I am using version number 8.2.1905.1401
I am not able to download the new version.
Please let me know the latest version number and how to download it.
While installing a new version i am getting an error. Kindly help me in fixing this issue.
Please find the attached pic for the error pic.
Hello sir,
Please let me know about the GXDLMSDirector settings.
I want to access HDLC with the optical port.
kindly suggest how to make associations.
Before I have used GuruX but this version I am facing the issue.
I am not at all able to add associations.
Dear sir,
I am able to add associations and download associations.
Can you share the tool manual if any?
It will be useful for me to download and operate DLMS functionalities.
Thanks for your support.
I am able to download and access data through serial port(Optical port).
Now I want to establish a connection through TCP. I tried establishing the connection but unable to connect.
kindly help me in this regard. I am using two Static IPV6 sim cards, one in PC and one in Modem for connection establishment.
After establishing connection it is failing automatically I am not able to download associations.
I am not able to download data from the Meter.
Please find the attached pic for the error message.
You can download GXDLMSDirector and read your meter with that.
You need to know the password if you want to write anything. Do you have it?
Hi Vikas,
Hi Vikas,
You must download GXDLMSDirector from Gurux.
https://www.gurux.fi/Downloads
I am unable to download it
I am unable to download it from your link. It is showing error. The error pic is attached.
There is something wrong with your Windows certifications. Try to solve why the https connection fails.
Sir i am able to download 8.2
Sir i am able to download 8.2.2005.1401 version but unable to add associations.
kindly help me in adding associations.
Hello sir,
Hello sir,
Kindly help.
Dear sir,
Dear sir,
Hi Vikas,
Hi Vikas,
You can start reading this:
https://www.gurux.fi/GXDLMSDirectorHelp
Dear Sir,
Dear Sir,
PFA
PFA
This is Windows error. The client can't make TCP/IP connection to the meter. Check your IP address and port number.
