  3. Disconnect Control
gxdn
By Administrator , 23 January, 2018
Disconnect control object is used to manage an internal or external disconnect unit.
Properties
  • 1. Logical Name
    Logical name of the object.
  • 2. Output state
    Actual physical state.
  • 3. Control state
    Internal state.
  • 4. Control mode
    Defines how disconnect can be used. (local, remote,both or neighter).
Actions
  • 1. Remote disconnect
    Remote disconnect.
  • 2. Remote reconnect
    Remote reconnect.
This example forces the disconnect control object into 'disconnected' state if remote disconnection is enabled.
  • Java
  • C#
  • Delphi
  • ANSI C++
  • ANSI C
  • Python
GXDLMSDisconnectControl dc = new GXDLMSDisconnectControl();
readDataBlock(dc.remoteDisconnect(client), reply);
ReadDataBlock(dc.RemoteDisconnect(client), reply);
reply := TGXReplyData.Create();
dc = TGXDLMSDisconnectControl.Create();
CGXReplyData reply;
CGXDLMSDisconnectControl dc;
int ret;
message messages;
gxReplyData reply;
gxDisconnectControl dc;
dlmsVARIANT params;
const unsigned char ln[6] = { 0,0,96,3,10,255 };
GX_INT8(params, 0);
if ((ret = INIT_OBJECT(dc, DLMS_OBJECT_TYPE_DISCONNECT_CONTROL, ln)) == 0)
    mes_init(&messages);
    reply_init(&reply);
    //Remote disconnect
    if ((ret = cl_method(&connection->settings, BASE(dc), 1, &params, &messages)) != 0 ||
        (ret = com_readDataBlock(connection, &messages, &reply)) != 0)
        printf("Method failed %s\r\n", hlp_getErrorMessage(ret));
    mes_clear(&messages);
    reply_clear(&reply);
    //Remote reconnect
    if ((ret = cl_method(&connection->settings, BASE(dc), 2, &params, &messages)) != 0 ||
    var_clear(&params);
reply = GXReplyData()
dc = GXDLMSDisconnectControl()
self.readDataBlock(dc.remoteDisconnect(client), reply)
Frank G
4 years 9 months ago
Disconnect Control /Control Mode in Python
is there an example how to read and write the control mode using python?
Many Thanks
Frank
You can read it in the normal way. Create Disconnect Control object and read attribute index #4.
Frank G
reading is working, thank you!.
I am having problems with writing. I dont know where to put the value to be written.
My code:
rele = GXDLMSDisconnectControl ("0.0.96.3.10.255");
#####Read#####
lector.read(rele, 4)
print(rele.controlMode)
#####Write######
lector.write(rele, 4)
Many Thnaks
Frank
You need to update value for the Disconnect control object.
rele.controlMode = YOUR_VALUE
Make sure that you have enough access rights to write the objects.
alnardn
3 years ago
Hello! I also need to change…
Hello! I also need to change disconnect control mode, but i don't understand what is lector? What is this?
Frank G
it is working now
it is working now
Many Thanks
Frank
Kumaresh
1 year 2 months ago
Change Control Mode
Hi Kurmi ji,
below is my code and i want to update the Control Mode to Mode6 how can I. pls guide me!!!
def Re_Connect(self):
dc=GXDLMSDisconnectControl("0.0.96.3.10.255")
data=dc.remoteDisconnect(self.client)
print("Load Relay Reconnect")
time.sleep(10)
dc.getValues()
time.sleep(10)
dc.setValue()
time.sleep(10)
time.sleep(10)
dc.getValues()
time.sleep(10)
data=dc.remoteReconnect(self.client)
dc.getValues()
self.writeTrace(dc)
print(dc)
Book navigation
  • Activity calendar
  • Association Logical Name
  • Auto Connect
  • Auto answer
  • Clock
  • Compact data
  • Data
  • Demand register
  • Disconnect control
  • Extended register
  • GPRS modem setup
  • GSM diagnostic
  • IEC HDLC setup
  • IEC local port setup
  • IPv4 setup
  • IPv6 setup
  • Image transfer
  • Limiter
  • M-Bus Client
  • M-Bus master port setup
  • M-Bus slave port setup
  • MAC address setup
  • Modem configuration
  • PPP setup
  • Profile generic
  • Push Setup
  • Register
  • Register Monitor
  • Register activation
  • Register table
  • SAP assignment
  • Script table
  • Security setup
  • Single action schedule
  • Special days table
  • Status mapping
  • Tcp Udp Setup
  • Utility tables
  • Manufacturer custom objects
