  3. Initial Settings For Itron SL7000 By Terminal - GXDLMSDirector 8.0.1703.1301
initial settings for Itron SL7000 by terminal - GXDLMSDirector 8.0.1703.1301
By CLic , 1 October, 2018
hi,
i'm reading the registers of some Iton SL7000 761 Ref. Firmware 5.35 using ACEPILOT software using GSM modem.
i would like to try to do it also with GXDLMSDirector 8.0.1703.1301 using GSM modem (by terminal).
please, can you give me info about the default initial settings?
moreover:
- the firmware version must be set in any place? in ACE pilot software it is required!
- the meter Serial number must be set in any place? in ACE pilot software it is required!
i hope to receive a feedback!
best regards Claudio Liciotti
7 years 8 months ago
You don't need to set that info. You can check settings from there:
There are two version from SL7000. One is supporting DLMS and other Spain some standard.
Make sure that your meter is supporting DLMS. You can find more information from this in our forum.
