  3. Unable To Read The Data From Crystal.xml File
unable to read the data from crystal.xml file
By Harish07 , 14 July, 2023
Can you please provide with xml file containing real meter readings ,because I was unable to find any data in the template which was given in crystal.xml (Github project)
3 years 2 months ago
Hi, The simulator is using…
The simulator is using crystal.xml and you don't need it in GXDLMSDirector. Select Indian Standard as a manufacturer and set the correct password and you can connect for the meter.
