  3. Data Objects Missing
Data objects missing
Profile picture for user oulahsensaid
By oulahsensaid , 24 February, 2023
GXDLMSDirector 9.0.2302.2001
Log created 22:34:42
Disconnect request
Disconnect request
7E A0 08 02 23 21 53 B1 A2 7E
Initializing serial connection.
IEC Sending:/?!<CR><LF>
HDLC received: /ACE5\2ACE6K_MK2_R2<CR><LF>
BaudRate is : 9600
Moving to mode E.
06 32 35 32 0D 0A
Send SNRM request.
7E A0 08 02 23 21 93 BD 64 7E
7E A0 23 21 00 02 00 23 73 F6 C5 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
Parsing UA reply succeeded.
Send AARQ request.
7E A0 2C 02 23 21 10 AF 9F E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 88 55 7E
7E A0 3A 21 00 02 00 23 30 99 41 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1D 21 34 00 07 89 9B 7E
Parsing AARE reply succeeded.
Read object type Data index: 2
7E A0 1A 02 23 21 32 F6 72 E6 E6 00 C0 01 C1 00 01 00 00 2A 00 00 FF 02 00 12 80 7E
7E A0 25 21 00 02 00 23 52 B0 AD E6 E7 00 C4 01 C1 00 0A 10 41 43 45 36 36 31 4D 41 38 34 34 35 37 36 38 34 EE E1 7E
3 years 8 months ago
Hi, The available data…
The available data objects might depend on the authentication level used. You need to change the authentication level to Low or High and change the client address.
After that, you can access more objects.
Problem solved, thank you…
Problem solved, thank you very much.
One more question please. Is OBIS code are the same for all meters? and which code for consumption quantity?
In reply to Problem solved, thank you… by oulahsensaid
Hi, The basic idea is that…
The basic idea is that the OBIS codes should be the same for all the meters. In reality, some meter manufacturers are using different OBIS codes. You can check available objects and their OBIS codes by reading the association view.
  • hassannouri
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
