  3. E450 Prime Meter (L&Gyr) Metering Data
E450 Prime meter (L&Gyr) metering data
By sunnysouth , 16 January, 2022
i can connect to the E450 Prime meter (L&Gyr) and even read it but where does it show the actual meter readings? I did not put any password anywhere. Do i need some password? This meter is in Spain. See screenshot attached
4 years 3 months ago
This is the data that you can see without a password. If you can get the password try to change the authentication level to Low and set a correct password. Then select "Refresh" from the "File" menu. It will read the object tree and you can see more objects on the left side.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
