  3. Wrong Timezone Value Send To Meter When "adjust To Current Timezone"
Wrong timezone value send to meter when "adjust to current timezone"
By Miguel MontaƱo , 11 March, 2019
Hello.
I found the following problem:
My timezone is UTC-6 (Mexico City) and I am runing DLMSDirector under Windows 10. When I update the meter current time zone using the clock object, DLMSDirector sends a 360 value instead of -360. If I change my time zone to UTC+6 (ex. Dacca) DLMSDirector now sends a -360 value instead of the expected 360.
I think that could be a problem with locales
7 years 8 months ago
DLMS standard defines time zone from normal time to UTC, not UTC time
http://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
If you want to use UTC time zone, select "Use UTC time zone, not standard" from "Advanced" tab in meter settings.
