7C 3B 99 42 03 D9 C2 F8 A8 5B
9:12:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 13 09 81 80 C2 F8 7C 1B D2 F8 40 3B 1B B1 D2 F8 14 3B 99 42 0A D2 C2 F8 40 5B 05 E0 B0 4E 07 00 20 5D 07 00 E8 6C 00 10 C2 F8 14 1B 04 EB C0 03 03 F5 3F 6C D3 F8 F0 7B D3 F8 F4 2B 79 18 42 F1 00 02 CC E9 00 12 B3 F8 F6 2B 40 F6 F6 31 52 1C 40 1C C0 B2 CA 52 03 28 C4 D3 0A A8 00 E0 B7 E0 0A F0 26 FD F0 BB 0C A8 0A F0 10 FE D0 BB 0F A8 B8 F7 E5 FD B0 BB 9D F8 3C 10 11 F0 2A 0F 0D D0 FE 48 BD F8
9:12:19 AM
9:12:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 14 09 81 80 28 20 D0 F8 38 0C 02 44 FB 48 C8 F8 00 20 D0 F8 3C 0C 40 1C CB F8 00 00 11 F0 15 0F 0D D0 F6 48 D0 F8 40 2C BD F8 30 00 02 44 F3 48 CA F8 00 20 D0 F8 44 0C 40 1C C9 F8 00 00 DF F8 C0 E3 00 20 0D F1 28 0A 0D F1 30 0B 0D F1 58 09 0D F1 60 08 0A EB 40 02 53 88 29 F8 10 30 0B EB 40 02 00 E0 2B E0 56 88 28 F8 10 60 1E F8 00 20 0A 42 0D D0 04 EB C0 02 40 F6 08 47 D2 F8 08 CC 63 44 BB 50
9:12:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 15 09 81 80 02 F6 0C 43 D2 F8 0C 2C 52 1C 1A 60 DB 4A D2 1C 12 5C 0A 42 0D D0 04 EB C0 03 4F F4 42 62 D3 F8 20 7C 3E 44 D6 50 03 F6 24 42 D3 F8 24 3C 5B 1C 13 60 40 1C C0 B2 03 28 CA D3 0E A8 B8 F7 FC FF 9D F8 38 00 40 07 4B D0 08 A8 B8 F7 5D FF E8 BB BD F8 20 00 60 B1 9D F8 38 20 D1 07 08 D0 BD F8 22 10 61 B1 93 07 0A D5 81 42 08 D8 08 46 06 E0 BD F8 22 00 60 B1 9D F8 38 20 91 07 08 D5 BD F8
9:12:20 AM
9:12:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 16 09 81 80 24 10 69 B1 52 07 0B D5 81 42 09 D8 08 46 07 E0 BD F8 24 00 18 B1 9D F8 38 10 49 07 00 D4 00 20 B5 49 D1 F8 D4 1B 21 B1 B3 49 B1 F8 98 1B 81 42 04 D2 B1 49 A1 F8 98 0B C1 F8 D4 5B AE 49 D1 F8 6C 1B 31 B1 AC 49 B1 F8 30 1B 00 E0 08 E0 81 42 06 D9 28 B1 A8 49 A1 F8 30 0B 08 46 C0 F8 6C 5B 1E 98 C0 07 7E D0 00 26 B2 46 DF F8 8C 82 08 EB C6 07 B7 F8 DE 4B 2C B3 07 F6 D8 30 22 46 03 C8
9:12:21 AM
9:12:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 17 09 81 80 81 46 89 B2 8B 46 00 23 C7 F7 D4 FF D7 F8 78 2C 40 F6 78 41 10 44 C8 51 08 1D D7 F8 7C 1C 22 46 49 1C C1 51 00 23 48 46 59 46 C7 F7 C3 FF D7 F8 A8 2C 40 F6 A8 41 10 44 C8 51 08 1D D7 F8 AC 1C 49 1C C1 51 00 20 07 F6 D8 32 01 46 03 C2 A7 F8 DE AB C1 46 B7 F8 F6 4B D0 46 2C B3 07 F5 3F 60 22 46 03 C8 83 46 89 B2 00 23 00 91 C7 F7 A2 FF D7 F8 90 2C 4F F4 49 61 10 44 C8 51 08 1D D7 F8
9:12:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 18 09 81 80 94 1C 22 46 49 1C C1 51 00 23 58 46 00 99 C7 F7 91 FF D7 F8 C0 2C 4F F4 4C 61 10 44 C8 51 08 1D D7 F8 C4 1C 49 1C C1 51 00 21 07 F5 3F 67 06 F1 01 06 C7 E9 00 11 F6 B2 48 46 44 46 A7 F8 06 80 03 2E 92 D3 6C 49 D1 F8 3C 1C E9 B3 6A 4A D2 F8 38 2C B2 FB F1 F1 68 4A 89 B2 A2 F8 4E 1C C2 F8 5C 5C 00 E0 67 E1 D2 F8 CC 2B 22 B1 62 4A B2 F8 94 2B 8A 42 04 D2 60 4A A2 F8 94 1B C2 F8 CC 5B
9:12:22 AM
9:12:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 19 09 81 80 5D 4A D2 F8 64 2B 22 B1 5B 4A B2 F8 2C 2B 8A 42 04 D9 59 4A A2 F8 2C 1B C2 F8 64 5B 56 4B 03 F6 08 52 D3 F8 08 3D 0B 44 13 60 53 4B 03 F6 0C 52 D3 F8 0C 3D 5B 1C 13 60 4F 4B 03 F6 48 52 D3 F8 48 3D 0B 44 13 60 00 E0 15 E0 4B 4B 03 F6 4C 52 D3 F8 4C 3D 5B 1C 13 60 47 4B 03 F6 88 52 D3 F8 88 3D 19 44 11 60 44 4A 02 F6 8C 51 D2 F8 8C 2D 52 1C 0A 60 04 E0 40 4A A2 F8 4E AC C2 F8 5C AC
9:12:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 1A 09 81 80 3D 49 D1 F8 44 1C E1 B3 3B 4A D2 F8 40 2C B2 FB F1 F1 39 4A 89 B2 A2 F8 66 1C C2 F8 74 5C D2 F8 D0 2B 22 B1 34 4A B2 F8 96 2B 8A 42 04 D2 32 4A A2 F8 96 1B C2 F8 D0 5B 2F 4A D2 F8 68 2B 22 B1 2D 4A B2 F8 2E 2B 8A 42 04 D9 2B 4A A2 F8 2E 1B C2 F8 68 5B 28 4B 03 F5 51 62 D3 F8 10 3D 0B 44 13 60 25 4B 03 F6 14 52 D3 F8 14 3D 5B 1C 13 60 21 4B 03 F5 55 62 D3 F8 50 3D 0B 44 13 60 1E 4B
9:12:23 AM
9:12:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 1B 09 81 80 00 E0 14 E0 03 F6 54 52 D3 F8 54 3D 5B 1C 13 60 19 4B 03 F5 59 62 D3 F8 90 3D 19 44 11 60 16 4A 02 F6 94 51 D2 F8 94 2D 52 1C 0A 60 04 E0 12 4A A2 F8 66 AC C2 F8 74 AC 5F F0 00 02 00 EB C2 01 D1 F8 0C 3C F3 B3 D1 F8 08 6C 00 EB 42 07 B6 FB F3 F3 9B B2 00 EB 82 06 A7 F8 48 3C C6 F8 50 5C D6 F8 B4 CB BC F1 00 0F 03 D0 B7 F8 88 CB 9C 45 08 D2 A7 F8 88 3B 03 E0 E8 6C 00 10 48 4E 07 00
9:12:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 1C 09 81 80 C6 F8 B4 5B D6 F8 4C CB BC F1 00 0F 03 D0 B7 F8 20 CB 9C 45 03 D9 A7 F8 20 3B C6 F8 4C 5B D1 F8 D8 7C 40 F6 D8 46 1F 44 77 50 D1 F8 DC 7C 36 1D 7F 1C 77 50 D1 F8 18 7D 40 F6 18 56 1F 44 77 50 36 1D 00 E0 0F E0 D1 F8 1C 7D 7F 1C 77 50 D1 F8 58 7D 40 F6 58 56 3B 44 73 50 33 1D D1 F8 5C 6D 76 1C 5E 50 07 E0 00 EB 42 03 A3 F8 48 4C 00 EB 82 03 C3 F8 50 4C D1 F8 24 3C EB B3 D1 F8 20 6C
9:12:24 AM
9:12:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 1D 09 81 80 00 EB 42 07 B6 FB F3 F3 9B B2 00 EB 82 06 A7 F8 60 3C C6 F8 68 5C D6 F8 C0 CB BC F1 00 0F 03 D0 B7 F8 8E CB 9C 45 03 D2 A7 F8 8E 3B C6 F8 C0 5B D6 F8 58 CB BC F1 00 0F 03 D0 B7 F8 26 CB 9C 45 03 D9 A7 F8 26 3B C6 F8 58 5B D1 F8 F0 7C 4F F4 4F 66 1F 44 77 50 D1 F8 F4 7C 36 1D 7F 1C 77 50 D1 F8 30 7D 4F F4 53 66 1F 44 77 50 D1 F8 34 7D 36 1D 7F 1C 77 50 00 E0 0C E0 D1 F8 70 7D 4F F4
9:12:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 1E 09 81 80 57 66 3B 44 73 50 01 F6 74 53 D1 F8 74 1D 49 1C 19 60 07 E0 00 EB 42 01 A1 F8 60 4C 00 EB 82 01 C1 F8 68 4C 52 1C D2 B2 03 2A FF F4 47 AF 70 21 FE 48 B0 F7 D2 F9 21 B0 5A E4 2D E9 F0 41 FE B0 04 46 FF F7 5F FB FA 4E 06 20 74 60 B5 F7 28 FC 28 B1 01 23 1A 46 21 46 07 20 FD F7 65 F9 FF F7 49 FC 4F F4 FC 75 29 46 68 46 B0 F7 B6 F9 2A 46 69 46 04 20 D1 F7 7E FD 4F F4 C0 71 ED 48 B0 F7
9:12:25 AM
9:12:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 1F 09 81 80 AC F9 4F F4 40 71 EC 48 B0 F7 A7 F9 E7 48 68 21 D0 38 B0 F7 A2 F9 E5 48 68 21 68 38 B0 F7 9D F9 40 21 E6 48 B0 F7 99 F9 01 22 21 46 00 20 FF F7 85 FC 00 24 DE 4B 01 21 32 78 20 46 9C 3B 0A 42 03 D0 1D 18 95 F8 6C 50 2C 43 49 06 40 1C 09 0E C0 B2 04 28 F3 D3 01 27 00 25 98 46 3C 42 04 D0 08 EB C5 00 78 30 B7 F7 1D FE 78 06 6D 1C 07 0E ED B2 04 2D F2 D3 00 22 40 F6 98 51 D0 48 B7 F7
9:12:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 20 09 81 80 21 FF CF 49 C0 43 A1 F8 98 0D 70 88 40 1C 70 80 00 20 30 70 F0 60 04 20 0B F0 AD FA 10 20 FD F7 8B FC 10 22 C2 49 41 F2 D4 10 D1 F7 EE FB 7E B0 01 20 BD E8 F0 81 BE 49 00 20 9C 39 01 EB C0 02 B2 F8 78 20 0A B1 01 20 70 47 40 1C C0 B2 04 28 F4 D3 00 20 70 47 B6 48 00 21 44 38 10 22 41 64 81 64 C1 64 01 65 B2 49 41 F2 D4 10 D1 F7 CD BB 70 B5 AF 4C 06 46 9C 3C 01 28 06 D0 02 2E 0E D0
9:12:26 AM
9:12:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 21 09 81 80 04 2E 0E D0 08 2E 24 D1 15 E0 94 F8 69 00 00 25 C0 07 1E D0 94 F8 6A 00 C0 07 1A D0 14 E0 01 25 12 E0 02 25 B9 F7 4B FB C0 04 0D D4 A0 48 2C 38 B7 F7 B8 FD 08 E0 B4 F8 70 00 03 25 20 B1 9C 48 0C 38 B7 F7 AF FD 04 E0 04 EB C5 00 B0 F8 78 00 08 B1 00 20 70 BD 94 F8 6A 00 30 42 0C D0 94 48 01 78 31 43 01 70 08 30 B7 F7 79 FD 10 22 90 49 41 F2 D4 10 D1 F7 89 FB 01 20 70 BD 8C 49 9C 39
9:12:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 22 09 81 80 91 F8 68 10 C1 F3 C0 01 01 70 89 48 00 78 00 07 00 D0 01 20 70 47 10 B5 04 46 F4 F7 9A FB 20 46 FF F7 0B FF 00 28 02 D0 F3 F7 DD FF 01 20 10 BD 02 22 02 70 04 22 42 70 11 22 82 70 C2 70 02 71 42 71 06 20 08 60 01 20 70 47 00 20 08 70 01 20 48 70 02 20 88 70 03 20 C8 70 04 20 10 60 01 20 70 47 01 20 70 47 72 48 10 B5 9C 38 90 F8 3A 00 02 28 01 D3 00 20 10 BD 72 49 31 F8 10 40 03 F0
9:12:27 AM
9:12:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 23 09 81 80 B6 FA 00 28 F7 D0 4F F4 5A 62 6D 49 20 46 D1 F7 71 FC 20 46 D1 F7 C6 FB 00 28 EC D0 64 49 04 22 0C 31 4F F4 8F 50 D1 F7 30 FB 01 20 10 BD 60 48 10 B5 9C 38 90 F8 3A 10 02 29 02 D3 00 21 80 F8 3A 10 C8 B2 5F 49 4F F4 5A 62 31 F8 10 00 5C 49 D1 F7 1F FC 00 28 04 D0 03 F0 89 FA 00 28 00 D0 01 20 10 BD 0E B5 02 AA 16 21 CD E9 00 12 0A 46 01 46 00 23 21 20 D1 F7 32 FA 00 28 00 D0 01 20
9:12:28 AM
9:12:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 24 09 81 80 0E BD 2D E9 F0 43 87 B0 04 46 0D 46 68 46 FF F7 E9 FF FC B1 01 2C 1A D1 04 98 24 26 25 27 06 90 00 24 0D F1 18 09 6D 1C 19 F8 04 00 A8 42 0A D1 04 F0 01 01 C4 F3 40 08 30 46 F3 F7 D1 FF 41 46 38 46 F3 F7 CD FF 64 1C A4 B2 04 2C EC D3 07 B0 BD E8 F0 83 03 98 22 26 23 27 06 90 E0 E7 F0 B5 AD F2 44 7D 04 46 0E 46 15 46 11 46 68 46 05 F0 5D FE 00 28 34 D0 28 46 05 F0 C2 FB 01 46 04 B1
9:12:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 25 09 81 80 64 1E BD F8 00 00 8B 88 A2 B2 98 42 00 D3 18 46 82 42 2C D2 02 EB 42 00 C0 EB 42 12 68 46 00 EB 42 07 C8 88 7C 88 84 42 00 D3 04 46 00 25 1C E0 C5 EB C5 00 07 EB 40 00 C0 88 20 F0 78 00 E1 F7 6F FE 80 B1 C2 78 00 21 0A B1 52 1E D1 B2 80 79 00 B1 40 1E 00 EB 41 00 C0 B2 86 42 03 D1 01 20 0D F2 44 7D F0 BD 6D 1C AD B2 A5 42 E0 D3 00 20 F6 E7 2D E9 F0 41 13 4D 62 35 08 B1 05 F5 90 65
9:12:29 AM
9:12:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 26 09 81 80 0B 49 00 22 9C 39 0E 18 01 EB 00 10 0E 4F B2 74 14 46 00 F1 16 08 00 BF 04 EB 44 00 41 46 35 F8 20 00 FF F7 31 F9 A0 B1 B0 7C 0F E0 C0 78 00 10 24 7B 00 10 E8 6F 00 10 68 74 00 10 C0 79 00 10 E8 6C 00 10 4E 4E 07 00 68 C1 01 00 39 5D 08 43 B0 74 64 1C E4 B2 08 2C DE D3 6A E6 70 B5 04 46 00 25 01 46 28 46 FE F7 DE FD 00 28 0D D0 FE 48 22 46 01 19 0D 75 00 EB 04 11 16 31 28 46 FE F7
9:12:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 27 09 81 80 FE FD 20 46 FF F7 B5 FF 01 20 70 BD 3E B5 04 00 0D 46 1E D0 A8 B2 E1 F7 03 FE 00 28 18 D0 01 7A AD F8 00 10 D0 F8 02 10 CD F8 02 10 C0 88 AD F8 06 00 01 20 8D F8 08 00 69 46 20 46 E1 F7 A1 FE 00 28 05 D0 06 20 04 F8 B8 0F 28 0C A0 80 01 20 3E BD 00 20 3E BD E4 4B 58 B1 01 28 0B D0 00 20 59 B1 50 B1 B1 FB F0 F3 00 FB 13 13 3A B1 C8 1A 70 47 18 68 F4 E7 98 68 F2 E7 00 20 70 47 C0 1A
9:12:30 AM
9:12:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 28 09 81 80 08 44 70 47 3E B5 00 24 0C 28 0F D8 02 D1 4F F0 01 02 01 E0 4F F0 04 02 02 AB CD E9 00 23 03 46 4F F0 05 00 D1 F7 1B F9 00 B1 01 24 20 46 3E BD 10 B5 00 20 07 F0 B2 FC 01 20 10 BD 00 B5 89 B0 20 22 69 46 B0 20 D1 F7 AB FB 01 20 8D F8 1E 00 20 22 69 46 B0 20 D1 F7 D8 F9 01 20 09 B0 00 BD 38 B5 04 46 68 46 07 F0 AF FC 40 B1 14 B1 9D F8 00 00 20 80 9D F8 00 00 08 B1 01 20 38 BD 00 20
9:12:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 29 09 81 80 38 BD 30 B5 89 B0 0D 46 04 46 02 29 02 D3 00 20 09 B0 30 BD 20 22 69 46 B0 20 D1 F7 81 FB 00 28 F6 D0 68 46 00 EB 85 00 21 0C C4 82 01 83 20 22 69 46 B0 20 D1 F7 A9 F9 EA E7 00 B5 89 B0 20 22 69 46 B0 20 D1 F7 6C FB 00 28 C7 D0 9D F8 1E 00 01 28 C3 D0 00 20 C1 E7 00 B5 89 B0 20 22 69 46 B0 20 D1 F7 5D FB 38 B1 00 20 8D F8 1E 00 20 22 69 46 B0 20 D1 F7 89 F9 01 20 AF E7 30 B5 89 B0
9:12:31 AM
9:12:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 2A 09 81 80 0D 46 04 46 02 29 10 D2 20 22 69 46 B0 20 D1 F7 47 FB 60 B1 68 46 00 EB 85 00 A2 B2 C1 8A 91 42 05 D1 00 8B 21 0C 88 42 01 D1 00 20 B0 E7 01 20 AE E7 2D E9 F0 4F 05 46 8C 48 8B 49 01 27 4C 19 02 88 94 F8 44 00 EF B0 4F F0 00 09 32 B1 C1 07 7E D1 40 F0 01 00 84 F8 44 00 8B E0 20 F0 01 00 84 F8 44 00 8B 46 60 A8 FF F7 3C FE 6A 08 01 2D 0E D0 9D F8 80 01 56 AB 03 EB 05 08 7A 4B 00 21
9:12:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 2B 09 81 80 03 EB 85 06 38 B1 01 28 7A D0 04 28 6B D1 77 E0 9D F8 94 01 EF E7 74 48 BD F8 82 21 00 EB 45 0A 52 B1 BB F8 60 20 1A B9 BA F8 40 20 00 2A 5A D0 01 2D 01 D1 AB F8 60 10 60 A9 28 46 03 F0 A9 F8 07 46 FF 28 50 D0 B7 F7 19 FB 01 46 DB F8 98 00 08 1A B0 F5 FA 7F 06 D2 20 22 56 A9 B0 20 D1 F7 DF FA 98 F8 13 70 49 F2 01 0A 52 46 29 46 38 46 FF F7 35 FE 00 28 DA D0 B6 F8 50 10 51 45 03 D1
9:12:32 AM
9:12:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 2C 09 81 80 B6 F8 52 00 B8 42 D2 D0 4F F4 A6 71 68 46 AF F7 64 FE 50 46 E1 F7 C4 FC 00 28 24 D0 01 7A AD F8 A0 11 D0 F8 02 10 CD F8 A2 11 C0 88 AD F8 A6 01 01 20 8D F8 A8 01 68 A9 68 46 E1 F7 62 FD 00 28 11 D0 06 20 8D F8 B8 00 AD F8 BC 70 68 46 00 E0 13 E0 05 F0 5A FD 00 28 05 D0 A6 F8 50 A0 A6 F8 52 70 4F F0 01 09 A5 E0 20 7D 18 B9 BA F8 40 00 01 28 02 D1 28 46 FF F7 71 FE 6F B0 BD E8 F0 8F
9:12:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 2D 09 81 80 BD F8 82 01 38 B1 BB F8 60 30 00 2B 70 D0 01 2D 01 D1 AB F8 60 10 55 A9 10 46 0B F0 DC F9 00 28 94 F8 44 00 7A D0 20 F0 04 00 84 F8 44 00 BD F8 54 11 D1 B1 A1 F5 7F 42 FF 3A 16 D0 BD F8 56 21 FF 2A 12 D0 20 F0 02 00 84 F8 44 00 B6 F8 50 00 88 42 03 D1 B6 F8 52 00 90 42 6B D0 29 46 55 98 FF F7 0C FF 70 B1 5D B1 0C E0 80 07 62 D4 29 46 00 20 FE F7 18 FC 94 F8 44 00 40 F0 02 00 57 E0
9:12:33 AM
9:12:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 2E 09 81 80 FF F7 EA FE 4F F4 A6 71 68 46 AF F7 E6 FD 68 46 55 99 FF F7 3B FE 58 B3 FF F7 CF FE 38 B9 68 46 05 F0 F3 FC 20 B3 29 46 55 98 FF F7 AA FE BD F8 54 01 A6 F8 50 00 BD F8 56 01 A6 F8 52 00 9D F8 80 01 4F F0 01 09 04 28 1F D1 F5 B9 5F A8 FF F7 87 FE D0 B1 BD F8 54 01 60 F3 0F 06 BD F8 7C 01 31 46 60 F3 1F 41 04 E0 88 7A 00 10 D0 80 00 10 12 E0 68 46 FF F7 0A FE 38 B1 68 46 05 F0 C5 FC
9:12:34 AM
9:12:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 2F 09 81 80 18 B1 FF F7 5B FE FF F7 53 FE BD F8 48 01 C0 07 10 D0 01 20 F4 F7 A1 F8 0C E0 FF E7 40 07 09 D4 29 46 00 20 FE F7 BF FB 94 F8 44 00 40 F0 04 00 84 F8 44 00 29 46 67 A8 FE F7 CC FB 20 7D 9D F8 9C 11 5E 46 88 42 02 D1 B9 F1 00 0F 15 D0 20 22 56 A9 B0 20 D1 F7 E4 F9 BD F8 82 01 D0 B1 30 7C 40 F0 04 00 30 74 21 7D 88 F8 11 10 88 F8 13 70 20 22 56 A9 B0 20 D1 F7 08 F8 9D F8 9C 01 06 EB
9:12:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 30 09 81 80 05 11 20 75 16 31 2A 46 FE F7 B9 FB 28 46 FF F7 70 FD 32 E7 70 7C 40 F0 04 00 70 74 E8 07 E2 D0 6B A9 0C 20 FF F7 EE FD 00 28 DC D0 9D F8 AC 01 40 07 D8 D5 98 F8 11 00 9D F8 9C 11 88 42 D2 D0 00 22 10 46 56 99 FF F7 C6 FD 70 60 70 7C 40 F0 01 00 70 74 01 20 A6 F8 5E 00 C4 E7 10 B5 FF 4B 00 22 00 BF 33 F8 22 40 84 42 05 D1 03 EB 82 00 80 78 08 70 01 20 10 BD 52 1C D2 B2 06 2A F1 D3
9:12:35 AM
9:12:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 31 09 81 80 00 20 08 70 10 BD 18 B5 04 46 08 46 69 46 FF F7 E5 FF 00 28 02 D0 9D F8 00 00 60 43 18 BD 2D E9 F3 4F AD F2 24 6D 05 46 DD F8 28 06 01 26 07 28 3E D2 DF E8 00 F0 3D 3D 3D 04 FE 04 FD 00 02 F0 16 FF 78 B9 E6 4C 94 F8 3B 00 58 B9 FF F7 6F FC 4F F0 00 01 30 B3 23 20 0A F0 C5 FF 00 21 16 20 0A F0 C1 FF 00 22 29 46 01 20 FE F7 E7 FF 4F F4 7C 72 7E A9 03 20 D1 F7 8C F8 4F F4 FC 72 69 46
9:12:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 32 09 81 80 04 20 D1 F7 86 F8 DF F8 54 83 4F F0 00 09 08 F1 22 08 D4 48 7E 99 D0 F8 80 0A 88 42 0B D8 00 99 49 B1 0A E0 16 20 0A F0 9E FF 02 20 84 F8 3B 00 0D F2 2C 6D A2 E6 00 95 7E 90 CB 48 09 EB 89 06 00 EB C6 04 7E A8 61 88 20 22 01 EB 00 0B C3 48 3C 38 00 EB C9 00 CD F8 1C 06 41 88 68 46 01 EB 00 0A 01 21 01 EB 49 00 C7 B2 0D F5 BF 61 B0 20 D1 F7 16 F9 0D F5 BF 60 38 44 3A 46 40 7C 0D F5
9:12:36 AM
9:12:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 33 09 81 80 BD 61 FE F7 FC FA E7 89 1E E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 F6 FD 90 B1 E0 89 B0 49 38 1A C0 B2 0B EB 00 12 D1 F8 80 1A 13 68 99 42 03 D8 0A EB 00 13 1B 68 1B B9 0A EB 00 10 11 60 05 60 7F 1C BF B2 A7 48 E1 89 10 F8 36 00 08 44 B8 42 DA D8 A3 48 7F 99 D0 F8 84 0A 88 42 01 D8 01 99 09 B9 01 95 7F 90 27 8A 1E E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 C4 FD
9:12:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 34 09 81 80 90 B1 20 8A 97 49 38 1A C0 B2 0B EB 00 12 D1 F8 84 1A 53 68 99 42 03 D8 0A EB 00 13 5B 68 1B B9 0A EB 00 10 51 60 45 60 7F 1C BF B2 8E 48 21 8A 10 F8 36 00 08 44 B8 42 DA D8 8A 48 80 99 D0 F8 88 0A 88 42 01 D8 02 99 09 B9 02 95 80 90 67 8A 1E E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 92 FD 90 B1 60 8A 7E 49 38 1A C0 B2 0B EB 00 12 D1 F8 88 1A 93 68 99 42 03 D8 0A EB 00 13
9:12:37 AM
9:12:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 35 09 81 80 9B 68 1B B9 0A EB 00 10 91 60 85 60 7F 1C BF B2 75 48 61 8A 10 F8 36 00 08 44 B8 42 DA D8 71 48 81 99 D0 F8 8C 0A 88 42 01 DC 03 99 21 B9 01 E0 E6 E2 DA E2 03 95 81 90 A7 8A 1D E0 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 5E FD 90 B1 A0 8A 64 49 38 1A C0 B2 0B EB 00 12 D1 F8 8C 1A D3 68 99 42 03 DC 0A EB 00 13 DB 68 1B B9 0A EB 00 10 D1 60 C5 60 7F 1C BF B2 5B 48 A1 8A 10 F8 36 00
9:12:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 36 09 81 80 08 44 B8 42 DA D8 57 48 92 99 D0 F8 90 0A 88 42 01 D8 0A 99 09 B9 0A 95 92 90 E2 88 7E A8 02 EB 00 0B DD F8 1C 06 E7 8A 82 88 68 46 02 EB 00 0A 1E E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 22 FD 90 B1 E0 8A 46 49 38 1A C0 B2 00 EB 40 00 D1 F8 90 1A 5B F8 30 20 91 42 02 D8 5A F8 30 20 1A B9 4B F8 30 10 4A F8 30 50 7F 1C BF B2 3D 48 E1 8A 10 F8 36 00 08 44 B8 42 DA D8 39 48
9:12:38 AM
9:12:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 37 09 81 80 93 99 D0 F8 94 0A 88 42 01 D8 0B 99 09 B9 0B 95 93 90 27 8B 20 E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 F0 FC A0 B1 20 8B 2D 49 38 1A C0 B2 00 EB 40 00 0B EB C0 02 D1 F8 94 1A 53 68 99 42 03 D8 0A EB C0 03 5B 68 1B B9 0A EB C0 00 51 60 45 60 7F 1C BF B2 23 48 21 8B 10 F8 36 00 08 44 B8 42 D8 D8 1F 48 94 99 D0 F8 98 0A 88 42 01 D8 0C 99 09 B9 0C 95 94 90 1A 48 95 99 D0 F8
9:12:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 38 09 81 80 9C 0A 88 42 01 D8 0D 99 09 B9 0D 95 95 90 15 48 96 99 D0 F8 A0 0A 88 42 01 D8 0E 99 09 B9 0E 95 96 90 10 48 97 99 D0 F8 A4 0A 88 42 01 D8 0F 99 09 B9 0F 95 97 90 67 8B 29 E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 9E FC E8 B1 60 8B 04 49 38 1A C0 B2 D1 F8 98 1A 07 E0 8E 4E 07 00 88 7A 00 10 E8 6C 00 10 5A 5D 07 00 00 EB 40 00 0B EB C0 02 93 68 99 42 03 D8 0A EB C0 03 9B 68
9:12:39 AM
9:12:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 39 09 81 80 1B B9 0A EB C0 00 91 60 85 60 7F 1C BF B2 F9 48 61 8B 10 F8 36 00 08 44 B8 42 CF D8 A7 8B 1F E0 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 6C FC A0 B1 A0 8B F0 49 38 1A C0 B2 00 EB 40 00 D1 F8 9C 2A 0B EB C0 01 CB 68 9A 42 03 D8 0A EB C0 03 DB 68 1B B9 0A EB C0 00 CA 60 C5 60 7F 1C BF B2 E4 48 A1 8B 10 F8 36 00 08 44 B8 42 D8 D8 E7 8B 20 E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61
9:12:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 3A 09 81 80 FE F7 42 FC A0 B1 E0 8B DB 49 38 1A C0 B2 00 EB 40 00 D1 F8 A0 2A 0B EB C0 01 0B 69 9A 42 03 D8 0A EB C0 03 1B 69 1B B9 0A EB C0 00 0A 61 05 61 7F 1C BF B2 CF 48 E1 8B 10 F8 36 00 08 44 B8 42 D8 D8 27 8C 20 E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 18 FC A0 B1 20 8C C6 49 38 1A C0 B2 00 EB 40 00 0B EB C0 02 D1 F8 A4 1A 53 69 99 42 03 D8 0A EB C0 03 5B 69 1B B9 0A EB C0 00
9:12:40 AM
9:12:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 3B 09 81 80 51 61 45 61 7F 1C BF B2 BA 48 21 8C 10 F8 36 00 08 44 B8 42 D8 D8 B8 48 AA 99 D0 F8 A8 0A 88 42 01 D8 16 99 09 B9 16 95 AA 90 62 89 7E A9 02 EB 01 0A DD F8 1C 16 67 8C CA 88 69 46 02 EB 01 0B 1C E0 00 BF 07 EB 47 01 38 F8 21 00 0D F5 BD 61 FE F7 DA FB 80 B1 60 8C A7 49 38 1A C0 B2 D1 F8 A8 1A 5A F8 30 20 91 42 02 D8 5B F8 30 20 1A B9 4A F8 30 10 4B F8 30 50 7F 1C BF B2 9D 48 61 8C
9:12:41 AM
9:12:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 3C 09 81 80 10 F8 36 00 08 44 B8 42 DC D8 9B 48 AB 99 D0 F8 AC 0A 88 42 01 D8 17 99 09 B9 17 95 AB 90 A7 8C 1E E0 00 BF 07 EB 47 00 0D F5 BD 61 38 F8 20 00 FE F7 AA FB 90 B1 A0 8C 8F 49 38 1A C0 B2 0A EB C0 02 D1 F8 AC 1A 53 68 99 42 03 D8 0B EB C0 03 5B 68 1B B9 0B EB C0 00 51 60 45 60 7F 1C BF B2 84 48 A1 8C 10 F8 36 00 08 44 B8 42 DA D8 82 48 82 99 D0 F8 B0 0A 88 42 01 D8 04 99 09 B9 04 95
9:12:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 3D 09 81 80 82 90 7D 48 83 99 D0 F8 B4 0A 88 42 01 D8 05 99 09 B9 05 95 83 90 78 48 84 99 D0 F8 C8 0A 88 42 01 D8 06 99 09 B9 06 95 84 90 73 48 85 99 D0 F8 CC 0A 88 42 01 D8 07 99 09 B9 07 95 85 90 6E 48 86 99 D0 F8 E0 0A 88 42 01 D8 08 99 09 B9 08 95 86 90 69 48 87 99 D0 F8 E4 0A 88 42 01 D8 09 99 09 B9 09 95 87 90 64 48 98 99 D0 F8 B8 0A 88 42 01 D8 10 99 09 B9 10 95 98 90 5F 48 99 99 D0 F8
9:12:42 AM
9:12:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 3E 09 81 80 BC 0A 88 42 01 D8 11 99 09 B9 11 95 99 90 5A 48 9A 99 D0 F8 D0 0A 88 42 01 D8 12 99 09 B9 12 95 9A 90 55 48 9B 99 D0 F8 D4 0A 88 42 01 D8 13 99 09 B9 13 95 9B 90 50 48 9C 99 D0 F8 E8 0A 88 42 01 D8 14 99 09 B9 14 95 9C 90 4B 48 9D 99 D0 F8 EC 0A 88 42 01 D8 15 99 09 B9 15 95 9D 90 46 48 AC 99 D0 F8 C0 0A 88 42 01 D8 18 99 09 B9 18 95 AC 90 41 48 AD 99 D0 F8 C4 0A 88 42 01 D8 19 99
9:12:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 3F 09 81 80 09 B9 19 95 AD 90 3C 48 AE 99 D0 F8 D8 0A 88 42 01 D8 1A 99 09 B9 1A 95 AE 90 37 48 AF 99 D0 F8 DC 0A 88 42 01 D8 1B 99 09 B9 1B 95 AF 90 32 48 B0 99 D0 F8 F0 0A 88 42 01 D8 1C 99 09 B9 1C 95 B0 90 2D 48 B1 99 D0 F8 F4 0A 88 42 01 D8 1D 99 09 B9 1D 95 B1 90 09 F1 01 00 10 F0 FF 09 3F F4 98 AC 4F F4 7C 72 7E A9 03 20 D0 F7 43 FD 4F F4 FC 72 69 46 04 20 D0 F7 3D FD 0D F5 C3 60 B6 F7
9:12:43 AM
9:12:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 40 09 81 80 EE FD 01 23 00 21 28 46 DD F8 28 26 E6 F7 78 FA 12 F0 58 F8 00 20 B5 F7 78 FA 01 20 B5 F7 75 FA 02 20 B5 F7 72 FA 03 20 B5 F7 6F FA 20 22 0D F5 BF 61 B0 20 D0 F7 B4 FD 01 22 00 20 DD F8 18 16 FF F7 C9 F9 0D 4C CD F8 F8 05 20 22 60 7D 8D F8 0A 06 0D F5 BF 61 B0 20 D0 F7 D7 FB 21 46 00 20 FF F7 D0 F9 01 20 A4 F8 60 00 04 49 00 20 AC 31 08 70 5D E4 5A 5D 07 00 E8 6C 00 10 88 7A 00 10
9:12:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 41 09 81 80 0D F5 C3 60 B6 F7 AB FD 12 F0 1C F8 FE 48 00 21 A0 F8 60 60 AC 30 01 70 4A E4 2D E9 F0 41 8A B0 80 46 0C 46 08 A8 B6 F7 9A FD F7 4E 00 25 AC 36 40 F6 98 57 03 2C 06 D0 04 2C 29 D0 05 2C 02 D0 06 2C 25 D1 1A E0 01 23 22 46 19 46 40 46 E6 F7 17 FA 20 22 69 46 B0 20 D0 F7 62 FD 01 22 10 46 08 99 FF F7 78 F9 01 90 20 22 69 46 B0 20 D0 F7 8C FB E5 49 04 20 08 31 FF F7 84 F9 00 22 39 46
9:12:44 AM
9:12:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 42 09 81 80 E2 48 B6 F7 9F FE E1 49 C0 43 A1 F8 98 0D 75 70 0A B0 BD E8 F0 81 0E B5 02 AA 04 21 CD E9 00 12 0A 46 01 46 20 23 05 20 D0 F7 99 FA 00 28 00 D0 01 20 0E BD 0E B5 02 AA 01 21 CD E9 00 12 0A 46 01 46 24 23 05 20 D0 F7 8A FA 00 28 00 D0 01 20 0E BD 0E B5 02 AA 0C 21 CD E9 00 12 0A 46 01 46 10 23 05 20 D0 F7 7B FA 00 28 00 D0 01 20 0E BD 10 B5 01 21 12 20 F3 F7 90 FB 00 28 00 D0 01 20
9:12:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 43 09 81 80 10 BD 38 B5 68 46 B6 F7 2A FD 01 22 00 20 00 99 FF F7 21 F9 04 46 00 22 10 46 00 99 FF F7 1B F9 00 9A 11 1B 82 1A 91 42 00 D2 20 46 38 BD 08 B5 69 46 05 20 F3 F7 62 FE 01 28 01 D0 00 20 08 BD 9D F8 00 00 41 07 0D D5 00 F0 80 01 05 20 F3 F7 64 FE AD 48 90 F8 5C 10 89 07 03 D5 41 7C 41 F0 80 01 41 74 01 20 08 BD 10 B5 8A B0 08 A8 B6 F7 F6 FC A6 4A 08 98 08 3A C1 B2 13 78 99 42 46 D0
9:12:45 AM
9:12:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 44 09 81 80 11 70 0A 22 B0 FB F2 F3 9F 4C 02 FB 13 00 21 7C 41 F0 40 01 21 74 10 B9 41 F0 80 00 20 74 20 22 69 46 B0 20 D0 F7 BC FC 08 99 00 98 88 42 14 D0 01 22 00 20 FF F7 CF F8 00 99 81 42 0D D0 4F F0 00 02 10 46 FF F7 C7 F8 60 60 20 7C 40 F0 01 00 20 74 60 7C 40 F0 01 00 60 74 08 99 01 98 88 42 15 D0 01 22 10 46 FF F7 B6 F8 01 99 81 42 0E D0 4F F0 00 02 4F F0 01 00 FF F7 AD F8 E0 60 20 7C
9:12:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 45 09 81 80 40 F0 20 00 20 74 60 7C 40 F0 20 00 60 74 0A B0 00 20 10 BD 1C B5 04 00 13 D0 A0 88 01 22 08 44 81 B2 A1 80 68 46 AE F7 2A FF DD E9 00 01 22 68 10 44 20 60 A1 80 76 49 88 42 02 D9 C9 43 08 44 20 60 1C BD 70 48 90 F8 4E 10 89 07 04 D5 B0 F8 4C 00 08 B1 01 20 70 47 00 20 70 47 1F B5 04 20 03 A9 CD E9 00 01 02 46 1C 23 02 A9 05 20 D0 F7 B6 F9 00 28 13 D0 6F F0 02 02 FF F7 E3 FF 00 B1
9:12:46 AM
9:12:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 46 09 81 80 00 22 50 42 40 B2 05 28 00 D3 00 20 61 49 31 F8 10 00 02 99 48 43 02 90 0C F0 E4 FE 01 20 04 B0 10 BD 10 B5 4F F4 C0 71 5B 48 AE F7 D6 FF 30 21 5A 48 AE F7 D2 FF 54 48 40 21 88 38 AE F7 CD FF 00 22 40 F6 98 51 51 48 B6 F7 7C FD 4F 49 C0 43 A1 F8 98 0D 01 20 10 BD 10 B5 4F F4 C0 71 50 48 AE F7 BB FF 4D 48 30 21 30 30 AE F7 B6 FF 46 48 40 21 48 38 AE F7 B1 FF 00 22 40 F6 98 51 43 48
9:12:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 47 09 81 80 B6 F7 60 FD 41 49 C0 43 A1 F8 98 0D 01 20 10 BD 33 B5 00 24 85 B0 05 46 0C 28 05 D2 02 A9 06 98 FF F7 5C FA 90 B1 04 E0 10 D8 02 D1 4F F0 01 02 01 E0 4F F0 04 02 03 A8 CD E9 00 20 2B 46 06 A9 4F F0 05 00 D0 F7 8B F9 00 B1 01 24 07 B0 20 46 30 BD 02 46 00 20 03 2A 0B D2 2B 4B 22 B1 01 2A 04 D0 02 2A 05 D1 02 E0 18 68 00 E0 98 68 08 60 01 20 70 47 3E B5 28 20 02 AD CD E9 00 05 25 49
9:12:47 AM
9:12:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 48 09 81 80 02 46 01 24 00 23 4A 39 05 20 D0 F7 68 F9 00 B9 00 24 0A 20 CD E9 00 05 1E 49 02 46 00 23 22 39 15 20 D0 F7 5C F9 00 B9 00 24 20 46 3E BD 3E B5 0A 20 02 A9 CD E9 00 01 16 49 02 46 01 24 00 23 22 39 15 20 D0 F7 4B F9 00 B9 00 24 20 46 3E BD 00 B5 87 B0 0A 20 05 A9 CD E9 00 01 02 46 00 23 02 A9 15 20 D0 F7 FB F8 00 28 0C D0 06 48 02 99 28 38 C0 F8 6E 10 03 99 C0 F8 72 10 BD F8 10 10
9:12:48 AM
9:12:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 49 09 81 80 A0 F8 76 10 01 20 0D E0 88 7A 00 10 E8 6C 00 10 FF C9 9A 3B A6 4E 07 00 68 71 00 10 60 79 00 10 E8 72 00 10 07 B0 00 BD FE 48 90 F8 4E 00 00 F0 01 00 70 47 FB 48 90 F8 4E 10 89 07 04 D5 B0 F8 48 00 08 B1 01 20 70 47 00 20 70 47 F5 49 B1 F8 46 20 92 B1 B1 F8 48 20 7A B1 B1 F8 4A 20 62 B1 B1 F8 4C 10 49 B1 EF 49 28 39 D1 F8 6E 20 02 60 D1 F8 72 10 41 60 01 20 70 47 00 20 70 47 E9 4A
9:12:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 4A 09 81 80 01 0C 00 B2 82 F8 3A 10 08 B1 FE F7 50 BE FE F7 2A BE 70 B5 04 46 06 F0 2E FD E3 4E 05 46 70 68 A8 42 00 D1 B4 B3 FF F7 93 FF 00 28 31 D0 00 20 DC 4C 01 46 04 EB 80 02 40 1C 22 F8 50 1F C0 B2 51 80 02 28 F6 D3 FF F7 C9 FE 00 28 21 D0 D5 48 58 30 FF F7 E0 FD 00 28 1B D0 D2 48 5C 30 FF F7 E9 FD 00 28 15 D0 CF 48 64 30 FF F7 F2 FD 00 28 0F D0 CE 48 61 6E 81 42 00 D9 01 46 61 66 09 B1
9:12:49 AM
9:12:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 4B 09 81 80 49 1E 61 66 08 46 4F F4 7A 71 48 43 60 66 01 20 75 60 70 BD FF E7 00 20 FB E7 2D E9 F0 41 C1 4E 00 24 40 F6 98 58 96 F8 3A 70 00 BF 86 F8 3A 40 FE F7 FD FD BC 48 00 22 41 46 08 30 B6 F7 42 FC C0 43 85 B2 B8 48 08 30 B0 F8 98 0D A8 42 17 D0 B5 48 C0 21 00 22 08 30 B6 F7 34 FC B2 49 C0 43 08 31 80 B2 B1 F8 98 1D 81 42 0B D1 AE 48 08 30 A0 F8 98 5D B8 F7 A3 F8 40 05 01 D4 FE F7 B3 FD
9:12:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 4C 09 81 80 01 25 00 E0 00 25 64 1C E4 B2 02 2C CE D3 86 F8 3A 70 FE F7 CC FD 28 46 7B E5 00 B5 89 B0 20 22 69 46 B0 20 D0 F7 BC FA 00 28 0C D0 00 20 8D F8 1E 00 CD F8 16 00 CD F8 1A 00 20 22 69 46 B0 20 D0 F7 E3 F8 01 20 09 B0 00 BD 10 B5 96 48 AD F5 BD 6D 4F F4 5A 61 08 30 AE F7 3F FE 92 48 00 22 40 F6 98 51 08 30 B6 F7 ED FB 8F 49 C0 43 08 31 4F F4 7C 74 A1 F8 98 0D 21 46 68 46 AE F7 2D FE
9:12:50 AM
9:12:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 4D 09 81 80 22 46 69 46 03 20 D0 F7 F5 F9 64 10 21 46 FC A8 AE F7 23 FE 22 46 FC A9 04 20 D0 F7 EB F9 0D F5 BD 6D 10 BD 2D E9 F0 4F 8D B0 82 46 8B 46 0B A8 B6 F7 95 FA 7B 4D 00 26 24 35 05 F8 14 6C 05 F8 13 6C AE 75 EE 75 6E 76 6E 83 6E 87 AE 87 B6 F7 95 FA 68 67 74 48 A5 F1 24 05 72 49 46 60 30 46 FE F7 90 FE 6F 49 04 20 08 31 FE F7 8B FE B8 F7 26 F8 40 05 02 D4 01 20 FF F7 0B FF B8 F7 1F F8
9:12:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 4E 09 81 80 DF F8 A0 91 40 05 09 F1 9C 09 41 F2 D4 18 02 AF 32 D4 AF F2 15 20 B4 F7 3A FF B8 F7 10 F8 40 07 2A D5 FF F7 92 FF 89 F8 00 60 A9 F8 02 60 00 24 01 22 00 20 0B 99 FE F7 4E FE 47 F8 24 00 64 1C E4 B2 03 2C F4 D3 80 20 8D F8 18 00 05 96 00 20 39 18 40 1C 4E 74 C0 B2 CE 74 02 28 F8 D3 20 22 02 A9 B0 20 D0 F7 51 F8 FF F7 57 FF 4D 49 10 22 9C 31 40 46 D0 F7 49 F8 4A 49 10 22 9C 31 40 46
9:12:51 AM
9:12:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 4F 09 81 80 D0 F7 0E FA 01 F0 B3 FF 70 B9 B4 F7 04 FF FF F7 04 FF B7 F7 D4 FF 40 05 06 D4 01 F0 A8 FF 18 B9 01 21 16 20 0A F0 5F F8 59 46 50 46 E6 F7 A6 F8 20 22 02 A9 B0 20 D0 F7 F3 F9 9D F8 18 00 00 24 BA 46 85 F8 3C 00 B0 46 5F F0 01 07 05 EB 44 00 2E 19 A0 F8 40 70 0A EB 04 00 05 EB 04 11 40 7C 30 75 16 31 22 46 FD F7 CA FB 20 46 FE F7 81 FD 86 F8 44 80 31 7D 20 46 FE F7 03 FD 64 1C E4 B2
9:12:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 50 09 81 80 02 2C E3 D3 5F F0 00 04 05 EB C4 00 78 30 B6 F7 05 FA 64 1C E4 B2 04 2C F6 D3 B7 F7 90 FF 40 05 7D D4 B7 F7 8C FF C0 04 79 D4 08 22 69 46 10 46 D0 F7 B6 F9 01 22 00 20 00 99 FE F7 CC FD 04 46 01 22 00 20 01 99 FE F7 C6 FD 84 42 0F D0 DD E9 00 01 88 42 01 D9 05 24 00 E0 03 24 01 46 00 22 10 46 FE F7 B8 FD 21 46 FF F7 19 F8 14 E0 0A A9 0C 20 FE F7 C7 FD 78 B1 9D F8 28 00 80 07 0B D5
9:12:52 AM
9:12:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 51 09 81 80 00 22 10 46 02 99 FE F7 A6 FD 68 60 68 7C 40 F0 01 00 68 74 A5 F8 5E 70 01 22 10 46 00 99 FE F7 9A FD 05 E0 88 7A 00 10 E0 6C 00 10 00 EA 24 00 04 46 01 22 10 46 01 99 FE F7 8D FD 84 42 0E D0 DD E9 00 01 88 42 01 D9 05 24 00 E0 03 24 01 46 00 22 01 20 FE F7 7F FD 21 46 FF F7 DE FB B7 F7 2E FF 00 F0 03 00 01 28 37 D1 DD E9 00 10 81 42 0B D2 41 1A D9 F8 0C 20 4F F4 8F 50 11 44 C9 F8
9:12:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 52 09 81 80 0C 10 04 22 F6 49 CF F7 80 FF 06 20 B3 F7 48 FF 88 B1 B7 F7 14 FF 00 06 0D D4 80 20 00 E0 1C E0 FC F7 0A F8 80 20 00 99 FB F7 C7 FC 40 20 FC F7 03 F8 EC 48 07 80 95 F8 68 00 40 07 10 D5 00 20 01 99 03 F0 E6 FF 01 24 DD E9 00 12 20 46 03 F0 47 FF 64 1C E4 B2 05 2C F6 D3 0D B0 BD E8 F0 8F DD E9 00 01 03 F0 C7 FF F7 E7 DD 49 A8 39 08 44 80 7C 70 47 F0 B5 01 29 7D D0 02 29 7C D0 03 29
9:12:53 AM
9:12:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 53 09 81 80 D9 49 7A D0 D9 4A 01 F5 40 71 02 F5 C0 73 04 68 B4 B1 D1 E9 00 75 3C 19 45 F1 00 05 C1 E9 00 45 D2 E9 00 74 05 68 7D 19 44 F1 00 04 C2 E9 00 54 D3 E9 00 74 05 68 7D 19 44 F1 00 04 C3 E9 00 54 44 68 B4 B1 D1 E9 02 75 3C 19 45 F1 00 05 C1 E9 02 45 D2 E9 02 74 45 68 7D 19 44 F1 00 04 C2 E9 02 54 D3 E9 02 74 45 68 7D 19 44 F1 00 04 C3 E9 02 54 84 6A B4 B1 D1 E9 04 75 3C 19 45 F1 00 05
9:12:54 AM
9:12:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 54 09 81 80 C1 E9 04 45 D2 E9 04 74 85 6A 7D 19 44 F1 00 04 C2 E9 04 54 D3 E9 04 74 85 6A 7D 19 44 F1 00 04 C3 E9 04 54 C4 6A B4 B1 D1 E9 06 75 E6 17 3C 19 75 41 C1 E9 06 45 D2 E9 06 74 C5 6A EE 17 7D 19 74 41 C2 E9 06 54 D3 E9 06 74 C5 6A EE 17 7D 19 74 41 C3 E9 06 54 84 68 D4 B1 D1 E9 08 75 3C 19 45 F1 00 05 C1 E9 08 45 D2 E9 08 74 85 68 7D 19 44 F1 00 04 02 E0 BC E0 C1 E0 C7 E0 C2 E9 08 54
9:12:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 55 09 81 80 D3 E9 08 74 85 68 7D 19 44 F1 00 04 C3 E9 08 54 C4 68 B4 B1 D1 E9 0A 75 3C 19 45 F1 00 05 C1 E9 0A 45 D2 E9 0A 74 C5 68 7D 19 44 F1 00 04 C2 E9 0A 54 D3 E9 0A 74 C5 68 7D 19 44 F1 00 04 C3 E9 0A 54 84 69 B4 B1 D1 E9 0C 75 3C 19 45 F1 00 05 C1 E9 0C 45 D2 E9 0C 74 85 69 7D 19 44 F1 00 04 C2 E9 0C 54 D3 E9 0C 74 85 69 7D 19 44 F1 00 04 C3 E9 0C 54 C4 69 B4 B1 D1 E9 0E 75 3C 19 45 F1
9:12:55 AM
9:12:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 56 09 81 80 00 05 C1 E9 0E 45 D2 E9 0E 74 C5 69 7D 19 44 F1 00 04 C2 E9 0E 54 D3 E9 0E 74 C5 69 7D 19 44 F1 00 04 C3 E9 0E 54 04 6A B4 B1 D1 E9 10 75 3C 19 45 F1 00 05 C1 E9 10 45 D2 E9 10 74 05 6A 7D 19 44 F1 00 04 C2 E9 10 54 D3 E9 10 74 05 6A 7D 19 44 F1 00 04 C3 E9 10 54 44 6A B4 B1 D1 E9 12 75 3C 19 45 F1 00 05 C1 E9 12 45 D2 E9 12 74 45 6A 7D 19 44 F1 00 04 C2 E9 12 54 D3 E9 12 74 45 6A
9:12:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 57 09 81 80 7D 19 44 F1 00 04 C3 E9 12 54 04 69 B4 B1 D1 E9 14 75 3C 19 45 F1 00 05 C1 E9 14 45 D2 E9 14 74 05 69 7D 19 44 F1 00 04 C2 E9 14 54 D3 E9 14 74 05 69 7D 19 44 F1 00 04 C3 E9 14 54 44 69 00 2C 16 D0 D1 E9 16 75 3C 19 45 F1 00 05 C1 E9 16 45 D2 E9 16 51 44 69 2C 19 41 F1 00 01 C2 E9 16 41 D3 E9 16 21 40 69 10 18 41 F1 00 01 C3 E9 16 01 F0 BD 3F 49 01 F5 C0 72 01 F5 40 73 C7 E6 3C 49
9:12:56 AM
9:12:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 58 09 81 80 60 31 01 F5 C0 72 01 F5 40 73 C0 E6 39 4A 01 F5 84 61 02 F5 C0 73 BA E6 2D E9 F7 4F 07 46 B2 B0 0E 46 B9 42 01 D9 F0 1B 00 E0 B8 1B 2C 4D 4F F0 00 09 A8 3D CD F8 BC 90 CD F8 C0 90 29 68 2D 91 A9 68 80 46 2C 48 CD F8 A8 90 2E 91 28 90 AF F6 B5 30 29 90 2B AA 21 21 03 A8 E5 F7 13 FF 00 24 20 46 FE F7 66 FC 64 1C E4 B2 02 2C F8 D3 00 24 0D F1 0C 0B 98 E0 03 2C 03 D2 2D A8 50 F8 24 00
9:12:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 59 09 81 80 03 E0 0B EB 84 00 50 F8 0C 0C 00 28 73 D0 34 99 B0 F5 61 7F 03 D2 64 23 B0 FB F3 F2 00 E0 09 22 8A 42 00 D2 11 46 41 45 01 D9 01 22 00 E0 02 22 0B 49 09 1D 01 2A 21 D0 02 2A 0E D0 23 46 01 F8 04 90 DF F8 1C A0 26 90 0A F1 04 0A 00 20 1A F8 04 10 1A 46 02 29 37 D1 17 E0 02 22 12 E0 00 00 30 7B 00 10 B0 94 00 10 E8 6C 00 10 68 71 00 10 48 70 00 10 88 72 00 10 9F 18 05 00 0A 5D 01 2A
9:12:57 AM
9:12:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 5A 09 81 80 EB D0 01 22 23 46 0A 55 DB E7 03 2A 4F F0 00 02 39 46 03 DA E0 B2 FE F7 5E FB 02 E0 26 98 E5 F7 BE F8 B0 42 03 D2 03 21 0A F8 04 10 0C E0 26 99 41 1A B1 42 01 D9 05 22 04 E0 B7 42 01 D9 06 22 00 E0 04 22 0A F8 04 20 03 2C 22 D2 28 A9 51 F8 24 20 82 B1 FE 4B 19 5D 05 29 07 D0 03 29 05 D0 B5 F8 5E C0 BC F1 01 0F 06 D0 0D E0 69 7C 41 F0 04 01 69 74 06 E0 15 E0 04 29 01 D0 06 29 03 D1
9:12:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 5B 09 81 80 03 21 19 55 01 21 E9 87 19 5D 90 47 A5 F8 5E 90 08 E0 EF 49 02 23 0A 5D 0B EB 84 01 51 F8 0C 1C E5 F7 AE FB 64 1C E4 B2 9D F8 AC 00 C0 1C 84 42 FF F4 61 AF 35 B0 D1 E5 2D E9 F0 4F AF B0 00 20 FF F7 A7 FB FF F7 F3 F9 FF F7 0E FA E0 4C 4F F0 02 06 AC 3C 20 7C 40 06 4A D5 04 F1 9C 01 C8 68 40 1C 00 25 2F 46 C8 60 28 46 FE F7 A2 FB 60 19 01 7D 28 46 FE F7 05 FA 04 EB 45 00 B0 F8 40 10
9:12:58 AM
9:12:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 5C 09 81 80 01 29 01 D1 A0 F8 40 70 6D 1C ED B2 02 2D EB D3 D0 F7 68 FD 94 F8 3B 10 20 46 49 B3 02 29 01 D9 80 F8 3B 60 90 F8 3B 10 49 1E 11 F0 FF 01 84 F8 3B 10 1D D1 B4 F7 AF FB 01 F0 59 FC A0 B9 06 20 B3 F7 AE FC 10 B1 02 20 09 F0 95 FB 00 22 40 F6 98 51 C0 48 B5 F7 F6 FF BE 49 C0 43 A1 F8 98 0D 01 21 16 20 09 F0 FF FC 00 21 16 20 09 F0 FB FC 04 A8 B5 F7 B4 FE 2B A8 FE F7 40 F9 30 B1 9D F8
9:12:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 5D 09 81 80 AC 00 60 B1 20 7C 40 F0 02 00 20 74 2A A8 B6 F7 01 FB 9D F8 A8 00 01 06 22 D5 80 21 23 E0 60 7C 2C A9 40 F0 02 00 60 74 0C 20 FE F7 AB FA 00 28 EC D0 9D F8 B0 00 00 07 E8 D5 20 22 1D A9 B0 20 CF F7 6E FE 00 22 10 46 1D 99 FE F7 84 FA 60 60 60 7C 40 F0 01 00 60 74 01 20 A4 F8 5E 00 D5 E7 40 06 03 D5 40 21 07 20 05 F0 33 FC 94 F8 3C 10 9D F8 A8 00 81 42 20 D0 20 22 1D A9 B0 20 CF F7
9:12:59 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:12:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 5E 09 81 80 4F FE 9D F8 A8 00 40 06 0C D5 20 99 04 98 81 42 03 D8 40 1A B0 F5 E1 6F 04 D9 84 20 09 F0 2B FB 04 98 20 90 9D F8 A8 00 84 F8 3C 00 8D F8 84 00 20 22 1D A9 B0 20 CF F7 68 FC 94 F8 3B 00 00 28 7D D1 01 F0 D4 FB 78 B3 00 21 16 20 09 F0 8B FC 01 25 11 A9 28 46 B4 F7 98 FA 29 46 11 A8 FF F7 09 FD 6D 1C ED B2 03 2D F3 D9 11 A9 00 20 B4 F7 8C FA 00 21 11 A8 FF F7 FD FC DF F8 DC A1 4F F0
9:13:00 AM
9:13:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 5F 09 81 80 00 0B 00 BF 4F EA 4B 60 07 0E 0B EB 4B 01 73 48 C1 EB 4B 16 00 EB 46 05 6E 48 69 8C 01 EB 00 08 11 98 C0 B3 28 89 2E E0 FF E7 B4 F7 F4 FA 01 F0 9E FB 00 28 CC D1 84 F8 3B 60 C9 E7 09 EB 49 02 04 EB 07 11 2D 92 16 31 3A F8 22 00 FD F7 DC FA B0 B1 2D 99 0A EB 81 00 11 99 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 11 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10
9:13:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 60 09 81 80 09 F1 01 00 80 B2 81 46 54 48 29 89 10 F8 16 00 08 44 48 45 D2 D8 12 98 88 B3 B5 F8 0A 90 27 E0 09 EB 49 00 04 EB 07 11 2D 90 16 31 3A F8 20 00 FD F7 AA FA C0 B1 2D 99 0A EB 81 00 00 E0 02 E3 D0 F8 04 C0 12 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 12 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00 1F FA 80 F9 3A 48 69 89 10 F8 16 00 01 44 49 45 D0 D8 1B 98
9:13:01 AM
9:13:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 61 09 81 80 78 B3 B5 F8 0C 90 25 E0 09 EB 49 00 04 EB 07 11 2D 90 16 31 3A F8 20 00 FD F7 76 FA B0 B1 2D 98 1B 99 0A EB 80 00 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 1B 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00 1F FA 80 F9 21 48 A9 89 10 F8 16 00 01 44 49 45 D2 D8 1C 98 78 B3 B5 F8 0E 90 25 E0 09 EB 49 02 04 EB 07 11 2D 92 16 31 3A F8 22 00 FD F7 44 FA
9:13:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 62 09 81 80 B0 B1 2D 98 1C 99 0A EB 80 00 CA 17 D0 F8 04 C0 DC E9 00 30 59 18 50 41 CC E9 00 10 08 EB C9 0C 1C 99 DC E9 00 30 CA 17 59 18 50 41 CC E9 00 10 09 F1 01 00 1F FA 80 F9 08 48 E9 89 10 F8 16 00 08 44 48 45 D2 D8 13 98 B8 B3 28 8A 2D E0 00 00 34 7B 00 10 E8 6C 00 10 B0 4E 07 00 20 5D 07 00 09 EB 49 00 04 EB 07 11 2D 90 16 31 3A F8 20 00 FD F7 0A FA B0 B1 2D 98 13 99 0A EB 80 00 D0 F8
9:13:02 AM
9:13:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 63 09 81 80 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 13 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00 80 B2 81 46 FE 48 29 8A 10 F8 16 00 01 44 49 45 D2 D8 14 98 78 B3 B5 F8 12 90 25 E0 09 EB 49 00 04 EB 07 11 2D 90 16 31 3A F8 20 00 FD F7 D8 F9 B0 B1 2D 98 14 99 0A EB 80 00 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 14 99 DC E9 00 30 59 18
9:13:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 64 09 81 80 40 F1 00 00 CC E9 00 10 09 F1 01 00 1F FA 80 F9 E5 48 69 8A 10 F8 16 00 01 44 49 45 D2 D8 17 98 78 B3 B5 F8 14 90 25 E0 09 EB 49 00 04 EB 07 11 2D 90 16 31 3A F8 20 00 FD F7 A6 F9 B0 B1 2D 99 0A EB 81 00 17 99 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 17 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00 1F FA 80 F9 CC 48 A9 8A 10 F8 16 00 01 44 49 45
9:13:03 AM
9:13:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 65 09 81 80 D2 D8 18 98 78 B3 B5 F8 16 90 25 E0 09 EB 49 02 04 EB 07 11 2D 92 16 31 3A F8 22 00 FD F7 74 F9 B0 B1 2D 99 0A EB 81 00 18 99 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 18 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00 1F FA 80 F9 B3 49 E8 8A 11 F8 16 10 08 44 48 45 D2 D8 19 98 78 B3 B5 F8 18 90 25 E0 09 EB 49 00 04 EB 07 11 2D 90 16 31 3A F8 20 00
9:13:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 66 09 81 80 FD F7 42 F9 B0 B1 2D 99 0A EB 81 00 19 99 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 19 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00 1F FA 80 F9 9A 48 29 8B 10 F8 16 00 01 44 49 45 D2 D8 1A 98 78 B3 B5 F8 1A 90 25 E0 09 EB 49 00 04 EB 07 11 2D 90 16 31 3A F8 20 00 FD F7 10 F9 B0 B1 2D 99 0A EB 81 00 1A 99 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00
9:13:04 AM
9:13:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 67 09 81 80 CC E9 00 10 08 EB C9 0C 1A 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00 1F FA 80 F9 81 48 69 8B 10 F8 16 00 01 44 49 45 D2 D8 15 98 78 B3 A8 8B 25 E0 00 BF 09 EB 49 00 04 EB 07 11 2D 90 16 31 3A F8 20 00 FD F7 DE F8 B0 B1 2D 99 0A EB 81 00 15 99 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 15 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00
9:13:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 68 09 81 80 80 B2 81 46 68 48 A9 8B 10 F8 16 00 08 44 48 45 D2 D8 16 98 78 B3 E8 8B 25 E0 00 BF 09 EB 49 02 04 EB 07 11 2D 92 16 31 3A F8 22 00 FD F7 AC F8 B0 B1 2D 98 16 99 0A EB 80 00 D0 F8 04 C0 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 08 EB C9 0C 16 99 DC E9 00 30 59 18 40 F1 00 00 CC E9 00 10 09 F1 01 00 80 B2 81 46 4F 48 E9 8B 10 F8 16 00 01 44 49 45 D2 D8 0B F1 01 00 10 F0 FF 0B 3F F4
9:13:05 AM
9:13:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 69 09 81 80 81 AD 29 A9 06 20 F2 F7 EC FC 48 4D 58 B1 BD F8 A4 00 40 B1 01 21 26 20 F1 F7 A2 FE 7C 21 28 46 AD F7 1B FF BE E0 00 21 26 20 F1 F7 99 FE 05 A9 00 20 B4 F7 14 F8 05 98 28 B1 21 68 FE F7 E3 F9 29 68 08 44 28 60 06 98 28 B1 21 68 FE F7 DB F9 69 68 08 44 68 60 0F 98 28 B1 21 68 FE F7 D3 F9 A9 68 08 44 A8 60 21 68 10 98 FE F7 CC F9 E9 68 08 44 E8 60 07 98 28 B1 21 68 FE F7 C4 F9 29 69
9:13:06 AM
9:13:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 6A 09 81 80 08 44 28 61 08 98 28 B1 21 68 FE F7 BC F9 69 69 08 44 68 61 0B 98 28 B1 21 68 FE F7 B4 F9 A9 69 08 44 A8 61 0C 98 28 B1 21 68 FE F7 AC F9 E9 69 08 44 E8 61 0D 98 28 B1 21 68 FE F7 A4 F9 29 6A 08 44 28 62 0E 98 28 B1 21 68 FE F7 9C F9 69 6A 08 44 68 62 09 98 28 B1 21 68 FE F7 94 F9 A9 6A 08 44 A8 62 0A 98 28 B1 21 68 FE F7 8C F9 E9 6A 08 44 E8 62 0D 4E 30 36 00 25 6F 1C 05 A9 F8 B2
9:13:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 6B 09 81 80 B3 F7 AD FF 05 98 48 B1 21 68 FE F7 7C F9 05 EB 45 01 56 F8 31 20 10 44 46 F8 31 00 06 98 70 B1 21 68 FE F7 70 F9 03 E0 20 5D 07 00 68 77 00 10 05 EB 45 01 06 EB C1 01 4A 68 10 44 48 60 07 98 48 B1 21 68 FE F7 5F F9 05 EB 45 01 06 EB C1 01 8A 68 10 44 88 60 08 98 48 B1 21 68 FE F7 53 F9 05 EB 45 01 06 EB C1 01 CA 68 10 44 C8 60 09 98 48 B1 21 68 FE F7 47 F9 05 EB 45 01 06 EB C1 01
9:13:07 AM
9:13:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 6C 09 81 80 0A 69 10 44 08 61 0A 98 48 B1 21 68 FE F7 3B F9 05 EB 45 01 06 EB C1 01 4A 69 10 44 48 61 BD B2 03 2D AA D3 20 7C 00 22 20 F0 01 00 04 99 FD F7 45 F9 00 22 40 F6 98 51 F2 48 B5 F7 03 FC F1 49 C0 43 A1 F8 98 0D 20 7C 20 F0 40 00 20 74 E5 F7 CC F9 60 7C C0 07 36 D0 E0 8F 90 B9 20 7C C0 07 03 D1 B4 F8 5E 00 01 28 0B D1 01 20 A4 F8 60 00 FD F7 5F FF 03 21 60 68 FE F7 11 F9 00 20 A4 F8
9:13:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 6D 09 81 80 5E 00 20 7C 81 07 06 D5 61 7C 20 F0 02 00 41 F0 02 01 61 74 20 74 C0 B2 41 07 06 D5 61 7C 20 F0 04 00 41 F0 04 01 61 74 20 74 60 7C 20 F0 01 00 60 74 20 7C 20 F0 01 00 20 74 E0 8F 08 B1 00 20 E0 87 FE F7 55 FD 60 7C 80 06 0B D5 03 21 E0 68 FE F7 E3 FC 60 7C 20 F0 20 00 60 74 20 7C 20 F0 20 00 20 74 60 7C 00 06 05 D5 07 F0 7F FB 60 7C 20 F0 80 00 60 74 00 20 03 F0 11 F8 38 B1 60 7C
9:13:08 AM
9:13:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 6E 09 81 80 20 F0 02 00 60 74 20 7C 20 F0 02 00 20 74 60 7C 80 07 0B D5 04 98 FD F7 FE FC 38 B1 60 7C 20 F0 02 00 60 74 20 7C 20 F0 02 00 20 74 00 20 B4 F7 2C F8 20 7C 01 06 02 D5 20 F0 80 00 20 74 60 7C 40 07 17 D5 00 25 66 19 06 F1 14 00 29 46 FC F7 01 FC 04 EB 05 11 16 31 30 7D 2A 46 FC F7 0F FC 6D 1C ED B2 02 2D EE D3 60 7C 20 F0 04 00 60 74 00 20 E0 87 5F F0 00 05 04 EB C5 00 78 30 06 46
9:13:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 6F 09 81 80 B5 F7 58 FA 61 6E 88 42 02 D9 30 46 B5 F7 46 FA 6D 1C AD B2 04 2D EF D3 2F B0 BD E8 F0 8F 10 B5 8C B0 08 A8 FD F7 AA FC 00 28 27 D0 96 48 00 78 40 07 23 D5 94 4C 9D F8 20 00 9C 3C 00 B3 B4 F8 60 00 18 B1 60 7C 40 F0 02 00 60 74 60 7C 80 07 14 D5 0A A8 B5 F7 03 FA 01 20 B3 F7 D6 FF 0A 98 FD F7 99 FC 38 B1 60 7C 20 F0 02 00 60 74 20 7C 20 F0 02 00 20 74 00 20 B3 F7 C7 FF 0C B0 10 BD
9:13:09 AM
9:13:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 70 09 81 80 60 7C 09 A9 40 F0 02 00 60 74 0C 20 FD F7 FA FD 00 28 DB D0 9D F8 24 00 00 07 D7 D5 B4 F8 60 00 00 28 D3 D1 20 22 69 46 B0 20 CF F7 B9 F9 00 22 10 46 00 99 FD F7 CF FD 60 60 21 68 40 1A 03 21 FE F7 2D F8 C2 E7 30 B5 0C 46 70 49 99 B0 00 22 02 EB 42 03 31 F8 23 30 83 42 0E D1 02 EB 42 00 01 EB 80 00 45 68 01 20 04 F0 9A FF D5 E9 00 01 C4 E9 00 01 01 20 19 B0 30 BD 52 1C 92 B2 C0 2A
9:13:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 71 09 81 80 E6 D3 63 49 00 22 00 BF 31 F8 32 30 83 42 23 D1 01 EB C2 05 68 88 01 04 01 D5 68 68 17 E0 C1 05 02 D5 69 46 00 20 0D E0 81 05 02 D5 69 46 01 20 08 E0 41 05 02 D5 69 46 02 20 03 E0 00 05 0F D5 69 46 03 20 B3 F7 CF FD 68 68 69 46 08 44 D0 E9 00 10 C4 E9 00 10 CD E7 52 1C 92 B2 4E 2A D3 D3 00 20 C8 E7 10 B5 47 4A B0 F5 C5 4F 70 D0 3B DC 46 F2 84 14 A0 EB 04 03 A0 42 6A D0 1C DC 46 F2
9:13:10 AM
9:13:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 72 09 81 80 06 14 A0 EB 04 03 A0 42 6F D0 08 DC A0 F5 C2 40 06 28 6B D2 DF E8 00 F0 66 6B 70 73 86 89 7B 2B 6F D0 04 DC 01 2B 77 D0 7A 2B 5F D1 85 E0 7C 2B 73 D0 7D 2B 5A D1 89 E0 7E 2B 6F D0 0C DC 03 2B 6D D0 04 DC 01 2B 6B D0 02 2B 4F D1 89 E0 7C 2B 67 D0 7D 2B 4A D1 8F E0 7F 3B 05 2B 46 D2 DF E8 03 F0 95 98 9B A1 A4 00 46 F2 04 34 03 1B A0 42 6F D0 1D DC 46 F2 86 24 A0 EB 04 03 A0 42 69 D0
9:13:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 73 09 81 80 09 DC 6F F4 C5 43 18 44 05 28 2F D2 DF E8 00 F0 95 98 9B A0 A3 00 7B 2B 71 D0 04 DC 01 2B 6F D0 7A 2B 23 D1 A0 E0 7C 2B 6B D0 7D 2B 1E D1 A4 E0 7E 2B 67 D0 0E DC 03 2B 71 D0 04 DC 01 2B 6F D0 02 2B 13 D1 A2 E0 7C 2B 6B D0 7D 2B 0E D1 AA E0 70 E0 40 E0 7F 3B 05 2B 08 D2 DF E8 03 F0 AB B0 B3 B9 BE 00 D2 E9 C0 02 03 E0 21 E0 BA E0 D2 E9 D8 02 C1 E9 00 02 A9 E0 D2 E9 F0 02 F9 E7 05 4A
9:13:11 AM
9:13:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 74 09 81 80 96 E0 1D E0 E8 6C 00 10 24 7B 00 10 B0 4E 07 00 B0 5A 07 00 08 71 00 10 0D E0 14 E0 33 E0 23 E0 1C E0 26 E0 D2 E9 C2 02 E3 E7 D2 E9 DA 02 E0 E7 D2 E9 F2 02 DD E7 F7 4A 7A E0 D2 E9 C4 02 D8 E7 D2 E9 DC 02 D5 E7 D2 E9 F4 02 D2 E7 F1 4A 08 32 6E E0 55 E0 42 E0 D2 E9 C6 02 CA E7 D2 E9 DE 02 C7 E7 D2 E9 F6 02 C4 E7 EB 4A 02 F5 87 62 05 CA BF E7 D2 E9 C8 02 BC E7 D2 E9 E0 02 B9 E7 36 E0
9:13:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 75 09 81 80 2F E0 37 E0 52 E0 D2 E9 F8 02 B2 E7 E1 4A 18 32 4E E0 D2 E9 CA 02 AC E7 D2 E9 E2 02 A9 E7 3A E0 31 E0 3D E0 D2 E9 FA 02 A3 E7 DB 4A 02 F5 89 62 05 CA 9E E7 D2 E9 CC 02 9B E7 D2 E9 E4 02 98 E7 D2 E9 FC 02 95 E7 D4 4A 02 F5 8A 62 05 CA 90 E7 D2 E9 CE 02 8D E7 D2 E9 E6 02 8A E7 D2 E9 FE 02 87 E7 CC 4A 30 32 23 E0 D2 E9 D0 02 81 E7 D2 E9 E8 02 7E E7 C7 4A 28 3A 1A E0 C6 4A 38 32 17 E0
9:13:12 AM
9:13:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 76 09 81 80 D2 E9 D2 02 75 E7 D2 E9 EA 02 72 E7 C2 4A 02 F5 81 62 05 CA 6D E7 C0 4A 02 F5 8D 62 05 CA 68 E7 D2 E9 D4 02 65 E7 D2 E9 EC 02 62 E7 B9 4A 18 3A 05 CA 5E E7 B8 4A 02 F5 8E 62 05 CA 59 E7 D2 E9 D6 02 56 E7 D2 E9 EE 03 C1 E9 00 03 01 20 10 BD B1 4A 02 F5 83 62 05 CA 4B E7 AF 4A 02 F5 8F 62 05 CA 46 E7 00 20 10 BD 10 B5 AC 4B 00 22 00 BF 33 F8 32 40 84 42 08 D1 03 EB C2 00 40 68 D0 E9
9:13:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 77 09 81 80 00 20 C1 E9 00 20 01 20 10 BD 52 1C 92 B2 60 2A EE D3 00 20 10 BD B0 F5 CB 4F 70 D0 3B DC 46 F2 84 43 A0 EB 03 02 98 42 6A D0 1C DC 46 F2 06 43 A0 EB 03 02 98 42 6F D0 08 DC A0 F5 C8 40 06 28 6B D2 DF E8 00 F0 66 6B 73 7C 81 87 7B 2A 72 D0 04 DC 01 2A 70 D0 7A 2A 5F D1 83 E0 7C 2A 6C D0 7D 2A F9 D1 8F E0 7E 2A 68 D0 0C DC 03 2A 6E D0 04 DC 01 2A 6C D0 02 2A EE D1 8D E0 7C 2A 68 D0
9:13:13 AM
9:13:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 78 09 81 80 7D 2A E9 D1 98 E0 7F 3A 05 2A D9 D2 DF E8 02 F0 A0 A3 A8 AD B2 00 46 F2 04 63 C2 1A 98 42 70 D0 1D DC 46 F2 86 53 A0 EB 03 02 98 42 6A D0 09 DC 6F F4 CB 42 10 44 05 28 2F D2 DF E8 00 F0 A5 AA AF B4 B7 00 7B 2A 6F D0 04 DC 01 2A 6D D0 7A 2A 23 D1 B8 E0 7C 2A 69 D0 7D 2A 1E D1 C2 E0 7E 2A 72 D0 0E DC 03 2A 70 D0 04 DC 01 2A 6E D0 02 2A 13 D1 C4 E0 7C 2A 6A D0 7D 2A 0E D1 D4 E0 7E E0
9:13:14 AM
9:13:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 79 09 81 80 44 E0 7F 3A 05 2A 08 D2 DF E8 02 F0 D6 DB DF E4 E9 00 60 4A 58 32 D6 E0 1F E0 E5 E0 5D 4A B8 32 D1 E0 00 BF C1 E9 00 02 01 20 70 47 5A 4A 02 F5 A8 62 05 CA F6 E7 1A E0 11 E0 1D E0 3F E0 56 4A 02 F5 B4 62 05 CA ED E7 52 4A 60 32 BB E0 26 E0 1F E0 2C E0 4F 4A C0 32 B5 E0 51 4A B3 E0 50 4A 60 32 B0 E0 4C 4A 02 F5 92 62 05 CA DA E7 4A 4A 02 F5 9E 62 05 CA D5 E7 47 4A 02 F5 AA 62 05 CA
9:13:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 7A 09 81 80 D0 E7 74 E0 57 E0 46 4A 68 32 9C E0 41 4A 70 32 99 E0 43 4A 50 3A 96 E0 41 4A 10 32 93 E0 3E 4A 02 F5 B7 62 05 CA BD E7 52 E0 47 E0 55 E0 3A 4A 02 F5 94 62 05 CA B5 E7 39 4A 48 3A 83 E0 36 4A 02 F5 AC 62 05 CA AD E7 71 E0 5D E0 52 E0 69 E0 33 4A 78 32 77 E0 30 4A 02 F5 95 62 05 CA A1 E7 2D 4A 02 F5 A1 62 05 CA 9C E7 2B 4A 02 F5 AD 62 05 CA 97 E7 28 4A 02 F5 B9 62 05 CA 92 E7 26 4A
9:13:15 AM
9:13:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 7B 09 81 80 02 F5 96 62 05 CA 8D E7 23 4A 02 F5 A2 62 05 CA 88 E7 21 4A 02 F5 AE 62 05 CA 83 E7 1E 4A 02 F5 BA 62 05 CA 7E E7 1B 4A 90 32 4C E0 1A 4A 02 F5 A3 62 05 CA 76 E7 1A 4A 30 32 44 E0 16 4A 02 F5 BB 62 05 CA 6E E7 14 4A 02 F5 98 62 05 CA 69 E7 11 4A 02 F5 A4 62 05 CA 64 E7 0F 4A 02 F5 B0 62 05 CA 5F E7 0C 4A 02 F5 BC 62 05 CA 5A E7 0C 4A 80 3A 28 E0 08 4A 02 F5 A5 62 05 CA 52 E7 06 4A
9:13:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 7C 09 81 80 02 F5 B1 62 05 CA 4D E7 03 4A 02 F5 BD 62 05 CA 48 E7 00 00 10 71 00 10 E8 6C 00 10 B0 57 07 00 30 72 00 10 FE 4A 0E E0 FD 4A 60 32 0B E0 FD 4A 02 F5 B2 62 05 CA 35 E7 FA 4A 02 F5 BE 62 05 CA 30 E7 F7 4A 08 32 05 CA 2C E7 F6 4A 02 F5 A7 62 05 CA 27 E7 F3 4A 02 F5 B3 62 05 CA 22 E7 F1 4A 02 F5 BF 62 05 CA 1D E7 00 20 70 47 B0 F5 D1 4F 70 D0 3B DC 46 F2 84 73 A0 EB 03 02 98 42 6A D0
9:13:16 AM
9:13:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 7D 09 81 80 1C DC 46 F2 06 73 A0 EB 03 02 98 42 71 D0 08 DC A0 F5 CE 40 06 28 6D D2 DF E8 00 F0 66 68 72 79 7E 84 7B 2A 67 D0 04 DC 01 2A 6E D0 7A 2A 61 D1 80 E0 7C 2A 6A D0 7D 2A F9 D1 8B E0 7E 2A 6E D0 0C DC 03 2A 6C D0 04 DC 01 2A 6A D0 02 2A EE D1 8B E0 7C 2A 73 D0 7D 2A E9 D1 97 E0 7F 3A 05 2A D9 D2 DF E8 02 F0 9B A1 A6 AB B0 00 46 F6 04 13 C2 1A 98 42 71 D0 1D DC 46 F6 86 03 A0 EB 03 02
9:13:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 7E 09 81 80 98 42 6B D0 09 DC 6F F4 D1 42 10 44 05 28 31 D2 DF E8 00 F0 A3 A8 AD B2 B5 00 7B 2A 72 D0 04 DC 01 2A 70 D0 7A 2A 25 D1 B6 E0 7C 2A 6C D0 7D 2A 20 D1 C0 E0 7E 2A 68 D0 0E DC 03 2A 71 D0 04 DC 01 2A 6F D0 02 2A 15 D1 C2 E0 7C 2A 6B D0 7D 2A 10 D1 CA E0 7C E0 42 E0 7F 3A 05 2A 0A D2 DF E8 02 F0 CC D1 D5 DA DF 00 AF 4A CD E0 AE 4A 60 32 CA E0 1A E0 D9 E0 23 E0 C1 E9 00 02 01 20 70 47
9:13:17 AM
9:13:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 7F 09 81 80 A8 4A 02 F5 D8 62 05 CA F6 E7 11 E0 1D E0 A5 4A 02 F5 E4 62 05 CA EF E7 A3 4A 08 32 B4 E0 38 E0 26 E0 1F E0 A0 4A 68 32 AE E0 9F 4A C8 32 AB E0 9E 4A A9 E0 9B 4A 02 F5 C2 62 05 CA DC E7 1C E0 98 4A 02 F5 CE 62 05 CA D6 E7 96 4A 02 F5 DA 62 05 CA D1 E7 95 4A 08 32 96 E0 71 E0 54 E0 92 4A 18 32 91 E0 90 4A 78 32 8E E0 90 4A 50 3A 8B E0 8C 4A 02 F5 E7 62 05 CA BE E7 8A 4A 02 F5 C4 62
9:13:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 80 09 81 80 05 CA B9 E7 4D E0 42 E0 50 E0 71 E0 86 4A 80 32 7A E0 84 4A 02 F5 DC 62 05 CA AD E7 83 4A 18 32 72 E0 5A E0 4F E0 5D E0 7E 4A 02 F5 C5 62 05 CA A2 E7 7C 4A 02 F5 D1 62 05 CA 9D E7 79 4A 02 F5 DD 62 05 CA 98 E7 77 4A 02 F5 E9 62 05 CA 93 E7 74 4A 02 F5 C6 62 05 CA 8E E7 72 4A 02 F5 D2 62 05 CA 89 E7 6F 4A 02 F5 DE 62 05 CA 84 E7 6D 4A 02 F5 EA 62 05 CA 7F E7 6B 4A 38 32 44 E0 69 4A
9:13:18 AM
9:13:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 81 09 81 80 02 F5 D3 62 05 CA 77 E7 68 4A 30 3A 3C E0 65 4A 02 F5 EB 62 05 CA 6F E7 62 4A 02 F5 C8 62 05 CA 6A E7 60 4A 02 F5 D4 62 05 CA 65 E7 5D 4A 02 F5 E0 62 05 CA 60 E7 5B 4A 02 F5 EC 62 05 CA 5B E7 59 4A 48 32 20 E0 57 4A 02 F5 D5 62 05 CA 53 E7 54 4A 02 F5 E1 62 05 CA 4E E7 52 4A 02 F5 ED 62 05 CA 49 E7 50 4A 50 32 0E E0 50 4A 78 3A 0B E0 4C 4A 02 F5 E2 62 05 CA 3E E7 4A 4A 02 F5 EE 62
9:13:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 82 09 81 80 05 CA 39 E7 48 4A 58 32 05 CA 35 E7 45 4A 02 F5 D7 62 05 CA 30 E7 43 4A 02 F5 E3 62 05 CA 2B E7 40 4A 02 F5 EF 62 05 CA 26 E7 00 20 70 47 70 B5 0C 46 15 46 20 F0 78 00 FB F7 79 FD 94 F9 00 00 FB F7 9A FD 28 60 70 BD 00 20 70 47 2D E9 F0 41 05 46 0C 46 03 20 07 F0 A2 FC 35 4B 01 00 05 EB 85 00 03 F1 3A 02 02 EB C0 02 05 EB 45 00 C0 EB 45 10 03 EB 40 00 05 D0 7C B3 01 2C 33 D0 02 2C
9:13:19 AM
9:13:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 83 09 81 80 05 D1 32 E0 34 B1 01 2C 09 D0 02 2C 0A D0 00 20 BD E8 F0 81 00 8C D1 8C 00 24 08 44 05 E0 00 24 06 8C 03 E0 04 8C D0 8C 20 44 86 B2 00 25 21 4F 0F E0 00 BF 04 EB 44 00 37 F8 20 00 DE F7 F0 FE 28 B1 40 89 10 F4 40 7F 01 D1 6D 1C AD B2 64 1C A4 B2 B4 42 EE D3 28 46 DA E7 FF E7 00 8C D1 8C 08 44 80 B2 D4 E7 00 8C D2 E7 D0 8C D0 E7 F0 B5 05 46 0E 46 6F F0 02 04 05 9F FE F7 5B F9 00 B1
9:13:20 AM
9:13:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 84 09 81 80 00 24 0C 48 0A 38 BC 42 22 DD A4 EB 07 01 4B B2 05 2B 00 D3 00 23 30 F8 13 00 7D B1 29 68 0B E0 B8 71 00 10 E8 6C 00 10 E8 72 00 10 10 74 00 10 20 5D 07 00 B0 4E 07 00 41 43 29 60 16 B1 31 68 41 43 31 60 00 2A 02 D0 11 68 41 43 11 60 F0 BD FD DA 39 1B 49 B2 05 29 00 D3 00 21 00 2B 30 F8 11 00 F4 D0 19 68 41 43 19 60 F0 BD FE B5 4C 1E 0D 46 16 46 04 2C 69 D2 A6 B3 F7 4A 0A 28 65 D2
9:13:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 85 09 81 80 DF E8 00 F0 05 15 1D 64 64 64 25 64 64 3F 68 46 B5 F7 DE FA 30 BB 03 2D 05 D9 DD E9 00 01 08 44 02 99 44 18 39 E0 E0 B2 5D F8 20 40 35 E0 02 2C 4C D8 E0 B2 02 EB 80 00 D0 F8 14 4B 2D E0 02 2C 44 D8 E0 B2 02 EB 80 00 D0 F8 7C 4B 25 E0 02 2C 3C D8 E0 B2 02 EB C0 01 D1 F8 94 0C 80 B3 D1 F8 90 1C 18 E0 32 E0 00 BF 01 F5 3F 61 00 23 03 C9 89 B2 C4 F7 1F FC 01 E0 00 20 01 46 04 46 0D 46
9:13:21 AM
9:13:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 86 09 81 80 0C E0 02 2C 22 D8 E0 B2 02 EB C0 01 D1 F8 C4 0C B0 B1 D1 F8 C0 1C B1 FB F0 F4 00 25 6F F0 02 02 FE F7 C8 F8 00 B1 00 22 CC 48 D2 1C 00 23 30 F8 12 20 20 46 29 46 C4 F7 FD FB 30 60 01 20 FE BD FF E7 B1 F8 F6 2B 00 2A D6 D0 CD E7 00 20 F6 E7 FE B5 4C 1E 0D 46 16 46 04 2C 62 D2 B6 B3 BE 4A 0A 28 5E D2 DF E8 00 F0 05 0F 17 5D 5D 5D 1F 5D 5D 38 68 46 B5 F7 D1 F9 40 BB 03 2D 51 D8 E0 B2
9:13:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 87 09 81 80 5D F8 20 40 34 E0 02 2C 4B D8 E0 B2 02 EB 80 00 D0 F8 08 4B 2C E0 02 2C 43 D8 E0 B2 02 EB 80 00 D0 F8 70 4B 24 E0 02 2C 3B D8 E0 B2 02 EB C0 01 D1 F8 7C 0C 78 B3 D1 F8 78 1C 17 E0 01 F6 D8 31 00 23 03 C9 89 B2 C4 F7 B5 FB 02 E0 29 E0 00 20 01 46 04 46 0D 46 0C E0 02 2C 22 D8 E0 B2 02 EB C0 01 D1 F8 AC 0C B0 B1 D1 F8 A8 1C B1 FB F0 F4 00 25 6F F0 02 02 FD F7 65 FF 00 B1 00 22 97 48
9:13:22 AM
9:13:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 88 09 81 80 D2 1C 00 23 30 F8 12 20 20 46 29 46 C4 F7 92 FB 30 60 01 20 93 E7 FF E7 B1 F8 DE 2B 00 2A D6 D0 CC E7 00 20 8B E7 FE B5 4E 1E 0C 46 15 46 04 2E 13 D2 95 B1 6F 46 00 28 38 46 0A D0 B5 F7 CB F9 09 E0 03 2C 09 D8 F0 B2 57 F8 20 00 28 60 01 20 75 E7 B5 F7 5C FA 00 28 F3 D0 00 20 6F E7 70 B5 0C 46 16 46 00 25 FA F7 D1 F9 00 69 83 B2 9C 42 03 D8 13 B1 18 1B 30 80 01 25 28 46 70 BD F0 B5
9:13:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 89 09 81 80 C3 B0 07 46 0D 46 07 26 00 24 69 46 30 46 FA F7 14 F9 A8 B1 30 46 F8 F7 54 FE 00 22 69 46 4F F6 FF 76 0B E0 01 EB 42 03 DB 88 B3 42 08 D0 BB 42 02 D1 2A 80 01 24 03 E0 52 1C D2 B2 82 42 F1 D3 43 B0 20 46 F0 BD 2D E9 F0 43 AD F2 E4 5D 0E 46 90 46 99 46 04 46 07 25 0D F2 34 51 FF F7 CF FF 01 28 04 D0 02 20 0D F2 E4 5D BD E8 F0 83 0D F5 A7 62 31 46 28 46 FF F7 B2 FF 80 B3 FF 22 0C 21
9:13:23 AM
9:13:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 8A 09 81 80 0D F5 B8 60 AD F7 3D FC 0D F5 B8 62 BD F8 38 15 28 46 F9 F7 1E FC 90 B3 0D F5 BB 61 08 1F CD E9 00 01 0D F5 B8 63 40 F2 24 42 02 A9 28 46 FA F7 8C F9 00 28 D7 D0 0D F2 2C 41 28 46 FA F7 BD F8 00 28 D0 D0 BD F8 34 05 80 28 06 D8 0D F2 2C 46 06 EB 40 00 C0 88 A0 42 02 D0 00 20 C3 E7 29 E0 F6 F7 84 FC 00 28 BE D0 47 88 02 AD 80 22 0D F5 A8 61 0D F2 CC 50 B4 F7 8F FC 00 24 0C E0 17 E0
9:13:24 AM
9:13:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 8B 09 81 80 06 EB 44 00 C0 88 F6 F7 71 FC 18 B1 40 88 C0 F3 0A 00 05 44 64 1C A4 B2 BD F8 34 05 84 42 EF D3 C7 F3 0A 02 42 45 03 D8 29 46 48 46 AC F7 F8 FD 01 20 98 E7 03 20 96 E7 30 B5 85 B0 07 25 1C 46 01 AA 28 46 FF F7 4B FF 80 B1 FF 22 0C 21 02 A8 AD F7 D7 FB 02 AA BD F8 04 10 28 46 F9 F7 B9 FB 20 B1 03 98 20 60 01 20 05 B0 30 BD 00 20 FB E7 F0 B5 AD F5 07 7D 04 46 0E 46 01 25 80 22 54 A9
9:13:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 8C 09 81 80 82 A8 B4 F7 49 FC 24 F0 78 00 DE F7 C9 FC 04 00 1E D0 20 7A AD F8 DC 01 07 20 8D F8 E4 01 D4 F8 02 00 CD F8 DE 01 E0 88 AD F8 E2 01 77 A9 68 46 DE F7 67 FD 00 28 0C D0 82 AA 7A A9 68 46 DF F7 CA FB 00 28 05 D0 9D F8 E8 01 09 28 08 D0 0D E0 00 20 0D F5 07 7D F0 BD E8 6C 00 10 A6 4E 07 00 BD F8 EC 21 7E A8 7C 99 AC F7 9A FD 84 A9 7E A8 D3 F7 07 FF 50 B1 76 A9 84 A8 B4 F7 6F F9 28 B1
9:13:25 AM
9:13:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 8D 09 81 80 75 A8 B4 F7 AC FA DD E9 75 01 47 1A 08 20 8D F8 E4 01 D4 F8 02 00 CD F8 DE 01 E0 88 AD F8 E2 01 77 A9 68 46 DE F7 2D FD 00 28 D2 D0 82 AA 7A A9 68 46 DF F7 90 FB 00 28 CB D0 9D F8 E8 01 06 28 04 D0 00 20 00 2E C4 D0 35 80 C2 E7 7B 98 B7 FB F0 F1 00 FB 11 71 3C 28 03 D9 3C 20 B1 FB F0 F0 F0 E7 64 22 51 43 B1 FB F0 F0 00 25 EA E7 10 B5 00 22 40 F6 98 51 1E 48 B4 F7 A4 FB 1C 49 C0 43
9:13:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 8E 09 81 80 80 B2 B1 F8 98 1D 81 42 01 D1 01 20 10 BD 00 20 10 BD FE B5 10 B1 01 28 21 D1 04 E0 48 68 00 90 01 20 02 26 03 E0 88 68 00 90 03 20 04 26 00 25 2C 46 01 A9 F1 F7 95 FB 01 28 04 D1 BD F8 04 00 00 B1 01 24 01 25 02 A9 30 46 F1 F7 8A FB 01 28 07 D0 25 B1 1D F8 04 00 41 1E 1F 29 00 D9 FF 20 ED E5 BD F8 08 00 00 28 F4 D0 44 F0 02 04 F1 E7 E8 6C 00 10 10 B5 04 46 B1 F7 3D FF 04 28 02 D9
9:13:26 AM
9:13:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 8F 09 81 80 4F F0 01 00 10 BD 01 D3 02 2C F9 D0 00 20 10 BD 10 B5 02 46 00 21 FB 4B 08 46 1C 5C 01 2C 04 D1 0C 46 49 1C C9 B2 94 42 04 D0 40 1C C0 B2 04 28 F3 D3 FF 20 10 BD 04 28 03 D2 F2 49 08 5C 01 28 00 D0 00 20 70 47 0E B5 83 01 02 AA 28 20 CD E9 00 02 02 46 02 20 CD F7 42 FF 00 28 00 D0 01 20 0E BD 04 28 01 D3 00 20 70 47 E7 49 51 F8 20 00 41 F2 11 11 08 40 F7 D0 01 20 70 47 10 B5 0B 46
9:13:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 90 09 81 80 04 46 00 22 FF F7 ED FF 58 B9 19 46 20 46 FF F7 DA FF 02 46 01 28 04 D1 DC 48 01 5D 21 F0 01 01 01 55 10 46 10 BD 0E B5 83 01 02 AA 28 20 CD E9 00 02 02 46 02 20 CD F7 52 FF 0E BD 10 B5 0B 46 02 46 FF F7 B8 FF 00 28 04 D0 BD E8 10 40 19 46 10 46 B8 E7 10 BD 7F B5 05 46 CC 48 6C 46 80 1D 00 90 00 F6 1C 60 01 90 00 F6 1C 60 02 90 C8 48 03 90 5D F8 25 00 00 28 0D D0 EF F7 CC FF 54 F8
9:13:27 AM
9:13:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 91 09 81 80 25 00 40 6C 00 28 06 D0 01 68 4F F4 7A 72 49 89 51 43 C0 F8 84 10 7F BD 70 B5 0D 46 04 46 FF F7 8A FF 00 28 1A D0 29 46 20 46 FF F7 BC FF 00 28 14 D0 20 46 FF F7 95 FF 28 B1 B4 48 01 5D 41 F0 01 01 01 55 09 E0 B3 48 28 22 00 EB 84 10 29 46 AC F7 66 FC 20 46 FF F7 BE FF 01 20 70 BD 70 47 70 47 10 B5 02 46 00 21 A6 4B 08 46 1C 5C 02 2C 04 D1 0C 46 49 1C C9 B2 94 42 04 D0 40 1C C0 B2
9:13:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 92 09 81 80 04 28 F3 D3 FF 20 10 BD 04 28 03 D2 9D 49 08 5C 02 28 01 D0 00 20 70 47 01 20 70 47 10 B5 01 46 04 28 01 D3 FF 20 10 BD 00 22 96 4B 10 46 1B 1D 1C 5C 24 B1 14 46 52 1C D2 B2 8C 42 F3 D0 40 1C C0 B2 04 28 F4 D3 08 46 10 BD 04 28 01 D3 00 20 70 47 8C 49 09 1D 08 5C 00 28 F9 D0 01 20 70 47 0E B5 83 01 02 AA 0E 20 CD E9 00 02 02 46 28 33 02 20 CD F7 74 FE 0E BD 10 B5 0B 46 04 46 00 22
9:13:28 AM
9:13:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 93 09 81 80 FF F7 2F FF 58 B9 19 46 20 46 FF F7 E9 FF 02 46 01 28 04 D1 7D 48 01 5D 21 F0 04 01 01 55 10 46 10 BD 0E B5 83 01 02 AA 0E 20 CD E9 00 02 02 46 28 33 02 20 CD F7 93 FE 0E BD 10 B5 0B 46 02 46 FF F7 C3 FF 00 28 04 D0 BD E8 10 40 19 46 10 46 C6 E7 10 BD 70 B5 0D 46 04 46 FF F7 B6 FF 00 28 1B D0 29 46 20 46 FF F7 DC FF 00 28 15 D0 20 46 FF F7 F7 FE 28 B1 65 48 01 5D 41 F0 04 01 01 55
9:13:29 AM
9:13:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 94 09 81 80 0A E0 64 48 0E 22 00 EB 84 10 28 30 29 46 AC F7 C7 FB 20 46 FF F7 1F FF 01 20 70 BD 04 28 01 D3 00 20 70 47 57 49 09 1D 08 5C 00 28 F9 D0 01 20 70 47 0E B5 83 01 02 AA 08 20 CD E9 00 02 02 46 38 33 02 20 CD F7 0B FE 0E BD 10 B5 0B 46 04 46 00 22 FF F7 C6 FE 58 B9 19 46 20 46 FF F7 E9 FF 02 46 01 28 04 D1 49 48 01 5D 21 F0 08 01 01 55 10 46 10 BD 0E B5 83 01 02 AA 08 20 CD E9 00 02
9:13:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 95 09 81 80 02 46 38 33 02 20 CD F7 2A FE 0E BD 10 B5 0B 46 02 46 FF F7 C3 FF 00 28 04 D0 BD E8 10 40 19 46 10 46 C6 E7 10 BD 70 B5 0D 46 04 46 FF F7 B6 FF 00 28 1A D0 29 46 20 46 FF F7 DC FF 00 28 14 D0 20 46 FF F7 8E FE 28 B1 30 48 01 5D 41 F0 08 01 01 55 09 E0 2F 48 D5 E9 00 12 00 EB 84 10 C0 E9 0E 12 20 46 FF F7 B7 FE 01 20 70 BD 0E B5 02 AA 02 21 CD E9 00 12 0A 46 01 46 4F F4 83 73 02 20
9:13:30 AM
9:13:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 96 09 81 80 CD F7 AD FD 00 28 00 D0 01 20 0E BD 10 B5 22 4C 28 B1 01 28 09 D0 02 28 05 D0 00 20 10 BD 00 21 20 46 E7 F7 81 FF 01 21 00 E0 00 21 20 46 E7 F7 7B FF 01 20 10 BD 0E B5 02 AA 04 21 CD E9 00 12 0A 46 01 46 4F F4 81 73 02 20 CD F7 88 FD 00 28 00 D0 01 20 0E BD 10 B5 0B 4A 00 21 52 F8 21 30 9B 03 01 D5 00 20 10 BD 49 1C 04 29 F6 DB FF F7 E2 FF 01 28 F7 D1 05 49 0A 79 22 F0 01 02 0A 71
9:13:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 97 09 81 80 10 BD 00 00 88 5D 07 00 1C 7E 00 20 06 3E 00 20 4C 6E 00 20 14 7D 00 20 30 5D 00 20 0E B5 02 AA 04 21 CD E9 00 12 0A 46 01 46 4F F4 81 73 02 20 CD F7 95 FD 0E BD BE E7 10 B5 04 46 FF F7 EE FF 00 28 DD D0 FA 48 00 21 50 F8 21 20 92 03 06 D5 F8 48 01 79 41 F0 01 01 01 71 01 20 D0 E7 49 1C C9 B2 04 29 F0 D3 F2 48 21 68 1C 38 C0 F8 16 10 A0 F5 96 70 0E F0 C4 FF EF E7 00 20 70 47 04 28
9:13:31 AM
9:13:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 98 09 81 80 01 D3 00 20 70 47 EA 49 51 F8 20 00 70 47 E8 48 00 69 70 47 00 20 E6 4A 01 46 00 BF 52 F8 21 30 49 1C 18 43 C9 B2 04 29 F8 D3 70 47 2D E9 F0 41 04 46 28 22 E0 49 AC F7 1E FB DF 49 0E 22 28 31 04 F1 28 00 AC F7 AC FA 00 25 A5 63 E5 63 65 87 28 22 D9 49 04 F1 40 00 AC F7 0D FB 04 F1 40 04 4F F0 01 06 A0 78 60 70 D3 49 04 F8 40 69 4F F0 0E 02 01 F1 28 01 04 F1 68 00 AC F7 91 FA A5 67
9:13:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 99 09 81 80 E5 67 04 F1 80 00 A4 F8 7A 50 28 22 CA 49 07 46 AC F7 F1 FA 04 F1 80 04 C7 49 A0 78 60 70 04 F8 80 69 4F F0 0E 02 01 F1 28 01 04 F1 A8 00 AC F7 77 FA 4F F4 FA 70 A4 F8 B0 00 BD 63 FD 63 A4 F8 BA 50 28 22 BC 49 04 F1 C0 00 AC F7 D4 FA 04 F1 C0 04 B9 49 A0 78 60 70 04 F8 C0 69 4F F0 0E 02 01 F1 28 01 04 F1 E8 00 AC F7 5A FA BD 67 FD 67 24 F8 FA 5F 40 F2 DC 50 A0 81 1E 20 E0 80 AD 48
9:13:32 AM
9:13:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 9A 09 81 80 80 1F C0 F8 06 50 85 72 AB 48 1C 38 00 68 A0 60 01 20 BD E8 F0 81 0E B5 02 A9 4F F4 84 72 CD E9 00 21 01 46 00 23 02 20 CD F7 99 FC 0E BD 0E B5 02 A9 4F F4 84 72 CD E9 00 21 01 46 00 23 02 20 CD F7 CD FC 0E BD 00 B5 C3 B0 68 46 FF F7 6E FF 00 28 05 D0 68 46 FF F7 EA FF 00 28 00 D0 01 20 43 B0 00 BD 10 B5 95 48 FF F7 D5 FF 10 B9 93 48 FF F7 5C FF 8F 48 00 21 80 1F C0 F8 06 10 81 72
9:13:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 9B 09 81 80 01 20 FD E6 05 F0 34 BF 10 B5 05 F0 31 FF 8C 49 88 60 01 F6 1C 61 88 60 8A 49 88 60 01 F6 1C 61 88 60 ED E6 00 28 01 D0 00 21 41 60 70 47 2D E9 F0 41 80 48 58 21 80 1D AC F7 8F FA 7D 48 5E 30 EC F7 A8 F9 7B 48 4F F4 3B 71 FE 30 AC F7 85 FA D0 21 7B 48 AC F7 81 FA 79 48 2C 21 D0 30 AC F7 7C FA 77 4C 0E 20 4F F4 6B 71 E0 86 E0 84 04 F1 FC 00 AC F7 72 FA 4F F4 B2 61 04 F5 95 60 AC F7
9:13:33 AM
9:13:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 9C 09 81 80 6C FA B9 F7 3C F9 00 27 A4 F5 79 75 08 B1 2F 70 01 E0 FF 20 28 70 67 48 68 4E 80 1D 6E 60 EF F7 FA FC 02 20 FF F7 A6 FC 18 B3 06 F1 28 00 20 60 05 F0 DE FE A0 60 20 68 4F F4 7A 71 40 89 48 43 C4 F8 84 00 F0 1C C4 F8 C4 70 60 60 5C 48 D0 30 C4 E9 32 50 00 F1 2C 01 6C 64 C0 E9 09 14 C1 F8 A0 03 06 F1 38 00 08 60 01 F5 6B 70 01 60 DF F7 16 FC 01 20 FF F7 7E FC 80 B1 4E 4A 4E 48 5E 32
9:13:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 9D 09 81 80 08 38 16 60 90 60 10 46 FF F7 8C FF 49 48 EA 64 FE 30 C2 F8 9C 50 02 60 EC F7 86 FB BD E8 F0 41 44 49 46 48 89 1D 4F F4 74 42 40 38 0E F0 45 BD 70 B5 58 21 44 48 AC F7 10 FA 43 48 58 30 EC F7 29 F9 41 48 4F F4 3B 71 F8 30 AC F7 06 FA D0 21 3E 48 AC F7 02 FA 3D 48 2C 21 D0 30 AC F7 FD F9 3A 4C 0E 20 4F F4 6B 71 E0 86 E0 84 04 F1 FC 00 AC F7 F3 F9 4F F4 B2 61 04 F5 95 60 AC F7 ED F9
9:13:34 AM
9:13:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 9E 09 81 80 B9 F7 BD F8 30 4D 01 28 05 D9 01 20 28 70 01 46 B9 F7 F4 F8 01 E0 FF 20 28 70 28 4E 02 20 40 36 6E 60 FF F7 27 FC 20 B3 06 F1 28 00 20 60 05 F0 5F FE A0 60 20 68 4F F4 7A 71 40 89 48 43 C4 F8 84 00 F0 1C 60 60 00 20 C4 E9 31 05 1F 48 D0 30 C4 F8 CC 00 00 F1 2C 01 6C 64 C0 E9 09 14 C1 F8 A0 03 06 F1 38 00 08 60 01 F5 6B 70 01 60 DF F7 96 FB 01 20 FF F7 FE FB 80 B1 13 4A 0E 48 58 32
9:13:35 AM
9:13:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 9F 09 81 80 08 38 16 60 90 60 10 46 FF F7 0C FF 0E 48 EA 64 F8 30 C2 F8 9C 50 02 60 EC F7 06 FB BD E8 70 40 06 48 4F F2 01 42 08 49 40 38 0E F0 C6 BC 00 00 1C 7E 00 20 06 3E 00 20 A0 5D 07 00 14 7D 00 20 F0 41 00 20 14 64 00 20 28 4C 00 20 0C 50 00 20 2D E9 F0 47 05 46 58 21 FE 48 AC F7 7E F9 FD 48 4F F4 C4 74 21 46 58 30 AC F7 77 F9 4F F4 86 71 F9 48 AC F7 72 F9 21 46 F8 48 AC F7 6E F9 4F F4
9:13:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A0 09 81 80 E0 71 F7 48 AC F7 69 F9 F6 49 4F F0 00 0A 01 F1 10 00 C1 F8 00 A0 C1 F8 04 A0 C1 F8 08 A0 C1 F8 0C A0 EC F7 77 F8 EF 48 4F F4 3B 71 B0 30 AC F7 54 F9 D0 21 EC 48 AC F7 50 F9 EB 48 2C 21 D0 30 AC F7 4B F9 DF F8 A0 93 0E 21 09 F1 FC 00 A9 F8 36 10 A9 F8 26 10 4F F4 6B 71 AC F7 3E F9 4F F4 B2 61 09 F5 95 60 AC F7 38 F9 4F F4 A4 61 DF 48 AC F7 33 F9 B9 F7 03 F8 02 26 D6 4C 02 28 01 D9
9:13:36 AM
9:13:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A1 09 81 80 26 70 01 E0 FF 20 20 70 D9 4F DF F8 54 83 67 60 28 04 28 D5 38 78 20 72 A7 F5 96 70 C4 E9 14 08 01 46 45 46 40 F6 82 22 6C 30 0E F0 46 FC A8 F2 1C 41 85 F8 78 61 C8 4A 0E 70 C8 48 C1 E9 60 02 C2 F8 08 11 C7 49 C0 F8 7C 21 C1 E9 02 20 C5 F8 BC 11 C0 F8 78 51 C5 F8 B0 41 C5 F8 B8 01 40 46 F1 F7 A3 FD 02 E0 BB 48 EF F7 95 FB 02 20 FF F7 41 FB C8 B3 BE 48 4D 46 28 30 C9 F8 00 00 05 F0
9:13:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A2 09 81 80 77 FD A8 60 28 68 4F F4 7A 71 40 89 48 43 C5 F8 84 00 B7 48 B4 49 C0 1C C5 F8 C4 A0 D0 31 68 60 C5 E9 32 41 01 F1 2C 00 65 64 C1 E9 09 05 C0 F8 A0 13 AF 49 C0 F8 A8 83 38 31 01 60 00 F5 6B 71 C8 F8 B4 01 08 60 A9 49 81 F8 1B 65 C1 F8 10 05 08 46 C0 F8 14 55 FA F7 8B FC A6 49 A3 48 C1 F8 78 05 08 46 DF F7 9B FA 01 20 FF F7 03 FB 80 B1 9C 48 A1 49 10 30 81 60 9D 49 86 31 C0 E9 00 71
9:13:37 AM
9:13:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A3 09 81 80 E0 64 00 F1 A0 01 C0 F8 9C 40 08 60 A0 30 EC F7 0B FA BD E8 F0 47 96 48 4F F2 02 42 8D 49 C0 38 0E F0 CB BB 70 B5 58 21 94 48 AC F7 96 F8 93 48 58 30 EB F7 AF FF 91 48 4F F4 3B 71 F8 30 AC F7 8C F8 D0 21 8E 48 AC F7 88 F8 8D 48 2C 21 D0 30 AC F7 83 F8 8A 48 4F F4 6B 71 FC 30 AC F7 7D F8 4F F4 B2 61 87 48 AC F7 78 F8 85 4C 0E 20 E0 86 E0 84 B8 F7 44 FF 81 4D 03 28 01 D9 03 20 00 E0
9:13:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A4 09 81 80 FF 20 7B 4E 28 70 40 36 7C 48 6E 60 EF F7 03 FB 02 20 FF F7 AF FA 40 B3 06 F1 28 00 20 60 05 F0 E7 FC A0 60 20 68 4F F4 7A 71 40 89 48 43 C4 F8 84 00 F0 1C 00 F1 35 01 60 60 A0 F6 AB 20 01 60 6C 64 04 F1 C4 04 4F F0 00 01 C4 E9 00 15 A0 F1 2C 01 A1 60 A4 F1 C4 04 C1 E9 09 04 C0 F8 A0 13 68 49 08 60 08 46 DF F7 1A FA 01 20 FF F7 82 FA 78 B1 62 4A 60 48 58 32 16 60 90 60 10 46 FF F7
9:13:38 AM
9:13:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A5 09 81 80 91 FD 5E 48 EA 64 F8 30 C2 F8 9C 50 02 60 EC F7 8B F9 BD E8 70 40 59 49 4F F2 03 42 01 F6 88 60 0E F0 4B BB 10 B5 01 21 57 48 DF F7 91 F9 01 21 56 48 DF F7 8D F9 01 21 4E 48 DF F7 89 F9 01 21 50 48 DF F7 85 F9 01 21 51 48 DF F7 81 F9 51 48 EC F7 49 F9 50 48 EC F7 46 F9 42 48 B0 30 EC F7 42 F9 46 48 BD E8 10 40 F8 30 EC F7 3C B9 70 B5 04 46 0D 46 C8 07 05 D0 20 46 E1 F7 EB FC 20 46
9:13:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A6 09 81 80 E1 F7 AE FC 00 20 20 60 4F F4 6B 71 43 48 AB F7 E4 FF 4F F4 B2 61 3E 48 AB F7 DF FF 28 04 02 D5 30 48 C4 F8 D8 00 3D 48 44 F8 D4 0F A0 F1 DC 01 C0 F8 A4 13 36 49 08 60 2D 49 38 31 01 60 4F F4 A4 61 37 48 AB F7 C9 FF 35 49 04 20 81 F8 1B 05 20 68 C1 F8 10 05 54 F8 D4 09 28 B1 D0 F8 A0 03 10 B1 80 6A C1 F8 14 05 2D 48 FA F7 81 FB 28 49 2B 48 C1 F8 78 05 02 20 FF F7 FC F9 28 B1 20 46
9:13:39 AM
9:13:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A7 09 81 80 E2 F7 93 FA 22 48 DF F7 8A F9 01 20 70 BD 70 47 2D E9 F0 41 04 46 FF F7 E5 FC 00 28 7D D0 02 20 FF F7 E8 F9 28 B1 EA F7 D2 FC F1 F7 03 F8 E3 F7 DF FB 0F 48 18 21 88 30 AB F7 8F FF DF F8 64 80 00 25 08 F1 02 00 C8 F8 06 50 88 F8 0A 50 01 88 2A E0 00 00 44 5A 00 20 24 5C 00 20 30 5D 00 20 B8 5E 00 20 78 60 00 20 14 64 00 20 CC 9E 00 10 94 7D 00 20 BC 68 00 20 98 5D 07 00 4C 6E 00 20
9:13:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A8 09 81 80 30 72 00 20 D8 76 00 20 98 46 00 20 B4 54 00 20 3C 99 00 10 04 3F 00 20 20 4D 00 20 90 95 00 10 EC A3 00 10 00 3E 00 20 40 F6 02 02 11 40 01 80 20 46 FF F7 BC FC 20 46 FF F7 3A FD 20 46 FF F7 C7 FD 20 46 FF F7 AE FE FE 48 DC F7 40 F8 E9 F7 1C F8 44 F4 00 41 FC 48 FF F7 49 FF 6C 21 FB 48 AB F7 3B FF F9 48 FA 49 41 66 01 F2 34 61 81 66 0D F0 47 FE E0 07 03 D0 F4 48 6C 30 0E F0 1A FA
9:13:40 AM
9:13:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 A9 09 81 80 F2 48 40 21 6C 30 AB F7 28 FF F2 48 A0 F5 A1 71 48 60 08 46 0E F0 74 FB 00 E0 2B E0 FF F7 02 FF E0 07 04 D1 EB 48 F4 21 1E 30 AB F7 16 FF E7 4F AC 37 07 F5 90 76 B7 F8 00 41 74 B1 4F F4 61 60 44 43 B5 F7 50 F9 03 21 B4 FB F1 F1 B0 FB F1 F2 01 FB 12 00 20 44 30 61 00 E0 35 61 B7 F8 00 01 70 80 35 80 03 F0 47 FD 70 60 07 F0 E2 F8 A8 F8 04 50 01 20 0D E4 10 B5 00 20 FF F7 49 FF 01 20
9:13:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 AA 09 81 80 3F E4 70 B5 D4 4D 06 46 49 B9 CB F7 2F FC 30 B1 CB F7 6F FC 3A 28 09 D2 CB F7 6E FC 30 B1 30 46 FF F7 36 FF BD E8 70 40 CB F7 AE B8 00 24 20 46 FF F7 65 FB 28 42 11 D1 01 2C 04 D0 02 2C 06 D0 03 2C 0B D1 07 E0 30 46 FF F7 B2 FC 06 E0 30 46 FF F7 3E FD 02 E0 30 46 FF F7 24 FE 64 1C E4 B2 04 2C E4 D3 46 F4 00 41 BD E8 70 40 B6 48 BE E6 10 B5 B5 48 E2 F7 10 FA 00 28 00 D0 01 20 10 E4
9:13:41 AM
9:13:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 AB 09 81 80 70 B5 05 46 0A 7A 00 24 01 F1 14 00 06 46 01 2A 01 D0 12 B1 07 E0 02 24 05 E0 01 F1 0C 00 B3 F7 49 FB 18 B9 30 46 B3 F7 45 FB 08 B1 44 F0 01 04 A8 48 80 1D 50 F8 25 10 21 F0 0F 01 21 43 40 F8 25 10 70 BD 10 B5 00 23 D1 F8 A0 43 1A 46 4C B1 A2 6A 3A B1 14 7B 2C B1 01 2C 03 D0 03 2C 01 D0 4F F4 80 53 D1 F8 A4 43 24 B1 24 78 06 2C 01 D1 43 F4 80 53 89 88 04 29 01 D1 43 F4 00 53 52 B1
9:13:42 AM
9:13:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 AC 09 81 80 51 7B CC 07 07 D0 21 F0 01 01 51 73 93 49 0A 5C 42 F0 40 02 0A 54 8F 49 89 1D 51 F8 20 20 22 F4 70 42 1A 43 41 F8 20 20 6A E7 09 7B 00 22 19 B1 01 29 01 D0 4F F4 80 72 86 49 89 1D 51 F8 20 30 23 F4 70 63 13 43 41 F8 20 30 70 47 2D E9 F0 47 7E 4F 00 24 82 4D 80 46 AC 37 42 F2 10 79 B7 F8 02 11 35 F8 34 00 00 26 81 42 03 D0 B7 F8 04 11 81 42 47 D1 B8 F8 30 00 01 28 07 D1 08 F1 30 00
9:13:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 AD 09 81 80 B3 F7 D8 FA 48 45 01 D2 4F F4 00 36 B7 F8 04 01 35 F8 34 10 88 42 0B D1 B8 F8 38 00 01 28 07 D1 08 F1 38 00 B3 F7 C6 FA 48 45 01 D2 46 F4 80 36 35 F8 34 00 4F F2 01 41 42 1A 88 42 0D D0 08 DC A0 F5 20 60 82 38 17 D0 A0 F5 69 40 7E 38 19 D1 03 E0 01 2A 01 D0 02 2A 14 D1 05 EB C4 00 40 68 0E E0 5C 49 00 78 89 1D 51 F8 20 20 22 F4 70 22 32 43 41 F8 20 20 05 E0 05 EB C4 00 40 68 40 6E
9:13:43 AM
9:13:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 AE 09 81 80 00 28 EE D1 64 1C E4 B2 05 2C A8 D3 BD E8 F0 87 2D E9 FE 43 05 46 03 F0 2E FC 4E 4C 06 46 1E 34 60 68 B0 42 00 D1 E5 B3 02 20 02 A9 CD E9 00 01 48 49 C3 01 02 46 89 1E CC F7 91 FF 00 28 2E D0 42 48 61 88 AC 30 B0 F8 00 71 B9 42 21 D0 80 46 00 25 77 B1 4F F4 61 60 47 43 B5 F7 04 F8 03 21 B7 FB F1 F1 B0 FB F1 F2 01 FB 12 00 38 44 20 61 00 E0 25 61 B8 F8 00 01 60 80 00 21 C4 F8 DC 50
9:13:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 AF 09 81 80 01 EB C1 00 04 EB 80 00 49 1C C9 B2 85 62 04 29 F6 D3 30 48 00 1D FF F7 A9 F9 01 20 66 60 BD E8 FE 83 FF E7 00 20 FA E7 70 B5 28 4E 00 24 2B 4D AC 36 28 5D F0 B3 C0 07 08 D0 06 EB 84 11 20 46 FF F7 1C F8 10 B1 20 46 FF F7 45 F8 28 5D 40 07 09 D5 06 EB 84 11 28 31 20 46 FF F7 CD F8 10 B1 20 46 FF F7 38 F8 28 5D 00 07 09 D5 06 EB 84 11 38 31 20 46 FF F7 29 F9 10 B1 20 46 FF F7 2B F8
9:13:44 AM
9:13:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B0 09 81 80 28 5D 40 06 09 D5 06 EB 84 11 28 31 20 46 FF F7 C8 F8 28 5D 20 F0 40 00 28 55 28 5D 00 06 0B D5 06 EB 84 11 38 31 20 46 FF F7 24 F9 28 5D 20 F0 80 00 00 E0 00 E0 28 55 64 1C E4 B2 04 2C B8 D3 00 20 0F E0 B8 5E 00 20 B4 94 00 10 68 7C 00 20 44 5A 00 20 16 7E 00 20 00 11 01 00 06 3E 00 20 D8 5D 07 00 FF F7 54 FF 28 79 C0 07 09 D0 FA 48 FF F7 71 F9 00 28 04 D0 BD E8 70 40 F7 48 0E F0
9:13:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B1 09 81 80 7F B9 70 BD 0E B5 09 B1 00 20 0E BD 02 AA 0C 21 CD E9 00 12 0A 46 01 46 00 23 23 20 CC F7 1F FF 00 28 F2 D0 01 20 0E BD 0E B5 09 B1 00 20 0E BD 02 AA 0C 21 CD E9 00 12 0A 46 01 46 00 23 23 20 CC F7 CD FE 00 28 F2 D0 01 20 0E BD 70 47 01 28 09 D1 E1 48 1E 30 01 88 00 29 04 D1 02 21 A0 F8 CC 10 01 21 01 80 70 47 DD 48 E7 F7 6C B8 10 B5 FF F7 FA FF D8 4C 26 34 02 28 04 D0 20 46 BD E8
9:13:45 AM
9:13:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B2 09 81 80 10 40 B3 F7 8B B9 D4 48 1E 30 00 89 10 B9 20 46 B3 F7 88 F9 02 20 FE F7 64 FF 00 28 20 46 03 D0 BD E8 10 40 B3 F7 7E B9 B3 F7 84 F9 CB 49 40 31 B1 F8 B2 10 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 05 D9 BD E8 10 40 00 21 C6 48 F1 F7 24 B9 D7 E5 30 B4 00 28 02 9C 13 D1 8D 05 02 D4 95 05 00 D5 01 20 89 04 01 D4 91 04 01 D4 00 28 08 D0 13 B1 B4 F5 61 7F 04 D9 30 BC 40 F2 0D 10 06 F0 FB BD
9:13:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B3 09 81 80 30 BC 70 47 2D E9 FF 5F 4F F0 00 08 01 21 68 46 CD F8 0C 80 05 F0 84 FF B3 49 B4 4C 00 25 03 28 18 D0 02 28 16 D0 20 88 20 B1 09 68 02 20 FF F7 6D F8 25 80 00 20 01 90 B4 F7 C1 FE 40 05 20 D5 01 20 DF F8 94 B2 81 46 0B F1 06 0B 00 26 0B F1 18 0A 18 E0 01 20 01 90 9D F8 00 00 01 28 0D D0 02 28 0B D0 04 28 01 D0 05 28 E5 D1 08 68 41 88 21 F4 40 71 41 80 01 20 20 80 DD E7 4F F0 01 08
9:13:46 AM
9:13:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B4 09 81 80 DA E7 05 20 DD E7 9D F8 00 00 FF 28 03 D1 98 48 80 5D 00 28 77 D0 06 EB C6 01 0A EB 81 04 5B F8 26 10 60 69 93 4A 80 EA 01 00 10 40 4F F0 00 07 27 D0 01 EA 00 07 F8 07 04 D0 E0 69 00 F1 01 00 C4 E9 07 05 F8 06 04 D5 E0 69 00 F1 01 00 C4 E9 07 05 F8 05 04 D5 60 6A 00 F1 01 00 C4 E9 09 05 B8 04 04 D5 60 6A 00 F1 01 00 C4 E9 09 05 F8 03 03 D5 60 6A 40 1C C4 E9 09 05 61 61 B3 F7 BE F8
9:13:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B5 09 81 80 18 E0 B3 F7 BB F8 61 6B 41 1A B1 F5 7A 7F 12 D9 5B F8 26 10 11 F0 11 0F 02 D1 22 6A 52 1C 22 62 74 4A 11 3A 11 42 05 D1 A1 6A 49 1C A1 62 21 6B 49 1C 21 63 60 63 69 48 40 30 B0 F8 00 11 01 B9 A5 62 B0 F8 04 11 6A 48 48 30 30 F8 36 00 81 42 03 D1 F8 03 01 D5 01 20 03 90 A0 6A 57 46 01 2E 03 D0 02 2E 10 D0 04 2E 32 D0 39 69 49 1D 81 42 2E D2 02 A8 B3 F7 73 F8 01 2E 0C D0 02 2E 0F D0
9:13:47 AM
9:13:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B6 09 81 80 03 2E 24 D1 1B E0 23 E0 D7 F8 B8 10 81 42 00 D9 01 46 08 46 E9 E7 01 20 FF F7 CA F9 F9 20 14 E0 01 98 A0 B1 B8 F1 01 0F 4F F0 01 00 03 D0 FF F7 4F FA FA 20 09 E0 A7 F8 CC 00 38 80 F9 E7 01 98 28 B1 01 20 FF F7 2E FB FB 20 06 F0 14 FD A5 62 76 1C F6 B2 4E 45 FF F4 3C AF 00 26 44 4B 01 22 9D F8 00 00 FF 28 01 D1 98 5C 18 B1 10 46 FF F7 46 F8 06 43 52 1C D2 B2 04 2A F1 D3 9D F8 00 00
9:13:48 AM
9:13:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B7 09 81 80 FF 28 02 D1 98 5C 01 28 02 D1 DB F8 10 00 06 43 03 99 06 F4 88 50 50 EA 01 09 06 D0 0A F1 DC 04 25 60 B3 F7 2B F8 E0 60 0E E0 B3 F7 27 F8 DA F8 E8 20 51 46 82 1A B2 F5 7A 7F 05 D9 51 F8 DC 2F 52 1C 0A 60 CA F8 E8 00 24 48 40 30 B0 F8 00 01 08 B9 CA F8 DC 50 DA F8 10 10 DA F8 DC 00 54 46 88 42 12 D9 40 46 FF F7 72 FE 19 20 06 F0 C3 FC 00 20 C4 F8 DC 50 00 BF 00 EB C0 01 04 EB 81 01
9:13:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B8 09 81 80 40 1C C0 B2 8D 62 04 28 F6 D3 22 88 14 48 DF F8 54 A0 04 27 18 49 47 F2 30 5B 01 91 05 2A 71 D2 DF E8 02 F0 71 03 2F 44 46 00 02 21 50 46 F0 F7 B2 FF 20 B1 01 98 B2 F7 F5 FF 02 20 09 E0 B4 F8 EC 00 00 28 01 98 19 D0 B2 F7 F4 FF 58 45 5A D9 03 20 20 80 57 E0 00 00 16 7E 00 20 D4 7C 00 20 30 5D 00 20 B8 5E 00 20 10 65 00 20 00 3E 00 20 90 5D 07 00 11 21 01 00 20 7F 00 20 B2 F7 D2 FF
9:13:49 AM
9:13:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 B9 09 81 80 41 E0 50 46 F0 F7 85 FE 05 28 01 98 0C D0 B2 F7 D1 FF 58 45 37 D9 01 98 B2 F7 C0 FF 01 21 50 46 F0 F7 2C FF 27 80 2E E0 B2 F7 B8 FF 00 21 F6 E7 E6 F7 77 FE 10 BB B4 F8 CC 10 48 F2 01 00 01 29 0B D0 B9 F1 00 0F 1B D0 5F F0 00 01 B8 F1 01 0F 00 D0 01 20 FF F7 15 FC 0D E0 B8 F1 01 0F 03 D0 01 20 FF F7 75 F9 06 E0 07 46 FF F7 71 F9 39 46 D4 48 FF F7 FC FA 25 80 A4 F8 CC 50 03 E0 01 E0
9:13:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 BA 09 81 80 01 21 E3 E7 25 80 FF F7 F2 FD FF F7 4D FD 02 F0 FA F8 18 B1 02 F0 DA F8 FF F7 C4 FA 41 F2 11 10 06 42 10 D1 CB F7 22 F8 10 B9 40 46 FF F7 CF FD CB F7 5F F8 3A 28 06 D2 CB F7 5E F8 00 28 02 D0 40 46 FF F7 C4 FD BD E8 FF 9F 70 47 70 47 70 B5 BD 4C 20 88 80 07 27 D4 A5 1E A8 88 C0 07 06 D0 F9 F7 83 FA 03 28 0B D0 04 28 13 D0 1C E0 05 20 F9 F7 A1 FA A8 88 40 F0 01 00 A8 80 20 88 06 E0
9:13:50 AM
9:13:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 BB 09 81 80 A8 88 20 F0 01 00 A8 80 20 88 40 F0 02 00 20 F4 00 60 08 E0 A8 88 20 F0 01 00 A8 80 20 88 40 F0 02 00 40 F4 00 60 20 80 01 20 70 BD 02 46 A2 F5 7E 42 08 46 05 3A 02 D0 00 21 01 60 70 47 0C F0 8B BE 02 46 A2 F5 7E 42 08 46 05 3A 02 D0 00 21 01 60 70 47 0C F0 8D BE 38 B5 01 21 68 46 05 F0 5F FD 00 25 04 46 03 28 01 D0 02 2C 14 D1 9D F8 00 00 01 28 01 D0 02 28 00 D1 01 25 03 2C 0B D1
9:13:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 BC 09 81 80 3D B1 48 F2 01 00 FF F7 E3 F8 90 48 DB F7 5F FB 02 E0 01 20 FF F7 DC F8 8D 49 00 20 08 60 8A 48 0A 30 EE F7 12 FE 88 49 00 20 0A 31 FF F7 A8 FB 02 20 FE F7 9F FC 90 B1 86 48 EA F7 C5 FA 85 48 D0 30 F0 F7 3D FB 83 48 FC 30 E4 F7 64 FA 81 49 00 20 FC 31 FF F7 B6 FB 7F 48 E0 F7 68 FE 01 20 FE F7 88 FC 58 B1 78 48 62 30 EB F7 CB FA 76 49 00 20 62 31 FF F7 D9 FB 78 48 EE F7 0B FC B4 F7
9:13:51 AM
9:13:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 BD 09 81 80 5E FC 40 05 2E D4 76 48 EE F7 DF FD 74 49 01 20 FF F7 76 FB 02 20 FE F7 6D FC 90 B1 71 48 EA F7 93 FA 70 48 D0 30 F0 F7 0B FB 6E 48 FC 30 E4 F7 32 FA 6D 48 E0 F7 3B FE 6A 49 01 20 FC 31 FF F7 81 FB 01 20 FE F7 56 FC 60 B1 65 48 58 30 EB F7 99 FA 63 48 F8 30 EE F7 DD FB 61 49 01 20 58 31 FF F7 A3 FB B4 F7 2B FC 40 05 37 D4 ED B3 5F 48 F2 F7 AF F9 5E 48 CE F7 91 F9 5E 48 E7 F7 00 FD
9:13:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 BE 09 81 80 52 48 F0 F7 CE FE 5C 48 0C F0 CD FF 02 20 FE F7 31 FC 90 B1 59 48 EA F7 57 FA 58 48 D0 30 F0 F7 CF FA 56 48 FC 30 E4 F7 F6 F9 55 48 E0 F7 FF FD 52 49 02 20 FC 31 FF F7 45 FB 01 20 FE F7 1A FC 60 B1 4D 48 10 30 EB F7 5D FA 4B 48 B0 30 EE F7 A1 FB 49 49 02 20 10 31 FF F7 67 FB B4 F7 EF FB 40 05 43 D4 03 2C 0F D0 11 E0 FF E7 03 2C 01 D0 02 2C CB D1 3D 48 58 38 EE F7 67 FD 3B 49 02 20
9:13:52 AM
9:13:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 BF 09 81 80 58 39 FF F7 FD FA C1 E7 01 20 FF F7 0B F9 3D 48 EE F7 5B FD 3B 49 03 20 FF F7 F2 FA 02 20 FE F7 E9 FB 90 B1 38 48 EA F7 0F FA 37 48 D0 30 F0 F7 87 FA 35 48 FC 30 E4 F7 AE F9 34 48 E0 F7 B7 FD 31 49 03 20 FC 31 FF F7 FD FA 01 20 FE F7 D2 FB 60 B1 2C 48 58 30 EB F7 15 FA 2A 48 F8 30 EE F7 59 FB 28 49 03 20 58 31 FF F7 1F FB B4 F7 A7 FB 40 05 21 D4 0D B1 DB F7 84 FA E8 F7 B2 F9 02 20
9:13:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C0 09 81 80 FE F7 B8 FB 70 B1 0F 48 E1 F7 3C FE 0D 48 DC 30 E4 F7 81 F9 1E 48 E0 F7 8A FD 0A 49 04 20 DC 31 FF F7 D0 FA 1B 48 0D F0 42 FD 1A 48 FF F7 0E FB 18 48 6C 38 0D F0 B5 FB FF F7 A4 FC FF F7 87 FE 38 BD 00 00 B4 94 00 10 02 3E 00 20 B8 5E 00 20 1C 7E 00 20 F0 41 00 20 98 46 00 20 04 3F 00 20 28 4C 00 20 0C 50 00 20 B4 54 00 20 9C 5A 00 20 24 5C 00 20 30 5D 00 20 78 60 00 20 14 64 00 20
9:13:53 AM
9:13:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C1 09 81 80 BC 68 00 20 4C 6E 00 20 30 72 00 20 D8 76 00 20 3C 99 00 10 D4 7C 00 20 0E B5 02 A9 40 F2 3A 22 CD E9 00 21 01 46 00 23 1A 20 CC F7 D8 FA 0E BD 70 B5 05 46 02 F0 5F FF FE 4E 04 46 70 68 A0 42 00 D1 5D B1 FB 48 08 30 FF F7 E6 FF F0 22 FA 49 D0 20 CC F7 65 FD 01 20 74 60 70 BD 00 20 70 BD 00 28 11 D0 01 78 FF 29 01 D0 17 29 0B D8 41 78 FF 29 01 D0 3B 29 06 D8 81 78 FF 29 01 D0 3B 29
9:13:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C2 09 81 80 01 D8 C0 78 08 B1 00 20 70 47 01 20 70 47 EB 4A 00 21 00 BF 02 EB 81 03 5B 88 83 42 02 D1 12 F8 21 00 70 47 49 1C C9 B2 05 29 F3 D3 05 20 70 47 0E B5 05 28 01 D3 00 20 0E BD 72 22 00 FB 02 F3 02 AA 72 20 CD E9 00 02 02 46 1A 20 CC F7 87 FA 0E BD 3E B5 02 A9 40 F2 3A 22 CD E9 00 21 00 24 01 46 23 46 1A 20 CC F7 BA FA 18 B1 01 20 FF F7 9F FF 04 46 20 46 3E BD 0E B5 0B 46 11 46 03 EB
9:13:54 AM
9:13:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C3 09 81 80 C3 02 C0 EB C0 03 C3 EB 80 10 02 EB 40 00 80 1D 83 B2 02 AA 09 20 CD E9 00 02 02 46 1A 20 CC F7 9E FA 0E BD 2D E9 F0 47 00 25 AD F5 10 7D A9 46 4F F6 FF 7A E8 46 01 27 C5 EB C5 00 C0 EB 85 11 08 EB 41 06 00 24 37 71 A6 F8 02 90 28 F8 11 A0 04 EB C4 00 30 44 80 1D FF 22 09 21 AB F7 D1 FD 64 1C E4 B2 0C 2C F3 D3 6D 1C ED B2 77 71 05 2D E2 D3 68 46 FF F7 AD FF 0D F5 10 7D BD E8 F0 87
9:13:55 AM
9:13:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C4 09 81 80 10 B5 AD F5 0C 7D 04 46 00 20 8B 90 CC 22 53 A9 89 A8 B2 F7 41 FE 4F F4 A6 71 68 46 AB F7 5D F8 A0 B2 DC F7 BD FE 00 28 20 D0 D0 F8 02 10 CD F8 1A 12 C1 88 AD F8 1E 12 00 7A AD F8 18 02 01 20 8D F8 20 02 86 A9 68 46 DC F7 5B FF 00 28 0D D0 06 20 8D F8 B8 00 20 0C AD F8 BC 00 89 AA 8B A9 68 46 D8 F7 E9 FB 00 28 00 D0 01 20 0D F5 0C 7D 10 BD F0 B5 BD B0 B4 F7 62 FA 40 05 1D D4 B4 F7
9:13:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C5 09 81 80 5E FA 40 07 19 D5 FF F7 8D FF 00 25 6F 46 05 EB 45 00 00 24 07 EB 00 16 06 EB 84 00 B2 F7 9F FC 64 1C E4 B2 0C 2C F7 D3 6D 1C ED B2 05 2D EE D3 F0 22 69 46 D0 20 CC F7 A8 FA 01 20 FF F7 F8 FE 3D B0 F0 BD 30 B5 8F B0 0A 46 04 46 FF F7 08 FF 00 28 3F D0 05 A9 10 46 B2 F7 DC FB 00 28 39 D0 03 AA 08 A9 05 A8 B2 F7 55 FC 00 28 32 D0 60 79 0B AA 60 F3 07 05 20 79 69 46 60 F3 0F 25 AD F8
9:13:56 AM
9:13:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C6 09 81 80 00 50 A0 79 8D F8 02 00 E0 79 8D F8 03 00 20 7A 8D F8 04 00 20 78 8D F8 05 00 60 78 8D F8 06 00 A0 78 8D F8 07 00 00 20 AD F8 08 00 08 A8 B9 F7 F5 FA 00 28 0E D0 BD F8 0C 20 05 A9 0B A8 B2 F7 EE FB 00 28 06 D0 04 A9 05 A8 B2 F7 07 FB 00 28 00 D0 04 98 0F B0 30 BD 30 B5 03 46 00 20 5D 79 65 F3 07 04 1D 79 65 F3 0F 24 A4 B2 A4 F5 7F 45 FF 3D 00 D1 08 20 9C 79 FF 2C 01 D1 40 F0 04 00
9:13:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C7 09 81 80 DC 79 FF 2C 01 D1 40 F0 02 00 1B 7A FF 2B 01 D1 40 F0 01 00 0C 28 02 D0 08 28 06 D0 0A E0 FE 2C 01 D0 FD 2C 06 D1 0D 20 04 E0 FE 2C 01 D0 FD 2C 00 D1 09 20 41 4B 14 33 53 F8 30 40 0C 60 03 EB C0 01 49 68 11 60 30 BD 2D E9 F0 43 97 B0 00 24 0D 46 17 46 06 46 12 94 A1 46 05 AA 08 A9 04 94 FF F7 BA FF 10 28 6B D2 DF E8 00 F0 C8 C8 C8 C8 C8 C8 C8 C8 08 96 08 08 96 96 96 96 14 A9 28 46
9:13:57 AM
9:13:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C8 09 81 80 B2 F7 48 FB 13 AA 0F A9 14 A8 B2 F7 C3 FB 01 94 02 94 0A 94 03 94 0B 94 0C 94 9D F8 3E C0 B1 79 00 24 01 20 8C 45 0B D9 BD F8 3C 10 AD F8 04 10 B2 79 8D F8 06 20 8D F8 07 00 AD F8 28 10 11 E0 16 D2 BD F8 3C 10 A1 F1 01 02 92 B2 AD F8 04 20 B3 79 8D F8 06 30 8D F8 07 00 B3 79 0C 2B 4E D0 AD F8 28 20 B1 79 49 1C 8D F8 2A 10 8D F8 2B 00 B1 79 8C 45 15 D1 BD F8 3C 10 AD F8 04 10 B2 79
9:13:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 C9 09 81 80 8D F8 06 20 8D F8 07 00 B2 79 0C 2A 3C D0 49 1E AD F8 28 10 B1 79 49 1C 8D F8 2A 10 8D F8 2B 00 2C 46 BD F8 4C 20 14 A9 01 A8 B2 F7 38 FB 12 A9 14 A8 06 E0 58 7B 00 10 9C 7D 00 10 04 5E 07 00 5C E0 B2 F7 4B FA BD F8 4C 20 14 A9 0A A8 B2 F7 26 FB 04 A9 14 A8 B2 F7 41 FA D4 B1 DD F8 10 90 04 95 21 46 30 46 FF F7 ED FE 38 60 20 B1 A8 42 02 D8 04 99 88 42 17 D9 05 98 28 1A 1B E0 AD F8
9:13:58 AM
9:13:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 CA 09 81 80 28 10 8D F8 2A 00 B1 E7 AD F8 28 10 8D F8 2A 00 C4 E7 04 9C 64 1E E4 E7 29 46 30 46 FF F7 D2 FE 38 60 28 B1 A8 42 03 D8 01 20 17 B0 BD E8 F0 83 05 98 2C 46 28 1A 80 46 1E E0 08 98 24 1A 21 46 30 46 FF F7 BF FE 12 99 89 B1 04 9A 7A B1 18 B1 A8 42 01 D8 90 42 0D D9 8C 42 0D D2 48 46 4C 45 0A D9 04 46 04 90 05 98 08 1A 12 90 04 E0 18 B1 A8 42 01 D8 38 60 D7 E7 44 45 DE D8 00 20 D4 E7
9:13:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 CB 09 81 80 2D E9 F0 41 96 B0 00 24 0E 46 17 46 14 94 05 46 09 AA 04 A9 0A 94 FF F7 DF FE 10 28 71 D2 DF E8 00 F0 BC BC BC BC BC BC BC BC 08 8B 08 08 8B 8B 8B 8B 0E A9 30 46 B2 F7 6D FA 15 AA 11 A9 0E A8 B2 F7 E8 FA 02 94 01 94 07 94 03 94 05 94 06 94 9D F8 46 20 A9 79 00 24 01 20 8A 42 0B D9 BD F8 44 10 01 F1 01 01 AD F8 04 10 AB 79 8D F8 06 30 8D F8 07 00 0C E0 13 D2 BD F8 44 10 AD F8 04 10
9:13:59 AM
9:13:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 CC 09 81 80 AB 79 8D F8 06 30 8D F8 07 00 AB 79 0C 2B 39 D0 AD F8 14 10 A9 79 49 1C 8D F8 16 10 8D F8 17 00 A9 79 8A 42 17 D1 BD F8 44 10 4A 1C 92 B2 AD F8 04 20 AB 79 8D F8 06 30 8D F8 07 00 AB 79 0C 2B 26 D0 AD F8 14 10 A9 79 49 1C 8D F8 16 10 00 BF 8D F8 17 00 34 46 BD F8 54 20 0E A9 01 A8 B2 F7 5E FA 14 A9 0E A8 B2 F7 79 F9 BD F8 54 20 0E A9 05 A8 B2 F7 54 FA 0A A9 0E A8 B2 F7 6F F9 64 B1
9:13:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 CD 09 81 80 0C E0 4A E0 49 1C AD F8 14 10 8D F8 16 00 C5 E7 AD F8 14 20 8D F8 16 00 DA E7 14 9C 28 46 21 46 FF F7 10 FE 38 60 20 B1 B0 42 02 D9 0A 99 88 42 0A D3 09 98 30 44 0E E0 31 46 28 46 FF F7 02 FE 38 60 28 B1 B0 42 03 D9 01 20 16 B0 BD E8 F0 81 09 98 34 46 30 44 80 46 1D E0 04 98 04 44 21 46 28 46 FF F7 EF FD 14 9A 82 B1 0A 99 71 B1 18 B1 86 42 01 D2 88 42 0C D3 8C 42 0C D9 94 42 0A D2
9:14:00 AM
9:14:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 CE 09 81 80 04 98 14 1A 09 98 08 44 0A 90 04 E0 18 B1 B0 42 01 D9 38 60 D8 E7 44 45 DF D3 00 20 D5 E7 2D E9 F8 4F 05 46 05 28 4F F0 00 00 57 D2 FF F7 C0 FC C5 EB C5 00 B0 49 C0 EB 85 10 01 EB 40 07 4F F0 00 0B 7E 79 05 EB 45 00 01 F5 0F 71 D8 46 01 EB 00 19 0C 2E 00 D3 0C 26 4F F0 00 0A 68 46 B2 F7 3E FA 00 24 2E E0 00 BF 04 EB C4 00 38 44 80 1D 00 99 FF F7 A7 FD 18 B3 59 F8 24 10 81 42 06 D9
9:14:01 AM
9:14:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 CF 09 81 80 00 9A 91 42 03 D9 49 F8 24 20 4F F0 01 08 00 99 81 42 15 D3 59 F8 24 10 81 42 11 D2 97 49 49 F8 24 00 BA F1 00 0F 41 F8 25 00 A1 F5 4D 70 05 70 06 D1 38 68 FF F7 24 FD 4F F0 01 08 C3 46 C2 46 64 1C E4 B2 B4 42 CF D3 B8 F1 00 0F 05 D0 8B 49 F0 22 F0 39 D0 20 CC F7 18 F8 58 46 BD E8 F8 8F 2D E9 F7 4F 8C B0 04 46 92 46 05 28 6F D2 00 20 FF F7 5E FC C4 EB C4 00 7F 49 C0 EB 84 10 01 EB
9:14:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D0 09 81 80 40 09 04 EB 44 00 99 F8 05 50 01 F5 0F 71 01 EB 00 1B 0C 2D 00 D3 0C 25 00 26 B0 46 37 46 30 E0 00 20 07 EB C7 01 05 90 01 EB 09 00 0A 90 80 1D 03 AA 0D 99 FF F7 A4 FE 58 B9 0A 98 0D 99 80 1D FF F7 40 FD 03 90 D0 B1 0D 99 88 42 17 D3 01 20 05 90 03 99 8A 45 0B D2 05 98 58 B9 0A 98 0B AA 80 1D 0D 99 FF F7 B0 FD 48 B1 0B 99 8A 45 01 D2 4F F0 01 08 16 B1 03 98 B0 42 00 D2 03 9E 7F 1C
9:14:02 AM
9:14:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D1 09 81 80 FF B2 AF 42 CC D3 5D 4F 5F EA 08 00 A7 F5 4D 78 18 D0 BE B1 47 F8 24 60 88 F8 00 40 D9 F8 00 00 FF F7 AE FC 01 A8 B2 F7 9A F9 00 20 04 E0 01 9A 4B F8 20 20 40 1C C0 B2 A8 42 F8 D3 01 98 47 F8 24 00 0D E0 0D 99 8A 45 12 D2 00 20 04 E0 0F E0 4B F8 20 A0 40 1C C0 B2 A8 42 F9 D3 47 F8 24 A0 46 49 88 F8 00 40 F0 22 F0 39 D0 20 CB F7 8D FF 0F B0 BD E8 F0 8F 70 B5 05 46 0E 46 00 24 32 46
9:14:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D2 09 81 80 29 46 20 46 FF F7 6C FF 64 1C E4 B2 05 2C F6 D3 70 BD 70 B5 04 46 0D 46 05 28 2B D2 00 20 FF F7 C7 FB C4 EB C4 00 34 49 C0 EB 84 10 33 4A 01 EB 40 00 04 EB 44 01 F0 3A 02 EB 01 11 42 79 0C 2A 01 D2 00 20 06 E0 0C 22 5F F0 00 00 41 F8 20 50 40 1C C0 B2 90 42 F9 D3 28 48 F0 22 40 F8 24 50 A0 F5 4D 70 00 F5 11 71 04 70 BD E8 70 40 D0 20 CB F7 4B BF 70 BD 38 B5 04 46 05 28 4F F0 00 00
9:14:03 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:14:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D3 09 81 80 16 D2 FF F7 95 FB 68 46 B2 F7 29 F9 1B 49 00 98 41 F8 24 00 A1 F5 4D 70 17 49 04 70 C4 EB C4 00 C0 EB 84 10 01 EB 40 00 00 68 FF F7 29 FC 01 20 38 BD 11 48 08 38 00 78 05 28 03 D2 0F 49 51 F8 20 00 70 47 00 20 70 47 93 42 0D D8 00 EB 40 02 0A 48 F0 38 00 EB 02 10 50 F8 21 20 9A 42 03 D2 40 F8 21 30 01 20 70 47 00 20 70 47 03 49 F0 22 F0 39 D0 20 CB F7 09 BF 60 7B 00 10 8C 7E 00 10
9:14:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D4 09 81 80 F8 4A 00 21 32 F8 31 30 83 42 02 D1 02 EB C1 00 70 47 49 1C 14 29 F5 D3 00 20 70 47 70 B5 0D 46 04 46 40 F2 42 71 AA F7 7F FC 00 22 ED 48 01 23 30 F8 32 10 A9 42 12 D1 00 EB C2 00 81 88 21 80 00 21 08 E0 01 EB 41 02 C2 EB 41 12 04 EB 42 02 49 1C 53 80 C9 B2 82 88 8A 42 F3 D8 05 E0 52 1C D2 B2 14 2A E4 D3 23 80 63 80 01 20 70 BD 10 B5 04 46 40 F2 42 71 AA F7 57 FC 01 20 20 80 60 80
9:14:04 AM
9:14:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D5 09 81 80 47 F2 0F 00 E0 80 02 20 20 71 43 F2 01 00 20 81 00 20 A0 72 01 20 10 BD 10 B5 04 46 40 F2 42 71 AA F7 42 FC 02 20 20 80 01 21 61 80 4F F6 08 72 E2 80 20 71 43 F2 01 02 22 81 00 23 A3 72 A1 87 4F F6 10 71 A4 F8 40 10 84 F8 3E 00 A4 F8 42 20 84 F8 44 30 01 20 10 BD 70 B5 04 46 40 F2 42 71 AA F7 22 FC 08 20 20 80 01 20 60 80 4F F6 0F 71 E1 80 02 21 21 71 43 F2 01 02 22 81 00 23 A3 72
9:14:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D6 09 81 80 A0 87 4F F6 17 75 A4 F8 40 50 84 F8 3E 10 A4 F8 42 20 84 F8 44 30 A4 F8 76 00 4F F6 88 75 A4 F8 7A 50 84 F8 78 10 A4 F8 7C 20 84 F8 7E 30 A4 F8 B0 00 4F F6 90 75 A4 F8 B4 50 84 F8 B2 10 A4 F8 B6 20 84 F8 B8 30 A4 F8 EA 00 ED 1F A4 F8 EE 50 84 F8 EC 10 A4 F8 F0 20 84 F8 F2 30 A4 F8 24 01 4F F6 91 75 A4 F8 28 51 84 F8 26 11 A4 F8 2A 21 84 F8 2C 31 A4 F8 5E 01 ED 1F A4 F8 62 51 84 F8
9:14:05 AM
9:14:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D7 09 81 80 60 11 A4 F8 64 21 84 F8 66 31 A4 F8 98 01 4F F6 92 70 A4 F8 9C 01 84 F8 9A 11 A4 F8 9E 21 84 F8 A0 31 01 20 70 BD 10 B5 04 46 40 F2 42 71 AA F7 BB FB 02 20 20 80 01 21 61 80 4F F6 08 22 E2 80 20 71 43 F2 01 02 22 81 00 23 A3 72 A1 87 4F F6 10 21 A4 F8 40 10 84 F8 3E 00 A4 F8 42 20 84 F8 44 30 01 20 10 BD 02 46 08 46 B2 F5 10 4F 07 D0 A2 F5 10 42 80 3A 04 D0 85 2A 03 D0 00 20 70 47
9:14:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D8 09 81 80 35 E7 49 E7 CF E7 70 B5 04 46 40 F2 42 71 AA F7 8B FB 20 20 00 21 20 80 0B 46 01 20 46 F2 20 05 48 F2 02 06 01 EB 41 02 C2 EB 41 12 04 EB 42 02 49 1C 50 80 10 71 D5 80 D1 72 16 81 89 B2 93 72 20 29 EF D3 01 20 70 BD 10 B5 04 46 40 F2 42 71 AA F7 6A FB 08 20 00 21 20 80 01 22 43 F2 01 03 01 EB 41 00 C0 EB 41 10 04 EB 40 00 49 1C 42 80 C9 B2 03 81 08 29 F3 D3 01 20 10 BD 2D E9 F0 47
9:14:06 AM
9:14:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 D9 09 81 80 81 46 0E 46 00 88 89 88 A4 B0 88 42 00 D3 08 46 AD F8 08 00 00 24 0D F1 08 0A 23 E0 04 EB 44 00 C0 EB 44 11 09 EB 41 08 F1 88 B8 F8 02 00 88 42 00 D3 08 46 0A EB 04 17 00 25 78 80 0D E0 00 BF C5 EB C5 00 08 EB 40 01 07 EB 40 00 09 1D 00 1D 0E 22 AA F7 65 FA 6D 1C ED B2 78 88 A8 42 EF D8 64 1C E4 B2 BD F8 08 00 A0 42 D7 D8 82 20 23 A9 CD E9 00 01 02 46 73 88 02 A9 10 20 CB F7 EF FC
9:14:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 DA 09 81 80 00 28 00 D0 01 20 24 B0 BD E8 F0 87 2D E9 F0 47 81 46 0E 46 00 88 89 88 AD F5 EA 6D 88 42 00 D3 08 46 AD F8 08 00 00 25 0D F1 08 0A 24 E0 00 BF 05 EB 45 00 C0 EB 45 12 09 EB 42 08 F1 88 B8 F8 02 00 88 42 00 D3 08 46 0A EB 42 07 00 24 78 80 0D E0 00 BF C4 EB C4 00 08 EB 40 01 07 EB 40 00 09 1D 00 1D 0E 22 AA F7 1B FA 64 1C E4 B2 78 88 A0 42 EF D8 6D 1C ED B2 BD F8 08 00 A8 42 D7 D8
9:14:07 AM
9:14:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 DB 09 81 80 0D F2 4C 70 40 F2 42 72 CD E9 00 20 73 88 02 A9 10 20 CB F7 A4 FC 00 28 00 D0 01 20 0D F5 EA 6D B2 E7 70 B5 05 46 0C 46 08 46 FF F7 29 FE 01 00 08 D0 48 88 A0 F5 7F 42 FF 3A 03 D0 28 88 8A 88 90 42 01 D9 00 20 70 BD 6F F4 10 40 20 18 04 D0 A0 F5 80 70 83 38 0C D1 06 E0 28 46 FF F7 96 FF 05 E0 00 00 98 5E 07 00 28 46 FF F7 47 FF 00 28 E9 D0 01 20 70 BD 10 B5 04 46 FF F7 04 FF 00 28
9:14:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 DC 09 81 80 13 D0 49 F2 01 01 20 46 FF F7 CB FF 00 28 0C D0 20 46 FF F7 19 FF 00 28 07 D0 49 F2 84 11 20 46 FF F7 BF FF 00 28 00 D0 01 20 10 BD 2D E9 F0 43 AD F2 54 7D 06 46 0D F2 4C 70 40 F2 42 72 CD E9 00 20 4B 88 02 A9 10 20 CB F7 09 FC 00 28 2B D0 BD F8 08 00 30 80 00 25 0D F1 08 09 20 E0 00 BF 05 EB 45 00 C0 EB 45 10 09 EB 40 08 06 EB 40 07 B8 F8 02 10 79 80 00 24 0D E0 00 BF C4 EB C4 00
9:14:08 AM
9:14:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 DD 09 81 80 08 EB 40 01 07 EB 40 00 09 1D 00 1D 0E 22 AA F7 87 F9 64 1C E4 B2 78 88 A0 42 EF D8 6D 1C ED B2 30 88 A8 42 DC D8 01 20 0D F2 54 7D BD E8 F0 83 2D E9 F0 43 A5 B0 06 46 23 AA 82 20 CD E9 00 02 4B 88 02 46 02 A9 10 20 CB F7 C9 FB 00 28 2B D0 BD F8 08 00 30 80 00 24 0D F1 08 09 20 E0 00 BF 04 EB 44 01 09 EB 04 18 C1 EB 44 11 06 EB 41 07 B8 F8 02 00 78 80 00 25 0D E0 00 BF C5 EB C5 00
9:14:09 AM
9:14:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 DE 09 81 80 08 EB 40 01 07 EB 40 00 09 1D 00 1D 0E 22 AA F7 47 F9 6D 1C ED B2 78 88 A8 42 EF D8 64 1C E4 B2 30 88 A0 42 DC D8 01 20 25 B0 BF E7 70 B5 05 46 0C 46 08 46 FF F7 64 FD 01 00 04 D0 48 88 A0 F5 7F 42 FF 3A 01 D1 00 20 70 BD A0 F5 7F 42 FE 3A 04 D1 29 46 20 46 FF F7 46 FE 0F E0 6F F4 10 40 20 18 04 D0 A0 F5 80 70 83 38 09 D1 03 E0 28 46 FF F7 5C FF 02 E0 28 46 FF F7 9A FF 00 28 E3 D0
9:14:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 DF 09 81 80 01 20 70 BD 10 B5 0A 88 10 23 B3 EB D2 2F 00 D1 DA 02 44 F2 02 04 13 1B A2 42 22 D0 0E DC 01 2A 23 D0 A2 F5 80 52 02 3A 21 D0 A2 F5 80 52 02 3A 1F D0 A2 F5 70 62 FD 3A 0F D1 10 E0 A3 F5 80 53 02 3B 10 D0 A3 F5 70 63 FD 3B 16 D0 B3 F5 80 5F 11 D0 A3 F5 F8 53 FF 3B 1A D0 00 20 10 BD 02 22 0C E0 03 22 0A E0 04 22 08 E0 05 22 06 E0 06 22 04 E0 07 22 02 E0 09 22 00 E0 0A 22 00 F8 04 2B
9:14:10 AM
9:14:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E0 09 81 80 31 F8 02 2B C2 F3 0A 02 AA F7 CA F8 01 20 10 BD 16 22 02 70 0A 88 C2 F3 0A 02 82 80 31 F8 02 2B 80 1D C2 F3 0A 02 EF E7 10 B5 0C 46 03 46 01 1D 00 78 4F F6 FF 72 06 28 1D D0 08 DC 02 28 0F D0 03 28 10 D0 04 28 11 D0 05 28 28 D1 11 E0 07 28 14 D0 09 28 15 D0 0A 28 16 D0 16 28 1F D1 16 E0 43 F2 01 00 1D E0 44 F2 02 00 1A E0 45 F2 04 00 17 E0 01 20 15 E0 41 F2 02 00 12 E0 42 F2 04 00
9:14:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E1 09 81 80 0F E0 47 F2 01 00 0C E0 46 F2 01 00 09 E0 98 88 08 28 04 D8 99 1D 40 F4 00 40 90 42 01 D1 00 20 10 BD 20 80 C0 F3 0A 02 A0 1C AA F7 79 F8 01 20 10 BD 01 29 06 D0 02 29 09 D0 03 29 0F D0 04 29 0B D1 11 E0 B0 F8 48 11 41 F0 02 01 03 E0 B0 F8 48 11 41 F0 04 01 A0 F8 48 11 01 20 70 47 B0 F8 48 11 41 F0 08 01 F6 E7 B0 F8 48 11 41 F0 10 01 F1 E7 00 B5 AD F2 44 7D 68 46 FF F7 7C FE 00 28
9:14:11 AM
9:14:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E2 09 81 80 00 D0 01 20 0D F2 44 7D 00 BD 2D E9 F0 41 05 46 AD F5 EA 6D 80 8D FF F7 73 FC 06 00 15 D0 A9 8D 68 46 FF F7 03 FF 00 28 10 D0 95 F8 B8 00 06 28 0B D1 B5 F8 BC 00 BD F8 00 10 40 1E B2 88 80 B2 91 42 00 D3 11 46 88 42 04 D3 00 20 0D F5 EA 6D BD E8 F0 81 00 EB 40 01 C1 EB 40 11 68 46 00 EB 41 07 F0 88 7C 88 84 42 00 D3 04 46 00 26 3D E0 C6 EB C6 00 07 EB 40 08 B8 F8 06 00 20 F0 78 00
9:14:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E3 09 81 80 DB F7 0E FF 80 B3 01 7A AD F8 44 17 D0 F8 02 10 CD F8 46 17 C0 88 AD F8 4A 07 B8 F8 06 00 0D F2 44 71 C0 F3 C3 00 8D F8 4C 07 28 46 DB F7 64 FF 00 28 CB D0 08 F1 08 01 05 F1 B8 00 FF F7 E2 FE 00 28 C3 D0 98 F8 04 00 01 28 02 D0 02 28 0B D1 03 E0 28 46 DC F7 7F FE 04 E0 00 22 11 46 28 46 DC F7 AE FE 00 28 B1 D0 76 1C B6 B2 A6 42 BF D3 01 20 AB E7 70 B5 04 46 4F F4 B2 71 AA F7 6D F8
9:14:12 AM
9:14:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E4 09 81 80 F7 49 00 20 04 EB C0 02 D1 E9 00 35 C2 E9 00 35 40 1C 10 F0 FF 00 F5 D0 F1 49 1C 22 38 31 04 F1 08 00 AA F7 28 F8 00 20 20 86 C4 F8 32 00 84 F8 36 00 FF 20 84 F8 28 00 EA 48 60 62 24 21 04 F1 38 00 AA F7 4A F8 41 21 04 F1 5C 00 AA F7 45 F8 39 21 04 F1 9D 00 AA F7 67 F8 41 21 04 F1 D6 00 AA F7 62 F8 41 21 04 F2 17 10 AA F7 5D F8 04 F5 AC 74 DD 48 60 60 4F F4 4D 70 A0 60 4F F0 78 00
9:14:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E5 09 81 80 20 70 4F F0 68 00 60 70 4F F0 29 00 A0 70 4F F0 10 00 E0 70 4F F0 01 00 70 BD 0E B5 08 B1 00 20 0E BD 02 A8 08 22 CD E9 00 20 00 23 01 20 CB F7 D6 F9 08 B1 01 20 0E BD 00 20 0E BD 10 B5 AD F5 14 7D 04 46 8D A9 00 20 FF F7 E7 FF 00 28 2D D0 00 20 91 90 92 90 DD E9 8D 01 CD E9 8F 01 C3 A0 D0 E9 00 10 CD E9 91 10 68 46 C8 F7 81 FF E0 B9 BB 49 10 22 85 31 68 46 C8 F7 81 FF A8 B9 68 46
9:14:13 AM
9:14:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E6 09 81 80 C8 F7 CA FF 88 B9 10 22 8F A9 68 46 C8 F7 97 FF 58 B9 B3 49 68 46 95 31 C8 F7 C8 FF 28 B9 10 22 21 46 68 46 C9 F7 08 F8 18 B1 00 20 0D F5 14 7D 10 BD 01 20 FA E7 30 B5 8F B0 05 46 0C 46 10 21 0B A8 FF F7 BB FF 00 28 14 D0 20 22 03 A9 11 20 8D E8 07 00 10 23 0B AA 19 46 A7 A0 C8 F7 DC FE 38 B9 80 23 07 AA 03 A9 28 46 00 94 C9 F7 6A F8 10 B1 00 20 0F B0 30 BD 01 20 FB E7 2D E9 FE 43
9:14:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E7 09 81 80 0C 46 81 46 20 88 0A 99 80 B1 12 04 02 EB 03 22 57 18 A6 1C 4F EA E7 78 10 28 0A D2 C0 F1 10 01 10 25 30 44 AA 22 AA F7 EC FC 03 E0 01 20 BD E8 FE 83 05 46 00 97 CD E9 01 86 2A 46 A1 1C 48 46 C9 F7 B0 F8 08 B1 00 20 F1 E7 20 88 40 F4 00 40 20 80 EB E7 3E B5 4F EA 02 42 06 9C 02 EB 03 22 02 EB 04 03 0A 88 4F EA E3 74 15 04 0F D5 32 F4 00 42 0A 80 0B D0 10 2A 00 D2 10 22 8D 1C 8D E8
9:14:14 AM
9:14:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E8 09 81 80 38 00 89 1C C9 F7 E4 F8 08 B1 00 20 3E BD 01 20 3E BD 2D E9 F0 41 AD F5 7C 7D 07 46 00 21 01 A8 FF F7 89 FF 00 28 22 D0 00 25 F3 AE 4F F0 20 08 19 E0 00 BF 07 EB 45 14 21 1D 20 22 B0 1C A9 F7 AF FE E8 B2 00 90 AD F8 CC 83 00 23 02 22 F3 A9 01 A8 FF F7 93 FF 00 28 09 D0 20 1D 20 22 B1 1C A9 F7 9E FE 6D 1C 38 78 A8 42 E3 D8 01 20 0D F5 7C 7D BD E8 F0 81 2D E9 F0 41 AD F5 7C 7D 07 46
9:14:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 E9 09 81 80 01 21 01 A8 FF F7 57 FF 00 28 F0 D0 00 25 F3 AE 48 F2 20 08 19 E0 00 BF 07 EB 45 14 21 1D 20 22 B0 1C A9 F7 7D FE E8 B2 00 90 AD F8 CC 83 00 23 02 22 F3 A9 01 A8 FF F7 8D FF 00 28 D7 D0 20 1D 20 22 B1 1C A9 F7 6C FE 6D 1C 38 78 A8 42 E3 D8 01 20 CC E7 10 B5 38 30 FF F7 9B FF 00 28 00 D0 01 20 10 BD 10 B5 38 30 FF F7 C5 FF 00 28 00 D0 01 20 10 BD 3E B5 04 46 02 A8 4F F4 B2 72 CD E9
9:14:15 AM
9:14:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 EA 09 81 80 00 20 00 23 21 46 01 20 CB F7 A9 F8 00 28 03 D0 20 46 FF F7 E7 FF 01 20 3E BD 3E B5 04 46 FF F7 D9 FF 02 A8 4F F4 B2 72 CD E9 00 20 00 23 21 46 01 20 CB F7 D4 F8 00 28 00 D0 01 20 3E BD 00 B5 D9 B0 68 46 FF F7 D6 FF 48 B9 B3 F7 F8 F8 40 05 05 D4 68 46 FF F7 4E FE 68 46 FF F7 DE FF 02 A8 B1 F7 71 FA 59 B0 01 20 00 BD 00 21 01 70 02 22 42 70 81 70 C1 70 01 71 14 22 42 71 01 22 C2 80
9:14:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 EB 09 81 80 01 72 41 72 C1 72 82 72 70 47 2D E9 FF 4F 87 B0 4F F0 01 08 04 AD CD E9 00 85 0E 46 93 46 5C 23 42 46 02 A9 40 46 CB F7 5A F8 04 00 12 D0 CD E9 00 85 00 23 01 22 03 A9 14 20 CB F7 50 F8 04 00 08 D0 9D F8 0C 00 00 F0 0F 00 8D F8 0C 00 9D F8 08 00 30 60 5D 26 4F F0 00 09 4F F0 FF 3A 90 E0 3C 5F 07 00 80 3A 09 00 CE 31 F8 00 59 3D 32 77 5B 6B 45 49 00 00 00 00 36 65 76 65 50 5F 3F 78
9:14:16 AM
9:14:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 EC 09 81 80 61 2B 75 24 72 61 44 75 00 00 00 00 01 27 11 E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CB F7 1E F8 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 07 98 BD F8 14 10 01 80 02 27 0C E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CB F7 01 F8 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 07 98 BD F8 14 10 41 80
9:14:17 AM
9:14:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 ED 09 81 80 02 27 0C E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CA F7 E4 FF 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 07 98 BD F8 14 10 81 80 02 27 0C E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CA F7 C7 FF 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 07 98 BD F8 14 10 C1 80 07 98 08 30 07 90 09 F1 01 00 00 F0
9:14:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 EE 09 81 80 FF 09 9D F8 08 10 89 45 04 D2 00 2C 7F F4 7E AF 9D 26 10 E0 9D 26 74 B1 CD E9 00 85 01 22 9D 23 02 A9 10 46 CA F7 9B FF 04 00 03 D0 0A 98 9D F8 08 10 01 60 9E 26 00 20 83 E0 00 27 11 E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CA F7 87 FF 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 9D F8 14 10 8B F8 00 10 02 27 0C E0 05 A8 CD E9 00 85 C1 19
9:14:18 AM
9:14:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 EF 09 81 80 01 22 B3 B2 10 46 CA F7 6A FF 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB BD F8 14 10 AB F8 02 10 02 27 0C E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CA F7 4D FF 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB BD F8 14 10 AB F8 04 10 02 27 0C E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CA F7 30 FF 08 B1
9:14:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F0 09 81 80 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB BD F8 14 10 AB F8 06 10 9B F8 00 00 4F F4 7A 71 48 43 9D F8 0C 10 C0 F7 92 FE CB F8 08 00 09 F1 01 00 0B F1 0C 0B C0 B2 9D F8 08 10 81 46 88 42 04 D2 00 2C 7F F4 74 AF D6 26 10 E0 D6 26 74 B1 CD E9 00 85 01 22 D6 23 02 A9 10 46 CA F7 FA FE 04 00 03 D0 15 98 9D F8 08 10 01 60 D7 26 4F F0 00 09 C3 46 7B E0
9:14:19 AM
9:14:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F1 09 81 80 01 27 D8 46 11 E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CA F7 E3 FE 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 14 98 BD F8 14 10 01 80 02 27 0C E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CA F7 C6 FE 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 14 98 BD F8 14 10 41 80 02 27 0C E0 05 A8 CD E9 00 85
9:14:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F2 09 81 80 C1 19 01 22 B3 B2 10 46 CA F7 A9 FE 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 14 98 BD F8 14 10 81 80 02 27 0C E0 05 A8 CD E9 00 85 C1 19 01 22 B3 B2 10 46 CA F7 8C FE 08 B1 76 1C 00 E0 54 46 38 00 A7 F1 01 07 FF B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 14 98 BD F8 14 10 C1 80 14 98 08 30 14 90 09 F1 01 00 00 F0 FF 09 9D F8 08 00 81 45 02 D2
9:14:20 AM
9:14:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F3 09 81 80 00 2C 7F F4 7D AF CD E9 00 B5 01 22 40 F2 17 13 A8 46 D9 46 02 A9 10 46 CA F7 61 FE 04 00 09 D0 9D F8 0C 00 9D F8 08 10 00 F0 0F 00 8D F8 0C 00 17 98 01 60 4F F4 8C 75 00 27 83 E0 01 26 0D F1 14 0B 11 E0 CD E9 00 98 01 22 0B EB 06 01 AB B2 10 46 CA F7 44 FE 08 B1 6D 1C 00 E0 54 46 30 00 A6 F1 01 06 F6 B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 16 98 BD F8 14 10 01 80 02 26 0D F1 14 0B
9:14:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F4 09 81 80 0D E0 00 BF CD E9 00 98 01 22 0B EB 06 01 AB B2 10 46 CA F7 24 FE 08 B1 6D 1C 00 E0 54 46 30 00 A6 F1 01 06 F6 B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 16 98 BD F8 14 10 41 80 02 26 0D F1 14 0B 0D E0 00 BF CD E9 00 98 01 22 0B EB 06 01 AB B2 10 46 CA F7 04 FE 08 B1 6D 1C 00 E0 54 46 30 00 A6 F1 01 06 F6 B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 16 98 BD F8 14 10 81 80 02 26 0D F1 14 0B
9:14:21 AM
9:14:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F5 09 81 80 0D E0 00 BF CD E9 00 98 01 22 0B EB 06 01 AB B2 10 46 CA F7 E4 FD 08 B1 6D 1C 00 E0 54 46 30 00 A6 F1 01 06 F6 B2 02 D0 00 2C EB DA 05 E0 00 2C 03 DB 16 98 BD F8 14 10 C1 80 16 98 08 30 7F 1C FF B2 16 90 9D F8 08 00 87 42 03 D2 00 2C 7F F4 75 AF 24 E0 1C B3 04 25 CD E9 00 58 46 46 4F F4 AE 73 2A 46 01 20 18 99 CA F7 B9 FD 04 00 16 D0 CD E9 00 56 4F F4 B0 73 04 22 01 20 19 99 CA F7
9:14:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F6 09 81 80 AE FD 04 00 0B D0 1A 98 48 B1 CD E9 00 56 01 46 4F F4 AC 73 04 22 01 20 CA F7 A1 FD 04 46 0B B0 20 B2 BD E8 F0 8F 10 B5 9E B0 04 46 68 46 AB F7 3F FD 08 22 21 46 68 46 AC F7 77 FD 04 22 04 F1 08 01 68 46 AC F7 71 FD 10 22 FE 49 68 46 AC F7 6C FD 17 A9 68 46 AC F7 A0 FD 14 22 04 F1 0C 01 17 A8 A9 F7 F1 FA 58 B9 1C A9 00 20 FF F7 95 FB 00 28 06 D0 08 22 1C A9 20 46 A9 F7 E5 FA 10 B1
9:14:22 AM
9:14:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F7 09 81 80 00 20 1E B0 10 BD A0 68 FB E7 70 B5 8C B0 24 20 0B A9 CD E9 00 01 02 46 38 23 02 A9 01 20 CA F7 5E FD 00 28 18 D0 02 A8 FF F7 65 FC 00 25 2C 46 02 AE 07 E0 06 EB 44 10 00 1D FF F7 B4 FF 05 43 64 1C E4 B2 9D F8 08 00 A0 42 F3 D8 DE 48 45 64 48 30 B1 F7 27 F8 01 20 0C B0 70 BD 2D E9 F0 47 04 46 4F F4 A9 61 A9 F7 78 FB 00 21 A4 F8 58 12 08 46 08 26 00 EB C0 02 04 EB 42 02 D3 A3 A2 F8
9:14:23 AM
9:14:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F8 09 81 80 5A 62 1D 68 C2 F8 5C 52 40 1C 5B 68 C0 B2 C2 F8 60 32 04 28 EE D3 00 25 10 27 88 46 04 F5 29 79 05 EB 05 10 04 EB 40 00 A0 F8 A2 72 F5 B3 CA 49 00 F5 29 70 10 22 00 BF A9 F7 B2 FA 6D 1C ED B2 04 2D ED D3 00 20 45 46 00 EB 00 11 04 EB 41 01 40 1C C0 B2 A1 F8 2A 53 02 28 F5 D3 A4 F8 C0 53 5F F0 00 00 00 EB C0 01 04 EB 41 01 B7 A2 A1 F8 C2 63 13 68 C1 F8 C4 33 40 1C 52 68 C0 B2 C1 F8
9:14:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 F9 09 81 80 C8 23 04 28 EE D3 00 26 04 F2 0C 48 06 EB 06 10 04 EB 40 00 A0 F8 0A 74 06 B3 AF 49 00 F2 0C 40 10 22 00 BF A9 F7 7C FA 76 1C 00 E0 11 E0 F6 B2 04 2E EB D3 5F F0 00 00 00 EB 00 11 04 EB 41 01 40 1C C0 B2 A1 F8 92 54 02 28 F5 D3 01 20 BD E8 F0 87 A1 49 10 22 18 39 48 46 AD E7 9E 49 10 22 18 39 40 46 DE E7 70 B5 AD F5 74 7D 05 46 0E 46 02 29 03 D3 00 20 0D F5 74 7D 70 BD 00 21 01 A8
9:14:24 AM
9:14:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 FA 09 81 80 FF F7 19 FB 00 28 F6 D0 00 24 E0 B2 00 90 04 EB C4 00 05 EB 40 01 89 1C 00 23 32 46 01 A8 FF F7 2D FB 00 28 E7 D0 64 1C 04 2C EE D3 00 24 E0 B2 00 90 04 EB 04 10 05 EB 40 01 4A 31 01 23 32 46 01 A8 FF F7 1B FB 00 28 D5 D0 64 1C 04 2C EE D3 00 24 E0 B2 00 90 04 EB 04 10 05 EB 40 01 D2 31 02 23 32 46 01 A8 FF F7 09 FB 00 28 C3 D0 64 1C 02 2C EE D3 01 20 BE E7 70 B5 AD F5 74 7D 05 46
9:14:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 FB 09 81 80 0E 46 02 29 01 D3 00 20 B5 E7 01 21 01 A8 FF F7 D2 FA 00 28 AF D0 00 24 E0 B2 00 90 04 EB C4 00 05 EB 40 01 89 1C 00 23 32 46 01 A8 FF F7 12 FB 00 28 A0 D0 64 1C 04 2C EE D3 00 24 E0 B2 00 90 04 EB 04 10 05 EB 40 01 4A 31 01 23 32 46 01 A8 FF F7 00 FB 00 28 8E D0 64 1C 04 2C EE D3 00 24 E0 B2 00 90 04 EB 04 10 05 EB 40 01 D2 31 02 23 32 46 01 A8 FF F7 EE FA 00 28 C5 D0 64 1C 02 2C
9:14:25 AM
9:14:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 FC 09 81 80 EE D3 01 20 77 E7 10 B5 04 46 00 21 00 F5 16 70 FF F7 69 FF 00 28 07 D0 01 21 04 F5 70 70 FF F7 62 FF 00 28 00 D0 01 20 10 BD 10 B5 04 46 00 21 00 F5 16 70 FF F7 A0 FF 00 28 07 D0 01 21 04 F5 70 70 FF F7 99 FF 00 28 00 D0 01 20 10 BD 3E B5 04 46 02 A8 4F F4 A9 62 CD E9 00 20 00 23 21 46 18 20 CA F7 FC FB 00 28 05 D0 20 46 FF F7 DD FF 00 28 00 D0 01 20 3E BD 3E B5 04 46 FF F7 C3 FF
9:14:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 FD 09 81 80 00 28 0C D0 02 A8 4F F4 A9 62 CD E9 00 20 00 23 21 46 18 20 CA F7 23 FC 00 28 00 D0 01 20 3E BD 29 49 10 B5 4F F4 A9 62 BC 31 A9 F7 E4 F9 01 20 10 BD 01 46 24 48 10 B5 4F F4 A9 62 BC 30 A9 F7 DA F9 21 48 BD E8 10 40 BC 30 D5 E7 30 B5 23 4D 00 24 AD F2 4C 5D 28 89 C0 07 10 D0 68 46 FF F7 B6 FF 04 46 01 28 0A D1 4F F4 A9 62 69 46 05 F5 3B 70 A9 F7 C0 F9 28 89 20 F0 01 00 28 81 0D F2
9:14:26 AM
9:14:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 FE 09 81 80 4C 5D 20 46 30 BD 15 48 00 89 00 F0 01 00 70 47 12 48 01 89 41 F0 01 01 01 81 70 47 00 B5 AD F2 4C 5D 68 46 FF F7 93 FF 48 B9 B2 F7 08 FC 40 05 05 D4 68 46 FF F7 52 FE 68 46 FF F7 9D FF 4F F4 A9 62 0D E0 00 10 00 00 D0 80 00 10 31 32 33 34 35 36 37 38 00 00 00 00 5C 5F 07 00 A0 7E 00 10 69 46 FC 48 A9 F7 87 F9 FB 49 00 20 08 81 0D F2 4C 5D 01 20 00 BD 3E B5 05 46 0C 00 03 D0 01 2C
9:14:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 06 FF 09 81 80 04 D0 00 20 3E BD 4F F4 16 71 01 E0 4F F4 70 71 02 A8 4F F4 8B 72 CD E9 00 20 8B B2 29 46 18 20 CA F7 5D FB 00 28 ED D0 21 46 28 46 FF F7 E4 FE 00 28 E7 D0 01 20 3E BD 3E B5 05 46 19 B1 01 29 04 D0 00 20 3E BD 4F F4 16 74 01 E0 4F F4 70 74 FF F7 89 FE 00 28 F5 D0 02 A8 4F F4 8B 72 CD E9 00 20 A3 B2 29 46 18 20 CA F7 79 FB 00 28 E9 D0 01 20 3E BD 10 B5 4F F4 8B 72 19 B1 01 29 03 D0
9:14:27 AM
9:14:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 00 09 81 80 00 20 10 BD D5 49 00 E0 D5 49 A9 F7 C9 F8 01 20 10 BD 70 B5 0C 00 05 46 4F F4 8B 72 03 D0 01 2C 04 D0 00 20 70 BD 01 46 CC 48 01 E0 01 46 CC 48 A9 F7 B6 F8 21 46 28 46 FF F7 BE FF 00 28 F1 D0 01 20 70 BD F0 B5 AD F5 75 7D 07 46 0C 46 16 46 1D 46 02 29 29 D2 36 B1 05 EB 05 10 01 2E 13 D0 02 2E 22 D1 1C E0 04 2D 1F D2 05 EB C5 00 14 B1 01 2C 03 D0 19 E0 40 F2 5A 21 01 E0 40 F2 C2 31
9:14:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 01 09 81 80 01 EB 40 00 12 22 1C E0 04 2D 0E D2 14 B1 01 2C 03 D0 0A E0 40 F2 A2 21 10 E0 40 F2 0A 41 0D E0 02 2D 02 D2 2C B1 01 2C 06 D0 00 20 0D F5 75 7D F0 BD 40 F2 2A 31 01 E0 40 F2 92 41 01 EB 40 00 22 22 F4 A9 CD E9 00 21 83 B2 39 46 18 20 CA F7 C6 FA 00 28 EA D0 01 21 02 A8 FF F7 2C F9 00 28 E4 D0 33 46 22 46 39 46 02 A8 00 95 FF F7 72 F9 00 28 DB D0 01 20 D9 E7 2D E9 F0 43 AD F5 75 7D
9:14:28 AM
9:14:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 02 09 81 80 81 46 0C 46 1E 46 90 46 02 29 2A D2 11 00 06 D0 06 EB 06 10 01 29 13 D0 02 2A 22 D1 1C E0 04 2E 1F D2 06 EB C6 00 14 B1 01 2C 03 D0 19 E0 40 F2 5A 21 01 E0 40 F2 C2 31 01 EB 40 05 12 27 1D E0 04 2E 0E D2 14 B1 01 2C 03 D0 0A E0 40 F2 A2 21 11 E0 40 F2 0A 41 0E E0 02 2E 02 D2 34 B1 01 2C 07 D0 00 20 0D F5 75 7D BD E8 F0 83 40 F2 2A 31 01 E0 40 F2 92 41 01 EB 40 05 22 27 00 21 02 A8
9:14:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 03 09 81 80 FF F7 D9 F8 00 28 ED D0 43 46 22 46 49 46 02 A8 00 96 FF F7 F3 F8 00 28 E4 D0 F4 A8 CD E9 00 70 AB B2 3A 46 49 46 18 20 CA F7 99 FA 00 28 D9 D0 01 20 D7 E7 70 B5 0C 46 02 29 38 D2 4A B1 65 4D 03 EB 03 11 05 EB 41 01 01 2A 14 D0 02 2A 2E D1 1D E0 04 2B 2B D2 5F 4A 03 EB C3 01 02 EB 41 01 14 B1 01 2C 03 D0 20 E0 01 F2 5A 21 01 E0 01 F2 C2 31 12 22 17 E0 04 2B 19 D2 14 B1 01 2C 03 D0
9:14:29 AM
9:14:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 04 09 81 80 13 E0 01 F2 A2 21 0D E0 01 F2 0A 41 0A E0 02 2B 0D D2 14 B1 01 2C 03 D0 07 E0 01 F2 2A 31 01 E0 01 F2 92 41 22 22 A8 F7 BB FF 01 20 70 BD 00 20 70 BD 2D E9 F0 41 07 46 0C 46 16 46 1D 46 02 29 42 D2 4E B1 43 49 05 EB 05 10 01 EB 40 00 01 2E 14 D0 02 2E 38 D1 1D E0 04 2D 35 D2 3D 49 05 EB C5 00 01 EB 40 00 14 B1 01 2C 03 D0 21 E0 00 F2 5A 20 01 E0 00 F2 C2 30 12 22 17 E0 04 2D 23 D2
9:14:30 AM
9:14:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 05 09 81 80 14 B1 01 2C 03 D0 14 E0 00 F2 A2 20 0D E0 00 F2 0A 40 0A E0 02 2D 17 D2 14 B1 01 2C 03 D0 08 E0 00 F2 2A 30 01 E0 00 F2 92 40 22 22 39 46 A8 F7 77 FF 2B 46 32 46 21 46 38 46 FF F7 1D FF 00 28 00 D0 01 20 BD E8 F0 81 00 20 FB E7 70 B5 AD F5 76 7D 06 46 0D 46 14 46 02 2A 04 D2 04 EB 04 11 2D B1 01 2D 06 D0 00 20 0D F5 76 7D 70 BD 40 F2 2A 30 01 E0 40 F2 92 40 00 EB 41 00 F4 AA 22 21
9:14:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 06 09 81 80 CD E9 00 12 83 B2 0A 46 31 46 18 20 CA F7 A7 F9 00 28 E9 D0 01 21 02 A8 FF F7 0D F8 00 28 E3 D0 02 23 2A 46 31 46 02 A8 00 94 FF F7 53 F8 00 28 DA D0 01 20 D8 E7 F0 B5 AD F5 75 7D 07 46 0D 46 14 46 02 2A 04 D2 04 EB 04 10 5D B1 01 2D 0C D0 00 20 AB E6 8C 81 00 10 A0 7E 00 10 E4 83 00 10 4C 85 00 10 40 F2 2A 31 01 E0 40 F2 92 41 01 EB 40 06 00 21 02 A8 FE F7 DE FF 00 28 E9 D0 02 23
9:14:31 AM
9:14:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 07 09 81 80 2A 46 39 46 02 A8 00 94 FE F7 F8 FF 00 28 E0 D0 22 20 F4 A9 CD E9 00 01 02 46 B3 B2 39 46 18 20 CA F7 9D F9 00 28 D4 D0 01 20 7F E6 10 B5 02 2A 07 D2 F8 4B 02 EB 02 12 03 EB 42 03 19 B1 01 29 04 D0 00 20 10 BD 03 F2 2A 31 01 E0 03 F2 92 41 22 22 A8 F7 E5 FE 01 20 10 BD 70 B5 06 46 0C 46 15 46 02 2A 07 D2 EB 49 05 EB 05 10 01 EB 40 00 1C B1 01 2C 04 D0 00 20 70 BD 00 F2 2A 30 01 E0
9:14:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 08 09 81 80 00 F2 92 40 22 22 31 46 A8 F7 CA FE 2A 46 21 46 30 46 FF F7 90 FF 00 28 EE D0 01 20 70 BD 3E B5 4B 1E 14 46 01 2B 01 D8 D9 B2 04 E0 0A 1F 01 2A 04 D8 89 1E C9 B2 18 B1 01 28 04 D0 00 20 3E BD 4F F4 5C 70 01 E0 4F F4 9B 60 00 EB 81 00 02 AA 04 21 CD E9 00 12 83 B2 0A 46 21 46 18 20 CA F7 3E F9 00 28 EB D0 01 20 3E BD 4B 1E 01 2B 01 D8 D9 B2 04 E0 0B 1F 01 2B 05 D8 89 1E C9 B2 C5 4B
9:14:32 AM
9:14:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 09 09 81 80 18 B1 01 28 06 D0 00 20 70 47 03 EB 81 00 D0 F8 70 03 03 E0 03 EB 81 00 D0 F8 D8 04 10 60 01 20 70 47 70 B5 4B 1E 01 2B 05 D8 BA 4C DB B2 38 B1 01 28 0B D0 15 E0 0B 1F 01 2B 12 D8 8B 1E F4 E7 04 EB 83 03 15 68 C3 F8 70 53 04 E0 04 EB 83 03 15 68 C3 F8 D8 54 FF F7 A2 FF 00 28 00 D0 01 20 70 BD 00 20 70 BD 3E B5 4B 1E 14 46 01 2B 01 D8 D9 B2 04 E0 0A 1F 01 2A 04 D8 89 1E C9 B2 18 B1
9:14:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 0A 09 81 80 01 28 04 D0 00 20 3E BD 4F F4 60 70 01 E0 4F F4 9D 60 00 EB 01 10 02 AA 10 21 CD E9 00 12 83 B2 0A 46 21 46 18 20 CA F7 DA F8 00 28 EB D0 01 20 3E BD 10 B5 4B 1E 01 2B 01 D8 D9 B2 04 E0 0B 1F 01 2B 05 D8 89 1E C9 B2 92 4B 18 B1 01 28 06 D0 00 20 10 BD 03 EB 01 10 00 F5 60 70 03 E0 03 EB 01 10 00 F5 9D 60 90 E8 1A 00 C0 68 C2 E9 02 40 C2 E9 00 13 4F F0 01 00 10 BD 2D E9 F0 41 4B 1E
9:14:33 AM
9:14:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 0B 09 81 80 01 2B 05 D8 83 4C DB B2 38 B1 01 28 0A D0 16 E0 0B 1F 01 2B 13 D8 8B 1E F4 E7 04 EB 03 13 03 F5 60 73 03 E0 04 EB 03 13 03 F5 9D 63 92 E8 F0 00 F0 C3 FF F7 98 FF 00 28 00 D0 01 20 82 E6 00 20 80 E6 0E B5 08 28 01 D3 00 20 0E BD 4F F4 A5 62 02 EB 80 03 02 AA 04 20 CD E9 00 02 02 46 18 20 CA F7 7D F8 00 28 F0 D0 01 20 0E BD 08 28 01 D3 00 20 70 47 67 4A 02 EB 80 00 D0 F8 28 05 08 60
9:14:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 0C 09 81 80 01 20 70 47 10 B5 08 28 01 D3 00 20 10 BD 61 4B 0A 68 03 EB 80 03 C3 F8 28 25 FF F7 D2 FF 00 28 F4 D0 01 20 10 BD 10 B5 04 46 68 21 A8 F7 55 FE B4 20 E0 82 07 20 60 83 00 20 05 21 04 EB 80 02 40 1C C0 B2 91 64 02 28 F8 D3 00 20 20 75 60 75 84 F8 60 00 3C 21 E1 65 02 21 21 83 4F F4 61 61 A4 F8 62 10 84 F8 61 00 84 F8 64 00 01 20 10 BD 0E B5 02 AA 68 21 CD E9 00 12 0A 46 01 46 00 23
9:14:34 AM
9:14:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 0D 09 81 80 1B 20 C9 F7 EC FF 00 28 00 D0 01 20 0E BD 0E B5 02 AA 68 21 CD E9 00 12 0A 46 01 46 00 23 1B 20 CA F7 1D F8 00 28 00 D0 01 20 0E BD 10 B5 68 22 39 49 A8 F7 E0 FD 01 20 10 BD 10 B5 01 46 68 22 35 48 A8 F7 D8 FD BD E8 10 40 33 48 DF E7 70 B5 32 4D 00 26 9A B0 68 89 C0 07 24 D0 68 46 FF F7 C7 FF 06 46 01 28 1E D1 2B 48 9D F8 61 10 90 F8 61 00 88 42 0E D0 05 F5 0C 74 E0 7F AF F7 26 FD
9:14:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 0E 09 81 80 00 20 20 77 FF 21 E1 77 9D F8 61 20 01 2A 0D D0 84 F8 2C 00 68 22 69 46 1F 48 A8 F7 AC FD 68 89 20 F0 01 00 68 81 1A B0 30 46 70 BD 14 F8 1D 2F 42 F0 01 02 22 70 E1 73 20 74 EB E7 17 48 40 89 00 F0 01 00 70 47 15 48 41 89 41 F0 01 01 41 81 70 47 70 47 10 B5 04 46 0F 48 FF F7 89 FF 0E 48 50 30 01 88 A1 43 01 80 60 07 02 D5 00 20 EC F7 74 FE E0 05 03 D5 00 21 06 20 FF F7 EA FF 20 46
9:14:35 AM
9:14:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 0F 09 81 80 B1 F7 A8 F9 03 48 84 38 B0 F7 48 FA BD E8 10 40 01 48 7C E7 8C 81 00 10 D4 86 00 10 A0 7E 00 10 FE 49 B1 F8 50 10 01 42 01 D0 01 20 70 47 00 20 70 47 00 B5 9B B0 68 46 FF F7 5A FF 48 B9 B1 F7 BE FF 40 05 05 D4 68 46 FF F7 2D FF 68 46 FF F7 5E FF 68 22 69 46 F1 48 A8 F7 4D FD 05 20 FF F7 DF FF 30 B1 B1 F7 AB FF 40 05 02 D4 05 20 FF F7 B1 FF 1B B0 01 20 00 BD 10 B5 04 46 3A 21 A8 F7
9:14:36 AM
9:14:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 10 09 81 80 93 FD 01 20 20 70 03 20 60 70 00 20 A0 70 01 20 10 BD 0E B5 02 AA 3A 21 CD E9 00 12 0A 46 01 46 00 23 27 20 C9 F7 1B FF 00 28 00 D0 01 20 0E BD 0E B5 02 AA 3A 21 CD E9 00 12 0A 46 01 46 00 23 27 20 C9 F7 4C FF 00 28 00 D0 01 20 0E BD D3 49 10 B5 3A 22 68 31 A8 F7 A3 FC 01 20 10 BD 01 46 CE 48 10 B5 3A 22 68 30 A8 F7 9A FC CB 48 BD E8 10 40 68 30 DC E7 30 B5 C9 4D 00 24 8F B0 A8 89
9:14:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 11 09 81 80 C0 07 0F D0 68 46 FF F7 C4 FF 04 46 01 28 09 D1 3A 22 69 46 05 F6 9C 00 A8 F7 82 FC A8 89 20 F0 01 00 A8 81 0F B0 20 46 30 BD BD 48 80 89 00 F0 01 00 70 47 BA 48 81 89 41 F0 01 01 81 81 70 47 00 B5 8F B0 68 46 FF F7 A4 FF 48 B9 B1 F7 37 FF 40 05 05 D4 68 46 FF F7 8F FF 68 46 FF F7 A8 FF AE 48 3A 22 69 46 68 30 A8 F7 5A FC AC 49 00 20 88 81 01 20 0F B0 00 BD 00 B5 8F B0 68 46 FF F7
9:14:37 AM
9:14:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 12 09 81 80 7B FF 00 28 F6 D0 68 46 FF F7 92 FF 00 28 F1 D0 01 20 EF E7 00 B5 93 B0 68 46 FF F7 6D FF 0F A8 F9 F7 17 FC 28 B1 9D F8 43 00 8D F8 00 00 8D F8 01 00 68 46 FF F7 7C FF 13 B0 00 BD 00 21 01 60 41 60 01 81 81 72 01 20 70 47 0E B5 02 AA 0B 21 CD E9 00 12 0A 46 01 46 00 23 2A 20 C9 F7 7F FE 00 28 00 D0 01 20 0E BD 0E B5 02 AA 0B 21 CD E9 00 12 0A 46 01 46 00 23 2A 20 C9 F7 B0 FE 00 28
9:14:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 13 09 81 80 00 D0 01 20 0E BD 85 49 4C 31 D1 F8 56 20 02 60 D1 F8 5A 20 42 60 31 F8 5E 2F 02 81 89 78 81 72 01 20 70 47 7D 49 02 68 4C 31 C1 F8 56 20 42 68 C1 F8 5A 20 02 89 21 F8 5E 2F 80 7A 88 70 77 48 A2 30 D1 E7 3E B5 76 4C 00 20 E1 89 C9 07 17 D0 68 46 FF F7 BA FF 01 28 12 D1 04 F5 08 61 00 9A C1 F8 56 20 01 9A C1 F8 5A 20 BD F8 08 20 21 F8 5E 2F 9D F8 0A 20 8A 70 E1 89 21 F0 01 01 E1 81
9:14:38 AM
9:14:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 14 09 81 80 3E BD 67 48 C0 89 00 F0 01 00 70 47 64 48 C1 89 41 F0 01 01 C1 81 70 47 0E B5 68 46 FF F7 95 FF 48 B9 B1 F7 8C FE 40 05 05 D4 68 46 FF F7 86 FF 68 46 FF F7 99 FF 59 48 00 99 4C 30 C0 F8 56 10 01 99 C0 F8 5A 10 BD F8 08 10 20 F8 5E 1F 9D F8 0A 10 81 70 52 49 00 20 C8 81 01 20 0E BD 0E B5 68 46 FF F7 6B FF 00 28 05 D0 68 46 FF F7 7C FF 00 28 00 D0 01 20 0E BD 48 48 A2 30 00 78 01 28
9:14:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 15 09 81 80 00 D0 00 20 70 47 00 B5 4F F4 80 72 10 46 FF F7 87 FE 01 28 04 D1 11 46 06 20 5D F8 04 EB 58 E6 00 BD 01 46 64 20 1C 22 CA F7 7A B8 01 46 64 20 1C 22 C9 F7 AA BE 1F B5 00 20 00 90 01 90 02 90 03 90 01 A8 B0 F7 8B F8 03 A8 B0 F7 88 F8 00 24 10 20 00 EB 04 10 10 22 69 46 C9 F7 96 FE 64 1C E4 B2 04 2C F4 D9 1F BD 2D E9 FF 41 00 25 0C 46 17 46 05 28 02 D3 28 46 04 B0 5F E5 10 21 01 EB
9:14:39 AM
9:14:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 16 09 81 80 00 16 0A 46 69 46 30 46 CA F7 4A F8 6F B1 23 49 03 98 C9 8A 20 1A 81 42 0E D2 BD F8 02 10 02 90 49 1C AD F8 02 10 01 25 06 E0 BD F8 00 00 01 94 40 1C 03 94 AD F8 00 00 10 22 69 46 30 46 C9 F7 64 FE D8 E7 FE B5 16 4E 15 4C 5C 36 07 25 30 78 40 B3 01 28 5E D1 68 46 B0 F7 AE FF 9D F8 00 00 85 43 8D F8 00 50 58 D0 08 20 28 43 8D F8 00 00 A1 88 01 F0 0F 01 8D F8 04 10 88 42 7C D0 02 A8
9:14:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 17 09 81 80 B0 F7 2D F8 A0 88 80 06 0E D5 01 22 00 20 02 99 FF F7 AA FF A0 88 20 F0 20 00 04 E0 D4 86 00 10 A0 7E 00 10 17 E0 A0 80 9D F8 00 10 9D F8 04 00 21 EA 00 02 D2 07 32 D0 A0 88 00 22 40 F0 01 00 A0 80 01 20 02 99 FF F7 8F FF 0F 20 03 F0 D3 FC 4F F4 80 70 34 E0 B1 F7 0A F8 00 28 1A D0 00 20 8D F8 00 00 B1 F7 AB FD 80 07 03 D4 B1 F7 A7 FD C0 07 02 D1 68 46 B0 F7 5F FF 9D F8 00 00 85 43
9:14:40 AM
9:14:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 18 09 81 80 8D F8 00 50 07 D0 08 20 A1 88 28 43 08 43 A0 80 01 20 30 70 FE BD 00 20 F6 E7 00 20 A5 E7 88 43 C0 07 0F D0 A0 88 01 22 20 F0 01 00 A0 80 10 46 02 99 FF F7 59 FF 12 20 03 F0 9D FC 4F F4 00 60 F5 F7 7A FE 9D F8 00 00 80 07 00 28 9D F8 04 00 4F EA 80 70 11 DA 00 28 21 DB A0 88 00 22 40 F0 02 00 A0 80 02 20 02 99 FF F7 3E FF 10 20 03 F0 82 FC 4F F4 00 70 10 E0 6E E0 00 28 0F DA A0 88
9:14:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 19 09 81 80 01 22 20 F0 02 00 A0 80 02 20 02 99 FF F7 2C FF 13 20 03 F0 70 FC 4F F4 80 50 F5 F7 4D FE 9D F8 00 00 40 07 00 28 9D F8 04 00 4F EA 40 70 10 DA 00 28 20 DB A0 88 00 22 40 F0 04 00 A0 80 03 20 02 99 FF F7 11 FF 11 20 03 F0 55 FC 4F F4 80 60 0F E0 00 28 0F DA A0 88 01 22 20 F0 04 00 A0 80 03 20 02 99 FF F7 00 FF 14 20 03 F0 44 FC 4F F4 00 50 F5 F7 21 FE 9D F8 00 00 00 07 00 28 9D F8
9:14:41 AM
9:14:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 1A 09 81 80 04 00 4F EA 00 70 0B DA 00 28 1B DB A0 88 00 22 40 F0 08 00 A0 80 04 20 02 99 FF F7 E5 FE 11 E0 00 28 0F DA A0 88 01 22 20 F0 08 00 A0 80 04 20 02 99 FF F7 D9 FE 28 B1 00 23 1A 46 03 20 02 99 F5 F7 72 FA A1 88 0F 20 88 43 8D F8 04 00 01 22 01 A9 60 20 C9 F7 59 FD 68 46 B0 F7 AD FE 9D F8 00 00 C0 07 01 D0 00 21 00 E0 01 21 07 20 03 F0 7A FD 9D F8 00 00 80 07 01 D5 00 21 00 E0 01 21
9:14:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 1B 09 81 80 08 20 03 F0 70 FD 9D F8 00 00 40 07 01 D5 00 21 00 E0 01 21 09 20 03 F0 66 FD FE BD 1F B5 20 28 02 D9 00 20 04 B0 10 BD 8D F8 08 00 01 20 03 A9 CD E9 00 01 02 46 64 23 02 A9 1B 20 C9 F7 8F FC 00 28 EF D0 01 20 ED E7 1F B5 04 00 4F F0 64 03 0F D0 01 20 03 A9 CD E9 00 01 02 46 02 A9 1B 20 C9 F7 3D FC 00 28 DD D0 9D F8 08 00 20 70 01 20 D8 E7 00 20 D6 E7 FE 49 08 71 70 47 FC 49 09 79
9:14:42 AM
9:14:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 1C 09 81 80 01 70 70 47 FA 49 08 60 70 47 F9 49 09 68 01 60 70 47 00 B5 DB B0 59 A8 B5 F7 FE FB 68 46 FE F7 69 FB F3 48 BD F8 30 10 50 38 0D F1 24 0C C1 80 BC E8 0E 00 50 30 0E C0 5B B0 00 BD 2D E9 F0 41 80 46 88 B0 0C 20 06 AF CD E9 00 07 14 46 0D 46 02 46 01 26 00 23 41 46 14 20 C9 F7 00 FC 00 28 64 D0 E3 49 98 F8 02 00 50 39 00 23 48 70 0A 20 CD E9 00 07 02 46 02 A9 15 20 C9 F7 F0 FB E8 B3
9:14:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 1D 09 81 80 BD F8 08 00 60 80 BD F8 0A 00 A0 80 BD F8 0C 00 E0 80 BD F8 0E 00 20 81 00 20 20 80 9D F8 10 10 CA 07 4F F0 01 01 00 D0 21 80 9D F8 10 10 89 07 03 D5 21 88 41 F0 02 01 21 80 28 60 04 20 CD E9 00 07 02 46 1C 23 05 A9 05 20 C9 F7 C8 FB 00 28 29 D0 05 98 81 B2 14 20 E9 80 A8 80 28 70 68 70 80 46 A8 70 20 88 80 07 1C D4 22 89 00 20 E3 88 47 08 4F EA 32 00 E1 FB 03 07 00 E0 16 E0 39 46
9:14:43 AM
9:14:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 1E 09 81 80 4F F0 00 03 BF F7 16 FE E8 80 A2 88 00 20 67 88 41 08 4F EA 32 00 E8 FB 07 01 4F F0 00 03 BF F7 09 FE A8 80 30 46 08 B0 BD E8 F0 81 00 26 F9 E7 70 B5 05 00 4F F0 01 04 18 D1 AD 4A 24 32 A2 F1 3C 01 01 F1 30 00 FF F7 79 FF 68 B1 A8 48 A8 49 18 30 50 39 00 79 88 70 01 F1 74 02 38 31 01 F1 30 00 B0 F7 E5 F9 08 B1 00 24 02 E0 28 46 B0 F7 7B F9 20 46 70 BD 9F 48 C0 68 70 47 30 B5 89 B0
9:14:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 1F 09 81 80 01 46 FF F7 F8 FF 9A 4C 05 46 50 3C 20 69 A8 42 01 D1 00 29 38 D0 05 AA 69 46 02 A8 FF F7 4E FF 00 28 31 D0 92 49 0C 22 18 31 02 A8 A8 F7 CC F8 68 B9 8F 49 08 22 18 39 68 46 A8 F7 C5 F8 30 B9 8B 49 0A 22 24 31 05 A8 A8 F7 BE F8 D8 B1 9D F8 0C 00 A0 70 05 AA 69 46 02 A8 B0 F7 A9 F9 00 28 12 D1 02 98 A0 66 03 98 E0 66 04 98 20 67 00 98 A0 63 01 98 E0 63 05 98 60 67 06 98 A0 67 BD F8
9:14:44 AM
9:14:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 20 09 81 80 1C 00 A4 F8 7C 00 25 61 09 B0 30 BD 01 20 70 47 2D E9 F0 4F 85 B0 81 46 00 2B 7D D0 00 2A 7B D0 00 20 05 E0 0C 88 9C 42 04 D8 08 31 40 1C C0 B2 90 42 F7 D3 90 B1 90 42 1D D1 31 F9 06 0C C2 17 86 46 02 92 31 F9 04 0C C2 17 CD E9 00 02 31 F9 02 0C 00 BF 4F EA E0 7B 82 46 7E E0 B1 F9 02 00 C2 17 86 46 02 92 B1 F9 04 00 C2 17 CD E9 00 02 B1 F9 06 00 EE E7 B1 F9 02 00 31 F9 06 4C 01 94
9:14:45 AM
9:14:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 21 09 81 80 02 1B B1 F9 04 40 31 F9 04 0C 00 90 24 1A B1 F9 06 00 31 F9 02 5C 03 95 A0 EB 05 0C 31 F8 08 0C D6 17 86 46 18 1A A0 FB 02 B7 00 23 03 FB 02 72 00 FB 06 26 1A 46 A0 FB 04 53 02 FB 04 32 A0 FB 0C 73 4F EA E4 78 00 FB 08 28 00 22 02 FB 0C 32 4F EA EC 7A 04 95 0A FB 00 2A 09 88 A1 EB 0E 02 D3 17 D0 17 41 10 4F EA 32 00 10 EB 0B 00 14 46 71 41 BF F7 96 FD 83 46 E3 17 E0 17 02 91 41 10
9:14:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 22 09 81 80 04 9D 4F EA 34 00 40 19 22 46 41 EB 08 01 BF F7 88 FD 05 46 88 46 00 E0 C0 E0 E3 17 E0 17 41 10 4F EA 34 00 C0 19 22 46 41 EB 0A 01 BF F7 79 FD DD E9 01 43 02 46 14 EB 0B 0E 00 98 43 EB E4 76 4F EA E0 74 40 19 44 EB 08 04 03 9D CD E9 00 04 15 EB 02 0A 02 96 41 EB E5 7B 4F F0 00 00 00 BF D9 F8 00 30 03 93 02 9C 53 F8 20 C0 D9 F8 08 10 AE FB 0C 56 04 FB 0C 64 4F EA EC 78 0E FB 08 43
9:14:46 AM
9:14:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 23 09 81 80 4F F4 00 54 2C 19 43 F1 00 03 A4 0B 44 EA 83 44 51 F8 20 10 DD E9 00 35 A3 FB 01 67 05 FB 01 75 4F EA E1 72 03 FB 02 53 4F F4 00 55 75 19 43 F1 00 03 AD 0B 45 EA 83 45 64 1B AE FB 01 56 03 9B 43 F8 20 40 02 9C 04 FB 01 61 0E FB 02 12 4F F4 00 51 69 18 42 F1 00 02 89 0B 41 EA 82 41 DD E9 00 32 A3 FB 0C 45 02 FB 0C 52 03 FB 08 22 03 E0 F0 7E 00 10 D0 80 00 10 4F F4 00 53 E3 18 42 F1
9:14:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 24 09 81 80 00 02 94 04 44 EA 93 32 89 18 D9 F8 08 20 42 F8 20 10 D9 F8 00 20 52 F8 20 30 A3 FB 0A 67 4F EA E3 75 05 FB 0A 74 03 FB 0B 41 4F F4 00 53 F3 18 41 F1 00 01 8C 04 44 EA 93 31 42 F8 20 10 D9 F8 08 40 4F F4 00 52 54 F8 20 10 A1 FB 0A 67 CD 17 05 FB 0A 73 01 FB 0B 31 B2 18 41 F1 00 01 8B 04 43 EA 92 31 44 F8 20 10 D9 F8 0C 10 51 F8 20 30 A3 FB 0A 67 DD 17 05 FB 0A 74 03 FB 0B 42 4F F4
9:14:47 AM
9:14:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 25 09 81 80 00 53 F3 18 42 F1 00 02 94 04 44 EA 93 32 41 F8 20 20 40 1C C0 B2 03 28 FF F4 62 AF 05 B0 BD E8 F0 8F 2D E9 F0 4F 81 46 FE 48 8D B0 81 69 00 29 7E D0 00 24 FB 48 DF F8 EC A3 00 21 82 69 0A F1 C0 0A 09 EB 84 00 08 E0 C5 69 DA F8 08 30 9D 42 05 D3 49 1C 0A F1 0C 0A C9 B2 91 42 F4 D3 89 B1 91 42 1C D1 3A F9 0A 1C CA 17 8E 46 05 92 3A F9 08 1C CA 17 CD E9 03 21 3A F9 06 0C 4F EA E0 7B
9:14:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 26 09 81 80 82 46 7F E0 BA F9 02 00 C1 17 86 46 05 91 BA F9 04 00 C1 17 CD E9 03 10 BA F9 06 00 EE E7 BA F9 02 20 3A F9 0A 6C 08 96 91 1B BA F9 04 30 3A F9 08 6C 09 96 9A 1B BA F9 06 70 3A F9 06 6C 0A 96 C3 69 A7 EB 06 0C 5A F8 04 0C 0C 90 18 1A A0 FB 01 37 CD 17 00 26 06 FB 01 71 00 FB 05 1E A0 FB 02 57 06 FB 02 71 4F EA E2 7B 00 FB 0B 12 03 92 A0 FB 0C 72 06 FB 0C 21 4F EA EC 78 08 FB 00 18
9:14:48 AM
9:14:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 27 09 81 80 DA F8 08 10 0C 98 AB 46 0E 1A 00 20 41 10 4F EA 36 00 C0 18 41 EB 0E 01 32 46 00 23 BF F7 41 FC CD E9 05 10 00 20 41 10 4F EA 36 00 03 9A 00 E0 C5 E0 10 EB 0B 00 51 41 32 46 00 23 BF F7 31 FC 05 46 8A 46 00 20 41 10 4F EA 36 00 C0 19 41 EB 08 01 32 46 00 23 BF F7 24 FC 02 46 0B 46 DD E9 05 10 08 9E 16 EB 00 0E 41 EB E6 77 09 9E 05 97 75 19 4A EB E6 70 CD E9 03 05 0A 9E 16 EB 02 0A
9:14:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 28 09 81 80 43 EB E6 7B D9 F8 00 00 07 90 05 9A 50 F8 24 C0 D9 F8 08 00 AE FB 0C 35 50 F8 24 00 02 FB 0C 52 4F EA EC 78 4F EA E0 71 08 90 0E FB 08 22 4F F4 00 50 1B 18 42 F1 00 00 9B 0B 43 EA 80 43 DD E9 03 52 08 98 A2 FB 00 67 05 FB 00 70 02 FB 01 02 4F F4 00 50 30 18 42 F1 00 02 80 0B 40 EA 82 40 1A 1A 07 98 40 F8 24 20 08 98 05 9B AE FB 00 56 03 FB 00 60 0E FB 01 01 4F F4 00 50 28 18 41 F1
9:14:49 AM
9:14:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 29 09 81 80 00 01 80 0B 40 EA 81 40 DD E9 03 21 A1 FB 0C 35 02 FB 0C 52 01 FB 08 21 4F F4 00 52 9B 18 41 F1 00 01 8A 04 42 EA 93 31 41 18 D9 F8 08 00 40 F8 24 10 D9 F8 00 00 50 F8 24 10 A1 FB 0A 67 4F EA E1 75 05 FB 0A 72 01 FB 0B 21 4F F4 00 52 B2 18 41 F1 00 01 92 0B 42 EA 81 42 40 F8 24 20 D9 F8 08 00 55 46 50 F8 24 20 A2 FB 05 67 D3 17 03 FB 0A 73 02 FB 0B 31 4F F4 00 52 B2 18 41 F1 00 01
9:14:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 2A 09 81 80 8B 04 43 EA 92 31 40 F8 24 10 D9 F8 0C 20 52 F8 24 00 A0 FB 0A 76 C3 17 03 FB 0A 61 00 FB 0B 11 4F F4 00 50 38 18 41 F1 00 01 80 0B 40 EA 81 40 42 F8 24 00 64 1C E4 B2 03 2C FF F4 BB AE 0D B0 AD E6 2D E9 F0 4F 57 4D 82 46 57 4C E8 69 87 B0 00 28 7C D0 02 A8 B0 F7 17 FA 00 28 77 D1 00 21 BD F8 08 00 EA 69 05 E0 23 88 98 42 04 D3 08 34 49 1C C9 B2 91 42 F7 D3 91 B1 91 42 1D D1 34 F9
9:14:50 AM
9:14:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 2B 09 81 80 06 0C C1 17 86 46 05 91 34 F9 04 0C C1 17 CD E9 00 01 34 F9 02 0C 00 BF 4F EA E0 7B 81 46 7D E0 B4 F9 02 00 C1 17 86 46 05 91 B4 F9 04 00 C1 17 CD E9 00 01 B4 F9 06 00 EE E7 B4 F9 02 10 34 F9 06 2C 01 92 89 1A B4 F9 04 50 34 F9 04 2C 00 92 AA 1A B4 F9 06 60 34 F9 02 5C 04 95 A6 EB 05 0C 34 F8 08 5C CB 17 40 1B A0 FB 01 E7 C6 17 06 FB 01 71 00 FB 03 19 05 95 A0 FB 02 53 C1 17 01 FB
9:14:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 2C 09 81 80 02 31 4F EA E2 78 A0 FB 0C 72 00 FB 08 16 C1 17 01 FB 0C 21 4F EA EC 7B 0B FB 00 1B A8 46 20 88 05 9D 42 1B D3 17 D0 17 41 10 4F EA 32 00 10 EB 0E 00 14 46 41 EB 09 01 BF F7 F3 FA 81 46 E3 17 E0 17 05 91 41 10 22 46 4F EA 34 00 00 E0 C6 E0 10 EB 08 00 71 41 BF F7 E4 FA 05 46 88 46 E3 17 E0 17 22 46 41 10 4F EA 34 04 E0 19 41 EB 0B 01 BF F7 D7 FA 0C 46 01 9A 05 99 12 EB 09 0E 41 EB
9:14:51 AM
9:14:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 2D 09 81 80 E2 76 05 96 00 9A 03 46 50 19 48 EB E2 76 04 9D CD E9 00 06 15 EB 03 09 44 EB E5 7B 4F F0 00 00 04 E0 00 00 A0 7E 00 10 C0 7F 00 10 DA F8 00 30 04 93 05 9C 53 F8 20 C0 4F F4 00 53 AE FB 0C 56 04 FB 0C 64 4F EA EC 78 0E FB 08 44 EB 18 DA F8 08 10 44 F1 00 04 A5 04 45 EA 93 34 51 F8 20 10 DD E9 00 35 A3 FB 01 67 05 FB 01 75 4F EA E1 72 03 FB 02 53 4F F4 00 55 75 19 43 F1 00 03 AD 0B
9:14:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 2E 09 81 80 45 EA 83 45 64 1B AE FB 01 56 04 9B 43 F8 20 40 05 9C 04 FB 01 61 0E FB 02 11 4F F4 00 52 AA 18 41 F1 00 01 8B 04 43 EA 92 31 DD E9 00 32 A3 FB 0C 45 02 FB 0C 52 03 FB 08 23 4F F4 00 52 A2 18 43 F1 00 03 92 0B 42 EA 83 42 8A 18 DA F8 08 10 41 F8 20 20 DA F8 00 40 54 F8 20 10 A1 FB 09 67 4F EA E1 75 05 FB 09 72 01 FB 0B 21 4F F4 00 52 B2 18 41 F1 00 01 8B 04 43 EA 92 31 44 F8 20 10
9:14:52 AM
9:14:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 2F 09 81 80 DA F8 08 30 53 F8 20 10 A1 FB 09 67 CD 17 05 FB 09 72 01 FB 0B 21 4F F4 00 52 B2 18 41 F1 00 01 8C 04 44 EA 92 31 43 F8 20 10 DA F8 0C 40 54 F8 20 20 A2 FB 09 67 D5 17 05 FB 09 73 02 FB 0B 31 4F F4 00 52 B2 18 41 F1 00 01 8B 04 43 EA 92 31 44 F8 20 10 40 1C C0 B2 03 28 FF F4 61 AF 07 B0 5D E5 70 B5 FE 4C 05 46 04 F1 7E 01 A3 6A 62 69 FF F7 0E FC 28 46 FF F7 54 FD 28 46 FF F7 A1 FE
9:14:53 AM
9:14:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 30 09 81 80 D4 E9 08 23 04 F5 B0 71 28 46 BD E8 70 40 FF F7 FF BB 10 B5 00 21 01 60 41 60 08 30 04 46 AF F7 FD F9 20 46 BD E8 10 40 AF F7 FC B9 F8 B5 04 46 08 30 0D 46 06 46 AF F7 FD F9 B0 F5 7A 7F 18 D3 30 46 AF F7 EF F9 69 46 03 20 B0 F7 2F FB 01 00 4F F0 00 00 11 D0 9D F9 00 20 23 68 02 F2 11 12 93 42 07 D1 61 68 49 1C 61 60 05 29 01 D1 60 60 2B 60 F8 BD C4 E9 00 20 F8 BD 20 60 60 60 F8 BD
9:14:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 31 09 81 80 2D E9 F0 5F 07 46 0A 9E 89 46 93 46 96 F8 00 A0 4F EA 9A 08 D2 48 00 25 04 6B 00 20 01 06 41 EA 13 21 18 06 22 46 2B 46 BF F7 44 F9 02 46 00 20 D9 45 24 D9 A9 EB 0B 03 3C 21 B3 FB F1 F1 51 45 01 D3 38 60 1C E0 B1 FB F8 F0 08 FB 10 13 80 B1 03 28 11 D0 31 5C 30 44 40 78 08 1A 58 43 B0 FB F8 F0 08 1A A2 FB 00 01 00 0A 40 EA 01 60 38 60 06 E0 FF 21 70 78 F0 E7 F1 78 00 20 ED E7 38 60
9:14:54 AM
9:14:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 32 09 81 80 C7 F8 04 90 BD E8 F0 9F 2D E9 F0 4F DD F8 24 B0 4F F0 00 0E 4F F0 80 78 4F F0 00 09 B0 4E 00 25 F4 6A 36 6B 00 27 AC 46 4F F0 FF 0A 8B F8 00 A0 D0 F8 04 A0 A3 EB 0A 0A BA F1 78 0F 00 D3 43 60 D0 F8 04 A0 A3 EB 0A 0A BA F1 3C 0F 28 D3 4F F0 01 0C D2 F8 00 A0 0A FB 0A EE D2 F8 04 A0 0A FB 0A EA 92 68 02 FB 02 A2 4F F0 03 0A B2 FB FA F2 43 60 A8 FB 02 AE 09 FB 02 E2 00 23 08 FB 03 23
9:14:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 33 09 81 80 02 68 4F F0 00 08 A2 FB 04 9E 08 FB 04 E4 02 FB 05 42 1A EB 09 04 53 41 22 0E 42 EA 03 22 02 60 00 68 00 22 A0 FB 06 34 02 FB 06 42 00 FB 07 20 4F F0 80 72 9A 18 40 F1 00 00 03 02 43 EA 12 60 BC F1 00 0F 01 D0 8B F8 00 00 08 44 67 E4 3E B5 01 24 84 48 B0 F8 50 00 B0 F7 7A F8 B0 F7 AF FE 40 07 0F D5 7E 48 68 30 FD F7 BF FD 0C 21 02 A8 CD E9 00 10 0A 46 7A 49 00 23 68 31 14 20 C8 F7
9:14:55 AM
9:14:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 34 09 81 80 6E FE 04 46 14 B3 76 4A 74 32 A2 F1 3C 01 01 F1 30 00 FF F7 13 FA 98 B1 71 48 71 49 68 30 00 79 88 70 AF F2 41 23 01 F1 74 02 38 31 01 F1 30 00 AF F7 5B FC 40 B1 32 20 02 F0 9D FD 00 24 03 E0 32 20 02 F0 98 FD 00 24 04 B1 01 24 20 46 3E BD 00 B5 89 B0 01 AA 04 A9 06 A8 FF F7 EF F9 00 28 05 D0 00 23 01 AA 04 A9 06 A8 AF F7 3E FC 09 B0 00 BD 5D 48 5B 49 82 68 CB 68 9A 43 82 60 82 69
9:14:56 AM
9:14:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 35 09 81 80 C9 69 8A 43 82 61 70 47 10 B5 04 46 55 48 50 30 01 88 21 43 01 80 60 07 02 D5 01 20 EB F7 DD FC E0 05 04 D5 4F F4 80 71 06 20 FE F7 52 FE 20 46 B0 F7 0E F8 4C 48 B8 30 AF F7 B4 F8 BD E8 10 40 48 48 FE F7 E4 BD 10 B5 47 49 00 20 88 60 88 61 43 49 88 80 44 48 18 21 D8 30 A7 F7 FE FB 42 49 04 22 08 31 84 20 C9 F7 5B F8 3F 49 04 22 18 31 88 20 C9 F7 55 F8 3C 49 18 22 D8 31 BD E8 10 40
9:14:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 36 09 81 80 8C 20 C9 F7 4D B8 10 B5 FD F7 19 FD FE F7 06 FA FE F7 4F FE FE F7 D4 FE BD E8 10 40 FE F7 7C BF 1C B5 04 46 60 07 18 D5 01 21 05 20 02 F0 9B FE 01 21 1A 20 02 F0 97 FE 17 20 02 F0 1C FD 01 A9 00 20 FE F7 53 FD 01 98 41 1C 16 D0 40 1C 01 90 01 A9 00 20 FE F7 56 FD 0F E0 69 46 1A 20 B4 F7 17 FE 50 B1 BD F8 00 00 38 B1 01 21 05 20 02 F0 7A FE 01 21 1A 20 02 F0 76 FE 20 07 02 D5 18 20
9:14:57 AM
9:14:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 37 09 81 80 02 F0 F9 FC E0 07 0B D0 01 21 06 20 02 F0 6B FE 01 21 1A 20 02 F0 67 FE 15 20 02 F0 EC FC 0F E0 69 46 19 20 B4 F7 F4 FD 50 B1 BD F8 00 00 38 B1 01 21 06 20 02 F0 57 FE 01 21 1A 20 02 F0 53 FE A0 07 02 D5 16 20 02 F0 D6 FC E0 04 06 D5 01 21 37 20 02 F0 48 FE 80 20 02 F0 CD FC 60 05 05 E0 A0 7E 00 10 D4 86 00 10 50 80 00 10 0B D5 01 21 1A 20 02 F0 38 FE 01 21 3D 20 02 F0 34 FE 35 20
9:14:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 38 09 81 80 02 F0 B9 FC 0B E0 69 46 1B 20 B4 F7 C1 FD 30 B1 BD F8 00 00 18 B1 01 21 3D 20 02 F0 24 FE 20 04 02 D5 36 20 02 F0 A7 FC 60 06 06 D5 01 21 18 20 02 F0 19 FE 32 20 02 F0 9E FC 20 06 03 D5 00 21 18 20 02 F0 10 FE 1C BD 70 B5 10 B1 FE 48 BB F7 CB F8 00 24 FC 4E FD 4D 18 3E 55 F8 24 10 09 B1 B0 69 88 47 64 1C E4 B2 03 2C F6 D3 00 20 B0 61 70 BD F7 49 08 44 F7 49 88 42 01 D8 01 20 70 47
9:14:58 AM
9:14:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 39 09 81 80 00 20 70 47 01 46 41 F2 B0 10 24 22 C8 F7 BD BD 01 46 41 F2 B0 10 24 22 C8 F7 82 BF 70 B5 04 46 E9 48 58 30 FF F7 F4 FF D0 B1 E7 4D E1 43 58 35 28 68 88 42 02 D2 20 44 28 60 02 E0 4F F0 FF 30 28 60 A8 69 A0 42 02 D9 00 1B A8 61 01 E0 00 20 A8 61 DD 48 58 30 FF F7 D5 FF 08 B1 28 68 70 BD 00 20 70 BD 01 46 41 F2 34 20 28 22 C8 F7 8D BD 00 28 02 D0 00 21 41 60 01 60 70 47 01 46 41 F2
9:14:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 3A 09 81 80 34 20 28 22 C8 F7 4C BF 00 B5 89 B0 24 21 68 46 A7 F7 E3 FA D0 48 04 90 06 90 68 46 FF F7 B2 FF A5 E6 00 B5 8B B0 28 21 01 A8 A7 F7 D6 FA 01 A8 FF F7 D8 FF 0B B0 00 BD 10 B5 88 B0 04 46 01 A8 FE F7 AF FE C0 B1 01 98 40 1C 01 90 60 1C 15 D0 02 94 BD 48 01 21 18 38 81 80 02 99 C1 60 01 A8 FE F7 A4 FE 70 B1 BD 49 00 20 08 70 01 22 81 20 C8 F7 4B FD 08 B0 10 BD 00 20 FB E7 02 A8 AE F7
9:14:59 AM
9:14:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 3B 09 81 80 2E FF E6 E7 00 20 F5 E7 28 B1 08 23 01 46 08 22 18 46 C8 F7 05 BF 00 20 70 47 2D E9 F0 4F A3 B0 4F F0 00 08 00 26 08 96 00 27 A7 48 A8 38 FF F7 30 FD 09 A8 AE F7 13 FF A8 48 40 21 7E 30 A7 F7 B3 FA A6 4C 66 70 1F A8 C8 F7 2B FC 40 F2 DC 50 BA F7 5C FE 04 F5 1A 70 AE F7 20 FF 04 F5 E0 70 05 46 AE F7 1B FF 28 46 AE F7 1C FF FF F7 8B FE FE F7 49 FE FF F7 0D F8 04 F1 30 01 0A 1F A1 F1
9:14:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 3C 09 81 80 10 03 CD E9 03 32 07 A8 CD E9 05 10 01 F5 98 71 10 3A CD E9 01 21 A1 F1 40 00 13 1F 00 90 A4 32 19 1F A2 38 FD F7 B1 FB 40 B9 66 61 A6 61 E6 61 26 62 8B 48 E0 62 4F F4 4D 70 20 63 9D F8 80 00 80 07 0F D5 17 20 02 F0 69 FD 10 B9 30 20 02 F0 92 FB 01 21 24 20 02 F0 06 FD 01 21 17 20 02 F0 02 FD 07 E0 00 21 24 20 02 F0 FD FC 00 21 17 20 02 F0 F9 FC DF F8 D0 91 01 25 A9 F1 98 09 A9 F8
9:15:00 AM
9:15:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 3D 09 81 80 7E 50 00 20 FF F7 A3 FD 28 B9 01 20 FF F7 9F FD 08 B9 A9 F8 7E 60 E6 65 26 66 66 66 6F 48 60 30 AE F7 C0 FE 68 48 98 38 81 68 C1 60 81 69 C1 61 1B A8 FF F7 69 FF 20 B9 1B A8 AE F7 90 FE 1B 98 1C 90 01 22 65 49 81 20 C8 F7 6A FE 63 48 5E 4C 00 78 18 3C 38 B1 B0 F7 32 FC 40 05 08 D4 1B 98 FF F7 2A FF 04 E0 14 A8 FE F7 DB FD 15 98 E0 60 B0 F7 25 FC 42 07 54 48 A0 F1 18 00 00 F1 35 09
9:15:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 3E 09 81 80 00 F1 36 0A 00 F1 37 0B 00 F1 14 01 00 F1 40 00 CD E9 21 01 3A D5 1B A8 AE F7 61 FE FE F7 CB FD 49 48 58 21 18 38 A7 F7 D8 F9 FF F7 FA FE FF F7 EB FE 0A 96 01 22 0A A9 80 20 C8 F7 66 FC 49 48 20 64 04 22 AC 20 21 99 C8 F7 5F FC 01 22 A1 1D A4 20 C8 F7 5A FC 01 22 49 46 A5 20 C8 F7 55 FC 01 22 51 46 A6 20 C8 F7 50 FC 01 22 59 46 A7 20 C8 F7 4B FC 02 22 A8 20 22 99 C8 F7 46 FC 08 96
9:15:01 AM
9:15:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 3F 09 81 80 01 22 08 A9 61 20 C8 F7 40 FC 39 E0 01 22 0A A9 80 20 C8 F7 05 FE 04 22 AC 20 21 99 C8 F7 00 FE 30 49 20 6C C9 43 88 42 0C D0 C9 43 88 42 09 D0 21 64 B0 F7 C4 FB 40 05 04 D4 04 22 AC 20 21 99 C8 F7 23 FC 01 22 A1 1D A4 20 C8 F7 E9 FD 01 22 49 46 A5 20 C8 F7 E4 FD 01 22 51 46 A6 20 C8 F7 DF FD 01 22 59 46 A7 20 C8 F7 DA FD 02 22 A8 20 22 99 C8 F7 D5 FD 01 22 08 A9 61 20 C8 F7 D0 FD
9:15:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 40 09 81 80 07 A8 00 90 15 48 9D F8 20 30 48 30 1B 9A 09 99 FF F7 36 FC DF F8 44 90 41 F2 88 30 09 F1 50 09 99 F8 04 10 01 29 4C D0 BA F7 35 FD 06 48 7C 30 FF F7 64 FE 04 48 38 30 AE F7 F4 FD 07 48 40 30 FF F7 56 FE 00 48 0F E0 E8 80 00 10 90 5F 07 00 00 04 CF C3 7F 4D 1F B8 00 06 98 25 A0 7E 00 10 CE 31 F8 00 21 3F 31 53 58 30 FF F7 11 FE B0 F7 66 FB C0 06 02 D5 2F 20 02 F0 7D FA B0 F7 5F FB
9:15:02 AM
9:15:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 41 09 81 80 C0 07 7D D0 1C A8 AE F7 AA FD B0 F7 58 FB 40 05 09 D4 DD E9 1B 10 40 1A FA 49 0A 68 10 44 08 60 08 46 FF F7 1F FE B0 F7 4A FB 40 06 14 D5 F6 49 1C 98 88 42 0A D1 65 80 99 F8 04 00 01 28 03 D0 0B E0 BA F7 E8 FC B1 E7 01 27 06 E0 99 F8 04 00 01 28 02 D0 65 80 00 E0 66 80 A0 8A 80 07 01 D5 4F F0 01 08 60 88 01 28 11 D0 DD E9 1B 10 88 42 0D D3 DD E9 1B 10 41 1A D9 F8 00 00 81 42 03 D9
9:15:03 AM
9:15:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 42 09 81 80 99 F8 04 10 01 B9 10 B9 B8 F1 00 0F 2C D0 1B 98 FF F7 AF FD 40 B3 10 A9 1B 98 AE F7 BB FC 10 A8 AE F7 A5 FC 1B 98 1C 90 17 B1 2A 20 02 F0 23 FA B0 F7 05 FB 40 05 05 D5 9D F8 28 00 40 F0 01 00 0A 90 11 E0 1B 98 C9 F7 D7 FB 9D F8 28 00 C1 07 0A D1 40 F0 01 00 0A 90 01 22 0A A9 80 20 C8 F7 54 FB 29 20 02 F0 07 FA B0 F7 E9 FA 40 06 0A D5 B0 F7 E5 FA 40 05 06 D4 B0 F7 DF FA 40 20 00 E0
9:15:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 43 09 81 80 72 E0 B0 F7 E4 FA 06 20 AC F7 0A FB 40 B1 B0 F7 D6 FA 80 07 02 D4 06 20 02 F0 ED F9 BB 48 05 80 9D F8 28 00 C0 07 00 D0 25 80 B0 F7 C8 FA 40 05 60 D4 01 22 0B A9 60 20 C8 F7 F2 FC B0 F7 BF FA 80 07 01 D5 0B 96 09 E0 9D F8 2C 00 00 B9 07 20 0B 90 00 22 10 46 1B 99 FE F7 86 FC 9D F8 2C 00 C0 07 04 D0 00 22 01 20 1B 99 FE F7 7D FC 9D F8 2C 00 80 07 04 D5 00 22 02 20 1B 99 FE F7 74 FC
9:15:04 AM
9:15:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 44 09 81 80 9D F8 2C 00 40 07 04 D5 00 22 03 20 1B 99 FE F7 6B FC 9D F8 2C 00 C0 43 40 07 04 D1 00 22 04 20 1B 99 FE F7 61 FC B0 F7 8A FA 80 07 04 D4 98 48 81 88 41 F0 20 01 81 80 B0 F7 81 FA 80 07 19 D4 1B 98 FF F7 16 FD 70 B1 60 88 60 B9 DD E9 1B 10 88 42 0F D9 99 F8 04 00 01 28 0B D1 DD E9 1B 10 40 1A FF F7 1B FD 05 E0 9D F8 28 00 C0 07 01 D0 25 80 65 80 87 48 05 80 00 20 FF F7 E5 FC 81 4D
9:15:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 45 09 81 80 4F F0 FF 30 A4 3D 28 80 A5 F1 20 00 46 84 24 30 AE F7 C8 FC AE 81 20 88 08 BB 13 A8 AE F7 C4 FB 10 A9 1B 98 AE F7 F6 FB 0C AA 0D A9 10 A8 AE F7 71 FC BD F8 30 00 C0 07 07 D0 BD F8 4E 00 C0 07 0A D1 76 20 02 F0 57 F9 06 E0 BD F8 4E 00 C0 07 02 D0 75 20 02 F0 4F F9 BD F8 4E 00 A0 82 B0 F7 2E FA 40 05 0A D4 02 22 0D F1 4E 01 A8 20 C8 F7 8C FA 08 22 1B A9 10 46 C8 F7 87 FA 08 22 1D A9
9:15:05 AM
9:15:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 46 09 81 80 00 20 C8 F7 4D FC B0 F7 1A FA 80 07 19 D5 BD F8 74 00 40 1C AD F8 74 00 BD F8 76 00 40 1C 80 B2 AD F8 76 00 0A 28 05 D3 01 21 19 20 02 F0 9B FA AD F8 76 60 31 20 02 F0 1E F9 01 21 35 20 02 F0 92 FA 1E A8 AE F7 4B FC B0 F7 F9 F9 40 05 04 D4 08 22 1D A9 00 20 C8 F7 58 FA A6 80 26 77 FF 20 E0 77 4D 49 91 F8 61 10 01 29 09 D0 84 F8 2C 60 26 63 84 F8 34 60 FD F7 08 FC 23 B0 BD E8 F0 8F
9:15:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 47 09 81 80 61 7F 41 F0 01 01 61 77 84 F8 2C 00 F0 E7 40 48 81 88 41 F4 00 41 81 80 70 47 3D 48 81 88 41 F4 80 41 81 80 70 47 70 B5 39 4E B0 88 00 04 01 D4 00 20 70 BD FA F7 2E FC 10 F4 88 5F 01 D0 00 20 70 BD 01 20 C8 F7 05 FC C8 F7 45 F9 F8 F7 3D F9 AD F7 B6 F8 DD F7 84 FF 00 21 08 46 CD F7 06 F9 F6 F7 39 FE 2D 4D 00 24 AC 60 AC 61 EC 60 A5 F1 30 00 44 65 84 65 C4 65 04 66 44 66 84 66 C4 66
9:15:06 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:15:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 48 09 81 80 04 67 24 21 74 30 A6 F7 68 FF A5 F8 68 40 EC 66 18 21 05 F1 D8 00 A6 F7 60 FF 80 35 E8 7F AD F7 95 FE FF 20 E8 77 01 20 EB F7 FF F9 00 21 18 20 B4 F7 6D F9 00 20 EB F7 E6 F9 05 F1 20 00 AE F7 ED FB 85 F8 2C 40 2C 77 00 21 08 46 FB F7 53 F8 00 21 08 46 F8 F7 26 F9 F8 F7 DF F8 04 F0 47 FE 00 21 08 46 04 F0 A1 FD EA F7 57 FE B0 88 20 F4 00 40 20 F4 80 40 B0 80 DC 20 02 F0 7C F8 01 20
9:15:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 49 09 81 80 70 BD 00 00 64 81 00 10 00 FC 30 3C B2 94 00 10 A0 7E 00 10 B0 94 00 10 D4 86 00 10 50 80 00 10 FC 48 81 88 41 F4 00 51 81 80 70 47 F9 48 81 88 41 F4 80 51 81 80 70 47 10 B5 F6 4C A0 88 80 04 1E D5 F8 F7 C2 F8 AD F7 3B F8 DD F7 09 FF F6 F7 C2 FD 00 21 08 46 F8 F7 E5 F8 04 F0 08 FE 00 21 08 46 04 F0 62 FD EA F7 18 FE A0 88 20 F4 00 50 20 F4 80 50 A0 80 BD E8 10 40 F7 20 02 F0 3B B8
9:15:07 AM
9:15:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 4A 09 81 80 10 BD E6 49 E4 48 08 64 04 22 40 31 AC 20 C8 F7 7C B9 E1 48 E1 49 C0 43 08 64 04 22 40 31 AC 20 C8 F7 73 B9 70 B5 01 24 DC 4E DB 4D 31 6C A9 42 09 D0 E8 43 81 42 06 D0 04 22 06 F1 40 01 AC 20 C8 F7 2E FB 28 B1 30 6C A8 42 00 D1 00 24 20 46 96 E7 20 46 94 E7 00 B5 D9 B0 68 46 FC F7 4A FE 30 B1 68 46 FC F7 D9 FF 20 B1 01 20 59 B0 00 BD 00 20 FB E7 00 20 F9 E7 00 B5 87 B0 04 A8 FC F7
9:15:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 4B 09 81 80 F4 FF 0C 21 03 A8 CD E9 00 10 0A 46 00 23 04 A9 14 20 C8 F7 A4 F8 07 B0 00 BD 00 B5 AD F2 4C 5D 01 A8 FD F7 1B FB 38 B1 01 A8 FD F7 65 FC 28 B1 01 20 0D F2 4C 5D 00 BD 00 20 FA E7 00 20 F8 E7 00 B5 9B B0 01 A8 FE F7 2E F8 30 B1 01 A8 FE F7 5E F8 20 B1 01 20 1B B0 00 BD 00 20 FB E7 00 20 F9 E7 AF 49 49 7D 01 70 01 20 70 47 AC 4A 20 B1 01 28 05 D0 00 20 08 60 70 47 D0 68 08 60 01 E0
9:15:08 AM
9:15:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 4C 09 81 80 D0 69 08 60 01 20 70 47 A5 4A 20 B1 01 28 05 D0 00 20 08 60 70 47 10 6C 08 60 01 E0 50 6C 08 60 01 20 70 47 03 B5 83 B0 52 21 01 EB 40 03 02 21 02 A8 CD E9 00 10 0A 46 04 A9 1B 20 C8 F7 4F F8 10 B1 01 20 05 B0 00 BD 00 20 FB E7 38 B5 0C 46 69 46 DE F7 7E FA 48 B1 91 48 9D F8 00 20 00 EB 42 00 B0 F8 52 00 20 80 01 20 38 BD 00 20 38 BD 38 B5 0C 46 69 46 DE F7 6C FA 50 B1 88 4A 9D F8
9:15:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 4D 09 81 80 00 00 02 EB 40 02 A2 F8 52 40 21 46 FF F7 CA FF 38 BD 00 20 38 BD 2D E9 F0 47 01 25 00 24 DF F8 00 82 A8 F2 AC 59 D8 F8 2C 00 D9 F8 00 10 08 42 05 D1 D8 F8 30 00 D9 F8 0C 10 08 42 01 D0 01 26 00 E0 00 26 31 46 10 20 EA F7 8A FD 00 B9 00 25 72 4F 76 B1 97 F8 37 00 C0 07 13 D1 E4 20 01 F0 4A FF 97 F8 37 00 40 F0 01 00 87 F8 37 00 01 24 08 E0 97 F8 37 00 C1 07 04 D0 20 F0 01 00 87 F8
9:15:09 AM
9:15:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 4E 09 81 80 37 00 01 24 D8 F8 34 00 D9 F8 00 10 08 42 05 D1 D8 F8 38 00 D9 F8 0C 10 08 42 01 D0 01 26 00 E0 00 26 31 46 11 20 EA F7 5B FD 00 B9 00 25 6E B1 97 F8 37 00 80 07 12 D4 E5 20 01 F0 1C FF 17 F8 37 0F 40 F0 02 00 38 70 01 24 08 E0 97 F8 37 00 81 07 04 D5 20 F0 02 00 87 F8 37 00 01 24 2C B1 4E 49 01 22 37 31 A7 20 C8 F7 4F F8 28 46 BD E8 F0 87 4B 4A 20 B1 01 28 05 D0 00 20 08 60 70 47
9:15:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 4F 09 81 80 10 69 08 60 01 E0 10 6A 08 60 01 20 70 47 10 B5 9C B0 04 46 02 A8 FD F7 89 FF 00 28 0B D0 01 A8 AE F7 1D FA 00 28 06 D0 01 98 03 90 AD F8 08 40 02 A8 FD F7 82 FF 1C B0 10 BD 10 B5 AB F7 C4 FE 08 B1 00 20 10 BD 00 20 AB F7 B3 FE 01 20 10 BD 0E B5 02 AA 02 23 CD E9 00 32 01 46 08 23 02 22 1B 20 C7 F7 3C FF 08 B1 01 20 0E BD 00 20 0E BD 1C B5 04 46 00 20 20 80 01 A8 AE F7 15 FD 20 B9
9:15:10 AM
9:15:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 50 09 81 80 20 88 9D F8 04 10 08 43 20 80 69 46 14 20 B3 F7 BF FF 30 B1 BD F8 00 00 18 B1 20 88 40 F4 80 70 20 80 FF F7 7F FE 18 B1 20 88 40 F4 00 70 20 80 01 20 1C BD 0E B5 08 B1 00 20 0E BD 02 A8 08 22 CD E9 00 20 00 23 01 20 C7 F7 49 FF 08 B1 01 20 0E BD 00 20 0E BD 0E B5 02 AA 1C 23 CD E9 00 32 01 46 08 23 1C 22 01 20 C7 F7 F9 FE 08 B1 01 20 0E BD 00 20 0E BD 0E B5 02 AA 1C 23 CD E9 00 32
9:15:11 AM
9:15:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 51 09 81 80 01 46 08 23 1C 22 01 20 C7 F7 29 FF 50 B1 01 20 0E BD 00 00 A0 7E 00 10 DE C0 CE AC D0 80 00 10 D4 86 00 10 00 20 F3 E7 10 B5 04 46 FD 48 01 79 21 71 00 68 20 60 04 F1 08 00 B4 F7 E8 FA 60 1D B4 F7 BE FA 01 20 10 BD 10 B5 04 46 F5 49 20 79 08 71 20 68 08 60 60 79 B4 F7 18 FA A0 68 B4 F7 B4 FA 01 20 10 BD 2D E9 F0 43 89 B0 04 46 07 A9 20 46 AE F7 33 F8 48 B1 00 26 06 A8 AE F7 6F F9
9:15:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 52 09 81 80 DD E9 06 21 91 42 05 D9 8D 1A 04 E0 00 20 09 B0 BD E8 F0 83 55 1A DF F8 90 93 A9 F2 04 68 B9 F8 1A 00 A8 42 02 D3 B8 F8 00 00 18 B1 05 20 01 F0 22 FE 01 26 20 46 AE F7 9A F8 00 20 A8 F8 00 00 D8 49 09 79 01 29 02 D1 D8 49 89 69 09 B1 A8 F8 02 00 08 90 01 22 08 A9 80 20 C7 F7 56 FF B9 F8 1A 20 DD E9 06 01 F8 F7 57 F9 00 24 10 20 00 EB 04 17 10 22 01 A9 38 46 C8 F7 12 F9 DD E9 06 10
9:15:12 AM
9:15:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 53 09 81 80 88 42 02 D9 04 98 41 19 01 E0 04 98 41 1B 04 91 10 22 01 A9 38 46 C7 F7 38 FF 64 1C E4 B2 04 2C E4 D9 26 B1 20 24 20 20 F3 F7 C6 FF 05 E0 48 F2 40 04 4F F4 00 40 F3 F7 BF FF 20 46 06 99 F3 F7 7C FC DD E9 06 01 FB F7 96 FF 07 98 C8 F7 94 FF EA F7 28 FB 16 B1 28 20 01 F0 CD FD 99 F8 15 00 01 28 00 D0 30 B9 05 A8 AE F7 1E F8 BD F8 16 00 A8 F8 14 00 01 20 8A E7 F0 B5 89 B0 8C 46 16 46
9:15:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 54 09 81 80 1F 46 01 78 8D F8 14 10 41 78 8D F8 15 10 00 24 00 21 31 60 00 25 BD F8 14 10 A1 F5 7F 42 FF 3A 00 D1 08 24 81 78 FF 29 01 D1 44 F0 04 04 C1 78 FF 29 01 D1 44 F0 02 04 00 79 FF 28 01 D1 44 F0 01 04 06 A9 60 46 AE F7 25 F8 04 AA 01 A9 06 A8 AE F7 A0 F8 BD F8 04 10 88 07 09 D0 00 20 0D 2C 14 D0 07 DC 9C B3 01 2C 42 D0 09 2C 41 D1 31 E0 01 20 F4 E7 0E 2C 05 D0 0F 2C 3A D1 8C 48 30 60
9:15:13 AM
9:15:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 55 09 81 80 01 25 36 E0 8B 48 30 60 01 25 32 E0 9F B1 9D F8 06 10 01 29 05 D0 02 29 0B D0 87 4A 51 5C 08 44 10 E0 9D F8 07 10 1C 29 01 D2 1F 20 0A E0 1C 30 08 E0 1C 30 06 E0 9D F8 06 10 03 29 08 D0 7E 48 40 1E 08 5C 7A 49 48 43 30 60 01 25 11 E0 0F E0 1C 30 F7 E7 1F B9 49 1E 88 07 03 D0 00 20 18 B1 76 48 02 E0 01 20 FA E7 75 48 30 60 01 25 00 E0 02 25 09 B0 28 46 F0 BD 70 B5 04 46 69 4D 50 3D
9:15:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 56 09 81 80 28 78 34 EA 00 00 18 D0 10 2C 08 D0 80 2C 09 D1 B1 20 01 F0 30 FD E0 01 F3 F7 0E FF 02 E0 B5 20 01 F0 29 FD 28 78 20 43 28 70 5E 49 BD E8 70 40 01 22 50 39 81 20 C7 F7 68 BE A1 E4 70 B5 59 4C 10 3C 60 68 88 42 1F D0 61 60 58 49 08 68 42 1C 01 D0 40 1C 08 60 88 69 00 25 08 B1 40 1E 88 61 88 69 40 B9 51 48 70 38 41 88 21 B9 01 21 41 80 01 20 01 F0 00 FD 20 68 40 1C 20 60 05 28 03 D3
9:15:14 AM
9:15:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 57 09 81 80 4A 48 FF F7 7F F8 25 60 7A E4 70 B5 04 46 45 48 00 79 01 28 01 D0 00 20 72 E4 44 4D 64 26 2A 69 5A B1 A8 69 00 23 A0 FB 06 01 BD F7 C3 FF 20 70 20 78 64 28 04 D9 26 70 07 E0 00 20 20 70 F7 E7 18 B9 A8 69 08 B1 01 20 20 70 01 20 58 E4 35 48 50 38 80 88 70 47 33 48 4A 38 00 88 70 47 32 48 68 30 80 88 70 47 30 48 68 30 90 F8 38 00 70 47 10 B5 86 B0 01 24 00 94 01 A9 00 20 FC F7 4D FB
9:15:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 58 09 81 80 70 B1 DD E9 01 01 CD E9 03 01 00 20 8D F8 14 00 6A 46 2C A1 03 A8 A6 F7 81 FF 01 28 00 D0 00 94 00 98 00 B9 00 94 00 98 06 B0 10 BD 08 B5 00 22 02 60 42 60 24 A2 12 88 02 80 4B 22 82 70 65 22 C2 70 00 91 9D F8 03 10 01 71 9D F8 02 20 01 1D 42 71 9D F8 01 00 88 70 9D F8 00 00 C8 70 08 BD 70 B5 05 46 0C 46 FF F7 C3 FF 01 46 28 46 FF F7 DD FF 08 20 20 80 01 20 6A E4 1C B5 69 46 DD F7
9:15:15 AM
9:15:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 59 09 81 80 68 FF 00 28 36 D0 01 A8 AD F7 A9 FF 07 48 9D F8 00 40 F0 38 00 EB 84 00 41 6A 01 9A 8A 42 15 D9 53 1A 14 E0 F0 7E 00 10 D4 86 00 10 40 81 00 10 80 51 01 00 80 3A 09 00 B4 5F 07 00 00 85 E2 01 80 33 E1 01 25 75 00 00 49 53 4B 00 8B 1A 42 62 FE 49 C2 6A 01 EB 84 01 89 6C 8A 42 0B D2 52 1C C2 62 8A 42 06 D1 37 20 01 F0 45 FC 01 21 1A 20 01 F0 B9 FD 1C BD C1 62 3C 2B FB D3 01 21 C1 62
9:15:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 5A 09 81 80 1C BD 1C B5 69 46 DD F7 24 FF 68 B1 01 A8 AD F7 66 FF EF 48 9D F8 00 30 00 EB 83 02 50 6A 01 99 81 42 03 D9 08 1A 02 E0 01 20 1C BD 40 1A D1 6A E6 4A 02 EB 83 02 92 6C 91 42 03 D3 3C 28 01 D2 01 20 1C BD 00 20 1C BD 1C B5 69 46 DD F7 01 FF 00 28 21 D0 01 A8 AD F7 42 FF DD 48 9D F8 00 40 00 EB 84 00 41 6B 01 9A 8A 42 01 D9 53 1A 00 E0 8B 1A 42 63 D5 49 C2 6B 01 EB 84 01 89 6C 8A 42
9:15:16 AM
9:15:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 5B 09 81 80 0B D2 52 1C C2 63 8A 42 06 D1 B3 20 01 F0 F3 FB 01 21 1A 20 01 F0 67 FD 1C BD C1 63 3C 2B FB D3 01 21 C1 63 1C BD 1C B5 69 46 DD F7 D2 FE 68 B1 01 A8 AD F7 14 FF C6 48 9D F8 00 30 00 EB 83 02 50 6B 01 99 81 42 03 D9 08 1A 02 E0 01 20 1C BD 40 1A D1 6B BD 4A 02 EB 83 02 92 6C 91 42 03 D3 3C 28 01 D2 01 20 1C BD 00 20 1C BD 70 B5 A8 B0 0E A8 FD F7 3D FC C8 B1 B5 4D 9D F8 98 00 80 35
9:15:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 5C 09 81 80 95 F8 34 10 81 42 03 D0 85 F8 34 00 00 20 28 63 0D A8 AD F7 E4 FE 9D F8 98 00 02 28 29 D0 03 28 06 D0 05 28 40 D0 00 20 28 B0 86 E6 00 20 FB E7 28 6B 0D 99 1E 30 88 42 19 D2 3C 20 B1 FB F0 F2 00 FB 12 10 42 1E 1C 2A 01 D8 0C 1A 05 E0 A0 F1 1E 02 1D 2A 07 D8 0C 1A 3C 34 07 A9 20 46 AD F7 19 FE 10 B1 78 E0 00 20 DE E7 00 20 DC E7 00 20 DA E7 0B A9 00 20 F7 F7 AC FA 78 B1 28 6B 0B 99
9:15:17 AM
9:15:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 5D 09 81 80 00 EB 51 00 0D 99 88 42 0C D2 F7 F7 7A F9 04 46 07 A9 20 46 AD F7 FE FD 10 B1 5D E0 00 20 C3 E7 00 20 C1 E7 00 20 BF E7 28 6B 4A F6 C0 01 08 44 0D 99 88 42 5D D2 25 98 46 08 0A A9 01 A8 AD F7 1A FE 40 B3 0D A9 01 A8 AD F7 48 FD 28 B3 01 A8 04 AB 07 C8 07 C3 9D F8 8E 00 8D F8 15 00 9D F8 8F 00 8D F8 16 00 9D F8 90 00 8D F8 17 00 9D F8 91 00 00 EB 80 00 40 00 AD F8 18 00 0C A9 04 A8
9:15:18 AM
9:15:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 5E 09 81 80 AD F7 2C FD 58 B1 DD E9 0C 40 A0 42 09 D2 71 49 21 44 0C 91 08 E0 00 20 86 E7 00 20 84 E7 00 20 82 E7 6C 49 49 42 0C 44 0C 9A 81 1A 20 1A 81 42 03 D3 B0 42 04 D9 00 20 76 E7 B1 42 13 D8 14 46 04 A9 20 46 AD F7 A6 FD 78 B1 BD F8 28 20 07 A9 04 A8 AD F7 E4 FD 50 B1 07 A8 FF F7 C4 FC 50 B1 2C 63 01 20 60 E7 00 20 5E E7 00 20 5C E7 00 20 5A E7 00 20 58 E7 00 20 56 E7 38 B5 00 20 F7 F7
9:15:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 5F 09 81 80 F4 FC 01 09 41 EA 00 10 00 F0 CC 01 89 08 00 F0 33 00 41 EA 80 00 00 F0 AA 01 49 08 00 F0 55 00 41 EA 40 04 68 46 AE F7 75 FA 00 25 38 B9 9D F8 00 00 4F F4 00 01 01 EA 00 40 04 43 00 95 68 46 AE F7 AE FA 38 B9 9D F8 00 00 4F F4 80 01 01 EA C0 30 04 43 00 95 68 46 AE F7 5C FA 30 B9 9D F8 00 00 4F F4 00 11 01 EA 80 30 04 43 00 25 E8 B2 EA F7 29 F9 10 B1 44 F0 00 44 02 E0 6D 1C 03 2D
9:15:19 AM
9:15:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 60 09 81 80 F5 DB 20 46 38 BD 70 B5 8A B0 00 24 00 25 07 95 06 95 07 A8 AE F7 50 FD 70 B9 9D F8 1C 00 C1 07 01 D0 80 21 00 E0 00 21 40 22 02 EA 40 12 0A 43 20 21 01 EA C0 04 14 43 06 A8 AE F7 36 FD 30 B9 BD F8 18 00 08 B1 10 20 00 E0 00 20 04 43 22 4E 74 63 08 A8 AE F7 1E FA 48 B9 9D F8 20 00 80 06 02 D0 4F F4 00 40 00 E0 00 20 04 43 08 95 74 63 08 A8 AE F7 55 FA 48 B9 9D F8 20 00 80 06 02 D0
9:15:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 61 09 81 80 4F F4 80 40 00 E0 00 20 04 43 08 95 74 63 08 A8 AE F7 93 FA 48 B9 9D F8 20 00 80 06 02 D0 4F F4 00 50 00 E0 00 20 04 43 08 95 74 63 09 A8 FF F7 9F FB 28 B1 BD F8 24 00 C1 05 01 D5 80 05 01 D4 44 F4 00 04 74 63 CC F7 C8 FA 07 E0 D4 86 00 10 50 80 00 10 80 AE FE FF A0 7E 00 10 10 B1 4F F4 80 05 00 E0 00 25 25 43 75 63 68 46 F6 F7 7A F8 48 B1 9D F8 00 00 01 28 03 D0 9D F8 14 00 01 28
9:15:20 AM
9:15:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 62 09 81 80 01 D1 45 F4 00 15 75 63 FE 4A B2 F8 78 00 10 B1 4F F0 00 40 00 E0 00 20 28 43 B2 F8 80 10 11 B1 4F F0 80 41 00 E0 00 21 01 43 B2 F8 90 00 10 B1 4F F0 00 50 00 E0 00 20 08 43 70 63 0A B0 FC E4 10 B5 B4 20 01 F0 17 FA 01 21 BD E8 10 40 1A 20 01 F0 89 BB 01 28 01 D0 00 20 70 47 01 20 70 47 2D E9 F0 41 02 46 22 B1 01 2A 05 D0 00 20 BD E8 F0 81 01 20 E2 26 01 E0 02 20 E3 26 E2 4D 01 24
9:15:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 63 09 81 80 05 F1 36 07 94 40 99 B1 01 21 01 F0 6C FB 95 F8 36 00 20 42 1B D1 30 46 01 F0 ED F9 15 F8 36 0F 20 43 28 70 01 22 39 46 A6 20 C7 F7 2E FB 0E E0 00 21 01 F0 58 FB 95 F8 36 00 20 42 07 D0 A0 43 85 F8 36 00 01 22 39 46 A6 20 C7 F7 1E FB 01 20 CD E7 F0 B5 04 46 0D 46 4F F0 00 00 01 46 02 46 4F F0 80 43 03 E0 92 08 42 EA 83 72 9B 08 A6 1A 75 EB 03 06 F7 D3 1A E0 87 18 41 EB 03 06 E7 1B
9:15:21 AM
9:15:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 64 09 81 80 75 EB 06 06 0A D3 24 1A 65 EB 01 05 A4 1A 65 EB 03 05 97 18 43 EB 03 06 38 18 71 41 49 08 4F EA 30 00 4F EA 92 02 42 EA 83 72 4F EA 93 03 52 EA 03 06 E1 D1 F0 BD 2D E9 F0 47 98 B0 07 46 88 46 4F F0 00 09 CD F8 50 90 CD F8 40 90 CD F8 30 90 CD F8 20 90 CD F8 10 90 CD F8 00 90 14 A8 AE F7 F2 F9 06 46 1E B9 10 A8 AE F7 F8 F9 06 46 1E B9 0C A8 AE F7 14 FA 06 46 1E B9 08 A8 AE F7 19 FA
9:15:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 65 09 81 80 06 46 1E B9 04 A8 AE F7 1E FA 06 46 1E B9 68 46 AE F7 23 FA 06 46 00 2E 46 D1 17 99 15 98 13 9A 01 44 11 98 00 25 10 44 0C 1A 65 EB 05 05 97 48 40 78 01 28 39 D0 0F 99 0D 98 0B 9A 08 44 09 99 DD F8 0C C0 11 44 08 44 07 9A 05 99 00 23 11 44 01 9A 62 44 11 44 42 1A 63 EB 03 03 4F F0 03 0A 00 2D 36 DB AF B1 A4 FB 04 01 05 FB 04 11 04 FB 05 11 A2 FB 02 45 03 FB 02 55 02 FB 03 52 00 19
9:15:22 AM
9:15:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 66 09 81 80 51 41 FF F7 66 FF 38 60 B0 FB FA F0 78 60 B8 60 F8 60 B8 F1 00 0F 42 D0 C8 F8 00 90 C8 F8 04 90 C8 F8 08 90 C8 F8 0C 90 39 E0 0F 99 0D 98 03 9A 08 44 01 99 DD F8 1C C0 11 44 01 44 0B 9A 09 98 00 23 10 44 05 9A 62 44 10 44 0A 1A 63 EB 03 03 C4 E7 3F B1 C7 F8 00 90 C7 F8 04 90 C7 F8 08 90 C7 F8 0C 90 B8 F1 00 0F 19 D0 A4 FB 04 01 05 FB 04 11 04 FB 05 11 A2 FB 02 45 03 FB 02 55 02 FB
9:15:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 67 09 81 80 03 52 00 19 51 41 FF F7 24 FF C8 F8 00 00 B0 FB FA F0 C8 F8 04 00 C8 F8 08 00 C8 F8 0C 00 18 B0 30 46 BD E8 F0 87 F0 B5 89 B0 05 46 0C 46 17 46 00 26 08 2D 01 D0 09 2D 03 D1 54 48 80 78 01 28 08 D0 3A 46 21 46 28 46 AB F7 E5 FF 06 46 09 B0 30 46 F0 BD 01 A9 05 A8 FF F7 2D FF 00 28 F6 D1 08 2D 09 D0 D4 B1 01 2C 1A D0 02 2C 1A D0 03 2C 1A D0 38 60 01 26 EA E7 44 B1 01 2C 08 D0 02 2C
9:15:23 AM
9:15:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 68 09 81 80 08 D0 03 2C 08 D0 00 20 38 60 F3 E7 05 98 FB E7 06 98 F9 E7 07 98 F7 E7 08 98 F5 E7 01 98 E8 E7 02 98 E6 E7 03 98 E4 E7 04 98 E2 E7 2D E9 F0 4F 8B B0 80 46 35 48 4F F4 7A 7A 80 78 01 28 07 D0 05 A8 AE F7 00 F9 81 46 B9 F1 00 0F 3D D0 40 E0 05 A8 AE F7 F8 F8 81 46 B9 F1 00 0F 04 D1 00 21 01 A8 FF F7 E8 FE 81 46 B9 F1 00 0F 2C D1 05 9E 00 27 01 9C 00 25 54 EA 05 00 12 D0 4F F4 7A 70
9:15:24 AM
9:15:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 69 09 81 80 A6 FB 00 23 07 FB 00 30 00 21 06 FB 01 01 6B 08 4F EA 34 00 10 18 59 41 22 46 2B 46 BD F7 4A FB 04 E0 3E 43 01 D1 00 20 00 E0 50 46 80 B2 A8 F8 00 00 50 45 00 D8 82 46 A8 F8 00 A0 A8 F8 02 A0 A8 F8 04 A0 A8 F8 06 A0 9A E0 01 A8 AE F7 0F F9 81 46 B9 F1 00 0F 6E D1 DD E9 06 01 08 44 08 99 46 18 00 27 DD E9 02 01 08 44 04 99 44 18 00 25 02 98 98 B1 00 21 02 9A 49 08 06 9B 4F EA 32 00
9:15:25 AM
9:15:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 6A 09 81 80 06 E0 00 00 88 7A 00 10 D0 80 00 10 A0 7E 00 10 E3 FB 0A 01 2B 46 BD F7 0D FB 02 E0 06 98 98 B1 50 46 80 B2 A8 F8 02 00 0A 90 03 98 70 B1 00 21 03 9A 07 9B 49 08 4F EA 32 00 E3 FB 0A 01 4F F0 00 03 BD F7 F7 FA 04 E0 00 20 EA E7 07 98 98 B1 50 46 80 B2 A8 F8 04 00 09 90 04 98 70 B1 00 21 04 9A 08 9B 49 08 4F EA 32 00 E3 FB 0A 01 4F F0 00 03 BD F7 DF FA 04 E0 00 20 EA E7 08 98 D8 B1
9:15:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 6B 09 81 80 50 46 1F FA 80 FB A8 F8 06 B0 54 EA 05 00 15 D0 4F F4 7A 70 A6 FB 00 23 07 FB 00 30 00 21 06 FB 01 01 6B 08 4F EA 34 00 10 18 59 41 22 46 2B 46 BD F7 C0 FA 07 E0 23 E0 00 20 E2 E7 3E 43 01 D1 00 20 00 E0 50 46 80 B2 A8 F8 00 00 0A 99 51 45 01 D9 51 46 00 E0 0A 99 A8 F8 02 10 09 99 51 45 01 D9 51 46 00 E0 09 99 A8 F8 04 10 D3 45 00 D9 D3 46 A8 F8 06 B0 50 45 00 D9 50 46 A8 F8 00 00
9:15:26 AM
9:15:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 6C 09 81 80 48 46 0B B0 BD E8 F0 8F 2D E9 F0 4F 8B B0 80 46 DF F8 E4 B5 4F F4 7A 7A 9B F8 02 00 01 28 07 D0 05 A8 AE F7 1B F8 81 46 B9 F1 00 0F 3D D0 40 E0 05 A8 AE F7 13 F8 81 46 B9 F1 00 0F 04 D1 01 A9 00 20 FF F7 F8 FD 81 46 B9 F1 00 0F 2C D1 05 9E 00 27 01 9C 00 25 54 EA 05 00 12 D0 4F F4 7A 70 A6 FB 00 23 07 FB 00 30 00 21 06 FB 01 01 6B 08 4F EA 34 00 10 18 59 41 22 46 2B 46 BD F7 5A FA
9:15:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 6D 09 81 80 04 E0 3E 43 01 D1 00 20 00 E0 50 46 80 B2 A8 F8 00 00 50 45 00 D8 82 46 A8 F8 00 A0 A8 F8 02 A0 A8 F8 04 A0 A8 F8 06 A0 A9 E0 01 A8 AE F7 2A F8 81 46 B9 F1 00 0F 7D D1 DD E9 06 01 08 44 08 99 46 18 00 27 DD E9 02 01 08 44 04 99 44 18 00 25 9B F8 02 00 01 28 11 D1 43 F2 6C 70 A4 FB 00 23 05 FB 00 30 00 21 04 FB 01 00 4F F4 00 51 51 18 40 F1 00 00 8C 0B 44 EA 80 44 85 0B 02 98 60 B1
9:15:27 AM
9:15:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 6E 09 81 80 00 21 02 9A 06 9B 49 08 4F EA 32 00 E3 FB 0A 01 4F F0 00 03 BD F7 0E FA 02 E0 06 98 98 B1 50 46 80 B2 A8 F8 02 00 0A 90 03 98 70 B1 00 21 03 9A 07 9B 49 08 4F EA 32 00 E3 FB 0A 01 4F F0 00 03 BD F7 F8 F9 04 E0 00 20 EA E7 07 98 98 B1 50 46 80 B2 A8 F8 04 00 09 90 04 98 70 B1 00 21 04 9A 08 9B 49 08 4F EA 32 00 E3 FB 0A 01 4F F0 00 03 BD F7 E0 F9 04 E0 00 20 EA E7 08 98 D8 B1 50 46
9:15:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 6F 09 81 80 1F FA 80 FB A8 F8 06 B0 54 EA 05 00 15 D0 4F F4 7A 70 A6 FB 00 23 07 FB 00 30 00 21 06 FB 01 01 6B 08 4F EA 34 00 10 18 59 41 22 46 2B 46 BD F7 C1 F9 07 E0 23 E0 00 20 E2 E7 3E 43 01 D1 00 20 00 E0 50 46 80 B2 A8 F8 00 00 0A 99 51 45 01 D9 51 46 00 E0 0A 99 A8 F8 02 10 09 99 51 45 01 D9 51 46 00 E0 09 99 A8 F8 04 10 D3 45 00 D9 D3 46 A8 F8 06 B0 50 45 00 D9 50 46 A8 F8 00 00 48 46
9:15:28 AM
9:15:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 70 09 81 80 FF E6 38 B5 04 46 20 46 AD F7 8A FE 00 28 3A D1 F9 49 49 78 01 29 36 D1 68 46 AD F7 3B FE 00 28 31 D1 21 78 8A 07 08 D0 21 F0 03 01 21 70 9D F8 00 20 02 F0 03 02 11 43 21 70 21 78 11 F0 0C 0F 08 D0 21 F0 0C 01 21 70 9D F8 00 20 02 F0 0C 02 11 43 21 70 21 78 11 F0 30 0F 08 D0 21 F0 30 01 21 70 9D F8 00 20 02 F0 30 02 11 43 21 70 21 78 8A 09 08 D0 21 F0 C0 01 21 70 9D F8 00 20 02 F0
9:15:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 71 09 81 80 C0 02 11 43 21 70 38 BD DB 48 80 6A A0 F2 11 10 40 B2 70 47 D8 48 40 6A A0 F2 11 10 40 B2 70 47 D6 4B 1A 7F 02 2A 02 D0 98 7F A8 B9 10 E0 93 F8 2C 20 02 70 93 F8 2D 20 42 70 58 7F C2 07 05 D0 11 B1 20 F0 01 00 58 77 03 20 70 47 02 20 70 47 01 2A 01 D0 00 20 70 47 01 20 70 47 2D E9 F0 41 88 B0 C7 48 02 27 C5 4C 90 F8 61 00 01 28 11 D0 E9 F7 6C FF 21 7F 00 25 41 F6 58 38 04 F1 20 06
9:15:29 AM
9:15:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 72 09 81 80 69 B1 01 29 24 D0 02 29 71 D0 25 77 84 F8 2C 50 08 B0 2C E4 01 20 E9 F7 76 FF 27 77 F8 E7 01 28 03 D0 02 28 01 D0 A5 77 F2 E7 01 20 E9 F7 7D FF 00 21 18 20 B2 F7 EB FE 01 20 E9 F7 64 FF 30 46 AD F7 70 F9 A5 77 C4 F8 28 80 01 20 20 77 DF E7 88 B1 02 28 17 D0 30 46 AD F7 6C F9 01 46 A0 6A 40 F6 B8 38 81 42 71 D9 40 45 12 D1 30 46 AD F7 55 F9 25 77 CC E7 00 20 E9 F7 45 FF 30 46 AD F7
9:15:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 73 09 81 80 4D F9 25 77 C4 E7 C4 F8 28 80 30 46 AD F7 4A F9 BE E7 A0 7F 05 28 04 D9 30 46 AD F7 3F F9 25 77 B6 E7 04 A9 02 20 AC F7 62 FB 00 28 B0 D1 9D F8 11 00 C0 06 AC D5 91 4A 02 20 1F 32 05 99 AC F7 8C FB 00 28 A4 D1 A0 7F 40 1C A0 77 E0 7F 10 23 6A 46 00 21 AC F7 17 FC 41 F2 88 35 40 B1 E0 7F AC F7 B4 FB A5 62 30 46 AD F7 1C F9 90 E7 3B E0 00 98 84 49 88 42 07 D0 E0 7F AC F7 A7 FB A5 62
9:15:30 AM
9:15:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 74 09 81 80 30 46 AD F7 0F F9 83 E7 0F 21 68 46 AD F7 1C FA 9D F8 0F 10 81 42 07 D0 E0 7F AC F7 97 FB A5 62 30 46 AD F7 FF F8 73 E7 04 F1 1C 04 9D F8 04 00 20 74 9D F8 05 00 60 74 30 46 AD F7 EF F8 60 78 40 F0 01 00 60 70 27 70 62 E7 FF E7 A1 7F 05 29 90 D9 40 45 8E D0 00 20 E9 F7 D5 FE C4 F8 28 80 30 46 AD F7 DF F8 53 E7 01 28 8B D0 E0 7F AC F7 6D FB FF 20 E0 77 01 20 E9 F7 D7 FE 00 21 18 20
9:15:31 AM
9:15:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 75 09 81 80 B2 F7 45 FE 00 20 E9 F7 BE FE 30 46 AD F7 C6 F8 84 F8 2C 50 25 77 3B E7 58 48 40 6C 70 47 48 B1 59 49 40 1E 51 F8 20 00 54 49 49 6C 88 43 03 D0 00 20 70 47 01 20 70 47 01 20 70 47 50 48 68 30 90 F8 39 00 70 47 A0 F2 B9 42 4F F0 FF 31 01 EB C2 03 21 22 A0 F2 BA 40 01 EB C0 00 93 FB F2 F3 90 FB F2 F0 83 42 01 D0 01 20 70 47 00 20 70 47 00 B5 FF F7 E8 FF 10 B1 4F F4 B7 70 00 BD 40 F2
9:15:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 76 09 81 80 6D 10 00 BD 10 B5 0C 46 FF F7 DD FF 10 B1 3F 48 00 5D 10 BD 3D 48 0C 38 00 5D 10 BD 2D E9 F0 43 04 46 0F 46 90 46 99 46 40 F2 46 56 00 25 00 20 89 F8 00 00 88 F8 00 00 38 80 30 46 FF F7 D8 FF 84 42 1A D3 40 E0 3E 80 6D 1C 88 F8 00 50 64 1C 89 F8 00 40 BD E8 F0 83 24 1A 6D 1C ED B2 29 46 30 46 FF F7 CF FF 84 42 07 D2 3E 80 6D 1C 88 F8 00 50 64 1C 89 F8 00 40 EC E7 29 46 30 46 FF F7
9:15:32 AM
9:15:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 77 09 81 80 C1 FF 84 42 E8 D2 DE E7 3E 80 6D 1C 88 F8 00 50 64 1C 89 F8 00 40 DD E7 24 1A 6D 1C ED B2 29 46 30 46 FF F7 AF FF 84 42 07 D2 3E 80 6D 1C 88 F8 00 50 64 1C 89 F8 00 40 CC E7 29 46 30 46 FF F7 A1 FF 84 42 E8 D2 DF E7 30 46 FF F7 91 FF 24 1A 76 1C B6 B2 30 46 FF F7 8B FF 84 42 F4 D2 EC E7 7E B5 0C 46 00 21 21 60 61 60 21 81 08 4A 01 68 91 42 0F D2 00 20 7E BD A0 7E 00 10 D0 80 00 10
9:15:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 78 09 81 80 D4 86 00 10 CE FA D1 DE C0 C1 01 00 A8 5F 07 00 00 5A 49 02 FE 4A 11 44 01 60 FE 48 B1 FB F0 F6 00 FB 16 15 01 AB 02 AA 69 46 30 46 FF F7 76 FF BD F8 00 00 20 80 9D F8 08 00 A0 70 9D F8 04 00 E0 70 07 20 B6 FB F0 F1 00 FB 11 60 20 71 4F F4 61 61 B5 FB F1 F0 60 71 01 FB 10 50 3C 22 B0 FB F2 F1 A1 71 02 FB 11 00 E0 71 01 20 C3 E7 2D E9 F0 43 04 46 89 46 00 26 00 27 20 88 A0 F2 46 51
9:15:33 AM
9:15:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 79 09 81 80 89 29 0C D2 A1 78 51 B1 0C 29 08 D8 61 79 18 29 05 D8 A1 79 3C 29 02 D8 E1 79 3C 29 01 D9 00 20 58 E7 FF F7 10 FF 38 B1 A1 78 DB 4A E0 78 51 5C 88 42 0A D9 00 20 4D E7 D7 4A A1 78 0C 3A E0 78 51 5C 88 42 01 D9 00 20 44 E7 B4 F8 00 80 40 F2 6D 10 A8 F2 46 58 08 FB 00 F8 40 F2 46 55 07 E0 28 46 FF F7 F0 FE 08 B1 76 1C F6 B2 6D 1C AD B2 20 88 A8 42 F4 D8 00 25 07 E0 20 88 29 46 FF F7
9:15:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 7A 09 81 80 01 FF 38 44 87 B2 6D 1C ED B2 A0 78 40 1E A8 42 F3 DC E0 78 F1 19 40 44 08 44 40 1E 40 F2 A3 21 48 43 E1 79 01 EB C0 12 61 79 4F F4 61 60 41 43 A0 79 C0 EB 00 10 01 EB 80 00 10 44 B4 49 49 42 08 44 C9 F8 00 00 01 20 04 E7 F8 B5 04 46 0D 46 00 26 1A B1 01 2A 13 D0 00 20 F8 BD 69 46 28 46 FF F7 85 FF 28 B1 21 46 00 98 AC F7 93 FE 28 B1 10 E0 26 60 66 60 26 81 00 20 F8 BD 00 20 F8 BD
9:15:34 AM
9:15:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 7B 09 81 80 69 46 20 46 AC F7 EA FD 30 B1 29 46 68 46 FF F7 27 FF 30 B1 01 20 F8 BD 2E 60 6E 60 2E 81 00 20 F8 BD 00 20 F8 BD 2D E9 F0 47 94 B0 9B 48 04 46 AC F7 40 FF 9A 49 00 26 88 42 0E D9 08 22 09 A9 00 20 C6 F7 ED FE AD F8 26 60 08 22 09 A9 00 20 C6 F7 1B FD 20 46 AC F7 21 FF 90 4D 10 3D A8 69 80 05 06 D5 8F 48 AB F7 F3 FD A8 69 20 F4 00 70 A8 61 00 20 FD F7 C2 F8 01 20 FD F7 25 FF 0F A9
9:15:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 7C 09 81 80 1A 20 B2 F7 C5 FC BD F8 3C 00 20 B1 10 21 02 20 FC F7 9F FC 03 E0 00 21 02 20 FC F7 9A FC AA F7 E7 FB DF F8 F8 81 06 28 08 F1 70 08 03 D1 AA F7 E2 FB 06 28 18 D0 98 F8 06 00 C1 07 00 D1 70 B9 20 F0 01 00 40 F0 02 00 88 F8 06 00 2E 20 00 F0 92 FB 01 22 08 F1 06 01 A4 20 C6 F7 D6 FC 01 21 15 20 00 F0 00 FD 13 E0 98 F8 06 00 41 46 82 07 00 D4 48 B9 40 F0 01 00 20 F0 02 00 88 71 01 22
9:15:35 AM
9:15:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 7D 09 81 80 89 1D A4 20 C6 F7 C1 FC 00 21 15 20 00 F0 EB FC B8 F8 00 00 F0 BB 10 A8 AC F7 C6 FD BD F8 42 00 10 AC C0 07 12 D0 B8 F8 14 00 C0 07 20 D1 75 20 00 F0 61 FB 03 20 00 F0 5E FB 08 20 F2 F7 3C FD 02 22 A1 1C A8 20 C6 F7 A0 FC 11 E0 B8 F8 14 00 C0 07 0D D0 76 20 00 F0 4E FB 03 20 00 F0 4B FB 08 20 F2 F7 29 FD 02 22 A1 1C A8 20 C6 F7 8D FC B8 F8 14 00 81 07 03 D4 BD F8 42 10 89 07 05 D4
9:15:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 7E 09 81 80 80 07 0A D5 BD F8 42 00 80 07 06 D4 02 22 A1 1C A8 20 00 E0 05 E0 C6 F7 78 FC BD F8 42 00 A8 F8 14 00 13 A8 AC F7 5B FE D8 F8 08 10 13 98 81 42 2B D0 4F F4 61 61 B0 FB F1 F2 01 FB 12 00 0A 28 23 D1 C6 F7 8A FB 11 A8 C6 F7 6B FB 9D F8 48 00 80 07 0F D5 17 20 00 F0 E1 FC 10 B9 30 20 00 F0 0A FB 01 21 24 20 00 F0 7E FC 01 21 17 20 00 F0 7A FC 07 E0 00 21 24 20 00 F0 75 FC 00 21 17 20
9:15:36 AM
9:15:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 7F 09 81 80 00 F0 71 FC 13 98 C8 F8 08 00 B8 F8 04 00 26 4F 01 28 28 D1 FB F7 F9 FD 07 F1 30 00 CD E9 05 06 01 1F A0 F1 10 02 CD E9 03 21 00 F5 98 70 10 39 A0 F1 40 02 CD E9 00 21 0B 1F 02 90 60 3A 08 39 E2 38 FB F7 E2 FA 40 B9 7E 61 BE 61 FE 61 3E 62 16 48 F8 62 4F F4 4D 70 38 63 78 89 40 F0 01 00 78 81 A8 F8 04 60 FC F7 72 FB 68 B1 FD F7 41 FD 0A 49 04 22 08 39 84 20 C6 F7 07 FC 07 49 04 22
9:15:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 80 09 81 80 08 31 88 20 C6 F7 01 FC 07 4C 5C 34 20 1D 0F E0 00 A6 B6 FD 80 51 01 00 A8 5F 07 00 60 80 00 10 00 DD 6D 00 00 01 00 10 A0 7E 00 10 CE 31 F8 00 AC F7 00 FE C8 28 04 D9 FC F7 84 FD 20 1D AC F7 F1 FD A8 68 08 B9 A8 69 10 B1 01 20 F2 F7 74 FC AE F7 75 FB 40 04 4F F0 01 09 15 D5 01 22 0B A9 80 20 C6 F7 9D FD 9D F8 2C 00 C1 07 0A D1 40 F0 01 00 0B 90 01 22 0B A9 80 20 C6 F7 C6 FB 29 20
9:15:37 AM
9:15:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 81 09 81 80 00 F0 79 FA A8 F8 00 90 B8 F8 02 00 20 B1 01 21 14 20 00 F0 E8 FB 03 E0 00 21 14 20 00 F0 E3 FB B8 F8 00 00 58 B1 01 21 13 20 00 F0 DC FB 00 21 0A 20 FC F7 4E FB 02 20 F2 F7 3E FC 07 E0 00 21 13 20 00 F0 D0 FB 01 21 0A 20 FC F7 42 FB D5 E9 02 30 58 40 D5 E9 06 21 51 40 50 EA 01 04 0A D0 03 42 01 D1 0A 42 02 D0 00 20 00 F0 44 FA A8 68 E8 60 A8 69 E8 61 A8 68 08 B9 A8 69 18 B1 01 21
9:15:38 AM
9:15:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 82 09 81 80 12 20 00 F0 B0 FB 02 F0 EA FF 04 46 E0 00 04 D5 01 21 4C 20 00 F0 A7 FB 03 E0 00 21 4C 20 00 F0 A2 FB 20 03 04 D5 01 21 0A 20 00 F0 9C FB 03 E0 00 21 0A 20 00 F0 97 FB 60 02 04 D5 01 21 49 20 00 F0 91 FB 03 E0 00 21 49 20 00 F0 8C FB A0 01 04 D5 01 21 3F 20 00 F0 86 FB 03 E0 00 21 3F 20 00 F0 81 FB A0 00 04 D5 01 21 4D 20 00 F0 7B FB 03 E0 00 21 4D 20 00 F0 76 FB E0 02 04 D5 01 21
9:15:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 83 09 81 80 0B 20 00 F0 70 FB 03 E0 00 21 0B 20 00 F0 6B FB 20 02 04 D5 01 21 4A 20 00 F0 65 FB 03 E0 00 21 4A 20 00 F0 60 FB 60 01 04 D5 01 21 40 20 00 F0 5A FB 03 E0 00 21 40 20 00 F0 55 FB 60 00 04 D5 01 21 4E 20 00 F0 4F FB 03 E0 00 21 4E 20 00 F0 4A FB A0 02 04 D5 01 21 0C 20 00 F0 44 FB 03 E0 00 21 0C 20 00 F0 3F FB E0 01 04 D5 01 21 4B 20 00 F0 39 FB 03 E0 00 21 4B 20 00 F0 34 FB 20 01
9:15:39 AM
9:15:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 84 09 81 80 04 D5 01 21 41 20 00 F0 2E FB 03 E0 00 21 41 20 00 F0 29 FB E0 05 04 D5 01 21 0D 20 00 F0 23 FB 03 E0 00 21 0D 20 00 F0 1E FB 60 05 04 D5 01 21 42 20 00 F0 18 FB 03 E0 00 21 42 20 00 F0 13 FB AA 48 82 46 AC F7 F6 FC A9 4C C8 28 10 D9 20 8B 58 B1 0E A8 AD F7 29 FC C8 B1 4F F0 FF 30 25 F8 70 0F AE 70 EE 70 A5 F1 70 05 50 46 AC F7 DA FC B8 88 40 04 01 D5 FE F7 96 F8 B8 88 C0 04 01 D5
9:15:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 85 09 81 80 FE F7 1A F9 9B 48 00 79 01 28 36 D0 3A E0 BD F9 38 00 B8 B1 22 8B 95 F8 72 10 02 EB 82 02 91 42 03 D2 49 1C 85 F8 72 10 09 E0 B5 F9 70 10 81 42 05 D0 A5 F8 70 00 00 21 3E 20 00 F0 D4 FA 85 F8 73 60 D2 E7 22 8B 95 F8 73 10 02 EB 82 02 91 42 03 D2 49 1C 85 F8 73 10 0C E0 B5 F9 70 10 81 42 08 D0 A5 F8 70 00 AF 20 00 F0 45 F9 01 21 3E 20 00 F0 B9 FA 85 F8 72 60 B7 E7 7E 48 13 99 10 38
9:15:40 AM
9:15:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 86 09 81 80 FE F7 1C FC A8 69 80 05 06 D5 7B 48 AB F7 60 FB A8 69 20 F4 00 70 A8 61 D8 F8 10 00 13 99 88 42 0E D0 01 20 FA F7 FB F9 02 20 FA F7 F8 F9 03 20 FA F7 F5 F9 04 20 FA F7 F2 F9 13 98 C8 F8 10 00 FF F7 CC FA FE F7 A7 F9 0D A9 14 20 B2 F7 20 FA 18 B3 FE F7 E7 F8 BD F9 34 10 08 40 0D 90 63 4D 41 35 68 B1 98 F8 35 00 B8 B9 DD 20 00 F0 03 F9 88 F8 35 90 01 22 29 46 A5 20 C6 F7 46 FA 0C E0
9:15:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 87 09 81 80 98 F8 35 00 48 B1 DE 20 00 F0 F5 F8 88 F8 35 60 01 22 29 46 A5 20 C6 F7 38 FA 0C A8 AD F7 7A F8 9D F8 30 00 81 07 04 D5 00 21 43 20 00 F0 5B FA 05 E0 C0 07 03 D0 01 21 43 20 00 F0 54 FA 9D F8 30 00 01 07 04 D5 00 21 44 20 00 F0 4C FA 05 E0 40 07 03 D5 01 21 44 20 00 F0 45 FA 9D F8 30 00 81 06 04 D5 00 21 45 20 00 F0 3D FA 05 E0 C0 06 03 D5 01 21 45 20 00 F0 36 FA B8 F8 38 00 78 B1
9:15:41 AM
9:15:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 88 09 81 80 3A 48 44 30 AC F7 16 FC B4 F8 62 10 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 02 D9 05 20 FC F7 9A F9 32 48 54 30 AC F7 06 FC 4E F6 60 21 88 42 01 D9 FB F7 AB FB 2D 48 5C 30 06 46 AC F7 FB FB 4F F4 7A 75 A8 42 22 D3 29 4C A0 34 60 68 40 1C 60 60 20 46 FD F7 47 FC 00 20 F6 F7 87 FA 03 46 00 21 DF F8 98 C0 1C F8 01 00 18 42 04 D0 04 EB 81 02 90 68 40 1C 90 60 49 1C C9 B2 08 29 F2 D3 1B 48
9:15:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 89 09 81 80 A0 30 FD F7 2F FC 30 46 AC F7 CC FB 19 49 2C 39 01 F5 BE 70 FD F7 CA F9 08 A8 AC F7 A0 FB 05 A8 AD F7 D6 F9 05 98 B0 FB F5 F0 02 90 06 98 B0 FB F5 F0 03 90 07 98 B0 FB F5 F0 04 90 01 A8 00 90 0C 48 02 AA 08 9B 08 38 79 6A FD F7 1D FA B8 62 9D F8 04 00 FF 28 04 D0 01 22 01 A9 61 20 C6 F7 94 F9 14 B0 BD E8 F0 87 C6 F7 A5 BB C4 80 00 10 D4 86 00 10 F0 7E 00 10 01 01 00 10 68 C1 01 00
9:15:42 AM
9:15:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 8A 09 81 80 38 B5 05 46 00 20 0C 46 08 80 B5 F5 91 7F 1A D8 68 46 FE F7 66 F8 B0 B1 52 48 9D F8 00 10 00 EB C5 00 21 B1 01 29 04 D0 02 29 0C D1 05 E0 40 88 00 E0 80 88 20 80 30 B1 03 E0 C0 88 20 80 FF 28 00 D0 08 46 38 BD FF 20 38 BD 10 B5 03 46 00 20 4F F6 FF 74 14 80 01 2B 0C D1 A1 F1 28 03 06 2B 01 D8 13 80 05 E0 A1 F1 31 03 01 2B 02 D8 2A 39 11 80 01 20 10 BD F0 B5 85 B0 05 46 AE F7 DF F8
9:15:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 8B 09 81 80 40 05 6D D4 01 A9 28 46 FF F7 BA FF 06 46 FF 28 66 D0 34 4C 34 F8 35 00 C0 05 04 D5 BD F8 04 10 02 20 F2 F7 F6 F9 34 F8 35 00 80 05 2B D5 03 AA BD F8 04 10 30 46 FF F7 C8 FF F8 B1 BD F8 0C 00 09 28 1B D2 28 4F 07 EB 80 00 46 6C 04 A8 AC F7 06 FB 04 98 B0 42 01 D9 80 1B 00 E0 30 1A B0 F5 61 7F 10 D9 BD F8 04 10 08 20 F2 F7 D2 F9 BD F8 0C 10 04 98 07 EB 81 01 48 64 04 E0 BD F8 04 10
9:15:43 AM
9:15:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 8C 09 81 80 08 20 F2 F7 C6 F9 34 F8 35 00 C0 07 04 D0 BD F8 04 10 0A 20 F2 F7 BD F9 34 F8 35 00 80 07 04 D5 BD F8 04 10 09 20 F2 F7 B4 F9 34 F8 35 00 40 07 04 D5 BD F8 04 10 0B 20 F2 F7 AB F9 34 F8 35 00 00 07 04 D5 BD F8 04 10 0C 20 F2 F7 A2 F9 34 F8 35 00 C0 06 04 D5 BD F8 04 10 0D 20 F2 F7 99 F9 05 B0 F0 BD E2 5F 07 00 50 80 00 10 00 B5 9B B0 68 46 FC F7 1B F8 00 28 01 D0 9D F8 14 00 1B B0
9:15:44 AM
9:15:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 8D 09 81 80 00 BD 70 B5 04 46 0D 46 FF F7 F0 FF 02 46 29 46 20 46 BD E8 70 40 F9 F7 58 BB 70 B5 04 46 0D 46 FF F7 E4 FF 02 46 29 46 20 46 BD E8 70 40 F9 F7 4D BB 10 B5 FF F7 DA FF 02 28 01 D0 01 28 0D D1 CE 4C 61 68 11 B1 00 20 FF F7 DB FF 20 69 00 28 04 D0 61 68 BD E8 10 40 01 20 D2 E7 10 BD F8 B5 0C 46 06 46 69 46 FE F7 44 F8 00 98 04 40 1F D0 C2 49 4E B1 01 2E 1B D1 C8 68 00 25 20 42 17 D1
9:15:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 8E 09 81 80 0A 69 22 42 15 D0 15 E0 08 68 00 25 20 42 0F D1 4A 68 22 42 00 D1 01 25 20 43 22 43 C1 E9 00 02 0C 22 B6 49 8C 20 0D E0 21 46 30 46 FF F7 A9 FF F8 BD 01 25 20 43 22 43 C1 E9 03 02 AF 49 0C 22 0C 31 98 20 C6 F7 61 F8 00 2D ED D1 F8 BD AB 4A 90 B1 01 28 1F D1 D0 68 08 42 02 D0 53 69 0B 43 53 61 20 EA 01 03 D3 60 83 42 14 D0 A3 49 0C 22 0C 31 98 20 C6 F7 49 B8 10 68 08 42 02 D0 93 68
9:15:45 AM
9:15:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 8F 09 81 80 0B 43 93 60 20 EA 01 03 13 60 83 42 03 D0 0C 22 9A 49 8C 20 EE E7 70 47 38 B5 0C 46 05 46 69 46 FD F7 24 FF 00 98 96 49 84 43 85 B1 01 2D 0D D1 88 69 14 B1 40 EA 04 02 8A 61 89 69 81 42 05 D0 8F 49 04 22 18 31 88 20 C6 F7 1F F8 38 BD 88 68 14 B1 40 EA 04 02 8A 60 89 68 81 42 F6 D0 88 49 04 22 08 31 84 20 EF E7 85 4A 88 B1 01 28 1D D1 90 69 08 42 02 D0 20 EA 01 03 93 61 91 69 81 42
9:15:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 90 09 81 80 14 D0 7F 49 04 22 18 31 5F F0 88 00 C5 F7 FD BF 90 68 08 42 02 D0 20 EA 01 03 93 60 91 68 81 42 04 D0 77 49 04 22 08 31 84 20 EF E7 70 47 02 00 73 4B 4F F0 00 00 06 D0 01 2A 03 D1 9A 69 0A 42 00 D0 01 20 70 47 9A 68 F9 E7 02 00 6B 4B 4F F0 00 00 06 D0 01 2A 03 D1 DA 68 0A 42 00 D0 01 20 70 47 1A 68 F9 E7 2D E9 F0 41 06 46 0C 46 AD F7 66 FF 40 05 50 D4 4F 2E 4E D2 62 48 62 4F 00 EB
9:15:46 AM
9:15:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 91 09 81 80 C6 05 68 79 01 06 0B D5 00 F0 3F 01 01 2C 57 F8 21 10 88 46 2D D0 40 06 02 D4 00 20 FF F7 A4 FF E8 79 01 06 0A D5 00 F0 3F 01 01 2C 57 F8 21 10 28 D0 40 06 02 D4 01 20 FF F7 96 FF 68 78 01 06 09 D5 00 F0 3F 00 01 2C 57 F8 20 10 4F F0 00 00 1C D0 FF F7 3C FF E8 78 01 06 1D D5 00 F0 3F 00 01 2C 57 F8 20 10 4F F0 01 00 12 D0 BD E8 F0 41 2D E7 46 48 30 44 AB F7 6B F8 41 46 00 20 FF F7
9:15:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 92 09 81 80 4B FF CD E7 01 20 FF F7 47 FF D7 E7 FF F7 E7 FE E1 E7 BD E8 F0 41 E2 E6 BD E8 F0 81 30 B5 01 46 00 20 4F 29 18 D2 37 4A 37 4D 02 EB C1 04 61 79 0A 06 06 D5 01 F0 3F 00 55 F8 20 10 00 20 FF F7 76 FF E1 79 0A 06 07 D5 01 F0 3F 00 55 F8 20 10 BD E8 30 40 01 20 6A E7 30 BD 30 B5 01 46 00 20 4F 29 18 D2 27 4A 28 4D 02 EB C1 04 61 78 0A 06 06 D5 01 F0 3F 00 55 F8 20 10 00 20 FF F7 65 FF
9:15:47 AM
9:15:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 93 09 81 80 E1 78 0A 06 07 D5 01 F0 3F 00 55 F8 20 10 BD E8 30 40 01 20 59 E7 30 BD 30 B4 18 4B CC 43 78 B1 01 28 28 D1 18 46 00 69 88 43 E2 B1 01 2A 22 D1 18 61 12 49 0C 22 0C 31 98 20 30 BC C5 F7 25 BF 0E 48 40 68 88 43 1A B1 01 2A 14 D1 58 60 06 E0 58 60 98 68 20 40 98 60 18 68 20 40 18 60 0C 22 06 49 8C 20 E9 E7 18 61 58 69 20 40 58 61 D8 68 20 40 D8 60 DD E7 30 BC 70 47 00 00 28 81 00 10
9:15:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 94 09 81 80 50 80 00 10 FA 68 07 00 C0 C1 01 00 00 00 01 10 00 B5 89 B0 18 21 02 A8 A4 F7 5F FC 16 20 08 A9 CD E9 00 01 02 46 00 23 02 A9 21 20 C5 F7 57 FE 24 48 00 21 03 22 01 80 81 70 01 46 40 F2 5C 40 C5 F7 E3 FE 09 B0 01 20 00 BD 03 22 1D 49 40 F2 5C 40 C6 F7 A5 B8 70 B5 8A B0 05 46 0E 46 09 A9 06 A8 AC F7 48 F8 28 46 C6 F7 31 FE 10 B1 28 46 C6 F7 8C FE 6A 46 00 21 28 46 C6 F7 02 F9 00 28
9:15:48 AM
9:15:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 95 09 81 80 1D D0 31 46 28 46 C6 F7 50 FF C4 B2 B5 B9 00 21 0F 20 FB F7 5E FE 00 21 10 20 FB F7 5A FE 00 21 11 20 FB F7 56 FE 00 21 12 20 FB F7 52 FE 0C B1 71 88 00 E0 01 21 08 20 FB F7 4B FE 20 46 0A B0 70 BD 00 00 81 87 00 10 1F B5 04 46 03 A9 68 46 AC F7 11 F8 00 28 06 D0 21 46 68 46 AB F7 3E FF 00 28 00 D0 01 20 04 B0 10 BD 10 B5 00 22 0A 60 4A 60 8A 60 CA 60 4F F4 02 72 02 EB 00 10 10 22
9:15:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 96 09 81 80 C6 F7 4E F8 00 28 00 D0 01 20 10 BD 70 B5 0C 46 05 46 2C 21 20 46 A4 F7 E0 FB 05 EB 45 00 00 EB C5 00 4F F4 1E 71 01 EB 80 00 2C 22 21 46 C6 F7 37 F8 00 28 00 D0 01 20 70 BD 10 B5 00 22 0A 80 4F F4 34 72 02 EB 40 00 02 22 C6 F7 29 F8 00 28 00 D0 01 20 10 BD 4F F4 02 72 02 EB 00 10 10 22 C5 F7 53 BE 00 EB 40 02 02 EB C0 00 4F F4 1E 72 02 EB 80 00 2C 22 C5 F7 48 BE 4F F4 34 72 02 EB
9:15:49 AM
9:15:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 97 09 81 80 40 00 02 22 C5 F7 41 BE 4F F4 39 70 4F F4 80 72 FE 49 C5 F7 3A BE FD 49 4F F4 02 70 4F F4 EE 72 DC 39 C5 F7 32 BE 70 B5 4F F4 EE 74 05 46 4F F4 02 76 21 46 A4 F7 91 FB 22 46 29 46 30 46 BD E8 70 40 C5 F7 ED BF 10 B5 00 22 0A 60 4F F4 E0 72 02 EB 80 00 04 22 C5 F7 E3 FF 00 28 00 D0 01 20 10 BD 4F F4 E0 72 02 EB 80 00 04 22 C5 F7 0D BE 0E B5 02 AA D4 21 CD E9 00 12 0A 46 01 46 00 23
9:15:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 98 09 81 80 1C 20 C5 F7 2C FD 00 28 00 D0 01 20 0E BD 0E B5 02 AA D4 21 CD E9 00 12 0A 46 01 46 00 23 1C 20 C5 F7 5D FD 00 28 00 D0 01 20 0E BD 70 B5 D4 21 D7 48 A4 F7 52 FB D6 48 18 22 D6 49 60 30 A4 F7 AF FA D4 4D D2 4C 4C 3D 7C 34 D5 F8 16 00 E0 61 68 8B 20 84 E8 69 C4 F8 22 00 28 8C E0 84 D5 F8 22 00 A0 62 E8 8C A0 85 12 22 05 F1 84 01 04 F1 2E 00 A4 F7 95 FA D5 F8 0A 00 E0 64 A8 6A 20 64
9:15:50 AM
9:15:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 99 09 81 80 A8 8D A4 F8 44 00 D5 F8 2E 00 C4 F8 46 00 68 8E A4 F8 4A 00 20 22 05 F1 64 01 A4 F1 5C 00 A4 F7 EA FA D5 F8 0E 00 20 65 D5 F8 12 00 60 65 BD E8 70 40 B7 48 AB E7 10 B5 04 46 FC F7 5C F9 B6 49 4A 68 82 42 00 D1 34 B1 48 60 B1 48 FF F7 90 FF 08 B1 01 20 10 BD 00 20 10 BD 40 B1 3A B1 B1 FB F0 F1 B2 FB F0 F0 88 42 01 D0 01 20 70 47 00 20 70 47 2D E9 F0 4F A8 49 82 46 0C 31 01 EB 4A 14
9:15:51 AM
9:15:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 9A 09 81 80 04 F1 14 00 89 B0 05 46 AB F7 94 FF A1 49 0A EB 4A 02 4C 31 01 EB C2 07 39 69 81 42 46 D8 28 46 AB F7 80 FF B8 88 80 04 02 D5 99 48 05 6A 00 E0 7D 69 00 20 AD B3 80 46 83 46 05 90 06 90 46 46 0D F1 14 09 CD F8 1C 00 09 EB 86 02 76 1C F1 B2 00 20 F7 F7 FD FA 00 28 28 D0 F6 B2 03 2E F3 D3 A0 89 40 1C A0 81 20 68 05 99 08 44 20 60 60 68 06 99 08 44 60 60 A0 68 07 99 08 44 A0 60 68 46
9:15:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 9B 09 81 80 AB F7 2D FF E1 69 28 46 00 9A FF F7 A6 FF 00 28 0C D0 38 69 68 B1 4F F4 7A 71 69 43 B1 FB F0 F1 08 E0 FF E7 A0 81 20 60 60 60 A0 60 09 B0 BD E8 F0 8F 00 21 66 22 51 43 64 22 B1 FB F2 F6 A1 89 01 23 8E 42 0D D3 20 B1 4F F4 7A 76 6E 43 B6 FB F0 F0 62 26 70 43 B0 FB F2 F0 88 42 01 D8 A3 73 01 E0 84 F8 0E B0 E0 7B B0 B1 00 20 E0 73 00 98 E0 61 A0 7B 00 28 6F D0 97 F8 06 90 B9 F1 FF 0F
9:15:52 AM
9:15:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 9C 09 81 80 D4 D0 FE 68 BF 68 08 A9 50 46 FF F7 DC FE 2D B1 00 98 B0 FB F5 F0 02 E0 01 20 E7 E7 00 20 68 43 00 90 20 61 08 90 08 A9 50 46 FF F7 DA FE 01 A9 48 46 FF F7 5A FE A0 89 28 B1 21 68 01 EB 50 01 91 FB F0 F1 00 E0 00 21 53 48 08 30 00 68 28 B1 4F F4 7A 72 51 43 B1 FB F0 F1 00 E0 00 21 89 B2 B1 42 06 D3 B9 42 04 D8 01 99 4F F0 01 08 49 1C 01 91 A1 89 21 B1 62 68 02 EB 51 02 92 FB F1 F1
9:15:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 9D 09 81 80 28 B1 4F F4 7A 72 51 43 B1 FB F0 F1 00 E0 00 21 89 B2 B1 42 06 D3 B9 42 04 D8 02 99 4F F0 01 08 49 1C 02 91 A1 89 21 B1 A2 68 02 EB 51 02 92 FB F1 F1 20 B1 4F F4 7A 72 51 43 B1 FB F0 F0 82 B2 01 21 01 FA 0A F1 34 48 B2 42 06 D3 BA 42 04 D8 03 9A 52 1C 03 92 03 E0 17 E0 B8 F1 00 0F 06 D0 02 68 11 43 01 60 04 98 40 1C 04 90 02 E0 02 68 8A 43 02 60 26 49 01 AE D4 31 01 EB 09 10 2E CE
9:15:53 AM
9:15:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 9E 09 81 80 2E C0 01 A9 48 46 FF F7 26 FE 58 46 4A E7 2D E9 F0 4F 21 49 82 46 0C 31 01 EB 4A 14 04 F1 14 00 87 B0 05 46 AB F7 86 FE 1A 49 0A EB 4A 02 4C 31 01 EB C2 06 31 69 81 42 59 D8 28 46 AB F7 72 FE B0 88 80 04 03 D5 12 48 B0 F8 98 50 00 E0 75 69 00 20 ED B3 80 46 02 90 03 90 00 27 0D F1 08 09 CD F8 10 00 09 EB 87 02 7F 1C F9 B2 00 20 F7 F7 EF F9 00 28 3B D0 FF B2 03 2F F3 D3 A0 89 40 1C
9:15:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 9F 09 81 80 A0 81 02 98 21 68 02 28 09 D8 07 E0 BC 8C 00 10 0C 8B 00 10 C0 6B 07 00 88 87 00 10 00 20 08 44 20 60 03 98 61 68 02 28 00 D8 00 20 08 44 60 60 04 98 A1 68 02 28 00 D8 00 20 08 44 A0 60 01 A8 AB F7 0D FE E1 69 28 46 01 9A FF F7 86 FE 00 E0 09 E0 00 28 0B D0 30 69 58 B1 4F F4 7A 71 69 43 B1 FB F0 F1 06 E0 A0 81 20 60 60 60 A0 60 07 B0 DD E6 00 21 66 22 51 43 64 22 B1 FB F2 F3 A1 89
9:15:54 AM
9:15:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A0 09 81 80 4F F0 01 09 8B 42 0E D3 20 B1 4F F4 7A 73 6B 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 02 D8 84 F8 0E 90 01 E0 84 F8 0E 80 E0 7B 90 B1 00 20 E0 73 01 98 E0 61 A0 7B 00 28 7D D0 96 F8 06 B0 BB F1 FF 0F D3 D0 B0 88 C0 04 05 D5 FE 48 47 88 06 88 03 E0 01 20 EB E7 08 36 C0 CE 05 A9 50 46 FF F7 B1 FD 1D B1 01 98 B0 FB F5 F0 00 E0 00 20 68 43 01 90 20 61 05 90 05 A9 50 46 FF F7 B1 FD
9:15:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A1 09 81 80 69 46 58 46 FF F7 59 FD A0 89 00 28 03 D0 21 68 91 FB F0 F1 01 E0 4F F0 00 01 03 D0 62 68 92 FB F0 F2 01 E0 4F F0 00 02 03 D0 A3 68 93 FB F0 F3 01 E0 4F F0 00 03 01 EB 02 00 18 44 4F F0 03 05 B0 FB F5 F0 00 28 0E D0 4F F4 7A 75 01 FB 05 F1 4F F4 7A 75 B1 FB F0 F1 02 FB 05 F2 B2 FB F0 F2 1F FA 81 F1 04 E0 4F F0 00 01 00 BF 4F F0 00 02 92 B2 06 D0 4F F4 7A 75 03 FB 05 F3 B3 FB F0 F0
9:15:55 AM
9:15:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A2 09 81 80 01 E0 4F F0 00 00 BD F9 00 30 80 B2 AD F8 00 80 29 B1 B1 42 01 D8 B9 42 01 D2 AD F8 00 90 2A B1 B2 42 01 D8 BA 42 01 D2 AD F8 00 90 C7 4D 40 B1 B0 42 03 D8 B8 42 00 E0 1B E0 02 D2 AD F8 00 90 02 E0 BD F8 00 00 38 B1 13 B9 BC 20 FF F7 13 FA 28 68 40 F4 80 70 07 E0 01 2B 02 D1 BD 20 FF F7 0A FA 28 68 20 F4 80 70 28 60 69 46 58 46 FF F7 04 FD 40 46 37 E7 2D E9 F0 47 B4 49 80 46 0C 31
9:15:56 AM
9:15:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A3 09 81 80 01 EB 48 14 04 F1 14 00 88 B0 05 46 AB F7 52 FD AF 49 08 EB 48 02 01 EB C2 07 39 69 81 42 70 D8 28 46 AB F7 3F FD 02 A8 AC F7 52 FB 00 28 68 D1 01 A8 AC F7 6F F9 00 28 63 D1 A0 89 40 1C A0 81 02 98 64 28 0D D3 9D F8 04 00 81 07 03 D5 20 68 02 99 08 44 04 E0 C0 07 03 D0 20 68 02 99 40 1A 20 60 03 98 64 28 0D D3 9D F8 04 00 01 07 03 D5 60 68 03 99 08 44 04 E0 40 07 03 D5 60 68 03 99
9:15:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A4 09 81 80 40 1A 60 60 04 98 64 28 0D D3 9D F8 04 00 81 06 03 D5 A0 68 04 99 08 44 04 E0 C0 06 03 D5 A0 68 04 99 40 1A A0 60 68 46 AB F7 D9 FC 7D 69 E1 69 28 46 00 9A FF F7 51 FD 00 28 7D D0 38 69 28 B1 4F F4 7A 71 69 43 B1 FB F0 F1 00 E0 00 21 66 22 51 43 64 22 B1 FB F2 F3 A1 89 00 26 4F F0 01 0A 8B 42 0F D3 20 B1 4F F4 7A 73 6B 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 03 D8 84 F8 0E A0
9:15:57 AM
9:15:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A5 09 81 80 01 E0 59 E0 A6 73 E0 7B A0 B1 00 20 E0 73 00 98 E0 61 A0 7B 90 B3 97 F8 06 90 B9 F1 FF 0F 4B D0 BF 68 06 A9 40 46 FF F7 8E FC 2D B1 00 98 B0 FB F5 F0 02 E0 01 20 E9 E7 00 20 68 43 00 90 20 61 06 90 06 A9 40 46 FF F7 8C FC 05 A9 48 46 FF F7 34 FC A0 89 00 28 03 D0 21 68 91 FB F0 F1 01 E0 4F F0 00 01 03 D0 62 68 92 FB F0 F2 01 E0 4F F0 00 02 04 D0 A3 68 93 FB F0 F0 02 E0 18 E0 4F F0
9:15:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A6 09 81 80 00 00 11 44 08 18 00 D5 40 42 50 49 B8 42 05 D9 AD F8 14 A0 08 68 40 F4 00 70 04 E0 AD F8 14 60 08 68 20 F4 00 70 08 60 05 A9 48 46 FF F7 05 FC A6 81 26 60 66 60 A6 60 08 B0 BD E8 F0 87 2D E9 F0 4F 42 49 83 46 0C 31 01 EB 4B 14 04 F1 14 00 87 B0 05 46 AB F7 6E FC 3D 49 0B EB 4B 02 01 EB C2 06 31 69 81 42 6E D8 28 46 AB F7 5B FC B0 88 DF F8 D4 80 80 04 A8 F1 9A 08 02 D5 B8 F8 A4 50
9:15:58 AM
9:15:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A7 09 81 80 00 E0 75 69 4F F0 00 09 00 2D 7C D0 02 A8 AC F7 5F FA 00 28 57 D1 A0 89 40 1C A0 81 02 98 21 68 64 28 00 D8 00 20 08 44 20 60 03 98 61 68 64 28 00 D8 00 20 08 44 60 60 04 98 A1 68 64 28 00 D8 00 20 08 44 A0 60 01 A8 AB F7 09 FC E1 69 28 46 01 9A FF F7 82 FC 00 28 35 D0 30 69 28 B1 4F F4 7A 71 69 43 B1 FB F0 F1 00 E0 00 21 66 22 51 43 64 22 B1 FB F2 F3 A1 89 8B 42 0E D3 20 B1 4F F4
9:15:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A8 09 81 80 7A 73 6B 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 02 D8 01 20 A0 73 01 E0 84 F8 0E 90 E0 7B D8 B1 00 20 E0 73 01 98 E0 61 A0 7B 00 28 2A D0 96 F8 06 A0 BA F1 FF 0F 05 D0 B0 88 C0 04 0E D5 B8 F8 A8 70 06 E0 8C E0 A6 8B 00 10 88 87 00 10 0C 6C 07 00 B8 F8 A6 60 03 E0 01 20 E2 E7 08 36 C0 CE 05 A9 58 46 FF F7 AE FB 01 98 05 A9 B0 FB F5 F0 68 43 01 90 20 61 05 90 58 46 FF F7 B1 FB
9:15:59 AM
9:15:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 A9 09 81 80 69 46 50 46 00 E0 64 E0 FF F7 57 FB A0 89 00 28 03 D0 21 68 91 FB F0 F1 01 E0 4F F0 00 01 89 B2 03 D0 62 68 92 FB F0 F2 01 E0 4F F0 00 02 92 B2 03 D0 A3 68 93 FB F0 F0 01 E0 4F F0 00 00 83 B2 01 EB 02 00 18 44 4F F0 03 05 B0 FB F5 F0 DF F8 98 84 00 28 2A D0 4F F4 7A 75 01 FB 05 F1 03 FB 05 F3 B1 FB F0 F1 B3 FB F0 F3 02 FB 05 F2 B2 FB F0 F0 89 B2 9B B2 80 B2 B1 42 09 D8 B9 42 07 D3
9:15:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 AA 09 81 80 B0 42 05 D8 B8 42 03 D3 B3 42 01 D8 BB 42 0D D2 BD F8 00 00 10 B9 BE 20 FF F7 2D F8 01 20 AD F8 00 00 D8 F8 00 10 41 F4 80 61 0C E0 BD F8 00 00 01 28 02 D1 BF 20 FF F7 1E F8 AD F8 00 90 D8 F8 00 10 21 F4 80 61 C8 F8 00 10 69 46 50 46 FF F7 14 FB A4 F8 0C 90 C4 F8 00 90 C4 F8 04 90 C4 F8 08 90 44 E5 2D E9 F0 47 FF 49 81 46 0C 31 01 EB 49 14 04 F1 14 00 A2 B0 05 46 AB F7 5B FB FB 49
9:16:00 AM
9:16:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 AB 09 81 80 09 EB 49 02 01 EB C2 07 39 69 81 42 4D D8 28 46 AB F7 48 FB B8 88 80 04 02 D5 F5 48 05 6A 00 E0 7D 69 00 20 E5 B3 80 46 08 90 09 90 00 26 0D F1 20 0A 0A 90 0A EB 86 02 76 1C F1 B2 00 20 F6 F7 C7 FE 00 28 31 D0 F6 B2 03 2E F3 D3 A0 89 40 1C A0 81 08 98 21 68 02 28 00 D8 00 20 08 44 20 60 09 98 61 68 02 28 00 D8 00 20 08 44 60 60 0A 98 A1 68 02 28 00 D8 00 20 08 44 A0 60 68 46 FF F7
9:16:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 AC 09 81 80 63 FA E1 69 28 46 00 9A FF F7 67 FB 00 28 0C D0 38 69 60 B1 4F F4 7A 71 69 43 B1 FB F0 F1 07 E0 FF E7 A0 81 20 60 60 60 A0 60 22 B0 85 E6 00 21 66 22 51 43 64 22 B1 FB F2 F3 A1 89 8B 42 0E D3 20 B1 4F F4 7A 73 6B 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 02 D8 01 20 A0 73 01 E0 84 F8 0E 80 E0 7B 90 B1 00 20 E0 73 00 98 E0 61 A0 7B 00 28 7C D0 BE 79 FF 2E D7 D0 05 A9 48 46 FF F7
9:16:01 AM
9:16:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 AD 09 81 80 A2 FA 2D B1 00 98 B0 FB F5 F0 02 E0 01 20 EB E7 00 20 68 43 00 90 20 61 05 90 05 A9 48 46 FF F7 A0 FA 16 A9 30 46 FF F7 31 FA 4F F4 39 75 20 22 0E A9 28 46 C5 F7 74 FA A2 89 00 2A 05 D0 20 68 00 EB 52 00 90 FB F2 F0 01 E0 4F F0 00 00 05 D0 61 68 01 EB 52 01 91 FB F2 F1 01 E0 4F F0 00 01 05 D0 A3 68 03 EB 52 03 93 FB F2 F2 01 E0 4F F0 00 02 17 9B 83 42 02 D2 00 9B 17 90 0E 93 18 9B
9:16:01 AM
9:16:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 AE 09 81 80 83 42 00 D8 13 B9 00 9B 18 90 0F 93 1A 9B 8B 42 02 D2 1A 91 00 9B 10 93 1B 9B 8B 42 00 D8 13 B9 1B 91 00 9B 11 93 1D 9B 93 42 02 D2 00 9B 1D 92 12 93 1E 9B 93 42 00 D8 13 B9 1E 92 00 9B 13 93 16 90 08 44 19 91 10 44 40 1C 03 21 B0 FB F1 F0 1F 99 1C 92 81 42 02 D2 00 99 1F 90 14 91 20 99 81 42 00 D8 11 B9 20 90 00 98 15 90 00 E0 15 E0 7F 49 06 EB 46 00 00 EB C6 00 D4 31 01 EB 80 00
9:16:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 AF 09 81 80 70 30 2C 22 16 A9 A3 F7 76 FD 16 A9 30 46 FF F7 E9 F9 20 22 0E A9 28 46 C5 F7 37 F8 40 46 40 E7 F0 B5 07 46 70 48 AD B0 0C 30 00 EB 47 14 04 F1 14 00 05 46 AB F7 3E FA 6C 49 07 EB 47 02 01 EB C2 06 31 69 81 42 65 D8 28 46 AB F7 2B FA B0 88 80 04 61 D4 75 69 00 2D 5E D0 68 46 FF F7 74 F9 21 69 28 46 00 9A FF F7 78 FA 00 28 52 D0 21 A9 38 46 FF F7 E8 F9 00 98 21 A9 B0 FB F5 F0 68 43
9:16:03 AM
9:16:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B0 09 81 80 00 90 20 61 21 90 38 46 FF F7 EB F9 B4 79 FF 2C 40 D0 03 A9 20 46 FF F7 79 F9 00 25 0E A9 28 46 FF F7 74 F9 4F F4 41 76 20 22 22 A9 30 46 C5 F7 B7 F9 4F F4 39 77 20 22 19 A9 38 46 C5 F7 B0 F9 2C 22 0E A9 03 A8 A3 F7 16 FD 20 22 19 A9 22 A8 A3 F7 11 FD 2C 21 0E A8 A3 F7 3F FD 03 98 0E 90 06 98 11 90 09 98 14 90 20 21 19 A8 A3 F7 35 FD 03 A9 20 46 FF F7 76 F9 0E A9 28 46 FF F7 72 F9
9:16:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B1 09 81 80 20 22 22 A9 30 46 C4 F7 C0 FF 20 22 19 A9 38 46 C4 F7 BB FF 2D B0 F0 BD 00 20 A0 81 20 60 60 60 A0 60 F7 E7 2D E9 F0 4F 8D B0 06 46 0D 46 00 20 2F 49 01 90 60 31 02 90 03 90 A1 F5 77 72 08 88 13 68 4F F4 7A 72 58 43 B0 FB F2 F4 48 88 0D F1 04 09 58 43 B0 FB F2 F0 00 EB 04 08 00 27 00 BF 07 F1 01 0A 09 EB 87 02 0A F0 FF 01 00 20 F6 F7 2F FD 00 28 7B D0 07 EB 87 0B 35 F8 2B 00 C8 B3
9:16:04 AM
9:16:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B2 09 81 80 59 F8 27 00 40 45 52 D9 05 EB 8B 00 09 90 81 68 0C 30 00 91 0A 90 AB F7 8D F9 15 49 B1 F8 66 10 E1 B1 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 15 D9 06 EB 07 11 00 9A 0A 60 05 EB 87 02 12 6D C1 E9 01 20 C8 68 40 1C C8 60 FF F7 1E F9 1F 20 FE F7 12 FE 06 48 95 38 C0 5D FE F7 0D FE 00 20 25 F8 2B 00 05 EB 87 01 06 E0 88 87 00 10 0C 6C 07 00 0C 8B 00 10 06 E0 08 65 09 99 88 60 0A 98 AB F7
9:16:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B3 09 81 80 4D F9 1B E0 59 F8 27 10 A1 42 17 D2 05 EB 8B 00 00 90 81 60 05 EB 87 00 50 30 FF F7 95 F8 00 98 0C 30 AB F7 3F F9 01 21 25 F8 2B 10 06 E0 05 EB 8B 01 8A 68 90 42 00 D3 10 46 88 60 0A F0 FF 07 03 2F 8D D3 A8 8F 05 F1 48 07 88 B1 01 99 41 45 26 D9 02 98 40 45 23 D9 03 98 40 45 20 D9 34 68 0C B3 30 69 08 B3 A0 42 1F D8 04 46 1D E0 17 E0 01 98 A0 42 05 D3 02 98 A0 42 02 D3 03 98 A0 42
9:16:05 AM
9:16:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B4 09 81 80 0E D2 01 98 A8 60 02 98 E8 61 03 98 28 63 05 F1 5C 00 FF F7 59 F8 38 46 AB F7 04 F9 01 20 A8 87 0D B0 BD E8 F0 8F 34 69 2C B1 30 6A 20 B1 A0 42 02 D8 04 46 00 E0 34 6A 38 46 AB F7 FB F8 FE 49 B1 F8 66 10 91 B1 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 0B D9 34 63 E9 6D C6 E9 0D 10 F0 6B 40 1C F0 63 FF F7 91 F8 1F 20 FE F7 85 FD 00 20 A8 87 E8 65 68 64 38 46 AB F7 D1 F8 D1 E7 2D E9 F0 4F
9:16:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B5 09 81 80 85 B0 06 46 0C 46 00 20 EB 49 01 90 02 90 68 31 03 90 A1 F5 79 70 0B 88 00 68 4F F4 7A 72 43 43 49 88 B3 FB F2 F7 41 43 B1 FB F2 F0 87 42 01 D9 38 1A 00 E0 00 20 80 46 00 25 0D F1 04 09 00 BF 05 F1 01 0A 09 EB 85 02 0A F0 FF 01 00 20 F6 F7 3F FC 00 28 7D D0 05 EB 85 0B 34 F8 2B 00 C0 B3 59 F8 25 00 40 45 4A D2 04 EB 8B 00 00 90 0C 30 04 90 AB F7 9F F8 01 46 CF 48 B0 F8 6E 00 E0 B1
9:16:06 AM
9:16:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B6 09 81 80 00 EB 40 02 C2 EB C0 10 B1 EB C0 0F 15 D9 00 98 82 68 06 EB 05 10 02 60 04 EB 85 02 12 6D C0 E9 01 21 C1 68 49 1C C1 60 FF F7 2E F8 20 20 FE F7 22 FD C2 48 40 5D FE F7 1E FD 00 20 04 EB 85 01 24 F8 2B 00 08 65 00 99 88 60 04 98 AB F7 66 F8 1C E0 FF E7 59 F8 25 10 B9 42 17 D9 04 EB 8B 00 00 90 81 60 04 EB 85 00 50 30 FE F7 AD FF 00 98 0C 30 AB F7 57 F8 01 20 24 F8 2B 00 06 E0 04 EB
9:16:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B7 09 81 80 8B 02 91 68 88 42 00 D8 08 46 90 60 0A F0 FF 05 03 2D 95 D3 A0 8F 04 F1 48 05 B8 B3 01 99 41 45 32 D2 02 99 41 45 2F D2 03 99 41 45 2C D2 37 69 30 68 B8 42 00 D9 07 46 30 6A B8 42 00 D3 07 46 28 46 AB F7 37 F8 01 46 9B 48 B0 F8 6E 00 A0 B1 00 E0 19 E0 00 EB 40 02 C2 EB C0 10 B1 EB C0 0F 0B D9 37 63 E0 6D C6 E9 0D 01 F0 6B 40 1C F0 63 FE F7 CA FF 20 20 FE F7 BE FC 00 20 A0 87 E0 65
9:16:07 AM
9:16:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B8 09 81 80 60 64 28 46 AB F7 0A F8 05 B0 0A E7 FF E7 01 98 B8 42 05 D8 02 98 B8 42 02 D8 03 98 B8 42 F3 D9 04 F1 5C 00 FE F7 50 FF 28 46 AA F7 FB FF 01 20 A0 87 E9 E7 2D E9 F8 43 07 46 B0 F9 00 00 15 46 98 46 0C 46 01 28 12 D0 E1 1C CE B2 61 1C 6A 46 C9 B2 F6 F7 E8 FB 00 28 35 D0 07 EB 04 14 01 27 61 88 04 F1 08 09 21 B1 A0 88 50 B1 19 E0 0E 46 EC E7 00 98 A8 42 14 D9 48 46 AA F7 D3 FF 67 80
9:16:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 B9 09 81 80 0F E0 48 46 AA F7 D6 FF 4F F4 7A 71 B0 FB F1 F0 40 45 06 D9 69 48 2E 30 30 F8 16 00 FE F7 6B FC A7 80 00 98 A8 42 0E D2 A0 88 00 25 01 28 05 D1 62 48 3A 30 30 F8 16 00 FE F7 5D FC 48 46 AA F7 AD FF 65 80 A5 80 BD E8 F8 83 2D E9 F0 41 07 46 59 48 CC 30 00 24 45 88 06 88 2A 46 33 46 21 46 38 46 FF F7 A7 FF 64 1C E4 B2 03 2C F5 D3 BD E8 F0 81 2D E9 F0 41 50 49 00 F1 40 05 D0 31 00 24
9:16:08 AM
9:16:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 BA 09 81 80 4F 88 09 88 8E B2 33 46 3A 46 21 46 28 46 FF F7 91 FF 64 1C E4 B2 03 2C F5 D3 E8 E7 2D E9 F0 4F 87 B0 06 46 00 20 00 90 01 90 02 90 42 48 0C 46 62 30 A0 F2 DE 31 C3 89 0A 68 4F F4 7A 71 53 43 00 88 B3 FB F1 F7 50 43 B0 FB F1 F0 00 EB 07 08 00 25 E9 46 68 1C 82 46 C1 B2 09 EB 85 02 00 20 F6 F7 F6 FA 00 28 66 D0 05 EB 85 0B 34 F8 2B 00 F0 B3 59 F8 25 00 40 45 62 D9 04 EB 8B 00 03 90
9:16:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 BB 09 81 80 04 90 80 68 06 90 04 98 0C 30 05 90 AA F7 52 FF 01 46 04 98 40 68 00 EB 40 02 C2 EB C0 10 01 EB C0 00 25 49 B1 F8 76 10 C9 B1 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 12 D9 06 EB 05 11 06 9A 0A 60 04 EB 85 02 12 6D C1 E9 01 20 C8 68 40 1C C8 60 FE F7 DA FE 19 48 80 1F 40 5D FE F7 CC FB 00 20 04 EB 85 01 24 F8 2B 00 08 65 03 99 88 60 00 E0 06 E0 05 98 AA F7 12 FF 03 98 00 21 41 60 26 E0
9:16:09 AM
9:16:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 BC 09 81 80 59 F8 25 10 B9 42 03 D3 04 EB 8B 00 40 68 F0 B1 04 EB 8B 00 03 90 81 60 40 68 20 B9 04 EB 85 00 50 30 AA F7 DC FE 03 98 0C 30 AA F7 FB FE 01 20 24 F8 2B 00 0B E0 4B E0 0C 8B 00 10 7A 6B 07 00 04 EB 8B 02 91 68 88 42 00 D3 08 46 90 60 0A F0 FF 05 03 2D FF F4 7E AF A1 8F 04 F1 48 09 C9 B3 00 99 41 45 34 D9 01 99 41 45 31 D9 02 98 40 45 2E D9 35 68 30 69 85 42 00 D3 05 46 30 6A A8 42
9:16:10 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:16:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 BD 09 81 80 00 D8 05 46 48 46 AA F7 D5 FE 21 6C 01 EB 41 02 C2 EB C1 11 00 EB C1 00 F9 49 B1 F8 76 10 79 B1 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 08 D9 35 63 E1 6D C6 E9 0D 10 F0 6B 40 1C F0 63 FE F7 64 FE 00 25 A5 87 E5 65 48 46 65 64 AA F7 A7 FE 25 64 07 B0 A6 E5 FF E7 00 98 B8 42 05 D3 01 98 B8 42 02 D3 02 98 B8 42 F3 D2 00 98 A0 60 01 98 E0 61 02 98 20 63 20 6C 18 B9 04 F1 5C 00 AA F7 6F FE
9:16:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 BE 09 81 80 48 46 AA F7 8F FE 01 20 A0 87 E1 E7 2D E9 F0 4F 87 B0 4F F0 00 08 CD F8 08 80 CD F8 0C 80 CD F8 10 80 CD F8 14 80 AC F7 0A FC C0 07 D0 D0 68 46 FB F7 2A FF DD E9 00 50 DF F8 44 93 82 46 00 24 02 AF 4F F0 01 0B A9 F1 60 09 00 BF 66 1C 07 EB 84 02 F1 B2 00 20 F6 F7 FB F9 00 28 B8 D0 09 EB 84 02 48 46 11 6D A9 42 08 D2 39 B1 04 EB 84 02 00 EB 82 02 AA EB 01 01 51 60 0B E0 A9 42 00 D8
9:16:11 AM
9:16:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 BF 09 81 80 41 B9 15 65 04 EB 84 02 00 EB 82 02 AA EB 05 01 51 60 C5 65 BA 4A 57 F8 24 10 B2 F8 70 20 91 42 1D D8 05 99 01 29 1A D0 04 EB 84 03 03 22 29 F8 23 80 F4 B2 03 2C C9 D3 01 46 40 68 8B 69 98 42 00 D8 18 46 08 64 CB 6A 98 42 00 D8 18 46 08 64 02 2A 0A D0 03 2A 01 D1 A1 F8 3C 80 78 E7 04 EB 84 03 02 22 29 F8 23 B0 E3 E7 A1 F8 3C B0 6F E7 2D E9 F0 4F A3 49 82 46 01 EB 4A 14 04 F1 14 00
9:16:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C0 09 81 80 91 B0 05 46 AA F7 16 FE 9F 49 0A EB 4A 02 01 EB C2 07 39 69 81 42 75 D8 28 46 AA F7 03 FE B8 88 80 04 06 D5 96 48 AA 30 05 88 41 88 04 91 80 88 03 E0 7D 69 F8 68 04 90 B8 68 4F F0 00 09 80 46 00 2D 76 D0 00 26 0D F1 24 0B 00 BF 0B EB 86 02 76 1C F1 B2 00 20 F6 F7 09 F9 00 28 52 D0 F6 B2 03 2E F3 D3 A0 89 40 1C A0 81 20 68 09 99 08 44 20 60 60 68 0A 99 08 44 60 60 A1 68 0B 98 08 44
9:16:12 AM
9:16:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C1 09 81 80 A0 60 03 A8 AA F7 AB FD E1 69 28 46 03 9A FE F7 24 FE 00 28 36 D0 38 69 28 B1 4F F4 7A 71 69 43 B1 FB F0 F1 00 E0 00 21 66 22 51 43 64 22 B1 FB F2 F3 A1 89 8B 42 0E D3 20 B1 4F F4 7A 73 6B 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 02 D8 01 20 A0 73 01 E0 84 F8 0E 90 E0 7B 98 B1 00 20 E0 73 03 98 E0 61 A0 7B 00 28 22 D0 BE 79 FF 2E 08 D0 0F A9 50 46 FE F7 66 FD 35 B1 03 98 B0 FB
9:16:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C2 09 81 80 F5 F0 03 E0 98 E0 01 20 EA E7 00 20 68 43 03 90 20 61 0F 90 0F A9 50 46 FE F7 63 FD 0C A9 30 46 FE F7 0B FD A0 89 00 28 04 D0 21 68 91 FB F0 F1 02 E0 79 E0 4F F0 00 01 06 91 03 D0 61 68 91 FB F0 F1 01 E0 4F F0 00 01 0D 91 03 D0 A1 68 91 FB F0 F0 01 E0 4F F0 00 00 05 90 6F F0 02 00 00 90 04 AB 05 AA 0D A9 06 A8 F6 F7 41 F8 04 98 4F F4 7A 72 08 FB 00 F1 B1 FB F2 F1 0D 18 BD F8 30 10
9:16:13 AM
9:16:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C3 09 81 80 C9 07 0A D0 06 98 A8 42 13 D9 C3 20 FE F7 F3 F9 BD F8 30 00 20 F0 01 00 09 E0 06 99 81 42 08 D2 C0 20 FE F7 E8 F9 BD F8 30 00 40 F0 01 00 AD F8 30 00 BD F8 30 00 80 07 0D 98 09 D5 A8 42 13 D9 C4 20 FE F7 D8 F9 BD F8 30 00 20 F0 02 00 09 E0 04 99 88 42 08 D2 C1 20 FE F7 CD F9 BD F8 30 00 40 F0 02 00 AD F8 30 00 BD F8 30 00 40 07 0A D5 05 98 A8 42 14 D9 C5 20 FE F7 BD F9 BD F8 30 00
9:16:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C4 09 81 80 20 F0 04 00 0A E0 DD E9 04 01 81 42 08 D2 C2 20 FE F7 B1 F9 BD F8 30 00 40 F0 04 00 AD F8 30 00 0C A9 30 46 FE F7 A9 FC A4 F8 0C 90 C4 F8 00 90 C4 F8 04 90 C4 F8 08 90 11 B0 BD E8 F0 8F 2D E9 F0 4F 10 49 82 46 01 EB 4A 14 04 F1 14 00 91 B0 05 46 AA F7 EF FC 0C 49 0A EB 4A 02 01 EB C2 07 39 69 81 42 7A D8 28 46 AA F7 DC FC B8 88 80 04 0C D5 03 48 B6 30 05 88 B0 F8 04 80 40 88 08 E0
9:16:14 AM
9:16:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C5 09 81 80 0C 8B 00 10 94 87 00 10 0C 6C 07 00 D7 E9 02 08 7D 69 4F F0 00 09 04 90 00 2D 76 D0 00 26 0D F1 2C 0B 00 BF 0B EB 86 02 76 1C F1 B2 00 20 F5 F7 DD FF 00 28 52 D0 F6 B2 03 2E F3 D3 A0 89 40 1C A0 81 20 68 0B 99 08 44 20 60 60 68 0C 99 08 44 60 60 A0 68 0D 99 08 44 A0 60 03 A8 AA F7 7F FC E1 69 28 46 03 9A FE F7 F8 FC 00 28 36 D0 38 69 28 B1 4F F4 7A 71 69 43 B1 FB F0 F1 00 E0 00 21
9:16:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C6 09 81 80 66 22 51 43 64 22 B1 FB F2 F3 A1 89 8B 42 0E D3 20 B1 4F F4 7A 73 6B 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 02 D8 01 20 A0 73 01 E0 84 F8 0E 90 E0 7B 98 B1 00 20 E0 73 03 98 E0 61 A0 7B 00 28 22 D0 BE 79 FF 2E 08 D0 0E A9 50 46 FE F7 3A FC 35 B1 03 98 B0 FB F5 F0 03 E0 B7 E0 01 20 EA E7 00 20 68 43 03 90 20 61 0E 90 0E A9 50 46 FE F7 37 FC 09 A9 30 46 FE F7 DF FB A0 89 00 28
9:16:15 AM
9:16:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C7 09 81 80 04 D0 21 68 91 FB F0 F1 02 E0 98 E0 4F F0 00 01 05 91 03 D0 61 68 91 FB F0 F1 01 E0 4F F0 00 01 06 91 03 D0 A1 68 91 FB F0 F0 01 E0 4F F0 00 00 07 90 4F F0 FF 30 00 90 04 AB 07 AA 06 A9 05 A8 F5 F7 15 FF 04 98 4F F4 7A 72 08 FB 00 F1 B1 FB F2 F1 88 42 01 D9 47 1A 00 E0 00 27 BD F8 24 10 FE 4D C9 07 0F D0 05 98 B8 42 1C D2 C9 20 FE F7 C2 F8 BD F8 24 00 20 F0 01 00 AD F8 24 00 28 68
9:16:16 AM
9:16:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C8 09 81 80 20 F0 80 50 0E E0 05 99 81 42 0C D9 C6 20 FE F7 B2 F8 BD F8 24 00 40 F0 01 00 AD F8 24 00 28 68 40 F0 80 50 28 60 BD F8 24 00 80 07 06 98 0E D5 B8 42 1C D2 CA 20 FE F7 9E F8 BD F8 24 00 20 F0 02 00 AD F8 24 00 28 68 20 F0 00 50 0E E0 04 99 88 42 0C D9 C7 20 FE F7 8E F8 BD F8 24 00 40 F0 02 00 AD F8 24 00 28 68 40 F0 00 50 28 60 BD F8 24 00 40 07 07 98 0E D5 B8 42 1C D2 CB 20 FE F7
9:16:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 C9 09 81 80 7A F8 BD F8 24 00 20 F0 04 00 AD F8 24 00 28 68 20 F0 80 40 0E E0 04 99 88 42 0C D9 C8 20 FE F7 6A F8 BD F8 24 00 40 F0 04 00 AD F8 24 00 28 68 40 F0 80 40 28 60 09 A9 30 46 FE F7 5E FB A4 F8 0C 90 C4 F8 00 90 C4 F8 04 90 C4 F8 08 90 B3 E6 2D E9 F1 4F C2 4C 96 B0 04 F1 20 00 05 46 AA F7 A9 FB 16 99 01 EB 41 02 BE 49 01 EB C2 07 39 69 81 42 7D D8 28 46 AA F7 95 FB 04 F5 BC 70 B0 F8
9:16:17 AM
9:16:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 CA 09 81 80 BC 50 00 2D 75 D0 00 26 0D F1 38 0A 0D F1 44 0B 06 F1 01 09 09 F0 FF 01 0A EB 86 02 88 46 00 20 F5 F7 A4 FE 00 28 63 D0 0B EB 86 02 41 46 00 20 F5 F7 0E FF 00 28 5B D0 09 F0 FF 06 03 2E E7 D3 20 8B 40 1C 20 83 20 68 0E 99 08 44 20 60 E1 68 11 98 08 44 E0 60 60 68 0F 99 08 44 60 60 20 69 12 99 08 44 20 61 A0 68 10 99 08 44 A0 60 60 69 13 99 08 44 60 61 01 A8 AA F7 31 FB A1 6A 28 46
9:16:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 CB 09 81 80 01 9A FE F7 AA FB 00 28 32 D0 38 69 28 B1 4F F4 7A 71 69 43 B1 FB F0 F1 00 E0 00 21 66 22 51 43 64 22 B1 FB F2 F3 21 8B 8B 42 0D D3 20 B1 4F F4 7A 73 6B 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 01 D8 01 20 00 E0 00 20 A0 76 E0 7E B0 B1 00 20 E0 76 01 98 A0 62 A0 7E 00 28 92 D0 B8 79 15 90 FF 28 04 D0 14 A9 16 98 FE F7 EC FA 01 E0 06 E1 FD E0 2D B1 01 98 B0 FB F5 F0 02 E0 01 20
9:16:18 AM
9:16:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 CC 09 81 80 E7 E7 00 20 68 43 01 90 E0 61 14 90 14 A9 16 98 FE F7 E7 FA 05 A9 15 98 FE F7 8F FA 20 8B 00 28 03 D0 21 68 B1 FB F0 F1 01 E0 4F F0 00 01 08 91 03 D0 E1 68 B1 FB F0 F1 01 E0 4F F0 00 01 89 46 03 D0 61 68 B1 FB F0 F1 01 E0 4F F0 00 01 09 91 03 D0 21 69 B1 FB F0 F1 01 E0 4F F0 00 01 8A 46 03 D0 A1 68 B1 FB F0 F1 01 E0 4F F0 00 01 0A 91 03 D0 61 69 B1 FB F0 F0 01 E0 4F F0 00 00 5A 4D
9:16:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 CD 09 81 80 83 46 07 AB B5 F8 C0 00 07 90 6F F0 02 00 00 90 0A AA 09 A9 08 A8 F5 F7 AA FD 07 98 00 EB 80 01 8A 00 4F F4 7A 71 B2 FB F1 F2 90 42 01 D9 86 1A 00 E0 00 26 49 4A B5 F8 BE 30 08 32 DF F8 1C 81 12 68 53 43 B3 FB F1 F5 02 EB 82 02 92 00 B2 FB F1 F1 6F 18 BD F8 14 10 C9 07 12 D0 08 98 B0 42 01 D3 B9 45 21 D9 CF 20 FD F7 45 FF BD F8 14 00 20 F0 01 00 AD F8 14 00 D8 F8 00 10 21 F0 00 71
9:16:19 AM
9:16:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 CE 09 81 80 11 E0 08 99 81 42 10 D9 A9 45 0E D2 CC 20 FD F7 32 FF BD F8 14 00 40 F0 01 00 AD F8 14 00 D8 F8 00 10 41 F0 00 71 C8 F8 00 10 BD F8 14 00 80 07 09 98 11 D5 B0 42 01 D3 BA 45 21 D9 D0 20 FD F7 1A FF BD F8 14 00 20 F0 02 00 AD F8 14 00 D8 F8 00 10 21 F0 80 61 11 E0 07 99 88 42 10 D9 AA 45 0E D2 CD 20 FD F7 07 FF BD F8 14 00 40 F0 02 00 AD F8 14 00 D8 F8 00 10 41 F0 80 61 C8 F8 00 10
9:16:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 CF 09 81 80 BD F8 14 00 40 07 0A 98 11 D5 B0 42 01 D3 BB 45 21 D9 D1 20 FD F7 EF FE BD F8 14 00 20 F0 04 00 AD F8 14 00 D8 F8 00 10 21 F0 00 61 11 E0 07 99 88 42 10 D9 AB 45 0E D2 CE 20 FD F7 DC FE BD F8 14 00 40 F0 04 00 AD F8 14 00 D8 F8 00 10 41 F0 00 61 C8 F8 00 10 05 A9 15 98 07 E0 88 87 00 10 94 89 00 10 0C 6C 07 00 0C 8B 00 10 FE F7 C5 F9 00 20 20 83 20 60 E0 60 60 60 20 61 A0 60 60 61
9:16:20 AM
9:16:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D0 09 81 80 17 B0 1A E5 2D E9 F0 4F FF 49 81 46 01 EB 49 15 05 F1 14 00 87 B0 04 46 AA F7 0C FA FB 49 09 EB 49 02 01 EB C2 07 39 69 81 42 72 D8 20 46 AA F7 F9 F9 B8 88 80 04 04 D5 F5 48 06 88 44 88 80 88 02 E0 D7 E9 02 04 7E 69 82 46 00 2E 78 D0 00 20 0D F1 08 0B 00 F1 01 08 0B EB 80 02 08 F0 FF 01 00 20 F5 F7 75 FD 00 28 53 D0 08 F0 FF 00 03 28 F0 D3 A8 89 40 1C A8 81 28 68 02 99 08 44 28 60
9:16:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D1 09 81 80 68 68 03 99 08 44 68 60 A8 68 04 99 08 44 A8 60 01 A8 AA F7 A4 F9 E9 69 30 46 01 9A FE F7 1D FA 00 28 36 D0 38 69 28 B1 4F F4 7A 71 71 43 B1 FB F0 F1 00 E0 00 21 66 22 51 43 64 22 B1 FB F2 F3 A9 89 8B 42 0D D3 20 B1 4F F4 7A 73 73 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 01 D8 01 20 00 E0 00 20 A8 73 E8 7B A0 B1 00 20 E8 73 01 98 E8 61 A8 7B 00 28 A9 D0 B8 79 05 90 FF 28 08 D0
9:16:21 AM
9:16:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D2 09 81 80 06 A9 48 46 FE F7 5F F9 36 B1 01 98 B0 FB F6 F0 03 E0 77 E1 01 20 E9 E7 00 20 70 43 01 90 28 61 06 90 06 A9 48 46 FE F7 5C F9 69 46 05 98 FE F7 04 F9 A8 89 00 28 04 D0 29 68 91 FB F0 F2 02 E0 5B E1 4F F0 00 02 03 D0 69 68 91 FB F0 F6 01 E0 4F F0 00 06 03 D0 A9 68 91 FB F0 F7 01 E0 4F F0 00 07 A9 48 4F F4 7A 73 A0 F1 04 00 BA F1 14 0F 00 68 00 FB 04 F1 B1 FB F3 F8 00 FB 0A F1 B1 FB
9:16:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D3 09 81 80 F3 F9 04 F1 14 04 00 FB 04 F1 B1 FB F3 FB 05 D9 AA F1 14 01 48 43 B0 FB F3 F0 00 E0 00 20 82 46 BD F8 00 00 98 4C C1 07 A4 F1 0C 04 1E D0 5A 45 5B D9 4A 45 0D D9 D6 20 FD F7 DD FD BD F8 00 00 40 F0 10 00 AD F8 00 00 20 68 40 F4 80 00 20 60 02 E0 78 20 FD F7 CF FD BD F8 00 00 20 F0 01 00 AD F8 00 00 20 68 20 F4 00 20 3D E0 C0 06 1E D5 52 45 3A D2 42 45 0D D2 D9 20 FD F7 BC FD BD F8
9:16:22 AM
9:16:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D4 09 81 80 00 00 40 F0 01 00 AD F8 00 00 20 68 40 F4 00 20 20 60 02 E0 78 20 FD F7 AE FD BD F8 00 00 20 F0 10 00 AD F8 00 00 20 68 20 F4 80 00 1C E0 42 45 0C D2 D9 20 FD F7 9F FD BD F8 00 00 40 F0 01 00 AD F8 00 00 20 68 40 F4 00 20 0D E0 4A 45 0C D9 D6 20 FD F7 90 FD BD F8 00 00 40 F0 10 00 AD F8 00 00 20 68 40 F4 80 00 20 60 BD F8 00 00 81 07 1E D5 5E 45 5B D9 4E 45 0D D9 D7 20 FD F7 7B FD
9:16:23 AM
9:16:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D5 09 81 80 BD F8 00 00 40 F0 20 00 AD F8 00 00 20 68 40 F4 00 00 20 60 02 E0 7A 20 FD F7 6D FD BD F8 00 00 20 F0 02 00 AD F8 00 00 20 68 20 F4 80 10 3D E0 80 06 1E D5 56 45 3A D2 46 45 0D D2 DA 20 FD F7 5A FD BD F8 00 00 40 F0 02 00 AD F8 00 00 20 68 40 F4 80 10 20 60 02 E0 7A 20 FD F7 4C FD BD F8 00 00 20 F0 20 00 AD F8 00 00 20 68 20 F4 00 00 1C E0 46 45 0C D2 DA 20 FD F7 3D FD BD F8 00 00
9:16:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D6 09 81 80 40 F0 02 00 AD F8 00 00 20 68 40 F4 80 10 0D E0 4E 45 0C D9 D7 20 FD F7 2E FD BD F8 00 00 40 F0 20 00 AD F8 00 00 20 68 40 F4 00 00 20 60 BD F8 00 00 41 07 1E D5 5F 45 5B D9 4F 45 0D D9 D8 20 FD F7 19 FD BD F8 00 00 40 F0 40 00 AD F8 00 00 20 68 40 F0 80 70 20 60 02 E0 7C 20 FD F7 0B FD BD F8 00 00 20 F0 04 00 AD F8 00 00 20 68 20 F4 00 10 3D E0 40 06 1E D5 57 45 3A D2 47 45 0D D2
9:16:24 AM
9:16:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D7 09 81 80 DB 20 FD F7 F8 FC BD F8 00 00 40 F0 04 00 AD F8 00 00 20 68 40 F4 00 10 20 60 02 E0 7C 20 FD F7 EA FC BD F8 00 00 20 F0 40 00 AD F8 00 00 20 68 20 F0 80 70 1C E0 47 45 0C D2 DB 20 FD F7 DB FC BD F8 00 00 40 F0 04 00 AD F8 00 00 20 68 40 F4 00 10 0D E0 4F 45 0C D9 D8 20 FD F7 CC FC BD F8 00 00 40 F0 40 00 AD F8 00 00 20 68 40 F0 80 70 20 60 69 46 05 98 FD F7 C0 FF 00 20 A8 81 28 60
9:16:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D8 09 81 80 68 60 A8 60 07 B0 05 E0 94 87 00 10 0C 6C 07 00 AA 8B 00 10 BD E8 F0 8F 2D E9 F0 47 FF 4C 82 46 04 F1 20 00 92 B0 05 46 AA F7 04 F8 FC 49 0A EB 4A 02 01 EB C2 06 31 69 81 42 7D D8 28 46 A9 F7 F1 FF 04 F5 A6 77 4F F0 00 08 B7 F8 C2 50 00 2D 73 D0 0B A8 FC F7 EA FB 81 46 0D A8 FC F7 D4 FC 59 EA 00 00 68 D1 02 AA 00 21 08 20 FC F7 9B FB 00 28 61 D0 0A AA 00 21 09 20 FC F7 94 FB 00 28
9:16:25 AM
9:16:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 D9 09 81 80 5A D0 20 8B 40 1C 20 83 BD F8 2C 10 20 68 08 44 20 60 BD F8 34 10 60 68 08 44 60 60 E0 68 02 99 08 44 E0 60 20 69 0A 99 08 44 20 61 68 46 A9 F7 96 FF A1 6A 28 46 00 9A FE F7 0F F8 00 28 3B D0 30 69 28 B1 4F F4 7A 71 69 43 B1 FB F0 F1 00 E0 00 21 66 22 51 43 64 22 B1 FB F2 F3 21 8B 8B 42 0E D3 20 B1 4F F4 7A 73 6B 43 B3 FB F0 F0 62 23 58 43 B0 FB F2 F0 88 42 02 D8 01 20 A0 76 01 E0
9:16:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 DA 09 81 80 84 F8 1A 80 E0 7E 40 B3 00 20 E0 76 00 98 A0 62 A0 7E 00 28 11 D0 96 F8 06 90 B9 F1 FF 0F 0B D0 10 A9 50 46 FD F7 4F FF 00 98 10 A9 B0 FB F5 F0 68 43 00 90 E0 61 01 E0 8B E0 7C E0 10 90 50 46 FD F7 4F FF 0F A9 48 46 FD F7 F7 FE 20 8B 00 28 06 D0 21 68 B1 FB F0 F2 04 E0 4F F0 01 00 D4 E7 4F F0 00 02 03 D0 61 68 B1 FB F0 F3 01 E0 4F F0 00 03 03 D0 E1 68 B1 FB F0 F1 01 E0 4F F0 00 01
9:16:26 AM
9:16:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 DB 09 81 80 02 91 03 D0 21 69 B1 FB F0 F5 01 E0 4F F0 00 05 0A 95 37 F8 C4 1F 4F F4 7A 76 01 EB 81 00 4F EA 80 00 B0 FB F6 F0 01 EB 00 0C 78 88 00 EB 80 07 4F EA 87 07 B7 FB F6 F6 B0 42 02 D9 A0 EB 06 06 00 E0 00 26 BD F8 3C 70 DF F8 58 A2 3F 07 16 D5 62 45 02 D8 02 98 B0 42 29 D2 63 45 01 D8 B5 42 25 D2 D3 20 FD F7 C7 FB BD F8 3C 00 20 F0 08 00 AD F8 3C 00 DA F8 00 10 21 F4 00 31 15 E0 8A 42
9:16:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 DC 09 81 80 02 D2 02 9A 82 42 03 D8 8B 42 10 D2 85 42 0E D9 D2 20 FD F7 B0 FB BD F8 3C 00 40 F0 08 00 AD F8 3C 00 DA F8 00 10 41 F4 00 31 CA F8 00 10 0F A9 48 46 FD F7 A2 FE A4 F8 18 80 C4 F8 00 80 C4 F8 0C 80 C4 F8 04 80 C4 F8 10 80 C4 F8 08 80 C4 F8 14 80 12 B0 BD E8 F0 87 2D E9 F0 41 05 46 71 48 8C B0 0C 30 00 EB 45 14 04 F1 14 00 06 46 A9 F7 E1 FE 6B 49 05 EB 45 02 01 EB C2 07 39 69 81 42
9:16:27 AM
9:16:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 DD 09 81 80 3E D8 30 46 A9 F7 CE FE DF F8 9C 81 B8 F8 C8 00 80 B3 00 25 0D F1 04 06 06 EB 85 02 6D 1C E9 B2 00 20 F5 F7 E3 F9 00 28 2A D0 ED B2 03 2D F3 D3 0A A8 AA F7 EF FA BD 79 FF 2D 21 D0 09 A9 28 46 FD F7 3B FE B8 F8 CA 00 07 90 6F F0 02 00 00 90 47 46 07 AB 03 AA 31 1D 01 A8 F5 F7 88 F9 07 9B 01 98 00 21 98 42 11 D9 9D F8 28 00 82 07 0A D5 01 21 0B E0 FF E7 00 20 A0 81 20 60 60 60 A0 60
9:16:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 DE 09 81 80 0C B0 BD E8 F0 81 C0 07 00 D0 02 21 02 9A 00 20 9A 42 08 D9 9D F8 28 20 16 07 01 D5 01 20 02 E0 52 07 00 D5 02 20 03 9E 00 22 9E 42 08 D9 9D F8 28 30 9E 06 01 D5 01 22 02 E0 DB 06 00 D5 02 22 D9 B1 D0 B1 CA B1 81 42 01 D1 90 42 15 D0 B7 F8 C8 10 A0 89 01 EB 81 01 88 42 02 D2 00 F1 01 00 0F E0 BD F8 24 00 00 07 CA D4 D4 20 FD F7 03 FB BD F8 24 00 40 F0 08 00 10 E0 A0 89 18 B1 A0 F1
9:16:28 AM
9:16:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 DF 09 81 80 01 00 A0 81 BC E7 BD F8 24 00 00 07 B8 D5 D5 20 FD F7 F1 FA BD F8 24 00 20 F0 08 00 AD F8 24 00 09 A9 28 46 FD F7 E9 FD AA E7 2D E9 F8 43 AB F7 C6 FB 40 05 7E D4 AB F7 C2 FB 40 07 4F F4 EE 79 4F F0 00 06 12 D5 FD F7 31 FE 17 48 49 46 D4 30 A2 F7 83 F9 FD F7 DF FD 00 24 69 46 20 46 00 96 FD F7 FF FD 64 1C E4 B2 12 2C F6 D3 01 20 FD F7 62 FE 0C 4D 00 24 2E 60 05 F1 0C 06 06 EB 44 17
9:16:29 AM
9:16:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E0 09 81 80 20 21 38 46 A2 F7 69 F9 69 46 20 46 FD F7 DB FD 00 98 38 61 F8 61 07 F1 14 00 07 E0 C0 89 00 10 0C 6C 07 00 88 87 00 10 0C 8B 00 10 A9 F7 FA FD 64 1C E4 B2 10 2C E1 D3 DF F8 44 81 00 26 00 BF 06 EB 46 00 00 EB C6 01 08 EB 81 07 2C 21 38 46 A2 F7 43 F9 69 46 20 46 FD F7 B5 FD 00 98 F8 61 B8 62 07 F1 20 00 A9 F7 DD FD 64 1C 76 1C F6 B2 E4 B2 02 2E E4 D3 42 48 50 21 58 30 A2 F7 2D F9
9:16:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E1 09 81 80 3F 48 50 21 B8 30 A2 F7 28 F9 50 21 3D 48 A2 F7 24 F9 40 21 3C 48 A2 F7 20 F9 3B 48 40 21 40 30 A2 F7 1B F9 38 49 01 20 08 80 A1 F5 EE 70 FD F7 7A FD 00 E0 11 E0 28 B9 49 46 34 48 A2 F7 0D F9 FD F7 69 FD 31 48 B0 F8 C8 00 18 B1 28 68 40 F4 80 70 28 60 2D 48 FE F7 19 FF BD E8 F8 83 2C 48 00 68 70 47 2A 49 08 31 08 60 01 20 70 47 00 B5 93 B0 48 21 68 46 A2 F7 F0 F8 4F F4 E0 70 48 22
9:16:30 AM
9:16:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E2 09 81 80 69 46 C3 F7 82 FB 4F F4 EE 71 20 48 A2 F7 E5 F8 FD F7 41 FD 13 B0 00 BD 70 B5 00 20 FD F7 CB FD 1C 4D 00 24 04 EB 44 00 55 F8 30 10 20 46 88 47 64 1C E4 B2 12 2C F5 D3 12 49 01 F5 34 70 FE F7 ED FD 0F 49 58 31 01 F5 44 70 FE F7 AB FB 0D 49 60 39 01 F5 3C 70 FE F7 91 FC 0B 48 FE F7 B5 FD BD E8 70 40 08 48 FE F7 C4 BD 06 49 60 31 B1 F8 C0 10 01 80 09 B1 01 20 70 47 00 20 70 47 00 00
9:16:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E3 09 81 80 94 89 00 10 AC 8A 00 10 BC 8D 00 10 E0 8B 00 10 88 87 00 10 0C 6C 07 00 2D E9 F0 47 00 26 DF F8 5C 84 35 46 FF 27 4F F0 04 09 4F F0 02 0A 00 BF 06 EB 46 00 C0 EB 86 11 08 EB 81 04 04 F1 4C 04 25 75 E7 60 25 77 25 74 65 74 A5 74 A5 61 24 F8 3A 9C 24 F8 2A AC 48 F8 21 50 44 F8 48 5C A4 F1 4C 04 04 F1 28 00 A9 F7 1D FD 04 F1 38 00 A9 F7 15 FD 04 F1 40 00 A9 F7 11 FD 76 1C F6 B2 05 2E
9:16:31 AM
9:16:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E4 09 81 80 D6 D3 FE 48 80 F8 F2 54 80 F8 F3 54 80 F8 F4 54 80 F8 F5 54 80 F8 F6 54 80 F8 F7 54 80 F8 F8 54 80 F8 F9 54 A0 F8 0C 55 00 F2 04 50 A9 F7 F6 FC F2 48 A0 F8 F0 54 C0 F8 00 75 01 20 BD E8 F0 87 70 B5 06 46 40 F2 14 51 EC 48 A2 F7 46 F8 30 46 FF F7 A2 FF E9 48 00 24 00 F2 14 55 80 F8 C4 44 80 F8 C5 44 A5 F8 96 40 A5 F8 98 40 A5 F8 9A 40 00 F2 9E 50 2C 70 04 60 08 30 04 60 86 38 A9 F7
9:16:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E5 09 81 80 CD FC DE 48 DD 49 A0 F8 CC 44 C6 E9 00 05 B0 68 C1 F8 10 05 01 20 70 BD D8 48 90 F8 C4 04 06 28 05 D0 08 28 03 D0 07 28 01 D0 00 20 70 47 D3 49 00 20 A1 F8 F0 04 09 20 81 F8 C4 04 01 20 70 47 2D E9 F0 47 03 46 CE 48 16 46 4F F0 FF 37 00 78 28 28 01 D0 7C 20 0A E0 84 20 02 2B 07 D1 DF F8 20 A3 01 29 AA F1 1E 0A 06 D0 02 29 0B D0 C3 49 C1 F8 FC 04 38 46 A1 E7 06 2E F8 D1 BF 49 91 F8
9:16:32 AM
9:16:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E6 09 81 80 F6 14 05 29 F3 D2 BD 48 00 25 00 BF 05 EB 45 01 C1 EB 85 11 00 EB 81 04 94 F8 60 10 59 B9 A1 6D FF 29 08 D1 94 F8 5C 10 29 B9 94 F8 5D 10 11 B9 94 F8 5E 10 29 B1 6D 1C ED B2 05 2D E6 D3 18 20 D5 E7 05 EB 45 01 C1 EB 85 11 00 EB 81 00 F4 21 D0 E9 0A 80 81 46 20 46 A1 F7 BF FF 04 F1 44 04 4F F0 00 00 65 61 44 E9 07 89 20 77 4F F0 FF 00 20 76 60 76 A0 76 A4 F1 44 04 06 2E 02 D0 11 2E
9:16:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E7 09 81 80 0A D0 13 E0 01 20 84 F8 68 00 9C 48 90 F8 F6 04 40 1C 8A F8 00 00 09 E0 05 20 84 F8 68 00 97 48 00 F5 9F 61 90 F8 F8 04 40 1C 08 70 00 2C C6 D0 A0 6D 43 E7 F0 B5 4F F0 FF 35 05 28 0A D2 00 EB 40 03 DF F8 38 C2 C3 EB 80 13 0C EB 83 03 9C 6D 84 42 01 D0 82 20 17 E0 93 F8 68 40 16 26 01 2C 04 D1 86 4F 97 F8 F5 74 02 2F 03 D2 84 4F 3F 78 28 2F 03 D0 81 48 C0 F8 FC 64 30 E0 0E 88 02 2E
9:16:33 AM
9:16:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E8 09 81 80 01 D1 10 2A 04 D0 84 20 7C 49 C1 F8 FC 04 26 E0 4E 88 00 22 4F F0 66 0E 02 EB 42 01 C1 EB 82 11 0C EB 81 01 B1 F8 6A 70 B7 42 0D D1 01 2C 02 D0 05 2C 05 D0 08 E0 91 F8 68 70 02 2F 0C D0 03 E0 91 F8 68 70 06 2F 07 D0 8F 6D FF 2F 09 D0 91 F8 60 10 31 B1 82 42 04 D1 68 48 C0 F8 FC E4 28 46 F0 BD 52 1C D2 B2 05 2A D6 D3 03 F1 60 03 4F F0 01 00 5E 81 18 70 4F F0 00 00 F0 BD 10 B5 12 B1
9:16:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 E9 09 81 80 01 28 02 D0 25 E0 00 20 10 BD 5C 4A 00 20 00 BF 00 EB 40 01 C1 EB 80 11 02 EB 81 01 91 F8 60 30 01 2B 12 D1 4B 6E 5C 07 0F D5 9B 03 0D D4 00 EB 40 03 C3 EB 80 10 02 EB 80 00 40 6E 20 F0 04 00 48 66 02 20 81 F8 60 00 03 E0 40 1C C0 B2 05 28 DE D3 01 20 10 BD 2D E9 F0 4F 04 46 80 6D 99 B0 05 28 3B D2 60 6E 40 07 38 D4 04 F1 28 00 A9 F7 A1 FB 4F F4 7A 7B 58 45 30 D3 60 6E 80 07 2D D4
9:16:34 AM
9:16:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 EA 09 81 80 A0 6D FF 28 2A D0 00 27 94 F8 68 10 01 22 BA 46 01 29 23 D1 39 4D 00 20 05 F2 F2 49 95 F8 F2 34 13 42 06 D0 52 06 40 1C 12 0E C0 B2 02 28 F7 D3 14 E0 40 1C C5 B2 01 20 90 46 01 29 02 D0 05 29 04 D0 0B E0 03 22 2B 46 28 46 01 E0 01 22 3B 46 B4 F8 6A 60 01 29 05 D0 05 29 08 D0 00 20 19 B0 BD E8 F0 8F CD E9 00 60 26 A1 02 90 01 E0 2C A1 00 96 03 A8 B9 F7 BE FB 20 48 CD F8 00 B0 2E 4B
9:16:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 EB 09 81 80 D0 F8 10 05 03 AA 02 21 C4 F7 82 FC 10 B1 00 20 C0 B2 E4 E7 94 F8 68 00 01 28 02 D0 05 28 0F D0 1F E0 16 48 84 F8 5C 50 90 F8 F2 04 40 EA 08 00 89 F8 00 00 11 48 00 F2 F5 41 90 F8 F5 04 0E E0 0E 49 84 F8 5E 70 01 F2 F4 40 91 F8 F4 14 41 EA 0A 01 01 70 09 48 00 F2 F7 41 90 F8 F7 04 40 1C 08 70 00 20 FF 21 22 18 40 1C 82 F8 5F 10 10 F0 FF 00 F8 D0 60 6E 40 F0 04 00 1F E0 00 8F 00 10
9:16:35 AM
9:16:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 EC 09 81 80 14 94 00 10 2B 57 49 50 43 52 45 41 54 45 3D 25 75 2C 25 75 2C 25 75 2C 25 75 2C 25 75 00 00 00 2B 57 49 50 43 52 45 41 54 45 3D 25 75 2C 25 75 2C 25 75 00 00 00 00 00 7D F4 05 00 60 66 04 F1 30 00 A9 F7 EF FA F8 49 01 F2 C5 40 91 F8 C5 14 21 F0 02 01 01 70 01 20 9A E7 70 B5 4F F0 FF 36 05 28 09 D2 00 EB 40 02 C2 EB 80 13 EE 4A 02 EB 83 04 A2 6D 82 42 01 D0 82 20 06 E0 94 F8 68 00
9:16:36 AM
9:16:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 ED 09 81 80 01 28 06 D1 01 29 04 DD 37 20 E7 49 C1 F8 FC 04 2C E0 94 F8 60 10 00 25 81 20 03 29 26 D2 DF E8 01 F0 02 03 20 00 F0 E7 E0 49 09 78 28 29 EC D1 20 46 FF F7 10 FF 38 B1 94 F8 68 00 01 28 05 D0 05 28 05 D0 84 20 E0 E7 16 20 DE E7 02 20 00 E0 06 20 84 F8 68 00 04 F8 8E 5F 76 20 65 70 A5 70 D3 E7 D1 48 C0 F8 FC 54 00 20 70 BD 30 46 70 BD 01 46 CD 4A 00 20 00 BF 00 EB 40 03 C3 EB 80 13
9:16:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 EE 09 81 80 02 EB 83 03 93 F8 5D 30 8B 42 05 D0 40 1C C0 B2 05 28 F1 D3 4F F0 FF 30 70 47 01 46 C2 4A 00 20 00 EB 40 03 C3 EB 80 13 02 EB 83 03 93 F8 5E 30 8B 42 05 D0 40 1C C0 B2 05 28 F1 D3 4F F0 FF 30 70 47 2D E9 F0 41 02 26 04 27 03 25 B6 4C 4F F0 01 08 C9 B2 01 28 26 D0 02 28 22 D1 08 46 FF F7 C7 FF 05 28 1D D2 00 EB 40 01 C1 EB 80 10 04 EB 80 04 60 6E 01 07 14 D5 20 F0 08 00 60 66 84 F8
9:16:37 AM
9:16:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 EF 09 81 80 60 50 04 F1 48 00 A9 F7 4D FA 04 F1 38 00 A9 F7 49 FA 67 82 66 84 84 F8 8F 80 60 6E 40 F0 40 00 60 66 BD E8 F0 81 08 46 FF F7 B7 FF 05 28 F8 D2 00 EB 40 01 C1 EB 80 10 04 EB 80 04 60 6E 01 07 14 D5 20 F0 08 00 60 66 84 F8 60 50 04 F1 48 00 A9 F7 28 FA 04 F1 38 00 A9 F7 24 FA 67 82 66 84 84 F8 8F 80 60 6E 40 F0 40 00 60 66 94 F8 60 00 02 28 D6 D1 84 F8 60 50 04 F1 38 00 BD E8 F0 41
9:16:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F0 09 81 80 A9 F7 10 BA 30 B5 03 46 00 20 02 46 0B E0 9C 5C A4 F1 30 05 0A 2D 08 D2 00 EB 80 00 40 00 30 38 52 1C 20 44 D2 B2 8A 42 F1 D3 30 BD 2D E9 F0 41 80 46 08 46 17 46 1E 46 3A 21 A1 F7 50 FE 04 00 AF D0 00 BF 14 F8 01 0F 20 28 FB D0 00 25 06 E0 A1 F7 45 FE 00 28 A4 D0 6D 1C ED B2 44 1C BD 42 4F F0 2C 01 20 46 F3 D3 A1 F7 39 FE 21 78 22 29 00 D1 64 1C 38 B1 00 1B C5 B2 60 19 10 F8 01 0C
9:16:38 AM
9:16:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F1 09 81 80 22 28 04 D0 05 E0 20 46 A1 F7 0A FE F4 E7 6D 1E ED B2 B5 42 01 D2 2A 46 00 E0 32 46 21 46 40 46 A1 F7 7E FC 00 21 B5 42 00 D3 35 46 01 20 08 F8 05 10 76 E7 30 B4 40 F2 42 32 2A 23 5B 49 A0 F2 42 34 90 42 0C D0 0D DC B0 F5 4B 7F 1C D0 B0 F5 4C 7F 1B D0 A0 F5 40 70 31 38 17 D0 0E 28 13 D1 30 BC 70 47 50 48 04 2C 90 F8 C5 24 00 F2 C5 40 42 F0 01 02 13 D0 4C 4A 08 2C 92 F8 C5 24 42 F0
9:16:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F2 09 81 80 01 02 0C D0 09 2C 0C D0 0B 70 E9 E7 88 7E 00 28 E6 D1 08 78 28 28 E3 D1 1C 20 08 70 E0 E7 02 70 DE E7 02 70 40 49 00 20 00 EB 40 02 C2 EB 80 12 01 EB 82 02 53 6E DC 06 13 D5 DB 04 11 D5 00 EB 40 03 C3 EB 80 10 01 EB 80 00 40 6E 20 F4 80 50 50 66 01 20 82 F8 90 00 34 48 30 BC 10 38 A9 F7 61 B9 40 1C 80 B2 05 28 DE D3 B9 E7 A2 E7 30 B5 85 B0 2A B1 38 B1 01 28 3E D0 09 28 3C D1 02 E0
9:16:39 AM
9:16:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F3 09 81 80 00 20 05 B0 30 BD 8C 68 0C 22 29 A1 20 46 A1 F7 DB FB 30 B1 0B 22 2A A1 20 46 A1 F7 D5 FB 90 B1 2A E0 12 23 00 22 21 46 68 46 FF F7 3F FF 12 21 68 46 FF F7 27 FF 80 B2 A0 F5 40 71 4A 39 1B D1 FF F7 78 FF 18 E0 12 23 00 22 21 46 68 46 FF F7 2D FF 12 21 68 46 FF F7 15 FF 85 B2 12 23 01 22 21 46 68 46 FF F7 22 FF 12 21 68 46 FF F7 0A FF 81 B2 28 46 FF F7 A5 FE 01 20 C2 E7 2D E9 F0 4F
9:16:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F4 09 81 80 8B B0 05 46 0B 46 4F F0 FF 36 05 28 0A D2 05 EB 45 00 DF F8 14 80 C0 EB 85 10 08 EB 80 04 A0 6D A8 42 13 D0 82 20 21 E0 00 8F 00 10 14 94 00 10 2B 43 4D 45 20 45 52 52 4F 52 3A 20 00 00 00 00 2B 57 49 50 52 45 41 44 59 3A 20 00 18 88 4F F0 84 0A 02 28 01 D1 08 2A 03 D0 FE 49 C1 F8 FC A4 32 E0 FD 48 00 78 28 28 04 D0 7C 20 F9 49 C1 F8 FC 04 29 E0 94 F8 60 00 78 21 03 28 21 D0 94 F8
9:16:40 AM
9:16:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F5 09 81 80 68 00 81 46 02 28 22 D0 06 28 20 D0 04 28 18 D0 07 28 16 D0 00 21 4F F0 66 0B 00 BF 01 EB 41 02 C2 EB 81 12 08 EB 82 0C DC F8 58 20 FF 2A 25 D0 9C F8 60 20 12 B3 A9 42 0B D1 E6 49 C1 F8 FC B4 02 E0 E4 48 C0 F8 FC 14 30 46 0B B0 48 E5 16 20 CC E7 BC F8 6A 20 5F 88 BA 42 0F D1 B9 F1 01 0F 03 D0 B9 F1 05 0F 05 D0 08 E0 9C F8 68 20 04 2A E3 D0 03 E0 9C F8 68 20 07 2A DE D0 49 1C C9 B2
9:16:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F6 09 81 80 05 29 CB D3 04 F1 5C 04 4F F0 00 09 84 F8 01 90 84 F8 02 90 04 F8 5C 99 01 28 03 D0 05 28 9C D1 18 20 A3 E7 CB 4A 4F F0 04 0B 59 46 92 F8 F3 74 02 20 02 F2 F3 42 0F 42 06 D0 49 06 40 1C 09 0E C0 B2 03 28 F7 D3 EB E7 40 1C 84 F8 5D 00 C1 48 90 F8 F3 04 08 43 10 70 5F 88 04 F1 70 01 03 A8 A1 F7 04 FC 05 EB 45 01 BA 4A 94 F8 68 00 C1 EB 85 11 02 EB 81 08 0D F1 0C 0C 08 F1 98 08 01 28
9:16:41 AM
9:16:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F7 09 81 80 4E D0 05 28 CB D1 B3 48 49 F6 41 45 00 F2 F9 41 90 F8 F9 04 94 F8 5E 30 05 44 40 1C 08 70 A8 B2 CD E9 00 0C 01 22 AD A1 02 97 40 46 B9 F7 A2 F8 02 21 84 F8 F0 10 B1 4B 41 F2 88 30 C4 F8 94 30 60 65 00 90 A3 48 42 46 D0 F8 10 05 C4 F7 60 F9 00 28 60 6E 2C D0 40 F4 00 31 61 66 A4 F8 EE 90 04 F1 30 00 A9 F7 1E F8 60 6E 40 F0 08 00 60 66 01 20 84 F8 60 00 84 F8 8E 90 84 F8 8F 90 84 F8
9:16:42 AM
9:16:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F8 09 81 80 90 90 94 F8 68 10 48 46 01 29 15 D0 05 29 86 D1 07 21 84 F8 68 10 8F 49 C1 F8 FC 04 00 20 54 E7 94 F8 5D 30 CD E9 00 C7 02 22 95 A1 40 46 BD E7 20 F4 00 31 61 66 D3 E7 84 F8 68 B0 76 20 15 E7 F0 B5 4F F0 FF 36 05 28 09 D2 00 EB 40 03 C3 EB 80 14 80 4B 03 EB 84 05 AC 6D 84 42 01 D0 82 20 04 E0 7D 48 04 78 7C 20 28 2C 03 D0 79 49 C1 F8 FC 04 26 E0 95 F8 60 40 08 2C 22 D2 DF E8 04 F0
9:16:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 F9 09 81 80 05 05 07 43 21 21 21 04 F0 E7 16 20 EE E7 00 24 28 19 90 F8 5F 00 05 28 0F D2 00 EB 40 07 C7 EB 80 17 03 EB 87 07 97 F8 60 C0 BC F1 03 0F 04 D1 D7 F8 64 C0 5F EA CC 7C 05 D0 64 1C 14 F0 FF 04 E6 D0 30 46 F0 BD 95 F9 8E 40 00 2C 02 DD 64 1E 85 F8 8E 40 00 EB 40 04 C4 EB 80 14 03 EB 84 03 00 29 5B 6E 43 F0 01 03 7B 66 EB D0 00 2A E9 D0 12 68 08 2A E6 DB 02 22 0A 80 B7 F8 6A 20 4A 80
9:16:43 AM
9:16:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 FA 09 81 80 FA 6E 4A 60 F0 BD 84 20 B0 E7 00 21 01 60 70 47 10 B5 00 22 0B 68 05 E0 01 EB 82 04 64 68 84 42 02 D0 52 1C 93 42 F7 D8 93 42 07 D1 05 2B 05 D2 01 EB 82 02 50 60 08 68 40 1C 08 60 10 BD 10 B5 00 22 0B 68 08 E0 00 BF 01 EB 82 04 64 68 84 42 01 D1 01 20 10 BD 52 1C 93 42 F5 D8 00 20 10 BD 2D E9 F0 43 93 B0 81 46 DD F8 68 80 0F 46 15 46 1E 46 B8 F1 00 0F 06 D0 00 24 6F B1 18 22 68 46
9:16:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 FB 09 81 80 A1 F7 79 FA 09 E0 33 49 8F 20 C1 F8 FC 04 4F F0 FF 30 13 B0 BD E8 F0 83 00 94 2D B1 18 22 29 46 06 A8 A1 F7 68 FA 00 E0 06 94 2E B1 18 22 31 46 0C A8 A1 F7 60 FA 00 E0 0C 94 48 46 B9 F1 05 0F 00 DB 04 20 0C AB 06 AA 69 46 03 F0 9D F8 5F EA 00 09 05 D1 D8 F8 00 00 10 B9 D8 F8 04 00 B0 B1 27 B1 18 22 69 46 38 46 A1 F7 45 FA 25 B1 18 22 06 A9 28 46 A1 F7 3F FA 26 B1 18 22 0C A9 30 46
9:16:44 AM
9:16:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 FC 09 81 80 A1 F7 39 FA 13 48 C0 F8 FC 44 48 46 C1 E7 07 B1 3C 60 05 B1 2C 60 06 B1 34 60 0E 48 C0 F8 FC 44 00 20 B6 E7 2D E9 F0 41 05 28 01 D3 00 20 B8 E4 00 EB 40 01 C1 EB 80 11 06 48 00 27 00 EB 81 04 20 68 10 B1 C0 F7 B8 FC 27 60 60 68 25 1D 00 B1 24 E0 26 E0 00 8F 00 10 14 94 00 10 2B 57 49 50 43 52 45 41 54 45 3D 25 75 2C 25 75 2C 25 75 2C 22 25 73 22 2C 25 75 00 00 00 00 00 6F F9 05 00
9:16:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 FD 09 81 80 2B 57 49 50 43 52 45 41 54 45 3D 25 75 2C 25 75 2C 22 25 73 22 2C 25 75 00 00 00 00 C0 F7 8C FC 2F 60 04 F1 08 06 30 68 28 60 68 B1 40 68 30 60 00 B9 77 60 28 68 47 60 30 89 40 1E 30 81 28 68 10 B1 C0 F7 79 FC EE E7 18 34 20 68 28 60 68 B1 40 68 20 60 00 B9 67 60 28 68 47 60 20 89 40 1E 20 81 28 68 10 B1 C0 F7 67 FC EE E7 01 20 58 E4 00 20 70 47 0A B1 01 20 70 47 00 20 70 47 2D E9
9:16:45 AM
9:16:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 FE 09 81 80 F0 4F 9D B0 07 46 4F F0 00 09 05 28 09 D2 07 EB 47 00 FF 4A C0 EB 87 10 02 EB 80 04 A0 6D B8 42 01 D0 82 20 39 E1 FB 48 00 78 28 28 01 D0 60 6E 0F E0 F7 48 D0 F8 00 05 FF 28 01 D0 B8 42 F6 D1 60 68 18 B9 B4 F9 20 00 00 28 06 DD 60 6E 41 04 03 D4 40 F4 80 40 60 66 A7 E0 ED 48 94 F8 60 30 00 F5 A2 61 1B 91 07 EB 47 01 C1 EB 87 11 00 EB 81 01 01 F1 28 05 30 31 CD E9 17 51 00 F5 9F 65
9:16:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 07 FF 09 81 80 00 F2 F3 4B 00 F2 F7 4A 00 F2 F4 48 E9 1E C8 1E CD E9 19 10 AE 1E 09 2B 71 D2 DF E8 03 F0 05 05 8B E7 E7 E7 FD FD 8B 00 D9 48 94 F8 68 10 90 F8 F6 04 40 1E C2 B2 02 29 1D D0 D5 48 90 F8 F6 04 40 1E C2 B2 01 29 2A D0 D1 48 90 F8 F8 34 90 F8 F4 04 5B 1E DB B2 06 29 23 D0 CD 4B 93 F8 F8 34 5B 1E DB B2 05 29 2D D0 07 29 2D D0 03 29 37 D0 04 29 35 D0 44 E0 94 F8 5C 10 01 20 49 1E 88 40
9:16:46 AM
9:16:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 00 09 81 80 C1 B2 C3 48 90 F8 F2 04 08 42 39 D0 88 43 1A 99 08 70 BF 48 19 99 90 F8 F5 04 40 1E 08 70 32 70 2E E0 94 F8 5E 20 01 21 52 1E 91 40 C9 B2 08 42 26 D0 88 43 88 F8 00 00 B5 48 90 F8 F7 04 40 1E 8A F8 00 00 2B 70 1B E0 94 F8 5E 20 01 21 52 1E 91 40 C9 B2 08 42 13 D0 88 43 88 F8 00 00 F1 E7 94 F8 5D 10 01 20 49 1E 88 40 C1 B2 A8 48 90 F8 F3 04 08 42 04 D0 88 43 8B F8 00 00 CF E7 8B E0
9:16:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 01 09 81 80 04 F1 58 04 E0 68 20 F0 01 00 20 F4 80 40 20 F0 08 00 E0 60 4F F0 FF 00 20 60 4F F0 00 00 20 72 20 74 60 82 20 71 60 71 A0 71 4F F0 00 00 1D B0 BD E8 F0 8F 94 F8 68 00 06 28 02 D0 02 28 04 D0 6A E0 01 22 94 F8 5E 30 0E E0 00 25 60 19 90 F8 5F 00 05 28 01 D2 FF F7 12 FF 6D 1C 15 F0 FF 05 F4 D0 94 F8 5C 30 03 22 8B A1 01 A8 B8 F7 02 FE 4F F4 7A 70 00 90 86 48 8C 4B 01 AA D0 F8 10 05
9:16:47 AM
9:16:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 02 09 81 80 02 21 C3 F7 C5 FE 10 B1 4F F0 00 09 62 E0 94 F8 68 00 02 28 15 D1 94 F8 5C 10 01 20 49 1E 88 40 7B 49 91 F8 F2 14 81 43 1A 98 01 70 78 48 19 99 90 F8 F5 04 40 1E 08 70 75 48 90 F8 F6 04 40 1E 30 70 FF 20 44 F8 58 0F 00 20 20 72 E1 68 21 F4 80 41 E1 60 20 74 60 82 20 71 60 71 A0 71 84 F8 36 00 84 F8 37 00 84 F8 38 00 EA E0 60 6E C1 06 3F F5 DE AE 04 F1 38 00 A8 F7 50 FD 04 F1 40 00
9:16:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 03 09 81 80 A8 F7 4C FD 94 F8 68 00 07 28 0C D0 06 28 0A D0 03 28 0C D0 04 28 0A D0 84 20 5D 49 C1 F8 FC 04 4F F0 FF 30 83 E7 01 22 94 F8 5E 30 02 E0 94 F8 5D 30 02 22 58 A1 01 A8 B8 F7 9C FD 4F F4 7A 70 00 90 53 48 59 4B 01 AA D0 F8 10 05 02 21 C3 F7 5F FE 20 B1 60 6E 40 F4 80 40 60 66 B9 E0 94 F8 68 10 4B 48 03 29 1B D1 00 21 4F F0 FF 09 86 46 01 EB 41 02 C2 EB 81 13 00 20 0E EB 83 0C 00 BF
9:16:48 AM
9:16:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 04 09 81 80 0C EB 00 02 92 F8 5F 30 BB 42 01 D1 82 F8 5F 90 40 1C 10 F0 FF 00 F3 D0 49 1C C9 B2 05 29 E7 D3 94 F8 68 00 06 28 06 D0 07 28 16 D0 03 28 25 D0 04 28 23 D0 36 E0 94 F8 5E 10 01 20 49 1E 88 40 33 49 91 F8 F4 14 81 43 31 48 88 F8 00 10 90 F8 F7 04 40 1E 8A F8 00 00 0A E0 94 F8 5E 10 01 20 49 1E 88 40 2A 49 91 F8 F4 14 81 43 88 F8 00 10 27 48 90 F8 F8 04 40 1E 28 70 13 E0 94 F8 5D 10
9:16:49 AM
9:16:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 05 09 81 80 01 20 A1 F1 01 01 00 FA 01 F0 21 49 91 F8 F3 14 21 EA 00 01 1E 48 8B F8 00 10 90 F8 F6 04 A0 F1 01 00 30 70 60 6E C1 06 1B D5 20 F0 10 00 60 66 17 48 A1 6D D0 F8 00 05 88 42 03 D1 14 49 FF 20 C1 F8 00 05 12 48 03 21 D0 F8 10 05 C3 F7 24 FF 1B 98 17 49 00 68 C0 F8 EC 10 0D 49 00 20 A1 F8 0C 05 04 F1 5C 04 A0 68 20 F0 01 00 20 F4 80 40 A0 60 4F F0 06 00 20 71 4F F0 00 00 20 73 E0 81
9:16:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 06 09 81 80 20 70 60 70 A0 70 20 74 84 F8 32 00 12 E0 00 00 00 8F 00 10 14 94 00 10 2B 57 49 50 43 4C 4F 53 45 3D 25 75 2C 25 75 00 00 00 00 00 F5 FE 05 00 F1 FE 05 00 84 F8 33 00 84 F8 34 00 38 46 FF F7 71 FD 18 98 A8 F7 6E FC 17 98 A8 F7 6B FC 4F F0 00 09 48 46 AB E6 10 B5 00 22 05 28 09 D2 00 EB 40 03 C3 EB 80 14 FE 4B 03 EB 84 03 9C 6D 84 42 01 D0 82 20 04 E0 FB 48 00 78 28 28 04 D0 7C 20
9:16:50 AM
9:16:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 07 09 81 80 F7 4B C3 F8 FC 04 29 E0 93 F8 60 00 09 28 0F D2 DF E8 00 F0 05 07 07 0E 0E 09 0E 09 07 00 16 20 EE E7 80 20 EC E7 EE 4B 96 20 C3 F8 FC 04 1A E0 98 68 78 B1 44 68 9C 60 04 B9 DA 60 42 60 1C 8A 64 1E 24 B2 1C 82 00 2C 01 DC 83 F8 8E 20 08 60 01 20 10 BD 93 F8 8E 00 01 28 02 D0 00 20 0A 60 10 BD 83 F8 8E 20 0A 60 F2 E7 10 B5 05 28 09 D2 00 EB 40 02 C2 EB 80 13 D9 4A 02 EB 83 02 93 6D
9:16:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 08 09 81 80 83 42 01 D0 82 20 20 E0 D6 48 00 78 28 28 01 D0 7C 20 1A E0 92 F8 60 30 16 20 09 2B 0A D2 DF E8 03 F0 14 05 05 09 09 07 09 07 05 00 80 20 0C E0 96 20 0A E0 49 B1 B2 F9 20 00 B2 F9 22 30 98 42 08 DB 90 8C 40 1C 90 84 37 20 C5 49 C1 F8 FC 04 00 20 10 BD 00 20 48 60 D0 69 30 B1 41 60 D1 61 10 8C 40 1C 10 84 01 20 10 BD 91 61 F7 E7 BC 48 D0 F8 FC 04 70 47 BA 48 B0 F9 F0 04 70 47 10 B5
9:16:51 AM
9:16:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 09 09 81 80 00 22 0B 68 14 E0 00 BF 01 EB 82 04 64 68 84 42 05 D0 0C E0 01 EB 82 00 52 1C 83 68 43 60 08 68 40 1E 90 42 F6 D8 08 68 40 1E 08 60 10 BD 52 1C 93 42 E9 D8 10 BD AA 48 90 F8 C4 04 07 28 0B D2 DF E8 00 F0 04 08 08 08 08 08 08 00 A4 49 01 20 81 F8 C4 04 01 20 70 47 00 20 70 47 2D E9 F0 41 A0 4C 80 46 15 46 20 78 2A 28 04 D0 28 28 04 D0 28 B1 0D 20 9B E4 05 20 99 E4 03 20 97 E4 98 48
9:16:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 0A 09 81 80 90 F8 C4 04 08 28 06 D0 07 28 F3 D0 28 B1 06 28 03 D0 0F 20 8B E4 06 20 89 E4 08 78 01 28 01 D0 C0 B9 04 E0 91 F8 2B 20 A2 B1 04 2A 12 D8 4A 78 0A B1 01 2A 0E D1 91 F8 2C 30 DE 07 07 D1 91 F8 22 60 F7 07 03 D1 9B 07 01 D4 B3 07 02 D5 01 2A 02 D1 08 B1 0E 20 6A E4 82 48 7C 22 1A 30 A0 F7 1F FE E0 7E 01 28 05 D0 7E 48 00 21 8A 30 01 60 08 30 01 60 40 46 FF F7 9E FF 01 20 20 70 A4 F8
9:16:52 AM
9:16:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 0B 09 81 80 96 00 78 48 65 61 0C 30 A8 F7 4C FB 0C 20 4E E4 74 48 00 78 36 28 35 D2 DF E8 00 F0 1B 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 26 28 34 2A 2C 2E 30 32 32 32 32 32 32 32 63 48 90 F8 C4 04 06 28 01 D0 00 20 70 47 10 20 70 47 01 20 70 47 03 20 70 47 04 20 70 47 08 20 70 47 09 20 70 47 0A 20 70 47 0B 20 70 47
9:16:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 0C 09 81 80 02 20 70 47 05 20 70 47 10 B5 0A 46 FF F7 C0 FF 01 28 11 D0 02 28 0F D0 52 4C 01 20 A4 F8 98 00 00 20 A4 F8 9A 00 04 F1 0C 00 62 61 A8 F7 FA FA 2F 20 20 70 0C 20 10 BD 0D 20 10 BD 10 B5 49 4C 21 78 11 B1 28 29 05 D1 0A E0 45 48 90 F8 C4 04 06 28 01 D0 00 20 10 BD 34 20 20 70 01 20 10 BD 47 F2 30 51 FF F7 D0 FF 01 20 A4 F8 9A 00 F5 E7 01 46 3B 4A 00 20 00 BF 00 EB 40 03 C3 EB 80 13
9:16:53 AM
9:16:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 0D 09 81 80 02 EB 83 03 93 F8 5C 30 8B 42 05 D0 40 1C C0 B2 05 28 F1 D3 4F F0 FF 30 70 47 00 20 30 4B 01 46 01 EB 41 02 C2 EB 81 12 03 EB 82 02 92 F8 60 20 03 2A 03 D0 05 2A 01 D0 06 2A 01 D1 40 1C C0 B2 49 1C 05 29 EC D3 70 47 70 B5 A8 F7 97 FA 00 22 04 46 23 4D 50 1E 11 46 01 EB 41 03 C3 EB 81 13 05 EB 83 03 93 F8 60 60 03 2E 05 D1 1B 6D E3 1A 93 42 01 D3 1A 46 08 46 49 1C 05 29 EC D3 70 BD
9:16:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 0E 09 81 80 1C B5 0C 46 C2 B2 C0 F3 07 21 CD E9 00 12 02 0E C0 F3 07 43 14 A1 20 46 B8 F7 EC FA 20 46 1C BD 70 B5 01 25 00 24 20 46 FF F7 7C FB 00 B9 00 25 64 1C 05 2C F7 D3 28 46 70 BD 2D E9 F0 41 88 46 17 46 05 28 09 D2 00 EB 40 01 05 4D C1 EB 80 16 05 EB 86 04 A1 6D 81 42 0C D0 00 20 CA E6 00 00 00 8F 00 10 14 94 00 10 25 64 2E 25 64 2E 25 64 2E 25 64 00 55 F8 26 00 28 B9 BF F7 DB FF 45 F8
9:16:54 AM
9:16:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 0F 09 81 80 26 00 00 28 EA D0 42 46 39 B2 C0 F7 0C F9 80 B2 B8 42 02 D0 A1 8A 49 1C A1 82 B4 F9 10 10 B4 F9 12 20 00 27 91 42 09 DB A0 8A 40 1C A0 82 55 F8 26 00 C0 F7 01 F8 45 F8 26 70 CE E7 55 F8 26 10 4F 60 E1 68 81 B1 55 F8 26 20 4A 60 55 F8 26 10 E1 60 21 8A 49 1C 21 82 45 F8 26 70 10 B1 01 20 84 F8 8E 00 01 20 85 E6 55 F8 26 10 A1 60 ED E7 2D E9 F0 43 0C 46 F7 A1 05 46 D1 E9 00 03 8B B0
9:16:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 10 09 81 80 89 68 CD E9 02 03 F6 A0 04 91 D0 E9 00 13 80 68 08 91 CD E9 09 30 82 B1 00 21 0A 20 CD E9 00 01 90 46 01 26 0D 23 F1 A2 F2 A1 05 A8 B8 F7 62 FA 28 78 F3 4F 03 28 04 D0 13 E0 00 20 0B B0 BD E8 F0 83 D8 F8 00 00 D0 F8 00 05 05 28 09 D2 00 EB 40 01 C1 EB 80 10 07 EB 80 00 41 6E 41 F4 80 51 41 66 E8 48 A8 F7 E6 F9 40 F6 B8 31 88 42 13 D3 D8 F8 00 00 D0 F8 00 05 00 EB 40 01 C1 EB 80 10
9:16:55 AM
9:16:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 11 09 81 80 07 EB 80 00 40 6E C1 05 06 D4 80 05 04 D4 DC 48 B0 F8 0C 05 01 28 7D D1 4F F0 01 09 00 27 02 A8 A0 F7 FE FD 02 46 02 A9 28 46 A0 F7 83 FD 48 B1 02 A8 A0 F7 F5 FD 02 46 02 A9 A8 1C A0 F7 7A FD 20 B1 0A E0 00 26 0A 35 0A 3C 02 E0 00 26 0C 35 0C 3C 24 04 24 0C 00 D0 01 26 0B 22 08 A9 28 46 A0 F7 68 FD 30 B1 0B 22 08 A9 A8 1C A0 F7 62 FD 20 B1 0A E0 00 26 12 35 12 3C 02 E0 00 26 14 35
9:16:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 12 09 81 80 14 3C 24 04 24 0C 00 D0 01 26 05 A8 A0 F7 C8 FD 02 46 05 A9 28 46 A0 F7 4D FD 48 B1 05 A8 A0 F7 BF FD 02 46 05 A9 A8 1C A0 F7 44 FD 20 B1 0A E0 00 26 09 35 09 3C 02 E0 00 26 0B 35 0B 3C 24 04 24 0C 00 D0 01 26 0A 22 AF A1 28 46 A0 F7 FC FB 28 B1 0A 22 AC A1 A8 1C A0 F7 F6 FB 00 B9 00 26 0C 22 AC A1 28 46 A0 F7 EF FB 88 B1 0C 22 A9 A1 A8 1C A0 F7 E9 FB 58 B1 0F 22 AA A1 28 46 A0 F7
9:16:56 AM
9:16:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 13 09 81 80 E3 FB 28 B1 0F 22 A7 A1 A8 1C A0 F7 DD FB 00 B9 00 26 00 E0 16 E0 0C 22 AF F6 6C 71 28 46 A0 F7 D3 FB 30 B1 0C 22 AF F6 78 71 A8 1C A0 F7 CC FB 00 B9 00 26 7F 1C FF B2 B9 F1 00 0F 02 D0 03 2F FF F4 6D AF D8 F8 0C 00 DB F7 45 FD B8 B1 04 22 98 A1 28 46 A0 F7 B8 FB C8 B3 04 22 95 A1 A8 1C A0 F7 B2 FB 98 B3 05 22 94 A1 28 46 A0 F7 AC FB 68 B3 05 22 91 A1 A8 1C A0 F7 A6 FB 38 B3 01 2E
9:16:57 AM
9:16:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 14 09 81 80 25 D1 D8 F8 00 00 D0 F8 00 05 05 28 1F D2 22 46 29 46 FF F7 92 FE D8 F8 00 00 D0 F8 00 15 01 EB 41 02 C2 EB 81 11 38 22 02 EB 81 01 08 44 A8 F7 F9 F8 D8 F8 00 10 D1 F8 00 05 00 EB 40 02 C2 EB 80 10 40 22 02 EB 80 00 08 44 A8 F7 EB F8 01 20 F4 E6 30 B5 85 B0 5A B1 00 28 5A D0 01 28 58 D0 67 4C 04 28 04 F5 A0 65 05 D0 09 28 51 D1 21 E0 00 20 05 B0 30 BD 91 68 72 48 C1 F8 EC 00 90 68
9:16:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 15 09 81 80 10 F8 CB 1F 21 F0 01 01 01 70 5D 48 D0 F8 00 05 00 EB 40 01 C1 EB 80 10 04 EB 80 00 41 6E 41 F0 20 01 41 66 90 68 F8 30 A8 F7 B8 F8 55 48 A8 F7 B9 F8 2E E0 89 68 12 23 00 22 68 46 FE F7 B6 FE 12 21 68 46 FE F7 9E FE 80 B2 A0 F5 40 71 4E 39 1F D1 4B 48 D0 F8 00 05 05 28 13 D2 00 EB 40 01 C1 EB 80 10 04 EB 80 01 48 6E 20 F4 00 30 48 66 29 68 20 F0 10 00 01 EB 41 02 C2 EB 81 11 04 EB
9:16:58 AM
9:16:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 16 09 81 80 81 01 48 66 3E 49 FF 20 C1 F8 00 05 01 20 A1 F8 F0 04 01 20 AD E7 70 B5 06 46 39 48 98 B0 0D 46 B0 F8 0C 05 01 28 34 D0 05 2D 32 D2 05 EB 45 00 C0 EB 85 11 32 48 00 EB 81 04 60 6E C1 06 28 D4 94 F8 60 10 89 07 24 D0 2D 49 D1 F8 00 15 FF 29 06 D0 2B 49 09 1F 08 88 00 F1 01 00 08 80 18 E0 40 03 16 D5 94 F8 5E 20 02 23 0A B1 36 A1 03 E0 94 F8 5D 20 6A B1 39 A1 01 A8 B8 F7 BB F8 4F F4
9:16:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 17 09 81 80 FA 60 00 90 3A 4B 01 AA 03 21 B0 68 C3 F7 80 F9 10 B1 00 20 18 B0 70 BD 04 F1 38 00 A8 F7 42 F8 60 6E 20 F0 20 00 40 F0 10 00 60 66 14 48 C0 F8 00 55 01 20 EE E7 10 B5 86 B0 3A B1 48 B1 01 28 7D D0 02 28 05 D0 09 28 03 D1 53 E0 00 20 06 B0 10 BD 9F E0 53 48 55 54 44 4F 57 4E 0D 0A 00 00 41 54 2B 57 49 50 44 41 54 41 3D 00 43 4F 4E 4E 45 43 54 00 25 73 25 63 25 63 25 63 00 00 00 00
9:16:59 AM
9:16:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 18 09 81 80 00 8F 00 10 E8 93 00 10 2B 57 49 50 44 41 54 41 3A 20 00 00 2B 57 49 50 41 43 43 45 50 54 3A 20 00 00 00 00 2B 57 49 50 50 45 45 52 43 4C 4F 53 45 3A 20 00 52 49 4E 47 00 00 00 00 2B 43 4C 49 50 00 00 00 F1 07 06 00 2B 57 49 50 44 41 54 41 3D 31 2C 25 75 2C 25 75 00 00 00 00 2B 57 49 50 44 41 54 41 3D 32 2C 25 75 2C 25 75 00 00 00 00 53 0A 06 00 89 68 12 23 00 22 68 46 FE F7 D6 FD
9:16:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 19 09 81 80 12 21 68 46 FE F7 BE FD 80 B2 A0 F5 40 70 3F 38 40 D1 FE 48 00 F5 A0 61 D0 F8 00 05 00 EB 40 02 C2 EB 80 12 F9 48 00 EB 82 02 92 F8 90 30 01 2B 03 D1 53 6E 23 F0 10 03 53 66 F4 4A 00 E0 21 E0 D2 F8 00 25 05 2A 1D D2 02 EB 42 03 C3 EB 82 12 00 EB 82 02 53 6E 23 F4 00 33 53 66 0B 68 01 22 03 EB 43 04 C4 EB 83 13 00 EB 83 03 83 F8 90 20 09 68 00 22 01 EB 41 03 C3 EB 81 11 00 EB 81 00
9:17:00 AM
9:17:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 1A 09 81 80 80 F8 8F 20 E1 49 01 F2 04 50 B1 F8 04 15 09 B9 A7 F7 88 FF 01 20 5A E7 30 B5 05 46 DB 48 97 B0 B0 F8 04 05 58 BB 05 29 29 D2 01 EB 41 00 C0 EB 81 11 D6 48 00 EB 81 04 60 6E C0 06 1F D5 42 B9 60 68 08 B9 A0 69 20 B1 D0 49 00 20 A1 F8 0C 05 15 E0 94 F8 5E 20 0A B1 CD A1 03 E0 94 F8 5D 20 6A B1 D0 A1 01 A8 B7 F7 C5 FF 4F F4 FA 60 00 90 D1 4B 01 AA 02 21 A8 68 C3 F7 8A F8 10 B1 00 20
9:17:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 1B 09 81 80 17 B0 30 BD C1 49 01 20 A1 F8 0C 05 A7 F7 36 FF 20 65 01 20 F4 E7 70 B5 8C B0 12 B1 00 28 6E D1 02 E0 00 20 0C B0 70 BD 8C 68 09 22 C3 A1 20 46 A0 F7 CA F9 00 28 62 D1 02 90 03 90 04 90 05 90 12 23 02 22 21 46 06 A8 FE F7 30 FD 02 A9 03 A8 CD E9 00 01 04 AB 05 AA BB A1 06 A8 A0 F7 9E FE 05 98 20 B9 FF 20 05 90 04 90 03 90 02 90 A7 4C 00 20 00 BF 00 EB 40 01 C1 EB 80 11 04 EB 81 01
9:17:01 AM
9:17:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 1C 09 81 80 49 6E 49 05 2E D5 00 EB 40 01 C1 EB 80 10 14 EB 80 00 34 D0 00 F1 64 00 05 99 01 72 04 99 41 72 03 99 81 72 02 99 C1 72 01 68 21 F4 80 61 40 F8 64 19 4F F0 00 01 00 BF 01 EB 41 03 C3 EB 81 13 D0 F8 58 50 4F F0 00 02 04 EB 83 03 03 EB 02 06 96 F8 5F 60 AE 42 0A D1 13 F8 8E 1F 49 1C 19 70 05 21 08 E0 40 1C C0 B2 05 28 C3 D3 07 E0 52 1C 12 F0 FF 02 EA D0 49 1C C9 B2 05 29 DC D3 01 20
9:17:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 1D 09 81 80 90 E7 F0 B5 0C 46 06 46 80 4A A0 6D 97 B0 00 21 01 EB 41 03 C3 EB 81 13 02 EB 83 03 9D 6D 85 42 02 D0 5B 6E 5B 05 09 D4 49 1C C9 B2 05 29 EF D3 94 F8 68 00 03 28 04 D0 06 28 06 D0 00 20 17 B0 F0 BD 02 22 94 F8 5D 30 02 E0 94 F8 5E 30 01 22 41 F2 88 35 7F A1 01 A8 B7 F7 0C FF 00 95 82 4B 01 AA 02 21 B0 68 C2 F7 D3 FF 04 F1 30 06 80 B1 00 27 30 46 A7 F7 9E FE A8 42 08 D9 60 6E 41 05
9:17:02 AM
9:17:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 1E 09 81 80 05 D5 20 F4 80 60 60 66 30 46 A7 F7 87 FE 38 46 D5 E7 60 6E 40 F4 80 60 60 66 30 46 A7 F7 82 FE 01 27 E6 E7 10 B5 86 B0 0A B1 80 BB 01 E0 00 20 4D E6 8C 68 09 22 61 A1 20 46 A0 F7 05 F9 30 BB 00 20 05 90 12 23 02 22 21 46 68 46 FE F7 6E FC 05 AA 66 A1 68 46 A0 F7 E1 FD 4C 49 00 20 00 BF 00 EB 40 02 C2 EB 80 12 01 EB 82 02 52 6E 12 05 0F D5 00 EB 40 02 C2 EB 80 10 11 EB 80 00 06 D0
9:17:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 1F 09 81 80 05 99 A0 F8 6A 10 41 6E 21 F4 00 61 41 66 01 20 1D E6 40 1C C0 B2 05 28 E2 D3 F8 E7 F0 B5 0C 46 06 46 3A 4A D4 F8 58 00 97 B0 00 21 01 EB 41 03 C3 EB 81 13 02 EB 83 03 9D 6D 85 42 02 D0 5B 6E 1B 05 09 D4 49 1C C9 B2 05 29 EF D3 94 F8 68 00 03 28 03 D0 06 28 05 D0 00 20 70 E7 02 22 94 F8 5D 30 02 E0 94 F8 5E 30 01 22 41 F2 88 35 40 A1 01 A8 B7 F7 7F FE 00 95 42 4B 01 AA 02 21 B0 68
9:17:03 AM
9:17:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 20 09 81 80 C2 F7 46 FF 04 F1 30 06 80 B1 00 27 30 46 A7 F7 11 FE A8 42 08 D9 60 6E 01 05 05 D5 20 F4 00 60 60 66 30 46 A7 F7 FA FD 38 46 48 E7 60 6E 40 F4 00 60 60 66 30 46 A7 F7 F5 FD 01 27 E6 E7 10 B5 13 46 98 B0 04 46 0A 46 AF F6 34 51 01 A8 B7 F7 51 FE 64 20 00 90 00 23 01 AA 02 21 A0 68 C2 F7 17 FF 18 B0 B4 E5 70 B5 03 46 88 6D 0C 46 05 28 7A D8 60 68 00 25 38 B9 A0 69 60 60 00 28 73 D0
9:17:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 21 09 81 80 41 68 A1 61 09 B9 3F E0 47 E0 3E E0 00 8F 00 10 2B 57 49 50 44 41 54 41 3D 31 2C 25 75 2C 30 00 00 00 00 00 2B 57 49 50 44 41 54 41 3D 32 2C 25 75 2C 30 00 00 00 00 00 B7 0B 06 00 2B 57 49 50 4F 50 54 3A 20 00 00 00 25 75 2E 25 75 2E 25 75 2E 25 75 00 2B 57 49 50 4F 50 54 3D 25 75 2C 25 75 2C 31 2C 32 00 00 00 97 0D 06 00 25 75 00 00 2B 57 49 50 4F 50 54 3D 25 75 2C 25 75 2C 31 2C
9:17:04 AM
9:17:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 22 09 81 80 31 00 00 00 25 0F 06 00 E5 61 45 60 20 8C A0 F1 01 00 20 84 60 68 00 28 26 D0 60 6E C1 06 04 D4 A1 6D BD E8 70 40 18 46 F5 E4 FE 49 A2 6D D1 F8 00 15 91 42 18 D1 FB 49 B1 F8 0C 15 00 29 13 D1 80 06 11 D5 62 68 03 21 98 68 C2 F7 EA FF 00 28 0A D0 04 F1 38 00 65 60 A7 F7 64 FD 04 F1 40 00 BD E8 70 40 A7 F7 5E BD 70 BD 10 B5 86 B0 32 B1 E8 B1 01 24 01 28 17 D0 09 28 18 D1 01 E0 00 20
9:17:05 AM
9:17:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 23 09 81 80 25 E5 89 68 12 23 00 22 68 46 FE F7 4F FB 12 21 68 46 FE F7 37 FB 80 B2 B0 F5 53 7F 07 D1 E1 48 90 F8 C6 04 05 28 02 D1 DE 48 A0 F8 CE 44 01 20 0D E5 10 B5 12 B1 0A 28 02 D0 21 E0 00 20 07 E5 D8 49 01 F2 C5 40 91 F8 C5 14 41 F0 02 01 01 70 D4 48 B0 F8 0C 05 01 28 12 D1 D2 49 00 20 A1 F8 0C 05 08 46 D0 F8 00 05 05 28 09 D2 00 EB 40 01 C1 EB 80 10 CB 49 01 EB 80 00 38 30 A7 F7 12 FD
9:17:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 24 09 81 80 01 20 E5 E4 10 B5 D0 B2 FE F7 72 FA 05 28 12 D2 00 EB 40 01 C1 EB 80 11 C2 48 00 EB 81 00 41 6E 41 F4 80 71 41 66 00 21 80 F8 8F 10 BD E8 10 40 30 30 A7 F7 F7 BC CB E4 2D E9 F0 41 80 46 B9 4D 86 B0 0E 46 17 46 9C 46 D0 B2 01 29 02 D0 02 2E 31 D1 2B E0 FE F7 61 FA 04 46 05 28 2B D2 00 20 02 90 03 90 04 90 05 90 02 A9 03 A8 04 AB 05 AA CD E9 00 01 AF F2 B0 11 60 46 A0 F7 4F FC 05 98
9:17:06 AM
9:17:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 25 09 81 80 20 B9 FF 20 05 90 04 90 03 90 02 90 04 EB 44 00 C0 EB 84 10 05 EB 80 00 05 99 00 F8 6C 1F 04 99 41 70 03 99 81 70 02 99 C1 70 0C E0 FE F7 20 FA 04 46 05 28 07 D3 3A 46 31 46 40 46 FF F7 BF FE 06 B0 BD E8 F0 81 04 EB 44 00 C0 EB 84 10 05 EB 80 00 41 6E 41 F0 40 01 41 66 F1 E7 2D E9 F0 41 04 46 C8 B2 07 46 FE F7 03 FA 40 1C E9 D1 E0 B2 FF F7 BE F9 04 46 05 28 E3 D2 FF F7 CE F9 04 EB
9:17:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 26 09 81 80 44 01 C1 EB 84 12 87 49 06 46 00 20 01 EB 82 02 13 18 93 F8 5F 30 FF 2B 19 D1 00 25 05 EB 45 03 C3 EB 85 13 01 EB 83 04 94 F8 60 30 5B B9 A3 6D FF 2B 08 D1 94 F8 5C 30 2B B9 94 F8 5D 30 13 B9 94 F8 5E 30 43 B1 6D 1C ED B2 05 2D E6 D3 40 1C 10 F0 FF 00 DC D0 B4 E7 10 44 F4 21 80 F8 5F 50 20 46 9F F7 BA FF A5 65 03 25 84 F8 60 50 04 F1 48 00 A7 F7 57 FC 84 F8 68 50 01 20 84 F8 8F 00
9:17:07 AM
9:17:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 27 09 81 80 60 6E D6 B1 20 F4 80 20 40 F0 40 00 60 66 65 49 84 F8 5D 70 01 F2 F6 40 91 F8 F6 14 49 1C 01 70 04 F1 38 00 A7 F7 3E FC 04 20 60 82 02 20 60 84 60 6E 20 F4 40 60 60 66 83 E7 40 F4 80 20 E3 E7 F0 B5 8B B0 32 B1 15 46 38 B1 01 28 77 D0 09 28 75 D1 02 E0 00 20 0B B0 F0 BD 8E 68 FF 24 0C 22 51 49 30 46 9F F7 B0 FE 00 28 3E D0 4E 49 0B 22 10 31 30 46 9F F7 A8 FE 00 28 38 D0 0C 22 AF F2
9:17:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 28 09 81 80 EC 71 30 46 9F F7 A0 FE 00 28 32 D0 0C 22 47 A1 30 46 9F F7 99 FE 00 28 2D D0 0A 22 AF F6 18 01 30 46 9F F7 91 FE 40 B3 0F 22 AF F6 08 01 30 46 9F F7 8A FE 18 B3 09 22 AF F2 80 31 30 46 9F F7 83 FE F0 B1 0A 22 3D A1 30 46 9F F7 7D FE D0 B1 0A 22 3D A1 30 46 9F F7 77 FE B0 B1 08 22 3D A1 30 46 9F F7 71 FE 90 B1 12 E0 00 24 10 E0 01 24 0E E0 02 24 0C E0 03 24 0A E0 04 24 08 E0 05 24
9:17:08 AM
9:17:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 29 09 81 80 06 E0 06 24 04 E0 07 24 02 E0 08 24 00 E0 09 24 05 2C 65 D0 13 DC 05 2C 11 D2 DF E8 04 F0 03 11 2B BD 65 00 12 23 00 22 31 46 68 46 FE F7 BE F9 12 21 68 46 FE F7 A6 F9 80 B2 FE F7 FB F9 AB E0 12 23 00 22 31 46 68 46 FE F7 B0 F9 12 21 68 46 FE F7 98 F9 84 B2 12 23 01 22 31 46 68 46 FE F7 A5 F9 12 21 68 46 FE F7 8D F9 81 B2 20 46 FE F7 28 F9 91 E0 12 23 00 22 31 46 68 46 FE F7 96 F9
9:17:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 2A 09 81 80 12 21 68 46 FE F7 7E F9 84 B2 12 23 01 22 31 46 68 46 FE F7 8B F9 12 21 68 46 FE F7 73 F9 81 B2 20 46 1E E0 00 8F 00 10 30 FA 05 00 2B 57 49 50 44 41 54 41 52 57 3A 20 00 00 00 00 2B 57 49 50 50 49 4E 47 3A 20 00 00 2B 57 49 50 46 49 4C 45 3A 20 00 00 2B 57 49 50 42 52 3A 20 00 00 00 00 40 E0 FF F7 BB FE 57 E0 12 23 00 22 31 46 68 46 FE F7 5C F9 12 21 68 46 FE F7 44 F9 84 B2 12 23
9:17:09 AM
9:17:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 2B 09 81 80 01 22 31 46 68 46 FE F7 51 F9 12 21 68 46 FE F7 39 F9 87 B2 12 23 02 22 31 46 68 46 FE F7 46 F9 12 21 68 46 FE F7 2E F9 01 2C 02 D0 02 2C 12 D0 32 E0 12 23 03 22 31 46 05 A8 FE F7 37 F9 12 23 04 22 31 46 68 46 FE F7 31 F9 12 21 68 46 FE F7 19 F9 05 AB 00 E0 00 23 3A 46 21 46 28 46 FF F7 2B FE 19 E0 12 23 00 22 31 46 68 46 FE F7 1E F9 12 21 68 46 FE F7 06 F9 84 B2 12 23 01 22 31 46
9:17:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 2C 09 81 80 68 46 FE F7 13 F9 12 21 68 46 FE F7 FB F8 82 B2 21 46 28 46 FF F7 F6 FD 01 20 DC E6 30 B5 85 B0 1A B1 28 B1 09 28 40 D1 02 E0 00 20 05 B0 30 BD 8C 68 0C 22 FB 49 20 46 9F F7 86 FD 38 B1 F9 49 0B 22 10 31 20 46 9F F7 7F FD A8 B1 2D E0 12 23 00 22 21 46 68 46 FE F7 E9 F8 12 21 68 46 FE F7 D1 F8 80 B2 A0 F5 40 71 4A 39 02 D0 B0 F5 4B 7F 1B D1 FE F7 1F F9 18 E0 12 23 00 22 21 46 68 46
9:17:10 AM
9:17:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 2D 09 81 80 FE F7 D4 F8 12 21 68 46 FE F7 BC F8 85 B2 12 23 01 22 21 46 68 46 FE F7 C9 F8 12 21 68 46 FE F7 B1 F8 81 B2 28 46 FE F7 4C F8 01 20 BE E7 10 B5 91 F8 68 20 8C 6D 04 2A 04 D0 03 2A 02 D0 07 2A 04 D0 0B E0 02 23 91 F8 5D 20 02 E0 91 F8 5E 20 01 23 05 2C 04 D3 19 46 FF F7 B1 FC 00 20 6E E5 04 EB 44 00 C0 EB 84 12 CF 48 01 21 00 EB 82 00 80 F8 8E 10 05 21 80 F8 60 10 01 20 5F E5 F0 B5
9:17:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 2E 09 81 80 8F B0 6A B3 C9 4C 01 26 2A 25 2B 27 22 78 0A 28 73 D2 DF E8 00 F0 05 80 99 99 99 99 9B 99 99 43 8D 68 23 2A 03 D0 25 2A 01 D0 27 2A 35 D1 08 22 AF F2 E0 11 28 46 9F F7 07 FD 00 28 2D D1 0C AB 0B AA 0A A9 09 A8 8D E8 0F 00 0E AB 0D AA B8 A1 28 46 A0 F7 E3 F9 0D 98 05 28 04 D0 06 28 02 D0 00 20 0F B0 F0 BD 0E 98 0F 28 04 D0 10 28 06 D0 19 28 70 D1 07 E0 04 F1 8A 04 09 98 06 E0 04 F1
9:17:11 AM
9:17:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 2F 09 81 80 8E 04 09 98 02 E0 09 98 04 F1 92 04 20 70 0A 98 60 70 0B 98 A0 70 0C 98 E0 70 5C E0 89 68 12 23 00 22 04 A8 FE F7 42 F8 12 21 04 A8 FE F7 2A F8 80 B2 40 F2 25 33 2E 21 A0 F2 25 32 98 42 2C D0 0E DC 85 28 1A D0 04 DC 0A 28 3D D0 0B 28 3B D1 29 E0 95 28 31 D0 A0 F5 40 70 23 38 34 D1 17 E0 09 2A 2A D0 04 DC 06 2A 1D D0 07 2A 2C D1 1C E0 0C 2A 22 D0 2D 2A 27 D1 23 E0 25 E0 20 78 1F 28
9:17:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 30 09 81 80 01 D0 21 28 27 D1 2D 20 15 E0 21 28 22 D0 22 E0 20 78 21 28 1F D1 26 83 1D E0 20 78 31 28 FA D0 33 28 F8 D0 10 E0 21 70 15 E0 20 78 1F 28 01 D0 21 28 10 D1 2C 20 20 70 0D E0 20 78 1F 28 09 D0 E3 E7 20 78 35 28 E6 D0 25 70 04 E0 1F 2A 01 D0 21 2A 00 D1 27 70 01 20 83 E7 30 B5 73 4C 05 46 97 B0 20 78 02 28 05 D0 03 28 29 D1 20 8B 01 28 17 D0 1C E0 00 20 20 83 0A 46 74 A1 01 A8 B7 F7
9:17:12 AM
9:17:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 31 09 81 80 39 FA 4F F4 7A 70 00 90 73 4B 01 AA 02 21 A8 68 C2 F7 FE FA 00 28 13 D1 20 1D A7 F7 C3 F9 03 20 0D E0 05 29 0E D0 06 29 0E D0 2A 20 20 70 20 1D A7 F7 C0 F9 40 F2 4C 41 88 42 01 D9 02 20 20 70 17 B0 30 BD 04 20 F1 E7 0C 20 EF E7 2D E9 F0 4F 56 4C 05 46 23 46 27 78 B3 F9 18 10 93 F8 3C 00 3F 1F 00 26 93 F8 7F 30 97 B0 4F F0 08 0A 4F F0 06 0B 4F F4 7A 78 40 F2 4C 49 08 2F 28 D2 DF E8
9:17:13 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:17:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 32 09 81 80 07 F0 04 1C 2A 44 50 6A 76 ED 26 83 C0 07 01 D0 52 A1 00 E0 55 A1 01 A8 B7 F7 EC F9 CD F8 00 80 4D 4B 01 AA 02 21 A8 68 C2 F7 B2 FA 00 28 0F D1 20 1D A7 F7 77 F9 05 20 09 E0 01 29 01 D1 84 F8 00 B0 20 1D A7 F7 76 F9 48 45 01 D9 04 20 20 70 17 B0 BD E8 F0 8F 26 83 80 07 03 D5 58 07 01 D5 46 A1 00 E0 49 A1 01 A8 B7 F7 C4 F9 CD F8 00 80 39 4B 01 AA 02 21 A8 68 C2 F7 8A FA 00 28 E7 D1
9:17:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 33 09 81 80 20 1D A7 F7 4F F9 07 20 E1 E7 01 29 01 D1 84 F8 00 A0 20 1D A7 F7 4E F9 48 45 D9 D9 84 F8 00 B0 D6 E7 26 83 80 07 03 D5 D8 06 01 D5 3B A1 00 E0 3E A1 01 A8 B7 F7 9E F9 CD F8 00 80 26 4B 01 AA 02 21 A8 68 C2 F7 64 FA 00 28 C1 D1 20 1D A7 F7 29 F9 09 20 BB E7 01 29 01 D1 0A 20 20 70 20 1D A7 F7 28 F9 48 45 B3 D9 84 F8 00 A0 B0 E7 26 83 80 07 03 D5 98 06 01 D5 30 A1 00 E0 33 A1 01 A8
9:17:14 AM
9:17:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 34 09 81 80 B7 F7 78 F9 CD F8 00 80 13 4B 01 AA 02 21 A8 68 C2 F7 3E FA 00 28 9B D1 20 1D A7 F7 03 F9 0B 20 95 E7 5B E0 30 FA 05 00 00 8F 00 10 14 94 00 10 2B 57 49 50 42 52 3A 20 25 75 2C 25 75 2C 22 25 75 2E 25 75 2E 25 75 2E 25 75 22 00 2B 57 49 50 42 52 3D 31 2C 25 75 00 FF 16 06 00 2B 57 49 50 42 52 3D 32 2C 35 2C 37 2C 31 00 00 2B 57 49 50 42 52 3D 32 2C 35 2C 37 2C 30 00 00 2B 57 49 50
9:17:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 35 09 81 80 42 52 3D 32 2C 35 2C 38 2C 31 00 00 2B 57 49 50 42 52 3D 32 2C 35 2C 38 2C 30 00 00 2B 57 49 50 42 52 3D 32 2C 35 2C 39 2C 31 00 00 2B 57 49 50 42 52 3D 32 2C 35 2C 39 2C 30 00 00 2B 57 49 50 42 52 3D 32 2C 35 2C 31 30 2C 31 00 2B 57 49 50 42 52 3D 32 2C 35 2C 31 30 2C 30 00 01 29 04 D1 5A B1 01 2A 0B D0 2A 20 20 70 20 1D A7 F7 A2 F8 48 45 7F F6 55 AF 0A 20 29 E7 12 20 F4 E7 18 20
9:17:15 AM
9:17:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 36 09 81 80 F2 E7 F0 B5 FF 4C 05 46 97 B0 20 78 0C 28 05 D0 0D 28 38 D1 20 8B 01 28 2A D0 2B E0 00 20 20 83 F8 48 94 F8 46 60 00 F1 68 01 90 F8 45 20 B7 07 00 F1 47 03 02 D5 00 91 F3 A1 03 E0 F0 07 05 D0 00 91 F7 A1 01 A8 B7 F7 D5 F8 01 E0 2A 20 20 70 4F F4 7A 70 00 90 F8 4B 01 AA 02 21 A8 68 C2 F7 97 F9 00 28 0F D1 20 1D A7 F7 5C F8 0D 20 09 E0 0E 20 20 70 20 1D A7 F7 5D F8 40 F2 4C 41 88 42
9:17:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 37 09 81 80 01 D9 0C 20 20 70 17 B0 F0 BD 30 B5 DD 4C 05 46 97 B0 20 78 0E 28 05 D0 0F 28 27 D1 20 8B 01 28 19 D0 1A E0 00 20 D7 4B 20 83 0A 46 1C 33 E3 A1 01 A8 B7 F7 9F F8 4F F4 7A 70 00 90 DE 4B 01 AA 02 21 A8 68 C2 F7 64 F9 00 28 0F D1 20 1D A7 F7 29 F8 0F 20 09 E0 10 20 20 70 20 1D A7 F7 2A F8 40 F2 4C 41 88 42 01 D9 0E 20 20 70 68 E6 30 B5 C4 4C 05 46 97 B0 20 78 10 28 05 D0 11 28 27 D1
9:17:16 AM
9:17:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 38 09 81 80 20 8B 01 28 19 D0 1A E0 00 20 20 83 0A 46 94 F8 45 30 CF A1 01 A8 B7 F7 6D F8 4F F4 7A 70 00 90 C5 4B 01 AA 02 21 A8 68 C2 F7 32 F9 00 28 0F D1 20 1D A6 F7 F7 FF 11 20 09 E0 14 20 20 70 20 1D A6 F7 F8 FF 40 F2 4C 41 88 42 01 D9 10 20 20 70 36 E6 30 B5 AB 4C 05 46 97 B0 20 78 12 28 05 D0 13 28 27 D1 20 8B 01 28 19 D0 1A E0 00 20 A5 4B 20 83 0A 46 1C 33 BB A1 01 A8 B7 F7 3B F8 4F F4
9:17:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 39 09 81 80 7A 70 00 90 AC 4B 01 AA 02 21 A8 68 C2 F7 00 F9 00 28 0F D1 20 1D A6 F7 C5 FF 13 20 09 E0 14 20 20 70 20 1D A6 F7 C6 FF 40 F2 4C 41 88 42 01 D9 12 20 20 70 04 E6 30 B5 92 4C 05 46 97 B0 20 78 14 28 05 D0 15 28 31 D1 20 8B 01 28 23 D0 24 E0 00 20 20 83 05 29 13 D0 06 29 14 D0 2A 20 20 70 4F F4 7A 70 00 90 94 4B 01 AA 02 21 A8 68 C2 F7 CF F8 00 28 1A D1 20 1D A6 F7 94 FF 15 20 14 E0
9:17:17 AM
9:17:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 3A 09 81 80 80 4B 3D 33 01 E0 7F 4B 47 33 0A 46 9A A1 01 A8 B6 F7 F0 FF E4 E7 16 20 20 70 20 1D A6 F7 8A FF 40 F2 4C 41 88 42 01 D9 14 20 20 70 C8 E5 30 B5 74 4C 05 46 97 B0 20 78 16 28 05 D0 17 28 31 D1 20 8B 01 28 23 D0 24 E0 00 20 20 83 05 29 13 D0 06 29 14 D0 2A 20 20 70 4F F4 7A 70 00 90 76 4B 01 AA 02 21 A8 68 C2 F7 93 F8 00 28 1A D1 20 1D A6 F7 58 FF 17 20 14 E0 62 4B 5E 33 01 E0 61 4B
9:17:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 3B 09 81 80 68 33 0A 46 81 A1 01 A8 B6 F7 B4 FF E4 E7 1E 20 20 70 20 1D A6 F7 4E FF 40 F2 4C 41 88 42 01 D9 16 20 20 70 8C E5 30 B5 56 4C 05 46 99 B0 20 78 18 28 05 D0 19 28 30 D1 20 8B 01 28 22 D0 23 E0 04 F1 6E 04 00 20 24 F8 56 0C 60 7F E3 7F A2 7F 8D E8 0D 00 23 7F 0A 46 A4 F1 6E 04 70 A1 03 A8 B6 F7 88 FF 4F F4 7A 70 00 90 53 4B 03 AA 02 21 A8 68 C2 F7 4D F8 00 28 0F D1 20 1D A6 F7 12 FF
9:17:18 AM
9:17:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 3C 09 81 80 19 20 09 E0 1A 20 20 70 20 1D A6 F7 13 FF 40 F2 4C 41 88 42 01 D9 18 20 20 70 19 B0 30 BD 30 B5 38 4C 05 46 99 B0 20 78 1A 28 05 D0 1B 28 F4 D1 20 8B 01 28 22 D0 23 E0 04 F1 72 04 00 20 24 F8 5A 0C 60 7F E3 7F A2 7F 8D E8 0D 00 23 7F 0A 46 A4 F1 72 04 5A A1 03 A8 B6 F7 4C FF 4F F4 7A 70 00 90 35 4B 03 AA 02 21 A8 68 C2 F7 11 F8 00 28 D3 D1 20 1D A6 F7 D6 FE 1B 20 09 E0 1E 20 20 70
9:17:19 AM
9:17:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 3D 09 81 80 20 1D A6 F7 D7 FE 40 F2 4C 41 88 42 C5 D9 1A 20 20 70 C2 E7 30 B5 1B 4C 05 46 2A 23 20 78 99 B0 1E 28 0B D0 20 28 09 D0 21 46 1F 28 B1 F9 18 10 24 D0 21 28 B1 D1 01 29 21 D0 B0 E0 00 20 20 83 12 B1 01 2A 04 D0 05 E0 13 46 0A 46 44 A1 97 E0 05 29 15 D0 23 70 60 69 00 90 17 4B 02 AA 02 21 A8 68 C1 F7 D5 FF 00 28 97 D1 20 1D A6 F7 9A FE 20 78 1E 28 05 D0 21 20 20 70 8E E7 86 E0 8A E0
9:17:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 3E 09 81 80 76 E0 81 E0 14 94 00 10 2B 57 50 50 50 3D 32 2C 25 75 2C 22 25 73 22 2C 22 25 73 22 00 00 00 00 2B 57 50 50 50 3D 31 2C 25 75 2C 22 25 73 22 2C 22 25 73 22 00 00 00 00 FF 16 06 00 2B 57 49 50 42 52 3D 32 2C 25 75 2C 31 31 2C 22 25 73 22 00 2B 57 49 50 42 52 3D 32 2C 25 75 2C 31 32 2C 25 75 00 00 00 2B 57 49 50 42 52 3D 32 2C 25 75 2C 32 2C 22 25 73 22 00 00 2B 57 49 50 42 52 3D 32
9:17:20 AM
9:17:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 3F 09 81 80 2C 25 75 2C 30 2C 22 25 73 22 00 00 2B 57 49 50 42 52 3D 32 2C 25 75 2C 31 2C 22 25 73 22 00 00 2B 57 49 50 42 52 3D 32 2C 25 75 2C 31 35 2C 22 25 75 2E 25 75 2E 25 75 2E 25 75 22 00 00 00 00 2B 57 49 50 42 52 3D 32 2C 25 75 2C 31 36 2C 22 25 75 2E 25 75 2E 25 75 2E 25 75 22 00 00 00 00 2B 57 49 50 42 52 3D 34 2C 25 75 2C 25 75 00 00 F8 48 A0 F1 21 03 CD E9 00 30 13 46 0A 46 F6 A1
9:17:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 40 09 81 80 02 A8 B6 F7 77 FE 66 E7 1F 20 75 E7 01 29 7F F4 74 AF 20 20 70 E7 6A B1 01 2A 0D D0 23 70 20 1D A6 F7 08 FE 61 69 01 F5 7A 71 88 42 7F F6 65 AF 1E 20 61 E7 22 20 08 E0 E6 48 A2 38 A6 F7 F2 FD E4 48 52 38 A6 F7 EA FD 29 20 20 70 E7 E7 30 B5 E0 4C 05 46 5E 3C 97 B0 20 78 22 28 05 D0 23 28 2C D1 20 8B 01 28 17 D0 1F E0 00 20 20 83 0A 46 E0 A1 01 A8 B6 F7 3E FE 4F F4 FA 60 00 90 E1 4B
9:17:21 AM
9:17:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 41 09 81 80 01 AA 02 21 A8 68 C1 F7 03 FF 00 28 16 D1 20 1D A6 F7 C8 FD 23 20 10 E0 24 20 20 70 CD 48 52 38 A6 F7 BC FD 20 1D A6 F7 B9 FD 20 1D A6 F7 C2 FD 40 F6 34 01 88 42 01 D9 22 20 20 70 96 E5 30 B5 C4 4C 05 46 5E 3C 97 B0 20 78 24 28 05 D0 25 28 2C D1 20 8B 01 28 17 D0 1F E0 00 20 20 83 0A 46 C9 A1 01 A8 B6 F7 06 FE 4F F4 FA 60 00 90 C5 4B 01 AA 02 21 A8 68 C1 F7 CB FE 00 28 16 D1 20 1D
9:17:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 42 09 81 80 A6 F7 90 FD 25 20 10 E0 26 20 20 70 B1 48 52 38 A6 F7 84 FD 20 1D A6 F7 81 FD 20 1D A6 F7 8A FD 40 F6 34 01 88 42 01 D9 24 20 20 70 5E E5 30 B5 A8 4C 05 46 5E 3C 97 B0 20 78 26 28 05 D0 27 28 2C D1 20 8B 01 28 17 D0 1F E0 00 20 20 83 0A 46 B1 A1 01 A8 B6 F7 CE FD 4F F4 FA 60 00 90 A9 4B 01 AA 02 21 A8 68 C1 F7 93 FE 00 28 16 D1 20 1D A6 F7 58 FD 27 20 10 E0 28 20 20 70 95 48 52 38
9:17:22 AM
9:17:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 43 09 81 80 A6 F7 4C FD 20 1D A6 F7 49 FD 20 1D A6 F7 52 FD 40 F6 34 01 88 42 01 D9 24 20 20 70 26 E5 30 B5 8C 4C 05 46 5E 3C 97 B0 20 78 30 28 05 D0 31 28 25 D1 20 8B 01 28 17 D0 18 E0 00 20 20 83 0A 46 99 A1 01 A8 B6 F7 96 FD 42 F2 10 70 00 90 8D 4B 01 AA 02 21 A8 68 C1 F7 5B FE 00 28 0F D1 20 1D A6 F7 20 FD 31 20 09 E0 32 20 20 70 20 1D A6 F7 21 FD 42 F6 F8 21 88 42 01 D9 30 20 20 70 F5 E4
9:17:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 44 09 81 80 70 B5 74 4C 06 46 5E 3C 00 25 20 78 98 B0 32 28 05 D0 33 28 40 D1 20 8B 01 28 16 D0 33 E0 0A 46 25 83 84 A1 01 A8 B6 F7 65 FD 4F F4 7A 70 00 90 74 4B 01 AA 02 21 B0 68 C1 F7 2A FE 00 28 2B D1 20 1D A6 F7 EF FC 33 20 25 E0 30 46 FE F7 68 FA 30 46 FC F7 A1 FF 7A 48 80 F8 C5 54 00 F2 9E 50 05 60 08 30 05 60 B4 F8 9A 00 01 28 16 D0 74 49 25 70 06 20 81 F8 C4 04 01 F5 A4 60 A6 F7 CE FC
9:17:23 AM
9:17:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 45 09 81 80 20 1D A6 F7 CB FC 20 1D A6 F7 D4 FC 40 F2 4C 41 88 42 01 D9 32 20 20 70 18 B0 70 BD 34 20 20 70 EE E7 38 B5 4B 4C 00 21 5E 3C 22 78 34 2A 05 D0 35 2A 28 D1 20 8B 01 28 11 D0 1B E0 21 83 42 F2 10 71 00 91 80 68 4F 4B 5E A2 02 21 C1 F7 E0 FD 00 28 18 D1 20 1D A6 F7 A5 FC 35 20 12 E0 58 48 21 70 80 F8 C4 14 00 F5 A4 60 A6 F7 97 FC 20 1D A6 F7 94 FC 20 1D A6 F7 9D FC 42 F6 F8 21 88 42
9:17:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 46 09 81 80 01 D9 34 20 20 70 38 BD 2D E9 F0 47 31 4C 5E 3C A3 7E 53 B1 01 2B 5A D1 06 21 E2 7E 0A B1 01 2A 55 D1 01 2B 03 D0 2B B1 08 E0 05 21 F5 E7 94 F8 46 30 01 E0 94 F8 3C 30 9B 07 48 D0 25 4B 26 78 5E 3B 03 F1 0C 09 B3 F9 96 C0 B3 F9 98 50 3C 4B 4F F0 00 08 36 2E 93 F8 C4 34 39 D2 DF E8 06 F0 B9 1B 25 25 28 28 28 28 28 28 28 28 2B 2B 2E 2E 31 31 34 34 78 78 7B 7B 7E 7E 81 81 84 89 95 95
9:17:24 AM
9:17:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 47 09 81 80 95 95 98 98 9B 9B 9E 9E B9 B9 B9 B9 B9 B9 B9 A1 B1 B1 B4 B4 B7 B7 06 2B 1A D1 BC F1 01 0F 17 D1 B5 B9 A4 F8 96 80 02 20 89 E0 FF F7 56 FA 90 E0 FF F7 8C FA 8D E0 FF F7 A4 FB 8A E0 FF F7 E5 FB 87 E0 FF F7 14 FC 84 E0 FF F7 43 FC 81 E0 88 E0 5D E0 00 00 72 94 00 10 2B 57 49 50 42 52 3D 34 2C 25 75 2C 25 75 2C 22 25 73 22 2C 20 22 25 73 22 00 00 00 2B 57 49 50 42 52 3D 33 2C 25 75 2C
9:17:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 48 09 81 80 31 35 00 00 FF 16 06 00 2B 57 49 50 42 52 3D 33 2C 25 75 2C 31 36 00 00 2B 57 49 50 42 52 3D 33 2C 25 75 2C 32 35 00 00 2B 57 49 50 42 52 3D 35 2C 25 75 00 2B 57 49 50 42 52 3D 30 2C 25 75 00 00 8F 00 10 2B 57 49 50 43 46 47 3D 30 00 00 00 FF F7 31 FC 3D E0 FF F7 6A FC 3A E0 FF F7 A3 FC 37 E0 FF F7 DC FC 34 E0 20 1D A6 F7 DB FB 1D 20 25 E0 20 1D A6 F7 DE FB 40 F2 EE 21 88 42 28 D9
9:17:25 AM
9:17:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 49 09 81 80 48 46 A6 F7 CF FB 1E 20 19 E0 FF F7 03 FD 20 E0 FF F7 DD FD 1D E0 FF F7 12 FE 1A E0 FF F7 47 FE 17 E0 06 2B 03 D0 08 2B 01 D0 07 2B 11 D1 01 2D 0F D1 BC F1 00 0F 0C D1 A4 F8 98 80 30 20 20 70 07 E0 FF F7 6C FE 04 E0 FF F7 9A FE 01 E0 FF F7 E8 FE 48 46 A6 F7 AE FB 61 69 88 42 01 D9 2A 20 20 70 BD E8 F0 87 10 B5 04 46 40 6E 40 04 07 D5 A0 6D FD F7 97 FC A0 6D BD E8 10 40 FD F7 FF BC
9:17:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 4A 09 81 80 10 BD 2D E9 F8 4F 83 46 88 6D 92 46 0C 46 05 28 7E D8 08 46 FF F7 E7 FF 94 F8 60 10 00 26 44 F6 20 67 04 F1 38 05 04 F1 30 08 07 29 71 D2 DF E8 01 F0 70 04 70 2B 70 F6 F4 00 60 6E 4F F0 01 05 40 07 0E D5 FC 49 01 F2 C5 40 91 F8 C5 14 8A 07 07 D5 21 F0 02 01 01 70 84 F8 90 50 40 46 A6 F7 5D FB 60 6E 00 07 54 D5 40 46 A6 F7 63 FB F3 49 88 42 4E D9 60 6E 20 F0 08 00 60 66 84 F8 60 60
9:17:26 AM
9:17:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 4B 09 81 80 84 F8 90 50 40 46 E2 E0 60 6E 41 06 04 F1 48 00 81 46 18 D5 A6 F7 4E FB 50 28 14 D9 60 6E C1 06 04 D5 00 BF 20 F0 40 00 60 66 0C E0 94 F8 6C 00 38 B3 B4 F8 6A 00 20 B3 58 46 A1 6D FE F7 AB FA 08 B1 60 6E EE E7 60 6E C0 06 1A D5 FE F7 65 F8 01 28 04 D9 28 46 A6 F7 2D FB B8 42 02 D8 60 6E 40 04 0E D5 D4 48 A1 6D D0 F8 00 05 88 42 08 D1 52 46 58 46 FE F7 90 FB 01 28 28 46 14 D0 A6 F7
9:17:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 4C 09 81 80 11 FB 48 46 A6 F7 16 FB 64 28 18 D9 60 6E 01 E0 CB E0 81 E0 81 05 12 D4 C0 06 10 D4 C6 48 D0 F8 00 05 FF 28 03 D0 0A E0 A6 F7 F8 FA E9 E7 FE F7 4B F8 A1 6D 88 42 02 D1 58 46 FE F7 6C FA 60 6E C1 05 15 D5 C1 06 0B D5 40 46 A6 F7 F3 FA 32 28 0E D9 52 46 58 46 A1 6D FE F7 5E FB 40 B1 60 6E 20 F4 80 70 40 F4 00 70 60 66 40 46 A6 F7 DA FA 60 6E 80 05 15 D5 40 46 A6 F7 DC FA 32 28 10 D9
9:17:27 AM
9:17:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 4D 09 81 80 AD 48 D0 F8 00 05 FF 28 02 D0 A1 6D 88 42 08 D1 21 46 58 46 FF F7 0B F8 18 B1 60 6E 20 F4 00 70 60 66 B4 F8 6A 00 60 B9 94 F8 68 00 03 28 08 D1 48 46 A6 F7 BF FA 32 28 03 D9 21 46 58 46 FE F7 6D FC 94 F8 6C 00 60 B9 94 F8 68 00 03 28 08 D1 48 46 A6 F7 AF FA 32 28 03 D9 21 46 58 46 FE F7 D0 FB 04 F1 40 00 05 46 A6 F7 A4 FA 94 49 88 42 07 D9 A0 6D FD F7 03 FC 40 1C 02 D0 28 46 A6 F7
9:17:28 AM
9:17:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 4E 09 81 80 8D FA 60 6E 40 03 2E D4 FD F7 C7 FF 01 28 2A D8 60 6E 40 F4 80 20 60 66 25 E0 1B E0 FF E7 28 46 A6 F7 88 FA B8 42 1E D9 60 6E C0 06 1B D5 82 48 A1 6D D0 F8 00 05 88 42 15 D1 52 46 58 46 FE F7 EB FA 01 28 28 46 02 D0 A6 F7 6C FA 0B E0 A6 F7 65 FA 08 E0 40 46 A6 F7 6D FA 32 28 03 D9 84 F8 60 60 FF 20 A0 65 60 6E 80 03 17 D5 60 6D 00 90 71 48 94 F8 F0 10 D4 F8 94 30 D0 F8 10 05 04 F1
9:17:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 4F 09 81 80 98 02 C1 F7 85 FB 00 28 60 6E 10 D0 40 F4 00 30 60 66 B4 F8 EE 00 40 1C A4 F8 EE 00 B4 F8 EE 00 B0 F5 7A 7F 01 D9 A4 F8 EE 60 BD E8 F8 8F 20 F4 00 30 60 66 40 46 A6 F7 35 FA EF E7 70 B5 5E 4C 94 F8 C5 04 04 F2 C5 44 51 B1 42 07 02 D4 40 F0 08 00 20 70 58 48 90 F8 C5 04 40 F0 04 00 01 E0 20 F0 04 00 20 70 54 48 53 4D 90 F8 C5 04 00 07 2C D5 00 26 06 EB 46 00 C0 EB 86 10 05 EB 80 00
9:17:29 AM
9:17:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 50 09 81 80 90 F8 60 00 03 28 02 D1 30 46 FD F7 78 FB 76 1C 05 2E EF D3 48 48 90 F8 C5 04 20 F0 08 00 20 70 5F F0 00 00 00 EB 40 01 C1 EB 80 11 05 EB 81 01 91 F8 60 10 03 29 05 D1 3F 49 91 F8 C5 14 41 F0 08 01 21 70 40 1C 05 28 EC D3 70 BD 00 29 FC D0 5F F0 00 04 04 EB 44 00 C0 EB 84 10 05 EB 80 00 90 F8 60 10 03 29 08 D1 90 F8 68 00 03 28 01 D0 06 28 02 D1 20 46 FD F7 42 FB 64 1C 05 2C E9 D3
9:17:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 51 09 81 80 70 BD 30 B5 85 B0 0A B1 38 BB 02 E0 00 20 05 B0 30 BD 8C 68 08 22 2B 49 20 46 9E F7 55 FC E0 B9 12 23 00 22 21 46 68 46 FC F7 C0 FF 12 21 68 46 FC F7 A8 FF 85 B2 12 23 01 22 21 46 68 46 FC F7 B5 FF 12 21 68 46 FC F7 9D FF 80 B2 05 2D 04 D1 01 28 02 D1 1C 49 28 20 08 70 01 20 D7 E7 1C B5 00 21 01 91 00 91 04 46 6B 46 01 AA 17 A1 9F F7 15 F9 38 B9 6B 46 01 AA 18 A1 20 46 9F F7 0E F9
9:17:30 AM
9:17:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 52 09 81 80 00 28 17 D0 01 98 01 28 32 D0 02 28 35 D0 03 28 10 D1 00 98 C0 B2 FD F7 AB FE 05 28 0A D2 00 EB 40 01 C1 EB 80 11 04 48 00 EB 81 00 41 6E 21 F4 00 51 41 66 1C BD 00 00 00 8F 00 10 B0 30 01 00 00 51 25 02 54 15 06 00 14 94 00 10 2B 57 49 50 53 45 52 56 3A 20 25 75 2C 25 75 00 2B 57 49 50 52 45 41 44 59 3A 20 25 75 2C 25 75 00 00 00 00 00 98 C0 B2 FC F7 D1 FE CF E7 00 98 C0 B2 FC F7
9:17:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 53 09 81 80 B7 FE CA E7 70 B5 00 20 FC 4B 02 46 5F F0 01 05 00 EB 40 01 C1 EB 80 11 03 EB 81 01 4C 6E A6 04 08 D5 01 F1 74 01 24 F4 00 54 41 F8 10 4C 8A 76 CA 76 0D 77 00 F1 01 00 05 28 E9 D3 70 BD 10 B5 03 46 22 B1 10 46 23 B1 01 2B 15 D1 12 E0 00 20 10 BD 8C 68 0A 22 EA A1 20 46 9E F7 B5 FB 28 B1 0B 22 EA 49 20 46 9E F7 AF FB 28 B9 20 46 FF F7 76 FF 01 E0 FF F7 C6 FF 01 20 10 BD 08 B5 4F F4
9:17:31 AM
9:17:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 54 09 81 80 7A 71 00 91 80 68 E2 4B E2 A2 02 21 C1 F7 40 FA 08 B1 00 20 08 BD 01 20 08 BD 08 B5 40 F6 B8 31 00 91 80 68 DD 4B DE A2 02 21 C1 F7 31 FA 08 B1 00 20 08 BD D1 4B 00 BF 00 EB 40 01 C1 EB 80 11 03 EB 81 01 91 F8 60 20 02 2A 04 D0 03 2A 02 D0 4A 6E 12 07 03 D5 4A 6E 42 F4 00 52 4A 66 40 1C 80 B2 05 28 E8 D3 01 20 08 BD 70 B5 05 46 00 24 80 68 03 21 C1 F7 49 FB 01 28 1C D1 28 68 D0 F8
9:17:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 55 09 81 80 00 15 05 29 00 D2 01 24 00 21 64 22 01 EB 41 03 C3 EB 81 13 02 EB 83 03 C3 58 DB 06 00 D5 01 24 49 1C 05 29 F2 D3 00 2C 05 D1 A8 68 BD E8 70 40 03 21 C1 F7 31 BB 70 BD 10 B5 59 B1 00 EB 40 02 C2 EB 80 10 AD 4A 02 EB 80 00 70 30 9E F7 4E FC 01 20 10 BD 00 20 10 BD B4 49 CA 78 0B 78 02 EB 03 62 4B 78 89 78 1B 04 03 EB 01 21 11 44 01 60 70 47 AE 49 08 31 CA 78 0B 78 02 EB 03 62 4B 78
9:17:32 AM
9:17:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 56 09 81 80 89 78 1B 04 03 EB 01 21 11 44 01 60 70 47 9B 4A 00 20 00 BF 00 EB 40 01 C1 EB 80 11 02 EB 81 03 93 F8 60 10 03 29 06 D0 04 29 04 D0 05 29 02 D0 59 6E 09 07 01 D5 01 20 70 47 40 1C C0 B2 05 28 E8 D3 00 20 70 47 8D 4A 00 20 00 BF 00 EB 40 01 C1 EB 80 11 02 EB 81 03 93 F8 60 10 03 29 03 D0 04 29 01 D0 05 29 03 D1 93 F8 68 10 03 29 05 D0 40 1C C0 B2 05 28 E9 D3 00 20 70 47 01 20 70 47
9:17:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 57 09 81 80 2D E9 F0 4F 05 46 7D 48 87 B0 00 F5 9A 63 90 F8 C4 24 B0 F9 CE 14 01 93 08 33 00 F2 C6 44 00 F5 9C 68 05 93 04 26 DF F8 08 92 DF F8 08 B2 00 27 90 F8 C6 04 4F F0 0A 0A 0C 2A 41 D2 DF E8 02 F0 40 06 0B 30 41 78 A1 DC 40 DB DA D9 05 98 A6 F7 29 F8 02 20 19 E1 A8 68 00 22 02 21 D0 F8 08 01 E5 F7 13 FA 00 28 2B D0 A8 68 00 22 03 21 D0 F8 08 01 E5 F7 0A FA 00 28 F5 D0 00 95 6E 4B 6F 4A
9:17:33 AM
9:17:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 58 09 81 80 02 21 A8 68 C1 F7 94 F8 A9 68 00 23 6C 4A C1 F8 AC B0 00 95 03 21 A8 68 C1 F7 8A F8 03 20 F4 E0 A8 68 D0 F8 08 01 90 F8 C0 10 03 29 08 D1 90 F8 04 01 03 28 FA D1 51 48 80 F8 C4 64 80 F8 C6 74 F6 E0 03 28 0F D0 4D 49 5E 4B A1 F8 CE 74 00 EB C0 01 09 EB 81 02 10 6A 00 90 91 7F A8 68 C1 F7 17 F9 00 B3 E4 E0 58 48 B0 F8 8E 10 AD F8 18 10 90 F8 90 00 8D F8 1A 00 03 21 06 A8 FC F7 C2 FD
9:17:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 59 09 81 80 40 F2 1E 21 88 42 0C DB 3C 48 3C 49 90 F8 C6 04 40 1C 20 70 39 48 80 F8 C4 64 01 20 A1 F8 CE 04 C6 E0 07 20 B1 E0 01 98 A5 F7 BC FF 05 20 AC E0 01 29 11 D0 01 98 A5 F7 BD FF 30 49 91 F8 C6 14 01 EB C1 02 09 EB 82 01 09 6A 64 31 88 42 02 D9 2A 48 80 F8 C4 64 AB E0 40 1C C0 B2 27 49 20 70 0B 28 81 F8 C4 64 0B D3 06 20 81 F8 C4 04 01 98 A5 F7 94 FF 05 98 A5 F7 91 FF 40 46 A5 F7 92 FF
9:17:34 AM
9:17:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 5A 09 81 80 96 E0 28 46 FD F7 44 FC 04 28 11 D1 27 48 8A 38 C0 7E 01 28 0C D1 01 98 A5 F7 8C FF B0 F5 7A 7F 06 D9 28 46 FF F7 6A FE 10 B1 01 98 A5 F7 7A FF 40 46 A5 F7 7F FF 1D 4C 24 49 D9 3C 88 42 08 D9 0E 48 90 F8 C5 04 40 F0 01 00 20 70 40 46 A5 F7 69 FF 0A 48 90 F8 C5 04 C0 07 69 D0 28 46 FF F7 5C FE 50 B1 05 48 90 F8 C5 04 20 F0 01 00 20 70 5E E0 4E E0 37 E0 32 E0 2A E0 59 E0 00 8F 00 10
9:17:35 AM
9:17:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 5B 09 81 80 2B 57 49 50 53 45 52 56 3A 20 00 00 40 FA 05 00 83 28 06 00 2B 57 49 50 42 52 3F 00 BF 29 06 00 2B 57 49 50 43 52 45 41 54 45 3F 00 9E 94 00 10 C0 6D 07 00 F1 FE 05 00 B3 11 06 00 C1 13 06 00 1D 16 06 00 6B 11 06 00 30 58 00 10 C0 27 09 00 01 98 A5 F7 23 FF 05 98 A5 F7 20 FF 28 E0 05 98 A5 F7 20 FF 21 E0 7A 48 7A 4B A0 F8 CE 74 4F F4 7A 70 00 90 AF F6 B4 12 02 21 A8 68 C1 F7 48 F8
9:17:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 5C 09 81 80 B0 B9 01 98 A5 F7 0E FF 0B 20 71 49 81 F8 C4 04 0E E0 01 29 02 D1 28 46 FC F7 12 FA 01 98 A5 F7 09 FF 40 F2 4C 41 88 42 02 D9 69 49 81 F8 C4 A4 05 98 A5 F7 FF FE 49 F6 40 41 88 42 06 D9 05 98 A5 F7 EC FE 62 49 08 20 81 F8 C4 04 62 48 04 46 A5 F7 F0 FE 32 28 20 D9 20 46 A5 F7 DF FE 5C 49 01 F5 A0 60 D1 F8 00 15 05 29 16 D2 01 EB 41 02 C2 EB 81 12 56 49 01 EB 82 01 4A 6E 22 F0 10 02
9:17:36 AM
9:17:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 5D 09 81 80 4A 66 FF 21 01 60 03 21 A8 68 C1 F7 45 F9 A9 68 4F 48 C1 F8 EC B0 A0 F8 0C 75 28 46 FF F7 E5 FD 07 B0 BD E8 F0 8F 2D E9 F0 41 80 46 80 68 00 78 01 28 27 D1 A7 F7 43 FC 00 06 01 D5 01 25 00 E0 00 25 43 4F 00 24 00 BF 04 EB 44 00 C0 EB 84 10 07 EB 80 06 2A 46 31 46 40 46 FF F7 12 FB 31 46 40 46 FE F7 C0 F8 64 1C E4 B2 05 2C EC D3 40 46 FF F7 46 FE 40 46 FF F7 07 FA 29 46 40 46 BD E8
9:17:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 5E 09 81 80 F0 41 5B E4 BD E8 F0 81 2D E9 F0 43 00 24 06 46 05 28 93 B0 8C 46 90 46 99 46 20 46 54 DA 00 90 06 90 00 25 2A 4F 0C 90 3C E0 61 46 28 46 FC F7 06 FF 70 B1 05 EB 45 00 C0 EB 85 10 17 EB 80 00 07 D0 90 F8 8E 00 20 B1 69 46 28 46 FC F7 E0 FE 64 1C 41 46 28 46 FC F7 F2 FE 70 B1 05 EB 45 00 C0 EB 85 10 17 EB 80 00 07 D0 90 F8 8F 00 20 B1 06 A9 28 46 FC F7 CC FE 64 1C 49 46 28 46 FC F7
9:17:37 AM
9:17:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 5F 09 81 80 DE FE 70 B1 05 EB 45 00 C0 EB 85 10 17 EB 80 00 07 D0 90 F8 90 00 20 B1 0C A9 28 46 FC F7 B8 FE 64 1C 6D 1C B5 42 C0 DD 18 22 69 46 60 46 9E F7 62 F9 18 22 06 A9 40 46 9E F7 5D F9 18 22 0C A9 48 46 9E F7 58 F9 20 46 13 B0 BD E8 F0 83 00 00 00 8F 00 10 6B 11 06 00 04 94 00 10 2D E9 F0 41 04 46 00 F1 3C 05 C0 6B 00 27 10 B1 BD F7 E4 FB 2F 60 20 6C 04 F1 40 05 10 B1 BD F7 DD FB 2F 60
9:17:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 60 09 81 80 04 F1 44 06 30 68 28 60 68 B1 40 68 30 60 00 B9 77 60 28 68 47 60 30 89 40 1E 30 81 28 68 10 B1 BD F7 CA FB EE E7 54 34 20 68 28 60 68 B1 40 68 20 60 00 B9 67 60 28 68 47 60 20 89 40 1E 20 81 28 68 10 B1 BD F7 B8 FB EE E7 01 20 BD E8 F0 81 10 B5 04 46 FF F7 C2 FF 00 20 E0 63 02 21 20 64 A4 F8 4E 10 A4 F8 5E 10 20 70 A0 70 41 1E E1 60 21 61 A0 86 01 20 10 BD 00 78 07 28 01 D0 00 20
9:17:38 AM
9:17:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 61 09 81 80 70 47 01 20 70 47 7F B5 04 46 F5 F7 74 FF 21 6B 05 46 A9 42 03 D0 20 46 FF F7 EE FF 10 B1 00 20 04 B0 70 BD 04 20 03 A9 CD E9 00 01 02 46 00 23 02 A9 25 20 BF F7 D3 FA 00 28 F1 D0 E1 8D BD F8 0A 00 81 42 00 D0 E0 85 E0 8D 4F F4 61 61 88 42 00 D8 00 B9 E1 85 BD F8 08 00 A1 8D 88 42 00 D1 49 B9 A0 85 00 28 A0 78 08 D0 20 F0 02 00 C0 B2 40 F0 01 00 A0 70 01 20 25 63 D1 E7 40 F0 02 00
9:17:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 62 09 81 80 F5 E7 10 B5 04 46 4F F0 FF 30 20 63 20 46 FF F7 BA FF 20 46 FF F7 9C FF 00 20 60 70 A0 80 A0 60 01 20 10 BD 10 B5 06 21 01 70 C9 1F 01 61 00 21 41 70 44 6E 5C B1 60 6C 10 B1 DC F7 83 F9 02 E0 20 46 E1 F7 73 FB A0 6C 08 B1 00 F0 19 FD 01 20 10 BD 10 B5 04 46 00 69 FC F7 D1 FE 40 1C 03 D0 20 46 FF F7 DF FF 01 20 10 BD 70 B5 04 46 1C 30 0D 46 06 46 A5 F7 5E FD 40 F6 B8 31 48 43 4F F4
9:17:39 AM
9:17:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 63 09 81 80 7A 71 B0 FB F1 F0 A1 68 88 42 01 D8 08 1A 00 E0 00 20 A0 60 B5 F9 14 10 08 44 40 F6 B8 31 88 42 20 D8 30 46 A5 F7 3E FD 04 F1 24 00 A5 F7 3A FD B5 F9 14 10 A0 68 08 44 A0 60 A0 6B 20 B9 BD F7 B9 FA A0 63 00 28 0E D0 B0 F9 14 00 B0 F5 C8 7F 08 DC 0D E0 AE 89 AA 68 31 B2 A0 6B BD F7 E3 FB B0 42 01 D0 00 20 70 BD 28 46 BD F7 C2 FA 05 46 00 2D EF D1 01 20 70 BD 3E B5 04 20 02 A9 CD E9
9:17:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 64 09 81 80 00 01 02 46 01 24 00 23 F7 49 25 20 BF F7 67 FA 00 B9 00 24 20 46 3E BD 38 B5 44 6C 05 46 4C B3 61 68 00 20 69 64 01 B9 A8 64 60 60 B5 F8 4C 00 6B 46 40 1E A5 F8 4C 00 01 22 00 21 20 46 BD F7 C4 FA A0 68 C0 1C A0 60 A0 89 C0 1E A0 81 A0 8A C0 1E A0 82 9D F8 00 00 01 28 0B D0 03 28 09 D1 A2 89 A1 68 68 6E E1 F7 01 FB 20 46 BD F7 81 FA 04 00 F5 D1 01 20 38 BD 73 B5 04 46 C0 6B 20 B9
9:17:40 AM
9:17:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 65 09 81 80 BD F7 58 FA E0 63 00 28 31 D0 60 78 38 B1 02 28 15 D0 03 28 23 D0 00 25 04 28 4F D1 30 E0 E0 6B BD F7 21 FD 9D F8 04 00 03 28 48 D1 01 20 A0 80 01 AA 01 21 E0 6B BD F7 76 FB 02 20 0D E0 01 AA 01 21 E0 6B BD F7 6F FB 01 28 0F D1 A0 88 40 1C A0 80 9D F8 04 00 E0 71 03 20 60 70 2F E0 01 AA 01 21 E0 6B BD F7 5F FB 01 28 01 D0 00 20 7C BD A0 88 40 1C A0 80 9D F8 04 00 A0 71 04 20 EC E7
9:17:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 66 09 81 80 A0 88 01 AA 40 1C A0 80 01 21 E0 6B BD F7 4B FB E0 88 A1 88 C0 1C 81 42 11 D1 E0 6B 45 60 A0 6C 78 B1 E1 6B 41 60 E0 6B A0 64 B4 F8 4C 00 40 1C A4 F8 4C 00 20 46 E5 63 FF F7 6E FF 65 70 01 20 7C BD E0 6B 60 64 EE E7 2D E9 F0 41 80 46 0C 00 12 D0 D8 F8 3C 00 28 B9 BD F7 EC F9 C8 F8 3C 00 00 28 0A D0 A7 89 00 25 A6 68 0A E0 31 78 40 46 FF F7 82 FF 01 28 01 D0 00 20 67 E6 76 1C 6D 1C
9:17:41 AM
9:17:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 67 09 81 80 AD B2 BD 42 F2 D3 20 46 BD F7 F3 F9 04 00 E9 D1 01 20 5B E6 30 B5 04 46 00 78 8B B0 07 28 31 D1 01 A8 FC F7 B2 FC 01 A9 20 69 FC F7 B1 FC 00 25 08 A8 08 95 09 95 00 90 2B 46 2A 46 01 A9 20 69 FC F7 CE FC 08 B3 07 95 07 A9 20 69 FC F7 C3 FF 07 99 79 B1 88 89 C0 B1 04 F1 24 00 A5 F7 22 FC 20 46 07 99 FF F7 B0 FF 01 28 10 D0 07 98 BD F7 E3 F9 07 E0 01 28 05 D1 20 46 FF F7 EF FD 20 46
9:17:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 68 09 81 80 FF F7 A7 FE 00 20 0B B0 30 BD 01 20 FB E7 07 95 FB E7 30 B5 89 B0 04 46 0D 00 1C D0 01 A8 FC F7 74 FC 01 A9 20 69 FC F7 73 FC 00 20 07 90 08 90 07 A8 00 90 00 23 01 AA 19 46 20 69 FC F7 90 FC 00 28 06 D0 29 46 20 69 FC F7 CF FF 00 28 00 D0 01 20 09 B0 30 BD 00 20 FB E7 70 B5 04 46 00 6C 00 25 70 B9 60 6D 20 64 90 B1 41 68 61 65 01 B9 A5 65 45 60 B4 F8 5C 00 40 1E A4 F8 5C 00 20 6C
9:17:42 AM
9:17:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 69 09 81 80 30 B1 20 46 21 6C FF F7 C4 FF 01 28 02 D0 02 E0 00 20 70 BD 25 64 01 20 70 BD 2D E9 F0 41 04 46 80 6B B4 B0 00 28 4C D0 21 78 07 29 46 D1 B4 F9 5C 10 B4 F9 5E 20 91 42 43 DA B0 F9 14 60 00 27 E8 46 32 46 C8 2E 00 DD C8 22 08 F1 03 03 00 21 A0 6B BD F7 7A F9 05 46 70 1B 06 B2 29 46 A0 6B BD F7 F7 FA A0 6B 02 E0 BD F7 43 F9 A0 63 10 B1 81 89 00 29 F8 D0 03 20 8D F8 00 00 28 0A 8D F8
9:17:43 AM
9:17:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 6A 09 81 80 01 00 8D F8 02 50 1F B9 BD F7 14 F9 07 00 1A D0 ED 1C 6A 46 29 B2 38 46 BD F7 45 FA 00 2E D0 DC 00 20 78 60 A0 6D 80 B1 C0 F8 04 70 04 F1 38 04 27 62 A0 8C 00 F1 01 00 A0 84 20 68 BD F7 3C F9 00 20 34 B0 82 E5 A0 6B F8 E7 67 65 EE E7 2D E9 F0 43 04 46 10 F8 24 1B 9B B0 02 26 00 25 02 AF 80 46 04 F1 14 09 09 29 7D D2 DF E8 01 F0 05 15 1C 2D 3F 52 6D A3 F8 00 A0 78 80 07 07 D4 A0 8D
9:17:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 6B 09 81 80 28 B1 A0 6E FD F7 04 F8 03 28 03 D0 EF E0 01 20 20 70 EC E0 26 70 15 E0 A0 78 80 07 F6 D4 A0 8D 00 28 60 D1 E3 E0 06 22 01 21 02 20 FB F7 88 FE E0 60 40 1C 01 D0 03 20 44 E0 25 70 A0 8E 40 1C A0 86 D4 E0 A5 86 D8 E0 AD F8 10 60 A0 8D AD F8 12 00 05 95 10 22 04 A9 E0 68 FB F7 EB FE 40 1C 0C D0 04 20 2E E0 00 00 4C 6F 07 00 01 21 E0 68 FC F7 33 F8 FC F7 3B FF 76 28 03 D0 E0 68 FC F7
9:17:44 AM
9:17:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 6C 09 81 80 7E FC DA E7 05 20 20 70 A5 86 48 46 A5 F7 0A FB AD E0 48 46 A5 F7 0E FB B0 F5 FA 6F 09 D9 E0 68 FC F7 6D FC 25 70 A0 8E 40 1C A0 86 48 46 A5 F7 F5 FA 01 21 E0 68 FC F7 10 F8 FC F7 18 FF 00 28 32 D1 06 20 20 70 BD E7 09 A8 FC F7 5E FB 09 A9 E0 68 FC F7 5D FB 02 95 00 97 03 95 00 23 1A 46 09 A9 E0 68 00 E0 81 E0 FC F7 7A FB B8 B1 10 20 19 90 19 AA 15 A9 E0 68 FC F7 E2 FA 20 61 40 1C
9:17:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 6D 09 81 80 13 D0 20 46 FF F7 AA FC 24 F8 4E 6F 40 46 65 80 26 82 65 82 A5 F7 C6 FA 07 20 04 F8 4E 0D A0 6E FC F7 76 FF 03 28 61 D1 61 E0 E0 68 FC F7 27 FC 25 70 F4 E7 A0 6B 90 B1 04 F1 1C 00 06 46 A5 F7 B9 FA 1E 28 04 D8 A0 6B B0 F9 14 00 C8 28 06 DB 20 46 FF F7 E2 FE A0 63 30 46 A5 F7 A3 FA 20 46 FF F7 58 FE 20 46 FF F7 B8 FE 40 46 A5 F7 A2 FA E1 8D 01 EB 41 02 C2 EB C1 11 B0 EB C1 0F 0A D9
9:17:45 AM
9:17:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 6E 09 81 80 20 46 FF F7 6B FC 20 46 FF F7 23 FD 01 28 02 D1 40 46 A5 F7 83 FA 0F A8 FC F7 F7 FA 0F A9 20 69 FC F7 F6 FA 02 95 00 97 03 95 00 22 0F AB 11 46 20 69 FC F7 15 FB 28 B1 20 46 FF F7 4F FC 20 46 FF F7 07 FD A0 6E FC F7 23 FF 03 28 0F D0 20 46 FF F7 44 FC 20 46 FF F7 E5 FC 08 E0 FF E7 48 46 A5 F7 68 FA 41 F2 88 31 88 42 00 D9 25 70 A0 8E 42 F2 10 71 88 42 3F F6 0E AF A0 78 C0 07 0D D0
9:17:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 6F 09 81 80 E0 68 FC F7 BC FB 00 28 08 D1 08 20 20 70 A0 78 20 F0 01 00 A0 70 48 46 A5 F7 44 FA 1B B0 BD E8 F0 83 10 B5 04 46 FF F7 6E FC 20 46 BD E8 10 40 CD E6 00 00 10 B5 4F F2 01 44 13 1B A2 42 0D D0 08 DC A2 F5 20 62 82 3A 0A D0 A2 F5 69 42 7E 3A 05 D1 03 E0 01 2B 01 D0 02 2B 00 D1 88 64 10 BD 49 6E FB E7 2D E9 F0 41 04 46 30 30 A5 F7 16 FA 04 F1 38 00 A5 F7 12 FA 00 20 01 46 04 EB C0 02
9:17:46 AM
9:17:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 70 09 81 80 40 1C D1 60 C0 B2 91 60 02 28 F7 D3 00 25 E4 4E E4 4F 09 E0 06 EB C5 00 36 F8 35 20 41 68 00 20 FF F7 C8 FF 6D 1C ED B2 38 78 85 42 F2 D3 00 25 1B E0 60 68 36 F8 35 10 02 88 8A 42 05 D1 06 EB C5 00 A0 60 41 68 E1 60 07 E0 40 88 88 42 0A D1 06 EB C5 00 20 61 41 68 61 61 41 68 36 F8 35 20 20 46 FF F7 A7 FF 6D 1C ED B2 38 78 85 42 E0 D3 E1 68 D1 B1 60 69 C0 B1 81 42 16 D0 21 69 4F F2
9:17:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 71 09 81 80 01 43 09 88 CA 1A 99 42 0D D0 08 DC A1 F5 20 61 82 39 0A D0 A1 F5 69 41 7E 39 09 D1 03 E0 01 2A 01 D0 02 2A 04 D1 40 6D 10 B1 00 20 BD E8 F0 81 01 20 FB E7 70 B5 41 69 00 29 26 D0 00 69 4F F2 01 43 00 88 C2 1A 98 42 0D D0 08 DC A0 F5 20 60 82 38 0C D0 A0 F5 69 40 7E 38 16 D1 03 E0 01 2A 01 D0 02 2A 11 D1 01 F1 40 00 CC 6A 02 E0 4C 6D 01 F1 40 00 00 68 BC F7 5F FF 00 25 20 00 04 D0
9:17:47 AM
9:17:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 72 09 81 80 44 68 45 60 BC F7 58 FF F8 E7 70 BD 10 B5 01 78 00 24 11 B9 FF F7 66 FF 00 B1 01 24 20 46 10 BD 02 46 00 20 02 EB C0 03 DB 68 8B 42 04 D0 40 1C C0 B2 02 28 F6 D3 FF 20 70 47 00 B5 C3 68 8B 42 04 D0 43 69 8B 42 01 D0 00 20 00 BD FF F7 32 FF 01 20 00 BD 70 B5 14 46 00 25 10 B1 01 28 0D D1 01 E0 08 88 00 E0 48 88 CF F7 1A FB 30 B1 D0 F8 02 10 21 60 C0 88 A0 80 06 20 70 BD 25 60 A5 80
9:17:48 AM
9:17:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 73 09 81 80 FA E7 70 B5 16 46 1A 46 10 B1 01 28 27 D1 05 E0 00 25 0C 46 06 2A 03 D0 0D 80 20 E0 89 1C F7 E7 81 49 30 46 9D F7 D0 FB 40 B1 FF 21 30 46 CF F7 83 FA 28 B1 00 21 7A 4A 7A 4B 0D E0 25 80 07 E0 25 80 0C E0 05 88 32 F8 31 60 B5 42 02 D1 25 80 01 20 70 BD 49 1C C9 B2 1D 78 A9 42 F2 D3 00 20 70 BD 2D E9 F0 47 06 46 84 6C FF 20 18 70 20 78 00 27 89 46 90 46 1D 46 01 28 55 D1 31 46 20 46
9:17:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 74 09 81 80 FF F7 8E FF 40 B2 28 70 40 1C 09 D1 30 6D 38 B1 FF F7 32 FB 20 B1 20 46 31 6D FF F7 81 FF 28 70 95 F9 00 00 0F FA 88 F6 10 B1 01 28 13 D0 3B E0 A0 69 18 B9 BC F7 7E FE A0 61 28 B3 4A 46 31 46 BC F7 B1 FF 40 45 01 D0 A0 69 1B E0 04 F1 20 00 A5 F7 E8 F8 23 E0 20 8E 10 B3 04 F1 30 00 A5 F7 E9 F8 42 F2 10 71 88 42 1A D2 E0 69 18 B9 BC F7 61 FE E0 61 40 B1 4A 46 31 46 BC F7 94 FF 40 45
9:17:49 AM
9:17:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 75 09 81 80 03 D0 E0 69 BC F7 98 FE 0E E0 04 F1 28 00 A5 F7 C9 F8 04 F1 38 00 A5 F7 C5 F8 01 20 28 70 01 27 04 F1 30 00 A5 F7 BE F8 38 46 BD E8 F0 87 2D E9 F0 41 04 46 38 30 06 46 A5 F7 BC F8 42 F2 10 75 A8 42 02 D9 30 46 A5 F7 A9 F8 04 F1 30 00 06 46 A5 F7 B0 F8 A8 42 05 D9 30 46 A5 F7 9F F8 20 46 FF F7 E8 FE 20 78 00 28 49 D0 01 28 47 D1 A0 69 40 F6 82 26 00 27 D8 B1 04 F1 20 00 05 46 A5 F7
9:17:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 76 09 81 80 99 F8 0A 28 04 D8 A0 69 B0 F9 14 00 40 28 0F DD 20 69 00 88 B0 42 04 D0 D4 E9 05 01 E0 F7 3A FF 10 B9 A0 69 BC F7 48 FE 28 46 A7 61 A5 F7 76 F8 E0 69 00 28 23 D0 04 F1 28 00 00 25 80 46 A5 F7 79 F8 0A 28 04 D8 E0 69 B0 F9 14 00 40 28 16 DD A0 68 00 88 B0 42 03 D1 E0 68 10 B1 45 6E 00 E0 E5 68 E1 69 28 46 E0 F7 15 FF 10 B9 E0 69 BC F7 23 FE 40 46 E7 61 BD E8 F0 41 A5 F7 4F B8 95 E6
9:17:50 AM
9:17:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 77 09 81 80 10 B5 04 46 40 68 00 28 08 D0 20 46 FF F7 92 FE 20 46 FF F7 27 FE 00 B1 01 20 20 70 10 BD 00 00 D8 5D 07 00 00 5E 07 00 6A 45 06 00 30 B4 0C 46 11 46 1A 46 B0 F5 80 7F 02 D0 00 20 30 BC 70 47 20 46 30 BC ED F7 B4 BA 30 B4 0C 46 11 46 1A 46 02 9B B0 F5 80 7F 01 D0 00 20 EF E7 20 46 30 BC ED F7 B3 BA B0 F5 80 7F 01 D0 00 20 70 47 ED F7 B8 BA 00 00 01 20 70 47 1F B5 00 20 AD F8 08 00
9:17:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 78 09 81 80 02 20 03 A9 CD E9 00 01 02 46 00 23 02 A9 28 20 BE F7 65 FD 00 28 00 D0 01 20 04 B0 10 BD 7F B5 04 46 02 20 03 AD CD E9 00 05 02 46 00 23 02 A9 28 20 BE F7 14 FD 00 28 14 D0 AC B1 BD F8 08 00 20 80 BD F8 08 00 A1 1C 58 B1 4F F4 E4 72 50 43 82 B2 CD E9 00 25 02 23 28 20 BE F7 00 FD 00 28 00 D0 01 20 04 B0 70 BD 00 20 FB E7 0E B5 02 AA 02 21 CD E9 00 12 0A 46 01 46 00 23 28 20 BE F7
9:17:51 AM
9:17:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 79 09 81 80 EE FC 00 28 00 D0 01 20 0E BD 0E B5 00 21 AD F8 08 10 0B 46 01 88 72 29 01 D9 00 20 0E BD 02 A9 4F F4 E5 72 CD E9 00 21 01 46 28 20 BE F7 17 FD 00 28 F3 D0 01 20 0E BD F0 B5 F3 B0 04 46 0D 00 2C D0 68 46 FF F7 AB FF 00 28 1D D0 BD F8 00 70 00 22 6B 46 4F F6 FF 7C 24 F0 78 0E 1C E0 00 BF 03 EB 82 06 71 88 61 45 14 D0 11 F0 78 0F 0D D0 A1 42 0F D1 03 EB 82 00 00 79 60 F3 0F 24 70 79
9:17:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 7A 09 81 80 60 F3 07 04 2C 80 01 20 73 B0 F0 BD 21 F0 78 01 71 45 EF D0 52 1C 92 B2 BA 42 E1 D3 00 20 F3 E7 D1 48 D2 49 09 1A 00 22 03 E0 00 BF 00 F8 01 2B 49 1E 00 29 FA D1 70 47 70 B5 05 46 0E 46 4F F6 BF 64 A6 F7 FC FC 40 05 01 D5 A6 F7 17 F8 00 22 01 21 C7 48 A0 47 C7 4C 00 20 20 80 60 80 FF F7 DF FF BC F7 91 FC BD F7 7A FE BE F7 33 FF 78 B1 F5 F7 A9 FE C0 48 A6 F7 0E FD A6 F7 E0 FC C0 07
9:17:52 AM
9:17:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 7B 09 81 80 08 D0 A6 F7 DC FC 40 05 04 D4 BE F7 A6 FD 01 E0 F5 F7 99 FE A6 F7 D3 FC C0 06 03 D5 01 21 16 20 F8 F7 61 FD A6 F7 CB FC 40 05 06 D4 A6 F7 ED FC A9 F7 CE FB 00 20 A6 F7 1B FA A6 F7 C0 FC 00 06 7E D4 BC F7 61 FC A6 F7 BA FC 00 06 F8 D4 31 46 28 46 BE F7 20 FC A6 F7 B2 FC 00 06 F0 D4 31 46 28 46 E7 F7 63 F8 A6 F7 AA FC 00 06 E8 D4 31 46 28 46 CF F7 3F F9 A6 F7 A2 FC 00 06 E0 D4 07 20
9:17:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 7C 09 81 80 A2 F7 CE FC 18 B1 31 46 28 46 E1 F7 E5 FE A6 F7 96 FC 00 06 54 D4 06 20 A2 F7 C2 FC 18 B1 31 46 28 46 EA F7 E5 FA A6 F7 8A FC 00 06 48 D4 31 46 28 46 F5 F7 B2 FF A6 F7 82 FC 00 06 79 D4 03 20 A2 F7 AE FC 18 B1 31 46 28 46 C3 F7 CF FB A6 F7 76 FC 00 06 6D D4 A6 F7 72 FC C0 07 01 D0 06 20 00 E0 07 20 A6 F7 3E FB A6 F7 69 FC 00 06 60 D4 04 20 A2 F7 95 FC 18 B1 31 46 28 46 F1 F7 3B FB
9:17:53 AM
9:17:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 7D 09 81 80 A6 F7 5D FC 00 06 54 D4 31 46 28 46 BF F7 F7 FC A6 F7 55 FC 00 06 4C D4 31 46 28 46 F2 F7 E9 F9 A6 F7 4D FC 00 06 44 D4 31 46 28 46 F8 F7 CD FD A6 F7 45 FC 00 06 3C D4 07 20 A2 F7 71 FC 00 E0 37 E0 18 B1 31 46 28 46 E1 F7 D4 FE A6 F7 37 FC 00 06 2E D4 05 20 A2 F7 63 FC 18 B1 31 46 28 46 FB F7 63 F8 A6 F7 2B FC 00 06 22 D4 0A 20 A2 F7 57 FC 18 B1 31 46 28 46 EC F7 29 F9 A6 F7 1F FC
9:17:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 7E 09 81 80 00 06 16 D4 01 20 A2 F7 4B FC 18 B1 31 46 28 46 EE F7 C8 FB A6 F7 13 FC 00 06 0A D4 08 20 A2 F7 3F FC 00 28 11 D0 31 46 28 46 BD E8 70 40 BC F7 7D B8 A6 F7 04 FC C0 07 03 D0 60 88 08 B1 BE F7 A3 FC BD E8 70 40 A6 F7 36 BC 70 BD 10 B5 A2 F7 52 FB A6 F7 F4 FB 10 F4 90 6F 03 D1 01 20 A2 F7 1F FC 10 B9 A3 F7 1C FC 08 B1 EE F7 25 FF 01 20 A3 F7 5E FC A6 F7 E3 FB 10 F4 90 6F 20 D0 F8 F7
9:17:54 AM
9:17:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 7F 09 81 80 B3 FA 02 20 A3 F7 54 FC A6 F7 D9 FB 00 06 05 D4 03 20 A2 F7 05 FC 08 B1 C3 F7 6B FB 03 20 A3 F7 47 FC 04 20 A2 F7 FC FB 08 B1 F1 F7 15 FF 04 20 A3 F7 3E FC A6 F7 C3 FB 10 F4 90 6F 03 D0 08 E0 F7 F7 F1 FE DD E7 05 20 A2 F7 EA FB 08 B1 FB F7 A3 F8 05 20 A3 F7 2C FC A6 F7 B1 FB 10 F4 90 6F 07 D1 06 20 A2 F7 DC FB 18 B1 EA F7 30 FD EF F7 D6 FB 06 20 A3 F7 1C FC A6 F7 A1 FB 10 F4 90 6F
9:17:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 80 09 81 80 05 D1 07 20 A2 F7 CC FB 08 B1 E2 F7 CE F9 07 20 A3 F7 0E FC 08 20 A2 F7 C3 FB 08 B1 BC F7 08 F8 08 20 A3 F7 05 FC A6 F7 8A FB 10 F4 90 6F 05 D1 0A 20 A2 F7 B5 FB 08 B1 EC F7 52 FA 09 20 A3 F7 F7 FB 0A 20 A3 F7 F4 FB BD E8 10 40 A3 F7 AB BC 10 B5 00 21 08 46 FF F7 6F FE AF F2 0F 11 BD E8 10 40 06 A0 A2 F7 52 BA 00 3B 00 10 0C A9 00 10 8C 11 00 10 B0 94 00 10 C7 28 02 00 49 53 4B 41
9:17:55 AM
9:17:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 81 09 81 80 4D 4D 54 38 38 30 31 30 30 35 39 33 00 00 00 00 06 28 0D D2 DF E8 00 F0 0C 03 05 07 0C 09 10 20 70 47 18 20 70 47 4C 20 70 47 4F F4 BC 70 70 47 00 20 70 47 40 1A 02 28 00 DD 78 38 40 1C C0 B2 70 47 00 00 10 B5 7C 21 09 48 9D F7 06 F9 08 48 00 22 78 30 40 F6 98 51 42 60 82 60 C2 60 A0 F6 F8 20 A4 F7 AF FE 03 49 C0 43 A1 F8 98 0D 10 BD 68 77 00 10 E8 6C 00 10 11 22 33 44 55 66 77 88
9:17:56 AM
9:17:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 82 09 81 80 99 AA BB CC DD EE FF 00 22 33 44 55 66 77 88 99 AA BB CC DD EE FF 00 11 01 00 10 00 64 01 02 00 7C 01 08 01 03 00 8A 02 02 04 04 00 92 06 80 1B 05 00 18 22 28 00 06 00 48 22 AC 04 07 00 FA 26 96 02 09 00 E6 29 7A 11 08 00 96 29 4A 00 26 00 AC 53 30 09 0A 00 66 3B 0E 00 0B 00 7C 3B 90 00 0D 00 14 3C A0 00 0E 00 BA 3C 36 00 0F 00 F6 3C 24 03 10 00 20 40 C4 07 12 00 EC 47 68 00 13 00
9:17:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 83 09 81 80 5A 48 1C 00 14 00 7C 48 0C 00 15 00 8E 48 0A 00 18 00 A0 48 48 05 1A 00 EE 4D 3A 02 1B 00 30 50 68 00 1C 00 A0 50 D4 00 20 00 80 51 90 01 21 00 16 53 16 00 23 00 34 53 0C 00 24 00 48 53 54 00 25 00 A2 53 04 00 27 00 E2 5C 3A 00 28 00 22 5D CA 01 29 00 F2 5E 2C 00 2A 00 24 5F 0B 00 00 00 01 00 10 00 A0 0D 03 00 B8 0D F0 03 04 00 B0 11 F8 01 05 00 B0 13 A0 0D 80 00 58 21 14 00 81 00
9:17:57 AM
9:17:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 84 09 81 80 78 21 60 12 02 3E 00 20 00 00 02 00 FC 8A 00 10 04 00 10 00 80 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 80 00 FF 10 10 20 10 00 00 16 00 F7 00 78 01 7A 01 74 1B BA 0D 62 00 00 00 00 00 82 3B 03 3C 01 12 00 12 FF FF 0D 0C 0B 0A 09 08 07 04 05 06 07 17 16 13 14 10 11 12 15 74 75 76 77 31 32 33 30 70 AF AC EC F0 F3 F2 F1 38 40 48 50 58 60 68 B4 BC C4 CC
9:17:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 85 09 81 80 D4 DC E4 F9 F5 AE AD A4 A8 A0 9C AB 9F A3 A7 AA A6 A2 9E A9 A5 A1 9D 99 9A 95 96 97 9B 98 94 79 7D 80 7E 7F 7C 7A 7B 78 83 82 81 88 84 85 86 87 8B 8A 89 91 8D 92 8E 93 8F 8C 90 45 6E 64 20 20 20 20 20 00 45 6E 74 45 72 20 20 20 00 45 53 43 20 20 20 20 20 00 63 72 45 64 49 74 20 20 00 45 72 72 6F 72 20 32 33 00 45 72 72 6F 72 20 31 31 00 45 72 72 6F 72 20 33 31 00 4C 41 59 45 72 20
9:17:58 AM
9:17:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 86 09 81 80 55 50 00 45 6E 41 62 4C 45 20 20 00 2D 2D 2D 2D 2D 2D 2D 2D 00 00 00 00 00 00 00 00 52 6F 07 00 01 00 00 00 52 6F 07 00 02 00 00 00 F5 44 06 00 03 00 00 00 3D 45 06 00 04 00 00 00 46 45 06 00 05 00 00 00 0C 43 06 00 00 00 00 00 AD 44 06 00 01 00 00 00 D1 44 06 00 02 00 00 00 DA 44 06 00 03 00 00 00 E3 44 06 00 04 00 00 00 EC 44 06 00 05 00 00 00 BB 42 06 00 00 00 00 00 FE 44 06 00
9:17:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 87 09 81 80 01 00 00 00 B6 44 06 00 02 00 00 00 C8 44 06 00 03 00 00 00 F5 44 06 00 04 00 00 00 BB 42 06 00 01 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 E8 03 00 00 00 00 00 00 10 27 00 00 00 00 00 00 A0 86 01 00 00 00 00 00 40 42 0F 00 00 00 00 00 80 96 98 00 00 00 00 00 00 E1 F5 05 00 00 00 00 00 CA 9A 3B 00 00 00 00 00 E4 0B 54 02 00 00 00 00 E8 76 48 17 00 00 00
9:17:59 AM
9:17:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 88 09 81 80 00 10 A5 D4 E8 00 00 00 84 61 85 61 86 61 87 61 84 64 85 64 86 64 87 64 84 67 85 67 86 67 87 67 80 6B 81 6B 82 6B 83 6B 84 6B 85 6B 86 6B 87 6B 00 D0 01 D0 02 D0 03 D0 04 D0 05 D0 06 D0 07 D0 80 D0 06 D1 07 D1 80 D1 81 51 82 51 83 51 84 51 03 57 80 58 81 58 82 58 83 58 84 58 85 58 86 58 87 58 80 59 81 59 82 59 83 59 84 59 85 59 86 59 87 59 01 D3 02 D3 03 D3 04 D3 20 2D 30 31 32 33
9:17:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 89 09 81 80 34 35 36 37 38 39 41 42 43 44 45 46 47 48 49 4A 4C 4F 50 53 55 59 61 62 63 64 65 66 68 69 6C 6E 6F 72 74 75 53 74 41 72 74 20 20 20 00 53 74 64 20 64 41 74 41 00 74 45 53 74 20 20 20 20 00 4C 63 64 20 20 20 20 20 00 4C 63 64 20 74 45 53 74 00 50 30 31 20 20 20 20 20 00 50 30 32 20 20 20 20 20 00 50 39 39 20 20 20 20 20 00 47 72 69 64 20 20 20 20 00 72 45 53 45 74 20 20 20 00 53 45
9:18:00 AM
9:18:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 8A 09 81 80 74 20 20 20 20 20 00 53 43 72 6F 6C 6C 20 20 00 41 62 6F 72 74 20 20 20 00 43 6F 6E 6E 45 63 74 20 00 64 49 53 63 6F 6E 6E 20 00 45 43 20 53 45 4C 20 20 00 53 45 41 72 63 68 20 20 00 64 6F 6E 45 20 20 20 20 00 72 45 4A 45 63 74 45 64 00 53 45 41 72 63 68 20 6F 6E 20 50 32 20 63 68 31 20 2D 00 B3 FF B4 FF B5 FF B6 FF 00 00 00 00 00 00 60 85 74 05 08 01 01 00 07 00 00 00 70 45 06 00
9:18:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 8B 09 81 80 60 85 74 05 08 01 02 00 07 00 00 00 80 45 06 00 60 85 74 05 08 01 03 00 07 00 00 00 90 45 06 00 60 85 74 05 08 01 04 00 07 00 00 00 A0 45 06 00 01 00 00 00 06 5F 1F 04 00 00 7E 1F 04 B0 00 00 0E 00 00 00 B0 45 06 00 01 00 00 00 06 5F 1F 04 00 1C 03 20 04 B0 00 00 0E 00 00 00 C8 45 06 00 02 00 00 00 50 6F 07 00 A2 00 00 00 04 00 00 00 A3 00 00 00 04 00 00 00 A4 00 00 00 04 00 00 00
9:18:01 AM
9:18:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 8C 09 81 80 A5 00 00 00 04 00 00 00 A6 00 00 00 04 00 00 00 A7 00 00 00 04 00 00 00 A8 00 00 00 04 00 00 00 A9 00 00 00 04 00 00 00 8A 00 00 00 03 00 00 00 8B 00 00 00 06 00 00 00 BD 00 00 00 19 00 00 00 BE 00 00 00 04 00 00 00 BE 00 00 00 04 00 00 00 00 04 00 00 80 4E 06 00 00 01 00 00 B8 4F 06 00 01 12 00 00 A8 4D 06 00 00 01 00 00 B0 51 06 00 00 01 00 00 C8 51 06 00 00 01 00 00 24 53 06 00
9:18:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 8D 09 81 80 00 01 00 00 28 4C 06 00 01 00 00 00 06 00 FF FF 06 00 FF FF 01 00 01 00 02 00 FF FF 01 00 04 00 01 00 04 00 00 00 00 00 00 00 00 00 02 00 FF FF 02 00 FF FF 02 00 FF FF 00 00 00 00 01 00 01 00 00 00 00 00 01 00 01 00 01 00 02 00 01 00 01 00 01 00 02 00 06 00 FF FF 01 00 08 00 01 00 08 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 60 00 00 04 50 04 20 00 00 00 00 88 80
9:18:02 AM
9:18:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 8E 09 81 80 88 90 00 00 00 00 00 00 00 00 01 30 02 40 01 00 02 10 00 00 00 00 00 00 01 70 00 00 00 00 00 00 00 01 00 00 C8 4B 06 00 01 12 00 00 A8 4D 06 00 00 01 00 00 88 4C 06 00 00 01 00 00 94 4C 06 00 00 00 00 00 00 00 00 00 00 02 00 00 98 51 06 00 00 01 00 00 EC 4B 06 00 00 01 00 00 A0 4C 06 00 00 01 00 00 34 4C 06 00 00 01 00 00 04 4C 06 00 00 01 00 00 70 4C 06 00 00 01 00 00 1C 4C 06 00
9:18:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 8F 09 81 80 00 01 00 00 58 4C 06 00 00 01 00 00 10 4C 06 00 01 0E 00 00 AC 4C 06 00 00 01 00 00 54 4D 06 00 00 01 00 00 F8 4B 06 00 00 01 00 00 E0 4B 06 00 00 01 00 00 D4 4B 06 00 00 01 00 00 60 4D 06 00 00 01 00 00 6C 4D 06 00 00 02 00 00 78 4D 06 00 00 01 00 00 90 4D 06 00 00 01 00 00 9C 4D 06 00 00 01 00 00 28 4C 06 00 00 03 00 00 C4 4F 06 00 00 01 00 00 E8 4F 06 00 00 02 00 00 F4 4F 06 00
9:18:03 AM
9:18:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 90 09 81 80 00 01 00 00 54 50 06 00 00 01 00 00 60 50 06 00 00 03 00 00 6C 50 06 00 01 0A 00 00 90 50 06 00 01 06 00 00 08 51 06 00 01 06 00 00 50 51 06 00 00 01 00 00 B0 4E 06 00 00 01 00 00 BC 4E 06 00 00 01 00 00 C8 4E 06 00 00 03 00 00 D4 4E 06 00 00 02 00 00 F8 4E 06 00 00 05 00 00 10 4F 06 00 00 02 00 00 4C 4F 06 00 00 01 00 00 64 4F 06 00 00 01 00 00 70 4F 06 00 00 01 00 00 7C 4F 06 00
9:18:04 AM
9:18:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 91 09 81 80 00 01 00 00 88 4F 06 00 00 01 00 00 94 4F 06 00 00 01 00 00 A0 4F 06 00 00 01 00 00 AC 4F 06 00 01 04 00 00 E0 51 06 00 00 01 00 00 10 52 06 00 01 16 00 00 1C 52 06 00 00 01 00 00 64 4C 06 00 00 01 00 00 4C 4C 06 00 00 01 00 00 30 50 06 00 00 02 00 00 3C 50 06 00 00 01 00 00 0C 50 06 00 00 01 00 00 30 53 06 00 00 02 00 00 3C 53 06 00 00 01 00 00 54 53 06 00 00 01 00 00 60 53 06 00
9:18:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 92 09 81 80 00 01 00 00 6C 53 06 00 00 01 00 00 78 53 06 00 00 00 00 00 94 53 06 00 00 00 00 00 96 53 06 00 99 53 06 00 9E 53 06 00 A7 53 06 00 AB 53 06 00 B3 53 06 00 BC 53 06 00 00 00 00 00 BE 53 06 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 53 06 00 00 00 00 00 00 00 00 00 C9 53 06 00 D0 53 06 00 D9 53 06 00 E3 53 06 00 E7 53 06 00 EB 53 06 00 00 00 00 00 00 00 00 00 00 00 00 00 F4 53 06 00
9:18:05 AM
9:18:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 93 09 81 80 F8 53 06 00 FF 53 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 54 06 00 0C 54 06 00 12 54 06 00 00 00 00 00 1C 54 06 00 21 54 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:18:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 94 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 54 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 25 54 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:18:06 AM
9:18:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 95 09 81 80 00 00 00 00 60 85 74 05 08 02 00 00 07 00 00 00 84 4A 06 00 60 85 74 05 08 02 01 00 07 00 00 00 94 4A 06 00 60 85 74 05 08 02 02 00 07 00 00 00 A4 4A 06 00 60 85 74 05 08 02 03 00 07 00 00 00 B4 4A 06 00 60 85 74 05 08 02 04 00 07 00 00 00 C4 4A 06 00 60 85 74 05 08 02 05 00 07 00 00 00 D4 4A 06 00 00 00 04 D0 06 A0 02 A0 01 A0 01 A0 06 A0 08 A0 0C A0 10 A0 88 80 88 90 88 C0 01 70
9:18:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 96 09 81 80 01 60 01 00 02 10 04 20 08 28 01 30 02 40 04 50 04 20 04 20 01 30 01 00 02 10 05 A0 01 00 01 A0 0C A0 01 A0 01 A0 01 00 01 00 01 00 01 00 01 00 01 00 01 00 04 A0 06 A0 02 10 06 A0 02 10 06 A0 02 10 0C 80 0C 80 01 70 22 80 04 A0 05 A0 02 10 06 A0 01 30 02 10 02 10 06 A0 01 30 02 10 0C A0 04 20 04 20 04 20 02 10 02 10 01 00 01 00 12 80 12 80 04 20 04 20 82 80 04 20 04 20 02 10 01 60
9:18:07 AM
9:18:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 97 09 81 80 06 A0 02 10 04 A0 02 10 04 C0 06 C0 05 A0 05 A0 02 10 02 10 01 00 01 00 01 70 22 80 01 70 01 70 10 A0 02 10 04 20 01 00 01 00 01 00 01 00 01 00 01 00 01 00 02 10 02 10 01 00 01 00 01 60 01 00 01 00 01 00 01 00 00 00 00 00 00 00 0B 00 01 00 E8 4A 06 00 00 00 00 00 0C 00 01 00 EA 4A 06 00 00 00 00 00 13 00 01 00 F2 4A 06 00 00 00 00 00 16 00 01 00 F8 4A 06 00 00 00 00 00 18 00 01 00
9:18:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 98 09 81 80 FC 4A 06 00 00 00 00 00 09 00 01 00 FE 4A 06 00 00 00 00 00 0A 00 01 00 00 4B 06 00 00 00 00 00 05 00 01 00 02 4B 06 00 00 00 00 00 06 00 01 00 04 4B 06 00 00 00 00 00 07 00 01 00 06 4B 06 00 00 00 00 00 32 00 01 00 08 4B 06 00 01 00 00 00 0F 00 01 00 EE 4A 06 00 00 00 00 00 02 00 01 00 0A 4B 06 00 01 00 00 00 02 00 01 00 0A 4B 06 00 00 00 00 00 03 00 01 00 0C 4B 06 00 00 00 00 00
9:18:08 AM
9:18:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 99 09 81 80 04 00 01 00 0E 4B 06 00 01 00 00 00 0E 00 02 00 14 4B 06 00 00 00 00 00 14 00 01 00 F4 4A 06 00 02 00 00 00 21 00 04 00 4E 4B 06 00 02 00 00 00 06 00 01 00 04 4B 06 00 04 00 00 00 09 00 01 00 FE 4A 06 00 04 00 01 00 06 00 01 00 04 4B 06 00 04 00 02 00 16 00 01 00 F8 4A 06 00 04 00 03 00 02 00 01 00 0A 4B 06 00 04 00 04 00 02 00 01 00 0A 4B 06 00 04 00 04 00 03 00 01 00 0C 4B 06 00
9:18:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 9A 09 81 80 04 00 04 00 04 00 01 00 0E 4B 06 00 04 00 04 00 05 00 01 00 02 4B 06 00 04 00 04 00 06 00 01 00 04 4B 06 00 04 00 04 00 07 00 01 00 06 4B 06 00 04 00 04 00 09 00 01 00 FE 4A 06 00 04 00 04 00 16 00 01 00 F8 4A 06 00 04 00 04 00 17 00 01 00 FA 4A 06 00 02 00 00 00 1B 00 03 00 18 4B 06 00 02 00 00 00 1C 00 03 00 1E 4B 06 00 02 00 00 00 1D 00 08 00 24 4B 06 00 02 00 00 00 05 00 01 00
9:18:09 AM
9:18:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 9B 09 81 80 02 4B 06 00 04 00 00 00 1E 00 03 00 34 4B 06 00 01 00 00 00 1F 00 02 00 3A 4B 06 00 02 00 00 00 20 00 02 00 4A 4B 06 00 00 00 00 00 02 00 01 00 0A 4B 06 00 00 00 00 00 09 00 01 00 FE 4A 06 00 00 00 00 00 0A 00 01 00 00 4B 06 00 00 00 00 00 03 00 01 00 0C 4B 06 00 00 00 00 00 04 00 01 00 0E 4B 06 00 00 00 00 00 05 00 01 00 02 4B 06 00 00 00 00 00 06 00 01 00 04 4B 06 00 00 00 00 00
9:18:10 AM
9:18:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 9C 09 81 80 07 00 01 00 06 4B 06 00 00 00 00 00 16 00 01 00 F8 4A 06 00 00 00 00 00 17 00 01 00 FA 4A 06 00 01 00 00 00 08 00 02 00 10 4B 06 00 01 00 00 00 06 00 01 00 04 4B 06 00 01 00 00 00 17 00 01 00 FA 4A 06 00 01 00 01 00 17 00 01 00 FA 4A 06 00 02 00 00 00 09 00 01 00 FE 4A 06 00 02 00 01 00 17 00 01 00 FA 4A 06 00 03 00 00 00 16 00 01 00 F8 4A 06 00 03 00 01 00 06 00 01 00 04 4B 06 00
9:18:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 9D 09 81 80 02 00 00 00 21 00 04 00 4E 4B 06 00 01 00 01 00 07 00 01 00 06 4B 06 00 01 00 02 00 07 00 01 00 06 4B 06 00 03 00 00 00 21 00 04 00 4E 4B 06 00 02 00 00 00 05 00 01 00 02 4B 06 00 01 00 00 00 2B 00 02 00 78 4B 06 00 01 00 00 00 06 00 01 00 04 4B 06 00 02 00 00 00 16 00 01 00 F8 4A 06 00 02 00 01 00 06 00 01 00 04 4B 06 00 02 00 02 00 05 00 01 00 02 4B 06 00 02 00 00 00 06 00 01 00
9:18:11 AM
9:18:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 9E 09 81 80 04 4B 06 00 02 00 01 00 07 00 01 00 06 4B 06 00 01 00 00 00 07 00 01 00 06 4B 06 00 01 00 01 00 07 00 01 00 06 4B 06 00 01 00 02 00 07 00 01 00 06 4B 06 00 01 00 03 00 07 00 01 00 06 4B 06 00 01 00 04 00 07 00 01 00 06 4B 06 00 02 00 00 00 05 00 01 00 02 4B 06 00 02 00 01 00 07 00 01 00 02 4B 06 00 02 00 00 00 16 00 01 00 F8 4A 06 00 01 00 00 00 27 00 03 00 56 4B 06 00 01 00 00 00
9:18:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 9F 09 81 80 28 00 03 00 5C 4B 06 00 01 00 00 00 06 00 01 00 04 4B 06 00 02 00 00 00 29 00 02 00 3E 4B 06 00 02 00 00 00 2A 00 02 00 42 4B 06 00 02 00 00 00 2C 00 02 00 46 4B 06 00 01 00 00 00 22 00 04 00 62 4B 06 00 02 00 00 00 16 00 01 00 F8 4A 06 00 02 00 01 00 16 00 01 00 F8 4A 06 00 02 00 02 00 06 00 01 00 04 4B 06 00 01 00 00 00 16 00 01 00 F8 4A 06 00 02 00 00 00 14 00 01 00 F4 4A 06 00
9:18:12 AM
9:18:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A0 09 81 80 02 00 01 00 14 00 01 00 F4 4A 06 00 01 00 00 00 31 00 03 00 98 4B 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 2F 00 02 00 94 4B 06 00 02 00 00 00 16 00 01 00 F8 4A 06 00 02 00 01 00 09 00 01 00 FE 4A 06 00 01 00 00 00 16 00 01 00 F8 4A 06 00 01 00 00 00 07 00 01 00 06 4B 06 00 02 00 00 00 05 00 01 00 02 4B 06 00 02 00 01 00 05 00 01 00
9:18:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A1 09 81 80 02 4B 06 00 02 00 02 00 16 00 01 00 F8 4A 06 00 02 00 00 00 05 00 01 00 02 4B 06 00 02 00 01 00 05 00 01 00 02 4B 06 00 02 00 02 00 05 00 01 00 02 4B 06 00 02 00 02 00 06 00 01 00 04 4B 06 00 02 00 02 00 07 00 01 00 06 4B 06 00 02 00 02 00 0A 00 01 00 00 4B 06 00 03 00 00 00 0A 00 01 00 00 4B 06 00 03 00 01 00 05 00 01 00 02 4B 06 00 03 00 02 00 05 00 01 00 02 4B 06 00 03 00 03 00
9:18:13 AM
9:18:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A2 09 81 80 16 00 01 00 F8 4A 06 00 02 00 00 00 05 00 01 00 02 4B 06 00 02 00 01 00 05 00 01 00 02 4B 06 00 02 00 02 00 06 00 01 00 04 4B 06 00 02 00 02 00 07 00 01 00 06 4B 06 00 02 00 02 00 0A 00 01 00 00 4B 06 00 03 00 00 00 07 00 01 00 06 4B 06 00 01 00 00 00 01 00 01 00 E4 4A 06 00 01 00 00 00 16 00 01 00 F8 4A 06 00 01 00 00 00 0A 00 01 00 00 4B 06 00 01 00 01 00 16 00 01 00 F8 4A 06 00
9:18:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A3 09 81 80 01 00 01 00 0A 00 01 00 00 4B 06 00 01 00 02 00 0A 00 01 00 00 4B 06 00 02 00 00 00 16 00 01 00 F8 4A 06 00 03 00 00 00 05 00 01 00 02 4B 06 00 01 00 00 00 25 00 02 00 70 4B 06 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 26 00 02 00 74 4B 06 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 FF 00 07 00 01 00 06 4B 06 00 01 00 FF 00 06 00 01 00 04 4B 06 00 01 00 FF 00 05 00 01 00
9:18:14 AM
9:18:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A4 09 81 80 02 4B 06 00 01 00 FF 00 32 00 01 00 08 4B 06 00 03 00 00 00 29 00 02 00 3E 4B 06 00 01 00 00 00 06 00 01 00 04 4B 06 00 01 00 01 00 0A 00 01 00 00 4B 06 00 01 00 02 00 16 00 01 00 F8 4A 06 00 01 00 03 00 06 00 01 00 04 4B 06 00 01 00 04 00 16 00 01 00 F8 4A 06 00 01 00 05 00 06 00 01 00 04 4B 06 00 01 00 06 00 18 00 01 00 FC 4A 06 00 01 00 07 00 18 00 01 00 FC 4A 06 00 01 00 08 00
9:18:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A5 09 81 80 16 00 01 00 F8 4A 06 00 01 00 09 00 16 00 01 00 F8 4A 06 00 02 00 00 00 06 00 01 00 04 4B 06 00 02 00 01 00 0A 00 01 00 00 4B 06 00 02 00 02 00 16 00 01 00 F8 4A 06 00 02 00 03 00 06 00 01 00 04 4B 06 00 02 00 04 00 16 00 01 00 F8 4A 06 00 02 00 05 00 06 00 01 00 04 4B 06 00 02 00 06 00 18 00 01 00 FC 4A 06 00 02 00 07 00 18 00 01 00 FC 4A 06 00 02 00 08 00 16 00 01 00 F8 4A 06 00
9:18:15 AM
9:18:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A6 09 81 80 02 00 09 00 16 00 01 00 F8 4A 06 00 01 00 00 00 2D 00 0A 00 7C 4B 06 00 02 00 00 00 2D 00 0A 00 7C 4B 06 00 01 00 00 00 2E 00 02 00 90 4B 06 00 00 00 00 00 15 00 01 00 F6 4A 06 00 01 00 00 00 05 00 01 00 02 4B 06 00 01 00 01 00 06 00 01 00 04 4B 06 00 01 00 00 00 33 00 02 00 9E 4B 06 00 00 00 00 00 12 00 01 00 F0 4A 06 00 01 00 00 00 34 00 0B 00 A2 4B 06 00 01 00 00 00 35 00 07 00
9:18:15 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A7 09 81 80 B8 4B 06 00 01 04 00 00 E0 51 06 00 00 01 00 00 10 52 06 00 00 01 00 01 02 00 01 02 01 03 00 01 01 02 01 03 03 08 18 00 04 05 06 00 04 07 08 09 07 08 08 00 03 0A 0B 03 03 0C 0D 09 00 0E 00 0F 00 04 04 04 04 06 04 04 04 00 0B 10 08 0D 09 04 00 09 09 09 09 11 11 11 11 00 06 13 14 15 06 13 14 15 03 00 30 2A 31 00 16 09 17 00 09 0B 0B 18 18 18 18 18 00 09 19 1A 00 09 1B 09 0B 35 36 00
9:18:16 AM
9:18:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A8 09 81 80 09 0B 18 1B 1C 00 07 37 1B 18 0B 18 00 18 00 18 0B 18 00 00 08 1D 1E 08 08 0D 08 08 00 00 1F 20 21 00 06 18 22 00 0D 09 09 00 09 09 06 06 01 01 00 00 00 00 02 03 00 00 00 00 00 00 02 00 00 00 2E 54 06 00 00 00 00 00 00 00 00 00 01 00 00 00 3C 54 06 00 44 54 06 00 01 01 00 00 00 00 02 03 00 00 00 00 03 01 00 00 00 00 00 00 03 00 00 00 58 54 06 00 01 00 00 00 01 00 00 00 74 54 06 00
9:18:17 AM
9:18:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 A9 09 81 80 03 00 00 00 6C 54 06 00 78 54 06 00 01 01 00 00 00 00 02 03 00 00 00 00 03 01 00 00 00 00 04 01 00 00 00 00 05 01 00 00 00 00 00 00 05 00 00 00 8C 54 06 00 01 00 00 00 01 00 00 00 B4 54 06 00 04 00 00 00 AC 54 06 00 B8 54 06 00 01 01 00 00 00 00 02 01 00 00 00 00 03 01 00 00 00 00 04 01 00 00 00 00 05 01 00 00 00 00 06 01 00 00 00 00 07 01 00 00 00 00 08 03 00 00 00 00 09 03 00 00
9:18:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 AA 09 81 80 00 00 00 00 09 00 00 00 CC 54 06 00 01 00 02 00 02 00 00 00 0C 55 06 00 05 00 00 00 04 55 06 00 10 55 06 00 01 01 00 00 00 00 02 01 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 04 00 00 00 24 55 06 00 01 01 02 01 03 01 00 00 03 00 00 00 44 55 06 00 06 00 00 00 3C 55 06 00 4C 55 06 00 01 01 00 00 00 00 02 01 02 00 03 00 03 03 00 00 00 00 04 03 00 00 00 00 05 01 00 00 00 00 06 01
9:18:18 AM
9:18:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 AB 09 81 80 00 00 00 00 07 01 00 00 00 00 08 01 00 00 00 00 08 00 00 00 60 55 06 00 01 01 02 01 02 00 00 00 98 55 06 00 07 00 01 00 90 55 06 00 9C 55 06 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 01 00 00 00 00 05 03 00 00 00 00 06 03 00 00 00 00 07 03 00 00 00 00 08 03 00 00 00 00 09 01 00 00 00 00 00 00 09 00 00 00 B0 55 06 00 01 01 02 01 03 01 04 01 05 01 06 01 06 00 00 00
9:18:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 AC 09 81 80 F0 55 06 00 08 00 00 00 E8 55 06 00 FC 55 06 00 01 01 00 00 00 00 02 03 00 00 00 00 02 00 00 00 10 56 06 00 01 01 00 00 01 00 00 00 24 56 06 00 09 00 00 00 1C 56 06 00 28 56 06 00 01 01 00 00 00 00 02 03 00 00 00 00 02 00 00 00 3C 56 06 00 01 01 02 01 02 00 00 00 50 56 06 00 0B 00 00 00 48 56 06 00 28 56 06 00 01 01 00 00 00 00 02 01 00 00 00 00 03 01 00 00 00 00 04 01 00 00 00 00
9:18:19 AM
9:18:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 AD 09 81 80 05 01 00 00 00 00 06 03 00 00 00 00 07 00 00 00 00 00 08 01 00 00 00 00 09 01 00 00 00 00 00 00 09 00 00 00 68 56 06 00 01 01 02 01 03 00 04 00 04 00 00 00 A8 56 06 00 0F 00 01 00 A0 56 06 00 B0 56 06 00 01 01 00 00 00 00 02 01 00 00 00 00 02 00 00 00 C4 56 06 00 01 00 00 00 01 00 00 00 D8 56 06 00 11 00 00 00 D0 56 06 00 DC 56 06 00 01 01 00 00 00 00 02 01 00 00 00 00 03 01 00 00
9:18:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 AE 09 81 80 00 00 04 01 00 00 00 00 05 03 00 00 00 00 06 01 00 00 00 00 07 01 00 00 00 00 00 00 07 00 00 00 F0 56 06 00 01 01 02 01 03 01 04 01 04 00 00 00 24 57 06 00 12 00 00 00 1C 57 06 00 2C 57 06 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 05 03 00 00 00 00 06 03 00 00 00 00 07 03 00 00 00 00 08 03 00 00 00 00 09 03 00 00 00 00 00 00 09 00 00 00 40 57 06 00
9:18:20 AM
9:18:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 AF 09 81 80 13 00 01 00 78 57 06 00 00 00 00 00 01 01 00 00 00 00 02 01 00 00 00 00 03 01 00 00 00 00 04 01 00 00 00 00 05 01 00 00 00 00 06 03 00 00 00 00 07 03 00 00 00 00 08 03 00 00 00 00 09 03 00 00 00 00 0A 03 00 00 00 00 0A 00 00 00 8C 57 06 00 01 01 00 00 01 00 00 00 D0 57 06 00 14 00 00 00 C8 57 06 00 D4 57 06 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00
9:18:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B0 09 81 80 04 00 00 00 E8 57 06 00 15 00 00 00 00 58 06 00 00 00 00 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 04 00 00 00 14 58 06 00 16 00 00 00 2C 58 06 00 00 00 00 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 05 03 00 00 00 00 06 03 00 00 00 00 07 03 00 00 00 00 08 03 00 00 00 00 09 03 00 00 00 00 00 00 09 00 00 00 40 58 06 00
9:18:21 AM
9:18:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B1 09 81 80 17 00 01 00 78 58 06 00 00 00 00 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 04 00 00 00 8C 58 06 00 1B 00 01 00 A4 58 06 00 00 00 00 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 05 03 00 00 00 00 06 03 00 00 00 00 07 03 00 00 00 00 00 00 07 00 00 00 B8 58 06 00 1C 00 02 00 E4 58 06 00 00 00 00 00 01 01 00 00 00 00 02 03
9:18:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B2 09 81 80 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 05 03 00 00 00 00 06 03 00 00 00 00 06 00 00 00 F8 58 06 00 01 01 00 00 01 00 00 00 24 59 06 00 1D 00 02 00 1C 59 06 00 28 59 06 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 05 03 00 00 00 00 06 03 00 00 00 00 07 03 00 00 00 00 00 00 07 00 00 00 3C 59 06 00 01 01 00 00 01 00 00 00 70 59 06 00 28 00 00 00
9:18:22 AM
9:18:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B3 09 81 80 68 59 06 00 74 59 06 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 05 03 00 00 00 00 06 03 00 00 00 00 06 00 00 00 88 59 06 00 29 00 00 00 AC 59 06 00 00 00 00 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 05 03 00 00 00 00 06 03 00 00 00 00 07 03 00 00 00 00 08 03 00 00 00 00 09 03 00 00 00 00 0A 03 00 00 00 00 0A 00 00 00
9:18:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B4 09 81 80 C0 59 06 00 2A 00 00 00 FC 59 06 00 00 00 00 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 05 03 00 00 00 00 00 00 05 00 00 00 10 5A 06 00 2C 00 00 00 30 5A 06 00 00 00 00 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 03 00 00 00 00 04 00 00 00 44 5A 06 00 2D 00 00 00 5C 5A 06 00 00 00 00 00 01 01 00 00 00 00 02 01 00 00 00 00 03 01 00 00
9:18:23 AM
9:18:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B5 09 81 80 00 00 04 03 00 00 00 00 04 00 00 00 70 5A 06 00 01 01 02 01 02 00 00 00 90 5A 06 00 46 00 00 00 88 5A 06 00 94 5A 06 00 01 01 00 00 00 00 02 03 00 00 00 00 03 03 00 00 00 00 04 01 00 00 00 00 05 01 00 00 00 00 00 00 05 00 00 00 A8 5A 06 00 01 01 02 01 02 00 00 00 D0 5A 06 00 40 00 00 00 C8 5A 06 00 D4 5A 06 00 00 00 00 00 4C 54 06 00 00 00 00 00 80 54 06 00 C0 54 06 00 18 55 06 00
9:18:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B6 09 81 80 54 55 06 00 A4 55 06 00 04 56 06 00 30 56 06 00 00 00 00 00 5C 56 06 00 00 00 00 00 00 00 00 00 00 00 00 00 B8 56 06 00 00 00 00 00 E4 56 06 00 34 57 06 00 80 57 06 00 DC 57 06 00 08 58 06 00 34 58 06 00 80 58 06 00 00 00 00 00 00 00 00 00 00 00 00 00 AC 58 06 00 EC 58 06 00 30 59 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:18:24 AM
9:18:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B7 09 81 80 00 00 00 00 00 00 00 00 7C 59 06 00 B4 59 06 00 04 5A 06 00 00 00 00 00 38 5A 06 00 64 5A 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DC 5A 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:18:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B8 09 81 80 9C 5A 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 23 45 67 89 AB CD EF 23 45 67 89 AB CD EF 01 45 67 89 AB CD EF 01 23 FF FF FF FF FF FF 00 00 00 00 00 00
9:18:25 AM
9:18:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 B9 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 53 6F 07 00 00 00 02 00 62 01 01 00 60 01 34 01 35 85 02 00 00 00 00 00 00 00 00 00 00 00 01 00 02 00 04 00 36 00 01 00 01 00 02 00 32 00 14 00 35 85 02 00 4D 85 02 00 77 85 02 00 00 00 00 00 00 00 00 00 00 00 02 00 08 00 0A 00 0C 00 02 00 06 00 02 00 01 00 02 00 77 85 02 00 37 86 02 00 77 85 02 00
9:18:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 BA 09 81 80 4D 85 02 00 77 85 02 00 00 00 08 00 0C 00 14 00 7C 00 80 00 84 00 88 00 8C 00 06 00 04 00 08 00 66 00 04 00 04 00 01 00 04 00 04 00 37 86 02 00 8D 85 02 00 00 00 00 00 00 00 00 00 8D 85 02 00 8D 85 02 00 41 85 02 00 8D 85 02 00 8D 85 02 00 00 00 08 00 40 00 5C 00 06 00 38 00 1C 00 44 00 37 86 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 00 2C 00 2A 00 02 00 0A 00 49 86 02 00
9:18:26 AM
9:18:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 BB 09 81 80 77 85 02 00 29 87 02 00 00 00 01 00 02 00 03 00 04 00 0D 00 16 00 1F 00 01 00 01 00 01 00 01 00 08 00 08 00 08 00 08 00 35 85 02 00 35 85 02 00 35 85 02 00 35 85 02 00 37 86 02 00 37 86 02 00 37 86 02 00 37 86 02 00 00 00 02 00 01 00 06 00 04 00 08 00 0A 00 0C 00 01 00 01 00 01 00 02 00 02 00 02 00 02 00 02 00 35 85 02 00 4D 85 02 00 4D 85 02 00 77 85 02 00 77 85 02 00 77 85 02 00
9:18:27 AM
9:18:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 BC 09 81 80 77 85 02 00 77 85 02 00 00 80 00 00 01 00 00 FF 08 00 1F 00 91 00 1F 00 91 00 01 FD 00 00 02 00 00 FF 1B 00 1F 00 91 00 1F 00 D9 00 04 FD 00 00 02 01 00 FF 1D 00 1F 00 91 00 1F 00 D9 00 02 FD 00 00 02 02 00 FF 1C 00 1F 00 91 00 1F 00 D9 00 07 90 00 00 0A 00 00 FF 09 00 17 00 BA 01 17 00 B9 01 00 90 00 00 0A 00 01 FF 09 00 17 00 BA 00 17 00 F9 00 01 90 00 00 0A 00 64 FF 09 00 1F 00
9:18:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 BD 09 81 80 91 00 1F 00 D9 00 02 90 00 00 0A 00 65 FF 09 00 17 00 BA 00 17 00 F9 00 03 90 00 00 0A 00 66 FF 09 00 17 00 BA 00 17 00 F9 00 05 91 00 00 0A 00 67 FF 09 00 17 02 B9 00 17 02 F9 00 81 90 00 00 0A 00 6B FF 09 00 1F 00 B9 00 1F 00 F9 00 84 91 00 00 0A 00 6C FF 09 00 1F 00 91 00 1F 00 D9 00 04 93 00 00 0A 00 FB FF 09 00 17 00 B9 00 17 00 F9 00 81 91 00 00 0A 00 FD FF 09 00 17 00 B9 01
9:18:28 AM
9:18:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 BE 09 81 80 17 00 B9 01 82 91 00 00 0A 00 FE FF 09 00 17 00 79 00 17 00 F9 00 80 91 00 00 0A 01 00 FF 09 00 17 00 BA 01 17 00 B9 01 07 91 00 00 0A 01 FA FF 09 00 17 02 B9 00 17 02 F9 00 05 90 00 00 0A 01 FD FF 09 00 17 00 BA 01 17 00 B9 01 04 90 00 00 0A 01 FE FF 09 00 19 00 BE 01 19 00 BE 01 00 91 00 00 0A 02 FE FF 09 00 19 00 BE 01 19 00 BE 01 06 91 00 00 0A 03 65 FF 09 00 17 00 B9 01 17 00
9:18:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 BF 09 81 80 B9 01 01 93 00 00 0A 04 65 FF 09 00 19 00 BE 01 19 00 BE 01 02 93 00 00 0A 05 65 FF 09 00 1F 00 79 00 1F 00 F9 00 00 B0 00 00 0B 00 00 FF 0B 00 1F 00 91 00 1F 00 D9 00 00 F5 00 00 0D 00 00 FF 14 00 1F 00 91 00 1F 00 D9 00 00 60 00 00 0E 00 01 FF 06 00 1F 00 91 00 1F 00 D9 00 01 60 00 00 0E 00 02 FF 06 00 1F 00 91 00 1F 00 D9 00 00 F7 00 00 0F 00 00 FF 16 00 1F 00 91 00 1F 00 D9 00
9:18:29 AM
9:18:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C0 09 81 80 04 F7 00 00 0F 00 02 FF 16 00 1F 00 91 00 1F 00 D9 00 86 F6 00 00 10 01 00 FF 15 00 1F 00 91 00 1F 00 D9 00 87 F6 00 00 10 01 01 FF 15 00 1F 00 91 00 1F 00 D9 00 00 F4 00 00 14 00 00 FF 13 00 17 00 92 00 17 00 D9 00 04 70 00 00 15 00 00 FF 07 00 1F 00 D9 00 1F 00 D9 00 05 70 00 00 15 00 01 FF 07 00 1F 00 D9 00 1F 00 D9 00 06 70 00 00 15 00 02 FF 07 00 1F 00 D9 00 1F 00 D9 00 83 74
9:18:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C1 09 81 80 00 00 15 00 05 FF 07 00 1F 00 D9 00 1F 00 D9 00 00 F8 00 00 16 00 00 FF 17 00 1F 00 91 00 1F 00 D9 00 01 FE 00 00 19 00 00 FF 29 00 1F 00 91 00 1F 00 D9 00 02 FE 00 00 19 01 00 FF 2A 00 1F 00 91 00 1F 00 D9 00 04 FE 00 00 19 03 00 FF 2C 00 1F 00 91 00 1F 00 D9 00 05 FE 00 00 19 04 00 FF 2D 00 1F 00 91 00 1F 00 D9 00 00 FC 00 00 19 09 00 FF 28 00 1F 00 91 00 1F 00 D9 00 00 F0 00 00
9:18:30 AM
9:18:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C2 09 81 80 28 00 00 FF 0F 00 FF 00 90 00 FF 00 D8 00 00 F2 00 00 29 00 00 FF 11 00 FF 00 B8 00 FF 00 F8 00 01 18 00 00 2A 00 00 FF 01 00 FF 00 B8 00 FF 00 F8 00 03 FF 00 00 2B 00 00 FF 40 00 17 00 92 00 17 00 D9 00 05 FF 00 00 2B 00 02 FF 40 00 17 00 92 00 17 00 D9 00 80 05 00 00 2B 01 00 FF 01 00 FF 00 B0 01 FF 00 B0 01 81 05 00 00 2B 01 01 FF 01 00 FF 00 B0 01 FF 00 B0 01 80 06 00 00 2B 01
9:18:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C3 09 81 80 02 FF 01 00 FF 00 B0 01 FF 00 B0 01 06 FF 00 00 2C 00 00 FF 12 00 1F 00 91 00 1F 00 D9 00 00 11 00 00 60 01 00 FF 01 00 1F 00 F1 00 1F 00 F1 00 01 11 00 00 60 01 01 FF 01 00 1F 00 91 00 1F 00 D9 00 02 11 00 00 60 01 02 FF 01 00 1F 00 91 00 1F 00 D9 00 03 11 00 00 60 01 03 FF 01 00 1F 00 91 00 1F 00 D9 00 04 11 00 00 60 01 04 FF 01 00 1F 00 91 00 1F 00 D9 00 05 11 00 00 60 01 05 FF
9:18:31 AM
9:18:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C4 09 81 80 01 00 1F 00 B1 00 1F 00 F1 00 06 11 00 00 60 01 06 FF 01 00 1F 00 91 00 1F 00 D9 00 07 11 00 00 60 01 07 FF 01 00 1F 00 91 00 1F 00 D9 00 80 11 00 00 60 01 08 FF 01 00 1F 00 91 00 1F 00 D9 00 06 13 00 00 60 02 00 FF 01 00 17 00 7A 00 17 00 F9 00 07 13 00 00 60 02 01 FF 01 00 1F 00 79 00 1F 00 F9 00 86 19 00 00 60 02 04 FF 01 00 17 00 BA 00 17 00 F9 00 87 07 00 00 60 03 00 FF 01 00
9:18:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C5 09 81 80 1F 00 79 00 1F 00 F9 00 81 14 00 00 60 03 01 FF 01 00 1F 00 79 00 1F 00 F9 00 82 14 00 00 60 03 02 FF 01 00 1F 00 79 00 1F 00 F9 00 87 13 00 00 60 03 03 FF 01 00 1F 00 79 00 1F 00 F9 00 00 0F 00 00 60 04 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 01 0F 00 00 60 04 01 FF 01 00 1F 00 B9 00 1F 00 F9 00 02 0F 00 00 60 04 02 FF 01 00 1F 00 B9 00 1F 00 F9 00 03 0F 00 00 60 04 03 FF 01 00 1F 00
9:18:32 AM
9:18:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C6 09 81 80 B9 00 1F 00 F9 00 04 0F 00 00 60 04 04 FF 01 00 1F 00 B9 00 1F 00 F9 00 06 15 00 00 60 05 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 84 0E 00 00 60 05 01 FF 01 00 1F 00 B9 00 1F 00 F9 00 85 0E 00 00 60 05 02 FF 01 00 1F 00 B9 00 1F 00 F9 00 86 0E 00 00 60 05 03 FF 01 00 1F 00 B9 00 1F 00 F9 00 87 0E 00 00 60 05 04 FF 01 00 1F 00 B9 00 1F 00 F9 00 86 14 00 00 60 06 00 FF 03 00 1F 00 B1 00
9:18:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C7 09 81 80 1F 00 F1 00 00 0A 00 00 60 06 05 FF 01 00 1F 00 F1 01 1F 00 F1 01 87 14 00 00 60 06 06 FF 03 00 1F 00 B1 00 1F 00 F1 00 07 16 00 00 60 07 00 FF 01 00 1F 00 79 00 1F 00 F9 00 04 16 00 00 60 07 01 FF 01 00 1F 00 79 00 1F 00 F9 00 05 16 00 00 60 07 02 FF 01 00 1F 00 79 00 1F 00 F9 00 06 16 00 00 60 07 03 FF 01 00 1F 00 79 00 1F 00 F9 00 80 15 00 00 60 07 05 FF 01 00 1F 00 79 00 1F 00
9:18:33 AM
9:18:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C8 09 81 80 F9 00 81 15 00 00 60 07 06 FF 01 00 1F 00 79 00 1F 00 F9 00 82 15 00 00 60 07 07 FF 01 00 1F 00 79 00 1F 00 F9 00 83 15 00 00 60 07 08 FF 01 00 1F 00 79 00 1F 00 F9 00 84 16 00 00 60 07 09 FF 01 00 1F 00 79 00 1F 00 F9 00 84 15 00 00 60 07 0A FF 01 00 1F 00 79 00 1F 00 F9 00 85 15 00 00 60 07 0B FF 01 00 1F 00 79 00 1F 00 F9 00 86 15 00 00 60 07 0C FF 01 00 1F 00 79 00 1F 00 F9 00
9:18:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 C9 09 81 80 87 15 00 00 60 07 0D FF 01 00 1F 00 79 00 1F 00 F9 00 85 16 00 00 60 07 0E FF 01 00 1F 00 79 00 1F 00 F9 00 80 16 00 00 60 07 0F FF 03 00 1F 00 79 00 1F 00 F9 00 81 16 00 00 60 07 10 FF 03 00 1F 00 79 00 1F 00 F9 00 82 16 00 00 60 07 11 FF 03 00 1F 00 79 00 1F 00 F9 00 83 16 00 00 60 07 12 FF 03 00 1F 00 79 00 1F 00 F9 00 86 16 00 00 60 07 13 FF 03 00 1F 00 79 00 1F 00 F9 00 03 18
9:18:34 AM
9:18:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 CA 09 81 80 00 00 60 07 14 FF 03 00 1F 00 91 00 1F 00 D9 00 04 18 00 00 60 07 15 FF 01 00 1F 00 F9 01 1F 00 F9 01 01 C7 00 00 60 08 00 FF 03 00 1F 00 F1 01 1F 00 F1 01 02 C7 00 00 60 08 01 FF 03 00 1F 00 F1 01 1F 00 F1 01 03 C7 00 00 60 08 02 FF 03 00 1F 00 F1 01 1F 00 F1 01 04 C7 00 00 60 08 03 FF 03 00 1F 00 F1 01 1F 00 F1 01 05 C7 00 00 60 08 04 FF 03 00 1F 00 F1 01 1F 00 F1 01 06 C7 00 00
9:18:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 CB 09 81 80 60 08 05 FF 03 00 1F 00 F1 01 1F 00 F1 01 07 C7 00 00 60 08 06 FF 03 00 1F 00 F1 01 1F 00 F1 01 80 C7 00 00 60 08 07 FF 03 00 1F 00 F1 01 1F 00 F1 01 81 C7 00 00 60 08 08 FF 03 00 1F 00 F1 01 1F 00 F1 01 00 19 00 00 60 0A 01 FF 01 00 1F 00 79 00 1F 00 F9 00 01 19 00 00 60 0A 02 FF 01 00 1F 00 79 00 1F 00 F9 00 02 19 00 00 60 0A 03 FF 01 00 1F 00 79 00 1F 00 F9 00 82 13 00 00 60 0A
9:18:35 AM
9:18:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 CC 09 81 80 80 FF 01 00 1F 00 79 00 1F 00 F9 00 01 00 00 00 60 0B 00 FF 01 00 1F 00 79 00 1F 00 F9 00 02 00 00 00 60 0B 01 FF 01 00 1F 00 79 00 1F 00 F9 00 05 00 00 00 60 0B 04 FF 01 00 1F 00 79 00 1F 00 F9 00 06 00 00 00 60 0B 05 FF 01 00 1F 00 79 00 1F 00 F9 00 07 00 00 00 60 0B 06 FF 01 00 1F 00 79 00 1F 00 F9 00 04 04 00 00 60 0B 07 FF 01 00 1F 00 79 00 1F 00 F9 00 05 04 00 00 60 0B 08 FF
9:18:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 CD 09 81 80 01 00 1F 00 79 00 1F 00 F9 00 87 00 00 00 60 0E 00 FF 01 00 1F 00 79 00 1F 00 F9 00 86 01 00 00 60 0E 01 FF 01 00 1F 00 79 00 1F 00 F9 00 04 60 00 00 60 0E 0B FF 01 00 1F 00 91 00 1F 00 D9 00 80 03 00 00 60 0F 00 FF 01 00 17 00 BA 00 17 00 F9 00 82 03 00 00 60 3F 0A FF 01 00 17 00 BA 00 17 00 F9 00 00 16 00 00 60 60 00 FF 01 00 1F 00 79 00 1F 00 F9 00 85 04 00 00 60 80 00 FF 01 00
9:18:36 AM
9:18:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 CE 09 81 80 1F 00 FB 00 1F 00 F9 00 86 04 00 00 60 80 01 FF 01 00 1F 00 F9 00 1F 00 F9 00 87 04 00 00 60 80 02 FF 01 00 1F 00 FB 00 1F 00 F9 00 00 15 00 00 61 61 00 FF 01 00 17 00 92 00 17 00 D9 00 83 19 00 00 61 62 00 FF 01 00 17 00 92 00 17 00 D9 00 83 01 00 00 61 62 01 FF 01 00 17 00 92 00 17 00 D9 00 80 19 00 00 61 62 0A FF 01 00 17 00 92 00 17 00 D9 00 80 01 00 00 61 62 0B FF 01 00 17 00
9:18:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 CF 09 81 80 92 00 17 00 D9 00 00 0B 00 00 61 62 14 FF 01 00 1F 00 91 00 1F 00 D9 00 01 0B 00 00 61 62 15 FF 01 00 1F 00 91 00 1F 00 D9 00 07 70 00 00 62 01 00 FF 07 00 1F 00 91 00 1F 00 D9 00 02 70 00 00 63 62 00 FF 07 00 17 00 B2 00 17 00 F1 00 03 71 00 00 63 62 01 FF 07 00 17 00 B2 00 17 00 F1 00 06 72 00 00 63 62 04 FF 07 00 17 00 B2 00 17 00 F1 00 04 74 00 00 63 62 05 FF 07 00 17 00 B2 00
9:18:37 AM
9:18:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D0 09 81 80 17 00 F1 00 05 74 00 00 63 62 06 FF 07 00 17 00 B2 00 17 00 F1 00 06 74 00 00 63 62 07 FF 07 00 17 00 B2 00 17 00 F1 00 07 74 00 00 63 62 08 FF 07 00 17 00 B2 00 17 00 F1 00 01 16 00 00 80 01 00 FF 01 00 17 00 B1 01 17 00 B1 01 02 16 00 00 80 01 01 FF 01 00 17 00 B1 01 17 00 B1 01 87 2F 00 00 80 01 02 FF 01 00 17 00 B1 01 17 00 B1 01 83 2F 00 00 80 01 03 FF 01 00 17 00 B1 01 17 00
9:18:38 AM
9:18:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D1 09 81 80 B1 01 03 12 00 00 80 02 00 FF 01 00 1F 00 51 00 1F 00 D9 00 05 12 00 00 80 02 01 FF 01 00 1F 00 51 00 1F 00 D9 00 06 12 00 00 80 02 02 FF 01 00 1F 00 51 00 1F 00 D9 00 07 12 00 00 80 02 03 FF 01 00 1F 00 51 00 1F 00 D9 00 07 0F 00 00 80 02 04 FF 01 00 1F 00 E1 01 1F 00 D9 01 84 0A 00 00 80 04 04 FF 01 00 17 00 E1 01 17 00 E1 01 06 2C 00 00 80 05 00 FF 01 00 17 00 F9 01 17 00 F9 01
9:18:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D2 09 81 80 84 2C 00 00 80 05 01 FF 01 00 17 00 F1 01 17 00 F1 01 85 2C 00 00 80 05 02 FF 01 00 17 00 F1 01 17 00 F1 01 86 2C 00 00 80 05 03 FF 01 00 17 00 F1 01 17 00 F1 01 87 2C 00 00 80 05 04 FF 01 00 17 00 F9 01 17 00 F9 01 00 2D 00 00 80 05 05 FF 01 00 17 00 F1 01 17 00 F1 01 01 2D 00 00 80 05 06 FF 01 00 17 00 F1 01 17 00 F1 01 02 2D 00 00 80 05 07 FF 01 00 17 00 F9 01 17 00 F9 01 03 2D
9:18:39 AM
9:18:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D3 09 81 80 00 00 80 05 08 FF 01 00 17 00 F1 01 17 00 F1 01 04 2D 00 00 80 05 09 FF 01 00 17 00 F1 01 17 00 F1 01 05 2D 00 00 80 05 0A FF 01 00 17 00 F1 01 17 00 F1 01 06 2D 00 00 80 05 0B FF 01 00 17 00 F1 01 17 00 F1 01 03 16 00 00 80 06 00 FF 01 00 1F 00 79 00 1F 00 F9 00 87 16 00 00 80 06 01 FF 01 00 1F 00 79 00 1F 00 F9 00 03 FB 00 00 80 06 0A FF 01 00 1F 02 79 00 1F 02 F9 00 04 FB 00 00
9:18:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D4 09 81 80 80 06 0B FF 01 00 1F 02 79 00 1F 02 F9 00 05 FB 00 00 80 06 0C FF 01 00 1F 02 79 00 1F 02 F9 00 06 FB 00 00 80 06 0D FF 01 00 1F 02 79 00 1F 02 F9 00 07 FB 00 00 80 06 0E FF 01 00 1F 02 79 00 1F 02 F9 00 80 FB 00 00 80 06 0F FF 01 00 1F 02 79 00 1F 02 F9 00 81 FB 00 00 80 06 10 FF 01 00 1F 02 79 00 1F 02 F9 00 82 FB 00 00 80 06 11 FF 01 00 1F 02 79 00 1F 02 F9 00 83 FB 00 00 80 06
9:18:40 AM
9:18:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D5 09 81 80 12 FF 01 00 1F 02 79 00 1F 02 F9 00 00 20 00 00 80 07 0B FF 01 00 1F 00 91 00 1F 00 D9 00 01 20 00 00 80 07 0C FF 01 00 1F 00 91 00 1F 00 D9 00 02 20 00 00 80 07 0D FF 01 00 1F 00 91 00 1F 00 D9 00 03 20 00 00 80 07 0E FF 01 00 1F 00 91 00 1F 00 D9 00 04 20 00 00 80 07 0F FF 01 00 1F 00 91 00 1F 00 D9 00 05 20 00 00 80 07 10 FF 01 00 1F 00 91 00 1F 00 D9 00 06 20 00 00 80 07 11 FF
9:18:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D6 09 81 80 01 00 1F 00 91 00 1F 00 D9 00 80 20 00 00 80 07 15 FF 01 00 1F 00 91 00 1F 00 D9 00 81 20 00 00 80 07 16 FF 01 00 1F 00 91 00 1F 00 D9 00 82 20 00 00 80 07 17 FF 01 00 1F 00 91 00 1F 00 D9 00 83 20 00 00 80 07 18 FF 01 00 1F 00 91 00 1F 00 D9 00 84 20 00 00 80 07 19 FF 01 00 1F 00 91 00 1F 00 D9 00 85 20 00 00 80 07 1A FF 01 00 1F 00 91 00 1F 00 D9 00 86 20 00 00 80 07 1B FF 01 00
9:18:41 AM
9:18:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D7 09 81 80 1F 00 91 00 1F 00 D9 00 00 21 00 00 80 07 1F FF 01 00 1F 00 91 00 1F 00 D9 00 01 21 00 00 80 07 20 FF 01 00 1F 00 91 00 1F 00 D9 00 02 21 00 00 80 07 21 FF 01 00 1F 00 91 00 1F 00 D9 00 03 21 00 00 80 07 22 FF 01 00 1F 00 91 00 1F 00 D9 00 04 21 00 00 80 07 23 FF 01 00 1F 00 91 00 1F 00 D9 00 05 21 00 00 80 07 24 FF 01 00 1F 00 91 00 1F 00 D9 00 06 21 00 00 80 07 25 FF 01 00 1F 00
9:18:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D8 09 81 80 91 00 1F 00 D9 00 80 21 00 00 80 07 29 FF 01 00 1F 00 91 00 1F 00 D9 00 81 21 00 00 80 07 2A FF 01 00 1F 00 91 00 1F 00 D9 00 82 21 00 00 80 07 2B FF 01 00 1F 00 91 00 1F 00 D9 00 83 21 00 00 80 07 2C FF 01 00 1F 00 91 00 1F 00 D9 00 84 21 00 00 80 07 2D FF 01 00 1F 00 91 00 1F 00 D9 00 85 21 00 00 80 07 2E FF 01 00 1F 00 91 00 1F 00 D9 00 86 21 00 00 80 07 2F FF 01 00 1F 00 91 00
9:18:42 AM
9:18:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 D9 09 81 80 1F 00 D9 00 01 23 00 00 80 07 32 FF 03 00 1F 00 E1 01 1F 00 D9 01 02 23 00 00 80 07 33 FF 03 00 1F 00 E1 01 1F 00 D9 01 80 C1 00 00 80 07 34 FF 03 00 1F 00 E1 01 1F 00 D9 01 82 C1 00 00 80 07 3C FF 03 00 1F 00 E1 01 1F 00 D9 01 80 C2 00 00 80 07 3D FF 03 00 1F 00 E1 01 1F 00 D9 01 81 C2 00 00 80 07 3E FF 03 00 1F 00 E1 01 1F 00 D9 01 85 C1 00 00 80 07 46 FF 03 00 1F 00 E1 01 1F 00
9:18:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 DA 09 81 80 D9 01 85 C2 00 00 80 07 47 FF 03 00 1F 00 E1 01 1F 00 D9 01 82 C2 00 00 80 07 48 FF 03 00 1F 00 E1 01 1F 00 D9 01 86 C1 00 00 80 07 50 FF 03 00 1F 00 E1 01 1F 00 D9 01 87 C2 00 00 80 07 51 FF 03 00 1F 00 E1 01 1F 00 D9 01 81 C1 00 00 80 07 5A FF 03 00 1F 00 E1 01 1F 00 D9 01 02 C3 00 00 80 07 64 FF 03 00 1F 00 E1 01 1F 00 D9 01 03 C3 00 00 80 07 6E FF 03 00 1F 00 E1 01 1F 00 D9 01
9:18:43 AM
9:18:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 DB 09 81 80 02 C2 00 00 80 07 6F FF 03 00 1F 00 E1 01 1F 00 D9 01 04 C3 00 00 80 07 78 FF 03 00 1F 00 E1 01 1F 00 D9 01 03 C2 00 00 80 07 79 FF 03 00 1F 00 E1 01 1F 00 D9 01 00 22 00 00 80 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 22 00 00 80 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 22 00 00 80 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 22 00 00 80 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 22
9:18:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 DC 09 81 80 00 00 80 08 0A FF 03 00 1F 00 79 00 1F 00 F9 00 05 22 00 00 80 08 0B FF 03 00 1F 00 79 00 1F 00 F9 00 06 22 00 00 80 08 0C FF 03 00 1F 00 79 00 1F 00 F9 00 07 22 00 00 80 08 0D FF 03 00 1F 00 79 00 1F 00 F9 00 80 22 00 00 80 08 14 FF 03 00 1F 00 79 00 1F 00 F9 00 81 22 00 00 80 08 15 FF 03 00 1F 00 79 00 1F 00 F9 00 82 22 00 00 80 08 16 FF 03 00 1F 00 79 00 1F 00 F9 00 83 22 00 00
9:18:44 AM
9:18:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 DD 09 81 80 80 08 17 FF 03 00 1F 00 79 00 1F 00 F9 00 84 22 00 00 80 08 1E FF 03 00 1F 00 79 00 1F 00 F9 00 85 22 00 00 80 08 1F FF 03 00 1F 00 79 00 1F 00 F9 00 86 22 00 00 80 08 20 FF 03 00 1F 00 79 00 1F 00 F9 00 87 22 00 00 80 08 21 FF 03 00 1F 00 79 00 1F 00 F9 00 00 23 00 00 80 08 32 FF 01 00 17 00 E1 01 17 00 D9 01 00 17 00 00 80 0A 00 FF 01 00 1F 00 91 00 1F 00 D9 00 01 17 00 00 80 0A
9:18:45 AM
9:18:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 DE 09 81 80 01 FF 01 00 1F 00 91 00 1F 00 D9 00 02 09 00 00 80 0A 02 FF 01 00 1F 00 91 00 1F 00 D9 00 03 09 00 00 80 0A 03 FF 01 00 1F 00 91 00 1F 00 D9 00 06 18 00 00 80 0A 0A FF 01 00 1F 00 91 00 1F 00 D9 00 04 09 00 00 80 0A 0C FF 01 00 1F 00 91 00 1F 00 D9 00 05 09 00 00 80 0A 0D FF 01 00 1F 00 91 00 1F 00 D9 00 83 09 00 00 80 0A 14 FF 01 00 1F 00 B1 00 1F 00 F1 00 80 0F 00 00 80 0B 00 FF
9:18:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 DF 09 81 80 01 00 1F 00 E1 01 1F 00 D9 01 81 0F 00 00 80 0B 01 FF 01 00 1F 00 E1 01 1F 00 D9 01 82 0F 00 00 80 0B 02 FF 01 00 1F 00 F1 01 1F 00 F1 01 84 0F 00 00 80 0B 03 FF 01 00 1F 00 E1 01 1F 00 D9 01 85 0F 00 00 80 0B 04 FF 01 00 1F 00 E1 01 1F 00 D9 01 01 1A 00 00 80 14 00 FF 01 00 1F 00 91 00 1F 00 D9 00 02 1A 00 00 80 14 01 FF 01 00 1F 00 91 00 1F 00 D9 00 87 19 00 00 80 14 02 FF 01 00
9:18:46 AM
9:18:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E0 09 81 80 1F 00 F9 01 1F 00 F9 01 00 1A 00 00 80 14 03 FF 01 00 1F 00 F9 01 1F 00 F9 01 00 2E 00 00 80 14 04 FF 01 00 1F 00 F9 01 1F 00 F9 01 01 2E 00 00 80 14 05 FF 01 00 1F 00 F9 01 1F 00 F9 01 02 2E 00 00 80 14 06 FF 01 00 1F 00 F9 01 1F 00 F9 01 03 2E 00 00 80 14 07 FF 01 00 1F 00 F9 01 1F 00 F9 01 04 2E 00 00 80 14 08 FF 01 00 1F 00 F9 01 1F 00 F9 01 05 2E 00 00 80 14 09 FF 01 00 1F 00
9:18:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E1 09 81 80 F9 01 1F 00 F9 01 04 1A 00 00 80 14 0B FF 01 00 1F 00 91 00 1F 00 D9 00 05 1A 00 00 80 14 0C FF 01 00 1F 00 91 00 1F 00 D9 00 84 2F 00 00 80 14 1E FF 03 00 1F 00 A1 01 1F 00 99 01 85 2F 00 00 80 15 00 FF 01 00 1F 00 F9 01 1F 00 F9 01 82 2F 00 00 80 15 01 FF 01 00 1F 00 F1 01 1F 00 F1 01 80 0A 00 00 80 16 00 FF 01 00 1F 00 91 00 1F 00 D9 00 81 0A 00 00 80 16 01 FF 01 00 1F 00 91 00
9:18:47 AM
9:18:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E2 09 81 80 1F 00 D9 00 82 0A 00 00 80 17 00 FF 01 00 1F 00 91 00 1F 00 D9 00 83 0A 00 00 80 17 01 FF 01 00 1F 00 91 00 1F 00 D9 00 80 1A 00 00 80 1E 00 FF 01 00 1F 02 91 00 1F 02 D9 00 82 1A 00 00 80 1E 02 FF 01 00 1F 02 91 00 1F 02 D9 00 83 1A 00 00 80 1E 03 FF 01 00 1F 02 91 00 1F 02 D9 00 08 E5 00 00 80 1E 09 FF 01 00 1F 02 91 00 1F 02 D9 00 00 14 00 00 80 28 00 FF 01 00 17 00 BE 01 17 00
9:18:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E3 09 81 80 BE 01 01 14 00 00 80 28 01 FF 01 00 17 00 BE 01 17 00 BE 01 02 14 00 00 80 28 02 FF 01 00 17 00 BE 01 17 00 BE 01 03 14 00 00 80 28 03 FF 01 00 17 00 BE 01 17 00 BE 01 04 14 00 00 80 28 04 FF 01 00 17 00 BE 01 17 00 BE 01 05 14 00 00 80 28 05 FF 01 00 17 00 BE 01 17 00 BE 01 86 13 00 00 80 28 06 FF 01 00 17 00 BE 01 17 00 BE 01 86 13 00 00 80 28 07 FF 01 00 17 00 BE 01 17 00 BE 01
9:18:48 AM
9:18:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E4 09 81 80 06 14 00 00 80 29 00 FF 01 00 17 00 B6 01 17 00 B6 01 07 14 00 00 80 29 01 FF 01 00 17 00 BE 01 17 00 BE 01 00 09 00 00 80 2B 00 FF 01 00 17 00 B6 01 17 00 B6 01 01 09 00 00 80 2B 01 FF 01 00 17 00 BE 01 17 00 BE 01 00 01 00 00 80 46 00 FF 01 00 1F 00 B1 01 1F 00 B1 01 01 01 00 00 80 46 01 FF 01 00 1F 00 B1 01 1F 00 B1 01 80 FA 00 00 80 4B 00 FF 01 00 1F 00 D9 00 1F 00 D9 00 87 11
9:18:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E5 09 81 80 00 00 80 50 00 FF 01 00 1F 00 F7 01 1F 00 F7 01 87 7F 00 00 80 5A 00 FF 01 00 1F 00 B1 01 1F 00 B1 01 86 11 00 00 80 5A 01 FF 01 00 1F 00 B1 01 1F 00 B1 01 01 27 00 00 80 64 01 FF 01 00 17 00 DB 00 17 00 D9 00 02 27 00 00 80 64 02 FF 01 00 17 00 DB 00 17 00 DA 00 03 27 00 00 80 64 03 FF 01 00 17 00 24 01 17 00 DB 00 04 27 00 00 80 64 04 FF 01 00 17 00 24 01 17 00 DB 00 80 27 00 00
9:18:49 AM
9:18:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E6 09 81 80 80 64 0A FF 01 00 17 00 B6 01 17 00 B6 01 81 27 00 00 80 64 14 FF 01 00 17 00 B6 01 17 00 B6 01 82 27 00 00 80 64 15 FF 01 00 17 00 B6 01 17 00 B6 01 83 27 00 00 80 64 16 FF 01 00 17 00 B6 01 17 00 B6 01 80 12 00 00 80 66 00 FF 01 00 1F 00 79 00 1F 00 F9 00 81 12 00 00 80 66 01 FF 01 00 1F 00 79 00 1F 00 F9 00 80 18 00 00 80 67 00 FF 01 00 1F 00 79 00 1F 00 F9 00 81 18 00 00 80 67
9:18:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E7 09 81 80 01 FF 01 00 1F 00 79 00 1F 00 F9 00 82 18 00 00 80 67 02 FF 01 00 1F 00 91 00 1F 00 D9 00 00 E5 00 00 80 68 00 FF 01 00 1F 00 B1 01 1F 00 B1 01 84 CF 00 00 80 80 81 FF 01 00 19 00 B6 01 19 00 B6 01 83 14 00 00 C4 00 00 FF 01 00 17 00 B1 01 17 00 B1 01 04 3A 00 00 C4 00 01 FF 01 00 17 00 B1 01 17 00 B1 01 07 2C 00 00 C4 00 03 FF 01 00 17 00 B1 01 17 00 B1 01 86 18 00 00 C4 00 0A FF
9:18:50 AM
9:18:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E8 09 81 80 01 00 17 00 B1 01 17 00 B1 01 87 18 00 00 C4 00 0B FF 01 00 17 00 B1 01 17 00 B1 01 80 2C 00 00 C4 00 14 FF 01 00 17 00 B1 01 17 00 B1 01 81 2C 00 00 C4 00 15 FF 01 00 17 00 B1 01 17 00 B1 01 82 2C 00 00 C4 00 16 FF 01 00 17 00 B1 01 17 00 B1 01 83 2C 00 00 C4 00 17 FF 01 00 17 00 B1 01 17 00 B1 01 01 26 00 00 C4 01 00 FF 01 00 1F 00 A1 00 1F 00 D9 00 02 26 00 00 C4 01 01 FF 01 00
9:18:51 AM
9:18:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 E9 09 81 80 1F 00 A1 00 1F 00 D9 00 04 26 00 00 C4 01 03 FF 01 00 1F 00 A1 00 1F 00 D9 00 05 26 00 00 C4 01 04 FF 01 00 1F 00 A1 00 1F 00 D9 00 07 26 00 00 C4 01 05 FF 01 00 1F 00 A1 00 1F 00 D9 00 80 26 00 00 C4 01 06 FF 01 00 1F 00 A1 00 1F 00 D9 00 81 26 00 00 C4 01 07 FF 01 00 1F 00 A1 00 1F 00 D9 00 83 26 00 00 C4 01 08 FF 01 00 1F 00 A1 00 1F 00 D9 00 84 26 00 00 C4 01 09 FF 01 00 1F 00
9:18:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 EA 09 81 80 A1 00 1F 00 D9 00 06 26 00 00 C4 01 0A FF 01 00 1F 00 A1 00 1F 00 D9 00 85 26 00 00 C4 01 0B FF 01 00 1F 00 A1 00 1F 00 D9 00 82 26 00 00 C4 01 14 FF 01 00 1F 00 A1 00 1F 00 D9 00 00 07 00 00 C4 03 01 FF 01 00 1F 00 A1 00 1F 00 D9 00 01 07 00 00 C4 03 02 FF 01 00 1F 00 A1 00 1F 00 D9 00 02 07 00 00 C4 03 03 FF 01 00 1F 00 A1 00 1F 00 D9 00 03 07 00 00 C4 03 04 FF 01 00 1F 00 A1 00
9:18:52 AM
9:18:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 EB 09 81 80 1F 00 D9 00 04 07 00 00 C4 03 05 FF 01 00 1F 00 A1 00 1F 00 D9 00 05 07 00 00 C4 03 06 FF 01 00 1F 00 A1 00 1F 00 D9 00 06 07 00 00 C4 03 07 FF 01 00 1F 00 A1 00 1F 00 D9 00 07 07 00 00 C4 03 08 FF 01 00 1F 00 A1 00 1F 00 D9 00 80 07 00 00 C4 03 09 FF 01 00 1F 00 A1 00 1F 00 D9 00 81 07 00 00 C4 03 0A FF 01 00 1F 00 A1 00 1F 00 D9 00 82 07 00 00 C4 03 0B FF 01 00 1F 00 A1 00 1F 00
9:18:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 EC 09 81 80 D9 00 83 07 00 00 C4 03 0C FF 01 00 1F 00 A1 00 1F 00 D9 00 84 07 00 00 C4 03 0D FF 01 00 1F 00 A1 00 1F 00 D9 00 85 07 00 00 C4 03 1E FF 01 00 1F 00 B1 01 1F 00 B1 01 86 07 00 00 C4 03 1F FF 01 00 1F 00 B1 01 1F 00 B1 01 05 18 00 00 C4 03 28 FF 01 00 1F 00 B9 00 1F 00 F9 00 00 C7 00 00 C4 08 00 FF 03 00 1F 00 F1 01 1F 00 F1 01 01 15 00 00 C4 61 00 FF 01 00 1F 00 99 00 1F 00 D9 00
9:18:53 AM
9:18:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 ED 09 81 80 02 15 00 00 C4 61 0A FF 01 00 1F 00 A1 00 1F 00 D9 00 00 02 00 00 C4 62 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 01 02 00 00 C4 62 01 FF 01 00 1F 00 B9 00 1F 00 F9 00 02 02 00 00 C4 62 02 FF 01 00 1F 00 91 00 1F 00 D9 00 03 02 00 00 C4 62 03 FF 01 00 1F 00 B1 00 1F 00 F1 00 04 02 00 00 C4 62 04 FF 01 00 1F 00 B9 00 1F 00 F9 00 05 02 00 00 C4 62 05 FF 01 00 1F 00 B9 00 1F 00 F9 00 80 F7
9:18:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 EE 09 81 80 00 01 0F 00 04 FF 16 00 1F 00 91 00 1F 00 D9 00 00 FB 00 01 10 00 00 FF 15 00 1F 02 91 00 1F 02 D9 00 01 F4 00 01 14 00 00 FF 13 00 17 00 92 00 17 00 D9 00 01 F8 00 01 16 00 00 FF 17 00 1F 00 91 00 17 00 D9 00 01 FC 00 01 19 09 00 FF 28 00 1F 00 91 00 17 00 D9 00 00 FA 00 01 60 03 0A FF 46 00 1F 02 91 00 1F 02 D9 00 83 13 00 01 60 0A 80 FF 01 00 1F 00 79 00 1F 00 F9 00 02 01 00 01
9:18:54 AM
9:18:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 EF 09 81 80 80 46 00 FF 01 00 1F 00 B1 01 1F 00 B1 01 03 01 00 01 80 46 01 FF 01 00 1F 00 B1 01 1F 00 B1 01 81 FA 00 01 80 4B 00 FF 01 00 1F 00 D9 00 1F 00 D9 00 84 27 00 01 80 64 0A FF 01 00 17 00 B6 01 17 00 B6 01 85 27 00 01 80 64 14 FF 01 00 17 00 B6 01 17 00 B6 01 86 27 00 01 80 64 15 FF 01 00 17 00 B6 01 17 00 B6 01 87 27 00 01 80 64 16 FF 01 00 17 00 B6 01 17 00 B6 01 80 02 00 01 C4 62
9:18:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F0 09 81 80 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 81 02 00 01 C4 62 01 FF 01 00 1F 00 B9 00 1F 00 F9 00 82 02 00 01 C4 62 02 FF 01 00 1F 00 91 00 1F 00 D9 00 83 02 00 01 C4 62 03 FF 01 00 1F 00 B1 00 1F 00 F1 00 84 02 00 01 C4 62 04 FF 01 00 1F 00 B9 00 1F 00 F9 00 85 02 00 01 C4 62 05 FF 01 00 1F 00 B9 00 1F 00 F9 00 81 F7 00 02 0F 00 04 FF 16 00 1F 00 91 00 1F 00 D9 00 01 FB 00 02 10 00 00 FF
9:18:55 AM
9:18:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F1 09 81 80 15 00 1F 02 91 00 1F 02 D9 00 02 F4 00 02 14 00 00 FF 13 00 17 00 92 00 17 00 D9 00 02 F8 00 02 16 00 00 FF 17 00 1F 00 91 00 1F 00 D9 00 02 FC 00 02 19 09 00 FF 28 00 1F 00 91 00 1F 00 D9 00 84 13 00 02 60 0A 80 FF 01 00 1F 00 79 00 1F 00 F9 00 04 01 00 02 80 46 00 FF 01 00 1F 00 B1 01 1F 00 B1 01 05 01 00 02 80 46 01 FF 01 00 1F 00 B1 01 1F 00 B1 01 82 FA 00 02 80 4B 00 FF 01 00
9:18:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F2 09 81 80 1F 00 D9 00 1F 00 D9 00 82 F7 00 03 0F 00 04 FF 16 00 1F 00 91 00 1F 00 D9 00 02 FB 00 03 10 00 00 FF 15 00 1F 02 91 00 1F 02 D9 00 03 F4 00 03 14 00 00 FF 13 00 17 00 92 00 17 00 D9 00 03 F8 00 03 16 00 00 FF 17 00 1F 00 91 00 1F 00 D9 00 03 FC 00 03 19 09 00 FF 28 00 1F 00 91 00 1F 00 D9 00 85 13 00 03 60 0A 80 FF 01 00 1F 00 79 00 1F 00 F9 00 06 01 00 03 80 46 00 FF 01 00 1F 00
9:18:56 AM
9:18:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F3 09 81 80 B1 01 1F 00 B1 01 07 01 00 03 80 46 01 FF 01 00 1F 00 B1 01 1F 00 B1 01 83 FA 00 03 80 4B 00 FF 01 00 1F 00 D9 00 1F 00 D9 00 04 FC 00 04 19 09 00 FF 28 00 1F 00 91 00 1F 00 D9 00 07 FC 00 07 19 09 00 FF 28 00 1F 00 91 00 1F 00 D9 00 00 10 01 00 00 00 00 FF 01 00 1F 00 91 00 1F 00 D9 00 05 17 01 00 00 01 00 FF 01 00 1F 00 79 00 1F 00 F9 00 07 17 01 00 00 01 02 FF 01 00 1F 00 79 00
9:18:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F4 09 81 80 1F 00 F9 00 82 28 01 00 00 02 00 FF 01 00 17 00 BA 00 17 00 F9 00 82 11 01 00 00 02 02 FF 01 00 1F 00 91 00 1F 00 D9 00 06 0F 01 00 00 02 04 FF 01 00 17 00 F2 01 17 00 F1 01 84 28 01 00 00 02 08 FF 01 00 17 00 BA 00 17 00 F9 00 84 39 01 00 00 03 00 FF 01 00 1F 00 D9 00 1F 00 D9 00 85 39 01 00 00 03 01 FF 01 00 1F 00 D9 00 1F 00 D9 00 05 3A 01 00 00 03 02 FF 01 00 1F 00 D9 00 1F 00
9:18:57 AM
9:18:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F5 09 81 80 D9 00 86 39 01 00 00 03 03 FF 01 00 1F 00 D9 00 1F 00 D9 00 87 39 01 00 00 03 04 FF 01 00 1F 00 D9 00 1F 00 D9 00 06 3A 01 00 00 03 05 FF 01 00 1F 00 D9 00 1F 00 D9 00 00 3A 01 00 00 04 02 FF 01 00 1F 00 D9 00 1F 00 D9 00 01 3A 01 00 00 04 03 FF 01 00 1F 00 D9 00 1F 00 D9 00 02 3A 01 00 00 04 05 FF 01 00 1F 00 D9 00 1F 00 D9 00 03 3A 01 00 00 04 06 FF 01 00 1F 00 D9 00 1F 00 D9 00
9:18:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F6 09 81 80 84 24 01 00 00 06 00 FF 03 00 1F 00 D9 00 1F 00 D9 00 00 50 01 00 00 08 00 FF 01 00 1F 00 61 00 1F 00 D9 00 04 50 01 00 00 08 04 FF 01 00 1F 00 71 00 1F 00 F1 00 04 51 01 00 00 08 05 FF 01 00 1F 00 71 00 1F 00 F1 00 86 0F 01 00 00 09 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 12 01 00 00 09 01 FF 01 00 1F 00 79 00 1F 00 F9 00 01 12 01 00 00 09 02 FF 01 00 1F 00 79 00 1F 00 F9 00 87 0F
9:18:58 AM
9:18:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F7 09 81 80 01 00 00 09 08 FF 03 00 1F 00 21 01 1F 00 D9 00 04 12 01 00 00 09 0A FF 01 00 1F 00 51 00 1F 00 D9 00 02 12 01 00 00 09 0B FF 03 00 1F 00 51 00 1F 00 D9 00 83 0F 01 00 00 09 0C FF 03 00 1F 00 E1 01 1F 00 D9 01 00 47 01 00 01 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 47 01 00 01 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 47 01 00 01 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 47 01 00
9:18:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F8 09 81 80 01 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 47 01 00 01 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 05 47 01 00 01 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 06 47 01 00 01 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 07 47 01 00 01 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 80 47 01 00 01 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 02 50 01 00 01 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 05 50 01 00 01 05
9:18:59 AM
9:18:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 F9 09 81 80 00 FF 04 00 1F 00 79 00 1F 00 F9 00 80 81 01 00 01 06 00 01 04 00 10 00 79 00 10 00 F9 00 00 40 01 00 01 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 81 81 01 00 01 06 01 01 04 00 10 00 79 00 10 00 F9 00 01 40 01 00 01 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 82 81 01 00 01 06 02 01 04 00 10 00 79 00 10 00 F9 00 02 40 01 00 01 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 03 40 01 00 01 06 03 FF
9:19:00 AM
9:19:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 FA 09 81 80 04 00 1F 00 79 00 1F 00 F9 00 04 40 01 00 01 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 05 40 01 00 01 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 06 40 01 00 01 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 07 40 01 00 01 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 80 40 01 00 01 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 87 3A 01 00 01 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 81 01 00 01 08 00 01 03 00
9:19:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 FB 09 81 80 10 00 79 00 10 00 F9 00 00 30 01 00 01 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 81 01 00 01 08 01 01 03 00 10 00 79 00 10 00 F9 00 01 30 01 00 01 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 81 01 00 01 08 02 01 03 00 10 00 79 00 10 00 F9 00 02 30 01 00 01 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 30 01 00 01 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 30 01 00 01 08 04 FF 03 00 1F 00
9:19:01 AM
9:19:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 FC 09 81 80 79 00 1F 00 F9 00 00 32 01 00 01 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 01 32 01 00 01 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 02 32 01 00 01 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 03 32 01 00 01 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 00 61 01 00 01 09 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 6A 01 00 01 09 01 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 6A 01 00 01 09 02 FF 03 00 1F 00 F9 01
9:19:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 FD 09 81 80 1F 00 F9 01 02 6A 01 00 01 09 03 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 6A 01 00 01 09 04 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 6A 01 00 01 09 05 FF 03 00 1F 03 F9 01 1F 03 F9 01 05 6A 01 00 01 09 06 FF 03 00 1F 03 F9 01 1F 03 F9 01 06 6A 01 00 01 09 07 FF 03 00 1F 03 F9 01 1F 03 F9 01 07 6A 01 00 01 09 08 FF 03 00 1F 03 F9 01 1F 03 F9 01 00 64 01 00 01 1D 00 FF 03 00 1F 00 F9 01 1F 00
9:19:02 AM
9:19:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 FE 09 81 80 F9 01 00 67 01 00 01 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 48 01 00 02 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 48 01 00 02 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 48 01 00 02 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 48 01 00 02 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 48 01 00 02 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 05 48 01 00 02 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00
9:19:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 08 FF 09 81 80 06 48 01 00 02 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 07 48 01 00 02 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 80 48 01 00 02 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 02 51 01 00 02 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 05 51 01 00 02 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 41 01 00 02 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 01 41 01 00 02 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 02 41
9:19:03 AM
9:19:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 00 09 81 80 01 00 02 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 03 41 01 00 02 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 04 41 01 00 02 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 05 41 01 00 02 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 06 41 01 00 02 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 07 41 01 00 02 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 80 41 01 00 02 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 00 3B 01 00
9:19:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 01 09 81 80 02 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 31 01 00 02 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 31 01 00 02 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 31 01 00 02 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 31 01 00 02 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 31 01 00 02 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 32 01 00 02 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 32 01 00 02 08
9:19:04 AM
9:19:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 02 09 81 80 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 32 01 00 02 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 32 01 00 02 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 04 61 01 00 02 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 80 6A 01 00 02 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 6A 01 00 02 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00 82 6A 01 00 02 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 6A 01 00 02 09 04 FF
9:19:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 03 09 81 80 03 00 1F 00 79 00 1F 00 F9 00 84 6A 01 00 02 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 6A 01 00 02 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 6A 01 00 02 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00 87 6A 01 00 02 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 04 64 01 00 02 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 67 01 00 02 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 49 01 00 03 02 00 FF 03 00
9:19:05 AM
9:19:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 04 09 81 80 1F 00 79 00 1F 00 F9 00 01 49 01 00 03 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 49 01 00 03 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 49 01 00 03 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 49 01 00 03 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 05 49 01 00 03 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 06 49 01 00 03 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 07 49 01 00 03 02 07 FF 03 00 1F 03
9:19:06 AM
9:19:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 05 09 81 80 79 00 1F 03 F9 00 80 49 01 00 03 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 02 52 01 00 03 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 05 52 01 00 03 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 42 01 00 03 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 01 42 01 00 03 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 02 42 01 00 03 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 03 42 01 00 03 06 03 FF 04 00 1F 00 79 00
9:19:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 06 09 81 80 1F 00 F9 00 04 42 01 00 03 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 05 42 01 00 03 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 06 42 01 00 03 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 07 42 01 00 03 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 80 42 01 00 03 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 86 35 01 00 03 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 33 01 00 03 08 00 FF 03 00 1F 00 79 00 1F 00
9:19:07 AM
9:19:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 07 09 81 80 F9 00 01 33 01 00 03 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 33 01 00 03 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 33 01 00 03 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 33 01 00 03 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 00 35 01 00 03 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 01 35 01 00 03 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 02 35 01 00 03 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00
9:19:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 08 09 81 80 03 35 01 00 03 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 00 62 01 00 03 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 6C 01 00 03 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 6C 01 00 03 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 6C 01 00 03 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 6C 01 00 03 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 6C 01 00 03 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 6C
9:19:08 AM
9:19:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 09 09 81 80 01 00 03 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 6C 01 00 03 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 6C 01 00 03 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 00 65 01 00 03 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 68 01 00 03 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 4A 01 00 04 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 4A 01 00 04 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 4A 01 00
9:19:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 0A 09 81 80 04 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 4A 01 00 04 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 4A 01 00 04 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 05 4A 01 00 04 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 06 4A 01 00 04 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 07 4A 01 00 04 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 80 4A 01 00 04 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 02 53 01 00 04 04
9:19:09 AM
9:19:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 0B 09 81 80 00 FF 05 00 1F 00 59 00 1F 00 D9 00 05 53 01 00 04 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 43 01 00 04 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 01 43 01 00 04 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 02 43 01 00 04 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 03 43 01 00 04 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 04 43 01 00 04 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 05 43 01 00 04 06 05 FF
9:19:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 0C 09 81 80 04 00 1F 03 79 00 1F 03 F9 00 06 43 01 00 04 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 07 43 01 00 04 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 80 43 01 00 04 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 87 35 01 00 04 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 34 01 00 04 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 34 01 00 04 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 34 01 00 04 08 02 FF 03 00
9:19:10 AM
9:19:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 0D 09 81 80 1F 00 79 00 1F 00 F9 00 03 34 01 00 04 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 34 01 00 04 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 35 01 00 04 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 35 01 00 04 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 35 01 00 04 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 35 01 00 04 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 04 62 01 00 04 09 00 FF 03 00 1F 00
9:19:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 0E 09 81 80 79 00 1F 00 F9 00 80 6C 01 00 04 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 6C 01 00 04 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00 82 6C 01 00 04 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 6C 01 00 04 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 84 6C 01 00 04 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 6C 01 00 04 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 6C 01 00 04 09 07 FF 03 00 1F 03 79 00
9:19:11 AM
9:19:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 0F 09 81 80 1F 03 F9 00 87 6C 01 00 04 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 04 65 01 00 04 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 68 01 00 04 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 53 01 00 05 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 5C 01 00 05 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 5C 01 00 05 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 5C 01 00 05 02 03 FF 03 00 1F 00 79 00 1F 00
9:19:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 10 09 81 80 F9 00 03 5C 01 00 05 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 5C 01 00 05 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 5C 01 00 05 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 5C 01 00 05 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 5C 01 00 05 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 80 52 01 00 05 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 84 52 01 00 05 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00
9:19:12 AM
9:19:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 11 09 81 80 80 53 01 00 05 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 5A 01 00 05 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 01 5A 01 00 05 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 02 5A 01 00 05 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 03 5A 01 00 05 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 04 5A 01 00 05 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 05 5A 01 00 05 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 06 5A
9:19:13 AM
9:19:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 12 09 81 80 01 00 05 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 07 5A 01 00 05 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 05 D3 01 00 05 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 81 01 00 05 08 00 01 03 00 10 00 79 00 10 00 F9 00 81 D0 01 00 05 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 36 01 00 05 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 36 01 00 05 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 36 01 00
9:19:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 13 09 81 80 05 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 36 01 00 05 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 36 01 00 05 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 36 01 00 05 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 36 01 00 05 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 36 01 00 05 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 80 62 01 00 05 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 6D 01 00 05 09
9:19:14 AM
9:19:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 14 09 81 80 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 6D 01 00 05 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 6D 01 00 05 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 6D 01 00 05 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 6D 01 00 05 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 6D 01 00 05 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 6D 01 00 05 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 6D 01 00 05 09 08 FF
9:19:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 15 09 81 80 03 00 1F 03 79 00 1F 03 F9 00 80 65 01 00 05 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 68 01 00 05 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 53 01 00 06 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 80 5C 01 00 06 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 5C 01 00 06 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 82 5C 01 00 06 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 5C 01 00 06 02 04 FF 03 00
9:19:15 AM
9:19:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 16 09 81 80 1F 00 79 00 1F 00 F9 00 84 5C 01 00 06 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 5C 01 00 06 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 5C 01 00 06 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 87 5C 01 00 06 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 81 52 01 00 06 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 85 52 01 00 06 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 81 53 01 00 06 06 00 FF 04 00 1F 00
9:19:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 17 09 81 80 79 00 1F 00 F9 00 80 5A 01 00 06 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 81 5A 01 00 06 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 82 5A 01 00 06 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 83 5A 01 00 06 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 84 5A 01 00 06 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 85 5A 01 00 06 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 86 5A 01 00 06 06 07 FF 04 00 1F 03 79 00
9:19:16 AM
9:19:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 18 09 81 80 1F 03 F9 00 87 5A 01 00 06 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 06 D3 01 00 06 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 82 D0 01 00 06 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 37 01 00 06 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 37 01 00 06 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 37 01 00 06 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 37 01 00 06 08 04 FF 03 00 1F 00 79 00 1F 00
9:19:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 19 09 81 80 F9 00 04 37 01 00 06 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 37 01 00 06 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 37 01 00 06 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 37 01 00 06 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 84 62 01 00 06 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 80 6D 01 00 06 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 6D 01 00 06 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00
9:19:17 AM
9:19:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 1A 09 81 80 82 6D 01 00 06 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 6D 01 00 06 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 84 6D 01 00 06 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 6D 01 00 06 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 6D 01 00 06 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00 87 6D 01 00 06 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 84 65 01 00 06 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 68
9:19:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 1B 09 81 80 01 00 06 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 53 01 00 07 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 5D 01 00 07 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 5D 01 00 07 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 5D 01 00 07 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 5D 01 00 07 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 5D 01 00 07 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 5D 01 00
9:19:18 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:19:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 1C 09 81 80 07 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 5D 01 00 07 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 5D 01 00 07 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 82 52 01 00 07 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 86 52 01 00 07 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 82 53 01 00 07 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 5B 01 00 07 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 01 5B 01 00 07 06
9:19:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 1D 09 81 80 02 FF 04 00 1F 00 79 00 1F 00 F9 00 02 5B 01 00 07 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 03 5B 01 00 07 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 04 5B 01 00 07 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 05 5B 01 00 07 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 06 5B 01 00 07 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 07 5B 01 00 07 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 07 D3 01 00 07 07 00 FF
9:19:19 AM
9:19:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 1E 09 81 80 03 00 1F 00 F9 01 1F 00 F9 01 83 D0 01 00 07 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 38 01 00 07 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 38 01 00 07 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 38 01 00 07 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 38 01 00 07 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 38 01 00 07 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 38 01 00 07 08 06 FF 03 00
9:19:20 AM
9:19:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 1F 09 81 80 1F 03 79 00 1F 03 F9 00 06 38 01 00 07 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 38 01 00 07 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 00 63 01 00 07 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 6E 01 00 07 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 6E 01 00 07 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 6E 01 00 07 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 6E 01 00 07 09 04 FF 03 00 1F 00
9:19:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 20 09 81 80 79 00 1F 00 F9 00 04 6E 01 00 07 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 6E 01 00 07 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 6E 01 00 07 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 6E 01 00 07 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 00 66 01 00 07 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 69 01 00 07 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 53 01 00 08 02 00 FF 03 00 1F 00 79 00
9:19:21 AM
9:19:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 21 09 81 80 1F 00 F9 00 80 5D 01 00 08 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 5D 01 00 08 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 82 5D 01 00 08 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 5D 01 00 08 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 84 5D 01 00 08 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 5D 01 00 08 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 5D 01 00 08 02 07 FF 03 00 1F 03 79 00 1F 03
9:19:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 22 09 81 80 F9 00 87 5D 01 00 08 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 83 52 01 00 08 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 87 52 01 00 08 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 83 53 01 00 08 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 80 5B 01 00 08 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 81 5B 01 00 08 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 82 5B 01 00 08 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00
9:19:22 AM
9:19:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 23 09 81 80 83 5B 01 00 08 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 84 5B 01 00 08 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 85 5B 01 00 08 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 86 5B 01 00 08 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 87 5B 01 00 08 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 80 D3 01 00 08 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 D0 01 00 08 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 80 38
9:19:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 24 09 81 80 01 00 08 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 38 01 00 08 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 82 38 01 00 08 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 38 01 00 08 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 84 38 01 00 08 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 38 01 00 08 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 38 01 00 08 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 87 38 01 00
9:19:23 AM
9:19:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 25 09 81 80 08 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 04 63 01 00 08 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 80 6E 01 00 08 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 6E 01 00 08 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00 82 6E 01 00 08 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 6E 01 00 08 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 84 6E 01 00 08 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 6E 01 00 08 09
9:19:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 26 09 81 80 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 6E 01 00 08 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00 87 6E 01 00 08 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 04 66 01 00 08 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 69 01 00 08 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 4B 01 00 09 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 4B 01 00 09 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 4B 01 00 09 02 02 FF
9:19:24 AM
9:19:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 27 09 81 80 03 00 1F 00 79 00 1F 00 F9 00 03 4B 01 00 09 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 4B 01 00 09 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 05 4B 01 00 09 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 06 4B 01 00 09 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 07 4B 01 00 09 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 80 4B 01 00 09 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 02 54 01 00 09 04 00 FF 05 00
9:19:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 28 09 81 80 1F 00 59 00 1F 00 D9 00 05 54 01 00 09 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 44 01 00 09 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 01 44 01 00 09 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 02 44 01 00 09 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 03 44 01 00 09 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 04 44 01 00 09 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 05 44 01 00 09 06 05 FF 04 00 1F 03
9:19:25 AM
9:19:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 29 09 81 80 79 00 1F 03 F9 00 06 44 01 00 09 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 07 44 01 00 09 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 80 44 01 00 09 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 80 3B 01 00 09 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 82 3B 01 00 09 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 83 3B 01 00 09 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 84 3B 01 00 09 08 02 FF 03 00 1F 00 79 00
9:19:26 AM
9:19:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 2A 09 81 80 1F 00 F9 00 85 3B 01 00 09 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 86 3B 01 00 09 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 87 3B 01 00 09 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 00 3C 01 00 09 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 01 3C 01 00 09 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 02 3C 01 00 09 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 80 63 01 00 09 09 00 FF 03 00 1F 00 79 00 1F 00
9:19:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 2B 09 81 80 F9 00 00 6F 01 00 09 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 6F 01 00 09 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 6F 01 00 09 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 6F 01 00 09 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 6F 01 00 09 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 6F 01 00 09 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 6F 01 00 09 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00
9:19:27 AM
9:19:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 2C 09 81 80 07 6F 01 00 09 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 80 66 01 00 09 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 69 01 00 09 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 4C 01 00 0A 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 4C 01 00 0A 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 4C 01 00 0A 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 4C 01 00 0A 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 4C
9:19:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 2D 09 81 80 01 00 0A 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 05 4C 01 00 0A 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 06 4C 01 00 0A 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 07 4C 01 00 0A 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 80 4C 01 00 0A 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 02 55 01 00 0A 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 05 55 01 00 0A 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 45 01 00
9:19:28 AM
9:19:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 2E 09 81 80 0A 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 01 45 01 00 0A 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 02 45 01 00 0A 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 03 45 01 00 0A 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 04 45 01 00 0A 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 05 45 01 00 0A 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 06 45 01 00 0A 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 07 45 01 00 0A 06
9:19:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 2F 09 81 80 07 FF 04 00 1F 03 79 00 1F 03 F9 00 80 45 01 00 0A 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 81 3B 01 00 0A 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 3C 01 00 0A 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 04 3C 01 00 0A 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 05 3C 01 00 0A 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 06 3C 01 00 0A 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 07 3C 01 00 0A 08 04 FF
9:19:29 AM
9:19:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 30 09 81 80 03 00 1F 00 79 00 1F 00 F9 00 80 3C 01 00 0A 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 81 3C 01 00 0A 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 82 3C 01 00 0A 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 83 3C 01 00 0A 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 84 63 01 00 0A 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 80 6F 01 00 0A 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 6F 01 00 0A 09 02 FF 03 00
9:19:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 31 09 81 80 1F 00 79 00 1F 00 F9 00 82 6F 01 00 0A 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 6F 01 00 0A 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 84 6F 01 00 0A 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 6F 01 00 0A 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 6F 01 00 0A 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00 87 6F 01 00 0A 09 08 FF 03 00 1F 03 F9 00 1F 03 F9 00 84 66 01 00 0A 1D 00 FF 03 00 1F 00
9:19:30 AM
9:19:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 32 09 81 80 F9 01 1F 00 F9 01 84 69 01 00 0A 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 C3 01 00 0B 23 00 FF 03 00 1F 00 E1 01 1F 00 D9 01 86 C2 01 00 0B 27 00 FF 03 00 1F 00 E1 01 1F 00 D9 01 84 C1 01 00 0B 2C 00 FF 03 00 1F 00 E1 01 1F 00 D9 01 83 C1 01 00 0B 2D 00 FF 03 00 1F 00 E1 01 1F 00 D9 01 00 39 01 00 0C 1F 00 00 03 00 1F 00 E1 01 1F 00 D9 01 83 C2 01 00 0C 1F 00 01 03 00 1F 00 E1 01
9:19:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 33 09 81 80 1F 00 D9 01 06 39 01 00 0C 20 00 FF 01 00 1F 00 79 00 1F 00 F9 00 00 C0 01 00 0C 21 00 FF 03 00 1F 00 79 00 1F 00 F9 00 04 39 01 00 0C 22 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 39 01 00 0C 23 00 00 03 00 1F 00 E1 01 1F 00 D9 01 84 C2 01 00 0C 23 00 01 03 00 1F 00 E1 01 1F 00 D9 01 07 39 01 00 0C 24 00 FF 01 00 1F 00 F9 01 1F 00 F9 01 01 C0 01 00 0C 25 00 FF 03 00 1F 00 F9 01 1F 00
9:19:31 AM
9:19:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 34 09 81 80 F9 01 05 39 01 00 0C 26 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 C1 01 00 0C 27 00 FF 03 00 1F 00 51 00 1F 00 D9 00 00 C1 01 00 0C 2B 00 00 03 00 1F 00 E1 01 1F 00 D9 01 00 C2 01 00 0C 2B 00 01 03 00 1F 00 E1 01 1F 00 D9 01 01 C1 01 00 0C 2C 00 00 03 00 1F 00 E1 01 1F 00 D9 01 01 C2 01 00 0C 2C 00 01 03 00 1F 00 E1 01 1F 00 D9 01 02 C1 01 00 0C 2D 00 FF 03 00 1F 00 D1 01 1F 00 D9 01
9:19:32 AM
9:19:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 35 09 81 80 01 4E 01 00 0D 03 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 03 4E 01 00 0D 05 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 05 4E 01 00 0D 06 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 00 CE 01 00 0D 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 80 CC 01 00 0D 0E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 CD 01 00 0D 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 CD 01 00 0D 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 C3
9:19:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 36 09 81 80 01 00 0D 1F 00 FF 03 00 1F 00 E1 01 1F 00 D9 01 87 C1 01 00 0D 2B 00 FF 03 00 1F 00 E1 01 1F 00 D9 01 01 CF 01 00 0E 03 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 02 CF 01 00 0E 06 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 00 CF 01 00 0E 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 51 01 00 0F 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 00 59 01 00 0F 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 59 01 00
9:19:33 AM
9:19:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 37 09 81 80 0F 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 59 01 00 0F 02 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 59 01 00 0F 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 59 01 00 0F 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 59 01 00 0F 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 59 01 00 0F 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 07 59 01 00 0F 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 02 56 01 00 0F 04
9:19:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 38 09 81 80 00 FF 05 00 1F 00 59 00 1F 00 D9 00 05 56 01 00 0F 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 46 01 00 0F 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 01 46 01 00 0F 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 02 46 01 00 0F 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 03 46 01 00 0F 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 04 46 01 00 0F 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 05 46 01 00 0F 06 05 FF
9:19:34 AM
9:19:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 39 09 81 80 04 00 1F 03 79 00 1F 03 F9 00 06 46 01 00 0F 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 07 46 01 00 0F 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 80 46 01 00 0F 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 01 3B 01 00 0F 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 3D 01 00 0F 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 3D 01 00 0F 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 3D 01 00 0F 08 02 FF 03 00
9:19:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 3A 09 81 80 1F 00 79 00 1F 00 F9 00 03 3D 01 00 0F 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 3D 01 00 0F 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 05 3D 01 00 0F 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 06 3D 01 00 0F 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 07 3D 01 00 0F 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 80 3D 01 00 0F 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 80 61 01 00 0F 09 00 FF 03 00 1F 00
9:19:35 AM
9:19:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 3B 09 81 80 79 00 1F 00 F9 00 00 6B 01 00 0F 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 01 6B 01 00 0F 09 02 FF 03 00 1F 00 79 00 1F 00 F9 00 02 6B 01 00 0F 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 03 6B 01 00 0F 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 04 6B 01 00 0F 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 05 6B 01 00 0F 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 06 6B 01 00 0F 09 07 FF 03 00 1F 03 79 00
9:19:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 3C 09 81 80 1F 03 F9 00 07 6B 01 00 0F 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 80 64 01 00 0F 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 67 01 00 0F 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 51 01 00 10 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 80 59 01 00 10 02 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 59 01 00 10 02 02 FF 03 00 1F 00 79 00 1F 00 F9 00 82 59 01 00 10 02 03 FF 03 00 1F 00 79 00 1F 00
9:19:36 AM
9:19:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 3D 09 81 80 F9 00 83 59 01 00 10 02 04 FF 03 00 1F 00 79 00 1F 00 F9 00 84 59 01 00 10 02 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 59 01 00 10 02 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 59 01 00 10 02 07 FF 03 00 1F 03 79 00 1F 03 F9 00 87 59 01 00 10 02 08 FF 03 00 1F 03 79 00 1F 03 F9 00 81 51 01 00 10 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 82 51 01 00 10 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00
9:19:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 3E 09 81 80 83 51 01 00 10 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 80 58 01 00 10 06 01 FF 04 00 1F 00 79 00 1F 00 F9 00 81 58 01 00 10 06 02 FF 04 00 1F 00 79 00 1F 00 F9 00 82 58 01 00 10 06 03 FF 04 00 1F 00 79 00 1F 00 F9 00 83 58 01 00 10 06 04 FF 04 00 1F 00 79 00 1F 00 F9 00 84 58 01 00 10 06 05 FF 04 00 1F 03 79 00 1F 03 F9 00 85 58 01 00 10 06 06 FF 04 00 1F 03 79 00 1F 03 F9 00 86 58
9:19:37 AM
9:19:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 3F 09 81 80 01 00 10 06 07 FF 04 00 1F 03 79 00 1F 03 F9 00 87 58 01 00 10 06 08 FF 04 00 1F 03 79 00 1F 03 F9 00 01 D3 01 00 10 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 D0 01 00 10 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 D0 01 00 10 08 01 FF 03 00 1F 00 79 00 1F 00 F9 00 02 D0 01 00 10 08 02 FF 03 00 1F 00 79 00 1F 00 F9 00 03 D0 01 00 10 08 03 FF 03 00 1F 00 79 00 1F 00 F9 00 04 D0 01 00
9:19:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 40 09 81 80 10 08 04 FF 03 00 1F 00 79 00 1F 00 F9 00 05 D0 01 00 10 08 05 FF 03 00 1F 03 79 00 1F 03 F9 00 06 D0 01 00 10 08 06 FF 03 00 1F 03 79 00 1F 03 F9 00 07 D0 01 00 10 08 07 FF 03 00 1F 03 79 00 1F 03 F9 00 80 D0 01 00 10 08 08 FF 03 00 1F 03 79 00 1F 03 F9 00 84 61 01 00 10 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 80 6B 01 00 10 09 01 FF 03 00 1F 00 79 00 1F 00 F9 00 81 6B 01 00 10 09
9:19:38 AM
9:19:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 41 09 81 80 02 FF 03 00 1F 00 79 00 1F 00 F9 00 82 6B 01 00 10 09 03 FF 03 00 1F 00 79 00 1F 00 F9 00 83 6B 01 00 10 09 04 FF 03 00 1F 00 79 00 1F 00 F9 00 84 6B 01 00 10 09 05 FF 03 00 1F 03 79 00 1F 03 F9 00 85 6B 01 00 10 09 06 FF 03 00 1F 03 79 00 1F 03 F9 00 86 6B 01 00 10 09 07 FF 03 00 1F 03 79 00 1F 03 F9 00 87 6B 01 00 10 09 08 FF 03 00 1F 03 79 00 1F 03 F9 00 84 64 01 00 10 1D 00 FF
9:19:39 AM
9:19:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 42 09 81 80 03 00 1F 00 F9 01 1F 00 F9 01 84 67 01 00 10 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 E1 01 00 15 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 E0 01 00 15 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 07 E0 01 00 15 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 85 E0 01 00 15 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 02 3B 01 00 15 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 D0 01 00 15 08 00 FF 03 00
9:19:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 43 09 81 80 1F 00 79 00 1F 00 F9 00 01 61 01 00 15 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 64 01 00 15 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 67 01 00 15 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 E1 01 00 16 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 02 E0 01 00 16 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 80 E0 01 00 16 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 86 E0 01 00 16 06 00 FF 04 00 1F 00
9:19:40 AM
9:19:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 44 09 81 80 79 00 1F 00 F9 00 83 D2 01 00 16 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 D1 01 00 16 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 05 61 01 00 16 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 05 64 01 00 16 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 67 01 00 16 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 E2 01 00 17 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 81 E1 01 00 17 04 00 FF 05 00 1F 00 59 00
9:19:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 45 09 81 80 1F 00 D9 00 87 E1 01 00 17 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 05 E2 01 00 17 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 81 D3 01 00 17 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 81 D1 01 00 17 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 62 01 00 17 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 65 01 00 17 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 68 01 00 17 1E 00 FF 03 00 1F 00 F9 01 1F 00
9:19:41 AM
9:19:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 46 09 81 80 F9 01 84 E2 01 00 18 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 82 E1 01 00 18 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 00 E2 01 00 18 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 06 E2 01 00 18 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 84 D3 01 00 18 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 D1 01 00 18 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 05 62 01 00 18 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00
9:19:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 47 09 81 80 05 65 01 00 18 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 68 01 00 18 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 D3 01 00 19 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 D1 01 00 19 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 81 62 01 00 19 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 81 65 01 00 19 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 81 68 01 00 19 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 D4
9:19:42 AM
9:19:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 48 09 81 80 01 00 1A 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 D2 01 00 1A 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 85 62 01 00 1A 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 85 65 01 00 1A 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 68 01 00 1A 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 D4 01 00 1B 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 D2 01 00 1B 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 63 01 00
9:19:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 49 09 81 80 1B 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 66 01 00 1B 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 69 01 00 1B 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 D4 01 00 1C 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 D2 01 00 1C 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 05 63 01 00 1C 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 05 66 01 00 1C 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 69 01 00 1C 1E
9:19:43 AM
9:19:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 4A 09 81 80 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 E4 01 00 1D 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 01 E3 01 00 1D 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 07 E3 01 00 1D 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 85 E3 01 00 1D 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 05 3B 01 00 1D 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 30 01 00 1D 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 81 63 01 00 1D 09 00 FF
9:19:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 4B 09 81 80 03 00 1F 00 79 00 1F 00 F9 00 81 66 01 00 1D 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 81 69 01 00 1D 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 E4 01 00 1E 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 02 E3 01 00 1E 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 80 E3 01 00 1E 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 86 E3 01 00 1E 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 83 D4 01 00 1E 07 00 FF 03 00
9:19:44 AM
9:19:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 4C 09 81 80 1F 00 F9 01 1F 00 F9 01 85 31 01 00 1E 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 85 63 01 00 1E 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 85 66 01 00 1E 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 69 01 00 1E 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 C5 01 00 1F 03 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 01 58 01 00 1F 04 00 FF 05 00 1F 00 D1 01 1F 00 D9 01 03 C5 01 00 1F 06 00 FF 04 00 1F 00
9:19:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 4D 09 81 80 F9 01 1F 00 F9 01 80 3A 01 00 1F 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 00 B7 01 00 1F 07 01 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B7 01 00 1F 07 02 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 B7 01 00 1F 07 03 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B7 01 00 1F 07 04 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 B7 01 00 1F 07 05 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B7 01 00 1F 07 06 FF 03 00 1F 01 F9 01
9:19:45 AM
9:19:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 4E 09 81 80 1F 01 F9 01 06 B7 01 00 1F 07 07 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B7 01 00 1F 07 08 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B7 01 00 1F 07 09 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 B7 01 00 1F 07 0A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B7 01 00 1F 07 0B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 B7 01 00 1F 07 0C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 B7 01 00 1F 07 0D FF 03 00 1F 01 F9 01 1F 01
9:19:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 4F 09 81 80 F9 01 85 B7 01 00 1F 07 0E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B7 01 00 1F 07 0F FF 03 00 1F 01 F9 01 1F 01 F9 01 87 B7 01 00 1F 07 10 FF 03 00 1F 01 F9 01 1F 01 F9 01 00 B8 01 00 1F 07 11 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B8 01 00 1F 07 12 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 B8 01 00 1F 07 13 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B8 01 00 1F 07 14 FF 03 00 1F 01 F9 01 1F 01 F9 01
9:19:46 AM
9:19:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 50 09 81 80 04 B8 01 00 1F 07 15 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B8 01 00 1F 07 16 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 B8 01 00 1F 07 17 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B8 01 00 1F 07 18 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B8 01 00 1F 07 19 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 B8 01 00 1F 07 1A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B8 01 00 1F 07 1B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 B8
9:19:47 AM
9:19:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 51 09 81 80 01 00 1F 07 1C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 B8 01 00 1F 07 1D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 B8 01 00 1F 07 1E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B8 01 00 1F 07 1F FF 03 00 1F 01 F9 01 1F 01 F9 01 83 C6 01 00 1F 07 7C FF 03 00 1F 01 B9 00 1F 01 F9 00 80 C5 01 00 1F 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 C5 01 00 1F 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 2C 01 00
9:19:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 52 09 81 80 1F 80 80 FF 01 00 19 00 F7 01 19 00 F7 01 00 C4 01 00 20 03 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 03 C4 01 00 20 06 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 84 3A 01 00 20 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 00 B1 01 00 20 07 01 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B1 01 00 20 07 02 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 B1 01 00 20 07 03 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B1 01 00 20 07
9:19:48 AM
9:19:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 53 09 81 80 04 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 B1 01 00 20 07 05 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B1 01 00 20 07 06 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 B1 01 00 20 07 07 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B1 01 00 20 07 08 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B1 01 00 20 07 09 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 B1 01 00 20 07 0A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B1 01 00 20 07 0B FF
9:19:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 54 09 81 80 03 00 1F 01 F9 01 1F 01 F9 01 83 B1 01 00 20 07 0C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 B1 01 00 20 07 0D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 B1 01 00 20 07 0E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B1 01 00 20 07 0F FF 03 00 1F 01 F9 01 1F 01 F9 01 87 B1 01 00 20 07 10 FF 03 00 1F 01 F9 01 1F 01 F9 01 00 B2 01 00 20 07 11 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B2 01 00 20 07 12 FF 03 00
9:19:49 AM
9:19:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 55 09 81 80 1F 01 F9 01 1F 01 F9 01 02 B2 01 00 20 07 13 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B2 01 00 20 07 14 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 B2 01 00 20 07 15 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B2 01 00 20 07 16 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 B2 01 00 20 07 17 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B2 01 00 20 07 18 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B2 01 00 20 07 19 FF 03 00 1F 01
9:19:50 AM
9:19:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 56 09 81 80 F9 01 1F 01 F9 01 81 B2 01 00 20 07 1A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B2 01 00 20 07 1B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 B2 01 00 20 07 1C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 B2 01 00 20 07 1D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 B2 01 00 20 07 1E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B2 01 00 20 07 1F FF 03 00 1F 01 F9 01 1F 01 F9 01 80 C6 01 00 20 07 7C FF 03 00 1F 01 B9 00
9:19:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 57 09 81 80 1F 01 F9 00 05 23 01 00 20 18 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 80 C4 01 00 20 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 C4 01 00 20 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 24 01 00 20 20 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 02 C0 01 00 20 21 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 00 24 01 00 20 22 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 03 24 01 00 20 24 00 FF 01 00 1F 00 B9 00 1F 00
9:19:51 AM
9:19:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 58 09 81 80 F9 00 03 C0 01 00 20 25 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 02 24 01 00 20 26 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 00 2C 01 00 20 80 80 FF 01 00 19 00 F7 01 19 00 F7 01 80 CB 01 00 21 03 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 00 CB 01 00 21 05 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 00 CC 01 00 21 06 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 01 CE 01 00 21 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00
9:19:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 59 09 81 80 81 CC 01 00 21 0E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 CD 01 00 21 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 81 CD 01 00 21 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 D2 01 00 23 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 D1 01 00 23 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 81 61 01 00 23 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 81 64 01 00 23 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 81 67
9:19:52 AM
9:19:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 5A 09 81 80 01 00 23 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 D3 01 00 24 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 D1 01 00 24 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 85 61 01 00 24 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 85 64 01 00 24 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 67 01 00 24 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 E1 01 00 29 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 03 E0 01 00
9:19:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 5B 09 81 80 29 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 81 E0 01 00 29 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 87 E0 01 00 29 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 03 3B 01 00 29 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 D0 01 00 29 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 02 61 01 00 29 09 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 64 01 00 29 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 67 01 00 29 1E
9:19:53 AM
9:19:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 5C 09 81 80 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 E1 01 00 2A 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 04 E0 01 00 2A 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 82 E0 01 00 2A 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 00 E1 01 00 2A 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 84 D2 01 00 2A 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 D1 01 00 2A 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 06 61 01 00 2A 09 00 FF
9:19:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 5D 09 81 80 03 00 1F 00 79 00 1F 00 F9 00 06 64 01 00 2A 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 67 01 00 2A 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 E2 01 00 2B 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 83 E1 01 00 2B 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 01 E2 01 00 2B 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 07 E2 01 00 2B 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 82 D3 01 00 2B 07 00 FF 03 00
9:19:54 AM
9:19:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 5E 09 81 80 1F 00 F9 01 1F 00 F9 01 82 D1 01 00 2B 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 02 62 01 00 2B 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 02 65 01 00 2B 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 68 01 00 2B 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 E2 01 00 2C 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 84 E1 01 00 2C 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 02 E2 01 00 2C 05 00 FF 04 00 1F 00
9:19:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 5F 09 81 80 79 00 1F 00 F9 00 80 E2 01 00 2C 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 85 D3 01 00 2C 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 D1 01 00 2C 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 06 62 01 00 2C 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 06 65 01 00 2C 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 68 01 00 2C 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 D4 01 00 2D 07 00 FF 03 00 1F 00 F9 01
9:19:55 AM
9:19:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 60 09 81 80 1F 00 F9 01 00 D2 01 00 2D 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 82 62 01 00 2D 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 82 65 01 00 2D 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 82 68 01 00 2D 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 D4 01 00 2E 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 D2 01 00 2E 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 86 62 01 00 2E 09 00 FF 03 00 1F 00 79 00 1F 00
9:19:56 AM
9:19:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 61 09 81 80 F9 00 86 65 01 00 2E 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 68 01 00 2E 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 D4 01 00 2F 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 D2 01 00 2F 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 02 63 01 00 2F 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 02 66 01 00 2F 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 69 01 00 2F 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01
9:19:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 62 09 81 80 81 D4 01 00 30 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 81 D2 01 00 30 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 06 63 01 00 30 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 06 66 01 00 30 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 69 01 00 30 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 E4 01 00 31 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 03 E3 01 00 31 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 81 E3
9:19:57 AM
9:19:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 63 09 81 80 01 00 31 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 87 E3 01 00 31 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 06 3B 01 00 31 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 30 01 00 31 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 82 63 01 00 31 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 82 66 01 00 31 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 82 69 01 00 31 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 07 E4 01 00
9:19:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 64 09 81 80 32 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 04 E3 01 00 32 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 82 E3 01 00 32 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 01 E4 01 00 32 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 84 D4 01 00 32 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 31 01 00 32 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 86 63 01 00 32 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 86 66 01 00 32 1D
9:19:58 AM
9:19:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 65 09 81 80 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 69 01 00 32 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 C5 01 00 33 03 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 02 58 01 00 33 04 00 FF 05 00 1F 00 91 00 1F 00 D9 00 04 C5 01 00 33 06 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 81 3A 01 00 33 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 00 B9 01 00 33 07 01 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B9 01 00 33 07 02 FF
9:19:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 66 09 81 80 03 00 1F 01 F9 01 1F 01 F9 01 02 B9 01 00 33 07 03 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B9 01 00 33 07 04 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 B9 01 00 33 07 05 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B9 01 00 33 07 06 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 B9 01 00 33 07 07 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B9 01 00 33 07 08 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B9 01 00 33 07 09 FF 03 00
9:19:59 AM
9:19:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 67 09 81 80 1F 01 F9 01 1F 01 F9 01 81 B9 01 00 33 07 0A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B9 01 00 33 07 0B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 B9 01 00 33 07 0C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 B9 01 00 33 07 0D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 B9 01 00 33 07 0E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B9 01 00 33 07 0F FF 03 00 1F 01 F9 01 1F 01 F9 01 87 B9 01 00 33 07 10 FF 03 00 1F 01
9:19:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 68 09 81 80 F9 01 1F 01 F9 01 00 BA 01 00 33 07 11 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 BA 01 00 33 07 12 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 BA 01 00 33 07 13 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 BA 01 00 33 07 14 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 BA 01 00 33 07 15 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 BA 01 00 33 07 16 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 BA 01 00 33 07 17 FF 03 00 1F 01 F9 01
9:20:00 AM
9:20:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 69 09 81 80 1F 01 F9 01 07 BA 01 00 33 07 18 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 BA 01 00 33 07 19 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 BA 01 00 33 07 1A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 BA 01 00 33 07 1B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 BA 01 00 33 07 1C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 BA 01 00 33 07 1D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 BA 01 00 33 07 1E FF 03 00 1F 01 F9 01 1F 01
9:20:01 AM
9:20:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 6A 09 81 80 F9 01 86 BA 01 00 33 07 1F FF 03 00 1F 01 F9 01 1F 01 F9 01 84 C6 01 00 33 07 7C FF 03 00 1F 01 B9 00 1F 01 F9 00 81 C5 01 00 33 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 C5 01 00 33 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 2C 01 00 33 80 80 FF 01 00 19 00 F7 01 19 00 F7 01 01 C4 01 00 34 03 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 04 C4 01 00 34 06 00 FF 04 00 1F 00 F9 01 1F 00 F9 01
9:20:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 6B 09 81 80 85 3A 01 00 34 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 00 B3 01 00 34 07 01 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B3 01 00 34 07 02 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 B3 01 00 34 07 03 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B3 01 00 34 07 04 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 B3 01 00 34 07 05 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B3 01 00 34 07 06 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 B3
9:20:02 AM
9:20:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 6C 09 81 80 01 00 34 07 07 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B3 01 00 34 07 08 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B3 01 00 34 07 09 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 B3 01 00 34 07 0A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B3 01 00 34 07 0B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 B3 01 00 34 07 0C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 B3 01 00 34 07 0D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 B3 01 00
9:20:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 6D 09 81 80 34 07 0E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B3 01 00 34 07 0F FF 03 00 1F 01 F9 01 1F 01 F9 01 87 B3 01 00 34 07 10 FF 03 00 1F 01 F9 01 1F 01 F9 01 00 B4 01 00 34 07 11 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B4 01 00 34 07 12 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 B4 01 00 34 07 13 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B4 01 00 34 07 14 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 B4 01 00 34 07
9:20:03 AM
9:20:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 6E 09 81 80 15 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B4 01 00 34 07 16 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 B4 01 00 34 07 17 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B4 01 00 34 07 18 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B4 01 00 34 07 19 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 B4 01 00 34 07 1A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B4 01 00 34 07 1B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 B4 01 00 34 07 1C FF
9:20:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 6F 09 81 80 03 00 1F 01 F9 01 1F 01 F9 01 84 B4 01 00 34 07 1D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 B4 01 00 34 07 1E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B4 01 00 34 07 1F FF 03 00 1F 01 F9 01 1F 01 F9 01 81 C6 01 00 34 07 7C FF 03 00 1F 01 B9 00 1F 01 F9 00 06 23 01 00 34 18 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 81 C4 01 00 34 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 C4 01 00 34 1C 00 FF 03 00
9:20:04 AM
9:20:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 70 09 81 80 1F 00 F9 01 1F 00 F9 01 05 24 01 00 34 20 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 04 C0 01 00 34 21 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 04 24 01 00 34 22 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 07 24 01 00 34 24 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 05 C0 01 00 34 25 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 06 24 01 00 34 26 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 01 2C 01 00 34 80 80 FF 01 00 19 00
9:20:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 71 09 81 80 F7 01 19 00 F7 01 81 CB 01 00 35 03 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 01 CB 01 00 35 05 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 01 CC 01 00 35 06 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 02 CE 01 00 35 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 82 CC 01 00 35 0E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 CD 01 00 35 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 82 CD 01 00 35 1C 00 FF 03 00 1F 00 F9 01
9:20:05 AM
9:20:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 72 09 81 80 1F 00 F9 01 87 D2 01 00 37 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 D1 01 00 37 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 82 61 01 00 37 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 82 64 01 00 37 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 82 67 01 00 37 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 D3 01 00 38 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 07 D1 01 00 38 08 00 FF 03 00 1F 00 79 00 1F 00
9:20:06 AM
9:20:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 73 09 81 80 F9 00 86 61 01 00 38 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 86 64 01 00 38 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 67 01 00 38 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 07 E1 01 00 3D 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 05 E0 01 00 3D 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 83 E0 01 00 3D 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 01 E1 01 00 3D 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00
9:20:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 74 09 81 80 04 3B 01 00 3D 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 D0 01 00 3D 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 03 61 01 00 3D 09 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 64 01 00 3D 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 67 01 00 3D 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 E1 01 00 3E 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 06 E0 01 00 3E 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 84 E0
9:20:07 AM
9:20:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 75 09 81 80 01 00 3E 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 02 E1 01 00 3E 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 85 D2 01 00 3E 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 D1 01 00 3E 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 07 61 01 00 3E 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 07 64 01 00 3E 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 07 67 01 00 3E 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 E2 01 00
9:20:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 76 09 81 80 3F 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 85 E1 01 00 3F 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 03 E2 01 00 3F 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 81 E2 01 00 3F 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 83 D3 01 00 3F 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 D1 01 00 3F 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 03 62 01 00 3F 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 03 65 01 00 3F 1D
9:20:08 AM
9:20:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 77 09 81 80 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 68 01 00 3F 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 E3 01 00 40 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 86 E1 01 00 40 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 04 E2 01 00 40 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 82 E2 01 00 40 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 86 D3 01 00 40 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 D1 01 00 40 08 00 FF
9:20:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 78 09 81 80 03 00 1F 00 79 00 1F 00 F9 00 07 62 01 00 40 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 07 65 01 00 40 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 07 68 01 00 40 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 D4 01 00 41 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 D2 01 00 41 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 83 62 01 00 41 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 83 65 01 00 41 1D 00 FF 03 00
9:20:09 AM
9:20:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 79 09 81 80 1F 00 F9 01 1F 00 F9 01 83 68 01 00 41 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 D4 01 00 42 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 D2 01 00 42 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 87 62 01 00 42 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 87 65 01 00 42 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 68 01 00 42 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 07 D4 01 00 43 07 00 FF 03 00 1F 00
9:20:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 7A 09 81 80 F9 01 1F 00 F9 01 07 D2 01 00 43 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 03 63 01 00 43 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 03 66 01 00 43 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 69 01 00 43 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 82 D4 01 00 44 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 82 D2 01 00 44 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 07 63 01 00 44 09 00 FF 03 00 1F 00 79 00
9:20:10 AM
9:20:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 7B 09 81 80 1F 00 F9 00 07 66 01 00 44 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 07 69 01 00 44 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 E4 01 00 45 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 05 E3 01 00 45 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 83 E3 01 00 45 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00 02 E4 01 00 45 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 07 3B 01 00 45 07 00 FF 03 00 1F 00 F9 01 1F 00
9:20:11 AM
9:20:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 7C 09 81 80 F9 01 87 30 01 00 45 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 83 63 01 00 45 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 83 66 01 00 45 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 69 01 00 45 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 81 E4 01 00 46 02 00 FF 03 00 1F 00 79 00 1F 00 F9 00 06 E3 01 00 46 04 00 FF 05 00 1F 00 59 00 1F 00 D9 00 84 E3 01 00 46 05 00 FF 04 00 1F 00 79 00 1F 00 F9 00
9:20:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 7D 09 81 80 03 E4 01 00 46 06 00 FF 04 00 1F 00 79 00 1F 00 F9 00 85 D4 01 00 46 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 31 01 00 46 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 87 63 01 00 46 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 87 66 01 00 46 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 69 01 00 46 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 C5 01 00 47 03 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 03 58
9:20:12 AM
9:20:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 7E 09 81 80 01 00 47 04 00 FF 05 00 1F 00 91 00 1F 00 D9 00 05 C5 01 00 47 06 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 82 3A 01 00 47 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 00 BB 01 00 47 07 01 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 BB 01 00 47 07 02 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 BB 01 00 47 07 03 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 BB 01 00 47 07 04 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 BB 01 00
9:20:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 7F 09 81 80 47 07 05 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 BB 01 00 47 07 06 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 BB 01 00 47 07 07 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 BB 01 00 47 07 08 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 BB 01 00 47 07 09 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 BB 01 00 47 07 0A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 BB 01 00 47 07 0B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 BB 01 00 47 07
9:20:13 AM
9:20:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 80 09 81 80 0C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 BB 01 00 47 07 0D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 BB 01 00 47 07 0E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 BB 01 00 47 07 0F FF 03 00 1F 01 F9 01 1F 01 F9 01 87 BB 01 00 47 07 10 FF 03 00 1F 01 F9 01 1F 01 F9 01 00 BC 01 00 47 07 11 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 BC 01 00 47 07 12 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 BC 01 00 47 07 13 FF
9:20:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 81 09 81 80 03 00 1F 01 F9 01 1F 01 F9 01 03 BC 01 00 47 07 14 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 BC 01 00 47 07 15 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 BC 01 00 47 07 16 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 BC 01 00 47 07 17 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 BC 01 00 47 07 18 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 BC 01 00 47 07 19 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 BC 01 00 47 07 1A FF 03 00
9:20:14 AM
9:20:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 82 09 81 80 1F 01 F9 01 1F 01 F9 01 82 BC 01 00 47 07 1B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 BC 01 00 47 07 1C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 BC 01 00 47 07 1D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 BC 01 00 47 07 1E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 BC 01 00 47 07 1F FF 03 00 1F 01 F9 01 1F 01 F9 01 85 C6 01 00 47 07 7C FF 03 00 1F 01 B9 00 1F 01 F9 00 82 C5 01 00 47 1B 00 FF 03 00 1F 00
9:20:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 83 09 81 80 F9 01 1F 00 F9 01 85 C5 01 00 47 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 2C 01 00 47 80 80 FF 01 00 19 00 F7 01 19 00 F7 01 02 C4 01 00 48 03 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 05 C4 01 00 48 06 00 FF 04 00 1F 00 F9 01 1F 00 F9 01 86 3A 01 00 48 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 00 B5 01 00 48 07 01 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B5 01 00 48 07 02 FF 03 00 1F 01 F9 01
9:20:15 AM
9:20:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 84 09 81 80 1F 01 F9 01 02 B5 01 00 48 07 03 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B5 01 00 48 07 04 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 B5 01 00 48 07 05 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B5 01 00 48 07 06 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 B5 01 00 48 07 07 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B5 01 00 48 07 08 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B5 01 00 48 07 09 FF 03 00 1F 01 F9 01 1F 01
9:20:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 85 09 81 80 F9 01 81 B5 01 00 48 07 0A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B5 01 00 48 07 0B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 B5 01 00 48 07 0C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 B5 01 00 48 07 0D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 B5 01 00 48 07 0E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B5 01 00 48 07 0F FF 03 00 1F 01 F9 01 1F 01 F9 01 87 B5 01 00 48 07 10 FF 03 00 1F 01 F9 01 1F 01 F9 01
9:20:16 AM
9:20:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 86 09 81 80 00 B6 01 00 48 07 11 FF 03 00 1F 01 F9 01 1F 01 F9 01 01 B6 01 00 48 07 12 FF 03 00 1F 01 F9 01 1F 01 F9 01 02 B6 01 00 48 07 13 FF 03 00 1F 01 F9 01 1F 01 F9 01 03 B6 01 00 48 07 14 FF 03 00 1F 01 F9 01 1F 01 F9 01 04 B6 01 00 48 07 15 FF 03 00 1F 01 F9 01 1F 01 F9 01 05 B6 01 00 48 07 16 FF 03 00 1F 01 F9 01 1F 01 F9 01 06 B6 01 00 48 07 17 FF 03 00 1F 01 F9 01 1F 01 F9 01 07 B6
9:20:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 87 09 81 80 01 00 48 07 18 FF 03 00 1F 01 F9 01 1F 01 F9 01 80 B6 01 00 48 07 19 FF 03 00 1F 01 F9 01 1F 01 F9 01 81 B6 01 00 48 07 1A FF 03 00 1F 01 F9 01 1F 01 F9 01 82 B6 01 00 48 07 1B FF 03 00 1F 01 F9 01 1F 01 F9 01 83 B6 01 00 48 07 1C FF 03 00 1F 01 F9 01 1F 01 F9 01 84 B6 01 00 48 07 1D FF 03 00 1F 01 F9 01 1F 01 F9 01 85 B6 01 00 48 07 1E FF 03 00 1F 01 F9 01 1F 01 F9 01 86 B6 01 00
9:20:17 AM
9:20:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 88 09 81 80 48 07 1F FF 03 00 1F 01 F9 01 1F 01 F9 01 82 C6 01 00 48 07 7C FF 03 00 1F 01 B9 00 1F 01 F9 00 07 23 01 00 48 18 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 82 C4 01 00 48 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 C4 01 00 48 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 81 24 01 00 48 20 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 06 C0 01 00 48 21 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 80 24 01 00 48 22
9:20:18 AM
9:20:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 89 09 81 80 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 83 24 01 00 48 24 00 FF 01 00 1F 00 B9 00 1F 00 F9 00 07 C0 01 00 48 25 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 82 24 01 00 48 26 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 02 2C 01 00 48 80 80 FF 01 00 19 00 F7 01 19 00 F7 01 82 CB 01 00 49 03 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 02 CB 01 00 49 05 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 02 CC 01 00 49 06 00 FF
9:20:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 8A 09 81 80 04 00 1F 00 B9 00 1F 00 F9 00 03 CE 01 00 49 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 83 CC 01 00 49 0E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 03 CD 01 00 49 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 CD 01 00 49 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 00 D3 01 00 4B 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 D1 01 00 4B 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 83 61 01 00 4B 09 00 FF 03 00
9:20:19 AM
9:20:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 8B 09 81 80 1F 00 79 00 1F 00 F9 00 83 64 01 00 4B 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 67 01 00 4B 1E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 D3 01 00 4C 07 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 80 D1 01 00 4C 08 00 FF 03 00 1F 00 79 00 1F 00 F9 00 87 61 01 00 4C 09 00 FF 03 00 1F 00 79 00 1F 00 F9 00 87 64 01 00 4C 1D 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 67 01 00 4C 1E 00 FF 03 00 1F 00
9:20:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 8C 09 81 80 F9 01 1F 00 F9 01 00 C6 01 00 51 07 01 FF 03 00 1F 00 F9 01 1F 00 F9 01 01 C6 01 00 51 07 02 FF 03 00 1F 00 F9 01 1F 00 F9 01 02 C6 01 00 51 07 0C FF 03 00 1F 00 F9 01 1F 00 F9 01 03 C6 01 00 51 07 28 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 C6 01 00 51 07 33 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 C6 01 00 51 07 3E FF 03 00 1F 00 F9 01 1F 00 F9 01 02 4E 01 00 54 03 00 FF 04 00 1F 00 B9 00
9:20:20 AM
9:20:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 8D 09 81 80 1F 00 F9 00 04 4E 01 00 54 05 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 06 4E 01 00 54 06 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 04 CE 01 00 54 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 84 CC 01 00 54 0E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 04 CD 01 00 54 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 CD 01 00 54 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 CB 01 00 55 03 00 FF 04 00 1F 00 B9 00 1F 00
9:20:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 8E 09 81 80 F9 00 03 CB 01 00 55 05 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 03 CC 01 00 55 06 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 05 CE 01 00 55 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 85 CC 01 00 55 0E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 05 CD 01 00 55 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 CD 01 00 55 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 84 CB 01 00 56 03 00 FF 04 00 1F 00 B9 00 1F 00 F9 00
9:20:21 AM
9:20:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 8F 09 81 80 04 CB 01 00 56 05 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 04 CC 01 00 56 06 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 06 CE 01 00 56 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 86 CC 01 00 56 0E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 06 CD 01 00 56 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 86 CD 01 00 56 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 85 CB 01 00 57 03 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 05 CB
9:20:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 90 09 81 80 01 00 57 05 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 05 CC 01 00 57 06 00 FF 04 00 1F 00 B9 00 1F 00 F9 00 07 CE 01 00 57 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 87 CC 01 00 57 0E 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 07 CD 01 00 57 1B 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 87 CD 01 00 57 1C 00 FF 03 00 1F 00 F9 01 1F 00 F9 01 83 3A 01 00 5A 07 00 FF 03 00 1F 00 B9 00 1F 00 F9 00 81 19 01 00
9:20:22 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:20:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 91 09 81 80 60 F2 00 FF 01 00 1F 00 91 00 1F 00 D9 00 81 01 01 00 60 F2 0A FF 01 00 1F 00 91 00 1F 00 D9 00 82 19 01 00 60 F3 00 FF 01 00 1F 00 91 00 1F 00 D9 00 82 01 01 00 60 F3 0A FF 01 00 1F 00 91 00 1F 00 D9 00 81 04 01 00 60 F4 02 FF 01 00 17 00 92 00 1F 00 D9 00 83 04 01 00 60 F4 03 FF 01 00 17 00 92 00 17 00 D9 00 82 04 01 00 60 F4 0C FF 01 00 17 00 92 00 17 00 D9 00 84 04 01 00 60 F4
9:20:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 92 09 81 80 0D FF 01 00 17 00 92 00 17 00 D9 00 85 18 01 00 60 F5 00 FF 01 00 1F 00 91 00 1F 00 D9 00 84 18 01 00 60 F6 00 FF 01 00 1F 00 91 00 1F 00 D9 00 00 70 01 00 63 01 00 FF 07 00 1F 00 91 00 1F 00 D9 00 01 70 01 00 63 02 00 FF 07 00 1F 00 91 00 1F 00 D9 00 03 70 01 00 63 61 00 FF 07 00 1F 00 91 00 1F 00 D9 00 02 70 01 00 63 62 00 FF 07 00 1F 00 91 00 1F 00 D9 00 82 74 01 00 63 63 00 FF
9:20:23 AM
9:20:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 93 09 81 80 07 00 1F 00 B1 01 1F 00 B1 01 86 28 01 01 00 02 00 FF 01 00 17 00 BA 00 17 00 F9 00 00 29 01 01 00 02 08 FF 01 00 17 00 BA 00 17 00 F9 00 00 F0 00 00 28 00 00 FF 0C 00 FF 00 B8 00 AF 31 03 00 D7 31 03 00 6F BD 02 00 00 00 00 00 00 00 00 00 0B BE 02 00 BC C9 06 00 C8 C9 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 F5 BF 02 00 35 C0 02 00 00 00 00 00 00 00 00 00 79 C0 02 00 83 C0 02 00
9:20:24 AM
9:20:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 94 09 81 80 E0 C9 06 00 F0 C9 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 F5 BF 02 00 35 C0 02 00 95 BF 02 00 A9 BF 02 00 00 00 00 00 00 00 00 00 79 C0 02 00 83 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 C1 BF 02 00 0C CA 06 00 24 CA 06 00 3C CA 06 00 AF 31 03 00 D7 31 03 00 F5 BF 02 00 F5 BF 02 00 35 C0 02 00 95 BF 02 00 A9 BF 02 00 A9 BF 02 00 9B 7C 03 00 CD 7C 03 00 00 00 00 00 00 00 00 00
9:20:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 95 09 81 80 00 00 00 00 00 00 00 00 83 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01 7D 03 00 5D 7D 03 00 00 00 00 00 00 00 00 00 00 00 00 00 50 CA 06 00 78 CA 06 00 A0 CA 06 00 AF 31 03 00 D7 31 03 00 6D C8 02 00 C5 C9 02 00 41 CB 02 00 00 00 00 00 00 00 00 00 00 00 00 00 B9 CB 02 00 B9 CB 02 00 B8 CA 06 00 CC CA 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 8D DB 02 00 EB DB 02 00 B1 DC 02 00
9:20:25 AM
9:20:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 96 09 81 80 DD DC 02 00 15 DD 02 00 73 DD 02 00 9D DD 02 00 00 00 00 00 00 00 00 00 00 00 00 00 C7 DD 02 00 89 DF 02 00 D9 DF 02 00 DD DF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 E1 DF 02 00 FD DF 02 00 EC CA 06 00 10 CB 06 00 34 CB 06 00 AF 31 03 00 D7 31 03 00 71 B3 02 00 A3 B3 02 00 CB B3 02 00 FD B3 02 00 39 B4 02 00 75 B4 02 00 99 B4 02 00 BB B4 02 00 00 00 00 00 00 00 00 00 CB B4 02 00
9:20:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 97 09 81 80 E5 B4 02 00 00 00 00 00 23 B5 02 00 5F B5 02 00 9D B5 02 00 D7 B5 02 00 00 00 00 00 4C CB 06 00 74 CB 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 F9 E6 02 00 00 00 00 00 00 00 00 00 DF E8 02 00 00 00 00 00 39 EA 02 00 A8 CB 06 00 B4 CB 06 00 C0 CB 06 00 AF 31 03 00 D7 31 03 00 C5 E1 02 00 00 00 00 00 00 00 00 00 7F E2 02 00 D4 CB 06 00 E0 CB 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00
9:20:26 AM
9:20:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 98 09 81 80 19 FD 02 00 03 00 03 00 67 00 03 00 93 00 03 00 21 01 03 00 8D 01 03 00 09 02 03 00 1B 02 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4B 01 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 07 03 00 03 07 03 00 03 07 03 00 03 07 03 00 F8 CB 06 00 20 CC 06 00 48 CC 06 00 AF 31 03 00 D7 31 03 00 7F 2C 03 00 7F 2C 03 00 7F 2C 03 00 7F 2C 03 00
9:20:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 99 09 81 80 7F 2C 03 00 7F 2C 03 00 00 00 00 00 00 00 00 00 8D 2C 03 00 8D 2C 03 00 8D 2C 03 00 8D 2C 03 00 8D 2C 03 00 8D 2C 03 00 00 00 00 00 CD 2D 03 00 CD 2D 03 00 CD 2D 03 00 CD 2D 03 00 68 CC 06 00 88 CC 06 00 A8 CC 06 00 AF 31 03 00 D7 31 03 00 31 07 03 00 C8 CC 06 00 00 00 00 00 00 00 00 00 AF 31 03 00 D7 31 03 00 AB 26 03 00 AB 26 03 00 AB 26 03 00 AB 26 03 00 AB 26 03 00 AB 26 03 00
9:20:27 AM
9:20:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 9A 09 81 80 AB 26 03 00 AB 26 03 00 00 00 00 00 00 00 00 00 F5 26 03 00 F5 26 03 00 F5 26 03 00 F5 26 03 00 F5 26 03 00 F5 26 03 00 F5 26 03 00 F5 26 03 00 E0 CC 06 00 08 CD 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 6B F5 02 00 9F F5 02 00 6B F6 02 00 27 F7 02 00 6B F5 02 00 9F F5 02 00 6B F6 02 00 27 F7 02 00 3D F8 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 9B 09 81 80 6D F8 02 00 B5 F8 02 00 59 F9 02 00 01 FA 02 00 D9 FA 02 00 00 00 00 00 03 FB 02 00 3C CD 06 00 68 CD 06 00 94 CD 06 00 AF 31 03 00 D7 31 03 00 25 D0 02 00 25 D0 02 00 25 D0 02 00 00 00 00 00 00 00 00 00 5B D1 02 00 5B D1 02 00 5B D1 02 00 A8 CD 06 00 BC CD 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 F5 E2 02 00 F5 E2 02 00 F5 E2 02 00 00 00 00 00 00 00 00 00 9B E5 02 00 9B E5 02 00
9:20:28 AM
9:20:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 9C 09 81 80 9B E5 02 00 DC CD 06 00 F0 CD 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 67 27 03 00 67 27 03 00 67 27 03 00 67 27 03 00 67 27 03 00 67 27 03 00 67 27 03 00 67 27 03 00 00 00 00 00 00 00 00 00 BB 27 03 00 BB 27 03 00 BB 27 03 00 BB 27 03 00 BB 27 03 00 BB 27 03 00 BB 27 03 00 BB 27 03 00 10 CE 06 00 38 CE 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 2B 08 03 00 2B 08 03 00 2B 08 03 00
9:20:29 AM
9:20:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 9D 09 81 80 00 00 00 00 00 00 00 00 25 09 03 00 25 09 03 00 25 09 03 00 6C CE 06 00 80 CE 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 65 E5 03 00 65 E5 03 00 65 E5 03 00 65 E5 03 00 65 E5 03 00 65 E5 03 00 00 00 00 00 00 00 00 00 ED E6 03 00 ED E6 03 00 ED E6 03 00 ED E6 03 00 ED E6 03 00 ED E6 03 00 A0 CE 06 00 C0 CE 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 7D 0A 03 00 7D 0A 03 00 7D 0A 03 00
9:20:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 9E 09 81 80 7D 0A 03 00 7D 0A 03 00 00 00 00 00 00 00 00 00 93 0B 03 00 93 0B 03 00 93 0B 03 00 93 0B 03 00 93 0B 03 00 00 00 00 00 45 0D 03 00 EC CE 06 00 08 CF 06 00 24 CF 06 00 AF 31 03 00 D7 31 03 00 9B 40 03 00 9B 40 03 00 9B 40 03 00 9B 40 03 00 9B 40 03 00 9B 40 03 00 00 00 00 00 00 00 00 00 F3 41 03 00 F3 41 03 00 F3 41 03 00 F3 41 03 00 F3 41 03 00 F3 41 03 00 00 00 00 00 77 44 03 00
9:20:30 AM
9:20:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 9F 09 81 80 38 CF 06 00 58 CF 06 00 78 CF 06 00 AF 31 03 00 D7 31 03 00 37 18 03 00 37 18 03 00 37 18 03 00 37 18 03 00 37 18 03 00 00 00 00 00 00 00 00 00 8D 18 03 00 8D 18 03 00 8D 18 03 00 8D 18 03 00 8D 18 03 00 8C CF 06 00 A8 CF 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 4F 19 03 00 4F 19 03 00 4F 19 03 00 4F 19 03 00 4F 19 03 00 4F 19 03 00 4F 19 03 00 4F 19 03 00 4F 19 03 00 00 00 00 00
9:20:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A0 09 81 80 00 00 00 00 05 1B 03 00 05 1B 03 00 05 1B 03 00 05 1B 03 00 05 1B 03 00 05 1B 03 00 05 1B 03 00 05 1B 03 00 05 1B 03 00 D0 CF 06 00 FC CF 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 8B 20 03 00 8B 20 03 00 8B 20 03 00 8B 20 03 00 00 00 00 00 00 00 00 00 17 22 03 00 17 22 03 00 17 22 03 00 17 22 03 00 34 D0 06 00 4C D0 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 4D 25 03 00 4D 25 03 00
9:20:31 AM
9:20:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A1 09 81 80 4D 25 03 00 00 00 00 00 00 00 00 00 97 25 03 00 97 25 03 00 97 25 03 00 70 D0 06 00 84 D0 06 00 00 00 00 00 AF 31 03 00 D7 31 03 00 75 2B 03 00 75 2B 03 00 75 2B 03 00 75 2B 03 00 00 00 00 00 00 00 00 00 95 2B 03 00 95 2B 03 00 95 2B 03 00 95 2B 03 00 00 00 00 00 AF 2B 03 00 AF 2B 03 00 A4 D0 06 00 BC D0 06 00 D4 D0 06 00 AF 31 03 00 D7 31 03 00 49 BE 02 00 49 BE 02 00 49 BE 02 00
9:20:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A2 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 C7 BE 02 00 C7 BE 02 00 00 00 00 00 31 BF 02 00 31 BF 02 00 EC D0 06 00 00 D1 06 00 14 D1 06 00 00 00 00 00 D4 C9 06 00 00 00 00 00 00 CA 06 00 44 CA 06 00 AC CA 06 00 E0 CA 06 00 40 CB 06 00 9C CB 06 00 C8 CB 06 00 00 00 00 00 EC CB 06 00 00 00 00 00 00 00 00 00 00 00 00 00 5C CC 06 00 00 00 00 00 D4 CC 06 00 BC CC 06 00 30 CD 06 00 9C CD 06 00
9:20:32 AM
9:20:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A3 09 81 80 D0 CD 06 00 04 CE 06 00 60 CE 06 00 00 00 00 00 00 00 00 00 00 00 00 00 94 CE 06 00 E0 CE 06 00 2C CF 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 CF 06 00 C4 CF 06 00 28 D0 06 00 00 00 00 00 64 D0 06 00 98 D0 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A4 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 D0 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 D1 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:33 AM
9:20:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A5 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 5A 00 00 00 01 00 00 00 5A 00 00 00 01 00 00 00 5A 00 00 00 01 00 00 00 00 00 02 50 03 01 00 00 00 00 00 00 68 77 00 10 01 00 02 51
9:20:34 AM
9:20:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A6 09 81 80 03 01 4C 00 02 00 00 00 6C 77 00 10 02 00 02 56 03 01 98 00 04 00 00 00 70 77 00 10 03 00 81 51 03 01 E4 00 06 00 00 00 74 77 00 10 04 00 02 52 03 01 30 01 08 00 00 00 78 77 00 10 05 00 02 53 03 01 7C 01 0A 00 00 00 7C 77 00 10 06 00 80 52 03 01 C8 01 0C 00 00 00 80 77 00 10 07 00 81 52 03 01 14 02 0E 00 00 00 84 77 00 10 08 00 82 52 03 01 60 02 10 00 00 00 88 77 00 10 09 00 83 52
9:20:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A7 09 81 80 03 01 AC 02 12 00 00 00 8C 77 00 10 0A 00 02 54 03 01 F8 02 14 00 00 00 90 77 00 10 0B 00 02 55 03 01 44 03 16 00 00 00 94 77 00 10 0C 00 01 E0 03 01 90 03 18 00 00 00 98 77 00 10 0D 00 03 E0 03 01 DC 03 1A 00 00 00 B0 77 00 10 0E 00 05 E0 03 01 28 04 1C 00 00 00 C8 77 00 10 0F 00 02 E0 03 01 74 04 1E 00 00 00 9C 77 00 10 10 00 04 E0 03 01 C0 04 20 00 00 00 B4 77 00 10 11 00 06 E0
9:20:35 AM
9:20:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A8 09 81 80 03 01 0C 05 22 00 00 00 CC 77 00 10 12 00 81 E1 03 01 58 05 24 00 00 00 A0 77 00 10 13 00 83 E1 03 01 A4 05 26 00 00 00 B8 77 00 10 14 00 85 E1 03 01 F0 05 28 00 00 00 D0 77 00 10 15 00 82 E1 03 01 3C 06 2A 00 00 00 A4 77 00 10 16 00 84 E1 03 01 88 06 2C 00 00 00 BC 77 00 10 17 00 86 E1 03 01 D4 06 2E 00 00 00 D4 77 00 10 18 00 01 E3 03 01 20 07 30 00 00 00 A8 77 00 10 19 00 03 E3
9:20:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 A9 09 81 80 03 01 6C 07 32 00 00 00 C0 77 00 10 1A 00 05 E3 03 01 B8 07 34 00 00 00 D8 77 00 10 1B 00 02 E3 03 01 04 08 36 00 00 00 AC 77 00 10 1C 00 04 E3 03 01 50 08 38 00 00 00 C4 77 00 10 1D 00 06 E3 03 01 9C 08 3A 00 00 00 DC 77 00 10 1E 00 01 58 05 02 E8 08 3C 00 00 00 24 58 00 10 1F 00 02 58 05 02 60 0A 44 00 00 00 28 58 00 10 20 00 03 58 05 02 D8 0B 4C 00 00 00 2C 58 00 10 05 50 05 51
9:20:36 AM
9:20:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 AA 09 81 80 05 56 82 51 05 52 05 53 84 52 85 52 86 52 87 52 05 54 05 55 07 E0 81 E0 83 E0 80 E0 82 E0 84 E0 87 E1 01 E2 03 E2 00 E2 02 E2 04 E2 07 E3 81 E3 83 E3 80 E3 82 E3 84 E3 FF FF 00 FF FF 00 02 00 01 00 10 00 01 00 01 00 01 00 66 00 01 00 68 00 69 00 12 00 01 00 22 00 06 00 0C 00 00 00 6C 00 6F 00 72 00 00 00 00 00 FE 9F 00 05 00 05 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 AB 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:37 AM
9:20:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 AC 09 81 80 00 00 00 00 00 00 00 00 FE 9F 00 05 00 05 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 AD 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE 9F 00 05 00 05 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:38 AM
9:20:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 AE 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE 9F 00 05 00 05 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 AF 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FE 9F 00 05 00 05 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:39 AM
9:20:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B0 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B1 09 81 80 00 00 00 00 00 00 41 42 43 44 45 46 47 48 49 4A 4B 4C 4D 4E 4F 50 51 52 53 54 55 56 57 58 59 5A 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 71 72 73 74 75 76 77 78 79 7A 30 31 32 33 34 35 36 37 38 39 2B 2F 00 00 01 00 43 46 4C 50 00 00 45 30 56 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2F B7 03 00 B8 0B 00 00 2B 43 47 4D 4D 00 00 00
9:20:40 AM
9:20:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B2 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1F BA 03 00 D0 07 00 00 2B 43 4D 45 45 3D 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 77 B7 03 00 B8 0B 00 00 2B 43 4D 55 58 3D 30 2C 30 2C 35 2C 31 32 37 2C 31 30 2C 33 2C 31 35 2C 31 30 00 00 00 00 00 00 B7 B7 03 00 B8 0B 00 00 45 30 56 31 00 00 00 00 00 00 00 00 00 00 00 00
9:20:41 AM
9:20:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B3 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2F B7 03 00 B8 0B 00 00 2B 43 50 49 4E 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 41 BC 03 00 D0 07 00 00 2B 43 50 49 4E 3D 25 30 34 75 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7 B7 03 00 40 1F 00 00 2B 43 4C 49 50 3D 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:41 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B4 09 81 80 00 00 00 00 00 00 00 00 19 B8 03 00 E8 03 00 00 2B 43 52 43 3D 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4F B8 03 00 E8 03 00 00 2B 43 47 4D 49 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DB B9 03 00 D0 07 00 00 2B 43 47 4D 52 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:42 AM
9:20:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B5 09 81 80 77 BA 03 00 D0 07 00 00 2B 43 47 53 4E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 85 B8 03 00 D0 07 00 00 2B 43 43 49 44 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 B9 03 00 D0 07 00 00 2B 43 4F 50 53 3D 33 2C 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C5 BA 03 00 D0 07 00 00
9:20:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B6 09 81 80 2B 57 49 50 43 46 47 3D 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E7 BA 03 00 D0 07 00 00 2B 43 4D 47 46 3D 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 BB 03 00 D0 07 00 00 2B 43 4E 4D 49 3D 32 2C 31 2C 30 2C 30 2C 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7B BB 03 00 D0 07 00 00 2B 43 50 4D 53 3D 22 4D
9:20:43 AM
9:20:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B7 09 81 80 45 22 2C 22 4D 45 22 2C 22 4D 45 22 00 00 00 00 00 00 00 00 00 00 00 00 B1 BB 03 00 B8 0B 00 00 2B 43 4D 47 44 3D 31 2C 34 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E7 BB 03 00 B8 0B 00 00 2B 43 4F 50 53 3D 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2F C1 03 00 50 C3 00 00 2B 43 43 45 44 3D 30 2C 31 31 00 00 00 00 00 00
9:20:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B8 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 73 C0 03 00 40 1F 00 00 2B 43 50 49 4E 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 41 BC 03 00 D0 07 00 00 2B 43 53 51 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 81 BD 03 00 D0 07 00 00 2B 43 52 45 47 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:44 AM
9:20:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 B9 09 81 80 00 00 00 00 00 00 00 00 1D BE 03 00 D0 07 00 00 2B 43 47 52 45 47 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 BE 03 00 D0 07 00 00 2B 43 4F 50 53 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 33 BF 03 00 D0 07 00 00 2B 43 47 41 43 54 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 BA 09 81 80 DB BF 03 00 D0 07 00 00 2B 43 50 4D 53 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 B6 03 00 D0 07 00 00 2C 01 00 00 58 02 00 00 B0 04 00 00 60 09 00 00 C0 12 00 00 80 25 00 00 00 4B 00 00 00 96 00 00 00 E1 00 00 00 C2 01 00 00 80 80 00 80 00 00 80 80 00 00 80 00 80 80 00 80 00 00 80 00 80 80 00 00 80 80 00 80 00 00 80 80 00 00 80 00 80 80 00
9:20:45 AM
9:20:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 BB 09 81 80 00 80 80 00 80 00 00 80 00 80 80 00 80 00 00 80 80 00 00 80 00 80 80 00 80 00 00 80 00 80 80 00 00 80 80 00 80 00 00 80 00 80 80 00 80 00 00 80 80 00 00 80 00 80 80 00 00 80 80 00 80 00 00 80 80 00 00 80 00 80 80 00 80 00 00 80 00 80 80 00 00 80 80 00 80 00 00 80 01 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 E8 03 00 00 00 00 00 00 10 27 00 00 00 00 00 00
9:20:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 BC 09 81 80 A0 86 01 00 00 00 00 00 40 42 0F 00 00 00 00 00 80 96 98 00 00 00 00 00 00 E1 F5 05 00 00 00 00 00 CA 9A 3B 00 00 00 00 00 E4 0B 54 02 00 00 00 00 E8 76 48 17 00 00 00 00 10 A5 D4 E8 00 00 00 10 10 10 10 01 00 10 11 10 11 01 00 11 11 90 11 01 00 90 10 93 10 01 00 94 10 97 10 01 00 97 07 97 07 17 00 10 0F 10 0F 17 00 16 15 16 15 17 00 10 13 14 13 06 00 10 12 10 12 02 00 11 12 11 12
9:20:46 AM
9:20:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 BD 09 81 80 03 00 92 13 95 13 05 00 90 14 93 14 05 00 96 14 97 14 06 00 10 15 10 15 17 00 90 15 93 15 06 00 94 15 97 15 13 00 10 16 12 16 05 00 13 16 94 16 06 00 95 16 95 16 13 00 96 16 96 16 06 00 10 17 11 17 06 00 16 18 16 18 06 00 12 09 12 09 05 00 13 09 13 09 05 00 15 17 15 17 06 00 16 17 17 17 13 00 11 18 11 18 01 00 14 09 14 09 05 00 15 09 15 09 05 00 10 19 13 19 06 00 11 00 15 00 06 00
9:20:47 AM
9:20:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 BE 09 81 80 91 19 93 19 05 00 11 1A 15 1A 06 00 90 1A 12 1B 06 00 10 30 17 32 04 00 10 D0 90 D0 04 00 10 33 95 35 09 00 10 36 97 38 09 00 91 D0 94 D0 09 00 92 3B 97 3C 0B 00 10 3D 90 3D 04 00 94 39 97 39 06 00 10 3A 13 3A 06 00 15 3A 16 3A 06 00 90 3A 93 3A 0D 00 10 C5 95 C5 0D 00 10 B7 96 BC 16 00 10 B1 96 B6 16 00 94 3A 96 3A 0E 00 10 C4 95 C4 0E 00 15 23 17 23 0E 00 97 3A 14 3B 07 00 10 40
9:20:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 BF 09 81 80 92 41 07 00 93 41 96 41 07 00 10 42 92 43 0A 00 93 43 96 43 0A 00 96 35 97 35 0A 00 10 44 96 45 0C 00 15 3B 91 3B 0C 00 93 D4 95 D4 0C 00 11 E0 94 E0 07 00 95 E0 90 E1 07 00 10 46 96 46 07 00 10 47 96 48 07 00 10 49 96 4A 0A 00 10 4B 96 4C 0C 00 10 50 10 50 06 00 11 50 13 50 07 00 14 50 14 50 06 00 15 50 13 51 07 00 14 51 14 51 06 00 15 51 17 51 07 00 90 51 94 51 07 00 11 52 15 53
9:20:48 AM
9:20:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C0 09 81 80 0A 00 90 53 97 53 0A 00 11 54 15 55 0C 00 11 56 1B 57 07 00 11 58 13 58 0D 00 90 58 97 59 07 00 10 5A 97 5D 0A 00 97 00 97 00 05 00 10 FF 10 FF 06 00 10 CF 10 CF 10 00 10 CE 17 CE 11 00 11 4E 14 4E 11 00 10 61 97 61 04 00 10 62 17 63 09 00 90 63 97 63 0B 00 10 6A 97 6B 04 00 10 6C 97 6E 09 00 10 6F 97 6F 0B 00 10 64 97 64 04 00 10 65 17 66 09 00 90 66 97 66 0B 00 10 67 97 67 04 00
9:20:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C1 09 81 80 10 68 17 69 09 00 90 69 97 69 0B 00 95 D0 90 D1 04 00 91 D1 92 D2 09 00 93 D2 14 D3 07 00 15 D3 92 D4 0A 00 93 D4 95 D4 0C 00 92 28 92 28 01 00 94 28 94 28 01 00 10 29 10 29 01 00 96 28 96 28 01 00 94 0A 94 0A 06 00 2C 01 00 00 58 02 00 00 B0 04 00 00 60 09 00 00 C0 12 00 00 80 25 00 00 00 4B 00 00 00 96 00 00 00 E1 00 00 00 C2 01 00 29 2A 2B 00 00 00 00 FA 00 01 01 01 46 00 47 00
9:20:49 AM
9:20:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C2 09 81 80 48 00 1E 00 17 03 1E 00 1A 03 00 00 00 00 00 00 00 00 FF 01 01 00 00 00 01 02 00 01 02 00 00 00 01 01 01 00 03 00 00 00 01 01 02 00 04 00 00 00 01 02 00 02 05 00 00 00 02 02 02 01 06 00 00 00 02 01 01 02 07 00 00 00 03 01 01 02 08 00 00 00 03 02 02 01 00 00 00 00 00 00 00 00 02 03 06 07 04 05 00 00 02 03 06 07 01 05 00 00 02 03 07 00 04 05 00 00 02 03 07 00 01 05 00 00 02 03 06 07
9:20:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C3 09 81 80 04 05 08 00 02 03 07 00 04 05 08 00 00 00 32 00 1E 00 64 00 00 00 92 00 00 00 32 00 1E 00 64 00 00 00 92 00 01 00 00 00 F4 01 00 00 00 00 54 00 01 00 00 00 64 00 00 00 00 00 58 00 01 00 00 00 64 00 00 00 00 00 58 00 01 00 00 00 64 00 00 00 00 00 58 00 01 00 00 00 64 00 32 00 00 00 58 00 15 00 00 16 01 00 17 02 00 18 06 01 19 07 01 1A 0C 01 1B 08 01 1C 09 01 1D 0A 01 1E 0B 01 1F 0D
9:20:50 AM
9:20:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C4 09 81 80 02 20 0E 02 21 0F 02 00 00 00 00 00 01 00 00 00 02 00 00 00 03 00 00 00 04 00 00 00 05 00 00 00 06 00 00 00 07 00 00 00 00 54 54 54 54 54 54 54 54 54 54 54 52 52 52 52 81 81 92 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 81 92 92 92 00 0D 01 02 00 7F 00 2C 01 04 00 7F 00 2C 01 90 01 10 27 04 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:20:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C5 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 91 E3 72 07 96 E4 75 0E 9F ED 7C 09 98 EA 7B 1C 8D FF 6E 1B 8A F8 69 12 83 F1 60 15 84 F6 67 38 A9 DB 4A 3F AE DC 4D 36 A7 D5 44 31 A0 D2 43 24 B5 C7 56 23 B2 C0 51 2A BB C9 58 2D BC CE 5F 70 E1 93 02 77 E6 94 05 7E EF 9D 0C 79 E8 9A 0B
9:20:51 AM
9:20:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C6 09 81 80 6C FD 8F 1E 6B FA 88 19 62 F3 81 10 65 F4 86 17 48 D9 AB 3A 4F DE AC 3D 46 D7 A5 34 41 D0 A2 33 54 C5 B7 26 53 C2 B0 21 5A CB B9 28 5D CC BE 2F E0 71 03 92 E7 76 04 95 EE 7F 0D 9C E9 78 0A 9B FC 6D 1F 8E FB 6A 18 89 F2 63 11 80 F5 64 16 87 D8 49 3B AA DF 4E 3C AD D6 47 35 A4 D1 40 32 A3 C4 55 27 B6 C3 52 20 B1 CA 5B 29 B8 CD 5C 2E BF 90 01 73 E2 97 06 74 E5 9E 0F 7D EC 99 08 7A EB
9:20:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C7 09 81 80 8C 1D 6F FE 8B 1A 68 F9 82 13 61 F0 85 14 66 F7 A8 39 4B DA AF 3E 4C DD A6 37 45 D4 A1 30 42 D3 B4 25 57 C6 B3 22 50 C1 BA 2B 59 C8 BD 2C 5E CF ED 03 00 00 B1 82 04 00 F9 82 04 00 51 83 04 00 00 00 00 00 71 83 04 00 A9 83 04 00 EF 83 04 00 00 00 00 00 65 84 04 00 B1 84 04 00 11 85 04 00 55 85 04 00 A9 85 04 00 C9 85 04 00 FB 85 04 00 19 86 04 00 00 00 00 00 49 86 04 00 C9 86 04 00
9:20:52 AM
9:20:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C8 09 81 80 5F 87 04 00 EF 87 04 00 4F 88 04 00 87 88 04 00 00 00 00 00 F9 88 04 00 00 00 00 00 15 89 04 00 55 89 04 00 B9 89 04 00 00 00 00 00 E7 89 04 00 00 00 00 00 1B 8A 04 00 00 00 00 00 99 8A 04 00 C5 8A 04 00 0B 8B 04 00 43 8B 04 00 7D 8B 04 00 E9 8B 04 00 BF 8C 04 00 DB 8C 04 00 F5 8C 04 00 00 00 00 00 1D 8D 04 00 75 8D 04 00 11 8E 04 00 00 00 00 00 85 8E 04 00 00 00 00 00 E7 8E 04 00
9:20:53 AM
9:20:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 C9 09 81 80 3B 8F 04 00 7D 8F 04 00 DD 8F 04 00 57 90 04 00 F3 90 04 00 F7 90 04 00 63 91 04 00 67 91 04 00 00 00 00 00 C7 91 04 00 00 00 00 00 27 92 04 00 00 00 00 00 87 92 04 00 00 00 00 00 E7 92 04 00 00 00 00 00 27 93 04 00 00 00 00 00 53 93 04 00 00 00 00 00 8B 93 04 00 FB 93 04 00 73 94 04 00 00 00 00 00 81 94 04 00 00 00 00 00 CD 94 04 00 00 00 00 00 07 95 04 00 00 00 00 00 6D 95 04 00
9:20:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 CA 09 81 80 00 00 00 00 15 96 04 00 00 00 00 00 BD 96 04 00 00 00 00 00 BB 97 04 00 00 00 00 00 0B 98 04 00 00 00 00 00 61 98 04 00 00 00 00 00 A3 98 04 00 00 00 00 00 EF 98 04 00 00 00 00 00 69 9A 04 00 00 00 00 00 71 9C 04 00 00 00 00 00 F1 9C 04 00 00 00 00 00 29 9D 04 00 00 00 00 00 7D 9D 04 00 00 00 00 00 AF 9D 04 00 00 00 00 00 E1 9D 04 00 00 00 00 00 23 9E 04 00 00 00 00 00 55 9E 04 00
9:20:54 AM
9:20:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 CB 09 81 80 B7 9E 04 00 ED 9E 04 00 00 00 00 00 23 9F 04 00 00 00 00 00 49 9F 04 00 00 00 00 00 7D 9F 04 00 00 00 00 00 A3 9F 04 00 00 00 00 00 D7 9F 04 00 00 00 00 00 FD 9F 04 00 00 00 00 00 31 A0 04 00 00 00 00 00 57 A0 04 00 00 00 00 00 8B A0 04 00 00 00 00 00 B1 A0 04 00 00 00 00 00 E5 A0 04 00 00 00 00 00 4D A1 04 00 00 00 00 00 CF A1 04 00 00 00 00 00 0D A2 04 00 2D A2 04 00 47 A2 04 00
9:20:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 CC 09 81 80 00 00 00 00 67 A2 04 00 C5 A2 04 00 E1 A2 04 00 00 00 00 00 6D A3 04 00 00 00 00 00 99 A3 04 00 CF A3 04 00 47 A4 04 00 7B A4 04 00 D5 A4 04 00 47 A5 04 00 C3 A5 04 00 00 00 00 00 7B A6 04 00 00 00 00 00 F9 A6 04 00 00 00 00 00 21 A7 04 00 B9 A7 04 00 6D A8 04 00 A1 AA 04 00 33 AD 04 00 00 00 00 00 11 00 02 10 38 04 00 00 34 E4 06 00 12 00 02 10 38 04 00 00 34 E4 06 00 13 00 02 10
9:20:55 AM
9:20:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 CD 09 81 80 38 04 00 00 34 E4 06 00 14 00 02 10 38 04 00 00 34 E4 06 00 15 00 02 10 38 04 00 00 34 E4 06 00 16 00 02 10 38 04 00 00 34 E4 06 00 17 00 02 10 38 04 00 00 34 E4 06 00 97 00 0A 80 38 04 00 00 CC E3 06 00 10 01 02 10 08 04 00 00 D4 E3 06 00 11 01 02 10 09 04 00 00 D4 E3 06 00 12 01 02 10 08 04 00 00 D4 E3 06 00 13 01 02 10 09 04 00 00 D4 E3 06 00 14 01 02 10 08 04 00 00 D4 E3 06 00
9:20:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 CE 09 81 80 15 01 02 10 09 04 00 00 D4 E3 06 00 16 01 02 10 08 04 00 00 D4 E3 06 00 17 01 02 10 09 04 00 00 D4 E3 06 00 90 01 04 20 08 04 00 00 44 E4 06 00 91 01 04 20 08 04 00 00 4C E4 06 00 92 01 04 20 08 04 00 00 4C E4 06 00 93 01 04 20 08 04 00 00 4C E4 06 00 96 01 0A 80 38 04 00 00 CC E3 06 00 10 02 04 D0 38 01 00 00 74 80 00 10 11 02 04 20 38 01 00 00 7C 80 00 10 12 02 04 20 08 03 00 00
9:20:56 AM
9:20:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 CF 09 81 80 48 00 1B 00 13 02 02 10 08 03 00 00 52 00 1B 00 14 02 04 D0 38 01 00 00 84 80 00 10 15 02 04 20 38 01 00 00 8C 80 00 10 90 02 04 D0 38 01 00 00 78 80 00 10 91 02 04 20 38 01 00 00 80 80 00 10 92 02 04 20 08 03 00 00 4C 00 1B 00 93 02 02 10 08 03 00 00 54 00 1B 00 94 02 04 D0 38 01 00 00 88 80 00 10 95 02 04 20 38 01 00 00 90 80 00 10 90 03 04 20 08 03 00 00 28 05 18 00 91 03 04 20
9:20:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D0 09 81 80 08 03 00 00 2C 05 18 00 92 03 04 20 08 03 00 00 30 05 18 00 10 04 04 20 38 04 00 00 2C E4 06 00 11 04 04 20 38 04 00 00 2C E4 06 00 14 04 02 10 38 04 00 00 34 E4 06 00 15 04 02 10 38 04 00 00 34 E4 06 00 91 04 04 20 08 03 00 00 2C 00 1B 00 92 04 04 20 08 03 00 00 30 00 1B 00 93 04 04 20 08 03 00 00 34 00 1B 00 94 04 04 20 08 03 00 00 38 00 1B 00 95 04 06 A0 38 04 00 00 54 E5 06 00
9:20:57 AM
9:20:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D1 09 81 80 96 04 04 20 38 02 00 00 F0 21 02 00 97 04 04 20 38 02 00 00 F4 21 02 00 90 05 04 20 08 03 00 00 8C 03 18 00 91 05 04 20 08 03 00 00 9C 03 18 00 90 06 04 20 08 03 00 00 F4 04 18 00 10 07 04 A0 00 04 00 00 D4 E4 06 00 11 07 04 A0 00 04 00 00 D4 E4 06 00 12 07 04 A0 00 04 00 00 D4 E4 06 00 13 07 04 A0 00 04 00 00 D4 E4 06 00 14 07 04 A0 00 04 00 00 D4 E4 06 00 15 07 04 A0 00 04 00 00
9:20:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D2 09 81 80 D4 E4 06 00 16 07 04 A0 00 04 00 00 D4 E4 06 00 17 07 04 A0 00 04 00 00 D4 E4 06 00 90 07 04 A0 00 04 00 00 D4 E4 06 00 91 07 04 A0 00 04 00 00 D4 E4 06 00 92 07 04 A0 00 04 00 00 D4 E4 06 00 93 07 04 A0 00 04 00 00 D4 E4 06 00 94 07 04 A0 00 04 00 00 D4 E4 06 00 95 07 04 A0 00 04 00 00 D4 E4 06 00 96 07 04 A0 00 04 00 00 D4 E4 06 00 97 07 04 20 38 01 00 00 40 5D 00 10 12 09 04 A0
9:20:58 AM
9:20:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D3 09 81 80 08 03 00 00 04 00 21 00 13 09 04 A0 08 03 00 00 0C 00 21 00 14 09 04 A0 08 03 00 00 08 00 21 00 15 09 04 A0 08 03 00 00 10 00 21 00 93 09 01 00 30 04 00 00 EC E3 06 00 10 0A 04 D0 30 04 00 00 24 E6 06 00 90 0A 06 A0 08 04 00 00 B4 E3 06 00 91 0A 06 A0 08 04 00 00 B4 E3 06 00 92 0A 02 10 08 03 00 00 00 00 25 00 93 0A 02 10 08 03 00 00 02 00 25 00 94 0A 02 10 08 03 00 00 06 01 02 00
9:20:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D4 09 81 80 10 0B 04 20 08 04 00 00 4C E4 06 00 11 0B 04 20 08 04 00 00 4C E4 06 00 94 0E 01 00 38 04 00 00 6C E4 06 00 95 0E 01 00 38 04 00 00 6C E4 06 00 96 0E 01 00 38 04 00 00 6C E4 06 00 97 0E 01 00 38 04 00 00 6C E4 06 00 10 0F 04 20 08 04 00 00 74 E4 06 00 11 0F 01 00 08 04 00 00 74 E4 06 00 12 0F 01 00 08 04 00 00 74 E4 06 00 13 0F 01 00 08 04 00 00 74 E4 06 00 14 0F 01 00 08 04 00 00
9:20:59 AM
9:20:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D5 09 81 80 74 E4 06 00 16 0F 01 00 18 03 00 00 04 00 14 00 17 0F 01 00 18 04 00 00 7C E4 06 00 90 0F 01 00 18 03 00 00 16 00 05 00 91 0F 01 00 18 03 00 00 14 00 05 00 92 0F 01 00 30 03 00 00 15 00 05 00 93 0F 04 20 18 03 00 00 10 00 05 00 94 0F 04 A0 08 03 00 00 18 00 05 00 95 0F 03 00 18 03 00 00 00 00 27 00 96 0F 02 10 18 04 00 00 BC E3 06 00 97 0F 02 10 08 03 00 00 64 00 12 00 10 10 08 B0
9:21:00 AM
9:21:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D6 09 81 80 08 04 00 00 C4 E3 06 00 11 10 08 B0 08 04 00 00 C4 E3 06 00 10 11 08 A0 08 03 00 00 00 00 01 00 11 11 32 80 08 03 00 00 00 00 18 00 12 11 32 80 08 03 00 00 32 00 18 00 13 11 32 80 08 03 00 00 64 00 18 00 14 11 32 80 08 03 00 00 96 00 18 00 15 11 32 80 08 03 00 00 C8 00 18 00 16 11 32 80 08 03 00 00 FA 00 18 00 17 11 32 80 08 03 00 00 2C 01 18 00 90 11 32 80 08 03 00 00 5E 01 18 00
9:21:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D7 09 81 80 92 11 32 80 08 03 00 00 06 00 27 00 96 11 01 00 09 04 00 00 E4 E3 06 00 97 11 86 80 37 04 00 00 F4 E3 06 00 10 12 04 A0 08 04 00 00 FC E3 06 00 11 12 05 A0 08 04 00 00 04 E4 06 00 12 12 01 00 08 03 00 00 1A 00 1B 00 13 12 01 00 08 03 00 00 24 00 05 00 14 12 01 70 08 03 00 00 60 00 1B 00 15 12 04 A0 08 04 00 00 FC E3 06 00 16 12 04 20 08 03 00 00 5C 00 1B 00 17 12 04 20 08 03 00 00
9:21:01 AM
9:21:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D8 09 81 80 20 00 05 00 16 13 04 20 38 02 00 00 DC 21 02 00 17 13 04 D0 38 02 00 00 E0 21 02 00 92 13 04 20 08 04 00 00 CC E4 06 00 93 13 04 20 08 04 00 00 CC E4 06 00 94 13 04 20 08 04 00 00 CC E4 06 00 95 13 04 20 08 04 00 00 CC E4 06 00 97 13 01 00 38 01 00 00 42 5D 00 10 91 14 01 00 38 01 00 00 40 5D 00 10 92 14 01 00 38 01 00 00 41 5D 00 10 93 14 01 00 30 03 00 00 00 00 14 00 96 14 04 20
9:21:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 D9 09 81 80 30 04 00 00 24 E6 06 00 97 14 04 20 30 04 00 00 24 E6 06 00 10 15 04 20 08 04 00 00 3C E4 06 00 11 15 04 20 18 03 00 00 0C 00 1B 00 12 15 04 20 18 03 00 00 40 00 1B 00 14 15 04 20 18 03 00 00 1C 00 1B 00 15 15 04 20 18 03 00 00 44 00 1B 00 16 15 04 20 08 04 00 00 6C E4 06 00 90 15 02 10 38 02 00 00 8A 21 02 00 91 15 02 10 38 02 00 00 9A 21 02 00 92 15 02 10 38 02 00 00 AA 21 02 00
9:21:02 AM
9:21:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 DA 09 81 80 93 15 02 10 38 02 00 00 BA 21 02 00 94 15 04 D0 38 02 00 00 8C 21 02 00 95 15 04 D0 38 02 00 00 9C 21 02 00 96 15 04 D0 38 02 00 00 AC 21 02 00 97 15 04 D0 38 02 00 00 BC 21 02 00 10 16 02 10 38 01 00 00 50 80 00 10 11 16 01 00 30 04 00 00 64 E4 06 00 12 16 04 20 30 04 00 00 64 E4 06 00 13 16 02 10 38 02 00 00 78 21 02 00 14 16 02 10 38 02 00 00 98 21 02 00 15 16 02 10 38 02 00 00
9:21:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 DB 09 81 80 A8 21 02 00 16 16 02 10 38 02 00 00 B8 21 02 00 17 16 02 10 38 02 00 00 88 21 02 00 90 16 04 20 38 02 00 00 90 21 02 00 91 16 04 20 38 02 00 00 A0 21 02 00 92 16 04 20 38 02 00 00 B0 21 02 00 93 16 04 20 38 02 00 00 C0 21 02 00 94 16 02 10 38 02 00 00 CA 21 02 00 95 16 04 D0 38 02 00 00 CC 21 02 00 96 16 04 20 38 02 00 00 D0 21 02 00 97 16 04 20 38 04 00 00 BC E4 06 00 10 17 01 00
9:21:03 AM
9:21:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 DC 09 81 80 08 03 00 00 00 00 21 00 11 17 01 00 08 03 00 00 02 00 21 00 15 17 02 10 38 01 00 00 26 7B 00 10 17 17 04 D0 38 04 00 00 0C E4 06 00 11 18 10 A0 38 04 00 00 14 E4 06 00 12 18 02 10 38 01 00 00 B0 E3 06 00 13 18 02 10 08 03 00 00 16 00 1B 00 14 18 02 10 38 04 00 00 C4 E4 06 00 15 18 04 00 38 01 00 00 3C 5D 00 10 16 18 01 00 08 03 00 00 14 00 21 00 90 18 02 10 38 03 00 00 00 00 1B 00
9:21:04 AM
9:21:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 DD 09 81 80 91 18 04 D0 38 03 00 00 04 00 1B 00 92 18 02 10 08 03 00 00 08 00 1B 00 94 18 01 00 08 03 00 00 14 00 1B 00 95 18 01 00 08 03 00 00 15 00 1B 00 96 18 01 00 18 03 00 00 01 00 14 00 97 18 01 00 18 03 00 00 02 00 14 00 10 19 02 10 38 04 00 00 24 E4 06 00 11 19 02 10 38 04 00 00 24 E4 06 00 12 19 02 10 38 04 00 00 24 E4 06 00 13 19 02 10 38 04 00 00 24 E4 06 00 14 19 02 10 38 04 00 00
9:21:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 DE 09 81 80 24 E4 06 00 15 19 02 10 38 04 00 00 24 E4 06 00 16 19 02 10 38 04 00 00 24 E4 06 00 17 19 02 10 38 04 00 00 24 E4 06 00 90 19 04 20 08 04 00 00 44 E4 06 00 91 19 04 20 08 04 00 00 4C E4 06 00 92 19 04 20 08 04 00 00 4C E4 06 00 93 19 04 20 08 04 00 00 4C E4 06 00 96 19 02 10 30 04 00 00 5C E4 06 00 97 19 16 90 08 04 00 00 0C E6 06 00 10 1A 32 90 08 04 00 00 0C E6 06 00 11 1A 01 00
9:21:05 AM
9:21:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 DF 09 81 80 08 01 00 00 31 58 00 10 12 1A 02 10 08 04 00 00 04 E6 06 00 14 1A 01 00 08 03 00 00 04 00 13 00 15 1A 01 00 08 03 00 00 05 00 13 00 90 1A 01 00 08 03 00 00 00 00 12 00 92 1A 02 10 08 03 00 00 04 00 12 00 93 1A 02 10 08 03 00 00 02 00 12 00 10 20 04 20 08 02 00 00 80 23 02 00 11 20 04 20 08 02 00 00 90 23 02 00 12 20 04 20 08 02 00 00 A0 23 02 00 13 20 04 20 08 02 00 00 B0 23 02 00
9:21:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E0 09 81 80 14 20 04 20 08 02 00 00 C0 23 02 00 15 20 04 20 08 02 00 00 D0 23 02 00 16 20 04 20 08 02 00 00 E0 23 02 00 90 20 04 20 08 02 00 00 84 23 02 00 91 20 04 20 08 02 00 00 94 23 02 00 92 20 04 20 08 02 00 00 A4 23 02 00 93 20 04 20 08 02 00 00 B4 23 02 00 94 20 04 20 08 02 00 00 C4 23 02 00 95 20 04 20 08 02 00 00 D4 23 02 00 96 20 04 20 08 02 00 00 E4 23 02 00 10 21 04 20 08 02 00 00
9:21:06 AM
9:21:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E1 09 81 80 88 23 02 00 11 21 04 20 08 02 00 00 98 23 02 00 12 21 04 20 08 02 00 00 A8 23 02 00 13 21 04 20 08 02 00 00 B8 23 02 00 14 21 04 20 08 02 00 00 C8 23 02 00 15 21 04 20 08 02 00 00 D8 23 02 00 16 21 04 20 08 02 00 00 E8 23 02 00 90 21 04 20 08 02 00 00 8C 23 02 00 91 21 04 20 08 02 00 00 9C 23 02 00 92 21 04 20 08 02 00 00 AC 23 02 00 93 21 04 20 08 02 00 00 BC 23 02 00 94 21 04 20
9:21:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E2 09 81 80 08 02 00 00 CC 23 02 00 95 21 04 20 08 02 00 00 DC 23 02 00 96 21 04 20 08 02 00 00 EC 23 02 00 10 22 04 20 38 02 00 00 14 24 02 00 11 22 04 20 38 02 00 00 40 24 02 00 12 22 04 20 38 02 00 00 18 24 02 00 13 22 04 20 38 02 00 00 44 24 02 00 14 22 04 20 38 02 00 00 F4 23 02 00 15 22 04 20 38 02 00 00 20 24 02 00 16 22 04 20 38 02 00 00 F8 23 02 00 17 22 04 20 38 02 00 00 24 24 02 00
9:21:07 AM
9:21:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E3 09 81 80 28 22 04 D0 38 02 00 00 74 24 02 00 29 22 04 D0 38 02 00 00 94 24 02 00 2A 22 04 D0 38 02 00 00 78 24 02 00 2B 22 04 D0 38 02 00 00 98 24 02 00 2C 22 04 D0 38 02 00 00 5C 24 02 00 2D 22 04 D0 38 02 00 00 7C 24 02 00 2E 22 04 D0 38 02 00 00 60 24 02 00 2F 22 04 D0 38 02 00 00 80 24 02 00 90 22 04 20 38 02 00 00 00 24 02 00 91 22 04 20 38 02 00 00 2C 24 02 00 92 22 04 20 38 02 00 00
9:21:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E4 09 81 80 04 24 02 00 93 22 04 20 38 02 00 00 30 24 02 00 94 22 04 20 38 02 00 00 0C 24 02 00 95 22 04 20 38 02 00 00 38 24 02 00 96 22 04 20 38 02 00 00 10 24 02 00 97 22 04 20 38 02 00 00 3C 24 02 00 A8 22 04 D0 38 02 00 00 64 24 02 00 A9 22 04 D0 38 02 00 00 84 24 02 00 AA 22 04 D0 38 02 00 00 68 24 02 00 AB 22 04 D0 38 02 00 00 88 24 02 00 AC 22 04 D0 38 02 00 00 6C 24 02 00 AD 22 04 D0
9:21:08 AM
9:21:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E5 09 81 80 38 02 00 00 8C 24 02 00 AE 22 04 D0 38 02 00 00 70 24 02 00 AF 22 04 D0 38 02 00 00 90 24 02 00 10 23 04 20 18 03 00 00 20 00 1C 00 11 23 02 10 18 03 00 00 9A 00 1C 00 12 23 02 10 18 03 00 00 9C 00 1C 00 15 23 04 20 38 02 00 00 F0 23 02 00 16 23 04 20 38 02 00 00 FC 23 02 00 17 23 04 20 38 02 00 00 08 24 02 00 10 24 04 20 38 02 00 00 9C 24 02 00 11 24 02 10 38 02 00 00 A8 24 02 00
9:21:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E6 09 81 80 12 24 04 20 38 02 00 00 DC 24 02 00 13 24 02 10 38 02 00 00 E8 24 02 00 14 24 04 20 38 02 00 00 AC 24 02 00 15 24 02 10 38 02 00 00 B8 24 02 00 16 24 04 20 38 02 00 00 EC 24 02 00 17 24 02 10 38 02 00 00 F8 24 02 00 90 24 04 20 38 02 00 00 BC 24 02 00 91 24 02 10 38 02 00 00 C8 24 02 00 92 24 04 20 38 02 00 00 FC 24 02 00 93 24 02 10 38 02 00 00 08 25 02 00 94 24 02 10 08 03 00 00
9:21:09 AM
9:21:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E7 09 81 80 1C 00 05 00 11 26 01 A0 18 03 00 00 00 00 13 00 12 26 01 A0 18 03 00 00 01 00 13 00 14 26 01 A0 18 03 00 00 03 00 13 00 15 26 0C A0 18 03 00 00 06 00 13 00 16 26 01 00 18 03 00 00 66 00 12 00 17 26 01 A0 18 03 00 00 12 00 13 00 90 26 01 A0 18 03 00 00 13 00 13 00 91 26 01 A0 18 03 00 00 14 00 13 00 92 26 02 10 18 03 00 00 62 00 1B 00 93 26 02 10 18 03 00 00 16 00 13 00 94 26 02 10
9:21:10 AM
9:21:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E8 09 81 80 18 03 00 00 18 00 13 00 95 26 02 10 18 03 00 00 1A 00 13 00 11 27 12 80 09 04 00 00 4C E6 06 00 12 27 12 80 09 04 00 00 4C E6 06 00 13 27 12 80 09 04 00 00 4C E6 06 00 14 27 12 80 09 04 00 00 4C E6 06 00 90 27 22 80 09 04 00 00 4C E6 06 00 91 27 22 80 09 04 00 00 4C E6 06 00 92 27 22 80 09 04 00 00 4C E6 06 00 93 27 22 80 09 04 00 00 4C E6 06 00 94 27 22 80 09 04 00 00 4C E6 06 00
9:21:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 E9 09 81 80 95 27 22 80 09 04 00 00 4C E6 06 00 96 27 22 80 09 04 00 00 4C E6 06 00 97 27 22 80 09 04 00 00 4C E6 06 00 10 28 04 20 38 04 00 00 5C E5 06 00 11 28 04 20 38 04 00 00 64 E5 06 00 12 28 C2 81 38 04 00 00 6C E5 06 00 13 28 04 20 38 04 00 00 74 E5 06 00 14 28 88 80 08 04 00 00 7C E5 06 00 15 28 04 20 38 04 00 00 84 E5 06 00 16 28 10 A0 38 04 00 00 8C E5 06 00 17 28 04 20 38 04 00 00
9:21:11 AM
9:21:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 EA 09 81 80 94 E5 06 00 90 28 10 A0 38 04 00 00 9C E5 06 00 91 28 04 20 38 04 00 00 A4 E5 06 00 92 28 10 A0 38 04 00 00 AC E5 06 00 93 28 04 20 38 04 00 00 B4 E5 06 00 94 28 10 A0 38 04 00 00 BC E5 06 00 95 28 04 20 38 04 00 00 C4 E5 06 00 96 28 10 A0 38 04 00 00 CC E5 06 00 97 28 04 20 38 04 00 00 D4 E5 06 00 10 29 10 A0 38 04 00 00 DC E5 06 00 10 2C 04 20 30 04 00 00 54 E6 06 00 11 2C 04 20
9:21:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 EB 09 81 80 30 04 00 00 54 E6 06 00 12 2C 04 20 30 04 00 00 54 E6 06 00 13 2C 04 20 30 04 00 00 54 E6 06 00 14 2C 04 20 30 04 00 00 54 E6 06 00 15 2C 04 20 30 04 00 00 54 E6 06 00 16 2C 01 00 30 04 00 00 54 E6 06 00 17 2C 01 00 18 03 00 00 03 00 14 00 90 2C 02 10 18 03 00 00 06 00 14 00 91 2C 01 00 18 03 00 00 05 00 14 00 92 2C 01 30 18 03 00 00 08 00 14 00 93 2C 01 00 18 03 00 00 09 00 14 00
9:21:12 AM
9:21:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 EC 09 81 80 94 2C 36 A0 30 04 00 00 54 E6 06 00 95 2C 54 A0 30 04 00 00 54 E6 06 00 96 2C 41 A0 30 03 00 00 5C 00 01 00 97 2C 01 30 38 04 00 00 5C E6 06 00 10 2D 39 A0 30 03 00 00 9D 00 01 00 11 2D 41 A0 30 03 00 00 D6 00 01 00 12 2D 01 30 38 04 00 00 5C E6 06 00 13 2D 41 A0 30 03 00 00 17 01 01 00 14 2D 04 20 30 03 00 00 5C 01 01 00 15 2D 04 20 30 03 00 00 60 01 01 00 16 2D 04 A0 30 03 00 00
9:21:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 ED 09 81 80 58 01 01 00 10 2E 0F 90 08 04 00 00 0C E6 06 00 11 2E 25 90 08 04 00 00 0C E6 06 00 12 2E 23 90 08 04 00 00 0C E6 06 00 13 2E FA 90 08 04 00 00 0C E6 06 00 14 2E 90 91 08 04 00 00 0C E6 06 00 15 2E 01 00 08 01 00 00 32 58 00 10 92 2F 01 00 30 03 00 00 61 00 1B 00 93 2F 04 20 30 04 00 00 64 E4 06 00 94 2F 02 10 18 03 00 00 00 01 02 00 95 2F 05 80 08 04 00 00 14 E6 06 00 97 2F 01 00
9:21:13 AM
9:21:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 EE 09 81 80 30 04 00 00 64 E4 06 00 10 30 08 28 30 04 00 00 84 E4 06 00 11 30 08 28 30 04 00 00 84 E4 06 00 12 30 08 28 30 04 00 00 84 E4 06 00 13 30 08 28 30 04 00 00 84 E4 06 00 14 30 08 28 30 04 00 00 84 E4 06 00 95 30 08 28 30 04 00 00 84 E4 06 00 96 30 08 28 30 04 00 00 84 E4 06 00 97 30 08 28 30 04 00 00 84 E4 06 00 10 31 08 28 30 04 00 00 84 E4 06 00 11 31 08 28 30 04 00 00 84 E4 06 00
9:21:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 EF 09 81 80 12 31 08 28 30 04 00 00 84 E4 06 00 13 31 08 28 30 04 00 00 84 E4 06 00 14 31 08 28 30 04 00 00 84 E4 06 00 95 31 08 28 30 04 00 00 84 E4 06 00 96 31 08 28 30 04 00 00 84 E4 06 00 97 31 08 28 30 04 00 00 84 E4 06 00 10 32 08 28 30 04 00 00 84 E4 06 00 11 32 08 28 30 04 00 00 84 E4 06 00 12 32 08 28 30 04 00 00 84 E4 06 00 13 32 08 28 30 04 00 00 84 E4 06 00 14 32 08 28 30 04 00 00
9:21:14 AM
9:21:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F0 09 81 80 84 E4 06 00 15 32 08 28 30 04 00 00 84 E4 06 00 16 32 08 28 30 04 00 00 84 E4 06 00 17 32 08 28 30 04 00 00 84 E4 06 00 10 33 08 28 30 04 00 00 84 E4 06 00 11 33 08 28 30 04 00 00 84 E4 06 00 12 33 08 28 30 04 00 00 84 E4 06 00 13 33 08 28 30 04 00 00 84 E4 06 00 14 33 08 28 30 04 00 00 84 E4 06 00 10 34 08 28 30 04 00 00 84 E4 06 00 11 34 08 28 30 04 00 00 84 E4 06 00 12 34 08 28
9:21:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F1 09 81 80 30 04 00 00 84 E4 06 00 13 34 08 28 30 04 00 00 84 E4 06 00 14 34 08 28 30 04 00 00 84 E4 06 00 10 35 08 28 30 04 00 00 84 E4 06 00 11 35 08 28 30 04 00 00 84 E4 06 00 12 35 08 28 30 04 00 00 84 E4 06 00 13 35 08 28 30 04 00 00 84 E4 06 00 14 35 08 28 30 04 00 00 84 E4 06 00 15 35 08 28 30 04 00 00 84 E4 06 00 16 35 08 28 30 04 00 00 84 E4 06 00 17 35 08 28 30 04 00 00 84 E4 06 00
9:21:15 AM
9:21:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F2 09 81 80 96 35 04 20 38 04 00 00 3C E5 06 00 97 35 04 20 38 04 00 00 3C E5 06 00 10 36 08 28 30 04 00 00 84 E4 06 00 11 36 08 28 30 04 00 00 84 E4 06 00 12 36 08 28 30 04 00 00 84 E4 06 00 13 36 08 28 30 04 00 00 84 E4 06 00 14 36 08 28 30 04 00 00 84 E4 06 00 15 36 08 28 30 04 00 00 84 E4 06 00 16 36 08 28 30 04 00 00 84 E4 06 00 17 36 08 28 30 04 00 00 84 E4 06 00 10 37 08 28 30 04 00 00
9:21:16 AM
9:21:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F3 09 81 80 84 E4 06 00 11 37 08 28 30 04 00 00 84 E4 06 00 12 37 08 28 30 04 00 00 84 E4 06 00 13 37 08 28 30 04 00 00 84 E4 06 00 14 37 08 28 30 04 00 00 84 E4 06 00 15 37 08 28 30 04 00 00 84 E4 06 00 16 37 08 28 30 04 00 00 84 E4 06 00 17 37 08 28 30 04 00 00 84 E4 06 00 10 38 08 28 30 04 00 00 84 E4 06 00 11 38 08 28 30 04 00 00 84 E4 06 00 12 38 08 28 30 04 00 00 84 E4 06 00 13 38 08 28
9:21:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F4 09 81 80 30 04 00 00 84 E4 06 00 14 38 08 28 30 04 00 00 84 E4 06 00 15 38 08 28 30 04 00 00 84 E4 06 00 16 38 08 28 30 04 00 00 84 E4 06 00 17 38 08 28 30 04 00 00 84 E4 06 00 90 38 08 28 30 04 00 00 84 E4 06 00 91 38 08 28 30 04 00 00 84 E4 06 00 92 38 08 28 30 04 00 00 84 E4 06 00 93 38 08 28 30 04 00 00 84 E4 06 00 94 38 08 28 30 04 00 00 84 E4 06 00 95 38 08 28 30 04 00 00 84 E4 06 00
9:21:17 AM
9:21:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F5 09 81 80 96 38 08 28 30 04 00 00 84 E4 06 00 97 38 08 28 30 04 00 00 84 E4 06 00 10 39 02 10 18 03 00 00 60 00 1C 00 11 39 02 10 18 03 00 00 68 00 1C 00 14 39 04 20 08 01 00 00 2C 8D 00 10 15 39 04 20 08 01 00 00 6C 8D 00 10 16 39 04 20 08 01 00 00 38 8D 00 10 17 39 04 20 08 01 00 00 78 8D 00 10 94 39 04 20 08 03 00 00 4C 00 12 00 95 39 04 20 08 03 00 00 50 00 12 00 96 39 04 20 08 03 00 00
9:21:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F6 09 81 80 58 00 12 00 97 39 04 20 08 03 00 00 5C 00 12 00 10 3A 02 10 08 03 00 00 00 00 15 00 11 3A 02 10 08 03 00 00 04 00 15 00 12 3A 02 10 08 03 00 00 02 00 15 00 13 3A 02 10 08 03 00 00 06 00 15 00 14 3A 01 00 30 03 00 00 08 00 15 00 15 3A 04 20 08 03 00 00 54 00 12 00 16 3A 04 20 08 03 00 00 60 00 12 00 90 3A 04 20 38 04 00 00 F4 E4 06 00 91 3A 04 20 38 04 00 00 F4 E4 06 00 92 3A 04 20
9:21:18 AM
9:21:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F7 09 81 80 38 04 00 00 F4 E4 06 00 93 3A 04 20 38 04 00 00 F4 E4 06 00 94 3A 04 20 38 04 00 00 F4 E4 06 00 95 3A 04 20 38 04 00 00 F4 E4 06 00 96 3A 04 20 38 04 00 00 F4 E4 06 00 97 3A 04 20 38 04 00 00 3C E5 06 00 10 3B 04 20 38 04 00 00 3C E5 06 00 11 3B 04 20 38 04 00 00 3C E5 06 00 12 3B 04 20 38 04 00 00 3C E5 06 00 13 3B 04 20 38 04 00 00 3C E5 06 00 14 3B 04 20 38 04 00 00 3C E5 06 00
9:21:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F8 09 81 80 15 3B 04 20 38 04 00 00 3C E5 06 00 16 3B 04 20 38 04 00 00 3C E5 06 00 17 3B 04 20 38 04 00 00 3C E5 06 00 90 3B 04 20 38 04 00 00 3C E5 06 00 91 3B 04 20 38 04 00 00 3C E5 06 00 92 3B 08 28 30 04 00 00 84 E4 06 00 93 3B 08 28 30 04 00 00 84 E4 06 00 94 3B 08 28 30 04 00 00 84 E4 06 00 95 3B 08 28 30 04 00 00 84 E4 06 00 96 3B 08 28 30 04 00 00 84 E4 06 00 97 3B 08 28 30 04 00 00
9:21:19 AM
9:21:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 F9 09 81 80 84 E4 06 00 10 3C 08 28 30 04 00 00 84 E4 06 00 11 3C 08 28 30 04 00 00 84 E4 06 00 12 3C 08 28 30 04 00 00 84 E4 06 00 13 3C 08 28 30 04 00 00 84 E4 06 00 14 3C 08 28 30 04 00 00 84 E4 06 00 15 3C 08 28 30 04 00 00 84 E4 06 00 16 3C 08 28 30 04 00 00 84 E4 06 00 17 3C 08 28 30 04 00 00 84 E4 06 00 90 3C 08 28 30 04 00 00 84 E4 06 00 91 3C 08 28 30 04 00 00 84 E4 06 00 92 3C 08 28
9:21:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 FA 09 81 80 30 04 00 00 84 E4 06 00 93 3C 08 28 30 04 00 00 84 E4 06 00 10 3D 08 28 30 04 00 00 84 E4 06 00 11 3D 08 28 30 04 00 00 84 E4 06 00 12 3D 08 28 30 04 00 00 84 E4 06 00 13 3D 08 28 30 04 00 00 84 E4 06 00 14 3D 08 28 30 04 00 00 84 E4 06 00 15 3D 08 28 30 04 00 00 84 E4 06 00 16 3D 08 28 30 04 00 00 84 E4 06 00 17 3D 08 28 30 04 00 00 84 E4 06 00 90 3D 08 28 30 04 00 00 84 E4 06 00
9:21:20 AM
9:21:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 FB 09 81 80 10 40 04 20 38 02 00 00 B8 0D 02 00 11 40 04 20 38 02 00 00 A8 0E 02 00 12 40 04 20 38 02 00 00 B8 0E 02 00 13 40 04 20 38 02 00 00 C8 0E 02 00 14 40 04 20 38 02 00 00 D8 0E 02 00 15 40 04 20 38 02 00 00 E8 0E 02 00 16 40 04 20 38 02 00 00 F8 0E 02 00 17 40 04 20 38 02 00 00 08 0F 02 00 20 40 01 00 38 04 00 00 DC E4 06 00 21 40 01 00 38 04 00 00 DC E4 06 00 22 40 01 00 38 04 00 00
9:21:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 FC 09 81 80 DC E4 06 00 23 40 01 00 38 04 00 00 DC E4 06 00 24 40 01 00 38 04 00 00 DC E4 06 00 25 40 01 00 38 04 00 00 DC E4 06 00 26 40 01 00 38 04 00 00 DC E4 06 00 27 40 01 00 38 04 00 00 DC E4 06 00 28 40 04 D0 38 02 00 00 B0 11 02 00 29 40 04 D0 38 02 00 00 28 12 02 00 2A 40 04 D0 38 02 00 00 38 12 02 00 2B 40 04 D0 38 02 00 00 48 12 02 00 2C 40 04 D0 38 02 00 00 58 12 02 00 2D 40 04 D0
9:21:21 AM
9:21:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 FD 09 81 80 38 02 00 00 68 12 02 00 2E 40 04 D0 38 02 00 00 78 12 02 00 2F 40 04 D0 38 02 00 00 88 12 02 00 90 40 04 20 38 02 00 00 18 0F 02 00 A0 40 01 00 38 04 00 00 DC E4 06 00 A8 40 04 D0 38 02 00 00 98 12 02 00 10 41 04 20 38 02 00 00 BC 0D 02 00 11 41 04 20 38 02 00 00 AC 0E 02 00 12 41 04 20 38 02 00 00 BC 0E 02 00 13 41 04 20 38 02 00 00 CC 0E 02 00 14 41 04 20 38 02 00 00 DC 0E 02 00
9:21:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 FE 09 81 80 15 41 04 20 38 02 00 00 EC 0E 02 00 16 41 04 20 38 02 00 00 FC 0E 02 00 17 41 04 20 38 02 00 00 0C 0F 02 00 20 41 01 00 38 04 00 00 DC E4 06 00 21 41 01 00 38 04 00 00 DC E4 06 00 22 41 01 00 38 04 00 00 DC E4 06 00 23 41 01 00 38 04 00 00 DC E4 06 00 24 41 01 00 38 04 00 00 DC E4 06 00 25 41 01 00 38 04 00 00 DC E4 06 00 26 41 01 00 38 04 00 00 DC E4 06 00 27 41 01 00 38 04 00 00
9:21:22 AM
9:21:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 09 FF 09 81 80 DC E4 06 00 28 41 04 D0 38 02 00 00 B4 11 02 00 29 41 04 D0 38 02 00 00 2C 12 02 00 2A 41 04 D0 38 02 00 00 3C 12 02 00 2B 41 04 D0 38 02 00 00 4C 12 02 00 2C 41 04 D0 38 02 00 00 5C 12 02 00 2D 41 04 D0 38 02 00 00 6C 12 02 00 2E 41 04 D0 38 02 00 00 7C 12 02 00 2F 41 04 D0 38 02 00 00 8C 12 02 00 90 41 04 20 38 02 00 00 1C 0F 02 00 A0 41 01 00 38 04 00 00 DC E4 06 00 A8 41 04 D0
9:21:22 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 00 09 81 80 38 02 00 00 9C 12 02 00 10 42 04 20 38 02 00 00 08 0E 02 00 11 42 04 20 38 02 00 00 A8 0F 02 00 12 42 04 20 38 02 00 00 C0 0F 02 00 13 42 04 20 38 02 00 00 D8 0F 02 00 14 42 04 20 38 02 00 00 F0 0F 02 00 15 42 04 20 38 02 00 00 08 10 02 00 16 42 04 20 38 02 00 00 20 10 02 00 17 42 04 20 38 02 00 00 38 10 02 00 20 42 01 00 38 04 00 00 DC E4 06 00 21 42 01 00 38 04 00 00 DC E4 06 00
9:21:23 AM
9:21:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 01 09 81 80 22 42 01 00 38 04 00 00 DC E4 06 00 23 42 01 00 38 04 00 00 DC E4 06 00 24 42 01 00 38 04 00 00 DC E4 06 00 25 42 01 00 38 04 00 00 DC E4 06 00 26 42 01 00 38 04 00 00 DC E4 06 00 27 42 01 00 38 04 00 00 DC E4 06 00 28 42 04 D0 38 02 00 00 D8 11 02 00 29 42 04 D0 38 02 00 00 A8 12 02 00 2A 42 04 D0 38 02 00 00 C0 12 02 00 2B 42 04 D0 38 02 00 00 D8 12 02 00 2C 42 04 D0 38 02 00 00
9:21:24 AM
9:21:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 02 09 81 80 F0 12 02 00 2D 42 04 D0 38 02 00 00 08 13 02 00 2E 42 04 D0 38 02 00 00 20 13 02 00 2F 42 04 D0 38 02 00 00 38 13 02 00 90 42 04 20 38 02 00 00 50 10 02 00 A0 42 01 00 38 04 00 00 DC E4 06 00 A8 42 04 D0 38 02 00 00 50 13 02 00 10 43 04 20 38 02 00 00 0C 0E 02 00 11 43 04 20 38 02 00 00 AC 0F 02 00 12 43 04 20 38 02 00 00 C4 0F 02 00 13 43 04 20 38 02 00 00 DC 0F 02 00 14 43 04 20
9:21:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 03 09 81 80 38 02 00 00 F4 0F 02 00 15 43 04 20 38 02 00 00 0C 10 02 00 16 43 04 20 38 02 00 00 24 10 02 00 17 43 04 20 38 02 00 00 3C 10 02 00 20 43 01 00 38 04 00 00 DC E4 06 00 21 43 01 00 38 04 00 00 DC E4 06 00 22 43 01 00 38 04 00 00 DC E4 06 00 23 43 01 00 38 04 00 00 DC E4 06 00 24 43 01 00 38 04 00 00 DC E4 06 00 25 43 01 00 38 04 00 00 DC E4 06 00 26 43 01 00 38 04 00 00 DC E4 06 00
9:21:25 AM
9:21:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 04 09 81 80 27 43 01 00 38 04 00 00 DC E4 06 00 28 43 04 D0 38 02 00 00 DC 11 02 00 29 43 04 D0 38 02 00 00 AC 12 02 00 2A 43 04 D0 38 02 00 00 C4 12 02 00 2B 43 04 D0 38 02 00 00 DC 12 02 00 2C 43 04 D0 38 02 00 00 F4 12 02 00 2D 43 04 D0 38 02 00 00 0C 13 02 00 2E 43 04 D0 38 02 00 00 24 13 02 00 2F 43 04 D0 38 02 00 00 3C 13 02 00 90 43 04 20 38 02 00 00 54 10 02 00 A0 43 01 00 38 04 00 00
9:21:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 05 09 81 80 DC E4 06 00 A8 43 04 D0 38 02 00 00 54 13 02 00 10 44 04 20 38 02 00 00 68 0E 02 00 11 44 04 20 38 02 00 00 28 11 02 00 12 44 04 20 38 02 00 00 30 11 02 00 13 44 04 20 38 02 00 00 38 11 02 00 14 44 04 20 38 02 00 00 40 11 02 00 15 44 04 20 38 02 00 00 48 11 02 00 16 44 04 20 38 02 00 00 50 11 02 00 17 44 04 20 38 02 00 00 58 11 02 00 20 44 01 00 38 04 00 00 DC E4 06 00 21 44 01 00
9:21:26 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:21:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 06 09 81 80 38 04 00 00 DC E4 06 00 22 44 01 00 38 04 00 00 DC E4 06 00 23 44 01 00 38 04 00 00 DC E4 06 00 24 44 01 00 38 04 00 00 DC E4 06 00 25 44 01 00 38 04 00 00 DC E4 06 00 26 44 01 00 38 04 00 00 DC E4 06 00 27 44 01 00 38 04 00 00 DC E4 06 00 28 44 04 D0 38 02 00 00 08 12 02 00 29 44 04 D0 38 02 00 00 68 13 02 00 2A 44 04 D0 38 02 00 00 70 13 02 00 2B 44 04 D0 38 02 00 00 78 13 02 00
9:21:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 07 09 81 80 2C 44 04 D0 38 02 00 00 80 13 02 00 2D 44 04 D0 38 02 00 00 88 13 02 00 2E 44 04 D0 38 02 00 00 90 13 02 00 2F 44 04 D0 38 02 00 00 98 13 02 00 90 44 04 20 38 02 00 00 60 11 02 00 A0 44 01 00 38 04 00 00 DC E4 06 00 A8 44 04 D0 38 02 00 00 A0 13 02 00 10 45 04 20 38 02 00 00 6C 0E 02 00 11 45 04 20 38 02 00 00 2C 11 02 00 12 45 04 20 38 02 00 00 34 11 02 00 13 45 04 20 38 02 00 00
9:21:27 AM
9:21:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 08 09 81 80 3C 11 02 00 14 45 04 20 38 02 00 00 44 11 02 00 15 45 04 20 38 02 00 00 4C 11 02 00 16 45 04 20 38 02 00 00 54 11 02 00 17 45 04 20 38 02 00 00 5C 11 02 00 20 45 01 00 38 04 00 00 DC E4 06 00 21 45 01 00 38 04 00 00 DC E4 06 00 22 45 01 00 38 04 00 00 DC E4 06 00 23 45 01 00 38 04 00 00 DC E4 06 00 24 45 01 00 38 04 00 00 DC E4 06 00 25 45 01 00 38 04 00 00 DC E4 06 00 26 45 01 00
9:21:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 09 09 81 80 38 04 00 00 DC E4 06 00 27 45 01 00 38 04 00 00 DC E4 06 00 28 45 04 D0 38 02 00 00 0C 12 02 00 29 45 04 D0 38 02 00 00 6C 13 02 00 2A 45 04 D0 38 02 00 00 74 13 02 00 2B 45 04 D0 38 02 00 00 7C 13 02 00 2C 45 04 D0 38 02 00 00 84 13 02 00 2D 45 04 D0 38 02 00 00 8C 13 02 00 2E 45 04 D0 38 02 00 00 94 13 02 00 2F 45 04 D0 38 02 00 00 9C 13 02 00 90 45 04 20 38 02 00 00 64 11 02 00
9:21:28 AM
9:21:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 0A 09 81 80 A0 45 01 00 38 04 00 00 DC E4 06 00 A8 45 04 D0 38 02 00 00 A4 13 02 00 10 46 04 20 38 02 00 00 C0 0D 02 00 11 46 04 20 38 02 00 00 B0 0E 02 00 12 46 04 20 38 02 00 00 C0 0E 02 00 13 46 04 20 38 02 00 00 D0 0E 02 00 14 46 04 20 38 02 00 00 E0 0E 02 00 15 46 04 20 38 02 00 00 F0 0E 02 00 16 46 04 20 38 02 00 00 00 0F 02 00 17 46 04 20 38 02 00 00 10 0F 02 00 20 46 01 00 38 04 00 00
9:21:29 AM
9:21:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 0B 09 81 80 DC E4 06 00 21 46 01 00 38 04 00 00 DC E4 06 00 22 46 01 00 38 04 00 00 DC E4 06 00 23 46 01 00 38 04 00 00 DC E4 06 00 24 46 01 00 38 04 00 00 DC E4 06 00 25 46 01 00 38 04 00 00 DC E4 06 00 26 46 01 00 38 04 00 00 DC E4 06 00 27 46 01 00 38 04 00 00 DC E4 06 00 28 46 04 D0 38 02 00 00 B8 11 02 00 29 46 04 D0 38 02 00 00 30 12 02 00 2A 46 04 D0 38 02 00 00 40 12 02 00 2B 46 04 D0
9:21:29 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 0C 09 81 80 38 02 00 00 50 12 02 00 2C 46 04 D0 38 02 00 00 60 12 02 00 2D 46 04 D0 38 02 00 00 70 12 02 00 2E 46 04 D0 38 02 00 00 80 12 02 00 2F 46 04 D0 38 02 00 00 90 12 02 00 90 46 04 20 38 02 00 00 20 0F 02 00 A0 46 01 00 38 04 00 00 DC E4 06 00 A8 46 04 D0 38 02 00 00 A0 12 02 00 10 47 04 20 38 02 00 00 E0 0D 02 00 11 47 04 20 38 02 00 00 28 0F 02 00 12 47 04 20 38 02 00 00 38 0F 02 00
9:21:30 AM
9:21:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 0D 09 81 80 13 47 04 20 38 02 00 00 48 0F 02 00 14 47 04 20 38 02 00 00 58 0F 02 00 15 47 04 20 38 02 00 00 68 0F 02 00 16 47 04 20 38 02 00 00 78 0F 02 00 17 47 04 20 38 02 00 00 88 0F 02 00 90 47 04 20 38 02 00 00 98 0F 02 00 10 48 04 20 38 02 00 00 E4 0D 02 00 11 48 04 20 38 02 00 00 2C 0F 02 00 12 48 04 20 38 02 00 00 3C 0F 02 00 13 48 04 20 38 02 00 00 4C 0F 02 00 14 48 04 20 38 02 00 00
9:21:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 0E 09 81 80 5C 0F 02 00 15 48 04 20 38 02 00 00 6C 0F 02 00 16 48 04 20 38 02 00 00 7C 0F 02 00 17 48 04 20 38 02 00 00 8C 0F 02 00 90 48 04 20 38 02 00 00 9C 0F 02 00 10 49 04 20 38 02 00 00 38 0E 02 00 11 49 04 20 38 02 00 00 68 10 02 00 12 49 04 20 38 02 00 00 80 10 02 00 13 49 04 20 38 02 00 00 98 10 02 00 14 49 04 20 38 02 00 00 B0 10 02 00 15 49 04 20 38 02 00 00 C8 10 02 00 16 49 04 20
9:21:31 AM
9:21:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 0F 09 81 80 38 02 00 00 E0 10 02 00 17 49 04 20 38 02 00 00 F8 10 02 00 90 49 04 20 38 02 00 00 10 11 02 00 10 4A 04 20 38 02 00 00 3C 0E 02 00 11 4A 04 20 38 02 00 00 6C 10 02 00 12 4A 04 20 38 02 00 00 84 10 02 00 13 4A 04 20 38 02 00 00 9C 10 02 00 14 4A 04 20 38 02 00 00 B4 10 02 00 15 4A 04 20 38 02 00 00 CC 10 02 00 16 4A 04 20 38 02 00 00 E4 10 02 00 17 4A 04 20 38 02 00 00 FC 10 02 00
9:21:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 10 09 81 80 90 4A 04 20 38 02 00 00 14 11 02 00 10 4B 04 20 38 02 00 00 88 0E 02 00 11 4B 04 20 38 02 00 00 68 11 02 00 12 4B 04 20 38 02 00 00 70 11 02 00 13 4B 04 20 38 02 00 00 78 11 02 00 14 4B 04 20 38 02 00 00 80 11 02 00 15 4B 04 20 38 02 00 00 88 11 02 00 16 4B 04 20 38 02 00 00 90 11 02 00 17 4B 04 20 38 02 00 00 98 11 02 00 90 4B 04 20 38 02 00 00 A0 11 02 00 10 4C 04 20 38 02 00 00
9:21:32 AM
9:21:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 11 09 81 80 8C 0E 02 00 11 4C 04 20 38 02 00 00 6C 11 02 00 12 4C 04 20 38 02 00 00 74 11 02 00 13 4C 04 20 38 02 00 00 7C 11 02 00 14 4C 04 20 38 02 00 00 84 11 02 00 15 4C 04 20 38 02 00 00 8C 11 02 00 16 4C 04 20 38 02 00 00 94 11 02 00 17 4C 04 20 38 02 00 00 9C 11 02 00 90 4C 04 20 38 02 00 00 A4 11 02 00 11 4E 02 10 38 01 00 00 14 78 00 10 12 4E 02 10 38 01 00 00 16 78 00 10 13 4E 02 10
9:21:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 12 09 81 80 38 01 00 00 36 79 00 10 14 4E 02 10 38 01 00 00 4E 79 00 10 15 4E 02 10 38 01 00 00 7C 78 00 10 16 4E 02 10 38 01 00 00 7E 78 00 10 21 4E 01 00 38 04 00 00 DC E4 06 00 22 4E 01 00 38 04 00 00 DC E4 06 00 23 4E 01 00 38 04 00 00 DC E4 06 00 24 4E 01 00 38 04 00 00 DC E4 06 00 25 4E 01 00 38 04 00 00 DC E4 06 00 26 4E 01 00 38 04 00 00 DC E4 06 00 29 4E 04 D0 38 01 00 00 4C 78 00 10
9:21:33 AM
9:21:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 13 09 81 80 2A 4E 04 D0 38 01 00 00 50 78 00 10 2B 4E 04 D0 38 01 00 00 44 79 00 10 2C 4E 04 D0 38 01 00 00 5C 79 00 10 2D 4E 04 D0 38 01 00 00 B4 78 00 10 2E 4E 04 D0 38 01 00 00 B8 78 00 10 10 50 04 20 18 04 00 00 7C E4 06 00 12 50 04 20 38 04 00 00 44 E5 06 00 14 50 04 20 18 04 00 00 1C E4 06 00 15 50 04 20 38 04 00 00 4C E5 06 00 1A 50 04 20 38 04 00 00 44 E5 06 00 25 50 01 00 38 04 00 00
9:21:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 14 09 81 80 DC E4 06 00 2A 50 01 00 38 04 00 00 DC E4 06 00 2D 50 04 D0 38 01 00 00 B0 4A 00 10 32 50 04 D0 38 04 00 00 44 E5 06 00 3A 50 04 D0 38 04 00 00 44 E5 06 00 12 51 04 20 38 04 00 00 44 E5 06 00 14 51 04 20 18 04 00 00 1C E4 06 00 15 51 04 20 38 04 00 00 4C E5 06 00 1A 51 04 20 38 04 00 00 44 E5 06 00 25 51 01 00 38 04 00 00 DC E4 06 00 2A 51 01 00 38 04 00 00 DC E4 06 00 2D 51 04 D0
9:21:34 AM
9:21:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 15 09 81 80 38 01 00 00 FC 4A 00 10 32 51 04 D0 38 04 00 00 44 E5 06 00 3A 51 04 D0 38 04 00 00 44 E5 06 00 90 51 04 20 38 02 00 00 E8 0D 02 00 91 51 04 50 38 04 00 00 44 E5 06 00 92 51 04 50 38 04 00 00 4C E5 06 00 93 51 04 50 38 02 00 00 C4 0D 02 00 94 51 04 50 38 02 00 00 EC 0D 02 00 99 51 04 50 38 04 00 00 44 E5 06 00 A2 51 01 00 38 04 00 00 DC E4 06 00 A3 51 01 00 38 04 00 00 DC E4 06 00
9:21:35 AM
9:21:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 16 09 81 80 A9 51 01 00 38 04 00 00 DC E4 06 00 AA 51 04 D0 38 01 00 00 94 4B 00 10 AB 51 04 D0 38 02 00 00 BC 11 02 00 B1 51 04 D0 38 04 00 00 44 E5 06 00 B9 51 04 D0 38 04 00 00 44 E5 06 00 12 52 04 20 38 04 00 00 44 E5 06 00 15 52 04 20 38 04 00 00 4C E5 06 00 1A 52 04 20 38 04 00 00 44 E5 06 00 25 52 01 00 38 04 00 00 DC E4 06 00 2A 52 01 00 38 04 00 00 DC E4 06 00 2D 52 04 D0 38 01 00 00
9:21:35 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 17 09 81 80 E0 4B 00 10 32 52 04 D0 38 04 00 00 44 E5 06 00 3A 52 04 D0 38 04 00 00 44 E5 06 00 90 52 04 20 38 04 00 00 44 E5 06 00 91 52 04 20 38 04 00 00 44 E5 06 00 92 52 04 20 38 04 00 00 44 E5 06 00 93 52 04 20 38 04 00 00 44 E5 06 00 94 52 04 20 38 04 00 00 4C E5 06 00 95 52 04 20 38 04 00 00 4C E5 06 00 96 52 04 20 38 04 00 00 4C E5 06 00 97 52 04 20 38 04 00 00 4C E5 06 00 98 52 04 20
9:21:36 AM
9:21:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 18 09 81 80 38 04 00 00 44 E5 06 00 99 52 04 20 38 04 00 00 44 E5 06 00 9A 52 04 20 38 04 00 00 44 E5 06 00 9B 52 04 20 38 04 00 00 44 E5 06 00 A4 52 01 00 38 04 00 00 DC E4 06 00 A5 52 01 00 38 04 00 00 DC E4 06 00 A6 52 01 00 38 04 00 00 DC E4 06 00 A7 52 01 00 38 04 00 00 DC E4 06 00 A8 52 01 00 38 04 00 00 DC E4 06 00 A9 52 01 00 38 04 00 00 DC E4 06 00 AA 52 01 00 38 04 00 00 DC E4 06 00
9:21:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 19 09 81 80 AB 52 01 00 38 04 00 00 DC E4 06 00 AC 52 04 D0 38 01 00 00 78 4C 00 10 AD 52 04 D0 38 01 00 00 C4 4C 00 10 AE 52 04 D0 38 01 00 00 10 4D 00 10 AF 52 04 D0 38 01 00 00 5C 4D 00 10 B0 52 04 D0 38 04 00 00 44 E5 06 00 B1 52 04 D0 38 04 00 00 44 E5 06 00 B2 52 04 D0 38 04 00 00 44 E5 06 00 B3 52 04 D0 38 04 00 00 44 E5 06 00 B8 52 04 D0 38 04 00 00 44 E5 06 00 B9 52 04 D0 38 04 00 00
9:21:37 AM
9:21:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 1A 09 81 80 44 E5 06 00 BA 52 04 D0 38 04 00 00 44 E5 06 00 BB 52 04 D0 38 04 00 00 44 E5 06 00 12 53 04 20 38 04 00 00 44 E5 06 00 15 53 04 20 38 04 00 00 4C E5 06 00 1A 53 04 20 38 04 00 00 44 E5 06 00 25 53 01 00 38 04 00 00 DC E4 06 00 2A 53 01 00 38 04 00 00 DC E4 06 00 2D 53 04 D0 38 01 00 00 2C 4C 00 10 32 53 04 D0 38 04 00 00 44 E5 06 00 3A 53 04 D0 38 04 00 00 44 E5 06 00 90 53 04 20
9:21:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 1B 09 81 80 38 02 00 00 10 0E 02 00 91 53 04 20 38 02 00 00 14 0E 02 00 92 53 04 20 38 02 00 00 18 0E 02 00 93 53 04 20 38 02 00 00 1C 0E 02 00 94 53 04 20 38 02 00 00 40 0E 02 00 95 53 04 20 38 02 00 00 44 0E 02 00 96 53 04 20 38 02 00 00 48 0E 02 00 97 53 04 20 38 02 00 00 4C 0E 02 00 A0 53 01 00 38 04 00 00 DC E4 06 00 A1 53 01 00 38 04 00 00 DC E4 06 00 A2 53 01 00 38 04 00 00 DC E4 06 00
9:21:38 AM
9:21:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 1C 09 81 80 A3 53 01 00 38 04 00 00 DC E4 06 00 A8 53 04 D0 38 02 00 00 E0 11 02 00 A9 53 04 D0 38 02 00 00 E4 11 02 00 AA 53 04 D0 38 02 00 00 E8 11 02 00 AB 53 04 D0 38 02 00 00 EC 11 02 00 12 54 04 20 38 04 00 00 44 E5 06 00 15 54 04 20 38 04 00 00 4C E5 06 00 1A 54 04 20 38 04 00 00 44 E5 06 00 25 54 01 00 38 04 00 00 DC E4 06 00 2A 54 01 00 38 04 00 00 DC E4 06 00 2D 54 04 D0 38 01 00 00
9:21:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 1D 09 81 80 A8 4D 00 10 32 54 04 D0 38 04 00 00 44 E5 06 00 3A 54 04 D0 38 04 00 00 44 E5 06 00 12 55 04 20 38 04 00 00 44 E5 06 00 15 55 04 20 38 04 00 00 4C E5 06 00 1A 55 04 20 38 04 00 00 44 E5 06 00 25 55 01 00 38 04 00 00 DC E4 06 00 2A 55 01 00 38 04 00 00 DC E4 06 00 2D 55 04 D0 38 01 00 00 F4 4D 00 10 32 55 04 D0 38 04 00 00 44 E5 06 00 3A 55 04 D0 38 04 00 00 44 E5 06 00 12 56 04 20
9:21:39 AM
9:21:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 1E 09 81 80 38 04 00 00 44 E5 06 00 15 56 04 20 38 04 00 00 4C E5 06 00 1A 56 04 20 38 04 00 00 44 E5 06 00 25 56 01 00 38 04 00 00 DC E4 06 00 2A 56 01 00 38 04 00 00 DC E4 06 00 2D 56 04 D0 38 01 00 00 48 4B 00 10 32 56 04 D0 38 04 00 00 44 E5 06 00 3A 56 04 D0 38 04 00 00 44 E5 06 00 11 58 04 20 38 04 00 00 44 E5 06 00 12 58 04 20 38 04 00 00 44 E5 06 00 13 58 04 20 38 04 00 00 44 E5 06 00
9:21:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 1F 09 81 80 19 58 04 20 38 04 00 00 44 E5 06 00 1A 58 04 20 38 04 00 00 44 E5 06 00 1B 58 04 20 38 04 00 00 44 E5 06 00 29 58 01 00 38 04 00 00 DC E4 06 00 2A 58 01 00 38 04 00 00 DC E4 06 00 2B 58 01 00 38 04 00 00 DC E4 06 00 31 58 04 D0 38 04 00 00 44 E5 06 00 32 58 04 D0 38 04 00 00 44 E5 06 00 33 58 04 D0 38 04 00 00 44 E5 06 00 39 58 04 D0 38 04 00 00 44 E5 06 00 3A 58 04 D0 38 04 00 00
9:21:40 AM
9:21:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 20 09 81 80 44 E5 06 00 3B 58 04 D0 38 04 00 00 44 E5 06 00 90 58 04 50 38 02 00 00 B4 0E 02 00 91 58 04 50 38 02 00 00 C4 0E 02 00 92 58 04 50 38 02 00 00 D4 0E 02 00 93 58 04 50 38 02 00 00 E4 0E 02 00 94 58 04 50 38 02 00 00 F4 0E 02 00 95 58 04 50 38 02 00 00 04 0F 02 00 96 58 04 50 38 02 00 00 14 0F 02 00 97 58 04 50 38 02 00 00 24 0F 02 00 A0 58 01 00 38 04 00 00 DC E4 06 00 A1 58 01 00
9:21:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 21 09 81 80 38 04 00 00 DC E4 06 00 A2 58 01 00 38 04 00 00 DC E4 06 00 A3 58 01 00 38 04 00 00 DC E4 06 00 A4 58 01 00 38 04 00 00 DC E4 06 00 A5 58 01 00 38 04 00 00 DC E4 06 00 A6 58 01 00 38 04 00 00 DC E4 06 00 A7 58 01 00 38 04 00 00 DC E4 06 00 A8 58 04 D0 38 02 00 00 34 12 02 00 A9 58 04 D0 38 02 00 00 44 12 02 00 AA 58 04 D0 38 02 00 00 54 12 02 00 AB 58 04 D0 38 02 00 00 64 12 02 00
9:21:41 AM
9:21:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 22 09 81 80 AC 58 04 D0 38 02 00 00 74 12 02 00 AD 58 04 D0 38 02 00 00 84 12 02 00 AE 58 04 D0 38 02 00 00 94 12 02 00 AF 58 04 D0 38 02 00 00 A4 12 02 00 10 59 04 20 38 02 00 00 30 0F 02 00 11 59 04 20 38 02 00 00 40 0F 02 00 12 59 04 20 38 02 00 00 50 0F 02 00 13 59 04 20 38 02 00 00 60 0F 02 00 14 59 04 20 38 02 00 00 70 0F 02 00 15 59 04 20 38 02 00 00 80 0F 02 00 16 59 04 20 38 02 00 00
9:21:42 AM
9:21:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 23 09 81 80 90 0F 02 00 17 59 04 20 38 02 00 00 A0 0F 02 00 90 59 04 50 38 02 00 00 34 0F 02 00 91 59 04 50 38 02 00 00 44 0F 02 00 92 59 04 50 38 02 00 00 54 0F 02 00 93 59 04 50 38 02 00 00 64 0F 02 00 94 59 04 50 38 02 00 00 74 0F 02 00 95 59 04 50 38 02 00 00 84 0F 02 00 96 59 04 50 38 02 00 00 94 0F 02 00 97 59 04 50 38 02 00 00 A4 0F 02 00 10 5A 04 20 38 02 00 00 B0 0F 02 00 11 5A 04 20
9:21:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 24 09 81 80 38 02 00 00 C8 0F 02 00 12 5A 04 20 38 02 00 00 E0 0F 02 00 13 5A 04 20 38 02 00 00 F8 0F 02 00 14 5A 04 20 38 02 00 00 10 10 02 00 15 5A 04 20 38 02 00 00 28 10 02 00 16 5A 04 20 38 02 00 00 40 10 02 00 17 5A 04 20 38 02 00 00 58 10 02 00 20 5A 01 00 38 04 00 00 DC E4 06 00 21 5A 01 00 38 04 00 00 DC E4 06 00 22 5A 01 00 38 04 00 00 DC E4 06 00 23 5A 01 00 38 04 00 00 DC E4 06 00
9:21:43 AM
9:21:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 25 09 81 80 24 5A 01 00 38 04 00 00 DC E4 06 00 25 5A 01 00 38 04 00 00 DC E4 06 00 26 5A 01 00 38 04 00 00 DC E4 06 00 27 5A 01 00 38 04 00 00 DC E4 06 00 28 5A 04 D0 38 02 00 00 B0 12 02 00 29 5A 04 D0 38 02 00 00 C8 12 02 00 2A 5A 04 D0 38 02 00 00 E0 12 02 00 2B 5A 04 D0 38 02 00 00 F8 12 02 00 2C 5A 04 D0 38 02 00 00 10 13 02 00 2D 5A 04 D0 38 02 00 00 28 13 02 00 2E 5A 04 D0 38 02 00 00
9:21:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 26 09 81 80 40 13 02 00 2F 5A 04 D0 38 02 00 00 58 13 02 00 90 5A 04 20 38 02 00 00 B4 0F 02 00 91 5A 04 20 38 02 00 00 CC 0F 02 00 92 5A 04 20 38 02 00 00 E4 0F 02 00 93 5A 04 20 38 02 00 00 FC 0F 02 00 94 5A 04 20 38 02 00 00 14 10 02 00 95 5A 04 20 38 02 00 00 2C 10 02 00 96 5A 04 20 38 02 00 00 44 10 02 00 97 5A 04 20 38 02 00 00 5C 10 02 00 A0 5A 01 00 38 04 00 00 DC E4 06 00 A1 5A 01 00
9:21:44 AM
9:21:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 27 09 81 80 38 04 00 00 DC E4 06 00 A2 5A 01 00 38 04 00 00 DC E4 06 00 A3 5A 01 00 38 04 00 00 DC E4 06 00 A4 5A 01 00 38 04 00 00 DC E4 06 00 A5 5A 01 00 38 04 00 00 DC E4 06 00 A6 5A 01 00 38 04 00 00 DC E4 06 00 A7 5A 01 00 38 04 00 00 DC E4 06 00 A8 5A 04 D0 38 02 00 00 B4 12 02 00 A9 5A 04 D0 38 02 00 00 CC 12 02 00 AA 5A 04 D0 38 02 00 00 E4 12 02 00 AB 5A 04 D0 38 02 00 00 FC 12 02 00
9:21:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 28 09 81 80 AC 5A 04 D0 38 02 00 00 14 13 02 00 AD 5A 04 D0 38 02 00 00 2C 13 02 00 AE 5A 04 D0 38 02 00 00 44 13 02 00 AF 5A 04 D0 38 02 00 00 5C 13 02 00 10 5B 04 20 38 02 00 00 B8 0F 02 00 11 5B 04 20 38 02 00 00 D0 0F 02 00 12 5B 04 20 38 02 00 00 E8 0F 02 00 13 5B 04 20 38 02 00 00 00 10 02 00 14 5B 04 20 38 02 00 00 18 10 02 00 15 5B 04 20 38 02 00 00 30 10 02 00 16 5B 04 20 38 02 00 00
9:21:45 AM
9:21:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 29 09 81 80 48 10 02 00 17 5B 04 20 38 02 00 00 60 10 02 00 20 5B 01 00 38 04 00 00 DC E4 06 00 21 5B 01 00 38 04 00 00 DC E4 06 00 22 5B 01 00 38 04 00 00 DC E4 06 00 23 5B 01 00 38 04 00 00 DC E4 06 00 24 5B 01 00 38 04 00 00 DC E4 06 00 25 5B 01 00 38 04 00 00 DC E4 06 00 26 5B 01 00 38 04 00 00 DC E4 06 00 27 5B 01 00 38 04 00 00 DC E4 06 00 28 5B 04 D0 38 02 00 00 B8 12 02 00 29 5B 04 D0
9:21:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 2A 09 81 80 38 02 00 00 D0 12 02 00 2A 5B 04 D0 38 02 00 00 E8 12 02 00 2B 5B 04 D0 38 02 00 00 00 13 02 00 2C 5B 04 D0 38 02 00 00 18 13 02 00 2D 5B 04 D0 38 02 00 00 30 13 02 00 2E 5B 04 D0 38 02 00 00 48 13 02 00 2F 5B 04 D0 38 02 00 00 60 13 02 00 90 5B 04 20 38 02 00 00 BC 0F 02 00 91 5B 04 20 38 02 00 00 D4 0F 02 00 92 5B 04 20 38 02 00 00 EC 0F 02 00 93 5B 04 20 38 02 00 00 04 10 02 00
9:21:46 AM
9:21:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 2B 09 81 80 94 5B 04 20 38 02 00 00 1C 10 02 00 95 5B 04 20 38 02 00 00 34 10 02 00 96 5B 04 20 38 02 00 00 4C 10 02 00 97 5B 04 20 38 02 00 00 64 10 02 00 A0 5B 01 00 38 04 00 00 DC E4 06 00 A1 5B 01 00 38 04 00 00 DC E4 06 00 A2 5B 01 00 38 04 00 00 DC E4 06 00 A3 5B 01 00 38 04 00 00 DC E4 06 00 A4 5B 01 00 38 04 00 00 DC E4 06 00 A5 5B 01 00 38 04 00 00 DC E4 06 00 A6 5B 01 00 38 04 00 00
9:21:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 2C 09 81 80 DC E4 06 00 A7 5B 01 00 38 04 00 00 DC E4 06 00 A8 5B 04 D0 38 02 00 00 BC 12 02 00 A9 5B 04 D0 38 02 00 00 D4 12 02 00 AA 5B 04 D0 38 02 00 00 EC 12 02 00 AB 5B 04 D0 38 02 00 00 04 13 02 00 AC 5B 04 D0 38 02 00 00 1C 13 02 00 AD 5B 04 D0 38 02 00 00 34 13 02 00 AE 5B 04 D0 38 02 00 00 4C 13 02 00 AF 5B 04 D0 38 02 00 00 64 13 02 00 10 5C 04 20 38 02 00 00 70 10 02 00 11 5C 04 20
9:21:47 AM
9:21:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 2D 09 81 80 38 02 00 00 88 10 02 00 12 5C 04 20 38 02 00 00 A0 10 02 00 13 5C 04 20 38 02 00 00 B8 10 02 00 14 5C 04 20 38 02 00 00 D0 10 02 00 15 5C 04 20 38 02 00 00 E8 10 02 00 16 5C 04 20 38 02 00 00 00 11 02 00 17 5C 04 20 38 02 00 00 18 11 02 00 90 5C 04 20 38 02 00 00 74 10 02 00 91 5C 04 20 38 02 00 00 8C 10 02 00 92 5C 04 20 38 02 00 00 A4 10 02 00 93 5C 04 20 38 02 00 00 BC 10 02 00
9:21:47 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 2E 09 81 80 94 5C 04 20 38 02 00 00 D4 10 02 00 95 5C 04 20 38 02 00 00 EC 10 02 00 96 5C 04 20 38 02 00 00 04 11 02 00 97 5C 04 20 38 02 00 00 1C 11 02 00 10 5D 04 20 38 02 00 00 78 10 02 00 11 5D 04 20 38 02 00 00 90 10 02 00 12 5D 04 20 38 02 00 00 A8 10 02 00 13 5D 04 20 38 02 00 00 C0 10 02 00 14 5D 04 20 38 02 00 00 D8 10 02 00 15 5D 04 20 38 02 00 00 F0 10 02 00 16 5D 04 20 38 02 00 00
9:21:48 AM
9:21:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 2F 09 81 80 08 11 02 00 17 5D 04 20 38 02 00 00 20 11 02 00 90 5D 04 20 38 02 00 00 7C 10 02 00 91 5D 04 20 38 02 00 00 94 10 02 00 92 5D 04 20 38 02 00 00 AC 10 02 00 93 5D 04 20 38 02 00 00 C4 10 02 00 94 5D 04 20 38 02 00 00 DC 10 02 00 95 5D 04 20 38 02 00 00 F4 10 02 00 96 5D 04 20 38 02 00 00 0C 11 02 00 97 5D 04 20 38 02 00 00 24 11 02 00 14 60 01 00 18 04 00 00 54 E4 06 00 10 61 08 28
9:21:49 AM
9:21:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 30 09 81 80 30 04 00 00 9C E4 06 00 11 61 08 28 30 04 00 00 9C E4 06 00 12 61 08 28 30 04 00 00 9C E4 06 00 13 61 08 28 30 04 00 00 9C E4 06 00 14 61 08 28 30 04 00 00 9C E4 06 00 15 61 08 28 30 04 00 00 9C E4 06 00 16 61 08 28 30 04 00 00 9C E4 06 00 17 61 08 28 30 04 00 00 9C E4 06 00 90 61 08 28 30 04 00 00 9C E4 06 00 91 61 08 28 30 04 00 00 9C E4 06 00 92 61 08 28 30 04 00 00 9C E4 06 00
9:21:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 31 09 81 80 93 61 08 28 30 04 00 00 9C E4 06 00 94 61 08 58 30 04 00 00 9C E4 06 00 95 61 08 58 30 04 00 00 9C E4 06 00 96 61 08 58 30 04 00 00 9C E4 06 00 97 61 08 58 30 04 00 00 9C E4 06 00 10 62 08 28 30 04 00 00 9C E4 06 00 11 62 08 28 30 04 00 00 9C E4 06 00 12 62 08 28 30 04 00 00 9C E4 06 00 13 62 08 28 30 04 00 00 9C E4 06 00 14 62 08 28 30 04 00 00 9C E4 06 00 15 62 08 28 30 04 00 00
9:21:50 AM
9:21:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 32 09 81 80 9C E4 06 00 16 62 08 28 30 04 00 00 9C E4 06 00 17 62 08 28 30 04 00 00 9C E4 06 00 90 62 08 28 30 04 00 00 9C E4 06 00 91 62 08 28 30 04 00 00 9C E4 06 00 92 62 08 28 30 04 00 00 9C E4 06 00 93 62 08 28 30 04 00 00 9C E4 06 00 94 62 08 28 30 04 00 00 9C E4 06 00 95 62 08 28 30 04 00 00 9C E4 06 00 96 62 08 28 30 04 00 00 9C E4 06 00 97 62 08 28 30 04 00 00 9C E4 06 00 10 63 08 28
9:21:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 33 09 81 80 30 04 00 00 9C E4 06 00 11 63 08 28 30 04 00 00 9C E4 06 00 12 63 08 28 30 04 00 00 9C E4 06 00 13 63 08 28 30 04 00 00 9C E4 06 00 14 63 08 28 30 04 00 00 9C E4 06 00 15 63 08 28 30 04 00 00 9C E4 06 00 16 63 08 28 30 04 00 00 9C E4 06 00 17 63 08 28 30 04 00 00 9C E4 06 00 90 63 08 28 30 04 00 00 9C E4 06 00 91 63 08 28 30 04 00 00 9C E4 06 00 92 63 08 28 30 04 00 00 9C E4 06 00
9:21:51 AM
9:21:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 34 09 81 80 93 63 08 28 30 04 00 00 9C E4 06 00 94 63 08 28 30 04 00 00 9C E4 06 00 95 63 08 28 30 04 00 00 9C E4 06 00 96 63 08 28 30 04 00 00 9C E4 06 00 97 63 08 28 30 04 00 00 9C E4 06 00 10 64 08 28 30 04 00 00 AC E4 06 00 11 64 08 28 30 04 00 00 AC E4 06 00 12 64 08 28 30 04 00 00 AC E4 06 00 13 64 08 28 30 04 00 00 AC E4 06 00 14 64 08 28 30 04 00 00 AC E4 06 00 15 64 08 28 30 04 00 00
9:21:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 35 09 81 80 AC E4 06 00 16 64 08 28 30 04 00 00 AC E4 06 00 17 64 08 28 30 04 00 00 AC E4 06 00 90 64 08 28 30 04 00 00 AC E4 06 00 91 64 08 28 30 04 00 00 AC E4 06 00 92 64 08 28 30 04 00 00 AC E4 06 00 93 64 08 28 30 04 00 00 AC E4 06 00 94 64 08 58 30 04 00 00 AC E4 06 00 95 64 08 58 30 04 00 00 AC E4 06 00 96 64 08 58 30 04 00 00 AC E4 06 00 97 64 08 58 30 04 00 00 AC E4 06 00 10 65 08 28
9:21:52 AM
9:21:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 36 09 81 80 30 04 00 00 AC E4 06 00 11 65 08 28 30 04 00 00 AC E4 06 00 12 65 08 28 30 04 00 00 AC E4 06 00 13 65 08 28 30 04 00 00 AC E4 06 00 14 65 08 28 30 04 00 00 AC E4 06 00 15 65 08 28 30 04 00 00 AC E4 06 00 16 65 08 28 30 04 00 00 AC E4 06 00 17 65 08 28 30 04 00 00 AC E4 06 00 90 65 08 28 30 04 00 00 AC E4 06 00 91 65 08 28 30 04 00 00 AC E4 06 00 92 65 08 28 30 04 00 00 AC E4 06 00
9:21:52 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 37 09 81 80 93 65 08 28 30 04 00 00 AC E4 06 00 94 65 08 28 30 04 00 00 AC E4 06 00 95 65 08 28 30 04 00 00 AC E4 06 00 96 65 08 28 30 04 00 00 AC E4 06 00 97 65 08 28 30 04 00 00 AC E4 06 00 10 66 08 28 30 04 00 00 AC E4 06 00 11 66 08 28 30 04 00 00 AC E4 06 00 12 66 08 28 30 04 00 00 AC E4 06 00 13 66 08 28 30 04 00 00 AC E4 06 00 14 66 08 28 30 04 00 00 AC E4 06 00 15 66 08 28 30 04 00 00
9:21:53 AM
9:21:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 38 09 81 80 AC E4 06 00 16 66 08 28 30 04 00 00 AC E4 06 00 17 66 08 28 30 04 00 00 AC E4 06 00 90 66 08 28 30 04 00 00 AC E4 06 00 91 66 08 28 30 04 00 00 AC E4 06 00 92 66 08 28 30 04 00 00 AC E4 06 00 93 66 08 28 30 04 00 00 AC E4 06 00 94 66 08 28 30 04 00 00 AC E4 06 00 95 66 08 28 30 04 00 00 AC E4 06 00 96 66 08 28 30 04 00 00 AC E4 06 00 97 66 08 28 30 04 00 00 AC E4 06 00 10 67 08 28
9:21:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 39 09 81 80 30 04 00 00 B4 E4 06 00 11 67 08 28 30 04 00 00 B4 E4 06 00 12 67 08 28 30 04 00 00 B4 E4 06 00 13 67 08 28 30 04 00 00 B4 E4 06 00 14 67 08 28 30 04 00 00 B4 E4 06 00 15 67 08 28 30 04 00 00 B4 E4 06 00 16 67 08 28 30 04 00 00 B4 E4 06 00 17 67 08 28 30 04 00 00 B4 E4 06 00 90 67 08 28 30 04 00 00 B4 E4 06 00 91 67 08 28 30 04 00 00 B4 E4 06 00 92 67 08 28 30 04 00 00 B4 E4 06 00
9:21:54 AM
9:21:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 3A 09 81 80 93 67 08 28 30 04 00 00 B4 E4 06 00 94 67 08 58 30 04 00 00 B4 E4 06 00 95 67 08 58 30 04 00 00 B4 E4 06 00 96 67 08 58 30 04 00 00 B4 E4 06 00 97 67 08 58 30 04 00 00 B4 E4 06 00 10 68 08 28 30 04 00 00 B4 E4 06 00 11 68 08 28 30 04 00 00 B4 E4 06 00 12 68 08 28 30 04 00 00 B4 E4 06 00 13 68 08 28 30 04 00 00 B4 E4 06 00 14 68 08 28 30 04 00 00 B4 E4 06 00 15 68 08 28 30 04 00 00
9:21:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 3B 09 81 80 B4 E4 06 00 16 68 08 28 30 04 00 00 B4 E4 06 00 17 68 08 28 30 04 00 00 B4 E4 06 00 90 68 08 28 30 04 00 00 B4 E4 06 00 91 68 08 28 30 04 00 00 B4 E4 06 00 92 68 08 28 30 04 00 00 B4 E4 06 00 93 68 08 28 30 04 00 00 B4 E4 06 00 94 68 08 28 30 04 00 00 B4 E4 06 00 95 68 08 28 30 04 00 00 B4 E4 06 00 96 68 08 28 30 04 00 00 B4 E4 06 00 97 68 08 28 30 04 00 00 B4 E4 06 00 10 69 08 28
9:21:55 AM
9:21:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 3C 09 81 80 30 04 00 00 B4 E4 06 00 11 69 08 28 30 04 00 00 B4 E4 06 00 12 69 08 28 30 04 00 00 B4 E4 06 00 13 69 08 28 30 04 00 00 B4 E4 06 00 14 69 08 28 30 04 00 00 B4 E4 06 00 15 69 08 28 30 04 00 00 B4 E4 06 00 16 69 08 28 30 04 00 00 B4 E4 06 00 17 69 08 28 30 04 00 00 B4 E4 06 00 90 69 08 28 30 04 00 00 B4 E4 06 00 91 69 08 28 30 04 00 00 B4 E4 06 00 92 69 08 28 30 04 00 00 B4 E4 06 00
9:21:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 3D 09 81 80 93 69 08 28 30 04 00 00 B4 E4 06 00 94 69 08 28 30 04 00 00 B4 E4 06 00 95 69 08 28 30 04 00 00 B4 E4 06 00 96 69 08 28 30 04 00 00 B4 E4 06 00 97 69 08 28 30 04 00 00 B4 E4 06 00 10 6A 08 28 30 04 00 00 A4 E4 06 00 11 6A 08 28 30 04 00 00 A4 E4 06 00 12 6A 08 28 30 04 00 00 A4 E4 06 00 13 6A 08 28 30 04 00 00 A4 E4 06 00 14 6A 08 28 30 04 00 00 A4 E4 06 00 15 6A 08 28 30 04 00 00
9:21:56 AM
9:21:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 3E 09 81 80 A4 E4 06 00 16 6A 08 28 30 04 00 00 A4 E4 06 00 17 6A 08 28 30 04 00 00 A4 E4 06 00 90 6A 08 28 30 04 00 00 A4 E4 06 00 91 6A 08 28 30 04 00 00 A4 E4 06 00 92 6A 08 28 30 04 00 00 A4 E4 06 00 93 6A 08 28 30 04 00 00 A4 E4 06 00 94 6A 08 28 30 04 00 00 A4 E4 06 00 95 6A 08 28 30 04 00 00 A4 E4 06 00 96 6A 08 28 30 04 00 00 A4 E4 06 00 97 6A 08 28 30 04 00 00 A4 E4 06 00 10 6B 08 28
9:21:57 AM
9:21:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 3F 09 81 80 30 04 00 00 A4 E4 06 00 11 6B 08 28 30 04 00 00 A4 E4 06 00 12 6B 08 28 30 04 00 00 A4 E4 06 00 13 6B 08 28 30 04 00 00 A4 E4 06 00 14 6B 08 28 30 04 00 00 A4 E4 06 00 15 6B 08 28 30 04 00 00 A4 E4 06 00 16 6B 08 28 30 04 00 00 A4 E4 06 00 17 6B 08 28 30 04 00 00 A4 E4 06 00 90 6B 08 58 30 04 00 00 A4 E4 06 00 91 6B 08 58 30 04 00 00 A4 E4 06 00 92 6B 08 58 30 04 00 00 A4 E4 06 00
9:21:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 40 09 81 80 93 6B 08 58 30 04 00 00 A4 E4 06 00 94 6B 08 58 30 04 00 00 A4 E4 06 00 95 6B 08 58 30 04 00 00 A4 E4 06 00 96 6B 08 58 30 04 00 00 A4 E4 06 00 97 6B 08 58 30 04 00 00 A4 E4 06 00 10 6C 08 28 30 04 00 00 A4 E4 06 00 11 6C 08 28 30 04 00 00 A4 E4 06 00 12 6C 08 28 30 04 00 00 A4 E4 06 00 13 6C 08 28 30 04 00 00 A4 E4 06 00 14 6C 08 28 30 04 00 00 A4 E4 06 00 15 6C 08 28 30 04 00 00
9:21:58 AM
9:21:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 41 09 81 80 A4 E4 06 00 16 6C 08 28 30 04 00 00 A4 E4 06 00 17 6C 08 28 30 04 00 00 A4 E4 06 00 90 6C 08 28 30 04 00 00 A4 E4 06 00 91 6C 08 28 30 04 00 00 A4 E4 06 00 92 6C 08 28 30 04 00 00 A4 E4 06 00 93 6C 08 28 30 04 00 00 A4 E4 06 00 94 6C 08 28 30 04 00 00 A4 E4 06 00 95 6C 08 28 30 04 00 00 A4 E4 06 00 96 6C 08 28 30 04 00 00 A4 E4 06 00 97 6C 08 28 30 04 00 00 A4 E4 06 00 10 6D 08 28
9:21:58 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 42 09 81 80 30 04 00 00 A4 E4 06 00 11 6D 08 28 30 04 00 00 A4 E4 06 00 12 6D 08 28 30 04 00 00 A4 E4 06 00 13 6D 08 28 30 04 00 00 A4 E4 06 00 14 6D 08 28 30 04 00 00 A4 E4 06 00 15 6D 08 28 30 04 00 00 A4 E4 06 00 16 6D 08 28 30 04 00 00 A4 E4 06 00 17 6D 08 28 30 04 00 00 A4 E4 06 00 90 6D 08 28 30 04 00 00 A4 E4 06 00 91 6D 08 28 30 04 00 00 A4 E4 06 00 92 6D 08 28 30 04 00 00 A4 E4 06 00
9:21:59 AM
9:21:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 43 09 81 80 93 6D 08 28 30 04 00 00 A4 E4 06 00 94 6D 08 28 30 04 00 00 A4 E4 06 00 95 6D 08 28 30 04 00 00 A4 E4 06 00 96 6D 08 28 30 04 00 00 A4 E4 06 00 97 6D 08 28 30 04 00 00 A4 E4 06 00 10 6E 08 28 30 04 00 00 A4 E4 06 00 11 6E 08 28 30 04 00 00 A4 E4 06 00 12 6E 08 28 30 04 00 00 A4 E4 06 00 13 6E 08 28 30 04 00 00 A4 E4 06 00 14 6E 08 28 30 04 00 00 A4 E4 06 00 15 6E 08 28 30 04 00 00
9:21:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 44 09 81 80 A4 E4 06 00 16 6E 08 28 30 04 00 00 A4 E4 06 00 17 6E 08 28 30 04 00 00 A4 E4 06 00 90 6E 08 28 30 04 00 00 A4 E4 06 00 91 6E 08 28 30 04 00 00 A4 E4 06 00 92 6E 08 28 30 04 00 00 A4 E4 06 00 93 6E 08 28 30 04 00 00 A4 E4 06 00 94 6E 08 28 30 04 00 00 A4 E4 06 00 95 6E 08 28 30 04 00 00 A4 E4 06 00 96 6E 08 28 30 04 00 00 A4 E4 06 00 97 6E 08 28 30 04 00 00 A4 E4 06 00 10 6F 08 28
9:22:00 AM
9:22:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 45 09 81 80 30 04 00 00 A4 E4 06 00 11 6F 08 28 30 04 00 00 A4 E4 06 00 12 6F 08 28 30 04 00 00 A4 E4 06 00 13 6F 08 28 30 04 00 00 A4 E4 06 00 14 6F 08 28 30 04 00 00 A4 E4 06 00 15 6F 08 28 30 04 00 00 A4 E4 06 00 16 6F 08 28 30 04 00 00 A4 E4 06 00 17 6F 08 28 30 04 00 00 A4 E4 06 00 90 6F 08 28 30 04 00 00 A4 E4 06 00 91 6F 08 28 30 04 00 00 A4 E4 06 00 92 6F 08 28 30 04 00 00 A4 E4 06 00
9:22:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 46 09 81 80 93 6F 08 28 30 04 00 00 A4 E4 06 00 94 6F 08 28 30 04 00 00 A4 E4 06 00 95 6F 08 28 30 04 00 00 A4 E4 06 00 96 6F 08 28 30 04 00 00 A4 E4 06 00 97 6F 08 28 30 04 00 00 A4 E4 06 00 97 7F 02 10 08 03 00 00 04 00 27 00 10 81 08 28 30 04 00 00 8C E4 06 00 11 81 08 28 30 04 00 00 8C E4 06 00 12 81 08 28 30 04 00 00 8C E4 06 00 90 81 04 20 38 04 00 00 8C E4 06 00 91 81 04 20 38 04 00 00
9:22:01 AM
9:22:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 47 09 81 80 8C E4 06 00 92 81 04 20 38 04 00 00 8C E4 06 00 93 81 08 28 30 04 00 00 8C E4 06 00 A0 81 01 00 38 04 00 00 DC E4 06 00 A1 81 01 00 38 04 00 00 DC E4 06 00 A2 81 01 00 38 04 00 00 DC E4 06 00 A8 81 04 D0 38 04 00 00 94 E4 06 00 A9 81 04 D0 38 04 00 00 94 E4 06 00 AA 81 04 D0 38 04 00 00 94 E4 06 00 10 B1 02 10 38 04 00 00 1C E5 06 00 11 B1 02 10 38 04 00 00 1C E5 06 00 12 B1 02 10
9:22:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 48 09 81 80 38 04 00 00 1C E5 06 00 13 B1 02 10 38 04 00 00 1C E5 06 00 14 B1 02 10 38 04 00 00 1C E5 06 00 15 B1 02 10 38 04 00 00 1C E5 06 00 16 B1 02 10 38 04 00 00 1C E5 06 00 17 B1 02 10 38 04 00 00 1C E5 06 00 90 B1 02 10 38 04 00 00 1C E5 06 00 91 B1 02 10 38 04 00 00 1C E5 06 00 92 B1 02 10 38 04 00 00 1C E5 06 00 93 B1 02 10 38 04 00 00 1C E5 06 00 94 B1 02 10 38 04 00 00 1C E5 06 00
9:22:02 AM
9:22:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 49 09 81 80 95 B1 02 10 38 04 00 00 1C E5 06 00 96 B1 02 10 38 04 00 00 1C E5 06 00 97 B1 02 10 38 04 00 00 1C E5 06 00 10 B2 02 10 38 04 00 00 1C E5 06 00 11 B2 02 10 38 04 00 00 1C E5 06 00 12 B2 02 10 38 04 00 00 1C E5 06 00 13 B2 02 10 38 04 00 00 1C E5 06 00 14 B2 02 10 38 04 00 00 1C E5 06 00 15 B2 02 10 38 04 00 00 1C E5 06 00 16 B2 02 10 38 04 00 00 1C E5 06 00 17 B2 02 10 38 04 00 00
9:22:03 AM
9:22:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 4A 09 81 80 1C E5 06 00 90 B2 02 10 38 04 00 00 1C E5 06 00 91 B2 02 10 38 04 00 00 1C E5 06 00 92 B2 02 10 38 04 00 00 1C E5 06 00 93 B2 02 10 38 04 00 00 1C E5 06 00 94 B2 02 10 38 04 00 00 1C E5 06 00 95 B2 02 10 38 04 00 00 1C E5 06 00 96 B2 02 10 38 04 00 00 1C E5 06 00 10 B3 02 10 38 04 00 00 1C E5 06 00 11 B3 02 10 38 04 00 00 1C E5 06 00 12 B3 02 10 38 04 00 00 1C E5 06 00 13 B3 02 10
9:22:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 4B 09 81 80 38 04 00 00 1C E5 06 00 14 B3 02 10 38 04 00 00 1C E5 06 00 15 B3 02 10 38 04 00 00 1C E5 06 00 16 B3 02 10 38 04 00 00 1C E5 06 00 17 B3 02 10 38 04 00 00 1C E5 06 00 90 B3 02 10 38 04 00 00 1C E5 06 00 91 B3 02 10 38 04 00 00 1C E5 06 00 92 B3 02 10 38 04 00 00 1C E5 06 00 93 B3 02 10 38 04 00 00 1C E5 06 00 94 B3 02 10 38 04 00 00 1C E5 06 00 95 B3 02 10 38 04 00 00 1C E5 06 00
9:22:04 AM
9:22:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 4C 09 81 80 96 B3 02 10 38 04 00 00 1C E5 06 00 97 B3 02 10 38 04 00 00 1C E5 06 00 10 B4 02 10 38 04 00 00 1C E5 06 00 11 B4 02 10 38 04 00 00 1C E5 06 00 12 B4 02 10 38 04 00 00 1C E5 06 00 13 B4 02 10 38 04 00 00 1C E5 06 00 14 B4 02 10 38 04 00 00 1C E5 06 00 15 B4 02 10 38 04 00 00 1C E5 06 00 16 B4 02 10 38 04 00 00 1C E5 06 00 17 B4 02 10 38 04 00 00 1C E5 06 00 90 B4 02 10 38 04 00 00
9:22:04 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 4D 09 81 80 1C E5 06 00 91 B4 02 10 38 04 00 00 1C E5 06 00 92 B4 02 10 38 04 00 00 1C E5 06 00 93 B4 02 10 38 04 00 00 1C E5 06 00 94 B4 02 10 38 04 00 00 1C E5 06 00 95 B4 02 10 38 04 00 00 1C E5 06 00 96 B4 02 10 38 04 00 00 1C E5 06 00 10 B5 02 10 38 04 00 00 1C E5 06 00 11 B5 02 10 38 04 00 00 1C E5 06 00 12 B5 02 10 38 04 00 00 1C E5 06 00 13 B5 02 10 38 04 00 00 1C E5 06 00 14 B5 02 10
9:22:05 AM
9:22:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 4E 09 81 80 38 04 00 00 1C E5 06 00 15 B5 02 10 38 04 00 00 1C E5 06 00 16 B5 02 10 38 04 00 00 1C E5 06 00 17 B5 02 10 38 04 00 00 1C E5 06 00 90 B5 02 10 38 04 00 00 1C E5 06 00 91 B5 02 10 38 04 00 00 1C E5 06 00 92 B5 02 10 38 04 00 00 1C E5 06 00 93 B5 02 10 38 04 00 00 1C E5 06 00 94 B5 02 10 38 04 00 00 1C E5 06 00 95 B5 02 10 38 04 00 00 1C E5 06 00 96 B5 02 10 38 04 00 00 1C E5 06 00
9:22:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 4F 09 81 80 97 B5 02 10 38 04 00 00 1C E5 06 00 10 B6 02 10 38 04 00 00 1C E5 06 00 11 B6 02 10 38 04 00 00 1C E5 06 00 12 B6 02 10 38 04 00 00 1C E5 06 00 13 B6 02 10 38 04 00 00 1C E5 06 00 14 B6 02 10 38 04 00 00 1C E5 06 00 15 B6 02 10 38 04 00 00 1C E5 06 00 16 B6 02 10 38 04 00 00 1C E5 06 00 17 B6 02 10 38 04 00 00 1C E5 06 00 90 B6 02 10 38 04 00 00 1C E5 06 00 91 B6 02 10 38 04 00 00
9:22:06 AM
9:22:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 50 09 81 80 1C E5 06 00 92 B6 02 10 38 04 00 00 1C E5 06 00 93 B6 02 10 38 04 00 00 1C E5 06 00 94 B6 02 10 38 04 00 00 1C E5 06 00 95 B6 02 10 38 04 00 00 1C E5 06 00 96 B6 02 10 38 04 00 00 1C E5 06 00 10 B7 02 10 38 04 00 00 14 E5 06 00 11 B7 02 10 38 04 00 00 14 E5 06 00 12 B7 02 10 38 04 00 00 14 E5 06 00 13 B7 02 10 38 04 00 00 14 E5 06 00 14 B7 02 10 38 04 00 00 14 E5 06 00 15 B7 02 10
9:22:06 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 51 09 81 80 38 04 00 00 14 E5 06 00 16 B7 02 10 38 04 00 00 14 E5 06 00 17 B7 02 10 38 04 00 00 14 E5 06 00 90 B7 02 10 38 04 00 00 14 E5 06 00 91 B7 02 10 38 04 00 00 14 E5 06 00 92 B7 02 10 38 04 00 00 14 E5 06 00 93 B7 02 10 38 04 00 00 14 E5 06 00 94 B7 02 10 38 04 00 00 14 E5 06 00 95 B7 02 10 38 04 00 00 14 E5 06 00 96 B7 02 10 38 04 00 00 14 E5 06 00 97 B7 02 10 38 04 00 00 14 E5 06 00
9:22:07 AM
9:22:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 52 09 81 80 10 B8 02 10 38 04 00 00 14 E5 06 00 11 B8 02 10 38 04 00 00 14 E5 06 00 12 B8 02 10 38 04 00 00 14 E5 06 00 13 B8 02 10 38 04 00 00 14 E5 06 00 14 B8 02 10 38 04 00 00 14 E5 06 00 15 B8 02 10 38 04 00 00 14 E5 06 00 16 B8 02 10 38 04 00 00 14 E5 06 00 17 B8 02 10 38 04 00 00 14 E5 06 00 90 B8 02 10 38 04 00 00 14 E5 06 00 91 B8 02 10 38 04 00 00 14 E5 06 00 92 B8 02 10 38 04 00 00
9:22:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 53 09 81 80 14 E5 06 00 93 B8 02 10 38 04 00 00 14 E5 06 00 94 B8 02 10 38 04 00 00 14 E5 06 00 95 B8 02 10 38 04 00 00 14 E5 06 00 96 B8 02 10 38 04 00 00 14 E5 06 00 10 B9 02 10 38 04 00 00 14 E5 06 00 11 B9 02 10 38 04 00 00 14 E5 06 00 12 B9 02 10 38 04 00 00 14 E5 06 00 13 B9 02 10 38 04 00 00 14 E5 06 00 14 B9 02 10 38 04 00 00 14 E5 06 00 15 B9 02 10 38 04 00 00 14 E5 06 00 16 B9 02 10
9:22:08 AM
9:22:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 54 09 81 80 38 04 00 00 14 E5 06 00 17 B9 02 10 38 04 00 00 14 E5 06 00 90 B9 02 10 38 04 00 00 14 E5 06 00 91 B9 02 10 38 04 00 00 14 E5 06 00 92 B9 02 10 38 04 00 00 14 E5 06 00 93 B9 02 10 38 04 00 00 14 E5 06 00 94 B9 02 10 38 04 00 00 14 E5 06 00 95 B9 02 10 38 04 00 00 14 E5 06 00 96 B9 02 10 38 04 00 00 14 E5 06 00 97 B9 02 10 38 04 00 00 14 E5 06 00 10 BA 02 10 38 04 00 00 14 E5 06 00
9:22:09 AM
9:22:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 55 09 81 80 11 BA 02 10 38 04 00 00 14 E5 06 00 12 BA 02 10 38 04 00 00 14 E5 06 00 13 BA 02 10 38 04 00 00 14 E5 06 00 14 BA 02 10 38 04 00 00 14 E5 06 00 15 BA 02 10 38 04 00 00 14 E5 06 00 16 BA 02 10 38 04 00 00 14 E5 06 00 17 BA 02 10 38 04 00 00 14 E5 06 00 90 BA 02 10 38 04 00 00 14 E5 06 00 91 BA 02 10 38 04 00 00 14 E5 06 00 92 BA 02 10 38 04 00 00 14 E5 06 00 93 BA 02 10 38 04 00 00
9:22:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 56 09 81 80 14 E5 06 00 94 BA 02 10 38 04 00 00 14 E5 06 00 95 BA 02 10 38 04 00 00 14 E5 06 00 96 BA 02 10 38 04 00 00 14 E5 06 00 10 BB 02 10 38 04 00 00 14 E5 06 00 11 BB 02 10 38 04 00 00 14 E5 06 00 12 BB 02 10 38 04 00 00 14 E5 06 00 13 BB 02 10 38 04 00 00 14 E5 06 00 14 BB 02 10 38 04 00 00 14 E5 06 00 15 BB 02 10 38 04 00 00 14 E5 06 00 16 BB 02 10 38 04 00 00 14 E5 06 00 17 BB 02 10
9:22:10 AM
9:22:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 57 09 81 80 38 04 00 00 14 E5 06 00 90 BB 02 10 38 04 00 00 14 E5 06 00 91 BB 02 10 38 04 00 00 14 E5 06 00 92 BB 02 10 38 04 00 00 14 E5 06 00 93 BB 02 10 38 04 00 00 14 E5 06 00 94 BB 02 10 38 04 00 00 14 E5 06 00 95 BB 02 10 38 04 00 00 14 E5 06 00 96 BB 02 10 38 04 00 00 14 E5 06 00 97 BB 02 10 38 04 00 00 14 E5 06 00 10 BC 02 10 38 04 00 00 14 E5 06 00 11 BC 02 10 38 04 00 00 14 E5 06 00
9:22:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 58 09 81 80 12 BC 02 10 38 04 00 00 14 E5 06 00 13 BC 02 10 38 04 00 00 14 E5 06 00 14 BC 02 10 38 04 00 00 14 E5 06 00 15 BC 02 10 38 04 00 00 14 E5 06 00 16 BC 02 10 38 04 00 00 14 E5 06 00 17 BC 02 10 38 04 00 00 14 E5 06 00 90 BC 02 10 38 04 00 00 14 E5 06 00 91 BC 02 10 38 04 00 00 14 E5 06 00 92 BC 02 10 38 04 00 00 14 E5 06 00 93 BC 02 10 38 04 00 00 14 E5 06 00 94 BC 02 10 38 04 00 00
9:22:11 AM
9:22:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 59 09 81 80 14 E5 06 00 95 BC 02 10 38 04 00 00 14 E5 06 00 96 BC 02 10 38 04 00 00 14 E5 06 00 10 C0 04 20 38 04 00 00 34 E6 06 00 11 C0 04 20 38 04 00 00 34 E6 06 00 12 C0 02 10 38 04 00 00 34 E6 06 00 13 C0 02 10 38 04 00 00 34 E6 06 00 14 C0 02 10 38 04 00 00 34 E6 06 00 15 C0 02 10 38 04 00 00 34 E6 06 00 16 C0 02 10 38 04 00 00 34 E6 06 00 17 C0 02 10 38 04 00 00 34 E6 06 00 10 C1 02 10
9:22:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 5A 09 81 80 18 03 00 00 66 00 1C 00 11 C1 02 10 18 03 00 00 6E 00 1C 00 12 C1 02 10 08 03 00 00 76 00 1C 00 13 C1 02 10 08 03 00 00 70 00 1C 00 90 C1 02 10 18 03 00 00 98 00 1C 00 91 C1 02 10 18 03 00 00 18 00 1B 00 92 C1 02 10 18 03 00 00 A4 00 1C 00 93 C1 02 10 18 03 00 00 AA 00 1C 00 94 C1 02 10 18 03 00 00 B6 00 1C 00 95 C1 02 10 18 03 00 00 BC 00 1C 00 96 C1 02 10 18 03 00 00 C8 00 1C 00
9:22:12 AM
9:22:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 5B 09 81 80 97 C1 02 10 18 03 00 00 C2 00 1C 00 10 C2 02 10 18 03 00 00 9E 00 1C 00 11 C2 02 10 18 03 00 00 9E 00 1C 00 12 C2 02 10 18 03 00 00 CC 00 1C 00 13 C2 02 10 18 03 00 00 D0 00 1C 00 90 C2 02 10 18 03 00 00 A8 00 1C 00 91 C2 02 10 18 03 00 00 A6 00 1C 00 92 C2 02 10 18 03 00 00 BE 00 1C 00 93 C2 02 10 18 03 00 00 A0 00 1C 00 94 C2 02 10 18 03 00 00 A2 00 1C 00 95 C2 02 10 18 03 00 00
9:22:12 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 5C 09 81 80 C0 00 1C 00 96 C2 02 10 18 03 00 00 AC 00 1C 00 97 C2 02 10 18 03 00 00 CA 00 1C 00 10 C3 02 10 18 03 00 00 B8 00 1C 00 11 C3 02 10 18 03 00 00 C4 00 1C 00 12 C3 02 10 18 03 00 00 C6 00 1C 00 13 C3 02 10 18 03 00 00 CE 00 1C 00 14 C3 02 10 18 03 00 00 D2 00 1C 00 10 C4 04 20 38 04 00 00 FC E4 06 00 11 C4 04 20 38 04 00 00 FC E4 06 00 12 C4 04 20 38 04 00 00 FC E4 06 00 13 C4 04 20
9:22:13 AM
9:22:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 5D 09 81 80 38 04 00 00 FC E4 06 00 14 C4 04 20 38 04 00 00 FC E4 06 00 15 C4 04 20 38 04 00 00 FC E4 06 00 20 C4 01 00 38 04 00 00 DC E4 06 00 21 C4 01 00 38 04 00 00 DC E4 06 00 22 C4 01 00 38 04 00 00 DC E4 06 00 23 C4 01 00 38 04 00 00 DC E4 06 00 24 C4 01 00 38 04 00 00 DC E4 06 00 25 C4 01 00 38 04 00 00 DC E4 06 00 28 C4 04 D0 38 01 00 00 1C 78 00 10 29 C4 04 D0 38 01 00 00 20 78 00 10
9:22:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 5E 09 81 80 2A C4 04 D0 38 01 00 00 24 78 00 10 2B C4 04 D0 38 01 00 00 84 78 00 10 2C C4 04 D0 38 01 00 00 88 78 00 10 2D C4 04 D0 38 01 00 00 8C 78 00 10 90 C4 04 20 38 04 00 00 FC E4 06 00 91 C4 04 20 38 04 00 00 FC E4 06 00 92 C4 04 20 38 04 00 00 FC E4 06 00 93 C4 04 20 38 04 00 00 FC E4 06 00 94 C4 04 20 38 04 00 00 FC E4 06 00 95 C4 04 20 38 04 00 00 FC E4 06 00 10 C5 04 20 38 04 00 00
9:22:14 AM
9:22:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 5F 09 81 80 04 E5 06 00 11 C5 04 20 38 04 00 00 04 E5 06 00 12 C5 04 20 38 04 00 00 04 E5 06 00 13 C5 04 20 38 04 00 00 04 E5 06 00 14 C5 04 20 38 04 00 00 04 E5 06 00 15 C5 04 20 38 04 00 00 04 E5 06 00 20 C5 01 00 38 04 00 00 DC E4 06 00 21 C5 01 00 38 04 00 00 DC E4 06 00 22 C5 01 00 38 04 00 00 DC E4 06 00 23 C5 01 00 38 04 00 00 DC E4 06 00 24 C5 01 00 38 04 00 00 DC E4 06 00 25 C5 01 00
9:22:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 60 09 81 80 38 04 00 00 DC E4 06 00 28 C5 04 D0 38 01 00 00 28 78 00 10 29 C5 04 D0 38 01 00 00 2C 78 00 10 2A C5 04 D0 38 01 00 00 30 78 00 10 2B C5 04 D0 38 01 00 00 90 78 00 10 2C C5 04 D0 38 01 00 00 94 78 00 10 2D C5 04 D0 38 01 00 00 98 78 00 10 90 C5 04 20 38 04 00 00 04 E5 06 00 91 C5 04 20 38 04 00 00 04 E5 06 00 92 C5 04 20 38 04 00 00 04 E5 06 00 93 C5 04 20 38 04 00 00 04 E5 06 00
9:22:15 AM
9:22:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 61 09 81 80 94 C5 04 20 38 04 00 00 04 E5 06 00 95 C5 04 20 38 04 00 00 04 E5 06 00 10 C6 02 10 38 04 00 00 0C E5 06 00 11 C6 02 10 38 04 00 00 0C E5 06 00 12 C6 02 10 38 04 00 00 0C E5 06 00 13 C6 02 10 38 04 00 00 0C E5 06 00 14 C6 02 10 38 04 00 00 0C E5 06 00 15 C6 02 10 38 04 00 00 0C E5 06 00 90 C6 02 10 38 04 00 00 2C E5 06 00 91 C6 02 10 38 04 00 00 2C E5 06 00 92 C6 02 10 38 04 00 00
9:22:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 62 09 81 80 2C E5 06 00 93 C6 02 10 38 04 00 00 24 E5 06 00 94 C6 02 10 38 04 00 00 24 E5 06 00 95 C6 02 10 38 04 00 00 24 E5 06 00 10 C7 04 20 30 04 00 00 2C E6 06 00 11 C7 04 20 30 04 00 00 2C E6 06 00 12 C7 04 20 30 04 00 00 2C E6 06 00 13 C7 04 20 30 04 00 00 2C E6 06 00 14 C7 04 20 30 04 00 00 2C E6 06 00 15 C7 04 20 30 04 00 00 2C E6 06 00 16 C7 04 20 30 04 00 00 2C E6 06 00 17 C7 04 20
9:22:16 AM
9:22:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 63 09 81 80 30 04 00 00 2C E6 06 00 90 C7 04 20 30 04 00 00 2C E6 06 00 91 C7 04 20 30 04 00 00 2C E6 06 00 10 CB 02 10 38 01 00 00 30 79 00 10 11 CB 02 10 38 01 00 00 32 79 00 10 12 CB 02 10 38 01 00 00 34 79 00 10 13 CB 02 10 38 01 00 00 48 79 00 10 14 CB 02 10 38 01 00 00 4A 79 00 10 15 CB 02 10 38 01 00 00 4C 79 00 10 20 CB 01 00 38 04 00 00 DC E4 06 00 21 CB 01 00 38 04 00 00 DC E4 06 00
9:22:17 AM
9:22:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 64 09 81 80 22 CB 01 00 38 04 00 00 DC E4 06 00 23 CB 01 00 38 04 00 00 DC E4 06 00 24 CB 01 00 38 04 00 00 DC E4 06 00 25 CB 01 00 38 04 00 00 DC E4 06 00 28 CB 04 D0 38 01 00 00 38 79 00 10 29 CB 04 D0 38 01 00 00 3C 79 00 10 2A CB 04 D0 38 01 00 00 40 79 00 10 2B CB 04 D0 38 01 00 00 50 79 00 10 2C CB 04 D0 38 01 00 00 54 79 00 10 2D CB 04 D0 38 01 00 00 58 79 00 10 90 CB 02 10 38 01 00 00
9:22:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 65 09 81 80 08 78 00 10 91 CB 02 10 38 01 00 00 0A 78 00 10 92 CB 02 10 38 01 00 00 0C 78 00 10 93 CB 02 10 38 01 00 00 0E 78 00 10 94 CB 02 10 38 01 00 00 10 78 00 10 95 CB 02 10 38 01 00 00 12 78 00 10 A0 CB 01 00 38 04 00 00 DC E4 06 00 A1 CB 01 00 38 04 00 00 DC E4 06 00 A2 CB 01 00 38 04 00 00 DC E4 06 00 A3 CB 01 00 38 04 00 00 DC E4 06 00 A4 CB 01 00 38 04 00 00 DC E4 06 00 A5 CB 01 00
9:22:18 AM
9:22:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 66 09 81 80 38 04 00 00 DC E4 06 00 A8 CB 04 D0 38 01 00 00 34 78 00 10 A9 CB 04 D0 38 01 00 00 38 78 00 10 AA CB 04 D0 38 01 00 00 3C 78 00 10 AB CB 04 D0 38 01 00 00 40 78 00 10 AC CB 04 D0 38 01 00 00 44 78 00 10 AD CB 04 D0 38 01 00 00 48 78 00 10 10 CC 02 10 38 01 00 00 70 78 00 10 11 CC 02 10 38 01 00 00 72 78 00 10 12 CC 02 10 38 01 00 00 74 78 00 10 13 CC 02 10 38 01 00 00 76 78 00 10
9:22:18 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 67 09 81 80 14 CC 02 10 38 01 00 00 78 78 00 10 15 CC 02 10 38 01 00 00 7A 78 00 10 20 CC 01 00 38 04 00 00 DC E4 06 00 21 CC 01 00 38 04 00 00 DC E4 06 00 22 CC 01 00 38 04 00 00 DC E4 06 00 23 CC 01 00 38 04 00 00 DC E4 06 00 24 CC 01 00 38 04 00 00 DC E4 06 00 25 CC 01 00 38 04 00 00 DC E4 06 00 28 CC 04 D0 38 01 00 00 9C 78 00 10 29 CC 04 D0 38 01 00 00 A0 78 00 10 2A CC 04 D0 38 01 00 00
9:22:19 AM
9:22:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 68 09 81 80 A4 78 00 10 2B CC 04 D0 38 01 00 00 A8 78 00 10 2C CC 04 D0 38 01 00 00 AC 78 00 10 2D CC 04 D0 38 01 00 00 B0 78 00 10 90 CC 02 10 38 04 00 00 34 E5 06 00 91 CC 02 10 38 04 00 00 34 E5 06 00 92 CC 02 10 38 04 00 00 34 E5 06 00 93 CC 02 10 38 04 00 00 34 E5 06 00 94 CC 02 10 38 04 00 00 34 E5 06 00 95 CC 02 10 38 04 00 00 34 E5 06 00 96 CC 02 10 38 04 00 00 34 E5 06 00 97 CC 02 10
9:22:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 69 09 81 80 38 04 00 00 34 E5 06 00 10 CD 02 10 38 04 00 00 34 E5 06 00 11 CD 02 10 38 04 00 00 34 E5 06 00 12 CD 02 10 38 04 00 00 34 E5 06 00 13 CD 02 10 38 04 00 00 34 E5 06 00 14 CD 02 10 38 04 00 00 34 E5 06 00 15 CD 02 10 38 04 00 00 34 E5 06 00 16 CD 02 10 38 04 00 00 34 E5 06 00 17 CD 02 10 38 04 00 00 34 E5 06 00 90 CD 02 10 38 04 00 00 34 E5 06 00 91 CD 02 10 38 04 00 00 34 E5 06 00
9:22:20 AM
9:22:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 6A 09 81 80 92 CD 02 10 38 04 00 00 34 E5 06 00 93 CD 02 10 38 04 00 00 34 E5 06 00 94 CD 02 10 38 04 00 00 34 E5 06 00 95 CD 02 10 38 04 00 00 34 E5 06 00 96 CD 02 10 38 04 00 00 34 E5 06 00 97 CD 02 10 38 04 00 00 34 E5 06 00 10 CE 02 10 38 04 00 00 3C E6 06 00 11 CE 02 10 38 04 00 00 3C E6 06 00 12 CE 02 10 38 04 00 00 3C E6 06 00 13 CE 02 10 38 04 00 00 3C E6 06 00 14 CE 02 10 38 04 00 00
9:22:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 6B 09 81 80 3C E6 06 00 15 CE 02 10 38 04 00 00 3C E6 06 00 16 CE 02 10 38 04 00 00 3C E6 06 00 17 CE 02 10 38 04 00 00 3C E6 06 00 10 CF 02 10 38 04 00 00 E4 E4 06 00 11 CF 02 10 38 04 00 00 EC E4 06 00 12 CF 02 10 38 04 00 00 EC E4 06 00 21 CF 01 00 38 04 00 00 DC E4 06 00 22 CF 01 00 38 04 00 00 DC E4 06 00 29 CF 04 D0 38 01 00 00 54 78 00 10 2A CF 04 D0 38 01 00 00 BC 78 00 10 94 CF 58 80
9:22:21 AM
9:22:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 6C 09 81 80 00 04 00 00 44 E6 06 00 10 D0 08 58 30 04 00 00 84 E4 06 00 11 D0 08 58 30 04 00 00 84 E4 06 00 12 D0 08 58 30 04 00 00 84 E4 06 00 13 D0 08 58 30 04 00 00 84 E4 06 00 14 D0 08 58 30 04 00 00 84 E4 06 00 15 D0 08 58 30 04 00 00 84 E4 06 00 16 D0 08 58 30 04 00 00 84 E4 06 00 17 D0 08 58 30 04 00 00 84 E4 06 00 90 D0 08 58 30 04 00 00 84 E4 06 00 91 D0 08 28 30 04 00 00 84 E4 06 00
9:22:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 6D 09 81 80 92 D0 08 28 30 04 00 00 84 E4 06 00 93 D0 08 28 30 04 00 00 84 E4 06 00 94 D0 08 28 30 04 00 00 84 E4 06 00 95 D0 08 28 30 04 00 00 84 E4 06 00 96 D0 08 28 30 04 00 00 84 E4 06 00 97 D0 08 28 30 04 00 00 84 E4 06 00 10 D1 08 28 30 04 00 00 84 E4 06 00 11 D1 08 28 30 04 00 00 84 E4 06 00 12 D1 08 28 30 04 00 00 84 E4 06 00 13 D1 08 28 30 04 00 00 84 E4 06 00 14 D1 08 28 30 04 00 00
9:22:22 AM
9:22:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 6E 09 81 80 84 E4 06 00 15 D1 08 28 30 04 00 00 84 E4 06 00 16 D1 08 58 30 04 00 00 84 E4 06 00 17 D1 08 58 30 04 00 00 84 E4 06 00 90 D1 08 58 30 04 00 00 84 E4 06 00 91 D1 08 28 30 04 00 00 84 E4 06 00 92 D1 08 28 30 04 00 00 84 E4 06 00 93 D1 08 28 30 04 00 00 84 E4 06 00 94 D1 08 28 30 04 00 00 84 E4 06 00 95 D1 08 28 30 04 00 00 84 E4 06 00 96 D1 08 28 30 04 00 00 84 E4 06 00 97 D1 08 28
9:22:23 AM
9:22:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 6F 09 81 80 30 04 00 00 84 E4 06 00 10 D2 08 28 30 04 00 00 84 E4 06 00 11 D2 08 28 30 04 00 00 84 E4 06 00 12 D2 08 28 30 04 00 00 84 E4 06 00 13 D2 08 28 30 04 00 00 84 E4 06 00 14 D2 08 28 30 04 00 00 84 E4 06 00 15 D2 08 28 30 04 00 00 84 E4 06 00 16 D2 08 28 30 04 00 00 84 E4 06 00 17 D2 08 28 30 04 00 00 84 E4 06 00 90 D2 08 28 30 04 00 00 84 E4 06 00 91 D2 08 28 30 04 00 00 84 E4 06 00
9:22:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 70 09 81 80 92 D2 08 28 30 04 00 00 84 E4 06 00 93 D2 04 20 38 04 00 00 3C E5 06 00 94 D2 04 20 38 04 00 00 3C E5 06 00 95 D2 04 20 38 04 00 00 3C E5 06 00 96 D2 04 20 38 04 00 00 3C E5 06 00 97 D2 04 20 38 04 00 00 3C E5 06 00 10 D3 04 20 38 04 00 00 3C E5 06 00 11 D3 04 50 38 04 00 00 3C E5 06 00 12 D3 04 50 38 04 00 00 3C E5 06 00 13 D3 04 50 38 04 00 00 3C E5 06 00 14 D3 04 50 38 04 00 00
9:22:24 AM
9:22:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 71 09 81 80 3C E5 06 00 15 D3 04 20 38 04 00 00 3C E5 06 00 16 D3 04 20 38 04 00 00 3C E5 06 00 17 D3 04 20 38 04 00 00 3C E5 06 00 90 D3 04 20 38 04 00 00 3C E5 06 00 91 D3 04 20 38 04 00 00 3C E5 06 00 92 D3 04 20 38 04 00 00 3C E5 06 00 93 D3 04 20 38 04 00 00 3C E5 06 00 94 D3 04 20 38 04 00 00 3C E5 06 00 95 D3 04 20 38 04 00 00 3C E5 06 00 96 D3 04 20 38 04 00 00 3C E5 06 00 97 D3 04 20
9:22:24 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 72 09 81 80 38 04 00 00 3C E5 06 00 10 D4 04 20 38 04 00 00 3C E5 06 00 11 D4 04 20 38 04 00 00 3C E5 06 00 12 D4 04 20 38 04 00 00 3C E5 06 00 13 D4 04 20 38 04 00 00 3C E5 06 00 14 D4 04 20 38 04 00 00 3C E5 06 00 15 D4 04 20 38 04 00 00 3C E5 06 00 16 D4 04 20 38 04 00 00 3C E5 06 00 17 D4 04 20 38 04 00 00 3C E5 06 00 90 D4 04 20 38 04 00 00 3C E5 06 00 91 D4 04 20 38 04 00 00 3C E5 06 00
9:22:25 AM
9:22:25 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 73 09 81 80 92 D4 04 20 38 04 00 00 3C E5 06 00 93 D4 04 20 38 04 00 00 3C E5 06 00 94 D4 04 20 38 04 00 00 3C E5 06 00 95 D4 04 20 38 04 00 00 3C E5 06 00 11 E0 04 20 38 04 00 00 44 E5 06 00 12 E0 04 20 38 04 00 00 44 E5 06 00 13 E0 04 20 38 04 00 00 44 E5 06 00 14 E0 04 20 38 04 00 00 44 E5 06 00 15 E0 04 20 38 04 00 00 44 E5 06 00 16 E0 04 20 38 04 00 00 44 E5 06 00 17 E0 04 20 38 04 00 00
9:22:25 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 74 09 81 80 4C E5 06 00 19 E0 04 20 38 04 00 00 44 E5 06 00 1A E0 04 20 38 04 00 00 44 E5 06 00 1B E0 04 20 38 04 00 00 44 E5 06 00 1C E0 04 20 38 04 00 00 44 E5 06 00 1D E0 04 20 38 04 00 00 44 E5 06 00 1E E0 04 20 38 04 00 00 44 E5 06 00 27 E0 01 00 38 04 00 00 DC E4 06 00 29 E0 01 00 38 04 00 00 DC E4 06 00 2A E0 01 00 38 04 00 00 DC E4 06 00 2B E0 01 00 38 04 00 00 DC E4 06 00 2C E0 01 00
9:22:26 AM
9:22:26 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 75 09 81 80 38 04 00 00 DC E4 06 00 2D E0 01 00 38 04 00 00 DC E4 06 00 2E E0 01 00 38 04 00 00 DC E4 06 00 2F E0 04 D0 38 01 00 00 40 4E 00 10 31 E0 04 D0 38 04 00 00 44 E5 06 00 32 E0 04 D0 38 04 00 00 44 E5 06 00 33 E0 04 D0 38 04 00 00 44 E5 06 00 34 E0 04 D0 38 04 00 00 44 E5 06 00 35 E0 04 D0 38 04 00 00 44 E5 06 00 36 E0 04 D0 38 04 00 00 44 E5 06 00 39 E0 04 D0 38 04 00 00 44 E5 06 00
9:22:26 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 76 09 81 80 3A E0 04 D0 38 04 00 00 44 E5 06 00 3B E0 04 D0 38 04 00 00 44 E5 06 00 3C E0 04 D0 38 04 00 00 44 E5 06 00 3D E0 04 D0 38 04 00 00 44 E5 06 00 3E E0 04 D0 38 04 00 00 44 E5 06 00 90 E0 04 20 38 04 00 00 4C E5 06 00 91 E0 04 20 38 04 00 00 4C E5 06 00 92 E0 04 20 38 04 00 00 4C E5 06 00 93 E0 04 20 38 04 00 00 4C E5 06 00 94 E0 04 20 38 04 00 00 4C E5 06 00 95 E0 04 20 38 02 00 00
9:22:27 AM
9:22:27 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 77 09 81 80 C8 0D 02 00 96 E0 04 20 38 02 00 00 CC 0D 02 00 97 E0 04 20 38 02 00 00 D0 0D 02 00 A0 E0 01 00 38 04 00 00 DC E4 06 00 A1 E0 01 00 38 04 00 00 DC E4 06 00 A2 E0 01 00 38 04 00 00 DC E4 06 00 A3 E0 01 00 38 04 00 00 DC E4 06 00 A4 E0 01 00 38 04 00 00 DC E4 06 00 A5 E0 01 00 38 04 00 00 DC E4 06 00 A6 E0 01 00 38 04 00 00 DC E4 06 00 A7 E0 01 00 38 04 00 00 DC E4 06 00 A8 E0 04 D0
9:22:27 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 78 09 81 80 38 01 00 00 24 4F 00 10 A9 E0 04 D0 38 01 00 00 8C 4E 00 10 AA E0 04 D0 38 01 00 00 70 4F 00 10 AB E0 04 D0 38 01 00 00 D8 4E 00 10 AC E0 04 D0 38 01 00 00 BC 4F 00 10 AD E0 04 D0 38 02 00 00 C0 11 02 00 AE E0 04 D0 38 02 00 00 C4 11 02 00 AF E0 04 D0 38 02 00 00 C8 11 02 00 10 E1 04 20 38 02 00 00 D4 0D 02 00 11 E1 04 20 38 02 00 00 D8 0D 02 00 12 E1 04 20 38 02 00 00 DC 0D 02 00
9:22:28 AM
9:22:28 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 79 09 81 80 13 E1 04 20 38 02 00 00 F0 0D 02 00 14 E1 04 20 38 02 00 00 F4 0D 02 00 15 E1 04 20 38 02 00 00 F8 0D 02 00 16 E1 04 20 38 02 00 00 FC 0D 02 00 17 E1 04 20 38 02 00 00 00 0E 02 00 20 E1 01 00 38 04 00 00 DC E4 06 00 21 E1 01 00 38 04 00 00 DC E4 06 00 22 E1 01 00 38 04 00 00 DC E4 06 00 28 E1 04 D0 38 02 00 00 CC 11 02 00 29 E1 04 D0 38 02 00 00 D0 11 02 00 2A E1 04 D0 38 02 00 00
9:22:28 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 7A 09 81 80 D4 11 02 00 90 E1 04 20 38 02 00 00 04 0E 02 00 91 E1 04 20 38 04 00 00 44 E5 06 00 92 E1 04 20 38 04 00 00 44 E5 06 00 93 E1 04 20 38 04 00 00 44 E5 06 00 94 E1 04 20 38 04 00 00 44 E5 06 00 95 E1 04 20 38 04 00 00 44 E5 06 00 96 E1 04 20 38 04 00 00 44 E5 06 00 97 E1 04 20 38 04 00 00 4C E5 06 00 99 E1 04 20 38 04 00 00 44 E5 06 00 9A E1 04 20 38 04 00 00 44 E5 06 00 9B E1 04 20
9:22:29 AM
00 01 00 01 00 01 00 05 C7 01 C1 00 00
9:22:29 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 7B 09 81 80 38 04 00 00 44 E5 06 00 9C E1 04 20 38 04 00 00 44 E5 06 00 9D E1 04 20 38 04 00 00 44 E5 06 00 9E E1 04 20 38 04 00 00 44 E5 06 00 A7 E1 01 00 38 04 00 00 DC E4 06 00 A9 E1 01 00 38 04 00 00 DC E4 06 00 AA E1 01 00 38 04 00 00 DC E4 06 00 AB E1 01 00 38 04 00 00 DC E4 06 00 AC E1 01 00 38 04 00 00 DC E4 06 00 AD E1 01 00 38 04 00 00 DC E4 06 00 AE E1 01 00 38 04 00 00 DC E4 06 00
9:22:30 AM
9:22:30 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 7C 09 81 80 AF E1 04 D0 38 01 00 00 08 50 00 10 B1 E1 04 D0 38 04 00 00 44 E5 06 00 B2 E1 04 D0 38 04 00 00 44 E5 06 00 B3 E1 04 D0 38 04 00 00 44 E5 06 00 B4 E1 04 D0 38 04 00 00 44 E5 06 00 B5 E1 04 D0 38 04 00 00 44 E5 06 00 B6 E1 04 D0 38 04 00 00 44 E5 06 00 B9 E1 04 D0 38 04 00 00 44 E5 06 00 BA E1 04 D0 38 04 00 00 44 E5 06 00 BB E1 04 D0 38 04 00 00 44 E5 06 00 BC E1 04 D0 38 04 00 00
9:22:30 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 7D 09 81 80 44 E5 06 00 BD E1 04 D0 38 04 00 00 44 E5 06 00 BE E1 04 D0 38 04 00 00 44 E5 06 00 10 E2 04 20 38 04 00 00 4C E5 06 00 11 E2 04 20 38 04 00 00 4C E5 06 00 12 E2 04 20 38 04 00 00 4C E5 06 00 13 E2 04 20 38 04 00 00 4C E5 06 00 14 E2 04 20 38 04 00 00 4C E5 06 00 15 E2 04 20 38 02 00 00 20 0E 02 00 16 E2 04 20 38 02 00 00 24 0E 02 00 17 E2 04 20 38 02 00 00 28 0E 02 00 20 E2 01 00
9:22:31 AM
9:22:31 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 7E 09 81 80 38 04 00 00 DC E4 06 00 21 E2 01 00 38 04 00 00 DC E4 06 00 22 E2 01 00 38 04 00 00 DC E4 06 00 23 E2 01 00 38 04 00 00 DC E4 06 00 24 E2 01 00 38 04 00 00 DC E4 06 00 25 E2 01 00 38 04 00 00 DC E4 06 00 26 E2 01 00 38 04 00 00 DC E4 06 00 27 E2 01 00 38 04 00 00 DC E4 06 00 28 E2 04 D0 38 01 00 00 EC 50 00 10 29 E2 04 D0 38 01 00 00 54 50 00 10 2A E2 04 D0 38 01 00 00 38 51 00 10
9:22:31 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 7F 09 81 80 2B E2 04 D0 38 01 00 00 A0 50 00 10 2C E2 04 D0 38 01 00 00 84 51 00 10 2D E2 04 D0 38 02 00 00 F0 11 02 00 2E E2 04 D0 38 02 00 00 F4 11 02 00 2F E2 04 D0 38 02 00 00 F8 11 02 00 90 E2 04 20 38 02 00 00 2C 0E 02 00 91 E2 04 20 38 02 00 00 30 0E 02 00 92 E2 04 20 38 02 00 00 34 0E 02 00 93 E2 04 20 38 02 00 00 50 0E 02 00 94 E2 04 20 38 02 00 00 54 0E 02 00 95 E2 04 20 38 02 00 00
9:22:32 AM
9:22:32 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 80 09 81 80 58 0E 02 00 96 E2 04 20 38 02 00 00 5C 0E 02 00 97 E2 04 20 38 02 00 00 60 0E 02 00 A0 E2 01 00 38 04 00 00 DC E4 06 00 A1 E2 01 00 38 04 00 00 DC E4 06 00 A2 E2 01 00 38 04 00 00 DC E4 06 00 A8 E2 04 D0 38 02 00 00 FC 11 02 00 A9 E2 04 D0 38 02 00 00 00 12 02 00 AA E2 04 D0 38 02 00 00 04 12 02 00 10 E3 04 20 38 02 00 00 64 0E 02 00 11 E3 04 20 38 04 00 00 44 E5 06 00 12 E3 04 20
9:22:32 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 81 09 81 80 38 04 00 00 44 E5 06 00 13 E3 04 20 38 04 00 00 44 E5 06 00 14 E3 04 20 38 04 00 00 44 E5 06 00 15 E3 04 20 38 04 00 00 44 E5 06 00 16 E3 04 20 38 04 00 00 44 E5 06 00 17 E3 04 20 38 04 00 00 4C E5 06 00 19 E3 04 20 38 04 00 00 44 E5 06 00 1A E3 04 20 38 04 00 00 44 E5 06 00 1B E3 04 20 38 04 00 00 44 E5 06 00 1C E3 04 20 38 04 00 00 44 E5 06 00 1D E3 04 20 38 04 00 00 44 E5 06 00
9:22:33 AM
9:22:33 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 82 09 81 80 1E E3 04 20 38 04 00 00 44 E5 06 00 27 E3 01 00 38 04 00 00 DC E4 06 00 29 E3 01 00 38 04 00 00 DC E4 06 00 2A E3 01 00 38 04 00 00 DC E4 06 00 2B E3 01 00 38 04 00 00 DC E4 06 00 2C E3 01 00 38 04 00 00 DC E4 06 00 2D E3 01 00 38 04 00 00 DC E4 06 00 2E E3 01 00 38 04 00 00 DC E4 06 00 2F E3 04 D0 38 01 00 00 D0 51 00 10 31 E3 04 D0 38 04 00 00 44 E5 06 00 32 E3 04 D0 38 04 00 00
9:22:33 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 83 09 81 80 44 E5 06 00 33 E3 04 D0 38 04 00 00 44 E5 06 00 34 E3 04 D0 38 04 00 00 44 E5 06 00 35 E3 04 D0 38 04 00 00 44 E5 06 00 36 E3 04 D0 38 04 00 00 44 E5 06 00 39 E3 04 D0 38 04 00 00 44 E5 06 00 3A E3 04 D0 38 04 00 00 44 E5 06 00 3B E3 04 D0 38 04 00 00 44 E5 06 00 3C E3 04 D0 38 04 00 00 44 E5 06 00 3D E3 04 D0 38 04 00 00 44 E5 06 00 3E E3 04 D0 38 04 00 00 44 E5 06 00 90 E3 04 20
9:22:34 AM
9:22:34 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 84 09 81 80 38 04 00 00 4C E5 06 00 91 E3 04 20 38 04 00 00 4C E5 06 00 92 E3 04 20 38 04 00 00 4C E5 06 00 93 E3 04 20 38 04 00 00 4C E5 06 00 94 E3 04 20 38 04 00 00 4C E5 06 00 95 E3 04 20 38 02 00 00 70 0E 02 00 96 E3 04 20 38 02 00 00 74 0E 02 00 97 E3 04 20 38 02 00 00 78 0E 02 00 A0 E3 01 00 38 04 00 00 DC E4 06 00 A1 E3 01 00 38 04 00 00 DC E4 06 00 A2 E3 01 00 38 04 00 00 DC E4 06 00
9:22:34 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 85 09 81 80 A3 E3 01 00 38 04 00 00 DC E4 06 00 A4 E3 01 00 38 04 00 00 DC E4 06 00 A5 E3 01 00 38 04 00 00 DC E4 06 00 A6 E3 01 00 38 04 00 00 DC E4 06 00 A7 E3 01 00 38 04 00 00 DC E4 06 00 A8 E3 04 D0 38 01 00 00 B4 52 00 10 A9 E3 04 D0 38 01 00 00 1C 52 00 10 AA E3 04 D0 38 01 00 00 00 53 00 10 AB E3 04 D0 38 01 00 00 68 52 00 10 AC E3 04 D0 38 01 00 00 4C 53 00 10 AD E3 04 D0 38 02 00 00
9:22:35 AM
9:22:35 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 86 09 81 80 10 12 02 00 AE E3 04 D0 38 02 00 00 14 12 02 00 AF E3 04 D0 38 02 00 00 18 12 02 00 11 E4 04 20 38 02 00 00 7C 0E 02 00 12 E4 04 20 38 02 00 00 80 0E 02 00 13 E4 04 20 38 02 00 00 84 0E 02 00 14 E4 04 20 38 02 00 00 90 0E 02 00 15 E4 04 20 38 02 00 00 94 0E 02 00 16 E4 04 20 38 02 00 00 98 0E 02 00 17 E4 04 20 38 02 00 00 9C 0E 02 00 21 E4 01 00 38 04 00 00 DC E4 06 00 22 E4 01 00
9:22:36 AM
9:22:36 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 87 09 81 80 38 04 00 00 DC E4 06 00 23 E4 01 00 38 04 00 00 DC E4 06 00 29 E4 04 D0 38 02 00 00 1C 12 02 00 2A E4 04 D0 38 02 00 00 20 12 02 00 2B E4 04 D0 38 02 00 00 24 12 02 00 90 E4 04 20 38 02 00 00 A0 0E 02 00 91 E4 04 20 38 02 00 00 A4 0E 02 00 10 E5 72 80 20 03 00 00 00 00 28 00 18 E5 01 00 10 03 00 00 00 00 2A 00 90 FA 01 00 08 04 00 00 DC E3 06 00 91 FA 01 00 08 04 00 00 DC E3 06 00
9:22:36 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 88 09 81 80 92 FA 01 00 08 04 00 00 DC E3 06 00 93 FA 01 00 08 04 00 00 DC E3 06 00 13 FB 02 10 38 02 00 00 68 33 02 00 14 FB 04 20 38 02 00 00 60 33 02 00 15 FB 04 20 38 02 00 00 64 33 02 00 16 FB 02 10 38 02 00 00 74 33 02 00 17 FB 04 20 38 02 00 00 6C 33 02 00 90 FB 04 20 38 02 00 00 70 33 02 00 91 FB 02 10 38 02 00 00 80 33 02 00 92 FB 04 20 38 02 00 00 78 33 02 00 93 FB 04 20 38 02 00 00
9:22:37 AM
9:22:37 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 89 09 81 80 7C 33 02 00 16 FF 04 20 38 04 00 00 64 E5 06 00 1E FF C2 C1 38 04 00 00 E4 E5 06 00 26 FF 04 20 38 04 00 00 EC E5 06 00 2E FF 01 60 00 04 00 00 F4 E5 06 00 36 FF 01 70 38 04 00 00 FC E5 06 00 00 B1 00 B3 00 B5 00 B7 00 B9 00 BB 00 70 01 70 02 70 03 70 04 70 05 70 06 70 07 70 03 71 06 72 04 74 05 74 06 74 07 74 82 74 83 74 00 01 52 01 BC 02 00 00 01 00 00 00 30 75 00 00 44 02 00 00
9:22:37 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 8A 09 81 80 01 01 52 01 2C 01 00 00 01 00 00 00 10 27 00 00 64 00 00 00 02 01 04 00 01 00 00 00 22 06 00 00 FF 00 00 00 00 00 00 00 03 01 04 00 01 00 00 00 78 00 00 00 0A 00 00 00 00 00 00 00 04 01 80 00 01 00 00 00 24 05 00 00 01 00 00 00 00 00 00 00 04 FF 80 00 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 04 FF 80 00 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 05 01 42 00 82 04 00 00
9:22:38 AM
9:22:38 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 8B 09 81 80 01 00 00 00 23 00 00 00 23 00 00 00 02 01 04 00 01 00 00 00 22 06 00 00 FF 00 00 00 00 00 00 00 02 01 04 00 01 00 00 00 22 06 00 00 FF 00 00 00 00 00 00 00 02 01 04 00 01 00 00 00 A8 01 00 00 40 00 00 00 00 00 00 00 02 01 04 00 01 00 00 00 22 06 00 00 FF 00 00 00 00 00 00 00 02 01 04 00 01 00 00 00 A0 00 00 00 14 00 00 00 00 00 00 00 02 01 04 00 01 00 00 00 A0 00 00 00 14 00 00 00
9:22:38 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 8C 09 81 80 00 00 00 00 02 01 08 00 01 00 00 00 38 07 00 00 64 00 00 00 00 00 00 00 04 FF 00 00 01 00 00 00 01 00 00 00 01 00 00 00 00 00 00 00 10 0E 00 00 01 00 10 80 10 19 10 30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 80 51 01 00 01 00 10 80 11 30 12 30
9:22:39 AM
9:22:39 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 8D 09 81 80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 01 00 10 80 11 00 00 00 00 00 00 00 01 00 10 80 96 16 00 00 00 00 00 00 00 00 10 11 10 12 11 12 10 30 11 30 12 30 12 50 15 50 10 15 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
9:22:39 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 8E 09 81 80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:22:40 AM
9:22:40 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 8F 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 11 10 12 11 12 10 30 11 30 12 30 12 50 15 50 10 15 FF FF FF FF FF FF FF FF FF FF FF FF
9:22:40 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 90 09 81 80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:22:41 AM
9:22:41 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 91 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 11 10 12 11 12 10 30 11 30 12 30 12 50 15 50 10 15 FF FF FF FF
9:22:42 AM
9:22:42 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 92 09 81 80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:22:42 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 93 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 10 80 11 30 12 30 11 40 12 40 FF FF FF FF
9:22:43 AM
9:22:43 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 94 09 81 80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 10 80 12 00 00 00 00 00 00 00 00 00 10 80 15 00 00 00 00 00 00 00 00 00 10 80 16 00 00 00 00 00 00 00 00 00 10 80 17 00 00 00 00 00 00 00 00 00 10 80 14 04 00 00 00 00 00 00 00 00 10 80 15 04 00 00 00 00 00 00
9:22:43 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 95 09 81 80 01 00 10 80 95 04 96 04 97 04 FF FF 00 00 00 00 00 00 00 00 00 00 94 3A 95 3A 96 3A 90 3A 91 3A 92 3A 11 3B 10 CE 10 CF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 48 00 90 00 9C 00 A8 00 B0 01 B8 02 C0 03 08 04 14 04 20 04 2C 04 38 04 44 04 50 04 64 04 AC 04 00 00 00 00 00 00
9:22:44 AM
9:22:44 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 96 09 81 80 06 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 00 03 00 04 00 06 00 14 00 22 00 23 00 24 00 25 00 26 00 27 00 28 00 29 00 2A 00 00 00 00 00 00 FC 00 00 00 00 96 00 98 00 08 00 34 00 04 00 01 00 01 FC 02 00 F8 00 8E 01 90 01 20 00 2C 01 04 00 02 00 02 FC 04 00 10 03 A6 03 A8 03 20 00 44 03 04 00 03 00
9:22:44 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 97 09 81 80 03 FC 06 00 28 05 BE 05 C0 05 20 00 5C 05 04 00 04 00 04 FC 08 00 40 07 D6 07 D8 07 08 00 74 07 04 00 05 00 07 FC 0A 00 38 08 CE 08 D0 08 08 00 6C 08 04 00 01 00 0A 00 64 00 E8 03 10 27 00 30 84 30 00 1E 00 31 84 31 00 1E 00 32 83 32 00 1E 00 3D 80 3D 00 1E 00 40 80 41 00 1B 01 50 84 51 00 1B 01 56 03 57 00 1B 80 58 87 59 00 1B 00 5A 87 5D 00 1D 01 E0 80 E1 00 1B 81 E1 00 E3 00 1D
9:22:45 AM
9:22:45 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 98 09 81 80 01 E3 81 E4 00 1C 00 81 02 81 00 1E 80 81 82 81 00 1B 83 81 83 81 00 20 00 61 87 61 00 1E 00 64 87 64 00 1E 00 67 87 67 00 1E 00 6A 87 6B 00 1E 00 D0 80 D0 00 1E 85 D0 80 D1 00 1E 86 35 87 35 00 1D 00 33 85 35 00 20 00 36 87 38 00 20 81 D0 84 D0 00 20 01 52 87 53 00 1D 00 42 80 43 00 1D 00 49 80 4A 00 1D 00 62 07 63 00 20 00 65 07 66 00 20 00 68 07 69 00 20 00 6C 87 6E 00 20 81 D1
9:22:45 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 99 09 81 80 82 D2 00 20 05 D3 82 D4 00 1D 05 3B 81 3B 00 1C 83 D4 85 D4 00 1C 82 3B 83 3C 00 1F 80 63 87 63 00 1F 80 66 87 66 00 1F 80 69 87 69 00 1F 00 6F 87 6F 00 1F 85 30 87 30 00 1F 85 31 87 31 00 1F 01 54 05 55 00 1C 00 44 80 45 00 1C 00 4B 80 4C 00 1C 00 46 80 48 00 1B 00 22 87 22 FD 23 05 23 07 23 FD 23 87 3A 04 3B 00 1B 83 D2 04 D3 00 1B 80 3A 83 3A FD 21 01 58 03 58 FD 21 84 3A 86 3A
9:22:46 AM
9:22:46 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 9A 09 81 80 FD 23 00 C4 85 C4 FD 23 00 C5 85 C5 FD 21 00 C6 05 C6 00 08 07 3A 07 3A 00 07 02 12 02 12 00 07 00 24 00 24 FD 23 02 24 02 24 FD 23 04 24 04 24 FD 23 06 24 06 24 FD 23 80 24 80 24 FD 23 82 24 82 24 FD 23 00 39 01 39 FF 38 04 39 05 39 FD 23 03 18 03 18 00 07 00 C1 02 C1 00 07 03 C1 03 C1 FF 38 00 CF 02 CF FF 2C 00 CB 07 CE FD FF 01 4E 06 4E FD FF 00 C0 07 C0 00 07 80 16 83 16 00 07
9:22:46 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 9B 09 81 80 86 16 86 16 00 07 80 C1 01 C2 00 07 01 23 02 23 FF 38 80 C2 84 C2 FF 38 85 C2 87 C2 FD 21 00 C3 00 C3 FF 21 01 C3 01 C3 FD FF 02 C3 02 C3 00 1C 86 14 87 14 00 07 84 24 84 24 00 23 87 0F 87 0F FD 07 83 0F 83 0F 00 07 84 2F 84 2F 00 05 80 C6 85 C6 FF 38 00 B1 86 BC FF 38 86 0F 86 0F 00 04 03 C3 04 C3 FF 38 02 C2 03 C2 00 07 00 C7 81 C7 00 07 00 60 10 00 00 00 91 01 01 60 10 00 92 01
9:22:47 AM
9:22:47 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 9C 09 81 80 91 01 00 00 00 00 00 00 00 00 00 00 00 FB 00 00 00 00 00 00 03 02 05 00 01 FB 00 00 00 00 00 00 03 02 05 00 02 FB 00 00 00 00 00 00 03 02 05 00 86 F6 00 00 00 00 00 00 4D 04 05 00 87 F6 00 00 00 00 00 00 4D 04 05 00 02 08 20 01 04 10 01 00 05 00 08 00 78 00 F8 00 B8 01 00 00 10 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3C 00 00 00 00 01 0F 00 00 00 00 00 E6 00 00 00 01 00 00 00
9:22:48 AM
9:22:48 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 9D 09 81 80 02 00 00 00 01 00 01 00 01 00 01 00 00 00 3C 00 3C 00 2C 01 0C 00 58 02 06 00 84 03 04 00 08 07 02 00 10 0E 01 00 01 00 0A 00 64 00 E8 03 10 27 01 30 00 00 E8 6C 00 10 00 1E 00 00 02 30 00 00 08 6D 00 10 00 1E 00 00 03 30 00 00 28 6D 00 10 00 1E 00 00 04 30 00 00 48 6D 00 10 00 1E 00 00 00 32 00 00 68 6D 00 10 00 1E 00 00 01 32 00 00 88 6D 00 10 00 1E 00 00 02 32 00 00 A8 6D 00 10
9:22:48 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 9E 09 81 80 00 1E 00 00 03 32 00 00 C8 6D 00 10 00 1E 00 00 01 31 00 00 F0 6C 00 10 00 1E 00 00 02 31 00 00 10 6D 00 10 00 1E 00 00 03 31 00 00 30 6D 00 10 00 1E 00 00 04 31 00 00 50 6D 00 10 00 1E 00 00 04 32 00 00 70 6D 00 10 00 1E 00 00 05 32 00 00 90 6D 00 10 00 1E 00 00 06 32 00 00 B0 6D 00 10 00 1E 00 00 07 32 00 00 D0 6D 00 10 00 1E 00 00 01 3D 00 00 F8 6C 00 10 00 1E 00 00 02 3D 00 00
9:22:49 AM
9:22:49 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A 9F 09 81 80 18 6D 00 10 00 1E 00 00 03 3D 00 00 38 6D 00 10 00 1E 00 00 04 3D 00 00 58 6D 00 10 00 1E 00 00 05 3D 00 00 78 6D 00 10 00 1E 00 00 06 3D 00 00 98 6D 00 10 00 1E 00 00 07 3D 00 00 B8 6D 00 10 00 1E 00 00 80 3D 00 00 D8 6D 00 10 00 1E 00 00 01 D0 00 00 00 6D 00 10 00 1E 00 00 02 D0 00 00 20 6D 00 10 00 1E 00 00 03 D0 00 00 40 6D 00 10 00 1E 00 00 04 D0 00 00 60 6D 00 10 00 1E 00 00
9:22:49 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A0 09 81 80 05 D0 00 00 80 6D 00 10 00 1E 00 00 06 D0 00 00 A0 6D 00 10 00 1E 00 00 07 D0 00 00 C0 6D 00 10 00 1E 00 00 80 D0 00 00 E0 6D 00 10 00 1E 00 00 01 33 00 00 E8 6D 00 10 00 20 00 00 02 33 00 00 18 6E 00 10 00 20 00 00 03 33 00 00 48 6E 00 10 00 20 00 00 04 33 00 00 78 6E 00 10 00 20 00 00 00 35 00 00 A8 6E 00 10 00 20 00 00 01 35 00 00 D8 6E 00 10 00 20 00 00 02 35 00 00 08 6F 00 10
9:22:50 AM
9:22:50 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A1 09 81 80 00 20 00 00 03 35 00 00 38 6F 00 10 00 20 00 00 01 34 00 00 F0 6D 00 10 00 20 00 00 02 34 00 00 20 6E 00 10 00 20 00 00 03 34 00 00 50 6E 00 10 00 20 00 00 04 34 00 00 80 6E 00 10 00 20 00 00 04 35 00 00 B0 6E 00 10 00 20 00 00 05 35 00 00 E0 6E 00 10 00 20 00 00 06 35 00 00 10 6F 00 10 00 20 00 00 07 35 00 00 40 6F 00 10 00 20 00 00 00 36 00 00 F8 6D 00 10 00 20 00 00 01 36 00 00
9:22:50 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A2 09 81 80 28 6E 00 10 00 20 00 00 02 36 00 00 58 6E 00 10 00 20 00 00 03 36 00 00 88 6E 00 10 00 20 00 00 04 36 00 00 B8 6E 00 10 00 20 00 00 05 36 00 00 E8 6E 00 10 00 20 00 00 06 36 00 00 18 6F 00 10 00 20 00 00 07 36 00 00 48 6F 00 10 00 20 00 00 00 37 00 00 00 6E 00 10 00 20 00 00 01 37 00 00 30 6E 00 10 00 20 00 00 02 37 00 00 60 6E 00 10 00 20 00 00 03 37 00 00 90 6E 00 10 00 20 00 00
9:22:51 AM
9:22:51 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A3 09 81 80 04 37 00 00 C0 6E 00 10 00 20 00 00 05 37 00 00 F0 6E 00 10 00 20 00 00 06 37 00 00 20 6F 00 10 00 20 00 00 07 37 00 00 50 6F 00 10 00 20 00 00 00 38 00 00 08 6E 00 10 00 20 00 00 01 38 00 00 38 6E 00 10 00 20 00 00 02 38 00 00 68 6E 00 10 00 20 00 00 03 38 00 00 98 6E 00 10 00 20 00 00 04 38 00 00 C8 6E 00 10 00 20 00 00 05 38 00 00 F8 6E 00 10 00 20 00 00 06 38 00 00 28 6F 00 10
9:22:51 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A4 09 81 80 00 20 00 00 07 38 00 00 58 6F 00 10 00 20 00 00 80 38 00 00 10 6E 00 10 00 20 00 00 81 38 00 00 40 6E 00 10 00 20 00 00 82 38 00 00 70 6E 00 10 00 20 00 00 83 38 00 00 A0 6E 00 10 00 20 00 00 84 38 00 00 D0 6E 00 10 00 20 00 00 85 38 00 00 00 6F 00 10 00 20 00 00 86 38 00 00 30 6F 00 10 00 20 00 00 87 38 00 00 60 6F 00 10 00 20 00 00 83 3B 00 00 68 6F 00 10 00 1F 00 00 84 3B 00 00
9:22:52 AM
9:22:52 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A5 09 81 80 78 6F 00 10 00 1F 00 00 85 3B 00 00 88 6F 00 10 00 1F 00 00 86 3B 00 00 98 6F 00 10 00 1F 00 00 87 3B 00 00 A8 6F 00 10 00 1F 00 00 00 3C 00 00 B8 6F 00 10 00 1F 00 00 01 3C 00 00 C8 6F 00 10 00 1F 00 00 02 3C 00 00 D8 6F 00 10 00 1F 00 00 04 3C 00 00 70 6F 00 10 00 1F 00 00 05 3C 00 00 80 6F 00 10 00 1F 00 00 06 3C 00 00 90 6F 00 10 00 1F 00 00 07 3C 00 00 A0 6F 00 10 00 1F 00 00
9:22:53 AM
9:22:53 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A6 09 81 80 80 3C 00 00 B0 6F 00 10 00 1F 00 00 81 3C 00 00 C0 6F 00 10 00 1F 00 00 82 3C 00 00 D0 6F 00 10 00 1F 00 00 83 3C 00 00 E0 6F 00 10 00 1F 00 00 01 40 00 00 00 00 00 00 00 1B 00 00 02 40 00 00 00 00 00 00 00 1B 00 00 03 40 00 00 00 00 00 00 00 1B 00 00 04 40 00 00 00 00 00 00 00 1B 00 00 05 40 00 00 00 00 00 00 00 1B 00 00 06 40 00 00 00 00 00 00 00 1B 00 00 07 40 00 00 00 00 00 00
9:22:53 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A7 09 81 80 00 1B 00 00 80 40 00 00 00 00 00 00 00 1B 00 00 01 41 00 00 00 00 00 00 00 1B 00 00 02 41 00 00 00 00 00 00 00 1B 00 00 03 41 00 00 00 00 00 00 00 1B 00 00 04 41 00 00 00 00 00 00 00 1B 00 00 05 41 00 00 00 00 00 00 00 1B 00 00 06 41 00 00 00 00 00 00 00 1B 00 00 07 41 00 00 00 00 00 00 00 1B 00 00 80 41 00 00 00 00 00 00 00 1B 00 00 01 46 00 00 00 00 00 00 00 1B 00 00 02 46 00 00
9:22:54 AM
9:22:54 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A8 09 81 80 00 00 00 00 00 1B 00 00 03 46 00 00 00 00 00 00 00 1B 00 00 04 46 00 00 00 00 00 00 00 1B 00 00 05 46 00 00 00 00 00 00 00 1B 00 00 06 46 00 00 00 00 00 00 00 1B 00 00 07 46 00 00 00 00 00 00 00 1B 00 00 80 46 00 00 00 00 00 00 00 1B 00 00 80 58 00 00 00 00 00 00 00 1B 00 00 81 58 00 00 00 00 00 00 00 1B 00 00 82 58 00 00 00 00 00 00 00 1B 00 00 83 58 00 00 00 00 00 00 00 1B 00 00
9:22:54 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A A9 09 81 80 84 58 00 00 00 00 00 00 00 1B 00 00 85 58 00 00 00 00 00 00 00 1B 00 00 86 58 00 00 00 00 00 00 00 1B 00 00 87 58 00 00 00 00 00 00 00 1B 00 00 01 42 00 00 00 00 00 00 00 1D 00 00 02 42 00 00 00 00 00 00 00 1D 00 00 03 42 00 00 00 00 00 00 00 1D 00 00 04 42 00 00 00 00 00 00 00 1D 00 00 05 42 00 00 00 00 00 00 00 1D 00 00 06 42 00 00 00 00 00 00 00 1D 00 00 07 42 00 00 00 00 00 00
9:22:55 AM
9:22:55 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A AA 09 81 80 00 1D 00 00 80 42 00 00 00 00 00 00 00 1D 00 00 01 43 00 00 00 00 00 00 00 1D 00 00 02 43 00 00 00 00 00 00 00 1D 00 00 03 43 00 00 00 00 00 00 00 1D 00 00 04 43 00 00 00 00 00 00 00 1D 00 00 05 43 00 00 00 00 00 00 00 1D 00 00 06 43 00 00 00 00 00 00 00 1D 00 00 07 43 00 00 00 00 00 00 00 1D 00 00 80 43 00 00 00 00 00 00 00 1D 00 00 00 5A 00 00 00 00 00 00 00 1D 00 00 01 5A 00 00
9:22:55 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A AB 09 81 80 00 00 00 00 00 1D 00 00 02 5A 00 00 00 00 00 00 00 1D 00 00 03 5A 00 00 00 00 00 00 00 1D 00 00 04 5A 00 00 00 00 00 00 00 1D 00 00 05 5A 00 00 00 00 00 00 00 1D 00 00 06 5A 00 00 00 00 00 00 00 1D 00 00 07 5A 00 00 00 00 00 00 00 1D 00 00 80 5A 00 00 00 00 00 00 00 1D 00 00 81 5A 00 00 00 00 00 00 00 1D 00 00 82 5A 00 00 00 00 00 00 00 1D 00 00 83 5A 00 00 00 00 00 00 00 1D 00 00
9:22:56 AM
9:22:56 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A AC 09 81 80 84 5A 00 00 00 00 00 00 00 1D 00 00 85 5A 00 00 00 00 00 00 00 1D 00 00 86 5A 00 00 00 00 00 00 00 1D 00 00 87 5A 00 00 00 00 00 00 00 1D 00 00 00 5B 00 00 00 00 00 00 00 1D 00 00 01 5B 00 00 00 00 00 00 00 1D 00 00 02 5B 00 00 00 00 00 00 00 1D 00 00 03 5B 00 00 00 00 00 00 00 1D 00 00 04 5B 00 00 00 00 00 00 00 1D 00 00 05 5B 00 00 00 00 00 00 00 1D 00 00 06 5B 00 00 00 00 00 00
9:22:56 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A AD 09 81 80 00 1D 00 00 07 5B 00 00 00 00 00 00 00 1D 00 00 80 5B 00 00 00 00 00 00 00 1D 00 00 81 5B 00 00 00 00 00 00 00 1D 00 00 82 5B 00 00 00 00 00 00 00 1D 00 00 83 5B 00 00 00 00 00 00 00 1D 00 00 84 5B 00 00 00 00 00 00 00 1D 00 00 85 5B 00 00 00 00 00 00 00 1D 00 00 86 5B 00 00 00 00 00 00 00 1D 00 00 87 5B 00 00 00 00 00 00 00 1D 00 00 01 44 00 00 00 00 00 00 00 1C 00 00 02 44 00 00
9:22:57 AM
9:22:57 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A AE 09 81 80 00 00 00 00 00 1C 00 00 03 44 00 00 00 00 00 00 00 1C 00 00 04 44 00 00 00 00 00 00 00 1C 00 00 05 44 00 00 00 00 00 00 00 1C 00 00 06 44 00 00 00 00 00 00 00 1C 00 00 07 44 00 00 00 00 00 00 00 1C 00 00 80 44 00 00 00 00 00 00 00 1C 00 00 01 45 00 00 00 00 00 00 00 1C 00 00 02 45 00 00 00 00 00 00 00 1C 00 00 03 45 00 00 00 00 00 00 00 1C 00 00 04 45 00 00 00 00 00 00 00 1C 00 00
9:22:57 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A AF 09 81 80 05 45 00 00 00 00 00 00 00 1C 00 00 06 45 00 00 00 00 00 00 00 1C 00 00 07 45 00 00 00 00 00 00 00 1C 00 00 80 45 00 00 00 00 00 00 00 1C 00 00 00 6A 00 00 68 74 00 10 01 6A 00 00 70 74 00 10 02 6A 00 00 78 74 00 10 03 6A 00 00 80 74 00 10 04 6A 00 00 88 74 00 10 05 6A 00 00 90 74 00 10 06 6A 00 00 98 74 00 10 07 6A 00 00 A0 74 00 10 80 6A 00 00 A8 74 00 10 81 6A 00 00 B0 74 00 10
9:22:58 AM
9:22:58 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B0 09 81 80 82 6A 00 00 B8 74 00 10 83 6A 00 00 C0 74 00 10 84 6A 00 00 C8 74 00 10 85 6A 00 00 D0 74 00 10 86 6A 00 00 D8 74 00 10 87 6A 00 00 E0 74 00 10 00 6B 00 00 E8 74 00 10 01 6B 00 00 F0 74 00 10 02 6B 00 00 F8 74 00 10 03 6B 00 00 00 75 00 10 04 6B 00 00 08 75 00 10 05 6B 00 00 10 75 00 10 06 6B 00 00 18 75 00 10 07 6B 00 00 20 75 00 10 80 6B 00 00 28 75 00 10 81 6B 00 00 30 75 00 10
9:22:59 AM
9:22:59 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B1 09 81 80 82 6B 00 00 38 75 00 10 83 6B 00 00 40 75 00 10 84 6B 00 00 48 75 00 10 85 6B 00 00 50 75 00 10 86 6B 00 00 58 75 00 10 87 6B 00 00 60 75 00 10 00 6C 00 00 68 75 00 10 01 6C 00 00 70 75 00 10 02 6C 00 00 78 75 00 10 03 6C 00 00 80 75 00 10 04 6C 00 00 88 75 00 10 05 6C 00 00 90 75 00 10 06 6C 00 00 98 75 00 10 07 6C 00 00 A0 75 00 10 80 6C 00 00 A8 75 00 10 81 6C 00 00 B0 75 00 10
9:22:59 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B2 09 81 80 82 6C 00 00 B8 75 00 10 83 6C 00 00 C0 75 00 10 84 6C 00 00 C8 75 00 10 85 6C 00 00 D0 75 00 10 86 6C 00 00 D8 75 00 10 87 6C 00 00 E0 75 00 10 00 6D 00 00 E8 75 00 10 01 6D 00 00 F0 75 00 10 02 6D 00 00 F8 75 00 10 03 6D 00 00 00 76 00 10 04 6D 00 00 08 76 00 10 05 6D 00 00 10 76 00 10 06 6D 00 00 18 76 00 10 07 6D 00 00 20 76 00 10 80 6D 00 00 28 76 00 10 81 6D 00 00 30 76 00 10
9:23:00 AM
9:23:00 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B3 09 81 80 82 6D 00 00 38 76 00 10 83 6D 00 00 40 76 00 10 84 6D 00 00 48 76 00 10 85 6D 00 00 50 76 00 10 86 6D 00 00 58 76 00 10 87 6D 00 00 60 76 00 10 00 6E 00 00 68 76 00 10 01 6E 00 00 70 76 00 10 02 6E 00 00 78 76 00 10 03 6E 00 00 80 76 00 10 04 6E 00 00 88 76 00 10 05 6E 00 00 90 76 00 10 06 6E 00 00 98 76 00 10 07 6E 00 00 A0 76 00 10 80 6E 00 00 A8 76 00 10 81 6E 00 00 B0 76 00 10
9:23:00 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B4 09 81 80 82 6E 00 00 B8 76 00 10 83 6E 00 00 C0 76 00 10 84 6E 00 00 C8 76 00 10 85 6E 00 00 D0 76 00 10 86 6E 00 00 D8 76 00 10 87 6E 00 00 E0 76 00 10 00 6F 00 00 E8 76 00 10 01 6F 00 00 F0 76 00 10 02 6F 00 00 F8 76 00 10 03 6F 00 00 00 77 00 10 04 6F 00 00 08 77 00 10 05 6F 00 00 10 77 00 10 06 6F 00 00 18 77 00 10 07 6F 00 00 20 77 00 10 80 6F 00 00 28 77 00 10 81 6F 00 00 30 77 00 10
9:23:01 AM
9:23:01 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B5 09 81 80 82 6F 00 00 38 77 00 10 83 6F 00 00 40 77 00 10 84 6F 00 00 48 77 00 10 85 6F 00 00 50 77 00 10 86 6F 00 00 58 77 00 10 87 6F 00 00 60 77 00 10 00 30 11 01 00 00 00 00 00 31 11 01 08 00 00 00 00 3D 11 01 50 00 00 00 00 D0 11 01 58 00 00 00 00 33 11 01 10 00 00 00 00 34 11 01 18 00 00 00 81 D0 11 01 30 00 00 00 82 D0 11 01 38 00 00 00 83 D0 11 01 40 00 00 00 84 D0 11 01 48 00 00 00
9:23:01 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B6 09 81 80 82 3B 11 01 20 00 00 00 03 3C 11 01 28 00 00 00 85 D0 11 02 00 00 00 00 00 D1 11 02 08 00 00 00 81 D1 11 02 10 00 00 00 84 D1 11 02 18 00 00 00 87 D1 11 02 30 00 00 00 02 D2 11 02 38 00 00 00 05 D2 11 02 40 00 00 00 80 D2 11 02 48 00 00 00 85 30 11 02 20 00 00 00 85 31 11 02 28 00 00 00 03 D1 11 02 50 00 00 00 06 D1 11 02 58 00 00 00 86 D0 11 04 00 00 00 00 01 D1 11 04 08 00 00 00
9:23:02 AM
9:23:02 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B7 09 81 80 82 D1 11 04 10 00 00 00 85 D1 11 04 18 00 00 00 00 D2 11 04 30 00 00 00 03 D2 11 04 38 00 00 00 06 D2 11 04 40 00 00 00 81 D2 11 04 48 00 00 00 86 30 11 04 20 00 00 00 86 31 11 04 28 00 00 00 04 D1 11 04 50 00 00 00 07 D1 11 04 58 00 00 00 87 D0 11 08 00 00 00 00 02 D1 11 08 08 00 00 00 83 D1 11 08 10 00 00 00 86 D1 11 08 18 00 00 00 01 D2 11 08 30 00 00 00 04 D2 11 08 38 00 00 00
9:23:02 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B8 09 81 80 07 D2 11 08 40 00 00 00 82 D2 11 08 48 00 00 00 87 30 11 08 20 00 00 00 87 31 11 08 28 00 00 00 05 D1 11 08 50 00 00 00 80 D1 11 08 58 00 00 00 00 40 16 80 68 77 00 10 00 41 16 80 6C 77 00 10 00 46 16 80 70 77 00 10 83 51 16 80 74 77 00 10 00 42 16 80 78 77 00 10 00 43 16 80 7C 77 00 10 80 53 16 80 80 77 00 10 81 53 16 80 84 77 00 10 82 53 16 80 88 77 00 10 83 53 16 80 8C 77 00 10
9:23:03 AM
9:23:03 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A B9 09 81 80 00 44 16 80 90 77 00 10 00 45 16 80 94 77 00 10 01 E0 16 80 98 77 00 10 02 E0 16 80 9C 77 00 10 81 E1 16 80 A0 77 00 10 82 E1 16 80 A4 77 00 10 01 E3 16 80 A8 77 00 10 02 E3 16 80 AC 77 00 10 03 E0 16 80 B0 77 00 10 04 E0 16 80 B4 77 00 10 83 E1 16 80 B8 77 00 10 84 E1 16 80 BC 77 00 10 03 E3 16 80 C0 77 00 10 04 E3 16 80 C4 77 00 10 05 E0 16 80 C8 77 00 10 06 E0 16 80 CC 77 00 10
9:23:03 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A BA 09 81 80 85 E1 16 80 D0 77 00 10 86 E1 16 80 D4 77 00 10 05 E3 16 80 D8 77 00 10 06 E3 16 80 DC 77 00 10 08 00 00 00 00 01 80 02 00 00 08 00 10 00 18 00 20 00 28 00 30 00 38 00 40 00 48 00 50 00 58 00 60 00 80 07 C0 07 00 08 40 08 80 08 C0 08 00 09 40 09 80 09 C0 09 00 0A 40 0A 08 00 F0 00 70 01 F0 01 B0 02 70 03 B0 03 60 00 68 00 70 00 78 00 80 00 88 00 90 00 98 00 A0 00 A8 00 B0 00 B8 00
9:23:04 AM
9:23:04 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A BB 09 81 80 60 00 00 00 00 00 00 00 01 01 01 01 01 01 01 01 01 01 00 01 00 00 00 00 67 6F 07 00 5C 6F 07 00 00 00 05 00 30 30 30 30 30 30 30 30 00 31 32 33 34 35 36 37 38 00 31 32 33 34 35 36 37 38 00 31 32 33 34 35 36 37 38 00 05 01 01 00 9A 00 9A 00 32 00 78 00 11 00 00 00 00 F4 00 00 0C 3E 00 20 01 F4 00 00 28 4C 00 20 02 F4 00 00 44 5A 00 20 03 F4 00 00 4C 6E 00 20 82 0A 00 00 68 7C 00 20
9:23:05 AM
9:23:05 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A BC 09 81 80 05 00 00 00 00 00 00 F7 01 00 04 F7 02 00 80 F7 03 00 81 F7 04 00 82 F7 00 00 00 00 00 00 00 00 00 EA 24 00 00 85 E2 01 80 51 01 00 00 85 E2 01 80 51 01 00 00 85 E2 01 00 00 00 00 00 00 00 00 00 EA 24 00 80 9B 7A 00 80 51 01 00 80 3A 09 00 80 51 01 00 80 51 01 00 80 51 01 00 00 85 E2 01 00 EA 24 00 00 85 E2 01 80 51 01 00 00 85 E2 01 80 51 01 00 00 85 E2 01 80 51 01 00 80 24 2E 00
9:23:05 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A BD 09 81 80 00 EA 24 00 80 9B 7A 00 80 3A 09 00 80 3A 09 00 80 51 01 00 80 51 01 00 00 90 FE FF 01 00 01 00 01 90 00 00 20 00 04 00 02 90 FF FF 02 00 01 00 03 90 FF FF 01 00 01 00 04 90 FF FF 01 00 01 00 05 90 FF FF 01 00 01 00 07 90 FF FF 02 00 01 00 80 90 FE FF 02 00 01 00 81 90 FF FF 01 00 01 00 87 90 FF FF 01 00 01 00 00 91 FF FF 01 00 01 00 05 91 FE FF 02 00 01 00 06 91 FF FF 01 00 01 00
9:23:06 AM
9:23:06 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A BE 09 81 80 07 91 FF FF 06 00 01 00 80 91 FF FF 02 00 01 00 81 91 FF FF 01 00 01 00 82 91 FF FF 01 00 01 00 84 91 42 07 08 00 01 00 01 93 FF FF 01 00 01 00 04 93 FF FF 03 00 01 00 B4 00 00 00 30 30 30 30 30 30 30 30 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 10 11 12 13 14 15 16 17 00 11 22 33 44 55 66 77 88 99 AA BB CC DD EE FF 00 11 22 33 44 55 66 77 10 0E 00 00 FF FF 03 FE 00 02 00 00
9:23:07 AM
9:23:07 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A BF 09 81 80 00 00 FF FF 0A FE 00 03 00 00 00 00 10 0E 00 00 21 9B 05 00 00 00 00 00 00 00 00 00 1F 1F 1F 1F 1F 1F 1E 1E 1E 1E 1E 1D 1F 1F 1F 1F 1F 1F 1E 1E 1E 1E 1E 1E 1F 1F 1C 1F 1E 1F 1E 1F 1F 1E 1F 1E 1F C4 23 73 88 81 8E 19 E1 38 33 C8 3D 3D 39 12 B7 60 B4 90 42 C8 50 3A 78 52 03 0D 25 23 11 3D FC 00 00 01 01 00 E6 00 FF 00 00 01 02 00 07 00 FF 00 00 01 04 00 00 00 FF 00 00 01 08 00 03 00
9:23:07 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C0 09 81 80 FF 00 00 01 10 00 E7 00 FF 00 00 01 20 00 04 00 2B 00 01 01 40 00 02 00 FF 00 01 01 80 00 01 00 FF 00 00 01 00 01 00 00 FF 00 00 01 00 02 00 00 FF 00 00 01 00 04 00 00 FF 00 00 01 00 08 00 00 FF 00 00 01 00 10 00 00 FF 00 00 01 00 20 FF 00 00 00 00 01 00 00 00 00 FF 00 01 01 01 80 E8 00 FF 00 01 01 02 80 E9 00 FF 00 01 01 03 80 EA 00 FF 00 01 01 04 80 EB 00 FF 00 01 01 05 80 EC 00
9:23:08 AM
9:23:08 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C1 09 81 80 FF 00 01 01 06 80 ED 00 FF 00 08 02 10 80 2C 00 15 00 08 02 0E 80 2D 00 16 00 08 02 11 80 28 00 15 00 08 02 0F 80 29 00 16 00 04 01 12 80 EE 00 FF 00 00 01 13 80 EF 00 FF 00 00 01 14 80 F0 00 FF 00 00 01 15 80 F1 00 FF 00 00 01 16 80 F2 00 FF 00 00 01 17 80 F3 00 FF 00 00 01 00 00 00 00 FF 00 00 01 00 00 00 00 FF 00 00 04 30 80 3E 00 01 00 00 04 31 80 3B 00 01 00 00 04 32 80 3F 00
9:23:08 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C2 09 81 80 0B 00 00 04 33 80 40 00 FF 00 00 04 34 80 3C 00 FF 00 00 04 35 80 3D 00 0C 00 00 01 00 00 00 00 FF 00 00 01 40 80 05 00 2C 00 00 01 55 80 06 00 2D 00 00 01 00 00 08 00 FF 00 00 01 46 80 09 00 54 00 00 01 43 80 0A 00 FF 00 00 01 44 80 0B 00 FF 00 00 01 50 80 0C 00 3D 00 00 01 51 80 0D 00 3C 00 00 01 52 80 0E 00 FF 00 00 01 53 80 0F 00 FF 00 00 01 54 80 10 00 41 00 00 01 60 80 11 00
9:23:09 AM
9:23:09 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C3 09 81 80 FF 00 00 01 61 80 12 00 50 00 10 02 24 81 2A 00 FF 00 10 02 25 81 2B 00 FF 00 00 02 4A 80 2E 00 FF 00 00 04 00 00 41 00 FF 00 00 04 00 00 42 00 FF 00 00 04 00 00 43 00 FF 00 00 08 00 00 64 00 FF 00 00 08 00 00 65 00 FF 00 00 08 00 00 66 00 FF 00 00 08 00 00 67 00 FF 00 00 08 00 00 68 00 FF 00 00 08 00 00 6E 00 FF 00 00 08 00 00 6F 00 FF 00 00 08 00 00 70 00 FF 00 00 08 00 00 71 00
9:23:09 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C4 09 81 80 FF 00 00 08 00 00 72 00 FF 00 00 08 00 00 78 00 FF 00 00 08 00 00 79 00 FF 00 00 08 00 00 7A 00 FF 00 00 08 00 00 7B 00 FF 00 00 08 00 00 7C 00 FF 00 00 08 00 00 82 00 FF 00 00 08 00 00 83 00 FF 00 00 08 00 00 84 00 FF 00 00 08 00 00 85 00 FF 00 00 08 00 00 86 00 FF 00 00 10 00 00 A0 00 FF 00 00 10 00 00 A1 00 FF 00 00 10 00 00 A2 00 FF 00 00 10 00 00 A3 00 FF 00 00 10 00 00 A4 00
9:23:10 AM
9:23:10 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C5 09 81 80 FF 00 00 20 00 00 AA 00 FF 00 00 20 00 00 AB 00 FF 00 00 20 00 00 AC 00 FF 00 00 20 00 00 AD 00 FF 00 00 20 00 00 AE 00 FF 00 00 40 00 00 B4 00 FF 00 00 40 00 00 B5 00 FF 00 00 40 00 00 B6 00 FF 00 00 40 00 00 B7 00 FF 00 00 40 00 00 B8 00 FF 00 00 80 00 00 BE 00 FF 00 00 80 00 00 BF 00 FF 00 00 80 00 00 C0 00 FF 00 00 80 00 00 C1 00 FF 00 00 80 00 00 C2 00 FF 00 00 02 00 00 00 00
9:23:10 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C6 09 81 80 00 00 00 04 00 00 00 00 00 00 00 08 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 04 00 00 00 00 02 00 00 04 00 00 00 00 03 00 00 04 00 00 00 00 04 00 00 04 00 00 00 00 0D 00 00 04 00 00 00 00 0E 00 00 08 00 00 00 00 1F 00 00 08 00 00 00 00 20 00 00 08 00 00 00 00 21 00 00 08 00 00 00 00 22 00 00 08 00 00 00 00 23 00 00 08 00 00 00 00 24 00 00 08 00 00 00 00 25 00 00 08 00 00 00 00
9:23:11 AM
9:23:11 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C7 09 81 80 26 00 00 08 00 00 00 00 27 00 00 01 00 00 00 00 29 00 00 01 00 00 00 00 2A 00 02 00 0B 81 52 00 33 00 02 00 05 81 55 00 34 00 02 00 0C 81 53 00 35 00 02 00 06 81 56 00 36 00 02 00 0D 81 54 00 37 00 02 00 07 81 57 00 38 00 00 01 00 00 00 00 3E 00 00 01 00 00 00 00 3F 00 00 01 00 00 0F 00 40 00 00 01 00 00 00 00 42 00 00 01 00 00 00 00 43 00 00 01 00 00 00 00 44 00 00 01 00 00 00 00
9:23:11 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C8 09 81 80 45 00 00 02 00 00 5B 00 46 00 00 01 00 00 00 00 47 00 00 01 00 00 00 00 48 00 00 01 62 80 33 00 51 00 00 01 00 00 00 00 52 00 00 01 00 00 00 00 53 00 00 01 00 00 00 00 55 00 00 01 00 00 00 00 56 00 00 01 00 00 00 00 57 00 00 01 00 00 00 00 58 00 00 01 00 00 00 00 59 00 00 01 00 00 00 00 5A 00 00 01 00 00 00 00 5B 00 00 01 00 00 00 00 5C 00 00 01 00 00 00 00 5D 00 00 01 00 00 00 00
9:23:12 AM
9:23:12 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A C9 09 81 80 5E 00 00 01 00 00 00 00 5F 00 00 04 00 00 00 00 05 00 00 04 00 00 00 00 06 00 00 08 00 00 00 00 1D 00 00 08 00 00 00 00 1E 00 00 04 00 00 44 00 FF 00 00 04 00 00 45 00 FF 00 00 04 00 00 46 00 FF 00 00 04 00 00 47 00 FF 00 00 04 00 00 48 00 FF 00 00 04 00 00 49 00 FF 00 00 04 00 00 4A 00 FF 00 00 04 00 00 4B 00 FF 00 00 02 00 20 FF 00 FF 00 00 04 00 00 FF 00 FF 00 00 08 00 00 FF 00
9:23:13 AM
9:23:13 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A CA 09 81 80 FF 00 00 10 00 00 FF 00 FF 00 00 20 00 00 FF 00 FF 00 00 40 00 00 FF 00 FF 00 00 80 00 00 FF 00 FF 00 02 00 00 20 FF 00 FF 00 02 00 20 80 4C 00 FF 00 02 00 23 80 4F 00 FF 00 02 00 21 80 4D 00 FF 00 02 00 24 80 50 00 FF 00 02 00 22 80 4E 00 FF 00 02 00 25 80 51 00 FF 00 00 01 71 80 58 00 FF 00 00 01 72 80 59 00 FF 00 00 01 41 80 2F 00 FF 00 00 01 47 80 30 00 FF 00 00 02 4B 80 31 00
9:23:13 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A CB 09 81 80 FF 00 00 02 4C 80 32 00 FF 00 00 01 45 80 13 00 FF 00 00 01 00 40 FE 00 FF 00 00 08 00 00 FE 00 FF 00 01 00 00 20 FF 00 FF 00 04 00 00 20 FF 00 FF 00 08 00 00 20 FF 00 FF 00 10 00 00 20 FF 00 FF 00 00 02 00 81 5A 00 FF 00 00 02 01 81 00 00 FF 00 00 02 94 80 00 00 FF 00 00 02 95 80 00 00 FF 00 00 02 86 80 00 00 FF 00 00 02 87 80 00 00 FF 00 00 02 88 80 00 00 FF 00 00 02 89 80 00 00
9:23:14 AM
9:23:14 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A CC 09 81 80 FF 00 00 02 8A 80 00 00 FF 00 00 02 8B 80 00 00 FF 00 00 02 8C 80 00 00 FF 00 00 02 8D 80 00 00 FF 00 00 02 8E 80 00 00 FF 00 00 02 8F 80 00 00 FF 00 00 02 90 80 00 00 FF 00 00 02 91 80 00 00 FF 00 00 02 80 80 00 00 FF 00 00 02 81 80 00 00 FF 00 00 02 82 80 00 00 FF 00 00 02 83 80 00 00 FF 00 00 02 84 80 00 00 FF 00 00 02 85 80 00 00 FF 00 00 02 22 81 00 00 FF 00 00 02 23 81 00 00
9:23:14 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A CD 09 81 80 FF 00 00 02 20 81 00 00 FF 00 00 02 21 81 00 00 FF 00 02 00 02 81 00 00 FF 00 02 00 03 81 00 00 FF 00 02 00 04 81 00 00 FF 00 02 00 08 81 00 00 FF 00 02 00 09 81 00 00 FF 00 02 00 0A 81 00 00 FF 00 00 01 42 80 00 00 FF 00 00 01 49 80 00 00 FF 00 00 01 48 80 00 00 FF 00 00 01 70 80 00 00 FF 00 00 01 74 80 00 00 FF 00 00 01 73 80 00 00 FF 00 00 01 30 81 00 00 FF 00 00 01 31 81 00 00
9:23:15 AM
9:23:15 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A CE 09 81 80 FF 00 00 01 32 81 00 00 FF 00 00 01 33 81 00 00 FF 00 00 01 40 81 00 00 FF 00 00 01 41 81 00 00 FF 00 00 01 42 81 00 00 FF 00 00 01 43 81 00 00 FF 00 00 01 44 81 00 00 FF 00 00 01 45 81 00 00 FF 00 04 00 50 81 00 00 FF 00 04 00 51 81 2F 00 FF 00 04 00 52 81 59 00 FF 00 04 00 53 81 00 00 FF 00 04 00 54 81 15 00 FF 00 04 00 55 81 00 00 FF 00 04 00 56 81 00 00 FF 00 04 00 57 81 00 00
9:23:15 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A CF 09 81 80 FF 00 04 00 58 81 00 00 FF 00 04 00 59 81 00 00 FF 00 04 00 5A 81 00 00 FF 00 00 01 75 80 00 00 FF 00 04 00 60 81 00 00 FF 00 04 00 70 81 00 00 FF 00 04 00 71 81 00 00 FF 00 04 00 72 81 00 00 FF 00 00 08 00 00 6A 00 FF 00 00 08 00 00 74 00 FF 00 00 08 00 00 7E 00 FF 00 00 08 00 00 88 00 FF 00 00 08 00 00 69 00 FF 00 00 08 00 00 73 00 FF 00 00 08 00 00 7D 00 FF 00 00 08 00 00 87 00
9:23:16 AM
9:23:16 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D0 09 81 80 FF 00 00 10 00 00 A5 00 FF 00 00 10 00 00 A6 00 FF 00 00 20 00 00 AF 00 FF 00 00 20 00 00 B0 00 FF 00 00 40 00 00 B9 00 FF 00 00 40 00 00 BA 00 FF 00 00 80 00 00 C3 00 FF 00 00 80 00 00 C4 00 FF 00 00 01 00 00 34 00 FF 00 00 01 00 00 35 00 FF 00 00 01 00 00 14 00 FF 00 02 00 00 00 5C 00 FF 00 02 00 00 00 5D 00 FF 00 02 00 00 00 5E 00 FF 00 04 00 5B 81 00 00 FF 00 04 00 5C 81 00 00
9:23:16 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D1 09 81 80 FF 00 04 00 5D 81 00 00 FF 00 04 00 5E 81 00 00 FF 00 04 00 00 00 00 00 FF 00 02 00 0E 81 00 00 FF 00 02 00 0F 81 00 00 FF 00 02 00 10 81 00 00 FF 00 02 00 11 81 00 00 FF 00 02 00 12 81 00 00 FF 00 02 00 13 81 00 00 FF 00 02 00 14 81 00 00 FF 00 02 00 15 81 00 00 FF 00 02 00 16 81 00 00 FF 00 02 00 17 81 00 00 FF 00 02 00 18 81 00 00 FF 00 02 00 19 81 00 00 FF 00 00 00 00 00 00 00
9:23:17 AM
9:23:17 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D2 09 81 80 00 00 80 00 00 80 00 00 00 00 83 00 00 81 00 00 00 00 81 00 00 00 00 00 00 00 82 00 00 00 00 00 00 00 86 00 95 86 00 00 85 00 87 00 95 87 00 00 85 00 88 00 00 88 00 00 00 00 89 00 00 89 00 00 00 00 8A 00 00 8A 00 00 00 00 8B 00 00 8B 00 00 00 00 8C 00 00 8C 00 00 00 00 8D 00 00 8D 00 00 00 00 8E 00 00 8E 00 00 00 00 8F 00 00 00 00 00 00 00 90 00 00 90 00 00 00 00 91 00 00 00 00 00
9:23:17 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D3 09 81 80 00 00 98 00 00 98 00 00 00 00 9F 00 00 9F 00 00 00 00 00 80 81 00 00 C0 00 00 00 81 9B 00 00 C1 8B 00 00 88 00 00 00 C8 00 00 00 89 90 00 D0 C9 80 00 00 8A 91 00 D1 CA 81 00 00 8B 96 00 00 CB 86 00 00 8C 00 00 00 CC 00 00 00 8D 00 00 00 00 00 00 00 90 00 00 00 90 00 00 00 91 00 00 00 91 00 00 00 92 00 00 00 92 00 00 00 93 00 00 00 93 00 00 00 94 00 00 00 00 00 00 00 95 00 00 00 00
9:23:18 AM
9:23:18 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D4 09 81 80 00 00 00 96 00 00 00 00 00 00 00 97 00 00 00 00 00 00 00 00 00 00 C9 00 00 00 00 00 91 00 CA 00 81 00 00 00 00 00 CB 00 00 00 00 00 00 00 CC 00 00 00 00 00 00 00 00 00 00 00 00 00 82 00 00 00 00 00 00 00 88 00 00 00 00 00 00 00 89 00 00 00 00 00 00 00 8A 00 00 00 00 00 96 00 00 00 00 00 00 00 97 00 00 00 00 00 00 00 99 00 00 00 00 00 00 00 9A 00 00 00 00 00 00 00 9B 00 00 00 00 00
9:23:19 AM
9:23:19 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D5 09 81 80 00 00 9C 00 00 00 00 00 00 00 9D 00 00 00 00 00 00 00 9E 00 00 00 00 00 00 00 00 00 92 00 00 00 82 00 00 00 93 00 00 00 83 00 00 00 94 00 00 00 84 00 00 00 97 00 00 00 87 00 00 00 98 00 00 00 88 00 00 00 99 00 00 00 89 00 00 00 9A 00 00 00 8A 00 00 00 9C 00 00 00 8C 00 00 00 9D 00 00 00 8D 00 00 00 00 85 00 00 00 00 00 00 00 8F 00 00 00 00 00 00 00 91 00 00 00 00 00 00 00 92 00 00
9:23:19 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D6 09 81 80 00 00 00 00 00 93 00 00 00 00 00 00 00 94 00 00 00 00 00 00 00 95 00 00 00 00 00 00 00 96 00 00 00 00 00 00 00 97 00 00 00 00 00 00 00 99 00 00 00 00 00 00 00 9A 00 00 00 00 00 00 00 9B 00 00 00 00 00 00 00 9C 00 00 00 00 00 00 00 9D 00 00 00 00 00 00 00 9E 00 00 00 00 00 00 00 82 00 00 00 00 00 00 00 83 00 00 00 00 00 00 00 84 00 00 00 00 00 00 77 79 7B A9 AB AD AA AC AE 00 0A 00
9:23:20 AM
9:23:20 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D7 09 81 80 64 00 3C 00 64 00 3C 00 64 00 58 02 06 04 CA 03 58 02 84 03 4C 04 58 02 FC 03 D4 03 0A 00 BC 02 64 00 0A 00 F4 01 64 00 17 01 18 01 19 01 1D 01 1E 01 1F 01 1A 01 1B 01 1C 01 20 01 21 01 22 01 84 03 14 00 01 00 1E 00 4C 04 14 00 01 00 1E 00 BF 01 14 00 01 00 1E 00 58 02 00 00 CF 07 4C 04 4B 04 1A 04 19 04 E8 03 E7 03 B6 03 B5 03 84 03 83 03 52 03 51 03 00 00 0A 00 64 00 14 00 0A 00
9:23:20 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D8 09 81 80 E8 03 14 00 0A 00 20 4E 14 00 00 00 65 D5 05 00 02 20 00 00 00 00 00 00 00 00 00 00 C8 00 00 00 58 02 00 00 F3 CC 05 00 04 20 00 00 CF 07 00 00 4C 04 00 00 C8 00 00 00 58 02 00 00 F3 CC 05 00 04 20 01 00 4B 04 00 00 1A 04 00 00 C8 00 00 00 58 02 00 00 F3 CC 05 00 04 20 02 00 19 04 00 00 E8 03 00 00 C8 00 00 00 58 02 00 00 F3 CC 05 00 04 20 03 00 E7 03 00 00 B6 03 00 00 C8 00 00 00
9:23:21 AM
9:23:21 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A D9 09 81 80 58 02 00 00 F3 CC 05 00 04 20 04 00 B5 03 00 00 84 03 00 00 C8 00 00 00 58 02 00 00 F3 CC 05 00 04 20 05 00 83 03 00 00 52 03 00 00 C8 00 00 00 58 02 00 00 F3 CC 05 00 04 20 06 00 51 03 00 00 00 00 00 00 C8 00 00 00 58 02 00 00 0F CF 05 00 01 30 00 00 06 04 00 00 CA 03 00 00 C8 00 00 00 58 02 00 00 77 D1 05 00 01 00 01 00 C8 00 00 00 00 00 00 00 C8 00 00 00 58 02 00 00 3F D3 05 00
9:23:21 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A DA 09 81 80 01 30 02 00 FC 03 00 00 D4 03 00 00 C8 00 00 00 58 02 00 00 A1 D7 05 00 02 00 01 00 00 00 00 00 00 00 00 00 F4 01 00 00 80 51 01 00 F1 DF 05 00 01 30 03 00 14 00 00 00 64 00 00 00 C8 00 00 00 0A 00 00 00 3F E2 05 00 01 30 04 00 C8 00 00 00 14 00 00 00 C8 00 00 00 0A 00 00 00 05 E8 05 00 01 30 08 00 4C 04 00 00 84 03 00 00 C8 00 00 00 0A 00 00 00 59 EE 05 00 01 30 05 00 64 00 00 00
9:23:22 AM
9:23:22 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A DB 09 81 80 14 00 00 00 C8 00 00 00 0A 00 00 00 D1 E4 05 00 01 30 06 00 00 00 00 00 00 00 00 00 C8 00 00 00 0A 00 00 00 19 EC 05 00 01 30 07 00 00 00 00 00 00 00 00 00 C8 00 00 00 0A 00 00 00 78 7A 7C 00 2B 57 4F 50 45 4E 3D 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 30 75 00 00 45 30 56 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
9:23:23 AM
9:23:23 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A DC 09 81 80 00 00 02 00 E8 03 00 00 45 30 56 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 00 E8 03 00 00 2B 57 49 50 43 46 47 3D 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 E8 03 00 00 2B 43 4D 45 45 3D 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 E8 03 00 00 2B 57 49 50 43 46 47 3D 31 00 00 00
9:23:23 AM
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A DD 09 81 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 10 27 00 00 2B 57 49 50 43 46 47 3D 32 2C 33 2C 34 30 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 E8 03 00 00 2B 57 49 50 43 46 47 3D 32 2C 34 2C 31 34 36 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 E8 03 00 00 2B 57 49 50 43 46 47 3D 32 2C 31 32 2C 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00
9:23:24 AM
9:23:24 AM Updating image MT880_ARM_035000458_M1...
00 01 00 01 00 01 00 97 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A DE 09 81 80 E8 03 00 00 2B 57 49 50 43 46 47 3D 32 2C 31 36 2C 38 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 E8 03 00 00 2B 57 49 50 43 46 47 3D 32 2C 31 37 2C 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 E8 03 00 00 DA 07 78 00 07 80 00 30 30 30 30 30 30 30 30 00 4D 54 38 38 30 2D 31 30 30 35 00 49 53 4B 00 00 00 00 00 00 49 53 4B 41 4D 4D 54 38 38 30 31 30 30 35 39 33
9:23:24 AM
00 01 00 01 00 01 00 26 C3 01 C1 00 12 00 00 2C 00 00 FF 02 01 02 02 06 00 00 0A DF 09 10 DE 09 DA BE 5D EC 89 51 DD 6E 90 39 57 D4 AC 76
9:23:25 AM
00 01 00 01 00 01 00 05 C7 01 C1 FA 00
9:25:15 AM Send Keep Alive
00 01 00 01 00 01 00 0D C0 01 C1 00 0F 00 00 28 00 00 FF 01 00
9:25:16 AM
00 01 00 01 00 01 00 0C C4 01 C1 00 09 06 00 00 28 00 00 FF
9:27:05 AM Send Keep Alive
9:27:06 AM
4 years ago
The firmware identification number can be anything. The meter manufacturer defines that. You need to check it with the meter vendor.
The picture doesn't tell anything. You move all image blocks for the meter. Is this error coming in Image verify or image activate? Try to read the Image transferred blocks status (Attribute index #3) and check that all the blocks are on the meter.
It might be that you receive this error because the image identifier is something else that the meter expects.
prasanth
4 years ago
Thanks for your quick response.
This error is coming at the end period of the image update activity. The image is showing transferring, and at the end of completion, this access error: pop up showing. if we close this error window, activate and verify button in gurux UI is disabled, and only the update function shows active.
also the image transfer status is showing transfer initiated.
Image block transfer is showing image transferred. Please see the attached image.
4 years ago
Please, don't app pics. There is no use for it. You can activate the Verify and Activate buttons if you check Manual before you connect for the meter.
Try to increase the wait time from 10 seconds to one minute. It might be that the meter is still verifying the image and that causes the problem.
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
