  3. Kamstrup Meters
Kamstrup meters
By cappa , 16 February, 2012
Has anyone sucessfully connected to any Kamstrup meters. Got a 382 K at the moment. It should respond to port 1025 But doesnt give any ok connection. Sometimes lucky on getting the setup from telnet to port 50100.
If successfully connected, how is the kamstrup model setup. Need details. I do think there might be a problem in the setup there and not the gurux software. Since the Kamstrup company keeps all information rather closed its hard to guess what to do. Any portscan on the meter is also unsuccessfull so guessing is the only option ( kinda many ports to guess from ). The default port as described in the standard setup doesnt respond to telnet either. One of the big issues with this meter is also guessing when it will respond, since also telnet to standard setup port doesnt response regulary.
The setup we got is a wifi connection. New meter with working cable (TCP/IP) is ordered but no need to say that the waiting time is long. Any suggestions and ideas would be welcome
kai
14 years 7 months ago
Kamstrup meter
Yes we are reading Kamstrup meters. Have you try with IF eye or just TCP/IP?
If you have eye try with GXDLMSDirector using following settings:
If you succeeded to read meter using eye you can see TCP/IP settings as well so
you do not need to search the TCP/IP port.
  • lh
